CCSv5.1.0.07001 Does Not Open DSP/BIOS .tcf file
Guru 15580 points
Gents,
My CCSv5.1 no longer opens my DSP/BIOS .tcf file for editing since I attempted to reconfigure the default file associations in preferences (Windows->Preferences->General->Editors->File Associations) . I need a workaround asap. Your help would be much appreciated.
  • Hi Mike,
    There is a known issue with opening some files from the Project Explorer. It is resolved in M8. One workaround is you can open it by directly calling gconf on the file (<INSTALL DIR>\bios_5_41_10_36\packages\ti\bios\config\gconf\bin\gconf.exe). You will need to provide the xdcroot and path to the platform files. If I think of a better workaround, i'll let you know.
    ki
  • Ki,
    Unfortunately doing this has confused CCS. It now appears to find two copies of the .cfg file and reports the following errors.
    Description Resource Path Location Type
    CACHE_L1D memory range has already been specified DSP_CELT C/C++ Problem
    CACHE_L1D memory range overlaps existing memory range CACHE_L1D DSP_CELT C/C++ Problem
    CACHE_L1P memory range has already been specified DSP_CELT C/C++ Problem
    CACHE_L1P memory range overlaps existing memory range CACHE_L1P DSP_CELT C/C++ Problem
    CACHE_L2 memory range has already been specified DSP_CELT C/C++ Problem
    CACHE_L2 memory range overlaps existing memory range CACHE_L2 DSP_CELT C/C++ Problem
    DDR memory range has already been specified DSP_CELT C/C++ Problem
    DDR memory range overlaps existing memory range DDR DSP_CELT C/C++ Problem
    DSP_SHARED_RAM memory range has already been specified DSP_CELT C/C++ Problem
    DSP_SHARED_RAM memory range overlaps existing memory range DSP_SHARED_RAM DSP_CELT C/C++ Problem
    errors encountered during linking; "DSP_CELT.out" not built DSP_CELT C/C++ Problem
    IRAM memory range has already been specified DSP_CELT C/C++ Problem
    IRAM memory range overlaps existing memory range IRAM DSP_CELT C/C++ Problem
    Vectors memory range has already been specified DSP_CELT C/C++ Problem
    Vectors memory range overlaps existing memory range Vectors DSP_CELT C/C++ Problem
    Can you help me get rid of these errors?
  • Ki...this is urgent....I'm dead in the water with these errors.
       redefined
    "../DSP_CELTcfg.cmd", line 52: warning: absolute symbol "SYS_ABORTFXN" being
       redefined
    "../DSP_CELTcfg.cmd", line 54: warning: absolute symbol "SYS_ERRORFXN" being
       redefined
    "../DSP_CELTcfg.cmd", line 56: warning: absolute symbol "SYS_EXITFXN" being
       redefined
    "../DSP_CELTcfg.cmd", line 58: warning: absolute symbol "SYS_PUTCFXN" being
       redefined
    "../DSP_CELTcfg.cmd", line 61: warning: absolute symbol "GIO_CREATEFXN" being
       redefined
    "../DSP_CELTcfg.cmd", line 63: warning: absolute symbol "GIO_DELETEFXN" being
       redefined
    "../DSP_CELTcfg.cmd", line 65: warning: absolute symbol "GIO_PENDFXN" being
       redefined
    "../DSP_CELTcfg.cmd", line 67: warning: absolute symbol "GIO_POSTFXN" being
       redefined
    "../DSP_CELTcfg.cmd", line 70: warning: absolute symbol "PWRM_PWRM_SLOTHOOKFXN"
       being redefined
    "../DSP_CELTcfg.cmd", line 72: warning: absolute symbol
       "PWRM_PWRM_SHAREDRESOURCEFXN" being redefined
    "../DSP_CELTcfg.cmd", line 75: warning: absolute symbol "_CACHE_L2" being
       redefined
    "../DSP_CELTcfg.cmd", line 76: warning: absolute symbol "_CACHE_L1P" being
       redefined
    "../DSP_CELTcfg.cmd", line 77: warning: absolute symbol "_CACHE_L1D" being
       redefined
    "../DSP_CELTcfg.cmd", line 78: warning: absolute symbol "_DDR" being redefined
    "../DSP_CELTcfg.cmd", line 79: warning: absolute symbol "_IRAM" being
       redefined
    "../DSP_CELTcfg.cmd", line 80: warning: absolute symbol "_Vectors" being
       redefined
    "../DSP_CELTcfg.cmd", line 81: warning: absolute symbol "_DSP_SHARED_RAM" being
       redefined
    "../DSP_CELTcfg.cmd", line 82: warning: absolute symbol "_PRD_clock" being
       redefined
    "../DSP_CELTcfg.cmd", line 83: warning: absolute symbol "_SWMonitorPRD" being
       redefined
    "../DSP_CELTcfg.cmd", line 84: warning: absolute symbol "_PRD_frameSearch"
       being redefined
    "../DSP_CELTcfg.cmd", line 85: warning: absolute symbol "_PRD_led_flash" being
       redefined
    "../DSP_CELTcfg.cmd", line 86: warning: absolute symbol "_RTA_fromHost" being
       redefined
    "../DSP_CELTcfg.cmd", line 87: warning: absolute symbol "_RTA_toHost" being
       redefined
    "../DSP_CELTcfg.cmd", line 88: warning: absolute symbol "_HWI_RESET" being
       redefined
    "../DSP_CELTcfg.cmd", line 89: warning: absolute symbol "_HWI_NMI" being
       redefined
    "../DSP_CELTcfg.cmd", line 90: warning: absolute symbol "_HWI_RESERVED0" being
       redefined
    "../DSP_CELTcfg.cmd", line 91: warning: absolute symbol "_HWI_RESERVED1" being
       redefined
    "../DSP_CELTcfg.cmd", line 92: warning: absolute symbol "_HWI_INT4" being
       redefined
    "../DSP_CELTcfg.cmd", line 93: warning: absolute symbol "_HWI_INT5" being
       redefined
    "../DSP_CELTcfg.cmd", line 94: warning: absolute symbol "_HWI_INT6" being
       redefined
    "../DSP_CELTcfg.cmd", line 95: warning: absolute symbol "_HWI_INT7" being
       redefined
    "../DSP_CELTcfg.cmd", line 96: warning: absolute symbol "_HWI_INT8" being
       redefined
    "../DSP_CELTcfg.cmd", line 97: warning: absolute symbol "_HWI_INT9" being
       redefined
    "../DSP_CELTcfg.cmd", line 98: warning: absolute symbol "_HWI_INT10" being
       redefined
    "../DSP_CELTcfg.cmd", line 99: warning: absolute symbol "_HWI_INT11" being
       redefined
    "../DSP_CELTcfg.cmd", line 100: warning: absolute symbol "_HWI_INT12" being
       redefined
    "../DSP_CELTcfg.cmd", line 101: warning: absolute symbol "_HWI_INT13" being
       redefined
    "../DSP_CELTcfg.cmd", line 102: warning: absolute symbol "_HWI_INT14" being
       redefined
    "../DSP_CELTcfg.cmd", line 103: warning: absolute symbol "_HWI_INT15" being
       redefined
    "../DSP_CELTcfg.cmd", line 104: warning: absolute symbol "_EVENT4" being
       redefined
    "../DSP_CELTcfg.cmd", line 105: warning: absolute symbol "_EVENT5" being
       redefined
    "../DSP_CELTcfg.cmd", line 106: warning: absolute symbol "_EVENT6" being
       redefined
    "../DSP_CELTcfg.cmd", line 107: warning: absolute symbol "_EVENT7" being
       redefined
    "../DSP_CELTcfg.cmd", line 108: warning: absolute symbol "_EVENT8" being
       redefined
    "../DSP_CELTcfg.cmd", line 109: warning: absolute symbol "_EVENT9" being
       redefined
    "../DSP_CELTcfg.cmd", line 110: warning: absolute symbol "_EVENT10" being
       redefined
    "../DSP_CELTcfg.cmd", line 111: warning: absolute symbol "_EVENT11" being
       redefined
    "../DSP_CELTcfg.cmd", line 112: warning: absolute symbol "_EVENT12" being
       redefined
    "../DSP_CELTcfg.cmd", line 113: warning: absolute symbol "_EVENT13" being
       redefined
    "../DSP_CELTcfg.cmd", line 114: warning: absolute symbol "_EVENT14" being
       redefined
    "../DSP_CELTcfg.cmd", line 115: warning: absolute symbol "_EVENT15" being
       redefined
    "../DSP_CELTcfg.cmd", line 116: warning: absolute symbol "_EVENT16" being
       redefined
    "../DSP_CELTcfg.cmd", line 117: warning: absolute symbol "_EVENT17" being
       redefined
    "../DSP_CELTcfg.cmd", line 118: warning: absolute symbol "_EVENT18" being
       redefined
    "../DSP_CELTcfg.cmd", line 119: warning: absolute symbol "_EVENT19" being
       redefined
    "../DSP_CELTcfg.cmd", line 120: warning: absolute symbol "_EVENT20" being
       redefined
    "../DSP_CELTcfg.cmd", line 121: warning: absolute symbol "_EVENT21" being
       redefined
    "../DSP_CELTcfg.cmd", line 122: warning: absolute symbol "_EVENT22" being
       redefined
    "../DSP_CELTcfg.cmd", line 123: warning: absolute symbol "_EVENT23" being
       redefined
    "../DSP_CELTcfg.cmd", line 124: warning: absolute symbol "_EVENT24" being
       redefined
    "../DSP_CELTcfg.cmd", line 125: warning: absolute symbol "_EVENT25" being
       redefined
    "../DSP_CELTcfg.cmd", line 126: warning: absolute symbol "_EVENT26" being
       redefined
    "../DSP_CELTcfg.cmd", line 127: warning: absolute symbol "_EVENT27" being
       redefined
    "../DSP_CELTcfg.cmd", line 128: warning: absolute symbol "_EVENT28" being
       redefined
    "../DSP_CELTcfg.cmd", line 129: warning: absolute symbol "_EVENT29" being
       redefined
    "../DSP_CELTcfg.cmd", line 130: warning: absolute symbol "_EVENT30" being
       redefined
    "../DSP_CELTcfg.cmd", line 131: warning: absolute symbol "_EVENT31" being
       redefined
    "../DSP_CELTcfg.cmd", line 132: warning: absolute symbol "_EVENT32" being
       redefined
    "../DSP_CELTcfg.cmd", line 133: warning: absolute symbol "_EVENT33" being
       redefined
    "../DSP_CELTcfg.cmd", line 134: warning: absolute symbol "_EVENT34" being
       redefined
    "../DSP_CELTcfg.cmd", line 135: warning: absolute symbol "_EVENT35" being
       redefined
    "../DSP_CELTcfg.cmd", line 136: warning: absolute symbol "_EVENT36" being
       redefined
    "../DSP_CELTcfg.cmd", line 137: warning: absolute symbol "_EVENT37" being
       redefined
    "../DSP_CELTcfg.cmd", line 138: warning: absolute symbol "_EVENT38" being
       redefined
    "../DSP_CELTcfg.cmd", line 139: warning: absolute symbol "_EVENT39" being
       redefined
    "../DSP_CELTcfg.cmd", line 140: warning: absolute symbol "_EVENT40" being
       redefined
    "../DSP_CELTcfg.cmd", line 141: warning: absolute symbol "_EVENT41" being
       redefined
    "../DSP_CELTcfg.cmd", line 142: warning: absolute symbol "_EVENT42" being
       redefined
    "../DSP_CELTcfg.cmd", line 143: warning: absolute symbol "_EVENT43" being
       redefined
    "../DSP_CELTcfg.cmd", line 144: warning: absolute symbol "_EVENT44" being
       redefined
    "../DSP_CELTcfg.cmd", line 145: warning: absolute symbol "_EVENT45" being
       redefined
    "../DSP_CELTcfg.cmd", line 146: warning: absolute symbol "_EVENT46" being
       redefined
    "../DSP_CELTcfg.cmd", line 147: warning: absolute symbol "_EVENT47" being
       redefined
    "../DSP_CELTcfg.cmd", line 148: warning: absolute symbol "_EVENT48" being
       redefined
    "../DSP_CELTcfg.cmd", line 149: warning: absolute symbol "_EVENT49" being
       redefined
    "../DSP_CELTcfg.cmd", line 150: warning: absolute symbol "_EVENT50" being
       redefined
    "../DSP_CELTcfg.cmd", line 151: warning: absolute symbol "_EVENT51" being
       redefined
    "../DSP_CELTcfg.cmd", line 152: warning: absolute symbol "_EVENT52" being
       redefined
    "../DSP_CELTcfg.cmd", line 153: warning: absolute symbol "_EVENT53" being
       redefined
    "../DSP_CELTcfg.cmd", line 154: warning: absolute symbol "_EVENT54" being
       redefined
    "../DSP_CELTcfg.cmd", line 155: warning: absolute symbol "_EVENT55" being
       redefined
    "../DSP_CELTcfg.cmd", line 156: warning: absolute symbol "_EVENT56" being
       redefined
    "../DSP_CELTcfg.cmd", line 157: warning: absolute symbol "_EVENT57" being
       redefined
    "../DSP_CELTcfg.cmd", line 158: warning: absolute symbol "_EVENT58" being
       redefined
    "../DSP_CELTcfg.cmd", line 159: warning: absolute symbol "_EVENT59" being
       redefined
    "../DSP_CELTcfg.cmd", line 160: warning: absolute symbol "_EVENT60" being
       redefined
    "../DSP_CELTcfg.cmd", line 161: warning: absolute symbol "_EVENT61" being
       redefined
    "../DSP_CELTcfg.cmd", line 162: warning: absolute symbol "_EVENT62" being
       redefined
    "../DSP_CELTcfg.cmd", line 163: warning: absolute symbol "_EVENT63" being
       redefined
    "../DSP_CELTcfg.cmd", line 164: warning: absolute symbol "_EVENT64" being
       redefined
    "../DSP_CELTcfg.cmd", line 165: warning: absolute symbol "_EVENT65" being
       redefined
    "../DSP_CELTcfg.cmd", line 166: warning: absolute symbol "_EVENT66" being
       redefined
    "../DSP_CELTcfg.cmd", line 167: warning: absolute symbol "_EVENT67" being
       redefined
    "../DSP_CELTcfg.cmd", line 168: warning: absolute symbol "_EVENT68" being
       redefined
    "../DSP_CELTcfg.cmd", line 169: warning: absolute symbol "_EVENT69" being
       redefined
    "../DSP_CELTcfg.cmd", line 170: warning: absolute symbol "_EVENT70" being
       redefined
    "../DSP_CELTcfg.cmd", line 171: warning: absolute symbol "_EVENT71" being
       redefined
    "../DSP_CELTcfg.cmd", line 172: warning: absolute symbol "_EVENT72" being
       redefined
    "../DSP_CELTcfg.cmd", line 173: warning: absolute symbol "_EVENT73" being
       redefined
    "../DSP_CELTcfg.cmd", line 174: warning: absolute symbol "_EVENT74" being
       redefined
    "../DSP_CELTcfg.cmd", line 175: warning: absolute symbol "_EVENT75" being
       redefined
    "../DSP_CELTcfg.cmd", line 176: warning: absolute symbol "_EVENT76" being
       redefined
    "../DSP_CELTcfg.cmd", line 177: warning: absolute symbol "_EVENT77" being
       redefined
    "../DSP_CELTcfg.cmd", line 178: warning: absolute symbol "_EVENT78" being
       redefined
    "../DSP_CELTcfg.cmd", line 179: warning: absolute symbol "_EVENT79" being
       redefined
    "../DSP_CELTcfg.cmd", line 180: warning: absolute symbol "_EVENT80" being
       redefined
    "../DSP_CELTcfg.cmd", line 181: warning: absolute symbol "_EVENT81" being
       redefined
    "../DSP_CELTcfg.cmd", line 182: warning: absolute symbol "_EVENT82" being
       redefined
    "../DSP_CELTcfg.cmd", line 183: warning: absolute symbol "_EVENT83" being
       redefined
    "../DSP_CELTcfg.cmd", line 184: warning: absolute symbol "_EVENT84" being
       redefined
    "../DSP_CELTcfg.cmd", line 185: warning: absolute symbol "_EVENT85" being
       redefined
    "../DSP_CELTcfg.cmd", line 186: warning: absolute symbol "_EVENT86" being
       redefined
    "../DSP_CELTcfg.cmd", line 187: warning: absolute symbol "_EVENT87" being
       redefined
    "../DSP_CELTcfg.cmd", line 188: warning: absolute symbol "_EVENT88" being
       redefined
    "../DSP_CELTcfg.cmd", line 189: warning: absolute symbol "_EVENT89" being
       redefined
    "../DSP_CELTcfg.cmd", line 190: warning: absolute symbol "_EVENT90" being
       redefined
    "../DSP_CELTcfg.cmd", line 191: warning: absolute symbol "_EVENT91" being
       redefined
    "../DSP_CELTcfg.cmd", line 192: warning: absolute symbol "_EVENT92" being
       redefined
    "../DSP_CELTcfg.cmd", line 193: warning: absolute symbol "_EVENT93" being
       redefined
    "../DSP_CELTcfg.cmd", line 194: warning: absolute symbol "_EVENT94" being
       redefined
    "../DSP_CELTcfg.cmd", line 195: warning: absolute symbol "_EVENT95" being
       redefined
    "../DSP_CELTcfg.cmd", line 196: warning: absolute symbol "_EVENT96" being
       redefined
    "../DSP_CELTcfg.cmd", line 197: warning: absolute symbol "_EVENT97" being
       redefined
    "../DSP_CELTcfg.cmd", line 198: warning: absolute symbol "_EVENT98" being
       redefined
    "../DSP_CELTcfg.cmd", line 199: warning: absolute symbol "_EVENT99" being
       redefined
    "../DSP_CELTcfg.cmd", line 200: warning: absolute symbol "_EVENT100" being
       redefined
    "../DSP_CELTcfg.cmd", line 201: warning: absolute symbol "_EVENT101" being
       redefined
    "../DSP_CELTcfg.cmd", line 202: warning: absolute symbol "_EVENT102" being
       redefined
    "../DSP_CELTcfg.cmd", line 203: warning: absolute symbol "_EVENT103" being
       redefined
    "../DSP_CELTcfg.cmd", line 204: warning: absolute symbol "_EVENT104" being
       redefined
    "../DSP_CELTcfg.cmd", line 205: warning: absolute symbol "_EVENT105" being
       redefined
    "../DSP_CELTcfg.cmd", line 206: warning: absolute symbol "_EVENT106" being
       redefined
    "../DSP_CELTcfg.cmd", line 207: warning: absolute symbol "_EVENT107" being
       redefined
    "../DSP_CELTcfg.cmd", line 208: warning: absolute symbol "_EVENT108" being
       redefined
    "../DSP_CELTcfg.cmd", line 209: warning: absolute symbol "_EVENT109" being
       redefined
    "../DSP_CELTcfg.cmd", line 210: warning: absolute symbol "_EVENT110" being
       redefined
    "../DSP_CELTcfg.cmd", line 211: warning: absolute symbol "_EVENT111" being
       redefined
    "../DSP_CELTcfg.cmd", line 212: warning: absolute symbol "_EVENT112" being
       redefined
    "../DSP_CELTcfg.cmd", line 213: warning: absolute symbol "_EVENT113" being
       redefined
    "../DSP_CELTcfg.cmd", line 214: warning: absolute symbol "_EVENT114" being
       redefined
    "../DSP_CELTcfg.cmd", line 215: warning: absolute symbol "_EVENT115" being
       redefined
    "../DSP_CELTcfg.cmd", line 216: warning: absolute symbol "_EVENT116" being
       redefined
    "../DSP_CELTcfg.cmd", line 217: warning: absolute symbol "_EVENT117" being
       redefined
    "../DSP_CELTcfg.cmd", line 218: warning: absolute symbol "_EVENT118" being
       redefined
    "../DSP_CELTcfg.cmd", line 219: warning: absolute symbol "_EVENT119" being
       redefined
    "../DSP_CELTcfg.cmd", line 220: warning: absolute symbol "_EVENT120" being
       redefined
    "../DSP_CELTcfg.cmd", line 221: warning: absolute symbol "_EVENT121" being
       redefined
    "../DSP_CELTcfg.cmd", line 222: warning: absolute symbol "_EVENT122" being
       redefined
    "../DSP_CELTcfg.cmd", line 223: warning: absolute symbol "_EVENT123" being
       redefined
    "../DSP_CELTcfg.cmd", line 224: warning: absolute symbol "_EVENT124" being
       redefined
    "../DSP_CELTcfg.cmd", line 225: warning: absolute symbol "_EVENT125" being
       redefined
    "../DSP_CELTcfg.cmd", line 226: warning: absolute symbol "_EVENT126" being
       redefined
    "../DSP_CELTcfg.cmd", line 227: warning: absolute symbol "_EVENT127" being
       redefined
    "../DSP_CELTcfg.cmd", line 228: warning: absolute symbol "_PRD_swi" being
       redefined
    "../DSP_CELTcfg.cmd", line 229: warning: absolute symbol "_KNL_swi" being
       redefined
    "../DSP_CELTcfg.cmd", line 230: warning: absolute symbol
       "_SWI_processReceivedPacket" being redefined
    "../DSP_CELTcfg.cmd", line 231: warning: absolute symbol "_SWI_SendPacket"
       being redefined
    "../DSP_CELTcfg.cmd", line 232: warning: absolute symbol "_SWI_BurstTimeout"
       being redefined
    "../DSP_CELTcfg.cmd", line 233: warning: absolute symbol "_TSK_SlaveSequence"
       being redefined
    "../DSP_CELTcfg.cmd", line 234: warning: absolute symbol "_TSK_MasterSequence"
       being redefined
    "../DSP_CELTcfg.cmd", line 235: warning: absolute symbol "_TSK_idle" being
       redefined
    "../DSP_CELTcfg.cmd", line 236: warning: absolute symbol "_TSK_SWMonitor" being
       redefined
    "../DSP_CELTcfg.cmd", line 237: warning: absolute symbol "_TSK_mac_frame_init"
       being redefined
    "../DSP_CELTcfg.cmd", line 238: warning: absolute symbol "_TSK_LEDFlash" being
       redefined
    "../DSP_CELTcfg.cmd", line 239: warning: absolute symbol "_IDL_cpuLoad" being
       redefined
    "../DSP_CELTcfg.cmd", line 240: warning: absolute symbol "_LNK_dataPump" being
       redefined
    "../DSP_CELTcfg.cmd", line 241: warning: absolute symbol "_RTA_dispatcher"
       being redefined
    "../DSP_CELTcfg.cmd", line 242: warning: absolute symbol "_LOG_system" being
       redefined
    "../DSP_CELTcfg.cmd", line 243: warning: absolute symbol "_trace" being
       redefined
    "../DSP_CELTcfg.cmd", line 244: warning: absolute symbol "_trace2" being
       redefined
    "../DSP_CELTcfg.cmd", line 245: warning: absolute symbol "_OsSem" being
       redefined
    "../DSP_CELTcfg.cmd", line 246: warning: absolute symbol "_rcvBuffReady" being
       redefined
    "../DSP_CELTcfg.cmd", line 247: warning: absolute symbol "_xmtBuffReady" being
       redefined
    "../DSP_CELTcfg.cmd", line 248: warning: absolute symbol "_SWMonitorSem" being
       redefined
    "../DSP_CELTcfg.cmd", line 249: warning: absolute symbol "_SPIBUF_ready" being
       redefined
    "../DSP_CELTcfg.cmd", line 250: warning: absolute symbol "_SPIDAT1_ready" being
       redefined
    "../DSP_CELTcfg.cmd", line 251: warning: absolute symbol "_SEM_spi_rxempty"
       being redefined
    "../DSP_CELTcfg.cmd", line 252: warning: absolute symbol "_SEM_spi_pass" being
       redefined
    "../DSP_CELTcfg.cmd", line 253: warning: absolute symbol
       "_SEM_frame_search_timeout" being redefined
    "../DSP_CELTcfg.cmd", line 254: warning: absolute symbol
       "_SEM_processMasterFrame" being redefined
    "../DSP_CELTcfg.cmd", line 255: warning: absolute symbol
       "_SEM_processSlaveFrame" being redefined
    "../DSP_CELTcfg.cmd", line 256: warning: absolute symbol "_SEM_led_flash" being
       redefined
    "../DSP_CELTcfg.cmd", line 257: warning: absolute symbol "_IDL_busyObj" being
       redefined
    "../DSP_CELTcfg.cmd", line 258: warning: absolute symbol "_STS_celt_encode"
       being redefined
    "../DSP_CELTcfg.cmd", line 259: warning: absolute symbol "_STS_celt_decode"
       being redefined
    "../DSP_CELTcfg.cmd", line 260: warning: absolute symbol "_STS_sample_period"
       being redefined
    "../DSP_CELTcfg.cmd", line 261: warning: absolute symbol "_STS_memcopy" being
       redefined
    "../DSP_CELTcfg.cmd", line 283: warning: absolute symbol "_GBL_CACHE" being
       redefined
    "../DSP_CELTcfg.cmd", line 284: warning: absolute symbol "_BCACHE_bootInit"
       being redefined
    "../DSP_CELTcfg.cmd", line 303: warning: absolute symbol "_CLK_PRD" being
       redefined
    "../DSP_CELTcfg.cmd", line 304: warning: absolute symbol "_CLK_COUNTSPMS" being
       redefined
    "../DSP_CELTcfg.cmd", line 305: warning: absolute symbol "_CLK_REGS" being
       redefined
    "../DSP_CELTcfg.cmd", line 306: warning: absolute symbol "_CLK_USETIMER" being
       redefined
    "../DSP_CELTcfg.cmd", line 307: warning: absolute symbol "_CLK_TIMERNUM" being
       redefined
    "../DSP_CELTcfg.cmd", line 308: warning: absolute symbol "_CLK_TDDR" being
       redefined
    "../DSP_CELTcfg.cmd", line 321: warning: absolute symbol
       "_LNK_dspFrameReadyMask" being redefined
    "../DSP_CELTcfg.cmd", line 322: warning: absolute symbol
       "_LNK_dspFrameRequestMask" being redefined
    "../DSP_CELTcfg.cmd", line 323: warning: absolute symbol "_LNK_readDone" being
       redefined
    "../DSP_CELTcfg.cmd", line 324: warning: absolute symbol "_LNK_readFail" being
       redefined
    "../DSP_CELTcfg.cmd", line 325: warning: absolute symbol "_LNK_readPend" being
       redefined
    "../DSP_CELTcfg.cmd", line 326: warning: absolute symbol "_LNK_writeFail" being
       redefined
    "../DSP_CELTcfg.cmd", line 332: warning: absolute symbol "_HWI_CFGDISPATCHED"
       being redefined
    "../DSP_CELTcfg.cmd", line 301: warning: absolute symbol "CLK_A_TABBEG" being
       redefined
    "../DSP_CELTcfg.cmd", line 312: warning: absolute symbol "PRD_A_TABBEG" being
       redefined
    "../DSP_CELTcfg.cmd", line 312: warning: absolute symbol "PRD_A_TABEND" being
       redefined
    "../DSP_CELTcfg.cmd", line 336: warning: absolute symbol "SWI_A_TABBEG" being
       redefined
    "../DSP_CELTcfg.cmd", line 336: warning: absolute symbol "SWI_A_TABEND" being
       redefined
    "../DSP_CELTcfg.cmd", line 352: warning: absolute symbol "IDL_A_TABBEG" being
       redefined
    "../DSP_CELTcfg.cmd", line 356: warning: absolute symbol "IDL_A_CALBEG" being
       redefined
    "../DSP_CELTcfg.cmd", line 368: warning: absolute symbol "HWI_A_VECS" being
       redefined
    "../DSP_CELTcfg.cmd", line 415: warning: absolute symbol "GBL_stackbeg" being
       redefined
    "../DSP_CELTcfg.cmd", line 417: warning: absolute symbol "GBL_stackend" being
       redefined
    "../DSP_CELTcfg.cmd", line 418: warning: absolute symbol "_HWI_STKBOTTOM" being
       redefined
    "../DSP_CELTcfg.cmd", line 419: warning: absolute symbol "_HWI_STKTOP" being
       redefined
    "../DSP_CELTcfg.cmd", line 424: warning: absolute symbol "DDR$B" being
       redefined
    "../DSP_CELTcfg.cmd", line 424: warning: absolute symbol "_DDR_base" being
       redefined
    "../DSP_CELTcfg.cmd", line 424: warning: absolute symbol "DDR$L" being
       redefined
    "../DSP_CELTcfg.cmd", line 424: warning: absolute symbol "_DDR_length" being
       redefined
    "../DSP_CELTcfg.cmd", line 478: warning: absolute symbol "_SYS_PUTCBEG" being
    >> Compilation failure
       redefined
    "../DSP_CELTcfg.cmd", line 480: warning: absolute symbol "_SYS_PUTCEND" being
       redefined
    "../DSP_CELTcfg.cmd", line 483: warning: absolute symbol "HST_A_TABBEG" being
       redefined
    "../DSP_CELTcfg.cmd", line 483: warning: absolute symbol "_HST_A_TABBEG" being
       redefined
    "../DSP_CELTcfg.cmd", line 483: warning: absolute symbol "HST_A_TABEND" being
       redefined
    "../DSP_CELTcfg.cmd", line 483: warning: absolute symbol "_HST_A_TABEND" being
       redefined
    "../DSP_CELTcfg.cmd", line 486: warning: absolute symbol "LOG_A_TABBEG" being
       redefined
    "../DSP_CELTcfg.cmd", line 486: warning: absolute symbol "_LOG_A_TABBEG" being
       redefined
    "../DSP_CELTcfg.cmd", line 486: warning: absolute symbol "LOG_A_TABEND" being
       redefined
    "../DSP_CELTcfg.cmd", line 486: warning: absolute symbol "_LOG_A_TABEND" being
       redefined
    "../DSP_CELTcfg.cmd", line 489: warning: absolute symbol "PIP_A_TABBEG" being
       redefined
    "../DSP_CELTcfg.cmd", line 489: warning: absolute symbol "_PIP_A_TABBEG" being
       redefined
    "../DSP_CELTcfg.cmd", line 489: warning: absolute symbol "PIP_A_TABEND" being
       redefined
    "../DSP_CELTcfg.cmd", line 489: warning: absolute symbol "_PIP_A_TABEND" being
       redefined
    "../DSP_CELTcfg.cmd", line 492: warning: absolute symbol "STS_A_TABBEG" being
       redefined
    "../DSP_CELTcfg.cmd", line 492: warning: absolute symbol "_STS_A_TABBEG" being
       redefined
    "../DSP_CELTcfg.cmd", line 492: warning: absolute symbol "STS_A_TABEND" being
       redefined
    "../DSP_CELTcfg.cmd", line 492: warning: absolute symbol "_STS_A_TABEND" being
       redefined
    error: errors encountered during linking; "DSP_CELT.out" not built
    gmake: *** [DSP_CELT.out] Error 1
    gmake: Target `all' not remade because of errors.
    **** Build Finished ****
  • Hi Mike,
    You probably have multiple tcf files in the project, caused by when you called gconf manually. You can try excluding the older one.
    Anyway, I've escalated your original issue for a better workaround and hope to have an answer for you soon.
    ki
  • Hi Mike,
    Try opening from the Navigator view (Window->Show View->Navigator). This seems to work.
    ki
  • Ki,
    There is only one .tcf file in my project root directory. However, in my .gconf directory I have the following files:
    I'm afraid to mess with these too much based on what just happened. But it appears to me that the two TMPtcfXXX.cdb files may be the problem. Please let me know what you find asap. Not the same file times on both.
    Yes try deleting the two cdb files and the associated tcf files (If you have problems deleting them, then some other process has them locked and you have to kill those or you can reboot) open the original tcf file from the navigator view.
  • Ki,
    I deleted the xxxcmd.cfg file and all is well now.
    I am able to open my .tcf file from the Navigator. Thanks!
  • Mike,
    To get things to work from the Project Explorer (not just *.tcf but other files like *.map, *.mk, etc), try the following:
    Under "Window->Preferences->General->Capabilities" enable the “Java development” and “PDE Tools” options.
    ki
  • Ki,
    I'm managed to get it working with a combination of your suggestion and re-doing the file associations. Hope this becomes a bit more reliable in M9.
  • Hello  Ki-Soo Lee
    I have faced  with the same problem and I found two tcf files in my project. when I delete one of them, I solved the problem.
    Thank you very much!
