Part Number: CODECOMPOSER
Other Parts Discussed in Thread: MSPM0L1306
I am trying to integrate a ADC with the MSPM0L1306 LP. Initially, I would like to test the connection with reading the status register, but I am stuck with this error: 10234-D, and not sure where I am going wrong. The codes and build message are copied here. Please help.
SPI_Try.c,
#include <ti/driverlib/m0p/dl_interrupt.h>
#include "ti/driverlib/dl_gpio.h"
#include "ti/driverlib/m0p/dl_core.h"
#include "ti_msp_dl_config.h"
#include <ADS131M08.h>
/* This results in approximately 0.5s of delay assuming 32MHz CPU_CLK */
#define DELAY_500 (16000000)
/* This results in approximately 125 ms of delay assuming 32MHz CPU_CLK */
#define DELAY_125 (4000000)
// Internal variables
// Array used to recall device register map configurations */
static uint16_t registerMap[NUM_REGISTERS];
static uint16_t Register_Value;
// Array of SPI word lengths
const static uint8_t wlength_byte_values[] = {2, 3, 4, 4};
uint8_t numberOfBytes;
// Internal function prototypes
uint8_t buildSPIarray(const uint16_t opcodeArray[], uint8_t numberOpcodes, uint8_t byteArray[]);
uint16_t enforce_selected_device_modes(uint16_t data);
uint8_t getWordByteLength(void);
int main(void)
SYSCFG_DL_init();
delay_cycles(DELAY_500);
resetDevice();
restoreRegisterDefaults();
Register_Value = readSingleRegister(0x01);
while (1) {
void resetDevice()
DL_GPIO_clearPins(GPIO_PORT, GPIO_RESET_PIN);
delay_cycles(DELAY_125);
DL_GPIO_setPins(GPIO_PORT, GPIO_RESET_PIN);
delay_cycles(DELAY_125/10);
uint16_t readSingleRegister(uint8_t address)
/* Check that the register address is in range */
assert(address < NUM_REGISTERS);
// Build TX and RX byte array
#ifdef ENABLE_CRC_IN
uint8_t dataTx[8] = { 0 }; // 2 words, up to 4 bytes each = 8 bytes maximum
uint8_t dataRx[8] = { 0 };
#else
uint8_t dataTx[4] = { 0 }; // 1 word, up to 4 bytes long = 4 bytes maximum
uint8_t dataRx[4] = { 0 };
#endif
uint16_t opcode = OPCODE_RREG | (((uint16_t) address) << 7);
numberOfBytes = buildSPIarray(&opcode, 1, dataTx);
return numberOfBytes;
* Frame size = opcode word(s) + optional CRC word
* Number of bytes per word = 2, 3, or 4
* Total bytes = bytes per word * number of words
uint8_t numberWords = numberOpcodes + (SPI_CRC_ENABLED ? 1 : 0);
uint8_t bytesPerWord = getWordByteLength();
uint8_t numberOfBytes = numberWords * bytesPerWord;
int i;
for (i = 0; i < numberOpcodes; i++)
// NOTE: Be careful not to accidentally overflow the array here.
// The array and opcodes are defined in the calling function, so
// we are trusting that no mistakes were made in the calling function!
byteArray[(i*bytesPerWord) + 0] = upperByte(opcodeArray[i]);
byteArray[(i*bytesPerWord) + 1] = lowerByte(opcodeArray[i]);
// Calculate CRC and put it into TX array
uint16_t crcWord = calculateCRC(&byteArray[0], numberOfBytes, 0xFFFF);
byteArray[(i*bytesPerWord) + 0] = upperByte(crcWord);
byteArray[(i*bytesPerWord) + 1] = lowerByte(crcWord);
#endif
return wlength_byte_values[WLENGTH];
void restoreRegisterDefaults(void)
registerMap[ID_ADDRESS] = 0x00; /* NOTE: This a read-only register */
registerMap[STATUS_ADDRESS] = STATUS_DEFAULT;
registerMap[MODE_ADDRESS] = MODE_DEFAULT;
registerMap[CLOCK_ADDRESS] = CLOCK_DEFAULT;
registerMap[GAIN1_ADDRESS] = GAIN1_DEFAULT;
registerMap[GAIN2_ADDRESS] = GAIN2_DEFAULT;
registerMap[CFG_ADDRESS] = CFG_DEFAULT;
registerMap[THRSHLD_MSB_ADDRESS] = THRSHLD_MSB_DEFAULT;
registerMap[THRSHLD_LSB_ADDRESS] = THRSHLD_LSB_DEFAULT;
registerMap[CH0_CFG_ADDRESS] = CH0_CFG_DEFAULT;
registerMap[CH0_OCAL_MSB_ADDRESS] = CH0_OCAL_MSB_DEFAULT;
registerMap[CH0_OCAL_LSB_ADDRESS] = CH0_OCAL_LSB_DEFAULT;
registerMap[CH0_GCAL_MSB_ADDRESS] = CH0_GCAL_MSB_DEFAULT;
registerMap[CH0_GCAL_LSB_ADDRESS] = CH0_GCAL_LSB_DEFAULT;
#if (CHANNEL_COUNT > 1)
registerMap[CH1_CFG_ADDRESS] = CH1_CFG_DEFAULT;
registerMap[CH1_OCAL_MSB_ADDRESS] = CH1_OCAL_MSB_DEFAULT;
registerMap[CH1_OCAL_LSB_ADDRESS] = CH1_OCAL_LSB_DEFAULT;
registerMap[CH1_GCAL_MSB_ADDRESS] = CH1_GCAL_MSB_DEFAULT;
registerMap[CH1_GCAL_LSB_ADDRESS] = CH1_GCAL_LSB_DEFAULT;
#endif
#if (CHANNEL_COUNT > 2)
registerMap[CH2_CFG_ADDRESS] = CH2_CFG_DEFAULT;
registerMap[CH2_OCAL_MSB_ADDRESS] = CH2_OCAL_MSB_DEFAULT;
registerMap[CH2_OCAL_LSB_ADDRESS] = CH2_OCAL_LSB_DEFAULT;
registerMap[CH2_GCAL_MSB_ADDRESS] = CH2_GCAL_MSB_DEFAULT;
registerMap[CH2_GCAL_LSB_ADDRESS] = CH2_GCAL_LSB_DEFAULT;
#endif
#if (CHANNEL_COUNT > 3)
registerMap[CH3_CFG_ADDRESS] = CH3_CFG_DEFAULT;
registerMap[CH3_OCAL_MSB_ADDRESS] = CH3_OCAL_MSB_DEFAULT;
registerMap[CH3_OCAL_LSB_ADDRESS] = CH3_OCAL_LSB_DEFAULT;
registerMap[CH3_GCAL_MSB_ADDRESS] = CH3_GCAL_MSB_DEFAULT;
registerMap[CH3_GCAL_LSB_ADDRESS] = CH3_GCAL_LSB_DEFAULT;
#endif
#if (CHANNEL_COUNT > 4)
registerMap[CH4_CFG_ADDRESS] = CH4_CFG_DEFAULT;
registerMap[CH4_OCAL_MSB_ADDRESS] = CH4_OCAL_MSB_DEFAULT;
registerMap[CH4_OCAL_LSB_ADDRESS] = CH4_OCAL_LSB_DEFAULT;
registerMap[CH4_GCAL_MSB_ADDRESS] = CH4_GCAL_MSB_DEFAULT;
registerMap[CH4_GCAL_LSB_ADDRESS] = CH4_GCAL_LSB_DEFAULT;
#endif
#if (CHANNEL_COUNT > 5)
registerMap[CH5_CFG_ADDRESS] = CH5_CFG_DEFAULT;
registerMap[CH5_OCAL_MSB_ADDRESS] = CH5_OCAL_MSB_DEFAULT;
registerMap[CH5_OCAL_LSB_ADDRESS] = CH5_OCAL_LSB_DEFAULT;
registerMap[CH5_GCAL_MSB_ADDRESS] = CH5_GCAL_MSB_DEFAULT;
registerMap[CH5_GCAL_LSB_ADDRESS] = CH5_GCAL_LSB_DEFAULT;
#endif
#if (CHANNEL_COUNT > 6)
registerMap[CH6_CFG_ADDRESS] = CH6_CFG_DEFAULT;
registerMap[CH6_OCAL_MSB_ADDRESS] = CH6_OCAL_MSB_DEFAULT;
registerMap[CH6_OCAL_LSB_ADDRESS] = CH6_OCAL_LSB_DEFAULT;
registerMap[CH6_GCAL_MSB_ADDRESS] = CH6_GCAL_MSB_DEFAULT;
registerMap[CH6_GCAL_LSB_ADDRESS] = CH6_GCAL_LSB_DEFAULT;
#endif
#if (CHANNEL_COUNT > 7)
registerMap[CH7_CFG_ADDRESS] = CH7_CFG_DEFAULT;
registerMap[CH7_OCAL_MSB_ADDRESS] = CH7_OCAL_MSB_DEFAULT;
registerMap[CH7_OCAL_LSB_ADDRESS] = CH7_OCAL_LSB_DEFAULT;
registerMap[CH7_GCAL_MSB_ADDRESS] = CH7_GCAL_MSB_DEFAULT;
registerMap[CH7_GCAL_LSB_ADDRESS] = CH7_GCAL_LSB_DEFAULT;
#endif
registerMap[REGMAP_CRC_ADDRESS] = REGMAP_CRC_DEFAULT;
ASD131M08.h,
#ifndef ADS131M0X_H_
#define ADS131M0X_H_
// Standard libraries
#include <assert.h>
#include <stdint.h>
#include <stdbool.h>
// Select the device variant to use...
#define CHANNEL_COUNT (8) // ADS131M08 -> 8 Channels
#if ((CHANNEL_COUNT < 1) || (CHANNEL_COUNT > 8))
#error Invalid channel count configured in 'ads131m0x.h'.
#endif
// Select the desired MODE register settings...
// NOTE: These settings will be enforced and not modifiable during runtime!
/* Pick one (and only one) mode to use... */
//#define WORD_LENGTH_16BIT_TRUNCATED
#define WORD_LENGTH_24BIT
//#define WORD_LENGTH_32BIT_SIGN_EXTEND
//#define WORD_LENGTH_32BIT_ZERO_PADDED
/* Enable this define statement to use the DRDY pulse format... */
#define DRDY_FMT_PULSE
/* Enable this define statement to use CRC on DIN... */
//#define ENABLE_CRC_IN
/* Select CRC type */
#define CRC_CCITT
//#define CRC_ANSI
/* Disable assertions when not in the CCS "Debug" configuration */
#ifndef _DEBUG
#define NDEBUG
#endif
// Validation
// Throw an error if no WORD_LENGTH mode was selected above
#if !defined WORD_LENGTH_16BIT_TRUNCATED && \
!defined WORD_LENGTH_24BIT && \
!defined WORD_LENGTH_32BIT_SIGN_EXTEND && \
!defined WORD_LENGTH_32BIT_ZERO_PADDED
#error Must define at least one WORD_LENGTH mode
#endif
// Throw an error if none or both CRC types are selected
#if !defined CRC_CCITT && !defined CRC_ANSI
#error Must define at least one CRC type
#endif
#if defined CRC_CCITT && defined CRC_ANSI
#error Must define only one CRC type
#endif
// Constants
#define NUM_REGISTERS ((uint8_t) 64)
// SPI command opcodes
#define OPCODE_NULL ((uint16_t) 0x0000)
#define OPCODE_RESET ((uint16_t) 0x0011)
#define OPCODE_RREG ((uint16_t) 0xA000)
#define OPCODE_WREG ((uint16_t) 0x6000)
#define OPCODE_STANDBY ((uint16_t) 0x0022)
#define OPCODE_WAKEUP ((uint16_t) 0x0033)
#define OPCODE_LOCK ((uint16_t) 0x0555)
#define OPCODE_UNLOCK ((uint16_t) 0x0655)
// Register definitions
/* NOTE: Whenever possible, macro names (defined below) were derived from
* datasheet defined names; however, updates to documentation may cause
* mismatches between names defined here in example code from those shown
* in the device datasheet.
/* Register 0x00 (ID) definition - READ ONLY
* | Bit 15 | Bit 14 | Bit 13 | Bit 12 | Bit 11 | Bit 10 | Bit 9 | Bit 8 | Bit 7 | Bit 6 | Bit 5 | Bit 4 | Bit 3 | Bit 2 | Bit 1 | Bit 0 |
* | RESERVED[3:0] | CHANCNT[3:0] | REVID[7:0] |
/* ID register address & default value */
#define ID_ADDRESS ((uint8_t) 0x00)
#define ID_DEFAULT ((uint16_t) 0x2000 | (CHANNEL_COUNT << 8)) // NOTE: May change with future device revisions!
/* RESERVED field mask */
#define ID_RESERVED_MASK ((uint16_t) 0xF000)
/* CHANCNT field mask & values */
#define ID_CHANCNT_MASK ((uint16_t) 0x0F00)
#define ID_CHANCNT_4CH ((uint16_t) 0x0004 << 8)
#define ID_CHANCNT_6CH ((uint16_t) 0x0006 << 8)
#define ID_CHANCNT_8CH ((uint16_t) 0x0008 << 8)
/* REVID field mask & values */
#define ID_REVID_MASK ((uint16_t) 0x00FF)
#define ID_REVID_REVA ((uint16_t) 0x0000 << 0) // DEFAULT
/* Register 0x01 (STATUS) definition - READ ONLY
* | LOCK | F_RESYNC | REG_MAP | CRC_ERR | CRC_TYPE | RESET | WLENGTH[1:0] | DRDY7 | DRDY6 | DRDY5 | DRDY4 | DRDY3 | DRDY2 | DRDY1 | DRDY0 |
* NOTE 1: Bits 0 through 7 are hardware controlled. Reading these values multiple times may return different results.
* NOTE 2: Bits 0 through 4 are RESERVED on the ADS131M04. These bits will always read 0.
/* STATUS register address & default value */
#define STATUS_ADDRESS ((uint8_t) 0x01)
#define STATUS_DEFAULT ((uint16_t) 0x0500)
/* LOCK field mask & values */
#define STATUS_LOCK_MASK ((uint16_t) 0x8000)
#define STATUS_LOCK_UNLOCKED ((uint16_t) 0x0000 << 15) // DEFAULT
#define STATUS_LOCK_LOCKED ((uint16_t) 0x0001 << 15)
/* F_RESYNC field mask & values */
#define STATUS_F_RESYNC_MASK ((uint16_t) 0x4000)
#define STATUS_F_RESYNC_NO_FAULT ((uint16_t) 0x0000 << 14) // DEFAULT
#define STATUS_F_RESYNC_FAULT ((uint16_t) 0x0001 << 14)
/* REG_MAP field mask & values */
#define STATUS_REG_MAP_MASK ((uint16_t) 0x2000)
#define STATUS_REG_MAP_NO_CHANGE_CRC ((uint16_t) 0x0000 << 13) // DEFAULT
#define STATUS_REG_MAP_CHANGED_CRC ((uint16_t) 0x0001 << 13)
/* CRC_ERR field mask & values */
#define STATUS_CRC_ERR_MASK ((uint16_t) 0x1000)
#define STATUS_CRC_ERR_NO_CRC_ERROR ((uint16_t) 0x0000 << 12) // DEFAULT
#define STATUS_CRC_ERR_INPUT_CRC_ERROR ((uint16_t) 0x0001 << 12)
/* CRC_TYPE field mask & values */
#define STATUS_CRC_TYPE_MASK ((uint16_t) 0x0800)
#define STATUS_CRC_TYPE_16BIT_CCITT ((uint16_t) 0x0000 << 11) // DEFAULT
#define STATUS_CRC_TYPE_16BIT_ANSI ((uint16_t) 0x0001 << 11)
/* RESET field mask & values */
#define STATUS_RESET_MASK ((uint16_t) 0x0400)
#define STATUS_RESET_NO_RESET ((uint16_t) 0x0000 << 10)
#define STATUS_RESET_RESET_OCCURRED ((uint16_t) 0x0001 << 10) // DEFAULT
/* WLENGTH field mask & values */
#define STATUS_WLENGTH_MASK ((uint16_t) 0x0300)
#define STATUS_WLENGTH_16BIT ((uint16_t) 0x0000 << 8)
#define STATUS_WLENGTH_24BIT ((uint16_t) 0x0001 << 8) // DEFAULT
#define STATUS_WLENGTH_32BIT_LSB_ZEROES ((uint16_t) 0x0002 << 8)
#define STATUS_WLENGTH_32BIT_MSB_SIGN_EXT ((uint16_t) 0x0003 << 8)
/* DRDY7 field mask & values */
#define STATUS_DRDY7_MASK ((uint16_t) 0x0080)
#define STATUS_DRDY7_NO_NEW_DATA ((uint16_t) 0x0000 << 7)
#define STATUS_DRDY7_NEW_DATA ((uint16_t) 0x0001 << 7)
#endif
/* DRDY6 field mask & values */
#define STATUS_DRDY6_MASK ((uint16_t) 0x0040)
#define STATUS_DRDY6_NO_NEW_DATA ((uint16_t) 0x0000 << 6)
#define STATUS_DRDY6_NEW_DATA ((uint16_t) 0x0001 << 6)
#endif
/* DRDY5 field mask & values */
#define STATUS_DRDY5_MASK ((uint16_t) 0x0020)
#define STATUS_DRDY5_NO_NEW_DATA ((uint16_t) 0x0000 << 5)
#define STATUS_DRDY5_NEW_DATA ((uint16_t) 0x0001 << 5)
#endif
/* DRDY4 field mask & values */
#define STATUS_DRDY4_MASK ((uint16_t) 0x0010)
#define STATUS_DRDY4_NO_NEW_DATA ((uint16_t) 0x0000 << 4)
#define STATUS_DRDY4_NEW_DATA ((uint16_t) 0x0001 << 4)
#endif
/* DRDY3 field mask & values */
#define STATUS_DRDY3_MASK ((uint16_t) 0x0008)
#define STATUS_DRDY3_NO_NEW_DATA ((uint16_t) 0x0000 << 3)
#define STATUS_DRDY3_NEW_DATA ((uint16_t) 0x0001 << 3)
#endif
/* DRDY2 field mask & values */
#define STATUS_DRDY2_MASK ((uint16_t) 0x0004)
#define STATUS_DRDY2_NO_NEW_DATA ((uint16_t) 0x0000 << 2)
#define STATUS_DRDY2_NEW_DATA ((uint16_t) 0x0001 << 2)
#endif
/* DRDY1 field mask & values */
#define STATUS_DRDY1_MASK ((uint16_t) 0x0002)
#define STATUS_DRDY1_NO_NEW_DATA ((uint16_t) 0x0000 << 1)
#define STATUS_DRDY1_NEW_DATA ((uint16_t) 0x0001 << 1)
#endif
/* DRDY0 field mask & values */
#define STATUS_DRDY0_MASK ((uint16_t) 0x0001)
#define STATUS_DRDY0_NO_NEW_DATA ((uint16_t) 0x0000 << 0)
#define STATUS_DRDY0_NEW_DATA ((uint16_t) 0x0001 << 0)
/* Register 0x02 (MODE) definition
* | RESERVED0[1:0] | REG_CRC_EN | RX_CRC_EN | CRC_TYPE | RESET | WLENGTH[1:0] | RESERVED1[2:0] | TIMEOUT | DRDY_SEL[1:0] | DRDY_HiZ | DRDY_FMT |
/* MODE register address & default value */
#define MODE_ADDRESS ((uint8_t) 0x02)
#define MODE_DEFAULT ((uint16_t) 0x0510)
/* RESERVED0 field mask */
#define MODE_RESERVED0_MASK ((uint16_t) 0xC000)
/* REG_CRC_EN field mask & values */
#define MODE_REG_CRC_EN_MASK ((uint16_t) 0x2000)
#define MODE_REG_CRC_EN_DISABLED ((uint16_t) 0x0000 << 13) // DEFAULT
#define MODE_REG_CRC_EN_ENABLED ((uint16_t) 0x0001 << 13)
/* RX_CRC_EN field mask & values */
#define MODE_RX_CRC_EN_MASK ((uint16_t) 0x1000)
#define MODE_RX_CRC_EN_DISABLED ((uint16_t) 0x0000 << 12) // DEFAULT
#define MODE_RX_CRC_EN_ENABLED ((uint16_t) 0x0001 << 12)
#define MODE_CRC_TYPE_MASK ((uint16_t) 0x0800)
#define MODE_CRC_TYPE_16BIT_CCITT ((uint16_t) 0x0000 << 11) // DEFAULT
#define MODE_CRC_TYPE_16BIT_ANSI ((uint16_t) 0x0001 << 11)
#define MODE_RESET_MASK ((uint16_t) 0x0400)
#define MODE_RESET_NO_RESET ((uint16_t) 0x0000 << 10)
#define MODE_RESET_RESET_OCCURRED ((uint16_t) 0x0001 << 10) // DEFAULT
#define MODE_WLENGTH_MASK ((uint16_t) 0x0300)
#define MODE_WLENGTH_16BIT ((uint16_t) 0x0000 << 8)
#define MODE_WLENGTH_24BIT ((uint16_t) 0x0001 << 8)
#define MODE_WLENGTH_32BIT_LSB_ZEROES ((uint16_t) 0x0002 << 8)
#define MODE_WLENGTH_32BIT_MSB_SIGN_EXT ((uint16_t) 0x0003 << 8)
/* RESERVED1 field mask */
#define MODE_RESERVED1_MASK ((uint16_t) 0x00E0)
/* TIMEOUT field mask & values */
#define MODE_TIMEOUT_MASK ((uint16_t) 0x0010)
#define MODE_TIMEOUT_DISABLED ((uint16_t) 0x0000 << 4)
#define MODE_TIMEOUT_ENABLED ((uint16_t) 0x0001 << 4) // DEFAULT
/* DRDY_SEL field mask & values */
#define MODE_DRDY_SEL_MASK ((uint16_t) 0x000C)
#define MODE_DRDY_SEL_MOST_LAGGING ((uint16_t) 0x0000 << 2) // DEFAULT
#define MODE_DRDY_SEL_LOGIC_OR ((uint16_t) 0x0001 << 2)
#define MODE_DRDY_SEL_MOST_LEADING ((uint16_t) 0x0002 << 2) // Alternative value: ((uint16_t) 0x0003 << 2)
/* DRDY_HiZ field mask & values */
#define MODE_DRDY_HiZ_MASK ((uint16_t) 0x0002)
#define MODE_DRDY_HiZ_LOGIC_HIGH ((uint16_t) 0x0000 << 1) // DEFAULT
#define MODE_DRDY_HiZ_HIGH_IMPEDANCE ((uint16_t) 0x0001 << 1)
/* DRDY_FMT field mask & values */
#define MODE_DRDY_FMT_MASK ((uint16_t) 0x0001)
#define MODE_DRDY_FMT_LOGIC_LOW ((uint16_t) 0x0000 << 0) // DEFAULT
#define MODE_DRDY_FMT_NEG_PULSE_FIXED_WIDTH ((uint16_t) 0x0001 << 0)
/* Register 0x03 (CLOCK) definition
* | CH7_EN | CH6_EN | CH5_EN | CH4_EN | CH3_EN | CH2_EN | CH1_EN | CH0_EN | RESERVED[2:0] | OSR[2:0] | PWR[1:0] |
* NOTE 1: Bits 12 through 15 are RESERVED on the ADS131M04.
/* CLOCK register address & default value */
#define CLOCK_ADDRESS ((uint8_t) 0x03)
#if (CHANNEL_COUNT == 8)
#define CLOCK_DEFAULT ((uint16_t) 0xFF0E)
#endif
#if (CHANNEL_COUNT == 7)
#define CLOCK_DEFAULT ((uint16_t) 0x7F0E)
#endif
#if (CHANNEL_COUNT == 6)
#define CLOCK_DEFAULT ((uint16_t) 0x3F0E)
#endif
#if (CHANNEL_COUNT == 5)
#define CLOCK_DEFAULT ((uint16_t) 0x1F0E)
#endif
#if (CHANNEL_COUNT == 4)
#define CLOCK_DEFAULT ((uint16_t) 0x0F0E)
#endif
#if (CHANNEL_COUNT == 3)
#define CLOCK_DEFAULT ((uint16_t) 0x070E)
#endif
#if (CHANNEL_COUNT == 2)
#define CLOCK_DEFAULT ((uint16_t) 0x030E)
#endif
#if (CHANNEL_COUNT == 1)
#define CLOCK_DEFAULT ((uint16_t) 0x010E)
#endif
/* CH7_EN field mask & values */
#define CLOCK_CH7_EN_MASK ((uint16_t) 0x8000)
#define CLOCK_CH7_EN_DISABLED ((uint16_t) 0x0000 << 15)
#define CLOCK_CH7_EN_ENABLED ((uint16_t) 0x0001 << 15)
#endif
/* CH6_EN field mask & values */
#define CLOCK_CH6_EN_MASK ((uint16_t) 0x4000)
#define CLOCK_CH6_EN_DISABLED ((uint16_t) 0x0000 << 14)
#define CLOCK_CH6_EN_ENABLED ((uint16_t) 0x0001 << 14)
#endif
/* CH5_EN field mask & values */
#define CLOCK_CH5_EN_MASK ((uint16_t) 0x2000)
#define CLOCK_CH5_EN_DISABLED ((uint16_t) 0x0000 << 13)
#define CLOCK_CH5_EN_ENABLED ((uint16_t) 0x0001 << 13)
#endif
/* CH4_EN field mask & values */
#define CLOCK_CH4_EN_MASK ((uint16_t) 0x1000)
#define CLOCK_CH4_EN_DISABLED ((uint16_t) 0x0000 << 12)
#define CLOCK_CH4_EN_ENABLED ((uint16_t) 0x0001 << 12)
#endif
/* CH3_EN field mask & values */
#define CLOCK_CH3_EN_MASK ((uint16_t) 0x0800)
#define CLOCK_CH3_EN_DISABLED ((uint16_t) 0x0000 << 11)
#define CLOCK_CH3_EN_ENABLED ((uint16_t) 0x0001 << 11)
#endif
/* CH2_EN field mask & values */
#define CLOCK_CH2_EN_MASK ((uint16_t) 0x0400)
#define CLOCK_CH2_EN_DISABLED ((uint16_t) 0x0000 << 10)
#define CLOCK_CH2_EN_ENABLED ((uint16_t) 0x0001 << 10)
#endif
/* CH1_EN field mask & values */
#define CLOCK_CH1_EN_MASK ((uint16_t) 0x0200)
#define CLOCK_CH1_EN_DISABLED ((uint16_t) 0x0000 << 9)
#define CLOCK_CH1_EN_ENABLED ((uint16_t) 0x0001 << 9)
#endif
/* CH0_EN field mask & values */
#define CLOCK_CH0_EN_MASK ((uint16_t) 0x0100)
#define CLOCK_CH0_EN_DISABLED ((uint16_t) 0x0000 << 8)
#define CLOCK_CH0_EN_ENABLED ((uint16_t) 0x0001 << 8) // DEFAULT
#define CLOCK_RESERVED_MASK ((uint16_t) 0x00E0)
/* OSR field mask & values */
#define CLOCK_OSR_MASK ((uint16_t) 0x001C)
#define CLOCK_OSR_128 ((uint16_t) 0x0000 << 2)
#define CLOCK_OSR_256 ((uint16_t) 0x0001 << 2)
#define CLOCK_OSR_512 ((uint16_t) 0x0002 << 2)
#define CLOCK_OSR_1024 ((uint16_t) 0x0003 << 2) // DEFAULT
#define CLOCK_OSR_2048 ((uint16_t) 0x0004 << 2)
#define CLOCK_OSR_4096 ((uint16_t) 0x0005 << 2)
#define CLOCK_OSR_8192 ((uint16_t) 0x0006 << 2)
#define CLOCK_OSR_16384 ((uint16_t) 0x0007 << 2)
/* PWR field mask & values */
#define CLOCK_PWR_MASK ((uint16_t) 0x0003)
#define CLOCK_PWR_VLP ((uint16_t) 0x0000 << 0)
#define CLOCK_PWR_LP ((uint16_t) 0x0001 << 0)
#define CLOCK_PWR_HR ((uint16_t) 0x0002 << 0) // DEFAULT, Alternative value: ((uint16_t) 0x0003 << 2)
/* Register 0x04 (GAIN1) definition
* | RESERVED0 | PGAGAIN3[2:0] | RESERVED1 | PGAGAIN2[2:0] | RESERVED2 | PGAGAIN1[2:0] | RESERVED3 | PGAGAIN0[2:0] |
/* GAIN1 register address & default value */
#define GAIN1_ADDRESS ((uint8_t) 0x04)
#define GAIN1_DEFAULT ((uint16_t) 0x0000)
/* RESERVED0 field mask & values */
#define GAIN1_RESERVED0_MASK ((uint16_t) 0x8000)
/* PGAGAIN3 field mask & values */
#define GAIN1_PGAGAIN3_MASK ((uint16_t) 0x7000)
#define GAIN1_PGAGAIN3_1 ((uint16_t) 0x0000 << 12) // DEFAULT
#define GAIN1_PGAGAIN3_2 ((uint16_t) 0x0001 << 12)
#define GAIN1_PGAGAIN3_4 ((uint16_t) 0x0002 << 12)
#define GAIN1_PGAGAIN3_8 ((uint16_t) 0x0003 << 12)
#define GAIN1_PGAGAIN3_16 ((uint16_t) 0x0004 << 12)
#define GAIN1_PGAGAIN3_32 ((uint16_t) 0x0005 << 12)
#define GAIN1_PGAGAIN3_64 ((uint16_t) 0x0006 << 12)
#define GAIN1_PGAGAIN3_128 ((uint16_t) 0x0007 << 12)
/* RESERVED1 field mask & values */
#define GAIN1_RESERVED1_MASK ((uint16_t) 0x0800)
/* PGAGAIN2 field mask & values */
#define GAIN1_PGAGAIN2_MASK ((uint16_t) 0x0700)
#define GAIN1_PGAGAIN2_1 ((uint16_t) 0x0000 << 8) // DEFAULT
#define GAIN1_PGAGAIN2_2 ((uint16_t) 0x0001 << 8)
#define GAIN1_PGAGAIN2_4 ((uint16_t) 0x0002 << 8)
#define GAIN1_PGAGAIN2_8 ((uint16_t) 0x0003 << 8)
#define GAIN1_PGAGAIN2_16 ((uint16_t) 0x0004 << 8)
#define GAIN1_PGAGAIN2_32 ((uint16_t) 0x0005 << 8)
#define GAIN1_PGAGAIN2_64 ((uint16_t) 0x0006 << 8)
#define GAIN1_PGAGAIN2_128 ((uint16_t) 0x0007 << 8)
/* RESERVED2 field mask & values */
#define GAIN1_RESERVED2_MASK ((uint16_t) 0x0080)
/* PGAGAIN1 field mask & values */
#define GAIN1_PGAGAIN1_MASK ((uint16_t) 0x0070)
#define GAIN1_PGAGAIN1_1 ((uint16_t) 0x0000 << 4) // DEFAULT
#define GAIN1_PGAGAIN1_2 ((uint16_t) 0x0001 << 4)
#define GAIN1_PGAGAIN1_4 ((uint16_t) 0x0002 << 4)
#define GAIN1_PGAGAIN1_8 ((uint16_t) 0x0003 << 4)
#define GAIN1_PGAGAIN1_16 ((uint16_t) 0x0004 << 4)
#define GAIN1_PGAGAIN1_32 ((uint16_t) 0x0005 << 4)
#define GAIN1_PGAGAIN1_64 ((uint16_t) 0x0006 << 4)
#define GAIN1_PGAGAIN1_128 ((uint16_t) 0x0007 << 4)
/* RESERVED3 field mask & values */
#define GAIN1_RESERVED3_MASK ((uint16_t) 0x0008)
/* PGAGAIN0 field mask & values */
#define GAIN1_PGAGAIN0_MASK ((uint16_t) 0x0007)
#define GAIN1_PGAGAIN0_1 ((uint16_t) 0x0000 << 0) // DEFAULT
#define GAIN1_PGAGAIN0_2 ((uint16_t) 0x0001 << 0)
#define GAIN1_PGAGAIN0_4 ((uint16_t) 0x0002 << 0)
#define GAIN1_PGAGAIN0_8 ((uint16_t) 0x0003 << 0)
#define GAIN1_PGAGAIN0_16 ((uint16_t) 0x0004 << 0)
#define GAIN1_PGAGAIN0_32 ((uint16_t) 0x0005 << 0)
#define GAIN1_PGAGAIN0_64 ((uint16_t) 0x0006 << 0)
#define GAIN1_PGAGAIN0_128 ((uint16_t) 0x0007 << 0)
/* Register 0x05 (GAIN2) definition
* | RESERVED0 | PGAGAIN7[2:0] | RESERVED1 | PGAGAIN6[2:0] | RESERVED2 | PGAGAIN5[2:0] | RESERVED3 | PGAGAIN4[2:0] |
* NOTE 1: This register is RESERVED on the ADS131M04. Only write 0x0000 to this register.
/* GAIN2 register address & default value */
#define GAIN2_ADDRESS ((uint8_t) 0x05)
#define GAIN2_DEFAULT ((uint16_t) 0x0000)
#define GAIN2_RESERVED0_MASK ((uint16_t) 0x8000)
/* PGAGAIN7 field mask & values */
#define GAIN2_PGAGAIN7_MASK ((uint16_t) 0x7000)
#define GAIN2_PGAGAIN7_1 ((uint16_t) 0x0000 << 12) // DEFAULT
#define GAIN2_PGAGAIN7_2 ((uint16_t) 0x0001 << 12)
#define GAIN2_PGAGAIN7_4 ((uint16_t) 0x0002 << 12)
#define GAIN2_PGAGAIN7_8 ((uint16_t) 0x0003 << 12)
#define GAIN2_PGAGAIN7_16 ((uint16_t) 0x0004 << 12)
#define GAIN2_PGAGAIN7_32 ((uint16_t) 0x0005 << 12)
#define GAIN2_PGAGAIN7_64 ((uint16_t) 0x0006 << 12)
#define GAIN2_PGAGAIN7_128 ((uint16_t) 0x0007 << 12)
#define GAIN2_RESERVED1_MASK ((uint16_t) 0x0800)
/* PGAGAIN6 field mask & values */
#define GAIN2_PGAGAIN6_MASK ((uint16_t) 0x0700)
#define GAIN2_PGAGAIN6_1 ((uint16_t) 0x0000 << 8) // DEFAULT
#define GAIN2_PGAGAIN6_2 ((uint16_t) 0x0001 << 8)
#define GAIN2_PGAGAIN6_4 ((uint16_t) 0x0002 << 8)
#define GAIN2_PGAGAIN6_8 ((uint16_t) 0x0003 << 8)
#define GAIN2_PGAGAIN6_16 ((uint16_t) 0x0004 << 8)
#define GAIN2_PGAGAIN6_32 ((uint16_t) 0x0005 << 8)
#define GAIN2_PGAGAIN6_64 ((uint16_t) 0x0006 << 8)
#define GAIN2_PGAGAIN6_128 ((uint16_t) 0x0007 << 8)
#define GAIN2_RESERVED2_MASK ((uint16_t) 0x0080)
/* PGAGAIN5 field mask & values */
#define GAIN2_PGAGAIN5_MASK ((uint16_t) 0x0070)
#define GAIN2_PGAGAIN5_1 ((uint16_t) 0x0000 << 4) // DEFAULT
#define GAIN2_PGAGAIN5_2 ((uint16_t) 0x0001 << 4)
#define GAIN2_PGAGAIN5_4 ((uint16_t) 0x0002 << 4)
#define GAIN2_PGAGAIN5_8 ((uint16_t) 0x0003 << 4)
#define GAIN2_PGAGAIN5_16 ((uint16_t) 0x0004 << 4)
#define GAIN2_PGAGAIN5_32 ((uint16_t) 0x0005 << 4)
#define GAIN2_PGAGAIN5_64 ((uint16_t) 0x0006 << 4)
#define GAIN2_PGAGAIN5_128 ((uint16_t) 0x0007 << 4)
#define GAIN2_RESERVED3_MASK ((uint16_t) 0x0008)
/* PGAGAIN4 field mask & values */
#define GAIN2_PGAGAIN4_MASK ((uint16_t) 0x0007)
#define GAIN2_PGAGAIN4_1 ((uint16_t) 0x0000 << 0) // DEFAULT
#define GAIN2_PGAGAIN4_2 ((uint16_t) 0x0001 << 0)
#define GAIN2_PGAGAIN4_4 ((uint16_t) 0x0002 << 0)
#define GAIN2_PGAGAIN4_8 ((uint16_t) 0x0003 << 0)
#define GAIN2_PGAGAIN4_16 ((uint16_t) 0x0004 << 0)
#define GAIN2_PGAGAIN4_32 ((uint16_t) 0x0005 << 0)
#define GAIN2_PGAGAIN4_64 ((uint16_t) 0x0006 << 0)
#define GAIN2_PGAGAIN4_128 ((uint16_t) 0x0007 << 0)
#endif
/* Register 0x06 (CFG) definition
* | RESERVED0[2:0] | GC_DLY[3:0] | GC_EN | CD_ALLCH | CD_NUM[2:0] | CD_LEN[2:0] | CD_EN |
/* CFG register address & default value */
#define CFG_ADDRESS ((uint8_t) 0x06)
#define CFG_DEFAULT ((uint16_t) 0x0600)
#define CFG_RESERVED0_MASK ((uint16_t) 0xE000)
/* GC_DLY field mask & values */
#define CFG_GC_DLY_MASK ((uint16_t) 0x1E00)
#define CFG_GC_DLY_2 ((uint16_t) 0x0000 << 9)
#define CFG_GC_DLY_4 ((uint16_t) 0x0001 << 9)
#define CFG_GC_DLY_8 ((uint16_t) 0x0002 << 9)
#define CFG_GC_DLY_16 ((uint16_t) 0x0003 << 9) // DEFAULT
#define CFG_GC_DLY_32 ((uint16_t) 0x0004 << 9)
#define CFG_GC_DLY_64 ((uint16_t) 0x0005 << 9)
#define CFG_GC_DLY_128 ((uint16_t) 0x0006 << 9)
#define CFG_GC_DLY_256 ((uint16_t) 0x0007 << 9)
#define CFG_GC_DLY_512 ((uint16_t) 0x0008 << 9)
#define CFG_GC_DLY_1024 ((uint16_t) 0x0009 << 9)
#define CFG_GC_DLY_2048 ((uint16_t) 0x000A << 9)
#define CFG_GC_DLY_4096 ((uint16_t) 0x000B << 9)
#define CFG_GC_DLY_8192 ((uint16_t) 0x000C << 9)
#define CFG_GC_DLY_16484 ((uint16_t) 0x000D << 9)
#define CFG_GC_DLY_32768 ((uint16_t) 0x000E << 9)
#define CFG_GC_DLY_65536 ((uint16_t) 0x000F << 9)
/* GC_EN field mask & values */
#define CFG_GC_EN_MASK ((uint16_t) 0x0100)
#define CFG_GC_EN_DISABLED ((uint16_t) 0x0000 << 8) // DEFAULT
#define CFG_GC_EN_ENABLED ((uint16_t) 0x0001 << 8)
/* CD_ALLCH field mask & values */
#define CFG_CD_ALLCH_MASK ((uint16_t) 0x0080)
#define CFG_CD_ALLCH_ANY_CHANNEL ((uint16_t) 0x0000 << 7) // DEFAULT
#define CFG_CD_ALLCH_ALL_CHANNELS ((uint16_t) 0x0001 << 7)
/* CD_NUM field mask & values */
#define CFG_CD_NUM_MASK ((uint16_t) 0x0070)
#define CFG_CD_NUM_1 ((uint16_t) 0x0000 << 4) // DEFAULT
#define CFG_CD_NUM_2 ((uint16_t) 0x0001 << 4)
#define CFG_CD_NUM_4 ((uint16_t) 0x0002 << 4)
#define CFG_CD_NUM_8 ((uint16_t) 0x0003 << 4)
#define CFG_CD_NUM_16 ((uint16_t) 0x0004 << 4)
#define CFG_CD_NUM_32 ((uint16_t) 0x0005 << 4)
#define CFG_CD_NUM_64 ((uint16_t) 0x0006 << 4)
#define CFG_CD_NUM_128 ((uint16_t) 0x0007 << 4)
/* CD_LEN field mask & values */
#define CFG_CD_LEN_MASK ((uint16_t) 0x000E)
#define CFG_CD_LEN_128 ((uint16_t) 0x0000 << 1) // DEFAULT
#define CFG_CD_LEN_256 ((uint16_t) 0x0001 << 1)
#define CFG_CD_LEN_512 ((uint16_t) 0x0002 << 1)
#define CFG_CD_LEN_768 ((uint16_t) 0x0003 << 1)
#define CFG_CD_LEN_1280 ((uint16_t) 0x0004 << 1)
#define CFG_CD_LEN_1792 ((uint16_t) 0x0005 << 1)
#define CFG_CD_LEN_2560 ((uint16_t) 0x0006 << 1)
#define CFG_CD_LEN_3584 ((uint16_t) 0x0007 << 1)
/* CD_EN field mask & values */
#define CFG_CD_EN_MASK ((uint16_t) 0x0001)
#define CFG_CD_EN_DISABLED ((uint16_t) 0x0000 << 0) // DEFAULT
#define CFG_CD_EN_ENABLED ((uint16_t) 0x0001 << 0)
/* Register 0x07 (THRSHLD_MSB) definition
* | CD_TH_MSB[15:0] |
/* THRSHLD_MSB register address & default value */
#define THRSHLD_MSB_ADDRESS ((uint8_t) 0x07)
#define THRSHLD_MSB_DEFAULT ((uint16_t) 0x0000)
/* CD_TH_MSB field mask & values */
#define THRSHLD_MSB_CD_TH_MSB_MASK ((uint16_t) 0xFFFF)
/* Register 0x08 (THRSHLD_LSB) definition
* | CD_TH_LSB[7:0] | RESERVED0[7:0] |
/* THRSHLD_LSB register address & default value */
#define THRSHLD_LSB_ADDRESS ((uint8_t) 0x08)
#define THRSHLD_LSB_DEFAULT ((uint16_t) 0x0000)
/* CD_TH_LSB field mask & values */
#define THRSHLD_LSB_CD_TH_LSB_MASK ((uint16_t) 0xFF00)
#define THRSHLD_LSB_RESERVED0_MASK ((uint16_t) 0x00FF)
/* Register 0x09 (CH0_CFG) definition
* | PHASE0[9:0] | RESERVED0[3:0] | MUX0[1:0] |
/* CH0_CFG register address & default value */
#define CH0_CFG_ADDRESS ((uint8_t) 0x09)
#define CH0_CFG_DEFAULT ((uint16_t) 0x0000)
/* PHASE0 field mask & values */
#define CH0_CFG_PHASE0_MASK ((uint16_t) 0xFFC0)
#define CH0_CFG_RESERVED0_MASK ((uint16_t) 0x003C)
/* MUX0 field mask & values */
#define CH0_CFG_MUX0_MASK ((uint16_t) 0x0003)
#define CH0_CFG_MUX0_AIN0P_AIN0N ((uint16_t) 0x0000 << 0) // DEFAULT
#define CH0_CFG_MUX0_ADC_INPUT_SHORT ((uint16_t) 0x0001 << 0)
#define CH0_CFG_MUX0_DC_DIAGNOSTIC ((uint16_t) 0x0002 << 0)
#define CH0_CFG_MUX0_AC_DIAGNOSTIC ((uint16_t) 0x0003 << 0)
/* Register 0x0A (CH0_OCAL_MSB) definition
* | OCAL0_MSB[15:0] |
/* CH0_OCAL_MSB register address & default value */
#define CH0_OCAL_MSB_ADDRESS ((uint8_t) 0x0A)
#define CH0_OCAL_MSB_DEFAULT ((uint16_t) 0x0000)
/* OCAL0_MSB field mask & values */
#define CH0_OCAL_MSB_OCAL0_MSB_MASK ((uint16_t) 0xFFFF)
/* Register 0x0B (CH0_OCAL_LSB) definition
* | OCAL0_LSB[7:0] | RESERVED0[7:0] |
/* CH0_OCAL_LSB register address & default value */
#define CH0_OCAL_LSB_ADDRESS ((uint8_t) 0x0B)
#define CH0_OCAL_LSB_DEFAULT ((uint16_t) 0x0000)
/* OCAL0_LSB field mask & values */
#define CH0_OCAL_LSB_OCAL0_LSB_MASK ((uint16_t) 0xFF00)
#define CH0_OCAL_LSB_RESERVED0_MASK ((uint16_t) 0x00FF)
/* Register 0x0C (CH0_GCAL_MSB) definition
* | GCAL0_MSB[15:0] |
/* CH0_GCAL_MSB register address & default value */
#define CH0_GCAL_MSB_ADDRESS ((uint8_t) 0x0C)
#define CH0_GCAL_MSB_DEFAULT ((uint16_t) 0x8000)
/* GCAL0_MSB field mask & values */
#define CH0_GCAL_MSB_GCAL0_MSB_MASK ((uint16_t) 0xFFFF)
/* Register 0x0D (CH0_GCAL_LSB) definition
* | GCAL0_LSB[7:0] | RESERVED0[7:0] |
/* CH0_GCAL_LSB register address & default value */
#define CH0_GCAL_LSB_ADDRESS ((uint8_t) 0x0D)
#define CH0_GCAL_LSB_DEFAULT ((uint16_t) 0x0000)
/* GCAL0_LSB field mask & values */
#define CH0_GCAL_LSB_GCAL0_LSB_MASK ((uint16_t) 0xFF00)
#define CH0_GCAL_LSB_RESERVED0_MASK ((uint16_t) 0x00FF)
/* Register 0x0E (CH1_CFG) definition
* | PHASE1[9:0] | RESERVED0[3:0] | MUX1[1:0] |
/* CH1_CFG register address & default value */
#define CH1_CFG_ADDRESS ((uint8_t) 0x0E)
#define CH1_CFG_DEFAULT ((uint16_t) 0x0000)
/* PHASE1 field mask & values */
#define CH1_CFG_PHASE1_MASK ((uint16_t) 0xFFC0)
#define CH1_CFG_RESERVED0_MASK ((uint16_t) 0x003C)
/* MUX1 field mask & values */
#define CH1_CFG_MUX1_MASK ((uint16_t) 0x0003)
#define CH1_CFG_MUX1_AIN1P_AIN1N ((uint16_t) 0x0000 << 0) // DEFAULT
#define CH1_CFG_MUX1_ADC_INPUT_SHORT ((uint16_t) 0x0001 << 0)
#define CH1_CFG_MUX1_DC_DIAGNOSTIC ((uint16_t) 0x0002 << 0)
#define CH1_CFG_MUX1_AC_DIAGNOSTIC ((uint16_t) 0x0003 << 0)
/* Register 0x0F (CH1_OCAL_MSB) definition
* | OCAL1_MSB[15:0] |
/* CH1_OCAL_MSB register address & default value */
#define CH1_OCAL_MSB_ADDRESS ((uint8_t) 0x0F)
#define CH1_OCAL_MSB_DEFAULT ((uint16_t) 0x0000)
/* OCAL1_MSB field mask & values */
#define CH1_OCAL_MSB_OCAL1_MSB_MASK ((uint16_t) 0xFFFF)
/* Register 0x10 (CH1_OCAL_LSB) definition
* | OCAL1_LSB[7:0] | RESERVED0[7:0] |
/* CH1_OCAL_LSB register address & default value */
#define CH1_OCAL_LSB_ADDRESS ((uint8_t) 0x10)
#define CH1_OCAL_LSB_DEFAULT ((uint16_t) 0x0000)
/* OCAL1_LSB field mask & values */
#define CH1_OCAL_LSB_OCAL1_LSB_MASK ((uint16_t) 0xFF00)
#define CH1_OCAL_LSB_RESERVED0_MASK ((uint16_t) 0x00FF)
/* Register 0x11 (CH1_GCAL_MSB) definition
* | GCAL1_MSB[15:0] |
/* CH1_GCAL_MSB register address & default value */
#define CH1_GCAL_MSB_ADDRESS ((uint8_t) 0x11)
#define CH1_GCAL_MSB_DEFAULT ((uint16_t) 0x8000)
/* GCAL1_MSB field mask & values */
#define CH1_GCAL_MSB_GCAL1_MSB_MASK ((uint16_t) 0xFFFF)
/* Register 0x12 (CH1_GCAL_LSB) definition
* | GCAL1_LSB[7:0] | RESERVED0[7:0] |
/* CH1_GCAL_LSB register address & default value */
#define CH1_GCAL_LSB_ADDRESS ((uint8_t) 0x12)
#define CH1_GCAL_LSB_DEFAULT ((uint16_t) 0x0000)
/* GCAL1_LSB field mask & values */
#define CH1_GCAL_LSB_GCAL1_LSB_MASK ((uint16_t) 0xFF00)
#define CH1_GCAL_LSB_RESERVED0_MASK ((uint16_t) 0x00FF)
#endif
/* Register 0x13 (CH2_CFG) definition
* | PHASE2[9:0] | RESERVED0[3:0] | MUX2[1:0] |
/* CH2_CFG register address & default value */
#define CH2_CFG_ADDRESS ((uint8_t) 0x13)
#define CH2_CFG_DEFAULT ((uint16_t) 0x0000)
/* PHASE2 field mask & values */
#define CH2_CFG_PHASE2_MASK ((uint16_t) 0xFFC0)
#define CH2_CFG_RESERVED0_MASK ((uint16_t) 0x003C)
/* MUX2 field mask & values */
#define CH2_CFG_MUX2_MASK ((uint16_t) 0x0003)
#define CH2_CFG_MUX2_AIN2P_AIN2N ((uint16_t) 0x0000 << 0) // DEFAULT
#define CH2_CFG_MUX2_ADC_INPUT_SHORT ((uint16_t) 0x0001 << 0)
#define CH2_CFG_MUX2_DC_DIAGNOSTIC ((uint16_t) 0x0002 << 0)
#define CH2_CFG_MUX2_AC_DIAGNOSTIC ((uint16_t) 0x0003 << 0)
/* Register 0x14 (CH2_OCAL_MSB) definition
* | OCAL2_MSB[15:0] |
/* CH2_OCAL_MSB register address & default value */
#define CH2_OCAL_MSB_ADDRESS ((uint8_t) 0x14)
#define CH2_OCAL_MSB_DEFAULT ((uint16_t) 0x0000)
/* OCAL2_MSB field mask & values */
#define CH2_OCAL_MSB_OCAL2_MSB_MASK ((uint16_t) 0xFFFF)
/* Register 0x15 (CH2_OCAL_LSB) definition
* | OCAL2_LSB[7:0] | RESERVED0[7:0] |
/* CH2_OCAL_LSB register address & default value */
#define CH2_OCAL_LSB_ADDRESS ((uint8_t) 0x15)
#define CH2_OCAL_LSB_DEFAULT ((uint16_t) 0x0000)
/* OCAL2_LSB field mask & values */
#define CH2_OCAL_LSB_OCAL2_LSB_MASK ((uint16_t) 0xFF00)
#define CH2_OCAL_LSB_RESERVED0_MASK ((uint16_t) 0x00FF)
/* Register 0x16 (CH2_GCAL_MSB) definition
* | GCAL2_MSB[15:0] |
/* CH2_GCAL_MSB register address & default value */
#define CH2_GCAL_MSB_ADDRESS ((uint8_t) 0x16)
#define CH2_GCAL_MSB_DEFAULT ((uint16_t) 0x8000)
/* GCAL2_MSB field mask & values */
#define CH2_GCAL_MSB_GCAL2_MSB_MASK ((uint16_t) 0xFFFF)
/* Register 0x17 (CH2_GCAL_LSB) definition
* | GCAL2_LSB[7:0] | RESERVED0[7:0] |
/* CH2_GCAL_LSB register address & default value */
#define CH2_GCAL_LSB_ADDRESS ((uint8_t) 0x17)
#define CH2_GCAL_LSB_DEFAULT ((uint16_t) 0x0000)
/* GCAL2_LSB field mask & values */
#define CH2_GCAL_LSB_GCAL2_LSB_MASK ((uint16_t) 0xFF00)
#define CH2_GCAL_LSB_RESERVED0_MASK ((uint16_t) 0x00FF)
#endif
/* Register 0x18 (CH3_CFG) definition
* | PHASE3[9:0] | RESERVED0[3:0] | MUX3[1:0] |
/* CH3_CFG register address & default value */
#define CH3_CFG_ADDRESS ((uint8_t) 0x18)
#define CH3_CFG_DEFAULT ((uint16_t) 0x0000)
/* PHASE3 field mask & values */
#define CH3_CFG_PHASE3_MASK ((uint16_t) 0xFFC0)
#define CH3_CFG_RESERVED0_MASK ((uint16_t) 0x003C)
/* MUX3 field mask & values */
#define CH3_CFG_MUX3_MASK ((uint16_t) 0x0003)
#define CH3_CFG_MUX3_AIN3P_AIN3N ((uint16_t) 0x0000 << 0) // DEFAULT
#define CH3_CFG_MUX3_ADC_INPUT_SHORT ((uint16_t) 0x0001 << 0)
#define CH3_CFG_MUX3_DC_DIAGNOSTIC ((uint16_t) 0x0002 << 0)
#define CH3_CFG_MUX3_AC_DIAGNOSTIC ((uint16_t) 0x0003 << 0)
/* Register 0x19 (CH3_OCAL_MSB) definition
* | OCAL3_MSB[15:0] |
/* CH3_OCAL_MSB register address & default value */
#define CH3_OCAL_MSB_ADDRESS ((uint8_t) 0x19)
#define CH3_OCAL_MSB_DEFAULT ((uint16_t) 0x0000)
/* OCAL3_MSB field mask & values */
#define CH3_OCAL_MSB_OCAL3_MSB_MASK ((uint16_t) 0xFFFF)
/* Register 0x1A (CH3_OCAL_LSB) definition
* | OCAL3_LSB[7:0] | RESERVED0[7:0] |
/* CH3_OCAL_LSB register address & default value */
#define CH3_OCAL_LSB_ADDRESS ((uint8_t) 0x1A)
#define CH3_OCAL_LSB_DEFAULT ((uint16_t) 0x0000)
/* OCAL3_LSB field mask & values */
#define CH3_OCAL_LSB_OCAL3_LSB_MASK ((uint16_t) 0xFF00)
#define CH3_OCAL_LSB_RESERVED0_MASK ((uint16_t) 0x00FF)
/* Register 0x1B (CH3_GCAL_MSB) definition
* | GCAL3_MSB[15:0] |
/* CH3_GCAL_MSB register address & default value */
#define CH3_GCAL_MSB_ADDRESS ((uint8_t) 0x1B)
#define CH3_GCAL_MSB_DEFAULT ((uint16_t) 0x8000)
/* GCAL3_MSB field mask & values */
#define CH3_GCAL_MSB_GCAL3_MSB_MASK ((uint16_t) 0xFFFF)
/* Register 0x1C (CH3_GCAL_LSB) definition
* | GCAL3_LSB[7:0] | RESERVED0[7:0] |
/* CH3_GCAL_LSB register address & default value */
#define CH3_GCAL_LSB_ADDRESS ((uint8_t) 0x1C)
#define CH3_GCAL_LSB_DEFAULT ((uint16_t) 0x0000)
/* GCAL3_LSB field mask & values */
#define CH3_GCAL_LSB_GCAL3_LSB_MASK ((uint16_t) 0xFF00)
#define CH3_GCAL_LSB_RESERVED0_MASK ((uint16_t) 0x00FF)
#endif
/* Register 0x1D (CH4_CFG) definition
* | PHASE4[9:0] | RESERVED0[3:0] | MUX4[1:0] |
/* CH4_CFG register address & default value */
#define CH4_CFG_ADDRESS ((uint8_t) 0x1D)
#define CH4_CFG_DEFAULT ((uint16_t) 0x0000)
/* PHASE4 field mask & values */
#define CH4_CFG_PHASE4_MASK ((uint16_t) 0xFFC0)
#define CH4_CFG_RESERVED0_MASK ((uint16_t) 0x003C)
/* MUX4 field mask & values */
#define CH4_CFG_MUX4_MASK ((uint16_t) 0x0003)
#define CH4_CFG_MUX4_AIN4P_AIN4N ((uint16_t) 0x0000 << 0) // DEFAULT
#define CH4_CFG_MUX4_ADC_INPUT_SHORT ((uint16_t) 0x0001 << 0)
#define CH4_CFG_MUX4_DC_DIAGNOSTIC ((uint16_t) 0x0002 << 0)
#define CH4_CFG_MUX4_AC_DIAGNOSTIC ((uint16_t) 0x0003 << 0)
/* Register 0x1E (CH4_OCAL_MSB) definition
* | OCAL4_MSB[15:0] |
/* CH4_OCAL_MSB register address & default value */
#define CH4_OCAL_MSB_ADDRESS ((uint8_t) 0x1E)
#define CH4_OCAL_MSB_DEFAULT ((uint16_t) 0x0000)
/* OCAL4_MSB field mask & values */
#define CH4_OCAL_MSB_OCAL4_MSB_MASK ((uint16_t) 0xFFFF)
/* Register 0x1F (CH4_OCAL_LSB) definition
* | OCAL4_LSB[7:0] | RESERVED0[7:0] |
/* CH4_OCAL_LSB register address & default value */
#define CH4_OCAL_LSB_ADDRESS ((uint8_t) 0x1F)
#define CH4_OCAL_LSB_DEFAULT ((uint16_t) 0x0000)
/* OCAL4_LSB field mask & values */
#define CH4_OCAL_LSB_OCAL4_LSB_MASK ((uint16_t) 0xFF00)
#define CH4_OCAL_LSB_RESERVED0_MASK ((uint16_t) 0x00FF)
/* Register 0x20 (CH4_GCAL_MSB) definition
* | GCAL4_MSB[15:0] |
/* CH4_GCAL_MSB register address & default value */
#define CH4_GCAL_MSB_ADDRESS ((uint8_t) 0x20)
#define CH4_GCAL_MSB_DEFAULT ((uint16_t) 0x8000)
/* GCAL4_MSB field mask & values */
#define CH4_GCAL_MSB_GCAL4_MSB_MASK ((uint16_t) 0xFFFF)
/* Register 0x21 (CH4_GCAL_LSB) definition
* | GCAL4_LSB[7:0] | RESERVED0[7:0] |
/* CH4_GCAL_LSB register address & default value */
#define CH4_GCAL_LSB_ADDRESS ((uint8_t) 0x21)
#define CH4_GCAL_LSB_DEFAULT ((uint16_t) 0x0000)
/* GCAL4_LSB field mask & values */
#define CH4_GCAL_LSB_GCAL4_LSB_MASK ((uint16_t) 0xFF00)
#define CH4_GCAL_LSB_RESERVED0_MASK ((uint16_t) 0x00FF)
#endif
/* Register 0x22 (CH5_CFG) definition
* | PHASE5[9:0] | RESERVED0[3:0] | MUX5[1:0] |
/* CH5_CFG register address & default value */
#define CH5_CFG_ADDRESS ((uint8_t) 0x22)
#define CH5_CFG_DEFAULT ((uint16_t) 0x0000)
/* PHASE5 field mask & values */
#define CH5_CFG_PHASE5_MASK ((uint16_t) 0xFFC0)
#define CH5_CFG_RESERVED0_MASK ((uint16_t) 0x003C)
/* MUX5 field mask & values */
#define CH5_CFG_MUX5_MASK ((uint16_t) 0x0003)
#define CH5_CFG_MUX5_AIN5P_AIN5N ((uint16_t) 0x0000 << 0) // DEFAULT
#define CH5_CFG_MUX5_ADC_INPUT_SHORT ((uint16_t) 0x0001 << 0)
#define CH5_CFG_MUX5_DC_DIAGNOSTIC ((uint16_t) 0x0002 << 0)
#define CH5_CFG_MUX5_AC_DIAGNOSTIC ((uint16_t) 0x0003 << 0)
/* Register 0x23 (CH5_OCAL_MSB) definition
* | OCAL5_MSB[15:0] |
/* CH5_OCAL_MSB register address & default value */
#define CH5_OCAL_MSB_ADDRESS ((uint8_t) 0x23)
#define CH5_OCAL_MSB_DEFAULT ((uint16_t) 0x0000)
/* OCAL5_MSB field mask & values */
#define CH5_OCAL_MSB_OCAL5_MSB_MASK ((uint16_t) 0xFFFF)
/* Register 0x24 (CH5_OCAL_LSB) definition
* | OCAL5_LSB[7:0] | RESERVED0[7:0] |
/* CH5_OCAL_LSB register address & default value */
#define CH5_OCAL_LSB_ADDRESS ((uint8_t) 0x24)
#define CH5_OCAL_LSB_DEFAULT ((uint16_t) 0x0000)
/* OCAL5_LSB field mask & values */
#define CH5_OCAL_LSB_OCAL5_LSB_MASK ((uint16_t) 0xFF00)
#define CH5_OCAL_LSB_RESERVED0_MASK ((uint16_t) 0x00FF)
/* Register 0x25 (CH5_GCAL_MSB) definition
* | GCAL5_MSB[15:0] |
/* CH5_GCAL_MSB register address & default value */
#define CH5_GCAL_MSB_ADDRESS ((uint8_t) 0x25)
#define CH5_GCAL_MSB_DEFAULT ((uint16_t) 0x8000)
/* GCAL5_MSB field mask & values */
#define CH5_GCAL_MSB_GCAL5_MSB_MASK ((uint16_t) 0xFFFF)
/* Register 0x26 (CH5_GCAL_LSB) definition
* | GCAL5_LSB[7:0] | RESERVED0[7:0] |
/* CH5_GCAL_LSB register address & default value */
#define CH5_GCAL_LSB_ADDRESS ((uint8_t) 0x26)
#define CH5_GCAL_LSB_DEFAULT ((uint16_t) 0x0000)
/* GCAL5_LSB field mask & values */
#define CH5_GCAL_LSB_GCAL5_LSB_MASK ((uint16_t) 0xFF00)
#define CH5_GCAL_LSB_RESERVED0_MASK ((uint16_t) 0x00FF)
#endif
/* Register 0x27 (CH6_CFG) definition
* | PHASE6[9:0] | RESERVED0[3:0] | MUX6[1:0] |
/* CH6_CFG register address & default value */
#define CH6_CFG_ADDRESS ((uint8_t) 0x27)
#define CH6_CFG_DEFAULT ((uint16_t) 0x0000)
/* PHASE6 field mask & values */
#define CH6_CFG_PHASE6_MASK ((uint16_t) 0xFFC0)
#define CH6_CFG_RESERVED0_MASK ((uint16_t) 0x003C)
/* MUX6 field mask & values */
#define CH6_CFG_MUX6_MASK ((uint16_t) 0x0003)
#define CH6_CFG_MUX6_AIN6P_AIN6N ((uint16_t) 0x0000 << 0) // DEFAULT
#define CH6_CFG_MUX6_ADC_INPUT_SHORT ((uint16_t) 0x0001 << 0)
#define CH6_CFG_MUX6_DC_DIAGNOSTIC ((uint16_t) 0x0002 << 0)
#define CH6_CFG_MUX6_AC_DIAGNOSTIC ((uint16_t) 0x0003 << 0)
/* Register 0x28 (CH6_OCAL_MSB) definition
* | OCAL6_MSB[15:0] |
/* CH6_OCAL_MSB register address & default value */
#define CH6_OCAL_MSB_ADDRESS ((uint8_t) 0x28)
#define CH6_OCAL_MSB_DEFAULT ((uint16_t) 0x0000)
/* OCAL6_MSB field mask & values */
#define CH6_OCAL_MSB_OCAL6_MSB_MASK ((uint16_t) 0xFFFF)
/* Register 0x29 (CH6_OCAL_LSB) definition
* | OCAL6_LSB[7:0] | RESERVED0[7:0] |
/* CH6_OCAL_LSB register address & default value */
#define CH6_OCAL_LSB_ADDRESS ((uint8_t) 0x29)
#define CH6_OCAL_LSB_DEFAULT ((uint16_t) 0x0000)
/* OCAL6_LSB field mask & values */
#define CH6_OCAL_LSB_OCAL6_LSB_MASK ((uint16_t) 0xFF00)
#define CH6_OCAL_LSB_RESERVED0_MASK ((uint16_t) 0x00FF)
/* Register 0x2A (CH6_GCAL_MSB) definition
* | GCAL6_MSB[15:0] |
/* CH6_GCAL_MSB register address & default value */
#define CH6_GCAL_MSB_ADDRESS ((uint8_t) 0x2A)
#define CH6_GCAL_MSB_DEFAULT ((uint16_t) 0x8000)
/* GCAL6_MSB field mask & values */
#define CH6_GCAL_MSB_GCAL6_MSB_MASK ((uint16_t) 0xFFFF)
/* Register 0x2B (CH6_GCAL_LSB) definition
* | GCAL6_LSB[7:0] | RESERVED0[7:0] |
/* CH6_GCAL_LSB register address & default value */
#define CH6_GCAL_LSB_ADDRESS ((uint8_t) 0x2B)
#define CH6_GCAL_LSB_DEFAULT ((uint16_t) 0x0000)
/* GCAL6_LSB field mask & values */
#define CH6_GCAL_LSB_GCAL6_LSB_MASK ((uint16_t) 0xFF00)
#define CH6_GCAL_LSB_RESERVED0_MASK ((uint16_t) 0x00FF)
#endif
/* Register 0x2C (CH7_CFG) definition
* | PHASE7[9:0] | RESERVED0[3:0] | MUX7[1:0] |
/* CH7_CFG register address & default value */
#define CH7_CFG_ADDRESS ((uint8_t) 0x2C)
#define CH7_CFG_DEFAULT ((uint16_t) 0x0000)
/* PHASE7 field mask & values */
#define CH7_CFG_PHASE7_MASK ((uint16_t) 0xFFC0)
#define CH7_CFG_RESERVED0_MASK ((uint16_t) 0x003C)
/* MUX7 field mask & values */
#define CH7_CFG_MUX7_MASK ((uint16_t) 0x0003)
#define CH7_CFG_MUX7_AIN7P_AIN7N ((uint16_t) 0x0000 << 0) // DEFAULT
#define CH7_CFG_MUX7_ADC_INPUT_SHORT ((uint16_t) 0x0001 << 0)
#define CH7_CFG_MUX7_DC_DIAGNOSTIC ((uint16_t) 0x0002 << 0)
#define CH7_CFG_MUX7_AC_DIAGNOSTIC ((uint16_t) 0x0003 << 0)
/* Register 0x2D (CH7_OCAL_MSB) definition
* | OCAL7_MSB[15:0] |
/* CH7_OCAL_MSB register address & default value */
#define CH7_OCAL_MSB_ADDRESS ((uint8_t) 0x2D)
#define CH7_OCAL_MSB_DEFAULT ((uint16_t) 0x0000)
/* OCAL7_MSB field mask & values */
#define CH7_OCAL_MSB_OCAL7_MSB_MASK ((uint16_t) 0xFFFF)
/* Register 0x2E (CH7_OCAL_LSB) definition
* | OCAL7_LSB[7:0] | RESERVED0[7:0] |
/* CH7_OCAL_LSB register address & default value */
#define CH7_OCAL_LSB_ADDRESS ((uint8_t) 0x2E)
#define CH7_OCAL_LSB_DEFAULT ((uint16_t) 0x0000)
/* OCAL7_LSB field mask & values */
#define CH7_OCAL_LSB_OCAL7_LSB_MASK ((uint16_t) 0xFF00)
#define CH7_OCAL_LSB_RESERVED0_MASK ((uint16_t) 0x00FF)
/* Register 0x2F (CH7_GCAL_MSB) definition
* | GCAL7_MSB[15:0] |
/* CH7_GCAL_MSB register address & default value */
#define CH7_GCAL_MSB_ADDRESS ((uint8_t) 0x2F)
#define CH7_GCAL_MSB_DEFAULT ((uint16_t) 0x8000)
/* GCAL7_MSB field mask & values */
#define CH7_GCAL_MSB_GCAL7_MSB_MASK ((uint16_t) 0xFFFF)
/* Register 0x30 (CH7_GCAL_LSB) definition
* | GCAL7_LSB[7:0] | RESERVED0[7:0] |
/* CH7_GCAL_LSB register address & default value */
#define CH7_GCAL_LSB_ADDRESS ((uint8_t) 0x30)
#define CH7_GCAL_LSB_DEFAULT ((uint16_t) 0x0000)
/* GCAL7_LSB field mask & values */
#define CH7_GCAL_LSB_GCAL7_LSB_MASK ((uint16_t) 0xFF00)
#define CH7_GCAL_LSB_RESERVED0_MASK ((uint16_t) 0x00FF)
#endif
/* Register 0x3E (REGMAP_CRC) definition
* | REG_CRC[15:0] |
/* REGMAP_CRC register address & default value */
#define REGMAP_CRC_ADDRESS ((uint8_t) 0x3E)
#define REGMAP_CRC_DEFAULT ((uint16_t) 0x0000)
/* REG_CRC field mask & values */
#define REGMAP_CRC_REG_CRC_MASK ((uint16_t) 0xFFFF)
// Channel data structure
typedef struct
uint16_t response;
uint16_t crc;
int32_t channel0;
int32_t channel1;
#endif
int32_t channel2;
#endif
int32_t channel3;
#endif
int32_t channel4;
#endif
int32_t channel5;
#endif
int32_t channel6;
#endif
int32_t channel7;
#endif
} adc_channel_data;
// Function prototypes
void adcStartup(void);
uint16_t sendCommand(uint16_t op_code);
bool readData(adc_channel_data *DataStruct);
uint16_t readSingleRegister(uint8_t address);
void writeSingleRegister(uint8_t address, uint16_t data);
bool lockRegisters(void);
bool unlockRegisters(void);
void resetDevice(void);
void restoreRegisterDefaults(void);
uint16_t calculateCRC(const uint8_t dataBytes[], uint8_t numberBytes, uint16_t initialValue);
// Getter functions
uint16_t getRegisterValue(uint8_t address);
// Helper functions
uint8_t upperByte(uint16_t uint16_Word);
uint8_t lowerByte(uint16_t uint16_Word);
uint16_t combineBytes(uint8_t upperByte, uint8_t lowerByte);
int32_t signExtend(const uint8_t dataBytes[]);
// Register macros
/** Returns Number of Channels */
#define CHANCNT ((uint8_t) ((getRegisterValue(ID_ADDRESS) & ID_CHANCNT_MASK) >> 8))
/** Revision ID bits */
#define REVISION_ID ((uint8_t) ((getRegisterValue(ID_ADDRESS) & ID_REVID_MASK) >> 0))
/** Returns true if SPI interface is locked */
#define SPI_LOCKED ((bool) (getRegisterValue(STATUS_ADDRESS) & STATUS_LOCK_LOCKED))
/** Returns SPI Communication Word Format*/
#define WLENGTH ((uint8_t) ((getRegisterValue(MODE_ADDRESS) & STATUS_WLENGTH_MASK) >> 8))
/** Returns true if Register Map CRC byte enable bit is set */
#define REGMAP_CRC_ENABLED ((bool) (getRegisterValue(MODE_ADDRESS) & MODE_REG_CRC_EN_ENABLED))
/** Returns true if SPI CRC byte enable bit is set */
#define SPI_CRC_ENABLED ((bool) (getRegisterValue(MODE_ADDRESS) & MODE_RX_CRC_EN_ENABLED))
/** Returns false for CCITT and true for ANSI CRC type */
#define SPI_CRC_TYPE ((bool) (getRegisterValue(MODE_ADDRESS) & MODE_CRC_TYPE_MASK))
/** Data rate register field setting */
#define OSR_INDEX ((uint8_t) ((getRegisterValue(CLOCK_ADDRESS) & CLOCK_OSR_MASK) >> 2))
#define POWER_MODE ((uint8_t) ((getRegisterValue(CLOCK_ADDRESS) & CLOCK_PWR_MASK) >> 0))
#endif /* ADS131M0X_H_ */
and the build report.
[0]**** Clean-only build of configuration Debug for project SPI_Try **** [1]"C:\\ti\\ccstheia140\\ccs\\utils\\bin\\gmake" -k -j 12 clean -O [2]DEL /F "device.cmd.genlibs" "ti_msp_dl_config.h" "Event.dot" "device_linker.cmd" "device.opt" "ti_msp_dl_config.c" "SPI_Try.out" [3]DEL /F "ti_msp_dl_config.o" "startup_mspm0l130x_ticlang.o" "SPI_try.o" "ti\driverlib\dl_adc12.o" "ti\driverlib\dl_aes.o" "ti\driverlib\dl_aesadv.o" "ti\driverlib\dl_common.o" "ti\driverlib\dl_crc.o" "ti\driverlib\dl_crcp.o" "ti\driverlib\dl_dac12.o" "ti\driverlib\dl_dma.o" "ti\driverlib\dl_flashctl.o" "ti\driverlib\dl_i2c.o" "ti\driverlib\dl_keystorectl.o" "ti\driverlib\dl_lcd.o" "ti\driverlib\dl_lfss.o" "ti\driverlib\dl_mathacl.o" "ti\driverlib\dl_mcan.o" "ti\driverlib\dl_opa.o" "ti\driverlib\dl_rtc_common.o" "ti\driverlib\dl_spi.o" "ti\driverlib\dl_timer.o" "ti\driverlib\dl_trng.o" "ti\driverlib\dl_uart.o" "ti\driverlib\dl_vref.o" "ti\driverlib\m0p\dl_interrupt.o" "ti\driverlib\m0p\sysctl\dl_sysctl_mspm0c110x.o" "ti\driverlib\m0p\sysctl\dl_sysctl_mspm0g1x0x_g3x0x.o" "ti\driverlib\m0p\sysctl\dl_sysctl_mspm0l11xx_l13xx.o" "ti\driverlib\m0p\sysctl\dl_sysctl_mspm0l122x_l222x.o" [4]DEL /F "ti_msp_dl_config.d" "startup_mspm0l130x_ticlang.d" "SPI_try.d" "ti\driverlib\dl_adc12.d" "ti\driverlib\dl_aes.d" "ti\driverlib\dl_aesadv.d" "ti\driverlib\dl_common.d" "ti\driverlib\dl_crc.d" "ti\driverlib\dl_crcp.d" "ti\driverlib\dl_dac12.d" "ti\driverlib\dl_dma.d" "ti\driverlib\dl_flashctl.d" "ti\driverlib\dl_i2c.d" "ti\driverlib\dl_keystorectl.d" "ti\driverlib\dl_lcd.d" "ti\driverlib\dl_lfss.d" "ti\driverlib\dl_mathacl.d" "ti\driverlib\dl_mcan.d" "ti\driverlib\dl_opa.d" "ti\driverlib\dl_rtc_common.d" "ti\driverlib\dl_spi.d" "ti\driverlib\dl_timer.d" "ti\driverlib\dl_trng.d" "ti\driverlib\dl_uart.d" "ti\driverlib\dl_vref.d" "ti\driverlib\m0p\dl_interrupt.d" "ti\driverlib\m0p\sysctl\dl_sysctl_mspm0c110x.d" "ti\driverlib\m0p\sysctl\dl_sysctl_mspm0g1x0x_g3x0x.d" "ti\driverlib\m0p\sysctl\dl_sysctl_mspm0l11xx_l13xx.d" "ti\driverlib\m0p\sysctl\dl_sysctl_mspm0l122x_l222x.d" [5]Finished clean [6]**** Build Finished **** [7]**** Build of configuration Debug for project SPI_Try **** [8]"C:\\ti\\ccstheia140\\ccs\\utils\\bin\\gmake" -k -j 12 all -O [9]Building file: "../SPI_Try.syscfg" [10]Invoking: SysConfig [11]"C:/ti/sysconfig_1.19.0/sysconfig_cli.bat" --script "C:/Users/rampr/workspace_ccstheia/SPI_Try/SPI_Try.syscfg" -o "." -s "C:/ti/mspm0_sdk_2_00_01_00/.metadata/product.json" --compiler ticlang [12]Running script... [13]Validating... [14]info: /ti/project_config/ProjectConfig deviceSpin: Note: User must select a device after migration. User must make sure to select the same device as the CCS Launch Device setting for proper configuration. [15]Generating Code (SPI_Try.syscfg)... [16]Writing C:\Users\rampr\workspace_ccstheia\SPI_Try\Debug\device_linker.cmd... [17]Writing C:\Users\rampr\workspace_ccstheia\SPI_Try\Debug\device.opt... [18]Writing C:\Users\rampr\workspace_ccstheia\SPI_Try\Debug\device.cmd.genlibs... [19]Writing C:\Users\rampr\workspace_ccstheia\SPI_Try\Debug\ti_msp_dl_config.c... [20]Writing C:\Users\rampr\workspace_ccstheia\SPI_Try\Debug\ti_msp_dl_config.h... [21]Writing C:\Users\rampr\workspace_ccstheia\SPI_Try\Debug\Event.dot... [22]Finished building: "../SPI_Try.syscfg" [23]Building file: "C:/ti/mspm0_sdk_2_00_01_00/source/ti/devices/msp/m0p/startup_system_files/ticlang/startup_mspm0l130x_ticlang.c" [24]Invoking: Arm Compiler [25]"C:/ti/ccstheia140/ccs/tools/compiler/ti-cgt-armllvm_3.2.2.LTS/bin/tiarmclang.exe" -c @"device.opt" -march=thumbv6m -mcpu=cortex-m0plus -mfloat-abi=soft -mlittle-endian -mthumb -O2 -I"C:/Users/rampr/workspace_ccstheia/SPI_Try" -I"C:/Users/rampr/workspace_ccstheia/SPI_Try/Debug" -I"C:/ti/mspm0_sdk_2_00_01_00/source/third_party/CMSIS/Core/Include" -I"C:/ti/mspm0_sdk_2_00_01_00/source" -gdwarf-3 -MMD -MP -MF"startup_mspm0l130x_ticlang.d_raw" -MT"startup_mspm0l130x_ticlang.o" @"./device.opt" -o"startup_mspm0l130x_ticlang.o" "C:/ti/mspm0_sdk_2_00_01_00/source/ti/devices/msp/m0p/startup_system_files/ticlang/startup_mspm0l130x_ticlang.c" [26]Finished building: "C:/ti/mspm0_sdk_2_00_01_00/source/ti/devices/msp/m0p/startup_system_files/ticlang/startup_mspm0l130x_ticlang.c" [27]Building file: "ti_msp_dl_config.c" [28]Invoking: Arm Compiler [29]"C:/ti/ccstheia140/ccs/tools/compiler/ti-cgt-armllvm_3.2.2.LTS/bin/tiarmclang.exe" -c @"device.opt" -march=thumbv6m -mcpu=cortex-m0plus -mfloat-abi=soft -mlittle-endian -mthumb -O2 -I"C:/Users/rampr/workspace_ccstheia/SPI_Try" -I"C:/Users/rampr/workspace_ccstheia/SPI_Try/Debug" -I"C:/ti/mspm0_sdk_2_00_01_00/source/third_party/CMSIS/Core/Include" -I"C:/ti/mspm0_sdk_2_00_01_00/source" -gdwarf-3 -MMD -MP -MF"ti_msp_dl_config.d_raw" -MT"ti_msp_dl_config.o" @"./device.opt" -o"ti_msp_dl_config.o" "ti_msp_dl_config.c" [30]Finished building: "ti_msp_dl_config.c" [31]Building file: "../SPI_try.c" [32]Invoking: Arm Compiler [33]"C:/ti/ccstheia140/ccs/tools/compiler/ti-cgt-armllvm_3.2.2.LTS/bin/tiarmclang.exe" -c @"device.opt" -march=thumbv6m -mcpu=cortex-m0plus -mfloat-abi=soft -mlittle-endian -mthumb -O2 -I"C:/Users/rampr/workspace_ccstheia/SPI_Try" -I"C:/Users/rampr/workspace_ccstheia/SPI_Try/Debug" -I"C:/ti/mspm0_sdk_2_00_01_00/source/third_party/CMSIS/Core/Include" -I"C:/ti/mspm0_sdk_2_00_01_00/source" -gdwarf-3 -MMD -MP -MF"SPI_try.d_raw" -MT"SPI_try.o" @"./device.opt" -o"SPI_try.o" "../SPI_try.c" [34]Finished building: "../SPI_try.c" [35]Building file: "../ti/driverlib/dl_adc12.c" [36]Invoking: Arm Compiler [37]"C:/ti/ccstheia140/ccs/tools/compiler/ti-cgt-armllvm_3.2.2.LTS/bin/tiarmclang.exe" -c @"device.opt" -march=thumbv6m -mcpu=cortex-m0plus -mfloat-abi=soft -mlittle-endian -mthumb -O2 -I"C:/Users/rampr/workspace_ccstheia/SPI_Try" -I"C:/Users/rampr/workspace_ccstheia/SPI_Try/Debug" -I"C:/ti/mspm0_sdk_2_00_01_00/source/third_party/CMSIS/Core/Include" -I"C:/ti/mspm0_sdk_2_00_01_00/source" -gdwarf-3 -MMD -MP -MF"ti/driverlib/dl_adc12.d_raw" -MT"ti/driverlib/dl_adc12.o" @"./device.opt" -o"ti/driverlib/dl_adc12.o" "../ti/driverlib/dl_adc12.c" [38]Finished building: "../ti/driverlib/dl_adc12.c" [39]Building file: "../ti/driverlib/dl_aes.c" [40]Invoking: Arm Compiler [41]"C:/ti/ccstheia140/ccs/tools/compiler/ti-cgt-armllvm_3.2.2.LTS/bin/tiarmclang.exe" -c @"device.opt" -march=thumbv6m -mcpu=cortex-m0plus -mfloat-abi=soft -mlittle-endian -mthumb -O2 -I"C:/Users/rampr/workspace_ccstheia/SPI_Try" -I"C:/Users/rampr/workspace_ccstheia/SPI_Try/Debug" -I"C:/ti/mspm0_sdk_2_00_01_00/source/third_party/CMSIS/Core/Include" -I"C:/ti/mspm0_sdk_2_00_01_00/source" -gdwarf-3 -MMD -MP -MF"ti/driverlib/dl_aes.d_raw" -MT"ti/driverlib/dl_aes.o" @"./device.opt" -o"ti/driverlib/dl_aes.o" "../ti/driverlib/dl_aes.c" [42]Finished building: "../ti/driverlib/dl_aes.c" [43]Building file: "../ti/driverlib/dl_aesadv.c" [44]Invoking: Arm Compiler [45]"C:/ti/ccstheia140/ccs/tools/compiler/ti-cgt-armllvm_3.2.2.LTS/bin/tiarmclang.exe" -c @"device.opt" -march=thumbv6m -mcpu=cortex-m0plus -mfloat-abi=soft -mlittle-endian -mthumb -O2 -I"C:/Users/rampr/workspace_ccstheia/SPI_Try" -I"C:/Users/rampr/workspace_ccstheia/SPI_Try/Debug" -I"C:/ti/mspm0_sdk_2_00_01_00/source/third_party/CMSIS/Core/Include" -I"C:/ti/mspm0_sdk_2_00_01_00/source" -gdwarf-3 -MMD -MP -MF"ti/driverlib/dl_aesadv.d_raw" -MT"ti/driverlib/dl_aesadv.o" @"./device.opt" -o"ti/driverlib/dl_aesadv.o" "../ti/driverlib/dl_aesadv.c" [46]Finished building: "../ti/driverlib/dl_aesadv.c" [47]Building file: "../ti/driverlib/dl_common.c" [48]Invoking: Arm Compiler [49]"C:/ti/ccstheia140/ccs/tools/compiler/ti-cgt-armllvm_3.2.2.LTS/bin/tiarmclang.exe" -c @"device.opt" -march=thumbv6m -mcpu=cortex-m0plus -mfloat-abi=soft -mlittle-endian -mthumb -O2 -I"C:/Users/rampr/workspace_ccstheia/SPI_Try" -I"C:/Users/rampr/workspace_ccstheia/SPI_Try/Debug" -I"C:/ti/mspm0_sdk_2_00_01_00/source/third_party/CMSIS/Core/Include" -I"C:/ti/mspm0_sdk_2_00_01_00/source" -gdwarf-3 -MMD -MP -MF"ti/driverlib/dl_common.d_raw" -MT"ti/driverlib/dl_common.o" @"./device.opt" -o"ti/driverlib/dl_common.o" "../ti/driverlib/dl_common.c" [50]Finished building: "../ti/driverlib/dl_common.c" [51]Building file: "../ti/driverlib/dl_crc.c" [52]Invoking: Arm Compiler [53]"C:/ti/ccstheia140/ccs/tools/compiler/ti-cgt-armllvm_3.2.2.LTS/bin/tiarmclang.exe" -c @"device.opt" -march=thumbv6m -mcpu=cortex-m0plus -mfloat-abi=soft -mlittle-endian -mthumb -O2 -I"C:/Users/rampr/workspace_ccstheia/SPI_Try" -I"C:/Users/rampr/workspace_ccstheia/SPI_Try/Debug" -I"C:/ti/mspm0_sdk_2_00_01_00/source/third_party/CMSIS/Core/Include" -I"C:/ti/mspm0_sdk_2_00_01_00/source" -gdwarf-3 -MMD -MP -MF"ti/driverlib/dl_crc.d_raw" -MT"ti/driverlib/dl_crc.o" @"./device.opt" -o"ti/driverlib/dl_crc.o" "../ti/driverlib/dl_crc.c" [54]Finished building: "../ti/driverlib/dl_crc.c" [55]Building file: "../ti/driverlib/dl_crcp.c" [56]Invoking: Arm Compiler [57]"C:/ti/ccstheia140/ccs/tools/compiler/ti-cgt-armllvm_3.2.2.LTS/bin/tiarmclang.exe" -c @"device.opt" -march=thumbv6m -mcpu=cortex-m0plus -mfloat-abi=soft -mlittle-endian -mthumb -O2 -I"C:/Users/rampr/workspace_ccstheia/SPI_Try" -I"C:/Users/rampr/workspace_ccstheia/SPI_Try/Debug" -I"C:/ti/mspm0_sdk_2_00_01_00/source/third_party/CMSIS/Core/Include" -I"C:/ti/mspm0_sdk_2_00_01_00/source" -gdwarf-3 -MMD -MP -MF"ti/driverlib/dl_crcp.d_raw" -MT"ti/driverlib/dl_crcp.o" @"./device.opt" -o"ti/driverlib/dl_crcp.o" "../ti/driverlib/dl_crcp.c" [58]Finished building: "../ti/driverlib/dl_crcp.c" [59]Building file: "../ti/driverlib/dl_dac12.c" [60]Invoking: Arm Compiler [61]"C:/ti/ccstheia140/ccs/tools/compiler/ti-cgt-armllvm_3.2.2.LTS/bin/tiarmclang.exe" -c @"device.opt" -march=thumbv6m -mcpu=cortex-m0plus -mfloat-abi=soft -mlittle-endian -mthumb -O2 -I"C:/Users/rampr/workspace_ccstheia/SPI_Try" -I"C:/Users/rampr/workspace_ccstheia/SPI_Try/Debug" -I"C:/ti/mspm0_sdk_2_00_01_00/source/third_party/CMSIS/Core/Include" -I"C:/ti/mspm0_sdk_2_00_01_00/source" -gdwarf-3 -MMD -MP -MF"ti/driverlib/dl_dac12.d_raw" -MT"ti/driverlib/dl_dac12.o" @"./device.opt" -o"ti/driverlib/dl_dac12.o" "../ti/driverlib/dl_dac12.c" [62]Finished building: "../ti/driverlib/dl_dac12.c" [63]Building file: "../ti/driverlib/dl_dma.c" [64]Invoking: Arm Compiler [65]"C:/ti/ccstheia140/ccs/tools/compiler/ti-cgt-armllvm_3.2.2.LTS/bin/tiarmclang.exe" -c @"device.opt" -march=thumbv6m -mcpu=cortex-m0plus -mfloat-abi=soft -mlittle-endian -mthumb -O2 -I"C:/Users/rampr/workspace_ccstheia/SPI_Try" -I"C:/Users/rampr/workspace_ccstheia/SPI_Try/Debug" -I"C:/ti/mspm0_sdk_2_00_01_00/source/third_party/CMSIS/Core/Include" -I"C:/ti/mspm0_sdk_2_00_01_00/source" -gdwarf-3 -MMD -MP -MF"ti/driverlib/dl_dma.d_raw" -MT"ti/driverlib/dl_dma.o" @"./device.opt" -o"ti/driverlib/dl_dma.o" "../ti/driverlib/dl_dma.c" [66]Finished building: "../ti/driverlib/dl_dma.c" [67]Building file: "../ti/driverlib/dl_flashctl.c" [68]Invoking: Arm Compiler [69]"C:/ti/ccstheia140/ccs/tools/compiler/ti-cgt-armllvm_3.2.2.LTS/bin/tiarmclang.exe" -c @"device.opt" -march=thumbv6m -mcpu=cortex-m0plus -mfloat-abi=soft -mlittle-endian -mthumb -O2 -I"C:/Users/rampr/workspace_ccstheia/SPI_Try" -I"C:/Users/rampr/workspace_ccstheia/SPI_Try/Debug" -I"C:/ti/mspm0_sdk_2_00_01_00/source/third_party/CMSIS/Core/Include" -I"C:/ti/mspm0_sdk_2_00_01_00/source" -gdwarf-3 -MMD -MP -MF"ti/driverlib/dl_flashctl.d_raw" -MT"ti/driverlib/dl_flashctl.o" @"./device.opt" -o"ti/driverlib/dl_flashctl.o" "../ti/driverlib/dl_flashctl.c" [70]Finished building: "../ti/driverlib/dl_flashctl.c" [71]Building file: "../ti/driverlib/dl_i2c.c" [72]Invoking: Arm Compiler [73]"C:/ti/ccstheia140/ccs/tools/compiler/ti-cgt-armllvm_3.2.2.LTS/bin/tiarmclang.exe" -c @"device.opt" -march=thumbv6m -mcpu=cortex-m0plus -mfloat-abi=soft -mlittle-endian -mthumb -O2 -I"C:/Users/rampr/workspace_ccstheia/SPI_Try" -I"C:/Users/rampr/workspace_ccstheia/SPI_Try/Debug" -I"C:/ti/mspm0_sdk_2_00_01_00/source/third_party/CMSIS/Core/Include" -I"C:/ti/mspm0_sdk_2_00_01_00/source" -gdwarf-3 -MMD -MP -MF"ti/driverlib/dl_i2c.d_raw" -MT"ti/driverlib/dl_i2c.o" @"./device.opt" -o"ti/driverlib/dl_i2c.o" "../ti/driverlib/dl_i2c.c" [74]Finished building: "../ti/driverlib/dl_i2c.c" [75]Building file: "../ti/driverlib/dl_lcd.c" [76]Invoking: Arm Compiler [77]"C:/ti/ccstheia140/ccs/tools/compiler/ti-cgt-armllvm_3.2.2.LTS/bin/tiarmclang.exe" -c @"device.opt" -march=thumbv6m -mcpu=cortex-m0plus -mfloat-abi=soft -mlittle-endian -mthumb -O2 -I"C:/Users/rampr/workspace_ccstheia/SPI_Try" -I"C:/Users/rampr/workspace_ccstheia/SPI_Try/Debug" -I"C:/ti/mspm0_sdk_2_00_01_00/source/third_party/CMSIS/Core/Include" -I"C:/ti/mspm0_sdk_2_00_01_00/source" -gdwarf-3 -MMD -MP -MF"ti/driverlib/dl_lcd.d_raw" -MT"ti/driverlib/dl_lcd.o" @"./device.opt" -o"ti/driverlib/dl_lcd.o" "../ti/driverlib/dl_lcd.c" [78]Finished building: "../ti/driverlib/dl_lcd.c" [79]Building file: "../ti/driverlib/dl_keystorectl.c" [80]Invoking: Arm Compiler [81]"C:/ti/ccstheia140/ccs/tools/compiler/ti-cgt-armllvm_3.2.2.LTS/bin/tiarmclang.exe" -c @"device.opt" -march=thumbv6m -mcpu=cortex-m0plus -mfloat-abi=soft -mlittle-endian -mthumb -O2 -I"C:/Users/rampr/workspace_ccstheia/SPI_Try" -I"C:/Users/rampr/workspace_ccstheia/SPI_Try/Debug" -I"C:/ti/mspm0_sdk_2_00_01_00/source/third_party/CMSIS/Core/Include" -I"C:/ti/mspm0_sdk_2_00_01_00/source" -gdwarf-3 -MMD -MP -MF"ti/driverlib/dl_keystorectl.d_raw" -MT"ti/driverlib/dl_keystorectl.o" @"./device.opt" -o"ti/driverlib/dl_keystorectl.o" "../ti/driverlib/dl_keystorectl.c" [82]Finished building: "../ti/driverlib/dl_keystorectl.c" [83]Building file: "../ti/driverlib/dl_lfss.c" [84]Invoking: Arm Compiler [85]"C:/ti/ccstheia140/ccs/tools/compiler/ti-cgt-armllvm_3.2.2.LTS/bin/tiarmclang.exe" -c @"device.opt" -march=thumbv6m -mcpu=cortex-m0plus -mfloat-abi=soft -mlittle-endian -mthumb -O2 -I"C:/Users/rampr/workspace_ccstheia/SPI_Try" -I"C:/Users/rampr/workspace_ccstheia/SPI_Try/Debug" -I"C:/ti/mspm0_sdk_2_00_01_00/source/third_party/CMSIS/Core/Include" -I"C:/ti/mspm0_sdk_2_00_01_00/source" -gdwarf-3 -MMD -MP -MF"ti/driverlib/dl_lfss.d_raw" -MT"ti/driverlib/dl_lfss.o" @"./device.opt" -o"ti/driverlib/dl_lfss.o" "../ti/driverlib/dl_lfss.c" [86]Finished building: "../ti/driverlib/dl_lfss.c" [87]Building file: "../ti/driverlib/dl_mathacl.c" [88]Invoking: Arm Compiler [89]"C:/ti/ccstheia140/ccs/tools/compiler/ti-cgt-armllvm_3.2.2.LTS/bin/tiarmclang.exe" -c @"device.opt" -march=thumbv6m -mcpu=cortex-m0plus -mfloat-abi=soft -mlittle-endian -mthumb -O2 -I"C:/Users/rampr/workspace_ccstheia/SPI_Try" -I"C:/Users/rampr/workspace_ccstheia/SPI_Try/Debug" -I"C:/ti/mspm0_sdk_2_00_01_00/source/third_party/CMSIS/Core/Include" -I"C:/ti/mspm0_sdk_2_00_01_00/source" -gdwarf-3 -MMD -MP -MF"ti/driverlib/dl_mathacl.d_raw" -MT"ti/driverlib/dl_mathacl.o" @"./device.opt" -o"ti/driverlib/dl_mathacl.o" "../ti/driverlib/dl_mathacl.c" [90]Finished building: "../ti/driverlib/dl_mathacl.c" [91]Building file: "../ti/driverlib/dl_mcan.c" [92]Invoking: Arm Compiler [93]"C:/ti/ccstheia140/ccs/tools/compiler/ti-cgt-armllvm_3.2.2.LTS/bin/tiarmclang.exe" -c @"device.opt" -march=thumbv6m -mcpu=cortex-m0plus -mfloat-abi=soft -mlittle-endian -mthumb -O2 -I"C:/Users/rampr/workspace_ccstheia/SPI_Try" -I"C:/Users/rampr/workspace_ccstheia/SPI_Try/Debug" -I"C:/ti/mspm0_sdk_2_00_01_00/source/third_party/CMSIS/Core/Include" -I"C:/ti/mspm0_sdk_2_00_01_00/source" -gdwarf-3 -MMD -MP -MF"ti/driverlib/dl_mcan.d_raw" -MT"ti/driverlib/dl_mcan.o" @"./device.opt" -o"ti/driverlib/dl_mcan.o" "../ti/driverlib/dl_mcan.c" [94]Finished building: "../ti/driverlib/dl_mcan.c" [95]Building file: "../ti/driverlib/dl_opa.c" [96]Invoking: Arm Compiler [97]"C:/ti/ccstheia140/ccs/tools/compiler/ti-cgt-armllvm_3.2.2.LTS/bin/tiarmclang.exe" -c @"device.opt" -march=thumbv6m -mcpu=cortex-m0plus -mfloat-abi=soft -mlittle-endian -mthumb -O2 -I"C:/Users/rampr/workspace_ccstheia/SPI_Try" -I"C:/Users/rampr/workspace_ccstheia/SPI_Try/Debug" -I"C:/ti/mspm0_sdk_2_00_01_00/source/third_party/CMSIS/Core/Include" -I"C:/ti/mspm0_sdk_2_00_01_00/source" -gdwarf-3 -MMD -MP -MF"ti/driverlib/dl_opa.d_raw" -MT"ti/driverlib/dl_opa.o" @"./device.opt" -o"ti/driverlib/dl_opa.o" "../ti/driverlib/dl_opa.c" [98]Finished building: "../ti/driverlib/dl_opa.c" [99]Building file: "../ti/driverlib/dl_rtc_common.c" [100]Invoking: Arm Compiler [101]"C:/ti/ccstheia140/ccs/tools/compiler/ti-cgt-armllvm_3.2.2.LTS/bin/tiarmclang.exe" -c @"device.opt" -march=thumbv6m -mcpu=cortex-m0plus -mfloat-abi=soft -mlittle-endian -mthumb -O2 -I"C:/Users/rampr/workspace_ccstheia/SPI_Try" -I"C:/Users/rampr/workspace_ccstheia/SPI_Try/Debug" -I"C:/ti/mspm0_sdk_2_00_01_00/source/third_party/CMSIS/Core/Include" -I"C:/ti/mspm0_sdk_2_00_01_00/source" -gdwarf-3 -MMD -MP -MF"ti/driverlib/dl_rtc_common.d_raw" -MT"ti/driverlib/dl_rtc_common.o" @"./device.opt" -o"ti/driverlib/dl_rtc_common.o" "../ti/driverlib/dl_rtc_common.c" [102]Finished building: "../ti/driverlib/dl_rtc_common.c" [103]Building file: "../ti/driverlib/dl_spi.c" [104]Invoking: Arm Compiler [105]"C:/ti/ccstheia140/ccs/tools/compiler/ti-cgt-armllvm_3.2.2.LTS/bin/tiarmclang.exe" -c @"device.opt" -march=thumbv6m -mcpu=cortex-m0plus -mfloat-abi=soft -mlittle-endian -mthumb -O2 -I"C:/Users/rampr/workspace_ccstheia/SPI_Try" -I"C:/Users/rampr/workspace_ccstheia/SPI_Try/Debug" -I"C:/ti/mspm0_sdk_2_00_01_00/source/third_party/CMSIS/Core/Include" -I"C:/ti/mspm0_sdk_2_00_01_00/source" -gdwarf-3 -MMD -MP -MF"ti/driverlib/dl_spi.d_raw" -MT"ti/driverlib/dl_spi.o" @"./device.opt" -o"ti/driverlib/dl_spi.o" "../ti/driverlib/dl_spi.c" [106]Finished building: "../ti/driverlib/dl_spi.c" [107]Building file: "../ti/driverlib/dl_timer.c" [108]Invoking: Arm Compiler [109]"C:/ti/ccstheia140/ccs/tools/compiler/ti-cgt-armllvm_3.2.2.LTS/bin/tiarmclang.exe" -c @"device.opt" -march=thumbv6m -mcpu=cortex-m0plus -mfloat-abi=soft -mlittle-endian -mthumb -O2 -I"C:/Users/rampr/workspace_ccstheia/SPI_Try" -I"C:/Users/rampr/workspace_ccstheia/SPI_Try/Debug" -I"C:/ti/mspm0_sdk_2_00_01_00/source/third_party/CMSIS/Core/Include" -I"C:/ti/mspm0_sdk_2_00_01_00/source" -gdwarf-3 -MMD -MP -MF"ti/driverlib/dl_timer.d_raw" -MT"ti/driverlib/dl_timer.o" @"./device.opt" -o"ti/driverlib/dl_timer.o" "../ti/driverlib/dl_timer.c" [110]Finished building: "../ti/driverlib/dl_timer.c" [111]Building file: "../ti/driverlib/dl_trng.c" [112]Invoking: Arm Compiler [113]"C:/ti/ccstheia140/ccs/tools/compiler/ti-cgt-armllvm_3.2.2.LTS/bin/tiarmclang.exe" -c @"device.opt" -march=thumbv6m -mcpu=cortex-m0plus -mfloat-abi=soft -mlittle-endian -mthumb -O2 -I"C:/Users/rampr/workspace_ccstheia/SPI_Try" -I"C:/Users/rampr/workspace_ccstheia/SPI_Try/Debug" -I"C:/ti/mspm0_sdk_2_00_01_00/source/third_party/CMSIS/Core/Include" -I"C:/ti/mspm0_sdk_2_00_01_00/source" -gdwarf-3 -MMD -MP -MF"ti/driverlib/dl_trng.d_raw" -MT"ti/driverlib/dl_trng.o" @"./device.opt" -o"ti/driverlib/dl_trng.o" "../ti/driverlib/dl_trng.c" [114]Finished building: "../ti/driverlib/dl_trng.c" [115]Building file: "../ti/driverlib/dl_uart.c" [116]Invoking: Arm Compiler [117]"C:/ti/ccstheia140/ccs/tools/compiler/ti-cgt-armllvm_3.2.2.LTS/bin/tiarmclang.exe" -c @"device.opt" -march=thumbv6m -mcpu=cortex-m0plus -mfloat-abi=soft -mlittle-endian -mthumb -O2 -I"C:/Users/rampr/workspace_ccstheia/SPI_Try" -I"C:/Users/rampr/workspace_ccstheia/SPI_Try/Debug" -I"C:/ti/mspm0_sdk_2_00_01_00/source/third_party/CMSIS/Core/Include" -I"C:/ti/mspm0_sdk_2_00_01_00/source" -gdwarf-3 -MMD -MP -MF"ti/driverlib/dl_uart.d_raw" -MT"ti/driverlib/dl_uart.o" @"./device.opt" -o"ti/driverlib/dl_uart.o" "../ti/driverlib/dl_uart.c" [118]Finished building: "../ti/driverlib/dl_uart.c" [119]Building file: "../ti/driverlib/dl_vref.c" [120]Invoking: Arm Compiler [121]"C:/ti/ccstheia140/ccs/tools/compiler/ti-cgt-armllvm_3.2.2.LTS/bin/tiarmclang.exe" -c @"device.opt" -march=thumbv6m -mcpu=cortex-m0plus -mfloat-abi=soft -mlittle-endian -mthumb -O2 -I"C:/Users/rampr/workspace_ccstheia/SPI_Try" -I"C:/Users/rampr/workspace_ccstheia/SPI_Try/Debug" -I"C:/ti/mspm0_sdk_2_00_01_00/source/third_party/CMSIS/Core/Include" -I"C:/ti/mspm0_sdk_2_00_01_00/source" -gdwarf-3 -MMD -MP -MF"ti/driverlib/dl_vref.d_raw" -MT"ti/driverlib/dl_vref.o" @"./device.opt" -o"ti/driverlib/dl_vref.o" "../ti/driverlib/dl_vref.c" [122]Finished building: "../ti/driverlib/dl_vref.c" [123]Building file: "../ti/driverlib/m0p/sysctl/dl_sysctl_mspm0c110x.c" [124]Invoking: Arm Compiler [125]"C:/ti/ccstheia140/ccs/tools/compiler/ti-cgt-armllvm_3.2.2.LTS/bin/tiarmclang.exe" -c @"device.opt" -march=thumbv6m -mcpu=cortex-m0plus -mfloat-abi=soft -mlittle-endian -mthumb -O2 -I"C:/Users/rampr/workspace_ccstheia/SPI_Try" -I"C:/Users/rampr/workspace_ccstheia/SPI_Try/Debug" -I"C:/ti/mspm0_sdk_2_00_01_00/source/third_party/CMSIS/Core/Include" -I"C:/ti/mspm0_sdk_2_00_01_00/source" -gdwarf-3 -MMD -MP -MF"ti/driverlib/m0p/sysctl/dl_sysctl_mspm0c110x.d_raw" -MT"ti/driverlib/m0p/sysctl/dl_sysctl_mspm0c110x.o" @"./device.opt" -o"ti/driverlib/m0p/sysctl/dl_sysctl_mspm0c110x.o" "../ti/driverlib/m0p/sysctl/dl_sysctl_mspm0c110x.c" [126]Finished building: "../ti/driverlib/m0p/sysctl/dl_sysctl_mspm0c110x.c" [127]Building file: "../ti/driverlib/m0p/dl_interrupt.c" [128]Invoking: Arm Compiler [129]"C:/ti/ccstheia140/ccs/tools/compiler/ti-cgt-armllvm_3.2.2.LTS/bin/tiarmclang.exe" -c @"device.opt" -march=thumbv6m -mcpu=cortex-m0plus -mfloat-abi=soft -mlittle-endian -mthumb -O2 -I"C:/Users/rampr/workspace_ccstheia/SPI_Try" -I"C:/Users/rampr/workspace_ccstheia/SPI_Try/Debug" -I"C:/ti/mspm0_sdk_2_00_01_00/source/third_party/CMSIS/Core/Include" -I"C:/ti/mspm0_sdk_2_00_01_00/source" -gdwarf-3 -MMD -MP -MF"ti/driverlib/m0p/dl_interrupt.d_raw" -MT"ti/driverlib/m0p/dl_interrupt.o" @"./device.opt" -o"ti/driverlib/m0p/dl_interrupt.o" "../ti/driverlib/m0p/dl_interrupt.c" [130]Finished building: "../ti/driverlib/m0p/dl_interrupt.c" [131]Building file: "../ti/driverlib/m0p/sysctl/dl_sysctl_mspm0g1x0x_g3x0x.c" [132]Invoking: Arm Compiler [133]"C:/ti/ccstheia140/ccs/tools/compiler/ti-cgt-armllvm_3.2.2.LTS/bin/tiarmclang.exe" -c @"device.opt" -march=thumbv6m -mcpu=cortex-m0plus -mfloat-abi=soft -mlittle-endian -mthumb -O2 -I"C:/Users/rampr/workspace_ccstheia/SPI_Try" -I"C:/Users/rampr/workspace_ccstheia/SPI_Try/Debug" -I"C:/ti/mspm0_sdk_2_00_01_00/source/third_party/CMSIS/Core/Include" -I"C:/ti/mspm0_sdk_2_00_01_00/source" -gdwarf-3 -MMD -MP -MF"ti/driverlib/m0p/sysctl/dl_sysctl_mspm0g1x0x_g3x0x.d_raw" -MT"ti/driverlib/m0p/sysctl/dl_sysctl_mspm0g1x0x_g3x0x.o" @"./device.opt" -o"ti/driverlib/m0p/sysctl/dl_sysctl_mspm0g1x0x_g3x0x.o" "../ti/driverlib/m0p/sysctl/dl_sysctl_mspm0g1x0x_g3x0x.c" [134]Finished building: "../ti/driverlib/m0p/sysctl/dl_sysctl_mspm0g1x0x_g3x0x.c" [135]Building file: "../ti/driverlib/m0p/sysctl/dl_sysctl_mspm0l11xx_l13xx.c" [136]Invoking: Arm Compiler [137]"C:/ti/ccstheia140/ccs/tools/compiler/ti-cgt-armllvm_3.2.2.LTS/bin/tiarmclang.exe" -c @"device.opt" -march=thumbv6m -mcpu=cortex-m0plus -mfloat-abi=soft -mlittle-endian -mthumb -O2 -I"C:/Users/rampr/workspace_ccstheia/SPI_Try" -I"C:/Users/rampr/workspace_ccstheia/SPI_Try/Debug" -I"C:/ti/mspm0_sdk_2_00_01_00/source/third_party/CMSIS/Core/Include" -I"C:/ti/mspm0_sdk_2_00_01_00/source" -gdwarf-3 -MMD -MP -MF"ti/driverlib/m0p/sysctl/dl_sysctl_mspm0l11xx_l13xx.d_raw" -MT"ti/driverlib/m0p/sysctl/dl_sysctl_mspm0l11xx_l13xx.o" @"./device.opt" -o"ti/driverlib/m0p/sysctl/dl_sysctl_mspm0l11xx_l13xx.o" "../ti/driverlib/m0p/sysctl/dl_sysctl_mspm0l11xx_l13xx.c" [138]Finished building: "../ti/driverlib/m0p/sysctl/dl_sysctl_mspm0l11xx_l13xx.c" [139]Building file: "../ti/driverlib/m0p/sysctl/dl_sysctl_mspm0l122x_l222x.c" [140]Invoking: Arm Compiler [141]"C:/ti/ccstheia140/ccs/tools/compiler/ti-cgt-armllvm_3.2.2.LTS/bin/tiarmclang.exe" -c @"device.opt" -march=thumbv6m -mcpu=cortex-m0plus -mfloat-abi=soft -mlittle-endian -mthumb -O2 -I"C:/Users/rampr/workspace_ccstheia/SPI_Try" -I"C:/Users/rampr/workspace_ccstheia/SPI_Try/Debug" -I"C:/ti/mspm0_sdk_2_00_01_00/source/third_party/CMSIS/Core/Include" -I"C:/ti/mspm0_sdk_2_00_01_00/source" -gdwarf-3 -MMD -MP -MF"ti/driverlib/m0p/sysctl/dl_sysctl_mspm0l122x_l222x.d_raw" -MT"ti/driverlib/m0p/sysctl/dl_sysctl_mspm0l122x_l222x.o" @"./device.opt" -o"ti/driverlib/m0p/sysctl/dl_sysctl_mspm0l122x_l222x.o" "../ti/driverlib/m0p/sysctl/dl_sysctl_mspm0l122x_l222x.c" [142]Finished building: "../ti/driverlib/m0p/sysctl/dl_sysctl_mspm0l122x_l222x.c" [143]Building target: "SPI_Try.out" [144]Invoking: Arm Linker [145]"C:/ti/ccstheia140/ccs/tools/compiler/ti-cgt-armllvm_3.2.2.LTS/bin/tiarmclang.exe" @"device.opt" -march=thumbv6m -mcpu=cortex-m0plus -mfloat-abi=soft -mlittle-endian -mthumb -O2 -gdwarf-3 -Wl,-m"SPI_Try.map" -Wl,-i"C:/ti/mspm0_sdk_2_00_01_00/source" -Wl,-i"C:/Users/rampr/workspace_ccstheia/SPI_Try" -Wl,-i"C:/Users/rampr/workspace_ccstheia/SPI_Try/Debug/syscfg" -Wl,-i"C:/ti/ccstheia140/ccs/tools/compiler/ti-cgt-armllvm_3.2.2.LTS/lib" -Wl,--diag_wrap=off -Wl,--display_error_number -Wl,--warn_sections -Wl,--xml_link_info="SPI_Try_linkInfo.xml" -Wl,--rom_model -o "SPI_Try.out" "./ti_msp_dl_config.o" "./startup_mspm0l130x_ticlang.o" "./SPI_try.o" "./ti/driverlib/dl_adc12.o" "./ti/driverlib/dl_aes.o" "./ti/driverlib/dl_aesadv.o" "./ti/driverlib/dl_common.o" "./ti/driverlib/dl_crc.o" "./ti/driverlib/dl_crcp.o" "./ti/driverlib/dl_dac12.o" "./ti/driverlib/dl_dma.o" "./ti/driverlib/dl_flashctl.o" "./ti/driverlib/dl_i2c.o" "./ti/driverlib/dl_keystorectl.o" "./ti/driverlib/dl_lcd.o" "./ti/driverlib/dl_lfss.o" "./ti/driverlib/dl_mathacl.o" "./ti/driverlib/dl_mcan.o" "./ti/driverlib/dl_opa.o" "./ti/driverlib/dl_rtc_common.o" "./ti/driverlib/dl_spi.o" "./ti/driverlib/dl_timer.o" "./ti/driverlib/dl_trng.o" "./ti/driverlib/dl_uart.o" "./ti/driverlib/dl_vref.o" "./ti/driverlib/m0p/dl_interrupt.o" "./ti/driverlib/m0p/sysctl/dl_sysctl_mspm0c110x.o" "./ti/driverlib/m0p/sysctl/dl_sysctl_mspm0g1x0x_g3x0x.o" "./ti/driverlib/m0p/sysctl/dl_sysctl_mspm0l11xx_l13xx.o" "./ti/driverlib/m0p/sysctl/dl_sysctl_mspm0l122x_l222x.o" -Wl,-l"./device_linker.cmd" -Wl,-ldevice.cmd.genlibs -Wl,-llibc.a [146]makefile:170: recipe for target 'SPI_Try.out' failed [147] undefined first referenced [148] symbol in file [149] --------- ---------------- [150] getRegisterValue ./SPI_try.o [151] lowerByte ./SPI_try.o [152] upperByte ./SPI_try.o [153]error #10234-D: unresolved symbols remain [154]error #10010: errors encountered during linking; "SPI_Try.out" not built [155]tiarmclang: error: tiarmlnk command failed with exit code 1 (use -v to see invocation) [156]gmake[1]: *** [SPI_Try.out] Error 1 [157]makefile:166: recipe for target 'all' failed [158]gmake: *** [all] Error 2 [159]**** Build Finished ****
