CCS installing for the first time
Hi everyone.
I would really appreciate if anybody could help me somehow:
After downloading an exe-file (ccs_setup_5.1.0.08012) and entering it I got an error-window:
Does anybody know what is it connected with?
  • Alyona,
    Is this the lightweight installer or the full package?
    John
  • This is the lightweight installer (for Windows)
  • Alyona,
    You can probably work around this by downloading the full installer.  It seems like a problem with the installer not being able to connect to the TI site.
    Before you do that could you zip up the contents of C:\Program Files (x86)\InstallJammer Registry\ccsv5 OR C:\Program Files\InstallJammer Registry\ccsv5 depending on if you are 32bit or 64bit windows.  The log files contained there may confirm for us what is going on.
    John
  • Ok, the option of full installer is always available.
    Also currently we can look at log-file, truly there can be an answer (actually mine competence is not enough to find it by myself)
    ------ CCSv5_5.1.0.08012 Installation -------------
    10/06/2011 13:52:05PM -
    10/06/2011 13:52:05PM - InstallID      : 20819E5C-EC7B-40AD-BC45-1525574F1656
    10/06/2011 13:52:05PM - Installer      : C:\ alyona.nikiforova\Прочее\Programs\ccs_setup_5.1.0.08012.exe
    10/06/2011 13:52:05PM - Install version: 5.1.0.08012
    10/06/2011 13:52:05PM - Install source : C:\ alyona.nikiforova\Прочее\Programs
    10/06/2011 13:52:05PM - OS             : Windows
    10/06/2011 13:52:05PM - UserName       :	admin14
    10/06/2011 13:52:05PM - Update?        :	0
    10/06/2011 13:52:05PM - Command line   :/installkitvfs/main.tcl
    10/06/2011 13:52:05PM - Checking conditions for F0A046CD-8A59-4F7D-B025-7ED78FD8C0F3 - Execute Response File Action - Before Action is Executed
    10/06/2011 13:52:05PM - Checking condition C434E3F3-C405-466D-9713-A8F99B3BCC12 - Command Line Test Condition
    10/06/2011 13:52:05PM - Checking to see if response-file was passed on the command line
    10/06/2011 13:52:05PM - Condition failed
    10/06/2011 13:52:05PM - Skipping action F0A046CD-8A59-4F7D-B025-7ED78FD8C0F3 - Execute Response File Action - conditions failed
    10/06/2011 13:52:05PM - Checking conditions for 73286838-ADC5-44C6-9BF4-3D00C32317F7 - Set Windows information - Before Action is Executed
    10/06/2011 13:52:05PM - Checking condition DDEDDBE3-895A-4F08-B242-B5CEB39360F2 - Platform Condition
    10/06/2011 13:52:05PM - Checking to see if <%Platform%> is Windows
    10/06/2011 13:52:05PM - ** Checking to see if Windows is Windows
    10/06/2011 13:52:05PM - Condition passed
    10/06/2011 13:52:05PM - Executing action 73286838-ADC5-44C6-9BF4-3D00C32317F7 - Set Windows information
    10/06/2011 13:52:05PM - Checking System Info...
    10/06/2011 13:52:05PM - WindowsProductName=
    ! REG.EXE VERSION 3.0
    HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows NT\CurrentVersion
        ProductName	REG_SZ	Microsoft Windows XP
      WindowsCurrentVersion= 5.1
      WindowsCSDVersionString= Service Pack 2
      WindowsCSDVersionDWord= 512
      WindowsPlatform= WinXP
    10/06/2011 13:52:05PM - Checking conditions for 181F69AF-2B9D-44EF-B0B0-84126765120A - Remove common\bin from path (Windows) - Before Action is Executed
    10/06/2011 13:52:05PM - Checking condition 858075F5-D830-482D-A8EC-BBB15C017286 - Platform Condition
    10/06/2011 13:52:05PM - Checking condition 43D9D511-78C1-464A-909B-B7258F10652B - String Is Condition
    10/06/2011 13:52:05PM - Checking to see if <%Native_Eclipse_Selected%> is false
    10/06/2011 13:52:05PM - ** Checking to see if false is false
    10/06/2011 13:52:05PM - Executing action 181F69AF-2B9D-44EF-B0B0-84126765120A - Remove common\bin from path (Windows)
    10/06/2011 13:52:05PM - path is {c:\program files\manzanita systems\mp2tsae demo 5}
    10/06/2011 13:52:05PM - Setting active setup type to New Setup Type (B6E0CE8C-4E6F-4885-953A-32946A051105).
    10/06/2011 13:52:05PM - Activating component D253A697-7480-46F3-AF71-AB63991129FD
    10/06/2011 13:52:05PM - Executing actions A0AAD47D-43D9-43F8-9439-47A03F6F4E2B - Startup Actions
    10/06/2011 13:52:05PM - Executing action 1C82CB44-08EC-4BAE-BCF7-719902E9C236 - Execute Windows Startup
    10/06/2011 13:52:05PM - Checking conditions for AED7E1E0-3E40-41B5-A471-FAAFD73529F8 - Windows Startup Action - Before Action is Executed
    10/06/2011 13:52:05PM - Checking condition BDCBFA61-EF65-4DF4-A4C3-1CD5758BDD79 - Platform Condition
    10/06/2011 13:52:05PM - Executing actions AED7E1E0-3E40-41B5-A471-FAAFD73529F8 - Windows Startup Action
    10/06/2011 13:52:05PM - Executing action C4D1AB2C-8D0E-4AF0-BA43-2DF6CA3D3A1C - Check Memory
    10/06/2011 13:52:05PM - Checking Memory...
    10/06/2011 13:52:05PM - Checking conditions for 98FB6613-1F73-4BCB-8DDB-B431EBD71496 - Exit if no access to TEMP dir  - Before Action is Executed
    10/06/2011 13:52:05PM - Checking condition 17D28D55-F95F-4DD0-AC94-EF4CDE6400D2 - Execute Script Condition
    10/06/2011 13:52:05PM - C:/DOCUME~1/admin14/LOCALS~1/Temp is writable ? 1 or  1
    10/06/2011 13:52:05PM - C:/DOCUME~1/admin14/LOCALS~1/Temp/ijtmp_4AED92E6-18C3-46D6-A67D-5AC78CD9B884 exists? 1
    10/06/2011 13:52:05PM - C:/DOCUME~1/admin14/LOCALS~1/Temp/ijtmp_4AED92E6-18C3-46D6-A67D-5AC78CD9B884 is writable ? 1
    10/06/2011 13:52:05PM - making C:/DOCUME~1/admin14/LOCALS~1/Temp/ijtmp_4AED92E6-18C3-46D6-A67D-5AC78CD9B884/baserepo
    10/06/2011 13:52:05PM - Skipping action 98FB6613-1F73-4BCB-8DDB-B431EBD71496 - Exit if no access to TEMP dir  - conditions failed
    10/06/2011 13:52:05PM - Checking conditions for 390AFA53-7D35-4C26-A453-27B7CEBB834E - Unpack Setup xml file - Before Action is Executed
    10/06/2011 13:52:05PM - Checking condition AB402A5E-1927-4722-B563-CAF54B6E53AA - Platform Condition
    10/06/2011 13:52:05PM - Executing action 390AFA53-7D35-4C26-A453-27B7CEBB834E - Unpack Setup xml file
    10/06/2011 13:52:05PM - Unpacking C:/DOCUME~1/admin14/LOCALS~1/Temp/ijtmp_4AED92E6-18C3-46D6-A67D-5AC78CD9B884/ccs_installini.xml
    10/06/2011 13:52:05PM - Checking conditions for F4C790E5-5B05-43B4-ABC4-B4B9C1C01A59 - Unpack Setup xml file - Before Action is Executed
    10/06/2011 13:52:05PM - Checking condition D1A276F0-17F4-498A-B707-E9B7CDAF7109 - Platform Condition
    10/06/2011 13:52:05PM - Checking to see if <%Platform%> is Linux-x86
    10/06/2011 13:52:05PM - ** Checking to see if Windows is Linux-x86
    10/06/2011 13:52:05PM - Skipping action F4C790E5-5B05-43B4-ABC4-B4B9C1C01A59 - Unpack Setup xml file - conditions failed
    10/06/2011 13:52:05PM - Executing action C325767C-1961-4AB1-8037-7C19CB4BA543 - Get Setup Types
    10/06/2011 13:52:05PM - here: Custom ISA,FEATURE,EMU
    10/06/2011 13:52:05PM - here: Complete Feature Set EMU
    10/06/2011 13:52:05PM - editionpanes = ISA,FEATURE,EMU EMU
    10/06/2011 13:52:05PM - Checking conditions for 25BA989D-274D-4302-A91E-48B8454834E4 - Unpack Manifest xml file - Before Action is Executed
    10/06/2011 13:52:05PM - Checking condition 45766827-6E1C-43A5-AE55-3EDC12383C2C - Platform Condition
    10/06/2011 13:52:05PM - Skipping action 25BA989D-274D-4302-A91E-48B8454834E4 - Unpack Manifest xml file - conditions failed
    10/06/2011 13:52:05PM - Checking conditions for 1C65743D-E0A5-4787-B152-3A21723C2002 - Unpack Manifest xml file - Before Action is Executed
    10/06/2011 13:52:05PM - Checking condition 9B003E01-3775-4A7C-ABAD-252F786C62F6 - Platform Condition
    10/06/2011 13:52:05PM - Executing action 1C65743D-E0A5-4787-B152-3A21723C2002 - Unpack Manifest xml file
    10/06/2011 13:52:05PM - Unpacking C:/DOCUME~1/admin14/LOCALS~1/Temp/ijtmp_4AED92E6-18C3-46D6-A67D-5AC78CD9B884/ccs_manifest.xml
    10/06/2011 13:52:05PM - Executing action 2237DB6B-9676-4FDA-8BBB-9CD0741C175B - Set Manifest file name
    10/06/2011 13:52:05PM - Executing action 7A1CB0AB-04A3-41C0-8655-22F6AE6A972A - Full CCS or Component install test
    10/06/2011 13:52:05PM - ccs_setup_5.1.*
    10/06/2011 13:52:05PM - full installer
    10/06/2011 13:52:05PM - Executing action D6E650CF-E79A-4C23-86E7-FE0AF5BB288C - Set USERPROFILE variable
    10/06/2011 13:52:05PM - userprofile = C:\Documents and Settings\admin14
    10/06/2011 13:52:05PM - Executing action C3322C75-C36B-4CAA-99B6-D10C70E75CED - Look for Local Respository
    10/06/2011 13:52:05PM - local repo = C:\ alyona.nikiforova\Прочее\Programs/featurerepo
    10/06/2011 13:52:05PM - localbaserepo = C:/DOCUME~1/admin14/LOCALS~1/Temp/ijtmp_4AED92E6-18C3-46D6-A67D-5AC78CD9B884/baserepo
    10/06/2011 13:52:05PM - localrepo = C:/DOCUME~1/admin14/LOCALS~1/Temp/ijtmp_4AED92E6-18C3-46D6-A67D-5AC78CD9B884/featurerepo
    10/06/2011 13:52:05PM - Executing action 0606F3A6-B4B3-430D-BF58-90FD8DC7E9D0 - Read Manifest file
