Other Parts Discussed in Thread: TMS320C5535
HI:
I installed the Code Composer that comes with the TMS320C5535 eZdsp USB kit (the Platinum Edition for 30 days). It worked fine. Now I want to use the MSP-EXP430G2 LaunchPad then I was requested to generate a new license file. I went through the step to obtain my license file which I save to my hard drive in one folder. Then I start Code Composer, I go to the Help Menu-> Licensing options and select the license file and it seems to be fine. Then I can compile the project but when I try to debug it ask me again for the license file and I get this error
Could you please help me with this problem. ? I need to work with both kits at the same time.
Thank you in advance for your help with this issue
Best regards
Carlos L. Castillo
