Part Number: LAUNCHXL-F28P55X
Other Parts Discussed in Thread: BOOSTXL-3PHGANINV, LVSERVOMTR, C2000WARE
I have the following items:
1. Controller Board: [LAUNCHXL-F28P55X (TMS320F28P55x LaunchPad developm.)]
2. Inverter Board: [BOOSTXL-3PHGANINV (48-V/10-A three-phase GaN inverter)].
3. Supported Motor: Low Voltage Servo Motor - Low voltage servo (encoder) motor and wiring harness
[LVSERVOMTR, P/N: M-2310P-LN-04K, Teknic M-2310P-LN-04K]
Also, I have installed Code Composer Studio (CCS Version: 12.8.0.00012) IDE for development and C2000Ware Software Development Kit (SDK Version: C2000Ware Motor Control SDK_5_02_00_00).
With reference to the subject above,
1. Is it possible for the tool (Code Composer Studio) to generate code that can be used to run the motor with the hardware combination mentioned above?
2. If not, could you please suggest any other tools that support pin configuration, code generation, etc.?
Thanks, and regards,
Prasanth K P
