CCS5 Simulation
Other Parts Discussed in Thread: CCSTUDIO
Hi everyone.
I've just started working with CCS and a of problem - I have to opportunity to get a testing board, so I'll have to stick to simulation for the time being.
I tried to follow the CCSv3.3 tutorial for creating a simulation project, but the 5th version looks so much different.
Is there a tutorial somewhere, which explains how to set up simulation in CCS5?
Thanks in advance.
    CCSv5 is a much different environment than v3. I recommend looking at the various introductory material on the main v5 wiki page:
    http://processors.wiki.ti.com/index.php/Category:Code_Composer_Studio_v5
    There is a getting started guide and some videos to help get you started. Not all the material is specific to simulators but the process of creating projects and configuring CCS for a target (whether simulator or hardware).
    Here is a video for CCSv4 that shows how to create a target configuration for a simulator. The steps for v5 are similar;
    http://software-dl.ti.com/dsps/dsps_public_sw/sdo_ccstudio/CCSv4/Demos/ccs4-setup1_b5.htm
    ki
  • Hi Azzar,
    CCSv5 uses a target configuration file to configure and debug.  If you wish to enter the debugger, you will need to start with one of these.  They are usually part of/included in a project but can also be created and used stand alone.  It is in the target configuration file where you select the simulator.  This is also where eventually you will select the emulator/debugger (the Blackhawk or XDS100 for example). These are .ccxml files.
    In CCS if you wish to see what one looks like you can go to view ->Target configurations or create and edit one by File->New->Target Configuration File.
    Here are some links to wikis and resources to help you get started
    http://processors.wiki.ti.com/index.php/Category:Simulation
    http://processors.wiki.ti.com/index.php/Category:CCS_Training
    http://software-dl.ti.com/dsps/dsps_public_sw/sdo_ccstudio/CCSv5/Demos/CCSv5GettingStarted.html
    http://processors.wiki.ti.com/index.php/Eclipse_Concepts
    http://processors.wiki.ti.com/index.php/Code_Composer_Studio_v5_Users_Guide
    I hope this helps.
    Lisa
  • Thanks a lot.
    That was much help and really fast.
    More questions incoming, so bear with me.
