CCS5 search
We are using CCS 5.1.0.08012.
When we use the search tool (CTRL + H) for some expressions (i.e. structures), tool otomatically removes the dot of the expressions by itself.
For example: we search flags.bootflag with CTRL+H, but it removes the dot and search flagsbootflag. so it can not find our expression. And we try to put a dot to there (in picture) but it does not let us.
  • Hi Yasin,
    I see the same thing.  For now, the only thing I can suggest is to use the ? for the . in as the ? is basically the character wild card.
    Please give this a try and keep us posted.
    Lisa
  • No Lisa, it is not working. I tried it before and after your advice.
    Neither ? nor * are not working. Although I use them, search tool can not find expressions.
    I think, tool searchs the expressions with * and ? characters. It doesn't use them
    instead of an unknown character.
    Because screenshots of messages like this:
    Thanks...
  • Hi Yasin,
    ok, I am going to dig into this and do my best to confirm whether it is even possible to do this type of search.  I will return with feedback as soon as I have any.
    Lisa
  • Hello again Yasin,
    I have been able to look into things a bit further and consult some development colleagues.  Unfortunately it seems that the search comes directly from eclipse and so it appears that as a C/C++ search what you are trying to do is not supported.
    Things I can suggest
    - try without the .
    - try the file search, this should work
    - if possible search for only one part ..... ie the word on either side of the .
    - try the eclipse forums
    I hope at least getting this answered helps, even if we do not have a work around for you.  As mentioned the file search is likely the best way to go.
    Lisa
