CCSv5 new Qt project build error
Hi
on CCSv5 I try a new QT project:
menu file --> new --> Qt gui project
I set the name "qt_miaprova"
I don't add code
I select build project and I see the following error:
make debug
make -f Makefile.Debug
make[1]: Entering directory `/home/beta/workspace/qt_miaprova'
make[1]: qt_miaprova.ui: Command not found
make[1]: *** [ui_qt_miaprova.h] Error 127
qt_miaprova.ui -o ui_qt_miaprova.h
make[1]: Leaving directory `/home/beta/workspace/qt_miaprova'
make: *** [debug] Error 2
I also tried to import  the project example "addressbook.pro"
and after the build project I have the same error.
Any suggest?
Paolo Preioni
  • Paolo,
    Sorry, I guess your thread got orphaned. Do you still see this issue?
    I am not an expert in Qt and its projects, but the error message leads me to suspect that they need to have some variable defined or some tool in the path of your system. Can you check the Qt documentation or the software development kit instructions to see if any steps are missing?
    Rafael
