CCS5.1 Build error
Other Parts Discussed in Thread: CONTROLSUITE
I have upgrade CCS3.3 to CCS5.1, since Ti has more supports for newer versions. I tried to run  CPU timer example and I even followed the Getting started video, hut I am getting Compile error.
C28xx: GEL: Encountered a problem loading file: C:\Documents and Settings\ED\workspace_v5_1\Example_2802xCpuTimer\Debug\Example_2802xCpuTimer.out Could not open file
I never had issues with CCS3.3 running a simple examples. I tried delitting project a few times, that didn't work.I selected XDX100v1, and Example_2802xCpuTimer as my target. I know that during setup I was asked if want to import project to "workspace" director, and I chose yes, but nothing got imported to "Workspace' directory, instead to "workspace_v5_1"  Bellow is complete build error.
Thank you
Edmon
**** Build of configuration Debug for project Example_2802xCpuTimer ****
C:\TI\ccsv5\utils\bin\gmake -k all
gmake: *** No rule to make target `C:/TI/ccsv5/eclipse/INSTALLROOT_2802X_V129/DSP2802x_common/source/DSP2802x_CodeStartBranch.asm', needed by `DSP2802x_CodeStartBranch.obj'.
gmake: *** No rule to make target `C:/TI/ccsv5/eclipse/INSTALLROOT_2802X_V129/DSP2802x_common/source/DSP2802x_CpuTimers.c', needed by `DSP2802x_CpuTimers.obj'.
gmake: *** No rule to make target `C:/TI/ccsv5/eclipse/INSTALLROOT_2802X_V129/DSP2802x_common/source/DSP2802x_DefaultIsr.c', needed by `DSP2802x_DefaultIsr.obj'.
gmake: *** No rule to make target `C:/TI/ccsv5/eclipse/INSTALLROOT_2802X_V129/DSP2802x_headers/source/DSP2802x_GlobalVariableDefs.c', needed by `DSP2802x_GlobalVariableDefs.obj'.
gmake: *** No rule to make target `C:/TI/ccsv5/eclipse/INSTALLROOT_2802X_V129/DSP2802x_common/source/DSP2802x_PieCtrl.c', needed by `DSP2802x_PieCtrl.obj'.
gmake: *** No rule to make target `C:/TI/ccsv5/eclipse/INSTALLROOT_2802X_V129/DSP2802x_common/source/DSP2802x_PieVect.c', needed by `DSP2802x_PieVect.obj'.
gmake: *** No rule to make target `C:/TI/ccsv5/eclipse/INSTALLROOT_2802X_V129/DSP2802x_common/source/DSP2802x_SysCtrl.c', needed by `DSP2802x_SysCtrl.obj'.
gmake: *** No rule to make target `C:/TI/ccsv5/eclipse/INSTALLROOT_2802X_V129/DSP2802x_common/source/DSP2802x_usDelay.asm', needed by `DSP2802x_usDelay.obj'.
'Building file: ../Example_2802xCpuTimer.c'
'Invoking: C2000 Compiler'
"C:/TI/ccsv5/tools/compiler/c2000/bin/cl2000" --silicon_version=28 -g --define="_DEBUG" --define="LARGE_MODEL" --include_path="C:/TI/ccsv5/tools/compiler/c2000/include" --include_path="/packages/ti/xdais" --include_path="/DSP2802x_headers/include" --include_path="/DSP2802x_common/include" --include_path="/v15c/include" --quiet --verbose_diagnostics --diag_warning=225 --issue_remarks --large_memory_model --unified_memory --output_all_syms --cdebug_asm_data --preproc_with_compile --preproc_dependency="Example_2802xCpuTimer.pp" "../Example_2802xCpuTimer.c"
"../Example_2802xCpuTimer.c", line 66: fatal error: could not open source file
"DSP28x_Project.h"
#include "DSP28x_Project.h" // Device Headerfile and Examples Include File
1 fatal error detected in the compilation of "../Example_2802xCpuTimer.c".
Compilation terminated.
>> Compilation failure
gmake: *** [Example_2802xCpuTimer.obj] Error 1
gmake: *** No rule to make target `C:/TI/ccsv5/eclipse/INSTALLROOT_2802X_V129/DSP2802x_common/cmd/28027_RAM_lnk.cmd', needed by `Example_2802xCpuTimer.out'.
gmake: *** No rule to make target `C:/TI/ccsv5/eclipse/INSTALLROOT_2802X_V129/DSP2802x_headers/cmd/DSP2802x_Headers_nonBIOS.cmd', needed by `Example_2802xCpuTimer.out'.
gmake: Target `all' not remade because of errors.
**** Build Finished ****
