CCSv3.3 project to CCSv5.1 file name case issue
I am trying to convert a project from CCSv3.3 to CCSv5.1 I was able to succesfully build the project but noticed that the linker was moving a section around. It turns out that the case of the object files passed to the linker v4.3.1 results in the object file getting linked in a different location. I noticed that CCSv5.1 converts all of the file names to lower case when passing to the compiler or linker. Is there a way to keep the Case of the file in tact.
  • Hi Matthew,
    this seems to have slipped through the cracks somehow.
    Do you still need assistance here?
    I am going to see if I can reproduce this.    Can you be a bit more specific about what is being renamed?  Possibly even share a project offline?  Are you seeing this will all projects you import?
    Lisa
  • Hi Matthew,
    just thought would check again whether assistance is still required here?   If so, would you be able to send the requested further info?
    Lisa
