Here's cl55_segfault.c
static const int a[1];
int
main(void)
(void)a[0];
return 0;
static const int a[1] = { 0 };
Here's a Command prompt session
C:\Users\JFisher\my\test\segfault>dir
Volume in drive C has no label.
Volume Serial Number is 44E2-187C
Directory of C:\Users\JFisher\my\test\segfault
11/11/2011 02:19 PM <DIR> .
11/11/2011 02:19 PM <DIR> ..
11/11/2011 02:09 PM 119 cl55_segfault.c
1 File(s) 119 bytes
2 Dir(s) 958,283,997,184 bytes free
C:\Users\JFisher\my\test\segfault>c:\ti\ccsv5\tools\compiler\c5500\bin\cl55 cl55
_segfault.c
INTERNAL ERROR: c:\ti\ccsv5\tools\compiler\c5500\bin\acp55.exe experienced a seg
mentation fault while
processing
This is a serious problem. Please contact Customer
Support with this message and a copy of the input file
and help us to continue to make the tools more robust.
>> Compilation failure
1 File(s) 119 bytes
C:\Users\JFisher\my\test\segfault>c:\ti\ccsv5\tools\compiler\c5500\bin\cl55 -ver
sion
TMS320C55x C/C++ Compiler v4.4.0
Build Number 1LJ7O-KDADEMDK-RTARQ-TAV-ZAB3T_U_U_Q
TMS320C55x C/C++ Parser v4.4.0
Build Number 1LJ7M-KDADEMDK-RTARQ-TAV-ZAB3T_U_U_Q
TMS320C55x C/C++ File Merge v4.4.0
Build Number 1LJ7N-KDADEMDK-RTARQ-TAV-ZAB3T_U_U_Q
TMS320C55x C/C++ Optimizer v4.4.0
TMS320C55x C/C++ Codegen v4.4.0
TMS320C55x Consultant Generator v4.4.0
TMS320C55x Assembler v4.4.0
TMS320C55x Mnemonic Preprocessor v4.4.0
TMS320C55x Embed Utility v4.4.0
TMS320C55x C Source Interlister v4.4.0
TMS320C55x Linker v4.4.0
TMS320C55x Absolute Lister v4.4.0
TMS320C55x Strip Utility v4.4.0
TMS320C55x XREF Utility v4.4.0
TMS320C55x C++ Demangler v4.4.0
TMS320C55x Hex Converter v4.4.0
TMS320C55x Library Builder v4.4.0
TMS320C55x Name Utility v4.4.0
TMS320C55x Object File Display v4.4.0
TMS320C55x Archiver v4.4.0
C:\Users\JFisher\my\test\segfault>"C:/Program Files/Texas Instruments/ccsv4/tool
s/compiler/C5500 Code Generation Tools 4.3.9/bin/cl55" cl55_segfault.c
s/compiler/C5500 Code Generation Tools 4.3.9/bin/cl55" -version
TMS320C55x C/C++ Compiler v4.3.9
Build Number 1LFKM-KDADEMDK-RTARQ-TAV-ZAB3T_U_T_Z9
TMS320C55x C/C++ Parser v4.3.9
TMS320C55x C/C++ File Merge v4.3.9
TMS320C55x C/C++ Optimizer v4.3.9
TMS320C55x C/C++ Codegen v4.3.9
Build Number 1LFKN-KDADEMDK-RTARQ-TAV-ZAB3T_U_T_Z9
TMS320C55x Consultant Generator v4.3.9
TMS320C55x Assembler v4.3.9
TMS320C55x Mnemonic Preprocessor v4.3.9
TMS320C55x Embed Utility v4.3.9
TMS320C55x C Source Interlister v4.3.9
TMS320C55x Linker v4.3.9
TMS320C55x Absolute Lister v4.3.9
TMS320C55x Strip Utility v4.3.9
TMS320C55x XREF Utility v4.3.9
TMS320C55x C++ Demangler v4.3.9
TMS320C55x Hex Converter v4.3.9
TMS320C55x Library Builder v4.3.9
TMS320C55x Name Utility v4.3.9
TMS320C55x Object File Display v4.3.9
TMS320C55x Archiver v4.3.9
11/11/2011 02:20 PM <DIR> .
11/11/2011 02:20 PM <DIR> ..
11/11/2011 02:20 PM 2,671 cl55_segfault.obj
2 File(s) 2,790 bytes
2 Dir(s) 958,284,005,376 bytes free
