CCS Debugger Stopped Working
Other Parts Discussed in Thread: CCSTUDIO, MSP430F5529
The debugger just suddenly stopped working. I'm getting a pop up error:
An internal error occurred during 'Creating Debug Server'.
Please see the Error Log for details.
When I click details, it shows a long error message, but the copy command doesn't copy it. I have no idea where the error log is.
Matt
  • Hi Matt,
    Please provide more details about your environment.
    What is the full version number of your CCS installation?
    What device are you using?
    What emulator are you using?
    See the below link on how to generate a zip of the diagnostic logs:
    http://processors.wiki.ti.com/index.php/Troubleshooting_CCS#CCS_Diagnostic_Logs
    ki
  • I found how to view errors. Pressing the "CCS Support Activities" menu item causes an error:
    org.mozilla.xpcom.XPCOMException: Could not createInstance(@ti.com/DSLogger1;1,{88de5d06-9f14-4628-bc1c-9cef687a039e})Java/XPCOM bridge: exception while executing submit() with parameterorg.mozilla.xpcom.internal.XPCOMJavaProxy$3@17a0b4d.
    org.mozilla.xpcom.XPCOMException: The function "createInstanceByContractID" returned an error condition  (0x80040154)  (0x80004005)  (0x80004005)
    at com.ti.debug.engine.xpcom.Runtime.createComponent(Runtime.java:229)
    at com.ti.logger.impl.DSLogger.<init>(DSLogger.java:29)
    at com.ti.logger.impl.DSLogger.instance(DSLogger.java:46)
    at com.ti.logger.impl.DSLogger.getLoggerConfiguration(DSLogger.java:67)
    at com.ti.ccstudio.ui.support.internal.DebugServerSupportActivity.getLogLocation(DebugServerSupportActivity.java:45)
    at com.ti.ccstudio.ui.support.internal.dialog.SupportDialog.updateActivity(SupportDialog.java:253)
    at com.ti.ccstudio.ui.support.internal.dialog.SupportDialog.insertActivities(SupportDialog.java:271)
    at com.ti.ccstudio.ui.support.internal.dialog.SupportDialog.createDialogArea(SupportDialog.java:186)
    at org.eclipse.jface.dialogs.TitleAreaDialog.createContents(TitleAreaDialog.java:165)
    at org.eclipse.jface.window.Window.create(Window.java:426)
    at org.eclipse.jface.dialogs.Dialog.create(Dialog.java:1124)
    at org.eclipse.jface.window.Window.open(Window.java:785)
    at com.ti.ccstudio.ui.actions.SupportActivityActionDelegate.run(SupportActivityActionDelegate.java:35)
    at org.eclipse.ui.internal.PluginAction.runWithEvent(PluginAction.java:254)
    at org.eclipse.ui.internal.WWinPluginAction.runWithEvent(WWinPluginAction.java:229)
    at org.eclipse.jface.action.ActionContributionItem.handleWidgetSelection(ActionContributionItem.java:539)
    at org.eclipse.jface.action.ActionContributionItem.access$2(ActionContributionItem.java:488)
    at org.eclipse.jface.action.ActionContributionItem$5.handleEvent(ActionContributionItem.java:400)
    at org.eclipse.swt.widgets.EventTable.sendEvent(EventTable.java:84)
    at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:1003)
    at org.eclipse.swt.widgets.Display.runDeferredEvents(Display.java:3823)
    at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java:3422)
    at org.eclipse.ui.internal.Workbench.runEventLoop(Workbench.java:1914)
    at org.eclipse.ui.internal.Workbench.runUI(Workbench.java:1878)
    at org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Workbench.java:419)
    at org.eclipse.ui.PlatformUI.createAndRunWorkbench(PlatformUI.java:149)
    at org.eclipse.ui.internal.ide.IDEApplication.run(IDEApplication.java:97)
    at org.eclipse.core.internal.runtime.PlatformActivator$1.run(PlatformActivator.java:78)
    at org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher.runApplication(EclipseAppLauncher.java:92)
    at org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher.start(EclipseAppLauncher.java:68)
    at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:400)
    at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:177)
    at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method)
    at sun.reflect.NativeMethodAccessorImpl.invoke(Unknown Source)
    at sun.reflect.DelegatingMethodAccessorImpl.invoke(Unknown Source)
    at java.lang.reflect.Method.invoke(Unknown Source)
    at org.eclipse.core.launcher.Main.invokeFramework(Main.java:336)
    at org.eclipse.core.launcher.Main.basicRun(Main.java:280)
    at org.eclipse.core.launcher.Main.run(Main.java:996)
    at org.eclipse.core.launcher.Main.main(Main.java:971)
  • I'm using CCS 4.2.4. With a USB FET and an MSP430F5529
  • The contents of the error log look similar to what has been reported in a previous thread:
    http://e2e.ti.com/support/development_tools/code_composer_studio/f/81/p/130506/467526.aspx
  • That link does not work.
  • There was a syntax error in the link. Try the below:
    ki
  • Uninstalling and then reinstalling seems to have worked. It locked up and failed on the first re-install, but the second try seems to have worked.
