Other Parts Discussed in Thread: MSPM0G3507
Hello
I want to Update Firmware LP-MSPM0G3507.
I'm did Update for Led Toggle Example
provided by TI.
Then, I was update new Firmware File.
https://www.ti.com/tool/TIDA-010935
TIDA-010935-UART-EXAMPLE
I was Import and try build "TIDA_010935_UART_echo" Folder.
but it's failed and I can view error log.
[0]**** Build of configuration Debug for project TIDA_010935_UART_echo ****
[1]"C:\\ti\\ccs2000\\ccs\\utils\\bin\\gmake" -k -j 12 all -O
[2]Building target: "TIDA_010935_UART_echo.out"
[3]Invoking: Arm Linker
[4]"C:/ti/ccs2000/ccs/tools/compiler/ti-cgt-armllvm_4.0.1.LTS/bin/tiarmclang.exe" -march=thumbv6m -mcpu=cortex-m0plus -mfloat-abi=soft -mlittle-endian -mthumb -O0 -D__MSPM0G3507__ -gdwarf-3 -Wl,-m"TIDA_010935_UART_echo.map" -Wl,--stack_size=512 -Wl,-i"C:/Users/D-Tech/workspace_ccstheia/TIDA_010935_UART_echo/Debug/syscfg" -Wl,-i"C:/ti/ccs2000/ccs/tools/compiler/ti-cgt-armllvm_4.0.1.LTS/lib" -Wl,--diag_wrap=off -Wl,--display_error_number -Wl,--warn_sections -Wl,--xml_link_info="TIDA_010935_UART_echo_linkInfo.xml" -Wl,--rom_model -o "TIDA_010935_UART_echo.out" "./TIDA_010935_echo.o" "./syscfg/ti_msp_dl_config.o" "./startup_mspm0g350x_ticlang.o" "./ticlang/startup_mspm0g3507_ticlang.o" "../mspm0g3507.cmd" -Wl,-l"syscfg/device_linker.cmd" -Wl,-l"C:/ti/mspm0_sdk_2_03_00_07/source/ti/driverlib/lib/ticlang/m0p/mspm0g1x0x_g3x0x/driverlib.a" -Wl,-llibc.a
[5]makefile:141: recipe for target 'TIDA_010935_UART_echo.out' failed
[6]"syscfg/device_linker.cmd", line 40: error #10263: FLASH memory range has already been specified
[7]"syscfg/device_linker.cmd", line 40: error #10264: FLASH memory range overlaps existing memory range FLASH
[8]"syscfg/device_linker.cmd", line 41: error #10263: SRAM memory range has already been specified
[9]"syscfg/device_linker.cmd", line 41: error #10264: SRAM memory range overlaps existing memory range SRAM
[10]"syscfg/device_linker.cmd", line 42: error #10263: BCR_CONFIG memory range has already been specified
[11]"syscfg/device_linker.cmd", line 42: error #10264: BCR_CONFIG memory range overlaps existing memory range BCR_CONFIG
[12]"syscfg/device_linker.cmd", line 43: error #10263: BSL_CONFIG memory range has already been specified
[13]"syscfg/device_linker.cmd", line 43: error #10264: BSL_CONFIG memory range overlaps existing memory range BSL_CONFIG
[14]error #10056: symbol "interruptVectors" redefined: first defined in "./startup_mspm0g350x_ticlang.o"; redefined in "./ticlang/startup_mspm0g3507_ticlang.o"
[15]error #10010: errors encountered during linking; "TIDA_010935_UART_echo.out" not built
[16]tiarmclang: error: tiarmlnk command failed with exit code 1 (use -v to see invocation)
[17]gmake[1]: *** [TIDA_010935_UART_echo.out] Error 1
[18]makefile:137: recipe for target 'all' failed
[19]gmake: *** [all] Error 2
[20]**** Build Finished ****
I was view this error the first.
Can you give me some advice about this error?
