interrupt vector table file
Hi
I want to write non DSPBIOS application.In this case how I handle interrupt .plz give guideline for writing vector.asm file.
regards
satheesh kumar
  • Satheesh,
    This is dependent on the device you are working with. For many processor families there are example projects you can begin with that set up interrupt vectors and give you a starting point for your development. If you post in the device forum for the specific device you are using, they should be able to point you in the right direction.
