Does CCS v4 or v5 run on Windows Vista (for sw development for the C6726B DSP chip)?
I have Windows 7 on my desktop machine, but the laptop I have runs Vista.
Thanks.
Steve
Thanks.
Steve
v4 officially supports Vista and 7 while v5 only officially supports 7. "Officially" means what we test with. However there are many CCSv5 users who run fine on Vista so you should be fine.
http://processors.wiki.ti.com/index.php/System_Requirements
Some fyi's you should read:
http://processors.wiki.ti.com/index.php/Using_CCS_with_Windows_Vista_and_7#CCSv4.2F5
http://processors.wiki.ti.com/index.php/FAQ_-_CCSv4#Operating_System_Support
ki
Ki,
Thanks for sending that information - I will look over the documents you have mentioned.
What is the difference between CCS v4.x and v5.1? Do they require different versions of
Eclipse, or different versions of Java runtime?
Does the installer for CCS v4.x (or v5.x) automatically install the infrastructure required (e.g. Eclipse and Java runtime)?
What is the size of CCS + Eclipse + Java on the hard disk?
Steve
Steven Tuttle said:What is the difference between CCS v4.x and v5.1?
Check out:
http://processors.wiki.ti.com/images/4/4a/CCSv5-WhatsNew.pdf
http://processors.wiki.ti.com/index.php/CCSv5_Changes
Steven Tuttle said:Do they require different versions of
v4 uses Eclipse 3.2. v5.1 uses Eclipse 3.7. v5.1 also uses an updated version of the JRE
Steven Tuttle said:Does the installer for CCS v4.x (or v5.x) automatically install the infrastructure required (e.g. Eclipse and Java runtime)?
Yes, unless you request it to not do so.
Steven Tuttle said:What is the size of CCS + Eclipse + Java on the hard disk?
It really depends on what components you choose to install. A FULL CCS install can take up to 4 GB of space. But that includes EVERYTHING (support for all devices, BIOS, compilers, etc) and most people rarely install everything.
ki
