CCS 4.2.4 SD XDS510 emulator connecting problem
i have the following problem:
I want to connect with a C6000 DaVinci DM648 platform. The connecting time takes about 2 minutes, but it works! But i think it takes too much time.
In the output window i can see, that the emulator retries the same call in a loop and i think something is going wrong:
   14:23:01:228 | ICE CD: icebox invoked pid 5636
  14:23:01:228 | ICE CD: Trace Server invoked PID 3064 .
  14:23:01:228 | ICE CD: Trying to initialize ICE with properties.
  14:23:01:256 | ICE CD: Trying to get channel server instance.
  14:23:03:056 | ICE CD: Trying to initialize ICE with properties.
  14:23:03:056 | ICE CD: Trying to get channel server instance.
  14:23:05:010 | ICE CD: Trying to initialize ICE with properties.
  14:23:05:010 | ICE CD: Trying to get channel server instance.
  14:23:06:769 | ICE CD: Trying to initialize ICE with properties.
  14:23:06:769 | ICE CD: Trying to get channel server instance.
  14:23:08:723 | ICE CD: Trying to initialize ICE with properties.
  14:23:08:723 | ICE CD: Trying to get channel server instance.
  14:23:10:677 | ICE CD: Trying to initialize ICE with properties.
  14:23:10:677 | ICE CD: Trying to get channel server instance.
  14:23:12:435 | ICE CD: Trying to initialize ICE with properties.
  14:23:12:435 | ICE CD: Trying to get channel server instance.
  14:23:14:389 | ICE CD: Trying to initialize ICE with properties.
  14:23:14:389 | ICE CD: Trying to get channel server instance.
  14:23:16:148 | ICE CD: Trying to initialize ICE with properties.
  14:23:16:148 | ICE CD: Trying to get channel server instance.
  14:23:18:004 | ICE CD: Trying to initialize ICE with properties.
  14:23:18:004 | ICE CD: Trying to get channel server instance.
  14:23:19:706 | ICE CD: failed to get proxy instance for the channel server
  14:23:19:706 | ICE CD: ~IceChannelServer
  14:23:19:706 | ICE CD: Created new Channel Server 0x2558f3b0
E 14:23:19:706 | Trace Factory: Channel server creation failed.
Does anybody knows what is going wrong?
Best regards
Simon
  • Simon,
    Where these messages are coming from? I have a DM648, connected using a SD510USB and used the GEL file provided by Lyrtech's companion software but I don't see anything similar to what you are seeing. Is that shown in any of the CCS views or is it contents of a debug server log file?
    Rafael
  • Hello Rafael,
    these messages are coming from the debug output console. The messages are generated a longer time before the GEL file is executed.
    Simon
  • Hallo,
    can somebody help me with my problem?
    I have a trace log of the problem
    M     09:51:48:361 | Trace JNI: connecting channel server
    M     09:51:48:361 | Trace Factory: Calling CreateTraceFactory
    M     09:51:48:361 | Trace Factory: CreateTraceFactory pStaticFactory=0x1b7e2e30    refcount=2
    M     09:51:48:361 | Trace Factory: calling CreateChannelServer  m_channelServer=0x0
    M     09:51:48:361 | Trace Factory: Reusing environment from previous session.
    M     09:51:48:361 | Trace Factory: CreateChannelServer  - connect existing
        E 09:51:48:361 | Trace Factory: Channel server creation failed.
        E 09:51:48:361 | Trace JNI: Channel server creation failed..
    M     09:51:48:361 | Trace JNI: connecting channel server - DONE
    M     09:51:49:548 | cToolsIF: CreateSystem() is passed
    M     09:51:49:548 | Trace Factory: Calling CreateTraceFactory
    M     09:51:49:548 | Trace Factory: CreateTraceFactory pStaticFactory=0x1b7e2e30    refcount=3
    M     09:51:49:548 | Trace Factory: calling CreateChannelServer  m_channelServer=0x0
    M     09:51:49:548 | Trace Factory: Reusing environment from previous session.
    M     09:51:49:548 | Trace Factory: CreateChannelServer  - create new
    M     09:51:49:548 | ICE CD: Initializing channel server in mode 1.
    M     09:51:49:564 | ICE CD: Initializing channel server for CCS v4 in mode 1.
    M     09:51:49:564 | ICE CD: Strting to load ICE client properties.
    M     09:51:49:642 | ICE CD: Loaded ICE client properties.
    M     09:51:49:642 | ICE CD: using C:\Dokumente und Einstellungen\eodsch\.TI-trace\data\trace_server_config.txt as icebox server configuration
    M     09:51:49:642 | ICE CD: starting icebox : TraceCompMgr.exe --Ice.Config="C:\Dokumente und Einstellungen\eodsch\.TI-trace\data\trace_server_config.txt"
    M     09:51:49:720 | ICE CD: icebox invoked pid 4828
    M     09:51:49:860 | ICE CD: Trace Server invoked PID 3804 .
    M     09:51:49:860 | ICE CD: Trying to initialize ICE with properties.
    M     09:51:49:907 | ICE CD: Trying to get channel server instance.
    M     01/24/12 09:51:51:891 | ********** Trace Server Starting **********
    M      MODULE INFO - TraceServer.exe  PID=3804 : TraceServer.exe
    M     09:51:51:906 | Trace Server: Init server successful
    M     09:51:51:906 | Trace Server: register exit handlers
    M     09:51:51:906 | Trace Server: getting topic manager. Attempt = 1
    M     09:51:52:219 | ICE CD: Trying to initialize ICE with properties.
    M     09:51:52:219 | ICE CD: Trying to get channel server instance.
     W    09:51:53:937 | Trace Server: Network.cpp:545: Ice::ConnectionRefusedException:
    connection refused: WSAECONNREFUSEDsly set
    # a
    M     09:51:53:937 | Trace Server: getting topic manager. Attempt = 2
    M     09:51:54:406 | ICE CD: Trying to initialize ICE with properties.
    M     09:51:54:406 | ICE CD: Trying to get channel server instance.
     W    09:51:55:983 | Trace Server: Network.cpp:545: Ice::ConnectionRefusedException:
    connection refused: WSAECONNREFUSEDServerAdapt�
    M     09:51:55:983 | Trace Server: getting topic manager. Attempt = 3
    M     09:51:56:373 | ICE CD: Trying to initialize ICE with properties.
    M     09:51:56:373 | ICE CD: Trying to get channel server instance.
     W    09:51:58:060 | Trace Server: Network.cpp:545: Ice::ConnectionRefusedException:
    connection refused: WSAECONNREFUSEDure the end�
    M     09:51:58:060 | Trace Server: getting topic manager. Attempt = 4
    M     09:51:58:451 | ICE CD: Trying to initialize ICE with properties.
    M     09:51:58:451 | ICE CD: Trying to get channel server instance.
     W    09:52:00:247 | Trace Server: Network.cpp:545: Ice::ConnectionRefusedException:
    connection refused: WSAECONNREFUSEDs property �
    M     09:52:00:247 | Trace Server: getting topic manager. Attempt = 5
    M     09:52:00:419 | ICE CD: Trying to initialize ICE with properties.
    M     09:52:00:419 | ICE CD: Trying to get channel server instance.
    M     09:52:02:605 | ICE CD: Trying to initialize ICE with properties.
    M     09:52:02:605 | ICE CD: Trying to get channel server instance.
     W    09:52:02:652 | Trace Server: Network.cpp:545: Ice::ConnectionRefusedException:
    connection refused: WSAECONNREFUSEDnager:defauw
    M     09:52:02:652 | Trace Server: getting topic manager. Attempt = 6
    M     09:52:04:573 | ICE CD: Trying to initialize ICE with properties.
    M     09:52:04:573 | ICE CD: Trying to get channel server instance.
     W    09:52:04:839 | Trace Server: Network.cpp:545: Ice::ConnectionRefusedException:
    connection refused: WSAECONNREFUSEDtens.
    Icej
    M     09:52:04:839 | Trace Server: getting topic manager. Attempt = 7
     W    09:52:06:807 | Trace Server: Network.cpp:545: Ice::ConnectionRefusedException:
    connection refused: WSAECONNREFUSEDch the topi]
    M     09:52:06:807 | Trace Server: getting topic manager. Attempt = 8
    M     09:52:06:869 | ICE CD: Trying to initialize ICE with properties.
    M     09:52:06:869 | ICE CD: Trying to get channel server instance.
     W    09:52:08:869 | Trace Server: Network.cpp:545: Ice::ConnectionRefusedException:
    connection refused: WSAECONNREFUSED#
    # 0 = no P
    M     09:52:08:869 | Trace Server: getting topic manager. Attempt = 9
    M     09:52:08:931 | ICE CD: Trying to initialize ICE with properties.
    M     09:52:08:931 | ICE CD: Trying to get channel server instance.
     W    09:52:10:946 | ICE CD: failed to get proxy instance for the channel server.
    connection refused: WSAECONNREFUSEDdetailed suC
    M     09:52:10:946 | Trace Server: getting topic manager. Attempt = 10
    M     09:52:10:946 | ICE CD: ~IceChannelServer
    M     09:52:10:946 | ICE CD: Created new Channel Server 0x1b7ea610
        E 09:52:10:946 | Trace Factory: Channel server creation failed.
    M     09:52:11:040 | AETPropertyHelper: Get server name from file C:\Programme\Texas Instruments\ccsv4\emulation\analysis\bin\../xmldb/aet_config/aetdvrs.xml
        E 09:52:11:055 | AETProperties: No server name for CPU 2000
    M     09:52:11:555 | cTools2000: CreateSystem() is called. CPU Type: 6455
    M     09:52:11:555 | cToolsIF: CreateSystem() is passed
    M     09:52:11:555 | Trace Factory: Calling CreateTraceFactory
    M     09:52:11:555 | Trace Factory: CreateTraceFactory pStaticFactory=0x1b7e2e30    refcount=4
    M     09:52:11:555 | Trace Factory: calling CreateChannelServer  m_channelServer=0x0
    M     09:52:11:555 | Trace Factory: Reusing environment from previous session.
    M     09:52:11:555 | Trace Factory: CreateChannelServer  - create new
    M     09:52:11:555 | ICE CD: Initializing channel server in mode 1.
    M     09:52:11:571 | ICE CD: Initializing channel server for CCS v4 in mode 1.
    M     09:52:11:571 | ICE CD: Terminating icebox from prev session pid=4828.
    M     09:52:11:571 | ICE CD: Terminating trace server from prev session pid=3804.
    M     09:52:11:571 | ICE CD: Strting to load ICE client properties.
    M     09:52:11:571 | ICE CD: Loaded ICE client properties.
    M     09:52:11:571 | ICE CD: using C:\Dokumente und Einstellungen\eodsch\.TI-trace\data\trace_server_config.txt as icebox server configuration
    M     09:52:11:571 | ICE CD: starting icebox : TraceCompMgr.exe --Ice.Config="C:\Dokumente und Einstellungen\eodsch\.TI-trace\data\trace_server_config.txt"
    M     09:52:11:586 | ICE CD: icebox invoked pid 4828
    M     09:52:11:586 | ICE CD: Trace Server invoked PID 3804 .
    M     09:52:11:586 | ICE CD: Trying to initialize ICE with properties.
    M     01/24/12 09:52:11:586 | ********** Trace Server Starting **********
    M      MODULE INFO - TraceServer.exe  PID=5716 : TraceServer.exe
    M     09:52:11:618 | ICE CD: Trying to get channel server instance.
    M     09:52:11:649 | Trace Server: Init server successful
    M     09:52:11:649 | Trace Server: register exit handlers
    M     09:52:11:649 | Trace Server: getting topic manager. Attempt = 1
     W    09:52:13:789 | Trace Server: Network.cpp:545: Ice::ConnectionRefusedException:
    # a
    M     09:52:13:789 | Trace Server: getting topic manager. Attempt = 2
    M     09:52:13:851 | ICE CD: Trying to initialize ICE with properties.
    M     09:52:13:851 | ICE CD: Trying to get channel server instance.
     W    09:52:15:757 | Trace Server: Network.cpp:545: Ice::ConnectionRefusedException:
    M     09:52:15:757 | Trace Server: getting topic manager. Attempt = 3
    M     09:52:16:475 | ICE CD: Trying to initialize ICE with properties.
    M     09:52:16:475 | ICE CD: Trying to get channel server instance.
     W    09:52:18:021 | Trace Server: Network.cpp:545: Ice::ConnectionRefusedException:
    M     09:52:18:021 | Trace Server: getting topic manager. Attempt = 4
    M     09:52:18:521 | ICE CD: Trying to initialize ICE with properties.
    M     09:52:18:521 | ICE CD: Trying to get channel server instance.
     W    09:52:20:317 | Trace Server: Network.cpp:545: Ice::ConnectionRefusedException:
    M     09:52:20:317 | Trace Server: getting topic manager. Attempt = 5
    M     09:52:20:708 | ICE CD: Trying to initialize ICE with properties.
    M     09:52:20:708 | ICE CD: Trying to get channel server instance.
     W    09:52:22:504 | Trace Server: Network.cpp:545: Ice::ConnectionRefusedException:
    M     09:52:22:504 | Trace Server: getting topic manager. Attempt = 6
    M     09:52:23:004 | ICE CD: Trying to initialize ICE with properties.
    M     09:52:23:004 | ICE CD: Trying to get channel server instance.
     W    09:52:24:691 | Trace Server: Network.cpp:545: Ice::ConnectionRefusedException:
    Icej
    M     09:52:24:691 | Trace Server: getting topic manager. Attempt = 7
    M     09:52:25:519 | ICE CD: Trying to initialize ICE with properties.
    M     09:52:25:519 | ICE CD: Trying to get channel server instance.
     W    09:52:26:877 | Trace Server: Network.cpp:545: Ice::ConnectionRefusedException:
    M     09:52:26:877 | Trace Server: getting topic manager. Attempt = 8
    M     09:52:27:705 | ICE CD: Trying to initialize ICE with properties.
    M     09:52:27:705 | ICE CD: Trying to get channel server instance.
     W    09:52:29:173 | Trace Server: Network.cpp:545: Ice::ConnectionRefusedException:
    # 0 = no P
    M     09:52:29:173 | Trace Server: getting topic manager. Attempt = 9
    M     09:52:29:783 | ICE CD: Trying to initialize ICE with properties.
    M     09:52:29:783 | ICE CD: Trying to get channel server instance.
     W    09:52:31:251 | Trace Server: Network.cpp:545: Ice::ConnectionRefusedException:
    M     09:52:31:251 | Trace Server: getting topic manager. Attempt = 10
    M     09:52:31:969 | ICE CD: Trying to initialize ICE with properties.
    M     09:52:31:985 | ICE CD: Trying to get channel server instance.
     W    09:52:33:437 | Trace Server: Network.cpp:545: Ice::ConnectionRefusedException:
    connection refused: WSAECONNREFUSED# 1 = trace6
        E 09:52:33:437 | Trace Server: Error Unable to initialize the IceStorm service.
    M     09:52:33:437 | Trace Server: Destroying communicator
    M     09:52:33:437 | Trace Server: handling exit
     W    09:52:34:203 | ICE CD: failed to get proxy instance for the channel server.
    M     09:52:34:203 | ICE CD: ~IceChannelServer
    M     09:52:34:203 | ICE CD: Created new Channel Server 0x1d2853c8
        E 09:52:34:203 | Trace Factory: Channel server creation failed.
    M     09:52:34:203 | AETPropertyHelper: Get server name from file C:\Programme\Texas Instruments\ccsv4\emulation\analysis\bin\../xmldb/aet_config/aetdvrs.xml
    M     09:52:34:203 | AETProperties: Operation Server Name AETOperationServer for CPU 6455
    M     09:52:34:250 | AETProperties: Call GetOperationServer() for CPU 6455
    M     09:52:34:265 | AETOperationServer: Device Identifier loaded
    M     09:52:34:265 | DevId: Can Create Server.
    M     09:52:34:281 | DevId: CreateDeviceIdentifier - devIdPtr=0x1b7ea158 devIdRefCount=1
    M     09:52:34:281 | DevId: Loading factory DLL - TraceFactory.dll
    M     09:52:34:281 | DevId: Connecting to Trace factory
    M     09:52:34:281 | Trace Factory: Calling CreateTraceFactory
    M     09:52:34:281 | Trace Factory: CreateTraceFactory pStaticFactory=0x1b7e2e30    refcount=5
    M     09:52:34:281 | DevId: Connecting Live Channel Server
    M     09:52:34:281 | Trace Factory: calling CreateChannelServer  m_channelServer=0x0
    M     09:52:34:281 | Trace Factory: Reusing environment from previous session.
    M     09:52:34:281 | Trace Factory: CreateChannelServer  - connect existing
    M     09:52:34:281 | ICE CD: Initializing channel server in mode 0.
    M     09:52:34:281 | ICE CD: Initializing channel server for CCS v4 in mode 0.
    M     09:52:34:281 | ICE CD: ~IceChannelServer
        E 09:52:34:281 | Trace Factory: Channel server creation failed.
     W    09:52:34:281 | DevId: Exception in connecting Channel Server
    M     09:52:34:281 | Trace Factory: CreateTraceFactory pStaticFactory=0x1b7e2e30    refcount=6
        E 09:52:34:281 | DevId: channel driver is not valid in LoadDeviceConnectionInfo()
    M     09:52:34:281 | Trace Factory: CreateTraceFactory pStaticFactory=0x1b7e2e30    refcount=7
    M     09:52:34:296 | ICE CD: Initializing channel server for CCS v4 in mode 0.
    M     09:52:34:296 | ICE CD: ~IceChannelServer
        E 09:52:34:296 | Trace Factory: Channel server creation failed.
     W    09:52:34:296 | DevId: Exception in connecting Channel Server
    M     09:52:34:296 | AETOperationServer: nGEMType value =0
    M     09:52:34:296 | AETPropertyHelper: UBM property file name AET_Property64Plus.xml for CPU 6455
    M     09:52:34:296 | AETPropertyHelper: Created DB for C:\Programme\Texas Instruments\ccsv4\emulation\analysis\bin\../xmldb/aet_config/AET_Property64Plus.xml not found
    M     09:52:34:328 | AETPropertyHelper: Create new DB for C:\Programme\Texas Instruments\ccsv4\emulation\analysis\bin\../xmldb/aet_config/AET_Property64Plus.xml
    M     09:52:34:359 | AETPropertyHelper: Property database 0 is created.
    M     09:52:34:359 | DevId: Loading factory DLL - TraceFactory.dll
    M     09:52:34:359 | DevId: Connecting to Trace factory
    M     09:52:34:359 | Trace Factory: Calling CreateTraceFactory
    M     09:52:34:359 | Trace Factory: CreateTraceFactory pStaticFactory=0x1b7e2e30    refcount=8
    M     09:52:34:359 | DevId: Connecting Live Channel Server
    M     09:52:34:359 | Trace Factory: calling CreateChannelServer  m_channelServer=0x0
    M     09:52:34:359 | Trace Factory: Reusing environment from previous session.
    M     09:52:34:359 | Trace Factory: CreateChannelServer  - connect existing
    M     09:52:34:359 | ICE CD: Initializing channel server in mode 0.
    M     09:52:34:375 | ICE CD: Initializing channel server for CCS v4 in mode 0.
    M     09:52:34:375 | ICE CD: ~IceChannelServer
        E 09:52:34:375 | Trace Factory: Channel server creation failed.
     W    09:52:34:375 | DevId: Exception in connecting Channel Server
    M     09:52:34:375 | DevId: Loading factory DLL - TraceFactory.dll
    M     09:52:34:375 | DevId: Connecting to Trace factory
    M     09:52:34:375 | Trace Factory: Calling CreateTraceFactory
    M     09:52:34:375 | Trace Factory: CreateTraceFactory pStaticFactory=0x1b7e2e30    refcount=9
    M     09:52:34:375 | DevId: Connecting Live Channel Server
    M     09:52:34:375 | Trace Factory: calling CreateChannelServer  m_channelServer=0x0
    M     09:52:34:375 | Trace Factory: Reusing environment from previous session.
    M     09:52:34:375 | Trace Factory: CreateChannelServer  - connect existing
    M     09:52:34:375 | ICE CD: Initializing channel server in mode 0.
    M     09:52:34:375 | AETOperationServer: Creating operation server for CPU 6455
    M     09:52:34:375 | AETProperties: Operation Server # 0 is created
    M     09:52:34:375 | AETProperties: Operation Server Createed 0x1d2e66b0 for CPU 6455
    M     09:52:35:296 | Trace Factory: calling CreateChannelServer  m_channelServer=0x0
    M     09:52:35:296 | Trace Factory: Reusing environment from previous session.
    M     09:52:35:296 | Trace Factory: CreateChannelServer  - connect existing
    M     09:52:35:296 | ICE CD: Initializing channel server in mode 0.
    M     09:52:35:296 | ICE CD: Initializing channel server for CCS v4 in mode 0.
    M     09:52:35:296 | ICE CD: ~IceChannelServer
        E 09:52:35:296 | Trace Factory: Channel server creation failed.
    M     09:57:27:795 | AETProperties: Operation Server # 0 is released
    M     09:57:27:795 | DevId: DestroyDeviceIdentifier - 0x1b7ea158  devIdRefCount=1
    M     10:12:56:617 | Trace JNI: connecting channel server
    M     10:12:56:633 | Trace Factory: calling CreateChannelServer  m_channelServer=0x0
    M     10:12:56:633 | Trace Factory: Reusing environment from previous session.
    M     10:12:56:633 | Trace Factory: CreateChannelServer  - connect existing
    M     10:12:56:633 | ICE CD: Initializing channel server in mode 0.
    M     10:12:56:633 | ICE CD: Initializing channel server for CCS v4 in mode 0.
    M     10:12:56:633 | ICE CD: ~IceChannelServer
        E 10:12:56:633 | Trace Factory: Channel server creation failed.
        E 10:12:56:633 | Trace JNI: Channel server creation failed..
    M     10:12:56:633 | Trace JNI: connecting channel server - DONE
    M     10:12:57:179 | cToolsIF: CreateSystem() is passed
    M     10:12:57:179 | Trace Factory: Calling CreateTraceFactory
    M     10:12:57:179 | Trace Factory: CreateTraceFactory pStaticFactory=0x1b7e2e30    refcount=10
    M     10:12:57:179 | Trace Factory: calling CreateChannelServer  m_channelServer=0x0
    M     10:12:57:179 | Trace Factory: Reusing environment from previous session.
    M     10:12:57:179 | Trace Factory: CreateChannelServer  - create new
    M     10:12:57:179 | ICE CD: Initializing channel server in mode 1.
    M     10:12:57:179 | ICE CD: Initializing channel server for CCS v4 in mode 1.
    M     10:12:57:179 | ICE CD: Strting to load ICE client properties.
    M     10:12:57:242 | ICE CD: Loaded ICE client properties.
    M     10:12:57:242 | ICE CD: using C:\Dokumente und Einstellungen\eodsch\.TI-trace\data\trace_server_config.txt as icebox server configuration
    M     10:12:57:288 | ICE CD: starting icebox : TraceCompMgr.exe --Ice.Config="C:\Dokumente und Einstellungen\eodsch\.TI-trace\data\trace_server_config.txt"
    M     10:12:57:382 | ICE CD: icebox invoked pid 5788
    M     10:12:57:445 | ICE CD: Trace Server invoked PID 5876 .
    M     10:12:57:445 | ICE CD: Trying to initialize ICE with properties.
    M     10:12:57:445 | ICE CD: Trying to get channel server instance.
    M     10:12:59:568 | ICE CD: Trying to initialize ICE with properties.
    M     10:12:59:568 | ICE CD: Trying to get channel server instance.
    M     01/24/12 10:13:00:239 | ********** Trace Server Starting **********
    M      MODULE INFO - TraceServer.exe  PID=5876 : TraceServer.exe
    M     10:13:00:270 | Trace Server: Init server successful
    M     10:13:00:270 | Trace Server: register exit handlers
    M     10:13:00:270 | Trace Server: getting topic manager. Attempt = 1
    M     10:13:01:644 | ICE CD: Trying to initialize ICE with properties.
    M     10:13:01:644 | ICE CD: Trying to get channel server instance.
     W    10:13:02:253 | Trace Server: Network.cpp:545: Ice::ConnectionRefusedException:
    # a
    M     10:13:02:253 | Trace Server: getting topic manager. Attempt = 2
    M     10:13:04:048 | ICE CD: Trying to initialize ICE with properties.
    M     10:13:04:048 | ICE CD: Trying to get channel server instance.
     W    10:13:04:422 | Trace Server: Network.cpp:545: Ice::ConnectionRefusedException:
    M     10:13:04:422 | Trace Server: getting topic manager. Attempt = 3
    M     10:13:06:015 | ICE CD: Trying to initialize ICE with properties.
    M     10:13:06:015 | ICE CD: Trying to get channel server instance.
     W    10:13:06:608 | Trace Server: Network.cpp:545: Ice::ConnectionRefusedException:
    M     10:13:06:608 | Trace Server: getting topic manager. Attempt = 4
    M     10:13:08:091 | ICE CD: Trying to initialize ICE with properties.
    M     10:13:08:091 | ICE CD: Trying to get channel server instance.
     W    10:13:08:575 | Trace Server: Network.cpp:545: Ice::ConnectionRefusedException:
    M     10:13:08:575 | Trace Server: getting topic manager. Attempt = 5
    M     10:13:10:277 | ICE CD: Trying to initialize ICE with properties.
    M     10:13:10:277 | ICE CD: Trying to get channel server instance.
     W    10:13:10:652 | Trace Server: Network.cpp:545: Ice::ConnectionRefusedException:
    M     10:13:10:652 | Trace Server: getting topic manager. Attempt = 6
    M     10:13:12:463 | ICE CD: Trying to initialize ICE with properties.
    M     10:13:12:463 | ICE CD: Trying to get channel server instance.
     W    10:13:12:729 | Trace Server: Network.cpp:545: Ice::ConnectionRefusedException:
    Icej
    M     10:13:12:729 | Trace Server: getting topic manager. Attempt = 7
    M     10:13:14:649 | ICE CD: Trying to initialize ICE with properties.
    M     10:13:14:649 | ICE CD: Trying to get channel server instance.
     W    10:13:14:915 | Trace Server: Network.cpp:545: Ice::ConnectionRefusedException:
    M     10:13:14:915 | Trace Server: getting topic manager. Attempt = 8
    M     10:13:16:726 | ICE CD: Trying to initialize ICE with properties.
    M     10:13:16:726 | ICE CD: Trying to get channel server instance.
     W    10:13:17:210 | Trace Server: Network.cpp:545: Ice::ConnectionRefusedException:
    # 0 = no P
    M     10:13:17:210 | Trace Server: getting topic manager. Attempt = 9
     W    10:13:18:631 | ICE CD: failed to get proxy instance for the channel server.
    M     10:13:18:631 | ICE CD: ~IceChannelServer
    M     10:13:18:631 | ICE CD: Created new Channel Server 0x1d284d68
        E 10:13:18:631 | Trace Factory: Channel server creation failed.
    M     10:13:18:647 | AETPropertyHelper: Get server name from file C:\Programme\Texas Instruments\ccsv4\emulation\analysis\bin\../xmldb/aet_config/aetdvrs.xml
        E 10:13:18:678 | AETProperties: No server name for CPU 2000
     W    10:13:19:178 | Trace Server: Network.cpp:545: Ice::ConnectionRefusedException:
    M     10:13:19:178 | Trace Server: getting topic manager. Attempt = 10
    M     10:13:19:287 | cTools2000: CreateSystem() is called. CPU Type: 6455
    M     10:13:19:287 | cToolsIF: CreateSystem() is passed
    M     10:13:19:287 | Trace Factory: Calling CreateTraceFactory
    M     10:13:19:287 | Trace Factory: CreateTraceFactory pStaticFactory=0x1b7e2e30    refcount=11
    M     10:13:19:287 | Trace Factory: calling CreateChannelServer  m_channelServer=0x0
    M     10:13:19:287 | Trace Factory: Reusing environment from previous session.
    M     10:13:19:287 | Trace Factory: CreateChannelServer  - create new
    M     10:13:19:303 | ICE CD: Initializing channel server in mode 1.
    M     10:13:19:303 | ICE CD: Initializing channel server for CCS v4 in mode 1.
    M     10:13:19:303 | ICE CD: Terminating icebox from prev session pid=5788.
    M     10:13:19:303 | ICE CD: Terminating trace server from prev session pid=5876.
    M     10:13:19:303 | ICE CD: Strting to load ICE client properties.
    M     10:13:19:303 | ICE CD: Loaded ICE client properties.
    M     10:13:19:303 | ICE CD: using C:\Dokumente und Einstellungen\eodsch\.TI-trace\data\trace_server_config.txt as icebox server configuration
    M     10:13:19:303 | ICE CD: starting icebox : TraceCompMgr.exe --Ice.Config="C:\Dokumente und Einstellungen\eodsch\.TI-trace\data\trace_server_config.txt"
    M     10:13:19:334 | ICE CD: icebox invoked pid 5788
    M     10:13:19:334 | ICE CD: Trace Server invoked PID 5876 .
    M     10:13:19:334 | ICE CD: Trying to initialize ICE with properties.
    M     01/24/12 10:13:19:334 | ********** Trace Server Starting **********
    M      MODULE INFO - TraceServer.exe  PID=2360 : TraceServer.exe
    M     10:13:19:381 | ICE CD: Trying to get channel server instance.
    M     10:13:19:396 | Trace Server: Init server successful
    M     10:13:19:396 | Trace Server: register exit handlers
    M     10:13:19:396 | Trace Server: getting topic manager. Attempt = 1
    M     10:13:21:426 | ICE CD: Trying to initialize ICE with properties.
    M     10:13:21:426 | ICE CD: Trying to get channel server instance.
     W    10:13:21:473 | Trace Server: Network.cpp:545: Ice::ConnectionRefusedException:
    # a
    M     10:13:21:473 | Trace Server: getting topic manager. Attempt = 2
    M     10:13:23:503 | ICE CD: Trying to initialize ICE with properties.
    M     10:13:23:503 | ICE CD: Trying to get channel server instance.
     W    10:13:23:768 | Trace Server: Network.cpp:545: Ice::ConnectionRefusedException:
    M     10:13:23:768 | Trace Server: getting topic manager. Attempt = 3
    M     10:13:25:580 | ICE CD: Trying to initialize ICE with properties.
    M     10:13:25:580 | ICE CD: Trying to get channel server instance.
     W    10:13:25:955 | Trace Server: Network.cpp:545: Ice::ConnectionRefusedException:
    M     10:13:25:955 | Trace Server: getting topic manager. Attempt = 4
    M     10:13:27:766 | ICE CD: Trying to initialize ICE with properties.
    M     10:13:27:766 | ICE CD: Trying to get channel server instance.
     W    10:13:27:922 | Trace Server: Network.cpp:545: Ice::ConnectionRefusedException:
    M     10:13:27:922 | Trace Server: getting topic manager. Attempt = 5
    M     10:13:29:952 | ICE CD: Trying to initialize ICE with properties.
    M     10:13:29:952 | ICE CD: Trying to get channel server instance.
     W    10:13:30:108 | Trace Server: Network.cpp:545: Ice::ConnectionRefusedException:
    M     10:13:30:108 | Trace Server: getting topic manager. Attempt = 6
    M     10:13:32:076 | ICE CD: Trying to initialize ICE with properties.
    M     10:13:32:201 | ICE CD: Trying to get channel server instance.
     W    10:13:32:294 | Trace Server: Network.cpp:545: Ice::ConnectionRefusedException:
    Icej
    M     10:13:32:294 | Trace Server: getting topic manager. Attempt = 7
    M     10:13:34:324 | ICE CD: Trying to initialize ICE with properties.
    M     10:13:34:324 | ICE CD: Trying to get channel server instance.
     W    10:13:34:699 | Trace Server: Network.cpp:545: Ice::ConnectionRefusedException:
    M     10:13:34:699 | Trace Server: getting topic manager. Attempt = 8
    M     10:13:36:510 | ICE CD: Trying to initialize ICE with properties.
    M     10:13:36:510 | ICE CD: Trying to get channel server instance.
     W    10:13:36:776 | Trace Server: Network.cpp:545: Ice::ConnectionRefusedException:
    # 0 = no P
    M     10:13:36:776 | Trace Server: getting topic manager. Attempt = 9
    M     10:13:38:478 | ICE CD: Trying to initialize ICE with properties.
    M     10:13:38:478 | ICE CD: Trying to get channel server instance.
     W    10:13:38:853 | Trace Server: Network.cpp:545: Ice::ConnectionRefusedException:
    M     10:13:38:853 | Trace Server: getting topic manager. Attempt = 10
     W    10:13:40:601 | ICE CD: failed to get proxy instance for the channel server.
    M     10:13:40:601 | ICE CD: ~IceChannelServer
    M     10:13:40:601 | ICE CD: Created new Channel Server 0x1d2858c0
        E 10:13:40:601 | Trace Factory: Channel server creation failed.
    M     10:13:40:601 | AETPropertyHelper: Get server name from file C:\Programme\Texas Instruments\ccsv4\emulation\analysis\bin\../xmldb/aet_config/aetdvrs.xml
    M     10:13:40:601 | AETProperties: Operation Server Name AETOperationServer for CPU 6455
    M     10:13:40:633 | AETProperties: Call GetOperationServer() for CPU 6455
    M     10:13:40:664 | AETOperationServer: Device Identifier loaded
    M     10:13:40:664 | DevId: Can Create Server.
    M     10:13:40:664 | DevId: CreateDeviceIdentifier - devIdPtr=0x1b7ea158 devIdRefCount=1
    M     10:13:40:664 | DevId: Loading factory DLL - TraceFactory.dll
    M     10:13:40:664 | DevId: Connecting to Trace factory
    M     10:13:40:664 | Trace Factory: Calling CreateTraceFactory
    M     10:13:40:664 | Trace Factory: CreateTraceFactory pStaticFactory=0x1b7e2e30    refcount=12
    M     10:13:40:664 | DevId: Connecting Live Channel Server
    M     10:13:40:664 | Trace Factory: calling CreateChannelServer  m_channelServer=0x0
    M     10:13:40:664 | Trace Factory: Reusing environment from previous session.
    M     10:13:40:664 | Trace Factory: CreateChannelServer  - connect existing
    M     10:13:40:664 | ICE CD: Initializing channel server in mode 0.
    M     10:13:40:680 | ICE CD: Initializing channel server for CCS v4 in mode 0.
    M     10:13:40:680 | ICE CD: Strting to load ICE client properties.
    M     10:13:40:680 | ICE CD: Loaded ICE client properties.
    M     10:13:40:680 | ICE CD: using C:\Dokumente und Einstellungen\eodsch\.TI-trace\data\trace_server_config.txt as icebox server configuration
    M     10:13:40:680 | ICE CD: starting icebox : TraceCompMgr.exe --Ice.Config="C:\Dokumente und Einstellungen\eodsch\.TI-trace\data\trace_server_config.txt"
    M     10:13:40:695 | ICE CD: icebox invoked pid 500
    M     10:13:40:695 | ICE CD: Trying to initialize ICE with properties.
    M     10:13:40:711 | ICE CD: Trying to get channel server instance.
     W    10:13:40:929 | Trace Server: Network.cpp:545: Ice::ConnectionRefusedException:
        E 10:13:40:929 | Trace Server: Error Unable to initialize the IceStorm service.
    M     10:13:40:929 | Trace Server: Destroying communicator
    M     10:13:40:929 | Trace Server: handling exit
     W    10:13:42:897 | ICE CD: failed to get proxy instance for the channel server.
    M     10:13:42:897 | ICE CD: ~IceChannelServer
        E 10:13:42:897 | Trace Factory: Channel server creation failed.
     W    10:13:42:897 | DevId: Exception in connecting Channel Server
    M     10:13:42:897 | DevId: Loading factory DLL - TraceFactory.dll
    M     10:13:42:897 | DevId: Connecting to Trace factory
    M     10:13:42:897 | Trace Factory: Calling CreateTraceFactory
    M     10:13:42:897 | Trace Factory: CreateTraceFactory pStaticFactory=0x1b7e2e30    refcount=13
    M     10:13:42:897 | DevId: Connecting Live Channel Server
    M     10:13:42:897 | Trace Factory: calling CreateChannelServer  m_channelServer=0x0
    M     10:13:42:897 | Trace Factory: Reusing environment from previous session.
    M     10:13:42:897 | Trace Factory: CreateChannelServer  - connect existing
    M     10:13:42:897 | ICE CD: Initializing channel server in mode 0.
    M     10:13:42:897 | ICE CD: Initializing channel server for CCS v4 in mode 0.
    M     10:13:42:897 | ICE CD: Strting to load ICE client properties.
    M     10:13:42:897 | ICE CD: Loaded ICE client properties.
    M     10:13:42:897 | ICE CD: Trying to initialize ICE with properties.
    M     10:13:42:912 | ICE CD: Trying to get channel server instance.
     W    10:13:44:974 | ICE CD: failed to get proxy instance for the channel server.
    M     10:13:44:974 | ICE CD: ~IceChannelServer
        E 10:13:44:974 | Trace Factory: Channel server creation failed.
     W    10:13:44:974 | DevId: Exception in connecting Channel Server
        E 10:13:44:974 | DevId: channel driver is not valid in LoadDeviceConnectionInfo()
    M     10:13:44:974 | DevId: Loading factory DLL - TraceFactory.dll
    M     10:13:44:974 | DevId: Connecting to Trace factory
    M     10:13:44:974 | Trace Factory: Calling CreateTraceFactory
    M     10:13:44:974 | Trace Factory: CreateTraceFactory pStaticFactory=0x1b7e2e30    refcount=14
    M     10:13:44:974 | DevId: Connecting Live Channel Server
    M     10:13:44:974 | Trace Factory: calling CreateChannelServer  m_channelServer=0x0
    M     10:13:44:974 | Trace Factory: Reusing environment from previous session.
    M     10:13:44:974 | Trace Factory: CreateChannelServer  - connect existing
    M     10:13:44:974 | ICE CD: Initializing channel server in mode 0.
    M     10:13:44:974 | ICE CD: Initializing channel server for CCS v4 in mode 0.
    M     10:13:44:974 | ICE CD: Strting to load ICE client properties.
    M     10:13:44:974 | ICE CD: Loaded ICE client properties.
    M     10:13:44:974 | ICE CD: Trying to initialize ICE with properties.
    M     10:13:44:974 | ICE CD: Trying to get channel server instance.
     W    10:13:47:160 | ICE CD: failed to get proxy instance for the channel server.
    M     10:13:47:160 | ICE CD: ~IceChannelServer
        E 10:13:47:160 | Trace Factory: Channel server creation failed.
     W    10:13:47:160 | DevId: Exception in connecting Channel Server
    M     10:13:47:160 | AETOperationServer: nGEMType value =0
    M     10:13:47:160 | AETPropertyHelper: UBM property file name AET_Property64Plus.xml for CPU 6455
    M     10:13:47:160 | AETPropertyHelper: Created DB for C:\Programme\Texas Instruments\ccsv4\emulation\analysis\bin\../xmldb/aet_config/AET_Property64Plus.xml not found
    M     10:13:47:160 | AETPropertyHelper: Create new DB for C:\Programme\Texas Instruments\ccsv4\emulation\analysis\bin\../xmldb/aet_config/AET_Property64Plus.xml
    M     10:13:47:191 | AETPropertyHelper: Property database 0 is created.
    M     10:13:47:191 | DevId: Loading factory DLL - TraceFactory.dll
    M     10:13:47:191 | DevId: Connecting to Trace factory
    M     10:13:47:191 | Trace Factory: Calling CreateTraceFactory
    M     10:13:47:191 | Trace Factory: CreateTraceFactory pStaticFactory=0x1b7e2e30    refcount=15
    M     10:13:47:191 | DevId: Connecting Live Channel Server
    M     10:13:47:191 | Trace Factory: calling CreateChannelServer  m_channelServer=0x0
    M     10:13:47:191 | Trace Factory: Reusing environment from previous session.
    M     10:13:47:191 | Trace Factory: CreateChannelServer  - connect existing
    M     10:13:47:191 | ICE CD: Initializing channel server in mode 0.
    M     10:13:47:207 | ICE CD: Initializing channel server for CCS v4 in mode 0.
    M     10:13:47:207 | ICE CD: Strting to load ICE client properties.
    M     10:13:47:207 | ICE CD: Loaded ICE client properties.
    M     10:13:47:207 | ICE CD: Trying to initialize ICE with properties.
    M     10:13:47:207 | ICE CD: Trying to get channel server instance.
     W    10:13:49:346 | ICE CD: failed to get proxy instance for the channel server.
    M     10:13:49:346 | ICE CD: ~IceChannelServer
        E 10:13:49:346 | Trace Factory: Channel server creation failed.
     W    10:13:49:346 | DevId: Exception in connecting Channel Server
    M     10:13:49:346 | DevId: Loading factory DLL - TraceFactory.dll
    M     10:13:49:346 | DevId: Connecting to Trace factory
    M     10:13:49:346 | Trace Factory: Calling CreateTraceFactory
    M     10:13:49:346 | Trace Factory: CreateTraceFactory pStaticFactory=0x1b7e2e30    refcount=16
    M     10:13:49:346 | DevId: Connecting Live Channel Server
    M     10:13:49:346 | Trace Factory: calling CreateChannelServer  m_channelServer=0x0
    M     10:13:49:346 | Trace Factory: Reusing environment from previous session.
    M     10:13:49:346 | Trace Factory: CreateChannelServer  - connect existing
    M     10:13:49:346 | ICE CD: Initializing channel server in mode 0.
    M     10:13:49:346 | ICE CD: Initializing channel server for CCS v4 in mode 0.
    M     10:13:49:346 | ICE CD: Strting to load ICE client properties.
    M     10:13:49:346 | ICE CD: Loaded ICE client properties.
    M     10:13:49:346 | ICE CD: Trying to initialize ICE with properties.
    M     10:13:49:346 | ICE CD: Trying to get channel server instance.
     W    10:13:51:641 | ICE CD: failed to get proxy instance for the channel server.
    M     10:13:51:641 | ICE CD: ~IceChannelServer
        E 10:13:51:641 | Trace Factory: Channel server creation failed.
     W    10:13:51:641 | DevId: Exception in connecting Channel Server
    M     10:13:51:641 | AETOperationServer: Creating operation server for CPU 6455
    M     10:13:51:641 | AETProperties: Operation Server # 0 is created
    M     10:13:51:641 | AETProperties: Operation Server Createed 0x1d3374f0 for CPU 6455
    M     10:13:52:188 | Trace Factory: calling CreateChannelServer  m_channelServer=0x0
    M     10:13:52:188 | Trace Factory: Reusing environment from previous session.
    M     10:13:52:188 | Trace Factory: CreateChannelServer  - connect existing
    M     10:13:52:188 | ICE CD: Initializing channel server in mode 0.
    M     10:13:52:188 | ICE CD: Initializing channel server for CCS v4 in mode 0.
    M     10:13:52:188 | ICE CD: Strting to load ICE client properties.
    M     10:13:52:188 | ICE CD: Loaded ICE client properties.
    M     10:13:52:188 | ICE CD: Trying to initialize ICE with properties.
    M     10:13:52:188 | ICE CD: Trying to get channel server instance.
     W    10:13:54:155 | ICE CD: failed to get proxy instance for the channel server.
    M     10:13:54:155 | ICE CD: ~IceChannelServer
        E 10:13:54:155 | Trace Factory: Channel server creation failed.
    M     10:14:06:054 | AETProperties: Operation Server # 0 is released
    M     10:14:06:054 | DevId: DestroyDeviceIdentifier - 0x1b7ea158  devIdRefCount=1
    Simon
