Other Parts Discussed in Thread: CCSTUDIO
For some inexplicable reason, I recently an unable to use the Expressions (Watch) window. Whenever I first launch the debugger, I get a "Problem Occurred" dialog box that says: "'Asynchronous viewer input update' has encountered a problem." with an internal error of "Argument cannot be null". I am running CCS version 5.1.0.09000.
Any clues here would be greatly appreciated, as this has made my last few debug sessions rather painful.
The event in the error log is as follows:
Exception Stack Trace:
java.lang.IllegalArgumentException: Argument cannot be null
at org.eclipse.swt.SWT.error(SWT.java:4263)
at org.eclipse.swt.SWT.error(SWT.java:4197)
at org.eclipse.swt.SWT.error(SWT.java:4168)
at org.eclipse.swt.widgets.Widget.error(Widget.java:468)
at org.eclipse.swt.widgets.TreeColumn.setText(TreeColumn.java:649)
at org.eclipse.debug.internal.ui.viewers.model.InternalTreeModelViewer.buildColumns(InternalTreeModelViewer.java:1425)
at org.eclipse.debug.internal.ui.viewers.model.InternalTreeModelViewer.configureColumns(InternalTreeModelViewer.java:1292)
at org.eclipse.debug.internal.ui.viewers.model.InternalTreeModelViewer.resetColumns(InternalTreeModelViewer.java:1268)
at org.eclipse.debug.internal.ui.viewers.model.InternalTreeModelViewer.inputChanged(InternalTreeModelViewer.java:1239)
at org.eclipse.jface.viewers.ContentViewer.setInput(ContentViewer.java:280)
at org.eclipse.jface.viewers.StructuredViewer.setInput(StructuredViewer.java:1690)
at org.eclipse.debug.internal.ui.views.variables.VariablesView.setViewerInput(VariablesView.java:483)
at org.eclipse.debug.internal.ui.views.expression.ExpressionView.viewerInputUpdateComplete(ExpressionView.java:127)
at org.eclipse.debug.internal.ui.views.variables.VariablesView$1.viewerInputComplete(VariablesView.java:300)
at org.eclipse.debug.internal.ui.viewers.model.provisional.ViewerInputService$2.viewerInputComplete(ViewerInputService.java:51)
at org.eclipse.debug.internal.ui.viewers.model.ViewerInputUpdate$1.runInUIThread(ViewerInputUpdate.java:68)
at org.eclipse.ui.progress.UIJob$1.run(UIJob.java:95)
at org.eclipse.swt.widgets.RunnableLock.run(RunnableLock.java:35)
at org.eclipse.swt.widgets.Synchronizer.runAsyncMessages(Synchronizer.java:135)
at org.eclipse.swt.widgets.Display.runAsyncMessages(Display.java:4140)
at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java:3757)
at org.eclipse.ui.internal.Workbench.runEventLoop(Workbench.java:2696)
at org.eclipse.ui.internal.Workbench.runUI(Workbench.java:2660)
at org.eclipse.ui.internal.Workbench.access$4(Workbench.java:2494)
at org.eclipse.ui.internal.Workbench$7.run(Workbench.java:674)
at org.eclipse.core.databinding.observable.Realm.runWithDefault(Realm.java:332)
at org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Workbench.java:667)
at org.eclipse.ui.PlatformUI.createAndRunWorkbench(PlatformUI.java:149)
at org.eclipse.ui.internal.ide.application.IDEApplication.start(IDEApplication.java:123)
at org.eclipse.equinox.internal.app.EclipseAppHandle.run(EclipseAppHandle.java:196)
at org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher.runApplication(EclipseAppLauncher.java:110)
at org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher.start(EclipseAppLauncher.java:79)
at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:344)
at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:179)
at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method)
at sun.reflect.NativeMethodAccessorImpl.invoke(Unknown Source)
at sun.reflect.DelegatingMethodAccessorImpl.invoke(Unknown Source)
at java.lang.reflect.Method.invoke(Unknown Source)
at org.eclipse.equinox.launcher.Main.invokeFramework(Main.java:622)
at org.eclipse.equinox.launcher.Main.basicRun(Main.java:577)
at org.eclipse.equinox.launcher.Main.run(Main.java:1410)
Session Data:
eclipse.buildId=M20110909-1335
java.version=1.6.0_13
java.vendor=Sun Microsystems Inc.
BootLoader constants: OS=win32, ARCH=x86, WS=win32, NL=en_US
Framework arguments: -product com.ti.ccstudio.branding.product
Command-line arguments: -os win32 -ws win32 -arch x86 -product com.ti.ccstudio.branding.product
