Part Number: CODECOMPOSER
How to add ARMNotVisible.xml file to CCS debug view?
My CCS Version:12.8.1.00005
Thanks!
Thanks!
I am currently debugging a bootloader I wrote myself and need to inspect the CP15 registers. However, I found that they cannot be viewed by default. Adding them manually in CCS each time is quite troublesome, so I want to add this XML file to the registers permanently. thanks!
Can you let me know which device/board are you using? If you have the ccxml you are using, please attach it as well.
Thank you.
