CODECOMPOSER: HELP - Choosing the latest CCS for a specific legacy Chip set
Part Number: CODECOMPOSER
Is there a simple way of choosing the correct CCS release per below link?
CCSTUDIO IDE, configuration, compiler or debugger | TI.com
CCS release that supports this Chip set:
I need to create the SBOM for one CCS Project. Below is the relevant SBOM link from another user:
CODECOMPOSER: Need Help Generating SBOM for CCS Project - Code Composer Studio forum - Code Composer StudioTm︎ - TI E2E support forums
Currently, I'm creating the SBOM manually. Any help in choosing the correct CCS release that could generate the SBOM information would be great - Thank you!!!
  • Hi George,
    I don't think there is a programmatic way to determine if a device or device family is supported in a particular release, but we should be listing out families we are dropping support for in the release notes.
    For the one you have highlighted in your screenshot (C64x), we should have support for up to CCS v12. And we should have similar support in the new CCS v20 as well.
    Ricky
  • Hi Ricky,
    Per your advice, I've installed CCS V20 but could not quite import one partial CCS 6xx project. The complete project also requires other checked mark chip sets as well.
    Since I'm working on this "science" subject on my own time to support for the upcoming project with the proper funding so we can select the right CCS tool.
    I do appreciate much for your detailed response.
    George
