CODECOMPOSER: Sysconfig doesn't work
Expert 4466 points
Part Number: CODECOMPOSER
Other Parts Discussed in Thread: SYSCONFIG, CCSTUDIO
Hello Champs,
My customer suddenly can't open the sysconfig file inside any C2000 projects. The error message is as below. But basically they have tried to re-install the CCS v12.7.1, v12.8.1 but it doesn't help. They also tried with CCSv20.2.0 but it even can't start after. There are Windows 10 and Windows 11 machines that encountered same issue. Please advise possible root causes and workaround.
Java.lang.RuntimeException: Unable to initialize the browser engine. For Linux host, please check the dependencies are installed by running the 'ldd' command for the libraries in this folder C:\ti\ccs1281\ccs\eclipse\configuration\.jxbrowser.bin\7.29.
               at com.ti.chromium.browser.JxBrowser.<init>(JxBrowser.java:338)
               at com.ti.chromium.browser.ChromiumBrowserContributor.createBrowser(ChromiumBrowserContributor.java:39)
               at com.ti.browser.internal.TIBrowser.<init>(TIBrowser.java:98)
               at com.ti.browser.internal.TIBrowser.<init>(TIBrowser.java:88)
               at com.ti.browser.internal.TIBrowser.<init>(TIBrowser.java:76)
               at com.ti.browser.TIBrowserFactory.createBrowser(TIBrowserFactory.java:34)
               at com.ti.ccstudio.project.ui.webcontent.internal.sysconfig.SysConfigEditor.createPartControl(SysConfigEditor.java:563)
               at org.eclipse.ui.internal.e4.compatibility.CompatibilityPart.createPartControl(CompatibilityPart.java:158)
               at org.eclipse.ui.internal.e4.compatibility.CompatibilityEditor.createPartControl(CompatibilityEditor.java:96)
               at org.eclipse.ui.internal.e4.compatibility.CompatibilityPart.create(CompatibilityPart.java:365)
               at java.base/jdk.internal.reflect.NativeMethodAccessorImpl.invoke0(Native Method)
               at java.base/jdk.internal.reflect.NativeMethodAccessorImpl.invoke(Unknown Source)
               at java.base/jdk.internal.reflect.DelegatingMethodAccessorImpl.invoke(Unknown Source)
               at java.base/java.lang.reflect.Method.invoke(Unknown Source)
               at org.eclipse.e4.core.internal.di.MethodRequestor.execute(MethodRequestor.java:58)
               at org.eclipse.e4.core.internal.di.InjectorImpl.processAnnotated(InjectorImpl.java:995)
               at org.eclipse.e4.core.internal.di.InjectorImpl.processAnnotated(InjectorImpl.java:960)
               at org.eclipse.e4.core.internal.di.InjectorImpl.internalInject(InjectorImpl.java:140)
               at org.eclipse.e4.core.internal.di.InjectorImpl.internalMake(InjectorImpl.java:403)
               at org.eclipse.e4.core.internal.di.InjectorImpl.make(InjectorImpl.java:330)
               at org.eclipse.e4.core.contexts.ContextInjectionFactory.make(ContextInjectionFactory.java:202)
               at org.eclipse.e4.ui.internal.workbench.ReflectionContributionFactory.createFromBundle(ReflectionContributionFactory.java:91)
               at org.eclipse.e4.ui.internal.workbench.ReflectionContributionFactory.doCreate(ReflectionContributionFactory.java:60)
               at org.eclipse.e4.ui.internal.workbench.ReflectionContributionFactory.create(ReflectionContributionFactory.java:42)
               at org.eclipse.e4.ui.workbench.renderers.swt.ContributedPartRenderer.createWidget(ContributedPartRenderer.java:132)
               at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine.createWidget(PartRenderingEngine.java:995)
               at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine.safeCreateGui(PartRenderingEngine.java:659)
               at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine.safeCreateGui(PartRenderingEngine.java:763)
               at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine$2.run(PartRenderingEngine.java:728)
               at org.eclipse.core.runtime.SafeRunner.run(SafeRunner.java:45)
               at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine.createGui(PartRenderingEngine.java:712)
               at org.eclipse.e4.ui.internal.workbench.PartServiceImpl.lambda$0(PartServiceImpl.java:105)
               at org.eclipse.e4.ui.services.internal.events.UIEventHandler.lambda$0(UIEventHandler.java:38)
               at org.eclipse.swt.widgets.Synchronizer.syncExec(Synchronizer.java:236)
               at org.eclipse.ui.internal.UISynchronizer.syncExec(UISynchronizer.java:133)
               at org.eclipse.swt.widgets.Display.syncExec(Display.java:4779)
               at org.eclipse.e4.ui.workbench.swt.DisplayUISynchronize.syncExec(DisplayUISynchronize.java:34)
               at org.eclipse.e4.ui.services.internal.events.UIEventHandler.handleEvent(UIEventHandler.java:38)
               at org.eclipse.equinox.internal.event.EventHandlerWrapper.handleEvent(EventHandlerWrapper.java:205)
               at org.eclipse.equinox.internal.event.EventHandlerTracker.dispatchEvent(EventHandlerTracker.java:203)
               at org.eclipse.equinox.internal.event.EventHandlerTracker.dispatchEvent(EventHandlerTracker.java:1)
               at org.eclipse.osgi.framework.eventmgr.EventManager.dispatchEvent(EventManager.java:234)
               at org.eclipse.osgi.framework.eventmgr.ListenerQueue.dispatchEventSynchronous(ListenerQueue.java:151)
               at org.eclipse.equinox.internal.event.EventAdminImpl.dispatchEvent(EventAdminImpl.java:133)
               at org.eclipse.equinox.internal.event.EventAdminImpl.sendEvent(EventAdminImpl.java:75)
               at org.eclipse.equinox.internal.event.EventComponent.sendEvent(EventComponent.java:44)
               at org.eclipse.e4.ui.services.internal.events.EventBroker.send(EventBroker.java:55)
               at org.eclipse.e4.ui.internal.workbench.UIEventPublisher.notifyChanged(UIEventPublisher.java:63)
               at org.eclipse.emf.common.notify.impl.BasicNotifierImpl.eNotify(BasicNotifierImpl.java:424)
               at org.eclipse.e4.ui.model.application.ui.impl.ElementContainerImpl.setSelectedElementGen(ElementContainerImpl.java:170)
               at org.eclipse.e4.ui.model.application.ui.impl.ElementContainerImpl.setSelectedElement(ElementContainerImpl.java:188)
               at org.eclipse.e4.ui.internal.workbench.ModelServiceImpl.showElementInWindow(ModelServiceImpl.java:660)
               at org.eclipse.e4.ui.internal.workbench.ModelServiceImpl.bringToTop(ModelServiceImpl.java:624)
               at org.eclipse.e4.ui.internal.workbench.PartServiceImpl.delegateBringToTop(PartServiceImpl.java:787)
               at org.eclipse.e4.ui.internal.workbench.PartServiceImpl.bringToTop(PartServiceImpl.java:401)
               at org.eclipse.e4.ui.internal.workbench.PartServiceImpl.showPart(PartServiceImpl.java:1261)
               at org.eclipse.ui.internal.WorkbenchPage.busyOpenEditor(WorkbenchPage.java:3207)
               at org.eclipse.ui.internal.WorkbenchPage.lambda$9(WorkbenchPage.java:3097)
               at org.eclipse.swt.custom.BusyIndicator.showWhile(BusyIndicator.java:74)
               at org.eclipse.ui.internal.WorkbenchPage.openEditor(WorkbenchPage.java:3095)
               at org.eclipse.ui.internal.WorkbenchPage.openEditor(WorkbenchPage.java:3065)
               at org.eclipse.ui.actions.OpenWithMenu.openEditor(OpenWithMenu.java:325)
               at org.eclipse.ui.actions.OpenWithMenu.lambda$0(OpenWithMenu.java:182)
               at org.eclipse.swt.widgets.EventTable.sendEvent(EventTable.java:89)
               at org.eclipse.swt.widgets.Display.sendEvent(Display.java:4243)
               at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:1063)
               at org.eclipse.swt.widgets.Display.runDeferredEvents(Display.java:4060)
               at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java:3632)
               at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine$5.run(PartRenderingEngine.java:1155)
               at org.eclipse.core.databinding.observable.Realm.runWithDefault(Realm.java:338)
               at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine.run(PartRenderingEngine.java:1046)
               at org.eclipse.e4.ui.internal.workbench.E4Workbench.createAndRunUI(E4Workbench.java:155)
               at org.eclipse.ui.internal.Workbench.lambda$3(Workbench.java:644)
               at org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Workbench.java:551)
               at org.eclipse.ui.PlatformUI.createAndRunWorkbench(PlatformUI.java:156)
               at org.eclipse.ui.internal.ide.application.IDEApplication.start(IDEApplication.java:152)
               at org.eclipse.equinox.internal.app.EclipseAppHandle.run(EclipseAppHandle.java:203)
               at org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher.runApplication(EclipseAppLauncher.java:136)
               at org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher.start(EclipseAppLauncher.java:104)
               at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:401)
               at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:255)
               at org.eclipse.equinox.launcher.Main.invokeFramework(Main.java:659)
               at org.eclipse.equinox.launcher.Main.basicRun(Main.java:596)
               at org.eclipse.equinox.launcher.Main.run(Main.java:1467)
Kien Nguyen
