CODECOMPOSER: proper way to migrate CCS and SDK
Part Number: CODECOMPOSER
I was using CSS 12.7.1 and mspm0 2.1.0.03.
I had checked in my code, projects, and build... i figured it would be easy for someone else to pick up my project and continue, ran into many issues.
1) i can find older version of CSS at https://www.ti.com/tool/download/CCSTUDIO where do i find older versions of sdk mspm0?
2) i would think if i have the .out file and the usb programmer, thats all that is needed to flash the chip, where is the way to do this without recompiling the project?
3) what is the proper way to import my project into CSS 20.2.0.12, i made a new workspace, and then import project, it mostly worked, but the debugger only works from some menu choices (can expand on this later)
4) what is the proper way to import my project from mspm0 2.1.0.03 to mspm0 2.5.1.00?  i did not see how to do this with menus, i tried manually doing it, but no luck.
thanks
