Part Number: CODECOMPOSER
I am having trouble renaming a project in Code Composer Studio 20.2.0.
I have already checked the Theia-related instructions (right-click project → Rename), but in my installation the Rename option does not appear in the context menu.
Steps I tried:
Created a new project and selected device F28335 (also tested with F2833x).
Kernel: No RTOS
Compiler: CCS – TI Compiler
Example: gpio toggle
Copied the generated project folder from
workspace_csstheiato my Desktop. -
Imported the copied project into CCS.
Tried to rename the project, but the Rename option is missing.
Additional issue:
I noticed that the examples 2833x Example in C and 2833x Example in CPP are not available or do not import correctly.
When I try, I get this error message:
" Import failed for project '28335_IQsampleC' because its meta-data cannot be interpreted - please contact support"
Could you let me know:
How I can properly rename a project in CCS 20.2.0?
Whether the missing/invalid examples are a known issue, and if there is a workaround or corrected version?
Thank you for your help!
My Installation:
- Code Composer Studio 20.2.0
- C2000Ware_6_00_00_00
