LAUNCHXL-F28P55X: ccsCompiler.opt compiler argument file fails
Part Number: LAUNCHXL-F28P55X
I have encountered an odd CCS behaviour. When the compiler command input passes over the ~8000 char threshold, CCS will put the args into a x_ccsCompiler.opt file to then pass to the compiler. However, this specifically fails when compiling the FreeRTOS kernel code. See the snippet below that shows the compilation of the queue.c file failing. Note that below I have replaced our project root directory with C:/root, so the command line looks considerably shorter.
Building file: "C:/root/lib/c2000/kernel/FreeRTOS/Source/queue.c"
Invoking: C2000 Compiler
Flags: -v28 -ml -mt --cla_support=cla2 --float_support=fpu32 --tmu_support=tmu0 --vcu_support=vcrc -O3 --opt_for_speed=1 --fp_mode=relaxed --include_path="C:/root/src/brompton/device" --include_path="C:/root/src/brompton" --include_path="C:/root/lib/etl/include" --include_path="C:/root/lib/brixton-library/inc" --include_path="C:/root/lib/c2000/kernel/FreeRTOS/Source/include" --include_path="C:/root/lib/c2000/device_support/f28p55x/headers/include" --include_path="C:/root/lib/c2000/device_support/f28p55x/common/include" --include_path="C:/root/shared_linker" --include_path="C:/root/lib/c2000" --include_path="C:/root/lib/c2000/driverlib/f28p55x/driverlib/" --include_path="C:/ti/ccs2020/ccs/tools/compiler/ti-cgt-c2000_22.6.2.LTS/include" --include_path="C:/root/lib/c2000/kernel/FreeRTOS/Source/portable/CCS/C2000_C28x" --include_path="C:/root/lib/c2000/driverlib/f28p55x/driverlib/inc" --include_path="C:/root/syscfg_gen/launchpad" --include_path="C:/root/lib/c2000ware-motorcontrol-sdk" --include_path="C:/root/lib/c2000ware-motorcontrol-sdk/libraries/control/ctrl/include" --include_path="C:/root/lib/c2000ware-motorcontrol-sdk/libraries/control/pi/include" --include_path="C:/root/lib/c2000ware-motorcontrol-sdk/libraries/control/vsf/include" --include_path="C:/root/lib/c2000ware-motorcontrol-sdk/libraries/control/fwc/include" --include_path="C:/root/lib/c2000ware-motorcontrol-sdk/libraries/control/mtpa/include" --include_path="C:/root/lib/c2000ware-motorcontrol-sdk/libraries/control/vs_freq/include" --include_path="C:/root/lib/c2000ware-motorcontrol-sdk/libraries/control/dclink_ss/include" --include_path="C:/root/lib/c2000ware-motorcontrol-sdk/libraries/filter/filter_fo/include" --include_path="C:/root/lib/c2000ware-motorcontrol-sdk/libraries/filter/filter_so/include" --include_path="C:/root/lib/c2000ware-motorcontrol-sdk/libraries/observers/est_lib/include" --include_path="C:/root/lib/c2000ware-motorcontrol-sdk/libraries/observers/est/include" --include_path="C:/root/lib/c2000ware-motorcontrol-sdk/libraries/observers/esmo/include" --include_path="C:/root/lib/c2000ware-motorcontrol-sdk/libraries/observers/speedfr/include" --include_path="C:/root/lib/c2000ware-motorcontrol-sdk/libraries/observers/speedcalc/include" --include_path="C:/root/lib/c2000ware-motorcontrol-sdk/libraries/observers/ssipd/include" --include_path="C:/root/lib/c2000ware-motorcontrol-sdk/libraries/observers/isbldc/include" --include_path="C:/root/lib/c2000ware-motorcontrol-sdk/libraries/observers/encoder/include" --include_path="C:/root/lib/c2000ware-motorcontrol-sdk/libraries/observers/hall/include" --include_path="C:/root/lib/c2000ware-motorcontrol-sdk/libraries/observers/mpid/include" --include_path="C:/root/lib/c2000ware-motorcontrol-sdk/libraries/transforms/clarke/include" --include_path="C:/root/lib/c2000ware-motorcontrol-sdk/libraries/transforms/ipark/include" --include_path="C:/root/lib/c2000ware-motorcontrol-sdk/libraries/transforms/park/include" --include_path="C:/root/lib/c2000ware-motorcontrol-sdk/libraries/transforms/svgen/include" --include_path="C:/root/lib/c2000ware-motorcontrol-sdk/libraries/transforms/volts/include" --include_path="C:/root/lib/c2000ware-motorcontrol-sdk/libraries/utilities/angle_gen/include" --include_path="C:/root/lib/c2000ware-motorcontrol-sdk/libraries/utilities/cpu_time/include" --include_path="C:/root/lib/c2000ware-motorcontrol-sdk/libraries/utilities/datalog/include" --include_path="C:/root/lib/c2000ware-motorcontrol-sdk/libraries/utilities/step_response/include" --include_path="C:/root/lib/c2000ware-motorcontrol-sdk/libraries/utilities/traj/include/" --include_path="C:/root/lib/c2000ware-motorcontrol-sdk/libraries/utilities/rimpulse/include" --include_path="C:/root/lib/c2000ware-motorcontrol-sdk/libraries/utilities/mod6cnt/include" --include_path="C:/root/lib/c2000ware-motorcontrol-sdk/libraries/utilities/types/include" --include_path="C:/root/lib/c2000/libraries/dsp/VCU/c28/include/vcu0" --define=_FLASH --define=_LAUNCHXL_F28P55X --define=_DUAL_HEADERS --define=CPU1 --define=F28P55x_DEVICE --define=DEBUG --define=_FULL_FAST_LIB --define=__TI_EABI__ --define=__STDC_LIMIT_MACROS --define=_BOOSTXL_DRV8320RS -g --symdebug:dwarf_version=4 --c11 --c++03 --relaxed_ansi --float_operations_allowed=all --printf_support=full --diag_suppress=10063 --diag_warning=225 --diag_wrap=off --display_error_number --verbose_diagnostics --gen_func_subsections=on --abi=eabi --cla_background_task=off --cla_signed_compare_workaround=off --silicon_errata_fpu1_workaround=off --sat_reassoc=off --preproc_with_compile --preproc_dependency="lib/c2000/kernel/FreeRTOS/Source/queue.d_raw" --include_path="C:/root/F28P55x_FLASH/syscfg"
Flags (cont-d): --obj_directory="lib/c2000/kernel/FreeRTOS/Source" --cmd_file="syscfg/board.opt" --cmd_file="syscfg/c2000ware_libraries.opt" --cmd_file="syscfg/c2000_freertos.opt"
"C:/ti/ccs2020/ccs/tools/compiler/ti-cgt-c2000_22.6.2.LTS/bin/cl2000" -@"c2000/kernel/FreeRTOS/Source/queue_ccsCompiler.opt"
The system cannot find the path specified.
>> ERROR: Cannot open command file 'c2000/kernel/FreeRTOS/Source/queue_ccsCompiler.opt': No such file or directory
>> ERROR: no source files, nothing to do
Finished building: "C:/root/lib/c2000/kernel/FreeRTOS/Source/queue.c"
One thing that I have observed, is that the RTOS files are compiled using the absolute path, where the other files (c2000, local project source) are compiled using the relative path. See below a working compilation call. From my CCS project, I cannot figure out why the file paths might be different for the FreeRTOS source files vs other source files.
Building file: "../src/brompton/device/gate_driver/drv8353_decoder.cpp"
Flags: -v28 -ml -mt --cla_support=cla2 --float_support=fpu32 --tmu_support=tmu0 --vcu_support=vcrc -O3 --opt_for_speed=1 --fp_mode=relaxed --include_path="C:/root/f28p55x-application/src/brompton/device" --include_path="C:/root/f28p55x-application/src/brompton" --include_path="C:/root/f28p55x-application/lib/etl/include" --include_path="C:/root/f28p55x-application/lib/brixton-library/inc" --include_path="C:/root/f28p55x-application/lib/c2000/kernel/FreeRTOS/Source/include" --include_path="C:/root/f28p55x-application/lib/c2000/device_support/f28p55x/headers/include" --include_path="C:/root/f28p55x-application/lib/c2000/device_support/f28p55x/common/include" --include_path="C:/root/f28p55x-application/shared_linker" --include_path="C:/root/f28p55x-application/lib/c2000" --include_path="C:/root/f28p55x-application/lib/c2000/driverlib/f28p55x/driverlib/" --include_path="C:/ti/ccs2020/ccs/tools/compiler/ti-cgt-c2000_22.6.2.LTS/include" --include_path="C:/root/f28p55x-application/lib/c2000/kernel/FreeRTOS/Source/portable/CCS/C2000_C28x" --include_path="C:/root/f28p55x-application/lib/c2000/driverlib/f28p55x/driverlib/inc" --include_path="C:/root/f28p55x-application/syscfg_gen/launchpad" --include_path="C:/root/f28p55x-application/lib/c2000ware-motorcontrol-sdk" --include_path="C:/root/f28p55x-application/lib/c2000ware-motorcontrol-sdk/libraries/control/ctrl/include" --include_path="C:/root/f28p55x-application/lib/c2000ware-motorcontrol-sdk/libraries/control/pi/include" --include_path="C:/root/f28p55x-application/lib/c2000ware-motorcontrol-sdk/libraries/control/vsf/include" --include_path="C:/root/f28p55x-application/lib/c2000ware-motorcontrol-sdk/libraries/control/fwc/include" --include_path="C:/root/f28p55x-application/lib/c2000ware-motorcontrol-sdk/libraries/control/mtpa/include" --include_path="C:/root/f28p55x-application/lib/c2000ware-motorcontrol-sdk/libraries/control/vs_freq/include" --include_path="C:/root/f28p55x-application/lib/c2000ware-motorcontrol-sdk/libraries/control/dclink_ss/include" --include_path="C:/root/f28p55x-application/lib/c2000ware-motorcontrol-sdk/libraries/filter/filter_fo/include" --include_path="C:/root/f28p55x-application/lib/c2000ware-motorcontrol-sdk/libraries/filter/filter_so/include" --include_path="C:/root/f28p55x-application/lib/c2000ware-motorcontrol-sdk/libraries/observers/est_lib/include" --include_path="C:/root/f28p55x-application/lib/c2000ware-motorcontrol-sdk/libraries/observers/est/include" --include_path="C:/root/f28p55x-application/lib/c2000ware-motorcontrol-sdk/libraries/observers/esmo/include" --include_path="C:/root/f28p55x-application/lib/c2000ware-motorcontrol-sdk/libraries/observers/speedfr/include" --include_path="C:/root/f28p55x-application/lib/c2000ware-motorcontrol-sdk/libraries/observers/speedcalc/include" --include_path="C:/root/f28p55x-application/lib/c2000ware-motorcontrol-sdk/libraries/observers/ssipd/include" --include_path="C:/root/f28p55x-application/lib/c2000ware-motorcontrol-sdk/libraries/observers/isbldc/include" --include_path="C:/root/f28p55x-application/lib/c2000ware-motorcontrol-sdk/libraries/observers/encoder/include" --include_path="C:/root/f28p55x-application/lib/c2000ware-motorcontrol-sdk/libraries/observers/hall/include" --include_path="C:/root/f28p55x-application/lib/c2000ware-motorcontrol-sdk/libraries/observers/mpid/include" --include_path="C:/root/f28p55x-application/lib/c2000ware-motorcontrol-sdk/libraries/transforms/clarke/include" --include_path="C:/root/f28p55x-application/lib/c2000ware-motorcontrol-sdk/libraries/transforms/ipark/include" --include_path="C:/root/f28p55x-application/lib/c2000ware-motorcontrol-sdk/libraries/transforms/park/include" --include_path="C:/root/f28p55x-application/lib/c2000ware-motorcontrol-sdk/libraries/transforms/svgen/include" --include_path="C:/root/f28p55x-application/lib/c2000ware-motorcontrol-sdk/libraries/transforms/volts/include" --include_path="C:/root/f28p55x-application/lib/c2000ware-motorcontrol-sdk/libraries/utilities/angle_gen/include" --include_path="C:/root/f28p55x-application/lib/c2000ware-motorcontrol-sdk/libraries/utilities/cpu_time/include" --include_path="C:/root/f28p55x-application/lib/c2000ware-motorcontrol-sdk/libraries/utilities/datalog/include" --include_path="C:/root/f28p55x-application/lib/c2000ware-motorcontrol-sdk/libraries/utilities/step_response/include" --include_path="C:/root/f28p55x-application/lib/c2000ware-motorcontrol-sdk/libraries/utilities/traj/include/" --include_path="C:/root/f28p55x-application/lib/c2000ware-motorcontrol-sdk/libraries/utilities/rimpulse/include" --include_path="C:/root/f28p55x-application/lib/c2000ware-motorcontrol-sdk/libraries/utilities/mod6cnt/include" --include_path="C:/root/f28p55x-application/lib/c2000ware-motorcontrol-sdk/libraries/utilities/types/include" --include_path="C:/root/f28p55x-application/lib/c2000/libraries/dsp/VCU/c28/include/vcu0" --define=_FLASH --define=_LAUNCHXL_F28P55X --define=_DUAL_HEADERS --define=CPU1 --define=F28P55x_DEVICE --define=DEBUG --define=_FULL_FAST_LIB --define=__TI_EABI__ --define=__STDC_LIMIT_MACROS --define=_BOOSTXL_DRV8320RS -g --symdebug:dwarf_version=4 --c11 --c++03 --relaxed_ansi --float_operations_allowed=all --printf_support=full --diag_suppress=10063 --diag_warning=225 --diag_wrap=off --display_error_number --verbose_diagnostics --gen_func_subsections=on --abi=eabi --cla_background_task=off --cla_signed_compare_workaround=off --silicon_errata_fpu1_workaround=off --sat_reassoc=off --preproc_with_compile --preproc_dependency="src/brompton/device/gate_driver/drv8353_decoder.d_raw" --include_path="C:/root/f28p55x-application/F28P55x_FLASH/syscfg"
Flags (cont-d): --obj_directory="src/brompton/device/gate_driver" --cmd_file="syscfg/board.opt" --cmd_file="syscfg/c2000ware_libraries.opt" --cmd_file="syscfg/c2000_freertos.opt"
"C:/ti/ccs2020/ccs/tools/compiler/ti-cgt-c2000_22.6.2.LTS/bin/cl2000" -@"src/brompton/device/gate_driver/drv8353_decoder_ccsCompiler.opt"
Finished building: "../src/brompton/device/gate_driver/drv8353_decoder.cpp"
I should note that in our project we are not using the C2000 SDK as a product installed, instead it is a git submodule within the project itself.
  • Does this file exist in your project folder?
    Either that file is not getting generated or the path to it is incorrect.
  • Hi Ki,
    Nope, the file does not exist in the source dir
    .\lib\c2000\kernel\FreeRTOS\Source
    or the build dir (build config is named F28p55x_FLASH)
    .\F28P55x_FLASH\lib\c2000\kernel\FreeRTOS\Source
    For the other source files, they do exist. For example my driver_uart.cpp file has its ccsCompiler.opt file in
    .\F28P55x_FLASH\src\brompton\device\driver_uart_ccsCompiler.opt
  • Thank you for checking. I will try to reproduce this issue on my end.
