Part Number: CODECOMPOSER
Other Parts Discussed in Thread: C2000-CGT
Hello TI team,
We are maintaining a legacy TMS320C2812 project in a regulated industry environment, using:
Code Composer Studio 5.5.0.00077
TI C2000 Compiler v6.2.0
We have encountered the known issue where build output(hex file) changes depending on the project/module path length or location. From earlier forum discussions, I understand a similar problem was tracked as defect SDSCM00049890 (Inconsistent Build Output - Code Composer Studio forum - Code Composer Studio︎ - TI E2E support forums).
Since we operate in a regulated environment, we require maximum technical detail to properly document the issue:
Is it possible to get more details about SDSCM00049890?
Are there any TI documents, release notes, or test cases describing the defect and its resolution?
This information will help us justify an upgrade path and ensure compliance with our industry requirements.
Thank you for your support,
