LP-MSPM0G3507: Code composer Studio no longer reporting errors
Part Number: LP-MSPM0G3507
Other Parts Discussed in Thread: CCSTUDIO
Was running CCS 20.3, now running 20.3.1.5_1.9.1
using ticlang C compiler with FreeRTos
I have a large body of code which run's through the build process and finishes with "gmake: Target 'all' not remade because of errors.", but no errors are identified.   The build issues were becoming more frequent, with errors being flagged in the Output window, but no tagging within the actual files or workspace explorer window.   Then on Friday, the build process just stopped- it always hung.
Looking through other e2e posts, I read deleting cache from {home}/ti/  might help.  It did not.   Also, deleting the contents of the \Debug folder did not help.
Reading bug report EXT_EP_12940, i updated to 20.3.1 (bug report says fixed in 20.4.   After new install, we can run through the build process again, but still the build states there are errors, but does not identify where the problem(s) are.
I noticed changes occurred  in the files .cproject and .ccsproject during Azure Pull requests.   I wonder what differences across the design team could be throwing a wrench in the works.
Help about
  • @ccs/ccstudio 20.3.0
  • @ccs/ccstudio-debug 20.3.0
  • @ccs/ccstudio-getting-started 20.3.0
  • @ccs/ccstudio-guicomposer 20.3.0
  • @ccs/ccstudio-plugin 20.3.0
  • @ccs/ccstudio-project 20.3.0
  • @ccs/ccstudio-support 20.3.0
  • @ccs/ccstudio-trace-config 20.3.0
  • @ccs/ccstudio-trace-viewer 20.3.0
  • @ccs/ccstudio-updater 20.3.0
  • @theia/ai-anthropic 1.58.4
  • @theia/ai-chat 1.58.4
  • @theia/ai-chat-ui 1.58.4
  • @theia/ai-code-completion 1.58.4
  • @theia/ai-core 1.58.4
  • @theia/ai-history 1.58.4
  • @theia/ai-huggingface 1.58.4
  • @theia/ai-llamafile 1.58.4
  • @theia/ai-mcp 1.58.4
  • @theia/ai-ollama 1.58.4
  • @theia/ai-openai 1.58.4
  • @theia/ai-scanoss 1.58.4
  • @theia/ai-terminal 1.58.4
  • @theia/ai-workspace-agent 1.58.4
  • @theia/bulk-edit 1.58.4
  • @theia/callhierarchy 1.58.4
  • @theia/collaboration 1.58.4
  • @theia/console 1.58.4
  • @theia/core 1.58.4
  • @theia/debug 1.58.4
  • @theia/dev-container 1.58.4
  • @theia/editor 1.58.4
  • @theia/editor-preview 1.58.4
  • @theia/electron 1.58.4
  • @theia/external-terminal 1.58.4
  • @theia/file-search 1.58.4
  • @theia/filesystem 1.58.4
  • @theia/keymaps 1.58.4
  • @theia/markers 1.58.4
  • @theia/messages 1.58.4
  • @theia/metrics 1.58.4
  • @theia/mini-browser 1.58.4
  • @theia/monaco 1.58.4
  • @theia/navigator 1.58.4
  • @theia/notebook 1.58.4
  • @theia/outline-view 1.58.4
  • @theia/output 1.58.4
  • @theia/plugin-dev 1.58.4
  • @theia/plugin-ext 1.58.4
  • @theia/plugin-ext-headless 1.58.4
  • @theia/plugin-ext-vscode 1.58.4
  • @theia/preferences 1.58.4
  • @theia/preview 1.58.4
  • @theia/process 1.58.4
  • @theia/property-view 1.58.4
  • @theia/remote 1.58.4
  • @theia/scanoss 1.58.4
  • @theia/scm 1.58.4
  • @theia/scm-extra 1.58.4
  • @theia/search-in-workspace 1.58.4
  • @theia/secondary-window 1.58.4
  • @theia/task 1.58.4
  • @theia/terminal 1.58.4
  • @theia/test 1.58.4
  • @theia/timeline 1.58.4
  • @theia/toolbar 1.58.4
  • @theia/typehierarchy 1.58.4
  • @theia/userstorage 1.58.4
  • @theia/variable-resolver 1.58.4
  • @theia/vsx-registry 1.58.4
  • @theia/workspace 1.58.4
