Other Parts Discussed in Thread: DXP, ADS1299
I have a CCS3.1 which worked fine on Window XP.
I have upgraded my system to windows 7 but my CCS 3.1 won't work keep getting error 0xc0000005.
Can anyone help me fix this problem?
thnx
Most likely the projects you have are for CCSv3. But you should be able to import them into CCSv5. What issues are you experiencing?
I just open the FW project I'm using windows, and I try to compile and this is the whole bunch of errors.
Description Resource Path Location Type
gmake: *** No rule to make target `C:/ti/ccsv5/eclipse/INSTALLROOT_DXP_DEV/src/hw/mmb0/mmb0eeprom.c', needed by `mmb0eeprom.obj'. ccs-dxp-evm Unknown C/C++ Problem
gmake: *** No rule to make target `C:/ti/ccsv5/eclipse/INSTALLROOT_DXP_DEV/src/hw/mmb0/mmb0flash.c', needed by `mmb0flash.obj'. ccs-dxp-evm Unknown C/C++ Problem
gmake: *** No rule to make target `C:/ti/ccsv5/eclipse/INSTALLROOT_DXP_DEV/src/hw/mmb0/mmb0i2c.c', needed by `mmb0i2c.obj'. ccs-dxp-evm Unknown C/C++ Problem
gmake: *** No rule to make target `C:/ti/ccsv5/eclipse/INSTALLROOT_DXP_DEV/src/hw/mmb0/mmb0spibb.c', needed by `mmb0spibb.obj'. ccs-dxp-evm Unknown C/C++ Problem
gmake: *** No rule to make target `C:/ti/ccsv5/eclipse/INSTALLROOT_DXP_DEV/3rdparty/estyx/estyx.c', needed by `estyx.obj'. ccs-dxp-evm Unknown C/C++ Problem
gmake: *** No rule to make target `C:/ti/ccsv5/eclipse/INSTALLROOT_DXP_DEV/src/hwdriver/drivermmb0/gpio.c', needed by `gpio.obj'. ccs-dxp-evm Unknown C/C++ Problem
gmake: *** No rule to make target `C:/ti/ccsv5/eclipse/INSTALLROOT_DXP_DEV/src/hw/mmb0/mmb0.c', needed by `mmb0.obj'. ccs-dxp-evm Unknown C/C++ Problem
gmake: *** No rule to make target `C:/ti/ccsv5/eclipse/INSTALLROOT_DXP_DEV/src/hw/mmb0/mmb0clk.c', needed by `mmb0clk.obj'. ccs-dxp-evm Unknown C/C++ Problem
gmake: *** No rule to make target `C:/ti/ccsv5/eclipse/INSTALLROOT_DXP_DEV/3rdparty/porus/src/usbctl.c', needed by `usbctl.obj'. ccs-dxp-evm Unknown C/C++ Problem
gmake: *** No rule to make target `C:/ti/ccsv5/eclipse/INSTALLROOT_DXP_DEV/3rdparty/porus/port/c55x/usbhw.c', needed by `usbhw.obj'. ccs-dxp-evm Unknown C/C++ Problem
gmake: *** No rule to make target `C:/ti/ccsv5/eclipse/INSTALLROOT_DXP_DEV/src/hw/mmb0/mmb0ui.c', needed by `mmb0ui.obj'. ccs-dxp-evm Unknown C/C++ Problem
gmake: *** No rule to make target `C:/ti/ccsv5/eclipse/INSTALLROOT_DXP_DEV/src/hwdriver/driverdac/signal.c', needed by `signal.obj'. ccs-dxp-evm Unknown C/C++ Problem
gmake: *** No rule to make target `C:/ti/ccsv5/eclipse/INSTALLROOT_DXP_DEV/3rdparty/porus/src/usb.c', needed by `usb.obj'. ccs-dxp-evm Unknown C/C++ Problem
gmake: *** No rule to make target `C:/ti/ccsv5/eclipse/INSTALLROOT_DXP_DEV/3rdparty/porus/port/c55x/usbconfig/usbconfig.c', needed by `usbconfig.obj'. ccs-dxp-evm Unknown C/C++ Problem
gmake: *** No rule to make target `C:/ti/ccsv5/eclipse/INSTALLROOT_DXP_DEV/src/server/StyxServer.cpp', needed by `StyxServer.obj'. ccs-dxp-evm Unknown C/C++ Problem
gmake: *** No rule to make target `C:/ti/ccsv5/eclipse/INSTALLROOT_DXP_DEV/src/server/StyxParam.cpp', needed by `StyxParam.obj'. ccs-dxp-evm Unknown C/C++ Problem
gmake: *** No rule to make target `C:/ti/ccsv5/eclipse/INSTALLROOT_DXP_DEV/src/vfstl/porus/VfsTlPorus.cpp', needed by `VfsTlPorus.obj'. ccs-dxp-evm Unknown C/C++ Problem
gmake: *** No rule to make target `C:/ti/ccsv5/eclipse/INSTALLROOT_DXP_DEV/src/server/StyxWaveform.cpp', needed by `StyxWaveform.obj'. ccs-dxp-evm Unknown C/C++ Problem
gmake: *** No rule to make target `C:/ti/ccsv5/eclipse/INSTALLROOT_DXP_DEV/src/server/StyxDriver.cpp', needed by `StyxDriver.obj'. ccs-dxp-evm Unknown C/C++ Problem
gmake: *** No rule to make target `C:/ti/ccsv5/eclipse/INSTALLROOT_DXP_DEV/src/server/StyxDevice.cpp', needed by `StyxDevice.obj'. ccs-dxp-evm Unknown C/C++ Problem
gmake: *** No rule to make target `C:/ti/ccsv5/eclipse/INSTALLROOT_DXP_DEV/src/server/StyxFile.cpp', needed by `StyxFile.obj'. ccs-dxp-evm Unknown C/C++ Problem
gmake: *** No rule to make target `C:/ti/ccsv5/eclipse/INSTALLROOT_DXP_DEV/src/server/StyxEntry.cpp', needed by `StyxEntry.obj'. ccs-dxp-evm Unknown C/C++ Problem
gmake: *** No rule to make target `C:/ti/ccsv5/eclipse/INSTALLROOT_DXP_DEV/src/hwdriver/drivermmb0/drivermmb0evm.c', needed by `drivermmb0evm.obj'. ccs-dxp-evm Unknown C/C++ Problem
gmake: *** No rule to make target `C:/ti/ccsv5/eclipse/INSTALLROOT_DXP_DEV/src/hwdriver/driverdac/driverdac.c', needed by `driverdac.obj'. ccs-dxp-evm Unknown C/C++ Problem
gmake: *** No rule to make target `C:/ti/ccsv5/eclipse/INSTALLROOT_DXP_DEV/src/hwdriver/driverdac/dxp_acquire.cpp', needed by `dxp_acquire.obj'. ccs-dxp-evm Unknown C/C++ Problem
gmake: *** No rule to make target `C:/ti/ccsv5/eclipse/INSTALLROOT_DXP_DEV/src/hwdriver/driverdac/dxp.c', needed by `dxp.obj'. ccs-dxp-evm Unknown C/C++ Problem
gmake: *** No rule to make target `C:/ti/ccsv5/eclipse/INSTALLROOT_DXP_DEV/3rdparty/estyx/convM2D.c', needed by `convM2D.obj'. ccs-dxp-evm Unknown C/C++ Problem
gmake: *** No rule to make target `C:/ti/ccsv5/eclipse/INSTALLROOT_DXP_DEV/3rdparty/estyx/convD2M.c', needed by `convD2M.obj'. ccs-dxp-evm Unknown C/C++ Problem
gmake: *** No rule to make target `C:/ti/ccsv5/eclipse/INSTALLROOT_DXP_DEV/3rdparty/estyx/convS2M.c', needed by `convS2M.obj'. ccs-dxp-evm Unknown C/C++ Problem
gmake: *** No rule to make target `C:/ti/ccsv5/eclipse/INSTALLROOT_DXP_DEV/3rdparty/estyx/convM2S.c', needed by `convM2S.obj'. ccs-dxp-evm Unknown C/C++ Problem
Build variable 'INSTALLROOT_DXP_DEV' cannot be resolved. ccs-dxp-evm properties Problems
gmake: *** No rule to make target `C:/ti/ccsv5/eclipse/INSTALLROOT_DXP_DEV/src/server/mmb0dxp/Mmb0Device.cpp', needed by `Mmb0Device.obj'. ccs-dxp-evm Unknown C/C++ Problem
gmake: *** No rule to make target `C:/ti/ccsv5/eclipse/INSTALLROOT_DXP_DEV/src/server/mmb0dxp/Mmb0Server.cpp', needed by `Mmb0Server.obj'. ccs-dxp-evm Unknown C/C++ Problem
gmake: *** No rule to make target `C:/ti/ccsv5/eclipse/INSTALLROOT_DXP_DEV/src/common/DxpEntry.cpp', needed by `DxpEntry.obj'. ccs-dxp-evm Unknown C/C++ Problem
gmake: *** No rule to make target `C:/ti/ccsv5/eclipse/INSTALLROOT_DXP_DEV/src/hwdriver/driverdac/DriverDacWrapper.cpp', needed by `DriverDacWrapper.obj'. ccs-dxp-evm Unknown C/C++ Problem
gmake: *** No rule to make target `C:/ti/ccsv5/eclipse/INSTALLROOT_DXP_DEV/src/hwdriver/drivermmb0/DriverMmb0EvmWrapper.cpp', needed by `DriverMmb0EvmWrapper.obj'. ccs-dxp-evm Unknown C/C++ Problem
This project was created using a version of DSP/BIOS tools that is not currently installed: 5.41.10.36. Please install the DSP/BIOS tools of this version, or migrate the project to one of the supported versions. ccs-dxp-evm ccs-dxp-evm Problems
This project contains unresolved buildable linked resources. It might not build as expected. ccs-dxp-evm project Problems
This project was created using a version of compiler that is not currently installed: 4.3.8 [C5500]. Another version of the compiler will be used during build: 4.4.1. Please install the compiler of the required version, or migrate the project to one of the available compiler versions by adjusting project properties. ccs-dxp-evm properties Problems
could not open source file DxpMain.cpp /ccs-dxp-evm line 34 C/C++ Problem
How do I migrate the proyect ?
or where can I found the compiler version I need?
Juan Carlos
Shure,
This is it.
Can you start a private conversation with me? See the forum FAQ on how to do this.
ki
