How to modify memory map when CCS 5.1 has no Tools menu?
I need to modify the memory map settings created by the platform wizard. There is a CCS demo available to help with this but it is for CCS 4 and I'm using CCS 5.1.09000. I don't see the Tools menu which is seen in the demo. I am in the CCS Edit perspective.
This CCS forum post:
http://e2e.ti.com/support/development_tools/code_composer_studio/f/81/t/64266.aspx#231378
has this question:
Unfortunately I have no "Tools->RTSC Tools->Platform" menu item in my CCSv4 as mentioned in the
http://rtsc.eclipse.org/docs-tip/Demo_of_the_RTSC_Platform_Wizard_in_CCSv4
and this response:
Try File -> New.  Select Other.  There should be a folder called "RTSC Wizards" and if you expand that there is a "RTSC Platform Wizard".
This is what I used to create a platform. However, now I want to modify this platform. In the demo, I see that if I had the Tools->Platform menu it would have Edit/View as well as New as options. What I really want now is something like the Edit/View option. How can I get this?
Another post on a similar topic (http://e2e.ti.com/support/embedded/bios/f/355/t/115188.aspx#409785) has this comment:
The menu Tools/RTSC Tools/Platform is missing,
and this response:
That menu is contributed by plugin "org.eclipse.rtsc.xdctools.ui". Could you please check which version of this plugin is active in your colleagues' system? You can find it under menu:
   Help / About Code Composer Studio / Installation Details / Plug-ins
Also can you tell me the "N..." version number of their CCS, also from the Help / About dialog?
That menu was first added in XDCtools 3.20.01.51 .
I have checked my system which was a recent (just over a month old) install of CCS 5.1. The org.eclipse.rtsc.xdctools.ui plugin version is 3.22.4.46.
So it seems like I have a good version of XDCtools but still I don't have a Tools menu.
How can I edit the platform so that I can change its memory map?
Annie
