Part Number: CC3X00EMBEDDEDPROG
Hi TI Team,
I am working with the CC3501ENJARSHR device and using SimpleLink Wi-Fi Toolbox v4.1.8. I am facing a persistent issue while trying to program the CC3501ENJARSHR chipset using the SimpleLink Wi-Fi Toolbox. I have recorded the entire process and attached a video showing the issue across multiple laptops and with different image types.
Setup Details:
Tool: SimpleLink Wi-Fi Toolbox (Version 4.1.8)
Programmer Version: 1.0.10
Debug Probe: XDS110
Target Device: CC35X1E (CC3501ENJARSHR)
Flash IC: IS25WJ032F
PSRAM: No PSRAM
What works:
Hardware connection between XDS110 and the target board is stable.
Full flash erase before programming completes successfully every time.
What fails:
After successful erase, the actual programming step always fails.
I have tested this on three different laptops. same issue was repeated in all.
I have tried both:
Default images (via "Load Default Images")
Custom images (my own
.outand.binfiles uploaded in the Vendor Image slot)
The failure happens in all cases, and the error appears similar each time.
Attached Evidence:
I have attached a video that shows:
The full programming workflow
Successful erase
Failed programming attempt
Error screen as seen in the SimpleLink Wi-Fi Toolbox
video:
Please guide me on how to solve this issue.
Thank you.
Venkata Kishore
