MSPM0G1507: CCS 21.0.0: sporadic error when debug
Part Number: MSPM0G1507
Hallo,
we`ve upgraded from CCS 20.5.1 to 21.0.0. Same workspace same projects. So far we`ve encounter the following sporadic problems:
  1. When we start a debug (F5) session we get the error that the project can`t be found. Only a restart of CCS fixes the problem. See attached screenshot.1.png
  2. Sometimes certain open files can`t be edited anymore. You can´t type or erase characters in a c file for example. Only a restart of CCS fixes this problem.
We haven`t found a systematic way to produce these errors but with 20.5.1 we hadn`t any of these.
Thanks!
Best regards
Steffen
  • Hi Steffan,
    When this happens again, can you provide your CCS server and Theia error logs?
    https://software-dl.ti.com/ccs/esd/documents/ccs_diagnostic-logs.html
    ki
  • Hi Ki,
    check out attached logs.
    Best regards
    Steffen
    2026-06-24T05:53:22.348Z root INFO Backend DefaultMessagingService.initialize: 35.5 ms [Finished 1.204 s after backend start]
    2026-06-24T05:53:22.348Z root INFO Backend Object.initialize: 34.1 ms [Finished 1.204 s after backend start]
    2026-06-24T05:53:22.348Z root INFO Backend MiniBrowserBackendSecurityWarnings.initialize: 1.1 ms [Finished 1.204 s after backend start]
    2026-06-24T05:53:22.348Z root INFO Backend PluginDeployerContribution.initialize: 1.0 ms [Finished 1.204 s after backend start]
    2026-06-24T05:53:22.348Z root INFO Backend WebviewBackendSecurityWarnings.initialize: 0.8 ms [Finished 1.204 s after backend start]
    2026-06-24T05:53:22.348Z root INFO Backend HostedPluginLocalizationService.initialize: 0.9 ms [Finished 1.204 s after backend start]
    2026-06-24T05:53:22.348Z root INFO Backend HostedPluginReader.initialize: 0.8 ms [Finished 1.204 s after backend start]
    2026-06-24T05:53:22.348Z root INFO Backend CCSBackendContribution.initialize: 0.8 ms [Finished 1.204 s after backend start]
    2026-06-24T05:53:22.348Z root INFO Backend CCSGuiComposerBackendContribution.initialize: 0.7 ms [Finished 1.204 s after backend start]
    2026-06-24T05:53:22.348Z root INFO Backend CCSProjectBackendContribution.initialize: 0.6 ms [Finished 1.204 s after backend start]
    2026-06-24T05:53:22.348Z root INFO Backend CCSDropboxBackendContribution.initialize: 0.6 ms [Finished 1.204 s after backend start]
    2026-06-24T05:53:22.348Z root INFO Backend CCSBackendApplicationContribution.initialize: 0.6 ms [Finished 1.204 s after backend start]
    2026-06-24T05:53:22.348Z root INFO Backend CCSGettingStartedBackendContribution.initialize: 0.6 ms [Finished 1.204 s after backend start]
    2026-06-24T05:53:22.348Z root INFO Backend CCSSupportBackendContribution.initialize: 0.6 ms [Finished 1.204 s after backend start]
    2026-06-24T05:53:22.355Z root WARN Backend PluginLocalizationServer.initialize took longer than the expected maximum 50 milliseconds: 53.0 ms [Finished 1.223 s after backend start]
    2026-06-24T05:53:22.358Z root INFO configured all backend app contributions
    2026-06-24T05:53:22.358Z root INFO Backend WebsocketEndpoint.onStart: 1.0 ms [Finished 1.236 s after backend start]
    2026-06-24T05:53:22.363Z root ERROR (node:4148) [DEP0040] DeprecationWarning: The `punycode` module is deprecated. Please use a userland alternative instead.
    (Use `ccstudio --trace-deprecation ...` to show where the warning was created)
    2026-06-24T05:53:22.363Z root INFO Theia app listening on http://127.0.0.1:51884.
    2026-06-24T05:53:22.364Z root INFO Settings file not found at 'C:\Users\plenske\AppData\Local\Texas Instruments\CCS\ccs2100\0\theia\backend-settings.json'. Falling back to defaults.
    2026-06-24T05:53:22.366Z root WARN The local plugin referenced by local-dir:/c%3A/Users/plenske/AppData/Local/Texas%20Instruments/CCS/ccs2100/0/theia/plugins does not exist.
    2026-06-24T05:53:22.375Z root INFO Backend DefaultWorkspaceServer.onStart: 14.2 ms [Finished 1.250 s after backend start]
    2026-06-24T05:53:22.375Z root INFO Backend TaskBackendApplicationContribution.onStart: 0.4 ms [Finished 1.251 s after backend start]
    2026-06-24T05:53:22.375Z root INFO Backend MetricsBackendApplicationContribution.onStart: 2.3 ms [Finished 1.253 s after backend start]
    2026-06-24T05:53:22.378Z root INFO Backend MiniBrowserEndpoint.onStart: 0.2 ms [Finished 1.253 s after backend start]
    2026-06-24T05:53:22.379Z root INFO Backend PluginHostNavigatorStateInitializer.onStart: 0.2 ms [Finished 1.254 s after backend start]
    2026-06-24T05:53:22.379Z root INFO Backend Object.onStart: 3.0 ms [Finished 1.257 s after backend start]
    2026-06-24T05:53:22.381Z root INFO CCS Server workspace directory: 'C:\Users\plenske\AppData\Local\Texas Instruments\CCS\.ccs-server\workspaces\5b4ba671c8a05a53402cbf51e92e4d04'
    2026-06-24T05:53:22.381Z root INFO Backend CCSBackendContribution.onStart: 2.2 ms [Finished 1.259 s after backend start]
    2026-06-24T05:53:22.381Z root INFO Backend CCSGuiComposerBackendContribution.onStart: 0.0 ms [Finished 1.259 s after backend start]
    2026-06-24T05:53:22.381Z root INFO Backend CCSProjectBackendContribution.onStart: 0.0 ms [Finished 1.259 s after backend start]
    2026-06-24T05:53:22.381Z root INFO Backend CCSDropboxBackendContribution.onStart: 0.0 ms [Finished 1.259 s after backend start]
    2026-06-24T05:53:22.381Z root INFO Backend CCSBackendApplicationContribution.onStart: 0.0 ms [Finished 1.259 s after backend start]
    2026-06-24T05:53:22.381Z root INFO Backend CCSGettingStartedBackendContribution.onStart: 0.0 ms [Finished 1.259 s after backend start]
    2026-06-24T05:53:22.381Z root INFO Backend CCSSupportBackendContribution.onStart: 0.0 ms [Finished 1.259 s after backend start]
    2026-06-24T05:53:22.381Z root INFO Finished starting backend application: 0.0 ms [Finished 1.259 s after backend start]
    2026-06-24T05:53:22.453Z root ERROR Failed to load plugin dependencies from 'c:\ti\ccs2100\ccs\theia\resources\app\plugins\ccs-theia.builtin-extensions-pack' pathError: ENOENT: no such file or directory, open 'C:\ti\ccs2100\ccs\theia\resources\app\plugins\ccs-theia.builtin-extensions-pack\package.json'
    2026-06-24T05:53:22.532Z root INFO Resolve plugins list: 167.2 ms [Finished 1.410 s after backend start]
    2026-06-24T05:53:22.689Z root INFO Deploy plugins list: 324.2 ms [Finished 1.567 s after backend start]
    2026-06-24T05:53:22.691Z root INFO [3d0ba4c6-9502-464e-9ee0-7116c05018d1] Waiting for backend deployment: 0.3 ms [Finished 1.567 s after backend start]
    2026-06-24T05:53:22.711Z root INFO [3d0ba4c6-9502-464e-9ee0-7116c05018d1] Loading plugin contributions
    2026-06-24T05:53:23.687Z root INFO [ccs-server:stdout][ccs.trace] CCSServer> IDE session in progress: 2aa41972-9f71-4e36-8c0a-f52ae110ba7e (server v21.0.0.202605292334)
    2026-06-24T05:53:24.128Z root INFO creating connection for 1
    2026-06-24T05:53:25.055Z root ERROR (node:4148) [DEP0180] DeprecationWarning: fs.Stats constructor is deprecated.
    2026-06-24T05:53:25.808Z root INFO WebSocket connection opened: /services/ccs-backend (current total of 1)
    2026-06-24T05:53:25.888Z root INFO TICloudAgentHostApp starting...
    2026-06-24T05:53:26.091Z root WARN Frontend keybindings.onStart took longer than the expected maximum 100 milliseconds: 134.4 ms [Finished 3.503 s after frontend start]
    2026-06-24T05:53:26.219Z SkillService WARN Cannot watch skills directory 'C:\Users\plenske\Downloads\kal-processing-v2\.prompts\skills': parent directory does not exist
    2026-06-24T05:53:26.225Z SkillService INFO Watching parent directory 'C:\Users\plenske\AppData\Local\Texas Instruments\CCS\ccs2100\0\theia' for skills folder creation
    2026-06-24T05:53:26.346Z root WARN Frontend ClaudeCodeSlashCommandsContribution.onStart took longer than the expected maximum 100 milliseconds: 112.5 ms [Finished 3.781 s after frontend start]
    2026-06-24T05:53:26.719Z root WARN Linked preference "workbench.colorCustomizations" not found.
    2026-06-24T05:53:26.719Z root WARN Linked preference "editor.experimental.preferTreeSitter" not found.
    2026-06-24T05:53:26.750Z root WARN Frontend ContainerInfoContribution.onStart took longer than the expected maximum 100 milliseconds: 396.2 ms [Finished 4.185 s after frontend start]
    2026-06-24T05:53:26.792Z root INFO [3980516a-6308-4603-934e-2b1d994d57b9] Waiting for backend deployment: 39.9 ms [Finished 4.226 s after frontend start]
    2026-06-24T05:53:26.797Z root INFO Register CCS Webview route with id:tirex_explore and contentRoot=C:\ti\ccs2100\ccs\tirex4\ti-rex-core\public
    2026-06-24T05:53:26.797Z root INFO Register CCS Webview route with id:tirex_wizard and contentRoot=C:\ti\ccs2100\ccs\tirex4\ti-rex-core\public
    2026-06-24T05:53:26.926Z root INFO [3980516a-6308-4603-934e-2b1d994d57b9] Sync of 35 plugins: 134.5 ms [Finished 4.361 s after frontend start]
    2026-06-24T05:53:26.985Z vercel-ai INFO Vercel AI: Creating or updating model vercel/openai/gpt-4.1
    2026-06-24T05:53:26.985Z vercel-ai INFO Vercel AI: Creating or updating model vercel/openai/gpt-4.1-nano
    2026-06-24T05:53:26.985Z vercel-ai INFO Vercel AI: Creating or updating model vercel/openai/gpt-4.1-mini
    2026-06-24T05:53:26.985Z vercel-ai INFO Vercel AI: Creating or updating model vercel/openai/gpt-4-turbo
    2026-06-24T05:53:26.985Z vercel-ai INFO Vercel AI: Creating or updating model vercel/openai/gpt-4o
    2026-06-24T05:53:26.985Z vercel-ai INFO Vercel AI: Creating or updating model vercel/openai/gpt-4o-mini
    2026-06-24T05:53:26.985Z vercel-ai INFO Vercel AI: Creating or updating model vercel/anthropic/claude-3-7-sonnet-20250219
    2026-06-24T05:53:26.986Z vercel-ai INFO Vercel AI: Creating or updating model vercel/anthropic/claude-3-5-haiku-20241022
    2026-06-24T05:53:26.986Z vercel-ai INFO Vercel AI: Creating or updating model vercel/anthropic/claude-3-opus-20240229
    2026-06-24T05:53:26.991Z root WARN Frontend CCSGetStartedWithAIContribution.onStart took longer than the expected maximum 100 milliseconds: 223.7 ms [Finished 4.418 s after frontend start]
    2026-06-24T05:53:27.110Z root INFO Start frontend contributions: 1345.7 ms [Finished 4.498 s after frontend start]
    2026-06-24T05:53:27.110Z root INFO Changed application state from 'init' to 'started_contributions'.
    2026-06-24T05:53:27.271Z root INFO Changed application state from 'started_contributions' to 'attached_shell'.
    2026-06-24T05:53:27.272Z root INFO >>> Restoring the layout state...
    2026-06-24T05:53:27.275Z root INFO [3980516a-6308-4603-934e-2b1d994d57b9] Loading plugin contributions
    2026-06-24T05:53:27.275Z root WARN Could not register keybinding:
      {"command":"editor.action.copyLinesDownAction","keybinding":"ctrl+alt+win+down","when":"editorTextFocus"}
    Error: Unrecognized key win in ctrl+alt+win+down
      {"command":"editor.action.copyLinesUpAction","keybinding":"ctrl+alt+win+up","when":"editorTextFocus"}
    Error: Unrecognized key win in ctrl+alt+win+up
    2026-06-24T05:53:27.275Z root WARN Trying to register default override for non-existent preference: workbench.editor.restoreViewState
    2026-06-24T05:53:27.275Z root INFO [3980516a-6308-4603-934e-2b1d994d57b9] Load contributions of 35 plugins: 116.8 ms [Finished 4.665 s after frontend start]
    2026-06-24T05:53:27.287Z root ERROR Warning: Each child in a list should have a unique "key" prop.%s%s See https://reactjs.org/link/warning-keys for more information.%s
        at div
    2026-06-24T05:53:27.297Z terminal WARN Couldn't attach - can't find terminal with id: 1495951256
    2026-06-24T05:53:27.329Z root INFO ccs-serverconnected to 'ccs-server' process - ready for handshake...
    2026-06-24T05:53:27.330Z root INFO [ccs-server:stdout]CCSServer started! [3,693ms]
    2026-06-24T05:53:27.375Z root INFO ccstudiohandshake between ccs-server and theia-backend complete - waiting for theia-frontend...
    2026-06-24T05:53:27.431Z root INFO [hosted-plugin: 15552] PLUGIN_HOST(15552) starting instance
    2026-06-24T05:53:27.434Z root WARN 'cpp' language is remapped from 'source.cpp.embedded.macro' to 'source.cpp' scope
    2026-06-24T05:53:27.434Z root WARN a registered grammar configuration for 'cpp' language is overridden
    2026-06-24T05:53:27.435Z root WARN [3980516a-6308-4603-934e-2b1d994d57b9][vscode.html]: Language for 'source.css' not found.
    2026-06-24T05:53:27.435Z root WARN [3980516a-6308-4603-934e-2b1d994d57b9][vscode.html]: Language for 'source.smarty' not found.
    2026-06-24T05:53:27.436Z root WARN [3980516a-6308-4603-934e-2b1d994d57b9][vscode.markdown]: Language for 'source.css' not found.
    2026-06-24T05:53:27.437Z root WARN [3980516a-6308-4603-934e-2b1d994d57b9][vscode.markdown]: Language for 'meta.embedded.block.frontmatter' not found.
    2026-06-24T05:53:27.437Z root WARN [3980516a-6308-4603-934e-2b1d994d57b9][vscode.markdown]: Language for 'meta.embedded.block.css' not found.
    2026-06-24T05:53:27.437Z root WARN [3980516a-6308-4603-934e-2b1d994d57b9][vscode.markdown]: Language for 'meta.embedded.block.java' not found.
    2026-06-24T05:53:27.437Z root WARN [3980516a-6308-4603-934e-2b1d994d57b9][vscode.markdown]: Language for 'meta.embedded.block.lua' not found.
    2026-06-24T05:53:27.437Z root WARN [3980516a-6308-4603-934e-2b1d994d57b9][vscode.markdown]: Language for 'meta.embedded.block.perl' not found.
    2026-06-24T05:53:27.437Z root WARN [3980516a-6308-4603-934e-2b1d994d57b9][vscode.markdown]: Language for 'meta.embedded.block.r' not found.
    2026-06-24T05:53:27.438Z root WARN [3980516a-6308-4603-934e-2b1d994d57b9][vscode.markdown]: Language for 'meta.embedded.block.ruby' not found.
    2026-06-24T05:53:27.438Z root WARN [3980516a-6308-4603-934e-2b1d994d57b9][vscode.markdown]: Language for 'meta.embedded.block.php' not found.
    2026-06-24T05:53:27.438Z root WARN [3980516a-6308-4603-934e-2b1d994d57b9][vscode.markdown]: Language for 'meta.embedded.block.sql' not found.
    2026-06-24T05:53:27.438Z root WARN [3980516a-6308-4603-934e-2b1d994d57b9][vscode.markdown]: Language for 'meta.embedded.block.vs_net' not found.
    2026-06-24T05:53:27.438Z root WARN [3980516a-6308-4603-934e-2b1d994d57b9][vscode.markdown]: Language for 'meta.embedded.block.yaml' not found.
    2026-06-24T05:53:27.438Z root WARN [3980516a-6308-4603-934e-2b1d994d57b9][vscode.markdown]: Language for 'meta.embedded.block.dosbatch' not found.
    2026-06-24T05:53:27.438Z root WARN [3980516a-6308-4603-934e-2b1d994d57b9][vscode.markdown]: Language for 'meta.embedded.block.clojure' not found.
    2026-06-24T05:53:27.438Z root WARN [3980516a-6308-4603-934e-2b1d994d57b9][vscode.markdown]: Language for 'meta.embedded.block.coffee' not found.
    2026-06-24T05:53:27.438Z root WARN [3980516a-6308-4603-934e-2b1d994d57b9][vscode.markdown]: Language for 'meta.embedded.block.go' not found.
    2026-06-24T05:53:27.438Z root WARN [3980516a-6308-4603-934e-2b1d994d57b9][vscode.markdown]: Language for 'meta.embedded.block.groovy' not found.
    2026-06-24T05:53:27.438Z root WARN [3980516a-6308-4603-934e-2b1d994d57b9][vscode.markdown]: Language for 'meta.embedded.block.pug' not found.
    2026-06-24T05:53:27.438Z root WARN [3980516a-6308-4603-934e-2b1d994d57b9][vscode.markdown]: Language for 'meta.embedded.block.latex' not found.
    2026-06-24T05:53:27.440Z root WARN [3980516a-6308-4603-934e-2b1d994d57b9][vscode.markdown]: Language for 'meta.embedded.block.less' not found.
    2026-06-24T05:53:27.440Z root WARN [3980516a-6308-4603-934e-2b1d994d57b9][vscode.markdown]: Language for 'meta.embedded.block.objc' not found.
    2026-06-24T05:53:27.440Z root WARN [3980516a-6308-4603-934e-2b1d994d57b9][vscode.markdown]: Language for 'meta.embedded.block.scss' not found.
    2026-06-24T05:53:27.440Z root WARN [3980516a-6308-4603-934e-2b1d994d57b9][vscode.markdown]: Language for 'meta.embedded.block.perl6' not found.
    2026-06-24T05:53:27.440Z root WARN [3980516a-6308-4603-934e-2b1d994d57b9][vscode.markdown]: Language for 'meta.embedded.block.rust' not found.
    2026-06-24T05:53:27.440Z root WARN [3980516a-6308-4603-934e-2b1d994d57b9][vscode.markdown]: Language for 'meta.embedded.block.scala' not found.
    2026-06-24T05:53:27.440Z root WARN [3980516a-6308-4603-934e-2b1d994d57b9][vscode.markdown]: Language for 'meta.embedded.block.typescript' not found.
    2026-06-24T05:53:27.440Z root WARN [3980516a-6308-4603-934e-2b1d994d57b9][vscode.markdown]: Language for 'meta.embedded.block.typescriptreact' not found.
    2026-06-24T05:53:27.440Z root WARN [3980516a-6308-4603-934e-2b1d994d57b9][vscode.markdown]: Language for 'meta.embedded.block.csharp' not found.
    2026-06-24T05:53:27.440Z root WARN [3980516a-6308-4603-934e-2b1d994d57b9][vscode.markdown]: Language for 'meta.embedded.block.fsharp' not found.
    2026-06-24T05:53:27.678Z root INFO TICloudAgentHostApp started: {"port":59723,"version":"4.18","buildVersion":"5732"}
    2026-06-24T05:53:27.682Z root INFO TICloudAgentHostApp: connected to CloudAgent to keepalive.
    2026-06-24T05:53:27.869Z root INFO Connected to CCS Server - ready for handshake...
    2026-06-24T05:53:28.031Z terminal WARN Failed attaching to terminal id 1495951256, the terminal is most likely gone. Starting up a new terminal instead.
    2026-06-24T05:53:28.986Z root INFO <<< The layout has been successfully restored.
    2026-06-24T05:53:29.002Z root INFO Initialize the workbench layout: 1872.4 ms [Finished 6.420 s after frontend start]
    2026-06-24T05:53:29.004Z root INFO Changed application state from 'attached_shell' to 'initialized_layout'.
    2026-06-24T05:53:29.075Z root INFO TICloudAgentHostApp: (node:3640) Warning: Setting the NODE_TLS_REJECT_UNAUTHORIZED environment variable to '0' makes TLS connections and HTTPS requests insecure by disabling certificate verification.
    (Use `node --trace-warnings ...` to show where the warning was created)
    2026-06-24T05:53:29.077Z plugin-host INFO PLUGIN_HOST(15552): PluginManagerExtImpl/init()
    2026-06-24T05:53:29.132Z plugin-manager WARN Unsupported activation events: onProfile, onProfile:github, please open an issue: https://github.com/eclipse-theia/theia/issues/new
    2026-06-24T05:53:29.132Z plugin-manager WARN Unsupported activation events: onEditSession:file, please open an issue: https://github.com/eclipse-theia/theia/issues/new
    2026-06-24T05:53:29.133Z plugin-manager WARN Unsupported activation events: onTunnel, please open an issue: https://github.com/eclipse-theia/theia/issues/new
    2026-06-24T05:53:29.832Z plugin-host INFO [ccs-project:extension.ts] Activating ccs-project extension...
    2026-06-24T05:53:29.833Z plugin-host INFO [ccs-ai:extension.ts] Activating extension...
    2026-06-24T05:53:29.833Z plugin-host ERROR (node:15552) [DEP0040] DeprecationWarning: The `punycode` module is deprecated. Please use a userland alternative instead.
    2026-06-24T05:53:29.833Z plugin-host ERROR (node:15552) [DEP0174] DeprecationWarning: Calling promisify on a function that returns a Promise is likely a mistake.
    2026-06-24T05:53:29.908Z plugin-host INFO Clang Language Server is now active!
    2026-06-24T05:53:29.972Z root INFO [3980516a-6308-4603-934e-2b1d994d57b9] Starting plugins.
    2026-06-24T05:53:29.977Z root INFO Frontend application start: 4125.8 ms [Finished 8.854 s after backend start]
    2026-06-24T05:53:29.977Z root INFO Replace loading indicator with ready workbench UI (animation): 940.3 ms [Finished 7.411 s after frontend start]
    2026-06-24T05:53:29.977Z root INFO Changed application state from 'initialized_layout' to 'ready'.
    2026-06-24T05:53:30.136Z root INFO Attached to cloudagent with port 59723
    2026-06-24T05:53:31.327Z root ERROR [object Object]
    2026-06-24T05:53:31.328Z root ERROR [object Object]
    2026-06-24T05:53:31.406Z root INFO An authentication provider with id 'gitlab' was registered.
    2026-06-24T05:53:31.818Z root INFO ccstudiohandshake between ccs-server and theia-frontend complete
    2026-06-24T05:53:31.847Z root INFO CCS Server handshake complete!
    2026-06-24T05:53:32.031Z plugin-host INFO [ccs-ai:m] Sysconfig Proxy Server loaded successfully.
    2026-06-24T05:53:34.961Z root INFO [3980516a-6308-4603-934e-2b1d994d57b9] Start of 35 plugins: 6973.2 ms [Finished 12.396 s after frontend start]
    2026-06-24T05:53:36.027Z plugin-host ERROR Promise rejection not handled in one second: Error: Unknown Webview: a84705dc-0c5b-4645-ab39-1f1ee060659e , reason: Error: Unknown Webview: a84705dc-0c5b-4645-ab39-1f1ee060659e
    2026-06-24T05:53:36.028Z plugin-host ERROR With stack trace: Error: Unknown Webview: a84705dc-0c5b-4645-ab39-1f1ee060659e
        at WebviewsMainImpl.getWebview (file:///C:/ti/ccs2100/ccs/theia/resources/app.asar/lib/frontend/packages_plugin-ext_lib_hosted_browser_hosted-plugin_js.js:16192:19)
        at async WebviewsMainImpl.$setOptions (file:///C:/ti/ccs2100/ccs/theia/resources/app.asar/lib/frontend/packages_plugin-ext_lib_hosted_browser_hosted-plugin_js.js:16121:25)
        at async RpcProtocol.handleRequest (file:///C:/ti/ccs2100/ccs/theia/resources/app.asar/lib/frontend/bundle.js:424817:28)
    2026-06-24T05:53:36.028Z plugin-host ERROR Promise rejection not handled in one second: Error: Unknown Webview: e497c4ea-03f0-4ae3-9fc2-0971a02c3d48 , reason: Error: Unknown Webview: e497c4ea-03f0-4ae3-9fc2-0971a02c3d48
    2026-06-24T05:53:36.028Z plugin-host ERROR With stack trace: Error: Unknown Webview: e497c4ea-03f0-4ae3-9fc2-0971a02c3d48
    2026-06-24T05:53:36.028Z plugin-host ERROR Promise rejection not handled in one second: Error: Unknown Webview: 4dfff446-3605-4f38-b120-e4200c7dd22a , reason: Error: Unknown Webview: 4dfff446-3605-4f38-b120-e4200c7dd22a
    2026-06-24T05:53:36.028Z plugin-host ERROR With stack trace: Error: Unknown Webview: 4dfff446-3605-4f38-b120-e4200c7dd22a
    2026-06-24T05:53:36.035Z plugin-host ERROR Promise rejection not handled in one second: Error: Unknown Webview: a84705dc-0c5b-4645-ab39-1f1ee060659e , reason: Error: Unknown Webview: a84705dc-0c5b-4645-ab39-1f1ee060659e
    2026-06-24T05:53:36.036Z plugin-host ERROR With stack trace: Error: Unknown Webview: a84705dc-0c5b-4645-ab39-1f1ee060659e
        at async WebviewsMainImpl.$setHtml (file:///C:/ti/ccs2100/ccs/theia/resources/app.asar/lib/frontend/packages_plugin-ext_lib_hosted_browser_hosted-plugin_js.js:16117:25)
    2026-06-24T05:53:36.036Z plugin-host ERROR Promise rejection not handled in one second: Error: Unknown Webview: a84705dc-0c5b-4645-ab39-1f1ee060659e , reason: Error: Unknown Webview: a84705dc-0c5b-4645-ab39-1f1ee060659e
    2026-06-24T05:53:36.036Z plugin-host ERROR Promise rejection not handled in one second: Error: Unknown Webview: e497c4ea-03f0-4ae3-9fc2-0971a02c3d48 , reason: Error: Unknown Webview: e497c4ea-03f0-4ae3-9fc2-0971a02c3d48
    2026-06-24T05:53:36.036Z plugin-host ERROR With stack trace: Error: Unknown Webview: e497c4ea-03f0-4ae3-9fc2-0971a02c3d48
    2026-06-24T05:53:36.037Z plugin-host ERROR Promise rejection not handled in one second: Error: Unknown Webview: e497c4ea-03f0-4ae3-9fc2-0971a02c3d48 , reason: Error: Unknown Webview: e497c4ea-03f0-4ae3-9fc2-0971a02c3d48
    2026-06-24T05:53:36.037Z plugin-host ERROR With stack trace: Error: Unknown Webview: e497c4ea-03f0-4ae3-9fc2-0971a02c3d48
    2026-06-24T05:53:36.037Z plugin-host ERROR Promise rejection not handled in one second: Error: Unknown Webview: 4dfff446-3605-4f38-b120-e4200c7dd22a , reason: Error: Unknown Webview: 4dfff446-3605-4f38-b120-e4200c7dd22a
    2026-06-24T05:53:36.037Z plugin-host ERROR With stack trace: Error: Unknown Webview: 4dfff446-3605-4f38-b120-e4200c7dd22a
    2026-06-24T05:53:36.110Z plugin-host ERROR Promise rejection not handled in one second: Error: Unknown Webview: c7a8a20d-7bd4-4405-93cf-a4bc52b1da71 , reason: Error: Unknown Webview: c7a8a20d-7bd4-4405-93cf-a4bc52b1da71
    2026-06-24T05:53:36.111Z plugin-host ERROR With stack trace: Error: Unknown Webview: c7a8a20d-7bd4-4405-93cf-a4bc52b1da71
    2026-06-24T05:53:36.111Z plugin-host ERROR Promise rejection not handled in one second: Error: Unknown Webview: c7a8a20d-7bd4-4405-93cf-a4bc52b1da71 , reason: Error: Unknown Webview: c7a8a20d-7bd4-4405-93cf-a4bc52b1da71
    2026-06-24T05:53:43.047Z root INFO Register CCS Webview route with id:sysconfig_H37cjCi9CgapzB1Q and contentRoot=C:/ti/sysconfig_1.26.2/dist
    2026-06-24T05:53:43.059Z plugin-host INFO [ccs-ai:m] Sysconfig MCP Server started on port 59749
    2026-06-24T05:53:43.064Z plugin-host INFO [ccs-ai:m] Successfully registered SysConfig session for id: 1164205587, project: ADS
    2026-06-24T05:53:43.072Z plugin-host INFO [ccs-ai:m] Successfully registered SysConfig session for id: 1794954683, project: INA
    2026-06-24T05:53:46.107Z plugin-host ERROR Promise rejection not handled in one second: Error: Unknown Webview: e497c4ea-03f0-4ae3-9fc2-0971a02c3d48 , reason: Error: Unknown Webview: e497c4ea-03f0-4ae3-9fc2-0971a02c3d48
    2026-06-24T05:53:46.108Z plugin-host ERROR With stack trace: Error: Unknown Webview: e497c4ea-03f0-4ae3-9fc2-0971a02c3d48
    2026-06-24T05:53:46.108Z plugin-host ERROR Promise rejection not handled in one second: Error: Unknown Webview: c7a8a20d-7bd4-4405-93cf-a4bc52b1da71 , reason: Error: Unknown Webview: c7a8a20d-7bd4-4405-93cf-a4bc52b1da71
    2026-06-24T05:53:46.108Z plugin-host ERROR With stack trace: Error: Unknown Webview: c7a8a20d-7bd4-4405-93cf-a4bc52b1da71
    2026-06-24T05:54:12.380Z plugin-host ERROR (node:15552) [DEP0005] DeprecationWarning: Buffer() is deprecated due to security and usability issues. Please use the Buffer.alloc(), Buffer.allocUnsafe(), or Buffer.from() methods instead.
    2026-06-24T06:01:33.307Z root ERROR TypeError: Cannot read properties of undefined (reading 'group')
        at TabsMainImpl.onTabClosed (file:///C:/ti/ccs2100/ccs/theia/resources/app.asar/lib/frontend/packages_plugin-ext_lib_hosted_browser_hosted-plugin_js.js:12259:17)
        at TabsMainImpl.<anonymous> (file:///C:/ti/ccs2100/ccs/theia/resources/app.asar/lib/frontend/packages_plugin-ext_lib_hosted_browser_hosted-plugin_js.js:12051:22)
        at invokeSlot (file:///C:/ti/ccs2100/ccs/theia/resources/app.asar/lib/frontend/bundle.js:8970:18)
        at Object.emit (file:///C:/ti/ccs2100/ccs/theia/resources/app.asar/lib/frontend/bundle.js:8928:17)
        at Signal.emit (file:///C:/ti/ccs2100/ccs/theia/resources/app.asar/lib/frontend/bundle.js:8527:17)
        at TheiaDockPanel.onChildRemoved (file:///C:/ti/ccs2100/ccs/theia/resources/app.asar/lib/frontend/bundle.js:407469:28)
        at TheiaDockPanel.processMessage (file:///C:/ti/ccs2100/ccs/theia/resources/app.asar/lib/frontend/bundle.js:436644:22)
        at TheiaDockPanel.processMessage (file:///C:/ti/ccs2100/ccs/theia/resources/app.asar/lib/frontend/bundle.js:446676:19)
        at invokeHandler (file:///C:/ti/ccs2100/ccs/theia/resources/app.asar/lib/frontend/bundle.js:8085:21)
        at Object.sendMessage (file:///C:/ti/ccs2100/ccs/theia/resources/app.asar/lib/frontend/bundle.js:7839:13)
    ATT43686.log
  • Thanks, looks it happens fairly frequently. Can you try clearing the CCS cache to see if that helps?
    https://software-dl.ti.com/ccs/esd/documents/users_guide_ccs/ccs_faqs.html#i-want-to-restart-ccstudio-ide-with-a-fresh-environment-how-do-i-do-this
    ki
  • Hi Ki,
    thanks for the hint. This seams to fix the issue for now. I haven`t encounterd the problem so far...
    Best regards
    Steffen
  • Hi Ki,
    sorry we are back to getting the error. So this fixed it for a few hours of debugging. It happend right after stop debug session, code change and then a start of a debug session.
    Here are the logs:
    7043.ccs_theia_snapshot.log
    !SESSION 2026-06-25 08:19:26.450 -----------------------------------------------
    eclipse.buildId=unknown
    java.version=21.0.6
    java.vendor=Eclipse Adoptium
    BootLoader constants: OS=win32, ARCH=x86_64, WS=win32, NL=de_DE
    Framework arguments:  -application com.ti.ccs.server.start -pluginCustomization C:\ti\ccs2100\ccs\eclipse\ccs.preferences.ini -ccs.socketPath \\.\pipe\5b4ba671c8a05a53402cbf51e92e4d04.sock -ccs.workspaceFolderPaths c:\Users\plenske\Downloads\kal-processing-v2 -ccs.defaultImportDestinationPath c:\Users\plenske\Downloads\kal-processing-v2 -ccs.buildSecurityPolicy level:desktop
    Command-line arguments:  -os win32 -ws win32 -arch x86_64 -application com.ti.ccs.server.start -pluginCustomization C:\ti\ccs2100\ccs\eclipse\ccs.preferences.ini -data C:\Users\plenske\AppData\Local\Texas Instruments\CCS\.ccs-server\workspaces\5b4ba671c8a05a53402cbf51e92e4d04 -ccs.socketPath \\.\pipe\5b4ba671c8a05a53402cbf51e92e4d04.sock -ccs.workspaceFolderPaths c:\Users\plenske\Downloads\kal-processing-v2 -ccs.defaultImportDestinationPath c:\Users\plenske\Downloads\kal-processing-v2 -ccs.buildSecurityPolicy level:desktop
    !ENTRY com.ti.ccs.core 1 0 2026-06-25 08:19:27.408
    !MESSAGE [ccs.trace] CCSServer> IDE session in progress: abc8ad5f-c7b3-4e5c-9a24-ceb6b02e5a4c (server v21.0.0.202605292334)
    !ENTRY com.ti.ccs.core 1 0 2026-06-25 08:19:42.342
    !MESSAGE [ccs.trace] CCSServer> shutting down...
    !ENTRY com.ti.ccs.server 4 0 2026-06-25 08:19:42.356
    !MESSAGE An internal error was logged by 'com.ti.ccs.server'.
    !STACK 0
    org.json.JSONException: Stream closed
    	at com.ti.ccs.server.events.ServerEvent.push(ServerEvent.java:161)
    	at com.ti.ccs.server.CCSServer.pushEvent(CCSServer.java:256)
    	at com.ti.ccs.server.CCSServer.pushEvent(CCSServer.java:238)
    	at com.ti.ccs.server.handlers.ProjectPropertiesHandler$42.activeConfigurationChanged(ProjectPropertiesHandler.java:768)
    	at com.ti.ccs.project.target.TargetConfigurationManager.setActiveConfiguration(TargetConfigurationManager.java:240)
    	at com.ti.ccs.project.target.TargetConfigurationManager.createConfiguration(TargetConfigurationManager.java:212)
    	at com.ti.ccs.project.target.TargetConfigurationManager.updateManagedConfiguration(TargetConfigurationManager.java:181)
    	at com.ti.ccs.project.target.TargetConfigurationManager$ProjectStateListener.onProjectLoaded(TargetConfigurationManager.java:81)
    	at com.ti.ccs.project.model.ProjectStateMonitor$ProjectDescriptionListener$1$1.visit(ProjectStateMonitor.java:225)
    	at com.ti.ccs.project.model.ProjectStateMonitor.notifyListeners(ProjectStateMonitor.java:1091)
    	at com.ti.ccs.project.model.ProjectStateMonitor$ProjectDescriptionListener$1.run(ProjectStateMonitor.java:220)
    	at com.ti.ccs.core.CCStudioIDE$StartupWaiter$1.run(CCStudioIDE.java:97)
    	at org.eclipse.core.internal.jobs.Worker.run(Worker.java:63)
    Caused by: java.io.IOException: Stream closed
    	at java.base/java.io.BufferedWriter.ensureOpen(Unknown Source)
    	at java.base/java.io.BufferedWriter.implWrite(Unknown Source)
    	at java.base/java.io.BufferedWriter.write(Unknown Source)
    	at com.ti.ccs.server.events.ServerEvent.push(ServerEvent.java:151)
    	... 12 more
    !ENTRY com.ti.ccs.core 1 0 2026-06-25 08:19:42.363
    !MESSAGE [ccs.trace] CCSServer> shutdown complete
    !SESSION 2026-06-25 08:20:30.872 -----------------------------------------------
    java.version=21.0.6
    !ENTRY com.ti.ccs.core 1 0 2026-06-25 08:20:31.884
    !MESSAGE [ccs.trace] CCSServer> IDE session in progress: 2335e48e-c980-4975-8765-37ef3e976e7f (server v21.0.0.202605292334)
    !ENTRY com.ti.ccs.core 1 0 2026-06-25 09:27:12.931
    !ENTRY com.ti.ccs.core 1 0 2026-06-25 09:27:12.949
    !SESSION 2026-06-25 09:28:15.562 -----------------------------------------------
    java.version=21.0.6
    !ENTRY com.ti.ccs.core 1 0 2026-06-25 09:28:16.569
    !MESSAGE [ccs.trace] CCSServer> IDE session in progress: c5bc5570-b537-4205-af26-bc902250a8cd (server v21.0.0.202605292334)
    !ENTRY com.ti.ccs.core 1 0 2026-06-25 09:28:27.767
    !ENTRY com.ti.ccs.core 1 0 2026-06-25 09:28:27.791
    Best regard
    Steffen
  • Would it be possible to provide the project for use to try to reproduce locally? There seems to be an issue with the executable action that is part of the project. Is the project with the executable action also called "ADS" or is that a separate project in your workspace? If it is a separate project, then we'd need both of them.
  • Hi Ki,
    the project with which we are currently seeing the problem has a main folder with two subfolders which contains the actual projects (ADS/INA). The main folder sits in our workspace besides other projects. We used this constellation with CCS 20.5.1 for weeks without problems.
    With 21.0.0 we are seeing the mentioned problem but with other projects in the same workspace as well.
    I will send you the project via PM but I´ve deleted the containing MSPM0 SDK because the upload would be to big. In order to compile please download the latest MSPM0 SDK and unzip it to ADS/MSPM0SDK and  INA/MSPM0SDK.
    Thanks!
    Best regards
    Steffen
  • I received your private message and will continue conversation there.
    ki
