TMDSCNCD263P: AM263P CC with Industrial Ethernet DP83826 Add on
Part Number: TMDSCNCD263P
Other Parts Discussed in Thread: LP-AM263P, DP83826-EVM-AM2, IND-COMMS-SDK,
I am interested in running the EtherCAT Cia402 Example on my AM263P Control Card. If i understood correctly, the on board PHY does not support EtherCAT. Hence i would like to run the example with the industrial Ethernet Add-on board. I have a few questions:
  1. Is it possible to run EtherCAT in the configuration AM263P CC + Industrial Ethernet Add-On Board?
  2. Do you have any Examples adapted for the CC + Industrial ETH Addon configuration? The industrial communications SDK seems to only provide Board examples for LP boards + on Board ETH. Is it possible to port the examples from LP -> CC without much effort?
As I dont have much experience with CCs or the AM263P Platform, i would be very thankful for your support.
With kind regards
