HEX utility .s28 file format to .svf file format
CCS / Codegen gurus,
I know HEX2000 currently doesn't support SVF file format. But do we already have any tool which can help customers convert .s28 file fomat to SVF file format
http://e2e.ti.com/support/microcontrollers/tms320c2000_32-bit_real-time_mcus/f/171/t/167675.aspx
Manoj
  • I have never heard of either .s28 or SVF file formats.  Even so, here is a suggestion to consider.
    The bootimage utility in the cg_xml package converts TI executable files (extension is usually .out) to C arrays which contain the raw data in a simple hex format.  The package comes with the Perl source code.  So, you could change it to output whatever format you need.
    Thanks and regards,
    -George
