Hello Support,
I have attached a ZIP file.
Unzip using Sub-FOLDER Option of WINZIP to a Folder.
In the Out sub-folder, you should see that there is a Cortex_Endian_Bug.lst file.
In that file, NOP instruction is in Big Endian Format OPCODE.
In the Cortex_Bug_RAM.hex file of Out Sub-Folder, for the same NOP OPCODE, you will see in Little Endian Format.
For TMS570LS3137 Processor, I need Big Endian OPCODE within Cortex_Bug_RAM.hex Intel HEX file.
How do I get it?
In the attached ZIP, there is a Readme.txt file with instruction for rebuilding the files in case you need to test the fault condition.
Any help is appreciated.
Thank you.
Pashan
