Hi everybody,
Yesterday I have installed CCSv5.1.1 but whenever I open up CCS after few second it gets closed!
Is it natural, or is there anything I can do to fix problem?
OS. Ubuntu 11.10, 32 bit. CCSv5.1.1, 32 bit
Hi everybody,
This is what I get, when I start eclipse from terminal:
user@ubuntu:~$ /opt/ti/ccsv5/eclipse/eclipse
flxInitLoad: client has not been protected.
(SWT:5235): LIBDBUSMENU-GTK-CRITICAL **: watch_submenu: assertion `GTK_IS_MENU_SHELL(menu)' failed
** (SWT:5235): DEBUG: NP_Initialize
** (SWT:5235): DEBUG: NP_Initialize succeeded
ERROR: Invalid browser function table. Some functionality may be restricted.
No bp log location saved, using default.
[000:000] Browser XEmbed support present: 1
[000:000] Browser toolkit is Gtk2.
[000:000] Using Gtk2 toolkit
[000:026] No bp log location saved, using default.
[000:026] Browser XEmbed support present: 1
[000:026] Browser toolkit is Gtk2.
[000:027] Using Gtk2 toolkit
java version "1.6.0_23"
OpenJDK Runtime Environment (IcedTea6 1.11pre) (6b23~pre11-0ubuntu1.11.10.2)
OpenJDK Server VM (build 20.0-b11, mixed mode)
Segmentation fault (core dumped)
Hello Feruz,
have you made sure to run everything with full permissions as with full access? Have you seen this wiki to make sure all dependencies are also installed in your installation?
It is not normal to have CCS crash like that.
http://processors.wiki.ti.com/index.php/Linux_Host_Support#Installation_Instructions
Do you get any error logs or dump files generated? Please see this wiki
http://processors.wiki.ti.com/index.php/Troubleshooting_CCS
Lisa
Hi Lisa,
Actually yes I did install with root, and here is the dslog.txt in case you can help me to figure out what is the problem.
Thanks.
Feruz
0xB75AC6C0 0 3 XPCOM C: nsIComponentRegistrar::autoRegister( (nil) ) 0xB75AC6C0 9 3 XPCOM R: nsIComponentRegistrar::autoRegister( (nil) ) 0xB75AC6C0 13 3 XPCOM C: nsIComponentManager::createInstance( 0x891f2f78, (nil), 0x891f0d90, 0x891f0a00 ) 0xB75AC6C0 13 3 XPCOM R: nsIComponentManager::createInstance( 0x891f2f78, (nil), 0x891f0d90, *0x891f0a00 = 0x891f0a18 ) 0xB75AC6C0 25 3 XPCOM C: nsIComponentRegistrar::isContractIDRegistered( @ti.com/Mdex;1, 0x891ec910 ) 0xB75AC6C0 25 3 XPCOM R: nsIComponentRegistrar::isContractIDRegistered( @ti.com/Mdex;1, *0x891ec910 = true ) 0xB75AC6C0 25 3 XPCOM C: nsIComponentManager::createInstanceByContractID( @ti.com/Mdex;1, (nil), 0x891edd00, 0x891f03f0 ) 0xB75AC6C0 33 3 XPCOM R: nsIComponentManager::createInstanceByContractID( @ti.com/Mdex;1, (nil), 0x891edd00, *0x891f03f0 = 0x891f34e0 ) 0xB75AC6C0 38 3 XPCOM C: dsIMdex::initialize( ) 0xB75AC6C0 39 3 XPCOM R: dsIMdex::initialize( ) 0xB75AC6C0 127 3 FS I: Locking /home/feruzm/.TI/.lock (count = 0) 0xB75AC6C0 127 3 FS I: Incremented lock-count on /home/feruzm/.TI/.lock (count = 1) 0xB75AC6C0 127 3 FS I: Locking /home/feruzm/.TI/3205019477/0/0/.lock (count = 0) 0xB75AC6C0 127 3 FS I: Incremented lock-count on /home/feruzm/.TI/3205019477/0/0/.lock (count = 1) 0xB75AC6C0 129 3 XPCOM C: dsIMdex::initialize( /opt/ti/ccsv5/ccs_base/DebugServer/license:/home/feruzm/ti/license ) 0xB75AC6C0 129 3 XPCOM R: dsIMdex::initialize( /opt/ti/ccsv5/ccs_base/DebugServer/license:/home/feruzm/ti/license ) 0xB75AC6C0 129 3 XPCOM C: dsIMdex::setLocation( /opt/ti/ccsv5/ccs_base/DebugServer/license:/home/feruzm/ti/license ) 0xB75AC6C0 129 3 XPCOM R: dsIMdex::setLocation( /opt/ti/ccsv5/ccs_base/DebugServer/license:/home/feruzm/ti/license ) 0xB75AC6C0 130 3 XPCOM C: dsIMdex::acquireLicense( CCS_DEBUGGER, 5.0, 0x891f8c88 ) 0xB75AC6C0 131 3 XPCOM R: dsIMdex::acquireLicense( CCS_DEBUGGER, 5.0, *0x891f8c88 = 0xFFFFFFFF ) 0xB75AC6C0 131 3 XPCOM C: dsIMdex::lastErrorDetails( 0x891fafe0 ) 0xB75AC6C0 131 3 XPCOM R: dsIMdex::lastErrorDetails( *0x891fafe0 = Cannot find license file. The license files (or license server system network addresses) attempted are listed below. Use LM_LICENSE_FILE to use a different license file, or contact your software provider for a license file. Feature: CCS_DEBUGGER Filename: /home/feruzm/ti/license License path: /opt/ti/ccsv5/ccs_base/DebugServer/license/*.lic:/home/feruzm/ti/license: FLEXnet Licensing error:-1,359. System Error: 2 "No such file or directory" For further information, refer to the FLEXnet Licensing End User Guide, available at "www.macrovision.com". ) 0xB75AC6C0 131 3 XPCOM C: dsIMdex::hostID( 0x891f2290 ) 0xB75AC6C0 131 3 XPCOM R: dsIMdex::hostID( *0x891f2290 = 60eb6974fb5e ) 0xB75AC6C0 131 3 XPCOM C: dsIMdex::fulfillmentID( 0x891f2290 ) 0xB75AC6C0 131 3 XPCOM R: dsIMdex::fulfillmentID( *0x891f2290 = ) 0x86B5DB70 9585 3 XPCOM C: dsIMdex::setLocation( /opt/ti/ccsv5/ccs_base/DebugServer/license:/home/feruzm/ti/license ) 0x86B5DB70 9585 3 XPCOM R: dsIMdex::setLocation( /opt/ti/ccsv5/ccs_base/DebugServer/license:/home/feruzm/ti/license ) 0x86B5DB70 9585 3 XPCOM C: dsIMdex::acquireLicense( CCS_DEBUGGER, 5.00, 0x8fb6c40 ) 0x86B5DB70 9586 3 XPCOM R: dsIMdex::acquireLicense( CCS_DEBUGGER, 5.00, *0x8fb6c40 = 0xFFFFFFFF ) 0x86B5DB70 9586 3 XPCOM C: dsIMdex::lastErrorDetails( 0x8e86fd8 ) 0x86B5DB70 9586 3 XPCOM R: dsIMdex::lastErrorDetails( *0x8e86fd8 = Cannot find license file. The license files (or license server system network addresses) attempted are listed below. Use LM_LICENSE_FILE to use a different license file, or contact your software provider for a license file. Feature: CCS_DEBUGGER Filename: /home/feruzm/ti/license License path: /opt/ti/ccsv5/ccs_base/DebugServer/license/*.lic:/home/feruzm/ti/license: FLEXnet Licensing error:-1,359. System Error: 2 "No such file or directory" For further information, refer to the FLEXnet Licensing End User Guide, available at "www.macrovision.com". ) 0x86B5DB70 9586 3 XPCOM C: dsIMdex::hostID( 0x902dbf0 ) 0x86B5DB70 9586 3 XPCOM R: dsIMdex::hostID( *0x902dbf0 = 60eb6974fb5e ) 0x86B5DB70 9586 3 XPCOM C: dsIMdex::fulfillmentID( 0x902dbf0 ) 0x86B5DB70 9586 3 XPCOM R: dsIMdex::fulfillmentID( *0x902dbf0 = ) 0x86B0CB70 12226 3 XPCOM C: dsIMdex::setLocation( /opt/ti/ccsv5/ccs_base/DebugServer/license:/home/feruzm/ti/license ) 0x86B0CB70 12226 3 XPCOM R: dsIMdex::setLocation( /opt/ti/ccsv5/ccs_base/DebugServer/license:/home/feruzm/ti/license ) 0x86B0CB70 12226 3 XPCOM C: dsIMdex::acquireLicense( CCS_DEBUGGER, 4, 0x9090050 ) 0x86B0CB70 12227 3 XPCOM R: dsIMdex::acquireLicense( CCS_DEBUGGER, 4, *0x9090050 = 0xFFFFFFFF ) 0x86B0CB70 12227 3 XPCOM C: dsIMdex::lastErrorDetails( 0x8e8aaa0 ) 0x86B0CB70 12227 3 XPCOM R: dsIMdex::lastErrorDetails( *0x8e8aaa0 = Cannot find license file. The license files (or license server system network addresses) attempted are listed below. Use LM_LICENSE_FILE to use a different license file, or contact your software provider for a license file. Feature: CCS_DEBUGGER Filename: /home/feruzm/ti/license License path: /opt/ti/ccsv5/ccs_base/DebugServer/license/*.lic:/home/feruzm/ti/license: FLEXnet Licensing error:-1,359. System Error: 2 "No such file or directory" For further information, refer to the FLEXnet Licensing End User Guide, available at "www.macrovision.com". ) 0x86B0CB70 12227 3 XPCOM C: dsIMdex::hostID( 0x8e8aaa0 ) 0x86B0CB70 12227 3 XPCOM R: dsIMdex::hostID( *0x8e8aaa0 = 60eb6974fb5e ) 0x86B0CB70 12227 3 XPCOM C: dsIMdex::fulfillmentID( 0x8e8aaa0 ) 0x86B0CB70 12227 3 XPCOM R: dsIMdex::fulfillmentID( *0x8e8aaa0 = ) 0x86B0CB70 12227 3 XPCOM C: dsIMdex::fulfillmentID( 0x8e8aaa0 ) 0x86B0CB70 12227 3 XPCOM R: dsIMdex::fulfillmentID( *0x8e8aaa0 = )
Hi Feruz,
ok, let me see if we can dig into the log a bit further. Do you have fulll permissions on all directories ccs might be trying to access? I do know that occassionally such problems are caused by permissions issues.
You say you had a previous version. Was this working ok? Do you see any other dump files or error logs?
Lisa
Feruz,
I'm guessing the icensing complaint isn't causing the crash and there is a dependency issue. Could you cd to <install_dr>/ccsv4/ccs_base/DebugServer/linux and run "ldd *.so >xpcom.txt". Then, cd to "components" and run "ldd *.so >ds.txt". Please post those files yere.
FWIW, I have CCS runnig on 11.10 32-bit.
Hi AndyW,
Here is the files...
libfreebl3.so: linux-gate.so.1 => (0xb7722000) libdl.so.2 => /lib/i386-linux-gnu/libdl.so.2 (0xb76a9000) libc.so.6 => /lib/i386-linux-gnu/libc.so.6 (0xb752b000) /lib/ld-linux.so.2 (0xb7723000) libjavaxpcomglue.so: linux-gate.so.1 => (0xb76e4000) libpthread.so.0 => /lib/i386-linux-gnu/libpthread.so.0 (0xb769c000) libasound.so.2 => /usr/lib/i386-linux-gnu/libasound.so.2 (0xb75ab000) libdl.so.2 => /lib/i386-linux-gnu/libdl.so.2 (0xb75a5000) libstdc++.so.6 => /usr/lib/i386-linux-gnu/libstdc++.so.6 (0xb74b8000) libm.so.6 => /lib/i386-linux-gnu/libm.so.6 (0xb748e000) libgcc_s.so.1 => /lib/i386-linux-gnu/libgcc_s.so.1 (0xb7470000) libc.so.6 => /lib/i386-linux-gnu/libc.so.6 (0xb72f2000) /lib/ld-linux.so.2 (0xb76e5000) librt.so.1 => /lib/i386-linux-gnu/librt.so.1 (0xb72e8000) libmozjs.so: linux-gate.so.1 => (0xb772c000) libpthread.so.0 => /lib/i386-linux-gnu/libpthread.so.0 (0xb7594000) libplds4.so => /usr/lib/i386-linux-gnu/libplds4.so (0xb758f000) libplc4.so => /usr/lib/i386-linux-gnu/libplc4.so (0xb7588000) libnspr4.so => /usr/lib/i386-linux-gnu/libnspr4.so (0xb754c000) libdl.so.2 => /lib/i386-linux-gnu/libdl.so.2 (0xb7547000) libm.so.6 => /lib/i386-linux-gnu/libm.so.6 (0xb751d000) libstdc++.so.6 => /usr/lib/i386-linux-gnu/libstdc++.so.6 (0xb7430000) libgcc_s.so.1 => /lib/i386-linux-gnu/libgcc_s.so.1 (0xb7411000) libc.so.6 => /lib/i386-linux-gnu/libc.so.6 (0xb7293000) /lib/ld-linux.so.2 (0xb772d000) libnspr4.so: linux-gate.so.1 => (0xb77a6000) libpthread.so.0 => /lib/i386-linux-gnu/libpthread.so.0 (0xb7730000) libdl.so.2 => /lib/i386-linux-gnu/libdl.so.2 (0xb772b000) libc.so.6 => /lib/i386-linux-gnu/libc.so.6 (0xb75ac000) /lib/ld-linux.so.2 (0xb77a7000) libnss3.so: linux-gate.so.1 => (0xb777d000) libnssutil3.so => /usr/lib/i386-linux-gnu/libnssutil3.so (0xb7666000) libplc4.so => /usr/lib/i386-linux-gnu/libplc4.so (0xb7660000) libplds4.so => /usr/lib/i386-linux-gnu/libplds4.so (0xb765a000) libnspr4.so => /usr/lib/i386-linux-gnu/libnspr4.so (0xb761e000) libpthread.so.0 => /lib/i386-linux-gnu/libpthread.so.0 (0xb7603000) libdl.so.2 => /lib/i386-linux-gnu/libdl.so.2 (0xb75fe000) libc.so.6 => /lib/i386-linux-gnu/libc.so.6 (0xb7480000) /lib/ld-linux.so.2 (0xb777e000) libnssckbi.so: linux-gate.so.1 => (0xb77a4000) libplc4.so => /usr/lib/i386-linux-gnu/libplc4.so (0xb771e000) libplds4.so => /usr/lib/i386-linux-gnu/libplds4.so (0xb7719000) libnspr4.so => /usr/lib/i386-linux-gnu/libnspr4.so (0xb76dc000) libpthread.so.0 => /lib/i386-linux-gnu/libpthread.so.0 (0xb76c1000) libdl.so.2 => /lib/i386-linux-gnu/libdl.so.2 (0xb76bc000) libc.so.6 => /lib/i386-linux-gnu/libc.so.6 (0xb753e000) /lib/ld-linux.so.2 (0xb77a5000) libnssdbm3.so: linux-gate.so.1 => (0xb77b2000) libnssutil3.so => /usr/lib/i386-linux-gnu/libnssutil3.so (0xb7751000) libplc4.so => /usr/lib/i386-linux-gnu/libplc4.so (0xb774b000) libplds4.so => /usr/lib/i386-linux-gnu/libplds4.so (0xb7745000) libnspr4.so => /usr/lib/i386-linux-gnu/libnspr4.so (0xb7709000) libpthread.so.0 => /lib/i386-linux-gnu/libpthread.so.0 (0xb76ee000) libdl.so.2 => /lib/i386-linux-gnu/libdl.so.2 (0xb76e9000) libc.so.6 => /lib/i386-linux-gnu/libc.so.6 (0xb756b000) /lib/ld-linux.so.2 (0xb77b3000) libnssutil3.so: linux-gate.so.1 => (0xb7736000) libplc4.so => /usr/lib/i386-linux-gnu/libplc4.so (0xb76f3000) libplds4.so => /usr/lib/i386-linux-gnu/libplds4.so (0xb76ee000) libnspr4.so => /usr/lib/i386-linux-gnu/libnspr4.so (0xb76b1000) libpthread.so.0 => /lib/i386-linux-gnu/libpthread.so.0 (0xb7696000) libdl.so.2 => /lib/i386-linux-gnu/libdl.so.2 (0xb7691000) libc.so.6 => /lib/i386-linux-gnu/libc.so.6 (0xb7513000) /lib/ld-linux.so.2 (0xb7737000) libplc4.so: linux-gate.so.1 => (0xb77ad000) libnspr4.so => /usr/lib/i386-linux-gnu/libnspr4.so (0xb7745000) libc.so.6 => /lib/i386-linux-gnu/libc.so.6 (0xb75c7000) libpthread.so.0 => /lib/i386-linux-gnu/libpthread.so.0 (0xb75ab000) libdl.so.2 => /lib/i386-linux-gnu/libdl.so.2 (0xb75a6000) /lib/ld-linux.so.2 (0xb77ae000) libplds4.so: linux-gate.so.1 => (0xb77d3000) libnspr4.so => /usr/lib/i386-linux-gnu/libnspr4.so (0xb776c000) libc.so.6 => /lib/i386-linux-gnu/libc.so.6 (0xb75ee000) libpthread.so.0 => /lib/i386-linux-gnu/libpthread.so.0 (0xb75d2000) libdl.so.2 => /lib/i386-linux-gnu/libdl.so.2 (0xb75cd000) /lib/ld-linux.so.2 (0xb77d4000) libsmime3.so: linux-gate.so.1 => (0xb77a7000) libnss3.so => /usr/lib/i386-linux-gnu/libnss3.so (0xb7620000) libnssutil3.so => /usr/lib/i386-linux-gnu/libnssutil3.so (0xb7605000) libplc4.so => /usr/lib/i386-linux-gnu/libplc4.so (0xb75fe000) libplds4.so => /usr/lib/i386-linux-gnu/libplds4.so (0xb75f9000) libnspr4.so => /usr/lib/i386-linux-gnu/libnspr4.so (0xb75bd000) libpthread.so.0 => /lib/i386-linux-gnu/libpthread.so.0 (0xb75a2000) libdl.so.2 => /lib/i386-linux-gnu/libdl.so.2 (0xb759d000) libc.so.6 => /lib/i386-linux-gnu/libc.so.6 (0xb741e000) /lib/ld-linux.so.2 (0xb77a8000) libsoftokn3.so: linux-gate.so.1 => (0xb775e000) libsqlite3.so => not found libnssutil3.so => /usr/lib/i386-linux-gnu/libnssutil3.so (0xb76ed000) libplc4.so => /usr/lib/i386-linux-gnu/libplc4.so (0xb76e6000) libplds4.so => /usr/lib/i386-linux-gnu/libplds4.so (0xb76e1000) libnspr4.so => /usr/lib/i386-linux-gnu/libnspr4.so (0xb76a5000) libpthread.so.0 => /lib/i386-linux-gnu/libpthread.so.0 (0xb768a000) libdl.so.2 => /lib/i386-linux-gnu/libdl.so.2 (0xb7685000) libc.so.6 => /lib/i386-linux-gnu/libc.so.6 (0xb7506000) /lib/ld-linux.so.2 (0xb775f000) libsqlite3.so: linux-gate.so.1 => (0xb77a2000) libpthread.so.0 => /lib/i386-linux-gnu/libpthread.so.0 (0xb76db000) libasound.so.2 => /usr/lib/i386-linux-gnu/libasound.so.2 (0xb75ea000) libdl.so.2 => /lib/i386-linux-gnu/libdl.so.2 (0xb75e4000) libm.so.6 => /lib/i386-linux-gnu/libm.so.6 (0xb75ba000) libc.so.6 => /lib/i386-linux-gnu/libc.so.6 (0xb743c000) /lib/ld-linux.so.2 (0xb77a3000) librt.so.1 => /lib/i386-linux-gnu/librt.so.1 (0xb7433000) libssl3.so: linux-gate.so.1 => (0xb77c9000) libnss3.so => /usr/lib/i386-linux-gnu/libnss3.so (0xb7637000) libnssutil3.so => /usr/lib/i386-linux-gnu/libnssutil3.so (0xb761c000) libplc4.so => /usr/lib/i386-linux-gnu/libplc4.so (0xb7615000) libplds4.so => /usr/lib/i386-linux-gnu/libplds4.so (0xb7610000) libnspr4.so => /usr/lib/i386-linux-gnu/libnspr4.so (0xb75d4000) libpthread.so.0 => /lib/i386-linux-gnu/libpthread.so.0 (0xb75b9000) libdl.so.2 => /lib/i386-linux-gnu/libdl.so.2 (0xb75b4000) libc.so.6 => /lib/i386-linux-gnu/libc.so.6 (0xb7435000) /lib/ld-linux.so.2 (0xb77ca000) libxpcom.so: linux-gate.so.1 => (0xb76fa000) libpthread.so.0 => /lib/i386-linux-gnu/libpthread.so.0 (0xb76b3000) libxul.so => not found libplds4.so => /usr/lib/i386-linux-gnu/libplds4.so (0xb76ad000) libplc4.so => /usr/lib/i386-linux-gnu/libplc4.so (0xb76a7000) libnspr4.so => /usr/lib/i386-linux-gnu/libnspr4.so (0xb766b000) libdl.so.2 => /lib/i386-linux-gnu/libdl.so.2 (0xb7666000) libasound.so.2 => /usr/lib/i386-linux-gnu/libasound.so.2 (0xb7575000) libstdc++.so.6 => /usr/lib/i386-linux-gnu/libstdc++.so.6 (0xb7487000) libm.so.6 => /lib/i386-linux-gnu/libm.so.6 (0xb745d000) libgcc_s.so.1 => /lib/i386-linux-gnu/libgcc_s.so.1 (0xb743f000) libc.so.6 => /lib/i386-linux-gnu/libc.so.6 (0xb72c1000) /lib/ld-linux.so.2 (0xb76fb000) librt.so.1 => /lib/i386-linux-gnu/librt.so.1 (0xb72b8000) libxul.so: linux-gate.so.1 => (0xb773e000) libpthread.so.0 => /lib/i386-linux-gnu/libpthread.so.0 (0xb686e000) libsqlite3.so => not found libmozjs.so => not found libsmime3.so => /usr/lib/i386-linux-gnu/libsmime3.so (0xb6842000) libssl3.so => /usr/lib/i386-linux-gnu/libssl3.so (0xb6809000) libnss3.so => /usr/lib/i386-linux-gnu/libnss3.so (0xb66c8000) libnssutil3.so => /usr/lib/i386-linux-gnu/libnssutil3.so (0xb66ad000) libXrender.so.1 => /usr/lib/i386-linux-gnu/libXrender.so.1 (0xb66a1000) libfreetype.so.6 => /usr/lib/i386-linux-gnu/libfreetype.so.6 (0xb660a000) libfontconfig.so.1 => /usr/lib/i386-linux-gnu/libfontconfig.so.1 (0xb65d5000) libplds4.so => /usr/lib/i386-linux-gnu/libplds4.so (0xb65d0000) libplc4.so => /usr/lib/i386-linux-gnu/libplc4.so (0xb65ca000) libnspr4.so => /usr/lib/i386-linux-gnu/libnspr4.so (0xb658d000) libdl.so.2 => /lib/i386-linux-gnu/libdl.so.2 (0xb6588000) libdbus-1.so.3 => /lib/i386-linux-gnu/libdbus-1.so.3 (0xb653f000) libX11.so.6 => /usr/lib/i386-linux-gnu/libX11.so.6 (0xb6409000) libXext.so.6 => /usr/lib/i386-linux-gnu/libXext.so.6 (0xb63f6000) libpangoft2-1.0.so.0 => /usr/lib/i386-linux-gnu/libpangoft2-1.0.so.0 (0xb63c8000) libpango-1.0.so.0 => /usr/lib/i386-linux-gnu/libpango-1.0.so.0 (0xb637f000) libgobject-2.0.so.0 => /usr/lib/i386-linux-gnu/libgobject-2.0.so.0 (0xb6330000) libgmodule-2.0.so.0 => /usr/lib/i386-linux-gnu/libgmodule-2.0.so.0 (0xb632b000) libglib-2.0.so.0 => /lib/i386-linux-gnu/libglib-2.0.so.0 (0xb6232000) libgtk-x11-2.0.so.0 => /usr/lib/i386-linux-gnu/libgtk-x11-2.0.so.0 (0xb5dc8000) libatk-1.0.so.0 => /usr/lib/i386-linux-gnu/libatk-1.0.so.0 (0xb5da8000) libgdk-x11-2.0.so.0 => /usr/lib/i386-linux-gnu/libgdk-x11-2.0.so.0 (0xb5cfa000) libgdk_pixbuf-2.0.so.0 => /usr/lib/i386-linux-gnu/libgdk_pixbuf-2.0.so.0 (0xb5cda000) libpangocairo-1.0.so.0 => /usr/lib/i386-linux-gnu/libpangocairo-1.0.so.0 (0xb5ccd000) libcairo.so.2 => /usr/lib/i386-linux-gnu/libcairo.so.2 (0xb5c01000) libXt.so.6 => /usr/lib/i386-linux-gnu/libXt.so.6 (0xb5ba3000) libgthread-2.0.so.0 => /usr/lib/i386-linux-gnu/libgthread-2.0.so.0 (0xb5b9d000) libz.so.1 => /lib/i386-linux-gnu/libz.so.1 (0xb5b88000) libasound.so.2 => /usr/lib/i386-linux-gnu/libasound.so.2 (0xb5a97000) libm.so.6 => /lib/i386-linux-gnu/libm.so.6 (0xb5a6c000) librt.so.1 => /lib/i386-linux-gnu/librt.so.1 (0xb5a63000) libstdc++.so.6 => /usr/lib/i386-linux-gnu/libstdc++.so.6 (0xb5976000) libgcc_s.so.1 => /lib/i386-linux-gnu/libgcc_s.so.1 (0xb5958000) libc.so.6 => /lib/i386-linux-gnu/libc.so.6 (0xb57da000) /lib/ld-linux.so.2 (0xb773f000) libexpat.so.1 => /lib/i386-linux-gnu/libexpat.so.1 (0xb57af000) libxcb.so.1 => /usr/lib/i386-linux-gnu/libxcb.so.1 (0xb5790000) libffi.so.6 => /usr/lib/i386-linux-gnu/libffi.so.6 (0xb5789000) libpcre.so.3 => /lib/i386-linux-gnu/libpcre.so.3 (0xb574a000) libXfixes.so.3 => /usr/lib/i386-linux-gnu/libXfixes.so.3 (0xb5744000) libgio-2.0.so.0 => /usr/lib/i386-linux-gnu/libgio-2.0.so.0 (0xb55fd000) libXinerama.so.1 => /usr/lib/i386-linux-gnu/libXinerama.so.1 (0xb55f9000) libXi.so.6 => /usr/lib/i386-linux-gnu/libXi.so.6 (0xb55e9000) libXrandr.so.2 => /usr/lib/i386-linux-gnu/libXrandr.so.2 (0xb55e0000) libXcursor.so.1 => /usr/lib/i386-linux-gnu/libXcursor.so.1 (0xb55d5000) libXcomposite.so.1 => /usr/lib/i386-linux-gnu/libXcomposite.so.1 (0xb55d0000) libXdamage.so.1 => /usr/lib/i386-linux-gnu/libXdamage.so.1 (0xb55cc000) libpixman-1.so.0 => /usr/lib/i386-linux-gnu/libpixman-1.so.0 (0xb5549000) libpng12.so.0 => /lib/i386-linux-gnu/libpng12.so.0 (0xb551f000) libxcb-shm.so.0 => /usr/lib/i386-linux-gnu/libxcb-shm.so.0 (0xb551b000) libxcb-render.so.0 => /usr/lib/i386-linux-gnu/libxcb-render.so.0 (0xb5510000) libSM.so.6 => /usr/lib/i386-linux-gnu/libSM.so.6 (0xb5507000) libICE.so.6 => /usr/lib/i386-linux-gnu/libICE.so.6 (0xb54ed000) libXau.so.6 => /usr/lib/i386-linux-gnu/libXau.so.6 (0xb54e9000) libXdmcp.so.6 => /usr/lib/i386-linux-gnu/libXdmcp.so.6 (0xb54e2000) libselinux.so.1 => /lib/i386-linux-gnu/libselinux.so.1 (0xb54c3000) libresolv.so.2 => /lib/i386-linux-gnu/libresolv.so.2 (0xb54ac000) libuuid.so.1 => /lib/i386-linux-gnu/libuuid.so.1 (0xb54a6000)
libDataSnapshotDecoder.so: linux-gate.so.1 => (0xb7728000) libti_logger.so => /opt/ti/ccsv5/ccs_base/DebugServer/linux/components/./../../../common/bin/libti_logger.so (0xb76c1000) libXPCOMUtility.so => /opt/ti/ccsv5/ccs_base/DebugServer/linux/components/./../../bin/linux_ia32/libXPCOMUtility.so (0xb768f000) libnspr4.so => /usr/lib/i386-linux-gnu/libnspr4.so (0xb762d000) libxpcom.so => not found libstdc++.so.6 => /usr/lib/i386-linux-gnu/libstdc++.so.6 (0xb7540000) libm.so.6 => /lib/i386-linux-gnu/libm.so.6 (0xb7516000) libgcc_s.so.1 => /lib/i386-linux-gnu/libgcc_s.so.1 (0xb74f7000) libpthread.so.0 => /lib/i386-linux-gnu/libpthread.so.0 (0xb74dc000) libc.so.6 => /lib/i386-linux-gnu/libc.so.6 (0xb735e000) libxpcom.so => not found libdl.so.2 => /lib/i386-linux-gnu/libdl.so.2 (0xb7359000) /lib/ld-linux.so.2 (0xb7729000) libdbusservice.so: linux-gate.so.1 => (0xb7731000) libpthread.so.0 => /lib/i386-linux-gnu/libpthread.so.0 (0xb76e6000) libxpcom.so => not found libplds4.so => /usr/lib/i386-linux-gnu/libplds4.so (0xb76e0000) libplc4.so => /usr/lib/i386-linux-gnu/libplc4.so (0xb76da000) libnspr4.so => /usr/lib/i386-linux-gnu/libnspr4.so (0xb769e000) libdl.so.2 => /lib/i386-linux-gnu/libdl.so.2 (0xb7699000) libdbus-glib-1.so.2 => /usr/lib/i386-linux-gnu/libdbus-glib-1.so.2 (0xb7674000) libdbus-1.so.3 => /lib/i386-linux-gnu/libdbus-1.so.3 (0xb762a000) libgobject-2.0.so.0 => /usr/lib/i386-linux-gnu/libgobject-2.0.so.0 (0xb75db000) libglib-2.0.so.0 => /lib/i386-linux-gnu/libglib-2.0.so.0 (0xb74e2000) libasound.so.2 => /usr/lib/i386-linux-gnu/libasound.so.2 (0xb73f1000) libstdc++.so.6 => /usr/lib/i386-linux-gnu/libstdc++.so.6 (0xb7304000) libm.so.6 => /lib/i386-linux-gnu/libm.so.6 (0xb72d9000) libgcc_s.so.1 => /lib/i386-linux-gnu/libgcc_s.so.1 (0xb72bb000) libc.so.6 => /lib/i386-linux-gnu/libc.so.6 (0xb713d000) /lib/ld-linux.so.2 (0xb7732000) libgio-2.0.so.0 => /usr/lib/i386-linux-gnu/libgio-2.0.so.0 (0xb6ff7000) librt.so.1 => /lib/i386-linux-gnu/librt.so.1 (0xb6fee000) libgthread-2.0.so.0 => /usr/lib/i386-linux-gnu/libgthread-2.0.so.0 (0xb6fe7000) libffi.so.6 => /usr/lib/i386-linux-gnu/libffi.so.6 (0xb6fe0000) libpcre.so.3 => /lib/i386-linux-gnu/libpcre.so.3 (0xb6fa1000) libgmodule-2.0.so.0 => /usr/lib/i386-linux-gnu/libgmodule-2.0.so.0 (0xb6f9c000) libz.so.1 => /lib/i386-linux-gnu/libz.so.1 (0xb6f87000) libselinux.so.1 => /lib/i386-linux-gnu/libselinux.so.1 (0xb6f68000) libresolv.so.2 => /lib/i386-linux-gnu/libresolv.so.2 (0xb6f51000) libDebugProperties.so: linux-gate.so.1 => (0xb77d1000) libti_logger.so => /opt/ti/ccsv5/ccs_base/DebugServer/linux/components/./../../../common/bin/libti_logger.so (0xb775a000) libXPCOMUtility.so => /opt/ti/ccsv5/ccs_base/DebugServer/linux/components/./../../bin/linux_ia32/libXPCOMUtility.so (0xb7728000) libnspr4.so => /usr/lib/i386-linux-gnu/libnspr4.so (0xb76c6000) libxpcom.so => not found libxerces-c.so.25 => /opt/ti/ccsv5/ccs_base/DebugServer/linux/components/./../../../common/bin/libxerces-c.so.25 (0xb7341000) libstdc++.so.6 => /usr/lib/i386-linux-gnu/libstdc++.so.6 (0xb7254000) libm.so.6 => /lib/i386-linux-gnu/libm.so.6 (0xb7229000) libgcc_s.so.1 => /lib/i386-linux-gnu/libgcc_s.so.1 (0xb720b000) libpthread.so.0 => /lib/i386-linux-gnu/libpthread.so.0 (0xb71f0000) libc.so.6 => /lib/i386-linux-gnu/libc.so.6 (0xb7072000) libxpcom.so => not found libdl.so.2 => /lib/i386-linux-gnu/libdl.so.2 (0xb706c000) /lib/ld-linux.so.2 (0xb77d2000) libDebugServer.so: linux-gate.so.1 => (0xb7710000) libtiofr11.so => /opt/ti/ccsv5/ccs_base/DebugServer/linux/components/./../../bin/linux_ia32/libtiofr11.so (0xb6d94000) libsetup_parser.so => /opt/ti/ccsv5/ccs_base/DebugServer/linux/components/./../../../common/bin/libsetup_parser.so (0xb6b22000) libti_logger.so => /opt/ti/ccsv5/ccs_base/DebugServer/linux/components/./../../../common/bin/libti_logger.so (0xb6af8000) libXPCOMUtility.so => /opt/ti/ccsv5/ccs_base/DebugServer/linux/components/./../../bin/linux_ia32/libXPCOMUtility.so (0xb6ac7000) libfsutil.so => /opt/ti/ccsv5/ccs_base/DebugServer/linux/components/./../../../common/bin/libfsutil.so (0xb6a5f000) libdl.so.2 => /lib/i386-linux-gnu/libdl.so.2 (0xb6a34000) libnspr4.so => /usr/lib/i386-linux-gnu/libnspr4.so (0xb69f7000) libxpcom.so => not found libxerces-c.so.25 => /opt/ti/ccsv5/ccs_base/DebugServer/linux/components/./../../../common/bin/libxerces-c.so.25 (0xb6672000) libjvm.so => not found librt.so.1 => /lib/i386-linux-gnu/librt.so.1 (0xb6669000) libstdc++.so.6 => /usr/lib/i386-linux-gnu/libstdc++.so.6 (0xb657b000) libm.so.6 => /lib/i386-linux-gnu/libm.so.6 (0xb6551000) libgcc_s.so.1 => /lib/i386-linux-gnu/libgcc_s.so.1 (0xb6533000) libpthread.so.0 => /lib/i386-linux-gnu/libpthread.so.0 (0xb6518000) libc.so.6 => /lib/i386-linux-gnu/libc.so.6 (0xb639a000) /lib/ld-linux.so.2 (0xb7711000) libxpcom.so => not found libimgicon.so: linux-gate.so.1 => (0xb77df000) libpthread.so.0 => /lib/i386-linux-gnu/libpthread.so.0 (0xb7792000) libgtk-x11-2.0.so.0 => /usr/lib/i386-linux-gnu/libgtk-x11-2.0.so.0 (0xb7329000) libatk-1.0.so.0 => /usr/lib/i386-linux-gnu/libatk-1.0.so.0 (0xb7308000) libgdk-x11-2.0.so.0 => /usr/lib/i386-linux-gnu/libgdk-x11-2.0.so.0 (0xb725a000) libgdk_pixbuf-2.0.so.0 => /usr/lib/i386-linux-gnu/libgdk_pixbuf-2.0.so.0 (0xb723a000) libpangocairo-1.0.so.0 => /usr/lib/i386-linux-gnu/libpangocairo-1.0.so.0 (0xb722d000) libpango-1.0.so.0 => /usr/lib/i386-linux-gnu/libpango-1.0.so.0 (0xb71e4000) libcairo.so.2 => /usr/lib/i386-linux-gnu/libcairo.so.2 (0xb7118000) libgobject-2.0.so.0 => /usr/lib/i386-linux-gnu/libgobject-2.0.so.0 (0xb70c9000) libgmodule-2.0.so.0 => /usr/lib/i386-linux-gnu/libgmodule-2.0.so.0 (0xb70c4000) libdl.so.2 => /lib/i386-linux-gnu/libdl.so.2 (0xb70bf000) libglib-2.0.so.0 => /lib/i386-linux-gnu/libglib-2.0.so.0 (0xb6fc6000) libxpcom.so => not found libplds4.so => /usr/lib/i386-linux-gnu/libplds4.so (0xb6fc0000) libplc4.so => /usr/lib/i386-linux-gnu/libplc4.so (0xb6fba000) libnspr4.so => /usr/lib/i386-linux-gnu/libnspr4.so (0xb6f7e000) libasound.so.2 => /usr/lib/i386-linux-gnu/libasound.so.2 (0xb6e8d000) libm.so.6 => /lib/i386-linux-gnu/libm.so.6 (0xb6e62000) libstdc++.so.6 => /usr/lib/i386-linux-gnu/libstdc++.so.6 (0xb6d75000) libgcc_s.so.1 => /lib/i386-linux-gnu/libgcc_s.so.1 (0xb6d57000) libc.so.6 => /lib/i386-linux-gnu/libc.so.6 (0xb6bd9000) /lib/ld-linux.so.2 (0xb77e0000) libX11.so.6 => /usr/lib/i386-linux-gnu/libX11.so.6 (0xb6aa3000) libXfixes.so.3 => /usr/lib/i386-linux-gnu/libXfixes.so.3 (0xb6a9c000) libgio-2.0.so.0 => /usr/lib/i386-linux-gnu/libgio-2.0.so.0 (0xb6956000) libpangoft2-1.0.so.0 => /usr/lib/i386-linux-gnu/libpangoft2-1.0.so.0 (0xb6929000) libfontconfig.so.1 => /usr/lib/i386-linux-gnu/libfontconfig.so.1 (0xb68f4000) libXext.so.6 => /usr/lib/i386-linux-gnu/libXext.so.6 (0xb68e1000) libXrender.so.1 => /usr/lib/i386-linux-gnu/libXrender.so.1 (0xb68d5000) libXinerama.so.1 => /usr/lib/i386-linux-gnu/libXinerama.so.1 (0xb68d1000) libXi.so.6 => /usr/lib/i386-linux-gnu/libXi.so.6 (0xb68c1000) libXrandr.so.2 => /usr/lib/i386-linux-gnu/libXrandr.so.2 (0xb68b8000) libXcursor.so.1 => /usr/lib/i386-linux-gnu/libXcursor.so.1 (0xb68ad000) libXcomposite.so.1 => /usr/lib/i386-linux-gnu/libXcomposite.so.1 (0xb68a8000) libXdamage.so.1 => /usr/lib/i386-linux-gnu/libXdamage.so.1 (0xb68a4000) libfreetype.so.6 => /usr/lib/i386-linux-gnu/libfreetype.so.6 (0xb680d000) libpixman-1.so.0 => /usr/lib/i386-linux-gnu/libpixman-1.so.0 (0xb678a000) libpng12.so.0 => /lib/i386-linux-gnu/libpng12.so.0 (0xb6760000) libxcb-shm.so.0 => /usr/lib/i386-linux-gnu/libxcb-shm.so.0 (0xb675b000) libxcb-render.so.0 => /usr/lib/i386-linux-gnu/libxcb-render.so.0 (0xb6751000) libxcb.so.1 => /usr/lib/i386-linux-gnu/libxcb.so.1 (0xb6732000) libz.so.1 => /lib/i386-linux-gnu/libz.so.1 (0xb671d000) libgthread-2.0.so.0 => /usr/lib/i386-linux-gnu/libgthread-2.0.so.0 (0xb6717000) libffi.so.6 => /usr/lib/i386-linux-gnu/libffi.so.6 (0xb670f000) libpcre.so.3 => /lib/i386-linux-gnu/libpcre.so.3 (0xb66d0000) librt.so.1 => /lib/i386-linux-gnu/librt.so.1 (0xb66c7000) libselinux.so.1 => /lib/i386-linux-gnu/libselinux.so.1 (0xb66a9000) libresolv.so.2 => /lib/i386-linux-gnu/libresolv.so.2 (0xb6692000) libexpat.so.1 => /lib/i386-linux-gnu/libexpat.so.1 (0xb6667000) libXau.so.6 => /usr/lib/i386-linux-gnu/libXau.so.6 (0xb6663000) libXdmcp.so.6 => /usr/lib/i386-linux-gnu/libXdmcp.so.6 (0xb665c000) libmdex.so: linux-gate.so.1 => (0xb7793000) libXPCOMUtility.so => /opt/ti/ccsv5/ccs_base/DebugServer/linux/components/./../../bin/linux_ia32/libXPCOMUtility.so (0xb7637000) libnspr4.so => /usr/lib/i386-linux-gnu/libnspr4.so (0xb75d4000) libxpcom.so => not found liblmgr10.so => /opt/ti/ccsv5/ccs_base/DebugServer/linux/components/./../../../common/bin/liblmgr10.so (0xb74ad000) libdl.so.2 => /lib/i386-linux-gnu/libdl.so.2 (0xb74a8000) libti_logger.so => /opt/ti/ccsv5/ccs_base/DebugServer/linux/components/./../../../common/bin/libti_logger.so (0xb747e000) libstdc++.so.6 => /usr/lib/i386-linux-gnu/libstdc++.so.6 (0xb7390000) libm.so.6 => /lib/i386-linux-gnu/libm.so.6 (0xb7366000) libgcc_s.so.1 => /lib/i386-linux-gnu/libgcc_s.so.1 (0xb7348000) libpthread.so.0 => /lib/i386-linux-gnu/libpthread.so.0 (0xb732d000) libc.so.6 => /lib/i386-linux-gnu/libc.so.6 (0xb71af000) /lib/ld-linux.so.2 (0xb7794000) libxpcom.so => not found libXPCOMTILogger.so: linux-gate.so.1 => (0xb7759000) libti_logger.so => /opt/ti/ccsv5/ccs_base/DebugServer/linux/components/./../../../common/bin/libti_logger.so (0xb7726000) libXPCOMUtility.so => /opt/ti/ccsv5/ccs_base/DebugServer/linux/components/./../../bin/linux_ia32/libXPCOMUtility.so (0xb76f4000) libnspr4.so => /usr/lib/i386-linux-gnu/libnspr4.so (0xb7692000) libxpcom.so => not found libstdc++.so.6 => /usr/lib/i386-linux-gnu/libstdc++.so.6 (0xb75a5000) libm.so.6 => /lib/i386-linux-gnu/libm.so.6 (0xb757b000) libgcc_s.so.1 => /lib/i386-linux-gnu/libgcc_s.so.1 (0xb755c000) libpthread.so.0 => /lib/i386-linux-gnu/libpthread.so.0 (0xb7541000) libc.so.6 => /lib/i386-linux-gnu/libc.so.6 (0xb73c3000) libxpcom.so => not found libdl.so.2 => /lib/i386-linux-gnu/libdl.so.2 (0xb73be000) /lib/ld-linux.so.2 (0xb775a000)
Thanks!
Feruz
Thanks for the files. Unfortuately, it doesn't point to anything unusual.
A couple of other things that might help:
There is a small chance the JVM created an "hs_err" log. It is usually located in the /tmp folder on linux. Could you have a look and see if you find any files that look like "hs_err_pidxxxx.log" with an appropriate timestamp?
Anohter thing we can do is capture the massive strace log up to the point CCS crashes and see if there are hints in there. If you want to give this a try, run "strace -o /tmp/strace.log ./ccstudio", zip up the log and post it.
I'm stil not suspecting this is a license issue as the ds log you posted indicates a license file wasn't found but it had returned from that area of the code sucessfully. I've certainly been wrong before though so I'll keep this information in mind.
No there isn't any error log files as "hs_err"...
I did strace while running, though after sudden close of CCS, I get problem report from system, unexpected close of "strace"...
Here is the file.... 8270.strace.log.tar.gz
Thanks for having patient on this!
Feruz
Feruz,
I'm seeing some Mozilla libraries being loaded from /usr/lib/Mozilla which might be causing a problem. These would get loaded when the internal Eclipse browser is loaded.
If the debugger works by itself, that would support the theory. To see if the debugger works by itself, could you run one of the Debug Server Scripting examples located in <installdir>/ccsv5/ccs_base/scripting/examples/DebugServerExamples. You can run an example if you cd to that folder and run ../../bin/dss.sh Memory.js from a terminal (for example).
After the script runs, you should see "TEST SUCCEEDED". If it crashes, we are not on the right path.
