CCS Loader issue
We are facing a loader issue in CCS 4. We have built the library with the TI Code Generation Tools 4.5.1 for Cortex-M3. We used the Code Sourcery tool chain for building the sample application and linked the above mentioned TI library with the Code Sourcery linker. The generated executable is attached.
We used the arm-none-eabi-objdump to see the disassembly of the executable. [attached]
We also used the TI ofd470 to see the disassembly of the executable. [attached]
In both the cases the disassembly shows the proper instructions.
But if we load the executable in CCS, we see the instructions are corrupted.
What is the reason for this behavior?
4885.disassembly_codeSourcery.txt
a.out:     file format elf32-littlearm
Disassembly of section vector_table:
00000000 <vector_table>:
   0:	9400009c 	strls	r0, [r0], #-156	; 0xffffff64
   4:	94000031 	strls	r0, [r0], #-49	; 0xffffffcf
   8:	94000041 	strls	r0, [r0], #-65	; 0xffffffbf
   c:	9400004d 	strls	r0, [r0], #-77	; 0xffffffb3
  10:	94000079 	strls	r0, [r0], #-121	; 0xffffff87
  14:	0000000a 	andeq	r0, r0, sl
  2c:	94000059 	strls	r0, [r0], #-89	; 0xffffffa7
Disassembly of section .text:
94000000 <main>:
94000000:	b580      	push	{r7, lr}
94000002:	b084      	sub	sp, #16
94000004:	af00      	add	r7, sp, #0
94000006:	f04f 030a 	mov.w	r3, #10
9400000a:	60fb      	str	r3, [r7, #12]
9400000c:	f04f 0314 	mov.w	r3, #20
94000010:	60bb      	str	r3, [r7, #8]
94000012:	68f8      	ldr	r0, [r7, #12]
94000014:	68b9      	ldr	r1, [r7, #8]
94000016:	f000 f83f 	bl	94000098 <doMath>
9400001a:	6078      	str	r0, [r7, #4]
9400001c:	687a      	ldr	r2, [r7, #4]
9400001e:	68bb      	ldr	r3, [r7, #8]
94000020:	429a      	cmp	r2, r3
94000022:	d000      	beq.n	94000026 <main+0x26>
94000024:	e7fe      	b.n	94000024 <main+0x24>
94000026:	4618      	mov	r0, r3
94000028:	f107 0710 	add.w	r7, r7, #16
9400002c:	46bd      	mov	sp, r7
9400002e:	bd80      	pop	{r7, pc}
94000030 <resetHandler>:
94000030:	b480      	push	{r7}
94000032:	af00      	add	r7, sp, #0
94000034:	f7ff bfe4 	b.w	94000000 <main>
94000038:	46bd      	mov	sp, r7
9400003a:	bc80      	pop	{r7}
9400003c:	4770      	bx	lr
9400003e:	bf00      	nop
94000040 <NMIHandler>:
94000040:	b480      	push	{r7}
94000042:	af00      	add	r7, sp, #0
94000044:	46bd      	mov	sp, r7
94000046:	bc80      	pop	{r7}
94000048:	4770      	bx	lr
9400004a:	bf00      	nop
9400004c <HFHandler>:
9400004c:	b480      	push	{r7}
9400004e:	af00      	add	r7, sp, #0
94000050:	46bd      	mov	sp, r7
94000052:	bc80      	pop	{r7}
94000054:	4770      	bx	lr
94000056:	bf00      	nop
94000058 <SVCallISR>:
94000058:	b480      	push	{r7}
9400005a:	b083      	sub	sp, #12
9400005c:	af00      	add	r7, sp, #0
9400005e:	f04f 0300 	mov.w	r3, #0
94000062:	607b      	str	r3, [r7, #4]
94000064:	687b      	ldr	r3, [r7, #4]
94000066:	f103 0301 	add.w	r3, r3, #1
9400006a:	607b      	str	r3, [r7, #4]
9400006c:	f107 070c 	add.w	r7, r7, #12
94000070:	46bd      	mov	sp, r7
94000072:	bc80      	pop	{r7}
94000074:	4770      	bx	lr
94000076:	bf00      	nop
94000078 <MemManageHandler>:
94000078:	b480      	push	{r7}
9400007a:	af00      	add	r7, sp, #0
9400007c:	46bd      	mov	sp, r7
9400007e:	bc80      	pop	{r7}
94000080:	4770      	bx	lr
94000082:	bf00      	nop
94000084 <init_ivt>:
94000084:	b480      	push	{r7}
94000086:	af00      	add	r7, sp, #0
94000088:	46bd      	mov	sp, r7
9400008a:	bc80      	pop	{r7}
9400008c:	4770      	bx	lr
9400008e:	bf00      	nop
94000090 <sub>:
94000090:	1a40      	subs	r0, r0, r1
94000092:	4770      	bx	lr
94000094 <add>:
94000094:	1808      	adds	r0, r1, r0
94000096:	4770      	bx	lr
94000098 <doMath>:
94000098:	4608      	mov	r0, r1
9400009a:	4770      	bx	lr
Disassembly of section .bss:
9400009c <__bss_start>:
Disassembly of section .TI.symbol.alias:
00000000 <__end__-0x9400d49c>:
   0:	00000001 	andeq	r0, r0, r1
   4:	49540000 	ldmdbmi	r4, {}^	; <UNPREDICTABLE>
Disassembly of section .TI.section.flags:
00000000 <.TI.section.flags>:
Disassembly of section .comment:
00000000 <.comment>:
   0:	3a434347 	bcc	10d0d24 <__TI_DW.debug_info.$base_types.4b0d1e45517085cb8ecdf519739bebb4+0x10d06aa>
   4:	6f532820 	svcvs	0x00532820
   8:	65637275 	strbvs	r7, [r3, #-629]!	; 0xfffffd8b
   c:	47207972 			; <UNDEFINED> instruction: 0x47207972
  10:	4c202b2b 	stcmi	11, cr2, [r0], #-172	; 0xffffff54
  14:	20657469 	rsbcs	r7, r5, r9, ror #8
  18:	31313032 	teqcc	r1, r2, lsr r0
  1c:	2d33302e 	ldccs	0, cr3, [r3, #-184]!	; 0xffffff48
  20:	20293234 	eorcs	r3, r9, r4, lsr r2
  24:	2e352e34 	mrccs	14, 1, r2, cr5, cr4, {1}
  28:	Address 0x00000028 is out of bounds.
Disassembly of section .debug_info:
00000000 <__TI_DW.debug_info.$base_types.4b0d1e45517085cb8ecdf519739bebb4-0x67a>:
   0:	0000036a 	andeq	r0, r0, sl, ror #6
   4:	00000002 	andeq	r0, r0, r2
   8:	01040000 	mrseq	r0, (UNDEF: 4)
   c:	696c5c2e 	stmdbvs	ip!, {r1, r2, r3, r5, sl, fp, ip, lr}^
  10:	72617262 	rsbvc	r7, r1, #536870918	; 0x20000006
  14:	00632e79 	rsbeq	r2, r3, r9, ror lr
  18:	00000000 	andeq	r0, r0, r0
  1c:	5c3a4602 	ldcpl	6, cr4, [sl], #-8
  20:	75716953 	ldrbvc	r6, [r1, #-2387]!	; 0xfffff6ad
  24:	735c6172 	cmpvc	ip, #-2147483620	; 0x8000001c
  28:	72757169 	rsbsvc	r7, r5, #1073741850	; 0x4000001a
  2c:	69735c61 	ldmdbvs	r3!, {r0, r5, r6, sl, fp, ip, lr}^
  30:	61727571 	cmnvs	r2, r1, ror r5
  34:	62696c5c 	rsbvs	r6, r9, #92, 24	; 0x5c00
  38:	79726172 	ldmdbvc	r2!, {r1, r4, r5, r6, r8, sp, lr}^
  3c:	6975625f 	ldmdbvs	r5!, {r0, r1, r2, r3, r4, r6, r9, sp, lr}^
  40:	345f646c 	ldrbcc	r6, [pc], #-1132	; 48 <vector_table+0x48>
  44:	6c5c3339 	mrrcvs	3, 3, r3, ip, cr9
  48:	54006269 	strpl	r6, [r0], #-617	; 0xfffffd97
  4c:	3734534d 	ldrcc	r5, [r4, -sp, asr #6]!
  50:	2f432030 	svccs	0x00432030
  54:	202b2b43 	eorcs	r2, fp, r3, asr #22
  58:	65646f43 	strbvs	r6, [r4, #-3907]!	; 0xfffff0bd
  5c:	206e6567 	rsbcs	r6, lr, r7, ror #10
  60:	76204350 			; <UNDEFINED> instruction: 0x76204350
  64:	2e392e34 	mrccs	14, 1, r2, cr9, cr4, {1}
  68:	6f432033 	svcvs	0x00432033
  6c:	69727970 	ldmdbvs	r2!, {r4, r5, r6, r8, fp, ip, sp, lr}^
  70:	20746867 	rsbscs	r6, r4, r7, ror #16
  74:	20296328 	eorcs	r6, r9, r8, lsr #6
  78:	36393931 			; <UNDEFINED> instruction: 0x36393931
  7c:	3130322d 	teqcc	r0, sp, lsr #4
  80:	65542032 	ldrbvs	r2, [r4, #-50]	; 0xffffffce
  84:	20736178 	rsbscs	r6, r3, r8, ror r1
  88:	74736e49 	ldrbtvc	r6, [r3], #-3657	; 0xfffff1b7
  8c:	656d7572 	strbvs	r7, [sp, #-1394]!	; 0xfffffa8e
  90:	2073746e 	rsbscs	r7, r3, lr, ror #8
  94:	6f636e49 	svcvs	0x00636e49
  98:	726f7072 	rsbvc	r7, pc, #114	; 0x72
  9c:	64657461 	strbtvs	r7, [r5], #-1121	; 0xfffffb9f
  a0:	01020100 	mrseq	r0, (UNDEF: 18)
  a4:	00314150 	eorseq	r4, r1, r0, asr r1
  a8:	41510102 	cmpmi	r1, r2, lsl #2
  ac:	01020032 	tsteq	r2, r2, lsr r0
  b0:	00334152 	eorseq	r4, r3, r2, asr r1
  b4:	41530102 	cmpmi	r3, r2, lsl #2
  b8:	01020034 	tsteq	r2, r4, lsr r0
  bc:	00315654 	eorseq	r5, r1, r4, asr r6
  c0:	56550102 	ldrbpl	r0, [r5], -r2, lsl #2
  c4:	01020032 	tsteq	r2, r2, lsr r0
  c8:	00335656 	eorseq	r5, r3, r6, asr r6
  cc:	56570102 	ldrbpl	r0, [r7], -r2, lsl #2
  d0:	01020034 	tsteq	r2, r4, lsr r0
  d4:	00355658 	eorseq	r5, r5, r8, asr r6
  d8:	56590102 	ldrbpl	r0, [r9], -r2, lsl #2
  dc:	01020036 	tsteq	r2, r6, lsr r0
  e0:	0037565a 	eorseq	r5, r7, sl, asr r6
  e4:	565b0102 	ldrbpl	r0, [fp], -r2, lsl #2
  e8:	01020038 	tsteq	r2, r8, lsr r0
  ec:	0039565c 	eorseq	r5, r9, ip, asr r6
  f0:	535d0102 	cmppl	sp, #-2147483648	; 0x80000000
  f4:	01020050 	qaddeq	r0, r0, r2
  f8:	00524c5e 	subseq	r4, r2, lr, asr ip
  fc:	505f0102 	subspl	r0, pc, r2, lsl #2
 100:	01020043 	tsteq	r2, r3, asr #32
 104:	00504160 	subseq	r4, r0, r0, ror #2
 108:	53610102 	cmnpl	r1, #-2147483648	; 0x80000000
 10c:	01020052 	qaddeq	r0, r2, r2
 110:	53504662 	cmppl	r0, #102760448	; 0x6200000
 114:	02005243 	andeq	r5, r0, #805306372	; 0x30000004
 118:	50466301 	subpl	r6, r6, r1, lsl #6
 11c:	00435845 	subeq	r5, r3, r5, asr #16
 120:	44640102 	strbtmi	r0, [r4], #-258	; 0xfffffefe
 124:	01020030 	tsteq	r2, r0, lsr r0
 128:	5f304465 	svcpl	0x00304465
 12c:	02006968 	andeq	r6, r0, #104, 18	; 0x1a0000
 130:	31446601 	cmpcc	r4, r1, lsl #12
 134:	67010200 	strvs	r0, [r1, -r0, lsl #4]
 138:	685f3144 	ldmdavs	pc, {r2, r6, r8, ip, sp}^	; <UNPREDICTABLE>
 13c:	01020069 	tsteq	r2, r9, rrx
 140:	00324468 	eorseq	r4, r2, r8, ror #8
 144:	44690102 	strbtmi	r0, [r9], #-258	; 0xfffffefe
 148:	69685f32 	stmdbvs	r8!, {r1, r4, r5, r8, r9, sl, fp, ip, lr}^
 14c:	6a010200 	bvs	40954 <__TI_DW.debug_info.$base_types.4b0d1e45517085cb8ecdf519739bebb4+0x402da>
 150:	02003344 	andeq	r3, r0, #68, 6	; 0x10000001
 154:	33446b01 	movtcc	r6, #19201	; 0x4b01
 158:	0069685f 	rsbeq	r6, r9, pc, asr r8
 15c:	446c0102 	strbtmi	r0, [ip], #-258	; 0xfffffefe
 160:	01020034 	tsteq	r2, r4, lsr r0
 164:	5f34446d 	svcpl	0x0034446d
 168:	02006968 	andeq	r6, r0, #104, 18	; 0x1a0000
 16c:	35446e01 	strbcc	r6, [r4, #-3585]	; 0xfffff1ff
 170:	6f010200 	svcvs	0x00010200
 174:	685f3544 	ldmdavs	pc, {r2, r6, r8, sl, ip, sp}^	; <UNPREDICTABLE>
 178:	02020069 	andeq	r0, r2, #105	; 0x69
 17c:	36442090 			; <UNDEFINED> instruction: 0x36442090
 180:	90020200 	andls	r0, r2, r0, lsl #4
 184:	5f364421 	svcpl	0x00364421
 188:	02006968 	andeq	r6, r0, #104, 18	; 0x1a0000
 18c:	44229002 	strtmi	r9, [r2], #-2
 190:	02020037 	andeq	r0, r2, #55	; 0x37
 194:	37442390 			; <UNDEFINED> instruction: 0x37442390
 198:	0069685f 	rsbeq	r6, r9, pc, asr r8
 19c:	24900202 	ldrcs	r0, [r0], #514	; 0x202
 1a0:	02003844 	andeq	r3, r0, #68, 16	; 0x440000
 1a4:	44259002 	strtmi	r9, [r5], #-2
 1a8:	69685f38 	stmdbvs	r8!, {r3, r4, r5, r8, r9, sl, fp, ip, lr}^
 1ac:	90020200 	andls	r0, r2, r0, lsl #4
 1b0:	00394426 	eorseq	r4, r9, r6, lsr #8
 1b4:	27900202 	ldrcs	r0, [r0, r2, lsl #4]
 1b8:	685f3944 	ldmdavs	pc, {r2, r6, r8, fp, ip, sp}^	; <UNPREDICTABLE>
 1bc:	02020069 	andeq	r0, r2, #105	; 0x69
 1c0:	31442890 			; <UNDEFINED> instruction: 0x31442890
 1c4:	02020030 	andeq	r0, r2, #48	; 0x30
 1c8:	31442990 			; <UNDEFINED> instruction: 0x31442990
 1cc:	69685f30 	stmdbvs	r8!, {r4, r5, r8, r9, sl, fp, ip, lr}^
 1d0:	90020200 	andls	r0, r2, r0, lsl #4
 1d4:	3131442a 	teqcc	r1, sl, lsr #8
 1d8:	90020200 	andls	r0, r2, r0, lsl #4
 1dc:	3131442b 	teqcc	r1, fp, lsr #8
 1e0:	0069685f 	rsbeq	r6, r9, pc, asr r8
 1e4:	2c900202 	lfmcs	f0, 4, [r0], {2}
 1e8:	00323144 	eorseq	r3, r2, r4, asr #2
 1ec:	2d900202 	lfmcs	f0, 4, [r0, #8]
 1f0:	5f323144 	svcpl	0x00323144
 1f4:	02006968 	andeq	r6, r0, #104, 18	; 0x1a0000
 1f8:	442e9002 	strtmi	r9, [lr], #-2
 1fc:	02003331 	andeq	r3, r0, #-1006632960	; 0xc4000000
 200:	442f9002 	strtmi	r9, [pc], #-2	; 208 <vector_table+0x208>
 204:	685f3331 	ldmdavs	pc, {r0, r4, r5, r8, r9, ip, sp}^	; <UNPREDICTABLE>
 208:	02020069 	andeq	r0, r2, #105	; 0x69
 20c:	31443090 	swpbcc	r3, r0, [r4]
 210:	02020034 	andeq	r0, r2, #52	; 0x34
 214:	31443190 			; <UNDEFINED> instruction: 0x31443190
 218:	69685f34 	stmdbvs	r8!, {r2, r4, r5, r8, r9, sl, fp, ip, lr}^
 21c:	90020200 	andls	r0, r2, r0, lsl #4
 220:	35314432 	ldrcc	r4, [r1, #-1074]!	; 0xfffffbce
 224:	90020200 	andls	r0, r2, r0, lsl #4
 228:	35314433 	ldrcc	r4, [r1, #-1075]!	; 0xfffffbcd
 22c:	0069685f 	rsbeq	r6, r9, pc, asr r8
 230:	34900202 	ldrcc	r0, [r0], #514	; 0x202
 234:	00363144 	eorseq	r3, r6, r4, asr #2
 238:	35900202 	ldrcc	r0, [r0, #514]	; 0x202
 23c:	5f363144 	svcpl	0x00363144
 240:	02006968 	andeq	r6, r0, #104, 18	; 0x1a0000
 244:	44369002 	ldrtmi	r9, [r6], #-2
 248:	02003731 	andeq	r3, r0, #12845056	; 0xc40000
 24c:	44379002 	ldrtmi	r9, [r7], #-2
 250:	685f3731 	ldmdavs	pc, {r0, r4, r5, r8, r9, sl, ip, sp}^	; <UNPREDICTABLE>
 254:	02020069 	andeq	r0, r2, #105	; 0x69
 258:	31443890 			; <UNDEFINED> instruction: 0x31443890
 25c:	02020038 	andeq	r0, r2, #56	; 0x38
 260:	31443990 			; <UNDEFINED> instruction: 0x31443990
 264:	69685f38 	stmdbvs	r8!, {r3, r4, r5, r8, r9, sl, fp, ip, lr}^
 268:	90020200 	andls	r0, r2, r0, lsl #4
 26c:	3931443a 	ldmdbcc	r1!, {r1, r3, r4, r5, sl, lr}
 270:	90020200 	andls	r0, r2, r0, lsl #4
 274:	3931443b 	ldmdbcc	r1!, {r0, r1, r3, r4, r5, sl, lr}
 278:	0069685f 	rsbeq	r6, r9, pc, asr r8
 27c:	3c900202 	lfmcc	f0, 4, [r0], {2}
 280:	00303244 	eorseq	r3, r0, r4, asr #4
 284:	3d900202 	lfmcc	f0, 4, [r0, #8]
 288:	5f303244 	svcpl	0x00303244
 28c:	02006968 	andeq	r6, r0, #104, 18	; 0x1a0000
 290:	443e9002 	ldrtmi	r9, [lr], #-2
 294:	02003132 	andeq	r3, r0, #-2147483636	; 0x8000000c
 298:	443f9002 	ldrtmi	r9, [pc], #-2	; 2a0 <vector_table+0x2a0>
 29c:	685f3132 	ldmdavs	pc, {r1, r4, r5, r8, ip, sp}^	; <UNPREDICTABLE>
 2a0:	02020069 	andeq	r0, r2, #105	; 0x69
 2a4:	32444090 	subcc	r4, r4, #144	; 0x90
 2a8:	02020032 	andeq	r0, r2, #50	; 0x32
 2ac:	32444190 	subcc	r4, r4, #144, 2	; 0x24
 2b0:	69685f32 	stmdbvs	r8!, {r1, r4, r5, r8, r9, sl, fp, ip, lr}^
 2b4:	90020200 	andls	r0, r2, r0, lsl #4
 2b8:	33324442 	teqcc	r2, #1107296256	; 0x42000000
 2bc:	90020200 	andls	r0, r2, r0, lsl #4
 2c0:	33324443 	teqcc	r2, #1124073472	; 0x43000000
 2c4:	0069685f 	rsbeq	r6, r9, pc, asr r8
 2c8:	44900202 	ldrmi	r0, [r0], #514	; 0x202
 2cc:	00343244 	eorseq	r3, r4, r4, asr #4
 2d0:	45900202 	ldrmi	r0, [r0, #514]	; 0x202
 2d4:	5f343244 	svcpl	0x00343244
 2d8:	02006968 	andeq	r6, r0, #104, 18	; 0x1a0000
 2dc:	44469002 	strbmi	r9, [r6], #-2
 2e0:	02003532 	andeq	r3, r0, #209715200	; 0xc800000
 2e4:	44479002 	strbmi	r9, [r7], #-2
 2e8:	685f3532 	ldmdavs	pc, {r1, r4, r5, r8, sl, ip, sp}^	; <UNPREDICTABLE>
 2ec:	02020069 	andeq	r0, r2, #105	; 0x69
 2f0:	32444890 	subcc	r4, r4, #144, 16	; 0x900000
 2f4:	02020036 	andeq	r0, r2, #54	; 0x36
 2f8:	32444990 	subcc	r4, r4, #144, 18	; 0x240000
 2fc:	69685f36 	stmdbvs	r8!, {r1, r2, r4, r5, r8, r9, sl, fp, ip, lr}^
 300:	90020200 	andls	r0, r2, r0, lsl #4
 304:	3732444a 	ldrcc	r4, [r2, -sl, asr #8]!
 308:	90020200 	andls	r0, r2, r0, lsl #4
 30c:	3732444b 	ldrcc	r4, [r2, -fp, asr #8]!
 310:	0069685f 	rsbeq	r6, r9, pc, asr r8
 314:	4c900202 	lfmmi	f0, 4, [r0], {2}
 318:	00383244 	eorseq	r3, r8, r4, asr #4
 31c:	4d900202 	lfmmi	f0, 4, [r0, #8]
 320:	5f383244 	svcpl	0x00383244
 324:	02006968 	andeq	r6, r0, #104, 18	; 0x1a0000
 328:	444e9002 	strbmi	r9, [lr], #-2
 32c:	02003932 	andeq	r3, r0, #819200	; 0xc8000
 330:	444f9002 	strbmi	r9, [pc], #-2	; 338 <vector_table+0x338>
 334:	685f3932 	ldmdavs	pc, {r1, r4, r5, r8, fp, ip, sp}^	; <UNPREDICTABLE>
 338:	02020069 	andeq	r0, r2, #105	; 0x69
 33c:	33445090 	movtcc	r5, #16528	; 0x4090
 340:	02020030 	andeq	r0, r2, #48	; 0x30
 344:	33445190 	movtcc	r5, #16784	; 0x4190
 348:	69685f30 	stmdbvs	r8!, {r4, r5, r8, r9, sl, fp, ip, lr}^
 34c:	90020200 	andls	r0, r2, r0, lsl #4
 350:	31334452 	teqcc	r3, r2, asr r4
 354:	90020200 	andls	r0, r2, r0, lsl #4
 358:	31334453 	teqcc	r3, r3, asr r4
 35c:	0069685f 	rsbeq	r6, r9, pc, asr r8
 360:	54900202 	ldrpl	r0, [r0], #514	; 0x202
 364:	5f454943 	svcpl	0x00454943
 368:	41544552 	cmpmi	r4, r2, asr r5
 36c:	00fe0000 	rscseq	r0, lr, r0
 370:	00020000 	andeq	r0, r2, r0
 374:	0000001e 	andeq	r0, r0, lr, lsl r0
 378:	5c2e0204 	sfmpl	f0, 4, [lr], #-16
 37c:	7262696c 	rsbvc	r6, r2, #108, 18	; 0x1b0000
 380:	2e797261 	cdpcs	2, 7, cr7, cr9, cr1, {3}
 384:	001d0063 	andseq	r0, sp, r3, rrx
 388:	00900000 	addseq	r0, r0, r0
 38c:	00949400 	addseq	r9, r4, r0, lsl #8
 390:	46029400 	strmi	r9, [r2], -r0, lsl #8
 394:	69535c3a 	ldmdbvs	r3, {r1, r3, r4, r5, sl, fp, ip, lr}^
 398:	61727571 	cmnvs	r2, r1, ror r5
 39c:	7169735c 	cmnvc	r9, ip, asr r3
 3a0:	5c617275 	sfmpl	f7, 2, [r1], #-468	; 0xfffffe2c
 3a4:	75716973 	ldrbvc	r6, [r1, #-2419]!	; 0xfffff68d
 3a8:	6c5c6172 	ldfvse	f6, [ip], {114}	; 0x72
 3ac:	61726269 	cmnvs	r2, r9, ror #4
 3b0:	625f7972 	subsvs	r7, pc, #1867776	; 0x1c8000
 3b4:	646c6975 	strbtvs	r6, [ip], #-2421	; 0xfffff68b
 3b8:	3339345f 	teqcc	r9, #1593835520	; 0x5f000000
 3bc:	62696c5c 	rsbvs	r6, r9, #92, 24	; 0x5c00
 3c0:	534d5400 	movtpl	r5, #54272	; 0xd400
 3c4:	20303734 	eorscs	r3, r0, r4, lsr r7
 3c8:	2b432f43 	blcs	10cc0dc <__TI_DW.debug_info.$base_types.4b0d1e45517085cb8ecdf519739bebb4+0x10cba62>
 3cc:	6f43202b 	svcvs	0x0043202b
 3d0:	65676564 	strbvs	r6, [r7, #-1380]!	; 0xfffffa9c
 3d4:	4350206e 	cmpmi	r0, #110	; 0x6e
 3d8:	2e347620 	cfmsuba32cs	mvax1, mvax7, mvfx4, mvfx0
 3dc:	20332e39 	eorscs	r2, r3, r9, lsr lr
 3e0:	79706f43 	ldmdbvc	r0!, {r0, r1, r6, r8, r9, sl, fp, sp, lr}^
 3e4:	68676972 	stmdavs	r7!, {r1, r4, r5, r6, r8, fp, sp, lr}^
 3e8:	63282074 	teqvs	r8, #116	; 0x74
 3ec:	39312029 	ldmdbcc	r1!, {r0, r3, r5, sp}
 3f0:	322d3639 	eorcc	r3, sp, #59768832	; 0x3900000
 3f4:	20323130 	eorscs	r3, r2, r0, lsr r1
 3f8:	61786554 	cmnvs	r8, r4, asr r5
 3fc:	6e492073 	mcrvs	0, 2, r2, cr9, cr3, {3}
 400:	75727473 	ldrbvc	r7, [r2, #-1139]!	; 0xfffffb8d
 404:	746e656d 	strbtvc	r6, [lr], #-1389	; 0xfffffa93
 408:	6e492073 	mcrvs	0, 2, r2, cr9, cr3, {3}
 40c:	70726f63 	rsbsvc	r6, r2, r3, ror #30
 410:	7461726f 	strbtvc	r7, [r1], #-623	; 0xfffffd91
 414:	01006465 	tsteq	r0, r5, ror #8
 418:	62757303 	rsbsvs	r7, r5, #201326592	; 0xc000000
 41c:	00009000 	andeq	r9, r0, r0
 420:	00009494 	muleq	r0, r4, r4
 424:	06010594 			; <UNDEFINED> instruction: 0x06010594
 428:	007d0201 	rsbseq	r0, sp, r1, lsl #4
 42c:	000006be 			; <UNDEFINED> instruction: 0x000006be
 430:	00627573 	rsbeq	r7, r2, r3, ror r5
 434:	696c5c2e 	stmdbvs	ip!, {r1, r2, r3, r5, sl, fp, ip, lr}^
 438:	72617262 	rsbvc	r7, r1, #536870918	; 0x20000006
 43c:	00632e79 	rsbeq	r2, r3, r9, ror lr
 440:	5c2e0506 	cfstr32pl	mvfx0, [lr], #-24	; 0xffffffe8
 444:	7262696c 	rsbvc	r6, r2, #108, 18	; 0x1b0000
 448:	2e797261 	cdpcs	2, 7, cr7, cr9, cr1, {3}
 44c:	01090063 	tsteq	r9, r3, rrx
 450:	01010001 	tsteq	r1, r1
 454:	be006150 	fltltsm	f0, r6
 458:	61000006 	tstvs	r0, r6
 45c:	51010100 	mrspl	r0, (UNDEF: 17)
 460:	06be0062 	ldrteq	r0, [lr], r2, rrx
 464:	00620000 	rsbeq	r0, r2, r0
 468:	00009204 	andeq	r9, r0, r4, lsl #4
 46c:	00000194 	muleq	r0, r4, r1
 470:	000000fe 	strdeq	r0, [r0], -lr
 474:	00810002 	addeq	r0, r1, r2
 478:	02040000 	andeq	r0, r4, #0
 47c:	696c5c2e 	stmdbvs	ip!, {r1, r2, r3, r5, sl, fp, ip, lr}^
 480:	72617262 	rsbvc	r7, r1, #536870918	; 0x20000006
 484:	00632e79 	rsbeq	r2, r3, r9, ror lr
 488:	00000057 	andeq	r0, r0, r7, asr r0
 48c:	94000094 	strls	r0, [r0], #-148	; 0xffffff6c
 490:	94000098 	strls	r0, [r0], #-152	; 0xffffff68
 494:	5c3a4602 	ldcpl	6, cr4, [sl], #-8
 498:	75716953 	ldrbvc	r6, [r1, #-2387]!	; 0xfffff6ad
 49c:	735c6172 	cmpvc	ip, #-2147483620	; 0x8000001c
 4a0:	72757169 	rsbsvc	r7, r5, #1073741850	; 0x4000001a
 4a4:	69735c61 	ldmdbvs	r3!, {r0, r5, r6, sl, fp, ip, lr}^
 4a8:	61727571 	cmnvs	r2, r1, ror r5
 4ac:	62696c5c 	rsbvs	r6, r9, #92, 24	; 0x5c00
 4b0:	79726172 	ldmdbvc	r2!, {r1, r4, r5, r6, r8, sp, lr}^
 4b4:	6975625f 	ldmdbvs	r5!, {r0, r1, r2, r3, r4, r6, r9, sp, lr}^
 4b8:	345f646c 	ldrbcc	r6, [pc], #-1132	; 4c0 <vector_table+0x4c0>
 4bc:	6c5c3339 	mrrcvs	3, 3, r3, ip, cr9
 4c0:	54006269 	strpl	r6, [r0], #-617	; 0xfffffd97
 4c4:	3734534d 	ldrcc	r5, [r4, -sp, asr #6]!
 4c8:	2f432030 	svccs	0x00432030
 4cc:	202b2b43 	eorcs	r2, fp, r3, asr #22
 4d0:	65646f43 	strbvs	r6, [r4, #-3907]!	; 0xfffff0bd
 4d4:	206e6567 	rsbcs	r6, lr, r7, ror #10
 4d8:	76204350 			; <UNDEFINED> instruction: 0x76204350
 4dc:	2e392e34 	mrccs	14, 1, r2, cr9, cr4, {1}
 4e0:	6f432033 	svcvs	0x00432033
 4e4:	69727970 	ldmdbvs	r2!, {r4, r5, r6, r8, fp, ip, sp, lr}^
 4e8:	20746867 	rsbscs	r6, r4, r7, ror #16
 4ec:	20296328 	eorcs	r6, r9, r8, lsr #6
 4f0:	36393931 			; <UNDEFINED> instruction: 0x36393931
 4f4:	3130322d 	teqcc	r0, sp, lsr #4
 4f8:	65542032 	ldrbvs	r2, [r4, #-50]	; 0xffffffce
 4fc:	20736178 	rsbscs	r6, r3, r8, ror r1
 500:	74736e49 	ldrbtvc	r6, [r3], #-3657	; 0xfffff1b7
 504:	656d7572 	strbvs	r7, [sp, #-1394]!	; 0xfffffa8e
 508:	2073746e 	rsbscs	r7, r3, lr, ror #8
 50c:	6f636e49 	svcvs	0x00636e49
 510:	726f7072 	rsbvc	r7, pc, #114	; 0x72
 514:	64657461 	strbtvs	r7, [r5], #-1121	; 0xfffffb9f
 518:	61030100 	mrsvs	r0, (UNDEF: 19)
 51c:	94006464 	strls	r6, [r0], #-1124	; 0xfffffb9c
 520:	98940000 	ldmls	r4, {}	; <UNPREDICTABLE>
 524:	05940000 	ldreq	r0, [r4]
 528:	02010101 	andeq	r0, r1, #1073741824	; 0x40000000
 52c:	06be007d 	sxtaheq	r0, lr, sp
 530:	64610000 	strbtvs	r0, [r1], #-0
 534:	5c2e0064 	stcpl	0, cr0, [lr], #-400	; 0xfffffe70
 538:	7262696c 	rsbvc	r6, r2, #108, 18	; 0x1b0000
 53c:	2e797261 	cdpcs	2, 7, cr7, cr9, cr1, {3}
 540:	05010063 	streq	r0, [r1, #-99]	; 0xffffff9d
 544:	696c5c2e 	stmdbvs	ip!, {r1, r2, r3, r5, sl, fp, ip, lr}^
 548:	72617262 	rsbvc	r7, r1, #536870918	; 0x20000006
 54c:	00632e79 	rsbeq	r2, r3, r9, ror lr
 550:	00010104 	andeq	r0, r1, r4, lsl #2
 554:	61500101 	cmpvs	r0, r1, lsl #2
 558:	0006be00 	andeq	fp, r6, r0, lsl #28
 55c:	01006100 	mrseq	r6, (UNDEF: 16)
 560:	00625101 	rsbeq	r5, r2, r1, lsl #2
 564:	000006be 			; <UNDEFINED> instruction: 0x000006be
 568:	96040062 	strls	r0, [r4], -r2, rrx
 56c:	01940000 	orrseq	r0, r4, r0
 570:	01040000 	mrseq	r0, (UNDEF: 4)
 574:	00020000 	andeq	r0, r2, r0
 578:	000000e4 	andeq	r0, r0, r4, ror #1
 57c:	5c2e0204 	sfmpl	f0, 4, [lr], #-16
 580:	7262696c 	rsbvc	r6, r2, #108, 18	; 0x1b0000
 584:	2e797261 	cdpcs	2, 7, cr7, cr9, cr1, {3}
 588:	00910063 	addseq	r0, r1, r3, rrx
 58c:	00980000 	addseq	r0, r8, r0
 590:	009c9400 	addseq	r9, ip, r0, lsl #8
 594:	46029400 	strmi	r9, [r2], -r0, lsl #8
 598:	69535c3a 	ldmdbvs	r3, {r1, r3, r4, r5, sl, fp, ip, lr}^
 59c:	61727571 	cmnvs	r2, r1, ror r5
 5a0:	7169735c 	cmnvc	r9, ip, asr r3
 5a4:	5c617275 	sfmpl	f7, 2, [r1], #-468	; 0xfffffe2c
 5a8:	75716973 	ldrbvc	r6, [r1, #-2419]!	; 0xfffff68d
 5ac:	6c5c6172 	ldfvse	f6, [ip], {114}	; 0x72
 5b0:	61726269 	cmnvs	r2, r9, ror #4
 5b4:	625f7972 	subsvs	r7, pc, #1867776	; 0x1c8000
 5b8:	646c6975 	strbtvs	r6, [ip], #-2421	; 0xfffff68b
 5bc:	3339345f 	teqcc	r9, #1593835520	; 0x5f000000
 5c0:	62696c5c 	rsbvs	r6, r9, #92, 24	; 0x5c00
 5c4:	534d5400 	movtpl	r5, #54272	; 0xd400
 5c8:	20303734 	eorscs	r3, r0, r4, lsr r7
 5cc:	2b432f43 	blcs	10cc2e0 <__TI_DW.debug_info.$base_types.4b0d1e45517085cb8ecdf519739bebb4+0x10cbc66>
 5d0:	6f43202b 	svcvs	0x0043202b
 5d4:	65676564 	strbvs	r6, [r7, #-1380]!	; 0xfffffa9c
 5d8:	4350206e 	cmpmi	r0, #110	; 0x6e
 5dc:	2e347620 	cfmsuba32cs	mvax1, mvax7, mvfx4, mvfx0
 5e0:	20332e39 	eorscs	r2, r3, r9, lsr lr
 5e4:	79706f43 	ldmdbvc	r0!, {r0, r1, r6, r8, r9, sl, fp, sp, lr}^
 5e8:	68676972 	stmdavs	r7!, {r1, r4, r5, r6, r8, fp, sp, lr}^
 5ec:	63282074 	teqvs	r8, #116	; 0x74
 5f0:	39312029 	ldmdbcc	r1!, {r0, r3, r5, sp}
 5f4:	322d3639 	eorcc	r3, sp, #59768832	; 0x3900000
 5f8:	20323130 	eorscs	r3, r2, r0, lsr r1
 5fc:	61786554 	cmnvs	r8, r4, asr r5
 600:	6e492073 	mcrvs	0, 2, r2, cr9, cr3, {3}
 604:	75727473 	ldrbvc	r7, [r2, #-1139]!	; 0xfffffb8d
 608:	746e656d 	strbtvc	r6, [lr], #-1389	; 0xfffffa93
 60c:	6e492073 	mcrvs	0, 2, r2, cr9, cr3, {3}
 610:	70726f63 	rsbsvc	r6, r2, r3, ror #30
 614:	7461726f 	strbtvc	r7, [r1], #-623	; 0xfffffd91
 618:	01006465 	tsteq	r0, r5, ror #8
 61c:	4d6f6403 	cfstrdmi	mvd6, [pc, #-12]!	; 618 <vector_table+0x618>
 620:	00687461 	rsbeq	r7, r8, r1, ror #8
 624:	94000098 	strls	r0, [r0], #-152	; 0xffffff68
 628:	9400009c 	strls	r0, [r0], #-156	; 0xffffff64
 62c:	010b0105 	tsteq	fp, r5, lsl #2
 630:	be007d02 	cdplt	13, 0, cr7, cr0, cr2, {0}
 634:	64000006 	strvs	r0, [r0], #-6
 638:	74614d6f 	strbtvc	r4, [r1], #-3439	; 0xfffff291
 63c:	5c2e0068 	stcpl	0, cr0, [lr], #-416	; 0xfffffe60
 640:	7262696c 	rsbvc	r6, r2, #108, 18	; 0x1b0000
 644:	2e797261 	cdpcs	2, 7, cr7, cr9, cr1, {3}
 648:	050b0063 	streq	r0, [fp, #-99]	; 0xffffff9d
 64c:	696c5c2e 	stmdbvs	ip!, {r1, r2, r3, r5, sl, fp, ip, lr}^
 650:	72617262 	rsbvc	r7, r1, #536870918	; 0x20000006
 654:	00632e79 	rsbeq	r2, r3, r9, ror lr
 658:	00010111 	andeq	r0, r1, r1, lsl r1
 65c:	61500101 	cmpvs	r0, r1, lsl #2
 660:	0006be00 	andeq	fp, r6, r0, lsl #28
 664:	01006100 	mrseq	r6, (UNDEF: 16)
 668:	00625101 	rsbeq	r5, r2, r1, lsl #2
 66c:	000006be 			; <UNDEFINED> instruction: 0x000006be
 670:	9a040062 	bls	100800 <__TI_DW.debug_info.$base_types.4b0d1e45517085cb8ecdf519739bebb4+0x100186>
 674:	01940000 	orrseq	r0, r4, r0
0000067a <__TI_DW.debug_info.$base_types.4b0d1e45517085cb8ecdf519739bebb4>:
 67a:	00000080 	andeq	r0, r0, r0, lsl #1
 67e:	01470002 	cmpeq	r7, r2
 682:	01040000 	mrseq	r0, (UNDEF: 4)
 686:	000000cb 	andeq	r0, r0, fp, asr #1
 68a:	00000102 	andeq	r0, r0, r2, lsl #2
 68e:	00002f00 	andeq	r2, r0, r0, lsl #30
 692:	85020100 	strhi	r0, [r2, #-256]	; 0xffffff00
 696:	01000000 	mrseq	r0, (UNDEF: 0)
 69a:	008a0202 	addeq	r0, sl, r2, lsl #4
 69e:	06010000 	streq	r0, [r1], -r0
 6a2:	00009602 	andeq	r9, r0, r2, lsl #12
 6a6:	02080100 	andeq	r0, r8, #0, 2
 6aa:	000000a4 	andeq	r0, r0, r4, lsr #1
 6ae:	ac020602 	stcge	6, cr0, [r2], {2}
 6b2:	02000000 	andeq	r0, r0, #0
 6b6:	00b20205 	adcseq	r0, r2, r5, lsl #4
 6ba:	07020000 	streq	r0, [r2, -r0]
 6be:	0000c102 	andeq	ip, r0, r2, lsl #2
 6c2:	02050400 	andeq	r0, r5, #0, 8
 6c6:	000000c5 	andeq	r0, r0, r5, asr #1
 6ca:	d2020704 	andle	r0, r2, #4, 14	; 0x100000
 6ce:	04000000 	streq	r0, [r0], #-0
 6d2:	00d70205 	sbcseq	r0, r7, r5, lsl #4
 6d6:	07040000 	streq	r0, [r4, -r0]
 6da:	0000e502 	andeq	lr, r0, r2, lsl #10
 6de:	02050800 	andeq	r0, r5, #0, 16
 6e2:	000000ef 	andeq	r0, r0, pc, ror #1
 6e6:	02020708 	andeq	r0, r2, #8, 14	; 0x200000
 6ea:	04000001 	streq	r0, [r0], #-1
 6ee:	01080204 	tsteq	r8, r4, lsl #4
 6f2:	04080000 	streq	r0, [r8], #-0
 6f6:	00010f02 	andeq	r0, r1, r2, lsl #30
 6fa:	00040800 	andeq	r0, r4, r0, lsl #16
Disassembly of section .debug_abbrev:
00000000 <.debug_abbrev>:
   0:	03011101 	movweq	r1, #4353	; 0x1101
   4:	13061008 	movwne	r1, #24584	; 0x6008
   8:	25081b0b 	strcs	r1, [r8, #-2827]	; 0xfffff4f5
   c:	0b408b08 	bleq	1022c34 <__TI_DW.debug_info.$base_types.4b0d1e45517085cb8ecdf519739bebb4+0x10225ba>
  10:	82020000 	andhi	r0, r2, #0
  14:	02000181 	andeq	r0, r0, #1073741856	; 0x40000020
  18:	0008030a 	andeq	r0, r8, sl, lsl #6
  1c:	05010000 	streq	r0, [r1, #-0]
  20:	030a0200 	movweq	r0, #41472	; 0xa200
  24:	81104908 	tsthi	r0, r8, lsl #18
  28:	00000840 	andeq	r0, r0, r0, asr #16
  2c:	03011102 	movweq	r1, #4354	; 0x1102
  30:	11061008 	tstne	r6, r8
  34:	13011201 	movwne	r1, #4609	; 0x1201
  38:	25081b0b 	strcs	r1, [r8, #-2827]	; 0xfffff4f5
  3c:	0b408b08 	bleq	1022c64 <__TI_DW.debug_info.$base_types.4b0d1e45517085cb8ecdf519739bebb4+0x10225ea>
  40:	2e030000 	cdpcs	0, 0, cr0, cr3, cr0, {0}
  44:	11080301 	tstne	r8, r1, lsl #6
  48:	39011201 	stmdbcc	r1, {r0, r9, ip}
  4c:	3b0b3a0b 	blcc	2ce880 <__TI_DW.debug_info.$base_types.4b0d1e45517085cb8ecdf519739bebb4+0x2ce206>
  50:	400c3f0b 	andmi	r3, ip, fp, lsl #30
  54:	8110490a 	tsthi	r0, sl, lsl #18
  58:	40830840 	addmi	r0, r3, r0, asr #16
  5c:	0b408408 	bleq	1021084 <__TI_DW.debug_info.$base_types.4b0d1e45517085cb8ecdf519739bebb4+0x1020a0a>
  60:	860b4085 	strhi	r4, [fp], -r5, lsl #1
  64:	40870840 	addmi	r0, r7, r0, asr #16
  68:	0b40880b 	bleq	102209c <__TI_DW.debug_info.$base_types.4b0d1e45517085cb8ecdf519739bebb4+0x1021a22>
  6c:	940c408e 	strls	r4, [ip], #-142	; 0xffffff72
  70:	00000b40 	andeq	r0, r0, r0, asr #22
  74:	01818804 	orreq	r8, r1, r4, lsl #16
  78:	89011100 	stmdbhi	r1, {r8, ip}
  7c:	00000c40 	andeq	r0, r0, r0, asr #24
  80:	00050100 	andeq	r0, r5, r0, lsl #2
  84:	08030a02 	stmdaeq	r3, {r1, r9, fp}
  88:	40811049 	addmi	r1, r1, r9, asr #32
  8c:	02000008 	andeq	r0, r0, #8
  90:	08030111 	stmdaeq	r3, {r0, r4, r8}
  94:	01110610 	tsteq	r1, r0, lsl r6
  98:	0b130112 	bleq	4c04e8 <__TI_DW.debug_info.$base_types.4b0d1e45517085cb8ecdf519739bebb4+0x4bfe6e>
  9c:	0825081b 	stmdaeq	r5!, {r0, r1, r3, r4, fp}
  a0:	000b408b 	andeq	r4, fp, fp, lsl #1
  a4:	012e0300 	teqeq	lr, r0, lsl #6
  a8:	01110803 	tsteq	r1, r3, lsl #16
  ac:	0b390112 	bleq	e404fc <__TI_DW.debug_info.$base_types.4b0d1e45517085cb8ecdf519739bebb4+0xe3fe82>
  b0:	0b3b0b3a 	bleq	ec2da0 <__TI_DW.debug_info.$base_types.4b0d1e45517085cb8ecdf519739bebb4+0xec2726>
  b4:	0a400c3f 	beq	10031b8 <__TI_DW.debug_info.$base_types.4b0d1e45517085cb8ecdf519739bebb4+0x1002b3e>
  b8:	40811049 	addmi	r1, r1, r9, asr #32
  bc:	08408308 	stmdaeq	r0, {r3, r8, r9, pc}^
  c0:	850b4084 	strhi	r4, [fp, #-132]	; 0xffffff7c
  c4:	40860b40 	addmi	r0, r6, r0, asr #22
  c8:	0b408708 	bleq	1021cf0 <__TI_DW.debug_info.$base_types.4b0d1e45517085cb8ecdf519739bebb4+0x1021676>
  cc:	8e0b4088 	cdphi	0, 0, cr4, cr11, cr8, {4}
  d0:	40940c40 	addsmi	r0, r4, r0, asr #24
  d4:	0400000b 	streq	r0, [r0], #-11
  d8:	00018188 	andeq	r8, r1, r8, lsl #3
  dc:	40890111 	addmi	r0, r9, r1, lsl r1
  e0:	0000000c 	andeq	r0, r0, ip
  e4:	02000501 	andeq	r0, r0, #4194304	; 0x400000
  e8:	4908030a 	stmdbmi	r8, {r1, r3, r8, r9}
  ec:	08408110 	stmdaeq	r0, {r4, r8, pc}^
  f0:	11020000 	mrsne	r0, (UNDEF: 2)
  f4:	10080301 	andne	r0, r8, r1, lsl #6
  f8:	12011106 	andne	r1, r1, #-2147483647	; 0x80000001
  fc:	1b0b1301 	blne	2c4d08 <__TI_DW.debug_info.$base_types.4b0d1e45517085cb8ecdf519739bebb4+0x2c468e>
 100:	8b082508 	blhi	209528 <__TI_DW.debug_info.$base_types.4b0d1e45517085cb8ecdf519739bebb4+0x208eae>
 104:	00000b40 	andeq	r0, r0, r0, asr #22
 108:	03012e03 	movweq	r2, #7683	; 0x1e03
 10c:	12011108 	andne	r1, r1, #8, 2
 110:	3a0b3901 	bcc	2ce51c <__TI_DW.debug_info.$base_types.4b0d1e45517085cb8ecdf519739bebb4+0x2cdea2>
 114:	3f0b3b0b 	svccc	0x000b3b0b
 118:	490a400c 	stmdbmi	sl, {r2, r3, lr}
 11c:	08408110 	stmdaeq	r0, {r4, r8, pc}^
 120:	84084083 	strhi	r4, [r8], #-131	; 0xffffff7d
 124:	40850b40 	addmi	r0, r5, r0, asr #22
 128:	0840860b 	stmdaeq	r0, {r0, r1, r3, r9, sl, pc}^
 12c:	880b4087 	stmdahi	fp, {r0, r1, r2, r7, lr}
 130:	408e0b40 	addmi	r0, lr, r0, asr #22
 134:	0b40940c 	bleq	102516c <__TI_DW.debug_info.$base_types.4b0d1e45517085cb8ecdf519739bebb4+0x1024af2>
 138:	88040000 	stmdahi	r4, {}	; <UNPREDICTABLE>
 13c:	11000181 	smlabbne	r0, r1, r1, r0
 140:	0c408901 	mcrreq	9, 0, r8, r0, cr1
 144:	01000000 	mrseq	r0, (UNDEF: 0)
 148:	06100111 			; <UNDEFINED> instruction: 0x06100111
 14c:	0e1b0b13 	vmoveq.32	r0, d11[0]
 150:	408b0e25 	addmi	r0, fp, r5, lsr #28
 154:	0200000b 	andeq	r0, r0, #11
 158:	0e030024 	cdpeq	0, 0, cr0, cr3, cr4, {1}
 15c:	0b3e0b0b 	bleq	f82d90 <__TI_DW.debug_info.$base_types.4b0d1e45517085cb8ecdf519739bebb4+0xf82716>
 160:	Address 0x00000160 is out of bounds.
Disassembly of section .debug_line:
00000000 <.debug_line>:
   0:	00000019 	andeq	r0, r0, r9, lsl r0
   4:	00100002 	andseq	r0, r0, r2
   8:	01010000 	mrseq	r0, (UNDEF: 1)
   c:	000aff00 	andeq	pc, sl, r0, lsl #30
  10:	01010101 	tsteq	r1, r1, lsl #2
  14:	00000000 	andeq	r0, r0, r0
  18:	01000000 	mrseq	r0, (UNDEF: 0)
  1c:	00003601 	andeq	r3, r0, r1, lsl #12
  20:	1f000200 	svcne	0x00000200
  24:	02000000 	andeq	r0, r0, #0
  28:	0a7b0001 	beq	1ec0034 <__TI_DW.debug_info.$base_types.4b0d1e45517085cb8ecdf519739bebb4+0x1ebf9ba>
  2c:	01010100 	mrseq	r0, (UNDEF: 17)
  30:	00000001 	andeq	r0, r0, r1
  34:	5c2e0000 	stcpl	0, cr0, [lr], #-0
  40:	00000063 	andeq	r0, r0, r3, rrx
  44:	05000000 	streq	r0, [r0, #-0]
  48:	00009002 	andeq	r9, r0, r2
  4c:	10010594 	mulne	r1, r4, r5
  50:	01020687 	smlabbeq	r2, r7, r6, r0
  54:	36010100 	strcc	r0, [r1], -r0, lsl #2
  58:	02000000 	andeq	r0, r0, #0
  5c:	00001f00 	andeq	r1, r0, r0, lsl #30
  60:	00010200 	andeq	r0, r1, r0, lsl #4
  64:	01000a7b 	tsteq	r0, fp, ror sl
  68:	00010101 	andeq	r0, r1, r1, lsl #2
  6c:	00000000 	andeq	r0, r0, r0
  70:	696c5c2e 	stmdbvs	ip!, {r1, r2, r3, r5, sl, fp, ip, lr}^
  74:	72617262 	rsbvc	r7, r1, #536870918	; 0x20000006
  78:	00632e79 	rsbeq	r2, r3, r9, ror lr
  7c:	00000000 	andeq	r0, r0, r0
  80:	94020500 	strls	r0, [r2], #-1280	; 0xfffffb00
  84:	05940000 	ldreq	r0, [r4]
  88:	06870b01 	streq	r0, [r7], r1, lsl #22
  8c:	01000102 	tsteq	r0, r2, lsl #2
  90:	00003601 	andeq	r3, r0, r1, lsl #12
  94:	1f000200 	svcne	0x00000200
  98:	02000000 	andeq	r0, r0, #0
  9c:	0a7b0001 	beq	1ec00a8 <__TI_DW.debug_info.$base_types.4b0d1e45517085cb8ecdf519739bebb4+0x1ebfa2e>
  a0:	01010100 	mrseq	r0, (UNDEF: 17)
  a4:	00000001 	andeq	r0, r0, r1
  a8:	5c2e0000 	stcpl	0, cr0, [lr], #-0
  ac:	7262696c 	rsbvc	r6, r2, #108, 18	; 0x1b0000
  b0:	2e797261 	cdpcs	2, 7, cr7, cr9, cr1, {3}
  b4:	00000063 	andeq	r0, r0, r3, rrx
  b8:	05000000 	streq	r0, [r0, #-0]
  bc:	00009802 	andeq	r9, r0, r2, lsl #16
  c0:	15010594 	strne	r0, [r1, #-1428]	; 0xfffffa6c
  c4:	0102068a 	smlabbeq	r2, sl, r6, r0
  c8:	19010100 	stmdbne	r1, {r8}
  cc:	02000000 	andeq	r0, r0, #0
  d0:	00001000 	andeq	r1, r0, r0
  d4:	00010100 	andeq	r0, r1, r0, lsl #2
  d8:	01000aff 	strdeq	r0, [r0, -pc]
  dc:	00010101 	andeq	r0, r1, r1, lsl #2
  e0:	00000000 	andeq	r0, r0, r0
  e4:	01010000 	mrseq	r0, (UNDEF: 1)
Disassembly of section .debug_str:
00000000 <.debug_str>:
   0:	5c3a4600 	ldcpl	6, cr4, [sl], #-0
   4:	75716953 	ldrbvc	r6, [r1, #-2387]!	; 0xfffff6ad
   8:	735c6172 	cmpvc	ip, #-2147483620	; 0x8000001c
   c:	72757169 	rsbsvc	r7, r5, #1073741850	; 0x4000001a
  10:	69735c61 	ldmdbvs	r3!, {r0, r5, r6, sl, fp, ip, lr}^
  14:	61727571 	cmnvs	r2, r1, ror r5
  18:	62696c5c 	rsbvs	r6, r9, #92, 24	; 0x5c00
  1c:	79726172 	ldmdbvc	r2!, {r1, r4, r5, r6, r8, sp, lr}^
  20:	6975625f 	ldmdbvs	r5!, {r0, r1, r2, r3, r4, r6, r9, sp, lr}^
  24:	345f646c 	ldrbcc	r6, [pc], #-1132	; 2c <vector_table+0x2c>
  28:	6c5c3339 	mrrcvs	3, 3, r3, ip, cr9
  2c:	54006269 	strpl	r6, [r0], #-617	; 0xfffffd97
  30:	3734534d 	ldrcc	r5, [r4, -sp, asr #6]!
  34:	2f432030 	svccs	0x00432030
  38:	202b2b43 	eorcs	r2, fp, r3, asr #22
  3c:	65646f43 	strbvs	r6, [r4, #-3907]!	; 0xfffff0bd
  40:	206e6567 	rsbcs	r6, lr, r7, ror #10
  44:	76204350 			; <UNDEFINED> instruction: 0x76204350
  48:	2e392e34 	mrccs	14, 1, r2, cr9, cr4, {1}
  4c:	6f432033 	svcvs	0x00432033
  50:	69727970 	ldmdbvs	r2!, {r4, r5, r6, r8, fp, ip, sp, lr}^
  54:	20746867 	rsbscs	r6, r4, r7, ror #16
  58:	20296328 	eorcs	r6, r9, r8, lsr #6
  5c:	36393931 			; <UNDEFINED> instruction: 0x36393931
  60:	3130322d 	teqcc	r0, sp, lsr #4
  64:	65542032 	ldrbvs	r2, [r4, #-50]	; 0xffffffce
  68:	20736178 	rsbscs	r6, r3, r8, ror r1
  6c:	74736e49 	ldrbtvc	r6, [r3], #-3657	; 0xfffff1b7
  70:	656d7572 	strbvs	r7, [sp, #-1394]!	; 0xfffffa8e
  74:	2073746e 	rsbscs	r7, r3, lr, ror #8
  78:	6f636e49 	svcvs	0x00636e49
  7c:	726f7072 	rsbvc	r7, pc, #114	; 0x72
  80:	64657461 	strbtvs	r7, [r5], #-1121	; 0xfffffb9f
  84:	6f6f6200 	svcvs	0x006f6200
  88:	6973006c 	ldmdbvs	r3!, {r2, r3, r5, r6}^
  8c:	64656e67 	strbtvs	r6, [r5], #-3687	; 0xfffff199
  90:	61686320 	cmnvs	r8, r0, lsr #6
  94:	6e750072 	mrcvs	0, 3, r0, cr5, cr2, {3}
  98:	6e676973 	mcrvs	9, 3, r6, cr7, cr3, {3}
  9c:	63206465 	teqvs	r0, #1694498816	; 0x65000000
  a0:	00726168 	rsbseq	r6, r2, r8, ror #2
  a4:	61686377 	smcvs	34359	; 0x8637
  a8:	00745f72 	rsbseq	r5, r4, r2, ror pc
  ac:	726f6873 	rsbvc	r6, pc, #7536640	; 0x730000
  b0:	6e750074 	mrcvs	0, 3, r0, cr5, cr4, {3}
  b4:	6e676973 	mcrvs	9, 3, r6, cr7, cr3, {3}
  b8:	73206465 	teqvc	r0, #1694498816	; 0x65000000
  bc:	74726f68 	ldrbtvc	r6, [r2], #-3944	; 0xfffff098
  c0:	746e6900 	strbtvc	r6, [lr], #-2304	; 0xfffff700
  c4:	736e7500 	cmnvc	lr, #0, 10
  c8:	656e6769 	strbvs	r6, [lr, #-1897]!	; 0xfffff897
  cc:	6e692064 	cdpvs	0, 6, cr2, cr9, cr4, {3}
  d0:	6f6c0074 	svcvs	0x006c0074
  d4:	7500676e 	strvc	r6, [r0, #-1902]	; 0xfffff892
  d8:	6769736e 	strbvs	r7, [r9, -lr, ror #6]!
  dc:	2064656e 	rsbcs	r6, r4, lr, ror #10
  e0:	676e6f6c 	strbvs	r6, [lr, -ip, ror #30]!
  e4:	6e6f6c00 	cdpvs	12, 6, cr6, cr15, cr0, {0}
  e8:	6f6c2067 	svcvs	0x006c2067
  ec:	7500676e 	strvc	r6, [r0, #-1902]	; 0xfffff892
  f0:	6769736e 	strbvs	r7, [r9, -lr, ror #6]!
  f4:	2064656e 	rsbcs	r6, r4, lr, ror #10
  f8:	676e6f6c 	strbvs	r6, [lr, -ip, ror #30]!
  fc:	6e6f6c20 	cdpvs	12, 6, cr6, cr15, cr0, {1}
 100:	6c660067 	stclvs	0, cr0, [r6], #-412	; 0xfffffe64
 104:	0074616f 	rsbseq	r6, r4, pc, ror #2
 108:	62756f64 	rsbsvs	r6, r5, #100, 30	; 0x190
 10c:	6c00656c 	cfstr32vs	mvfx6, [r0], {108}	; 0x6c
 110:	20676e6f 	rsbcs	r6, r7, pc, ror #28
 114:	62756f64 	rsbsvs	r6, r5, #100, 30	; 0x190
 118:	Address 0x00000118 is out of bounds.
Disassembly of section .ARM.attributes:
00000000 <.ARM.attributes>:
   0:	00003041 	andeq	r3, r0, r1, asr #32
   4:	61656100 	cmnvs	r5, r0, lsl #2
   8:	01006962 	tsteq	r0, r2, ror #18
   c:	00000026 	andeq	r0, r0, r6, lsr #32
  10:	726f4305 	rsbvc	r4, pc, #335544320	; 0x14000000
  14:	2d786574 	cfldr64cs	mvdx6, [r8, #-464]!	; 0xfffffe30
  18:	0600334d 	streq	r3, [r0], -sp, asr #6
  1c:	094d070a 	stmdbeq	sp, {r1, r3, r8, r9, sl}^
  20:	14041202 	strne	r1, [r4], #-514	; 0xfffffdfe
  24:	17011501 	strne	r1, [r1, -r1, lsl #10]
  28:	19011803 	stmdbne	r1, {r0, r1, fp, ip}
  2c:	1e011a01 	vmlane.f32	s2, s2, s2
  30:	Address 0x00000030 is out of bounds.
4237.tiDisassembly.txt
OBJECT FILE:  F:\Siqura\siqura\siqura\library_build_493\app\a.out
 Section Information
    <0> "(no name)"
       Load Address:        0x00000000  Run Address:        0x00000000
       Size:                0x0         Alignment:          0
       Loaded Onto Device:  No          Address Unit Size:  8 bits
       File Offset:         0x00000000  # Relocs:           0
       Section Type:        SHT_NULL    ELF sh_flags:       0x00000000
       TI ext_flags:        0x0
    <1> "vector_table"
       Size:                0xb8          Alignment:          4
       Loaded Onto Device:  Yes           Address Unit Size:  8 bits
       File Offset:         0x00008000    # Relocs:           0
       Section Type:        SHT_PROGBITS  ELF sh_flags:       0x00000002
       ELF sh_flag:         SHF_ALLOC     TI ext_flags:       0x0
    <2> ".text"
       Load Address:        0x94000000    Run Address:        0x94000000
       Size:                0x9c          Alignment:          4
       File Offset:         0x00010000    # Relocs:           0
       Section Type:        SHT_PROGBITS  ELF sh_flags:       0x00000006
       ELF sh_flag:         SHF_ALLOC     ELF sh_flag:        SHF_EXECINSTR
       TI ext_flags:        0x0
    <3> ".bss"
       Load Address:        0x9400009c  Run Address:        0x9400009c
       Size:                0xd400      Alignment:          4
       File Offset:         0x0001009c  # Relocs:           0
       Section Type:        SHT_NOBITS  ELF sh_flags:       0x00000003
       ELF sh_flag:         SHF_WRITE   ELF sh_flag:        SHF_ALLOC
       TI ext_flags:        0x0
    <4> ".TI.symbol.alias"
       Size:                0x9           Alignment:          1
       Section Type:        SHT_PROGBITS  ELF sh_flags:       0x00000000
       TI ext_flags:        0x0
    <5> ".TI.section.flags"
       Size:                0x1a          Alignment:          1
       File Offset:         0x000100a5    # Relocs:           0
       TI ext_flags:        0x0
    <6> ".comment"
       Size:                0x2a          Alignment:          1
       File Offset:         0x000100bf    # Relocs:           0
       Section Type:        SHT_PROGBITS  ELF sh_flags:       0x00000030
       ELF sh_flag:         SHF_MERGE     ELF sh_flag:        SHF_STRINGS
       TI ext_flags:        0x0
    <7> ".debug_info"
       Size:                0x6fe         Alignment:          1
       File Offset:         0x000100e9    # Relocs:           0
       TI ext_flags:        0x0
    <8> ".debug_abbrev"
       Size:                0x163         Alignment:          1
       File Offset:         0x000107e7    # Relocs:           0
       TI ext_flags:        0x0
    <9> ".debug_line"
       Size:                0xe8          Alignment:          1
       File Offset:         0x0001094a    # Relocs:           0
       TI ext_flags:        0x0
    <10> ".debug_str"
       Size:                0x11b         Alignment:          1
       File Offset:         0x00010a32    # Relocs:           0
       TI ext_flags:        0x0
    <11> ".ARM.attributes"
       Size:                0x31                Alignment:          1
       File Offset:         0x00010b4d          # Relocs:           0
       Section Type:        SHT_ARM_ATTRIBUTES  ELF sh_flags:       0x00000000
       TI ext_flags:        0x0
    <12> ".shstrtab"
       Size:                0xa0        Alignment:          1
       File Offset:         0x00010b7e  # Relocs:           0
       Section Type:        SHT_STRTAB  ELF sh_flags:       0x00000000
       TI ext_flags:        0x0
    <13> ".symtab"
       Size:                0x2e0       Alignment:          4
       File Offset:         0x00010e78  # Relocs:           0
       Section Type:        SHT_SYMTAB  String Table:       .strtab
       # Symbols:           46          # Local Symbols:    21
       Symbol Size:         16 bytes    ELF sh_flags:       0x00000000
       TI ext_flags:        0x0
    <14> ".strtab"
       Size:                0x172       Alignment:          1
       File Offset:         0x00011158  # Relocs:           0
       TI ext_flags:        0x0
 Raw Data for Section "vector_table"
00000000:  9c 00 00 94 31 00 00 94 41 00 00 94 4d 00 00 94 ....1...A...M...
00000010:  79 00 00 94 0a 00 00 00 00 00 00 00 00 00 00 00 y...............
00000020:  00 00 00 00 00 00 00 00 00 00 00 00 59 00 00 94 ............Y...
00000030:  00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................
00000040:  00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................
00000050:  00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................
00000060:  00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................
00000070:  00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................
00000080:  00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................
00000090:  00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................
000000a0:  00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................
000000b0:  00 00 00 00 00 00 00 00                         ........
 Raw Data for Section ".text"
00000000:  80 b5 84 b0 00 af 4f f0 0a 03 fb 60 4f f0 14 03 ......O....`O...
00000010:  bb 60 f8 68 b9 68 00 f0 3f f8 78 60 7a 68 bb 68 .`.h.h..?.x`zh.h
00000020:  9a 42 00 d0 fe e7 18 46 07 f1 10 07 bd 46 80 bd .B.....F.....F..
00000030:  80 b4 00 af ff f7 e4 bf bd 46 80 bc 70 47 00 bf .........F..pG..
00000040:  80 b4 00 af bd 46 80 bc 70 47 00 bf 80 b4 00 af .....F..pG......
00000050:  bd 46 80 bc 70 47 00 bf 80 b4 83 b0 00 af 4f f0 .F..pG........O.
00000060:  00 03 7b 60 7b 68 03 f1 01 03 7b 60 07 f1 0c 07 ..{`{h....{`....
00000070:  bd 46 80 bc 70 47 00 bf 80 b4 00 af bd 46 80 bc .F..pG.......F..
00000080:  70 47 00 bf 80 b4 00 af bd 46 80 bc 70 47 00 bf pG.......F..pG..
00000090:  40 1a 70 47 08 18 70 47 08 46 70 47             @.pG..pG.FpG
 Raw Data for Section ".TI.symbol.alias"
00000000:  01 00 00 00 00 00 54 49 00                      ......TI.
 Raw Data for Section ".TI.section.flags"
00000000:  01 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................
00000010:  00 00 00 00 00 00 00 00 00 00                   ..........
 Raw Data for Section ".comment"
00000000:  47 43 43 3a 20 28 53 6f 75 72 63 65 72 79 20 47 GCC: (Sourcery G
00000010:  2b 2b 20 4c 69 74 65 20 32 30 31 31 2e 30 33 2d ++ Lite 2011.03-
00000020:  34 32 29 20 34 2e 35 2e 32 00                   42) 4.5.2.
 Raw Data for Section ".debug_info"
00000000:  6a 03 00 00 02 00 00 00 00 00 04 01 2e 5c 6c 69 j............\li
00000010:  62 72 61 72 79 2e 63 00 00 00 00 00 02 46 3a 5c brary.c......F:\
00000020:  53 69 71 75 72 61 5c 73 69 71 75 72 61 5c 73 69 Siqura\siqura\si
00000030:  71 75 72 61 5c 6c 69 62 72 61 72 79 5f 62 75 69 qura\library_bui
00000040:  6c 64 5f 34 39 33 5c 6c 69 62 00 54 4d 53 34 37 ld_493\lib.TMS47
00000050:  30 20 43 2f 43 2b 2b 20 43 6f 64 65 67 65 6e 20 0 C/C++ Codegen
00000060:  50 43 20 76 34 2e 39 2e 33 20 43 6f 70 79 72 69 PC v4.9.3 Copyri
00000070:  67 68 74 20 28 63 29 20 31 39 39 36 2d 32 30 31 ght (c) 1996-201
00000080:  32 20 54 65 78 61 73 20 49 6e 73 74 72 75 6d 65 2 Texas Instrume
00000090:  6e 74 73 20 49 6e 63 6f 72 70 6f 72 61 74 65 64 nts Incorporated
000000a0:  00 01 02 01 50 41 31 00 02 01 51 41 32 00 02 01 ....PA1...QA2...
000000b0:  52 41 33 00 02 01 53 41 34 00 02 01 54 56 31 00 RA3...SA4...TV1.
000000c0:  02 01 55 56 32 00 02 01 56 56 33 00 02 01 57 56 ..UV2...VV3...WV
000000d0:  34 00 02 01 58 56 35 00 02 01 59 56 36 00 02 01 4...XV5...YV6...
000000e0:  5a 56 37 00 02 01 5b 56 38 00 02 01 5c 56 39 00 ZV7...[V8...\V9.
000000f0:  02 01 5d 53 50 00 02 01 5e 4c 52 00 02 01 5f 50 ..]SP...^LR..._P
00000100:  43 00 02 01 60 41 50 00 02 01 61 53 52 00 02 01 C...`AP...aSR...
00000110:  62 46 50 53 43 52 00 02 01 63 46 50 45 58 43 00 bFPSCR...cFPEXC.
00000120:  02 01 64 44 30 00 02 01 65 44 30 5f 68 69 00 02 ..dD0...eD0_hi..
00000130:  01 66 44 31 00 02 01 67 44 31 5f 68 69 00 02 01 .fD1...gD1_hi...
00000140:  68 44 32 00 02 01 69 44 32 5f 68 69 00 02 01 6a hD2...iD2_hi...j
00000150:  44 33 00 02 01 6b 44 33 5f 68 69 00 02 01 6c 44 D3...kD3_hi...lD
00000160:  34 00 02 01 6d 44 34 5f 68 69 00 02 01 6e 44 35 4...mD4_hi...nD5
00000170:  00 02 01 6f 44 35 5f 68 69 00 02 02 90 20 44 36 ...oD5_hi.... D6
00000180:  00 02 02 90 21 44 36 5f 68 69 00 02 02 90 22 44 ....!D6_hi...."D
00000190:  37 00 02 02 90 23 44 37 5f 68 69 00 02 02 90 24 7....#D7_hi....$
000001a0:  44 38 00 02 02 90 25 44 38 5f 68 69 00 02 02 90 D8....%D8_hi....
000001b0:  26 44 39 00 02 02 90 27 44 39 5f 68 69 00 02 02 &D9....'D9_hi...
000001c0:  90 28 44 31 30 00 02 02 90 29 44 31 30 5f 68 69 .(D10....)D10_hi
000001d0:  00 02 02 90 2a 44 31 31 00 02 02 90 2b 44 31 31 ....*D11....+D11
000001e0:  5f 68 69 00 02 02 90 2c 44 31 32 00 02 02 90 2d _hi....,D12....-
000001f0:  44 31 32 5f 68 69 00 02 02 90 2e 44 31 33 00 02 D12_hi.....D13..
00000200:  02 90 2f 44 31 33 5f 68 69 00 02 02 90 30 44 31 ../D13_hi....0D1
00000210:  34 00 02 02 90 31 44 31 34 5f 68 69 00 02 02 90 4....1D14_hi....
00000220:  32 44 31 35 00 02 02 90 33 44 31 35 5f 68 69 00 2D15....3D15_hi.
00000230:  02 02 90 34 44 31 36 00 02 02 90 35 44 31 36 5f ...4D16....5D16_
00000240:  68 69 00 02 02 90 36 44 31 37 00 02 02 90 37 44 hi....6D17....7D
00000250:  31 37 5f 68 69 00 02 02 90 38 44 31 38 00 02 02 17_hi....8D18...
00000260:  90 39 44 31 38 5f 68 69 00 02 02 90 3a 44 31 39 .9D18_hi....:D19
00000270:  00 02 02 90 3b 44 31 39 5f 68 69 00 02 02 90 3c ....;D19_hi....<
00000280:  44 32 30 00 02 02 90 3d 44 32 30 5f 68 69 00 02 D20....=D20_hi..
00000290:  02 90 3e 44 32 31 00 02 02 90 3f 44 32 31 5f 68 ..>D21....?D21_h
000002a0:  69 00 02 02 90 40 44 32 32 00 02 02 90 41 44 32 i....@D22....AD2
000002b0:  32 5f 68 69 00 02 02 90 42 44 32 33 00 02 02 90 2_hi....BD23....
000002c0:  43 44 32 33 5f 68 69 00 02 02 90 44 44 32 34 00 CD23_hi....DD24.
000002d0:  02 02 90 45 44 32 34 5f 68 69 00 02 02 90 46 44 ...ED24_hi....FD
000002e0:  32 35 00 02 02 90 47 44 32 35 5f 68 69 00 02 02 25....GD25_hi...
000002f0:  90 48 44 32 36 00 02 02 90 49 44 32 36 5f 68 69 .HD26....ID26_hi
00000300:  00 02 02 90 4a 44 32 37 00 02 02 90 4b 44 32 37 ....JD27....KD27
00000310:  5f 68 69 00 02 02 90 4c 44 32 38 00 02 02 90 4d _hi....LD28....M
00000320:  44 32 38 5f 68 69 00 02 02 90 4e 44 32 39 00 02 D28_hi....ND29..
00000330:  02 90 4f 44 32 39 5f 68 69 00 02 02 90 50 44 33 ..OD29_hi....PD3
00000340:  30 00 02 02 90 51 44 33 30 5f 68 69 00 02 02 90 0....QD30_hi....
00000350:  52 44 33 31 00 02 02 90 53 44 33 31 5f 68 69 00 RD31....SD31_hi.
00000360:  02 02 90 54 43 49 45 5f 52 45 54 41 00 00 fe 00 ...TCIE_RETA....
00000370:  00 00 02 00 1e 00 00 00 04 02 2e 5c 6c 69 62 72 ...........\libr
00000380:  61 72 79 2e 63 00 1d 00 00 00 90 00 00 94 94 00 ary.c...........
00000390:  00 94 02 46 3a 5c 53 69 71 75 72 61 5c 73 69 71 ...F:\Siqura\siq
000003a0:  75 72 61 5c 73 69 71 75 72 61 5c 6c 69 62 72 61 ura\siqura\libra
000003b0:  72 79 5f 62 75 69 6c 64 5f 34 39 33 5c 6c 69 62 ry_build_493\lib
000003c0:  00 54 4d 53 34 37 30 20 43 2f 43 2b 2b 20 43 6f .TMS470 C/C++ Co
000003d0:  64 65 67 65 6e 20 50 43 20 76 34 2e 39 2e 33 20 degen PC v4.9.3
000003e0:  43 6f 70 79 72 69 67 68 74 20 28 63 29 20 31 39 Copyright (c) 19
000003f0:  39 36 2d 32 30 31 32 20 54 65 78 61 73 20 49 6e 96-2012 Texas In
00000400:  73 74 72 75 6d 65 6e 74 73 20 49 6e 63 6f 72 70 struments Incorp
00000410:  6f 72 61 74 65 64 00 01 03 73 75 62 00 90 00 00 orated...sub....
00000420:  94 94 00 00 94 05 01 06 01 02 7d 00 be 06 00 00 ..........}.....
00000430:  73 75 62 00 2e 5c 6c 69 62 72 61 72 79 2e 63 00 sub..\library.c.
00000440:  06 05 2e 5c 6c 69 62 72 61 72 79 2e 63 00 09 01 ...\library.c...
00000450:  01 00 01 01 50 61 00 be 06 00 00 61 00 01 01 51 ....Pa.....a...Q
00000460:  62 00 be 06 00 00 62 00 04 92 00 00 94 01 00 00 b.....b.........
00000470:  fe 00 00 00 02 00 81 00 00 00 04 02 2e 5c 6c 69 .............\li
00000480:  62 72 61 72 79 2e 63 00 57 00 00 00 94 00 00 94 brary.c.W.......
00000490:  98 00 00 94 02 46 3a 5c 53 69 71 75 72 61 5c 73 .....F:\Siqura\s
000004a0:  69 71 75 72 61 5c 73 69 71 75 72 61 5c 6c 69 62 iqura\siqura\lib
000004b0:  72 61 72 79 5f 62 75 69 6c 64 5f 34 39 33 5c 6c rary_build_493\l
000004c0:  69 62 00 54 4d 53 34 37 30 20 43 2f 43 2b 2b 20 ib.TMS470 C/C++
000004d0:  43 6f 64 65 67 65 6e 20 50 43 20 76 34 2e 39 2e Codegen PC v4.9.
000004e0:  33 20 43 6f 70 79 72 69 67 68 74 20 28 63 29 20 3 Copyright (c)
000004f0:  31 39 39 36 2d 32 30 31 32 20 54 65 78 61 73 20 1996-2012 Texas
00000500:  49 6e 73 74 72 75 6d 65 6e 74 73 20 49 6e 63 6f Instruments Inco
00000510:  72 70 6f 72 61 74 65 64 00 01 03 61 64 64 00 94 rporated...add..
00000520:  00 00 94 98 00 00 94 05 01 01 01 02 7d 00 be 06 ............}...
00000530:  00 00 61 64 64 00 2e 5c 6c 69 62 72 61 72 79 2e ..add..\library.
00000540:  63 00 01 05 2e 5c 6c 69 62 72 61 72 79 2e 63 00 c....\library.c.
00000550:  04 01 01 00 01 01 50 61 00 be 06 00 00 61 00 01 ......Pa.....a..
00000560:  01 51 62 00 be 06 00 00 62 00 04 96 00 00 94 01 .Qb.....b.......
00000570:  00 00 04 01 00 00 02 00 e4 00 00 00 04 02 2e 5c ...............\
00000580:  6c 69 62 72 61 72 79 2e 63 00 91 00 00 00 98 00 library.c.......
00000590:  00 94 9c 00 00 94 02 46 3a 5c 53 69 71 75 72 61 .......F:\Siqura
000005a0:  5c 73 69 71 75 72 61 5c 73 69 71 75 72 61 5c 6c \siqura\siqura\l
000005b0:  69 62 72 61 72 79 5f 62 75 69 6c 64 5f 34 39 33 ibrary_build_493
000005c0:  5c 6c 69 62 00 54 4d 53 34 37 30 20 43 2f 43 2b \lib.TMS470 C/C+
000005d0:  2b 20 43 6f 64 65 67 65 6e 20 50 43 20 76 34 2e + Codegen PC v4.
000005e0:  39 2e 33 20 43 6f 70 79 72 69 67 68 74 20 28 63 9.3 Copyright (c
000005f0:  29 20 31 39 39 36 2d 32 30 31 32 20 54 65 78 61 ) 1996-2012 Texa
00000600:  73 20 49 6e 73 74 72 75 6d 65 6e 74 73 20 49 6e s Instruments In
00000610:  63 6f 72 70 6f 72 61 74 65 64 00 01 03 64 6f 4d corporated...doM
00000620:  61 74 68 00 98 00 00 94 9c 00 00 94 05 01 0b 01 ath.............
00000630:  02 7d 00 be 06 00 00 64 6f 4d 61 74 68 00 2e 5c .}.....doMath..\
00000640:  6c 69 62 72 61 72 79 2e 63 00 0b 05 2e 5c 6c 69 library.c....\li
00000650:  62 72 61 72 79 2e 63 00 11 01 01 00 01 01 50 61 brary.c.......Pa
00000660:  00 be 06 00 00 61 00 01 01 51 62 00 be 06 00 00 .....a...Qb.....
00000670:  62 00 04 9a 00 00 94 01 00 00 80 00 00 00 02 00 b...............
00000680:  47 01 00 00 04 01 cb 00 00 00 02 01 00 00 00 2f G............../
00000690:  00 00 00 01 02 85 00 00 00 01 02 02 8a 00 00 00 ................
000006a0:  01 06 02 96 00 00 00 01 08 02 a4 00 00 00 02 06 ................
000006b0:  02 ac 00 00 00 02 05 02 b2 00 00 00 02 07 02 c1 ................
000006c0:  00 00 00 04 05 02 c5 00 00 00 04 07 02 d2 00 00 ................
000006d0:  00 04 05 02 d7 00 00 00 04 07 02 e5 00 00 00 08 ................
000006e0:  05 02 ef 00 00 00 08 07 02 02 01 00 00 04 04 02 ................
000006f0:  08 01 00 00 08 04 02 0f 01 00 00 08 04 00       ..............
 Raw Data for Section ".debug_abbrev"
00000000:  01 11 01 03 08 10 06 13 0b 1b 08 25 08 8b 40 0b ...........%..@.
00000010:  00 00 02 82 81 01 00 02 0a 03 08 00 00 00 01 05 ................
00000020:  00 02 0a 03 08 49 10 81 40 08 00 00 02 11 01 03 .....I..@.......
00000030:  08 10 06 11 01 12 01 13 0b 1b 08 25 08 8b 40 0b ...........%..@.
00000040:  00 00 03 2e 01 03 08 11 01 12 01 39 0b 3a 0b 3b ...........9.:.;
00000050:  0b 3f 0c 40 0a 49 10 81 40 08 83 40 08 84 40 0b .?.@.I..@..@..@.
00000060:  85 40 0b 86 40 08 87 40 0b 88 40 0b 8e 40 0c 94 .@..@..@..@..@..
00000070:  40 0b 00 00 04 88 81 01 00 11 01 89 40 0c 00 00 @...........@...
00000080:  00 01 05 00 02 0a 03 08 49 10 81 40 08 00 00 02 ........I..@....
00000090:  11 01 03 08 10 06 11 01 12 01 13 0b 1b 08 25 08 ..............%.
000000a0:  8b 40 0b 00 00 03 2e 01 03 08 11 01 12 01 39 0b .@............9.
000000b0:  3a 0b 3b 0b 3f 0c 40 0a 49 10 81 40 08 83 40 08 :.;.?.@.I..@..@.
000000c0:  84 40 0b 85 40 0b 86 40 08 87 40 0b 88 40 0b 8e .@..@..@..@..@..
000000d0:  40 0c 94 40 0b 00 00 04 88 81 01 00 11 01 89 40 @..@...........@
000000e0:  0c 00 00 00 01 05 00 02 0a 03 08 49 10 81 40 08 ...........I..@.
000000f0:  00 00 02 11 01 03 08 10 06 11 01 12 01 13 0b 1b ................
00000100:  08 25 08 8b 40 0b 00 00 03 2e 01 03 08 11 01 12 .%..@...........
00000110:  01 39 0b 3a 0b 3b 0b 3f 0c 40 0a 49 10 81 40 08 .9.:.;.?.@.I..@.
00000120:  83 40 08 84 40 0b 85 40 0b 86 40 08 87 40 0b 88 .@..@..@..@..@..
00000130:  40 0b 8e 40 0c 94 40 0b 00 00 04 88 81 01 00 11 @..@..@.........
00000140:  01 89 40 0c 00 00 00 01 11 01 10 06 13 0b 1b 0e ..@.............
00000150:  25 0e 8b 40 0b 00 00 02 24 00 03 0e 0b 0b 3e 0b %..@....$.....>.
00000160:  00 00 00                                        ...
 Raw Data for Section ".debug_line"
00000000:  19 00 00 00 02 00 10 00 00 00 01 01 00 ff 0a 00 ................
00000010:  01 01 01 01 00 00 00 00 00 00 00 01 01 36 00 00 .............6..
00000020:  00 02 00 1f 00 00 00 02 01 00 7b 0a 00 01 01 01 ..........{.....
00000030:  01 00 00 00 00 00 2e 5c 6c 69 62 72 61 72 79 2e .......\library.
00000040:  63 00 00 00 00 00 00 05 02 90 00 00 94 05 01 10 c...............
00000050:  87 06 02 01 00 01 01 36 00 00 00 02 00 1f 00 00 .......6........
00000060:  00 02 01 00 7b 0a 00 01 01 01 01 00 00 00 00 00 ....{...........
00000070:  2e 5c 6c 69 62 72 61 72 79 2e 63 00 00 00 00 00 .\library.c.....
00000080:  00 05 02 94 00 00 94 05 01 0b 87 06 02 01 00 01 ................
00000090:  01 36 00 00 00 02 00 1f 00 00 00 02 01 00 7b 0a .6............{.
000000a0:  00 01 01 01 01 00 00 00 00 00 2e 5c 6c 69 62 72 ...........\libr
000000b0:  61 72 79 2e 63 00 00 00 00 00 00 05 02 98 00 00 ary.c...........
000000c0:  94 05 01 15 8a 06 02 01 00 01 01 19 00 00 00 02 ................
000000d0:  00 10 00 00 00 01 01 00 ff 0a 00 01 01 01 01 00 ................
000000e0:  00 00 00 00 00 00 01 01                         ........
 Raw Data for Section ".debug_str"
00000000:  00 46 3a 5c 53 69 71 75 72 61 5c 73 69 71 75 72 .F:\Siqura\siqur
00000010:  61 5c 73 69 71 75 72 61 5c 6c 69 62 72 61 72 79 a\siqura\library
00000020:  5f 62 75 69 6c 64 5f 34 39 33 5c 6c 69 62 00 54 _build_493\lib.T
00000030:  4d 53 34 37 30 20 43 2f 43 2b 2b 20 43 6f 64 65 MS470 C/C++ Code
00000040:  67 65 6e 20 50 43 20 76 34 2e 39 2e 33 20 43 6f gen PC v4.9.3 Co
00000050:  70 79 72 69 67 68 74 20 28 63 29 20 31 39 39 36 pyright (c) 1996
00000060:  2d 32 30 31 32 20 54 65 78 61 73 20 49 6e 73 74 -2012 Texas Inst
00000070:  72 75 6d 65 6e 74 73 20 49 6e 63 6f 72 70 6f 72 ruments Incorpor
00000080:  61 74 65 64 00 62 6f 6f 6c 00 73 69 67 6e 65 64 ated.bool.signed
00000090:  20 63 68 61 72 00 75 6e 73 69 67 6e 65 64 20 63  char.unsigned c
000000a0:  68 61 72 00 77 63 68 61 72 5f 74 00 73 68 6f 72 har.wchar_t.shor
000000b0:  74 00 75 6e 73 69 67 6e 65 64 20 73 68 6f 72 74 t.unsigned short
000000c0:  00 69 6e 74 00 75 6e 73 69 67 6e 65 64 20 69 6e .int.unsigned in
000000d0:  74 00 6c 6f 6e 67 00 75 6e 73 69 67 6e 65 64 20 t.long.unsigned
000000e0:  6c 6f 6e 67 00 6c 6f 6e 67 20 6c 6f 6e 67 00 75 long.long long.u
000000f0:  6e 73 69 67 6e 65 64 20 6c 6f 6e 67 20 6c 6f 6e nsigned long lon
00000100:  67 00 66 6c 6f 61 74 00 64 6f 75 62 6c 65 00 6c g.float.double.l
00000110:  6f 6e 67 20 64 6f 75 62 6c 65 00                ong double.
 Raw Data for Section ".ARM.attributes"
00000000:  41 30 00 00 00 61 65 61 62 69 00 01 26 00 00 00 A0...aeabi..&...
00000010:  05 43 6f 72 74 65 78 2d 4d 33 00 06 0a 07 4d 09 .Cortex-M3....M.
00000020:  02 12 04 14 01 15 01 17 03 18 01 19 01 1a 01 1e ................
00000030:  06                                              .
 Raw Data for Section ".shstrtab"
00000000:  00 2e 73 79 6d 74 61 62 00 2e 73 74 72 74 61 62 ..symtab..strtab
00000010:  00 2e 73 68 73 74 72 74 61 62 00 76 65 63 74 6f ..shstrtab.vecto
00000020:  72 5f 74 61 62 6c 65 00 2e 74 65 78 74 00 2e 62 r_table..text..b
00000030:  73 73 00 2e 54 49 2e 73 79 6d 62 6f 6c 2e 61 6c ss..TI.symbol.al
00000040:  69 61 73 00 2e 54 49 2e 73 65 63 74 69 6f 6e 2e ias..TI.section.
00000050:  66 6c 61 67 73 00 2e 63 6f 6d 6d 65 6e 74 00 2e flags..comment..
00000060:  64 65 62 75 67 5f 69 6e 66 6f 00 2e 64 65 62 75 debug_info..debu
00000070:  67 5f 61 62 62 72 65 76 00 2e 64 65 62 75 67 5f g_abbrev..debug_
00000080:  6c 69 6e 65 00 2e 64 65 62 75 67 5f 73 74 72 00 line..debug_str.
00000090:  2e 41 52 4d 2e 61 74 74 72 69 62 75 74 65 73 00 .ARM.attributes.
 Raw Data for Section ".symtab"
00000000:  00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................
00000010:  00 00 00 00 00 00 00 00 00 00 00 00 03 00 01 00 ................
00000020:  00 00 00 00 00 00 00 94 00 00 00 00 03 00 02 00 ................
00000030:  00 00 00 00 9c 00 00 94 00 00 00 00 03 00 03 00 ................
00000040:  00 00 00 00 00 00 00 00 00 00 00 00 03 00 04 00 ................
00000050:  00 00 00 00 00 00 00 00 00 00 00 00 03 00 05 00 ................
00000060:  00 00 00 00 00 00 00 00 00 00 00 00 03 00 06 00 ................
00000070:  00 00 00 00 00 00 00 00 00 00 00 00 03 00 07 00 ................
00000080:  00 00 00 00 00 00 00 00 00 00 00 00 03 00 08 00 ................
00000090:  00 00 00 00 00 00 00 00 00 00 00 00 03 00 09 00 ................
000000a0:  00 00 00 00 00 00 00 00 00 00 00 00 03 00 0a 00 ................
000000b0:  00 00 00 00 00 00 00 00 00 00 00 00 03 00 0b 00 ................
000000c0:  01 00 00 00 00 00 00 00 00 00 00 00 04 00 f1 ff ................
000000d0:  15 00 00 00 00 00 00 00 00 00 00 00 00 00 01 00 ................
000000e0:  18 00 00 00 30 00 00 94 00 00 00 00 00 00 02 00 ....0...........
000000f0:  1b 00 00 00 00 00 00 00 00 00 00 00 04 00 f1 ff ................
00000100:  18 00 00 00 00 00 00 94 00 00 00 00 00 00 02 00 ................
00000110:  22 00 00 00 00 00 00 00 00 00 00 00 04 02 f1 ff "...............
00000120:  18 00 00 00 90 00 00 94 00 00 00 00 00 02 02 00 ................
00000130:  18 00 00 00 94 00 00 94 00 00 00 00 00 02 02 00 ................
00000140:  18 00 00 00 98 00 00 94 00 00 00 00 00 02 02 00 ................
00000150:  2a 00 00 00 99 00 00 94 00 00 00 00 12 02 02 00 *...............
00000160:  31 00 00 00 9c 00 00 94 00 00 00 00 10 00 02 00 1...............
00000170:  3d 00 00 00 9c d4 00 94 00 00 00 00 10 00 03 00 =...............
00000180:  48 00 00 00 31 00 00 94 0e 00 00 00 12 00 02 00 H...1...........
00000190:  55 00 00 00 9c 00 00 94 00 00 00 00 10 00 03 00 U...............
000001a0:  63 00 00 00 9c 00 00 94 00 00 00 00 10 00 02 00 c...............
000001b0:  71 00 00 00 9c 00 00 94 00 d4 00 00 11 00 03 00 q...............
000001c0:  7c 00 00 00 85 00 00 94 0a 00 00 00 12 00 02 00 |...............
000001d0:  85 00 00 00 95 00 00 94 00 00 00 00 12 02 02 00 ................
000001e0:  89 00 00 00 00 00 00 00 b8 00 00 00 11 00 01 00 ................
000001f0:  96 00 00 00 9c d4 00 94 00 00 00 00 10 00 03 00 ................
00000200:  a2 00 00 00 00 00 00 00 00 00 00 00 22 02 00 00 ............"...
00000210:  b7 00 00 00 79 00 00 94 0a 00 00 00 12 00 02 00 ....y...........
00000220:  c8 00 00 00 59 00 00 94 1e 00 00 00 12 00 02 00 ....Y...........
00000230:  d2 00 00 00 9c 00 00 94 00 00 00 00 10 00 03 00 ................
00000240:  de 00 00 00 01 00 00 94 30 00 00 00 12 00 02 00 ........0.......
00000250:  e3 00 00 00 4d 00 00 94 0a 00 00 00 12 00 02 00 ....M...........
00000260:  ed 00 00 00 7a 06 00 00 00 00 00 00 10 02 07 00 ....z...........
00000270:  2d 01 00 00 9c d4 00 94 00 00 00 00 10 00 04 00 -...............
00000280:  35 01 00 00 41 00 00 94 0a 00 00 00 12 00 02 00 5...A...........
00000290:  40 01 00 00 9c 00 00 94 00 00 00 00 10 00 02 00 @...............
000002a0:  47 01 00 00 9c d4 00 94 00 00 00 00 10 00 04 00 G...............
000002b0:  4c 01 00 00 00 00 00 00 00 00 00 00 22 02 00 00 L..........."...
000002c0:  61 01 00 00 9c 00 00 94 00 00 00 00 10 00 02 00 a...............
000002d0:  6e 01 00 00 91 00 00 94 00 00 00 00 12 02 02 00 n...............
 Raw Data for Section ".strtab"
00000000:  00 49 6e 74 65 72 72 75 70 74 56 65 63 54 61 62 .InterruptVecTab
00000010:  6c 65 2e 63 00 24 64 00 24 74 00 6d 61 69 6e 2e le.c.$d.$t.main.
00000020:  63 00 30 31 33 30 30 31 30 00 64 6f 4d 61 74 68 c.0130010.doMath
00000030:  00 5f 5f 65 78 69 64 78 5f 65 6e 64 00 5f 62 73 .__exidx_end._bs
00000040:  73 5f 65 6e 64 5f 5f 00 72 65 73 65 74 48 61 6e s_end__.resetHan
00000050:  64 6c 65 72 00 5f 5f 62 73 73 5f 73 74 61 72 74 dler.__bss_start
00000060:  5f 5f 00 5f 5f 65 78 69 64 78 5f 73 74 61 72 74 __.__exidx_start
00000070:  00 73 74 61 63 6b 5f 62 61 73 65 00 69 6e 69 74 .stack_base.init
00000080:  5f 69 76 74 00 61 64 64 00 76 65 63 74 6f 72 5f _ivt.add.vector_
00000090:  74 61 62 6c 65 00 5f 5f 62 73 73 5f 65 6e 64 5f table.__bss_end_
000000a0:  5f 00 4c 69 62 24 24 52 65 71 75 65 73 74 24 24 _.Lib$$Request$$
000000b0:  63 70 70 6c 69 62 00 4d 65 6d 4d 61 6e 61 67 65 cpplib.MemManage
000000c0:  48 61 6e 64 6c 65 72 00 53 56 43 61 6c 6c 49 53 Handler.SVCallIS
000000d0:  52 00 5f 5f 62 73 73 5f 73 74 61 72 74 00 6d 61 R.__bss_start.ma
000000e0:  69 6e 00 48 46 48 61 6e 64 6c 65 72 00 5f 5f 54 in.HFHandler.__T
000000f0:  49 5f 44 57 2e 64 65 62 75 67 5f 69 6e 66 6f 2e I_DW.debug_info.
00000100:  24 62 61 73 65 5f 74 79 70 65 73 2e 34 62 30 64 $base_types.4b0d
00000110:  31 65 34 35 35 31 37 30 38 35 63 62 38 65 63 64 1e45517085cb8ecd
00000120:  66 35 31 39 37 33 39 62 65 62 62 34 00 5f 5f 65 f519739bebb4.__e
00000130:  6e 64 5f 5f 00 4e 4d 49 48 61 6e 64 6c 65 72 00 nd__.NMIHandler.
00000140:  5f 65 64 61 74 61 00 5f 65 6e 64 00 4c 69 62 24 _edata._end.Lib$
00000150:  24 52 65 71 75 65 73 74 24 24 61 72 6d 6c 69 62 $Request$$armlib
00000160:  00 5f 5f 64 61 74 61 5f 73 74 61 72 74 00 73 75 .__data_start.su
00000170:  62 00                                           b.
6278.executable.txt
Please rename the executable.txt to executable.out - This binary is for Cortex-M3
