CCSV5.1.0.09000 install problem
Other Parts Discussed in Thread: MSP430WARE, CCSTUDIO
Hi:
During  setting up CCSV5.1.0.09000 in my computer for the first time, a error occurs: one or more features were not installed properly.I tried many times but the same problem occurs. So what is the install environment of the CCSV5.1, Is there anything missing and  shoud be installed ?  the log file is
------ ccs_setup_5.1.0.09000 Installation -------------
04/18/2012 09:54:32AM -
04/18/2012 09:54:32AM - InstallID      : 59971826-EFCC-4331-8F8A-8A5BB079891D
04/18/2012 09:54:32AM - Installer      : E:\CCS5.1.0.09000_win32\ccs_setup_5.1.0.09000.exe
04/18/2012 09:54:32AM - BuildName      : ccs_setup_5.1.0.09000.exe
04/18/2012 09:54:32AM - Install version: 5.1.0.09000
04/18/2012 09:54:32AM - Install source : E:\CCS5.1.0.09000_win32
04/18/2012 09:54:32AM - OS             : Windows
04/18/2012 09:54:32AM - UserName       : Administrator
04/18/2012 09:54:32AM - Update?        : 0
04/18/2012 09:54:32AM - Command line   :/installkitvfs/main.tcl
04/18/2012 09:54:32AM - Checking conditions for 5A908E3F-6B9A-4311-B8CA-15578F03CEC9 - Set Native_Eclipse_Selected - Before Action is Executed
04/18/2012 09:54:32AM - Checking condition A2036039-9CCB-492A-8247-6D07128AEE2F - Command Line Test Condition
04/18/2012 09:54:32AM - Checking to see if eclipseprefix was passed on the command line
04/18/2012 09:54:32AM - Condition failed
04/18/2012 09:54:32AM - Skipping action 5A908E3F-6B9A-4311-B8CA-15578F03CEC9 - Set Native_Eclipse_Selected - conditions failed
04/18/2012 09:54:32AM - Checking conditions for F0A046CD-8A59-4F7D-B025-7ED78FD8C0F3 - Execute Response File Action - Before Action is Executed
04/18/2012 09:54:32AM - Checking condition C434E3F3-C405-466D-9713-A8F99B3BCC12 - Command Line Test Condition
04/18/2012 09:54:32AM - Checking to see if response-file was passed on the command line
04/18/2012 09:54:32AM - Skipping action F0A046CD-8A59-4F7D-B025-7ED78FD8C0F3 - Execute Response File Action - conditions failed
04/18/2012 09:54:32AM - Checking conditions for 73286838-ADC5-44C6-9BF4-3D00C32317F7 - Set Windows information - Before Action is Executed
04/18/2012 09:54:32AM - Checking condition DDEDDBE3-895A-4F08-B242-B5CEB39360F2 - Platform Condition
04/18/2012 09:54:32AM - Checking to see if <%Platform%> is Windows
04/18/2012 09:54:32AM - ** Checking to see if Windows is Windows
04/18/2012 09:54:32AM - Condition passed
04/18/2012 09:54:32AM - Executing action 73286838-ADC5-44C6-9BF4-3D00C32317F7 - Set Windows information
04/18/2012 09:54:32AM - Checking System Info...
04/18/2012 09:54:32AM - WindowsProductName=
! REG.EXE VERSION 3.0
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows NT\CurrentVersion
    ProductName REG_SZ Microsoft Windows XP
  WindowsCurrentVersion= 5.1
  WindowsCSDVersionString= Service Pack 3
  WindowsCSDVersionDWord= 768
  WindowsPlatform= WinXP
04/18/2012 09:54:32AM - Checking conditions for 181F69AF-2B9D-44EF-B0B0-84126765120A - Remove common\bin from path (Windows) - Before Action is Executed
04/18/2012 09:54:32AM - Checking condition 858075F5-D830-482D-A8EC-BBB15C017286 - Platform Condition
04/18/2012 09:54:32AM - Checking condition 43D9D511-78C1-464A-909B-B7258F10652B - String Is Condition
04/18/2012 09:54:32AM - Checking to see if <%Native_Eclipse_Selected%> is false
04/18/2012 09:54:32AM - ** Checking to see if false is false
04/18/2012 09:54:32AM - Executing action 181F69AF-2B9D-44EF-B0B0-84126765120A - Remove common\bin from path (Windows)
04/18/2012 09:54:32AM - path is {c:\program files\stormii\codec} {c:\program files\stormii}
04/18/2012 09:54:32AM - Executing action 1409F691-5623-49F1-99EB-D4ED15870571 - Set BuildName (default)
04/18/2012 09:54:32AM - Setting active setup type to New Setup Type (B6E0CE8C-4E6F-4885-953A-32946A051105).
04/18/2012 09:54:32AM - Activating component D253A697-7480-46F3-AF71-AB63991129FD
04/18/2012 09:54:32AM - Executing actions A0AAD47D-43D9-43F8-9439-47A03F6F4E2B - Startup Actions
04/18/2012 09:54:32AM - Executing action 1C82CB44-08EC-4BAE-BCF7-719902E9C236 - Execute Windows Startup
04/18/2012 09:54:32AM - Checking conditions for AED7E1E0-3E40-41B5-A471-FAAFD73529F8 - Windows Startup Action - Before Action is Executed
04/18/2012 09:54:32AM - Checking condition BDCBFA61-EF65-4DF4-A4C3-1CD5758BDD79 - Platform Condition
04/18/2012 09:54:32AM - Executing actions AED7E1E0-3E40-41B5-A471-FAAFD73529F8 - Windows Startup Action
04/18/2012 09:54:32AM - Executing action C4D1AB2C-8D0E-4AF0-BA43-2DF6CA3D3A1C - Check Memory
04/18/2012 09:54:32AM - Checking Memory...
04/18/2012 09:54:32AM - Checking conditions for 98FB6613-1F73-4BCB-8DDB-B431EBD71496 - Exit if no access to TEMP dir  - Before Action is Executed
04/18/2012 09:54:32AM - Checking condition 17D28D55-F95F-4DD0-AC94-EF4CDE6400D2 - Execute Script Condition
04/18/2012 09:54:32AM - C:/DOCUME~1/ADMINI~1/LOCALS~1/Temp is writable ? 1 or  1
04/18/2012 09:54:32AM - C:/DOCUME~1/ADMINI~1/LOCALS~1/Temp/ijtmp_229DB052-F356-473E-B6A6-F22ADD191452 exists? 1
04/18/2012 09:54:32AM - C:/DOCUME~1/ADMINI~1/LOCALS~1/Temp/ijtmp_229DB052-F356-473E-B6A6-F22ADD191452 is writable ? 1
04/18/2012 09:54:32AM - making C:/DOCUME~1/ADMINI~1/LOCALS~1/Temp/ijtmp_229DB052-F356-473E-B6A6-F22ADD191452/baserepo
04/18/2012 09:54:32AM - Skipping action 98FB6613-1F73-4BCB-8DDB-B431EBD71496 - Exit if no access to TEMP dir  - conditions failed
04/18/2012 09:54:32AM - Checking conditions for 1514399D-CAAF-4087-9E82-A65109B675F8 - Execute Look for EclipseDir - Before Action is Executed
04/18/2012 09:54:32AM - Checking condition 245ABF90-7270-43B9-A0A7-17F7DAAB3466 - Command Line Test Condition
04/18/2012 09:54:32AM - Skipping action 1514399D-CAAF-4087-9E82-A65109B675F8 - Execute Look for EclipseDir - conditions failed
04/18/2012 09:54:32AM - Checking conditions for 390AFA53-7D35-4C26-A453-27B7CEBB834E - Unpack Setup xml file - Before Action is Executed
04/18/2012 09:54:32AM - Checking condition AB402A5E-1927-4722-B563-CAF54B6E53AA - Platform Condition
04/18/2012 09:54:32AM - Executing action 390AFA53-7D35-4C26-A453-27B7CEBB834E - Unpack Setup xml file
04/18/2012 09:54:32AM - Unpacking C:/DOCUME~1/ADMINI~1/LOCALS~1/Temp/ijtmp_229DB052-F356-473E-B6A6-F22ADD191452/ccs_installini.xml
04/18/2012 09:54:32AM - Checking conditions for F4C790E5-5B05-43B4-ABC4-B4B9C1C01A59 - Unpack Setup xml file - Before Action is Executed
04/18/2012 09:54:32AM - Checking condition D1A276F0-17F4-498A-B707-E9B7CDAF7109 - Platform Condition
04/18/2012 09:54:32AM - Checking to see if <%Platform%> is Linux-x86
04/18/2012 09:54:32AM - ** Checking to see if Windows is Linux-x86
04/18/2012 09:54:32AM - Skipping action F4C790E5-5B05-43B4-ABC4-B4B9C1C01A59 - Unpack Setup xml file - conditions failed
04/18/2012 09:54:32AM - Executing action C325767C-1961-4AB1-8037-7C19CB4BA543 - Get Setup Types
04/18/2012 09:54:32AM - Checking conditions for 25BA989D-274D-4302-A91E-48B8454834E4 - Unpack Manifest xml file - Before Action is Executed
04/18/2012 09:54:32AM - Checking condition 45766827-6E1C-43A5-AE55-3EDC12383C2C - Platform Condition
04/18/2012 09:54:32AM - Skipping action 25BA989D-274D-4302-A91E-48B8454834E4 - Unpack Manifest xml file - conditions failed
04/18/2012 09:54:32AM - Checking conditions for 1C65743D-E0A5-4787-B152-3A21723C2002 - Unpack Manifest xml file - Before Action is Executed
04/18/2012 09:54:32AM - Checking condition 9B003E01-3775-4A7C-ABAD-252F786C62F6 - Platform Condition
04/18/2012 09:54:32AM - Executing action 1C65743D-E0A5-4787-B152-3A21723C2002 - Unpack Manifest xml file
04/18/2012 09:54:32AM - Unpacking C:/DOCUME~1/ADMINI~1/LOCALS~1/Temp/ijtmp_229DB052-F356-473E-B6A6-F22ADD191452/ccs_manifest.xml
04/18/2012 09:54:32AM - Executing action 2237DB6B-9676-4FDA-8BBB-9CD0741C175B - Set Manifest file name
04/18/2012 09:54:32AM - Executing action 7A1CB0AB-04A3-41C0-8655-22F6AE6A972A - Full CCS or Component install test
04/18/2012 09:54:32AM - ccs_setup_5.1.*
04/18/2012 09:54:32AM - full installer
04/18/2012 09:54:32AM - Executing action D6E650CF-E79A-4C23-86E7-FE0AF5BB288C - Set USERPROFILE variable
04/18/2012 09:54:32AM - userprofile = C:\Documents and Settings\Administrator
04/18/2012 09:54:32AM - Executing action C3322C75-C36B-4CAA-99B6-D10C70E75CED - Look for Local Respository
04/18/2012 09:54:32AM - local repo = E:\CCS5.1.0.09000_win32/featurerepo
04/18/2012 09:54:32AM - localbaserepo = E:\CCS5.1.0.09000_win32/baserepo
04/18/2012 09:54:32AM - localrepo = E:\CCS5.1.0.09000_win32/featurerepo
04/18/2012 09:54:32AM - Executing action 0606F3A6-B4B3-430D-BF58-90FD8DC7E9D0 - Read Manifest file
04/18/2012 09:54:32AM - Executing action 064CDB88-8721-4CDA-B246-37D052A32298 - Debug information
04/18/2012 09:54:32AM - Manifest file: C:/DOCUME~1/ADMINI~1/LOCALS~1/Temp/ijtmp_229DB052-F356-473E-B6A6-F22ADD191452/ccs_manifest.xml
04/18/2012 09:54:32AM - Setup file   : C:/DOCUME~1/ADMINI~1/LOCALS~1/Temp/ijtmp_229DB052-F356-473E-B6A6-F22ADD191452/ccs_installini.xml
04/18/2012 09:54:32AM - Installer: ccs_setup_5.1.0.09000.exe
04/18/2012 09:54:32AM - ccs_setup_5.1.0.09000.exe
04/18/2012 09:54:32AM - C:\Documents and Settings\Administrator
04/18/2012 09:54:32AM - Checking conditions for 8F539122-507F-4B01-8ABD-1443E5E641D6 - Execute Get Edition Details - Before Action is Executed
04/18/2012 09:54:32AM - Checking condition ECCFACBA-E04C-48D6-9BD9-2BA9B3C509E1 - String Is Condition
04/18/2012 09:54:32AM - Checking to see if <%ShowSetupPane%> is false
04/18/2012 09:54:32AM - ** Checking to see if true is false
04/18/2012 09:54:32AM - Skipping action 8F539122-507F-4B01-8ABD-1443E5E641D6 - Execute Get Edition Details - conditions failed
04/18/2012 09:54:32AM - Checking conditions for A0354A16-79FB-457B-9363-CED6124ADDCA - Execute Setup Panes to Display - Before Action is Executed
04/18/2012 09:54:32AM - Checking condition C483848C-C11F-41BC-AB86-7D4A0C24A5BA - String Is Condition
04/18/2012 09:54:32AM - Skipping action A0354A16-79FB-457B-9363-CED6124ADDCA - Execute Setup Panes to Display - conditions failed
04/18/2012 09:54:32AM - Executing action 17AAAD6D-433F-4CC7-A9E2-5EB0008F5832 - Set ARM MPU BU flag
04/18/2012 09:54:32AM - E:\CCS5.1.0.09000_win32/baserepo/arm_mpu.txt doesn't exist
04/18/2012 09:54:32AM - Checking conditions for 356EAA68-888B-4347-A851-EE731133C133 - Set ARM ISA on (for ARM MPU) - Before Action is Executed
04/18/2012 09:54:32AM - Checking condition A0D7DD06-8F87-416C-8B34-062A99D6C77A - String Is Condition
04/18/2012 09:54:32AM - Checking to see if <%arm_mpu%> is true
04/18/2012 09:54:32AM - ** Checking to see if 0 is true
04/18/2012 09:54:32AM - Skipping action 356EAA68-888B-4347-A851-EE731133C133 - Set ARM ISA on (for ARM MPU) - conditions failed
04/18/2012 09:54:32AM - Checking conditions for EECE82E1-6B6F-468C-A6BA-5AB21E7F19E8 - Non-admin Message (linux) - Before Action is Executed
04/18/2012 09:54:32AM - Checking condition 2660F337-EF5C-4F78-92FA-E0B8EE28FC23 - Platform Condition
04/18/2012 09:54:32AM - Skipping action EECE82E1-6B6F-468C-A6BA-5AB21E7F19E8 - Non-admin Message (linux) - conditions failed
04/18/2012 09:54:32AM - Checking conditions for 1EEDE33F-FA96-434E-A408-3A858B0CFE41 - Non-admin Message (linux) - Before Action is Executed
04/18/2012 09:54:32AM - Checking condition B2E179AA-7558-48D7-8D00-0E27D34F3026 - Platform Condition
04/18/2012 09:54:32AM - Skipping action 1EEDE33F-FA96-434E-A408-3A858B0CFE41 - Non-admin Message (linux) - conditions failed
04/18/2012 09:54:32AM - Checking conditions for AABD8C8E-3C88-4987-B89C-D6747C9394D5 - Exit - Before Action is Executed
04/18/2012 09:54:32AM - Checking condition 474FB0CF-0071-4661-AC05-9DBF4E4BFED2 - Platform Condition
04/18/2012 09:54:32AM - Skipping action AABD8C8E-3C88-4987-B89C-D6747C9394D5 - Exit - conditions failed
04/18/2012 09:54:32AM - Executing action 161F5BA9-3D23-4365-A8B8-ADFFE05E9A98 - Create Install Panes
04/18/2012 09:54:32AM - description = Select this option if you wish to customize the individual features that are installed.
04/18/2012 09:54:32AM - activating Custom
04/18/2012 09:54:33AM - Executing action 0FFC0C08-DA3A-4881-B6C3-FE17EA4D4F5B - Update Setup
04/18/2012 09:54:33AM - Checking conditions for 4BDB2FB9-99BA-45DA-86F0-6FBD39315F3A - Update Setup Action - Before Action is Executed
04/18/2012 09:54:33AM - Checking condition 0FF0BFFC-81E4-4720-9FE1-AA20B71FCE24 - String Is Condition
04/18/2012 09:54:33AM - Checking to see if <%UpdateMode%> is true
04/18/2012 09:54:33AM - ** Checking to see if 0 is true
04/18/2012 09:54:33AM - Condition failed
04/18/2012 09:54:33AM - Skipping action group 0FFC0C08-DA3A-4881-B6C3-FE17EA4D4F5B - Update Setup - conditions failed
04/18/2012 09:54:33AM - Checking conditions for A11790D2-A8D6-4BF2-B0AC-FD735A88B2B6 - License Agreement - Before Pane is Displayed
04/18/2012 09:54:33AM - Checking condition 5AD62789-2677-4DA5-84E1-739D4AAFA825 - Command Line Test Condition
04/18/2012 09:54:33AM - Checking to see if test was not passed on the command line
04/18/2012 09:54:33AM - Condition passed
04/18/2012 09:54:33AM - Executing actions A11790D2-A8D6-4BF2-B0AC-FD735A88B2B6 - License Agreement - Before Pane is Displayed
04/18/2012 09:54:33AM - Checking conditions for 8D4321BA-CBFE-487B-978A-6F8856E82BDF - Disable Next Button - Before Action is Executed
04/18/2012 09:54:33AM - Checking condition B9385049-E34B-4149-BEEA-19848C59FB8F - String Is Condition
04/18/2012 09:54:33AM - Checking to see if <%Property <%CurrentPane%> UserMustAcceptLicense%> is true
04/18/2012 09:54:33AM - ** Checking to see if Yes is true
04/18/2012 09:54:33AM - Checking condition 695C91E5-69F9-4B0B-8F89-C78D8E2C348F - String Is Condition
04/18/2012 09:54:33AM - Checking to see if <%LicenseAccepted%> is false
04/18/2012 09:54:33AM - ** Checking to see if No is false
04/18/2012 09:54:33AM - Executing action 8D4321BA-CBFE-487B-978A-6F8856E82BDF - Disable Next Button
04/18/2012 09:54:33AM - Displaying pane A11790D2-A8D6-4BF2-B0AC-FD735A88B2B6 - License Agreement
04/18/2012 09:54:33AM - Executing actions A11790D2-A8D6-4BF2-B0AC-FD735A88B2B6 - License Agreement - After Pane is Displayed
04/18/2012 09:54:33AM - Executing action DECD8C88-32C8-495F-B29B-39B0AB07DC86 - Add Print Button
04/18/2012 09:54:35AM - Executing actions A11790D2-A8D6-4BF2-B0AC-FD735A88B2B6 - License Agreement - Before Next Pane is Displayed
04/18/2012 09:54:35AM - Executing actions F47FFD38-C9F1-4896-B0C5-A870FBD8CDE7 - Select Destination - Before Pane is Displayed
04/18/2012 09:54:35AM - Executing action 572E4601-A7D6-49BD-A9FB-30C5DA9AAB1E - Add checkbox for Eclipse location
04/18/2012 09:54:35AM - Checking conditions for 7615A7D4-FB57-4CD7-9D01-345765DF42DE - Execute Look for EclipseDir - Before Action is Executed
04/18/2012 09:54:35AM - Checking condition A94F968A-97A1-4C75-BC27-CB9BA3F14E66 - String Is Condition
04/18/2012 09:54:35AM - Checking to see if <%EclipseDir%> is not empty
04/18/2012 09:54:35AM - ** Checking to see if  is not empty
04/18/2012 09:54:35AM - Condition failed
04/18/2012 09:54:35AM - Skipping action 7615A7D4-FB57-4CD7-9D01-345765DF42DE - Execute Look for EclipseDir - conditions failed
04/18/2012 09:54:35AM - Displaying pane F47FFD38-C9F1-4896-B0C5-A870FBD8CDE7 - Select Destination
04/18/2012 09:54:35AM - Executing actions F47FFD38-C9F1-4896-B0C5-A870FBD8CDE7 - Select Destination - After Pane is Displayed
04/18/2012 09:54:35AM - Checking conditions for DF3D9494-F760-448B-915E-A23D94B7FE9C - Initialize EclipseDir - Before Action is Executed
04/18/2012 09:54:35AM - Checking condition 541443C2-AE4D-4C32-891F-76BA4174C31A - String Is Condition
04/18/2012 09:54:35AM - Checking to see if <%Native_Eclipse_Selected%> is false
04/18/2012 09:54:35AM - ** Checking to see if 0 is false
04/18/2012 09:54:35AM - Condition passed
04/18/2012 09:54:35AM - Executing action DF3D9494-F760-448B-915E-A23D94B7FE9C - Initialize EclipseDir
04/18/2012 09:54:35AM - Executing action 76B72CC4-6A46-43FF-ACAD-88E10B96E4AA - Initialize Variables
04/18/2012 09:54:35AM - checking installedfbinary
04/18/2012 09:54:35AM - Executing action 7AE21CEE-B823-4A59-988A-CF452F9E8811 - Set ReRun (false)
04/18/2012 09:54:35AM - Executing action DAE3C4E4-3CE4-4A7F-A60B-9F332F4021CE - Set Update_Eclipse (true)
04/18/2012 09:54:35AM - Executing action B9E1016C-6068-4C82-8137-F472851CD25C - DestinationFrame
04/18/2012 09:54:35AM - Executing action B9CB2CE2-E2E9-45F1-B7B3-0FEDD1A31099 - DestinationLabel
04/18/2012 09:54:35AM - Executing action B000C96C-0BDA-43F2-BA4B-E0E15B1700AE - DestinationBrowseButton
04/18/2012 09:54:35AM - Executing action B4E4526D-A3DB-486D-A7BF-39320D74CB7F - Adjust Layout
04/18/2012 09:54:35AM - Checking conditions for D948D911-691E-4BBA-A789-FD437E15C553 - Set EclipseDir Checkbox - Before Action is Executed
04/18/2012 09:54:35AM - Checking condition 723CA04D-2EF9-4B6A-8FDD-97A01E04A617 - String Is Condition
04/18/2012 09:54:35AM - Checking to see if <%Valid_Eclipse_Found%> is true
04/18/2012 09:54:35AM - ** Checking to see if false is true
04/18/2012 09:54:35AM - Skipping action D948D911-691E-4BBA-A789-FD437E15C553 - Set EclipseDir Checkbox - conditions failed
04/18/2012 09:54:35AM - Executing action 1D063DD9-A021-42A2-B1F5-EDF53B08EEB4 - Execute EclipseDir Action
04/18/2012 09:54:35AM - Executing actions B520BD41-3AB6-4D4B-91B3-8C28D0C214D2 - EclipseDir Action
04/18/2012 09:54:35AM - Checking conditions for 7D9E88F0-5467-4E6D-A430-29312184ACD8 -  - Before Action is Executed
04/18/2012 09:54:35AM - Checking condition 9A5D877C-FFC1-4225-BD05-980C8F0532FE - String Is Condition
04/18/2012 09:54:35AM - Executing action 7D9E88F0-5467-4E6D-A430-29312184ACD8 - Execute Destroy Eclipse Location Action
04/18/2012 09:54:35AM - Executing actions 251DB6BC-DFA4-45BE-8ECE-D72CBE1E87D4 - Destroy Eclipse Location Action
04/18/2012 09:54:36AM - Checking conditions for F6D36286-ED6F-40D0-AD99-2F8450E51081 -  - Before Action is Executed
04/18/2012 09:54:36AM - Checking condition 8BBD9C89-EFBB-457A-B7B8-36C27F8C2D93 - Execute Script Condition
04/18/2012 09:54:36AM - aWidget = CDBAD941-00B7-4B5F-B3C8-74CF9FE03269
04/18/2012 09:54:36AM - Condition passed
04/18/2012 09:54:36AM - Executing action F6D36286-ED6F-40D0-AD99-2F8450E51081 - Delete Browse Button
04/18/2012 09:54:36AM - Checking conditions for AC055342-233D-4DBE-A388-8D459C788420 -  - Before Action is Executed
04/18/2012 09:54:36AM - Checking condition 552C5F74-33ED-4D6B-8386-8AEE0F861479 - Execute Script Condition
04/18/2012 09:54:36AM - aWidget = 355B175A-3A7D-43F2-BB48-483CE773678A
04/18/2012 09:54:36AM - Executing action AC055342-233D-4DBE-A388-8D459C788420 - Delete Eclipse Label
04/18/2012 09:54:36AM - Checking conditions for 9061C5E1-8C4A-4BAC-ADB0-7FE93901F568 -  - Before Action is Executed
04/18/2012 09:54:36AM - Checking condition 42DFCE80-B1CF-4341-BCA6-0DEE4C97BB0E - Execute Script Condition
04/18/2012 09:54:36AM - aWidget = 8C353761-A7C4-487F-8DED-7B6CEAFCC7F3
04/18/2012 09:54:36AM - Executing action 9061C5E1-8C4A-4BAC-ADB0-7FE93901F568 - Delete Eclipse Frame
04/18/2012 09:54:36AM - Executing action 7D140CC9-056A-46F3-9402-6200A6DD0179 - Enable Next Button 3
04/18/2012 09:54:36AM - Checking conditions for C3BBD85E-CF2E-4D18-830E-706680E62295 -  - Before Action is Executed
04/18/2012 09:54:36AM - Checking condition 21D3B6B1-8945-4630-B44A-6E752CCC6393 - String Is Condition
04/18/2012 09:54:36AM - Checking to see if <%Native_Eclipse_Selected%> is true
04/18/2012 09:54:36AM - ** Checking to see if 0 is true
04/18/2012 09:54:36AM - Condition failed
04/18/2012 09:54:36AM - Skipping action C3BBD85E-CF2E-4D18-830E-706680E62295 - Execute Create Eclipse Location Action - conditions failed
04/18/2012 09:54:37AM - Executing actions E674EC00-088C-4BFB-9F40-C6C1B6043B9B - Destination Browse Button Action
04/18/2012 09:54:37AM - Executing action ED6D0EBB-4865-4AFF-A903-7A4D3929D7C9 - Choose Install Location
04/18/2012 09:54:41AM - InstallDir=C:\ti; InstallDir=C:\ti
04/18/2012 09:54:42AM - Checking conditions for F47FFD38-C9F1-4896-B0C5-A870FBD8CDE7 - Select Destination - Before Next Pane is Displayed
04/18/2012 09:54:42AM - Checking condition 9988A480-90AF-4403-9780-1C5A957E2445 - File Permission Condition
04/18/2012 09:54:42AM - Checking to see if we can create <%InstallDir%>
04/18/2012 09:54:42AM - ** Checking to see if we can create C:\ti
04/18/2012 09:54:42AM - Condition passed
04/18/2012 09:54:42AM - Executing actions F47FFD38-C9F1-4896-B0C5-A870FBD8CDE7 - Select Destination - Before Next Pane is Displayed
04/18/2012 09:54:42AM - Executing action 00881923-FC71-43A3-9FC0-801A9E6C35B6 - Execute Look for Previous Installs
04/18/2012 09:54:42AM - Executing actions C72174AD-964D-449B-9E81-13CED09097C5 - Look for Previous Installs
04/18/2012 09:54:42AM - Executing action C72174AD-964D-449B-9E81-13CED09097C5 - Look for Previous Installs
04/18/2012 09:54:42AM - CCSDIR = C:\ti/ccsv5 false  0
04/18/2012 09:54:42AM - C:\ti C:\ti/ccsv5 C:\ti/ccsv5/eclipse C:\ti/ccsv5/eclipse/ccs_config.xml
04/18/2012 09:54:42AM - dir content C:/ti/ccsv5 =
04/18/2012 09:54:42AM - file exists 0
04/18/2012 09:54:42AM - no ccsdir or it's empty
04/18/2012 09:54:42AM - Checking conditions for A59224D3-9CA8-4944-9C35-A0C72BAE5D71 - Previous Install Found - Before Pane is Displayed
04/18/2012 09:54:42AM - Checking condition BEB51ECD-539D-4EB0-9BBD-70325303A603 - String Is Condition
04/18/2012 09:54:42AM - Checking to see if <%ReRun%> is true
04/18/2012 09:54:42AM - ** Checking to see if 0 is true
04/18/2012 09:54:42AM - Condition failed
04/18/2012 09:54:42AM - Skipping pane A59224D3-9CA8-4944-9C35-A0C72BAE5D71 - Previous Install Found - conditions failed
04/18/2012 09:54:42AM - Checking conditions for F6FCB570-82DE-4640-AEF0-5CD6A221E0EB - Custom Setup Type - Before Pane is Displayed
04/18/2012 09:54:42AM - Checking condition 60512861-E5AE-4FDD-8E7C-C982DD1A4B6C - String Is Condition
04/18/2012 09:54:42AM - Checking to see if <%ReRun%> is false
04/18/2012 09:54:42AM - ** Checking to see if 0 is false
04/18/2012 09:54:42AM - Checking condition 49610746-5157-47D5-BD44-A52DADA4E885 - String Is Condition
04/18/2012 09:54:42AM - Checking to see if <%ShowSetupPane%> is true
04/18/2012 09:54:42AM - ** Checking to see if true is true
04/18/2012 09:54:42AM - Executing actions F6FCB570-82DE-4640-AEF0-5CD6A221E0EB - Custom Setup Type - Before Pane is Displayed
04/18/2012 09:54:42AM - Displaying pane F6FCB570-82DE-4640-AEF0-5CD6A221E0EB - Custom Setup Type
04/18/2012 09:54:42AM - Executing actions F6FCB570-82DE-4640-AEF0-5CD6A221E0EB - Custom Setup Type - After Pane is Displayed
04/18/2012 09:54:46AM - Executing actions F6FCB570-82DE-4640-AEF0-5CD6A221E0EB - Custom Setup Type - Before Next Pane is Displayed
04/18/2012 09:54:46AM - Executing action 39084E99-5AFB-45DA-AFD1-8ACD3A936F53 - Disable Next
04/18/2012 09:54:46AM - Executing action 4CF4BB8E-1853-46E0-AB50-25BA2172B119 - Execute Get Edition Details
04/18/2012 09:54:46AM - Executing actions 214CDC31-6FF9-4C65-B874-265447EB94E3 - Get Edition Details
04/18/2012 09:54:46AM - Executing action 64877C38-51BE-4D33-8849-6C8852694A01 - Parse XML Input
04/18/2012 09:54:46AM - JRE_VERSION_REQUIRED = 1.6
04/18/2012 09:54:46AM - Complete Feature Set component settings:
04/18/2012 09:54:46AM - child node
04/18/2012 09:54:46AM - MSP430 Low Power MCUs: EMU_MSP430:mandatory
04/18/2012 09:54:46AM - MSP430 Low Power MCUs: CGT_DEFAULTLIBS_MSP430:default
04/18/2012 09:54:46AM - MSP430 Low Power MCUs: DMED:default
04/18/2012 09:54:46AM - MSP430 Low Power MCUs: MSP430_CGT_HELP:default
04/18/2012 09:54:46AM - MSP430 Low Power MCUs: TC_BIOS6:default
04/18/2012 09:54:46AM - MSP430 Low Power MCUs: UIA:default
04/18/2012 09:54:46AM - MSP430 Low Power MCUs: TC_XDCTOOLS:default
04/18/2012 09:54:46AM - MSP430 Low Power MCUs: TC_IPC:default
04/18/2012 09:54:46AM - MSP430 Low Power MCUs: TC_MSP430_BIOS6:default
04/18/2012 09:54:46AM - MSP430 Low Power MCUs: TC_MSP430_XDCTOOLS:default
04/18/2012 09:54:46AM - MSP430 Low Power MCUs: TC_MSP430_IPC:default
04/18/2012 09:54:46AM - MSP430 Low Power MCUs: IDE:mandatory
04/18/2012 09:54:46AM - MSP430 Low Power MCUs: CCSINIT:mandatory
04/18/2012 09:54:46AM - MSP430 Low Power MCUs: DVT_MIN:mandatory
04/18/2012 09:54:46AM - MSP430 Low Power MCUs: DS:mandatory
04/18/2012 09:54:46AM - MSP430 Low Power MCUs: GRACE:default
04/18/2012 09:54:46AM - MSP430 Low Power MCUs: MSP430Ware:default
04/18/2012 09:54:46AM - C28x 32-bit Real-time MCUs: EMU_TI:mandatory
04/18/2012 09:54:46AM - C28x 32-bit Real-time MCUs: EMU_BH:default
04/18/2012 09:54:46AM - C28x 32-bit Real-time MCUs: EMU_SD:default
04/18/2012 09:54:46AM - C28x 32-bit Real-time MCUs: EMU_C2000_FLASH:mandatory
04/18/2012 09:54:46AM - C28x 32-bit Real-time MCUs: EMU_C2000:mandatory
04/18/2012 09:54:46AM - C28x 32-bit Real-time MCUs: EMU_NOWFLASH:mandatory
04/18/2012 09:54:46AM - C28x 32-bit Real-time MCUs: CGT_DEFAULTLIBS_C2800:default
04/18/2012 09:54:46AM - C28x 32-bit Real-time MCUs: DMED:default
04/18/2012 09:54:46AM - C28x 32-bit Real-time MCUs: TC_BIOS5:default
04/18/2012 09:54:46AM - C28x 32-bit Real-time MCUs: TC_XDAIS_BIOS5:default
04/18/2012 09:54:46AM - C28x 32-bit Real-time MCUs: TC_XDCTOOLS_BIOS5:default
04/18/2012 09:54:46AM - C28x 32-bit Real-time MCUs: TC_BIOS6:default
04/18/2012 09:54:46AM - C28x 32-bit Real-time MCUs: UIA:default
04/18/2012 09:54:46AM - C28x 32-bit Real-time MCUs: TC_C2000_BIOS6:default
04/18/2012 09:54:46AM - C28x 32-bit Real-time MCUs: TC_XDAIS:default
04/18/2012 09:54:46AM - C28x 32-bit Real-time MCUs: TC_XDCTOOLS:default
04/18/2012 09:54:46AM - C28x 32-bit Real-time MCUs: TC_C2000_XDCTOOLS:default
04/18/2012 09:54:46AM - C28x 32-bit Real-time MCUs: TC_IPC:default
04/18/2012 09:54:46AM - C28x 32-bit Real-time MCUs: TC_C2000_IPC:default
04/18/2012 09:54:46AM - C28x 32-bit Real-time MCUs: IDE:mandatory
04/18/2012 09:54:46AM - C28x 32-bit Real-time MCUs: CCSINIT:mandatory
04/18/2012 09:54:46AM - C28x 32-bit Real-time MCUs: DS:mandatory
04/18/2012 09:54:46AM - C28x 32-bit Real-time MCUs: DVT:mandatory
04/18/2012 09:54:46AM - C28x 32-bit Real-time MCUs: SIM_TI:default
04/18/2012 09:54:46AM - Stellaris Cortex M MCUs: EMU_TI:mandatory
04/18/2012 09:54:46AM - Stellaris Cortex M MCUs: EMU_STELLARIS:mandatory
04/18/2012 09:54:46AM - Stellaris Cortex M MCUs: EMU_BH:default
04/18/2012 09:54:46AM - Stellaris Cortex M MCUs: EMU_SD:default
04/18/2012 09:54:46AM - Stellaris Cortex M MCUs: CGT_DEFAULTLIBS_TMS470:default
04/18/2012 09:54:46AM - Stellaris Cortex M MCUs: DMED:default
04/18/2012 09:54:46AM - Stellaris Cortex M MCUs: TC_BIOS6:default
04/18/2012 09:54:46AM - Stellaris Cortex M MCUs: UIA:default
04/18/2012 09:54:46AM - Stellaris Cortex M MCUs: TC_ARM_BIOS6:default
04/18/2012 09:54:46AM - Stellaris Cortex M MCUs: TC_XDAIS:default
04/18/2012 09:54:46AM - Stellaris Cortex M MCUs: TC_XDCTOOLS:default
04/18/2012 09:54:46AM - Stellaris Cortex M MCUs: TC_ARM_XDCTOOLS:default
04/18/2012 09:54:46AM - Stellaris Cortex M MCUs: TC_IPC:default
04/18/2012 09:54:46AM - Stellaris Cortex M MCUs: TC_ARM_IPC:default
04/18/2012 09:54:46AM - Stellaris Cortex M MCUs: IDE:mandatory
04/18/2012 09:54:46AM - Stellaris Cortex M MCUs: CCSINIT:mandatory
04/18/2012 09:54:46AM - Stellaris Cortex M MCUs: DS:mandatory
04/18/2012 09:54:46AM - Stellaris Cortex M MCUs: DVT:mandatory
04/18/2012 09:54:46AM - Stellaris Cortex M MCUs: SIM_TI:default
04/18/2012 09:54:46AM - Cortex-R4F MCUs: EMU_BH:default
04/18/2012 09:54:46AM - Cortex-R4F MCUs: EMU_SD:default
04/18/2012 09:54:46AM - Cortex-R4F MCUs: CGT_DEFAULTLIBS_TMS470:default
04/18/2012 09:54:46AM - Cortex-R4F MCUs: DMED:default
04/18/2012 09:54:46AM - Cortex-R4F MCUs: TC_BIOS6:default
04/18/2012 09:54:46AM - Cortex-R4F MCUs: UIA:default
04/18/2012 09:54:46AM - Cortex-R4F MCUs: TC_XDAIS:default
04/18/2012 09:54:46AM - Cortex-R4F MCUs: TC_XDCTOOLS:default
04/18/2012 09:54:46AM - Cortex-R4F MCUs: TC_IPC:default
04/18/2012 09:54:46AM - Cortex-R4F MCUs: TC_ARM_BIOS6:default
04/18/2012 09:54:46AM - Cortex-R4F MCUs: TC_ARM_XDCTOOLS:default
04/18/2012 09:54:46AM - Cortex-R4F MCUs: TC_ARM_IPC:default
04/18/2012 09:54:46AM - Cortex-R4F MCUs: EMU_TI:mandatory
04/18/2012 09:54:46AM - Cortex-R4F MCUs: EMU_HERCULES:mandatory
04/18/2012 09:54:46AM - Cortex-R4F MCUs: EMU_NOWFLASH:mandatory
04/18/2012 09:54:46AM - Cortex-R4F MCUs: IDE:mandatory
04/18/2012 09:54:46AM - Cortex-R4F MCUs: CCSINIT:mandatory
04/18/2012 09:54:46AM - Cortex-R4F MCUs: DS:mandatory
04/18/2012 09:54:46AM - Cortex-R4F MCUs: DVT:mandatory
04/18/2012 09:54:46AM - Cortex-R4F MCUs: SIM_TI:default
04/18/2012 09:54:46AM - AMxx Cortex-A and ARM9 processors: EMU_BH:default
04/18/2012 09:54:46AM - AMxx Cortex-A and ARM9 processors: EMU_SD:default
04/18/2012 09:54:46AM - AMxx Cortex-A and ARM9 processors: CGT_DEFAULTLIBS_TMS470:default
04/18/2012 09:54:46AM - AMxx Cortex-A and ARM9 processors: DMED:default
04/18/2012 09:54:46AM - AMxx Cortex-A and ARM9 processors: TC_BIOS5:default
04/18/2012 09:54:46AM - AMxx Cortex-A and ARM9 processors: TC_XDAIS_BIOS5:default
04/18/2012 09:54:46AM - AMxx Cortex-A and ARM9 processors: TC_XDCTOOLS_BIOS5:default
04/18/2012 09:54:46AM - AMxx Cortex-A and ARM9 processors: TC_BIOS6:default
04/18/2012 09:54:46AM - AMxx Cortex-A and ARM9 processors: UIA:default
04/18/2012 09:54:46AM - AMxx Cortex-A and ARM9 processors: TC_XDAIS:default
04/18/2012 09:54:46AM - AMxx Cortex-A and ARM9 processors: TC_XDCTOOLS:default
04/18/2012 09:54:46AM - AMxx Cortex-A and ARM9 processors: TC_IPC:default
04/18/2012 09:54:46AM - AMxx Cortex-A and ARM9 processors: TC_ARM_BIOS6:default
04/18/2012 09:54:46AM - AMxx Cortex-A and ARM9 processors: TC_ARM_XDCTOOLS:default
04/18/2012 09:54:46AM - AMxx Cortex-A and ARM9 processors: TC_ARM_IPC:default
04/18/2012 09:54:46AM - AMxx Cortex-A and ARM9 processors: EMU_TI:mandatory
04/18/2012 09:54:46AM - AMxx Cortex-A and ARM9 processors: IDE:mandatory
04/18/2012 09:54:46AM - AMxx Cortex-A and ARM9 processors: CCSINIT:mandatory
04/18/2012 09:54:46AM - AMxx Cortex-A and ARM9 processors: DS:mandatory
04/18/2012 09:54:46AM - AMxx Cortex-A and ARM9 processors: DVT:mandatory
04/18/2012 09:54:46AM - AMxx Cortex-A and ARM9 processors: SIM_TI:default
04/18/2012 09:54:46AM - C6x DSP + ARM processors: EMU_BH:default
04/18/2012 09:54:46AM - C6x DSP + ARM processors: EMU_SD:default
04/18/2012 09:54:46AM - C6x DSP + ARM processors: CGT_DEFAULTLIBS_TMS470:default
04/18/2012 09:54:46AM - C6x DSP + ARM processors: CGT_DEFAULTLIBS_C6000:default
04/18/2012 09:54:46AM - C6x DSP + ARM processors: DMED:default
04/18/2012 09:54:46AM - C6x DSP + ARM processors: TC_BIOS5:default
04/18/2012 09:54:46AM - C6x DSP + ARM processors: TC_XDAIS_BIOS5:default
04/18/2012 09:54:46AM - C6x DSP + ARM processors: TC_XDCTOOLS_BIOS5:default
04/18/2012 09:54:46AM - C6x DSP + ARM processors: TC_BIOS6:default
04/18/2012 09:54:46AM - C6x DSP + ARM processors: UIA:default
04/18/2012 09:54:46AM - C6x DSP + ARM processors: TC_XDAIS:default
04/18/2012 09:54:46AM - C6x DSP + ARM processors: TC_XDCTOOLS:default
04/18/2012 09:54:46AM - C6x DSP + ARM processors: TC_IPC:default
04/18/2012 09:54:46AM - C6x DSP + ARM processors: TC_ARM_BIOS6:default
04/18/2012 09:54:46AM - C6x DSP + ARM processors: TC_ARM_XDCTOOLS:default
04/18/2012 09:54:46AM - C6x DSP + ARM processors: TC_ARM_IPC:default
04/18/2012 09:54:46AM - C6x DSP + ARM processors: TC_C6000_BIOS6:default
04/18/2012 09:54:46AM - C6x DSP + ARM processors: TC_C6000_XDCTOOLS:default
04/18/2012 09:54:46AM - C6x DSP + ARM processors: TC_C6000_IPC:default
04/18/2012 09:54:46AM - C6x DSP + ARM processors: C6FLO:default
04/18/2012 09:54:46AM - C6x DSP + ARM processors: EMU_TI:mandatory
04/18/2012 09:54:46AM - C6x DSP + ARM processors: IDE:mandatory
04/18/2012 09:54:46AM - C6x DSP + ARM processors: CCSINIT:mandatory
04/18/2012 09:54:46AM - C6x DSP + ARM processors: DS:mandatory
04/18/2012 09:54:46AM - C6x DSP + ARM processors: DVT:mandatory
04/18/2012 09:54:46AM - C6x DSP + ARM processors: SIM_TI:default
04/18/2012 09:54:46AM - DaVinci Video Processors: EMU_BH:default
04/18/2012 09:54:46AM - DaVinci Video Processors: EMU_SD:default
04/18/2012 09:54:46AM - DaVinci Video Processors: CGT_DEFAULTLIBS_TMS470:default
04/18/2012 09:54:46AM - DaVinci Video Processors: CGT_DEFAULTLIBS_C6000:default
04/18/2012 09:54:46AM - DaVinci Video Processors: DMED:default
04/18/2012 09:54:46AM - DaVinci Video Processors: TC_BIOS5:default
04/18/2012 09:54:46AM - DaVinci Video Processors: TC_XDAIS_BIOS5:default
04/18/2012 09:54:46AM - DaVinci Video Processors: TC_XDCTOOLS_BIOS5:default
04/18/2012 09:54:46AM - DaVinci Video Processors: TC_BIOS6:default
04/18/2012 09:54:46AM - DaVinci Video Processors: UIA:default
04/18/2012 09:54:46AM - DaVinci Video Processors: TC_XDAIS:default
04/18/2012 09:54:46AM - DaVinci Video Processors: TC_XDCTOOLS:default
04/18/2012 09:54:46AM - DaVinci Video Processors: TC_IPC:default
04/18/2012 09:54:46AM - DaVinci Video Processors: TC_ARM_BIOS6:default
04/18/2012 09:54:46AM - DaVinci Video Processors: TC_ARM_XDCTOOLS:default
04/18/2012 09:54:46AM - DaVinci Video Processors: TC_ARM_IPC:default
04/18/2012 09:54:46AM - DaVinci Video Processors: TC_C6000_BIOS6:default
04/18/2012 09:54:46AM - DaVinci Video Processors: TC_C6000_XDCTOOLS:default
04/18/2012 09:54:46AM - DaVinci Video Processors: TC_C6000_IPC:default
04/18/2012 09:54:46AM - DaVinci Video Processors: C6FLO:default
04/18/2012 09:54:46AM - DaVinci Video Processors: EMU_TI:mandatory
04/18/2012 09:54:46AM - DaVinci Video Processors: IDE:mandatory
04/18/2012 09:54:46AM - DaVinci Video Processors: CCSINIT:mandatory
04/18/2012 09:54:46AM - DaVinci Video Processors: DS:mandatory
04/18/2012 09:54:46AM - DaVinci Video Processors: DVT:mandatory
04/18/2012 09:54:46AM - DaVinci Video Processors: SIM_TI:default
04/18/2012 09:54:46AM - C6000 Single Core DSPs: EMU_BH:default
04/18/2012 09:54:46AM - C6000 Single Core DSPs: EMU_SD:default
04/18/2012 09:54:46AM - C6000 Single Core DSPs: CGT_DEFAULTLIBS_C6000:default
04/18/2012 09:54:46AM - C6000 Single Core DSPs: DMED:default
04/18/2012 09:54:46AM - C6000 Single Core DSPs: TC_BIOS5:default
04/18/2012 09:54:46AM - C6000 Single Core DSPs: TC_XDAIS_BIOS5:default
04/18/2012 09:54:46AM - C6000 Single Core DSPs: TC_XDCTOOLS_BIOS5:default
04/18/2012 09:54:46AM - C6000 Single Core DSPs: TC_BIOS6:default
04/18/2012 09:54:46AM - C6000 Single Core DSPs: UIA:default
04/18/2012 09:54:46AM - C6000 Single Core DSPs: TC_XDAIS:default
04/18/2012 09:54:46AM - C6000 Single Core DSPs: TC_XDCTOOLS:default
04/18/2012 09:54:46AM - C6000 Single Core DSPs: TC_IPC:default
04/18/2012 09:54:46AM - C6000 Single Core DSPs: TC_C6000_BIOS6:default
04/18/2012 09:54:46AM - C6000 Single Core DSPs: TC_C6000_XDCTOOLS:default
04/18/2012 09:54:46AM - C6000 Single Core DSPs: TC_C6000_IPC:default
04/18/2012 09:54:46AM - C6000 Single Core DSPs: C6FLO:default
04/18/2012 09:54:46AM - C6000 Single Core DSPs: EMU_TI:mandatory
04/18/2012 09:54:46AM - C6000 Single Core DSPs: IDE:mandatory
04/18/2012 09:54:46AM - C6000 Single Core DSPs: CCSINIT:mandatory
04/18/2012 09:54:46AM - C6000 Single Core DSPs: DS:mandatory
04/18/2012 09:54:46AM - C6000 Single Core DSPs: DVT:mandatory
04/18/2012 09:54:46AM - C6000 Single Core DSPs: SIM_TI:default
04/18/2012 09:54:46AM - C6000 Multi Core DSPs: EMU_BH:default
04/18/2012 09:54:46AM - C6000 Multi Core DSPs: EMU_SD:default
04/18/2012 09:54:46AM - C6000 Multi Core DSPs: CGT_DEFAULTLIBS_C6000:default
04/18/2012 09:54:46AM - C6000 Multi Core DSPs: DMED:default
04/18/2012 09:54:46AM - C6000 Multi Core DSPs: TC_BIOS5:default
04/18/2012 09:54:46AM - C6000 Multi Core DSPs: TC_XDAIS_BIOS5:default
04/18/2012 09:54:46AM - C6000 Multi Core DSPs: TC_XDCTOOLS_BIOS5:default
04/18/2012 09:54:46AM - C6000 Multi Core DSPs: TC_BIOS6:default
04/18/2012 09:54:46AM - C6000 Multi Core DSPs: UIA:default
04/18/2012 09:54:46AM - C6000 Multi Core DSPs: TC_XDAIS:default
04/18/2012 09:54:46AM - C6000 Multi Core DSPs: TC_XDCTOOLS:default
04/18/2012 09:54:46AM - C6000 Multi Core DSPs: TC_IPC:default
04/18/2012 09:54:46AM - C6000 Multi Core DSPs: TC_C6000_BIOS6:default
04/18/2012 09:54:46AM - C6000 Multi Core DSPs: TC_C6000_XDCTOOLS:default
04/18/2012 09:54:46AM - C6000 Multi Core DSPs: TC_C6000_IPC:default
04/18/2012 09:54:46AM - C6000 Multi Core DSPs: EMU_TI:mandatory
04/18/2012 09:54:46AM - C6000 Multi Core DSPs: KEYSTONE1:mandatory
04/18/2012 09:54:46AM - C6000 Multi Core DSPs: IDE:mandatory
04/18/2012 09:54:46AM - C6000 Multi Core DSPs: CCSINIT:mandatory
04/18/2012 09:54:46AM - C6000 Multi Core DSPs: DS:mandatory
04/18/2012 09:54:46AM - C6000 Multi Core DSPs: DVT:mandatory
04/18/2012 09:54:46AM - C6000 Multi Core DSPs: SIM_TI:default
04/18/2012 09:54:46AM - OMAP: EMU_BH:default
04/18/2012 09:54:46AM - OMAP: EMU_SD:default
04/18/2012 09:54:46AM - OMAP: CGT_DEFAULTLIBS_C6000:default
04/18/2012 09:54:46AM - OMAP: CGT_DEFAULTLIBS_TMS470:default
04/18/2012 09:54:46AM - OMAP: CGT_DEFAULTLIBS_C5500:default
04/18/2012 09:54:46AM - OMAP: CGT_DEFAULTLIBS_C5400:default
04/18/2012 09:54:46AM - OMAP: DMED:default
04/18/2012 09:54:46AM - OMAP: TC_BIOS5:default
04/18/2012 09:54:46AM - OMAP: TC_XDAIS_BIOS5:default
04/18/2012 09:54:46AM - OMAP: TC_XDCTOOLS_BIOS5:default
04/18/2012 09:54:46AM - OMAP: TC_BIOS6:default
04/18/2012 09:54:46AM - OMAP: UIA:default
04/18/2012 09:54:46AM - OMAP: TC_XDAIS:default
04/18/2012 09:54:46AM - OMAP: TC_XDCTOOLS:default
04/18/2012 09:54:46AM - OMAP: TC_IPC:default
04/18/2012 09:54:46AM - OMAP: TC_C6000_BIOS6:default
04/18/2012 09:54:46AM - OMAP: TC_C6000_XDCTOOLS:default
04/18/2012 09:54:46AM - OMAP: TC_C6000_IPC:default
04/18/2012 09:54:46AM - OMAP: C6FLO:default
04/18/2012 09:54:46AM - OMAP: EMU_TI:mandatory
04/18/2012 09:54:46AM - OMAP: IDE:mandatory
04/18/2012 09:54:46AM - OMAP: CCSINIT:mandatory
04/18/2012 09:54:46AM - OMAP: DS:mandatory
04/18/2012 09:54:46AM - OMAP: DVT:mandatory
04/18/2012 09:54:46AM - OMAP: SIM_TI:default
04/18/2012 09:54:46AM - C5000 Ultra Low Power DSP: EMU_BH:default
04/18/2012 09:54:46AM - C5000 Ultra Low Power DSP: EMU_SD:default
04/18/2012 09:54:46AM - C5000 Ultra Low Power DSP: CGT_DEFAULTLIBS_C5500:default
04/18/2012 09:54:46AM - C5000 Ultra Low Power DSP: CGT_DEFAULTLIBS_C5400:default
04/18/2012 09:54:46AM - C5000 Ultra Low Power DSP: DMED:default
04/18/2012 09:54:46AM - C5000 Ultra Low Power DSP: TC_BIOS5:default
04/18/2012 09:54:46AM - C5000 Ultra Low Power DSP: TC_XDAIS_BIOS5:default
04/18/2012 09:54:46AM - C5000 Ultra Low Power DSP: TC_XDCTOOLS_BIOS5:default
04/18/2012 09:54:46AM - C5000 Ultra Low Power DSP: EMU_TI:mandatory
04/18/2012 09:54:46AM - C5000 Ultra Low Power DSP: IDE:mandatory
04/18/2012 09:54:46AM - C5000 Ultra Low Power DSP: CCSINIT:mandatory
04/18/2012 09:54:46AM - C5000 Ultra Low Power DSP: DS:mandatory
04/18/2012 09:54:46AM - C5000 Ultra Low Power DSP: DVT:mandatory
04/18/2012 09:54:46AM - C5000 Ultra Low Power DSP: SIM_TI:default
04/18/2012 09:54:46AM - Executing action E065533E-1E05-44C3-BB4D-F4D3CB0F8713 - Execute Setup Panes to Display
04/18/2012 09:54:46AM - Executing actions 3835C529-654B-4A82-B84B-B3A7CBEA79AB - Set Panes to Display
04/18/2012 09:54:46AM - Checking conditions for 3835C529-654B-4A82-B84B-B3A7CBEA79AB -  - Before Action is Executed
04/18/2012 09:54:46AM - Checking condition 15BC7606-F1AD-4573-8AA7-21FFCA15D5DB - String Is Condition
04/18/2012 09:54:46AM - Checking to see if <%UpdateMode%> is false
04/18/2012 09:54:46AM - ** Checking to see if 0 is false
04/18/2012 09:54:46AM - Condition passed
04/18/2012 09:54:46AM - Executing action 3835C529-654B-4A82-B84B-B3A7CBEA79AB - Set Panes to Display
04/18/2012 09:54:46AM - In Add Components:
04/18/2012 09:54:46AM - installed features =
04/18/2012 09:54:46AM - products installed:
04/18/2012 09:54:46AM - edition pane now: EMU
04/18/2012 09:54:46AM - Edition: Complete Feature Set EMU
04/18/2012 09:54:46AM - ISAs: false
04/18/2012 09:54:46AM - Features: false
04/18/2012 09:54:46AM - Emus: true
04/18/2012 09:54:46AM - selecting all isas - ShowISAs is false
04/18/2012 09:54:46AM - selecting MSP430 Low Power MCUs
04/18/2012 09:54:46AM - selecting C28x 32-bit Real-time MCUs
04/18/2012 09:54:46AM - selecting Stellaris Cortex M MCUs
04/18/2012 09:54:46AM - selecting Cortex-R4F MCUs
04/18/2012 09:54:46AM - selecting AMxx Cortex-A and ARM9 processors
04/18/2012 09:54:46AM - selecting C6x DSP + ARM processors
04/18/2012 09:54:46AM - selecting DaVinci Video Processors
04/18/2012 09:54:46AM - selecting C6000 Single Core DSPs
04/18/2012 09:54:46AM - selecting C6000 Multi Core DSPs
04/18/2012 09:54:46AM - selecting OMAP
04/18/2012 09:54:46AM - selecting C5000 Ultra Low Power DSP
04/18/2012 09:54:46AM - setting default and mandatory features on
04/18/2012 09:54:46AM - Checking sizes for MSP430 Low Power MCUs:
04/18/2012 09:54:46AM - Component = TC_BIOS6 TC_BIOS6:MSP430 Low Power MCUs def/mandatory = 1 ===================================
04/18/2012 09:54:46AM - TC_BIOS6 was not selected before - value now Selected_TC_BIOS61
04/18/2012 09:54:46AM - TC_BIOS6 was not offered before - value now 1
04/18/2012 09:54:46AM - Component = TC_XDCTOOLS TC_XDCTOOLS:MSP430 Low Power MCUs def/mandatory = 1 ===================================
04/18/2012 09:54:46AM - TC_XDCTOOLS was not selected before - value now Selected_TC_XDCTOOLS1
04/18/2012 09:54:46AM - TC_XDCTOOLS was not offered before - value now 1
04/18/2012 09:54:46AM - Component = DMED DMED:MSP430 Low Power MCUs def/mandatory = 1 ===================================
04/18/2012 09:54:46AM - DMED was not selected before - value now Selected_DMED1
04/18/2012 09:54:46AM - DMED was not offered before - value now 1
04/18/2012 09:54:46AM - Component = TC_MSP430_XDCTOOLS TC_MSP430_XDCTOOLS:MSP430 Low Power MCUs def/mandatory = 1 ===================================
04/18/2012 09:54:46AM - TC_MSP430_XDCTOOLS was not selected before - value now Selected_TC_MSP430_XDCTOOLS1
04/18/2012 09:54:46AM - TC_MSP430_XDCTOOLS was not offered before - value now 1
04/18/2012 09:54:46AM - Component = MSP430Ware MSP430Ware:MSP430 Low Power MCUs def/mandatory = 1 ===================================
04/18/2012 09:54:46AM - MSP430Ware was not selected before - value now Selected_MSP430Ware1
04/18/2012 09:54:46AM - MSP430Ware was not offered before - value now 1
04/18/2012 09:54:46AM - Component = CGT_DEFAULTLIBS_MSP430 CGT_DEFAULTLIBS_MSP430:MSP430 Low Power MCUs def/mandatory = 1 ===================================
04/18/2012 09:54:46AM - CGT_DEFAULTLIBS_MSP430 was not selected before - value now Selected_CGT_DEFAULTLIBS_MSP4301
04/18/2012 09:54:46AM - CGT_DEFAULTLIBS_MSP430 was not offered before - value now 1
04/18/2012 09:54:46AM - Component = IDE IDE:MSP430 Low Power MCUs def/mandatory = 2 ===================================
04/18/2012 09:54:46AM - IDE was not selected before - value now Selected_IDE1
04/18/2012 09:54:46AM - IDE was not offered before - value now 1
04/18/2012 09:54:46AM - Component = TC_IPC TC_IPC:MSP430 Low Power MCUs def/mandatory = 1 ===================================
04/18/2012 09:54:46AM - TC_IPC was not selected before - value now Selected_TC_IPC1
04/18/2012 09:54:46AM - TC_IPC was not offered before - value now 1
04/18/2012 09:54:46AM - Component = GRACE GRACE:MSP430 Low Power MCUs def/mandatory = 1 ===================================
04/18/2012 09:54:46AM - GRACE was not selected before - value now Selected_GRACE1
04/18/2012 09:54:46AM - GRACE was not offered before - value now 1
04/18/2012 09:54:46AM - Component = DS DS:MSP430 Low Power MCUs def/mandatory = 2 ===================================
04/18/2012 09:54:46AM - DS was not selected before - value now Selected_DS1
04/18/2012 09:54:46AM - DS was not offered before - value now 1
04/18/2012 09:54:46AM - Component = UIA UIA:MSP430 Low Power MCUs def/mandatory = 1 ===================================
04/18/2012 09:54:46AM - UIA was not selected before - value now Selected_UIA1
04/18/2012 09:54:46AM - UIA was not offered before - value now 1
04/18/2012 09:54:46AM - Component = EMU_MSP430 EMU_MSP430:MSP430 Low Power MCUs def/mandatory = 2 ===================================
04/18/2012 09:54:46AM - EMU_MSP430 was not selected before - value now Selected_EMU_MSP4301
04/18/2012 09:54:46AM - EMU_MSP430 was not offered before - value now 1
04/18/2012 09:54:46AM - Component = DVT_MIN DVT_MIN:MSP430 Low Power MCUs def/mandatory = 2 ===================================
04/18/2012 09:54:46AM - DVT_MIN was not selected before - value now Selected_DVT_MIN1
04/18/2012 09:54:46AM - DVT_MIN was not offered before - value now 1
04/18/2012 09:54:46AM - Component = TC_MSP430_IPC TC_MSP430_IPC:MSP430 Low Power MCUs def/mandatory = 1 ===================================
04/18/2012 09:54:46AM - TC_MSP430_IPC was not selected before - value now Selected_TC_MSP430_IPC1
04/18/2012 09:54:46AM - TC_MSP430_IPC was not offered before - value now 1
04/18/2012 09:54:46AM - Component = CCSINIT CCSINIT:MSP430 Low Power MCUs def/mandatory = 2 ===================================
04/18/2012 09:54:46AM - CCSINIT was not selected before - value now Selected_CCSINIT1
04/18/2012 09:54:46AM - CCSINIT was not offered before - value now 1
04/18/2012 09:54:46AM - Component = MSP430_CGT_HELP MSP430_CGT_HELP:MSP430 Low Power MCUs def/mandatory = 1 ===================================
04/18/2012 09:54:46AM - MSP430_CGT_HELP was not selected before - value now Selected_MSP430_CGT_HELP1
04/18/2012 09:54:46AM - MSP430_CGT_HELP was not offered before - value now 1
04/18/2012 09:54:46AM - Component = TC_MSP430_BIOS6 TC_MSP430_BIOS6:MSP430 Low Power MCUs def/mandatory = 1 ===================================
04/18/2012 09:54:46AM - TC_MSP430_BIOS6 was not selected before - value now Selected_TC_MSP430_BIOS61
04/18/2012 09:54:46AM - TC_MSP430_BIOS6 was not offered before - value now 1
04/18/2012 09:54:46AM - TI C2800 Compiler Tools CGT_DEFAULTLIBS_C2800
04/18/2012 09:54:46AM - BIOS 5 TC_BIOS5
04/18/2012 09:54:46AM - BIOS 6 TC_BIOS6
04/18/2012 09:54:46AM - Adding TC_BIOS6 23196499: new total 23196499
04/18/2012 09:54:46AM - C6000 BIOS6 TC_C6000_BIOS6
04/18/2012 09:54:46AM - TI MSP430 Compiler Tools CGT_DEFAULTLIBS_MSP430
04/18/2012 09:54:46AM - Adding CGT_DEFAULTLIBS_MSP430 20338099: new total 43534598
04/18/2012 09:54:46AM - Code Composer Plugins IDE
04/18/2012 09:54:46AM - Adding IDE 15711774: new total 59246372
04/18/2012 09:54:46AM - Spectrum Digital Emulators EMU_SD
04/18/2012 09:54:46AM - TI Simulators SIM_TI
04/18/2012 09:54:46AM - XDCTools TC_XDCTOOLS_BIOS5
04/18/2012 09:54:46AM - TI C5400 Compiler Tools CGT_DEFAULTLIBS_C5400
04/18/2012 09:54:46AM - MSP430 IPC TC_MSP430_IPC
04/18/2012 09:54:46AM - Adding TC_MSP430_IPC 2150909: new total 61397281
04/18/2012 09:54:46AM - Stellaris Emulators EMU_STELLARIS
04/18/2012 09:54:46AM - MSVC 2005 MSVC80
04/18/2012 09:54:46AM - TI ARM Compiler Tools CGT_DEFAULTLIBS_TMS470
04/18/2012 09:54:46AM - C6EZFlo C6FLO
04/18/2012 09:54:46AM - C6000 IPC TC_C6000_IPC
04/18/2012 09:54:46AM - IPC TC_IPC
04/18/2012 09:54:46AM - Adding TC_IPC 17305979: new total 78703260
04/18/2012 09:54:46AM - ARM XDCTools TC_ARM_XDCTOOLS
04/18/2012 09:54:46AM - Hercules Emulation EMU_HERCULES
04/18/2012 09:54:46AM - JRE JRE
04/18/2012 09:54:46AM - ARM IPC TC_ARM_IPC
04/18/2012 09:54:46AM - TI Emulators EMU_TI
04/18/2012 09:54:46AM - LightWeightInstaller INSTALL_JAR
04/18/2012 09:54:46AM - Keystone1 KEYSTONE1
04/18/2012 09:54:46AM - LWInstaller INSTALLER
04/18/2012 09:54:46AM - TI C5500 Compiler Tools CGT_DEFAULTLIBS_C5500
04/18/2012 09:54:46AM - CCS NowFlash Emulators EMU_NOWFLASH
04/18/2012 09:54:46AM - Grace GRACE
04/18/2012 09:54:46AM - Adding GRACE 21652625: new total 100355885
04/18/2012 09:54:46AM - Eclipse P2 Extensions P2TOOLS
04/18/2012 09:54:46AM - MSP430 XDCTools TC_MSP430_XDCTOOLS
04/18/2012 09:54:46AM - Adding TC_MSP430_XDCTOOLS 3299400: new total 103655285
04/18/2012 09:54:46AM - TI C6000 Compiler Tools CGT_DEFAULTLIBS_C6000
04/18/2012 09:54:46AM - Eclipse ECLIPSE
04/18/2012 09:54:46AM - MSP430 Emulators EMU_MSP430
04/18/2012 09:54:46AM - Adding EMU_MSP430 30049708: new total 133704993
04/18/2012 09:54:46AM - C2000 BIOS6 TC_C2000_BIOS6
04/18/2012 09:54:46AM - DVT DVT
04/18/2012 09:54:46AM - MSP430 BIOS6 TC_MSP430_BIOS6
04/18/2012 09:54:46AM - Adding TC_MSP430_BIOS6 8734432: new total 142439425
04/18/2012 09:54:46AM - DVT min DVT_MIN
04/18/2012 09:54:46AM - Adding DVT_MIN 25001089: new total 167440514
04/18/2012 09:54:46AM - C2000 IPC TC_C2000_IPC
04/18/2012 09:54:46AM - C2000 XDCTools TC_C2000_XDCTOOLS
04/18/2012 09:54:46AM - MSVC 2008  MSVC2008
04/18/2012 09:54:46AM - MSP430 Compiler Help MSP430_CGT_HELP
04/18/2012 09:54:46AM - Adding MSP430_CGT_HELP 18989015: new total 186429529
04/18/2012 09:54:46AM - Adding TC_XDCTOOLS 81351659: new total 267781188
04/18/2012 09:54:46AM - C6000 XDCTools TC_C6000_XDCTOOLS
04/18/2012 09:54:46AM - XDAIS TC_XDAIS
04/18/2012 09:54:46AM - Blackhawk Emulators EMU_BH
04/18/2012 09:54:46AM - Compiler Tools On-line Documentation DMED
04/18/2012 09:54:46AM - Adding DMED 1337117: new total 269118305
04/18/2012 09:54:46AM - MSI DLL MSI_DLL
04/18/2012 09:54:46AM - CCSINIT CCSINIT
04/18/2012 09:54:46AM - Adding CCSINIT 1331118: new total 270449423
04/18/2012 09:54:46AM - UIA UIA
04/18/2012 09:54:46AM - Adding UIA 16798858: new total 287248281
04/18/2012 09:54:46AM - Debug Server DS
04/18/2012 09:54:46AM - Adding DS 26562234: new total 313810515
04/18/2012 09:54:46AM - XDAIS TC_XDAIS_BIOS5
04/18/2012 09:54:46AM - C2000 Emulation Flash EMU_C2000_FLASH
04/18/2012 09:54:46AM - ARM BIOS6 TC_ARM_BIOS6
04/18/2012 09:54:46AM - C2000 Emulators EMU_C2000
04/18/2012 09:54:46AM - MSP430ware MSP430Ware
04/18/2012 09:54:46AM - Adding MSP430Ware 49015614: new total 362826129
04/18/2012 09:54:46AM - adding jre size
04/18/2012 09:54:46AM - adding eclipse size
04/18/2012 09:54:46AM - 485
04/18/2012 09:54:46AM - Checking sizes for C28x 32-bit Real-time MCUs:
04/18/2012 09:54:46AM - Component = TC_BIOS5 TC_BIOS5:C28x 32-bit Real-time MCUs def/mandatory = 1 ===================================
04/18/2012 09:54:46AM - TC_BIOS5 was not selected before - value now Selected_TC_BIOS51
04/18/2012 09:54:46AM - TC_BIOS5 was not offered before - value now 1
04/18/2012 09:54:46AM - Component = TC_C2000_XDCTOOLS TC_C2000_XDCTOOLS:C28x 32-bit Real-time MCUs def/mandatory = 1 ===================================
04/18/2012 09:54:46AM - TC_C2000_XDCTOOLS was not selected before - value now Selected_TC_C2000_XDCTOOLS1
04/18/2012 09:54:46AM - TC_C2000_XDCTOOLS was not offered before - value now 1
04/18/2012 09:54:46AM - Component = EMU_BH EMU_BH:C28x 32-bit Real-time MCUs def/mandatory = 1 ===================================
04/18/2012 09:54:46AM - EMU_BH was not selected before - value now Selected_EMU_BH1
04/18/2012 09:54:46AM - EMU_BH was not offered before - value now 1
04/18/2012 09:54:46AM - Component = TC_C2000_IPC TC_C2000_IPC:C28x 32-bit Real-time MCUs def/mandatory = 1 ===================================
04/18/2012 09:54:46AM - TC_C2000_IPC was not selected before - value now Selected_TC_C2000_IPC1
04/18/2012 09:54:46AM - TC_C2000_IPC was not offered before - value now 1
04/18/2012 09:54:46AM - Component = TC_IPC TC_IPC:C28x 32-bit Real-time MCUs def/mandatory = 1 ===================================
04/18/2012 09:54:46AM - TC_IPC was selected before - value now Selected_TC_IPC 2
04/18/2012 09:54:46AM - TC_IPC was offered before - value now 2
04/18/2012 09:54:46AM - Component = SIM_TI SIM_TI:C28x 32-bit Real-time MCUs def/mandatory = 1 ===================================
04/18/2012 09:54:46AM - SIM_TI was not selected before - value now Selected_SIM_TI1
04/18/2012 09:54:46AM - SIM_TI was not offered before - value now 1
04/18/2012 09:54:46AM - Component = EMU_SD EMU_SD:C28x 32-bit Real-time MCUs def/mandatory = 1 ===================================
04/18/2012 09:54:46AM - EMU_SD was not selected before - value now Selected_EMU_SD1
04/18/2012 09:54:46AM - EMU_SD was not offered before - value now 1
04/18/2012 09:54:46AM - Component = EMU_C2000 EMU_C2000:C28x 32-bit Real-time MCUs def/mandatory = 2 ===================================
04/18/2012 09:54:46AM - EMU_C2000 was not selected before - value now Selected_EMU_C20001
04/18/2012 09:54:46AM - EMU_C2000 was not offered before - value now 1
04/18/2012 09:54:46AM - Component = TC_C2000_BIOS6 TC_C2000_BIOS6:C28x 32-bit Real-time MCUs def/mandatory = 1 ===================================
04/18/2012 09:54:46AM - TC_C2000_BIOS6 was not selected before - value now Selected_TC_C2000_BIOS61
04/18/2012 09:54:46AM - TC_C2000_BIOS6 was not offered before - value now 1
04/18/2012 09:54:46AM - Component = DS DS:C28x 32-bit Real-time MCUs def/mandatory = 2 ===================================
04/18/2012 09:54:46AM - DS was selected before - value now Selected_DS 2
04/18/2012 09:54:46AM - DS was offered before - value now 2
04/18/2012 09:54:46AM - Component = UIA UIA:C28x 32-bit Real-time MCUs def/mandatory = 1 ===================================
04/18/2012 09:54:46AM - UIA was selected before - value now Selected_UIA 2
04/18/2012 09:54:46AM - UIA was offered before - value now 2
04/18/2012 09:54:46AM - Component = DMED DMED:C28x 32-bit Real-time MCUs def/mandatory = 1 ===================================
04/18/2012 09:54:46AM - DMED was selected before - value now Selected_DMED 2
04/18/2012 09:54:46AM - DMED was offered before - value now 2
04/18/2012 09:54:46AM - Component = CCSINIT CCSINIT:C28x 32-bit Real-time MCUs def/mandatory = 2 ===================================
04/18/2012 09:54:46AM - CCSINIT was selected before - value now Selected_CCSINIT 2
04/18/2012 09:54:46AM - CCSINIT was offered before - value now 2
04/18/2012 09:54:46AM - Component = TC_XDAIS_BIOS5 TC_XDAIS_BIOS5:C28x 32-bit Real-time MCUs def/mandatory = 1 ===================================
04/18/2012 09:54:46AM - TC_XDAIS_BIOS5 was not selected before - value now Selected_TC_XDAIS_BIOS51
04/18/2012 09:54:46AM - TC_XDAIS_BIOS5 was not offered before - value now 1
04/18/2012 09:54:46AM - Component = CGT_DEFAULTLIBS_C2800 CGT_DEFAULTLIBS_C2800:C28x 32-bit Real-time MCUs def/mandatory = 1 ===================================
04/18/2012 09:54:46AM - CGT_DEFAULTLIBS_C2800 was not selected before - value now Selected_CGT_DEFAULTLIBS_C28001
04/18/2012 09:54:46AM - CGT_DEFAULTLIBS_C2800 was not offered before - value now 1
04/18/2012 09:54:46AM - Component = TC_BIOS6 TC_BIOS6:C28x 32-bit Real-time MCUs def/mandatory = 1 ===================================
04/18/2012 09:54:46AM - TC_BIOS6 was selected before - value now Selected_TC_BIOS6 2
04/18/2012 09:54:46AM - TC_BIOS6 was offered before - value now 2
04/18/2012 09:54:46AM - Component = EMU_TI EMU_TI:C28x 32-bit Real-time MCUs def/mandatory = 2 ===================================
04/18/2012 09:54:46AM - EMU_TI was not selected before - value now Selected_EMU_TI1
04/18/2012 09:54:46AM - EMU_TI was not offered before - value now 1
04/18/2012 09:54:46AM - Component = DVT DVT:C28x 32-bit Real-time MCUs def/mandatory = 2 ===================================
04/18/2012 09:54:46AM - DVT was not selected before - value now Selected_DVT1
04/18/2012 09:54:46AM - DVT was not offered before - value now 1
04/18/2012 09:54:46AM - Component = EMU_C2000_FLASH EMU_C2000_FLASH:C28x 32-bit Real-time MCUs def/mandatory = 2 ===================================
04/18/2012 09:54:46AM - EMU_C2000_FLASH was not selected before - value now Selected_EMU_C2000_FLASH1
04/18/2012 09:54:46AM - EMU_C2000_FLASH was not offered before - value now 1
04/18/2012 09:54:46AM - Component = TC_XDCTOOLS TC_XDCTOOLS:C28x 32-bit Real-time MCUs def/mandatory = 1 ===================================
04/18/2012 09:54:46AM - TC_XDCTOOLS was selected before - value now Selected_TC_XDCTOOLS 2
04/18/2012 09:54:46AM - TC_XDCTOOLS was offered before - value now 2
04/18/2012 09:54:46AM - Component = TC_XDAIS TC_XDAIS:C28x 32-bit Real-time MCUs def/mandatory = 1 ===================================
04/18/2012 09:54:46AM - TC_XDAIS was not selected before - value now Selected_TC_XDAIS1
04/18/2012 09:54:46AM - TC_XDAIS was not offered before - value now 1
04/18/2012 09:54:46AM - Component = EMU_NOWFLASH EMU_NOWFLASH:C28x 32-bit Real-time MCUs def/mandatory = 2 ===================================
04/18/2012 09:54:46AM - EMU_NOWFLASH was not selected before - value now Selected_EMU_NOWFLASH1
04/18/2012 09:54:46AM - EMU_NOWFLASH was not offered before - value now 1
04/18/2012 09:54:46AM - Component = TC_XDCTOOLS_BIOS5 TC_XDCTOOLS_BIOS5:C28x 32-bit Real-time MCUs def/mandatory = 1 ===================================
04/18/2012 09:54:46AM - TC_XDCTOOLS_BIOS5 was not selected before - value now Selected_TC_XDCTOOLS_BIOS51
04/18/2012 09:54:46AM - TC_XDCTOOLS_BIOS5 was not offered before - value now 1
04/18/2012 09:54:46AM - Component = IDE IDE:C28x 32-bit Real-time MCUs def/mandatory = 2 ===================================
04/18/2012 09:54:46AM - IDE was selected before - value now Selected_IDE 2
04/18/2012 09:54:46AM - IDE was offered before - value now 2
04/18/2012 09:54:46AM - Adding CGT_DEFAULTLIBS_C2800 21474129: new total 21474129
04/18/2012 09:54:46AM - Adding TC_BIOS5 47741693: new total 69215822
04/18/2012 09:54:46AM - Adding TC_BIOS6 23196499: new total 92412321
04/18/2012 09:54:46AM - Adding CGT_DEFAULTLIBS_MSP430 20338099: new total 112750420
04/18/2012 09:54:46AM - Adding IDE 15711774: new total 128462194
04/18/2012 09:54:46AM - Adding EMU_SD 27415818: new total 155878012
04/18/2012 09:54:46AM - Adding SIM_TI 36678204: new total 192556216
04/18/2012 09:54:46AM - Adding TC_XDCTOOLS_BIOS5 81351659: new total 273907875
04/18/2012 09:54:46AM - Adding TC_MSP430_IPC 2150909: new total 276058784
04/18/2012 09:54:46AM - Adding TC_IPC 17305979: new total 293364763
04/18/2012 09:54:46AM - Adding EMU_TI 34684346: new total 328049109
04/18/2012 09:54:46AM - Adding EMU_NOWFLASH 3656983: new total 331706092
04/18/2012 09:54:46AM - Adding GRACE 21652625: new total 353358717
04/18/2012 09:54:46AM - Adding TC_MSP430_XDCTOOLS 3299400: new total 356658117
04/18/2012 09:54:46AM - Adding EMU_MSP430 30049708: new total 386707825
04/18/2012 09:54:46AM - Adding TC_C2000_BIOS6 8938407: new total 395646232
04/18/2012 09:54:46AM - Adding DVT 33189220: new total 428835452
04/18/2012 09:54:46AM - Adding TC_MSP430_BIOS6 8734432: new total 437569884
04/18/2012 09:54:46AM - Adding DVT_MIN 25001089: new total 462570973
04/18/2012 09:54:46AM - Adding TC_C2000_IPC 7295951: new total 469866924
04/18/2012 09:54:46AM - Adding TC_C2000_XDCTOOLS 3354908: new total 473221832
04/18/2012 09:54:46AM - Adding MSP430_CGT_HELP 18989015: new total 492210847
04/18/2012 09:54:46AM - Adding TC_XDCTOOLS 81351659: new total 573562506
04/18/2012 09:54:46AM - Adding TC_XDAIS 8492292: new total 582054798
04/18/2012 09:54:46AM - Adding EMU_BH 37362701: new total 619417499
04/18/2012 09:54:46AM - Adding DMED 1337117: new total 620754616
04/18/2012 09:54:46AM - Adding CCSINIT 1331118: new total 622085734
04/18/2012 09:54:46AM - Adding UIA 16798858: new total 638884592
04/18/2012 09:54:46AM - Adding DS 26562234: new total 665446826
04/18/2012 09:54:46AM - Adding TC_XDAIS_BIOS5 8492292: new total 673939118
04/18/2012 09:54:46AM - Adding EMU_C2000_FLASH 1671961: new total 675611079
04/18/2012 09:54:46AM - Adding EMU_C2000 2324056: new total 677935135
04/18/2012 09:54:46AM - Adding MSP430Ware 49015614: new total 726950749
04/18/2012 09:54:46AM - 832
04/18/2012 09:54:46AM - Checking sizes for Stellaris Cortex M MCUs:
04/18/2012 09:54:46AM - Component = EMU_TI EMU_TI:Stellaris Cortex M MCUs def/mandatory = 2 ===================================
04/18/2012 09:54:46AM - EMU_TI was selected before - value now Selected_EMU_TI 2
04/18/2012 09:54:46AM - EMU_TI was offered before - value now 2
04/18/2012 09:54:46AM - Component = EMU_BH EMU_BH:Stellaris Cortex M MCUs def/mandatory = 1 ===================================
04/18/2012 09:54:46AM - EMU_BH was selected before - value now Selected_EMU_BH 2
04/18/2012 09:54:46AM - EMU_BH was offered before - value now 2
04/18/2012 09:54:46AM - Component = CCSINIT CCSINIT:Stellaris Cortex M MCUs def/mandatory = 2 ===================================
04/18/2012 09:54:46AM - CCSINIT was selected before - value now Selected_CCSINIT 3
04/18/2012 09:54:46AM - CCSINIT was offered before - value now 3
04/18/2012 09:54:46AM - Component = TC_BIOS6 TC_BIOS6:Stellaris Cortex M MCUs def/mandatory = 1 ===================================
04/18/2012 09:54:46AM - TC_BIOS6 was selected before - value now Selected_TC_BIOS6 3
04/18/2012 09:54:46AM - TC_BIOS6 was offered before - value now 3
04/18/2012 09:54:46AM - Component = EMU_STELLARIS EMU_STELLARIS:Stellaris Cortex M MCUs def/mandatory = 2 ===================================
04/18/2012 09:54:46AM - EMU_STELLARIS was not selected before - value now Selected_EMU_STELLARIS1
04/18/2012 09:54:46AM - EMU_STELLARIS was not offered before - value now 1
04/18/2012 09:54:46AM - Component = CGT_DEFAULTLIBS_TMS470 CGT_DEFAULTLIBS_TMS470:Stellaris Cortex M MCUs def/mandatory = 1 ===================================
04/18/2012 09:54:46AM - CGT_DEFAULTLIBS_TMS470 was not selected before - value now Selected_CGT_DEFAULTLIBS_TMS4701
04/18/2012 09:54:46AM - CGT_DEFAULTLIBS_TMS470 was not offered before - value now 1
04/18/2012 09:54:46AM - Component = TC_IPC TC_IPC:Stellaris Cortex M MCUs def/mandatory = 1 ===================================
04/18/2012 09:54:46AM - TC_IPC was selected before - value now Selected_TC_IPC 3
04/18/2012 09:54:46AM - TC_IPC was offered before - value now 3
04/18/2012 09:54:46AM - Component = TC_ARM_XDCTOOLS TC_ARM_XDCTOOLS:Stellaris Cortex M MCUs def/mandatory = 1 ===================================
04/18/2012 09:54:46AM - TC_ARM_XDCTOOLS was not selected before - value now Selected_TC_ARM_XDCTOOLS1
04/18/2012 09:54:46AM - TC_ARM_XDCTOOLS was not offered before - value now 1
04/18/2012 09:54:46AM - Component = TC_XDCTOOLS TC_XDCTOOLS:Stellaris Cortex M MCUs def/mandatory = 1 ===================================
04/18/2012 09:54:46AM - TC_XDCTOOLS was selected before - value now Selected_TC_XDCTOOLS 3
04/18/2012 09:54:46AM - TC_XDCTOOLS was offered before - value now 3
04/18/2012 09:54:46AM - Component = UIA UIA:Stellaris Cortex M MCUs def/mandatory = 1 ===================================
04/18/2012 09:54:46AM - UIA was selected before - value now Selected_UIA 3
04/18/2012 09:54:46AM - UIA was offered before - value now 3
04/18/2012 09:54:46AM - Component = DS DS:Stellaris Cortex M MCUs def/mandatory = 2 ===================================
04/18/2012 09:54:46AM - DS was selected before - value now Selected_DS 3
04/18/2012 09:54:46AM - DS was offered before - value now 3
04/18/2012 09:54:46AM - Component = EMU_SD EMU_SD:Stellaris Cortex M MCUs def/mandatory = 1 ===================================
04/18/2012 09:54:46AM - EMU_SD was selected before - value now Selected_EMU_SD 2
04/18/2012 09:54:46AM - EMU_SD was offered before - value now 2
04/18/2012 09:54:46AM - Component = SIM_TI SIM_TI:Stellaris Cortex M MCUs def/mandatory = 1 ===================================
04/18/2012 09:54:46AM - SIM_TI was selected before - value now Selected_SIM_TI 2
04/18/2012 09:54:46AM - SIM_TI was offered before - value now 2
04/18/2012 09:54:46AM - Component = TC_ARM_IPC TC_ARM_IPC:Stellaris Cortex M MCUs def/mandatory = 1 ===================================
04/18/2012 09:54:46AM - TC_ARM_IPC was not selected before - value now Selected_TC_ARM_IPC1
04/18/2012 09:54:46AM - TC_ARM_IPC was not offered before - value now 1
04/18/2012 09:54:46AM - Component = TC_XDAIS TC_XDAIS:Stellaris Cortex M MCUs def/mandatory = 1 ===================================
04/18/2012 09:54:46AM - TC_XDAIS was selected before - value now Selected_TC_XDAIS 2
04/18/2012 09:54:46AM - TC_XDAIS was offered before - value now 2
04/18/2012 09:54:46AM - Component = DMED DMED:Stellaris Cortex M MCUs def/mandatory = 1 ===================================
04/18/2012 09:54:46AM - DMED was selected before - value now Selected_DMED 3
04/18/2012 09:54:46AM - DMED was offered before - value now 3
04/18/2012 09:54:46AM - Component = TC_ARM_BIOS6 TC_ARM_BIOS6:Stellaris Cortex M MCUs def/mandatory = 1 ===================================
04/18/2012 09:54:46AM - TC_ARM_BIOS6 was not selected before - value now Selected_TC_ARM_BIOS61
04/18/2012 09:54:46AM - TC_ARM_BIOS6 was not offered before - value now 1
04/18/2012 09:54:46AM - Component = IDE IDE:Stellaris Cortex M MCUs def/mandatory = 2 ===================================
04/18/2012 09:54:46AM - IDE was selected before - value now Selected_IDE 3
04/18/2012 09:54:46AM - IDE was offered before - value now 3
04/18/2012 09:54:46AM - Component = DVT DVT:Stellaris Cortex M MCUs def/mandatory = 2 ===================================
04/18/2012 09:54:46AM - DVT was selected before - value now Selected_DVT 2
04/18/2012 09:54:46AM - DVT was offered before - value now 2
04/18/2012 09:54:46AM - Adding EMU_STELLARIS 17515986: new total 293574770
04/18/2012 09:54:46AM - Adding CGT_DEFAULTLIBS_TMS470 44488244: new total 338063014
04/18/2012 09:54:46AM - Adding TC_IPC 17305979: new total 355368993
04/18/2012 09:54:46AM - Adding TC_ARM_XDCTOOLS 26837137: new total 382206130
04/18/2012 09:54:46AM - Adding TC_ARM_IPC 17625522: new total 399831652
04/18/2012 09:54:46AM - Adding EMU_TI 34684346: new total 434515998
04/18/2012 09:54:46AM - Adding EMU_NOWFLASH 3656983: new total 438172981
04/18/2012 09:54:46AM - Adding GRACE 21652625: new total 459825606
04/18/2012 09:54:46AM - Adding TC_MSP430_XDCTOOLS 3299400: new total 463125006
04/18/2012 09:54:46AM - Adding EMU_MSP430 30049708: new total 493174714
04/18/2012 09:54:46AM - Adding TC_C2000_BIOS6 8938407: new total 502113121
04/18/2012 09:54:46AM - Adding DVT 33189220: new total 535302341
04/18/2012 09:54:46AM - Adding TC_MSP430_BIOS6 8734432: new total 544036773
04/18/2012 09:54:46AM - Adding DVT_MIN 25001089: new total 569037862
04/18/2012 09:54:46AM - Adding TC_C2000_IPC 7295951: new total 576333813
04/18/2012 09:54:46AM - Adding TC_C2000_XDCTOOLS 3354908: new total 579688721
04/18/2012 09:54:46AM - Adding MSP430_CGT_HELP 18989015: new total 598677736
04/18/2012 09:54:46AM - Adding TC_XDCTOOLS 81351659: new total 680029395
04/18/2012 09:54:46AM - Adding TC_XDAIS 8492292: new total 688521687
04/18/2012 09:54:46AM - Adding EMU_BH 37362701: new total 725884388
04/18/2012 09:54:46AM - Adding DMED 1337117: new total 727221505
04/18/2012 09:54:46AM - Adding CCSINIT 1331118: new total 728552623
04/18/2012 09:54:46AM - Adding UIA 16798858: new total 745351481
04/18/2012 09:54:46AM - Adding DS 26562234: new total 771913715
04/18/2012 09:54:46AM - Adding TC_XDAIS_BIOS5 8492292: new total 780406007
04/18/2012 09:54:46AM - Adding EMU_C2000_FLASH 1671961: new total 782077968
04/18/2012 09:54:46AM - Adding TC_ARM_BIOS6 25714004: new total 807791972
04/18/2012 09:54:46AM - Adding EMU_C2000 2324056: new total 810116028
04/18/2012 09:54:46AM - Adding MSP430Ware 49015614: new total 859131642
04/18/2012 09:54:46AM - 958
04/18/2012 09:54:46AM - Checking sizes for Cortex-R4F MCUs:
04/18/2012 09:54:46AM - Component = UIA UIA:Cortex-R4F MCUs def/mandatory = 1 ===================================
04/18/2012 09:54:46AM - UIA was selected before - value now Selected_UIA 4
04/18/2012 09:54:46AM - UIA was offered before - value now 4
04/18/2012 09:54:46AM - Component = DS DS:Cortex-R4F MCUs def/mandatory = 2 ===================================
04/18/2012 09:54:46AM - DS was selected before - value now Selected_DS 4
04/18/2012 09:54:46AM - DS was offered before - value now 4
04/18/2012 09:54:46AM - Component = TC_ARM_BIOS6 TC_ARM_BIOS6:Cortex-R4F MCUs def/mandatory = 1 ===================================
04/18/2012 09:54:46AM - TC_ARM_BIOS6 was selected before - value now Selected_TC_ARM_BIOS6 2
04/18/2012 09:54:46AM - TC_ARM_BIOS6 was offered before - value now 2
04/18/2012 09:54:46AM - Component = CGT_DEFAULTLIBS_TMS470 CGT_DEFAULTLIBS_TMS470:Cortex-R4F MCUs def/mandatory = 1 ===================================
04/18/2012 09:54:46AM - CGT_DEFAULTLIBS_TMS470 was selected before - value now Selected_CGT_DEFAULTLIBS_TMS470 2
04/18/2012 09:54:46AM - CGT_DEFAULTLIBS_TMS470 was offered before - value now 2
04/18/2012 09:54:46AM - Component = TC_IPC TC_IPC:Cortex-R4F MCUs def/mandatory = 1 ===================================
04/18/2012 09:54:46AM - TC_IPC was selected before - value now Selected_TC_IPC 4
04/18/2012 09:54:46AM - TC_IPC was offered before - value now 4
04/18/2012 09:54:46AM - Component = EMU_HERCULES EMU_HERCULES:Cortex-R4F MCUs def/mandatory = 2 ===================================
04/18/2012 09:54:46AM - EMU_HERCULES was not selected before - value now Selected_EMU_HERCULES1
04/18/2012 09:54:46AM - EMU_HERCULES was not offered before - value now 1
04/18/2012 09:54:46AM - Component = TC_XDCTOOLS TC_XDCTOOLS:Cortex-R4F MCUs def/mandatory = 1 ===================================
04/18/2012 09:54:46AM - TC_XDCTOOLS was selected before - value now Selected_TC_XDCTOOLS 4
04/18/2012 09:54:46AM - TC_XDCTOOLS was offered before - value now 4
04/18/2012 09:54:46AM - Component = TC_XDAIS TC_XDAIS:Cortex-R4F MCUs def/mandatory = 1 ===================================
04/18/2012 09:54:46AM - TC_XDAIS was selected before - value now Selected_TC_XDAIS 3
04/18/2012 09:54:46AM - TC_XDAIS was offered before - value now 3
04/18/2012 09:54:46AM - Component = CCSINIT CCSINIT:Cortex-R4F MCUs def/mandatory = 2 ===================================
04/18/2012 09:54:46AM - CCSINIT was selected before - value now Selected_CCSINIT 4
04/18/2012 09:54:46AM - CCSINIT was offered before - value now 4
04/18/2012 09:54:46AM - Component = TC_BIOS6 TC_BIOS6:Cortex-R4F MCUs def/mandatory = 1 ===================================
04/18/2012 09:54:46AM - TC_BIOS6 was selected before - value now Selected_TC_BIOS6 4
04/18/2012 09:54:46AM - TC_BIOS6 was offered before - value now 4
04/18/2012 09:54:46AM - Component = TC_ARM_XDCTOOLS TC_ARM_XDCTOOLS:Cortex-R4F MCUs def/mandatory = 1 ===================================
04/18/2012 09:54:46AM - TC_ARM_XDCTOOLS was selected before - value now Selected_TC_ARM_XDCTOOLS 2
04/18/2012 09:54:46AM - TC_ARM_XDCTOOLS was offered before - value now 2
04/18/2012 09:54:46AM - Component = EMU_NOWFLASH EMU_NOWFLASH:Cortex-R4F MCUs def/mandatory = 2 ===================================
04/18/2012 09:54:46AM - EMU_NOWFLASH was selected before - value now Selected_EMU_NOWFLASH 2
04/18/2012 09:54:46AM - EMU_NOWFLASH was offered before - value now 2
04/18/2012 09:54:46AM - Component = EMU_BH EMU_BH:Cortex-R4F MCUs def/mandatory = 1 ===================================
04/18/2012 09:54:46AM - EMU_BH was selected before - value now Selected_EMU_BH 3
04/18/2012 09:54:46AM - EMU_BH was offered before - value now 3
04/18/2012 09:54:46AM - Component = DMED DMED:Cortex-R4F MCUs def/mandatory = 1 ===================================
04/18/2012 09:54:46AM - DMED was selected before - value now Selected_DMED 4
04/18/2012 09:54:46AM - DMED was offered before - value now 4
04/18/2012 09:54:46AM - Component = IDE IDE:Cortex-R4F MCUs def/mandatory = 2 ===================================
04/18/2012 09:54:46AM - IDE was selected before - value now Selected_IDE 4
04/18/2012 09:54:46AM - IDE was offered before - value now 4
04/18/2012 09:54:46AM - Component = SIM_TI SIM_TI:Cortex-R4F MCUs def/mandatory = 1 ===================================
04/18/2012 09:54:46AM - SIM_TI was selected before - value now Selected_SIM_TI 3
04/18/2012 09:54:46AM - SIM_TI was offered before - value now 3
04/18/2012 09:54:46AM - Component = EMU_SD EMU_SD:Cortex-R4F MCUs def/mandatory = 1 ===================================
04/18/2012 09:54:46AM - EMU_SD was selected before - value now Selected_EMU_SD 3
04/18/2012 09:54:46AM - EMU_SD was offered before - value now 3
04/18/2012 09:54:46AM - Component = TC_ARM_IPC TC_ARM_IPC:Cortex-R4F MCUs def/mandatory = 1 ===================================
04/18/2012 09:54:46AM - TC_ARM_IPC was selected before - value now Selected_TC_ARM_IPC 2
04/18/2012 09:54:46AM - TC_ARM_IPC was offered before - value now 2
04/18/2012 09:54:46AM - Component = EMU_TI EMU_TI:Cortex-R4F MCUs def/mandatory = 2 ===================================
04/18/2012 09:54:46AM - EMU_TI was selected before - value now Selected_EMU_TI 3
04/18/2012 09:54:46AM - EMU_TI was offered before - value now 3
04/18/2012 09:54:46AM - Component = DVT DVT:Cortex-R4F MCUs def/mandatory = 2 ===================================
04/18/2012 09:54:46AM - DVT was selected before - value now Selected_DVT 3
04/18/2012 09:54:46AM - DVT was offered before - value now 3
04/18/2012 09:54:46AM - Adding EMU_HERCULES 1559927: new total 383766057
04/18/2012 09:54:46AM - Adding TC_ARM_IPC 17625522: new total 401391579
04/18/2012 09:54:46AM - Adding EMU_TI 34684346: new total 436075925
04/18/2012 09:54:46AM - Adding EMU_NOWFLASH 3656983: new total 439732908
04/18/2012 09:54:46AM - Adding GRACE 21652625: new total 461385533
04/18/2012 09:54:46AM - Adding TC_MSP430_XDCTOOLS 3299400: new total 464684933
04/18/2012 09:54:46AM - Adding EMU_MSP430 30049708: new total 494734641
04/18/2012 09:54:46AM - Adding TC_C2000_BIOS6 8938407: new total 503673048
04/18/2012 09:54:46AM - Adding DVT 33189220: new total 536862268
04/18/2012 09:54:46AM - Adding TC_MSP430_BIOS6 8734432: new total 545596700
04/18/2012 09:54:46AM - Adding DVT_MIN 25001089: new total 570597789
04/18/2012 09:54:46AM - Adding TC_C2000_IPC 7295951: new total 577893740
04/18/2012 09:54:46AM - Adding TC_C2000_XDCTOOLS 3354908: new total 581248648
04/18/2012 09:54:46AM - Adding MSP430_CGT_HELP 18989015: new total 600237663
04/18/2012 09:54:46AM - Adding TC_XDCTOOLS 81351659: new total 681589322
04/18/2012 09:54:46AM - Adding TC_XDAIS 8492292: new total 690081614
04/18/2012 09:54:46AM - Adding EMU_BH 37362701: new total 727444315
04/18/2012 09:54:46AM - Adding DMED 1337117: new total 728781432
04/18/2012 09:54:46AM - Adding CCSINIT 1331118: new total 730112550
04/18/2012 09:54:46AM - Adding UIA 16798858: new total 746911408
04/18/2012 09:54:46AM - Adding DS 26562234: new total 773473642
04/18/2012 09:54:46AM - Adding TC_XDAIS_BIOS5 8492292: new total 781965934
04/18/2012 09:54:46AM - Adding EMU_C2000_FLASH 1671961: new total 783637895
04/18/2012 09:54:46AM - Adding TC_ARM_BIOS6 25714004: new total 809351899
04/18/2012 09:54:46AM - Adding EMU_C2000 2324056: new total 811675955
04/18/2012 09:54:46AM - Adding MSP430Ware 49015614: new total 860691569
04/18/2012 09:54:46AM - 960
04/18/2012 09:54:46AM - Checking sizes for AMxx Cortex-A and ARM9 processors:
04/18/2012 09:54:46AM - Component = IDE IDE:AMxx Cortex-A and ARM9 processors def/mandatory = 2 ===================================
04/18/2012 09:54:46AM - IDE was selected before - value now Selected_IDE 5
04/18/2012 09:54:46AM - IDE was offered before - value now 5
04/18/2012 09:54:46AM - Component = TC_IPC TC_IPC:AMxx Cortex-A and ARM9 processors def/mandatory = 1 ===================================
04/18/2012 09:54:46AM - TC_IPC was selected before - value now Selected_TC_IPC 5
04/18/2012 09:54:46AM - TC_IPC was offered before - value now 5
04/18/2012 09:54:46AM - Component = CGT_DEFAULTLIBS_TMS470 CGT_DEFAULTLIBS_TMS470:AMxx Cortex-A and ARM9 processors def/mandatory = 1 ===================================
04/18/2012 09:54:46AM - CGT_DEFAULTLIBS_TMS470 was selected before - value now Selected_CGT_DEFAULTLIBS_TMS470 3
04/18/2012 09:54:46AM - CGT_DEFAULTLIBS_TMS470 was offered before - value now 3
04/18/2012 09:54:46AM - Component = CCSINIT CCSINIT:AMxx Cortex-A and ARM9 processors def/mandatory = 2 ===================================
04/18/2012 09:54:46AM - CCSINIT was selected before - value now Selected_CCSINIT 5
04/18/2012 09:54:46AM - CCSINIT was offered before - value now 5
04/18/2012 09:54:46AM - Component = TC_XDAIS TC_XDAIS:AMxx Cortex-A and ARM9 processors def/mandatory = 1 ===================================
04/18/2012 09:54:46AM - TC_XDAIS was selected before - value now Selected_TC_XDAIS 4
04/18/2012 09:54:46AM - TC_XDAIS was offered before - value now 4
04/18/2012 09:54:46AM - Component = TC_ARM_IPC TC_ARM_IPC:AMxx Cortex-A and ARM9 processors def/mandatory = 1 ===================================
04/18/2012 09:54:46AM - TC_ARM_IPC was selected before - value now Selected_TC_ARM_IPC 3
04/18/2012 09:54:46AM - TC_ARM_IPC was offered before - value now 3
04/18/2012 09:54:46AM - Component = EMU_BH EMU_BH:AMxx Cortex-A and ARM9 processors def/mandatory = 1 ===================================
04/18/2012 09:54:46AM - EMU_BH was selected before - value now Selected_EMU_BH 4
04/18/2012 09:54:46AM - EMU_BH was offered before - value now 4
04/18/2012 09:54:46AM - Component = TC_XDAIS_BIOS5 TC_XDAIS_BIOS5:AMxx Cortex-A and ARM9 processors def/mandatory = 1 ===================================
04/18/2012 09:54:46AM - TC_XDAIS_BIOS5 was selected before - value now Selected_TC_XDAIS_BIOS5 2
04/18/2012 09:54:46AM - TC_XDAIS_BIOS5 was offered before - value now 2
04/18/2012 09:54:46AM - Component = TC_ARM_BIOS6 TC_ARM_BIOS6:AMxx Cortex-A and ARM9 processors def/mandatory = 1 ===================================
04/18/2012 09:54:46AM - TC_ARM_BIOS6 was selected before - value now Selected_TC_ARM_BIOS6 3
04/18/2012 09:54:46AM - TC_ARM_BIOS6 was offered before - value now 3
04/18/2012 09:54:46AM - Component = TC_XDCTOOLS TC_XDCTOOLS:AMxx Cortex-A and ARM9 processors def/mandatory = 1 ===================================
04/18/2012 09:54:46AM - TC_XDCTOOLS was selected before - value now Selected_TC_XDCTOOLS 5
04/18/2012 09:54:46AM - TC_XDCTOOLS was offered before - value now 5
04/18/2012 09:54:46AM - Component = EMU_SD EMU_SD:AMxx Cortex-A and ARM9 processors def/mandatory = 1 ===================================
04/18/2012 09:54:46AM - EMU_SD was selected before - value now Selected_EMU_SD 4
04/18/2012 09:54:46AM - EMU_SD was offered before - value now 4
04/18/2012 09:54:46AM - Component = SIM_TI SIM_TI:AMxx Cortex-A and ARM9 processors def/mandatory = 1 ===================================
04/18/2012 09:54:46AM - SIM_TI was selected before - value now Selected_SIM_TI 4
04/18/2012 09:54:46AM - SIM_TI was offered before - value now 4
04/18/2012 09:54:46AM - Component = UIA UIA:AMxx Cortex-A and ARM9 processors def/mandatory = 1 ===================================
04/18/2012 09:54:46AM - UIA was selected before - value now Selected_UIA 5
04/18/2012 09:54:46AM - UIA was offered before - value now 5
04/18/2012 09:54:46AM - Component = DS DS:AMxx Cortex-A and ARM9 processors def/mandatory = 2 ===================================
04/18/2012 09:54:46AM - DS was selected before - value now Selected_DS 5
04/18/2012 09:54:46AM - DS was offered before - value now 5
04/18/2012 09:54:46AM - Component = TC_XDCTOOLS_BIOS5 TC_XDCTOOLS_BIOS5:AMxx Cortex-A and ARM9 processors def/mandatory = 1 ===================================
04/18/2012 09:54:46AM - TC_XDCTOOLS_BIOS5 was selected before - value now Selected_TC_XDCTOOLS_BIOS5 2
04/18/2012 09:54:46AM - TC_XDCTOOLS_BIOS5 was offered before - value now 2
04/18/2012 09:54:46AM - Component = TC_BIOS5 TC_BIOS5:AMxx Cortex-A and ARM9 processors def/mandatory = 1 ===================================
04/18/2012 09:54:46AM - TC_BIOS5 was selected before - value now Selected_TC_BIOS5 2
04/18/2012 09:54:46AM - TC_BIOS5 was offered before - value now 2
04/18/2012 09:54:46AM - Component = TC_ARM_XDCTOOLS TC_ARM_XDCTOOLS:AMxx Cortex-A and ARM9 processors def/mandatory = 1 ===================================
04/18/2012 09:54:46AM - TC_ARM_XDCTOOLS was selected before - value now Selected_TC_ARM_XDCTOOLS 3
04/18/2012 09:54:46AM - TC_ARM_XDCTOOLS was offered before - value now 3
04/18/2012 09:54:46AM - Component = DVT DVT:AMxx Cortex-A and ARM9 processors def/mandatory = 2 ===================================
04/18/2012 09:54:46AM - DVT was selected before - value now Selected_DVT 4
04/18/2012 09:54:46AM - DVT was offered before - value now 4
04/18/2012 09:54:46AM - Component = EMU_TI EMU_TI:AMxx Cortex-A and ARM9 processors def/mandatory = 2 ===================================
04/18/2012 09:54:46AM - EMU_TI was selected before - value now Selected_EMU_TI 4
04/18/2012 09:54:46AM - EMU_TI was offered before - value now 4
04/18/2012 09:54:46AM - Component = TC_BIOS6 TC_BIOS6:AMxx Cortex-A and ARM9 processors def/mandatory = 1 ===================================
04/18/2012 09:54:46AM - TC_BIOS6 was selected before - value now Selected_TC_BIOS6 5
04/18/2012 09:54:46AM - TC_BIOS6 was offered before - value now 5
04/18/2012 09:54:46AM - Component = DMED DMED:AMxx Cortex-A and ARM9 processors def/mandatory = 1 ===================================
04/18/2012 09:54:46AM - DMED was selected before - value now Selected_DMED 5
04/18/2012 09:54:46AM - DMED was offered before - value now 5
04/18/2012 09:54:46AM - Checking sizes for C6x DSP + ARM processors:
04/18/2012 09:54:46AM - Component = TC_ARM_BIOS6 TC_ARM_BIOS6:C6x DSP + ARM processors def/mandatory = 1 ===================================
04/18/2012 09:54:46AM - TC_ARM_BIOS6 was selected before - value now Selected_TC_ARM_BIOS6 4
04/18/2012 09:54:46AM - TC_ARM_BIOS6 was offered before - value now 4
04/18/2012 09:54:46AM - Component = TC_XDAIS_BIOS5 TC_XDAIS_BIOS5:C6x DSP + ARM processors def/mandatory = 1 ===================================
04/18/2012 09:54:46AM - TC_XDAIS_BIOS5 was selected before - value now Selected_TC_XDAIS_BIOS5 3
04/18/2012 09:54:46AM - TC_XDAIS_BIOS5 was offered before - value now 3
04/18/2012 09:54:46AM - Component = TC_BIOS5 TC_BIOS5:C6x DSP + ARM processors def/mandatory = 1 ===================================
04/18/2012 09:54:46AM - TC_BIOS5 was selected before - value now Selected_TC_BIOS5 3
04/18/2012 09:54:46AM - TC_BIOS5 was offered before - value now 3
04/18/2012 09:54:46AM - Component = TC_C6000_BIOS6 TC_C6000_BIOS6:C6x DSP + ARM processors def/mandatory = 1 ===================================
04/18/2012 09:54:46AM - TC_C6000_BIOS6 was not selected before - value now Selected_TC_C6000_BIOS61
04/18/2012 09:54:46AM - TC_C6000_BIOS6 was not offered before - value now 1
04/18/2012 09:54:46AM - Component = TC_IPC TC_IPC:C6x DSP + ARM processors def/mandatory = 1 ===================================
04/18/2012 09:54:46AM - TC_IPC was selected before - value now Selected_TC_IPC 6
04/18/2012 09:54:46AM - TC_IPC was offered before - value now 6
04/18/2012 09:54:46AM - Component = CGT_DEFAULTLIBS_TMS470 CGT_DEFAULTLIBS_TMS470:C6x DSP + ARM processors def/mandatory = 1 ===================================
04/18/2012 09:54:46AM - CGT_DEFAULTLIBS_TMS470 was selected before - value now Selected_CGT_DEFAULTLIBS_TMS470 4
04/18/2012 09:54:46AM - CGT_DEFAULTLIBS_TMS470 was offered before - value now 4
04/18/2012 09:54:46AM - Component = EMU_TI EMU_TI:C6x DSP + ARM processors def/mandatory = 2 ===================================
04/18/2012 09:54:46AM - EMU_TI was selected before - value now Selected_EMU_TI 5
04/18/2012 09:54:46AM - EMU_TI was offered before - value now 5
04/18/2012 09:54:46AM - Component = EMU_SD EMU_SD:C6x DSP + ARM processors def/mandatory = 1 ===================================
04/18/2012 09:54:46AM - EMU_SD was selected before - value now Selected_EMU_SD 5
04/18/2012 09:54:46AM - EMU_SD was offered before - value now 5
04/18/2012 09:54:46AM - Component = SIM_TI SIM_TI:C6x DSP + ARM processors def/mandatory = 1 ===================================
04/18/2012 09:54:46AM - SIM_TI was selected before - value now Selected_SIM_TI 5
04/18/2012 09:54:46AM - SIM_TI was offered before - value now 5
04/18/2012 09:54:46AM - Component = EMU_BH EMU_BH:C6x DSP + ARM processors def/mandatory = 1 ===================================
04/18/2012 09:54:46AM - EMU_BH was selected before - value now Selected_EMU_BH 5
04/18/2012 09:54:46AM - EMU_BH was offered before - value now 5
04/18/2012 09:54:46AM - Component = TC_ARM_XDCTOOLS TC_ARM_XDCTOOLS:C6x DSP + ARM processors def/mandatory = 1 ===================================
04/18/2012 09:54:46AM - TC_ARM_XDCTOOLS was selected before - value now Selected_TC_ARM_XDCTOOLS 4
04/18/2012 09:54:46AM - TC_ARM_XDCTOOLS was offered before - value now 4
04/18/2012 09:54:46AM - Component = CGT_DEFAULTLIBS_C6000 CGT_DEFAULTLIBS_C6000:C6x DSP + ARM processors def/mandatory = 1 ===================================
04/18/2012 09:54:46AM - CGT_DEFAULTLIBS_C6000 was not selected before - value now Selected_CGT_DEFAULTLIBS_C60001
04/18/2012 09:54:46AM - CGT_DEFAULTLIBS_C6000 was not offered before - value now 1
04/18/2012 09:54:46AM - Component = TC_XDCTOOLS_BIOS5 TC_XDCTOOLS_BIOS5:C6x DSP + ARM processors def/mandatory = 1 ===================================
04/18/2012 09:54:46AM - TC_XDCTOOLS_BIOS5 was selected before - value now Selected_TC_XDCTOOLS_BIOS5 3
04/18/2012 09:54:46AM - TC_XDCTOOLS_BIOS5 was offered before - value now 3
04/18/2012 09:54:46AM - Component = DVT DVT:C6x DSP + ARM processors def/mandatory = 2 ===================================
04/18/2012 09:54:46AM - DVT was selected before - value now Selected_DVT 5
04/18/2012 09:54:46AM - DVT was offered before - value now 5
04/18/2012 09:54:46AM - Component = IDE IDE:C6x DSP + ARM processors def/mandatory = 2 ===================================
04/18/2012 09:54:46AM - IDE was selected before - value now Selected_IDE 6
04/18/2012 09:54:46AM - IDE was offered before - value now 6
04/18/2012 09:54:46AM - Component = TC_C6000_IPC TC_C6000_IPC:C6x DSP + ARM processors def/mandatory = 1 ===================================
04/18/2012 09:54:46AM - TC_C6000_IPC was not selected before - value now Selected_TC_C6000_IPC1
04/18/2012 09:54:46AM - TC_C6000_IPC was not offered before - value now 1
04/18/2012 09:54:46AM - Component = CCSINIT CCSINIT:C6x DSP + ARM processors def/mandatory = 2 ===================================
04/18/2012 09:54:46AM - CCSINIT was selected before - value now Selected_CCSINIT 6
04/18/2012 09:54:46AM - CCSINIT was offered before - value now 6
04/18/2012 09:54:46AM - Component = TC_XDCTOOLS TC_XDCTOOLS:C6x DSP + ARM processors def/mandatory = 1 ===================================
04/18/2012 09:54:46AM - TC_XDCTOOLS was selected before - value now Selected_TC_XDCTOOLS 6
04/18/2012 09:54:46AM - TC_XDCTOOLS was offered before - value now 6
04/18/2012 09:54:46AM - Component = TC_ARM_IPC TC_ARM_IPC:C6x DSP + ARM processors def/mandatory = 1 ===================================
04/18/2012 09:54:46AM - TC_ARM_IPC was selected before - value now Selected_TC_ARM_IPC 4
04/18/2012 09:54:46AM - TC_ARM_IPC was offered before - value now 4
04/18/2012 09:54:46AM - Component = TC_C6000_XDCTOOLS TC_C6000_XDCTOOLS:C6x DSP + ARM processors def/mandatory = 1 ===================================
04/18/2012 09:54:46AM - TC_C6000_XDCTOOLS was not selected before - value now Selected_TC_C6000_XDCTOOLS1
04/18/2012 09:54:46AM - TC_C6000_XDCTOOLS was not offered before - value now 1
04/18/2012 09:54:46AM - Component = TC_XDAIS TC_XDAIS:C6x DSP + ARM processors def/mandatory = 1 ===================================
04/18/2012 09:54:46AM - TC_XDAIS was selected before - value now Selected_TC_XDAIS 5
04/18/2012 09:54:46AM - TC_XDAIS was offered before - value now 5
04/18/2012 09:54:46AM - Component = DS DS:C6x DSP + ARM processors def/mandatory = 2 ===================================
04/18/2012 09:54:46AM - DS was selected before - value now Selected_DS 6
04/18/2012 09:54:46AM - DS was offered before - value now 6
04/18/2012 09:54:46AM - Component = UIA UIA:C6x DSP + ARM processors def/mandatory = 1 ===================================
04/18/2012 09:54:46AM - UIA was selected before - value now Selected_UIA 6
04/18/2012 09:54:46AM - UIA was offered before - value now 6
04/18/2012 09:54:46AM - Component = DMED DMED:C6x DSP + ARM processors def/mandatory = 1 ===================================
04/18/2012 09:54:46AM - DMED was selected before - value now Selected_DMED 6
04/18/2012 09:54:46AM - DMED was offered before - value now 6
04/18/2012 09:54:46AM - Component = TC_BIOS6 TC_BIOS6:C6x DSP + ARM processors def/mandatory = 1 ===================================
04/18/2012 09:54:46AM - TC_BIOS6 was selected before - value now Selected_TC_BIOS6 6
04/18/2012 09:54:46AM - TC_BIOS6 was offered before - value now 6
04/18/2012 09:54:46AM - Component = C6FLO C6FLO:C6x DSP + ARM processors def/mandatory = 1 ===================================
04/18/2012 09:54:46AM - C6FLO was not selected before - value now Selected_C6FLO1
04/18/2012 09:54:46AM - C6FLO was not offered before - value now 1
04/18/2012 09:54:46AM - Adding TC_C6000_BIOS6 79181565: new total 171593886
04/18/2012 09:54:46AM - Adding CGT_DEFAULTLIBS_MSP430 20338099: new total 191931985
04/18/2012 09:54:46AM - Adding IDE 15711774: new total 207643759
04/18/2012 09:54:46AM - Adding EMU_SD 27415818: new total 235059577
04/18/2012 09:54:46AM - Adding SIM_TI 36678204: new total 271737781
04/18/2012 09:54:46AM - Adding TC_XDCTOOLS_BIOS5 81351659: new total 353089440
04/18/2012 09:54:46AM - Adding TC_MSP430_IPC 2150909: new total 355240349
04/18/2012 09:54:46AM - Adding EMU_STELLARIS 17515986: new total 372756335
04/18/2012 09:54:46AM - Adding CGT_DEFAULTLIBS_TMS470 44488244: new total 417244579
04/18/2012 09:54:46AM - Adding C6FLO 25881835: new total 443126414
04/18/2012 09:54:46AM - Adding TC_C6000_IPC 48841212: new total 491967626
04/18/2012 09:54:46AM - Adding TC_IPC 17305979: new total 509273605
04/18/2012 09:54:46AM - Adding TC_ARM_XDCTOOLS 26837137: new total 536110742
04/18/2012 09:54:46AM - Adding EMU_HERCULES 1559927: new total 537670669
04/18/2012 09:54:46AM - Adding TC_ARM_IPC 17625522: new total 555296191
04/18/2012 09:54:46AM - Adding EMU_TI 34684346: new total 589980537
04/18/2012 09:54:46AM - Adding EMU_NOWFLASH 3656983: new total 593637520
04/18/2012 09:54:46AM - Adding GRACE 21652625: new total 615290145
04/18/2012 09:54:46AM - Adding TC_MSP430_XDCTOOLS 3299400: new total 618589545
04/18/2012 09:54:46AM - Adding CGT_DEFAULTLIBS_C6000 56556526: new total 675146071
04/18/2012 09:54:46AM - Adding EMU_MSP430 30049708: new total 705195779
04/18/2012 09:54:46AM - Adding TC_C2000_BIOS6 8938407: new total 714134186
04/18/2012 09:54:46AM - Adding DVT 33189220: new total 747323406
04/18/2012 09:54:46AM - Adding TC_MSP430_BIOS6 8734432: new total 756057838
04/18/2012 09:54:46AM - Adding DVT_MIN 25001089: new total 781058927
04/18/2012 09:54:46AM - Adding TC_C2000_IPC 7295951: new total 788354878
04/18/2012 09:54:46AM - Adding TC_C2000_XDCTOOLS 3354908: new total 791709786
04/18/2012 09:54:46AM - Adding MSP430_CGT_HELP 18989015: new total 810698801
04/18/2012 09:54:46AM - Adding TC_XDCTOOLS 81351659: new total 892050460
04/18/2012 09:54:46AM - Adding TC_C6000_XDCTOOLS 24012390: new total 916062850
04/18/2012 09:54:46AM - Adding TC_XDAIS 8492292: new total 924555142
04/18/2012 09:54:46AM - Adding EMU_BH 37362701: new total 961917843
04/18/2012 09:54:46AM - Adding DMED 1337117: new total 963254960
04/18/2012 09:54:46AM - Adding CCSINIT 1331118: new total 964586078
04/18/2012 09:54:46AM - Adding UIA 16798858: new total 981384936
04/18/2012 09:54:46AM - Adding DS 26562234: new total 1007947170
04/18/2012 09:54:46AM - Adding TC_XDAIS_BIOS5 8492292: new total 1016439462
04/18/2012 09:54:46AM - Adding EMU_C2000_FLASH 1671961: new total 1018111423
04/18/2012 09:54:46AM - Adding TC_ARM_BIOS6 25714004: new total 1043825427
04/18/2012 09:54:46AM - Adding EMU_C2000 2324056: new total 1046149483
04/18/2012 09:54:46AM - Adding MSP430Ware 49015614: new total 1095165097
04/18/2012 09:54:46AM - 1183
04/18/2012 09:54:46AM - Checking sizes for DaVinci Video Processors:
04/18/2012 09:54:46AM - Component = EMU_TI EMU_TI:DaVinci Video Processors def/mandatory = 2 ===================================
04/18/2012 09:54:46AM - EMU_TI was selected before - value now Selected_EMU_TI 6
04/18/2012 09:54:46AM - EMU_TI was offered before - value now 6
04/18/2012 09:54:46AM - Component = EMU_SD EMU_SD:DaVinci Video Processors def/mandatory = 1 ===================================
04/18/2012 09:54:46AM - EMU_SD was selected before - value now Selected_EMU_SD 6
04/18/2012 09:54:46AM - EMU_SD was offered before - value now 6
04/18/2012 09:54:46AM - Component = SIM_TI SIM_TI:DaVinci Video Processors def/mandatory = 1 ===================================
04/18/2012 09:54:46AM - SIM_TI was selected before - value now Selected_SIM_TI 6
04/18/2012 09:54:46AM - SIM_TI was offered before - value now 6
04/18/2012 09:54:46AM - Component = EMU_BH EMU_BH:DaVinci Video Processors def/mandatory = 1 ===================================
04/18/2012 09:54:46AM - EMU_BH was selected before - value now Selected_EMU_BH 6
04/18/2012 09:54:46AM - EMU_BH was offered before - value now 6
04/18/2012 09:54:46AM - Component = TC_ARM_XDCTOOLS TC_ARM_XDCTOOLS:DaVinci Video Processors def/mandatory = 1 ===================================
04/18/2012 09:54:46AM - TC_ARM_XDCTOOLS was selected before - value now Selected_TC_ARM_XDCTOOLS 5
04/18/2012 09:54:46AM - TC_ARM_XDCTOOLS was offered before - value now 5
04/18/2012 09:54:46AM - Component = CGT_DEFAULTLIBS_C6000 CGT_DEFAULTLIBS_C6000:DaVinci Video Processors def/mandatory = 1 ===================================
04/18/2012 09:54:46AM - CGT_DEFAULTLIBS_C6000 was selected before - value now Selected_CGT_DEFAULTLIBS_C6000 2
04/18/2012 09:54:46AM - CGT_DEFAULTLIBS_C6000 was offered before - value now 2
04/18/2012 09:54:46AM - Component = TC_XDCTOOLS_BIOS5 TC_XDCTOOLS_BIOS5:DaVinci Video Processors def/mandatory = 1 ===================================
04/18/2012 09:54:46AM - TC_XDCTOOLS_BIOS5 was selected before - value now Selected_TC_XDCTOOLS_BIOS5 4
04/18/2012 09:54:46AM - TC_XDCTOOLS_BIOS5 was offered before - value now 4
04/18/2012 09:54:46AM - Component = DVT DVT:DaVinci Video Processors def/mandatory = 2 ===================================
04/18/2012 09:54:46AM - DVT was selected before - value now Selected_DVT 6
04/18/2012 09:54:46AM - DVT was offered before - value now 6
04/18/2012 09:54:46AM - Component = IDE IDE:DaVinci Video Processors def/mandatory = 2 ===================================
04/18/2012 09:54:46AM - IDE was selected before - value now Selected_IDE 7
04/18/2012 09:54:46AM - IDE was offered before - value now 7
04/18/2012 09:54:46AM - Component = TC_C6000_IPC TC_C6000_IPC:DaVinci Video Processors def/mandatory = 1 ===================================
04/18/2012 09:54:46AM - TC_C6000_IPC was selected before - value now Selected_TC_C6000_IPC 2
04/18/2012 09:54:46AM - TC_C6000_IPC was offered before - value now 2
04/18/2012 09:54:46AM - Component = CCSINIT CCSINIT:DaVinci Video Processors def/mandatory = 2 ===================================
04/18/2012 09:54:46AM - CCSINIT was selected before - value now Selected_CCSINIT 7
04/18/2012 09:54:46AM - CCSINIT was offered before - value now 7
04/18/2012 09:54:46AM - Component = TC_XDCTOOLS TC_XDCTOOLS:DaVinci Video Processors def/mandatory = 1 ===================================
04/18/2012 09:54:46AM - TC_XDCTOOLS was selected before - value now Selected_TC_XDCTOOLS 7
04/18/2012 09:54:46AM - TC_XDCTOOLS was offered before - value now 7
04/18/2012 09:54:46AM - Component = TC_ARM_IPC TC_ARM_IPC:DaVinci Video Processors def/mandatory = 1 ===================================
04/18/2012 09:54:46AM - TC_ARM_IPC was selected before - value now Selected_TC_ARM_IPC 5
04/18/2012 09:54:46AM - TC_ARM_IPC was offered before - value now 5
04/18/2012 09:54:46AM - Component = TC_C6000_XDCTOOLS TC_C6000_XDCTOOLS:DaVinci Video Processors def/mandatory = 1 ===================================
04/18/2012 09:54:46AM - TC_C6000_XDCTOOLS was selected before - value now Selected_TC_C6000_XDCTOOLS 2
04/18/2012 09:54:46AM - TC_C6000_XDCTOOLS was offered before - value now 2
04/18/2012 09:54:46AM - Component = TC_XDAIS TC_XDAIS:DaVinci Video Processors def/mandatory = 1 ===================================
04/18/2012 09:54:46AM - TC_XDAIS was selected before - value now Selected_TC_XDAIS 6
04/18/2012 09:54:46AM - TC_XDAIS was offered before - value now 6
04/18/2012 09:54:46AM - Component = UIA UIA:DaVinci Video Processors def/mandatory = 1 ===================================
04/18/2012 09:54:46AM - UIA was selected before - value now Selected_UIA 7
04/18/2012 09:54:46AM - UIA was offered before - value now 7
04/18/2012 09:54:46AM - Component = DS DS:DaVinci Video Processors def/mandatory = 2 ===================================
04/18/2012 09:54:46AM - DS was selected before - value now Selected_DS 7
04/18/2012 09:54:46AM - DS was offered before - value now 7
04/18/2012 09:54:46AM - Component = DMED DMED:DaVinci Video Processors def/mandatory = 1 ===================================
04/18/2012 09:54:46AM - DMED was selected before - value now Selected_DMED 7
04/18/2012 09:54:46AM - DMED was offered before - value now 7
04/18/2012 09:54:46AM - Component = TC_BIOS6 TC_BIOS6:DaVinci Video Processors def/mandatory = 1 ===================================
04/18/2012 09:54:46AM - TC_BIOS6 was selected before - value now Selected_TC_BIOS6 7
04/18/2012 09:54:46AM - TC_BIOS6 was offered before - value now 7
04/18/2012 09:54:46AM - Component = C6FLO C6FLO:DaVinci Video Processors def/mandatory = 1 ===================================
04/18/2012 09:54:46AM - C6FLO was selected before - value now Selected_C6FLO 2
04/18/2012 09:54:46AM - C6FLO was offered before - value now 2
04/18/2012 09:54:46AM - Component = TC_ARM_BIOS6 TC_ARM_BIOS6:DaVinci Video Processors def/mandatory = 1 ===================================
04/18/2012 09:54:46AM - TC_ARM_BIOS6 was selected before - value now Selected_TC_ARM_BIOS6 5
04/18/2012 09:54:46AM - TC_ARM_BIOS6 was offered before - value now 5
04/18/2012 09:54:46AM - Component = TC_XDAIS_BIOS5 TC_XDAIS_BIOS5:DaVinci Video Processors def/mandatory = 1 ===================================
04/18/2012 09:54:46AM - TC_XDAIS_BIOS5 was selected before - value now Selected_TC_XDAIS_BIOS5 4
04/18/2012 09:54:46AM - TC_XDAIS_BIOS5 was offered before - value now 4
04/18/2012 09:54:46AM - Component = TC_BIOS5 TC_BIOS5:DaVinci Video Processors def/mandatory = 1 ===================================
04/18/2012 09:54:46AM - TC_BIOS5 was selected before - value now Selected_TC_BIOS5 4
04/18/2012 09:54:46AM - TC_BIOS5 was offered before - value now 4
04/18/2012 09:54:46AM - Component = TC_C6000_BIOS6 TC_C6000_BIOS6:DaVinci Video Processors def/mandatory = 1 ===================================
04/18/2012 09:54:46AM - TC_C6000_BIOS6 was selected before - value now Selected_TC_C6000_BIOS6 2
04/18/2012 09:54:46AM - TC_C6000_BIOS6 was offered before - value now 2
04/18/2012 09:54:46AM - Component = TC_IPC TC_IPC:DaVinci Video Processors def/mandatory = 1 ===================================
04/18/2012 09:54:46AM - TC_IPC was selected before - value now Selected_TC_IPC 7
04/18/2012 09:54:46AM - TC_IPC was offered before - value now 7
04/18/2012 09:54:46AM - Component = CGT_DEFAULTLIBS_TMS470 CGT_DEFAULTLIBS_TMS470:DaVinci Video Processors def/mandatory = 1 ===================================
04/18/2012 09:54:46AM - CGT_DEFAULTLIBS_TMS470 was selected before - value now Selected_CGT_DEFAULTLIBS_TMS470 5
04/18/2012 09:54:46AM - CGT_DEFAULTLIBS_TMS470 was offered before - value now 5
04/18/2012 09:54:46AM - Checking sizes for C6000 Single Core DSPs:
04/18/2012 09:54:46AM - Component = IDE IDE:C6000 Single Core DSPs def/mandatory = 2 ===================================
04/18/2012 09:54:46AM - IDE was selected before - value now Selected_IDE 8
04/18/2012 09:54:46AM - IDE was offered before - value now 8
04/18/2012 09:54:46AM - Component = C6FLO C6FLO:C6000 Single Core DSPs def/mandatory = 1 ===================================
04/18/2012 09:54:46AM - C6FLO was selected before - value now Selected_C6FLO 3
04/18/2012 09:54:46AM - C6FLO was offered before - value now 3
04/18/2012 09:54:46AM - Component = EMU_TI EMU_TI:C6000 Single Core DSPs def/mandatory = 2 ===================================
04/18/2012 09:54:46AM - EMU_TI was selected before - value now Selected_EMU_TI 7
04/18/2012 09:54:46AM - EMU_TI was offered before - value now 7
04/18/2012 09:54:46AM - Component = DVT DVT:C6000 Single Core DSPs def/mandatory = 2 ===================================
04/18/2012 09:54:46AM - DVT was selected before - value now Selected_DVT 7
04/18/2012 09:54:46AM - DVT was offered before - value now 7
04/18/2012 09:54:46AM - Component = TC_BIOS6 TC_BIOS6:C6000 Single Core DSPs def/mandatory = 1 ===================================
04/18/2012 09:54:46AM - TC_BIOS6 was selected before - value now Selected_TC_BIOS6 8
04/18/2012 09:54:46AM - TC_BIOS6 was offered before - value now 8
04/18/2012 09:54:46AM - Component = TC_IPC TC_IPC:C6000 Single Core DSPs def/mandatory = 1 ===================================
04/18/2012 09:54:46AM - TC_IPC was selected before - value now Selected_TC_IPC 8
04/18/2012 09:54:46AM - TC_IPC was offered before - value now 8
04/18/2012 09:54:46AM - Component = TC_XDCTOOLS TC_XDCTOOLS:C6000 Single Core DSPs def/mandatory = 1 ===================================
04/18/2012 09:54:46AM - TC_XDCTOOLS was selected before - value now Selected_TC_XDCTOOLS 8
04/18/2012 09:54:46AM - TC_XDCTOOLS was offered before - value now 8
04/18/2012 09:54:46AM - Component = UIA UIA:C6000 Single Core DSPs def/mandatory = 1 ===================================
04/18/2012 09:54:46AM - UIA was selected before - value now Selected_UIA 8
04/18/2012 09:54:46AM - UIA was offered before - value now 8
04/18/2012 09:54:46AM - Component = DS DS:C6000 Single Core DSPs def/mandatory = 2 ===================================
04/18/2012 09:54:46AM - DS was selected before - value now Selected_DS 8
04/18/2012 09:54:46AM - DS was offered before - value now 8
04/18/2012 09:54:46AM - Component = TC_BIOS5 TC_BIOS5:C6000 Single Core DSPs def/mandatory = 1 ===================================
04/18/2012 09:54:46AM - TC_BIOS5 was selected before - value now Selected_TC_BIOS5 5
04/18/2012 09:54:46AM - TC_BIOS5 was offered before - value now 5
04/18/2012 09:54:46AM - Component = EMU_SD EMU_SD:C6000 Single Core DSPs def/mandatory = 1 ===================================
04/18/2012 09:54:46AM - EMU_SD was selected before - value now Selected_EMU_SD 7
04/18/2012 09:54:46AM - EMU_SD was offered before - value now 7
04/18/2012 09:54:46AM - Component = SIM_TI SIM_TI:C6000 Single Core DSPs def/mandatory = 1 ===================================
04/18/2012 09:54:46AM - SIM_TI was selected before - value now Selected_SIM_TI 7
04/18/2012 09:54:46AM - SIM_TI was offered before - value now 7
04/18/2012 09:54:46AM - Component = DMED DMED:C6000 Single Core DSPs def/mandatory = 1 ===================================
04/18/2012 09:54:46AM - DMED was selected before - value now Selected_DMED 8
04/18/2012 09:54:46AM - DMED was offered before - value now 8
04/18/2012 09:54:46AM - Component = EMU_BH EMU_BH:C6000 Single Core DSPs def/mandatory = 1 ===================================
04/18/2012 09:54:46AM - EMU_BH was selected before - value now Selected_EMU_BH 7
04/18/2012 09:54:46AM - EMU_BH was offered before - value now 7
04/18/2012 09:54:46AM - Component = TC_C6000_BIOS6 TC_C6000_BIOS6:C6000 Single Core DSPs def/mandatory = 1 ===================================
04/18/2012 09:54:46AM - TC_C6000_BIOS6 was selected before - value now Selected_TC_C6000_BIOS6 3
04/18/2012 09:54:46AM - TC_C6000_BIOS6 was offered before - value now 3
04/18/2012 09:54:46AM - Component = TC_C6000_IPC TC_C6000_IPC:C6000 Single Core DSPs def/mandatory = 1 ===================================
04/18/2012 09:54:46AM - TC_C6000_IPC was selected before - value now Selected_TC_C6000_IPC 3
04/18/2012 09:54:46AM - TC_C6000_IPC was offered before - value now 3
04/18/2012 09:54:46AM - Component = TC_C6000_XDCTOOLS TC_C6000_XDCTOOLS:C6000 Single Core DSPs def/mandatory = 1 ===================================
04/18/2012 09:54:46AM - TC_C6000_XDCTOOLS was selected before - value now Selected_TC_C6000_XDCTOOLS 3
04/18/2012 09:54:46AM - TC_C6000_XDCTOOLS was offered before - value now 3
04/18/2012 09:54:46AM - Component = CCSINIT CCSINIT:C6000 Single Core DSPs def/mandatory = 2 ===================================
04/18/2012 09:54:46AM - CCSINIT was selected before - value now Selected_CCSINIT 8
04/18/2012 09:54:46AM - CCSINIT was offered before - value now 8
04/18/2012 09:54:46AM - Component = TC_XDAIS TC_XDAIS:C6000 Single Core DSPs def/mandatory = 1 ===================================
04/18/2012 09:54:46AM - TC_XDAIS was selected before - value now Selected_TC_XDAIS 7
04/18/2012 09:54:46AM - TC_XDAIS was offered before - value now 7
04/18/2012 09:54:46AM - Component = TC_XDAIS_BIOS5 TC_XDAIS_BIOS5:C6000 Single Core DSPs def/mandatory = 1 ===================================
04/18/2012 09:54:46AM - TC_XDAIS_BIOS5 was selected before - value now Selected_TC_XDAIS_BIOS5 5
04/18/2012 09:54:46AM - TC_XDAIS_BIOS5 was offered before - value now 5
04/18/2012 09:54:46AM - Component = CGT_DEFAULTLIBS_C6000 CGT_DEFAULTLIBS_C6000:C6000 Single Core DSPs def/mandatory = 1 ===================================
04/18/2012 09:54:46AM - CGT_DEFAULTLIBS_C6000 was selected before - value now Selected_CGT_DEFAULTLIBS_C6000 3
04/18/2012 09:54:46AM - CGT_DEFAULTLIBS_C6000 was offered before - value now 3
04/18/2012 09:54:46AM - Component = TC_XDCTOOLS_BIOS5 TC_XDCTOOLS_BIOS5:C6000 Single Core DSPs def/mandatory = 1 ===================================
04/18/2012 09:54:46AM - TC_XDCTOOLS_BIOS5 was selected before - value now Selected_TC_XDCTOOLS_BIOS5 5
04/18/2012 09:54:46AM - TC_XDCTOOLS_BIOS5 was offered before - value now 5
04/18/2012 09:54:46AM - Checking sizes for C6000 Multi Core DSPs:
04/18/2012 09:54:46AM - Component = TC_BIOS6 TC_BIOS6:C6000 Multi Core DSPs def/mandatory = 1 ===================================
04/18/2012 09:54:46AM - TC_BIOS6 was selected before - value now Selected_TC_BIOS6 9
04/18/2012 09:54:46AM - TC_BIOS6 was offered before - value now 9
04/18/2012 09:54:46AM - Component = EMU_SD EMU_SD:C6000 Multi Core DSPs def/mandatory = 1 ===================================
04/18/2012 09:54:46AM - EMU_SD was selected before - value now Selected_EMU_SD 8
04/18/2012 09:54:46AM - EMU_SD was offered before - value now 8
04/18/2012 09:54:46AM - Component = SIM_TI SIM_TI:C6000 Multi Core DSPs def/mandatory = 1 ===================================
04/18/2012 09:54:46AM - SIM_TI was selected before - value now Selected_SIM_TI 8
04/18/2012 09:54:46AM - SIM_TI was offered before - value now 8
04/18/2012 09:54:46AM - Component = TC_XDAIS TC_XDAIS:C6000 Multi Core DSPs def/mandatory = 1 ===================================
04/18/2012 09:54:46AM - TC_XDAIS was selected before - value now Selected_TC_XDAIS 8
04/18/2012 09:54:46AM - TC_XDAIS was offered before - value now 8
04/18/2012 09:54:46AM - Component = TC_XDCTOOLS TC_XDCTOOLS:C6000 Multi Core DSPs def/mandatory = 1 ===================================
04/18/2012 09:54:46AM - TC_XDCTOOLS was selected before - value now Selected_TC_XDCTOOLS 9
04/18/2012 09:54:46AM - TC_XDCTOOLS was offered before - value now 9
04/18/2012 09:54:46AM - Component = DMED DMED:C6000 Multi Core DSPs def/mandatory = 1 ===================================
04/18/2012 09:54:46AM - DMED was selected before - value now Selected_DMED 9
04/18/2012 09:54:46AM - DMED was offered before - value now 9
04/18/2012 09:54:46AM - Component = CGT_DEFAULTLIBS_C6000 CGT_DEFAULTLIBS_C6000:C6000 Multi Core DSPs def/mandatory = 1 ===================================
04/18/2012 09:54:46AM - CGT_DEFAULTLIBS_C6000 was selected before - value now Selected_CGT_DEFAULTLIBS_C6000 4
04/18/2012 09:54:46AM - CGT_DEFAULTLIBS_C6000 was offered before - value now 4
04/18/2012 09:54:46AM - Component = IDE IDE:C6000 Multi Core DSPs def/mandatory = 2 ===================================
04/18/2012 09:54:46AM - IDE was selected before - value now Selected_IDE 9
04/18/2012 09:54:46AM - IDE was offered before - value now 9
04/18/2012 09:54:46AM - Component = EMU_TI EMU_TI:C6000 Multi Core DSPs def/mandatory = 2 ===================================
04/18/2012 09:54:46AM - EMU_TI was selected before - value now Selected_EMU_TI 8
04/18/2012 09:54:46AM - EMU_TI was offered before - value now 8
04/18/2012 09:54:46AM - Component = KEYSTONE1 KEYSTONE1:C6000 Multi Core DSPs def/mandatory = 2 ===================================
04/18/2012 09:54:46AM - KEYSTONE1 was not selected before - value now Selected_KEYSTONE11
04/18/2012 09:54:46AM - KEYSTONE1 was not offered before - value now 1
04/18/2012 09:54:46AM - Component = TC_IPC TC_IPC:C6000 Multi Core DSPs def/mandatory = 1 ===================================
04/18/2012 09:54:46AM - TC_IPC was selected before - value now Selected_TC_IPC 9
04/18/2012 09:54:46AM - TC_IPC was offered before - value now 9
04/18/2012 09:54:46AM - Component = EMU_BH EMU_BH:C6000 Multi Core DSPs def/mandatory = 1 ===================================
04/18/2012 09:54:46AM - EMU_BH was selected before - value now Selected_EMU_BH 8
04/18/2012 09:54:46AM - EMU_BH was offered before - value now 8
04/18/2012 09:54:46AM - Component = TC_C6000_BIOS6 TC_C6000_BIOS6:C6000 Multi Core DSPs def/mandatory = 1 ===================================
04/18/2012 09:54:46AM - TC_C6000_BIOS6 was selected before - value now Selected_TC_C6000_BIOS6 4
04/18/2012 09:54:46AM - TC_C6000_BIOS6 was offered before - value now 4
04/18/2012 09:54:46AM - Component = TC_XDAIS_BIOS5 TC_XDAIS_BIOS5:C6000 Multi Core DSPs def/mandatory = 1 ===================================
04/18/2012 09:54:46AM - TC_XDAIS_BIOS5 was selected before - value now Selected_TC_XDAIS_BIOS5 6
04/18/2012 09:54:46AM - TC_XDAIS_BIOS5 was offered before - value now 6
04/18/2012 09:54:46AM - Component = DS DS:C6000 Multi Core DSPs def/mandatory = 2 ===================================
04/18/2012 09:54:46AM - DS was selected before - value now Selected_DS 9
04/18/2012 09:54:46AM - DS was offered before - value now 9
04/18/2012 09:54:46AM - Component = UIA UIA:C6000 Multi Core DSPs def/mandatory = 1 ===================================
04/18/2012 09:54:46AM - UIA was selected before - value now Selected_UIA 9
04/18/2012 09:54:46AM - UIA was offered before - value now 9
04/18/2012 09:54:46AM - Component = TC_C6000_XDCTOOLS TC_C6000_XDCTOOLS:C6000 Multi Core DSPs def/mandatory = 1 ===================================
04/18/2012 09:54:46AM - TC_C6000_XDCTOOLS was selected before - value now Selected_TC_C6000_XDCTOOLS 4
04/18/2012 09:54:46AM - TC_C6000_XDCTOOLS was offered before - value now 4
04/18/2012 09:54:46AM - Component = TC_XDCTOOLS_BIOS5 TC_XDCTOOLS_BIOS5:C6000 Multi Core DSPs def/mandatory = 1 ===================================
04/18/2012 09:54:46AM - TC_XDCTOOLS_BIOS5 was selected before - value now Selected_TC_XDCTOOLS_BIOS5 6
04/18/2012 09:54:46AM - TC_XDCTOOLS_BIOS5 was offered before - value now 6
04/18/2012 09:54:46AM - Component = TC_C6000_IPC TC_C6000_IPC:C6000 Multi Core DSPs def/mandatory = 1 ===================================
04/18/2012 09:54:46AM - TC_C6000_IPC was selected before - value now Selected_TC_C6000_IPC 4
04/18/2012 09:54:46AM - TC_C6000_IPC was offered before - value now 4
04/18/2012 09:54:46AM - Component = DVT DVT:C6000 Multi Core DSPs def/mandatory = 2 ===================================
04/18/2012 09:54:46AM - DVT was selected before - value now Selected_DVT 8
04/18/2012 09:54:46AM - DVT was offered before - value now 8
04/18/2012 09:54:46AM - Component = TC_BIOS5 TC_BIOS5:C6000 Multi Core DSPs def/mandatory = 1 ===================================
04/18/2012 09:54:46AM - TC_BIOS5 was selected before - value now Selected_TC_BIOS5 6
04/18/2012 09:54:46AM - TC_BIOS5 was offered before - value now 6
04/18/2012 09:54:46AM - Component = CCSINIT CCSINIT:C6000 Multi Core DSPs def/mandatory = 2 ===================================
04/18/2012 09:54:46AM - CCSINIT was selected before - value now Selected_CCSINIT 9
04/18/2012 09:54:46AM - CCSINIT was offered before - value now 9
04/18/2012 09:54:46AM - TI C2800 Compiler Tools CGT_DEFAULTLIBS_C2800
04/18/2012 09:54:46AM - BIOS 5 TC_BIOS5
04/18/2012 09:54:46AM - BIOS 6 TC_BIOS6
04/18/2012 09:54:46AM - C6000 BIOS6 TC_C6000_BIOS6
04/18/2012 09:54:46AM - TI MSP430 Compiler Tools CGT_DEFAULTLIBS_MSP430
04/18/2012 09:54:46AM - Code Composer Plugins IDE
04/18/2012 09:54:46AM - Spectrum Digital Emulators EMU_SD
04/18/2012 09:54:46AM - TI Simulators SIM_TI
04/18/2012 09:54:46AM - XDCTools TC_XDCTOOLS_BIOS5
04/18/2012 09:54:46AM - TI C5400 Compiler Tools CGT_DEFAULTLIBS_C5400
04/18/2012 09:54:46AM - MSP430 IPC TC_MSP430_IPC
04/18/2012 09:54:46AM - Stellaris Emulators EMU_STELLARIS
04/18/2012 09:54:46AM - MSVC 2005 MSVC80
04/18/2012 09:54:46AM - TI ARM Compiler Tools CGT_DEFAULTLIBS_TMS470
04/18/2012 09:54:46AM - C6EZFlo C6FLO
04/18/2012 09:54:46AM - C6000 IPC TC_C6000_IPC
04/18/2012 09:54:46AM - IPC TC_IPC
04/18/2012 09:54:46AM - ARM XDCTools TC_ARM_XDCTOOLS
04/18/2012 09:54:46AM - Hercules Emulation EMU_HERCULES
04/18/2012 09:54:46AM - JRE JRE
04/18/2012 09:54:46AM - ARM IPC TC_ARM_IPC
04/18/2012 09:54:46AM - TI Emulators EMU_TI
04/18/2012 09:54:46AM - LightWeightInstaller INSTALL_JAR
04/18/2012 09:54:46AM - Keystone1 KEYSTONE1
04/18/2012 09:54:46AM - Adding KEYSTONE1 1407559: new total 591388096
04/18/2012 09:54:46AM - LWInstaller INSTALLER
04/18/2012 09:54:46AM - TI C5500 Compiler Tools CGT_DEFAULTLIBS_C5500
04/18/2012 09:54:46AM - CCS NowFlash Emulators EMU_NOWFLASH
04/18/2012 09:54:46AM - Adding EMU_NOWFLASH 3656983: new total 595045079
04/18/2012 09:54:46AM - Grace GRACE
04/18/2012 09:54:46AM - Adding GRACE 21652625: new total 616697704
04/18/2012 09:54:46AM - Eclipse P2 Extensions P2TOOLS
04/18/2012 09:54:46AM - MSP430 XDCTools TC_MSP430_XDCTOOLS
04/18/2012 09:54:46AM - Adding TC_MSP430_XDCTOOLS 3299400: new total 619997104
04/18/2012 09:54:46AM - TI C6000 Compiler Tools CGT_DEFAULTLIBS_C6000
04/18/2012 09:54:46AM - Adding CGT_DEFAULTLIBS_C6000 56556526: new total 676553630
04/18/2012 09:54:46AM - Eclipse ECLIPSE
04/18/2012 09:54:46AM - MSP430 Emulators EMU_MSP430
04/18/2012 09:54:46AM - Adding EMU_MSP430 30049708: new total 706603338
04/18/2012 09:54:46AM - C2000 BIOS6 TC_C2000_BIOS6
04/18/2012 09:54:46AM - Adding TC_C2000_BIOS6 8938407: new total 715541745
04/18/2012 09:54:46AM - DVT DVT
04/18/2012 09:54:46AM - Adding DVT 33189220: new total 748730965
04/18/2012 09:54:46AM - MSP430 BIOS6 TC_MSP430_BIOS6
04/18/2012 09:54:46AM - Adding TC_MSP430_BIOS6 8734432: new total 757465397
04/18/2012 09:54:46AM - DVT min DVT_MIN
04/18/2012 09:54:46AM - Adding DVT_MIN 25001089: new total 782466486
04/18/2012 09:54:46AM - C2000 IPC TC_C2000_IPC
04/18/2012 09:54:46AM - Adding TC_C2000_IPC 7295951: new total 789762437
04/18/2012 09:54:46AM - C2000 XDCTools TC_C2000_XDCTOOLS
04/18/2012 09:54:46AM - Adding TC_C2000_XDCTOOLS 3354908: new total 793117345
04/18/2012 09:54:46AM - MSVC 2008  MSVC2008
04/18/2012 09:54:46AM - MSP430 Compiler Help MSP430_CGT_HELP
04/18/2012 09:54:46AM - Adding MSP430_CGT_HELP 18989015: new total 812106360
04/18/2012 09:54:46AM - Adding TC_XDCTOOLS 81351659: new total 893458019
04/18/2012 09:54:46AM - C6000 XDCTools TC_C6000_XDCTOOLS
04/18/2012 09:54:46AM - Adding TC_C6000_XDCTOOLS 24012390: new total 917470409
04/18/2012 09:54:46AM - XDAIS TC_XDAIS
04/18/2012 09:54:46AM - Adding TC_XDAIS 8492292: new total 925962701
04/18/2012 09:54:46AM - Blackhawk Emulators EMU_BH
04/18/2012 09:54:46AM - Adding EMU_BH 37362701: new total 963325402
04/18/2012 09:54:46AM - Compiler Tools On-line Documentation DMED
04/18/2012 09:54:46AM - Adding DMED 1337117: new total 964662519
04/18/2012 09:54:46AM - MSI DLL MSI_DLL
04/18/2012 09:54:46AM - CCSINIT CCSINIT
04/18/2012 09:54:46AM - Adding CCSINIT 1331118: new total 965993637
04/18/2012 09:54:46AM - UIA UIA
04/18/2012 09:54:46AM - Adding UIA 16798858: new total 982792495
04/18/2012 09:54:46AM - Debug Server DS
04/18/2012 09:54:46AM - Adding DS 26562234: new total 1009354729
04/18/2012 09:54:46AM - XDAIS TC_XDAIS_BIOS5
04/18/2012 09:54:46AM - Adding TC_XDAIS_BIOS5 8492292: new total 1017847021
04/18/2012 09:54:46AM - C2000 Emulation Flash EMU_C2000_FLASH
04/18/2012 09:54:46AM - Adding EMU_C2000_FLASH 1671961: new total 1019518982
04/18/2012 09:54:46AM - ARM BIOS6 TC_ARM_BIOS6
04/18/2012 09:54:46AM - Adding TC_ARM_BIOS6 25714004: new total 1045232986
04/18/2012 09:54:46AM - C2000 Emulators EMU_C2000
04/18/2012 09:54:46AM - Adding EMU_C2000 2324056: new total 1047557042
04/18/2012 09:54:46AM - MSP430ware MSP430Ware
04/18/2012 09:54:46AM - Adding MSP430Ware 49015614: new total 1096572656
04/18/2012 09:54:46AM - adding jre size
04/18/2012 09:54:46AM - adding eclipse size
04/18/2012 09:54:46AM - 1185
04/18/2012 09:54:46AM - Checking sizes for OMAP:
04/18/2012 09:54:46AM - Component = C6FLO C6FLO:OMAP def/mandatory = 1 ===================================
04/18/2012 09:54:46AM - C6FLO was selected before - value now Selected_C6FLO 4
04/18/2012 09:54:46AM - C6FLO was offered before - value now 4
04/18/2012 09:54:46AM - Component = TC_XDCTOOLS TC_XDCTOOLS:OMAP def/mandatory = 1 ===================================
04/18/2012 09:54:46AM - TC_XDCTOOLS was selected before - value now Selected_TC_XDCTOOLS 10
04/18/2012 09:54:46AM - TC_XDCTOOLS was offered before - value now 10
04/18/2012 09:54:46AM - Component = TC_BIOS6 TC_BIOS6:OMAP def/mandatory = 1 ===================================
04/18/2012 09:54:46AM - TC_BIOS6 was selected before - value now Selected_TC_BIOS6 10
04/18/2012 09:54:46AM - TC_BIOS6 was offered before - value now 10
04/18/2012 09:54:46AM - Component = CGT_DEFAULTLIBS_C6000 CGT_DEFAULTLIBS_C6000:OMAP def/mandatory = 1 ===================================
04/18/2012 09:54:46AM - CGT_DEFAULTLIBS_C6000 was selected before - value now Selected_CGT_DEFAULTLIBS_C6000 5
04/18/2012 09:54:46AM - CGT_DEFAULTLIBS_C6000 was offered before - value now 5
04/18/2012 09:54:46AM - Component = CCSINIT CCSINIT:OMAP def/mandatory = 2 ===================================
04/18/2012 09:54:46AM - CCSINIT was selected before - value now Selected_CCSINIT 10
04/18/2012 09:54:46AM - CCSINIT was offered before - value now 10
04/18/2012 09:54:46AM - Component = TC_XDAIS TC_XDAIS:OMAP def/mandatory = 1 ===================================
04/18/2012 09:54:46AM - TC_XDAIS was selected before - value now Selected_TC_XDAIS 9
04/18/2012 09:54:46AM - TC_XDAIS was offered before - value now 9
04/18/2012 09:54:46AM - Component = EMU_TI EMU_TI:OMAP def/mandatory = 2 ===================================
04/18/2012 09:54:46AM - EMU_TI was selected before - value now Selected_EMU_TI 9
04/18/2012 09:54:46AM - EMU_TI was offered before - value now 9
04/18/2012 09:54:46AM - Component = UIA UIA:OMAP def/mandatory = 1 ===================================
04/18/2012 09:54:46AM - UIA was selected before - value now Selected_UIA 10
04/18/2012 09:54:46AM - UIA was offered before - value now 10
04/18/2012 09:54:46AM - Component = DS DS:OMAP def/mandatory = 2 ===================================
04/18/2012 09:54:46AM - DS was selected before - value now Selected_DS 10
04/18/2012 09:54:46AM - DS was offered before - value now 10
04/18/2012 09:54:46AM - Component = CGT_DEFAULTLIBS_C5500 CGT_DEFAULTLIBS_C5500:OMAP def/mandatory = 1 ===================================
04/18/2012 09:54:46AM - CGT_DEFAULTLIBS_C5500 was not selected before - value now Selected_CGT_DEFAULTLIBS_C55001
04/18/2012 09:54:46AM - CGT_DEFAULTLIBS_C5500 was not offered before - value now 1
04/18/2012 09:54:46AM - Component = TC_IPC TC_IPC:OMAP def/mandatory = 1 ===================================
04/18/2012 09:54:46AM - TC_IPC was selected before - value now Selected_TC_IPC 10
04/18/2012 09:54:46AM - TC_IPC was offered before - value now 10
04/18/2012 09:54:46AM - Component = CGT_DEFAULTLIBS_TMS470 CGT_DEFAULTLIBS_TMS470:OMAP def/mandatory = 1 ===================================
04/18/2012 09:54:46AM - CGT_DEFAULTLIBS_TMS470 was selected before - value now Selected_CGT_DEFAULTLIBS_TMS470 6
04/18/2012 09:54:46AM - CGT_DEFAULTLIBS_TMS470 was offered before - value now 6
04/18/2012 09:54:46AM - Component = TC_C6000_XDCTOOLS TC_C6000_XDCTOOLS:OMAP def/mandatory = 1 ===================================
04/18/2012 09:54:46AM - TC_C6000_XDCTOOLS was selected before - value now Selected_TC_C6000_XDCTOOLS 5
04/18/2012 09:54:46AM - TC_C6000_XDCTOOLS was offered before - value now 5
04/18/2012 09:54:46AM - Component = TC_C6000_BIOS6 TC_C6000_BIOS6:OMAP def/mandatory = 1 ===================================
04/18/2012 09:54:46AM - TC_C6000_BIOS6 was selected before - value now Selected_TC_C6000_BIOS6 5
04/18/2012 09:54:46AM - TC_C6000_BIOS6 was offered before - value now 5
04/18/2012 09:54:46AM - Component = TC_XDAIS_BIOS5 TC_XDAIS_BIOS5:OMAP def/mandatory = 1 ===================================
04/18/2012 09:54:46AM - TC_XDAIS_BIOS5 was selected before - value now Selected_TC_XDAIS_BIOS5 7
04/18/2012 09:54:46AM - TC_XDAIS_BIOS5 was offered before - value now 7
04/18/2012 09:54:46AM - Component = TC_BIOS5 TC_BIOS5:OMAP def/mandatory = 1 ===================================
04/18/2012 09:54:46AM - TC_BIOS5 was selected before - value now Selected_TC_BIOS5 7
04/18/2012 09:54:46AM - TC_BIOS5 was offered before - value now 7
04/18/2012 09:54:46AM - Component = IDE IDE:OMAP def/mandatory = 2 ===================================
04/18/2012 09:54:46AM - IDE was selected before - value now Selected_IDE 10
04/18/2012 09:54:46AM - IDE was offered before - value now 10
04/18/2012 09:54:46AM - Component = TC_C6000_IPC TC_C6000_IPC:OMAP def/mandatory = 1 ===================================
04/18/2012 09:54:46AM - TC_C6000_IPC was selected before - value now Selected_TC_C6000_IPC 5
04/18/2012 09:54:46AM - TC_C6000_IPC was offered before - value now 5
04/18/2012 09:54:46AM - Component = EMU_BH EMU_BH:OMAP def/mandatory = 1 ===================================
04/18/2012 09:54:46AM - EMU_BH was selected before - value now Selected_EMU_BH 9
04/18/2012 09:54:46AM - EMU_BH was offered before - value now 9
04/18/2012 09:54:46AM - Component = TC_XDCTOOLS_BIOS5 TC_XDCTOOLS_BIOS5:OMAP def/mandatory = 1 ===================================
04/18/2012 09:54:46AM - TC_XDCTOOLS_BIOS5 was selected before - value now Selected_TC_XDCTOOLS_BIOS5 7
04/18/2012 09:54:46AM - TC_XDCTOOLS_BIOS5 was offered before - value now 7
04/18/2012 09:54:46AM - Component = CGT_DEFAULTLIBS_C5400 CGT_DEFAULTLIBS_C5400:OMAP def/mandatory = 1 ===================================
04/18/2012 09:54:46AM - CGT_DEFAULTLIBS_C5400 was not selected before - value now Selected_CGT_DEFAULTLIBS_C54001
04/18/2012 09:54:46AM - CGT_DEFAULTLIBS_C5400 was not offered before - value now 1
04/18/2012 09:54:46AM - Component = DMED DMED:OMAP def/mandatory = 1 ===================================
04/18/2012 09:54:46AM - DMED was selected before - value now Selected_DMED 10
04/18/2012 09:54:46AM - DMED was offered before - value now 10
04/18/2012 09:54:46AM - Component = EMU_SD EMU_SD:OMAP def/mandatory = 1 ===================================
04/18/2012 09:54:46AM - EMU_SD was selected before - value now Selected_EMU_SD 9
04/18/2012 09:54:46AM - EMU_SD was offered before - value now 9
04/18/2012 09:54:46AM - Component = SIM_TI SIM_TI:OMAP def/mandatory = 1 ===================================
04/18/2012 09:54:46AM - SIM_TI was selected before - value now Selected_SIM_TI 9
04/18/2012 09:54:46AM - SIM_TI was offered before - value now 9
04/18/2012 09:54:46AM - Component = DVT DVT:OMAP def/mandatory = 2 ===================================
04/18/2012 09:54:46AM - DVT was selected before - value now Selected_DVT 9
04/18/2012 09:54:46AM - DVT was offered before - value now 9
04/18/2012 09:54:46AM - Adding CGT_DEFAULTLIBS_C2800 21474129: new total 21474129
04/18/2012 09:54:46AM - Adding TC_BIOS5 47741693: new total 69215822
04/18/2012 09:54:46AM - Adding TC_BIOS6 23196499: new total 92412321
04/18/2012 09:54:46AM - Adding CGT_DEFAULTLIBS_C5400 10938723: new total 364028163
04/18/2012 09:54:46AM - Adding TC_MSP430_IPC 2150909: new total 366179072
04/18/2012 09:54:46AM - Adding EMU_STELLARIS 17515986: new total 383695058
04/18/2012 09:54:46AM - Adding CGT_DEFAULTLIBS_TMS470 44488244: new total 428183302
04/18/2012 09:54:46AM - Adding C6FLO 25881835: new total 454065137
04/18/2012 09:54:46AM - Adding TC_C6000_IPC 48841212: new total 502906349
04/18/2012 09:54:46AM - Adding TC_IPC 17305979: new total 520212328
04/18/2012 09:54:46AM - Adding TC_ARM_XDCTOOLS 26837137: new total 547049465
04/18/2012 09:54:46AM - Adding EMU_HERCULES 1559927: new total 548609392
04/18/2012 09:54:46AM - Adding TC_ARM_IPC 17625522: new total 566234914
04/18/2012 09:54:46AM - Adding EMU_TI 34684346: new total 600919260
04/18/2012 09:54:46AM - Adding KEYSTONE1 1407559: new total 602326819
04/18/2012 09:54:46AM - Adding CGT_DEFAULTLIBS_C5500 19476749: new total 621803568
04/18/2012 09:54:46AM - Adding EMU_NOWFLASH 3656983: new total 625460551
04/18/2012 09:54:46AM - Adding GRACE 21652625: new total 647113176
04/18/2012 09:54:46AM - Adding TC_MSP430_XDCTOOLS 3299400: new total 650412576
04/18/2012 09:54:46AM - Adding CGT_DEFAULTLIBS_C6000 56556526: new total 706969102
04/18/2012 09:54:46AM - Adding EMU_MSP430 30049708: new total 737018810
04/18/2012 09:54:46AM - Adding TC_C2000_BIOS6 8938407: new total 745957217
04/18/2012 09:54:46AM - Adding DVT 33189220: new total 779146437
04/18/2012 09:54:46AM - Adding TC_MSP430_BIOS6 8734432: new total 787880869
04/18/2012 09:54:46AM - Adding DVT_MIN 25001089: new total 812881958
04/18/2012 09:54:46AM - Adding TC_C2000_IPC 7295951: new total 820177909
04/18/2012 09:54:46AM - Adding TC_C2000_XDCTOOLS 3354908: new total 823532817
04/18/2012 09:54:46AM - Adding MSP430_CGT_HELP 18989015: new total 842521832
04/18/2012 09:54:46AM - Adding TC_XDCTOOLS 81351659: new total 923873491
04/18/2012 09:54:46AM - Adding TC_C6000_XDCTOOLS 24012390: new total 947885881
04/18/2012 09:54:46AM - Adding TC_XDAIS 8492292: new total 956378173
04/18/2012 09:54:46AM - Adding EMU_BH 37362701: new total 993740874
04/18/2012 09:54:46AM - Adding DMED 1337117: new total 995077991
04/18/2012 09:54:46AM - Adding CCSINIT 1331118: new total 996409109
04/18/2012 09:54:46AM - Adding UIA 16798858: new total 1013207967
04/18/2012 09:54:46AM - Adding DS 26562234: new total 1039770201
04/18/2012 09:54:46AM - Adding TC_XDAIS_BIOS5 8492292: new total 1048262493
04/18/2012 09:54:46AM - Adding EMU_C2000_FLASH 1671961: new total 1049934454
04/18/2012 09:54:46AM - Adding TC_ARM_BIOS6 25714004: new total 1075648458
04/18/2012 09:54:46AM - Adding EMU_C2000 2324056: new total 1077972514
04/18/2012 09:54:46AM - Adding MSP430Ware 49015614: new total 1126988128
04/18/2012 09:54:46AM - 1214
04/18/2012 09:54:46AM - Checking sizes for C5000 Ultra Low Power DSP:
04/18/2012 09:54:46AM - Component = EMU_TI EMU_TI:C5000 Ultra Low Power DSP def/mandatory = 2 ===================================
04/18/2012 09:54:46AM - EMU_TI was selected before - value now Selected_EMU_TI 10
04/18/2012 09:54:46AM - EMU_TI was offered before - value now 10
04/18/2012 09:54:46AM - Component = SIM_TI SIM_TI:C5000 Ultra Low Power DSP def/mandatory = 1 ===================================
04/18/2012 09:54:46AM - SIM_TI was selected before - value now Selected_SIM_TI 10
04/18/2012 09:54:46AM - SIM_TI was offered before - value now 10
04/18/2012 09:54:46AM - Component = EMU_SD EMU_SD:C5000 Ultra Low Power DSP def/mandatory = 1 ===================================
04/18/2012 09:54:46AM - EMU_SD was selected before - value now Selected_EMU_SD 10
04/18/2012 09:54:46AM - EMU_SD was offered before - value now 10
04/18/2012 09:54:46AM - Component = CGT_DEFAULTLIBS_C5500 CGT_DEFAULTLIBS_C5500:C5000 Ultra Low Power DSP def/mandatory = 1 ===================================
04/18/2012 09:54:46AM - CGT_DEFAULTLIBS_C5500 was selected before - value now Selected_CGT_DEFAULTLIBS_C5500 2
04/18/2012 09:54:46AM - CGT_DEFAULTLIBS_C5500 was offered before - value now 2
04/18/2012 09:54:46AM - Component = EMU_BH EMU_BH:C5000 Ultra Low Power DSP def/mandatory = 1 ===================================
04/18/2012 09:54:46AM - EMU_BH was selected before - value now Selected_EMU_BH 10
04/18/2012 09:54:46AM - EMU_BH was offered before - value now 10
04/18/2012 09:54:46AM - Component = TC_XDAIS_BIOS5 TC_XDAIS_BIOS5:C5000 Ultra Low Power DSP def/mandatory = 1 ===================================
04/18/2012 09:54:46AM - TC_XDAIS_BIOS5 was selected before - value now Selected_TC_XDAIS_BIOS5 8
04/18/2012 09:54:46AM - TC_XDAIS_BIOS5 was offered before - value now 8
04/18/2012 09:54:46AM - Component = DVT DVT:C5000 Ultra Low Power DSP def/mandatory = 2 ===================================
04/18/2012 09:54:46AM - DVT was selected before - value now Selected_DVT 10
04/18/2012 09:54:46AM - DVT was offered before - value now 10
04/18/2012 09:54:46AM - Component = DMED DMED:C5000 Ultra Low Power DSP def/mandatory = 1 ===================================
04/18/2012 09:54:46AM - DMED was selected before - value now Selected_DMED 11
04/18/2012 09:54:46AM - DMED was offered before - value now 11
04/18/2012 09:54:46AM - Component = IDE IDE:C5000 Ultra Low Power DSP def/mandatory = 2 ===================================
04/18/2012 09:54:46AM - IDE was selected before - value now Selected_IDE 11
04/18/2012 09:54:46AM - IDE was offered before - value now 11
04/18/2012 09:54:46AM - Component = TC_BIOS5 TC_BIOS5:C5000 Ultra Low Power DSP def/mandatory = 1 ===================================
04/18/2012 09:54:46AM - TC_BIOS5 was selected before - value now Selected_TC_BIOS5 8
04/18/2012 09:54:46AM - TC_BIOS5 was offered before - value now 8
04/18/2012 09:54:46AM - Component = DS DS:C5000 Ultra Low Power DSP def/mandatory = 2 ===================================
04/18/2012 09:54:46AM - DS was selected before - value now Selected_DS 11
04/18/2012 09:54:46AM - DS was offered before - value now 11
04/18/2012 09:54:46AM - Component = CGT_DEFAULTLIBS_C5400 CGT_DEFAULTLIBS_C5400:C5000 Ultra Low Power DSP def/mandatory = 1 ===================================
04/18/2012 09:54:46AM - CGT_DEFAULTLIBS_C5400 was selected before - value now Selected_CGT_DEFAULTLIBS_C5400 2
04/18/2012 09:54:46AM - CGT_DEFAULTLIBS_C5400 was offered before - value now 2
04/18/2012 09:54:46AM - Component = TC_XDCTOOLS_BIOS5 TC_XDCTOOLS_BIOS5:C5000 Ultra Low Power DSP def/mandatory = 1 ===================================
04/18/2012 09:54:46AM - TC_XDCTOOLS_BIOS5 was selected before - value now Selected_TC_XDCTOOLS_BIOS5 8
04/18/2012 09:54:46AM - TC_XDCTOOLS_BIOS5 was offered before - value now 8
04/18/2012 09:54:46AM - Component = CCSINIT CCSINIT:C5000 Ultra Low Power DSP def/mandatory = 2 ===================================
04/18/2012 09:54:46AM - CCSINIT was selected before - value now Selected_CCSINIT 11
04/18/2012 09:54:46AM - CCSINIT was offered before - value now 11
04/18/2012 09:54:46AM - Checking conditions for E72C84B4-EC31-4A8F-9380-31452E3AB764 - Choose ISAs - Before Pane is Displayed
04/18/2012 09:54:46AM - Checking condition B6C81A68-D44A-4C50-9EFE-31283C4A5DA2 - String Is Condition
04/18/2012 09:54:46AM - Checking to see if <%ShowISAs%> is true
04/18/2012 09:54:46AM - ** Checking to see if false is true
04/18/2012 09:54:46AM - Condition failed
04/18/2012 09:54:46AM - Skipping pane E72C84B4-EC31-4A8F-9380-31452E3AB764 - Choose ISAs - conditions failed
04/18/2012 09:54:46AM - Checking conditions for 0FF2C23D-509B-496F-9DED-C0FE5D001E3A - Custom Choose Components - Before Pane is Displayed
04/18/2012 09:54:46AM - Checking condition 78EC68E8-BDC8-4E8E-998E-339FA70D366A - String Is Condition
04/18/2012 09:54:46AM - Checking to see if <%ShowFEATUREs%> is true
04/18/2012 09:54:46AM - Skipping pane 0FF2C23D-509B-496F-9DED-C0FE5D001E3A - Custom Choose Components - conditions failed
04/18/2012 09:54:46AM - Checking conditions for 138B95D0-F89F-46BD-861F-A7465C02821B - Custom Choose Emulators - Before Pane is Displayed
04/18/2012 09:54:46AM - Checking condition 86672030-011E-487C-9422-A4E318ACDB1E - String Is Condition
04/18/2012 09:54:46AM - Checking to see if <%ShowEMUs%> is true
04/18/2012 09:54:46AM - ** Checking to see if true is true
04/18/2012 09:54:46AM - Condition passed
04/18/2012 09:54:46AM - Executing actions 138B95D0-F89F-46BD-861F-A7465C02821B - Custom Choose Emulators - Before Pane is Displayed
04/18/2012 09:54:46AM - Executing action 04EEB113-B28D-40F7-A356-0543BA36271F - Add Emulators
04/18/2012 09:54:46AM - In Add Emulators:
04/18/2012 09:54:46AM - emulatormessagewidget .wizard.steps.f138B95D0-F89F-46BD-861F-A7465C02821B.message
04/18/2012 09:54:46AM - installed features =
04/18/2012 09:54:46AM - Displaying feature list:
04/18/2012 09:54:46AM - caught delete JTAG_Emulator_Support
04/18/2012 09:54:46AM - {JTAG Emulator Support} {JTAG Emulator Support}
04/18/2012 09:54:46AM - JTAG Emulator Support JTAG Emulator Support
04/18/2012 09:54:46AM - addgroup=0:addsub=1:level=0
04/18/2012 09:54:46AM - c: DS,Base Installation Base Installation
04/18/2012 09:54:46AM - c: EMU_NOWFLASH,JTAG Emulator Support JTAG Emulator Support
04/18/2012 09:54:46AM - initializing showcomps for JTAG Emulator Support 0
04/18/2012 09:54:46AM - 1 Component EMU_NOWFLASH is offered
04/18/2012 09:54:46AM - caught delete EMU_NOWFLASH
04/18/2012 09:54:46AM - 1 Component EMU_NOWFLASH is selected
04/18/2012 09:54:46AM - 1 Component EMU_NOWFLASH is mandatory
04/18/2012 09:54:46AM - c: EMU_C2000_FLASH,JTAG Emulator Support JTAG Emulator Support
04/18/2012 09:54:46AM - 1 Component EMU_C2000_FLASH is offered
04/18/2012 09:54:46AM - caught delete EMU_C2000_FLASH
04/18/2012 09:54:46AM - 1 Component EMU_C2000_FLASH is selected
04/18/2012 09:54:46AM - 1 Component EMU_C2000_FLASH is mandatory
04/18/2012 09:54:46AM - c: GRACE,Grace Grace
04/18/2012 09:54:46AM - c: TC_C2000_BIOS6,SYS/BIOS v6 SYS/BIOS v6
04/18/2012 09:54:46AM - c: TC_ARM_XDCTOOLS,SYS/BIOS v6 SYS/BIOS v6
04/18/2012 09:54:46AM - c: CGT_DEFAULTLIBS_C2800,Compiler Tools Compiler Tools
04/18/2012 09:54:46AM - c: EMU_STELLARIS,JTAG Emulator Support JTAG Emulator Support
04/18/2012 09:54:46AM - 1 Component EMU_STELLARIS is offered
04/18/2012 09:54:46AM - caught delete EMU_STELLARIS
04/18/2012 09:54:46AM - 1 Component EMU_STELLARIS is selected
04/18/2012 09:54:46AM - 1 Component EMU_STELLARIS is mandatory
04/18/2012 09:54:46AM - c: TC_C6000_XDCTOOLS,SYS/BIOS v6 SYS/BIOS v6
04/18/2012 09:54:46AM - c: TC_XDCTOOLS,SYS/BIOS v6 SYS/BIOS v6
04/18/2012 09:54:46AM - c: TC_XDCTOOLS_BIOS5,DSP/BIOS v5 DSP/BIOS v5
04/18/2012 09:54:46AM - c: TC_MSP430_BIOS6,SYS/BIOS v6 SYS/BIOS v6
04/18/2012 09:54:46AM - c: TC_XDAIS,SYS/BIOS v6 SYS/BIOS v6
04/18/2012 09:54:46AM - c: CGT_DEFAULTLIBS_MSP430,Compiler Tools Compiler Tools
04/18/2012 09:54:46AM - c: MSP430_CGT_HELP,Documentation Documentation
04/18/2012 09:54:46AM - c: TC_XDAIS_BIOS5,DSP/BIOS v5 DSP/BIOS v5
04/18/2012 09:54:46AM - c: EMU_C2000,JTAG Emulator Support JTAG Emulator Support
04/18/2012 09:54:46AM - 1 Component EMU_C2000 is offered
04/18/2012 09:54:46AM - 1 Component EMU_C2000 is selected
04/18/2012 09:54:46AM - 1 Component EMU_C2000 is mandatory
04/18/2012 09:54:46AM - c: TC_C6000_BIOS6,SYS/BIOS v6 SYS/BIOS v6
04/18/2012 09:54:46AM - c: TC_ARM_IPC,SYS/BIOS v6 SYS/BIOS v6
04/18/2012 09:54:46AM - c: TC_BIOS6,SYS/BIOS v6 SYS/BIOS v6
04/18/2012 09:54:46AM - c: EMU_MSP430,JTAG Emulator Support JTAG Emulator Support
04/18/2012 09:54:46AM - 1 Component EMU_MSP430 is offered
04/18/2012 09:54:46AM - caught delete EMU_MSP430
04/18/2012 09:54:46AM - 1 Component EMU_MSP430 is selected
04/18/2012 09:54:46AM - 1 Component EMU_MSP430 is mandatory
04/18/2012 09:54:46AM - 1 Found additionoptions for EMU_MSP430
04/18/2012 09:54:46AM - caught delete MSP430_Parallel_Port_FET
04/18/2012 09:54:46AM - adding group JTAG_Emulator_Support
04/18/2012 09:54:46AM - level = 0  1
04/18/2012 09:54:46AM - showcomps for JTAG Emulator Support 1
04/18/2012 09:54:46AM - caught delete MSP430_USB_FET
04/18/2012 09:54:46AM - c: DVT,Base Installation Base Installation
04/18/2012 09:54:46AM - c: EMU_BH,JTAG Emulator Support JTAG Emulator Support
04/18/2012 09:54:46AM - 1 Component EMU_BH is offered
04/18/2012 09:54:46AM - caught delete EMU_BH
04/18/2012 09:54:46AM - 1 Component EMU_BH is selected
04/18/2012 09:54:46AM - c: MSP430Ware,MSP430ware MSP430ware
04/18/2012 09:54:46AM - c: CGT_DEFAULTLIBS_C5500,Compiler Tools Compiler Tools
04/18/2012 09:54:46AM - c: DMED,Documentation Documentation
04/18/2012 09:54:46AM - c: EMU_HERCULES,JTAG Emulator Support JTAG Emulator Support
04/18/2012 09:54:46AM - 1 Component EMU_HERCULES is offered
04/18/2012 09:54:46AM - caught delete EMU_HERCULES
04/18/2012 09:54:46AM - 1 Component EMU_HERCULES is selected
04/18/2012 09:54:46AM - 1 Component EMU_HERCULES is mandatory
04/18/2012 09:54:46AM - c: TC_C2000_IPC,SYS/BIOS v6 SYS/BIOS v6
04/18/2012 09:54:46AM - c: DVT_MIN,Base Installation Base Installation
04/18/2012 09:54:46AM - c: UIA,SYS/BIOS v6 SYS/BIOS v6
04/18/2012 09:54:46AM - c: CGT_DEFAULTLIBS_TMS470,Compiler Tools Compiler Tools
04/18/2012 09:54:46AM - c: TC_BIOS5,DSP/BIOS v5 DSP/BIOS v5
04/18/2012 09:54:46AM - c: IDE,Base Installation Base Installation
04/18/2012 09:54:46AM - c: KEYSTONE1,JTAG Emulator Support JTAG Emulator Support
04/18/2012 09:54:46AM - 1 Component KEYSTONE1 is offered
04/18/2012 09:54:46AM - caught delete KEYSTONE1
04/18/2012 09:54:46AM - 1 Component KEYSTONE1 is selected
04/18/2012 09:54:46AM - 1 Component KEYSTONE1 is mandatory
04/18/2012 09:54:46AM - c: EMU_TI,JTAG Emulator Support JTAG Emulator Support
04/18/2012 09:54:46AM - 1 Component EMU_TI is offered
04/18/2012 09:54:46AM - caught delete EMU_TI
04/18/2012 09:54:46AM - 1 Component EMU_TI is selected
04/18/2012 09:54:46AM - 1 Component EMU_TI is mandatory
04/18/2012 09:54:46AM - 1 Found additionoptions for EMU_TI
04/18/2012 09:54:46AM - caught delete XDS100_Class_Emulator_Support
04/18/2012 09:54:46AM - caught delete TI_XDS560_PCI_Emulator
04/18/2012 09:54:46AM - c: TC_MSP430_IPC,SYS/BIOS v6 SYS/BIOS v6
04/18/2012 09:54:46AM - c: TC_ARM_BIOS6,SYS/BIOS v6 SYS/BIOS v6
04/18/2012 09:54:46AM - c: SIM_TI,Simulators Simulators
04/18/2012 09:54:46AM - c: CGT_DEFAULTLIBS_C6000,Compiler Tools Compiler Tools
04/18/2012 09:54:46AM - c: EMU_SD,JTAG Emulator Support JTAG Emulator Support
04/18/2012 09:54:46AM - 1 Component EMU_SD is offered
04/18/2012 09:54:46AM - caught delete EMU_SD
04/18/2012 09:54:46AM - 1 Component EMU_SD is selected
04/18/2012 09:54:46AM - c: TC_C6000_IPC,SYS/BIOS v6 SYS/BIOS v6
04/18/2012 09:54:46AM - c: TC_C2000_XDCTOOLS,SYS/BIOS v6 SYS/BIOS v6
04/18/2012 09:54:46AM - c: TC_IPC,SYS/BIOS v6 SYS/BIOS v6
04/18/2012 09:54:46AM - c: CCSINIT,Base Installation Base Installation
04/18/2012 09:54:46AM - c: C6FLO,C6EZFlo C6EZFlo
04/18/2012 09:54:46AM - c: TC_MSP430_XDCTOOLS,SYS/BIOS v6 SYS/BIOS v6
04/18/2012 09:54:46AM - c: CGT_DEFAULTLIBS_C5400,Compiler Tools Compiler Tools
04/18/2012 09:54:46AM - Displaying pane 138B95D0-F89F-46BD-861F-A7465C02821B - Custom Choose Emulators
04/18/2012 09:54:46AM - Executing actions 138B95D0-F89F-46BD-861F-A7465C02821B - Custom Choose Emulators - After Pane is Displayed
04/18/2012 09:54:47AM - Executing actions 138B95D0-F89F-46BD-861F-A7465C02821B - Custom Choose Emulators - Before Next Pane is Displayed
04/18/2012 09:54:47AM - Executing actions 970555AE-BBCE-498A-BB1F-05C2F50D8552 - Start Copying Files - Before Pane is Displayed
04/18/2012 09:54:47AM - Executing action C4EC8154-C66E-4DC2-B476-02CB1D52201E - Display Installation Information
04/18/2012 09:54:47AM - Installdir = C:\ti
04/18/2012 09:54:47AM - Space required: 5728370688.0
04/18/2012 09:54:47AM - Space available: 16837083136
04/18/2012 09:54:47AM - Disk Space Detection: Prefered 5.33 GB ; Available 15.68 GB
04/18/2012 09:54:47AM - Checking DS  -1
04/18/2012 09:54:47AM - Checking EMU_NOWFLASH  -1
04/18/2012 09:54:47AM - Checking EMU_C2000_FLASH  -1
04/18/2012 09:54:47AM - Checking GRACE  -1
04/18/2012 09:54:47AM - Checking TC_C2000_BIOS6  -1
04/18/2012 09:54:47AM - Checking TC_ARM_XDCTOOLS  -1
04/18/2012 09:54:47AM - Checking CGT_DEFAULTLIBS_C2800  -1
04/18/2012 09:54:47AM - Checking EMU_STELLARIS  -1
04/18/2012 09:54:47AM - Checking TC_C6000_XDCTOOLS  -1
04/18/2012 09:54:47AM - Checking TC_XDCTOOLS  -1
04/18/2012 09:54:47AM - Checking TC_XDCTOOLS_BIOS5  -1
04/18/2012 09:54:47AM - Checking TC_MSP430_BIOS6  -1
04/18/2012 09:54:47AM - Checking TC_XDAIS  -1
04/18/2012 09:54:47AM - Checking CGT_DEFAULTLIBS_MSP430  -1
04/18/2012 09:54:47AM - Checking MSP430_CGT_HELP  -1
04/18/2012 09:54:47AM - Checking TC_XDAIS_BIOS5  -1
04/18/2012 09:54:47AM - Checking EMU_C2000  -1
04/18/2012 09:54:47AM - Checking TC_C6000_BIOS6  -1
04/18/2012 09:54:47AM - Checking TC_ARM_IPC  -1
04/18/2012 09:54:47AM - Checking TC_BIOS6  -1
04/18/2012 09:54:47AM - Checking EMU_MSP430  -1
04/18/2012 09:54:47AM - Checking DVT  -1
04/18/2012 09:54:47AM - Checking EMU_BH  -1
04/18/2012 09:54:47AM - Checking MSP430Ware  -1
04/18/2012 09:54:47AM - Checking CGT_DEFAULTLIBS_C5500  -1
04/18/2012 09:54:47AM - Checking DMED  -1
04/18/2012 09:54:47AM - Checking EMU_HERCULES  -1
04/18/2012 09:54:47AM - Checking TC_C2000_IPC  -1
04/18/2012 09:54:47AM - Checking DVT_MIN  -1
04/18/2012 09:54:47AM - Checking UIA  -1
04/18/2012 09:54:47AM - Checking CGT_DEFAULTLIBS_TMS470  -1
04/18/2012 09:54:47AM - Checking TC_BIOS5  -1
04/18/2012 09:54:47AM - Checking IDE  -1
04/18/2012 09:54:47AM - Checking KEYSTONE1  -1
04/18/2012 09:54:47AM - Checking EMU_TI  -1
04/18/2012 09:54:47AM - Checking TC_MSP430_IPC  -1
04/18/2012 09:54:47AM - Checking TC_ARM_BIOS6  -1
04/18/2012 09:54:47AM - Checking SIM_TI  -1
04/18/2012 09:54:47AM - Checking CGT_DEFAULTLIBS_C6000  -1
04/18/2012 09:54:47AM - Checking EMU_SD  -1
04/18/2012 09:54:47AM - Checking TC_C6000_IPC  -1
04/18/2012 09:54:47AM - Checking TC_C2000_XDCTOOLS  -1
04/18/2012 09:54:47AM - Checking TC_IPC  -1
04/18/2012 09:54:47AM - Checking CCSINIT  -1
04/18/2012 09:54:47AM - Checking C6FLO  -1
04/18/2012 09:54:47AM - Checking TC_MSP430_XDCTOOLS  -1
04/18/2012 09:54:47AM - Checking CGT_DEFAULTLIBS_C5400  -1
04/18/2012 09:54:47AM - Install Directory: C:\ti/ccsv5
Setup Type: Complete Feature Set
Total Download size: 1214 MB.
Product Families selected:
 MSP430 Low Power MCUs
 C28x 32-bit Real-time MCUs
 Stellaris Cortex M MCUs
 Cortex-R4F MCUs
 AMxx Cortex-A and ARM9 processors
 OMAP
Components to be installed:
 JRE
 Eclipse
 Installer Extensions
 ARM BIOS6
 ARM IPC
 ARM XDCTools
 BIOS 5
 BIOS 6
 Blackhawk Emulators
 C2000 BIOS6
 C2000 Emulators
 C2000 IPC
 C2000 XDCTools
 C6000 BIOS6
 C6000 IPC
 C6000 XDCTools
 C6EZFlo
 CCSINIT
 DVT
 Debug Server
 Grace
 Hercules Emulation
 IPC
 Keystone1
 MSP430 BIOS6
 MSP430 Emulators
 MSP430 IPC
 MSP430 USB FET
 MSP430 XDCTools
 MSP430ware
 Stellaris Emulators
 TI Emulators
 TI Simulators
 UIA
 XDAIS
 XDCTools
 XDS100 Class Emulator Support
04/18/2012 09:54:47AM - Displaying pane 970555AE-BBCE-498A-BB1F-05C2F50D8552 - Start Copying Files
04/18/2012 09:54:47AM - Executing actions 970555AE-BBCE-498A-BB1F-05C2F50D8552 - Start Copying Files - After Pane is Displayed
04/18/2012 09:54:48AM - Executing actions 970555AE-BBCE-498A-BB1F-05C2F50D8552 - Start Copying Files - Before Next Pane is Displayed
04/18/2012 09:54:48AM - Executing actions 52C7C2BC-1F41-4249-9F63-446012A9932F - Custom Copying Files - Before Pane is Displayed
04/18/2012 09:54:48AM - Executing action 91C1A8F5-F64C-49A5-B36F-13A27CBC2B2B - Disable Buttons
04/18/2012 09:54:48AM - Displaying pane 52C7C2BC-1F41-4249-9F63-446012A9932F - Custom Copying Files
04/18/2012 09:54:48AM - Executing actions 52C7C2BC-1F41-4249-9F63-446012A9932F - Custom Copying Files - After Pane is Displayed
04/18/2012 09:54:48AM - Executing action 597A14A8-9842-4C6F-A081-5DB914701168 - Install Everything
04/18/2012 09:54:48AM - Executing actions B51DE951-D209-4A30-820D-F4333DC0F757 - Install Actions
04/18/2012 09:54:48AM - Executing action B61916A4-E55E-433E-AD86-CA546CB82EBA - debug info
04/18/2012 09:54:48AM - InstallDir from update C:\ti
04/18/2012 09:54:48AM - CCSDIR From update C:\ti/ccsv5
04/18/2012 09:54:48AM - EclipseDir from update C:\ti/ccsv5/eclipse
04/18/2012 09:54:48AM - features previously installed:
04/18/2012 09:54:48AM - previously allowed (not installed) binaries:
04/18/2012 09:54:48AM - eclipse?
04/18/2012 09:54:48AM - Executing action ED594D8A-F0DB-4A5A-B795-708DF2A90A0B - Set executable name
04/18/2012 09:54:48AM - false 0
04/18/2012 09:54:48AM - New Executable name: C:\ti/ccsv5/eclipse\ccstudio.exe
04/18/2012 09:54:48AM - Executing action 0D989427-0F69-485D-BE72-F2E935B73E52 - Set OS Specific Environment
04/18/2012 09:54:48AM - Checking conditions for F42ABA50-C9D7-4771-920C-0FEBABED0FB0 -  - Before Action is Executed
04/18/2012 09:54:48AM - Checking condition 26BBE798-0872-4727-A392-CC2E02FCE122 - String Is Condition
04/18/2012 09:54:48AM - Checking to see if <%ValidURL%> is false
04/18/2012 09:54:48AM - Condition failed
04/18/2012 09:54:48AM - Skipping action F42ABA50-C9D7-4771-920C-0FEBABED0FB0 - Invalid URL message - conditions failed
04/18/2012 09:54:48AM - Checking conditions for D8E2B8AA-EB63-47FE-82AA-45EFA802BD78 -  - Before Action is Executed
04/18/2012 09:54:48AM - Checking condition 956ED6B2-B8A2-486E-B71A-69E860C2E462 - Command Line Test Condition
04/18/2012 09:54:48AM - Checking to see if test was not passed on the command line
04/18/2012 09:54:48AM - Condition passed
04/18/2012 09:54:48AM - Executing action D8E2B8AA-EB63-47FE-82AA-45EFA802BD78 - Check URL
04/18/2012 09:54:48AM - C:/DOCUME~1/ADMINI~1/LOCALS~1/Temp/ijtmp_229DB052-F356-473E-B6A6-F22ADD191452/tmpfile
04/18/2012 09:54:48AM - Checking conditions for A74CD224-6F8B-4D98-A7F0-1B0F834CAD19 -  - Before Action is Executed
04/18/2012 09:54:48AM - Checking condition D6D6ECF6-266D-4C54-8440-A632093FECFC - String Is Condition
04/18/2012 09:54:48AM - ** Checking to see if 1 is false
04/18/2012 09:54:48AM - Skipping action A74CD224-6F8B-4D98-A7F0-1B0F834CAD19 - Invalid URL message - conditions failed
04/18/2012 09:54:48AM - Checking conditions for F747BBA6-DCBA-4CDE-B57B-EF8FD7E27CB5 -  - Before Action is Executed
04/18/2012 09:54:48AM - Checking condition A7E1D8E2-DBB1-48E9-A360-E5D12D6AADEE - String Is Condition
04/18/2012 09:54:48AM - Skipping action F747BBA6-DCBA-4CDE-B57B-EF8FD7E27CB5 - Exit - conditions failed
04/18/2012 09:54:48AM - Executing action E40D7DAD-4686-4F93-B2CD-887A95143B07 - Progress Bar Setup
04/18/2012 09:54:48AM - JRE size = 31364806
04/18/2012 09:54:48AM - Eclipse size = 114844235
04/18/2012 09:54:48AM - Checking conditions for CB835508-B3C7-4C6D-86FB-A5722D1B4066 -  - Before Action is Executed
04/18/2012 09:54:48AM - Checking condition F9DA4F2D-C63D-42EE-BD4E-C8F42BBD36FD - Command Line Test Condition
04/18/2012 09:54:48AM - Checking to see if test was passed on the command line
04/18/2012 09:54:48AM - Skipping action CB835508-B3C7-4C6D-86FB-A5722D1B4066 - Run Test Actions - conditions failed
04/18/2012 09:54:48AM - Checking conditions for A313FF31-91FB-47AB-A9D4-C81E1B2DA8C1 -  - Before Action is Executed
04/18/2012 09:54:48AM - Checking condition 28013E47-E25A-45BE-A17E-6012E53D9AD5 - Command Line Test Condition
04/18/2012 09:54:48AM - Executing action A313FF31-91FB-47AB-A9D4-C81E1B2DA8C1 - Run Production Actions
04/18/2012 09:54:48AM - Executing actions E9AEA672-9CC4-4620-91F0-031A4399B5D9 - Production Actions
04/18/2012 09:54:48AM - Executing action D41C35E7-02DC-4EEC-BA82-1BD87F61CE73 - Execute Docs Action
04/18/2012 09:54:48AM - Checking conditions for CAF3FA66-77E5-4A58-9BCA-ECFACEF580F3 - Docs Action - Before Action is Executed
04/18/2012 09:54:48AM - Checking condition 79A77474-BD66-42DC-A088-EA843BB2E8B7 - Execute Script Condition
04/18/2012 09:54:48AM - Executing actions CAF3FA66-77E5-4A58-9BCA-ECFACEF580F3 - Docs Action
04/18/2012 09:54:48AM - Checking conditions for 3A959878-9042-4438-A935-EE26E2EB7662 -  - Before Action is Executed
04/18/2012 09:54:48AM - Checking condition 2A19BE5A-DB65-49F9-9B75-106C07596482 - String Is Condition
04/18/2012 09:54:48AM - Checking to see if <%LocalRepository_Exists%> is false
04/18/2012 09:54:48AM - Skipping action 3A959878-9042-4438-A935-EE26E2EB7662 - Fetch URL - conditions failed
04/18/2012 09:54:48AM - Executing action 78203424-E9E5-49B6-B339-5B7B3DB9FBD7 - Unzip doc folder
04/18/2012 09:54:48AM - Checking conditions for 46368434-9898-4D04-B7DC-D819E2845A1F -  - Before Action is Executed
04/18/2012 09:54:48AM - Checking condition 66802838-03B1-42D6-A8EB-A7C1DF1B1FF9 - String Is Condition
04/18/2012 09:54:48AM - Checking to see if <%update_ms2005%> is true
04/18/2012 09:54:48AM - ** Checking to see if false is true
04/18/2012 09:54:48AM - Skipping action 46368434-9898-4D04-B7DC-D819E2845A1F - Execute Install MS VC++ 2005 - conditions failed
04/18/2012 09:54:48AM - Checking conditions for 090F3622-BB9B-4B48-A970-3E15EB7510A9 -  - Before Action is Executed
04/18/2012 09:54:48AM - Checking condition 06712831-ABBC-475B-830B-9118429E5B27 - String Is Condition
04/18/2012 09:54:48AM - Checking to see if <%update_ms2008%> is true
04/18/2012 09:54:48AM - Skipping action 090F3622-BB9B-4B48-A970-3E15EB7510A9 - Execute Install MS VC++ 2008 - conditions failed
04/18/2012 09:54:48AM - Executing action 6EC1F21D-0682-41CB-9A41-4D8B8CDA8EEE - Set JavaFound
04/18/2012 09:54:48AM - Found existing java in C:\ti/ccsv5/eclipse/jre/bin/java.exe
04/18/2012 09:54:48AM - Checking conditions for 2B906FC9-940C-4500-87DA-E4345F52CF11 -  - Before Action is Executed
04/18/2012 09:54:48AM - Checking condition 5FDF7E5F-01B1-4335-AF40-6E72CE1EB0BC - String Is Condition
04/18/2012 09:54:48AM - Checking to see if <%JavaFound%> is false
04/18/2012 09:54:48AM - ** Checking to see if false is false
04/18/2012 09:54:48AM - Executing action 2B906FC9-940C-4500-87DA-E4345F52CF11 - Execute Install JRE
04/18/2012 09:54:48AM - Executing actions D67C8D7B-B238-4A29-A6F9-00E6298C302A - Install JRE Component
04/18/2012 09:54:48AM - Executing action 480FB096-9061-43E9-94C5-C8CE0AE83199 - Set Variables
04/18/2012 09:54:48AM - Eclipse url = E:\CCS5.1.0.09000_win32/baserepo
04/18/2012 09:54:48AM - Executing action 23949B5E-5883-4A6E-AF02-6549EB7C7638 - Execute Checkurls
04/18/2012 09:54:48AM - Executing actions AE999821-AA3F-40B6-AB8B-8196B5813470 - Checkurls
04/18/2012 09:54:48AM - Executing action 8A399EE0-2863-4ED6-828C-3FF39CA41B1B - Execute Script
04/18/2012 09:54:48AM - URL = E:\CCS5.1.0.09000_win32/baserepo
04/18/2012 09:54:48AM - Checking conditions for C1E448F1-BD23-4DD5-9FF9-8E11158807DF -  - Before Action is Executed
04/18/2012 09:54:48AM - Checking condition D6DB77DC-925A-4E71-9569-E6794BC73D67 - String Equal Condition
04/18/2012 09:54:48AM - Checking to see if Standard equals <%InstallMode%>
04/18/2012 09:54:48AM - ** Checking to see if Standard equals Standard
04/18/2012 09:54:48AM - Checking condition 3453FED3-F12C-4269-8764-A00A112CE736 - String Is Condition
04/18/2012 09:54:48AM - Checking to see if <%urlvalid%> is false
04/18/2012 09:54:48AM - Skipping action C1E448F1-BD23-4DD5-9FF9-8E11158807DF - Message Box - conditions failed
04/18/2012 09:54:48AM - Checking conditions for 71F8EAC7-5609-4AEA-8F4F-768F4F3F368E -  - Before Action is Executed
04/18/2012 09:54:48AM - Checking condition F544F20F-E254-4294-8FEF-212A59160A67 - String Is Condition
04/18/2012 09:54:48AM - Skipping action 71F8EAC7-5609-4AEA-8F4F-768F4F3F368E - Exit - conditions failed
04/18/2012 09:54:48AM - Checking conditions for 19214A83-29B6-415D-984B-EA92CE890157 -  - Before Action is Executed
04/18/2012 09:54:48AM - Checking condition FBC58300-10C7-463E-87C1-3F2B932CACD3 - String Is Condition
04/18/2012 09:54:48AM - Skipping action 19214A83-29B6-415D-984B-EA92CE890157 - Fetch JRE - conditions failed
04/18/2012 09:54:48AM - Executing action 054249D8-4F54-4F54-86CC-0A8227959182 - Execute Checksums
04/18/2012 09:54:48AM - Executing actions 80708CAB-515B-4AE1-B901-08ED269CE819 - Checksums
04/18/2012 09:54:48AM - Executing action 3B2647A9-C7F1-454A-AD2A-0732987DE023 - Check checksum
04/18/2012 09:54:48AM - successfully downloaded E:\CCS5.1.0.09000_win32/baserepo/jre_1.6.0_13.zip 31364806 31364806
04/18/2012 09:54:48AM - downloadstatus = true
04/18/2012 09:54:48AM - Checking conditions for 235C5CEC-715D-43D0-B271-0D06AD8F2F10 -  - Before Action is Executed
04/18/2012 09:54:48AM - Checking condition EB71E428-63B6-4D7D-B285-7620C80247FA - String Equal Condition
04/18/2012 09:54:48AM - Checking condition 897DD31E-3F2B-445F-B1A9-FB08FFD6A02C - String Is Condition
04/18/2012 09:54:48AM - Checking to see if <%downloadstatus%> is false
04/18/2012 09:54:48AM - ** Checking to see if true is false
04/18/2012 09:54:48AM - Skipping action 235C5CEC-715D-43D0-B271-0D06AD8F2F10 - Message Box - conditions failed
04/18/2012 09:54:48AM - Checking conditions for C40460F1-645D-4C8B-85D8-5D233809622A -  - Before Action is Executed
04/18/2012 09:54:48AM - Checking condition 07ADB0FE-31E6-48EC-BBA2-7F2A48F50157 - String Is Condition
04/18/2012 09:54:48AM - Skipping action C40460F1-645D-4C8B-85D8-5D233809622A - Exit - conditions failed
04/18/2012 09:54:48AM - Executing action 0C868981-EA82-41C1-9E3F-67634C69B973 - Set Variables
04/18/2012 09:54:48AM - Executing action 0E9B9DAE-30DC-4EA4-A29D-6C28BC5CD257 - Unzip JRE
04/18/2012 09:54:52AM - Checking conditions for 16F6AC3A-94F8-464C-AC96-C8015C57F77D -  - Before Action is Executed
04/18/2012 09:54:52AM - Checking condition 889CC2D9-119F-45A5-9F84-6A9B37B63E3F - Platform Condition
04/18/2012 09:54:52AM - Checking to see if <%Platform%> is Linux-x86
04/18/2012 09:54:52AM - ** Checking to see if Windows is Linux-x86
04/18/2012 09:54:52AM - Condition failed
04/18/2012 09:54:52AM - Skipping action 16F6AC3A-94F8-464C-AC96-C8015C57F77D - Change File Permissions - conditions failed
04/18/2012 09:54:52AM - Executing action D52407CC-D301-46E2-8AD3-2BAF8CDEC808 - Locate this JRE
04/18/2012 09:54:52AM - Looking for C:/ti/ccsv5/eclipse/jre/bin/bin/java.exe.
04/18/2012 09:54:52AM - Executing action D4BBCA35-C8F1-4A56-9E07-A1E6CA9E0C3E - Set Variables
04/18/2012 09:54:52AM - comp_size = 31364806
tot_size = 146209041
04/18/2012 09:54:52AM - ins_complete = 2.35972319933
04/18/2012 09:54:52AM - installed percent1: 0
04/18/2012 09:54:52AM - installed percent2: 2.35972319933
04/18/2012 09:54:52AM - Checking conditions for 0E926C02-09B5-4B61-A173-2DBB0BD6C3C2 -  - Before Action is Executed
04/18/2012 09:54:52AM - Checking condition 6FF0EBFF-A517-4C11-A0F1-CC54AC2BFDCC - String Is Condition
04/18/2012 09:54:52AM - Checking to see if <%Native_Eclipse_Selected%> is false
04/18/2012 09:54:52AM - ** Checking to see if 0 is false
04/18/2012 09:54:52AM - Condition passed
04/18/2012 09:54:52AM - Checking condition 6AFC9AFB-5D68-47C1-960B-1F9D16B94F01 - String Is Condition
04/18/2012 09:54:52AM - Checking to see if <%Update_Eclipse%> is true
04/18/2012 09:54:52AM - ** Checking to see if true is true
04/18/2012 09:54:52AM - Executing action 0E926C02-09B5-4B61-A173-2DBB0BD6C3C2 - Execute Install Eclipse
04/18/2012 09:54:52AM - Executing actions B728E189-570B-4403-A0C7-9B3EC923A24F - Install Eclipse Component
04/18/2012 09:54:52AM - Executing action 0CC9BE25-F7D6-4A41-96B2-4C947ADBB2A3 - Set Variables
04/18/2012 09:54:52AM - Eclipse url = E:\CCS5.1.0.09000_win32/baserepo
04/18/2012 09:54:52AM - Executing action E52F5561-8D7D-4395-B49D-F975F0666ECC - Execute Checkurls
04/18/2012 09:54:52AM - Executing actions AE999821-AA3F-40B6-AB8B-8196B5813470 - Checkurls
04/18/2012 09:54:52AM - Executing action 8A399EE0-2863-4ED6-828C-3FF39CA41B1B - Execute Script
04/18/2012 09:54:52AM - URL = E:\CCS5.1.0.09000_win32/baserepo
04/18/2012 09:54:52AM - Checking conditions for C1E448F1-BD23-4DD5-9FF9-8E11158807DF -  - Before Action is Executed
04/18/2012 09:54:52AM - Checking condition D6DB77DC-925A-4E71-9569-E6794BC73D67 - String Equal Condition
04/18/2012 09:54:52AM - Checking to see if Standard equals <%InstallMode%>
04/18/2012 09:54:52AM - ** Checking to see if Standard equals Standard
04/18/2012 09:54:52AM - Checking condition 3453FED3-F12C-4269-8764-A00A112CE736 - String Is Condition
04/18/2012 09:54:52AM - Checking to see if <%urlvalid%> is false
04/18/2012 09:54:52AM - ** Checking to see if 1 is false
04/18/2012 09:54:52AM - Skipping action C1E448F1-BD23-4DD5-9FF9-8E11158807DF - Message Box - conditions failed
04/18/2012 09:54:52AM - Checking conditions for 71F8EAC7-5609-4AEA-8F4F-768F4F3F368E -  - Before Action is Executed
04/18/2012 09:54:52AM - Checking condition F544F20F-E254-4294-8FEF-212A59160A67 - String Is Condition
04/18/2012 09:54:52AM - Skipping action 71F8EAC7-5609-4AEA-8F4F-768F4F3F368E - Exit - conditions failed
04/18/2012 09:54:52AM - Checking conditions for BB503668-45E6-4547-8B23-7A5B4015C8AA -  - Before Action is Executed
04/18/2012 09:54:52AM - Checking condition FEC7DB76-3926-4CFB-8A00-C3CFDB2F8226 - String Is Condition
04/18/2012 09:54:52AM - Checking to see if <%LocalRepository_Exists%> is false
04/18/2012 09:54:52AM - Skipping action BB503668-45E6-4547-8B23-7A5B4015C8AA - Fetch Eclipse - conditions failed
04/18/2012 09:54:52AM - Executing action D6283DAE-7082-4D01-9333-BFC1D8B34993 - Execute Checksums
04/18/2012 09:54:52AM - Executing actions 80708CAB-515B-4AE1-B901-08ED269CE819 - Checksums
04/18/2012 09:54:52AM - Executing action 3B2647A9-C7F1-454A-AD2A-0732987DE023 - Check checksum
04/18/2012 09:54:52AM - successfully downloaded E:\CCS5.1.0.09000_win32/baserepo/eclipsebase_setup_3.7.0.0.exe 114844235 114844235
04/18/2012 09:54:52AM - downloadstatus = true
04/18/2012 09:54:52AM - Checking conditions for 235C5CEC-715D-43D0-B271-0D06AD8F2F10 -  - Before Action is Executed
04/18/2012 09:54:52AM - Checking condition EB71E428-63B6-4D7D-B285-7620C80247FA - String Equal Condition
04/18/2012 09:54:52AM - Checking condition 897DD31E-3F2B-445F-B1A9-FB08FFD6A02C - String Is Condition
04/18/2012 09:54:52AM - Checking to see if <%downloadstatus%> is false
04/18/2012 09:54:52AM - ** Checking to see if true is false
04/18/2012 09:54:52AM - Skipping action 235C5CEC-715D-43D0-B271-0D06AD8F2F10 - Message Box - conditions failed
04/18/2012 09:54:52AM - Checking conditions for C40460F1-645D-4C8B-85D8-5D233809622A -  - Before Action is Executed
04/18/2012 09:54:52AM - Checking condition 07ADB0FE-31E6-48EC-BBA2-7F2A48F50157 - String Is Condition
04/18/2012 09:54:52AM - Skipping action C40460F1-645D-4C8B-85D8-5D233809622A - Exit - conditions failed
04/18/2012 09:54:52AM - Checking conditions for A6F5E560-DE83-4DF0-882E-CAFAC953EA2A -  - Before Action is Executed
04/18/2012 09:54:52AM - Checking condition A3295F10-7947-4A0A-B38E-8B325087642B - Platform Condition
04/18/2012 09:54:52AM - Checking to see if <%Platform%> is not Windows
04/18/2012 09:54:52AM - ** Checking to see if Windows is not Windows
04/18/2012 09:54:52AM - Skipping action A6F5E560-DE83-4DF0-882E-CAFAC953EA2A - chmod executable - conditions failed
04/18/2012 09:54:52AM - Executing action 6A430D12-FCD1-45AB-93BE-330AF7445D3C - Set Variables
04/18/2012 09:54:52AM - Executing action E5D8B3D2-F45D-4C19-955E-0DDC1154A49A - Install Eclipse
04/18/2012 09:54:52AM - Executing Command Line: {E:\CCS5.1.0.09000_win32/baserepo/eclipsebase_setup_3.7.0.0.exe} --mode silent --prefix {C:\ti/ccsv5}
04/18/2012 09:55:06AM - Executing action 47B1B86E-E1A3-402E-8C25-F03E9B1A4173 - Set Variables
04/18/2012 09:55:06AM - comp_size = 114844235
04/18/2012 09:55:06AM - ins_complete = 8.64027680067
04/18/2012 09:55:06AM - installed percent1: 2.35972319933
04/18/2012 09:55:06AM - installed percent2: 11.0
04/18/2012 09:55:06AM - Executing action DDCA7A0A-A787-4D34-8075-6DA0240A6E71 - Execute Install P2
04/18/2012 09:55:06AM - Checking conditions for 9B4D3842-3F95-4E94-B04A-133D03D9FFA5 - Install P2 Component - Before Action is Executed
04/18/2012 09:55:06AM - Checking condition 7B80EE19-D209-497A-AC2B-38A878752794 - String Is Condition
04/18/2012 09:55:06AM - Checking to see if <%Update_LW%> is true
04/18/2012 09:55:06AM - ** Checking to see if true is true
04/18/2012 09:55:06AM - Condition passed
04/18/2012 09:55:06AM - Executing actions 9B4D3842-3F95-4E94-B04A-133D03D9FFA5 - Install P2 Component
04/18/2012 09:55:06AM - Executing action 9277E614-3331-4B17-95A1-29CAA681A2BC - Set Variables
04/18/2012 09:55:06AM - mcomp_repository = E:\CCS5.1.0.09000_win32/baserepo
04/18/2012 09:55:06AM - Eclipse url = file:E:\CCS5.1.0.09000_win32/baserepo
04/18/2012 09:55:06AM - Executing action 207D8884-A37F-4970-9429-CFE8BED44BCC - Execute Checkurls
04/18/2012 09:55:06AM - Executing actions AE999821-AA3F-40B6-AB8B-8196B5813470 - Checkurls
04/18/2012 09:55:06AM - Executing action 8A399EE0-2863-4ED6-828C-3FF39CA41B1B - Execute Script
04/18/2012 09:55:06AM - URL = file:E:\CCS5.1.0.09000_win32/baserepo
04/18/2012 09:55:06AM - Checking conditions for C1E448F1-BD23-4DD5-9FF9-8E11158807DF -  - Before Action is Executed
04/18/2012 09:55:06AM - Checking condition D6DB77DC-925A-4E71-9569-E6794BC73D67 - String Equal Condition
04/18/2012 09:55:06AM - Checking to see if Standard equals <%InstallMode%>
04/18/2012 09:55:06AM - ** Checking to see if Standard equals Standard
04/18/2012 09:55:06AM - Checking condition 3453FED3-F12C-4269-8764-A00A112CE736 - String Is Condition
04/18/2012 09:55:06AM - Checking to see if <%urlvalid%> is false
04/18/2012 09:55:06AM - ** Checking to see if 1 is false
04/18/2012 09:55:06AM - Condition failed
04/18/2012 09:55:06AM - Skipping action C1E448F1-BD23-4DD5-9FF9-8E11158807DF - Message Box - conditions failed
04/18/2012 09:55:06AM - Checking conditions for 71F8EAC7-5609-4AEA-8F4F-768F4F3F368E -  - Before Action is Executed
04/18/2012 09:55:06AM - Checking condition F544F20F-E254-4294-8FEF-212A59160A67 - String Is Condition
04/18/2012 09:55:06AM - Skipping action 71F8EAC7-5609-4AEA-8F4F-768F4F3F368E - Exit - conditions failed
04/18/2012 09:55:06AM - Executing action BAF2FDEB-3D8D-4176-A0F8-C70D6EDA88AE - Uninstall P2
04/18/2012 09:55:06AM - Changing to working directory C:\ti/ccsv5/eclipse
04/18/2012 09:55:06AM - Executing Command Line: {C:\ti/ccsv5/eclipse/eclipsec.exe} -application org.eclipse.equinox.p2.director -repository {file:E:\CCS5.1.0.09000_win32/baserepo} -u com.ti.ccstudio.p2.feature.group -nosplash
04/18/2012 09:55:13AM - Error while executing: Installation failed.
The installable unit com.ti.ccstudio.p2.feature.group has not been found.
Application failed, log file location: C:\ti\ccsv5\eclipse\configuration\1334714107515.log
04/18/2012 09:55:13AM - Executing action 27EBC1FF-DD01-45FD-B208-71E86E62FF3E - Install P2
04/18/2012 09:55:13AM - Changing to working directory C:\ti/ccsv5/eclipse
04/18/2012 09:55:13AM - Executing Command Line: {C:\ti/ccsv5/eclipse/eclipsec.exe} -application org.eclipse.equinox.p2.director -repository {file:E:\CCS5.1.0.09000_win32/baserepo} -installIU com.ti.ccstudio.p2.feature.group -nosplash
04/18/2012 09:55:18AM - Executing action 6BA4E63A-CA02-464D-86BD-1BE19E1E0B9B - Set Variables
04/18/2012 09:55:18AM - Executing action 9941D4EF-61A7-4261-86F4-268DB48F6740 - Execute Install P2Tools
04/18/2012 09:55:18AM - Checking conditions for 655CBF3A-CD6B-4514-B41E-16E42E741483 - Install P2Tools Component - Before Action is Executed
04/18/2012 09:55:18AM - Checking condition 54A76100-D0D7-4EAB-8FD6-52B9D7C0134F - String Is Condition
04/18/2012 09:55:18AM - Checking to see if <%Update_LW%> is true
04/18/2012 09:55:18AM - ** Checking to see if true is true
04/18/2012 09:55:18AM - Condition passed
04/18/2012 09:55:18AM - Executing actions 655CBF3A-CD6B-4514-B41E-16E42E741483 - Install P2Tools Component
04/18/2012 09:55:18AM - Executing action 2EB53AFE-7694-42C2-BD59-BEF3DF285B13 - Set Variables
04/18/2012 09:55:18AM - Eclipse url = file:E:\CCS5.1.0.09000_win32/baserepo
04/18/2012 09:55:18AM - Executing action A2ED4521-4E64-4069-865D-D827F6C4A477 - Execute Checkurls
04/18/2012 09:55:18AM - Executing actions AE999821-AA3F-40B6-AB8B-8196B5813470 - Checkurls
04/18/2012 09:55:18AM - Executing action 8A399EE0-2863-4ED6-828C-3FF39CA41B1B - Execute Script
04/18/2012 09:55:18AM - URL = file:E:\CCS5.1.0.09000_win32/baserepo
04/18/2012 09:55:18AM - Checking conditions for C1E448F1-BD23-4DD5-9FF9-8E11158807DF -  - Before Action is Executed
04/18/2012 09:55:18AM - Checking condition D6DB77DC-925A-4E71-9569-E6794BC73D67 - String Equal Condition
04/18/2012 09:55:18AM - Checking to see if Standard equals <%InstallMode%>
04/18/2012 09:55:18AM - ** Checking to see if Standard equals Standard
04/18/2012 09:55:18AM - Checking condition 3453FED3-F12C-4269-8764-A00A112CE736 - String Is Condition
04/18/2012 09:55:18AM - Checking to see if <%urlvalid%> is false
04/18/2012 09:55:18AM - ** Checking to see if 1 is false
04/18/2012 09:55:18AM - Condition failed
04/18/2012 09:55:18AM - Skipping action C1E448F1-BD23-4DD5-9FF9-8E11158807DF - Message Box - conditions failed
04/18/2012 09:55:18AM - Checking conditions for 71F8EAC7-5609-4AEA-8F4F-768F4F3F368E -  - Before Action is Executed
04/18/2012 09:55:18AM - Checking condition F544F20F-E254-4294-8FEF-212A59160A67 - String Is Condition
04/18/2012 09:55:18AM - Skipping action 71F8EAC7-5609-4AEA-8F4F-768F4F3F368E - Exit - conditions failed
04/18/2012 09:55:18AM - Executing action C8341556-FB1D-446D-8C2A-DB9A7D74CFD7 - Uninstall P2 Tools
04/18/2012 09:55:18AM - Changing to working directory C:\ti/ccsv5/eclipse
04/18/2012 09:55:18AM - Executing Command Line: {C:\ti/ccsv5/eclipse/eclipsec.exe} -application org.eclipse.equinox.p2.director -repository {file:E:\CCS5.1.0.09000_win32/baserepo} -u com.ti.ccstudio.p2tool.feature.group -nosplash
04/18/2012 09:55:24AM - Error while executing: Installation failed.
The installable unit com.ti.ccstudio.p2tool.feature.group has not been found.
Application failed, log file location: C:\ti\ccsv5\eclipse\configuration\1334714119000.log
04/18/2012 09:55:24AM - Executing action 94C70A3D-A548-45CF-BA93-B467B626ACAC - Install P2Tools
04/18/2012 09:55:24AM - Changing to working directory C:\ti/ccsv5/eclipse
04/18/2012 09:55:24AM - Executing Command Line: {C:\ti/ccsv5/eclipse/eclipsec.exe} -application org.eclipse.equinox.p2.director -repository {file:E:\CCS5.1.0.09000_win32/baserepo} -installIU com.ti.ccstudio.p2tool.feature.group -nosplash
04/18/2012 09:55:29AM - Executing action DF55BCD9-85E4-4224-8380-3A660F8A6656 - Set Variables
04/18/2012 09:55:29AM - Checking conditions for 801C0AD2-8BB1-4F6E-BB64-5C47CADEAD76 -  - Before Action is Executed
04/18/2012 09:55:29AM - Checking condition 87203921-09FC-4CC6-9B24-1FFFE423DE95 - String Is Condition
04/18/2012 09:55:29AM - Checking to see if <%UpdateMode%> is false
04/18/2012 09:55:29AM - ** Checking to see if 0 is false
04/18/2012 09:55:29AM - Condition passed
04/18/2012 09:55:29AM - Executing action 801C0AD2-8BB1-4F6E-BB64-5C47CADEAD76 - Execute Install LWInstaller
04/18/2012 09:55:29AM - Executing actions D893F839-5A29-40DA-9C49-D57B1F6D2EB5 - Install LWInstaller
04/18/2012 09:55:29AM - Executing action D26D0723-DCB8-4D62-A718-BBF8A48DE27C - Set Variables
04/18/2012 09:55:29AM - INSTALLER url = file:E:\CCS5.1.0.09000_win32/featurerepo
04/18/2012 09:55:29AM - Executing action 83377826-4232-44D5-822D-810EB9869BA6 - Install LWInstaller feature
04/18/2012 09:55:29AM - Changing to working directory C:\ti/ccsv5/eclipse
04/18/2012 09:55:29AM - Executing Command Line: {C:\ti/ccsv5/eclipse/eclipsec.exe} -application org.eclipse.equinox.p2.director -repository {file:E:\CCS5.1.0.09000_win32/featurerepo} -installIU com.ti.ccstudio.installer.win32.feature.group -nosplash
04/18/2012 09:55:34AM - Error while executing: Installation failed.
Unable to load repositories.
Application failed, log file location: C:\ti\ccsv5\eclipse\configuration\1334714129906.log
04/18/2012 09:55:34AM - Executing action 1DDB56C0-5AFA-4A76-A805-681823801B81 - Execute Checkurls
04/18/2012 09:55:34AM - Executing actions AE999821-AA3F-40B6-AB8B-8196B5813470 - Checkurls
04/18/2012 09:55:34AM - Executing action 8A399EE0-2863-4ED6-828C-3FF39CA41B1B - Execute Script
04/18/2012 09:55:34AM - URL = file:E:\CCS5.1.0.09000_win32/featurerepo
04/18/2012 09:55:34AM - Checking conditions for C1E448F1-BD23-4DD5-9FF9-8E11158807DF -  - Before Action is Executed
04/18/2012 09:55:34AM - Checking condition D6DB77DC-925A-4E71-9569-E6794BC73D67 - String Equal Condition
04/18/2012 09:55:34AM - Checking to see if Standard equals <%InstallMode%>
04/18/2012 09:55:34AM - ** Checking to see if Standard equals Standard
04/18/2012 09:55:34AM - Condition passed
04/18/2012 09:55:34AM - Checking condition 3453FED3-F12C-4269-8764-A00A112CE736 - String Is Condition
04/18/2012 09:55:34AM - Checking to see if <%urlvalid%> is false
04/18/2012 09:55:34AM - ** Checking to see if 1 is false
04/18/2012 09:55:34AM - Condition failed
04/18/2012 09:55:34AM - Skipping action C1E448F1-BD23-4DD5-9FF9-8E11158807DF - Message Box - conditions failed
04/18/2012 09:55:34AM - Checking conditions for 71F8EAC7-5609-4AEA-8F4F-768F4F3F368E -  - Before Action is Executed
04/18/2012 09:55:34AM - Checking condition F544F20F-E254-4294-8FEF-212A59160A67 - String Is Condition
04/18/2012 09:55:34AM - Skipping action 71F8EAC7-5609-4AEA-8F4F-768F4F3F368E - Exit - conditions failed
04/18/2012 09:55:34AM - Executing action 3CCF8B69-1442-40BA-96AF-881813C67920 - Set Variables
04/18/2012 09:55:34AM - Executing action 6D4C31EA-783A-4805-8548-6089DBCF461E - Execute Write CCS Config File
04/18/2012 09:55:34AM - Executing actions FED08A3A-509D-4E89-86BB-AF9BE7E7E84C -  Write ccs_config.xml File
04/18/2012 09:55:34AM - Executing action FED08A3A-509D-4E89-86BB-AF9BE7E7E84C -  Write ccs_config.xml File
04/18/2012 09:55:34AM - ccs_config: Installedfeatures
04/18/2012 09:55:34AM - components: EMU_BH {JTAG Emulator Support} CGT_DEFAULTLIBS_C2800 {Compiler Tools} TC_BIOS5 {DSP/BIOS v5} DVT_MIN {Base Installation} EMU_HERCULES {JTAG Emulator Support} TC_C6000_BIOS6 {SYS/BIOS v6} TC_ARM_IPC {SYS/BIOS v6} TC_BIOS6 {SYS/BIOS v6} IDE {Base Installation} CGT_DEFAULTLIBS_MSP430 {Compiler Tools} DMED Documentation KEYSTONE1 {JTAG Emulator Support} EMU_TI {JTAG Emulator Support} CCSINIT {Base Installation} EMU_SD {JTAG Emulator Support} SIM_TI Simulators TC_C2000_IPC {SYS/BIOS v6} DS {Base Installation} UIA {SYS/BIOS v6} CGT_DEFAULTLIBS_C5400 {Compiler Tools} TC_XDCTOOLS_BIOS5 {DSP/BIOS v5} EMU_NOWFLASH {JTAG Emulator Support} EMU_C2000_FLASH {JTAG Emulator Support} TC_MSP430_IPC {SYS/BIOS v6} TC_ARM_BIOS6 {SYS/BIOS v6} CGT_DEFAULTLIBS_C5500 {Compiler Tools} TC_XDAIS_BIOS5 {DSP/BIOS v5} EMU_STELLARIS {JTAG Emulator Support} C6FLO C6EZFlo GRACE Grace TC_C6000_IPC {SYS/BIOS v6} TC_C2000_XDCTOOLS {SYS/BIOS v6} TC_IPC {SYS/BIOS v6} CGT_DEFAULTLIBS_TMS470 {Compiler Tools} EMU_C2000 {JTAG Emulator Support} TC_MSP430_XDCTOOLS {SYS/BIOS v6} CGT_DEFAULTLIBS_C6000 {Compiler Tools} MSP430_CGT_HELP Documentation EMU_MSP430 {JTAG Emulator Support} TC_C2000_BIOS6 {SYS/BIOS v6} TC_ARM_XDCTOOLS {SYS/BIOS v6} DVT {Base Installation} MSP430Ware MSP430ware TC_C6000_XDCTOOLS {SYS/BIOS v6} TC_XDCTOOLS {SYS/BIOS v6} TC_MSP430_BIOS6 {SYS/BIOS v6} TC_XDAIS {SYS/BIOS v6}
04/18/2012 09:55:34AM - not skipping MSP430 Low Power MCUs
04/18/2012 09:55:34AM - Looking for msp430
04/18/2012 09:55:34AM - /noc2400 /noc2800 /noc5400 /noc5500 /noc6000 /noarm /noomap /nodavinci
04/18/2012 09:55:34AM - not skipping C28x 32-bit Real-time MCUs
04/18/2012 09:55:34AM - Looking for c2800
04/18/2012 09:55:34AM - /noc2400 /noc5400 /noc5500 /noc6000 /noarm /noomap /nodavinci
04/18/2012 09:55:34AM - not skipping Stellaris Cortex M MCUs
04/18/2012 09:55:34AM - Looking for arm
04/18/2012 09:55:34AM - /noc2400 /noc5400 /noc5500 /noc6000 /noomap /nodavinci
04/18/2012 09:55:34AM - not skipping Cortex-R4F MCUs
04/18/2012 09:55:34AM - not skipping AMxx Cortex-A and ARM9 processors
04/18/2012 09:55:34AM - not skipping C6x DSP + ARM processors
04/18/2012 09:55:34AM - Looking for c6000
04/18/2012 09:55:34AM - /noc2400 /noc5400 /noc5500 /noomap /nodavinci
04/18/2012 09:55:34AM - not skipping DaVinci Video Processors
04/18/2012 09:55:34AM - Looking for davinci
04/18/2012 09:55:34AM - not skipping C6000 Single Core DSPs
04/18/2012 09:55:34AM - not skipping C6000 Multi Core DSPs
04/18/2012 09:55:34AM - not skipping OMAP
04/18/2012 09:55:34AM - Looking for c5400
04/18/2012 09:55:34AM - /noc2400 /noc5500 /noomap
04/18/2012 09:55:34AM - Looking for c5500
04/18/2012 09:55:34AM - /noc2400 /noomap
04/18/2012 09:55:34AM - Looking for omap
04/18/2012 09:55:34AM - not skipping C5000 Ultra Low Power DSP
04/18/2012 09:55:34AM - writing ccs_config file: JRE
04/18/2012 09:55:34AM - writing ccs_config file: ECLIPSE
04/18/2012 09:55:34AM - writing ccs_config file: P2TOOLS
04/18/2012 09:55:34AM - writing ccs_config file: INSTALL_JAR
04/18/2012 09:55:34AM - writing ccs_config file: MSI_DLL
04/18/2012 09:55:34AM - writing ccs_config file: MSVC2008
04/18/2012 09:55:34AM - writing ccs_config file: MSVC80
04/18/2012 09:55:34AM - writing ccs_config file: INSTALLER
04/18/2012 09:55:34AM - ccs_config: searching for INSTALLER in
04/18/2012 09:55:34AM - INSTALLER is new
04/18/2012 09:55:34AM - INSTALLER is not selected INSTALLER
04/18/2012 09:55:34AM - location: E:\CCS5.1.0.09000_win32/featurerepo for INSTALLER
04/18/2012 09:55:34AM - binary = 5.1.0.09000.zip
04/18/2012 09:55:34AM - writing ccs_config file: DS
04/18/2012 09:55:34AM - ccs_config: searching for DS in
04/18/2012 09:55:34AM - DS is new
04/18/2012 09:55:34AM - DS is selected DS
04/18/2012 09:55:34AM - location: E:\CCS5.1.0.09000_win32/featurerepo for DS
04/18/2012 09:55:34AM - binary = ti_dspack_setup_5.1.0.485.exe
04/18/2012 09:55:34AM - adding DS to JRE ECLIPSE P2TOOLS INSTALL_JAR MSI_DLL MSVC2008 MSVC80
04/18/2012 09:55:34AM - writing ccs_config file: CGT_DEFAULTLIBS_C2800
04/18/2012 09:55:34AM - ccs_config: searching for CGT_DEFAULTLIBS_C2800 in
04/18/2012 09:55:34AM - CGT_DEFAULTLIBS_C2800 is new
04/18/2012 09:55:34AM - CGT_DEFAULTLIBS_C2800 is selected CGT_DEFAULTLIBS_C2800
04/18/2012 09:55:34AM - location: E:\CCS5.1.0.09000_win32/featurerepo for CGT_DEFAULTLIBS_C2800
04/18/2012 09:55:34AM - binary = ti_cgt_c2000_6.0.2_setup_win32.exe
04/18/2012 09:55:34AM - adding CGT_DEFAULTLIBS_C2800 to JRE ECLIPSE P2TOOLS INSTALL_JAR MSI_DLL MSVC2008 MSVC80 DS
04/18/2012 09:55:34AM - writing ccs_config file: CGT_DEFAULTLIBS_C5400
04/18/2012 09:55:34AM - ccs_config: searching for CGT_DEFAULTLIBS_C5400 in
04/18/2012 09:55:34AM - CGT_DEFAULTLIBS_C5400 is new
04/18/2012 09:55:34AM - CGT_DEFAULTLIBS_C5400 is selected CGT_DEFAULTLIBS_C5400
04/18/2012 09:55:34AM - location: E:\CCS5.1.0.09000_win32/featurerepo for CGT_DEFAULTLIBS_C5400
04/18/2012 09:55:34AM - binary = ld_4_2_0.zip
04/18/2012 09:55:34AM - adding CGT_DEFAULTLIBS_C5400 to JRE ECLIPSE P2TOOLS INSTALL_JAR MSI_DLL MSVC2008 MSVC80 DS CGT_DEFAULTLIBS_C2800
04/18/2012 09:55:34AM - writing ccs_config file: CGT_DEFAULTLIBS_C5500
04/18/2012 09:55:34AM - ccs_config: searching for CGT_DEFAULTLIBS_C5500 in
04/18/2012 09:55:34AM - CGT_DEFAULTLIBS_C5500 is new
04/18/2012 09:55:34AM - CGT_DEFAULTLIBS_C5500 is selected CGT_DEFAULTLIBS_C5500
04/18/2012 09:55:34AM - location: E:\CCS5.1.0.09000_win32/featurerepo for CGT_DEFAULTLIBS_C5500
04/18/2012 09:55:34AM - binary = ti_cgt_c5500_4.4.0_setup_win32.exe
04/18/2012 09:55:34AM - adding CGT_DEFAULTLIBS_C5500 to JRE ECLIPSE P2TOOLS INSTALL_JAR MSI_DLL MSVC2008 MSVC80 DS CGT_DEFAULTLIBS_C2800 CGT_DEFAULTLIBS_C5400
04/18/2012 09:55:34AM - writing ccs_config file: CGT_DEFAULTLIBS_C6000
04/18/2012 09:55:34AM - ccs_config: searching for CGT_DEFAULTLIBS_C6000 in
04/18/2012 09:55:34AM - CGT_DEFAULTLIBS_C6000 is new
04/18/2012 09:55:34AM - CGT_DEFAULTLIBS_C6000 is selected CGT_DEFAULTLIBS_C6000
04/18/2012 09:55:34AM - location: E:\CCS5.1.0.09000_win32/featurerepo for CGT_DEFAULTLIBS_C6000
04/18/2012 09:55:34AM - binary = ti_cgt_c6000_7.3.1_setup_win32.exe
04/18/2012 09:55:34AM - adding CGT_DEFAULTLIBS_C6000 to JRE ECLIPSE P2TOOLS INSTALL_JAR MSI_DLL MSVC2008 MSVC80 DS CGT_DEFAULTLIBS_C2800 CGT_DEFAULTLIBS_C5400 CGT_DEFAULTLIBS_C5500
04/18/2012 09:55:34AM - writing ccs_config file: CGT_DEFAULTLIBS_MSP430
04/18/2012 09:55:34AM - ccs_config: searching for CGT_DEFAULTLIBS_MSP430 in
04/18/2012 09:55:34AM - CGT_DEFAULTLIBS_MSP430 is new
04/18/2012 09:55:34AM - CGT_DEFAULTLIBS_MSP430 is selected CGT_DEFAULTLIBS_MSP430
04/18/2012 09:55:34AM - location: E:\CCS5.1.0.09000_win32/featurerepo for CGT_DEFAULTLIBS_MSP430
04/18/2012 09:55:34AM - binary = ti_cgt_msp430_4.0.0_setup_win32.exe
04/18/2012 09:55:34AM - adding CGT_DEFAULTLIBS_MSP430 to JRE ECLIPSE P2TOOLS INSTALL_JAR MSI_DLL MSVC2008 MSVC80 DS CGT_DEFAULTLIBS_C2800 CGT_DEFAULTLIBS_C5400 CGT_DEFAULTLIBS_C5500 CGT_DEFAULTLIBS_C6000
04/18/2012 09:55:34AM - writing ccs_config file: CGT_DEFAULTLIBS_TMS470
04/18/2012 09:55:34AM - ccs_config: searching for CGT_DEFAULTLIBS_TMS470 in
04/18/2012 09:55:34AM - CGT_DEFAULTLIBS_TMS470 is new
04/18/2012 09:55:34AM - CGT_DEFAULTLIBS_TMS470 is selected CGT_DEFAULTLIBS_TMS470
04/18/2012 09:55:34AM - location: E:\CCS5.1.0.09000_win32/featurerepo for CGT_DEFAULTLIBS_TMS470
04/18/2012 09:55:34AM - binary = ti_cgt_tms470_4.9.1_setup_win32.exe
04/18/2012 09:55:34AM - adding CGT_DEFAULTLIBS_TMS470 to JRE ECLIPSE P2TOOLS INSTALL_JAR MSI_DLL MSVC2008 MSVC80 DS CGT_DEFAULTLIBS_C2800 CGT_DEFAULTLIBS_C5400 CGT_DEFAULTLIBS_C5500 CGT_DEFAULTLIBS_C6000 CGT_DEFAULTLIBS_MSP430
04/18/2012 09:55:34AM - writing ccs_config file: IDE
04/18/2012 09:55:34AM - ccs_config: searching for IDE in
04/18/2012 09:55:34AM - IDE is new
04/18/2012 09:55:34AM - IDE is selected IDE
04/18/2012 09:55:34AM - location: E:\CCS5.1.0.09000_win32/featurerepo for IDE
04/18/2012 09:55:34AM - binary = idecore_setup_5.1.0.N201110281600.exe
04/18/2012 09:55:34AM - adding IDE to JRE ECLIPSE P2TOOLS INSTALL_JAR MSI_DLL MSVC2008 MSVC80 DS CGT_DEFAULTLIBS_C2800 CGT_DEFAULTLIBS_C5400 CGT_DEFAULTLIBS_C5500 CGT_DEFAULTLIBS_C6000 CGT_DEFAULTLIBS_MSP430 CGT_DEFAULTLIBS_TMS470
04/18/2012 09:55:34AM - writing ccs_config file: DVT
04/18/2012 09:55:34AM - ccs_config: searching for DVT in
04/18/2012 09:55:34AM - DVT is new
04/18/2012 09:55:34AM - DVT is selected DVT
04/18/2012 09:55:34AM - location: E:\CCS5.1.0.09000_win32/featurerepo for DVT
04/18/2012 09:55:34AM - binary = ti_dvt_setup_3.1.0.201110191212.exe
04/18/2012 09:55:34AM - adding DVT to JRE ECLIPSE P2TOOLS INSTALL_JAR MSI_DLL MSVC2008 MSVC80 DS CGT_DEFAULTLIBS_C2800 CGT_DEFAULTLIBS_C5400 CGT_DEFAULTLIBS_C5500 CGT_DEFAULTLIBS_C6000 CGT_DEFAULTLIBS_MSP430 CGT_DEFAULTLIBS_TMS470 IDE
04/18/2012 09:55:34AM - writing ccs_config file: DVT_MIN
04/18/2012 09:55:34AM - ccs_config: searching for DVT_MIN in
04/18/2012 09:55:34AM - DVT_MIN is new
04/18/2012 09:55:34AM - DVT_MIN is not selected DVT_MIN
04/18/2012 09:55:34AM - location: E:\CCS5.1.0.09000_win32/featurerepo for DVT_MIN
04/18/2012 09:55:34AM - binary = ti_dvt_setup_mini_3.1.0.201110191212.exe
04/18/2012 09:55:34AM - writing ccs_config file: TC_XDCTOOLS
04/18/2012 09:55:34AM - ccs_config: searching for TC_XDCTOOLS in
04/18/2012 09:55:34AM - TC_XDCTOOLS is new
04/18/2012 09:55:34AM - TC_XDCTOOLS is selected TC_XDCTOOLS
04/18/2012 09:55:34AM - location: E:\CCS5.1.0.09000_win32/featurerepo for TC_XDCTOOLS
04/18/2012 09:55:34AM - binary = xdctools_3_22_04_46_base_windows.zip
04/18/2012 09:55:34AM - adding TC_XDCTOOLS to JRE ECLIPSE P2TOOLS INSTALL_JAR MSI_DLL MSVC2008 MSVC80 DS CGT_DEFAULTLIBS_C2800 CGT_DEFAULTLIBS_C5400 CGT_DEFAULTLIBS_C5500 CGT_DEFAULTLIBS_C6000 CGT_DEFAULTLIBS_MSP430 CGT_DEFAULTLIBS_TMS470 IDE DVT
04/18/2012 09:55:34AM - writing ccs_config file: TC_ARM_XDCTOOLS
04/18/2012 09:55:34AM - ccs_config: searching for TC_ARM_XDCTOOLS in
04/18/2012 09:55:34AM - TC_ARM_XDCTOOLS is new
04/18/2012 09:55:34AM - TC_ARM_XDCTOOLS is selected TC_ARM_XDCTOOLS
04/18/2012 09:55:34AM - location: E:\CCS5.1.0.09000_win32/featurerepo for TC_ARM_XDCTOOLS
04/18/2012 09:55:34AM - binary = xdctools_3_22_04_46_arm.zip
04/18/2012 09:55:34AM - adding TC_ARM_XDCTOOLS to JRE ECLIPSE P2TOOLS INSTALL_JAR MSI_DLL MSVC2008 MSVC80 DS CGT_DEFAULTLIBS_C2800 CGT_DEFAULTLIBS_C5400 CGT_DEFAULTLIBS_C5500 CGT_DEFAULTLIBS_C6000 CGT_DEFAULTLIBS_MSP430 CGT_DEFAULTLIBS_TMS470 IDE DVT TC_XDCTOOLS
04/18/2012 09:55:34AM - writing ccs_config file: TC_C2000_XDCTOOLS
04/18/2012 09:55:34AM - ccs_config: searching for TC_C2000_XDCTOOLS in
04/18/2012 09:55:34AM - TC_C2000_XDCTOOLS is new
04/18/2012 09:55:34AM - TC_C2000_XDCTOOLS is selected TC_C2000_XDCTOOLS
04/18/2012 09:55:34AM - location: E:\CCS5.1.0.09000_win32/featurerepo for TC_C2000_XDCTOOLS
04/18/2012 09:55:34AM - binary = xdctools_3_22_04_46_c2000.zip
04/18/2012 09:55:34AM - adding TC_C2000_XDCTOOLS to JRE ECLIPSE P2TOOLS INSTALL_JAR MSI_DLL MSVC2008 MSVC80 DS CGT_DEFAULTLIBS_C2800 CGT_DEFAULTLIBS_C5400 CGT_DEFAULTLIBS_C5500 CGT_DEFAULTLIBS_C6000 CGT_DEFAULTLIBS_MSP430 CGT_DEFAULTLIBS_TMS470 IDE DVT TC_XDCTOOLS TC_ARM_XDCTOOLS
04/18/2012 09:55:34AM - writing ccs_config file: TC_C6000_XDCTOOLS
04/18/2012 09:55:34AM - ccs_config: searching for TC_C6000_XDCTOOLS in
04/18/2012 09:55:34AM - TC_C6000_XDCTOOLS is new
04/18/2012 09:55:34AM - TC_C6000_XDCTOOLS is selected TC_C6000_XDCTOOLS
04/18/2012 09:55:34AM - location: E:\CCS5.1.0.09000_win32/featurerepo for TC_C6000_XDCTOOLS
04/18/2012 09:55:34AM - binary = xdctools_3_22_04_46_c6000.zip
04/18/2012 09:55:34AM - adding TC_C6000_XDCTOOLS to JRE ECLIPSE P2TOOLS INSTALL_JAR MSI_DLL MSVC2008 MSVC80 DS CGT_DEFAULTLIBS_C2800 CGT_DEFAULTLIBS_C5400 CGT_DEFAULTLIBS_C5500 CGT_DEFAULTLIBS_C6000 CGT_DEFAULTLIBS_MSP430 CGT_DEFAULTLIBS_TMS470 IDE DVT TC_XDCTOOLS TC_ARM_XDCTOOLS TC_C2000_XDCTOOLS
04/18/2012 09:55:34AM - writing ccs_config file: TC_MSP430_XDCTOOLS
04/18/2012 09:55:34AM - ccs_config: searching for TC_MSP430_XDCTOOLS in
04/18/2012 09:55:34AM - TC_MSP430_XDCTOOLS is new
04/18/2012 09:55:34AM - TC_MSP430_XDCTOOLS is selected TC_MSP430_XDCTOOLS
04/18/2012 09:55:34AM - location: E:\CCS5.1.0.09000_win32/featurerepo for TC_MSP430_XDCTOOLS
04/18/2012 09:55:34AM - binary = xdctools_3_22_04_46_msp430.zip
04/18/2012 09:55:34AM - adding TC_MSP430_XDCTOOLS to JRE ECLIPSE P2TOOLS INSTALL_JAR MSI_DLL MSVC2008 MSVC80 DS CGT_DEFAULTLIBS_C2800 CGT_DEFAULTLIBS_C5400 CGT_DEFAULTLIBS_C5500 CGT_DEFAULTLIBS_C6000 CGT_DEFAULTLIBS_MSP430 CGT_DEFAULTLIBS_TMS470 IDE DVT TC_XDCTOOLS TC_ARM_XDCTOOLS TC_C2000_XDCTOOLS TC_C6000_XDCTOOLS
04/18/2012 09:55:34AM - writing ccs_config file: TC_BIOS5
04/18/2012 09:55:34AM - ccs_config: searching for TC_BIOS5 in
04/18/2012 09:55:34AM - TC_BIOS5 is new
04/18/2012 09:55:34AM - TC_BIOS5 is selected TC_BIOS5
04/18/2012 09:55:34AM - location: E:\CCS5.1.0.09000_win32/featurerepo for TC_BIOS5
04/18/2012 09:55:34AM - binary = bios_ccsv4_setupwin32_5_41_11_38.exe
04/18/2012 09:55:34AM - adding TC_BIOS5 to JRE ECLIPSE P2TOOLS INSTALL_JAR MSI_DLL MSVC2008 MSVC80 DS CGT_DEFAULTLIBS_C2800 CGT_DEFAULTLIBS_C5400 CGT_DEFAULTLIBS_C5500 CGT_DEFAULTLIBS_C6000 CGT_DEFAULTLIBS_MSP430 CGT_DEFAULTLIBS_TMS470 IDE DVT TC_XDCTOOLS TC_ARM_XDCTOOLS TC_C2000_XDCTOOLS TC_C6000_XDCTOOLS TC_MSP430_XDCTOOLS
04/18/2012 09:55:34AM - writing ccs_config file: TC_BIOS6
04/18/2012 09:55:34AM - ccs_config: searching for TC_BIOS6 in
04/18/2012 09:55:34AM - TC_BIOS6 is new
04/18/2012 09:55:34AM - TC_BIOS6 is selected TC_BIOS6
04/18/2012 09:55:34AM - location: E:\CCS5.1.0.09000_win32/featurerepo for TC_BIOS6
04/18/2012 09:55:34AM - binary = bios_6_32_05_54_base.zip
04/18/2012 09:55:34AM - adding TC_BIOS6 to JRE ECLIPSE P2TOOLS INSTALL_JAR MSI_DLL MSVC2008 MSVC80 DS CGT_DEFAULTLIBS_C2800 CGT_DEFAULTLIBS_C5400 CGT_DEFAULTLIBS_C5500 CGT_DEFAULTLIBS_C6000 CGT_DEFAULTLIBS_MSP430 CGT_DEFAULTLIBS_TMS470 IDE DVT TC_XDCTOOLS TC_ARM_XDCTOOLS TC_C2000_XDCTOOLS TC_C6000_XDCTOOLS TC_MSP430_XDCTOOLS TC_BIOS5
04/18/2012 09:55:34AM - writing ccs_config file: TC_ARM_BIOS6
04/18/2012 09:55:34AM - ccs_config: searching for TC_ARM_BIOS6 in
04/18/2012 09:55:34AM - TC_ARM_BIOS6 is new
04/18/2012 09:55:34AM - TC_ARM_BIOS6 is selected TC_ARM_BIOS6
04/18/2012 09:55:34AM - location: E:\CCS5.1.0.09000_win32/featurerepo for TC_ARM_BIOS6
04/18/2012 09:55:34AM - binary = bios_6_32_05_54_arm.zip
04/18/2012 09:55:34AM - adding TC_ARM_BIOS6 to JRE ECLIPSE P2TOOLS INSTALL_JAR MSI_DLL MSVC2008 MSVC80 DS CGT_DEFAULTLIBS_C2800 CGT_DEFAULTLIBS_C5400 CGT_DEFAULTLIBS_C5500 CGT_DEFAULTLIBS_C6000 CGT_DEFAULTLIBS_MSP430 CGT_DEFAULTLIBS_TMS470 IDE DVT TC_XDCTOOLS TC_ARM_XDCTOOLS TC_C2000_XDCTOOLS TC_C6000_XDCTOOLS TC_MSP430_XDCTOOLS TC_BIOS5 TC_BIOS6
04/18/2012 09:55:34AM - writing ccs_config file: TC_C2000_BIOS6
04/18/2012 09:55:34AM - ccs_config: searching for TC_C2000_BIOS6 in
04/18/2012 09:55:34AM - TC_C2000_BIOS6 is new
04/18/2012 09:55:34AM - TC_C2000_BIOS6 is selected TC_C2000_BIOS6
04/18/2012 09:55:34AM - location: E:\CCS5.1.0.09000_win32/featurerepo for TC_C2000_BIOS6
04/18/2012 09:55:34AM - binary = bios_6_32_05_54_c2000.zip
04/18/2012 09:55:34AM - adding TC_C2000_BIOS6 to JRE ECLIPSE P2TOOLS INSTALL_JAR MSI_DLL MSVC2008 MSVC80 DS CGT_DEFAULTLIBS_C2800 CGT_DEFAULTLIBS_C5400 CGT_DEFAULTLIBS_C5500 CGT_DEFAULTLIBS_C6000 CGT_DEFAULTLIBS_MSP430 CGT_DEFAULTLIBS_TMS470 IDE DVT TC_XDCTOOLS TC_ARM_XDCTOOLS TC_C2000_XDCTOOLS TC_C6000_XDCTOOLS TC_MSP430_XDCTOOLS TC_BIOS5 TC_BIOS6 TC_ARM_BIOS6
04/18/2012 09:55:34AM - writing ccs_config file: TC_C6000_BIOS6
04/18/2012 09:55:34AM - ccs_config: searching for TC_C6000_BIOS6 in
04/18/2012 09:55:34AM - TC_C6000_BIOS6 is new
04/18/2012 09:55:34AM - TC_C6000_BIOS6 is selected TC_C6000_BIOS6
04/18/2012 09:55:34AM - location: E:\CCS5.1.0.09000_win32/featurerepo for TC_C6000_BIOS6
04/18/2012 09:55:34AM - binary = bios_6_32_05_54_c6000.zip
04/18/2012 09:55:34AM - adding TC_C6000_BIOS6 to JRE ECLIPSE P2TOOLS INSTALL_JAR MSI_DLL MSVC2008 MSVC80 DS CGT_DEFAULTLIBS_C2800 CGT_DEFAULTLIBS_C5400 CGT_DEFAULTLIBS_C5500 CGT_DEFAULTLIBS_C6000 CGT_DEFAULTLIBS_MSP430 CGT_DEFAULTLIBS_TMS470 IDE DVT TC_XDCTOOLS TC_ARM_XDCTOOLS TC_C2000_XDCTOOLS TC_C6000_XDCTOOLS TC_MSP430_XDCTOOLS TC_BIOS5 TC_BIOS6 TC_ARM_BIOS6 TC_C2000_BIOS6
04/18/2012 09:55:34AM - writing ccs_config file: TC_MSP430_BIOS6
04/18/2012 09:55:34AM - ccs_config: searching for TC_MSP430_BIOS6 in
04/18/2012 09:55:34AM - TC_MSP430_BIOS6 is new
04/18/2012 09:55:34AM - TC_MSP430_BIOS6 is selected TC_MSP430_BIOS6
04/18/2012 09:55:34AM - location: E:\CCS5.1.0.09000_win32/featurerepo for TC_MSP430_BIOS6
04/18/2012 09:55:34AM - binary = bios_6_32_05_54_msp430.zip
04/18/2012 09:55:34AM - adding TC_MSP430_BIOS6 to JRE ECLIPSE P2TOOLS INSTALL_JAR MSI_DLL MSVC2008 MSVC80 DS CGT_DEFAULTLIBS_C2800 CGT_DEFAULTLIBS_C5400 CGT_DEFAULTLIBS_C5500 CGT_DEFAULTLIBS_C6000 CGT_DEFAULTLIBS_MSP430 CGT_DEFAULTLIBS_TMS470 IDE DVT TC_XDCTOOLS TC_ARM_XDCTOOLS TC_C2000_XDCTOOLS TC_C6000_XDCTOOLS TC_MSP430_XDCTOOLS TC_BIOS5 TC_BIOS6 TC_ARM_BIOS6 TC_C2000_BIOS6 TC_C6000_BIOS6
04/18/2012 09:55:34AM - writing ccs_config file: TC_IPC
04/18/2012 09:55:34AM - ccs_config: searching for TC_IPC in
04/18/2012 09:55:34AM - TC_IPC is new
04/18/2012 09:55:34AM - TC_IPC is selected TC_IPC
04/18/2012 09:55:34AM - location: E:\CCS5.1.0.09000_win32/featurerepo for TC_IPC
04/18/2012 09:55:34AM - binary = ipc_1_23_05_40_base.zip
04/18/2012 09:55:34AM - adding TC_IPC to JRE ECLIPSE P2TOOLS INSTALL_JAR MSI_DLL MSVC2008 MSVC80 DS CGT_DEFAULTLIBS_C2800 CGT_DEFAULTLIBS_C5400 CGT_DEFAULTLIBS_C5500 CGT_DEFAULTLIBS_C6000 CGT_DEFAULTLIBS_MSP430 CGT_DEFAULTLIBS_TMS470 IDE DVT TC_XDCTOOLS TC_ARM_XDCTOOLS TC_C2000_XDCTOOLS TC_C6000_XDCTOOLS TC_MSP430_XDCTOOLS TC_BIOS5 TC_BIOS6 TC_ARM_BIOS6 TC_C2000_BIOS6 TC_C6000_BIOS6 TC_MSP430_BIOS6
04/18/2012 09:55:34AM - writing ccs_config file: TC_ARM_IPC
04/18/2012 09:55:34AM - ccs_config: searching for TC_ARM_IPC in
04/18/2012 09:55:34AM - TC_ARM_IPC is new
04/18/2012 09:55:34AM - TC_ARM_IPC is selected TC_ARM_IPC
04/18/2012 09:55:34AM - location: E:\CCS5.1.0.09000_win32/featurerepo for TC_ARM_IPC
04/18/2012 09:55:34AM - binary = ipc_1_23_05_40_arm.zip
04/18/2012 09:55:34AM - adding TC_ARM_IPC to JRE ECLIPSE P2TOOLS INSTALL_JAR MSI_DLL MSVC2008 MSVC80 DS CGT_DEFAULTLIBS_C2800 CGT_DEFAULTLIBS_C5400 CGT_DEFAULTLIBS_C5500 CGT_DEFAULTLIBS_C6000 CGT_DEFAULTLIBS_MSP430 CGT_DEFAULTLIBS_TMS470 IDE DVT TC_XDCTOOLS TC_ARM_XDCTOOLS TC_C2000_XDCTOOLS TC_C6000_XDCTOOLS TC_MSP430_XDCTOOLS TC_BIOS5 TC_BIOS6 TC_ARM_BIOS6 TC_C2000_BIOS6 TC_C6000_BIOS6 TC_MSP430_BIOS6 TC_IPC
04/18/2012 09:55:34AM - writing ccs_config file: TC_C2000_IPC
04/18/2012 09:55:34AM - ccs_config: searching for TC_C2000_IPC in
04/18/2012 09:55:34AM - TC_C2000_IPC is new
04/18/2012 09:55:34AM - TC_C2000_IPC is selected TC_C2000_IPC
04/18/2012 09:55:34AM - location: E:\CCS5.1.0.09000_win32/featurerepo for TC_C2000_IPC
04/18/2012 09:55:34AM - binary = ipc_1_23_05_40_c2000.zip
04/18/2012 09:55:34AM - adding TC_C2000_IPC to JRE ECLIPSE P2TOOLS INSTALL_JAR MSI_DLL MSVC2008 MSVC80 DS CGT_DEFAULTLIBS_C2800 CGT_DEFAULTLIBS_C5400 CGT_DEFAULTLIBS_C5500 CGT_DEFAULTLIBS_C6000 CGT_DEFAULTLIBS_MSP430 CGT_DEFAULTLIBS_TMS470 IDE DVT TC_XDCTOOLS TC_ARM_XDCTOOLS TC_C2000_XDCTOOLS TC_C6000_XDCTOOLS TC_MSP430_XDCTOOLS TC_BIOS5 TC_BIOS6 TC_ARM_BIOS6 TC_C2000_BIOS6 TC_C6000_BIOS6 TC_MSP430_BIOS6 TC_IPC TC_ARM_IPC
04/18/2012 09:55:34AM - writing ccs_config file: TC_C6000_IPC
04/18/2012 09:55:34AM - ccs_config: searching for TC_C6000_IPC in
04/18/2012 09:55:34AM - TC_C6000_IPC is new
04/18/2012 09:55:34AM - TC_C6000_IPC is selected TC_C6000_IPC
04/18/2012 09:55:34AM - location: E:\CCS5.1.0.09000_win32/featurerepo for TC_C6000_IPC
04/18/2012 09:55:34AM - binary = ipc_1_23_05_40_c6000.zip
04/18/2012 09:55:34AM - adding TC_C6000_IPC to JRE ECLIPSE P2TOOLS INSTALL_JAR MSI_DLL MSVC2008 MSVC80 DS CGT_DEFAULTLIBS_C2800 CGT_DEFAULTLIBS_C5400 CGT_DEFAULTLIBS_C5500 CGT_DEFAULTLIBS_C6000 CGT_DEFAULTLIBS_MSP430 CGT_DEFAULTLIBS_TMS470 IDE DVT TC_XDCTOOLS TC_ARM_XDCTOOLS TC_C2000_XDCTOOLS TC_C6000_XDCTOOLS TC_MSP430_XDCTOOLS TC_BIOS5 TC_BIOS6 TC_ARM_BIOS6 TC_C2000_BIOS6 TC_C6000_BIOS6 TC_MSP430_BIOS6 TC_IPC TC_ARM_IPC TC_C2000_IPC
04/18/2012 09:55:34AM - writing ccs_config file: TC_MSP430_IPC
04/18/2012 09:55:34AM - ccs_config: searching for TC_MSP430_IPC in
04/18/2012 09:55:34AM - TC_MSP430_IPC is new
04/18/2012 09:55:34AM - TC_MSP430_IPC is selected TC_MSP430_IPC
04/18/2012 09:55:34AM - location: E:\CCS5.1.0.09000_win32/featurerepo for TC_MSP430_IPC
04/18/2012 09:55:34AM - binary = ipc_1_23_05_40_msp430.zip
04/18/2012 09:55:34AM - adding TC_MSP430_IPC to JRE ECLIPSE P2TOOLS INSTALL_JAR MSI_DLL MSVC2008 MSVC80 DS CGT_DEFAULTLIBS_C2800 CGT_DEFAULTLIBS_C5400 CGT_DEFAULTLIBS_C5500 CGT_DEFAULTLIBS_C6000 CGT_DEFAULTLIBS_MSP430 CGT_DEFAULTLIBS_TMS470 IDE DVT TC_XDCTOOLS TC_ARM_XDCTOOLS TC_C2000_XDCTOOLS TC_C6000_XDCTOOLS TC_MSP430_XDCTOOLS TC_BIOS5 TC_BIOS6 TC_ARM_BIOS6 TC_C2000_BIOS6 TC_C6000_BIOS6 TC_MSP430_BIOS6 TC_IPC TC_ARM_IPC TC_C2000_IPC TC_C6000_IPC
04/18/2012 09:55:34AM - writing ccs_config file: TC_XDAIS
04/18/2012 09:55:34AM - ccs_config: searching for TC_XDAIS in
04/18/2012 09:55:34AM - TC_XDAIS is new
04/18/2012 09:55:34AM - TC_XDAIS is selected TC_XDAIS
04/18/2012 09:55:34AM - location: E:\CCS5.1.0.09000_win32/featurerepo for TC_XDAIS
04/18/2012 09:55:34AM - binary = xdais_7_21_01_07.zip
04/18/2012 09:55:34AM - adding TC_XDAIS to JRE ECLIPSE P2TOOLS INSTALL_JAR MSI_DLL MSVC2008 MSVC80 DS CGT_DEFAULTLIBS_C2800 CGT_DEFAULTLIBS_C5400 CGT_DEFAULTLIBS_C5500 CGT_DEFAULTLIBS_C6000 CGT_DEFAULTLIBS_MSP430 CGT_DEFAULTLIBS_TMS470 IDE DVT TC_XDCTOOLS TC_ARM_XDCTOOLS TC_C2000_XDCTOOLS TC_C6000_XDCTOOLS TC_MSP430_XDCTOOLS TC_BIOS5 TC_BIOS6 TC_ARM_BIOS6 TC_C2000_BIOS6 TC_C6000_BIOS6 TC_MSP430_BIOS6 TC_IPC TC_ARM_IPC TC_C2000_IPC TC_C6000_IPC TC_MSP430_IPC
04/18/2012 09:55:34AM - writing ccs_config file: GRACE
04/18/2012 09:55:34AM - ccs_config: searching for GRACE in
04/18/2012 09:55:34AM - GRACE is new
04/18/2012 09:55:34AM - GRACE is selected GRACE
04/18/2012 09:55:34AM - location: E:\CCS5.1.0.09000_win32/featurerepo for GRACE
04/18/2012 09:55:34AM - binary = grace_1_10_00_17.zip
04/18/2012 09:55:34AM - adding GRACE to JRE ECLIPSE P2TOOLS INSTALL_JAR MSI_DLL MSVC2008 MSVC80 DS CGT_DEFAULTLIBS_C2800 CGT_DEFAULTLIBS_C5400 CGT_DEFAULTLIBS_C5500 CGT_DEFAULTLIBS_C6000 CGT_DEFAULTLIBS_MSP430 CGT_DEFAULTLIBS_TMS470 IDE DVT TC_XDCTOOLS TC_ARM_XDCTOOLS TC_C2000_XDCTOOLS TC_C6000_XDCTOOLS TC_MSP430_XDCTOOLS TC_BIOS5 TC_BIOS6 TC_ARM_BIOS6 TC_C2000_BIOS6 TC_C6000_BIOS6 TC_MSP430_BIOS6 TC_IPC TC_ARM_IPC TC_C2000_IPC TC_C6000_IPC TC_MSP430_IPC TC_XDAIS
04/18/2012 09:55:34AM - writing ccs_config file: UIA
04/18/2012 09:55:34AM - ccs_config: searching for UIA in
04/18/2012 09:55:34AM - UIA is new
04/18/2012 09:55:34AM - UIA is selected UIA
04/18/2012 09:55:34AM - location: E:\CCS5.1.0.09000_win32/featurerepo for UIA
04/18/2012 09:55:34AM - binary = uia_1_00_03_25.zip
04/18/2012 09:55:34AM - adding UIA to JRE ECLIPSE P2TOOLS INSTALL_JAR MSI_DLL MSVC2008 MSVC80 DS CGT_DEFAULTLIBS_C2800 CGT_DEFAULTLIBS_C5400 CGT_DEFAULTLIBS_C5500 CGT_DEFAULTLIBS_C6000 CGT_DEFAULTLIBS_MSP430 CGT_DEFAULTLIBS_TMS470 IDE DVT TC_XDCTOOLS TC_ARM_XDCTOOLS TC_C2000_XDCTOOLS TC_C6000_XDCTOOLS TC_MSP430_XDCTOOLS TC_BIOS5 TC_BIOS6 TC_ARM_BIOS6 TC_C2000_BIOS6 TC_C6000_BIOS6 TC_MSP430_BIOS6 TC_IPC TC_ARM_IPC TC_C2000_IPC TC_C6000_IPC TC_MSP430_IPC TC_XDAIS GRACE
04/18/2012 09:55:34AM - writing ccs_config file: MSP430Ware
04/18/2012 09:55:34AM - ccs_config: searching for MSP430Ware in
04/18/2012 09:55:34AM - MSP430Ware is new
04/18/2012 09:55:34AM - MSP430Ware is selected MSP430Ware
04/18/2012 09:55:34AM - location: E:\CCS5.1.0.09000_win32/featurerepo for MSP430Ware
04/18/2012 09:55:34AM - binary = msp430ware_0_00_00_10.zip
04/18/2012 09:55:34AM - adding MSP430Ware to JRE ECLIPSE P2TOOLS INSTALL_JAR MSI_DLL MSVC2008 MSVC80 DS CGT_DEFAULTLIBS_C2800 CGT_DEFAULTLIBS_C5400 CGT_DEFAULTLIBS_C5500 CGT_DEFAULTLIBS_C6000 CGT_DEFAULTLIBS_MSP430 CGT_DEFAULTLIBS_TMS470 IDE DVT TC_XDCTOOLS TC_ARM_XDCTOOLS TC_C2000_XDCTOOLS TC_C6000_XDCTOOLS TC_MSP430_XDCTOOLS TC_BIOS5 TC_BIOS6 TC_ARM_BIOS6 TC_C2000_BIOS6 TC_C6000_BIOS6 TC_MSP430_BIOS6 TC_IPC TC_ARM_IPC TC_C2000_IPC TC_C6000_IPC TC_MSP430_IPC TC_XDAIS GRACE UIA
04/18/2012 09:55:34AM - writing ccs_config file: CCSINIT
04/18/2012 09:55:34AM - ccs_config: searching for CCSINIT in
04/18/2012 09:55:34AM - CCSINIT is new
04/18/2012 09:55:34AM - CCSINIT is selected CCSINIT
04/18/2012 09:55:34AM - location: E:\CCS5.1.0.09000_win32/featurerepo for CCSINIT
04/18/2012 09:55:34AM - binary = ccsinit_setup_5.1.0.0.exe
04/18/2012 09:55:34AM - adding CCSINIT to JRE ECLIPSE P2TOOLS INSTALL_JAR MSI_DLL MSVC2008 MSVC80 DS CGT_DEFAULTLIBS_C2800 CGT_DEFAULTLIBS_C5400 CGT_DEFAULTLIBS_C5500 CGT_DEFAULTLIBS_C6000 CGT_DEFAULTLIBS_MSP430 CGT_DEFAULTLIBS_TMS470 IDE DVT TC_XDCTOOLS TC_ARM_XDCTOOLS TC_C2000_XDCTOOLS TC_C6000_XDCTOOLS TC_MSP430_XDCTOOLS TC_BIOS5 TC_BIOS6 TC_ARM_BIOS6 TC_C2000_BIOS6 TC_C6000_BIOS6 TC_MSP430_BIOS6 TC_IPC TC_ARM_IPC TC_C2000_IPC TC_C6000_IPC TC_MSP430_IPC TC_XDAIS GRACE UIA MSP430Ware
04/18/2012 09:55:34AM - writing ccs_config file: C6FLO
04/18/2012 09:55:34AM - ccs_config: searching for C6FLO in
04/18/2012 09:55:34AM - C6FLO is new
04/18/2012 09:55:34AM - C6FLO is selected C6FLO
04/18/2012 09:55:34AM - location: E:\CCS5.1.0.09000_win32/featurerepo for C6FLO
04/18/2012 09:55:34AM - binary = ti_c6flo_setup_3.1.0.201110191212.exe
04/18/2012 09:55:34AM - adding C6FLO to JRE ECLIPSE P2TOOLS INSTALL_JAR MSI_DLL MSVC2008 MSVC80 DS CGT_DEFAULTLIBS_C2800 CGT_DEFAULTLIBS_C5400 CGT_DEFAULTLIBS_C5500 CGT_DEFAULTLIBS_C6000 CGT_DEFAULTLIBS_MSP430 CGT_DEFAULTLIBS_TMS470 IDE DVT TC_XDCTOOLS TC_ARM_XDCTOOLS TC_C2000_XDCTOOLS TC_C6000_XDCTOOLS TC_MSP430_XDCTOOLS TC_BIOS5 TC_BIOS6 TC_ARM_BIOS6 TC_C2000_BIOS6 TC_C6000_BIOS6 TC_MSP430_BIOS6 TC_IPC TC_ARM_IPC TC_C2000_IPC TC_C6000_IPC TC_MSP430_IPC TC_XDAIS GRACE UIA MSP430Ware CCSINIT
04/18/2012 09:55:34AM - writing ccs_config file: SIM_TI
04/18/2012 09:55:34AM - ccs_config: searching for SIM_TI in
04/18/2012 09:55:34AM - SIM_TI is new
04/18/2012 09:55:34AM - SIM_TI is selected SIM_TI
04/18/2012 09:55:34AM - location: E:\CCS5.1.0.09000_win32/featurerepo for SIM_TI
04/18/2012 09:55:34AM - binary = ti_simpack_setup_5.1_4.12.2.0.exe
04/18/2012 09:55:34AM - adding SIM_TI to JRE ECLIPSE P2TOOLS INSTALL_JAR MSI_DLL MSVC2008 MSVC80 DS CGT_DEFAULTLIBS_C2800 CGT_DEFAULTLIBS_C5400 CGT_DEFAULTLIBS_C5500 CGT_DEFAULTLIBS_C6000 CGT_DEFAULTLIBS_MSP430 CGT_DEFAULTLIBS_TMS470 IDE DVT TC_XDCTOOLS TC_ARM_XDCTOOLS TC_C2000_XDCTOOLS TC_C6000_XDCTOOLS TC_MSP430_XDCTOOLS TC_BIOS5 TC_BIOS6 TC_ARM_BIOS6 TC_C2000_BIOS6 TC_C6000_BIOS6 TC_MSP430_BIOS6 TC_IPC TC_ARM_IPC TC_C2000_IPC TC_C6000_IPC TC_MSP430_IPC TC_XDAIS GRACE UIA MSP430Ware CCSINIT C6FLO
04/18/2012 09:55:34AM - writing ccs_config file: EMU_BH
04/18/2012 09:55:34AM - ccs_config: searching for EMU_BH in
04/18/2012 09:55:34AM - EMU_BH is new
04/18/2012 09:55:34AM - EMU_BH is selected EMU_BH
04/18/2012 09:55:34AM - location: E:\CCS5.1.0.09000_win32/featurerepo for EMU_BH
04/18/2012 09:55:34AM - binary = bh_emupack_setup_5.1.0.104.exe
04/18/2012 09:55:34AM - adding EMU_BH to JRE ECLIPSE P2TOOLS INSTALL_JAR MSI_DLL MSVC2008 MSVC80 DS CGT_DEFAULTLIBS_C2800 CGT_DEFAULTLIBS_C5400 CGT_DEFAULTLIBS_C5500 CGT_DEFAULTLIBS_C6000 CGT_DEFAULTLIBS_MSP430 CGT_DEFAULTLIBS_TMS470 IDE DVT TC_XDCTOOLS TC_ARM_XDCTOOLS TC_C2000_XDCTOOLS TC_C6000_XDCTOOLS TC_MSP430_XDCTOOLS TC_BIOS5 TC_BIOS6 TC_ARM_BIOS6 TC_C2000_BIOS6 TC_C6000_BIOS6 TC_MSP430_BIOS6 TC_IPC TC_ARM_IPC TC_C2000_IPC TC_C6000_IPC TC_MSP430_IPC TC_XDAIS GRACE UIA MSP430Ware CCSINIT C6FLO SIM_TI
04/18/2012 09:55:34AM - writing ccs_config file: EMU_TI
04/18/2012 09:55:34AM - XDS100_Class_Emulator_Support selected
04/18/2012 09:55:34AM - ccs_config: searching for EMU_TI in
04/18/2012 09:55:34AM - EMU_TI is new
04/18/2012 09:55:34AM - EMU_TI is selected EMU_TI
04/18/2012 09:55:34AM - location: E:\CCS5.1.0.09000_win32/featurerepo for EMU_TI
04/18/2012 09:55:34AM - binary = ti_emupack_setup_5.0.520.1.exe
04/18/2012 09:55:34AM - adding EMU_TI to JRE ECLIPSE P2TOOLS INSTALL_JAR MSI_DLL MSVC2008 MSVC80 DS CGT_DEFAULTLIBS_C2800 CGT_DEFAULTLIBS_C5400 CGT_DEFAULTLIBS_C5500 CGT_DEFAULTLIBS_C6000 CGT_DEFAULTLIBS_MSP430 CGT_DEFAULTLIBS_TMS470 IDE DVT TC_XDCTOOLS TC_ARM_XDCTOOLS TC_C2000_XDCTOOLS TC_C6000_XDCTOOLS TC_MSP430_XDCTOOLS TC_BIOS5 TC_BIOS6 TC_ARM_BIOS6 TC_C2000_BIOS6 TC_C6000_BIOS6 TC_MSP430_BIOS6 TC_IPC TC_ARM_IPC TC_C2000_IPC TC_C6000_IPC TC_MSP430_IPC TC_XDAIS GRACE UIA MSP430Ware CCSINIT C6FLO SIM_TI EMU_BH
04/18/2012 09:55:34AM - in ccs_config: EMU_TI: checking ::info(Check_XDS100_Class_Emulator_Support)
04/18/2012 09:55:34AM - in ccs_config: EMU_TI: checking ::info(Check_TI_XDS560_PCI_Emulator)
04/18/2012 09:55:34AM - writing ccs_config file: EMU_STELLARIS
04/18/2012 09:55:34AM - ccs_config: searching for EMU_STELLARIS in
04/18/2012 09:55:34AM - EMU_STELLARIS is new
04/18/2012 09:55:34AM - EMU_STELLARIS is selected EMU_STELLARIS
04/18/2012 09:55:34AM - location: E:\CCS5.1.0.09000_win32/featurerepo for EMU_STELLARIS
04/18/2012 09:55:34AM - binary = ti_stellaris_setup-8132.exe
04/18/2012 09:55:34AM - adding EMU_STELLARIS to JRE ECLIPSE P2TOOLS INSTALL_JAR MSI_DLL MSVC2008 MSVC80 DS CGT_DEFAULTLIBS_C2800 CGT_DEFAULTLIBS_C5400 CGT_DEFAULTLIBS_C5500 CGT_DEFAULTLIBS_C6000 CGT_DEFAULTLIBS_MSP430 CGT_DEFAULTLIBS_TMS470 IDE DVT TC_XDCTOOLS TC_ARM_XDCTOOLS TC_C2000_XDCTOOLS TC_C6000_XDCTOOLS TC_MSP430_XDCTOOLS TC_BIOS5 TC_BIOS6 TC_ARM_BIOS6 TC_C2000_BIOS6 TC_C6000_BIOS6 TC_MSP430_BIOS6 TC_IPC TC_ARM_IPC TC_C2000_IPC TC_C6000_IPC TC_MSP430_IPC TC_XDAIS GRACE UIA MSP430Ware CCSINIT C6FLO SIM_TI EMU_BH EMU_TI EMU_TI_XDS100
04/18/2012 09:55:34AM - writing ccs_config file: EMU_HERCULES
04/18/2012 09:55:34AM - ccs_config: searching for EMU_HERCULES in
04/18/2012 09:55:34AM - EMU_HERCULES is new
04/18/2012 09:55:34AM - EMU_HERCULES is selected EMU_HERCULES
04/18/2012 09:55:34AM - location: E:\CCS5.1.0.09000_win32/featurerepo for EMU_HERCULES
04/18/2012 09:55:34AM - binary = ti_hercules_setup_4.2.4.0002.exe
04/18/2012 09:55:34AM - adding EMU_HERCULES to JRE ECLIPSE P2TOOLS INSTALL_JAR MSI_DLL MSVC2008 MSVC80 DS CGT_DEFAULTLIBS_C2800 CGT_DEFAULTLIBS_C5400 CGT_DEFAULTLIBS_C5500 CGT_DEFAULTLIBS_C6000 CGT_DEFAULTLIBS_MSP430 CGT_DEFAULTLIBS_TMS470 IDE DVT TC_XDCTOOLS TC_ARM_XDCTOOLS TC_C2000_XDCTOOLS TC_C6000_XDCTOOLS TC_MSP430_XDCTOOLS TC_BIOS5 TC_BIOS6 TC_ARM_BIOS6 TC_C2000_BIOS6 TC_C6000_BIOS6 TC_MSP430_BIOS6 TC_IPC TC_ARM_IPC TC_C2000_IPC TC_C6000_IPC TC_MSP430_IPC TC_XDAIS GRACE UIA MSP430Ware CCSINIT C6FLO SIM_TI EMU_BH EMU_TI EMU_TI_XDS100 EMU_STELLARIS
04/18/2012 09:55:34AM - writing ccs_config file: EMU_SD
04/18/2012 09:55:34AM - ccs_config: searching for EMU_SD in
04/18/2012 09:55:34AM - EMU_SD is new
04/18/2012 09:55:34AM - EMU_SD is selected EMU_SD
04/18/2012 09:55:34AM - location: E:\CCS5.1.0.09000_win32/featurerepo for EMU_SD
04/18/2012 09:55:34AM - binary = sd_emupack_setup_5.1.1.05.exe
04/18/2012 09:55:34AM - adding EMU_SD to JRE ECLIPSE P2TOOLS INSTALL_JAR MSI_DLL MSVC2008 MSVC80 DS CGT_DEFAULTLIBS_C2800 CGT_DEFAULTLIBS_C5400 CGT_DEFAULTLIBS_C5500 CGT_DEFAULTLIBS_C6000 CGT_DEFAULTLIBS_MSP430 CGT_DEFAULTLIBS_TMS470 IDE DVT TC_XDCTOOLS TC_ARM_XDCTOOLS TC_C2000_XDCTOOLS TC_C6000_XDCTOOLS TC_MSP430_XDCTOOLS TC_BIOS5 TC_BIOS6 TC_ARM_BIOS6 TC_C2000_BIOS6 TC_C6000_BIOS6 TC_MSP430_BIOS6 TC_IPC TC_ARM_IPC TC_C2000_IPC TC_C6000_IPC TC_MSP430_IPC TC_XDAIS GRACE UIA MSP430Ware CCSINIT C6FLO SIM_TI EMU_BH EMU_TI EMU_TI_XDS100 EMU_STELLARIS EMU_HERCULES
04/18/2012 09:55:34AM - writing ccs_config file: EMU_C2000
04/18/2012 09:55:34AM - ccs_config: searching for EMU_C2000 in
04/18/2012 09:55:34AM - EMU_C2000 is new
04/18/2012 09:55:34AM - EMU_C2000 is selected EMU_C2000
04/18/2012 09:55:34AM - location: E:\CCS5.1.0.09000_win32/featurerepo for EMU_C2000
04/18/2012 09:55:34AM - binary = ti_c2000support_setup_2.0.0.11.exe
04/18/2012 09:55:34AM - adding EMU_C2000 to JRE ECLIPSE P2TOOLS INSTALL_JAR MSI_DLL MSVC2008 MSVC80 DS CGT_DEFAULTLIBS_C2800 CGT_DEFAULTLIBS_C5400 CGT_DEFAULTLIBS_C5500 CGT_DEFAULTLIBS_C6000 CGT_DEFAULTLIBS_MSP430 CGT_DEFAULTLIBS_TMS470 IDE DVT TC_XDCTOOLS TC_ARM_XDCTOOLS TC_C2000_XDCTOOLS TC_C6000_XDCTOOLS TC_MSP430_XDCTOOLS TC_BIOS5 TC_BIOS6 TC_ARM_BIOS6 TC_C2000_BIOS6 TC_C6000_BIOS6 TC_MSP430_BIOS6 TC_IPC TC_ARM_IPC TC_C2000_IPC TC_C6000_IPC TC_MSP430_IPC TC_XDAIS GRACE UIA MSP430Ware CCSINIT C6FLO SIM_TI EMU_BH EMU_TI EMU_TI_XDS100 EMU_STELLARIS EMU_HERCULES EMU_SD
04/18/2012 09:55:34AM - writing ccs_config file: EMU_C2000_FLASH
04/18/2012 09:55:34AM - ccs_config: searching for EMU_C2000_FLASH in
04/18/2012 09:55:34AM - EMU_C2000_FLASH is new
04/18/2012 09:55:34AM - EMU_C2000_FLASH is selected EMU_C2000_FLASH
04/18/2012 09:55:34AM - location: E:\CCS5.1.0.09000_win32/featurerepo for EMU_C2000_FLASH
04/18/2012 09:55:34AM - binary = ti_c2000_flash_setup_1.0.0.1.exe
04/18/2012 09:55:34AM - adding EMU_C2000_FLASH to JRE ECLIPSE P2TOOLS INSTALL_JAR MSI_DLL MSVC2008 MSVC80 DS CGT_DEFAULTLIBS_C2800 CGT_DEFAULTLIBS_C5400 CGT_DEFAULTLIBS_C5500 CGT_DEFAULTLIBS_C6000 CGT_DEFAULTLIBS_MSP430 CGT_DEFAULTLIBS_TMS470 IDE DVT TC_XDCTOOLS TC_ARM_XDCTOOLS TC_C2000_XDCTOOLS TC_C6000_XDCTOOLS TC_MSP430_XDCTOOLS TC_BIOS5 TC_BIOS6 TC_ARM_BIOS6 TC_C2000_BIOS6 TC_C6000_BIOS6 TC_MSP430_BIOS6 TC_IPC TC_ARM_IPC TC_C2000_IPC TC_C6000_IPC TC_MSP430_IPC TC_XDAIS GRACE UIA MSP430Ware CCSINIT C6FLO SIM_TI EMU_BH EMU_TI EMU_TI_XDS100 EMU_STELLARIS EMU_HERCULES EMU_SD EMU_C2000
04/18/2012 09:55:34AM - writing ccs_config file: EMU_MSP430
04/18/2012 09:55:34AM - MSP430_USB_FET selected
04/18/2012 09:55:34AM - ccs_config: searching for EMU_MSP430 in
04/18/2012 09:55:34AM - EMU_MSP430 is new
04/18/2012 09:55:34AM - EMU_MSP430 is selected EMU_MSP430
04/18/2012 09:55:34AM - location: E:\CCS5.1.0.09000_win32/featurerepo for EMU_MSP430
04/18/2012 09:55:34AM - binary = ti_msp430pack_setup_5.1.1.9.exe
04/18/2012 09:55:34AM - adding EMU_MSP430 to JRE ECLIPSE P2TOOLS INSTALL_JAR MSI_DLL MSVC2008 MSVC80 DS CGT_DEFAULTLIBS_C2800 CGT_DEFAULTLIBS_C5400 CGT_DEFAULTLIBS_C5500 CGT_DEFAULTLIBS_C6000 CGT_DEFAULTLIBS_MSP430 CGT_DEFAULTLIBS_TMS470 IDE DVT TC_XDCTOOLS TC_ARM_XDCTOOLS TC_C2000_XDCTOOLS TC_C6000_XDCTOOLS TC_MSP430_XDCTOOLS TC_BIOS5 TC_BIOS6 TC_ARM_BIOS6 TC_C2000_BIOS6 TC_C6000_BIOS6 TC_MSP430_BIOS6 TC_IPC TC_ARM_IPC TC_C2000_IPC TC_C6000_IPC TC_MSP430_IPC TC_XDAIS GRACE UIA MSP430Ware CCSINIT C6FLO SIM_TI EMU_BH EMU_TI EMU_TI_XDS100 EMU_STELLARIS EMU_HERCULES EMU_SD EMU_C2000 EMU_C2000_FLASH
04/18/2012 09:55:34AM - in ccs_config: EMU_MSP430: checking ::info(Check_MSP430_Parallel_Port_FET)
04/18/2012 09:55:34AM - in ccs_config: EMU_MSP430: checking ::info(Check_MSP430_USB_FET)
04/18/2012 09:55:34AM - writing ccs_config file: EMU_NOWFLASH
04/18/2012 09:55:34AM - ccs_config: searching for EMU_NOWFLASH in
04/18/2012 09:55:34AM - EMU_NOWFLASH is new
04/18/2012 09:55:34AM - EMU_NOWFLASH is selected EMU_NOWFLASH
04/18/2012 09:55:34AM - location: E:\CCS5.1.0.09000_win32/featurerepo for EMU_NOWFLASH
04/18/2012 09:55:34AM - binary = ti_ccsnowflash_setup_4.2.4.0003.exe
04/18/2012 09:55:34AM - adding EMU_NOWFLASH to JRE ECLIPSE P2TOOLS INSTALL_JAR MSI_DLL MSVC2008 MSVC80 DS CGT_DEFAULTLIBS_C2800 CGT_DEFAULTLIBS_C5400 CGT_DEFAULTLIBS_C5500 CGT_DEFAULTLIBS_C6000 CGT_DEFAULTLIBS_MSP430 CGT_DEFAULTLIBS_TMS470 IDE DVT TC_XDCTOOLS TC_ARM_XDCTOOLS TC_C2000_XDCTOOLS TC_C6000_XDCTOOLS TC_MSP430_XDCTOOLS TC_BIOS5 TC_BIOS6 TC_ARM_BIOS6 TC_C2000_BIOS6 TC_C6000_BIOS6 TC_MSP430_BIOS6 TC_IPC TC_ARM_IPC TC_C2000_IPC TC_C6000_IPC TC_MSP430_IPC TC_XDAIS GRACE UIA MSP430Ware CCSINIT C6FLO SIM_TI EMU_BH EMU_TI EMU_TI_XDS100 EMU_STELLARIS EMU_HERCULES EMU_SD EMU_C2000 EMU_C2000_FLASH EMU_MSP430 MSP430_USB
04/18/2012 09:55:34AM - writing ccs_config file: KEYSTONE1
04/18/2012 09:55:34AM - ccs_config: searching for KEYSTONE1 in
04/18/2012 09:55:34AM - KEYSTONE1 is new
04/18/2012 09:55:34AM - KEYSTONE1 is selected KEYSTONE1
04/18/2012 09:55:34AM - location: E:\CCS5.1.0.09000_win32/featurerepo for KEYSTONE1
04/18/2012 09:55:34AM - binary = ti_emupack_keystone1_setup_1.0.0.1.exe
04/18/2012 09:55:34AM - adding KEYSTONE1 to JRE ECLIPSE P2TOOLS INSTALL_JAR MSI_DLL MSVC2008 MSVC80 DS CGT_DEFAULTLIBS_C2800 CGT_DEFAULTLIBS_C5400 CGT_DEFAULTLIBS_C5500 CGT_DEFAULTLIBS_C6000 CGT_DEFAULTLIBS_MSP430 CGT_DEFAULTLIBS_TMS470 IDE DVT TC_XDCTOOLS TC_ARM_XDCTOOLS TC_C2000_XDCTOOLS TC_C6000_XDCTOOLS TC_MSP430_XDCTOOLS TC_BIOS5 TC_BIOS6 TC_ARM_BIOS6 TC_C2000_BIOS6 TC_C6000_BIOS6 TC_MSP430_BIOS6 TC_IPC TC_ARM_IPC TC_C2000_IPC TC_C6000_IPC TC_MSP430_IPC TC_XDAIS GRACE UIA MSP430Ware CCSINIT C6FLO SIM_TI EMU_BH EMU_TI EMU_TI_XDS100 EMU_STELLARIS EMU_HERCULES EMU_SD EMU_C2000 EMU_C2000_FLASH EMU_MSP430 MSP430_USB EMU_NOWFLASH
04/18/2012 09:55:34AM - writing ccs_config file: DMED
04/18/2012 09:55:34AM - ccs_config: searching for DMED in
04/18/2012 09:55:34AM - DMED is new
04/18/2012 09:55:34AM - DMED is selected DMED
04/18/2012 09:55:34AM - location: E:\CCS5.1.0.09000_win32/featurerepo for DMED
04/18/2012 09:55:34AM - binary = ti_cgt_dmed_setup_1.0.0.0.exe
04/18/2012 09:55:34AM - adding DMED to JRE ECLIPSE P2TOOLS INSTALL_JAR MSI_DLL MSVC2008 MSVC80 DS CGT_DEFAULTLIBS_C2800 CGT_DEFAULTLIBS_C5400 CGT_DEFAULTLIBS_C5500 CGT_DEFAULTLIBS_C6000 CGT_DEFAULTLIBS_MSP430 CGT_DEFAULTLIBS_TMS470 IDE DVT TC_XDCTOOLS TC_ARM_XDCTOOLS TC_C2000_XDCTOOLS TC_C6000_XDCTOOLS TC_MSP430_XDCTOOLS TC_BIOS5 TC_BIOS6 TC_ARM_BIOS6 TC_C2000_BIOS6 TC_C6000_BIOS6 TC_MSP430_BIOS6 TC_IPC TC_ARM_IPC TC_C2000_IPC TC_C6000_IPC TC_MSP430_IPC TC_XDAIS GRACE UIA MSP430Ware CCSINIT C6FLO SIM_TI EMU_BH EMU_TI EMU_TI_XDS100 EMU_STELLARIS EMU_HERCULES EMU_SD EMU_C2000 EMU_C2000_FLASH EMU_MSP430 MSP430_USB EMU_NOWFLASH KEYSTONE1
04/18/2012 09:55:34AM - writing ccs_config file: MSP430_CGT_HELP
04/18/2012 09:55:34AM - ccs_config: searching for MSP430_CGT_HELP in
04/18/2012 09:55:34AM - MSP430_CGT_HELP is new
04/18/2012 09:55:34AM - MSP430_CGT_HELP is selected MSP430_CGT_HELP
04/18/2012 09:55:34AM - location: E:\CCS5.1.0.09000_win32/featurerepo for MSP430_CGT_HELP
04/18/2012 09:55:34AM - binary = ti_cgt_msp430help_setup_4.0.0.exe
04/18/2012 09:55:34AM - adding MSP430_CGT_HELP to JRE ECLIPSE P2TOOLS INSTALL_JAR MSI_DLL MSVC2008 MSVC80 DS CGT_DEFAULTLIBS_C2800 CGT_DEFAULTLIBS_C5400 CGT_DEFAULTLIBS_C5500 CGT_DEFAULTLIBS_C6000 CGT_DEFAULTLIBS_MSP430 CGT_DEFAULTLIBS_TMS470 IDE DVT TC_XDCTOOLS TC_ARM_XDCTOOLS TC_C2000_XDCTOOLS TC_C6000_XDCTOOLS TC_MSP430_XDCTOOLS TC_BIOS5 TC_BIOS6 TC_ARM_BIOS6 TC_C2000_BIOS6 TC_C6000_BIOS6 TC_MSP430_BIOS6 TC_IPC TC_ARM_IPC TC_C2000_IPC TC_C6000_IPC TC_MSP430_IPC TC_XDAIS GRACE UIA MSP430Ware CCSINIT C6FLO SIM_TI EMU_BH EMU_TI EMU_TI_XDS100 EMU_STELLARIS EMU_HERCULES EMU_SD EMU_C2000 EMU_C2000_FLASH EMU_MSP430 MSP430_USB EMU_NOWFLASH KEYSTONE1 DMED
04/18/2012 09:55:34AM - components verified: JRE ECLIPSE P2TOOLS INSTALL_JAR MSI_DLL MSVC2008 MSVC80 INSTALLER DS CGT_DEFAULTLIBS_C2800 CGT_DEFAULTLIBS_C5400 CGT_DEFAULTLIBS_C5500 CGT_DEFAULTLIBS_C6000 CGT_DEFAULTLIBS_MSP430 CGT_DEFAULTLIBS_TMS470 IDE DVT DVT_MIN TC_XDCTOOLS TC_XDCTOOLS_BIOS5 TC_ARM_XDCTOOLS TC_C2000_XDCTOOLS TC_C6000_XDCTOOLS TC_MSP430_XDCTOOLS TC_BIOS5 TC_BIOS6 TC_ARM_BIOS6 TC_C2000_BIOS6 TC_C6000_BIOS6 TC_MSP430_BIOS6 TC_IPC TC_ARM_IPC TC_C2000_IPC TC_C6000_IPC TC_MSP430_IPC TC_XDAIS TC_XDAIS_BIOS5 GRACE UIA MSP430Ware CCSINIT C6FLO SIM_TI EMU_BH EMU_TI EMU_STELLARIS EMU_HERCULES EMU_SD EMU_C2000 EMU_C2000_FLASH EMU_MSP430 EMU_NOWFLASH KEYSTONE1 DMED MSP430_CGT_HELP
04/18/2012 09:55:34AM - adding feature list: JRE ECLIPSE P2TOOLS INSTALL_JAR MSI_DLL MSVC2008 MSVC80 DS CGT_DEFAULTLIBS_C2800 CGT_DEFAULTLIBS_C5400 CGT_DEFAULTLIBS_C5500 CGT_DEFAULTLIBS_C6000 CGT_DEFAULTLIBS_MSP430 CGT_DEFAULTLIBS_TMS470 IDE DVT TC_XDCTOOLS TC_ARM_XDCTOOLS TC_C2000_XDCTOOLS TC_C6000_XDCTOOLS TC_MSP430_XDCTOOLS TC_BIOS5 TC_BIOS6 TC_ARM_BIOS6 TC_C2000_BIOS6 TC_C6000_BIOS6 TC_MSP430_BIOS6 TC_IPC TC_ARM_IPC TC_C2000_IPC TC_C6000_IPC TC_MSP430_IPC TC_XDAIS GRACE UIA MSP430Ware CCSINIT C6FLO SIM_TI EMU_BH EMU_TI EMU_TI_XDS100 EMU_STELLARIS EMU_HERCULES EMU_SD EMU_C2000 EMU_C2000_FLASH EMU_MSP430 MSP430_USB EMU_NOWFLASH KEYSTONE1 DMED MSP430_CGT_HELP
04/18/2012 09:55:34AM - adding Product families:
04/18/2012 09:55:34AM - adding product MSP430 Low Power MCUs
04/18/2012 09:55:34AM - adding product C28x 32-bit Real-time MCUs
04/18/2012 09:55:34AM - adding product Stellaris Cortex M MCUs
04/18/2012 09:55:34AM - adding product Cortex-R4F MCUs
04/18/2012 09:55:34AM - adding product AMxx Cortex-A and ARM9 processors
04/18/2012 09:55:34AM - adding product C6x DSP + ARM processors
04/18/2012 09:55:34AM - adding product DaVinci Video Processors
04/18/2012 09:55:34AM - adding product C6000 Single Core DSPs
04/18/2012 09:55:34AM - adding product C6000 Multi Core DSPs
04/18/2012 09:55:34AM - adding product OMAP
04/18/2012 09:55:34AM - adding product C5000 Ultra Low Power DSP
04/18/2012 09:55:34AM - Executing action F5F4E6DF-AFC2-48DD-A525-BDAB727CEC7A - Execute CCSExternalReferences Action
04/18/2012 09:55:34AM - Executing actions C7F8AE2D-4F72-4319-B4C3-CF1603BB148D - CCSExternalReferences Action
04/18/2012 09:55:34AM - Executing action DD6015AF-17F4-4949-9688-1198E22040F4 - Write CCSExternalReferences
04/18/2012 09:55:34AM - Executing action EFFD310B-8A6E-49ED-9BBF-DB3EB1CED639 - Set msp430ware values
04/18/2012 09:55:34AM - Checking conditions for 83C5A9F1-B42C-43BC-BD3F-6F09F561DA64 -  - Before Action is Executed
04/18/2012 09:55:34AM - Checking condition 6FA5C6EA-EF06-4F77-BB01-282BA316028B - String Is Condition
04/18/2012 09:55:34AM - Checking to see if <%runmsp430ware%> is true
04/18/2012 09:55:34AM - ** Checking to see if true is true
04/18/2012 09:55:34AM - Executing action 83C5A9F1-B42C-43BC-BD3F-6F09F561DA64 - Write CCSExternalReferences (msp430ware)
04/18/2012 09:55:34AM - Executing action 1C99078C-C159-4C77-BE06-97B942144836 - Write ccs.properties
04/18/2012 09:55:34AM - Checking conditions for E199035E-3D19-49EE-8EA4-03DB8ED790DC -  - Before Action is Executed
04/18/2012 09:55:34AM - Checking condition 1812B83A-DC51-4100-A3BC-B96979C230E0 - String Is Condition
04/18/2012 09:55:34AM - Checking to see if <%GuiMode%> is true
04/18/2012 09:55:34AM - ** Checking to see if 1 is true
04/18/2012 09:55:34AM - Executing action E199035E-3D19-49EE-8EA4-03DB8ED790DC - Modify Widget
04/18/2012 09:55:34AM - Executing action D94E95BD-30CD-41B0-916A-05E71BCFD015 - Run LightweightInstaller
04/18/2012 09:55:34AM - Executing with progressive output
04/18/2012 09:55:34AM - Watching progressive output for special syntax.
04/18/2012 09:55:34AM - Executing Command Line: {C:\ti/ccsv5/eclipse/eclipsec.exe} -application com.ti.ccstudio.install.parser.lightWeightInstaller {C:\ti/ccsv5/eclipse/ccs_config.xml} debug -nosplash
04/18/2012 09:55:34AM - Watching progressive output for matches
04/18/2012 09:55:35AM - Download duration is 0
04/18/2012 09:55:35AM - Registering com.ti.ccstudio.debugserver.win32
04/18/2012 09:55:35AM - Eclipse register cmd feature E:\CCS5.1.0.09000_win32/featurerepo repository found
04/18/2012 09:55:35AM - No repository found at file:/E:/CCS5.1.0.09000_win32/featurerepo/.
04/18/2012 09:55:35AM - Error registering Featurecom.ti.ccstudio.debugserver.win32eclipseInstallCmd failed
04/18/2012 09:55:35AM - Duration: 125
04/18/2012 09:55:36AM - Executing action AB6BF92C-17F3-442D-B86F-DC604FCDD272 - Run SiteCleanup
04/18/2012 09:55:36AM - Executing with progressive output
04/18/2012 09:55:36AM - Watching progressive output for special syntax.
04/18/2012 09:55:36AM - Executing Command Line: {C:\ti/ccsv5/eclipse/eclipsec.exe} -application com.ti.ccstudio.install.parser.siteCleanUp -nosplash
04/18/2012 09:55:36AM - Watching progressive output for matches
04/18/2012 09:55:38AM - Executing action 31112E80-7127-4B73-B048-C6966CF28137 - Set Variables
04/18/2012 09:55:38AM - Executing action 9B3E3C6F-0705-4B76-AABC-30E6D29E9938 - Look for debugserver base plugin
04/18/2012 09:55:38AM - Did not find baseplugin
04/18/2012 09:55:38AM - Executing action 8722E38C-7F4E-4775-BFA3-E6805C927AE6 - Verify Install
04/18/2012 09:55:38AM - EclipseDir C:\ti/ccsv5/eclipse
04/18/2012 09:55:38AM - Errors: 1
04/18/2012 09:55:38AM - ccsconfig file C:\ti/ccsv5/eclipse/ccs_config.xml
04/18/2012 09:55:38AM - found C:\ti/ccsv5/eclipse/ccs_config.xml
04/18/2012 09:55:38AM - JRE state: feature installed
04/18/2012 09:55:38AM - Eclipse state: feature installed
04/18/2012 09:55:38AM - Eclipse P2 Extensions state: feature installed
04/18/2012 09:55:38AM - LightWeightInstaller state: feature installed
04/18/2012 09:55:38AM - MSI DLL state: feature installed
04/18/2012 09:55:38AM - MSVC 2008  state: feature installed
04/18/2012 09:55:38AM - MSVC 2005 state: feature installed
04/18/2012 09:55:38AM - com.ti.ccstudio.installer.win32 state: do not install
04/18/2012 09:55:38AM - ERROR: com.ti.ccstudio.debugserver.win32 state: downloaded - something went wrong with the install
04/18/2012 09:55:38AM - ERROR: com.ti.cgt.c2000.6.0.win32 state: downloaded - something went wrong with the install
04/18/2012 09:55:38AM - ERROR: com.ti.cgt.c5400.4.2.win32 state: downloaded - something went wrong with the install
04/18/2012 09:55:38AM - ERROR: com.ti.cgt.c5500.4.4.win32 state: downloaded - something went wrong with the install
04/18/2012 09:55:38AM - ERROR: com.ti.cgt.c6000.7.3.win32 state: downloaded - something went wrong with the install
04/18/2012 09:55:38AM - ERROR: com.ti.cgt.msp430.4.0.win32 state: downloaded - something went wrong with the install
04/18/2012 09:55:38AM - ERROR: com.ti.cgt.tms470.4.9.win32 state: downloaded - something went wrong with the install
04/18/2012 09:55:38AM - ERROR: com.ti.ccstudio.ide.win32 state: downloaded - something went wrong with the install
04/18/2012 09:55:38AM - ERROR: com.ti.dvt.win32 state: downloaded - something went wrong with the install
04/18/2012 09:55:38AM - com.ti.dvt.min.win32 state: do not install
04/18/2012 09:55:38AM - ERROR: com.ti.xdctools.base.3.22.win32 state: downloaded - something went wrong with the install
04/18/2012 09:55:38AM - ERROR: com.ti.xdctools.arm.3.22.win32 state: downloaded - something went wrong with the install
04/18/2012 09:55:38AM - ERROR: com.ti.xdctools.c2000.3.22.win32 state: downloaded - something went wrong with the install
04/18/2012 09:55:38AM - ERROR: com.ti.xdctools.c6000.3.22.win32 state: downloaded - something went wrong with the install
04/18/2012 09:55:38AM - ERROR: com.ti.xdctools.msp430.3.22.win32 state: downloaded - something went wrong with the install
04/18/2012 09:55:38AM - ERROR: com.ti.bios.5.41.win32 state: downloaded - something went wrong with the install
04/18/2012 09:55:38AM - ERROR: com.ti.bios.base.6.32.win32 state: downloaded - something went wrong with the install
04/18/2012 09:55:38AM - ERROR: com.ti.bios.arm.6.32.win32 state: downloaded - something went wrong with the install
04/18/2012 09:55:38AM - ERROR: com.ti.bios.c2000.6.32.win32 state: downloaded - something went wrong with the install
04/18/2012 09:55:38AM - ERROR: com.ti.bios.c6000.6.32.win32 state: downloaded - something went wrong with the install
04/18/2012 09:55:38AM - ERROR: com.ti.bios.msp430.6.32.win32 state: downloaded - something went wrong with the install
04/18/2012 09:55:38AM - ERROR: com.ti.ipc.base.1.23.win32 state: downloaded - something went wrong with the install
04/18/2012 09:55:38AM - ERROR: com.ti.ipc.arm.1.23.win32 state: downloaded - something went wrong with the install
04/18/2012 09:55:38AM - ERROR: com.ti.ipc.c2000.1.23.win32 state: downloaded - something went wrong with the install
04/18/2012 09:55:38AM - ERROR: com.ti.ipc.c6000.1.23.win32 state: downloaded - something went wrong with the install
04/18/2012 09:55:38AM - ERROR: com.ti.ipc.msp430.1.23.win32 state: downloaded - something went wrong with the install
04/18/2012 09:55:38AM - ERROR: com.ti.xdais.7.21.win32 state: downloaded - something went wrong with the install
04/18/2012 09:55:38AM - ERROR: com.ti.grace.1.10.win32 state: downloaded - something went wrong with the install
04/18/2012 09:55:38AM - ERROR: com.ti.uia.1.0.win32 state: downloaded - something went wrong with the install
04/18/2012 09:55:38AM - ERROR: com.ti.msp430.msp430ware.win32 state: downloaded - something went wrong with the install
04/18/2012 09:55:38AM - ERROR: com.ti.ccstudio.ccsinit.win32 state: downloaded - something went wrong with the install
04/18/2012 09:55:38AM - ERROR: com.ti.c6flo.win32 state: downloaded - something went wrong with the install
04/18/2012 09:55:38AM - ERROR: com.ti.sim.pack.setup.win32 state: downloaded - something went wrong with the install
04/18/2012 09:55:38AM - ERROR: com.bh.ccstudio.emulation.win32 state: downloaded - something went wrong with the install
04/18/2012 09:55:38AM - ERROR: com.ti.emulation.pack.win32 state: downloaded - something went wrong with the install
04/18/2012 09:55:38AM - ERROR: com.ti.stellaris.setup.win32 state: downloaded - something went wrong with the install
04/18/2012 09:55:38AM - ERROR: com.ti.ccstudio.hercules.win32 state: downloaded - something went wrong with the install
04/18/2012 09:55:38AM - ERROR: com.sd.ccstudio.emulation.win32 state: downloaded - something went wrong with the install
04/18/2012 09:55:38AM - ERROR: com.ti.c2000.support.win32 state: downloaded - something went wrong with the install
04/18/2012 09:55:38AM - ERROR: com.ti.c2000.flash.setup.win32 state: downloaded - something went wrong with the install
04/18/2012 09:55:38AM - ERROR: com.ti.ccstudio.msp430.emu.win32 state: downloaded - something went wrong with the install
04/18/2012 09:55:38AM - ERROR: com.ti.ccstudio.nowflash.win32 state: downloaded - something went wrong with the install
04/18/2012 09:55:38AM - ERROR: com.ti.emulation.keystone1.win32 state: downloaded - something went wrong with the install
04/18/2012 09:55:38AM - ERROR: com.ti.cgt.dmed.win32 state: downloaded - something went wrong with the install
04/18/2012 09:55:38AM - ERROR: com.ti.cgt.msp430.help.4.0.win32 state: downloaded - something went wrong with the install
04/18/2012 09:55:38AM - Errors: 45
04/18/2012 09:55:38AM - Checking conditions for C462063B-1B3F-4868-A0BE-DB3305FBA3CF -  - Before Action is Executed
04/18/2012 09:55:38AM - Checking condition D103CF1D-9800-4D77-8D82-F1E7718764C5 - String Is Condition
04/18/2012 09:55:38AM - Checking to see if <%BadInstall%> is true
04/18/2012 09:55:38AM - ** Checking to see if true is true
04/18/2012 09:55:38AM - Condition passed
04/18/2012 09:55:38AM - Executing action C462063B-1B3F-4868-A0BE-DB3305FBA3CF - Invalid Install message
04/18/2012 09:55:38AM - One or more features were not installed correctly. Please look at the logs for more information.
04/18/2012 09:55:38AM - Checking conditions for CAF7EDEC-8588-485E-BF3B-540E26298D1C -  - Before Action is Executed
04/18/2012 09:55:38AM - Checking condition 048786B6-8E1E-4425-A85F-F4EA0002FEAA - String Is Condition
04/18/2012 09:55:38AM - Checking condition CBE3A61C-D649-46E7-AA3C-D3A49CA74479 - String Equal Condition
04/18/2012 09:55:38AM - Checking to see if Standard equals <%InstallMode%>
04/18/2012 09:55:38AM - ** Checking to see if Standard equals Standard
04/18/2012 09:55:38AM - Executing action CAF7EDEC-8588-485E-BF3B-540E26298D1C - Invalid Install message
04/18/2012 09:56:12AM - Checking conditions for 4D0258A9-328B-45F9-B8D5-5422DB943090 -  - Before Action is Executed
04/18/2012 09:56:12AM - Checking condition B51D0B01-217B-4319-A2FF-B3DD4ECF0D69 - String Is Condition
04/18/2012 09:56:12AM - Checking to see if <%BadInstall%> is true
04/18/2012 09:56:12AM - ** Checking to see if true is true
04/18/2012 09:56:12AM - Condition passed
04/18/2012 09:56:12AM - Executing action 4D0258A9-328B-45F9-B8D5-5422DB943090 - Exit
Thank you very much for your attention!
I
  • Hi Xiaoyan,
    could you please send the contents of your installjammer registry directory .. found under program files or program files(x86).
    In the mean time here are things to try/check
    - what about the latest version, 5.1.1?  Have you tried that?
    - have you tried redownloading in case of corruption in the download?
    - have you unzipped the install package first?  Have you used all directories that do not have accented or special characters?
    - do you have full admin privileges?
    Are you installing to a different drive?
    Lisa
  • Hi Xiaoyan,
    I wanted to check whether the tips helps?  Would you be able to send the requested logs?
    Lisa
