CCS5 crashes when connecting or resetting DSP
Other Parts Discussed in Thread: TMS320F28334, CCSTUDIO
I'm using CCS5  5.1.1.00031 in XP Pro with SD XD510PP debugging a TMS320F28334 project. Everything seems to work fine initially, but if I let CCS5 sit disconnected for a while (while I work on my board) then try to reconnect (right click in the ccxml line in the Debug tab, the IDE crashes and needs to be reloaded. Also, all of my settings are lost and revert back to what they were when I first started the IDE. This is getting very annoying having to restart and reset all the breakpoints/watchpoints etc. Why is this happening?
  • Hi Bob,
    how are you disconnecting?  Is there any reason you do not terminate the debug session?
    Can you send any error logs or dump files generated?  (see this wiki)
    http://processors.wiki.ti.com/index.php/Troubleshooting_CCS
    Have you tried renaming ctools.dll?
    I suspect the reason your breakpoints etc are not saved might be due to the crash.
    Please keep us informed.
    Lisa
  • Things were working fine for a while (I didn't delete or change anything) and now the constant crashing is back. Here's the log files.
    # An unexpected error has been detected by Java Runtime Environment:
    #  EXCEPTION_ACCESS_VIOLATION (0xc0000005) at pc=0x34b5c893, pid=3316, tid=2316
    # Java VM: Java HotSpot(TM) Client VM (11.3-b02 mixed mode windows-x86)
    # Problematic frame:
    # C  [sdsmg51095.dll+0xc893]
    # If you would like to submit a bug report, please visit:
    #   http://java.sun.com/webapps/bugreport/crash.jsp
    # The crash happened outside the Java Virtual Machine in native code.
    # See problematic frame for where to report the bug.
    ---------------  T H R E A D  ---------------
    Current thread (0x2bf1ac00):  JavaThread "polling thread" daemon [_thread_in_native, id=2316, stack(0x30340000,0x30440000)]
    siginfo: ExceptionCode=0xc0000005, reading address 0x0000002c
    Registers:
    EAX=0x00000000, EBX=0x3043f5a4, ECX=0x00000103, EDX=0x2c57006c
    ESP=0x3043f4d0, EBP=0x3043f4e0, ESI=0x00000001, EDI=0x3043f5a8
    EIP=0x34b5c893, EFLAGS=0x00010212
    Top of Stack: (sp=0x3043f4d0)
    0x3043f4d0:   00000000 2f6d006c 00000a45 3043f438
    0x3043f4e0:   3043f510 34b5d1fd 2f6d006c 3043f5a8
    0x3043f4f0:   00000001 34a020b0 00000000 7ff9e000
    0x3043f500:   3043f560 7c80262a 00000000 2f6d006c
    0x3043f510:   3043f528 34b5b439 00000378 34a028f8
    0x3043f520:   00000000 34a0ffff 3043f818 3497cfdb
    0x3043f530:   000000cd 34a028f8 0000003f 00260000
    0x3043f540:   34b50000 3043f578 3043f578 3497d077
    Instructions: (pc=0x34b5c893)
    0x34b5c883:   70 bf b6 34 8b 42 0c 50 e8 16 f9 ff ff 83 c4 04
    0x34b5c893:   8b 48 2c 89 0d 18 c0 b6 34 83 3d 18 c0 b6 34 00
    Stack: [0x30340000,0x30440000],  sp=0x3043f4d0,  free space=1021k
    Native frames: (J=compiled Java code, j=interpreted, Vv=VM code, C=native code)
    C  [sdsmg51095.dll+0xd1fd]
    C  [sdsmg51095.dll+0xb439]
    C  [sdgo28x.dvr+0xcfdb]
    Java frames: (J=compiled Java code, j=interpreted, Vv=VM code)
    j  org.mozilla.xpcom.internal.XPCOMJavaProxy.callXPCOMMethod(Ljava/lang/Object;Ljava/lang/String;[Ljava/lang/Object;)Ljava/lang/Object;+0
    j  org.mozilla.xpcom.internal.XPCOMJavaProxy.invoke(Ljava/lang/Object;Ljava/lang/reflect/Method;[Ljava/lang/Object;)Ljava/lang/Object;+198
    j  $Proxy4.pollThreadMain()J+9
    j  com.ti.debug.engine.cce.CCEDebugEngine.pollThreadMain()J+7
    j  com.ti.debug.engine.cce.CCEDebugEngine$PollingThread.run()V+122
    v  ~StubRoutines::call_stub
    ---------------  P R O C E S S  ---------------
    Java Threads: ( => current thread )
      0x3120b800 JavaThread "Worker-48" [_thread_blocked, id=2880, stack(0x33270000,0x33370000)]
      0x30e1fc00 JavaThread "Worker-47" [_thread_blocked, id=384, stack(0x33370000,0x33470000)]
      0x310a9000 JavaThread "Worker-45" [_thread_blocked, id=3756, stack(0x30440000,0x30540000)]
      0x30fe4400 JavaThread "Worker-44" [_thread_blocked, id=2304, stack(0x30a90000,0x30b90000)]
      0x31161800 JavaThread "Worker-37" [_thread_in_native, id=620, stack(0x33170000,0x33270000)]
      0x30ea2000 JavaThread "Worker-31" [_thread_blocked, id=652, stack(0x2f870000,0x2f970000)]
      0x30e38c00 JavaThread "org.eclipse.cdt.internal.ui.text.CReconciler" daemon [_thread_blocked, id=2288, stack(0x33070000,0x33170000)]
      0x30dffc00 JavaThread "org.eclipse.jface.text.reconciler.MonoReconciler" daemon [_thread_blocked, id=1680, stack(0x30990000,0x30a90000)]
      0x310d3400 JavaThread "org.eclipse.jface.text.reconciler.MonoReconciler" daemon [_thread_blocked, id=3600, stack(0x33930000,0x33a30000)]
      0x31d0b000 JavaThread "com.ti.ccstudio.debug.debugModel - 0" [_thread_blocked, id=4008, stack(0x344d0000,0x345d0000)]
      0x2c144000 JavaThread "[ThreadPool Manager] - Idle Thread" daemon [_thread_blocked, id=2688, stack(0x343d0000,0x344d0000)]
      0x2b6fc400 JavaThread "org.eclipse.cdt.internal.ui.text.CReconciler" daemon [_thread_blocked, id=2032, stack(0x342d0000,0x343d0000)]
      0x30eba800 JavaThread "org.eclipse.cdt.internal.ui.text.CReconciler" daemon [_thread_blocked, id=2236, stack(0x341c0000,0x342c0000)]
      0x2b71d400 JavaThread "Scripting Console - Rhino" [_thread_blocked, id=2308, stack(0x33d70000,0x33e70000)]
      0x31e8a800 JavaThread "org.eclipse.cdt.internal.ui.text.CReconciler" daemon [_thread_blocked, id=3376, stack(0x32940000,0x32a40000)]
      0x30d37800 JavaThread "Bundle File Closer" daemon [_thread_blocked, id=2276, stack(0x31840000,0x31940000)]
    =>0x2bf1ac00 JavaThread "polling thread" daemon [_thread_in_native, id=2316, stack(0x30340000,0x30440000)]
      0x2b82f800 JavaThread "Worker-JM" [_thread_blocked, id=2320, stack(0x2c260000,0x2c360000)]
      0x2b77a400 JavaThread "[Timer] - Main Queue Handler" daemon [_thread_blocked, id=3260, stack(0x2bc60000,0x2bd60000)]
      0x2b72b400 JavaThread "Framework Event Dispatcher" daemon [_thread_blocked, id=3508, stack(0x2bb60000,0x2bc60000)]
      0x2b708400 JavaThread "Start Level Event Dispatcher" daemon [_thread_blocked, id=3744, stack(0x2ba60000,0x2bb60000)]
      0x2b6f4400 JavaThread "State Data Manager" daemon [_thread_blocked, id=3296, stack(0x2b960000,0x2ba60000)]
      0x2b70c800 JavaThread "Framework Active Thread" [_thread_blocked, id=1872, stack(0x2b860000,0x2b960000)]
      0x2adc5800 JavaThread "Low Memory Detector" daemon [_thread_blocked, id=700, stack(0x2b430000,0x2b530000)]
      0x2adbf400 JavaThread "CompilerThread0" daemon [_thread_blocked, id=2544, stack(0x2b330000,0x2b430000)]
      0x2adbdc00 JavaThread "Attach Listener" daemon [_thread_blocked, id=2668, stack(0x2b230000,0x2b330000)]
      0x2adbc800 JavaThread "Signal Dispatcher" daemon [_thread_blocked, id=3884, stack(0x2b130000,0x2b230000)]
      0x2adac800 JavaThread "Finalizer" daemon [_thread_blocked, id=2124, stack(0x2b030000,0x2b130000)]
      0x2ada8000 JavaThread "Reference Handler" daemon [_thread_blocked, id=616, stack(0x2af30000,0x2b030000)]
      0x009d7000 JavaThread "main" [_thread_in_native, id=2312, stack(0x00030000,0x00130000)]
    Other Threads:
      0x2ada3000 VMThread [stack: 0x2ae30000,0x2af30000] [id=840]
      0x2adc7000 WatcherThread [stack: 0x2b530000,0x2b630000] [id=828]
    VM state:not at safepoint (normal execution)
    VM Mutex/Monitor currently owned by a thread: None
    Heap
     def new generation   total 6912K, used 6368K [0x02a90000, 0x03200000, 0x04810000)
      eden space 6208K,  97% used [0x02a90000, 0x030730a8, 0x030a0000)
      from space 704K,  48% used [0x03150000, 0x031a4fd0, 0x03200000)
      to   space 704K,   0% used [0x030a0000, 0x030a0000, 0x03150000)
     tenured generation   total 90280K, used 36664K [0x04810000, 0x0a03a000, 0x1aa90000)
       the space 90280K,  40% used [0x04810000, 0x06bde0f0, 0x06bde200, 0x0a03a000)
     compacting perm gen  total 69120K, used 68866K [0x1aa90000, 0x1ee10000, 0x2aa90000)
       the space 69120K,  99% used [0x1aa90000, 0x1edd0980, 0x1edd0a00, 0x1ee10000)
    No shared spaces configured.
    Dynamic libraries:
    0x00400000 - 0x0040d000     C:\Program Files\Texas Instruments\ccsv5\ccsv5\eclipse\ccstudio.exe
    0x7c900000 - 0x7c9b2000     C:\WINDOWS\system32\ntdll.dll
    0x7c800000 - 0x7c8f6000     C:\WINDOWS\system32\kernel32.dll
    0x64d00000 - 0x64d36000     C:\Program Files\Alwil Software\Avast5\snxhk.dll
    0x7e410000 - 0x7e4a1000     C:\WINDOWS\system32\USER32.dll
    0x77f10000 - 0x77f59000     C:\WINDOWS\system32\GDI32.dll
    0x5d090000 - 0x5d12a000     C:\WINDOWS\system32\COMCTL32.dll
    0x77dd0000 - 0x77e6b000     C:\WINDOWS\system32\ADVAPI32.dll
    0x77e70000 - 0x77f03000     C:\WINDOWS\system32\RPCRT4.dll
    0x77fe0000 - 0x77ff1000     C:\WINDOWS\system32\Secur32.dll
    0x77c10000 - 0x77c68000     C:\WINDOWS\system32\MSVCRT.dll
    0x76390000 - 0x763ad000     C:\WINDOWS\system32\IMM32.DLL
    0x629c0000 - 0x629c9000     C:\WINDOWS\system32\LPK.DLL
    0x74d90000 - 0x74dfb000     C:\WINDOWS\system32\USP10.dll
    0x72000000 - 0x7200d000     C:\Program Files\Texas Instruments\ccsv5\ccsv5\eclipse\plugins\org.eclipse.equinox.launcher.win32.win32.x86_1.1.100.v20110502\eclipse_1406.dll
    0x77c00000 - 0x77c08000     C:\WINDOWS\system32\VERSION.dll
    0x5ad70000 - 0x5ada8000     C:\WINDOWS\system32\uxtheme.dll
    0x755c0000 - 0x755ee000     C:\WINDOWS\system32\msctfime.ime
    0x774e0000 - 0x7761e000     C:\WINDOWS\system32\ole32.dll
    0x6d800000 - 0x6da56000     C:\Program Files\Texas Instruments\ccsv5\ccsv5\eclipse\jre\bin\client\jvm.dll
    0x76b40000 - 0x76b6d000     C:\WINDOWS\system32\WINMM.dll
    0x7c340000 - 0x7c396000     C:\WINDOWS\system32\MSVCR71.dll
    0x6bd00000 - 0x6bd0d000     C:\WINDOWS\system32\SYNCOR11.DLL
    0x6d290000 - 0x6d298000     C:\Program Files\Texas Instruments\ccsv5\ccsv5\eclipse\jre\bin\hpi.dll
    0x76bf0000 - 0x76bfb000     C:\WINDOWS\system32\PSAPI.DLL
    0x6d7b0000 - 0x6d7bc000     C:\Program Files\Texas Instruments\ccsv5\ccsv5\eclipse\jre\bin\verify.dll
    0x6d330000 - 0x6d34f000     C:\Program Files\Texas Instruments\ccsv5\ccsv5\eclipse\jre\bin\java.dll
    0x6d7f0000 - 0x6d7ff000     C:\Program Files\Texas Instruments\ccsv5\ccsv5\eclipse\jre\bin\zip.dll
    0x68000000 - 0x68036000     C:\WINDOWS\system32\rsaenh.dll
    0x769c0000 - 0x76a74000     C:\WINDOWS\system32\USERENV.dll
    0x5b860000 - 0x5b8b5000     C:\WINDOWS\system32\netapi32.dll
    0x6d610000 - 0x6d623000     C:\Program Files\Texas Instruments\ccsv5\ccsv5\eclipse\jre\bin\net.dll
    0x71ab0000 - 0x71ac7000     C:\WINDOWS\system32\WS2_32.dll
    0x71aa0000 - 0x71aa8000     C:\WINDOWS\system32\WS2HELP.dll
    0x71a50000 - 0x71a8f000     C:\WINDOWS\System32\mswsock.dll
    0x76f20000 - 0x76f47000     C:\WINDOWS\system32\DNSAPI.dll
    0x76d60000 - 0x76d79000     C:\WINDOWS\system32\iphlpapi.dll
    0x76fb0000 - 0x76fb8000     C:\WINDOWS\System32\winrnr.dll
    0x76f60000 - 0x76f8c000     C:\WINDOWS\system32\WLDAP32.dll
    0x76fc0000 - 0x76fc6000     C:\WINDOWS\system32\rasadhlp.dll
    0x6d630000 - 0x6d639000     C:\Program Files\Texas Instruments\ccsv5\ccsv5\eclipse\jre\bin\nio.dll
    0x2c370000 - 0x2c3de000     C:\Program Files\Texas Instruments\ccsv5\ccsv5\eclipse\configuration\org.eclipse.osgi\bundles\523\1\.cp\swt-win32-3738.dll
    0x77120000 - 0x771ab000     C:\WINDOWS\system32\OLEAUT32.dll
    0x763b0000 - 0x763f9000     C:\WINDOWS\system32\comdlg32.dll
    0x773d0000 - 0x774d3000     C:\WINDOWS\WinSxS\x86_Microsoft.Windows.Common-Controls_6595b64144ccf1df_6.0.2600.6028_x-ww_61e65202\COMCTL32.dll
    0x77f60000 - 0x77fd6000     C:\WINDOWS\system32\SHLWAPI.dll
    0x7c9c0000 - 0x7d1d7000     C:\WINDOWS\system32\SHELL32.dll
    0x73000000 - 0x73026000     C:\WINDOWS\system32\WINSPOOL.DRV
    0x3d930000 - 0x3da01000     C:\WINDOWS\system32\WININET.dll
    0x2c3f0000 - 0x2c3f9000     C:\WINDOWS\system32\Normaliz.dll
    0x3dfd0000 - 0x3e015000     C:\WINDOWS\system32\iertutil.dll
    0x77a80000 - 0x77b15000     C:\WINDOWS\system32\CRYPT32.dll
    0x77b20000 - 0x77b32000     C:\WINDOWS\system32\MSASN1.dll
    0x2c660000 - 0x2c666000     C:\Program Files\Texas Instruments\ccsv5\ccsv5\ccs_base\DebugServer\bin\win32\LibraryLoader.dll
    0x7c420000 - 0x7c4a7000     C:\WINDOWS\WinSxS\x86_Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_8.0.50727.6195_x-ww_44262b86\MSVCP80.dll
    0x78130000 - 0x781cb000     C:\WINDOWS\WinSxS\x86_Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_8.0.50727.6195_x-ww_44262b86\MSVCR80.dll
    0x2c6d0000 - 0x2c8c2000     C:\Program Files\Texas Instruments\ccsv5\ccsv5\ccs_base\common\bin\xerces-c_2_5_0.dll
    0x2c6a0000 - 0x2c6c0000     C:\Program Files\Texas Instruments\ccsv5\ccsv5\ccs_base\common\bin\ti_logger.dll
    0x2c8e0000 - 0x2c955000     C:\Program Files\Texas Instruments\ccsv5\ccsv5\ccs_base\common\bin\C4DLL.DLL
    0x2ca70000 - 0x2ca80000     C:\Program Files\Texas Instruments\ccsv5\ccsv5\ccs_base\common\bin\CCReg.dll
    0x2ca90000 - 0x2cad2000     C:\Program Files\Texas Instruments\ccsv5\ccsv5\ccs_base\common\bin\fsutil.dll
    0x2caf0000 - 0x2caf8000     C:\Program Files\Texas Instruments\ccsv5\ccsv5\ccs_base\common\bin\fsutiljni.dll
    0x2cb10000 - 0x2cb19000     C:\Program Files\Texas Instruments\ccsv5\ccsv5\ccs_base\common\bin\MiniDump.dll
    0x2cb30000 - 0x2cbc3000     C:\Program Files\Texas Instruments\ccsv5\ccsv5\ccs_base\common\bin\rtdx.dll
    0x2cbd0000 - 0x2cd40000     C:\Program Files\Texas Instruments\ccsv5\ccsv5\ccs_base\common\bin\setup_parser.dll
    0x2cd50000 - 0x2cd5d000     C:\Program Files\Texas Instruments\ccsv5\ccsv5\ccs_base\common\bin\ti_targetdb_parser.dll
    0x78480000 - 0x7850e000     C:\WINDOWS\WinSxS\x86_Microsoft.VC90.CRT_1fc8b3b9a1e18e3b_9.0.30729.6161_x-ww_31a54e43\MSVCP90.dll
    0x78520000 - 0x785c3000     C:\WINDOWS\WinSxS\x86_Microsoft.VC90.CRT_1fc8b3b9a1e18e3b_9.0.30729.6161_x-ww_31a54e43\MSVCR90.dll
    0x2cd80000 - 0x2cd88000     C:\Program Files\Texas Instruments\ccsv5\ccsv5\ccs_base\DebugServer\win32\javaxpcomglue.dll
    0x2cda0000 - 0x2cdca000     C:\Program Files\Texas Instruments\ccsv5\ccsv5\ccs_base\DebugServer\win32\nspr4.dll
    0x71ad0000 - 0x71ad9000     C:\WINDOWS\system32\WSOCK32.dll
    0x2cde0000 - 0x2cde7000     C:\Program Files\Texas Instruments\ccsv5\ccsv5\ccs_base\DebugServer\win32\plc4.dll
    0x2ce00000 - 0x2ce07000     C:\Program Files\Texas Instruments\ccsv5\ccsv5\ccs_base\DebugServer\win32\plds4.dll
    0x2ce20000 - 0x2ce9b000     C:\Program Files\Texas Instruments\ccsv5\ccsv5\ccs_base\DebugServer\win32\sqlite3.dll
    0x2ceb0000 - 0x2cec4000     C:\Program Files\Texas Instruments\ccsv5\ccsv5\ccs_base\DebugServer\win32\nssutil3.dll
    0x2cee0000 - 0x2cf06000     C:\Program Files\Texas Instruments\ccsv5\ccsv5\ccs_base\DebugServer\win32\softokn3.dll
    0x2cf20000 - 0x2cfbd000     C:\Program Files\Texas Instruments\ccsv5\ccsv5\ccs_base\DebugServer\win32\nss3.dll
    0x2cfd0000 - 0x2cff1000     C:\Program Files\Texas Instruments\ccsv5\ccsv5\ccs_base\DebugServer\win32\ssl3.dll
    0x2d010000 - 0x2d028000     C:\Program Files\Texas Instruments\ccsv5\ccsv5\ccs_base\DebugServer\win32\smime3.dll
    0x2d040000 - 0x2da2e000     C:\Program Files\Texas Instruments\ccsv5\ccsv5\ccs_base\DebugServer\win32\xul.dll
    0x2da40000 - 0x2db11000     C:\Program Files\Texas Instruments\ccsv5\ccsv5\ccs_base\DebugServer\win32\js3250.dll
    0x76380000 - 0x76385000     C:\WINDOWS\system32\MSIMG32.dll
    0x64e80000 - 0x64ea2000     C:\Program Files\Alwil Software\Avast5\aswJsFlt.dll
    0x59a60000 - 0x59b01000     C:\WINDOWS\system32\DBGHELP.DLL
    0x2dd40000 - 0x2dd47000     C:\Program Files\Texas Instruments\ccsv5\ccsv5\ccs_base\DebugServer\win32\xpcom.dll
    0x76fd0000 - 0x7704f000     C:\WINDOWS\system32\CLBCATQ.DLL
    0x77050000 - 0x77115000     C:\WINDOWS\system32\COMRes.dll
    0x662b0000 - 0x66308000     C:\WINDOWS\system32\hnetcfg.dll
    0x71a90000 - 0x71a98000     C:\WINDOWS\System32\wshtcpip.dll
    0x2bd60000 - 0x2bda0000     C:\Program Files\Texas Instruments\ccsv5\ccsv5\ccs_base\DebugServer\win32\components\DataSnapshotDecoder.dll
    0x2bdb0000 - 0x2bdcc000     C:\Program Files\Texas Instruments\ccsv5\ccsv5\ccs_base\DebugServer\bin\win32\XPCOMUtility.dll
    0x2bde0000 - 0x2be13000     C:\Program Files\Texas Instruments\ccsv5\ccsv5\ccs_base\DebugServer\win32\components\DebugProperties.dll
    0x2e590000 - 0x2e9e1000     C:\Program Files\Texas Instruments\ccsv5\ccsv5\ccs_base\DebugServer\win32\components\DebugServer.dll
    0x2e9f0000 - 0x2ea6e000     C:\Program Files\Texas Instruments\ccsv5\ccsv5\ccs_base\DebugServer\bin\win32\tiofr11.dll
    0x2ea70000 - 0x2eb08000     C:\Program Files\Texas Instruments\ccsv5\ccsv5\ccs_base\DebugServer\bin\win32\CollectorServer.dll
    0x2eb10000 - 0x2eb93000     C:\Program Files\Texas Instruments\ccsv5\ccsv5\ccs_base\DebugServer\bin\win32\DatasetServer.dll
    0x2ec10000 - 0x2edad000     C:\Program Files\Texas Instruments\ccsv5\ccsv5\ccs_base\DebugServer\win32\components\mdex.dll
    0x2f3b0000 - 0x2f3c1000     C:\Program Files\Texas Instruments\ccsv5\ccsv5\ccs_base\DebugServer\win32\components\XPCOMTILogger.dll
    0x2f3e0000 - 0x2f65d000     C:\Program Files\Texas Instruments\ccsv5\ccsv5\ccs_base\DebugServer\license\mdexutil.dll
    0x71f60000 - 0x71f68000     C:\WINDOWS\system32\snmpapi.dll
    0x77920000 - 0x77a13000     C:\WINDOWS\system32\SETUPAPI.dll
    0x30070000 - 0x30335000     C:\WINDOWS\system32\xpsp2res.dll
    0x76c30000 - 0x76c5e000     C:\WINDOWS\system32\WINTRUST.dll
    0x76c90000 - 0x76cb8000     C:\WINDOWS\system32\IMAGEHLP.dll
    0x30540000 - 0x3055d000     C:\Program Files\Texas Instruments\ccsv5\ccsv5\eclipse\configuration\org.eclipse.osgi\bundles\523\1\.cp\swt-gdip-win32-3738.dll
    0x4ec50000 - 0x4edfb000     C:\WINDOWS\WinSxS\x86_Microsoft.Windows.GdiPlus_6595b64144ccf1df_1.0.6002.22509_x-ww_c7dad023\gdiplus.dll
    0x30690000 - 0x3069e000     C:\Program Files\Texas Instruments\ccsv5\ccsv5\eclipse\configuration\org.eclipse.osgi\bundles\78\1\.cp\os\win32\x86\localfile_1_0_0.dll
    0x306d0000 - 0x306d8000     C:\Program Files\Texas Instruments\ccsv5\ccsv5\eclipse\configuration\org.eclipse.osgi\bundles\83\1\.cp\os\win32\x86\win32refresh.dll
    0x61880000 - 0x618ba000     C:\WINDOWS\system32\oleacc.dll
    0x77b40000 - 0x77b62000     C:\WINDOWS\system32\Apphelp.dll
    0x75cf0000 - 0x75d81000     C:\WINDOWS\system32\mlang.dll
    0x307f0000 - 0x307ff000     C:\Program Files\Texas Instruments\ccsv5\ccsv5\eclipse\configuration\org.eclipse.osgi\bundles\81\1\.cp\jWinHttp-1.0.0.dll
    0x4d4f0000 - 0x4d549000     C:\WINDOWS\system32\WINHTTP.dll
    0x76ee0000 - 0x76f1c000     C:\WINDOWS\system32\RASAPI32.DLL
    0x76e90000 - 0x76ea2000     C:\WINDOWS\system32\rasman.dll
    0x76eb0000 - 0x76edf000     C:\WINDOWS\system32\TAPI32.dll
    0x76e80000 - 0x76e8e000     C:\WINDOWS\system32\rtutils.dll
    0x77c70000 - 0x77c95000     C:\WINDOWS\system32\msv1_0.dll
    0x76790000 - 0x7679c000     C:\WINDOWS\system32\cryptdll.dll
    0x6d790000 - 0x6d798000     C:\Program Files\Texas Instruments\ccsv5\ccsv5\eclipse\jre\bin\sunmscapi.dll
    0x30be0000 - 0x30bed000     C:\Documents and Settings\bob\Local Settings\Temp\ext4258922724716915456.dll
    0x34650000 - 0x346eb000     C:\Program Files\Texas Instruments\ccsv5\ccsv5\ccs_base\emulation\analysis\bin\ctools.dll
    0x34700000 - 0x3471d000     C:\Program Files\Texas Instruments\ccsv5\ccsv5\ccs_base\emulation\analysis\bin\cToolsIF.dll
    0x34940000 - 0x34961000     C:\Program Files\Texas Instruments\ccsv5\ccsv5\ccs_base\emulation\analysis\bin\AETProperties.dll
    0x34970000 - 0x349a2000     C:\Program Files\Texas Instruments\ccsv5\ccsv5\ccs_base\emulation\drivers\sdgo28x.dvr
    0x349c0000 - 0x349e0000     C:\WINDOWS\system32\sddllmgt2.dll
    0x34a10000 - 0x34a1f000     C:\Program Files\Texas Instruments\ccsv5\ccsv5\ccs_base\common\uscif\jtagdata.dll
    0x34b50000 - 0x34b73000     C:\WINDOWS\system32\sdsmg51095.dll
    VM Arguments:
    jvm_args: -Dosgi.requiredJavaVersion=1.5 -Xms40m -Xmx384m -XX:ErrorFile=C:\DOCUME~1\bob\LOCALS~1\APPLIC~1\.TI\2467232089\0\dmp\hs_err_%p.log -XX:MaxPermSize=256M
    java_command: <unknown>
    Launcher Type: generic
    Environment Variables:
    CLASSPATH=C:\Program Files\PhotoDeluxe BE 1.0\AdobeConnectables;
    PATH=C:\Program Files\Texas Instruments\ccsv5\ccsv5\ccs_base\common\bin;C:\Program Files\Texas Instruments\ccsv5\ccsv5\ccs_base\common\uscif;C:\Program Files\Texas Instruments\ccsv5\ccsv5\ccs_base\DebugServer\license;C:/Program Files/Texas Instruments/ccsv5/ccsv5/eclipse/jre/bin/client;C:/Program Files/Texas Instruments/ccsv5/ccsv5/eclipse/jre/bin;C:/Program Files/Texas Instruments/ccsv5/ccsv5/eclipse/jre/lib/i386;C:\WINDOWS\system32;C:\WINDOWS;C:\WINDOWS\system32\wbem;C:\Xilinx\10.1\ISE\bin\nt;C:\Xilinx\10.1\ISE\lib\nt;C:\Xilinx\10.1\ISE\smartmodel\nt\installed_nt\lib\pcnt.lib;C:\Program Files\PC-Doctor for Windows;C:\Program;C:\Program Files\Common Files\Autodesk Shared;C:\Program Files\Altium Designer 6\System;C:\Program Files\Common Files\DivX Shared;C:\Program Files\IVI Foundation\IVI\bin;C:\Program Files\QuickTime\QTSystem;C:\Program Files\TortoiseSVN\bin;C:\Program Files\Common Files\Acronis\SnapAPI;C:\Program Files\SlikSvn\bin;C:\Program Files\Microsoft Network Monitor 3\;;C:\Program Files\Texas Instruments\ccsv5\ccsv5\eclipse;;C:\Program Files\Texas Instruments\ccsv5\ccsv5\ccs_base\emulation\analysis\bin\.;C:\Program Files\Texas Instruments\ccsv5\ccsv5\ccs_base\emulation\analysis\bin\../xmldb/aet_config;C:\Program Files\Texas Instruments\ccsv5\ccsv5\ccs_base\emulation\analysis\bin\../xmldb/trace_config/setup;C:\Program Files\Texas Instruments\ccsv5\ccsv5\ccs_base\emulation\analysis\bin\../xmldb/trace_config/devices;C:\Program Files\Texas Instruments\ccsv5\ccsv5\ccs_base\emulation\analysis\bin\../../../common/bin;C:\Program Files\Texas Instruments\ccsv5\ccsv5\ccs_base\emulation\analysis\bin\../../../common/uscif;C:\Program Files\Texas Instruments\ccsv5\ccsv5\ccs_base\emulation\analysis\bin\../../tpi;C:\Program Files\Texas Instruments\ccsv5\ccsv5\ccs_base\emulation\drivers
    USERNAME=bob
    OS=Windows_NT
    PROCESSOR_IDENTIFIER=x86 Family 15 Model 4 Stepping 1, GenuineIntel
    ---------------  S Y S T E M  ---------------
    OS: Windows XP Build 2600 Service Pack 3
    CPU:total 1 (1 cores per cpu, 1 threads per core) family 15 model 4 stepping 1, cmov, cx8, fxsr, mmx, sse, sse2, sse3
    Memory: 4k page, physical 2095580k(1110304k free), swap 4033112k(3179936k free)
    vm_info: Java HotSpot(TM) Client VM (11.3-b02) for windows-x86 JRE (1.6.0_13-b03), built on Mar  9 2009 01:15:24 by "java_re" with MS VC++ 7.1
    time: Wed May 02 15:47:19 2012
    elapsed time: 19709 seconds
    !SESSION 2012-05-02 10:18:51.703 -----------------------------------------------
    eclipse.buildId=M20110909-1335
    java.version=1.6.0_13
    java.vendor=Sun Microsystems Inc.
    BootLoader constants: OS=win32, ARCH=x86, WS=win32, NL=en_US
    Framework arguments:  -product com.ti.ccstudio.branding.product
    Command-line arguments:  -os win32 -ws win32 -arch x86 -product com.ti.ccstudio.branding.product
    This is a continuation of log file C:\Documents and Settings\bob\workspace_v5_1\.metadata\.bak_0.log
    Created Time: 2012-05-02 11:14:31.484
    !ENTRY org.eclipse.ui 4 4 2012-05-02 11:14:31.484
    !MESSAGE Class load Failure: 'com.ti.dvt.ccstudioideadapter.VariableObjectNewMenu'
    !ENTRY org.eclipse.ui 4 0 2012-05-02 11:14:31.484
    !STACK 1
    org.eclipse.core.runtime.CoreException: Plug-in com.ti.dvt.ccstudioideadapter was unable to load class com.ti.dvt.ccstudioideadapter.VariableObjectNewMenu.
        at org.eclipse.core.internal.registry.osgi.RegistryStrategyOSGI.throwException(RegistryStrategyOSGI.java:194)
        at org.eclipse.core.internal.registry.osgi.RegistryStrategyOSGI.createExecutableExtension(RegistryStrategyOSGI.java:176)
        at org.eclipse.core.internal.registry.ExtensionRegistry.createExecutableExtension(ExtensionRegistry.java:905)
        at org.eclipse.core.internal.registry.ConfigurationElement.createExecutableExtension(ConfigurationElement.java:243)
        at org.eclipse.core.internal.registry.ConfigurationElementHandle.createExecutableExtension(ConfigurationElementHandle.java:55)
        at org.eclipse.ui.internal.util.Util.safeLoadExecutableExtension(Util.java:879)
        at org.eclipse.ui.internal.menus.DynamicMenuContributionItem.createContributionItem(DynamicMenuContributionItem.java:222)
        at org.eclipse.ui.internal.menus.DynamicMenuContributionItem.getContributionItem(DynamicMenuContributionItem.java:215)
        at org.eclipse.ui.internal.menus.DynamicMenuContributionItem.fill(DynamicMenuContributionItem.java:195)
        at org.eclipse.jface.action.MenuManager.doItemFill(MenuManager.java:741)
        at org.eclipse.jface.action.MenuManager.update(MenuManager.java:822)
        at org.eclipse.jface.action.MenuManager.update(MenuManager.java:682)
        at org.eclipse.ui.internal.menus.WorkbenchMenuService.updateManagers(WorkbenchMenuService.java:330)
        at org.eclipse.ui.internal.menus.WorkbenchMenuService$4.propertyChange(WorkbenchMenuService.java:316)
        at org.eclipse.ui.internal.services.EvaluationAuthority$1.run(EvaluationAuthority.java:252)
        at org.eclipse.core.runtime.SafeRunner.run(SafeRunner.java:42)
        at org.eclipse.ui.internal.services.EvaluationAuthority.fireServiceChange(EvaluationAuthority.java:246)
        at org.eclipse.ui.internal.services.EvaluationAuthority.endSourceChange(EvaluationAuthority.java:197)
        at org.eclipse.ui.internal.services.EvaluationAuthority.sourceChanged(EvaluationAuthority.java:135)
        at org.eclipse.ui.internal.services.ExpressionAuthority.sourceChanged(ExpressionAuthority.java:311)
        at org.eclipse.ui.internal.services.ExpressionAuthority.sourceChanged(ExpressionAuthority.java:302)
        at org.eclipse.ui.AbstractSourceProvider.fireSourceChanged(AbstractSourceProvider.java:80)
        at org.eclipse.ui.internal.services.WorkbenchSourceProvider.selectionChanged(WorkbenchSourceProvider.java:177)
        at org.eclipse.ui.internal.AbstractSelectionService.fireSelection(AbstractSelectionService.java:156)
        at org.eclipse.ui.internal.AbstractSelectionService$1.selectionChanged(AbstractSelectionService.java:62)
        at org.eclipse.debug.internal.ui.views.variables.VariablesView$SelectionProviderWrapper.fireSelectionChanged(VariablesView.java:187)
        at org.eclipse.debug.internal.ui.views.variables.VariablesView$SelectionProviderWrapper.access$0(VariablesView.java:183)
        at org.eclipse.debug.internal.ui.views.variables.VariablesView$3.selectionChanged(VariablesView.java:155)
        at org.eclipse.jface.viewers.Viewer$2.run(Viewer.java:164)
        at org.eclipse.ui.internal.JFaceUtil$1.run(JFaceUtil.java:49)
        at org.eclipse.jface.util.SafeRunnable.run(SafeRunnable.java:175)
        at org.eclipse.jface.viewers.Viewer.fireSelectionChanged(Viewer.java:162)
        at org.eclipse.jface.viewers.StructuredViewer.updateSelection(StructuredViewer.java:2188)
        at org.eclipse.jface.viewers.StructuredViewer.handleSelect(StructuredViewer.java:1211)
        at org.eclipse.debug.internal.ui.viewers.model.InternalTreeModelViewer.handleSelect(InternalTreeModelViewer.java:2465)
        at org.eclipse.jface.viewers.StructuredViewer$4.widgetSelected(StructuredViewer.java:1241)
        at org.eclipse.jface.util.OpenStrategy.fireSelectionEvent(OpenStrategy.java:239)
        at org.eclipse.jface.util.OpenStrategy.access$4(OpenStrategy.java:233)
        at org.eclipse.jface.util.OpenStrategy$1.handleEvent(OpenStrategy.java:403)
        at org.eclipse.swt.widgets.EventTable.sendEvent(EventTable.java:84)
        at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:1053)
        at org.eclipse.swt.widgets.Display.runDeferredEvents(Display.java:4165)
        at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java:3754)
        at org.eclipse.ui.internal.Workbench.runEventLoop(Workbench.java:2696)
        at org.eclipse.ui.internal.Workbench.runUI(Workbench.java:2660)
        at org.eclipse.ui.internal.Workbench.access$4(Workbench.java:2494)
        at org.eclipse.ui.internal.Workbench$7.run(Workbench.java:674)
        at org.eclipse.core.databinding.observable.Realm.runWithDefault(Realm.java:332)
        at org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Workbench.java:667)
        at org.eclipse.ui.PlatformUI.createAndRunWorkbench(PlatformUI.java:149)
        at org.eclipse.ui.internal.ide.application.IDEApplication.start(IDEApplication.java:123)
        at org.eclipse.equinox.internal.app.EclipseAppHandle.run(EclipseAppHandle.java:196)
        at org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher.runApplication(EclipseAppLauncher.java:110)
        at org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher.start(EclipseAppLauncher.java:79)
        at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:344)
        at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:179)
        at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method)
        at sun.reflect.NativeMethodAccessorImpl.invoke(Unknown Source)
        at sun.reflect.DelegatingMethodAccessorImpl.invoke(Unknown Source)
        at java.lang.reflect.Method.invoke(Unknown Source)
        at org.eclipse.equinox.launcher.Main.invokeFramework(Main.java:622)
        at org.eclipse.equinox.launcher.Main.basicRun(Main.java:577)
        at org.eclipse.equinox.launcher.Main.run(Main.java:1410)
    Caused by: org.eclipse.core.runtime.internal.adaptor.EclipseLazyStarter$TerminatingClassNotFoundException: An error occurred while automatically activating bundle com.ti.dvt.ccstudioideadapter (596).
        at org.eclipse.core.runtime.internal.adaptor.EclipseLazyStarter.postFindLocalClass(EclipseLazyStarter.java:122)
        at org.eclipse.osgi.baseadaptor.loader.ClasspathManager.findLocalClass(ClasspathManager.java:462)
        at org.eclipse.osgi.internal.baseadaptor.DefaultClassLoader.findLocalClass(DefaultClassLoader.java:216)
        at org.eclipse.osgi.internal.loader.BundleLoader.findLocalClass(BundleLoader.java:400)
        at org.eclipse.osgi.internal.loader.BundleLoader.findClassInternal(BundleLoader.java:476)
        at org.eclipse.osgi.internal.loader.BundleLoader.findClass(BundleLoader.java:429)
        at org.eclipse.osgi.internal.loader.BundleLoader.findClass(BundleLoader.java:417)
        at org.eclipse.osgi.internal.baseadaptor.DefaultClassLoader.loadClass(DefaultClassLoader.java:107)
        at java.lang.ClassLoader.loadClass(Unknown Source)
        at org.eclipse.osgi.internal.loader.BundleLoader.loadClass(BundleLoader.java:345)
        at org.eclipse.osgi.framework.internal.core.BundleHost.loadClass(BundleHost.java:229)
        at org.eclipse.osgi.framework.internal.core.AbstractBundle.loadClass(AbstractBundle.java:1207)
        at org.eclipse.core.internal.registry.osgi.RegistryStrategyOSGI.createExecutableExtension(RegistryStrategyOSGI.java:174)
        ... 62 more
    Caused by: org.osgi.framework.BundleException: The activator com.ti.dvt.ccstudioideadapter.Activator for bundle com.ti.dvt.ccstudioideadapter is invalid
        at org.eclipse.osgi.framework.internal.core.AbstractBundle.loadBundleActivator(AbstractBundle.java:171)
        at org.eclipse.osgi.framework.internal.core.BundleContextImpl.start(BundleContextImpl.java:679)
        at org.eclipse.osgi.framework.internal.core.BundleHost.startWorker(BundleHost.java:381)
        at org.eclipse.osgi.framework.internal.core.AbstractBundle.start(AbstractBundle.java:299)
        at org.eclipse.osgi.framework.util.SecureAction.start(SecureAction.java:440)
        at org.eclipse.osgi.internal.loader.BundleLoader.setLazyTrigger(BundleLoader.java:268)
        at org.eclipse.core.runtime.internal.adaptor.EclipseLazyStarter.postFindLocalClass(EclipseLazyStarter.java:107)
        ... 74 more
    Caused by: java.lang.NoClassDefFoundError: com/ti/dvt/ideadapter/IDEAdapterManager$IIDEAdapterManagerEventListener
        at java.lang.Class.getDeclaredConstructors0(Native Method)
        at java.lang.Class.privateGetDeclaredConstructors(Unknown Source)
        at java.lang.Class.getConstructor0(Unknown Source)
        at java.lang.Class.newInstance0(Unknown Source)
        at java.lang.Class.newInstance(Unknown Source)
        at org.eclipse.osgi.framework.internal.core.AbstractBundle.loadBundleActivator(AbstractBundle.java:166)
        ... 80 more
    Caused by: java.lang.ClassNotFoundException: com.ti.dvt.ideadapter.IDEAdapterManager$IIDEAdapterManagerEventListener
        at org.eclipse.osgi.internal.loader.BundleLoader.findClassInternal(BundleLoader.java:513)
        at java.lang.ClassLoader.loadClassInternal(Unknown Source)
        ... 86 more
    !SUBENTRY 1 org.eclipse.equinox.registry 4 1 2012-05-02 11:14:31.484
    !MESSAGE Plug-in com.ti.dvt.ccstudioideadapter was unable to load class com.ti.dvt.ccstudioideadapter.VariableObjectNewMenu.
    !STACK 0
        ... 74 more
        ... 80 more
        ... 86 more
    !ENTRY org.eclipse.ui 4 4 2012-05-02 11:14:31.500
    !ENTRY org.eclipse.ui 4 0 2012-05-02 11:14:31.500
    !STACK 1
        ... 62 more
        ... 74 more
        ... 80 more
        ... 86 more
    !SUBENTRY 1 org.eclipse.equinox.registry 4 1 2012-05-02 11:14:31.500
    !STACK 0
        ... 74 more
        ... 80 more
        ... 86 more
    !ENTRY org.eclipse.ui 4 0 2012-05-02 11:14:31.515
    !STACK 1
        ... 62 more
        ... 74 more
        ... 80 more
        ... 86 more
    !SUBENTRY 1 org.eclipse.equinox.registry 4 1 2012-05-02 11:14:31.515
    !STACK 0
        ... 74 more
        ... 80 more
        ... 86 more
    !ENTRY org.eclipse.ui 4 4 2012-05-02 11:14:37.000
    !ENTRY org.eclipse.ui 4 0 2012-05-02 11:14:37.000
    !STACK 1
        at org.eclipse.ui.menus.CommandContributionItem$4.run(CommandContributionItem.java:374)
        at org.eclipse.ui.menus.CommandContributionItem.updateCommandProperties(CommandContributionItem.java:391)
        at org.eclipse.ui.menus.CommandContributionItem.access$7(CommandContributionItem.java:363)
        at org.eclipse.ui.menus.CommandContributionItem$3.commandChanged(CommandContributionItem.java:355)
        at org.eclipse.core.commands.Command$1.run(Command.java:511)
        at org.eclipse.core.commands.Command.fireCommandChanged(Command.java:506)
        at org.eclipse.core.commands.Command.access$0(Command.java:498)
        at org.eclipse.core.commands.Command$2.handlerChanged(Command.java:1010)
        at org.eclipse.core.commands.AbstractHandler.fireHandlerChanged(AbstractHandler.java:78)
        at org.eclipse.ui.internal.handlers.HandlerProxy.access$0(HandlerProxy.java:1)
        at org.eclipse.ui.internal.handlers.HandlerProxy$2.handlerChanged(HandlerProxy.java:385)
        at org.eclipse.core.commands.AbstractHandler.setBaseEnabled(AbstractHandler.java:111)
        at org.eclipse.cdt.debug.internal.ui.actions.RestoreDefaultTypeActionHandler.setEnabled(RestoreDefaultTypeActionHandler.java:82)
        at org.eclipse.ui.internal.handlers.HandlerProxy.setEnabled(HandlerProxy.java:232)
        at org.eclipse.ui.internal.handlers.HandlerProxy.loadHandler(HandlerProxy.java:352)
        at org.eclipse.ui.internal.handlers.HandlerProxy.setEnabled(HandlerProxy.java:230)
        at org.eclipse.core.commands.Command.setEnabled(Command.java:857)
        at org.eclipse.ui.menus.CommandContributionItem.isEnabled(CommandContributionItem.java:977)
        at org.eclipse.ui.menus.CommandContributionItem.isVisible(CommandContributionItem.java:988)
        at org.eclipse.jface.action.MenuManager.isChildVisible(MenuManager.java:999)
        at org.eclipse.jface.action.MenuManager.update(MenuManager.java:763)
        at org.eclipse.cdt.debug.internal.ui.actions.CastToArrayActionHandler.setEnabled(CastToArrayActionHandler.java:275)
        at org.eclipse.jface.action.MenuManager.handleAboutToShow(MenuManager.java:474)
        at org.eclipse.jface.action.MenuManager.access$1(MenuManager.java:469)
        at org.eclipse.jface.action.MenuManager$2.menuShown(MenuManager.java:495)
        at org.eclipse.swt.widgets.TypedListener.handleEvent(TypedListener.java:247)
        at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:1077)
        at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:1058)
        at org.eclipse.swt.widgets.Control.WM_INITMENUPOPUP(Control.java:4881)
        at org.eclipse.swt.widgets.Control.windowProc(Control.java:4557)
        at org.eclipse.swt.widgets.Canvas.windowProc(Canvas.java:341)
        at org.eclipse.swt.widgets.Decorations.windowProc(Decorations.java:1610)
        at org.eclipse.swt.widgets.Shell.windowProc(Shell.java:2061)
        at org.eclipse.swt.widgets.Display.windowProc(Display.java:4972)
        at org.eclipse.swt.internal.win32.OS.TrackPopupMenu(Native Method)
        at org.eclipse.swt.widgets.Menu._setVisible(Menu.java:256)
        at org.eclipse.swt.widgets.Display.runPopups(Display.java:4206)
        at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java:3748)
        ... 20 more
        ... 74 more
        ... 80 more
        ... 86 more
    !SUBENTRY 1 org.eclipse.equinox.registry 4 1 2012-05-02 11:14:37.000
    !STACK 0
        ... 74 more
        ... 80 more
        ... 86 more
    !ENTRY com.ti.ccstudio.debug 1 0 2012-05-02 11:44:17.359
    !MESSAGE DS_ERROR: C28xx: Error connecting to the target: Error 0x80000200/-145 Fatal Error during: OCS,  Error generated by SD scan controller module
    !ENTRY com.ti.ccstudio.debug 1 0 2012-05-02 11:44:17.390
    !MESSAGE DS_ERROR: Error connecting to the target:
    !ENTRY com.ti.ccstudio.debug 1 0 2012-05-02 11:44:19.171
    !ENTRY com.ti.ccstudio.debug 1 0 2012-05-02 15:02:27.062
    !MESSAGE DS_ERROR: C28xx: JTAG Communication Error: Error 0xA0000020/-2080 Error during: Execution,  Device driver: Timeout on Emulator or Target Processor It is recommended to RESET EMULATOR.  This will disconnect each  target from the emulator.  The targets should then be power cycled or hard reset followed by an emureset and reconnect to each target.
    !ENTRY com.ti.ccstudio.debug 1 0 2012-05-02 15:02:27.734
    !MESSAGE DS_ERROR: C28xx: Failed to remove the debug state from the target before disconnecting.  There may still be breakpoint op-codes embedded in program memory.  It is recommended that you reset the emulator before you connect and reload your program before you continue debugging
    !SESSION 2012-05-02 16:01:29.343 -----------------------------------------------
    !ENTRY com.ti.ccstudio.debug.server 4 214294189 2012-05-02 16:01:42.609
    !MESSAGE Unexpected CCS exit detected [5/2/12 9:09 AM]!!!
    !ENTRY org.eclipse.core.resources 2 10035 2012-05-02 16:01:43.281
    !MESSAGE The workspace exited with unsaved changes in the previous session; refreshing workspace to recover changes.
    !ENTRY org.eclipse.osgi 2 0 2012-05-02 16:02:29.062
    !MESSAGE The activator com.ti.dvt.ccstudioideadapter.Activator for bundle com.ti.dvt.ccstudioideadapter is invalid
    !STACK 0
        at org.eclipse.osgi.framework.internal.core.BundleHost.loadClass(BundleHost.java:236)
        at org.eclipse.osgi.internal.loader.buddy.GlobalPolicy.loadClass(GlobalPolicy.java:38)
        at org.eclipse.osgi.internal.loader.buddy.PolicyHandler.doBuddyClassLoading(PolicyHandler.java:135)
        at org.eclipse.osgi.internal.loader.BundleLoader.findClassInternal(BundleLoader.java:501)
        at org.eclipse.core.runtime.internal.adaptor.ContextFinder.loadClass(ContextFinder.java:126)
        at org.mozilla.javascript.Kit.classOrNull(Kit.java:88)
        at org.mozilla.javascript.NativeJavaPackage.getPkgProperty(NativeJavaPackage.java:154)
        at org.mozilla.javascript.NativeJavaPackage.get(NativeJavaPackage.java:105)
        at org.mozilla.javascript.ScriptableObject.getProperty(ScriptableObject.java:1315)
        at org.mozilla.javascript.ScriptRuntime.getObjectProp(ScriptRuntime.java:1337)
        at org.mozilla.javascript.ScriptRuntime.getObjectProp(ScriptRuntime.java:1326)
        at org.mozilla.javascript.Interpreter.interpretLoop(Interpreter.java:2816)
        at org.mozilla.javascript.Interpreter.interpret(Interpreter.java:2251)
        at org.mozilla.javascript.InterpretedFunction.exec(InterpretedFunction.java:175)
        at org.mozilla.javascript.tools.shell.Main.evaluateScript(Main.java:503)
        at org.mozilla.javascript.tools.shell.Main.processFileSecure(Main.java:425)
        at org.mozilla.javascript.tools.shell.Main.processFile(Main.java:391)
        at org.mozilla.javascript.tools.shell.Global.load(Global.java:223)
        at org.mozilla.javascript.MemberBox.invoke(MemberBox.java:145)
        at org.mozilla.javascript.FunctionObject.call(FunctionObject.java:408)
        at org.mozilla.javascript.Interpreter.interpretLoop(Interpreter.java:3085)
        at org.mozilla.javascript.InterpretedFunction.call(InterpretedFunction.java:161)
        at org.mozilla.javascript.ContextFactory.doTopCall(ContextFactory.java:340)
        at com.ti.ccstudio.rhino.CCSContextFactory.doTopCall(CCSContextFactory.java:42)
        at org.mozilla.javascript.ScriptRuntime.doTopCall(ScriptRuntime.java:2758)
        at org.mozilla.javascript.InterpretedFunction.exec(InterpretedFunction.java:172)
        at org.mozilla.javascript.Context.evaluateString(Context.java:1132)
        at com.ti.ccstudio.scripting.console.internal.Startup$1.safeRun(Startup.java:65)
        at com.ti.ccstudio.rhino.SafeRunnable.run(SafeRunnable.java:27)
        at com.ti.ccstudio.rhino.internal.RhinoThreadExecutor$1.run(RhinoThreadExecutor.java:67)
        at java.util.concurrent.ThreadPoolExecutor$Worker.runTask(Unknown Source)
        at java.util.concurrent.ThreadPoolExecutor$Worker.run(Unknown Source)
        at java.lang.Thread.run(Unknown Source)
        at com.ti.ccstudio.rhino.internal.RhinoThreadExecutor$RhinoThread.run(RhinoThreadExecutor.java:88)
        ... 50 more
        ... 56 more
    Root exception:
        ... 56 more
  • Hi Bob,
    could you send the debugger log?   The crash is in the spectrum digital driver and having the debugger log should help to investigate furhter.
    Lisa
  • which file is that?
  • Hi Bob,
    have a look and please zip and send us this folder.
    C:\Program Files (x86)\InstallJammer Registry\DebugServer
    The installjammer Registry directory might be under Program Files depending on Windows versions.
    Lisa
  • Hi Bob,
    I owe you an appology as I guess my instructions were not clear.
    This looks like an installer log.  A debugger log is obtained by going to help->CCS support, selecting debug server logging, enabling it and choosing a valid file name, then repeating whatever the scenario is that causes the issue.
    Please give this a try and send us the log.
    Lisa
  • Hi Bob,
    I just wanted to double check whether you were able to generate the debug log and/or have any update to your enquiry?
    Lisa
  • Hi Lisa,
     I've been off on a few other projects (that use good old CCS3.3) so I haven't been able to duplicate the problem. I plan to be back on this later this week.
    Bob
  • Hi Bob,
    no worries, please just keep us informed.
    Lisa
