ccs with matlab
hi ,
 i am doing simulink with c6713 dsk. i added board to pc by c6713 diagonistics and select the target by set up. then in matlab via command window i opened ccsboardinfo. then i run the model, but i am getting an error like
The call to idelink_ert_make_rtw_hook, during the entry hook generated the following error:
Could not connect to the board specified in Target Preferences block
This version of the Embedded IDE Link does not support your  version of Code Composer Studio(TM) IDE.  The Code Composer Studio(TM) version supported in this release is 3.3. Refer to the Embedded IDE Link data sheet  for more information on product requirements.
 i am using matlab r2010a and ccs 3.1
how should i clear my errors? pls, suggestions will be greatful.
