Hi All,
I just "upgraded" to CCS V5.2 for use with the MSP430 new "A" rev chip we are using. Here is what I dislike about CCS compared to CCE Pro (I did not find anything really better other than support for the new chips):
1. THIS IS SIGNIFICANT: When a change is made in your source code CCE, the line number in the left column is highlighted in a pale purple. In CCS there is no indication that an edit has been made. Highlighting changed lines (until saving) is extremely helpful.
2. When right-clicking a function or variable, the context menu in CCE had Open Declaration and Open Definition. CCS only has Open Declaration. Plus in CCE you don’t have left-click in it first as you do in CCS to get the right-click context menu to open the declaration.
3. Is there a way to set the tab size to 2 and to substitute spaces for tabs easily as in CCE (Windows -> Preferences -> Editors -> Text Editors.
4. My first installation failed (downloaded but the dialog hung where is should have begun installation. I found out because it did not like being installed in the My Documents folder, nor in C:\Program Files folder. It installed correctly when I kept the default folder, C:\ti.
If anyone knows how to resolve any of these issues I would appreciate a reply!
Thank you.
Ed
