How does one stop the Cheat Sheets from being displayed? ... Code Composer 4.
It depends on which CCSv4. In CCSv4.2.4 at the bottom of the cheat sheet, directly under "Do not show this again" I can select to "Disable all cheatsheets". It is a workspace level setting so if you switch to a different workspace you will need to do it again.
CCSv5 has removed a number of the cheat sheets.
