I am new to java and scripting. Could you please help me out for the documentation for different API's like given below:
debugServer.setConfig(), debugSession.callStack.print() ?
Thanks in advance.
Sudheer.
Thanks in advance.
Sudheer.
Hi Sudheer,
If you are looking for the DSS API documentation, you can access it from:
<CCS INSTALL DIR>/ccsv5/ccs_base/scripting/docs/GettingStarted.htm
Unfortunately the documentation is a bit weak in some areas. If you need more information (or information is missing), please let me know.
For the two APIs you mentioned:
SUGAM gama said:debugServer.setConfig()
This will configure the debug server for a specific target. Basically you are telling DSS for which target you want to talk to. It takes one parameter - a target configuration file (*.ccxml). This file has all the information DSS needs on what emulator/target (or simulator) you are trying to talk to.
SUGAM gama said:debugSession.callStack.print()
As per its name, it prints the call stack information for the application when the clal is made.
ki
