CCS5 crashes at startup in windows7
Other Parts Discussed in Thread: CCSTUDIO
I installed CCS 5.2 in Windows 7.  Any clue what is the reason?
It crashes after startup. Here is log file.
!SESSION 2012-07-10 11:37:49.966 -----------------------------------------------
eclipse.buildId=M20120208-0800
java.version=1.6.0_13
java.vendor=Sun Microsystems Inc.
BootLoader constants: OS=win32, ARCH=x86, WS=win32, NL=en_US
Framework arguments:  -product com.ti.ccstudio.branding.product
Command-line arguments:  -os win32 -ws win32 -arch x86 -product com.ti.ccstudio.branding.product
!ENTRY com.ti.ccstudio.debug.server 4 214294189 2012-07-10 11:37:58.316
!MESSAGE Unexpected CCS exit detected [7/10/12 11:35 AM]!!!
!ENTRY org.eclipse.ui 4 4 2012-07-10 11:37:59.116
!MESSAGE Referenced part does not exist yet: org.eclipse.cdt.ui.CView.
  • Hi Yingran,
    can you please provide the contents of your installjammer registry directory?
    Can you please check
    - did you have antivirus turned off?
    -have you used only directories with no spaces or accented/special characters?
    - can you provide more information?
    Lisa
  • I strictly following the installation. extract .zip first to /Temp then install to /ti.
    Antivirus? How to check that?
    Here is the screen of installJammer
  • HI Yingran,
    what temp directory is being used?  We have seen cases of the unzip utility not likeing spaces for example.  So if your temp direcotory is in documents and settings for example this might be a possible cause.
    We need the actual files from the installjammer registry.  Could you please attach those.
    Lisa
  • There are quite a few files under ...Registery/ccsv5/. Are you looking for .log file?
    # options: -translation lf -encoding utf-8
    :DIR C:/ti
    :DIR C:/ti/ccsv5
    :DIR C:/ti/ccsv5/doc
    :FILE C:/ti/ccsv5/doc/tilogo.jpg
    :FILE C:/ti/ccsv5/doc/ReleaseNote.htm
    :FILE C:/ti/ccsv5/doc/CCSv5.2SoftwareManifest.pdf
    :FILE C:/ti/ccsv5/doc/eclipse-css-2.ico
    :DIR C:/ti/ccsv5/utils
    :DIR C:/ti/ccsv5/utils/cygwin
    :FILE C:/ti/ccsv5/utils/cygwin/gunzip.exe
    :FILE C:/ti/ccsv5/utils/cygwin/cygncurses-9.dll
    :FILE C:/ti/ccsv5/utils/cygwin/date.exe
    :FILE C:/ti/ccsv5/utils/cygwin/rm.exe
    :FILE C:/ti/ccsv5/utils/cygwin/mkdir.exe
    :FILE C:/ti/ccsv5/utils/cygwin/cygreadline6.dll
    :FILE C:/ti/ccsv5/utils/cygwin/sh.exe
    :FILE C:/ti/ccsv5/utils/cygwin/cygintl-3.dll
    :FILE C:/ti/ccsv5/utils/cygwin/cygwin1.dll
    :FILE C:/ti/ccsv5/utils/cygwin/tar.exe
    :FILE C:/ti/ccsv5/utils/cygwin/echo.exe
    :FILE C:/ti/ccsv5/utils/cygwin/cat.exe
    :FILE C:/ti/ccsv5/utils/cygwin/cygintl-8.dll
    :FILE C:/ti/ccsv5/utils/cygwin/gzip.exe
    :FILE C:/ti/ccsv5/utils/cygwin/touch.exe
    :FILE C:/ti/ccsv5/utils/cygwin/pwd.exe
    :FILE C:/ti/ccsv5/utils/cygwin/mv.exe
    :FILE C:/ti/ccsv5/utils/cygwin/cp.exe
    :FILE C:/ti/ccsv5/utils/cygwin/cygiconv-2.dll
    :FILE C:/ti/ccsv5/utils/cygwin/sed.exe
    :DIR C:/ti/ccsv5/utils/bin
    :FILE C:/ti/ccsv5/utils/bin/make-3.81.tar.gz
    :FILE C:/ti/ccsv5/utils/bin/gmake.exe
    :FILE C:/ti/ccsv5/utils/bin/unzip.exe
    :FILE C:/ti/ccsv5/utils/bin/zip.exe
    :FILE C:/ti/ccsv5/utils/bin/LICENSE
    :DIR C:/ti/ccsv5/eclipse
    :DIR C:/ti/ccsv5/eclipse/jre
    :FILE C:/ti/ccsv5/eclipse/jre/README.txt
    :FILE C:/ti/ccsv5/eclipse/jre/LICENSE_es.rtf
    :FILE C:/ti/ccsv5/eclipse/jre/LICENSE_sv.rtf
    :FILE C:/ti/ccsv5/eclipse/jre/LICENSE_ko.rtf
    :FILE C:/ti/ccsv5/eclipse/jre/Welcome.html
    :FILE C:/ti/ccsv5/eclipse/jre/COPYRIGHT
    :FILE C:/ti/ccsv5/eclipse/jre/LICENSE_it.rtf
    :FILE C:/ti/ccsv5/eclipse/jre/LICENSE_fr.rtf
    :FILE C:/ti/ccsv5/eclipse/jre/LICENSE.rtf
    :FILE C:/ti/ccsv5/eclipse/jre/LICENSE_de.rtf
    :FILE C:/ti/ccsv5/eclipse/jre/LICENSE_zh_CN.rtf
    :FILE C:/ti/ccsv5/eclipse/jre/LICENSE_ja.rtf
    :FILE C:/ti/ccsv5/eclipse/jre/LICENSE_zh_TW.rtf
    :FILE C:/ti/ccsv5/eclipse/jre/THIRDPARTYLICENSEREADME.txt
    :DIR C:/ti/ccsv5/eclipse/jre/lib
    :FILE C:/ti/ccsv5/eclipse/jre/lib/resources.jar
    :FILE C:/ti/ccsv5/eclipse/jre/lib/fontconfig.bfc
    :FILE C:/ti/ccsv5/eclipse/jre/lib/javaws.jar
    :FILE C:/ti/ccsv5/eclipse/jre/lib/calendars.properties
    :FILE C:/ti/ccsv5/eclipse/jre/lib/charsets.jar
    :FILE C:/ti/ccsv5/eclipse/jre/lib/content-types.properties
    :FILE C:/ti/ccsv5/eclipse/jre/lib/deploy.jar
    :FILE C:/ti/ccsv5/eclipse/jre/lib/rt.jar
    :FILE C:/ti/ccsv5/eclipse/jre/lib/net.properties
    :FILE C:/ti/ccsv5/eclipse/jre/lib/sound.properties
    :FILE C:/ti/ccsv5/eclipse/jre/lib/psfontj2d.properties
    :FILE C:/ti/ccsv5/eclipse/jre/lib/jce.jar
    :FILE C:/ti/ccsv5/eclipse/jre/lib/psfont.properties.ja
    :FILE C:/ti/ccsv5/eclipse/jre/lib/fontconfig.properties.src
    :FILE C:/ti/ccsv5/eclipse/jre/lib/jvm.hprof.txt
    :FILE C:/ti/ccsv5/eclipse/jre/lib/jsse.jar
    :FILE C:/ti/ccsv5/eclipse/jre/lib/plugin.jar
    :FILE C:/ti/ccsv5/eclipse/jre/lib/logging.properties
    :FILE C:/ti/ccsv5/eclipse/jre/lib/classlist
    :FILE C:/ti/ccsv5/eclipse/jre/lib/flavormap.properties
    :FILE C:/ti/ccsv5/eclipse/jre/lib/meta-index
    :FILE C:/ti/ccsv5/eclipse/jre/lib/management-agent.jar
    :FILE C:/ti/ccsv5/eclipse/jre/lib/tzmappings
    :FILE C:/ti/ccsv5/eclipse/jre/lib/fontconfig.98.properties.src
    :FILE C:/ti/ccsv5/eclipse/jre/lib/fontconfig.98.bfc
    :DIR C:/ti/ccsv5/eclipse/jre/lib/security
    :FILE C:/ti/ccsv5/eclipse/jre/lib/security/US_export_policy.jar
    :FILE C:/ti/ccsv5/eclipse/jre/lib/security/java.security
    :FILE C:/ti/ccsv5/eclipse/jre/lib/security/java.policy
    :FILE C:/ti/ccsv5/eclipse/jre/lib/security/local_policy.jar
    :FILE C:/ti/ccsv5/eclipse/jre/lib/security/cacerts
    :FILE C:/ti/ccsv5/eclipse/jre/lib/security/javaws.policy
    :DIR C:/ti/ccsv5/eclipse/jre/lib/servicetag
    :FILE C:/ti/ccsv5/eclipse/jre/lib/servicetag/jdk_header.png
    :DIR C:/ti/ccsv5/eclipse/jre/lib/images
    :DIR C:/ti/ccsv5/eclipse/jre/lib/images/cursors
    :FILE C:/ti/ccsv5/eclipse/jre/lib/images/cursors/win32_MoveNoDrop32x32.gif
    :FILE C:/ti/ccsv5/eclipse/jre/lib/images/cursors/win32_CopyNoDrop32x32.gif
    :FILE C:/ti/ccsv5/eclipse/jre/lib/images/cursors/invalid32x32.gif
    :FILE C:/ti/ccsv5/eclipse/jre/lib/images/cursors/win32_LinkDrop32x32.gif
    :FILE C:/ti/ccsv5/eclipse/jre/lib/images/cursors/win32_MoveDrop32x32.gif
    :FILE C:/ti/ccsv5/eclipse/jre/lib/images/cursors/win32_LinkNoDrop32x32.gif
    :FILE C:/ti/ccsv5/eclipse/jre/lib/images/cursors/win32_CopyDrop32x32.gif
    :FILE C:/ti/ccsv5/eclipse/jre/lib/images/cursors/cursors.properties
    :FILE C:/ti/ccsv5/eclipse/jre/lib/im/thaiim.jar
    :FILE C:/ti/ccsv5/eclipse/jre/lib/im/indicim.jar
    :DIR C:/ti/ccsv5/eclipse/jre/lib/ext
    :FILE C:/ti/ccsv5/eclipse/jre/lib/ext/sunmscapi.jar
    :FILE C:/ti/ccsv5/eclipse/jre/lib/ext/sunpkcs11.jar
    :FILE C:/ti/ccsv5/eclipse/jre/lib/ext/meta-index
    :FILE C:/ti/ccsv5/eclipse/jre/lib/ext/sunjce_provider.jar
    :FILE C:/ti/ccsv5/eclipse/jre/lib/ext/localedata.jar
    :FILE C:/ti/ccsv5/eclipse/jre/lib/ext/dnsns.jar
    :DIR C:/ti/ccsv5/eclipse/jre/lib/i386
    :FILE C:/ti/ccsv5/eclipse/jre/lib/i386/jvm.cfg
    :DIR C:/ti/ccsv5/eclipse/jre/lib/fonts
    :FILE C:/ti/ccsv5/eclipse/jre/lib/fonts/LucidaSansRegular.ttf
    :FILE C:/ti/ccsv5/eclipse/jre/lib/fonts/LucidaTypewriterBold.ttf
    :FILE C:/ti/ccsv5/eclipse/jre/lib/fonts/LucidaBrightDemiBold.ttf
    :FILE C:/ti/ccsv5/eclipse/jre/lib/fonts/LucidaTypewriterRegular.ttf
    :FILE C:/ti/ccsv5/eclipse/jre/lib/fonts/LucidaSansDemiBold.ttf
    :FILE C:/ti/ccsv5/eclipse/jre/lib/fonts/LucidaBrightDemiItalic.ttf
    :FILE C:/ti/ccsv5/eclipse/jre/lib/fonts/LucidaBrightRegular.ttf
    :FILE C:/ti/ccsv5/eclipse/jre/lib/fonts/LucidaBrightItalic.ttf
    :DIR C:/ti/ccsv5/eclipse/jre/lib/audio
    :FILE C:/ti/ccsv5/eclipse/jre/lib/audio/soundbank.gm
    :DIR C:/ti/ccsv5/eclipse/jre/lib/zi
    :FILE C:/ti/ccsv5/eclipse/jre/lib/zi/MST
    :FILE C:/ti/ccsv5/eclipse/jre/lib/zi/MET
    :FILE C:/ti/ccsv5/eclipse/jre/lib/zi/EST5EDT
    :FILE C:/ti/ccsv5/eclipse/jre/lib/zi/PST8PDT
    :FILE C:/ti/ccsv5/eclipse/jre/lib/zi/MST7MDT
    :FILE C:/ti/ccsv5/eclipse/jre/lib/zi/GMT
    :FILE C:/ti/ccsv5/eclipse/jre/lib/zi/CST6CDT
    :FILE C:/ti/ccsv5/eclipse/jre/lib/zi/CET
    :FILE C:/ti/ccsv5/eclipse/jre/lib/zi/EET
    :FILE C:/ti/ccsv5/eclipse/jre/lib/zi/ZoneInfoMappings
    :FILE C:/ti/ccsv5/eclipse/jre/lib/zi/HST
    :FILE C:/ti/ccsv5/eclipse/jre/lib/zi/WET
    :DIR C:/ti/ccsv5/eclipse/jre/lib/zi/Etc
    :FILE C:/ti/ccsv5/eclipse/jre/lib/zi/Etc/GMT-4
    :FILE C:/ti/ccsv5/eclipse/jre/lib/zi/Etc/GMT+6
    :FILE C:/ti/ccsv5/eclipse/jre/lib/zi/Etc/GMT-5
    :FILE C:/ti/ccsv5/eclipse/jre/lib/zi/Etc/GMT+7
    :FILE C:/ti/ccsv5/eclipse/jre/lib/zi/Etc/GMT-6
    :FILE C:/ti/ccsv5/eclipse/jre/lib/zi/Etc/GMT+8
    :FILE C:/ti/ccsv5/eclipse/jre/lib/zi/Etc/UTC
    :FILE C:/ti/ccsv5/eclipse/jre/lib/zi/Etc/GMT-7
    :FILE C:/ti/ccsv5/eclipse/jre/lib/zi/Etc/GMT+9
    :FILE C:/ti/ccsv5/eclipse/jre/lib/zi/Etc/GMT+10
    :FILE C:/ti/ccsv5/eclipse/jre/lib/zi/Etc/GMT-8
    :FILE C:/ti/ccsv5/eclipse/jre/lib/zi/Etc/GMT+11
    :FILE C:/ti/ccsv5/eclipse/jre/lib/zi/Etc/GMT-9
    :FILE C:/ti/ccsv5/eclipse/jre/lib/zi/Etc/GMT-10
    :FILE C:/ti/ccsv5/eclipse/jre/lib/zi/Etc/GMT+12
    :FILE C:/ti/ccsv5/eclipse/jre/lib/zi/Etc/GMT-11
    :FILE C:/ti/ccsv5/eclipse/jre/lib/zi/Etc/GMT-12
    :FILE C:/ti/ccsv5/eclipse/jre/lib/zi/Etc/GMT-13
    :FILE C:/ti/ccsv5/eclipse/jre/lib/zi/Etc/GMT-14
    :FILE C:/ti/ccsv5/eclipse/jre/lib/zi/Etc/UCT
    :FILE C:/ti/ccsv5/eclipse/jre/lib/zi/Etc/GMT+2
    :FILE C:/ti/ccsv5/eclipse/jre/lib/zi/Etc/GMT+3
    :FILE C:/ti/ccsv5/eclipse/jre/lib/zi/Etc/GMT-2
    :FILE C:/ti/ccsv5/eclipse/jre/lib/zi/Etc/GMT+4
    :FILE C:/ti/ccsv5/eclipse/jre/lib/zi/Etc/GMT-3
    :FILE C:/ti/ccsv5/eclipse/jre/lib/zi/Etc/GMT+5
    :DIR C:/ti/ccsv5/eclipse/jre/lib/zi/Asia
    :FILE C:/ti/ccsv5/eclipse/jre/lib/zi/Asia/Kolkata
    :FILE C:/ti/ccsv5/eclipse/jre/lib/zi/Asia/Seoul
    :FILE C:/ti/ccsv5/eclipse/jre/lib/zi/Asia/Qatar
    :FILE C:/ti/ccsv5/eclipse/jre/lib/zi/Asia/Shanghai
    :FILE C:/ti/ccsv5/eclipse/jre/lib/zi/Asia/Rangoon
    :FILE C:/ti/ccsv5/eclipse/jre/lib/zi/Asia/Aqtau
    :FILE C:/ti/ccsv5/eclipse/jre/lib/zi/Asia/Brunei
    :FILE C:/ti/ccsv5/eclipse/jre/lib/zi/Asia/Almaty
    :FILE C:/ti/ccsv5/eclipse/jre/lib/zi/Asia/Dhaka
    :FILE C:/ti/ccsv5/eclipse/jre/lib/zi/Asia/Yerevan
    :FILE C:/ti/ccsv5/eclipse/jre/lib/zi/Asia/Manila
    :FILE C:/ti/ccsv5/eclipse/jre/lib/zi/Asia/Beirut
    :FILE C:/ti/ccsv5/eclipse/jre/lib/zi/Asia/Gaza
    :FILE C:/ti/ccsv5/eclipse/jre/lib/zi/Asia/Karachi
    :FILE C:/ti/ccsv5/eclipse/jre/lib/zi/Asia/Yakutsk
    :FILE C:/ti/ccsv5/eclipse/jre/lib/zi/Asia/Dubai
    :FILE C:/ti/ccsv5/eclipse/jre/lib/zi/Asia/Thimphu
    :FILE C:/ti/ccsv5/eclipse/jre/lib/zi/Asia/Samarkand
    :FILE C:/ti/ccsv5/eclipse/jre/lib/zi/Asia/Dili
    :FILE C:/ti/ccsv5/eclipse/jre/lib/zi/Asia/Colombo
    :FILE C:/ti/ccsv5/eclipse/jre/lib/zi/Asia/Pyongyang
    :FILE C:/ti/ccsv5/eclipse/jre/lib/zi/Asia/Aqtobe
    :FILE C:/ti/ccsv5/eclipse/jre/lib/zi/Asia/Jakarta
    :FILE C:/ti/ccsv5/eclipse/jre/lib/zi/Asia/Bishkek
    :FILE C:/ti/ccsv5/eclipse/jre/lib/zi/Asia/Kuching
    :FILE C:/ti/ccsv5/eclipse/jre/lib/zi/Asia/Magadan
    :FILE C:/ti/ccsv5/eclipse/jre/lib/zi/Asia/Tehran
    :FILE C:/ti/ccsv5/eclipse/jre/lib/zi/Asia/Dushanbe
    :FILE C:/ti/ccsv5/eclipse/jre/lib/zi/Asia/Kuala_Lumpur
    :FILE C:/ti/ccsv5/eclipse/jre/lib/zi/Asia/Baku
    :FILE C:/ti/ccsv5/eclipse/jre/lib/zi/Asia/Harbin
    :FILE C:/ti/ccsv5/eclipse/jre/lib/zi/Asia/Bahrain
    :FILE C:/ti/ccsv5/eclipse/jre/lib/zi/Asia/Kuwait
    :FILE C:/ti/ccsv5/eclipse/jre/lib/zi/Asia/Oral
    :FILE C:/ti/ccsv5/eclipse/jre/lib/zi/Asia/Qyzylorda
    :FILE C:/ti/ccsv5/eclipse/jre/lib/zi/Asia/Macau
    :FILE C:/ti/ccsv5/eclipse/jre/lib/zi/Asia/Tbilisi
    :FILE C:/ti/ccsv5/eclipse/jre/lib/zi/Asia/Singapore
    :FILE C:/ti/ccsv5/eclipse/jre/lib/zi/Asia/Krasnoyarsk
    :FILE C:/ti/ccsv5/eclipse/jre/lib/zi/Asia/Amman
    :FILE C:/ti/ccsv5/eclipse/jre/lib/zi/Asia/Baghdad
    :FILE C:/ti/ccsv5/eclipse/jre/lib/zi/Asia/Ashgabat
    :FILE C:/ti/ccsv5/eclipse/jre/lib/zi/Asia/Yekaterinburg
    :FILE C:/ti/ccsv5/eclipse/jre/lib/zi/Asia/Phnom_Penh
    :FILE C:/ti/ccsv5/eclipse/jre/lib/zi/Asia/Jayapura
    :FILE C:/ti/ccsv5/eclipse/jre/lib/zi/Asia/Muscat
    :FILE C:/ti/ccsv5/eclipse/jre/lib/zi/Asia/Nicosia
    :FILE C:/ti/ccsv5/eclipse/jre/lib/zi/Asia/Riyadh
    :FILE C:/ti/ccsv5/eclipse/jre/lib/zi/Asia/Damascus
    :FILE C:/ti/ccsv5/eclipse/jre/lib/zi/Asia/Kashgar
    :FILE C:/ti/ccsv5/eclipse/jre/lib/zi/Asia/Omsk
    :FILE C:/ti/ccsv5/eclipse/jre/lib/zi/Asia/Hong_Kong
    :FILE C:/ti/ccsv5/eclipse/jre/lib/zi/Asia/Urumqi
    :FILE C:/ti/ccsv5/eclipse/jre/lib/zi/Asia/Ulaanbaatar
    :FILE C:/ti/ccsv5/eclipse/jre/lib/zi/Asia/Taipei
    :FILE C:/ti/ccsv5/eclipse/jre/lib/zi/Asia/Bangkok
    :FILE C:/ti/ccsv5/eclipse/jre/lib/zi/Asia/Ho_Chi_Minh
    :FILE C:/ti/ccsv5/eclipse/jre/lib/zi/Asia/Vladivostok
    :FILE C:/ti/ccsv5/eclipse/jre/lib/zi/Asia/Jerusalem
    :FILE C:/ti/ccsv5/eclipse/jre/lib/zi/Asia/Hovd
    :FILE C:/ti/ccsv5/eclipse/jre/lib/zi/Asia/Tashkent
    :FILE C:/ti/ccsv5/eclipse/jre/lib/zi/Asia/Makassar
    :FILE C:/ti/ccsv5/eclipse/jre/lib/zi/Asia/Pontianak
    :FILE C:/ti/ccsv5/eclipse/jre/lib/zi/Asia/Irkutsk
    :FILE C:/ti/ccsv5/eclipse/jre/lib/zi/Asia/Kathmandu
    :FILE C:/ti/ccsv5/eclipse/jre/lib/zi/Asia/Anadyr
    :FILE C:/ti/ccsv5/eclipse/jre/lib/zi/Asia/Kabul
    :FILE C:/ti/ccsv5/eclipse/jre/lib/zi/Asia/Riyadh87
    :FILE C:/ti/ccsv5/eclipse/jre/lib/zi/Asia/Aden
    :FILE C:/ti/ccsv5/eclipse/jre/lib/zi/Asia/Riyadh88
    :FILE C:/ti/ccsv5/eclipse/jre/lib/zi/Asia/Novosibirsk
    :FILE C:/ti/ccsv5/eclipse/jre/lib/zi/Asia/Riyadh89
    :FILE C:/ti/ccsv5/eclipse/jre/lib/zi/Asia/Vientiane
    :FILE C:/ti/ccsv5/eclipse/jre/lib/zi/Asia/Sakhalin
    :FILE C:/ti/ccsv5/eclipse/jre/lib/zi/Asia/Choibalsan
    :FILE C:/ti/ccsv5/eclipse/jre/lib/zi/Asia/Kamchatka
    :FILE C:/ti/ccsv5/eclipse/jre/lib/zi/Asia/Tokyo
    :FILE C:/ti/ccsv5/eclipse/jre/lib/zi/Asia/Chongqing
    :DIR C:/ti/ccsv5/eclipse/jre/lib/zi/Australia
    :FILE C:/ti/ccsv5/eclipse/jre/lib/zi/Australia/Hobart
    :FILE C:/ti/ccsv5/eclipse/jre/lib/zi/Australia/Adelaide
    :FILE C:/ti/ccsv5/eclipse/jre/lib/zi/Australia/Melbourne
    :FILE C:/ti/ccsv5/eclipse/jre/lib/zi/Australia/Perth
    :FILE C:/ti/ccsv5/eclipse/jre/lib/zi/Australia/Lindeman
    :FILE C:/ti/ccsv5/eclipse/jre/lib/zi/Australia/Broken_Hill
    :FILE C:/ti/ccsv5/eclipse/jre/lib/zi/Australia/Currie
    :FILE C:/ti/ccsv5/eclipse/jre/lib/zi/Australia/Eucla
    :FILE C:/ti/ccsv5/eclipse/jre/lib/zi/Australia/Lord_Howe
    :FILE C:/ti/ccsv5/eclipse/jre/lib/zi/Australia/Sydney
    :FILE C:/ti/ccsv5/eclipse/jre/lib/zi/Australia/Darwin
    :FILE C:/ti/ccsv5/eclipse/jre/lib/zi/Australia/Brisbane
    :DIR C:/ti/ccsv5/eclipse/jre/lib/zi/Atlantic
    :FILE C:/ti/ccsv5/eclipse/jre/lib/zi/Atlantic/Faroe
    :FILE C:/ti/ccsv5/eclipse/jre/lib/zi/Atlantic/Cape_Verde
    :FILE C:/ti/ccsv5/eclipse/jre/lib/zi/Atlantic/Canary
    :FILE C:/ti/ccsv5/eclipse/jre/lib/zi/Atlantic/St_Helena
    :FILE C:/ti/ccsv5/eclipse/jre/lib/zi/Atlantic/Madeira
    :FILE C:/ti/ccsv5/eclipse/jre/lib/zi/Atlantic/Stanley
    :FILE C:/ti/ccsv5/eclipse/jre/lib/zi/Atlantic/South_Georgia
    :FILE C:/ti/ccsv5/eclipse/jre/lib/zi/Atlantic/Reykjavik
    :FILE C:/ti/ccsv5/eclipse/jre/lib/zi/Atlantic/Bermuda
    :FILE C:/ti/ccsv5/eclipse/jre/lib/zi/Atlantic/Azores
    :DIR C:/ti/ccsv5/eclipse/jre/lib/zi/America
    :FILE C:/ti/ccsv5/eclipse/jre/lib/zi/America/Puerto_Rico
    :FILE C:/ti/ccsv5/eclipse/jre/lib/zi/America/Guadeloupe
    :FILE C:/ti/ccsv5/eclipse/jre/lib/zi/America/Edmonton
    :FILE C:/ti/ccsv5/eclipse/jre/lib/zi/America/Toronto
    :FILE C:/ti/ccsv5/eclipse/jre/lib/zi/America/St_Kitts
    :FILE C:/ti/ccsv5/eclipse/jre/lib/zi/America/Monterrey
    :FILE C:/ti/ccsv5/eclipse/jre/lib/zi/America/Belem
    :FILE C:/ti/ccsv5/eclipse/jre/lib/zi/America/Tegucigalpa
    :FILE C:/ti/ccsv5/eclipse/jre/lib/zi/America/Caracas
    :FILE C:/ti/ccsv5/eclipse/jre/lib/zi/America/Danmarkshavn
    :FILE C:/ti/ccsv5/eclipse/jre/lib/zi/America/Vancouver
    :FILE C:/ti/ccsv5/eclipse/jre/lib/zi/America/Cayman
    :FILE C:/ti/ccsv5/eclipse/jre/lib/zi/America/Grand_Turk
    :FILE C:/ti/ccsv5/eclipse/jre/lib/zi/America/Atikokan
    :FILE C:/ti/ccsv5/eclipse/jre/lib/zi/America/Sao_Paulo
    :FILE C:/ti/ccsv5/eclipse/jre/lib/zi/America/Menominee
    :FILE C:/ti/ccsv5/eclipse/jre/lib/zi/America/Eirunepe
    :FILE C:/ti/ccsv5/eclipse/jre/lib/zi/America/Rankin_Inlet
    :FILE C:/ti/ccsv5/eclipse/jre/lib/zi/America/Nome
    :FILE C:/ti/ccsv5/eclipse/jre/lib/zi/America/La_Paz
    :FILE C:/ti/ccsv5/eclipse/jre/lib/zi/America/Mazatlan
    :FILE C:/ti/ccsv5/eclipse/jre/lib/zi/America/Boa_Vista
    :FILE C:/ti/ccsv5/eclipse/jre/lib/zi/America/Cambridge_Bay
    :FILE C:/ti/ccsv5/eclipse/jre/lib/zi/America/Managua
    :FILE C:/ti/ccsv5/eclipse/jre/lib/zi/America/Guayaquil
    :FILE C:/ti/ccsv5/eclipse/jre/lib/zi/America/Resolute
    :FILE C:/ti/ccsv5/eclipse/jre/lib/zi/America/Port_of_Spain
    :FILE C:/ti/ccsv5/eclipse/jre/lib/zi/America/Blanc-Sablon
    :FILE C:/ti/ccsv5/eclipse/jre/lib/zi/America/Santiago
    :FILE C:/ti/ccsv5/eclipse/jre/lib/zi/America/Regina
    :FILE C:/ti/ccsv5/eclipse/jre/lib/zi/America/Barbados
    :FILE C:/ti/ccsv5/eclipse/jre/lib/zi/America/Asuncion
    :FILE C:/ti/ccsv5/eclipse/jre/lib/zi/America/Goose_Bay
    :FILE C:/ti/ccsv5/eclipse/jre/lib/zi/America/Santo_Domingo
    :FILE C:/ti/ccsv5/eclipse/jre/lib/zi/America/Porto_Velho
    :FILE C:/ti/ccsv5/eclipse/jre/lib/zi/America/Iqaluit
    :FILE C:/ti/ccsv5/eclipse/jre/lib/zi/America/Araguaina
    :FILE C:/ti/ccsv5/eclipse/jre/lib/zi/America/Godthab
    :FILE C:/ti/ccsv5/eclipse/jre/lib/zi/America/Montreal
    :FILE C:/ti/ccsv5/eclipse/jre/lib/zi/America/Santarem
    :FILE C:/ti/ccsv5/eclipse/jre/lib/zi/America/Aruba
    :FILE C:/ti/ccsv5/eclipse/jre/lib/zi/America/Detroit
    :FILE C:/ti/ccsv5/eclipse/jre/lib/zi/America/Los_Angeles
    :FILE C:/ti/ccsv5/eclipse/jre/lib/zi/America/Guyana
    :FILE C:/ti/ccsv5/eclipse/jre/lib/zi/America/Paramaribo
    :FILE C:/ti/ccsv5/eclipse/jre/lib/zi/America/Panama
    :FILE C:/ti/ccsv5/eclipse/jre/lib/zi/America/Jamaica
    :FILE C:/ti/ccsv5/eclipse/jre/lib/zi/America/Montserrat
    :FILE C:/ti/ccsv5/eclipse/jre/lib/zi/America/Anchorage
    :FILE C:/ti/ccsv5/eclipse/jre/lib/zi/America/Winnipeg
    :FILE C:/ti/ccsv5/eclipse/jre/lib/zi/America/Guatemala
    :FILE C:/ti/ccsv5/eclipse/jre/lib/zi/America/Montevideo
    :FILE C:/ti/ccsv5/eclipse/jre/lib/zi/America/Nassau
    :FILE C:/ti/ccsv5/eclipse/jre/lib/zi/America/Dawson
    :FILE C:/ti/ccsv5/eclipse/jre/lib/zi/America/Denver
    :FILE C:/ti/ccsv5/eclipse/jre/lib/zi/America/Noronha
    :FILE C:/ti/ccsv5/eclipse/jre/lib/zi/America/Inuvik
    :FILE C:/ti/ccsv5/eclipse/jre/lib/zi/America/Swift_Current
    :FILE C:/ti/ccsv5/eclipse/jre/lib/zi/America/Havana
    :FILE C:/ti/ccsv5/eclipse/jre/lib/zi/America/Juneau
    :FILE C:/ti/ccsv5/eclipse/jre/lib/zi/America/Yellowknife
    :FILE C:/ti/ccsv5/eclipse/jre/lib/zi/America/Antigua
    :FILE C:/ti/ccsv5/eclipse/jre/lib/zi/America/Adak
    :FILE C:/ti/ccsv5/eclipse/jre/lib/zi/America/Yakutat
    :FILE C:/ti/ccsv5/eclipse/jre/lib/zi/America/Phoenix
    :FILE C:/ti/ccsv5/eclipse/jre/lib/zi/America/Scoresbysund
    :FILE C:/ti/ccsv5/eclipse/jre/lib/zi/America/Nipigon
    :FILE C:/ti/ccsv5/eclipse/jre/lib/zi/America/Bogota
    :FILE C:/ti/ccsv5/eclipse/jre/lib/zi/America/Dominica
    :FILE C:/ti/ccsv5/eclipse/jre/lib/zi/America/Thunder_Bay
    :FILE C:/ti/ccsv5/eclipse/jre/lib/zi/America/Anguilla
    :FILE C:/ti/ccsv5/eclipse/jre/lib/zi/America/Rio_Branco
    :FILE C:/ti/ccsv5/eclipse/jre/lib/zi/America/Recife
    :FILE C:/ti/ccsv5/eclipse/jre/lib/zi/America/Port-au-Prince
    :FILE C:/ti/ccsv5/eclipse/jre/lib/zi/America/Glace_Bay
    :FILE C:/ti/ccsv5/eclipse/jre/lib/zi/America/Fortaleza
    :FILE C:/ti/ccsv5/eclipse/jre/lib/zi/America/Thule
    :FILE C:/ti/ccsv5/eclipse/jre/lib/zi/America/Lima
    :FILE C:/ti/ccsv5/eclipse/jre/lib/zi/America/Belize
    :FILE C:/ti/ccsv5/eclipse/jre/lib/zi/America/Cayenne
    :FILE C:/ti/ccsv5/eclipse/jre/lib/zi/America/El_Salvador
    :FILE C:/ti/ccsv5/eclipse/jre/lib/zi/America/St_Vincent
    :FILE C:/ti/ccsv5/eclipse/jre/lib/zi/America/Pangnirtung
    :FILE C:/ti/ccsv5/eclipse/jre/lib/zi/America/Bahia
    :FILE C:/ti/ccsv5/eclipse/jre/lib/zi/America/Halifax
    :FILE C:/ti/ccsv5/eclipse/jre/lib/zi/America/New_York
    :FILE C:/ti/ccsv5/eclipse/jre/lib/zi/America/Moncton
    :FILE C:/ti/ccsv5/eclipse/jre/lib/zi/America/Hermosillo
    :FILE C:/ti/ccsv5/eclipse/jre/lib/zi/America/Curacao
    :FILE C:/ti/ccsv5/eclipse/jre/lib/zi/America/Martinique
    :FILE C:/ti/ccsv5/eclipse/jre/lib/zi/America/St_Johns
    :FILE C:/ti/ccsv5/eclipse/jre/lib/zi/America/Rainy_River
    :FILE C:/ti/ccsv5/eclipse/jre/lib/zi/America/Tijuana
    :FILE C:/ti/ccsv5/eclipse/jre/lib/zi/America/St_Lucia
    :FILE C:/ti/ccsv5/eclipse/jre/lib/zi/America/Tortola
    :FILE C:/ti/ccsv5/eclipse/jre/lib/zi/America/Mexico_City
    :FILE C:/ti/ccsv5/eclipse/jre/lib/zi/America/Manaus
    :FILE C:/ti/ccsv5/eclipse/jre/lib/zi/America/Cuiaba
    :FILE C:/ti/ccsv5/eclipse/jre/lib/zi/America/Dawson_Creek
    :FILE C:/ti/ccsv5/eclipse/jre/lib/zi/America/Maceio
    :FILE C:/ti/ccsv5/eclipse/jre/lib/zi/America/Chicago
    :FILE C:/ti/ccsv5/eclipse/jre/lib/zi/America/Campo_Grande
    :FILE C:/ti/ccsv5/eclipse/jre/lib/zi/America/Cancun
    :FILE C:/ti/ccsv5/eclipse/jre/lib/zi/America/Chihuahua
    :FILE C:/ti/ccsv5/eclipse/jre/lib/zi/America/Costa_Rica
    :FILE C:/ti/ccsv5/eclipse/jre/lib/zi/America/Whitehorse
    :FILE C:/ti/ccsv5/eclipse/jre/lib/zi/America/St_Thomas
    :FILE C:/ti/ccsv5/eclipse/jre/lib/zi/America/Miquelon
    :FILE C:/ti/ccsv5/eclipse/jre/lib/zi/America/Merida
    :FILE C:/ti/ccsv5/eclipse/jre/lib/zi/America/Boise
    :FILE C:/ti/ccsv5/eclipse/jre/lib/zi/America/Grenada
    :DIR C:/ti/ccsv5/eclipse/jre/lib/zi/America/North_Dakota
    :FILE C:/ti/ccsv5/eclipse/jre/lib/zi/America/North_Dakota/New_Salem
    :FILE C:/ti/ccsv5/eclipse/jre/lib/zi/America/North_Dakota/Center
    :DIR C:/ti/ccsv5/eclipse/jre/lib/zi/America/Kentucky
    :FILE C:/ti/ccsv5/eclipse/jre/lib/zi/America/Kentucky/Monticello
    :FILE C:/ti/ccsv5/eclipse/jre/lib/zi/America/Kentucky/Louisville
    :DIR C:/ti/ccsv5/eclipse/jre/lib/zi/America/Argentina
    :FILE C:/ti/ccsv5/eclipse/jre/lib/zi/America/Argentina/Catamarca
    :FILE C:/ti/ccsv5/eclipse/jre/lib/zi/America/Argentina/Salta
    :FILE C:/ti/ccsv5/eclipse/jre/lib/zi/America/Argentina/Buenos_Aires
    :FILE C:/ti/ccsv5/eclipse/jre/lib/zi/America/Argentina/Rio_Gallegos
    :FILE C:/ti/ccsv5/eclipse/jre/lib/zi/America/Argentina/Cordoba
    :FILE C:/ti/ccsv5/eclipse/jre/lib/zi/America/Argentina/Tucuman
    :FILE C:/ti/ccsv5/eclipse/jre/lib/zi/America/Argentina/Mendoza
    :FILE C:/ti/ccsv5/eclipse/jre/lib/zi/America/Argentina/San_Luis
    :FILE C:/ti/ccsv5/eclipse/jre/lib/zi/America/Argentina/Jujuy
    :FILE C:/ti/ccsv5/eclipse/jre/lib/zi/America/Argentina/San_Juan
    :FILE C:/ti/ccsv5/eclipse/jre/lib/zi/America/Argentina/Ushuaia
    :FILE C:/ti/ccsv5/eclipse/jre/lib/zi/America/Argentina/La_Rioja
    :DIR C:/ti/ccsv5/eclipse/jre/lib/zi/America/Indiana
    :FILE C:/ti/ccsv5/eclipse/jre/lib/zi/America/Indiana/Winamac
    :FILE C:/ti/ccsv5/eclipse/jre/lib/zi/America/Indiana/Knox
    :FILE C:/ti/ccsv5/eclipse/jre/lib/zi/America/Indiana/Vincennes
    :FILE C:/ti/ccsv5/eclipse/jre/lib/zi/America/Indiana/Tell_City
    :FILE C:/ti/ccsv5/eclipse/jre/lib/zi/America/Indiana/Marengo
    :FILE C:/ti/ccsv5/eclipse/jre/lib/zi/America/Indiana/Vevay
    :FILE C:/ti/ccsv5/eclipse/jre/lib/zi/America/Indiana/Petersburg
    :FILE C:/ti/ccsv5/eclipse/jre/lib/zi/America/Indiana/Indianapolis
    :DIR C:/ti/ccsv5/eclipse/jre/lib/zi/Indian
    :FILE C:/ti/ccsv5/eclipse/jre/lib/zi/Indian/Kerguelen
    :FILE C:/ti/ccsv5/eclipse/jre/lib/zi/Indian/Christmas
    :FILE C:/ti/ccsv5/eclipse/jre/lib/zi/Indian/Antananarivo
    :FILE C:/ti/ccsv5/eclipse/jre/lib/zi/Indian/Mayotte
    :FILE C:/ti/ccsv5/eclipse/jre/lib/zi/Indian/Mauritius
    :FILE C:/ti/ccsv5/eclipse/jre/lib/zi/Indian/Mahe
    :FILE C:/ti/ccsv5/eclipse/jre/lib/zi/Indian/Comoro
    :FILE C:/ti/ccsv5/eclipse/jre/lib/zi/Indian/Cocos
    :FILE C:/ti/ccsv5/eclipse/jre/lib/zi/Indian/Reunion
    :FILE C:/ti/ccsv5/eclipse/jre/lib/zi/Indian/Maldives
    :FILE C:/ti/ccsv5/eclipse/jre/lib/zi/Indian/Chagos
    :DIR C:/ti/ccsv5/eclipse/jre/lib/zi/Africa
    :FILE C:/ti/ccsv5/eclipse/jre/lib/zi/Africa/Algiers
    :FILE C:/ti/ccsv5/eclipse/jre/lib/zi/Africa/Accra
    :FILE C:/ti/ccsv5/eclipse/jre/lib/zi/Africa/Freetown
    :FILE C:/ti/ccsv5/eclipse/jre/lib/zi/Africa/Lubumbashi
    :FILE C:/ti/ccsv5/eclipse/jre/lib/zi/Africa/Maseru
    :FILE C:/ti/ccsv5/eclipse/jre/lib/zi/Africa/Cairo
    :FILE C:/ti/ccsv5/eclipse/jre/lib/zi/Africa/Douala
    :FILE C:/ti/ccsv5/eclipse/jre/lib/zi/Africa/Mbabane
    :FILE C:/ti/ccsv5/eclipse/jre/lib/zi/Africa/Kigali
    :FILE C:/ti/ccsv5/eclipse/jre/lib/zi/Africa/Mogadishu
    :FILE C:/ti/ccsv5/eclipse/jre/lib/zi/Africa/Harare
    :FILE C:/ti/ccsv5/eclipse/jre/lib/zi/Africa/Monrovia
    :FILE C:/ti/ccsv5/eclipse/jre/lib/zi/Africa/Niamey
    :FILE C:/ti/ccsv5/eclipse/jre/lib/zi/Africa/Kampala
    :FILE C:/ti/ccsv5/eclipse/jre/lib/zi/Africa/Windhoek
    :FILE C:/ti/ccsv5/eclipse/jre/lib/zi/Africa/Casablanca
    :FILE C:/ti/ccsv5/eclipse/jre/lib/zi/Africa/Djibouti
    :FILE C:/ti/ccsv5/eclipse/jre/lib/zi/Africa/Brazzaville
    :FILE C:/ti/ccsv5/eclipse/jre/lib/zi/Africa/Maputo
    :FILE C:/ti/ccsv5/eclipse/jre/lib/zi/Africa/Lusaka
    :FILE C:/ti/ccsv5/eclipse/jre/lib/zi/Africa/Kinshasa
    :FILE C:/ti/ccsv5/eclipse/jre/lib/zi/Africa/Bissau
    :FILE C:/ti/ccsv5/eclipse/jre/lib/zi/Africa/Ouagadougou
    :FILE C:/ti/ccsv5/eclipse/jre/lib/zi/Africa/Abidjan
    :FILE C:/ti/ccsv5/eclipse/jre/lib/zi/Africa/Libreville
    :FILE C:/ti/ccsv5/eclipse/jre/lib/zi/Africa/Bamako
    :FILE C:/ti/ccsv5/eclipse/jre/lib/zi/Africa/Porto-Novo
    :FILE C:/ti/ccsv5/eclipse/jre/lib/zi/Africa/Johannesburg
    :FILE C:/ti/ccsv5/eclipse/jre/lib/zi/Africa/Conakry
    :FILE C:/ti/ccsv5/eclipse/jre/lib/zi/Africa/Nouakchott
    :FILE C:/ti/ccsv5/eclipse/jre/lib/zi/Africa/Khartoum
    :FILE C:/ti/ccsv5/eclipse/jre/lib/zi/Africa/Banjul
    :FILE C:/ti/ccsv5/eclipse/jre/lib/zi/Africa/Nairobi
    :FILE C:/ti/ccsv5/eclipse/jre/lib/zi/Africa/Ndjamena
    :FILE C:/ti/ccsv5/eclipse/jre/lib/zi/Africa/Blantyre
    :FILE C:/ti/ccsv5/eclipse/jre/lib/zi/Africa/Tunis
    :FILE C:/ti/ccsv5/eclipse/jre/lib/zi/Africa/Tripoli
    :FILE C:/ti/ccsv5/eclipse/jre/lib/zi/Africa/Dakar
    :FILE C:/ti/ccsv5/eclipse/jre/lib/zi/Africa/Dar_es_Salaam
    :FILE C:/ti/ccsv5/eclipse/jre/lib/zi/Africa/Luanda
    :FILE C:/ti/ccsv5/eclipse/jre/lib/zi/Africa/Bangui
    :FILE C:/ti/ccsv5/eclipse/jre/lib/zi/Africa/El_Aaiun
    :FILE C:/ti/ccsv5/eclipse/jre/lib/zi/Africa/Lagos
    :FILE C:/ti/ccsv5/eclipse/jre/lib/zi/Africa/Sao_Tome
    :FILE C:/ti/ccsv5/eclipse/jre/lib/zi/Africa/Ceuta
    :FILE C:/ti/ccsv5/eclipse/jre/lib/zi/Africa/Addis_Ababa
    :FILE C:/ti/ccsv5/eclipse/jre/lib/zi/Africa/Malabo
    :FILE C:/ti/ccsv5/eclipse/jre/lib/zi/Africa/Bujumbura
    :FILE C:/ti/ccsv5/eclipse/jre/lib/zi/Africa/Asmara
    :FILE C:/ti/ccsv5/eclipse/jre/lib/zi/Africa/Gaborone
    :FILE C:/ti/ccsv5/eclipse/jre/lib/zi/Africa/Lome
    :DIR C:/ti/ccsv5/eclipse/jre/lib/zi/Pacific
    :FILE C:/ti/ccsv5/eclipse/jre/lib/zi/Pacific/Truk
    :FILE C:/ti/ccsv5/eclipse/jre/lib/zi/Pacific/Chatham
    :FILE C:/ti/ccsv5/eclipse/jre/lib/zi/Pacific/Galapagos
    :FILE C:/ti/ccsv5/eclipse/jre/lib/zi/Pacific/Pitcairn
    :FILE C:/ti/ccsv5/eclipse/jre/lib/zi/Pacific/Marquesas
    :FILE C:/ti/ccsv5/eclipse/jre/lib/zi/Pacific/Fiji
    :FILE C:/ti/ccsv5/eclipse/jre/lib/zi/Pacific/Funafuti
    :FILE C:/ti/ccsv5/eclipse/jre/lib/zi/Pacific/Tongatapu
    :FILE C:/ti/ccsv5/eclipse/jre/lib/zi/Pacific/Tahiti
    :FILE C:/ti/ccsv5/eclipse/jre/lib/zi/Pacific/Ponape
    :FILE C:/ti/ccsv5/eclipse/jre/lib/zi/Pacific/Palau
    :FILE C:/ti/ccsv5/eclipse/jre/lib/zi/Pacific/Norfolk
    :FILE C:/ti/ccsv5/eclipse/jre/lib/zi/Pacific/Nauru
    :FILE C:/ti/ccsv5/eclipse/jre/lib/zi/Pacific/Johnston
    :FILE C:/ti/ccsv5/eclipse/jre/lib/zi/Pacific/Auckland
    :FILE C:/ti/ccsv5/eclipse/jre/lib/zi/Pacific/Saipan
    :FILE C:/ti/ccsv5/eclipse/jre/lib/zi/Pacific/Pago_Pago
    :FILE C:/ti/ccsv5/eclipse/jre/lib/zi/Pacific/Noumea
    :FILE C:/ti/ccsv5/eclipse/jre/lib/zi/Pacific/Efate
    :FILE C:/ti/ccsv5/eclipse/jre/lib/zi/Pacific/Guadalcanal
    :FILE C:/ti/ccsv5/eclipse/jre/lib/zi/Pacific/Majuro
    :FILE C:/ti/ccsv5/eclipse/jre/lib/zi/Pacific/Kwajalein
    :FILE C:/ti/ccsv5/eclipse/jre/lib/zi/Pacific/Honolulu
    :FILE C:/ti/ccsv5/eclipse/jre/lib/zi/Pacific/Kiritimati
    :FILE C:/ti/ccsv5/eclipse/jre/lib/zi/Pacific/Fakaofo
    :FILE C:/ti/ccsv5/eclipse/jre/lib/zi/Pacific/Gambier
    :FILE C:/ti/ccsv5/eclipse/jre/lib/zi/Pacific/Wake
    :FILE C:/ti/ccsv5/eclipse/jre/lib/zi/Pacific/Tarawa
    :FILE C:/ti/ccsv5/eclipse/jre/lib/zi/Pacific/Enderbury
    :FILE C:/ti/ccsv5/eclipse/jre/lib/zi/Pacific/Niue
    :FILE C:/ti/ccsv5/eclipse/jre/lib/zi/Pacific/Guam
    :FILE C:/ti/ccsv5/eclipse/jre/lib/zi/Pacific/Midway
    :FILE C:/ti/ccsv5/eclipse/jre/lib/zi/Pacific/Apia
    :FILE C:/ti/ccsv5/eclipse/jre/lib/zi/Pacific/Wallis
    :FILE C:/ti/ccsv5/eclipse/jre/lib/zi/Pacific/Easter
    :FILE C:/ti/ccsv5/eclipse/jre/lib/zi/Pacific/Rarotonga
    :FILE C:/ti/ccsv5/eclipse/jre/lib/zi/Pacific/Port_Moresby
    :FILE C:/ti/ccsv5/eclipse/jre/lib/zi/Pacific/Kosrae
    :DIR C:/ti/ccsv5/eclipse/jre/lib/zi/Europe
    :FILE C:/ti/ccsv5/eclipse/jre/lib/zi/Europe/Warsaw
    :FILE C:/ti/ccsv5/eclipse/jre/lib/zi/Europe/Samara
    :FILE C:/ti/ccsv5/eclipse/jre/lib/zi/Europe/Oslo
    :FILE C:/ti/ccsv5/eclipse/jre/lib/zi/Europe/Amsterdam
    :FILE C:/ti/ccsv5/eclipse/jre/lib/zi/Europe/Belgrade
    :FILE C:/ti/ccsv5/eclipse/jre/lib/zi/Europe/Dublin
    :FILE C:/ti/ccsv5/eclipse/jre/lib/zi/Europe/Paris
    :FILE C:/ti/ccsv5/eclipse/jre/lib/zi/Europe/Lisbon
    :FILE C:/ti/ccsv5/eclipse/jre/lib/zi/Europe/Helsinki
    :FILE C:/ti/ccsv5/eclipse/jre/lib/zi/Europe/Andorra
    :FILE C:/ti/ccsv5/eclipse/jre/lib/zi/Europe/Simferopol
    :FILE C:/ti/ccsv5/eclipse/jre/lib/zi/Europe/Vienna
    :FILE C:/ti/ccsv5/eclipse/jre/lib/zi/Europe/Bucharest
    :FILE C:/ti/ccsv5/eclipse/jre/lib/zi/Europe/Uzhgorod
    :FILE C:/ti/ccsv5/eclipse/jre/lib/zi/Europe/Sofia
    :FILE C:/ti/ccsv5/eclipse/jre/lib/zi/Europe/Minsk
    :FILE C:/ti/ccsv5/eclipse/jre/lib/zi/Europe/Luxembourg
    :FILE C:/ti/ccsv5/eclipse/jre/lib/zi/Europe/Rome
    :FILE C:/ti/ccsv5/eclipse/jre/lib/zi/Europe/Riga
    :FILE C:/ti/ccsv5/eclipse/jre/lib/zi/Europe/Athens
    :FILE C:/ti/ccsv5/eclipse/jre/lib/zi/Europe/Zurich
    :FILE C:/ti/ccsv5/eclipse/jre/lib/zi/Europe/Volgograd
    :FILE C:/ti/ccsv5/eclipse/jre/lib/zi/Europe/Monaco
    :FILE C:/ti/ccsv5/eclipse/jre/lib/zi/Europe/Malta
    :FILE C:/ti/ccsv5/eclipse/jre/lib/zi/Europe/Kiev
    :FILE C:/ti/ccsv5/eclipse/jre/lib/zi/Europe/Moscow
    :FILE C:/ti/ccsv5/eclipse/jre/lib/zi/Europe/Budapest
    :FILE C:/ti/ccsv5/eclipse/jre/lib/zi/Europe/Copenhagen
    :FILE C:/ti/ccsv5/eclipse/jre/lib/zi/Europe/Gibraltar
    :FILE C:/ti/ccsv5/eclipse/jre/lib/zi/Europe/Madrid
    :FILE C:/ti/ccsv5/eclipse/jre/lib/zi/Europe/Vilnius
    :FILE C:/ti/ccsv5/eclipse/jre/lib/zi/Europe/Vaduz
    :FILE C:/ti/ccsv5/eclipse/jre/lib/zi/Europe/Tallinn
    :FILE C:/ti/ccsv5/eclipse/jre/lib/zi/Europe/London
    :FILE C:/ti/ccsv5/eclipse/jre/lib/zi/Europe/Istanbul
    :FILE C:/ti/ccsv5/eclipse/jre/lib/zi/Europe/Zaporozhye
    :FILE C:/ti/ccsv5/eclipse/jre/lib/zi/Europe/Tirane
    :FILE C:/ti/ccsv5/eclipse/jre/lib/zi/Europe/Brussels
    :FILE C:/ti/ccsv5/eclipse/jre/lib/zi/Europe/Stockholm
    :FILE C:/ti/ccsv5/eclipse/jre/lib/zi/Europe/Prague
    :FILE C:/ti/ccsv5/eclipse/jre/lib/zi/Europe/Kaliningrad
    :FILE C:/ti/ccsv5/eclipse/jre/lib/zi/Europe/Berlin
    :FILE C:/ti/ccsv5/eclipse/jre/lib/zi/Europe/Chisinau
    :DIR C:/ti/ccsv5/eclipse/jre/lib/zi/Antarctica
    :FILE C:/ti/ccsv5/eclipse/jre/lib/zi/Antarctica/Syowa
    :FILE C:/ti/ccsv5/eclipse/jre/lib/zi/Antarctica/McMurdo
    :FILE C:/ti/ccsv5/eclipse/jre/lib/zi/Antarctica/Davis
    :FILE C:/ti/ccsv5/eclipse/jre/lib/zi/Antarctica/Rothera
    :FILE C:/ti/ccsv5/eclipse/jre/lib/zi/Antarctica/Palmer
    :FILE C:/ti/ccsv5/eclipse/jre/lib/zi/Antarctica/Mawson
    :FILE C:/ti/ccsv5/eclipse/jre/lib/zi/Antarctica/Casey
    :FILE C:/ti/ccsv5/eclipse/jre/lib/zi/Antarctica/Vostok
    :FILE C:/ti/ccsv5/eclipse/jre/lib/zi/Antarctica/DumontDUrville
    :DIR C:/ti/ccsv5/eclipse/jre/lib/zi/SystemV
    :FILE C:/ti/ccsv5/eclipse/jre/lib/zi/SystemV/YST9YDT
    :FILE C:/ti/ccsv5/eclipse/jre/lib/zi/SystemV/AST4ADT
    :FILE C:/ti/ccsv5/eclipse/jre/lib/zi/SystemV/EST5EDT
    :FILE C:/ti/ccsv5/eclipse/jre/lib/zi/SystemV/PST8
    :FILE C:/ti/ccsv5/eclipse/jre/lib/zi/SystemV/PST8PDT
    :FILE C:/ti/ccsv5/eclipse/jre/lib/zi/SystemV/HST10
    :FILE C:/ti/ccsv5/eclipse/jre/lib/zi/SystemV/MST7MDT
    :FILE C:/ti/ccsv5/eclipse/jre/lib/zi/SystemV/CST6CDT
    :DIR C:/ti/ccsv5/eclipse/jre/lib/management
    :FILE C:/ti/ccsv5/eclipse/jre/lib/management/snmp.acl.template
    :FILE C:/ti/ccsv5/eclipse/jre/lib/management/jmxremote.password.template
    :FILE C:/ti/ccsv5/eclipse/jre/lib/management/jmxremote.access
    :FILE C:/ti/ccsv5/eclipse/jre/lib/management/management.properties
    :DIR C:/ti/ccsv5/eclipse/jre/lib/cmm
    :FILE C:/ti/ccsv5/eclipse/jre/lib/cmm/sRGB.pf
    :FILE C:/ti/ccsv5/eclipse/jre/lib/cmm/PYCC.pf
    :FILE C:/ti/ccsv5/eclipse/jre/lib/cmm/GRAY.pf
    :FILE C:/ti/ccsv5/eclipse/jre/lib/cmm/CIEXYZ.pf
    :FILE C:/ti/ccsv5/eclipse/jre/lib/cmm/LINEAR_RGB.pf
    :DIR C:/ti/ccsv5/eclipse/jre/lib/deploy
    :FILE C:/ti/ccsv5/eclipse/jre/lib/deploy/messages_fr.properties
    :FILE C:/ti/ccsv5/eclipse/jre/lib/deploy/ffjcext.zip
    :FILE C:/ti/ccsv5/eclipse/jre/lib/deploy/messages.properties
    :FILE C:/ti/ccsv5/eclipse/jre/lib/deploy/messages_sv.properties
    :FILE C:/ti/ccsv5/eclipse/jre/lib/deploy/messages_zh_HK.properties
    :FILE C:/ti/ccsv5/eclipse/jre/lib/deploy/messages_it.properties
    :FILE C:/ti/ccsv5/eclipse/jre/lib/deploy/messages_es.properties
    :FILE C:/ti/ccsv5/eclipse/jre/lib/deploy/messages_de.properties
    :FILE C:/ti/ccsv5/eclipse/jre/lib/deploy/messages_ko.properties
    :FILE C:/ti/ccsv5/eclipse/jre/lib/deploy/messages_zh_CN.properties
    :FILE C:/ti/ccsv5/eclipse/jre/lib/deploy/messages_ja.properties
    :FILE C:/ti/ccsv5/eclipse/jre/lib/deploy/messages_zh_TW.properties
    :FILE C:/ti/ccsv5/eclipse/jre/lib/deploy/lzma.dll
    :FILE C:/ti/ccsv5/eclipse/jre/lib/deploy/splash.gif
    :DIR C:/ti/ccsv5/eclipse/jre/lib/deploy/jqs
    :FILE C:/ti/ccsv5/eclipse/jre/lib/deploy/jqs/jqsmessages.properties
    :FILE C:/ti/ccsv5/eclipse/jre/lib/deploy/jqs/jqs.conf
    :DIR C:/ti/ccsv5/eclipse/jre/lib/deploy/jqs/ie
    :FILE C:/ti/ccsv5/eclipse/jre/lib/deploy/jqs/ie/jqs_plugin.dll
    :DIR C:/ti/ccsv5/eclipse/jre/lib/deploy/jqs/ff
    :FILE C:/ti/ccsv5/eclipse/jre/lib/deploy/jqs/ff/chrome.manifest
    :FILE C:/ti/ccsv5/eclipse/jre/lib/deploy/jqs/ff/install.rdf
    :DIR C:/ti/ccsv5/eclipse/jre/lib/deploy/jqs/ff/chrome
    :DIR C:/ti/ccsv5/eclipse/jre/lib/deploy/jqs/ff/chrome/content
    :FILE C:/ti/ccsv5/eclipse/jre/lib/deploy/jqs/ff/chrome/content/overlay.xul
    :FILE C:/ti/ccsv5/eclipse/jre/lib/deploy/jqs/ff/chrome/content/overlay.js
    :DIR C:/ti/ccsv5/eclipse/jre/bin
    :FILE C:/ti/ccsv5/eclipse/jre/bin/javaws.exe
    :FILE C:/ti/ccsv5/eclipse/jre/bin/sunmscapi.dll
    :FILE C:/ti/ccsv5/eclipse/jre/bin/jsound.dll
    :FILE C:/ti/ccsv5/eclipse/jre/bin/jqs.exe
    :FILE C:/ti/ccsv5/eclipse/jre/bin/ioser12.dll
    :FILE C:/ti/ccsv5/eclipse/jre/bin/jpioji.dll
    :FILE C:/ti/ccsv5/eclipse/jre/bin/nio.dll
    :FILE C:/ti/ccsv5/eclipse/jre/bin/net.dll
    :FILE C:/ti/ccsv5/eclipse/jre/bin/javaw.exe
    :FILE C:/ti/ccsv5/eclipse/jre/bin/jpinscp.dll
    :FILE C:/ti/ccsv5/eclipse/jre/bin/jaas_nt.dll
    :FILE C:/ti/ccsv5/eclipse/jre/bin/instrument.dll
    :FILE C:/ti/ccsv5/eclipse/jre/bin/npt.dll
    :FILE C:/ti/ccsv5/eclipse/jre/bin/java.dll
    :FILE C:/ti/ccsv5/eclipse/jre/bin/jpicom.dll
    :FILE C:/ti/ccsv5/eclipse/jre/bin/jsoundds.dll
    :FILE C:/ti/ccsv5/eclipse/jre/bin/jureg.exe
    :FILE C:/ti/ccsv5/eclipse/jre/bin/deploytk.dll
    :FILE C:/ti/ccsv5/eclipse/jre/bin/orbd.exe
    :FILE C:/ti/ccsv5/eclipse/jre/bin/management.dll
    :FILE C:/ti/ccsv5/eclipse/jre/bin/cmm.dll
    :FILE C:/ti/ccsv5/eclipse/jre/bin/jbroker.exe
    :FILE C:/ti/ccsv5/eclipse/jre/bin/jqsnotify.exe
    :FILE C:/ti/ccsv5/eclipse/jre/bin/pack200.exe
    :FILE C:/ti/ccsv5/eclipse/jre/bin/unicows.dll
    :FILE C:/ti/ccsv5/eclipse/jre/bin/dcpr.dll
    :FILE C:/ti/ccsv5/eclipse/jre/bin/tnameserv.exe
    :FILE C:/ti/ccsv5/eclipse/jre/bin/msvcr71.dll
    :FILE C:/ti/ccsv5/eclipse/jre/bin/jkernel.dll
    :FILE C:/ti/ccsv5/eclipse/jre/bin/jp2launcher.exe
    :FILE C:/ti/ccsv5/eclipse/jre/bin/java-rmi.exe
    :FILE C:/ti/ccsv5/eclipse/jre/bin/axbridge.dll
    :FILE C:/ti/ccsv5/eclipse/jre/bin/npdeploytk.dll
    :FILE C:/ti/ccsv5/eclipse/jre/bin/wsdetect.dll
    :FILE C:/ti/ccsv5/eclipse/jre/bin/servertool.exe
    :FILE C:/ti/ccsv5/eclipse/jre/bin/JdbcOdbc.dll
    :FILE C:/ti/ccsv5/eclipse/jre/bin/jp2native.dll
    :FILE C:/ti/ccsv5/eclipse/jre/bin/w2k_lsa_auth.dll
    :FILE C:/ti/ccsv5/eclipse/jre/bin/deploy.dll
    :FILE C:/ti/ccsv5/eclipse/jre/bin/javacpl.exe
    :FILE C:/ti/ccsv5/eclipse/jre/bin/ktab.exe
    :FILE C:/ti/ccsv5/eclipse/jre/bin/java_crw_demo.dll
    :FILE C:/ti/ccsv5/eclipse/jre/bin/unpack200.exe
    :FILE C:/ti/ccsv5/eclipse/jre/bin/rmid.exe
    :FILE C:/ti/ccsv5/eclipse/jre/bin/jp2iexp.dll
    :FILE C:/ti/ccsv5/eclipse/jre/bin/npjpi160_13.dll
    :FILE C:/ti/ccsv5/eclipse/jre/bin/jawt.dll
    :FILE C:/ti/ccsv5/eclipse/jre/bin/jpishare.dll
    :FILE C:/ti/ccsv5/eclipse/jre/bin/rmiregistry.exe
    :FILE C:/ti/ccsv5/eclipse/jre/bin/eula.dll
    :FILE C:/ti/ccsv5/eclipse/jre/bin/rmi.dll
    :FILE C:/ti/ccsv5/eclipse/jre/bin/jp2ssv.dll
    :FILE C:/ti/ccsv5/eclipse/jre/bin/ssvagent.exe
    :FILE C:/ti/ccsv5/eclipse/jre/bin/unpack.dll
    :FILE C:/ti/ccsv5/eclipse/jre/bin/fontmanager.dll
    :FILE C:/ti/ccsv5/eclipse/jre/bin/policytool.exe
    :FILE C:/ti/ccsv5/eclipse/jre/bin/jusched.exe
    :FILE C:/ti/ccsv5/eclipse/jre/bin/awt.dll
    :FILE C:/ti/ccsv5/eclipse/jre/bin/verify.dll
    :FILE C:/ti/ccsv5/eclipse/jre/bin/kinit.exe
    :FILE C:/ti/ccsv5/eclipse/jre/bin/regutils.dll
    :FILE C:/ti/ccsv5/eclipse/jre/bin/msvcrt.dll
    :FILE C:/ti/ccsv5/eclipse/jre/bin/hprof.dll
    :FILE C:/ti/ccsv5/eclipse/jre/bin/zip.dll
    :FILE C:/ti/ccsv5/eclipse/jre/bin/splashscreen.dll
    :FILE C:/ti/ccsv5/eclipse/jre/bin/keytool.exe
    :FILE C:/ti/ccsv5/eclipse/jre/bin/j2pcsc.dll
    :FILE C:/ti/ccsv5/eclipse/jre/bin/jdwp.dll
    :FILE C:/ti/ccsv5/eclipse/jre/bin/mlib_image.dll
    :FILE C:/ti/ccsv5/eclipse/jre/bin/jpeg.dll
    :FILE C:/ti/ccsv5/eclipse/jre/bin/npoji610.dll
    :FILE C:/ti/ccsv5/eclipse/jre/bin/j2pkcs11.dll
    :FILE C:/ti/ccsv5/eclipse/jre/bin/jli.dll
    :FILE C:/ti/ccsv5/eclipse/jre/bin/hpi.dll
    :FILE C:/ti/ccsv5/eclipse/jre/bin/dt_shmem.dll
    :FILE C:/ti/ccsv5/eclipse/jre/bin/jucheck.exe
    :FILE C:/ti/ccsv5/eclipse/jre/bin/ssv.dll
    :FILE C:/ti/ccsv5/eclipse/jre/bin/javacpl.cpl
    :FILE C:/ti/ccsv5/eclipse/jre/bin/klist.exe
    :FILE C:/ti/ccsv5/eclipse/jre/bin/dt_socket.dll
    :FILE C:/ti/ccsv5/eclipse/jre/bin/java.exe
    :FILE C:/ti/ccsv5/eclipse/jre/bin/jpiexp.dll
    :DIR C:/ti/ccsv5/eclipse/jre/bin/new_plugin
    :FILE C:/ti/ccsv5/eclipse/jre/bin/new_plugin/msvcr71.dll
    :FILE C:/ti/ccsv5/eclipse/jre/bin/new_plugin/npjp2.dll
    :FILE C:/ti/ccsv5/eclipse/jre/bin/new_plugin/npdeploytk.dll
    :DIR C:/ti/ccsv5/eclipse/jre/bin/client
    :FILE C:/ti/ccsv5/eclipse/jre/bin/client/classes.jsa
    :FILE C:/ti/ccsv5/eclipse/jre/bin/client/Xusage.txt
    :FILE C:/ti/ccsv5/eclipse/jre/bin/client/jvm.dll
    :FILE C:/ti/ccsv5/eclipse/jre/lib/ext/RXTXcomm.jar
    :FILE C:/ti/ccsv5/eclipse/jre/bin/rxtxSerial.dll
    :FILE C:/ti/ccsv5/eclipse/jre/bin/rxtxParallel.dll
    :FILE C:/Users/SESA126844/ti/CCSExternalReferences/CCS_5_2_0_00069
    :PATH PATH {C:\ti\ccsv5\utils\bin} user {;}
    :FILE C:/ti/ccsv5/ccs_base/common/targetdb/cpus/defaultProperties.dat
    :FILE C:/ti/ccsv5/ccs_base/common/targetdb/connections/defaultProperties.dat
    :FILE C:/ti/ccsv5/ccs_base/common/targetdb/routers/defaultProperties.dat
    :DIR C:/ti/ccsv5/install_scripts
    :DIR C:/ti/ccsv5/install_scripts/extras
    :FILE C:/ti/ccsv5/install_scripts/extras/rmdatfiles.sh
    :FILE C:/ti/ccsv5/install_scripts/extras/rmdatfiles.bat
    :PATH PATH {C:\ti\ccsv5\ccs_base\common\bin} user {;}
    :FILE {C:\ti/ccsv5/eclipse/install.log}
    :FILE {C:\ti/ccsv5/eclipse/ccs_config.xml}
    :REGISTRY {HKEY_LOCAL_MACHINE\Software\Microsoft\Windows\CurrentVersion\Uninstall\Code Composer Studio v5}
    :FILE {C:/ti/Code Composer Studio v5.lnk}
    :FILE {C:/Users/Public/Desktop/Code Composer Studio v5.lnk}
    :DIR {C:/ProgramData/Microsoft/Windows/Start Menu/Programs/Texas Instruments/Code Composer Studio v5}
    :FILE {C:/ProgramData/Microsoft/Windows/Start Menu/Programs/Texas Instruments/Code Composer Studio v5/Code Composer Studio v5.lnk}
    :FILE {C:/ProgramData/Microsoft/Windows/Start Menu/Programs/Texas Instruments/Code Composer Studio v5/Release Notes.lnk}
    :FILE {C:/ProgramData/Microsoft/Windows/Start Menu/Programs/Texas Instruments/Code Composer Studio v5/Uninstall Code Composer Studio v5.lnk}
    :FILE {C:/Program Files (x86)/InstallJammer Registry/ccsv5/60556FE5-C1A1-4061-8DF8-FFB8393BAE2D/20120710-113455_ccs_config.xml}
    :FILE {C:/Program Files (x86)/InstallJammer Registry/ccsv5/60556FE5-C1A1-4061-8DF8-FFB8393BAE2D/20120710-113455_ccs_manifest.xml}
    :FILE {C:/Program Files (x86)/InstallJammer Registry/ccsv5/60556FE5-C1A1-4061-8DF8-FFB8393BAE2D/20120710-113455_ccs_installini.xml}
    :FILE {C:/Program Files (x86)/InstallJammer Registry/ccsv5/60556FE5-C1A1-4061-8DF8-FFB8393BAE2D/20120710-113455_eclipse_install.log}
    3487.ccs_setup_5.2.0.00069_install.log
  • Hi Yingran,
    ok it seems there was no installation issue.  Could you please try the following.
    In your CCS installation you should have a file like vcredist*.exe ...  (Eg  vcredist_x86.exe)
    I believe this is where you can also also download it directly from Microsoft.  You will need the 2005 version.
    http://www.microsoft.com/download/en/details.aspx?id=3387
    Please keep us informed.
    Lisa
  • I saw vcredist_xx86_2005.exe. And I run it.  It ended itself like ccs5.
  • I have the issue solved. It turns out to be one of the display driver issue on my new PC.
    Thanks!
  • Hi Yingran,
    ok, glad to hear things got figured out for you.
    All the best with development.
    Lisa
