Hi TI ,
While installing ccs .v5 i encountered an error which resulted in incomplete installation,
=== Logging started: 7/27/2010 12:17:00 ===
Action start 12:17:00: INSTALL.
Action start 12:17:00: WiseGetIeVersion.
Action ended 12:17:00: WiseGetIeVersion. Return value 1.
Action start 12:17:00: LaunchConditions.
Action ended 12:17:00: LaunchConditions. Return value 1.
Action start 12:17:00: Setup_Dialog.
Info 2898. For MSSansSerif8 textstyle, the system created a 'MS Sans Serif' font, in 1 character set, of 13 pixels height.
Info 2898. For Arial14 textstyle, the system created a 'Arial' font, in 1 character set, of 22 pixels height.
Info 2898. For Arial10 textstyle, the system created a 'Arial' font, in 1 character set, of 16 pixels height.
Action ended 12:17:00: Setup_Dialog. Return value 1.
Action start 12:17:00: FindRelatedProducts.
Action ended 12:17:00: FindRelatedProducts. Return value 1.
Action start 12:17:00: AppSearch.
Action ended 12:17:00: AppSearch. Return value 1.
Action start 12:17:00: GetPerlInfoFromRegistry.
Action ended 12:17:01: GetPerlInfoFromRegistry. Return value 0.
Action start 12:17:01: ValidateProductID.
Action ended 12:17:01: ValidateProductID. Return value 1.
Action start 12:17:01: CostInitialize.
Action ended 12:17:01: CostInitialize. Return value 1.
Action start 12:17:01: FileCost.
Action ended 12:17:01: FileCost. Return value 1.
Action start 12:17:01: IsolateComponents.
Action ended 12:17:01: IsolateComponents. Return value 1.
Action start 12:17:01: CostFinalize.
Action ended 12:17:02: CostFinalize. Return value 1.
Action start 12:17:02: MigrateFeatureStates.
Action ended 12:17:02: MigrateFeatureStates. Return value 0.
Action start 12:17:02: Welcome_Dialog.
Info 2898. For RequirementMet textstyle, the system created a 'Arial' font, in 1 character set, of 16 pixels height.
Info 2898. For RequirementNotMet textstyle, the system created a 'Arial' font, in 1 character set, of 16 pixels height.
Info 2898. For Arial8 textstyle, the system created a 'Arial' font, in 1 character set, of 14 pixels height.
Info 2898. For Arial12 textstyle, the system created a 'Arial' font, in 1 character set, of 19 pixels height.
DEBUG: Error 2863: The control PushButton2 on dialog Installation_Type_Dialog needs the icon TypicalInstall.bmp in size 48x48, but that size is not available. Loading the first available size
Internal Error 2863. Installation_Type_Dialog, PushButton2, TypicalInstall.bmp
DEBUG: Error 2863: The control PushButton28 on dialog Installation_Type_Dialog needs the icon TypicalInstall.bmp in size 48x48, but that size is not available. Loading the first available size
Internal Error 2863. Installation_Type_Dialog, PushButton28, TypicalInstall.bmp
DEBUG: Error 2863: The control PushButton25 on dialog Installation_Type_Dialog needs the icon CustomInstall.bmp in size 48x48, but that size is not available. Loading the first available size
Internal Error 2863. Installation_Type_Dialog, PushButton25, CustomInstall.bmp
Info 2898. For MS_Sans_Serif81 textstyle, the system created a 'MS Sans Serif' font, in 1 character set, of 13 pixels height.
Info 2898. For MSSansSerif8__UL textstyle, the system created a 'MS Sans Serif' font, in 0 character set, of 13 pixels height.
Info 2898. For MS_Sans_Serif8 textstyle, the system created a 'MS Sans Serif' font, in 1 character set, of 13 pixels height.
Action ended 12:18:00: Welcome_Dialog. Return value 1.
Action start 12:18:00: Progress_Dialog.
Action ended 12:18:00: Progress_Dialog. Return value 1.
Action start 12:18:00: ExecuteAction.
Action start 12:18:05: INSTALL.
Action start 12:18:05: WiseGetIeVersion.
Action ended 12:18:05: WiseGetIeVersion. Return value 0.
Action start 12:18:05: LaunchConditions.
Action ended 12:18:05: LaunchConditions. Return value 1.
Action start 12:18:05: FindRelatedProducts.
Action ended 12:18:05: FindRelatedProducts. Return value 0.
Action start 12:18:05: AppSearch.
Action ended 12:18:05: AppSearch. Return value 0.
Action start 12:18:05: ValidateProductID.
Action ended 12:18:05: ValidateProductID. Return value 1.
Action start 12:18:05: CostInitialize.
Action ended 12:18:05: CostInitialize. Return value 1.
Action start 12:18:05: ResolveSource.
Action ended 12:18:05: ResolveSource. Return value 1.
Action start 12:18:05: FileCost.
Action ended 12:18:05: FileCost. Return value 1.
Action start 12:18:05: IsolateComponents.
Action ended 12:18:05: IsolateComponents. Return value 1.
Action start 12:18:05: CostFinalize.
Action ended 12:18:05: CostFinalize. Return value 1.
Action start 12:18:05: SetODBCFolders.
Action ended 12:18:05: SetODBCFolders. Return value 1.
Action start 12:18:05: MigrateFeatureStates.
Action ended 12:18:05: MigrateFeatureStates. Return value 0.
Action start 12:18:05: InstallValidate.
Action ended 12:18:08: InstallValidate. Return value 1.
Action start 12:18:08: InstallInitialize.
Action ended 12:18:15: InstallInitialize. Return value 1.
Action start 12:18:15: TIBuildInstallDirRegKey.
Action ended 12:18:18: TIBuildInstallDirRegKey. Return value 0.
Action start 12:18:18: TIBuildDisplayVersionCA.
Action ended 12:18:18: TIBuildDisplayVersionCA. Return value 0.
Action start 12:18:18: SetBiosInstallPropertyCA.
Action ended 12:18:18: SetBiosInstallPropertyCA. Return value 1.
Action start 12:18:18: SetCompMgrEXEPropertyCA.
Action ended 12:18:18: SetCompMgrEXEPropertyCA. Return value 1.
Action start 12:18:18: CCSInstallPluginSetup.
Action ended 12:18:18: CCSInstallPluginSetup. Return value 1.
Action start 12:18:18: AllocateRegistrySpace.
Action ended 12:18:18: AllocateRegistrySpace. Return value 1.
Action start 12:18:18: ProcessComponents.
Action ended 12:18:19: ProcessComponents. Return value 1.
Action start 12:18:19: UnpublishComponents.
Action ended 12:18:19: UnpublishComponents. Return value 1.
Action start 12:18:19: UnpublishFeatures.
Action ended 12:18:19: UnpublishFeatures. Return value 1.
Action start 12:18:19: StopServices.
Action ended 12:18:19: StopServices. Return value 1.
Action start 12:18:19: DeleteServices.
Action ended 12:18:19: DeleteServices. Return value 1.
Action start 12:18:19: UnregisterComPlus.
Action ended 12:18:19: UnregisterComPlus. Return value 1.
Action start 12:18:19: SelfUnregModules.
Action ended 12:18:19: SelfUnregModules. Return value 1.
Action start 12:18:19: UnregisterTypeLibraries.
Action ended 12:18:19: UnregisterTypeLibraries. Return value 1.
Action start 12:18:19: RemoveODBC.
Action ended 12:18:19: RemoveODBC. Return value 1.
Action start 12:18:19: UnregisterFonts.
Action ended 12:18:19: UnregisterFonts. Return value 1.
Action start 12:18:19: RemoveRegistryValues.
Action ended 12:18:19: RemoveRegistryValues. Return value 1.
Action start 12:18:19: UnregisterClassInfo.
Action ended 12:18:19: UnregisterClassInfo. Return value 1.
Action start 12:18:19: UnregisterExtensionInfo.
Action ended 12:18:19: UnregisterExtensionInfo. Return value 1.
Action start 12:18:19: UnregisterProgIdInfo.
Action ended 12:18:19: UnregisterProgIdInfo. Return value 1.
Action start 12:18:19: UnregisterMIMEInfo.
Action ended 12:18:19: UnregisterMIMEInfo. Return value 1.
Action start 12:18:19: RemoveIniValues.
Action ended 12:18:19: RemoveIniValues. Return value 1.
Action start 12:18:19: RemoveShortcuts.
Action ended 12:18:19: RemoveShortcuts. Return value 1.
Action start 12:18:19: RemoveEnvironmentStrings.
Action ended 12:18:19: RemoveEnvironmentStrings. Return value 1.
Action start 12:18:19: RemoveDuplicateFiles.
Action ended 12:18:19: RemoveDuplicateFiles. Return value 1.
Action start 12:18:19: RemoveFiles.
Action ended 12:18:19: RemoveFiles. Return value 1.
Action start 12:18:19: RemoveFolders.
Action ended 12:18:19: RemoveFolders. Return value 1.
Action start 12:18:19: CreateFolders.
Action ended 12:18:19: CreateFolders. Return value 1.
Action start 12:18:19: MoveFiles.
Action ended 12:18:19: MoveFiles. Return value 1.
Action start 12:18:19: InstallFiles.
Action ended 12:18:23: InstallFiles. Return value 1.
Action start 12:18:23: DuplicateFiles.
Action ended 12:18:23: DuplicateFiles. Return value 1.
Action start 12:18:23: PatchFiles.
Action ended 12:18:23: PatchFiles. Return value 1.
Action start 12:18:23: BindImage.
Action ended 12:18:23: BindImage. Return value 1.
Action start 12:18:23: CreateShortcuts.
Action ended 12:18:23: CreateShortcuts. Return value 1.
Action start 12:18:23: RegisterClassInfo.
Action ended 12:18:23: RegisterClassInfo. Return value 1.
Action start 12:18:23: RegisterExtensionInfo.
Action ended 12:18:23: RegisterExtensionInfo. Return value 1.
Action start 12:18:23: RegisterProgIdInfo.
Action ended 12:18:23: RegisterProgIdInfo. Return value 1.
Action start 12:18:23: RegisterMIMEInfo.
Action ended 12:18:23: RegisterMIMEInfo. Return value 1.
Action start 12:18:23: WriteRegistryValues.
Action ended 12:18:23: WriteRegistryValues. Return value 1.
Action start 12:18:23: WriteIniValues.
Action ended 12:18:23: WriteIniValues. Return value 1.
Action start 12:18:23: SetARPINSTALLLOCATIONPropertyCA.
Action ended 12:18:23: SetARPINSTALLLOCATIONPropertyCA. Return value 1.
Action start 12:18:23: SetDosRunBatCA.
Action ended 12:18:23: SetDosRunBatCA. Return value 1.
Action start 12:18:23: TIDosRunSetPathCA.
Action ended 12:18:23: TIDosRunSetPathCA. Return value 1.
Action start 12:18:23: WriteEnvironmentStrings.
Action ended 12:18:23: WriteEnvironmentStrings. Return value 1.
Action start 12:18:23: RegisterFonts.
Action ended 12:18:23: RegisterFonts. Return value 1.
Action start 12:18:23: InstallODBC.
Action ended 12:18:23: InstallODBC. Return value 0.
Action start 12:18:23: RegisterTypeLibraries.
Action ended 12:18:23: RegisterTypeLibraries. Return value 1.
Action start 12:18:23: SETUPinstallBios.
Action ended 12:18:23: SETUPinstallBios. Return value 1.
Action start 12:18:23: RegisterBiosHelp.
Action ended 12:18:23: RegisterBiosHelp. Return value 1.
Action start 12:18:23: RegisterBiosFunctionality.
Action ended 12:18:23: RegisterBiosFunctionality. Return value 1.
Action start 12:18:23: SelfRegModules.
Action ended 12:18:23: SelfRegModules. Return value 1.
Action start 12:18:23: RegisterComPlus.
Action ended 12:18:23: RegisterComPlus. Return value 1.
Action start 12:18:23: InstallServices.
Action ended 12:18:23: InstallServices. Return value 1.
Action start 12:18:23: StartServices.
Action ended 12:18:23: StartServices. Return value 1.
Action start 12:18:23: XDS560Install.
Action ended 12:18:23: XDS560Install. Return value 1.
Action start 12:18:23: RegisterUser.
Action ended 12:18:23: RegisterUser. Return value 1.
Action start 12:18:23: RegisterProduct.
Action ended 12:18:23: RegisterProduct. Return value 1.
Action start 12:18:23: PublishComponents.
Action ended 12:18:23: PublishComponents. Return value 1.
Action start 12:18:23: PublishFeatures.
Action ended 12:18:23: PublishFeatures. Return value 1.
Action start 12:18:23: PublishProduct.
Action ended 12:18:23: PublishProduct. Return value 1.
Action start 12:18:23: RegCCAPP.
Action ended 12:18:23: RegCCAPP. Return value 1.
Action start 12:18:23: SETUPinstallPlugins.
Action ended 12:18:23: SETUPinstallPlugins. Return value 1.
Action start 12:18:23: SetProductSKU.
Action ended 12:18:23: SetProductSKU. Return value 1.
Action start 12:18:23: SetupCompMgr.
Action ended 12:18:23: SetupCompMgr. Return value 1.
Action start 12:18:23: InstallFinalize.
Action ended 12:25:12: InstallFinalize. Return value 1.
Action start 12:25:12: SetPerlPathCA.
Action ended 12:25:12: SetPerlPathCA. Return value 1.
Action start 12:25:12: RemoveExistingProducts.
Action ended 12:25:12: RemoveExistingProducts. Return value 1.
Action ended 12:25:12: INSTALL. Return value 1.
Action ended 12:25:14: ExecuteAction. Return value 1.
Action start 12:25:15: PerlAbsentWarningSetCustomActionData.
Action ended 12:25:15: PerlAbsentWarningSetCustomActionData. Return value 1.
Action start 12:25:15: PerlAbsentWarning.
Action ended 12:25:23: PerlAbsentWarning. Return value 1.
Action start 12:25:23: Exit_Dialog.
Action start 12:25:27: SetRegisterURL.
Action ended 12:25:27: SetRegisterURL. Return value 1.
Action start 12:25:27: RegisterOnline.
Action ended 12:25:43: RegisterOnline. Return value 1.
Action ended 12:25:44: Exit_Dialog. Return value 1.
Action ended 12:25:44: INSTALL. Return value 1.
=== Logging stopped: 7/27/2010 12:25:45 ===
MSI (c) (E8:A8) [12:25:57:622]: Product: Code Composer Studio v3.3 -- Installation operation completed successfully.
MSI (c) (E8:A8) [12:25:57:653]: Windows Installer installed the product. Product Name: Code Composer Studio v3.3. Product Version: 3.3.38.2. Product Language: 1033. Installation success or error status: 0.
This is the log i got .
Please help me to install ccs properly.
janeeth
