Unable to connect to Beagleboard-xm with XDS100v2
I am using a beagleboard-xm and JTAG XDS100v2. I am facing some connection problem:-
C64XP_0: Error connecting to the target: (Error -1178 @ 0x6D) Device functional clock appears to be off. Power-cycle the board. If error persists, confirm configuration and/or try more reliable JTAG settings (e.g. lower TCLK). (Emulation package 5.0.747.0)
Also I need to debug uImage. Please suggest what could be the problem.
Suraj
  • Hi Suraj,
    what OS do you use?  What exact CCS version?  How have you been trying to connect?  (ie ccxml/project settings) Have you been simply connecting directly unmodified to the kit?
    Have you simply been trying to work with a demo/example?
    Any further info would help us help you.
    Lisa
  • what OS do you use? - Linux kernel
    What exact CCS version? - 2.6.37
    - .ccxml
    - I am using a customised OMAP3 (Beagleboard-xm)
    - Customised board.
    Connection is working but the error is different now:-
    Cortex_A8_0: Trouble Writing Memory Block at 0x48004c10 on Page 0 of Length 0x4: (Error -1065 @ 0x48004C10) Unable to access device memory. Verify that the memory address is in valid memory. If error persists, confirm configuration, power-cycle board, and/or try more reliable JTAG settings (e.g. lower TCLK). (Emulation package 5.0.747.0)
    Do you have any demo how to debug Beagleboard-xm with CCS using XDS100v2?
    Suraj
  • Hi Suraj,
    unfortunately between holiday and trying to find a colleague to help out here I see there has not yet been a further answer for you.  Do you still require assistance?  If so I will work to get you help as soon as I can.
    Lisa
  • Hi Surag,
    Have you seen the material on the following sites?
    http://processors.wiki.ti.com/index.php/Category:CCS_Training
    http://beagleboard.org/
    http://processors.wiki.ti.com/index.php/Getting_Started_With_C6Run_On_Beagleboard
    Does that help?
    Lisa
