Irritating CCS bug!
Other Parts Discussed in Thread: CCSTUDIO
 Using CCS Version: 5.2.1.00018 on a Linux VM...
All of a sudden when I tried to compile my app I got this:
And when I try to do a debug session I get this:
Clicking Yes or No makes no difference, it keeps coming back, even for other projects in the same workspace...
I have tried restarting CCS and rebooting the VM as well...
There is no .lock file in my .metadata folder either...
What is causing these issues and how to fix...this is really affecting my productivity...
  • Hi Kent,
    - have you tried a fresh workspace?
    - did something in your enviroment change?  Was new software installed, did you upgrade CCS, ie did something in your setup or environment change?
    Would you be able to send any error logs or .dmp files generated?
    http://processors.wiki.ti.com/index.php/Troubleshooting_CCS
    Lisa
  • Are you saying that I can just import the projects into a new workspace to fix this, or will I import the problem as well?
    No, no recent updates...happened out of the blue...
    Here's a cut/paste of the end of my .log file, since your groovy file uploader doesnt want to "accept file of this type"...
    !STACK 0
    java.lang.IllegalArgumentException: Generated resource conflict:
    two resources of the same name: /DSP/Release/.config/xconfig_app/package/cfg/configPkg/compiler.opt
    generated by different tools
    tool1: XDCtools
    tool2: XDCtools
        at org.eclipse.cdt.managedbuilder.internal.buildmodel.BuildResource.addToArg(BuildResource.java:154)
        at org.eclipse.cdt.managedbuilder.internal.buildmodel.BuildIOType.addResource(BuildIOType.java:64)
        at org.eclipse.cdt.managedbuilder.internal.buildmodel.BuildDescription.addOutputs(BuildDescription.java:1031)
        at org.eclipse.cdt.managedbuilder.internal.buildmodel.BuildDescription.calculateOutputs(BuildDescription.java:1347)
        at org.eclipse.cdt.managedbuilder.internal.buildmodel.BuildDescription.composeOutputs(BuildDescription.java:644)
        at org.eclipse.cdt.managedbuilder.internal.buildmodel.BuildDescription.access$1(BuildDescription.java:537)
        at org.eclipse.cdt.managedbuilder.internal.buildmodel.BuildDescription$RcVisitor.doVisitFile(BuildDescription.java:252)
        at org.eclipse.cdt.managedbuilder.internal.buildmodel.BuildDescription$RcVisitor.visit(BuildDescription.java:173)
        at org.eclipse.core.internal.resources.Resource$1.visitElement(Resource.java:65)
        at org.eclipse.core.internal.watson.ElementTreeIterator.doIteration(ElementTreeIterator.java:82)
        at org.eclipse.core.internal.watson.ElementTreeIterator.doIteration(ElementTreeIterator.java:86)
        at org.eclipse.core.internal.watson.ElementTreeIterator.iterate(ElementTreeIterator.java:127)
        at org.eclipse.core.internal.resources.Resource.accept(Resource.java:75)
        at org.eclipse.cdt.managedbuilder.internal.buildmodel.BuildDescription.initDescription(BuildDescription.java:741)
        at org.eclipse.cdt.managedbuilder.internal.buildmodel.BuildDescription.init(BuildDescription.java:810)
        at org.eclipse.cdt.managedbuilder.internal.buildmodel.DefaultBuildDescriptionFactory.createBuildDescription(DefaultBuildDescriptionFactory.java:44)
        at org.eclipse.cdt.managedbuilder.internal.buildmodel.DefaultBuildDescriptionFactory.createBuildDescription(DefaultBuildDescriptionFactory.java:36)
        at com.ti.ccstudio.project.core.internal.build.temp.BuildDescriptionManager.createBuildDescription(BuildDescriptionManager.java:87)
        at com.ti.ccstudio.project.core.internal.build.CCSMakefileGenerator.generateMakefiles(CCSMakefileGenerator.java:317)
        at org.eclipse.cdt.managedbuilder.internal.core.CommonBuilder.performMakefileGeneration(CommonBuilder.java:999)
        at org.eclipse.cdt.managedbuilder.internal.core.CommonBuilder.performPrebuildGeneration(CommonBuilder.java:864)
        at org.eclipse.cdt.managedbuilder.internal.core.CommonBuilder.build(CommonBuilder.java:739)
        at org.eclipse.cdt.managedbuilder.internal.core.CommonBuilder.build(CommonBuilder.java:501)
        at org.eclipse.cdt.managedbuilder.internal.core.CommonBuilder.build(CommonBuilder.java:450)
        at org.eclipse.core.internal.events.BuildManager$2.run(BuildManager.java:728)
        at org.eclipse.core.runtime.SafeRunner.run(SafeRunner.java:42)
        at org.eclipse.core.internal.events.BuildManager.basicBuild(BuildManager.java:199)
        at org.eclipse.core.internal.events.BuildManager.basicBuild(BuildManager.java:239)
        at org.eclipse.core.internal.events.BuildManager$1.run(BuildManager.java:292)
        at org.eclipse.core.internal.events.BuildManager.basicBuild(BuildManager.java:295)
        at org.eclipse.core.internal.events.BuildManager.basicBuildLoop(BuildManager.java:351)
        at org.eclipse.core.internal.events.BuildManager.build(BuildManager.java:374)
        at org.eclipse.core.internal.resources.Workspace.buildInternal(Workspace.java:513)
        at org.eclipse.core.internal.resources.Workspace.build(Workspace.java:432)
        at org.eclipse.ui.actions.BuildAction$1.runInWorkspace(BuildAction.java:305)
        at org.eclipse.core.internal.resources.InternalWorkspaceJob.run(InternalWorkspaceJob.java:38)
        at org.eclipse.core.internal.jobs.Worker.run(Worker.java:54)
    !SUBENTRY 1 org.eclipse.cdt.managedbuilder.core 4 0 2012-10-03 15:44:24.193
    !MESSAGE Generated resource conflict:
    tool1: XDCtools
    tool2: XDCtools
    !STACK 0
    tool1: XDCtools
    tool2: XDCtools
    !ENTRY org.eclipse.core.resources 4 75 2012-10-03 15:44:24.643
    !MESSAGE Errors occurred during the build.
    !SUBENTRY 1 org.eclipse.cdt.managedbuilder.core 4 75 2012-10-03 15:44:24.643
    !MESSAGE Errors running builder 'CDT Builder' on project 'DSP'.
    !STACK 1
    org.eclipse.core.runtime.CoreException: Generated resource conflict:
    tool1: XDCtools
    tool2: XDCtools
        at org.eclipse.cdt.managedbuilder.internal.buildmodel.BuildDescription$RcVisitor.visit(BuildDescription.java:185)
    Caused by: java.lang.IllegalArgumentException: Generated resource conflict:
    tool1: XDCtools
    tool2: XDCtools
        ... 34 more
    !SUBENTRY 2 org.eclipse.cdt.managedbuilder.core 4 0 2012-10-03 15:44:24.643
    tool1: XDCtools
    tool2: XDCtools
    !STACK 0
    tool1: XDCtools
    tool2: XDCtools
    !SUBENTRY 1 org.eclipse.cdt.managedbuilder.core 4 0 2012-10-03 15:44:24.654
    tool1: XDCtools
    tool2: XDCtools
    !STACK 0
    tool1: XDCtools
    tool2: XDCtools
  • Hi Kent,
    we have seen this before actually and there were two different causes (hidden files and a second cause)
    Have a look at this thread and please keep us informed whether it is related/helps solve the issue for you.
    http://e2e.ti.com/support/development_tools/code_composer_studio/f/81/p/203656/732251.aspx#732251
    Lisa
