CCS error when trying to halt target: "Trouble halting target CPU, could not terminate EEM Polling thread."
The odd behavior was that the code would load and run fine ... but could not pause it, or stop it.  Code Composer displayed, "Trouble halting target CPU, could not terminate EEM Polling thread."
I'd appreciate hearing potential solutions to the problem. Re-booting the computer did not fix it.  Re-starting Code Composer a number times did not fix it.  It just magically started to work again ... after I wasted a couple of hours.
  • From your other thread, you mentioned you are using CCSv4. Support for v4 is being deprecated for v5 (any bugs in v4 will be fixed in v5). Any chance taking the latest v5 build and giving it a try?
    ki
