I am using CCS 5.0.3, CGT 7.3.1, uia_1_00_01_17, xdctools_3_22_01_21 and I am trying to use MCSA.
The analyser starts correctly, I can run live and in the "MCSA Live Sessions: Logs" windows the list of task on the monitored cores appears.
When I start the cores, events start flowing, but almost immediately it seems to stop and the logs are cleaned up.
In the error log, then only error I can spot is this one:
eclipse.buildId=M20100909-0800
java.version=1.5.0_14
java.vendor=Sun Microsystems Inc.
BootLoader constants: OS=win32, ARCH=x86, WS=win32, NL=it_IT
Command-line arguments: -os win32 -ws win32 -arch x86
Error
Fri Nov 23 10:52:44 CET 2012
For input string: "100,00"
java.lang.NumberFormatException: For input string: "100,00"
at sun.misc.FloatingDecimal.readJavaFormatString(Unknown Source)
at java.lang.Double.valueOf(Unknown Source)
at com.ti.dvt.datamodel.core.DataTypeConversion.convert(DataTypeConversion.java:239)
at com.ti.dvt.datamodel.core.DataTypeAdapter.processInput(DataTypeAdapter.java:133)
at com.ti.dvt.datamodel.core.DataProcessor$Output.sendInput(DataProcessor.java:78)
at com.ti.dvt.datamodel.core.PassthruDataProcessor$PassthruOutput.sendInput(PassthruDataProcessor.java:203)
at com.ti.dvt.datamodel.core.FieldTranslator.processInput(FieldTranslator.java:68)
at com.ti.dvt.datamodel.core.Tap.processCorrelatedInput(Tap.java:1020)
at com.ti.dvt.datamodel.core.Tap.access$2(Tap.java:1003)
at com.ti.dvt.datamodel.core.Tap$Input.processInput(Tap.java:281)
at com.ti.dvt.datamodel.analysis.prototyping.BasicDataLossHandler.processInput(BasicDataLossHandler.java:139)
at com.ti.dvt.uia.dp.UIAPreprocessor.processInput(Unknown Source)
at com.ti.dvt.uia.dp.UIALogSource.sendMasterLog(Unknown Source)
at com.ti.dvt.uia.dp.UIALogSource$UIAThread.run(Unknown Source)
Any ideas?
Many thanks
Stefano
