I am trying to install CCS 5.5.1.00033 on Ubuntu 12.10 running in Vbox on a Windows 7 host machine. The install log referred by the installer when the install fails is below:
------ ccs_setup_5.1.1.00033 Installation -------------
12/05/2012 14:08:01PM -
12/05/2012 14:08:01PM - InstallID : BD9D00A8-6679-FFDA-F936-27930BD52305
12/05/2012 14:08:01PM - Installer : /home/dell/Desktop/Shared/CCS-5.1.1.00033-Sitara-ARM/CCS/ccs_setup_5.1.1.00033.bin
12/05/2012 14:08:01PM - BuildName : ccs_setup_5.1.1.00033.bin
12/05/2012 14:08:01PM - Install version: 5.1.1.00033
12/05/2012 14:08:01PM - Install source : /home/dell/Desktop/Shared/CCS-5.1.1.00033-Sitara-ARM/CCS
12/05/2012 14:08:01PM - OS : Linux-x86
12/05/2012 14:08:01PM - UserName : root
12/05/2012 14:08:01PM - Update? : 0
12/05/2012 14:08:01PM - Sudo user : dell
12/05/2012 14:08:01PM - Sudo command : ./ccs_setup_5.1.1.00033.bin
12/05/2012 14:08:01PM - Command line :/installkitvfs/main.tcl
12/05/2012 14:08:01PM - Checking conditions for 5A908E3F-6B9A-4311-B8CA-15578F03CEC9 - Set Native_Eclipse_Selected - Before Action is Executed
12/05/2012 14:08:01PM - Checking condition A2036039-9CCB-492A-8247-6D07128AEE2F - Command Line Test Condition
12/05/2012 14:08:01PM - Checking to see if eclipseprefix was passed on the command line
12/05/2012 14:08:01PM - Condition failed
12/05/2012 14:08:01PM - Skipping action 5A908E3F-6B9A-4311-B8CA-15578F03CEC9 - Set Native_Eclipse_Selected - conditions failed
12/05/2012 14:08:01PM - Checking conditions for F0A046CD-8A59-4F7D-B025-7ED78FD8C0F3 - Execute Response File Action - Before Action is Executed
12/05/2012 14:08:01PM - Checking condition C434E3F3-C405-466D-9713-A8F99B3BCC12 - Command Line Test Condition
12/05/2012 14:08:01PM - Checking to see if response-file was passed on the command line
12/05/2012 14:08:01PM - Skipping action F0A046CD-8A59-4F7D-B025-7ED78FD8C0F3 - Execute Response File Action - conditions failed
12/05/2012 14:08:01PM - Checking conditions for 73286838-ADC5-44C6-9BF4-3D00C32317F7 - Set Windows information - Before Action is Executed
12/05/2012 14:08:01PM - Checking condition DDEDDBE3-895A-4F08-B242-B5CEB39360F2 - Platform Condition
12/05/2012 14:08:01PM - Checking to see if <%Platform%> is Windows
12/05/2012 14:08:01PM - ** Checking to see if Linux-x86 is Windows
12/05/2012 14:08:01PM - Skipping action 73286838-ADC5-44C6-9BF4-3D00C32317F7 - Set Windows information - conditions failed
12/05/2012 14:08:01PM - Checking conditions for 181F69AF-2B9D-44EF-B0B0-84126765120A - Remove common\bin from path (Windows) - Before Action is Executed
12/05/2012 14:08:01PM - Checking condition 858075F5-D830-482D-A8EC-BBB15C017286 - Platform Condition
12/05/2012 14:08:01PM - Skipping action 181F69AF-2B9D-44EF-B0B0-84126765120A - Remove common\bin from path (Windows) - conditions failed
12/05/2012 14:08:01PM - Executing action 1409F691-5623-49F1-99EB-D4ED15870571 - Set BuildName (default)
12/05/2012 14:08:02PM - Setting active setup type to New Setup Type (B6E0CE8C-4E6F-4885-953A-32946A051105).
12/05/2012 14:08:02PM - Activating component D253A697-7480-46F3-AF71-AB63991129FD
12/05/2012 14:08:02PM - Executing actions A0AAD47D-43D9-43F8-9439-47A03F6F4E2B - Startup Actions
12/05/2012 14:08:02PM - Executing action 1C82CB44-08EC-4BAE-BCF7-719902E9C236 - Execute Windows Startup
12/05/2012 14:08:02PM - Checking conditions for AED7E1E0-3E40-41B5-A471-FAAFD73529F8 - Windows Startup Action - Before Action is Executed
12/05/2012 14:08:02PM - Checking condition BDCBFA61-EF65-4DF4-A4C3-1CD5758BDD79 - Platform Condition
12/05/2012 14:08:02PM - Checking to see if <%Platform%> is Windows
12/05/2012 14:08:02PM - ** Checking to see if Linux-x86 is Windows
12/05/2012 14:08:02PM - Condition failed
12/05/2012 14:08:02PM - Skipping action group 1C82CB44-08EC-4BAE-BCF7-719902E9C236 - Execute Windows Startup - conditions failed
12/05/2012 14:08:02PM - Checking conditions for 98FB6613-1F73-4BCB-8DDB-B431EBD71496 - Exit if no access to TEMP dir - Before Action is Executed
12/05/2012 14:08:02PM - Checking condition 17D28D55-F95F-4DD0-AC94-EF4CDE6400D2 - Execute Script Condition
12/05/2012 14:08:02PM - /tmp is writable ? 1 or 1
12/05/2012 14:08:02PM - /tmp/ijtmp_6CECF410-B6FA-AD39-7653-D5312F771648 exists? 1
12/05/2012 14:08:02PM - /tmp/ijtmp_6CECF410-B6FA-AD39-7653-D5312F771648 is writable ? 1
12/05/2012 14:08:02PM - making /tmp/ijtmp_6CECF410-B6FA-AD39-7653-D5312F771648/baserepo
12/05/2012 14:08:02PM - Skipping action 98FB6613-1F73-4BCB-8DDB-B431EBD71496 - Exit if no access to TEMP dir - conditions failed
12/05/2012 14:08:02PM - Checking conditions for 1514399D-CAAF-4087-9E82-A65109B675F8 - Execute Look for EclipseDir - Before Action is Executed
12/05/2012 14:08:02PM - Checking condition 245ABF90-7270-43B9-A0A7-17F7DAAB3466 - Command Line Test Condition
12/05/2012 14:08:02PM - Checking to see if eclipseprefix was passed on the command line
12/05/2012 14:08:02PM - Skipping action 1514399D-CAAF-4087-9E82-A65109B675F8 - Execute Look for EclipseDir - conditions failed
12/05/2012 14:08:02PM - Checking conditions for 390AFA53-7D35-4C26-A453-27B7CEBB834E - Unpack Setup xml file - Before Action is Executed
12/05/2012 14:08:02PM - Checking condition AB402A5E-1927-4722-B563-CAF54B6E53AA - Platform Condition
12/05/2012 14:08:02PM - Skipping action 390AFA53-7D35-4C26-A453-27B7CEBB834E - Unpack Setup xml file - conditions failed
12/05/2012 14:08:02PM - Checking conditions for F4C790E5-5B05-43B4-ABC4-B4B9C1C01A59 - Unpack Setup xml file - Before Action is Executed
12/05/2012 14:08:02PM - Checking condition D1A276F0-17F4-498A-B707-E9B7CDAF7109 - Platform Condition
12/05/2012 14:08:02PM - Checking to see if <%Platform%> is Linux-x86
12/05/2012 14:08:02PM - ** Checking to see if Linux-x86 is Linux-x86
12/05/2012 14:08:02PM - Condition passed
12/05/2012 14:08:02PM - Executing action F4C790E5-5B05-43B4-ABC4-B4B9C1C01A59 - Unpack Setup xml file
12/05/2012 14:08:02PM - Unpacking /tmp/ijtmp_6CECF410-B6FA-AD39-7653-D5312F771648/ccs_installini.xml
12/05/2012 14:08:02PM - Executing action 1FDA0E1A-FA6B-40B5-934E-553F9ABDC49B - Set InstallIni file name
12/05/2012 14:08:02PM - InstallSource = /home/dell/Desktop/Shared/CCS-5.1.1.00033-Sitara-ARM/CCS
12/05/2012 14:08:02PM - InstallIni file = <%InstallSource%>/ccs_installini.xml /home/dell/Desktop/Shared/CCS-5.1.1.00033-Sitara-ARM/CCS/ccs_installini.xml
12/05/2012 14:08:02PM - ** InstallIni file = /home/dell/Desktop/Shared/CCS-5.1.1.00033-Sitara-ARM/CCS/ccs_installini.xml /home/dell/Desktop/Shared/CCS-5.1.1.00033-Sitara-ARM/CCS/ccs_installini.xml
12/05/2012 14:08:02PM - Executing action C325767C-1961-4AB1-8037-7C19CB4BA543 - Get Setup Types
12/05/2012 14:08:02PM - Checking conditions for 25BA989D-274D-4302-A91E-48B8454834E4 - Unpack Manifest xml file - Before Action is Executed
12/05/2012 14:08:02PM - Checking condition 45766827-6E1C-43A5-AE55-3EDC12383C2C - Platform Condition
12/05/2012 14:08:02PM - Executing action 25BA989D-274D-4302-A91E-48B8454834E4 - Unpack Manifest xml file
12/05/2012 14:08:02PM - Unpacking /tmp/ijtmp_6CECF410-B6FA-AD39-7653-D5312F771648/ccs_manifest.xml
12/05/2012 14:08:02PM - Checking conditions for 1C65743D-E0A5-4787-B152-3A21723C2002 - Unpack Manifest xml file - Before Action is Executed
12/05/2012 14:08:02PM - Checking condition 9B003E01-3775-4A7C-ABAD-252F786C62F6 - Platform Condition
12/05/2012 14:08:02PM - Skipping action 1C65743D-E0A5-4787-B152-3A21723C2002 - Unpack Manifest xml file - conditions failed
12/05/2012 14:08:02PM - Executing action 2237DB6B-9676-4FDA-8BBB-9CD0741C175B - Set Manifest file name
12/05/2012 14:08:02PM - InstallIni file = /tmp/ijtmp_6CECF410-B6FA-AD39-7653-D5312F771648/ccs_manifest.xml /tmp/ijtmp_6CECF410-B6FA-AD39-7653-D5312F771648/ccs_manifest.xml
12/05/2012 14:08:02PM - Executing action 7A1CB0AB-04A3-41C0-8655-22F6AE6A972A - Full CCS or Component install test
12/05/2012 14:08:02PM - ccs_setup_5.1.*
12/05/2012 14:08:02PM - full installer
12/05/2012 14:08:02PM - Executing action D6E650CF-E79A-4C23-86E7-FE0AF5BB288C - Set USERPROFILE variable
12/05/2012 14:08:02PM - userprofile =
12/05/2012 14:08:02PM - Checking conditions for 2B4621D5-82FE-4B4D-99D9-19C075DAF02A - Set Eclipse Executable (Updates) - Before Action is Executed
12/05/2012 14:08:02PM - Checking condition 012691BA-6C89-4F03-BB4E-D8D88D1BCD26 - String Is Condition
12/05/2012 14:08:02PM - Checking to see if <%UpdateMode%> is true
12/05/2012 14:08:02PM - ** Checking to see if 0 is true
12/05/2012 14:08:02PM - Skipping action 2B4621D5-82FE-4B4D-99D9-19C075DAF02A - Set Eclipse Executable (Updates) - conditions failed
12/05/2012 14:08:02PM - Executing action 1D831DC1-741D-46B1-8E64-8029150A623F - Unpack LWInstaller Repository
12/05/2012 14:08:02PM - Unpacking /tmp/ijtmp_6CECF410-B6FA-AD39-7653-D5312F771648/lwrepo.zip
12/05/2012 14:08:02PM - Executing action 29030E51-6D6E-412C-AD77-563BB43B754D - Unzip LWInstaller Repository
12/05/2012 14:08:02PM - Executing action 4A2E4135-11DC-4CB3-B5E1-391DE9D2BAAF - Get LWInstaller Version
12/05/2012 14:08:02PM - in getting p2version /tmp/ijtmp_6CECF410-B6FA-AD39-7653-D5312F771648/lwrepo/features/com.ti.ccstudio.p2_5.0.1.201201231629.jar
12/05/2012 14:08:02PM - Executing action C6771919-CB79-4C4F-A842-7560C1B039E5 - Get URL Name
12/05/2012 14:08:02PM - P2version = 201201231629
12/05/2012 14:08:02PM - Reading manifest file /tmp/ijtmp_6CECF410-B6FA-AD39-7653-D5312F771648/ccs_manifest.xml
12/05/2012 14:08:02PM - tsvar = domNode0x8b410c8
12/05/2012 14:08:02PM - urlname = |Code Composer Studio v5 Updates|
12/05/2012 14:08:02PM - repotype = multiple
12/05/2012 14:08:02PM - ts = 20120216194848
12/05/2012 14:08:02PM - Checking conditions for D5573F6A-EEF9-4B37-BA6A-FABFC62A6373 - Get Update URL - Before Action is Executed
12/05/2012 14:08:02PM - Checking condition C823EF2C-262B-45F9-B535-4CAD5B69E8FD - String Is Condition
12/05/2012 14:08:02PM - Skipping action D5573F6A-EEF9-4B37-BA6A-FABFC62A6373 - Get Update URL - conditions failed
12/05/2012 14:08:02PM - Executing action C3322C75-C36B-4CAA-99B6-D10C70E75CED - Look for Local Respository
12/05/2012 14:08:02PM - updaterepo =
12/05/2012 14:08:02PM - localbaserepo = /home/dell/Desktop/Shared/CCS-5.1.1.00033-Sitara-ARM/CCS/baserepo
12/05/2012 14:08:02PM - localrepo = /home/dell/Desktop/Shared/CCS-5.1.1.00033-Sitara-ARM/CCS/featurerepo
12/05/2012 14:08:02PM - Executing action 0606F3A6-B4B3-430D-BF58-90FD8DC7E9D0 - Read Manifest file
12/05/2012 14:08:02PM - Executing action 064CDB88-8721-4CDA-B246-37D052A32298 - Debug information
12/05/2012 14:08:02PM - Manifest file: /tmp/ijtmp_6CECF410-B6FA-AD39-7653-D5312F771648/ccs_manifest.xml
12/05/2012 14:08:02PM - Setup file : <%InstallSource%>/ccs_installini.xml
12/05/2012 14:08:02PM - ** Setup file : /home/dell/Desktop/Shared/CCS-5.1.1.00033-Sitara-ARM/CCS/ccs_installini.xml
12/05/2012 14:08:02PM - Installer: ccs_setup_5.1.1.00033.bin
12/05/2012 14:08:02PM - ccs_setup_5.1.1.00033.bin
12/05/2012 14:08:02PM - /home/dell
12/05/2012 14:08:02PM - Checking conditions for 8F539122-507F-4B01-8ABD-1443E5E641D6 - Execute Get Edition Details - Before Action is Executed
12/05/2012 14:08:02PM - Checking condition ECCFACBA-E04C-48D6-9BD9-2BA9B3C509E1 - String Is Condition
12/05/2012 14:08:02PM - Checking to see if <%ShowSetupPane%> is false
12/05/2012 14:08:02PM - ** Checking to see if false is false
12/05/2012 14:08:02PM - Executing action 8F539122-507F-4B01-8ABD-1443E5E641D6 - Execute Get Edition Details
12/05/2012 14:08:02PM - Executing actions 214CDC31-6FF9-4C65-B874-265447EB94E3 - Get Edition Details
12/05/2012 14:08:02PM - Executing action 64877C38-51BE-4D33-8849-6C8852694A01 - Parse XML Input
12/05/2012 14:08:02PM - 3
12/05/2012 14:08:02PM - JRE_VERSION_REQUIRED = 1.6
12/05/2012 14:08:02PM - Custom component settings:
12/05/2012 14:08:02PM - child node
12/05/2012 14:08:02PM - C28x 32-bit Real-time MCUs: EMU_TI:mandatory
12/05/2012 14:08:02PM - C28x 32-bit Real-time MCUs: EMU_BH:optional
12/05/2012 14:08:02PM - C28x 32-bit Real-time MCUs: EMU_SD:optional
12/05/2012 14:08:02PM - C28x 32-bit Real-time MCUs: EMU_C2000_FLASH:mandatory
12/05/2012 14:08:02PM - C28x 32-bit Real-time MCUs: EMU_C2000:mandatory
12/05/2012 14:08:02PM - C28x 32-bit Real-time MCUs: EMU_NOWFLASH:mandatory
12/05/2012 14:08:02PM - C28x 32-bit Real-time MCUs: CGT_DEFAULTLIBS_C2800:optional
12/05/2012 14:08:02PM - C28x 32-bit Real-time MCUs: DMED:optional
12/05/2012 14:08:02PM - C28x 32-bit Real-time MCUs: TC_BIOS5:optional
12/05/2012 14:08:02PM - C28x 32-bit Real-time MCUs: TC_XDAIS_BIOS5:optional
12/05/2012 14:08:02PM - C28x 32-bit Real-time MCUs: TC_XDCTOOLS_BIOS5:optional
12/05/2012 14:08:02PM - C28x 32-bit Real-time MCUs: TC_BIOS6:optional
12/05/2012 14:08:02PM - C28x 32-bit Real-time MCUs: UIA:optional
12/05/2012 14:08:02PM - C28x 32-bit Real-time MCUs: TC_C2000_BIOS6:optional
12/05/2012 14:08:02PM - C28x 32-bit Real-time MCUs: TC_XDAIS:optional
12/05/2012 14:08:02PM - C28x 32-bit Real-time MCUs: TC_XDCTOOLS:optional
12/05/2012 14:08:02PM - C28x 32-bit Real-time MCUs: TC_C2000_XDCTOOLS:optional
12/05/2012 14:08:02PM - C28x 32-bit Real-time MCUs: TC_IPC:optional
12/05/2012 14:08:02PM - C28x 32-bit Real-time MCUs: TC_C2000_IPC:optional
12/05/2012 14:08:02PM - C28x 32-bit Real-time MCUs: IDE:mandatory
12/05/2012 14:08:02PM - C28x 32-bit Real-time MCUs: CCSINIT:mandatory
12/05/2012 14:08:02PM - C28x 32-bit Real-time MCUs: DS:mandatory
12/05/2012 14:08:02PM - C28x 32-bit Real-time MCUs: DVT:mandatory
12/05/2012 14:08:02PM - C28x 32-bit Real-time MCUs: SIM_TI:optional
12/05/2012 14:08:02PM - C28x 32-bit Real-time MCUs: ARM_RSE:mandatory
12/05/2012 14:08:02PM - C28x 32-bit Real-time MCUs: ARM_QT:mandatory
12/05/2012 14:08:02PM - Cortex-R4F MCUs: EMU_BH:optional
12/05/2012 14:08:02PM - Cortex-R4F MCUs: EMU_SD:optional
12/05/2012 14:08:02PM - Cortex-R4F MCUs: CGT_DEFAULTLIBS_TMS470:optional
12/05/2012 14:08:02PM - Cortex-R4F MCUs: DMED:optional
12/05/2012 14:08:02PM - Cortex-R4F MCUs: TC_BIOS6:optional
12/05/2012 14:08:02PM - Cortex-R4F MCUs: UIA:optional
12/05/2012 14:08:02PM - Cortex-R4F MCUs: TC_XDAIS:optional
12/05/2012 14:08:02PM - Cortex-R4F MCUs: TC_XDCTOOLS:optional
12/05/2012 14:08:02PM - Cortex-R4F MCUs: TC_IPC:optional
12/05/2012 14:08:02PM - Cortex-R4F MCUs: TC_ARM_BIOS6:optional
12/05/2012 14:08:02PM - Cortex-R4F MCUs: TC_ARM_XDCTOOLS:optional
12/05/2012 14:08:02PM - Cortex-R4F MCUs: TC_ARM_IPC:optional
12/05/2012 14:08:02PM - Cortex-R4F MCUs: EMU_TI:mandatory
12/05/2012 14:08:02PM - Cortex-R4F MCUs: EMU_NOWFLASH:mandatory
12/05/2012 14:08:02PM - Cortex-R4F MCUs: IDE:mandatory
12/05/2012 14:08:02PM - Cortex-R4F MCUs: CCSINIT:mandatory
12/05/2012 14:08:02PM - Cortex-R4F MCUs: DS:mandatory
12/05/2012 14:08:02PM - Cortex-R4F MCUs: DVT:mandatory
12/05/2012 14:08:02PM - Cortex-R4F MCUs: SIM_TI:optional
12/05/2012 14:08:02PM - Cortex-R4F MCUs: ARM_RSE:mandatory
12/05/2012 14:08:02PM - Cortex-R4F MCUs: ARM_QT:mandatory
12/05/2012 14:08:02PM - AMxx Cortex-A and ARM9 processors: EMU_BH:optional
12/05/2012 14:08:02PM - AMxx Cortex-A and ARM9 processors: EMU_SD:optional
12/05/2012 14:08:02PM - AMxx Cortex-A and ARM9 processors: CGT_DEFAULTLIBS_TMS470:optional
12/05/2012 14:08:02PM - AMxx Cortex-A and ARM9 processors: DMED:optional
12/05/2012 14:08:02PM - AMxx Cortex-A and ARM9 processors: TC_BIOS5:optional
12/05/2012 14:08:02PM - AMxx Cortex-A and ARM9 processors: TC_XDAIS_BIOS5:optional
12/05/2012 14:08:02PM - AMxx Cortex-A and ARM9 processors: TC_XDCTOOLS_BIOS5:optional
12/05/2012 14:08:02PM - AMxx Cortex-A and ARM9 processors: TC_BIOS6:optional
12/05/2012 14:08:02PM - AMxx Cortex-A and ARM9 processors: UIA:optional
12/05/2012 14:08:02PM - AMxx Cortex-A and ARM9 processors: TC_XDAIS:optional
12/05/2012 14:08:02PM - AMxx Cortex-A and ARM9 processors: TC_XDCTOOLS:optional
12/05/2012 14:08:02PM - AMxx Cortex-A and ARM9 processors: TC_IPC:optional
12/05/2012 14:08:02PM - AMxx Cortex-A and ARM9 processors: TC_ARM_BIOS6:optional
12/05/2012 14:08:02PM - AMxx Cortex-A and ARM9 processors: TC_ARM_XDCTOOLS:optional
12/05/2012 14:08:02PM - AMxx Cortex-A and ARM9 processors: TC_ARM_IPC:optional
12/05/2012 14:08:02PM - AMxx Cortex-A and ARM9 processors: EMU_TI:mandatory
12/05/2012 14:08:02PM - AMxx Cortex-A and ARM9 processors: IDE:mandatory
12/05/2012 14:08:02PM - AMxx Cortex-A and ARM9 processors: CCSINIT:mandatory
12/05/2012 14:08:02PM - AMxx Cortex-A and ARM9 processors: DS:mandatory
12/05/2012 14:08:02PM - AMxx Cortex-A and ARM9 processors: DVT:mandatory
12/05/2012 14:08:02PM - AMxx Cortex-A and ARM9 processors: SIM_TI:optional
12/05/2012 14:08:02PM - AMxx Cortex-A and ARM9 processors: ARM_RSE:mandatory
12/05/2012 14:08:02PM - AMxx Cortex-A and ARM9 processors: ARM_QT:mandatory
12/05/2012 14:08:02PM - C6x DSP + ARM processors: EMU_BH:optional
12/05/2012 14:08:02PM - C6x DSP + ARM processors: EMU_SD:optional
12/05/2012 14:08:02PM - C6x DSP + ARM processors: CGT_DEFAULTLIBS_TMS470:optional
12/05/2012 14:08:02PM - C6x DSP + ARM processors: CGT_DEFAULTLIBS_C6000:optional
12/05/2012 14:08:02PM - C6x DSP + ARM processors: DMED:optional
12/05/2012 14:08:02PM - C6x DSP + ARM processors: TC_BIOS5:optional
12/05/2012 14:08:02PM - C6x DSP + ARM processors: TC_XDAIS_BIOS5:optional
12/05/2012 14:08:02PM - C6x DSP + ARM processors: TC_XDCTOOLS_BIOS5:optional
12/05/2012 14:08:02PM - C6x DSP + ARM processors: TC_BIOS6:optional
12/05/2012 14:08:02PM - C6x DSP + ARM processors: UIA:optional
12/05/2012 14:08:02PM - C6x DSP + ARM processors: TC_XDAIS:optional
12/05/2012 14:08:02PM - C6x DSP + ARM processors: TC_XDCTOOLS:optional
12/05/2012 14:08:02PM - C6x DSP + ARM processors: TC_IPC:optional
12/05/2012 14:08:02PM - C6x DSP + ARM processors: TC_ARM_BIOS6:optional
12/05/2012 14:08:02PM - C6x DSP + ARM processors: TC_ARM_XDCTOOLS:optional
12/05/2012 14:08:02PM - C6x DSP + ARM processors: TC_ARM_IPC:optional
12/05/2012 14:08:02PM - C6x DSP + ARM processors: TC_C6000_BIOS6:optional
12/05/2012 14:08:02PM - C6x DSP + ARM processors: TC_C6000_XDCTOOLS:optional
12/05/2012 14:08:02PM - C6x DSP + ARM processors: TC_C6000_IPC:optional
12/05/2012 14:08:02PM - C6x DSP + ARM processors: C6FLO:optional
12/05/2012 14:08:02PM - C6x DSP + ARM processors: EMU_TI:mandatory
12/05/2012 14:08:02PM - C6x DSP + ARM processors: IDE:mandatory
12/05/2012 14:08:02PM - C6x DSP + ARM processors: CCSINIT:mandatory
12/05/2012 14:08:02PM - C6x DSP + ARM processors: DS:mandatory
12/05/2012 14:08:02PM - C6x DSP + ARM processors: DVT:mandatory
12/05/2012 14:08:02PM - C6x DSP + ARM processors: SIM_TI:optional
12/05/2012 14:08:02PM - C6x DSP + ARM processors: ARM_RSE:mandatory
12/05/2012 14:08:02PM - C6x DSP + ARM processors: ARM_QT:mandatory
12/05/2012 14:08:02PM - DaVinci Video Processors: EMU_BH:optional
12/05/2012 14:08:02PM - DaVinci Video Processors: EMU_SD:optional
12/05/2012 14:08:02PM - DaVinci Video Processors: CGT_DEFAULTLIBS_TMS470:optional
12/05/2012 14:08:02PM - DaVinci Video Processors: CGT_DEFAULTLIBS_C6000:optional
12/05/2012 14:08:02PM - DaVinci Video Processors: DMED:optional
12/05/2012 14:08:02PM - DaVinci Video Processors: TC_BIOS5:optional
12/05/2012 14:08:02PM - DaVinci Video Processors: TC_XDAIS_BIOS5:optional
12/05/2012 14:08:02PM - DaVinci Video Processors: TC_XDCTOOLS_BIOS5:optional
12/05/2012 14:08:02PM - DaVinci Video Processors: TC_BIOS6:optional
12/05/2012 14:08:02PM - DaVinci Video Processors: UIA:optional
12/05/2012 14:08:02PM - DaVinci Video Processors: TC_XDAIS:optional
12/05/2012 14:08:02PM - DaVinci Video Processors: TC_XDCTOOLS:optional
12/05/2012 14:08:02PM - DaVinci Video Processors: TC_IPC:optional
12/05/2012 14:08:02PM - DaVinci Video Processors: TC_ARM_BIOS6:optional
12/05/2012 14:08:02PM - DaVinci Video Processors: TC_ARM_XDCTOOLS:optional
12/05/2012 14:08:02PM - DaVinci Video Processors: TC_ARM_IPC:optional
12/05/2012 14:08:02PM - DaVinci Video Processors: TC_C6000_BIOS6:optional
12/05/2012 14:08:02PM - DaVinci Video Processors: TC_C6000_XDCTOOLS:optional
12/05/2012 14:08:02PM - DaVinci Video Processors: TC_C6000_IPC:optional
12/05/2012 14:08:02PM - DaVinci Video Processors: C6FLO:optional
12/05/2012 14:08:02PM - DaVinci Video Processors: EMU_TI:mandatory
12/05/2012 14:08:02PM - DaVinci Video Processors: IDE:mandatory
12/05/2012 14:08:02PM - DaVinci Video Processors: CCSINIT:mandatory
12/05/2012 14:08:02PM - DaVinci Video Processors: DS:mandatory
12/05/2012 14:08:02PM - DaVinci Video Processors: DVT:mandatory
12/05/2012 14:08:02PM - DaVinci Video Processors: SIM_TI:optional
12/05/2012 14:08:02PM - DaVinci Video Processors: ARM_RSE:mandatory
12/05/2012 14:08:02PM - DaVinci Video Processors: ARM_QT:mandatory
12/05/2012 14:08:02PM - C6000 Single Core DSPs: EMU_BH:optional
12/05/2012 14:08:02PM - C6000 Single Core DSPs: EMU_SD:optional
12/05/2012 14:08:02PM - C6000 Single Core DSPs: CGT_DEFAULTLIBS_C6000:optional
12/05/2012 14:08:02PM - C6000 Single Core DSPs: DMED:optional
12/05/2012 14:08:02PM - C6000 Single Core DSPs: TC_BIOS5:optional
12/05/2012 14:08:02PM - C6000 Single Core DSPs: TC_XDAIS_BIOS5:optional
12/05/2012 14:08:02PM - C6000 Single Core DSPs: TC_XDCTOOLS_BIOS5:optional
12/05/2012 14:08:02PM - C6000 Single Core DSPs: TC_BIOS6:optional
12/05/2012 14:08:02PM - C6000 Single Core DSPs: UIA:optional
12/05/2012 14:08:02PM - C6000 Single Core DSPs: TC_XDAIS:optional
12/05/2012 14:08:02PM - C6000 Single Core DSPs: TC_XDCTOOLS:optional
12/05/2012 14:08:02PM - C6000 Single Core DSPs: TC_IPC:optional
12/05/2012 14:08:02PM - C6000 Single Core DSPs: TC_C6000_BIOS6:optional
12/05/2012 14:08:02PM - C6000 Single Core DSPs: TC_C6000_XDCTOOLS:optional
12/05/2012 14:08:02PM - C6000 Single Core DSPs: TC_C6000_IPC:optional
12/05/2012 14:08:02PM - C6000 Single Core DSPs: C6FLO:optional
12/05/2012 14:08:02PM - C6000 Single Core DSPs: EMU_TI:mandatory
12/05/2012 14:08:02PM - C6000 Single Core DSPs: IDE:mandatory
12/05/2012 14:08:02PM - C6000 Single Core DSPs: CCSINIT:mandatory
12/05/2012 14:08:02PM - C6000 Single Core DSPs: DS:mandatory
12/05/2012 14:08:02PM - C6000 Single Core DSPs: DVT:mandatory
12/05/2012 14:08:02PM - C6000 Single Core DSPs: SIM_TI:optional
12/05/2012 14:08:02PM - C6000 Single Core DSPs: ARM_RSE:mandatory
12/05/2012 14:08:02PM - C6000 Single Core DSPs: ARM_QT:mandatory
12/05/2012 14:08:02PM - C6000 Multi Core DSPs: EMU_BH:optional
12/05/2012 14:08:02PM - C6000 Multi Core DSPs: EMU_SD:optional
12/05/2012 14:08:02PM - C6000 Multi Core DSPs: CGT_DEFAULTLIBS_C6000:optional
12/05/2012 14:08:02PM - C6000 Multi Core DSPs: DMED:optional
12/05/2012 14:08:02PM - C6000 Multi Core DSPs: TC_BIOS5:optional
12/05/2012 14:08:02PM - C6000 Multi Core DSPs: TC_XDAIS_BIOS5:optional
12/05/2012 14:08:02PM - C6000 Multi Core DSPs: TC_XDCTOOLS_BIOS5:optional
12/05/2012 14:08:02PM - C6000 Multi Core DSPs: TC_BIOS6:optional
12/05/2012 14:08:02PM - C6000 Multi Core DSPs: UIA:optional
12/05/2012 14:08:02PM - C6000 Multi Core DSPs: TC_XDAIS:optional
12/05/2012 14:08:02PM - C6000 Multi Core DSPs: TC_XDCTOOLS:optional
12/05/2012 14:08:02PM - C6000 Multi Core DSPs: TC_IPC:optional
12/05/2012 14:08:02PM - C6000 Multi Core DSPs: TC_C6000_BIOS6:optional
12/05/2012 14:08:02PM - C6000 Multi Core DSPs: TC_C6000_XDCTOOLS:optional
12/05/2012 14:08:02PM - C6000 Multi Core DSPs: TC_C6000_IPC:optional
12/05/2012 14:08:02PM - C6000 Multi Core DSPs: EMU_TI:mandatory
12/05/2012 14:08:02PM - C6000 Multi Core DSPs: KEYSTONE1:mandatory
12/05/2012 14:08:02PM - C6000 Multi Core DSPs: IDE:mandatory
12/05/2012 14:08:02PM - C6000 Multi Core DSPs: CCSINIT:mandatory
12/05/2012 14:08:02PM - C6000 Multi Core DSPs: DS:mandatory
12/05/2012 14:08:02PM - C6000 Multi Core DSPs: DVT:mandatory
12/05/2012 14:08:02PM - C6000 Multi Core DSPs: SIM_TI:optional
12/05/2012 14:08:02PM - C6000 Multi Core DSPs: ARM_RSE:mandatory
12/05/2012 14:08:02PM - C6000 Multi Core DSPs: ARM_QT:mandatory
12/05/2012 14:08:02PM - OMAP: EMU_BH:optional
12/05/2012 14:08:02PM - OMAP: EMU_SD:optional
12/05/2012 14:08:02PM - OMAP: CGT_DEFAULTLIBS_C6000:optional
12/05/2012 14:08:02PM - OMAP: CGT_DEFAULTLIBS_TMS470:optional
12/05/2012 14:08:02PM - OMAP: CGT_DEFAULTLIBS_C5500:optional
12/05/2012 14:08:02PM - OMAP: CGT_DEFAULTLIBS_C5400:optional
12/05/2012 14:08:02PM - OMAP: DMED:optional
12/05/2012 14:08:02PM - OMAP: TC_BIOS5:optional
12/05/2012 14:08:02PM - OMAP: TC_XDAIS_BIOS5:optional
12/05/2012 14:08:02PM - OMAP: TC_XDCTOOLS_BIOS5:optional
12/05/2012 14:08:02PM - OMAP: TC_BIOS6:optional
12/05/2012 14:08:02PM - OMAP: UIA:optional
12/05/2012 14:08:02PM - OMAP: TC_XDAIS:optional
12/05/2012 14:08:02PM - OMAP: TC_XDCTOOLS:optional
12/05/2012 14:08:02PM - OMAP: TC_IPC:optional
12/05/2012 14:08:02PM - OMAP: TC_C6000_BIOS6:optional
12/05/2012 14:08:02PM - OMAP: TC_C6000_XDCTOOLS:optional
12/05/2012 14:08:02PM - OMAP: TC_C6000_IPC:optional
12/05/2012 14:08:02PM - OMAP: C6FLO:optional
12/05/2012 14:08:02PM - OMAP: EMU_TI:mandatory
12/05/2012 14:08:02PM - OMAP: IDE:mandatory
12/05/2012 14:08:02PM - OMAP: CCSINIT:mandatory
12/05/2012 14:08:02PM - OMAP: DS:mandatory
12/05/2012 14:08:02PM - OMAP: DVT:mandatory
12/05/2012 14:08:02PM - OMAP: SIM_TI:optional
12/05/2012 14:08:02PM - OMAP: ARM_RSE:mandatory
12/05/2012 14:08:02PM - OMAP: ARM_QT:mandatory
12/05/2012 14:08:02PM - C5000 Ultra Low Power DSP: EMU_BH:optional
12/05/2012 14:08:02PM - C5000 Ultra Low Power DSP: EMU_SD:optional
12/05/2012 14:08:02PM - C5000 Ultra Low Power DSP: CGT_DEFAULTLIBS_C5500:optional
12/05/2012 14:08:02PM - C5000 Ultra Low Power DSP: CGT_DEFAULTLIBS_C5400:optional
12/05/2012 14:08:02PM - C5000 Ultra Low Power DSP: DMED:optional
12/05/2012 14:08:02PM - C5000 Ultra Low Power DSP: TC_BIOS5:optional
12/05/2012 14:08:02PM - C5000 Ultra Low Power DSP: TC_XDAIS_BIOS5:optional
12/05/2012 14:08:02PM - C5000 Ultra Low Power DSP: TC_XDCTOOLS_BIOS5:optional
12/05/2012 14:08:02PM - C5000 Ultra Low Power DSP: EMU_TI:mandatory
12/05/2012 14:08:02PM - C5000 Ultra Low Power DSP: IDE:mandatory
12/05/2012 14:08:02PM - C5000 Ultra Low Power DSP: CCSINIT:mandatory
12/05/2012 14:08:02PM - C5000 Ultra Low Power DSP: DS:mandatory
12/05/2012 14:08:02PM - C5000 Ultra Low Power DSP: DVT:mandatory
12/05/2012 14:08:02PM - C5000 Ultra Low Power DSP: SIM_TI:optional
12/05/2012 14:08:02PM - C5000 Ultra Low Power DSP: ARM_RSE:mandatory
12/05/2012 14:08:02PM - C5000 Ultra Low Power DSP: ARM_QT:mandatory
12/05/2012 14:08:02PM - Checking conditions for A0354A16-79FB-457B-9363-CED6124ADDCA - Execute Setup Panes to Display - Before Action is Executed
12/05/2012 14:08:02PM - Checking condition C483848C-C11F-41BC-AB86-7D4A0C24A5BA - String Is Condition
12/05/2012 14:08:02PM - Executing action A0354A16-79FB-457B-9363-CED6124ADDCA - Execute Setup Panes to Display
12/05/2012 14:08:02PM - Executing actions 3835C529-654B-4A82-B84B-B3A7CBEA79AB - Set Panes to Display
12/05/2012 14:08:02PM - Checking conditions for 3835C529-654B-4A82-B84B-B3A7CBEA79AB - - Before Action is Executed
12/05/2012 14:08:02PM - Checking condition 15BC7606-F1AD-4573-8AA7-21FFCA15D5DB - String Is Condition
12/05/2012 14:08:02PM - Checking to see if <%UpdateMode%> is false
12/05/2012 14:08:02PM - ** Checking to see if 0 is false
12/05/2012 14:08:02PM - Executing action 3835C529-654B-4A82-B84B-B3A7CBEA79AB - Set Panes to Display
12/05/2012 14:08:02PM - In Add Components:
12/05/2012 14:08:02PM - installed features =
12/05/2012 14:08:02PM - products installed:
12/05/2012 14:08:02PM - edition pane now: ISA,FEATURE,EMU
12/05/2012 14:08:02PM - Edition: Custom ISA,FEATURE,EMU
12/05/2012 14:08:02PM - ISAs: true
12/05/2012 14:08:02PM - Features: true
12/05/2012 14:08:02PM - Emus: true
12/05/2012 14:08:02PM - Executing action 17AAAD6D-433F-4CC7-A9E2-5EB0008F5832 - Set ARM MPU BU flag
12/05/2012 14:08:02PM - Checking conditions for 356EAA68-888B-4347-A851-EE731133C133 - Set ARM ISA on (for ARM MPU) - Before Action is Executed
12/05/2012 14:08:02PM - Checking condition A0D7DD06-8F87-416C-8B34-062A99D6C77A - String Is Condition
12/05/2012 14:08:02PM - Checking to see if <%arm_mpu%> is true
12/05/2012 14:08:02PM - ** Checking to see if 1 is true
12/05/2012 14:08:02PM - Executing action 356EAA68-888B-4347-A851-EE731133C133 - Set ARM ISA on (for ARM MPU)
12/05/2012 14:08:02PM - Checking conditions for EECE82E1-6B6F-468C-A6BA-5AB21E7F19E8 - Non-admin Message (linux) - Before Action is Executed
12/05/2012 14:08:02PM - Checking condition 2660F337-EF5C-4F78-92FA-E0B8EE28FC23 - Platform Condition
12/05/2012 14:08:02PM - Checking condition 32FF9593-A187-43AA-AE0B-DF4D85580818 - String Is Condition
12/05/2012 14:08:02PM - Checking to see if <%UserIsRoot%> is false
12/05/2012 14:08:02PM - ** Checking to see if 1 is false
12/05/2012 14:08:02PM - Skipping action EECE82E1-6B6F-468C-A6BA-5AB21E7F19E8 - Non-admin Message (linux) - conditions failed
12/05/2012 14:08:02PM - Checking conditions for 1EEDE33F-FA96-434E-A408-3A858B0CFE41 - Non-admin Message (linux) - Before Action is Executed
12/05/2012 14:08:02PM - Checking condition B2E179AA-7558-48D7-8D00-0E27D34F3026 - Platform Condition
12/05/2012 14:08:02PM - Checking condition CA6072F3-4631-4E1C-892E-B94B2E68D311 - String Is Condition
12/05/2012 14:08:02PM - Skipping action 1EEDE33F-FA96-434E-A408-3A858B0CFE41 - Non-admin Message (linux) - conditions failed
12/05/2012 14:08:02PM - Checking conditions for AABD8C8E-3C88-4987-B89C-D6747C9394D5 - Exit - Before Action is Executed
12/05/2012 14:08:02PM - Checking condition 474FB0CF-0071-4661-AC05-9DBF4E4BFED2 - Platform Condition
12/05/2012 14:08:02PM - Checking condition 480168B7-AA8C-4FB3-99EB-FCEBF6DF5B99 - String Equal Condition
12/05/2012 14:08:02PM - Checking to see if <%Answer%> equals No
12/05/2012 14:08:02PM - Skipping action AABD8C8E-3C88-4987-B89C-D6747C9394D5 - Exit - conditions failed
12/05/2012 14:08:02PM - Executing action 161F5BA9-3D23-4365-A8B8-ADFFE05E9A98 - Create Install Panes
12/05/2012 14:08:02PM - description = Select this option if you wish to customize the individual features that are installed.
12/05/2012 14:08:02PM - activating Custom
12/05/2012 14:08:02PM - Executing action 0FFC0C08-DA3A-4881-B6C3-FE17EA4D4F5B - Update Setup
12/05/2012 14:08:02PM - Checking conditions for 4BDB2FB9-99BA-45DA-86F0-6FBD39315F3A - Update Setup Action - Before Action is Executed
12/05/2012 14:08:02PM - Checking condition 0FF0BFFC-81E4-4720-9FE1-AA20B71FCE24 - String Is Condition
12/05/2012 14:08:02PM - Skipping action group 0FFC0C08-DA3A-4881-B6C3-FE17EA4D4F5B - Update Setup - conditions failed
12/05/2012 14:08:02PM - Checking conditions for A11790D2-A8D6-4BF2-B0AC-FD735A88B2B6 - License Agreement - Before Pane is Displayed
12/05/2012 14:08:02PM - Checking condition 5AD62789-2677-4DA5-84E1-739D4AAFA825 - Command Line Test Condition
12/05/2012 14:08:02PM - Checking to see if test was not passed on the command line
12/05/2012 14:08:02PM - Executing actions A11790D2-A8D6-4BF2-B0AC-FD735A88B2B6 - License Agreement - Before Pane is Displayed
12/05/2012 14:08:02PM - Checking conditions for 8D4321BA-CBFE-487B-978A-6F8856E82BDF - Disable Next Button - Before Action is Executed
12/05/2012 14:08:02PM - Checking condition B9385049-E34B-4149-BEEA-19848C59FB8F - String Is Condition
12/05/2012 14:08:02PM - Checking to see if <%Property <%CurrentPane%> UserMustAcceptLicense%> is true
12/05/2012 14:08:02PM - ** Checking to see if Yes is true
12/05/2012 14:08:02PM - Checking condition 695C91E5-69F9-4B0B-8F89-C78D8E2C348F - String Is Condition
12/05/2012 14:08:02PM - Checking to see if <%LicenseAccepted%> is false
12/05/2012 14:08:02PM - ** Checking to see if No is false
12/05/2012 14:08:02PM - Executing action 8D4321BA-CBFE-487B-978A-6F8856E82BDF - Disable Next Button
12/05/2012 14:08:02PM - Displaying pane A11790D2-A8D6-4BF2-B0AC-FD735A88B2B6 - License Agreement
12/05/2012 14:08:03PM - Executing actions A11790D2-A8D6-4BF2-B0AC-FD735A88B2B6 - License Agreement - After Pane is Displayed
12/05/2012 14:08:03PM - Executing action DECD8C88-32C8-495F-B29B-39B0AB07DC86 - Add Print Button
12/05/2012 14:08:08PM - Executing actions A11790D2-A8D6-4BF2-B0AC-FD735A88B2B6 - License Agreement - Before Next Pane is Displayed
12/05/2012 14:08:08PM - Executing actions F47FFD38-C9F1-4896-B0C5-A870FBD8CDE7 - Select Destination - Before Pane is Displayed
12/05/2012 14:08:08PM - Executing action 572E4601-A7D6-49BD-A9FB-30C5DA9AAB1E - Add checkbox for Eclipse location
12/05/2012 14:08:08PM - Checking conditions for 7615A7D4-FB57-4CD7-9D01-345765DF42DE - Execute Look for EclipseDir - Before Action is Executed
12/05/2012 14:08:08PM - Checking condition A94F968A-97A1-4C75-BC27-CB9BA3F14E66 - String Is Condition
12/05/2012 14:08:08PM - Checking to see if <%EclipseDir%> is not empty
12/05/2012 14:08:08PM - ** Checking to see if is not empty
12/05/2012 14:08:08PM - Condition failed
12/05/2012 14:08:08PM - Skipping action 7615A7D4-FB57-4CD7-9D01-345765DF42DE - Execute Look for EclipseDir - conditions failed
12/05/2012 14:08:08PM - Displaying pane F47FFD38-C9F1-4896-B0C5-A870FBD8CDE7 - Select Destination
12/05/2012 14:08:08PM - Executing actions F47FFD38-C9F1-4896-B0C5-A870FBD8CDE7 - Select Destination - After Pane is Displayed
12/05/2012 14:08:08PM - Checking conditions for DF3D9494-F760-448B-915E-A23D94B7FE9C - Initialize EclipseDir - Before Action is Executed
12/05/2012 14:08:08PM - Checking condition 541443C2-AE4D-4C32-891F-76BA4174C31A - String Is Condition
12/05/2012 14:08:08PM - Checking to see if <%Native_Eclipse_Selected%> is false
12/05/2012 14:08:08PM - ** Checking to see if 0 is false
12/05/2012 14:08:08PM - Condition passed
12/05/2012 14:08:08PM - Executing action DF3D9494-F760-448B-915E-A23D94B7FE9C - Initialize EclipseDir
12/05/2012 14:08:08PM - Executing action 76B72CC4-6A46-43FF-ACAD-88E10B96E4AA - Initialize Variables
12/05/2012 14:08:08PM - checking installedfbinary
12/05/2012 14:08:08PM - Executing action 7AE21CEE-B823-4A59-988A-CF452F9E8811 - Set ReRun (false)
12/05/2012 14:08:08PM - Executing action DAE3C4E4-3CE4-4A7F-A60B-9F332F4021CE - Set Update_Eclipse (true)
12/05/2012 14:08:08PM - Executing action B9E1016C-6068-4C82-8137-F472851CD25C - DestinationFrame
12/05/2012 14:08:08PM - Executing action B9CB2CE2-E2E9-45F1-B7B3-0FEDD1A31099 - DestinationLabel
12/05/2012 14:08:08PM - Executing action B000C96C-0BDA-43F2-BA4B-E0E15B1700AE - DestinationBrowseButton
12/05/2012 14:08:08PM - Executing action B4E4526D-A3DB-486D-A7BF-39320D74CB7F - Adjust Layout
12/05/2012 14:08:08PM - Checking conditions for D948D911-691E-4BBA-A789-FD437E15C553 - Set EclipseDir Checkbox - Before Action is Executed
12/05/2012 14:08:08PM - Checking condition 723CA04D-2EF9-4B6A-8FDD-97A01E04A617 - String Is Condition
12/05/2012 14:08:08PM - Checking to see if <%Valid_Eclipse_Found%> is true
12/05/2012 14:08:08PM - ** Checking to see if false is true
12/05/2012 14:08:08PM - Skipping action D948D911-691E-4BBA-A789-FD437E15C553 - Set EclipseDir Checkbox - conditions failed
12/05/2012 14:08:08PM - Executing action 1D063DD9-A021-42A2-B1F5-EDF53B08EEB4 - Execute EclipseDir Action
12/05/2012 14:08:08PM - Executing actions B520BD41-3AB6-4D4B-91B3-8C28D0C214D2 - EclipseDir Action
12/05/2012 14:08:08PM - Checking conditions for 7D9E88F0-5467-4E6D-A430-29312184ACD8 - - Before Action is Executed
12/05/2012 14:08:08PM - Checking condition 9A5D877C-FFC1-4225-BD05-980C8F0532FE - String Is Condition
12/05/2012 14:08:08PM - Executing action 7D9E88F0-5467-4E6D-A430-29312184ACD8 - Execute Destroy Eclipse Location Action
12/05/2012 14:08:08PM - Executing actions 251DB6BC-DFA4-45BE-8ECE-D72CBE1E87D4 - Destroy Eclipse Location Action
12/05/2012 14:08:08PM - Checking conditions for F6D36286-ED6F-40D0-AD99-2F8450E51081 - - Before Action is Executed
12/05/2012 14:08:08PM - Checking condition 8BBD9C89-EFBB-457A-B7B8-36C27F8C2D93 - Execute Script Condition
12/05/2012 14:08:08PM - aWidget = CDBAD941-00B7-4B5F-B3C8-74CF9FE03269
12/05/2012 14:08:08PM - Executing action F6D36286-ED6F-40D0-AD99-2F8450E51081 - Delete Browse Button
12/05/2012 14:08:08PM - Checking conditions for AC055342-233D-4DBE-A388-8D459C788420 - - Before Action is Executed
12/05/2012 14:08:08PM - Checking condition 552C5F74-33ED-4D6B-8386-8AEE0F861479 - Execute Script Condition
12/05/2012 14:08:08PM - aWidget = 355B175A-3A7D-43F2-BB48-483CE773678A
12/05/2012 14:08:08PM - Executing action AC055342-233D-4DBE-A388-8D459C788420 - Delete Eclipse Label
12/05/2012 14:08:08PM - Checking conditions for 9061C5E1-8C4A-4BAC-ADB0-7FE93901F568 - - Before Action is Executed
12/05/2012 14:08:08PM - Checking condition 42DFCE80-B1CF-4341-BCA6-0DEE4C97BB0E - Execute Script Condition
12/05/2012 14:08:08PM - aWidget = 8C353761-A7C4-487F-8DED-7B6CEAFCC7F3
12/05/2012 14:08:08PM - Executing action 9061C5E1-8C4A-4BAC-ADB0-7FE93901F568 - Delete Eclipse Frame
12/05/2012 14:08:08PM - Executing action 7D140CC9-056A-46F3-9402-6200A6DD0179 - Enable Next Button 3
12/05/2012 14:08:08PM - Checking conditions for C3BBD85E-CF2E-4D18-830E-706680E62295 - - Before Action is Executed
12/05/2012 14:08:08PM - Checking condition 21D3B6B1-8945-4630-B44A-6E752CCC6393 - String Is Condition
12/05/2012 14:08:08PM - Checking to see if <%Native_Eclipse_Selected%> is true
12/05/2012 14:08:08PM - ** Checking to see if 0 is true
12/05/2012 14:08:08PM - Skipping action C3BBD85E-CF2E-4D18-830E-706680E62295 - Execute Create Eclipse Location Action - conditions failed
12/05/2012 14:08:10PM - Executing actions E674EC00-088C-4BFB-9F40-C6C1B6043B9B - Destination Browse Button Action
12/05/2012 14:08:10PM - Executing action ED6D0EBB-4865-4AFF-A903-7A4D3929D7C9 - Choose Install Location
12/05/2012 14:08:17PM - InstallDir=/home/dell/Desktop/Shared/sitara/ti; InstallDir=/home/dell/Desktop/Shared/sitara/ti
12/05/2012 14:08:50PM - Checking conditions for F47FFD38-C9F1-4896-B0C5-A870FBD8CDE7 - Select Destination - Before Next Pane is Displayed
12/05/2012 14:08:50PM - Checking condition 9988A480-90AF-4403-9780-1C5A957E2445 - File Permission Condition
12/05/2012 14:08:50PM - Checking to see if we can create <%InstallDir%>
12/05/2012 14:08:50PM - ** Checking to see if we can create /home/dell/Desktop/Shared/sitara/ti
12/05/2012 14:08:50PM - Condition passed
12/05/2012 14:08:50PM - Executing actions F47FFD38-C9F1-4896-B0C5-A870FBD8CDE7 - Select Destination - Before Next Pane is Displayed
12/05/2012 14:08:50PM - Executing action 00881923-FC71-43A3-9FC0-801A9E6C35B6 - Execute Look for Previous Installs
12/05/2012 14:08:50PM - Executing actions C72174AD-964D-449B-9E81-13CED09097C5 - Look for Previous Installs
12/05/2012 14:08:50PM - Executing action C72174AD-964D-449B-9E81-13CED09097C5 - Look for Previous Installs
12/05/2012 14:08:50PM - CCSDIR = /home/dell/Desktop/Shared/sitara/ti/ccsv5 false 0
12/05/2012 14:08:50PM - /home/dell/Desktop/Shared/sitara/ti /home/dell/Desktop/Shared/sitara/ti/ccsv5 /home/dell/Desktop/Shared/sitara/ti/ccsv5/eclipse /home/dell/Desktop/Shared/sitara/ti/ccsv5/eclipse/ccs_config.xml
12/05/2012 14:08:50PM - dir content /home/dell/Desktop/Shared/sitara/ti/ccsv5 =
12/05/2012 14:08:50PM - file exists 0
12/05/2012 14:08:50PM - no ccsdir or it's empty
12/05/2012 14:08:50PM - Checking conditions for A59224D3-9CA8-4944-9C35-A0C72BAE5D71 - Previous Install Found - Before Pane is Displayed
12/05/2012 14:08:50PM - Checking condition BEB51ECD-539D-4EB0-9BBD-70325303A603 - String Is Condition
12/05/2012 14:08:50PM - Checking to see if <%ReRun%> is true
12/05/2012 14:08:50PM - ** Checking to see if 0 is true
12/05/2012 14:08:50PM - Condition failed
12/05/2012 14:08:50PM - Skipping pane A59224D3-9CA8-4944-9C35-A0C72BAE5D71 - Previous Install Found - conditions failed
12/05/2012 14:08:50PM - Checking conditions for F6FCB570-82DE-4640-AEF0-5CD6A221E0EB - Custom Setup Type - Before Pane is Displayed
12/05/2012 14:08:50PM - Checking condition 60512861-E5AE-4FDD-8E7C-C982DD1A4B6C - String Is Condition
12/05/2012 14:08:50PM - Checking to see if <%ReRun%> is false
12/05/2012 14:08:50PM - ** Checking to see if 0 is false
12/05/2012 14:08:50PM - Checking condition 49610746-5157-47D5-BD44-A52DADA4E885 - String Is Condition
12/05/2012 14:08:50PM - Checking to see if <%ShowSetupPane%> is true
12/05/2012 14:08:50PM - ** Checking to see if false is true
12/05/2012 14:08:50PM - Skipping pane F6FCB570-82DE-4640-AEF0-5CD6A221E0EB - Custom Setup Type - conditions failed
12/05/2012 14:08:50PM - Checking conditions for E72C84B4-EC31-4A8F-9380-31452E3AB764 - Choose ISAs - Before Pane is Displayed
12/05/2012 14:08:50PM - Checking condition B6C81A68-D44A-4C50-9EFE-31283C4A5DA2 - String Is Condition
12/05/2012 14:08:50PM - Checking to see if <%ShowISAs%> is true
12/05/2012 14:08:50PM - ** Checking to see if true is true
12/05/2012 14:08:50PM - Executing actions E72C84B4-EC31-4A8F-9380-31452E3AB764 - Choose ISAs - Before Pane is Displayed
12/05/2012 14:08:50PM - Executing action 5F503179-A182-4759-8CBD-71D018F72B92 - Disable Next
12/05/2012 14:08:50PM - Executing action FF47D51D-DCFF-4ADD-9EC5-F70146A0EBBF - Add ISAs
12/05/2012 14:08:50PM - products installed:
12/05/2012 14:08:50PM - BIOS 5 TC_BIOS5
12/05/2012 14:08:50PM - Blackhawk Emulators EMU_BH
12/05/2012 14:08:50PM - TI C2800 Compiler Tools CGT_DEFAULTLIBS_C2800
12/05/2012 14:08:50PM - C6000 BIOS6 TC_C6000_BIOS6
12/05/2012 14:08:50PM - BIOS 6 TC_BIOS6
12/05/2012 14:08:50PM - ARM IPC TC_ARM_IPC
12/05/2012 14:08:50PM - JRE JRE
12/05/2012 14:08:50PM - Hercules Emulation EMU_HERCULES
12/05/2012 14:08:50PM - DVT min DVT_MIN
12/05/2012 14:08:50PM - Code Composer Plugins IDE
12/05/2012 14:08:50PM - Adding IDE 15660778: new total 15660778
12/05/2012 14:08:50PM - Compiler Tools On-line Documentation DMED
12/05/2012 14:08:50PM - Keystone1 KEYSTONE1
12/05/2012 14:08:50PM - LightWeightInstaller INSTALL_JAR
12/05/2012 14:08:50PM - TI Emulators EMU_TI
12/05/2012 14:08:50PM - Adding EMU_TI 26887033: new total 42547811
12/05/2012 14:08:50PM - TI Simulators SIM_TI
12/05/2012 14:08:50PM - Spectrum Digital Emulators EMU_SD
12/05/2012 14:08:50PM - CCSINIT CCSINIT
12/05/2012 14:08:50PM - Adding CCSINIT 1077319: new total 43625130
12/05/2012 14:08:50PM - C2000 IPC TC_C2000_IPC
12/05/2012 14:08:50PM - LWInstaller INSTALLER
12/05/2012 14:08:50PM - UIA UIA
12/05/2012 14:08:50PM - XDCTools TC_XDCTOOLS_BIOS5
12/05/2012 14:08:50PM - TI C5400 Compiler Tools CGT_DEFAULTLIBS_C5400
12/05/2012 14:08:50PM - Debug Server DS
12/05/2012 14:08:50PM - Adding DS 32906104: new total 76531234
12/05/2012 14:08:50PM - XDAIS TC_XDAIS_BIOS5
12/05/2012 14:08:50PM - ARM BIOS6 TC_ARM_BIOS6
12/05/2012 14:08:50PM - CCS NowFlash Emulators EMU_NOWFLASH
12/05/2012 14:08:50PM - C2000 Emulation Flash EMU_C2000_FLASH
12/05/2012 14:08:50PM - TI C5500 Compiler Tools CGT_DEFAULTLIBS_C5500
12/05/2012 14:08:50PM - Remote System Explorer End-User Runtime ARM_RSE
12/05/2012 14:08:50PM - Adding ARM_RSE 7084: new total 76538318
12/05/2012 14:08:50PM - IPC TC_IPC
12/05/2012 14:08:50PM - C6000 IPC TC_C6000_IPC
12/05/2012 14:08:50PM - C2000 XDCTools TC_C2000_XDCTOOLS
12/05/2012 14:08:50PM - C6EZFlo C6FLO
12/05/2012 14:08:50PM - TI ARM Compiler Tools CGT_DEFAULTLIBS_TMS470
12/05/2012 14:08:50PM - Eclipse P2 Extensions P2TOOLS
12/05/2012 14:08:50PM - C2000 Emulators EMU_C2000
12/05/2012 14:08:50PM - Qt Integration ARM_QT
12/05/2012 14:08:50PM - Adding ARM_QT 24724293: new total 101262611
12/05/2012 14:08:50PM - TI C6000 Compiler Tools CGT_DEFAULTLIBS_C6000
12/05/2012 14:08:50PM - C2000 BIOS6 TC_C2000_BIOS6
12/05/2012 14:08:50PM - ARM XDCTools TC_ARM_XDCTOOLS
12/05/2012 14:08:50PM - Eclipse ECLIPSE
12/05/2012 14:08:50PM - C6000 XDCTools TC_C6000_XDCTOOLS
12/05/2012 14:08:50PM - DVT DVT
12/05/2012 14:08:50PM - Adding DVT 33755024: new total 135017635
12/05/2012 14:08:50PM - adding jre size
12/05/2012 14:08:50PM - adding eclipse size
12/05/2012 14:08:50PM - 272
12/05/2012 14:08:50PM - ==================== Download size: 272 MB. Install size: 1224.0 MB. s=23
12/05/2012 14:08:50PM - Displaying pane E72C84B4-EC31-4A8F-9380-31452E3AB764 - Choose ISAs
12/05/2012 14:08:50PM - Executing actions E72C84B4-EC31-4A8F-9380-31452E3AB764 - Choose ISAs - After Pane is Displayed
12/05/2012 14:08:51PM - Executing actions E72C84B4-EC31-4A8F-9380-31452E3AB764 - Choose ISAs - Before Next Pane is Displayed
12/05/2012 14:08:51PM - Checking conditions for 0FF2C23D-509B-496F-9DED-C0FE5D001E3A - Custom Choose Components - Before Pane is Displayed
12/05/2012 14:08:51PM - Checking condition 78EC68E8-BDC8-4E8E-998E-339FA70D366A - String Is Condition
12/05/2012 14:08:51PM - Checking to see if <%ShowFEATUREs%> is true
12/05/2012 14:08:51PM - ** Checking to see if true is true
12/05/2012 14:08:51PM - Condition passed
12/05/2012 14:08:51PM - Executing actions 0FF2C23D-509B-496F-9DED-C0FE5D001E3A - Custom Choose Components - Before Pane is Displayed
12/05/2012 14:08:51PM - Executing action 20F6E982-FCA8-4DA7-865F-66836D1A486B - Add Components
12/05/2012 14:08:51PM - In Add Components:
12/05/2012 14:08:51PM - compmessagewidget .wizard.steps.f0FF2C23D-509B-496F-9DED-C0FE5D001E3A.message
12/05/2012 14:08:51PM - installed features =
12/05/2012 14:08:51PM - product component list = {TC_BIOS5:C28x 32-bit Real-time MCUs} 0 C6FLO:OMAP 0 {ARM_RSE:Cortex-R4F MCUs} 2 {EMU_TI:DaVinci Video Processors} 2 TC_XDCTOOLS:OMAP 0 {EMU_SD:DaVinci Video Processors} 0 {SIM_TI:DaVinci Video Processors} 0 {EMU_BH:DaVinci Video Processors} 0 {IDE:C6000 Single Core DSPs} 2 {IDE:AMxx Cortex-A and ARM9 processors} 2 {TC_ARM_XDCTOOLS:DaVinci Video Processors} 0 {TC_XDAIS_BIOS5:C6x DSP + ARM processors} 0 {TC_ARM_BIOS6:C6x DSP + ARM processors} 0 TC_BIOS6:OMAP 0 {C6FLO:C6000 Single Core DSPs} 0 {ARM_RSE:C6000 Multi Core DSPs} 2 {EMU_TI:C6000 Single Core DSPs} 2 {ARM_QT:Cortex-R4F MCUs} 2 {CGT_DEFAULTLIBS_TMS470:AMxx Cortex-A and ARM9 processors} 0 {TC_IPC:AMxx Cortex-A and ARM9 processors} 0 {CGT_DEFAULTLIBS_C6000:DaVinci Video Processors} 0 {TC_BIOS5:C6x DSP + ARM processors} 0 {TC_XDCTOOLS_BIOS5:DaVinci Video Processors} 0 {TC_C2000_XDCTOOLS:C28x 32-bit Real-time MCUs} 0 {TC_C6000_BIOS6:C6x DSP + ARM processors} 0 CGT_DEFAULTLIBS_C6000:OMAP 0 CCSINIT:OMAP 2 {DVT:DaVinci Video Processors} 2 {TC_BIOS6:C6000 Multi Core DSPs} 0 {IDE:DaVinci Video Processors} 2 {EMU_SD:C6000 Multi Core DSPs} 0 {SIM_TI:C6000 Multi Core DSPs} 0 TC_XDAIS:OMAP 0 {CCSINIT:AMxx Cortex-A and ARM9 processors} 2 {EMU_BH:C28x 32-bit Real-time MCUs} 0 EMU_TI:OMAP 2 {CGT_DEFAULTLIBS_TMS470:C6x DSP + ARM processors} 0 {TC_IPC:C6x DSP + ARM processors} 0 {TC_C6000_IPC:DaVinci Video Processors} 0 DS:OMAP 2 {TC_C2000_IPC:C28x 32-bit Real-time MCUs} 0 UIA:OMAP 0 {CCSINIT:DaVinci Video Processors} 2 {TC_XDCTOOLS:DaVinci Video Processors} 0 {TC_XDAIS:C6000 Multi Core DSPs} 0 {TC_IPC:C28x 32-bit Real-time MCUs} 0 {EMU_TI:C5000 Ultra Low Power DSP} 2 {SIM_TI:C28x 32-bit Real-time MCUs} 0 {EMU_SD:C28x 32-bit Real-time MCUs} 0 CGT_DEFAULTLIBS_C5500:OMAP 0 CGT_DEFAULTLIBS_TMS470:OMAP 0 TC_IPC:OMAP 0 {EMU_C2000:C28x 32-bit Real-time MCUs} 2 {EMU_TI:C6x DSP + ARM processors} 2 {EMU_SD:C6x DSP + ARM processors} 0 {SIM_TI:C6x DSP + ARM processors} 0 TC_C6000_XDCTOOLS:OMAP 0 {DVT:C6000 Single Core DSPs} 2 {TC_XDCTOOLS:C6000 Multi Core DSPs} 0 {EMU_BH:C6x DSP + ARM processors} 0 {TC_XDAIS:AMxx Cortex-A and ARM9 processors} 0 {TC_ARM_IPC:AMxx Cortex-A and ARM9 processors} 0 {ARM_RSE:DaVinci Video Processors} 2 {DMED:C6000 Multi Core DSPs} 0 {SIM_TI:C5000 Ultra Low Power DSP} 0 {EMU_SD:C5000 Ultra Low Power DSP} 0 {TC_ARM_XDCTOOLS:C6x DSP + ARM processors} 0 {DS:Cortex-R4F MCUs} 2 {UIA:Cortex-R4F MCUs} 0 {CGT_DEFAULTLIBS_C5500:C5000 Ultra Low Power DSP} 0 {TC_ARM_BIOS6:Cortex-R4F MCUs} 0 TC_C6000_BIOS6:OMAP 0 {TC_BIOS6:C6000 Single Core DSPs} 0 {TC_IPC:C6000 Single Core DSPs} 0 {CGT_DEFAULTLIBS_C6000:C6x DSP + ARM processors} 0 {TC_C2000_BIOS6:C28x 32-bit Real-time MCUs} 0 {CGT_DEFAULTLIBS_C6000:C6000 Multi Core DSPs} 0 {TC_XDCTOOLS:C6000 Single Core DSPs} 0 {TC_XDCTOOLS_BIOS5:C6x DSP + ARM processors} 0 {UIA:C6000 Single Core DSPs} 0 {DS:C6000 Single Core DSPs} 2 {TC_BIOS5:C6000 Single Core DSPs} 0 {EMU_BH:AMxx Cortex-A and ARM9 processors} 0 {IDE:C6000 Multi Core DSPs} 2 {EMU_TI:C6000 Multi Core DSPs} 2 {KEYSTONE1:C6000 Multi Core DSPs} 2 {DS:C28x 32-bit Real-time MCUs} 2 {UIA:C28x 32-bit Real-time MCUs} 0 TC_XDAIS_BIOS5:OMAP 0 {TC_IPC:Cortex-R4F MCUs} 0 {CGT_DEFAULTLIBS_TMS470:Cortex-R4F MCUs} 0 {DMED:C28x 32-bit Real-time MCUs} 0 {TC_XDAIS_BIOS5:AMxx Cortex-A and ARM9 processors} 0 {TC_ARM_BIOS6:AMxx Cortex-A and ARM9 processors} 0 {TC_IPC:C6000 Multi Core DSPs} 0 {ARM_QT:AMxx Cortex-A and ARM9 processors} 2 {DVT:C6x DSP + ARM processors} 2 TC_BIOS5:OMAP 0 {EMU_BH:C5000 Ultra Low Power DSP} 0 {EMU_BH:C6000 Multi Core DSPs} 0 {IDE:C6x DSP + ARM processors} 2 {TC_C6000_BIOS6:C6000 Multi Core DSPs} 0 {CCSINIT:C28x 32-bit Real-time MCUs} 2 {TC_XDAIS_BIOS5:C5000 Ultra Low Power DSP} 0 {TC_XDAIS_BIOS5:C6000 Multi Core DSPs} 0 {TC_C6000_IPC:C6x DSP + ARM processors} 0 {TC_ARM_IPC:DaVinci Video Processors} 0 {ARM_QT:C5000 Ultra Low Power DSP} 2 {ARM_QT:C6000 Single Core DSPs} 2 {CCSINIT:C6x DSP + ARM processors} 2 {EMU_SD:C6000 Single Core DSPs} 0 {SIM_TI:C6000 Single Core DSPs} 0 {DVT:C5000 Ultra Low Power DSP} 2 {TC_XDCTOOLS:C6x DSP + ARM processors} 0 {TC_XDAIS_BIOS5:C28x 32-bit Real-time MCUs} 0 {TC_XDCTOOLS:AMxx Cortex-A and ARM9 processors} 0 {TC_C6000_XDCTOOLS:DaVinci Video Processors} 0 IDE:OMAP 2 {ARM_RSE:C6000 Single Core DSPs} 2 {DMED:C6000 Single Core DSPs} 0 {EMU_SD:AMxx Cortex-A and ARM9 processors} 0 {SIM_TI:AMxx Cortex-A and ARM9 processors} 0 {CGT_DEFAULTLIBS_C2800:C28x 32-bit Real-time MCUs} 0 {UIA:C6000 Multi Core DSPs} 0 {DS:C6000 Multi Core DSPs} 2 {TC_XDAIS:DaVinci Video Processors} 0 TC_C6000_IPC:OMAP 0 {TC_XDCTOOLS:Cortex-R4F MCUs} 0 {TC_XDAIS:Cortex-R4F MCUs} 0 {TC_C6000_XDCTOOLS:C6000 Multi Core DSPs} 0 {EMU_BH:C6000 Single Core DSPs} 0 {ARM_RSE:C6x DSP + ARM processors} 2 {UIA:DaVinci Video Processors} 0 {DS:DaVinci Video Processors} 2 {DMED:C5000 Ultra Low Power DSP} 0 {CCSINIT:Cortex-R4F MCUs} 2 {TC_XDCTOOLS_BIOS5:C6000 Multi Core DSPs} 0 {UIA:AMxx Cortex-A and ARM9 processors} 0 {DS:AMxx Cortex-A and ARM9 processors} 2 {TC_C6000_BIOS6:C6000 Single Core DSPs} 0 {TC_C6000_IPC:C6000 Single Core DSPs} 0 {TC_C6000_XDCTOOLS:C6000 Single Core DSPs} 0 EMU_BH:OMAP 0 {TC_BIOS6:Cortex-R4F MCUs} 0 {TC_BIOS6:C28x 32-bit Real-time MCUs} 0 {IDE:C5000 Ultra Low Power DSP} 2 {EMU_TI:C28x 32-bit Real-time MCUs} 2 {ARM_QT:C28x 32-bit Real-time MCUs} 2 {DMED:DaVinci Video Processors} 0 {TC_XDCTOOLS_BIOS5:AMxx Cortex-A and ARM9 processors} 0 {TC_BIOS6:DaVinci Video Processors} 0 {TC_C6000_IPC:C6000 Multi Core DSPs} 0 {TC_ARM_XDCTOOLS:Cortex-R4F MCUs} 0 {CCSINIT:C6000 Single Core DSPs} 2 {TC_BIOS5:AMxx Cortex-A and ARM9 processors} 0 {DVT:C28x 32-bit Real-time MCUs} 2 {EMU_NOWFLASH:Cortex-R4F MCUs} 2 {ARM_RSE:C5000 Ultra Low Power DSP} 2 {TC_ARM_IPC:C6x DSP + ARM processors} 0 {C6FLO:DaVinci Video Processors} 0 {TC_C6000_XDCTOOLS:C6x DSP + ARM processors} 0 {ARM_QT:DaVinci Video Processors} 2 {DVT:C6000 Multi Core DSPs} 2 {TC_BIOS5:C5000 Ultra Low Power DSP} 0 ARM_RSE:OMAP 2 {EMU_C2000_FLASH:C28x 32-bit Real-time MCUs} 2 {TC_BIOS5:C6000 Multi Core DSPs} 0 {TC_XDCTOOLS:C28x 32-bit Real-time MCUs} 0 {TC_XDAIS:C6x DSP + ARM processors} 0 {ARM_RSE:C28x 32-bit Real-time MCUs} 2 ARM_QT:OMAP 2 CGT_DEFAULTLIBS_C5400:OMAP 0 TC_XDCTOOLS_BIOS5:OMAP 0 {TC_ARM_XDCTOOLS:AMxx Cortex-A and ARM9 processors} 0 {UIA:C6x DSP + ARM processors} 0 {DS:C6x DSP + ARM processors} 2 {EMU_BH:Cortex-R4F MCUs} 0 {DMED:Cortex-R4F MCUs} 0 {TC_XDAIS:C6000 Single Core DSPs} 0 {TC_XDAIS_BIOS5:C6000 Single Core DSPs} 0 {TC_XDAIS_BIOS5:DaVinci Video Processors} 0 {TC_ARM_BIOS6:DaVinci Video Processors} 0 {CGT_DEFAULTLIBS_C6000:C6000 Single Core DSPs} 0 {TC_XDAIS:C28x 32-bit Real-time MCUs} 0 {EMU_NOWFLASH:C28x 32-bit Real-time MCUs} 2 {IDE:Cortex-R4F MCUs} 2 {DMED:C6x DSP + ARM processors} 0 {TC_BIOS5:DaVinci Video Processors} 0 {SIM_TI:Cortex-R4F MCUs} 0 {EMU_SD:Cortex-R4F MCUs} 0 {CCSINIT:C6000 Multi Core DSPs} 2 {DS:C5000 Ultra Low Power DSP} 2 {TC_BIOS6:C6x DSP + ARM processors} 0 {ARM_RSE:AMxx Cortex-A and ARM9 processors} 2 {TC_C6000_BIOS6:DaVinci Video Processors} 0 {TC_XDCTOOLS_BIOS5:C6000 Single Core DSPs} 0 {DVT:AMxx Cortex-A and ARM9 processors} 2 {TC_ARM_IPC:Cortex-R4F MCUs} 0 DMED:OMAP 0 {EMU_TI:Cortex-R4F MCUs} 2 {EMU_TI:AMxx Cortex-A and ARM9 processors} 2 {TC_XDCTOOLS_BIOS5:C5000 Ultra Low Power DSP} 0 {CGT_DEFAULTLIBS_C5400:C5000 Ultra Low Power DSP} 0 {TC_XDCTOOLS_BIOS5:C28x 32-bit Real-time MCUs} 0 {IDE:C28x 32-bit Real-time MCUs} 2 {C6FLO:C6x DSP + ARM processors} 0 SIM_TI:OMAP 0 {ARM_QT:C6x DSP + ARM processors} 2 {CGT_DEFAULTLIBS_TMS470:DaVinci Video Processors} 0 {TC_IPC:DaVinci Video Processors} 0 EMU_SD:OMAP 0 DVT:OMAP 2 {ARM_QT:C6000 Multi Core DSPs} 2 {DVT:Cortex-R4F MCUs} 2 {TC_BIOS6:AMxx Cortex-A and ARM9 processors} 0 {DMED:AMxx Cortex-A and ARM9 processors} 0 {CCSINIT:C5000 Ultra Low Power DSP} 2
12/05/2012 14:08:51PM - Displaying feature list:
12/05/2012 14:08:51PM - caught delete Compiler_Tools
12/05/2012 14:08:51PM - addgroup=0:addsub=1:level=0
12/05/2012 14:08:51PM - initializing showcomps for Compiler Tools 0
12/05/2012 14:08:51PM - 1 Component CGT_DEFAULTLIBS_TMS470 is offered
12/05/2012 14:08:51PM - caught delete CGT_DEFAULTLIBS_TMS470
12/05/2012 14:08:51PM - adding group Compiler_Tools
12/05/2012 14:08:51PM - level = 0 1
12/05/2012 14:08:51PM - showcomps for Compiler Tools 1
12/05/2012 14:08:51PM - addgroup=1:addsub=0:level=1
12/05/2012 14:08:51PM - caught delete Documentation
12/05/2012 14:08:51PM - initializing showcomps for Documentation 0
12/05/2012 14:08:51PM - 1 Component DMED is offered
12/05/2012 14:08:51PM - caught delete DMED
12/05/2012 14:08:51PM - 1 Adding subgroup: Documentation
12/05/2012 14:08:51PM - level = 1 1
12/05/2012 14:08:51PM - showcomps for Documentation 0
12/05/2012 14:08:51PM - caught delete Device_Software
12/05/2012 14:08:51PM - addgroup=0:addsub=0:level=1
12/05/2012 14:08:51PM - caught delete C6FLO
12/05/2012 14:08:51PM - initializing showcomps for C6FLO 0
12/05/2012 14:08:51PM - caught delete DSP/BIOS_v5
12/05/2012 14:08:51PM - initializing showcomps for DSP/BIOS v5 0
12/05/2012 14:08:51PM - 1 Component TC_XDCTOOLS_BIOS5 is offered
12/05/2012 14:08:51PM - caught delete TC_XDCTOOLS_BIOS5
12/05/2012 14:08:51PM - adding group Device_Software
12/05/2012 14:08:51PM - 1 Adding subgroup: DSP/BIOS v5
12/05/2012 14:08:51PM - showcomps for DSP/BIOS v5 0
12/05/2012 14:08:51PM - 1 Component TC_XDAIS_BIOS5 is offered
12/05/2012 14:08:51PM - caught delete TC_XDAIS_BIOS5
12/05/2012 14:08:51PM - 1 Component TC_BIOS5 is offered
12/05/2012 14:08:51PM - caught delete TC_BIOS5
12/05/2012 14:08:51PM - caught delete SYS/BIOS_v6
12/05/2012 14:08:51PM - initializing showcomps for SYS/BIOS v6 0
12/05/2012 14:08:51PM - 1 Component TC_ARM_XDCTOOLS is offered
12/05/2012 14:08:51PM - caught delete TC_ARM_XDCTOOLS
12/05/2012 14:08:51PM - 1 Adding subgroup: SYS/BIOS v6
12/05/2012 14:08:51PM - showcomps for SYS/BIOS v6 0
12/05/2012 14:08:51PM - 1 Component TC_XDCTOOLS is offered
12/05/2012 14:08:51PM - 1 Component TC_XDAIS is offered
12/05/2012 14:08:51PM - 1 Component TC_ARM_IPC is offered
12/05/2012 14:08:51PM - caught delete TC_ARM_IPC
12/05/2012 14:08:51PM - 1 Component TC_BIOS6 is offered
12/05/2012 14:08:51PM - caught delete TC_BIOS6
12/05/2012 14:08:51PM - 1 Component UIA is offered
12/05/2012 14:08:51PM - caught delete UIA
12/05/2012 14:08:51PM - 1 Component TC_ARM_BIOS6 is offered
12/05/2012 14:08:51PM - caught delete TC_ARM_BIOS6
12/05/2012 14:08:51PM - 1 Component TC_IPC is offered
12/05/2012 14:08:51PM - caught delete TC_IPC
12/05/2012 14:08:51PM - caught delete Simulators
12/05/2012 14:08:51PM - initializing showcomps for Simulators 0
12/05/2012 14:08:51PM - 1 Component SIM_TI is offered
12/05/2012 14:08:51PM - caught delete SIM_TI
12/05/2012 14:08:51PM - adding group Simulators
12/05/2012 14:08:51PM - showcomps for Simulators 1
12/05/2012 14:08:51PM - caught delete Base_Installation
12/05/2012 14:08:51PM - initializing showcomps for Base Installation 0
12/05/2012 14:08:51PM - 1 Component DS is offered
12/05/2012 14:08:51PM - 1 Component DS is selected
12/05/2012 14:08:51PM - 1 Component DS is mandatory
12/05/2012 14:08:51PM - 1 Component ARM_RSE is offered
12/05/2012 14:08:51PM - caught delete ARM_RSE
12/05/2012 14:08:51PM - 1 Component ARM_RSE is selected
12/05/2012 14:08:51PM - 1 Component ARM_RSE is mandatory
12/05/2012 14:08:51PM - 1 Component ARM_QT is offered
12/05/2012 14:08:51PM - caught delete ARM_QT
12/05/2012 14:08:51PM - 1 Component ARM_QT is selected
12/05/2012 14:08:51PM - 1 Component ARM_QT is mandatory
12/05/2012 14:08:51PM - 1 Component DVT is offered
12/05/2012 14:08:51PM - caught delete DVT
12/05/2012 14:08:51PM - 1 Component DVT is selected
12/05/2012 14:08:51PM - 1 Component DVT is mandatory
12/05/2012 14:08:51PM - 1 Component IDE is offered
12/05/2012 14:08:51PM - caught delete IDE
12/05/2012 14:08:51PM - 1 Component IDE is selected
12/05/2012 14:08:51PM - 1 Component IDE is mandatory
12/05/2012 14:08:51PM - 1 Component CCSINIT is offered
12/05/2012 14:08:51PM - caught delete CCSINIT
12/05/2012 14:08:51PM - 1 Component CCSINIT is selected
12/05/2012 14:08:51PM - 1 Component CCSINIT is mandatory
12/05/2012 14:08:51PM - all components in Base Installation are now being selected.
12/05/2012 14:08:51PM - showcomps: 0 Base_Installation: 1
12/05/2012 14:08:51PM - in click_componentsubgroup Base Installation
12/05/2012 14:08:51PM - Checking subgroup Base Installation
12/05/2012 14:08:51PM - DS has no additional options
12/05/2012 14:08:51PM - skipping DS, it's madatory
12/05/2012 14:08:51PM - ARM_RSE has no additional options
12/05/2012 14:08:51PM - skipping ARM_RSE, it's madatory
12/05/2012 14:08:51PM - ARM_QT has no additional options
12/05/2012 14:08:51PM - skipping ARM_QT, it's madatory
12/05/2012 14:08:51PM - DVT has no additional options
12/05/2012 14:08:51PM - skipping DVT, it's madatory
12/05/2012 14:08:51PM - IDE has no additional options
12/05/2012 14:08:51PM - skipping IDE, it's madatory
12/05/2012 14:08:51PM - CCSINIT has no additional options
12/05/2012 14:08:51PM - skipping CCSINIT, it's madatory
12/05/2012 14:08:51PM - Displaying pane 0FF2C23D-509B-496F-9DED-C0FE5D001E3A - Custom Choose Components
12/05/2012 14:08:51PM - Executing actions 0FF2C23D-509B-496F-9DED-C0FE5D001E3A - Custom Choose Components - After Pane is Displayed
12/05/2012 14:08:51PM - Checking conditions for CFB4CAC7-37EE-4FF6-AE3B-B128AA009E91 - SpecialLabel - Before Action is Executed
12/05/2012 14:08:51PM - Checking condition 21CB69A4-8E86-4E6C-8C0C-AF7F21D47827 - String Equal Condition
12/05/2012 14:08:51PM - Checking to see if yes equals <%allowrestricted%>
12/05/2012 14:08:51PM - ** Checking to see if yes equals yes
12/05/2012 14:08:51PM - Executing action CFB4CAC7-37EE-4FF6-AE3B-B128AA009E91 - SpecialLabel
12/05/2012 14:08:51PM - Checking conditions for 61274498-7290-431F-9098-ED970DFAE549 - RestrictedTextBox - Before Action is Executed
12/05/2012 14:08:51PM - Checking condition D0403FE3-D835-48CF-9E66-5B5FCDF034E1 - String Equal Condition
12/05/2012 14:08:51PM - Executing action 61274498-7290-431F-9098-ED970DFAE549 - RestrictedTextBox
12/05/2012 14:08:57PM - Executing actions 0FF2C23D-509B-496F-9DED-C0FE5D001E3A - Custom Choose Components - Before Next Pane is Displayed
12/05/2012 14:08:57PM - Checking conditions for 138B95D0-F89F-46BD-861F-A7465C02821B - Custom Choose Emulators - Before Pane is Displayed
12/05/2012 14:08:57PM - Checking condition 86672030-011E-487C-9422-A4E318ACDB1E - String Is Condition
12/05/2012 14:08:57PM - Checking to see if <%ShowEMUs%> is true
12/05/2012 14:08:57PM - ** Checking to see if true is true
12/05/2012 14:08:57PM - Condition passed
12/05/2012 14:08:57PM - Executing actions 138B95D0-F89F-46BD-861F-A7465C02821B - Custom Choose Emulators - Before Pane is Displayed
12/05/2012 14:08:57PM - Executing action 04EEB113-B28D-40F7-A356-0543BA36271F - Add Emulators
12/05/2012 14:08:57PM - In Add Emulators:
12/05/2012 14:08:57PM - emulatormessagewidget .wizard.steps.f138B95D0-F89F-46BD-861F-A7465C02821B.message
12/05/2012 14:08:57PM - installed features =
12/05/2012 14:08:57PM - Displaying feature list:
12/05/2012 14:08:57PM - caught delete JTAG_Emulator_Support
12/05/2012 14:08:57PM - {JTAG Emulator Support} {JTAG Emulator Support}
12/05/2012 14:08:57PM - JTAG Emulator Support JTAG Emulator Support
12/05/2012 14:08:57PM - addgroup=0:addsub=1:level=0
12/05/2012 14:08:57PM - c: EMU_NOWFLASH,JTAG Emulator Support JTAG Emulator Support
12/05/2012 14:08:57PM - initializing showcomps for JTAG Emulator Support 0
12/05/2012 14:08:57PM - c: EMU_C2000_FLASH,JTAG Emulator Support JTAG Emulator Support
12/05/2012 14:08:57PM - c: DS,Base Installation Base Installation
12/05/2012 14:08:57PM - c: C6FLO,C6FLO C6FLO
12/05/2012 14:08:57PM - c: TC_C2000_BIOS6,SYS/BIOS v6 SYS/BIOS v6
12/05/2012 14:08:57PM - c: TC_ARM_XDCTOOLS,SYS/BIOS v6 SYS/BIOS v6
12/05/2012 14:08:57PM - c: CGT_DEFAULTLIBS_C2800,Compiler Tools Compiler Tools
12/05/2012 14:08:57PM - c: TC_C6000_XDCTOOLS,SYS/BIOS v6 SYS/BIOS v6
12/05/2012 14:08:57PM - c: TC_XDCTOOLS,SYS/BIOS v6 SYS/BIOS v6
12/05/2012 14:08:57PM - c: TC_XDCTOOLS_BIOS5,DSP/BIOS v5 DSP/BIOS v5
12/05/2012 14:08:57PM - c: ARM_RSE,Base Installation Base Installation
12/05/2012 14:08:57PM - c: TC_XDAIS_BIOS5,DSP/BIOS v5 DSP/BIOS v5
12/05/2012 14:08:57PM - c: TC_XDAIS,SYS/BIOS v6 SYS/BIOS v6
12/05/2012 14:08:57PM - c: EMU_C2000,JTAG Emulator Support JTAG Emulator Support
12/05/2012 14:08:57PM - c: TC_C6000_BIOS6,SYS/BIOS v6 SYS/BIOS v6
12/05/2012 14:08:57PM - c: TC_ARM_IPC,SYS/BIOS v6 SYS/BIOS v6
12/05/2012 14:08:57PM - c: TC_BIOS6,SYS/BIOS v6 SYS/BIOS v6
12/05/2012 14:08:57PM - c: ARM_QT,Base Installation Base Installation
12/05/2012 14:08:57PM - c: DVT,Base Installation Base Installation
12/05/2012 14:08:57PM - c: EMU_BH,JTAG Emulator Support JTAG Emulator Support
12/05/2012 14:08:57PM - 1 Component EMU_BH is offered
12/05/2012 14:08:57PM - caught delete EMU_BH
12/05/2012 14:08:57PM - adding group JTAG_Emulator_Support
12/05/2012 14:08:57PM - level = 0 1
12/05/2012 14:08:57PM - showcomps for JTAG Emulator Support 1
12/05/2012 14:08:57PM - c: CGT_DEFAULTLIBS_C5500,Compiler Tools Compiler Tools
12/05/2012 14:08:57PM - c: DMED,Documentation Documentation
12/05/2012 14:08:57PM - c: TC_C2000_IPC,SYS/BIOS v6 SYS/BIOS v6
12/05/2012 14:08:57PM - c: DVT_MIN,Base Installation Base Installation
12/05/2012 14:08:57PM - c: UIA,SYS/BIOS v6 SYS/BIOS v6
12/05/2012 14:08:57PM - c: CGT_DEFAULTLIBS_TMS470,Compiler Tools Compiler Tools
12/05/2012 14:08:57PM - c: TC_BIOS5,DSP/BIOS v5 DSP/BIOS v5
12/05/2012 14:08:57PM - c: KEYSTONE1,JTAG Emulator Support JTAG Emulator Support
12/05/2012 14:08:57PM - c: EMU_TI,JTAG Emulator Support JTAG Emulator Support
12/05/2012 14:08:57PM - 1 Component EMU_TI is offered
12/05/2012 14:08:57PM - caught delete EMU_TI
12/05/2012 14:08:57PM - 1 Component EMU_TI is selected
12/05/2012 14:08:57PM - 1 Component EMU_TI is mandatory
12/05/2012 14:08:57PM - 1 Found additionoptions for EMU_TI
12/05/2012 14:08:57PM - caught delete XDS100_Class_Emulator_Support
12/05/2012 14:08:57PM - c: IDE,Base Installation Base Installation
12/05/2012 14:08:57PM - c: TC_ARM_BIOS6,SYS/BIOS v6 SYS/BIOS v6
12/05/2012 14:08:57PM - c: SIM_TI,Simulators Simulators
12/05/2012 14:08:57PM - c: CGT_DEFAULTLIBS_C6000,Compiler Tools Compiler Tools
12/05/2012 14:08:57PM - c: EMU_SD,JTAG Emulator Support JTAG Emulator Support
12/05/2012 14:08:57PM - 1 Component EMU_SD is offered
12/05/2012 14:08:57PM - caught delete EMU_SD
12/05/2012 14:08:57PM - c: TC_C6000_IPC,SYS/BIOS v6 SYS/BIOS v6
12/05/2012 14:08:57PM - c: TC_C2000_XDCTOOLS,SYS/BIOS v6 SYS/BIOS v6
12/05/2012 14:08:57PM - c: TC_IPC,SYS/BIOS v6 SYS/BIOS v6
12/05/2012 14:08:57PM - c: CCSINIT,Base Installation Base Installation
12/05/2012 14:08:57PM - c: CGT_DEFAULTLIBS_C5400,Compiler Tools Compiler Tools
12/05/2012 14:08:57PM - Displaying pane 138B95D0-F89F-46BD-861F-A7465C02821B - Custom Choose Emulators
12/05/2012 14:08:58PM - Executing actions 138B95D0-F89F-46BD-861F-A7465C02821B - Custom Choose Emulators - After Pane is Displayed
12/05/2012 14:09:01PM - Executing actions 138B95D0-F89F-46BD-861F-A7465C02821B - Custom Choose Emulators - Before Next Pane is Displayed
12/05/2012 14:09:01PM - Executing actions 970555AE-BBCE-498A-BB1F-05C2F50D8552 - Start Copying Files - Before Pane is Displayed
12/05/2012 14:09:01PM - Executing action C4EC8154-C66E-4DC2-B476-02CB1D52201E - Display Installation Information
12/05/2012 14:09:01PM - Installdir = /home/dell/Desktop/Shared/sitara/ti
12/05/2012 14:09:01PM - Space required: 1283457024.0
12/05/2012 14:09:01PM - Space available: 228254056448
12/05/2012 14:09:01PM - Disk Space Detection: Prefered 1.20 GB ; Available 212.58 GB
12/05/2012 14:09:01PM - Checking EMU_NOWFLASH -1
12/05/2012 14:09:01PM - Checking EMU_C2000_FLASH -1
12/05/2012 14:09:01PM - Checking DS -1
12/05/2012 14:09:01PM - Checking C6FLO -1
12/05/2012 14:09:01PM - Checking TC_C2000_BIOS6 -1
12/05/2012 14:09:01PM - Checking TC_ARM_XDCTOOLS -1
12/05/2012 14:09:01PM - Checking CGT_DEFAULTLIBS_C2800 -1
12/05/2012 14:09:01PM - Checking TC_C6000_XDCTOOLS -1
12/05/2012 14:09:01PM - Checking TC_XDCTOOLS -1
12/05/2012 14:09:01PM - Checking TC_XDCTOOLS_BIOS5 -1
12/05/2012 14:09:01PM - Checking ARM_RSE -1
12/05/2012 14:09:01PM - Checking TC_XDAIS_BIOS5 -1
12/05/2012 14:09:01PM - Checking TC_XDAIS -1
12/05/2012 14:09:01PM - Checking EMU_C2000 -1
12/05/2012 14:09:01PM - Checking TC_C6000_BIOS6 -1
12/05/2012 14:09:01PM - Checking TC_ARM_IPC -1
12/05/2012 14:09:01PM - Checking TC_BIOS6 -1
12/05/2012 14:09:01PM - Checking ARM_QT -1
12/05/2012 14:09:01PM - Checking DVT -1
12/05/2012 14:09:01PM - Checking EMU_BH -1
12/05/2012 14:09:01PM - Checking CGT_DEFAULTLIBS_C5500 -1
12/05/2012 14:09:01PM - Checking DMED -1
12/05/2012 14:09:01PM - Checking TC_C2000_IPC -1
12/05/2012 14:09:01PM - Checking DVT_MIN -1
12/05/2012 14:09:01PM - Checking UIA -1
12/05/2012 14:09:01PM - Checking CGT_DEFAULTLIBS_TMS470 -1
12/05/2012 14:09:01PM - Checking TC_BIOS5 -1
12/05/2012 14:09:01PM - Checking KEYSTONE1 -1
12/05/2012 14:09:01PM - Checking EMU_TI -1
12/05/2012 14:09:01PM - Checking IDE -1
12/05/2012 14:09:01PM - Checking TC_ARM_BIOS6 -1
12/05/2012 14:09:01PM - Checking SIM_TI -1
12/05/2012 14:09:01PM - Checking CGT_DEFAULTLIBS_C6000 -1
12/05/2012 14:09:01PM - Checking EMU_SD -1
12/05/2012 14:09:01PM - Checking TC_C6000_IPC -1
12/05/2012 14:09:01PM - Checking TC_C2000_XDCTOOLS -1
12/05/2012 14:09:01PM - Checking TC_IPC -1
12/05/2012 14:09:01PM - Checking CCSINIT -1
12/05/2012 14:09:01PM - Checking CGT_DEFAULTLIBS_C5400 -1
12/05/2012 14:09:01PM - Install Directory: /home/dell/Desktop/Shared/sitara/ti/ccsv5
Setup Type: Custom
Total Download size: 272 MB.
Product Families selected:
Components to be installed:
JRE
Eclipse
Installer Extensions
CCSINIT
DVT
Debug Server
Qt Integration
TI Emulators
12/05/2012 14:09:01PM - Displaying pane 970555AE-BBCE-498A-BB1F-05C2F50D8552 - Start Copying Files
12/05/2012 14:09:01PM - Executing actions 970555AE-BBCE-498A-BB1F-05C2F50D8552 - Start Copying Files - After Pane is Displayed
12/05/2012 14:09:10PM - Executing actions 970555AE-BBCE-498A-BB1F-05C2F50D8552 - Start Copying Files - Before Next Pane is Displayed
12/05/2012 14:09:10PM - Executing actions 52C7C2BC-1F41-4249-9F63-446012A9932F - Custom Copying Files - Before Pane is Displayed
12/05/2012 14:09:10PM - Executing action 91C1A8F5-F64C-49A5-B36F-13A27CBC2B2B - Disable Buttons
12/05/2012 14:09:10PM - Displaying pane 52C7C2BC-1F41-4249-9F63-446012A9932F - Custom Copying Files
12/05/2012 14:09:10PM - Executing actions 52C7C2BC-1F41-4249-9F63-446012A9932F - Custom Copying Files - After Pane is Displayed
12/05/2012 14:09:10PM - Executing action 597A14A8-9842-4C6F-A081-5DB914701168 - Install Everything
12/05/2012 14:09:10PM - Executing actions B51DE951-D209-4A30-820D-F4333DC0F757 - Install Actions
12/05/2012 14:09:10PM - Executing action B61916A4-E55E-433E-AD86-CA546CB82EBA - debug info
12/05/2012 14:09:10PM - InstallDir from update /home/dell/Desktop/Shared/sitara/ti
12/05/2012 14:09:10PM - CCSDIR From update /home/dell/Desktop/Shared/sitara/ti/ccsv5
12/05/2012 14:09:10PM - EclipseDir from update /home/dell/Desktop/Shared/sitara/ti/ccsv5/eclipse
12/05/2012 14:09:10PM - features previously installed:
12/05/2012 14:09:10PM - previously allowed (not installed) binaries:
12/05/2012 14:09:10PM - eclipse?
12/05/2012 14:09:10PM - Executing action ED594D8A-F0DB-4A5A-B795-708DF2A90A0B - Set executable name
12/05/2012 14:09:10PM - false 0
12/05/2012 14:09:10PM - New Executable name: /home/dell/Desktop/Shared/sitara/ti/ccsv5/eclipse/ccstudio
12/05/2012 14:09:10PM - Executing action 0D989427-0F69-485D-BE72-F2E935B73E52 - Set OS Specific Environment
12/05/2012 14:09:10PM - Checking conditions for D8E2B8AA-EB63-47FE-82AA-45EFA802BD78 - - Before Action is Executed
12/05/2012 14:09:10PM - Checking condition 956ED6B2-B8A2-486E-B71A-69E860C2E462 - Command Line Test Condition
12/05/2012 14:09:10PM - Checking to see if test was not passed on the command line
12/05/2012 14:09:10PM - Condition passed
12/05/2012 14:09:10PM - Executing action D8E2B8AA-EB63-47FE-82AA-45EFA802BD78 - Check URL
12/05/2012 14:09:10PM - /tmp/ijtmp_6CECF410-B6FA-AD39-7653-D5312F771648/tmpfile
12/05/2012 14:09:10PM - Checking conditions for F42ABA50-C9D7-4771-920C-0FEBABED0FB0 - - Before Action is Executed
12/05/2012 14:09:10PM - Checking condition 26BBE798-0872-4727-A392-CC2E02FCE122 - String Is Condition
12/05/2012 14:09:10PM - Checking to see if <%ValidURL%> is false
12/05/2012 14:09:10PM - ** Checking to see if 1 is false
12/05/2012 14:09:10PM - Condition failed
12/05/2012 14:09:10PM - Skipping action F42ABA50-C9D7-4771-920C-0FEBABED0FB0 - Invalid URL message - conditions failed
12/05/2012 14:09:10PM - Checking conditions for A74CD224-6F8B-4D98-A7F0-1B0F834CAD19 - - Before Action is Executed
12/05/2012 14:09:10PM - Checking condition D6D6ECF6-266D-4C54-8440-A632093FECFC - String Is Condition
12/05/2012 14:09:10PM - Skipping action A74CD224-6F8B-4D98-A7F0-1B0F834CAD19 - Invalid URL message - conditions failed
12/05/2012 14:09:10PM - Checking conditions for F747BBA6-DCBA-4CDE-B57B-EF8FD7E27CB5 - - Before Action is Executed
12/05/2012 14:09:10PM - Checking condition A7E1D8E2-DBB1-48E9-A360-E5D12D6AADEE - String Is Condition
12/05/2012 14:09:10PM - Skipping action F747BBA6-DCBA-4CDE-B57B-EF8FD7E27CB5 - Exit - conditions failed
12/05/2012 14:09:10PM - Executing action 6EC1F21D-0682-41CB-9A41-4D8B8CDA8EEE - Set JavaFound
12/05/2012 14:09:10PM - Found existing java in /home/dell/Desktop/Shared/sitara/ti/ccsv5/eclipse/jre/bin/java
12/05/2012 14:09:10PM - Executing action E40D7DAD-4686-4F93-B2CD-887A95143B07 - Progress Bar Setup
12/05/2012 14:09:10PM - JRE size = 36242027
12/05/2012 14:09:10PM - Eclipse size = 114186318
12/05/2012 14:09:10PM - Checking conditions for CB835508-B3C7-4C6D-86FB-A5722D1B4066 - - Before Action is Executed
12/05/2012 14:09:10PM - Checking condition F9DA4F2D-C63D-42EE-BD4E-C8F42BBD36FD - Command Line Test Condition
12/05/2012 14:09:10PM - Checking to see if test was passed on the command line
12/05/2012 14:09:10PM - Skipping action CB835508-B3C7-4C6D-86FB-A5722D1B4066 - Run Test Actions - conditions failed
12/05/2012 14:09:10PM - Checking conditions for A313FF31-91FB-47AB-A9D4-C81E1B2DA8C1 - - Before Action is Executed
12/05/2012 14:09:10PM - Checking condition 28013E47-E25A-45BE-A17E-6012E53D9AD5 - Command Line Test Condition
12/05/2012 14:09:10PM - Executing action A313FF31-91FB-47AB-A9D4-C81E1B2DA8C1 - Run Production Actions
12/05/2012 14:09:10PM - Executing actions E9AEA672-9CC4-4620-91F0-031A4399B5D9 - Production Actions
12/05/2012 14:09:10PM - Checking conditions for 89F5F788-B808-4C73-B1A6-598E1800859E - - Before Action is Executed
12/05/2012 14:09:10PM - Checking condition EE620C94-E4E9-4D83-9D26-BFCFD8845058 - String Is Condition
12/05/2012 14:09:10PM - Checking to see if <%UpdateMode%> is false
12/05/2012 14:09:10PM - ** Checking to see if 0 is false
12/05/2012 14:09:10PM - Executing action 89F5F788-B808-4C73-B1A6-598E1800859E - Execute Full Installer Actions
12/05/2012 14:09:10PM - Executing actions E9984187-D8FF-463D-8D8E-60C220EF35F4 - Full Installer Actions
12/05/2012 14:09:10PM - Executing action D41C35E7-02DC-4EEC-BA82-1BD87F61CE73 - Execute Docs Action
12/05/2012 14:09:10PM - Checking conditions for CAF3FA66-77E5-4A58-9BCA-ECFACEF580F3 - Docs Action - Before Action is Executed
12/05/2012 14:09:10PM - Checking condition 79A77474-BD66-42DC-A088-EA843BB2E8B7 - Execute Script Condition
12/05/2012 14:09:10PM - Executing actions CAF3FA66-77E5-4A58-9BCA-ECFACEF580F3 - Docs Action
12/05/2012 14:09:10PM - Checking conditions for 3A959878-9042-4438-A935-EE26E2EB7662 - - Before Action is Executed
12/05/2012 14:09:10PM - Checking condition 2A19BE5A-DB65-49F9-9B75-106C07596482 - String Is Condition
12/05/2012 14:09:10PM - Checking to see if <%LocalRepository_Exists%> is false
12/05/2012 14:09:10PM - Skipping action 3A959878-9042-4438-A935-EE26E2EB7662 - Fetch URL - conditions failed
12/05/2012 14:09:10PM - Executing action 78203424-E9E5-49B6-B339-5B7B3DB9FBD7 - Unzip doc folder
12/05/2012 14:09:10PM - Checking conditions for 46368434-9898-4D04-B7DC-D819E2845A1F - - Before Action is Executed
12/05/2012 14:09:10PM - Checking condition 66802838-03B1-42D6-A8EB-A7C1DF1B1FF9 - String Is Condition
12/05/2012 14:09:10PM - Checking to see if <%update_ms2005%> is true
12/05/2012 14:09:10PM - Skipping action 46368434-9898-4D04-B7DC-D819E2845A1F - Execute Install MS VC++ 2005 - conditions failed
12/05/2012 14:09:10PM - Checking conditions for 090F3622-BB9B-4B48-A970-3E15EB7510A9 - - Before Action is Executed
12/05/2012 14:09:10PM - Checking condition 06712831-ABBC-475B-830B-9118429E5B27 - String Is Condition
12/05/2012 14:09:10PM - Checking to see if <%update_ms2008%> is true
12/05/2012 14:09:10PM - Skipping action 090F3622-BB9B-4B48-A970-3E15EB7510A9 - Execute Install MS VC++ 2008 - conditions failed
12/05/2012 14:09:10PM - Checking conditions for 2B906FC9-940C-4500-87DA-E4345F52CF11 - - Before Action is Executed
12/05/2012 14:09:10PM - Checking condition 5FDF7E5F-01B1-4335-AF40-6E72CE1EB0BC - String Is Condition
12/05/2012 14:09:10PM - Checking to see if <%JavaFound%> is false
12/05/2012 14:09:10PM - ** Checking to see if false is false
12/05/2012 14:09:10PM - Checking condition 13C3AC65-D3B5-4E8E-ACAC-9096C24D4FBC - String Is Condition
12/05/2012 14:09:10PM - Checking to see if <%ComponentInstaller%> is false
12/05/2012 14:09:10PM - Executing action 2B906FC9-940C-4500-87DA-E4345F52CF11 - Execute Install JRE
12/05/2012 14:09:10PM - Executing actions D67C8D7B-B238-4A29-A6F9-00E6298C302A - Install JRE Component
12/05/2012 14:09:10PM - Executing action 480FB096-9061-43E9-94C5-C8CE0AE83199 - Set Variables
12/05/2012 14:09:10PM - Eclipse url = /home/dell/Desktop/Shared/CCS-5.1.1.00033-Sitara-ARM/CCS/baserepo
12/05/2012 14:09:10PM - Executing action 23949B5E-5883-4A6E-AF02-6549EB7C7638 - Execute Checkurls
12/05/2012 14:09:10PM - Executing actions AE999821-AA3F-40B6-AB8B-8196B5813470 - Checkurls
12/05/2012 14:09:10PM - Executing action 8A399EE0-2863-4ED6-828C-3FF39CA41B1B - Execute Script
12/05/2012 14:09:10PM - URL = /home/dell/Desktop/Shared/CCS-5.1.1.00033-Sitara-ARM/CCS/baserepo
12/05/2012 14:09:10PM - Checking conditions for C1E448F1-BD23-4DD5-9FF9-8E11158807DF - - Before Action is Executed
12/05/2012 14:09:10PM - Checking condition D6DB77DC-925A-4E71-9569-E6794BC73D67 - String Equal Condition
12/05/2012 14:09:10PM - Checking to see if Standard equals <%InstallMode%>
12/05/2012 14:09:10PM - ** Checking to see if Standard equals Standard
12/05/2012 14:09:10PM - Checking condition 3453FED3-F12C-4269-8764-A00A112CE736 - String Is Condition
12/05/2012 14:09:10PM - Checking to see if <%urlvalid%> is false
12/05/2012 14:09:10PM - Skipping action C1E448F1-BD23-4DD5-9FF9-8E11158807DF - Message Box - conditions failed
12/05/2012 14:09:11PM - Checking conditions for 71F8EAC7-5609-4AEA-8F4F-768F4F3F368E - - Before Action is Executed
12/05/2012 14:09:11PM - Checking condition F544F20F-E254-4294-8FEF-212A59160A67 - String Is Condition
12/05/2012 14:09:11PM - Checking to see if <%urlvalid%> is false
12/05/2012 14:09:11PM - ** Checking to see if 1 is false
12/05/2012 14:09:11PM - Condition failed
12/05/2012 14:09:11PM - Skipping action 71F8EAC7-5609-4AEA-8F4F-768F4F3F368E - Exit - conditions failed
12/05/2012 14:09:11PM - Checking conditions for 19214A83-29B6-415D-984B-EA92CE890157 - - Before Action is Executed
12/05/2012 14:09:11PM - Checking condition FBC58300-10C7-463E-87C1-3F2B932CACD3 - String Is Condition
12/05/2012 14:09:11PM - Checking to see if <%LocalRepository_Exists%> is false
12/05/2012 14:09:11PM - Skipping action 19214A83-29B6-415D-984B-EA92CE890157 - Fetch JRE - conditions failed
12/05/2012 14:09:11PM - Executing action 054249D8-4F54-4F54-86CC-0A8227959182 - Execute Checksums
12/05/2012 14:09:11PM - Executing actions 80708CAB-515B-4AE1-B901-08ED269CE819 - Checksums
12/05/2012 14:09:11PM - Executing action 3B2647A9-C7F1-454A-AD2A-0732987DE023 - Check checksum
12/05/2012 14:09:11PM - successfully downloaded /home/dell/Desktop/Shared/CCS-5.1.1.00033-Sitara-ARM/CCS/baserepo/jre_1.6.0_13.zip 36242027 36242027
12/05/2012 14:09:11PM - downloadstatus = true
12/05/2012 14:09:11PM - Checking conditions for 235C5CEC-715D-43D0-B271-0D06AD8F2F10 - - Before Action is Executed
12/05/2012 14:09:11PM - Checking condition EB71E428-63B6-4D7D-B285-7620C80247FA - String Equal Condition
12/05/2012 14:09:11PM - Checking to see if Standard equals <%InstallMode%>
12/05/2012 14:09:11PM - ** Checking to see if Standard equals Standard
12/05/2012 14:09:11PM - Condition passed
12/05/2012 14:09:11PM - Checking condition 897DD31E-3F2B-445F-B1A9-FB08FFD6A02C - String Is Condition
12/05/2012 14:09:11PM - Checking to see if <%downloadstatus%> is false
12/05/2012 14:09:11PM - ** Checking to see if true is false
12/05/2012 14:09:11PM - Skipping action 235C5CEC-715D-43D0-B271-0D06AD8F2F10 - Message Box - conditions failed
12/05/2012 14:09:11PM - Checking conditions for C40460F1-645D-4C8B-85D8-5D233809622A - - Before Action is Executed
12/05/2012 14:09:11PM - Checking condition 07ADB0FE-31E6-48EC-BBA2-7F2A48F50157 - String Is Condition
12/05/2012 14:09:11PM - Skipping action C40460F1-645D-4C8B-85D8-5D233809622A - Exit - conditions failed
12/05/2012 14:09:11PM - Executing action 0C868981-EA82-41C1-9E3F-67634C69B973 - Set Variables
12/05/2012 14:09:11PM - Executing action 0E9B9DAE-30DC-4EA4-A29D-6C28BC5CD257 - Unzip JRE
12/05/2012 14:09:54PM - Checking conditions for 16F6AC3A-94F8-464C-AC96-C8015C57F77D - - Before Action is Executed
12/05/2012 14:09:54PM - Checking condition 889CC2D9-119F-45A5-9F84-6A9B37B63E3F - Platform Condition
12/05/2012 14:09:54PM - Checking to see if <%Platform%> is Linux-x86
12/05/2012 14:09:54PM - ** Checking to see if Linux-x86 is Linux-x86
12/05/2012 14:09:54PM - Condition passed
12/05/2012 14:09:54PM - Executing action 16F6AC3A-94F8-464C-AC96-C8015C57F77D - Change File Permissions
12/05/2012 14:09:54PM - looking in /home/dell/Desktop/Shared/sitara/ti/ccsv5/eclipse/jre for xml files
12/05/2012 14:10:09PM - Executing action D52407CC-D301-46E2-8AD3-2BAF8CDEC808 - Locate this JRE
12/05/2012 14:10:09PM - Looking for /home/dell/Desktop/Shared/sitara/ti/ccsv5/eclipse/jre/bin/bin/java.
12/05/2012 14:10:09PM - Executing action D4BBCA35-C8F1-4A56-9E07-A1E6CA9E0C3E - Set Variables
12/05/2012 14:10:09PM - comp_size = 36242027
tot_size = 150428345
12/05/2012 14:10:09PM - ins_complete = 2.65018070231
12/05/2012 14:10:09PM - installed percent1: 0
12/05/2012 14:10:09PM - installed percent2: 2.65018070231
12/05/2012 14:10:09PM - Checking conditions for 0E926C02-09B5-4B61-A173-2DBB0BD6C3C2 - - Before Action is Executed
12/05/2012 14:10:09PM - Checking condition 6FF0EBFF-A517-4C11-A0F1-CC54AC2BFDCC - String Is Condition
12/05/2012 14:10:09PM - Checking to see if <%Native_Eclipse_Selected%> is false
12/05/2012 14:10:09PM - ** Checking to see if 0 is false
12/05/2012 14:10:09PM - Condition passed
12/05/2012 14:10:09PM - Checking condition 6AFC9AFB-5D68-47C1-960B-1F9D16B94F01 - String Is Condition
12/05/2012 14:10:09PM - Checking to see if <%Update_Eclipse%> is true
12/05/2012 14:10:09PM - ** Checking to see if true is true
12/05/2012 14:10:09PM - Checking condition 63DC6303-78C4-4579-9F18-277510744AC9 - String Is Condition
12/05/2012 14:10:09PM - Checking to see if <%ComponentInstaller%> is false
12/05/2012 14:10:09PM - ** Checking to see if false is false
12/05/2012 14:10:09PM - Executing action 0E926C02-09B5-4B61-A173-2DBB0BD6C3C2 - Execute Install Eclipse
12/05/2012 14:10:09PM - Executing actions B728E189-570B-4403-A0C7-9B3EC923A24F - Install Eclipse Component
12/05/2012 14:10:09PM - Executing action 0CC9BE25-F7D6-4A41-96B2-4C947ADBB2A3 - Set Variables
12/05/2012 14:10:09PM - Eclipse url = /home/dell/Desktop/Shared/CCS-5.1.1.00033-Sitara-ARM/CCS/baserepo
12/05/2012 14:10:09PM - Executing action E52F5561-8D7D-4395-B49D-F975F0666ECC - Execute Checkurls
12/05/2012 14:10:09PM - Executing actions AE999821-AA3F-40B6-AB8B-8196B5813470 - Checkurls
12/05/2012 14:10:09PM - Executing action 8A399EE0-2863-4ED6-828C-3FF39CA41B1B - Execute Script
12/05/2012 14:10:09PM - URL = /home/dell/Desktop/Shared/CCS-5.1.1.00033-Sitara-ARM/CCS/baserepo
12/05/2012 14:10:09PM - Checking conditions for C1E448F1-BD23-4DD5-9FF9-8E11158807DF - - Before Action is Executed
12/05/2012 14:10:09PM - Checking condition D6DB77DC-925A-4E71-9569-E6794BC73D67 - String Equal Condition
12/05/2012 14:10:09PM - Checking to see if Standard equals <%InstallMode%>
12/05/2012 14:10:09PM - ** Checking to see if Standard equals Standard
12/05/2012 14:10:09PM - Checking condition 3453FED3-F12C-4269-8764-A00A112CE736 - String Is Condition
12/05/2012 14:10:09PM - Checking to see if <%urlvalid%> is false
12/05/2012 14:10:09PM - ** Checking to see if 1 is false
12/05/2012 14:10:09PM - Condition failed
12/05/2012 14:10:09PM - Skipping action C1E448F1-BD23-4DD5-9FF9-8E11158807DF - Message Box - conditions failed
12/05/2012 14:10:09PM - Checking conditions for 71F8EAC7-5609-4AEA-8F4F-768F4F3F368E - - Before Action is Executed
12/05/2012 14:10:09PM - Checking condition F544F20F-E254-4294-8FEF-212A59160A67 - String Is Condition
12/05/2012 14:10:09PM - Skipping action 71F8EAC7-5609-4AEA-8F4F-768F4F3F368E - Exit - conditions failed
12/05/2012 14:10:09PM - Checking conditions for BB503668-45E6-4547-8B23-7A5B4015C8AA - - Before Action is Executed
12/05/2012 14:10:09PM - Checking condition FEC7DB76-3926-4CFB-8A00-C3CFDB2F8226 - String Is Condition
12/05/2012 14:10:09PM - Checking to see if <%LocalRepository_Exists%> is false
12/05/2012 14:10:09PM - Skipping action BB503668-45E6-4547-8B23-7A5B4015C8AA - Fetch Eclipse - conditions failed
12/05/2012 14:10:09PM - Executing action D6283DAE-7082-4D01-9333-BFC1D8B34993 - Execute Checksums
12/05/2012 14:10:09PM - Executing actions 80708CAB-515B-4AE1-B901-08ED269CE819 - Checksums
12/05/2012 14:10:09PM - Executing action 3B2647A9-C7F1-454A-AD2A-0732987DE023 - Check checksum
12/05/2012 14:10:09PM - successfully downloaded /home/dell/Desktop/Shared/CCS-5.1.1.00033-Sitara-ARM/CCS/baserepo/eclipsebase_setup_3.7.1.0.bin 114186318 114186318
12/05/2012 14:10:09PM - downloadstatus = true
12/05/2012 14:10:09PM - Checking conditions for 235C5CEC-715D-43D0-B271-0D06AD8F2F10 - - Before Action is Executed
12/05/2012 14:10:09PM - Checking condition EB71E428-63B6-4D7D-B285-7620C80247FA - String Equal Condition
12/05/2012 14:10:09PM - Checking condition 897DD31E-3F2B-445F-B1A9-FB08FFD6A02C - String Is Condition
12/05/2012 14:10:09PM - Checking to see if <%downloadstatus%> is false
12/05/2012 14:10:09PM - ** Checking to see if true is false
12/05/2012 14:10:09PM - Skipping action 235C5CEC-715D-43D0-B271-0D06AD8F2F10 - Message Box - conditions failed
12/05/2012 14:10:09PM - Checking conditions for C40460F1-645D-4C8B-85D8-5D233809622A - - Before Action is Executed
12/05/2012 14:10:09PM - Checking condition 07ADB0FE-31E6-48EC-BBA2-7F2A48F50157 - String Is Condition
12/05/2012 14:10:09PM - Skipping action C40460F1-645D-4C8B-85D8-5D233809622A - Exit - conditions failed
12/05/2012 14:10:09PM - Checking conditions for A6F5E560-DE83-4DF0-882E-CAFAC953EA2A - - Before Action is Executed
12/05/2012 14:10:09PM - Checking condition A3295F10-7947-4A0A-B38E-8B325087642B - Platform Condition
12/05/2012 14:10:09PM - Checking to see if <%Platform%> is not Windows
12/05/2012 14:10:09PM - ** Checking to see if Linux-x86 is not Windows
12/05/2012 14:10:09PM - Checking condition 4F3D904A-78A8-49DD-977B-837D4055D67A - File Exists Condition
12/05/2012 14:10:09PM - Checking to see if <%LocalBaseRepository%>/<%binary%> exists
12/05/2012 14:10:09PM - ** Checking to see if /home/dell/Desktop/Shared/CCS-5.1.1.00033-Sitara-ARM/CCS/baserepo/eclipsebase_setup_3.7.1.0.bin exists
12/05/2012 14:10:09PM - Executing action A6F5E560-DE83-4DF0-882E-CAFAC953EA2A - chmod executable
12/05/2012 14:10:09PM - Executing Command Line: chmod -R -v a+x /home/dell/Desktop/Shared/CCS-5.1.1.00033-Sitara-ARM/CCS/baserepo/eclipsebase_setup_3.7.1.0.bin
12/05/2012 14:10:09PM - Executing action 6A430D12-FCD1-45AB-93BE-330AF7445D3C - Set Variables
12/05/2012 14:10:09PM - Checking conditions for 01F62CC5-8F79-40A3-A8D2-BCA29172BCB6 - - Before Action is Executed
12/05/2012 14:10:09PM - Checking condition B216C2A2-2780-4766-8227-1B15670135A2 - File Exists Condition
12/05/2012 14:10:09PM - Checking to see if <%EclipseDir%>/configuration/config.ini exists
12/05/2012 14:10:09PM - ** Checking to see if /home/dell/Desktop/Shared/sitara/ti/ccsv5/eclipse/configuration/config.ini exists
12/05/2012 14:10:09PM - Skipping action 01F62CC5-8F79-40A3-A8D2-BCA29172BCB6 - Rename Config.ini - conditions failed
12/05/2012 14:10:09PM - Executing action E5D8B3D2-F45D-4C19-955E-0DDC1154A49A - Install Eclipse
12/05/2012 14:10:09PM - Executing Command Line: /home/dell/Desktop/Shared/CCS-5.1.1.00033-Sitara-ARM/CCS/baserepo/eclipsebase_setup_3.7.1.0.bin --mode silent --prefix /home/dell/Desktop/Shared/sitara/ti/ccsv5
12/05/2012 14:11:32PM - Executing action 47B1B86E-E1A3-402E-8C25-F03E9B1A4173 - Set Variables
12/05/2012 14:11:32PM - comp_size = 114186318
12/05/2012 14:11:32PM - ins_complete = 8.34981929769
12/05/2012 14:11:32PM - installed percent1: 2.65018070231
12/05/2012 14:11:32PM - installed percent2: 11.0
12/05/2012 14:11:32PM - Checking conditions for 7436EFCD-FA82-4464-82DA-61C173E6037C - - Before Action is Executed
12/05/2012 14:11:32PM - Checking condition 4DE22D33-C82C-4D52-B97D-301B73B1FC87 - String Is Condition
12/05/2012 14:11:32PM - Checking to see if <%UpdateMode%> is true
12/05/2012 14:11:32PM - ** Checking to see if 0 is true
12/05/2012 14:11:32PM - Condition failed
12/05/2012 14:11:32PM - Skipping action 7436EFCD-FA82-4464-82DA-61C173E6037C - Merge bundles.info file - conditions failed
12/05/2012 14:11:32PM - Executing action 163C605A-0649-43CC-A94B-715342843EAE - Run initialize
12/05/2012 14:11:32PM - Executing Command Line: /home/dell/Desktop/Shared/sitara/ti/ccsv5/eclipse/eclipse -initialize
12/05/2012 14:12:13PM - Executing action DDCA7A0A-A787-4D34-8075-6DA0240A6E71 - Execute Install P2
12/05/2012 14:12:13PM - Checking conditions for 9B4D3842-3F95-4E94-B04A-133D03D9FFA5 - Install P2 Component - Before Action is Executed
12/05/2012 14:12:13PM - Checking condition 7B80EE19-D209-497A-AC2B-38A878752794 - String Is Condition
12/05/2012 14:12:13PM - Checking to see if <%Update_LW%> is true
12/05/2012 14:12:13PM - ** Checking to see if true is true
12/05/2012 14:12:13PM - Condition passed
12/05/2012 14:12:13PM - Executing actions 9B4D3842-3F95-4E94-B04A-133D03D9FFA5 - Install P2 Component
12/05/2012 14:12:13PM - Executing action 9277E614-3331-4B17-95A1-29CAA681A2BC - Set Variables
12/05/2012 14:12:13PM - Executing action BAF2FDEB-3D8D-4176-A0F8-C70D6EDA88AE - Uninstall P2
12/05/2012 14:12:13PM - Changing to working directory /home/dell/Desktop/Shared/sitara/ti/ccsv5/eclipse
12/05/2012 14:12:13PM - Executing Command Line: /home/dell/Desktop/Shared/sitara/ti/ccsv5/eclipse/eclipse -application org.eclipse.equinox.p2.director -u com.ti.ccstudio.p2.feature.group -nosplash
12/05/2012 14:12:20PM - Error while executing: Installation failed.
The installable unit com.ti.ccstudio.p2.feature.group has not been found.
Application failed, log file location: /home/dell/Desktop/Shared/sitara/ti/ccsv5/eclipse/configuration/1354734737120.log
12/05/2012 14:12:20PM - Executing action 27EBC1FF-DD01-45FD-B208-71E86E62FF3E - Install P2
12/05/2012 14:12:20PM - Changing to working directory /home/dell/Desktop/Shared/sitara/ti/ccsv5/eclipse
12/05/2012 14:12:20PM - Executing Command Line: /home/dell/Desktop/Shared/sitara/ti/ccsv5/eclipse/eclipse -application org.eclipse.equinox.p2.director -repository file://tmp/ijtmp_6CECF410-B6FA-AD39-7653-D5312F771648/lwrepo -installIU com.ti.ccstudio.p2.feature.group -nosplash
12/05/2012 14:12:55PM - Executing action 6BA4E63A-CA02-464D-86BD-1BE19E1E0B9B - Set Variables
12/05/2012 14:12:55PM - Executing action 9941D4EF-61A7-4261-86F4-268DB48F6740 - Execute Install P2Tools
12/05/2012 14:12:55PM - Checking conditions for 655CBF3A-CD6B-4514-B41E-16E42E741483 - Install P2Tools Component - Before Action is Executed
12/05/2012 14:12:55PM - Checking condition 54A76100-D0D7-4EAB-8FD6-52B9D7C0134F - String Is Condition
12/05/2012 14:12:55PM - Checking to see if <%Update_LW%> is true
12/05/2012 14:12:55PM - ** Checking to see if true is true
12/05/2012 14:12:55PM - Condition passed
12/05/2012 14:12:55PM - Executing actions 655CBF3A-CD6B-4514-B41E-16E42E741483 - Install P2Tools Component
12/05/2012 14:12:55PM - Executing action 2EB53AFE-7694-42C2-BD59-BEF3DF285B13 - Set Variables
12/05/2012 14:12:55PM - Executing action C8341556-FB1D-446D-8C2A-DB9A7D74CFD7 - Uninstall P2 Tools
12/05/2012 14:12:55PM - Changing to working directory /home/dell/Desktop/Shared/sitara/ti/ccsv5/eclipse
12/05/2012 14:12:55PM - Executing Command Line: /home/dell/Desktop/Shared/sitara/ti/ccsv5/eclipse/eclipse -application org.eclipse.equinox.p2.director -u com.ti.ccstudio.p2tool.feature.group -nosplash
12/05/2012 14:13:11PM - Error while executing: Installation failed.
The installable unit com.ti.ccstudio.p2tool.feature.group has not been found.
Application failed, log file location: /home/dell/Desktop/Shared/sitara/ti/ccsv5/eclipse/configuration/1354734778694.log
12/05/2012 14:13:11PM - Executing action 94C70A3D-A548-45CF-BA93-B467B626ACAC - Install P2Tools
12/05/2012 14:13:11PM - Changing to working directory /home/dell/Desktop/Shared/sitara/ti/ccsv5/eclipse
12/05/2012 14:13:11PM - Executing Command Line: /home/dell/Desktop/Shared/sitara/ti/ccsv5/eclipse/eclipse -application org.eclipse.equinox.p2.director -repository file://tmp/ijtmp_6CECF410-B6FA-AD39-7653-D5312F771648/lwrepo -installIU com.ti.ccstudio.p2tool.feature.group -nosplash
12/05/2012 14:13:45PM - Executing action DF55BCD9-85E4-4224-8380-3A660F8A6656 - Set Variables
12/05/2012 14:13:45PM - Checking conditions for 801C0AD2-8BB1-4F6E-BB64-5C47CADEAD76 - - Before Action is Executed
12/05/2012 14:13:45PM - Checking condition 7072CD6B-4535-461D-B9FE-DC1E1511324E - String Is Condition
12/05/2012 14:13:45PM - Checking to see if <%UpdateMode%> is false
12/05/2012 14:13:45PM - ** Checking to see if 0 is false
12/05/2012 14:13:45PM - Condition passed
12/05/2012 14:13:45PM - Executing action 801C0AD2-8BB1-4F6E-BB64-5C47CADEAD76 - Execute Install LWInstaller
12/05/2012 14:13:45PM - Executing actions D893F839-5A29-40DA-9C49-D57B1F6D2EB5 - Install LWInstaller
12/05/2012 14:13:45PM - Executing action D26D0723-DCB8-4D62-A718-BBF8A48DE27C - Set Variables
12/05/2012 14:13:45PM - INSTALLER url = file:/home/dell/Desktop/Shared/CCS-5.1.1.00033-Sitara-ARM/CCS/featurerepo
12/05/2012 14:13:45PM - Executing action 537D8D51-FE60-45C3-80A5-B790F95D4360 - Uninstall LWInstaller feature
12/05/2012 14:13:45PM - Changing to working directory /home/dell/Desktop/Shared/sitara/ti/ccsv5/eclipse
12/05/2012 14:13:45PM - Executing Command Line: /home/dell/Desktop/Shared/sitara/ti/ccsv5/eclipse/eclipse -application org.eclipse.equinox.p2.director -u com.ti.ccstudio.installer.linux.feature.group -nosplash
12/05/2012 14:14:00PM - Error while executing: Installation failed.
The installable unit com.ti.ccstudio.installer.linux.feature.group has not been found.
Application failed, log file location: /home/dell/Desktop/Shared/sitara/ti/ccsv5/eclipse/configuration/1354734828284.log
12/05/2012 14:14:00PM - Executing action 83377826-4232-44D5-822D-810EB9869BA6 - Install LWInstaller feature
12/05/2012 14:14:00PM - Changing to working directory /home/dell/Desktop/Shared/sitara/ti/ccsv5/eclipse
12/05/2012 14:14:00PM - Executing Command Line: /home/dell/Desktop/Shared/sitara/ti/ccsv5/eclipse/eclipse -application org.eclipse.equinox.p2.director -repository file:/home/dell/Desktop/Shared/CCS-5.1.1.00033-Sitara-ARM/CCS/featurerepo -installIU com.ti.ccstudio.installer.linux.feature.group -nosplash
12/05/2012 14:14:35PM - Executing action 1DDB56C0-5AFA-4A76-A805-681823801B81 - Execute Checkurls
12/05/2012 14:14:35PM - Executing actions AE999821-AA3F-40B6-AB8B-8196B5813470 - Checkurls
12/05/2012 14:14:35PM - Executing action 8A399EE0-2863-4ED6-828C-3FF39CA41B1B - Execute Script
12/05/2012 14:14:35PM - URL = file:/home/dell/Desktop/Shared/CCS-5.1.1.00033-Sitara-ARM/CCS/featurerepo
12/05/2012 14:14:35PM - Checking conditions for C1E448F1-BD23-4DD5-9FF9-8E11158807DF - - Before Action is Executed
12/05/2012 14:14:35PM - Checking condition D6DB77DC-925A-4E71-9569-E6794BC73D67 - String Equal Condition
12/05/2012 14:14:35PM - Checking to see if Standard equals <%InstallMode%>
12/05/2012 14:14:35PM - ** Checking to see if Standard equals Standard
12/05/2012 14:14:35PM - Condition passed
12/05/2012 14:14:35PM - Checking condition 3453FED3-F12C-4269-8764-A00A112CE736 - String Is Condition
12/05/2012 14:14:35PM - Checking to see if <%urlvalid%> is false
12/05/2012 14:14:35PM - ** Checking to see if 1 is false
12/05/2012 14:14:35PM - Condition failed
12/05/2012 14:14:35PM - Skipping action C1E448F1-BD23-4DD5-9FF9-8E11158807DF - Message Box - conditions failed
12/05/2012 14:14:35PM - Checking conditions for 71F8EAC7-5609-4AEA-8F4F-768F4F3F368E - - Before Action is Executed
12/05/2012 14:14:35PM - Checking condition F544F20F-E254-4294-8FEF-212A59160A67 - String Is Condition
12/05/2012 14:14:35PM - Skipping action 71F8EAC7-5609-4AEA-8F4F-768F4F3F368E - Exit - conditions failed
12/05/2012 14:14:35PM - Executing action 3CCF8B69-1442-40BA-96AF-881813C67920 - Set Variables
12/05/2012 14:14:35PM - Checking conditions for C51982FE-9BDA-48CD-95BF-A6B70A993729 - - Before Action is Executed
12/05/2012 14:14:35PM - Checking condition 11E9FD2B-B3DE-49F8-9D69-853C25E16B47 - String Is Condition
12/05/2012 14:14:35PM - Checking to see if <%ComponentInstaller%> is true
12/05/2012 14:14:35PM - ** Checking to see if false is true
12/05/2012 14:14:35PM - Skipping action C51982FE-9BDA-48CD-95BF-A6B70A993729 - Execute Write ComponentInstaller config file - conditions failed
12/05/2012 14:14:35PM - Checking conditions for 6D4C31EA-783A-4805-8548-6089DBCF461E - - Before Action is Executed
12/05/2012 14:14:35PM - Checking condition ED229D09-4C22-4629-A526-48481FFDBEDB - String Is Condition
12/05/2012 14:14:35PM - Checking to see if <%ComponentInstaller%> is false
12/05/2012 14:14:35PM - ** Checking to see if false is false
12/05/2012 14:14:35PM - Executing action 6D4C31EA-783A-4805-8548-6089DBCF461E - Execute Write CCS Config File
12/05/2012 14:14:35PM - Executing actions A085CE76-4DD6-4499-9194-CA7BF3E1B747 - Write ccs_config.xml File
12/05/2012 14:14:35PM - Executing action A085CE76-4DD6-4499-9194-CA7BF3E1B747 - Write ccs_config.xml File
12/05/2012 14:14:35PM - ccs_config: Installedfeatures
12/05/2012 14:14:35PM - components: EMU_BH {JTAG Emulator Support} CGT_DEFAULTLIBS_C2800 {Compiler Tools} TC_BIOS5 {DSP/BIOS v5} DVT_MIN {Base Installation} TC_C6000_BIOS6 {SYS/BIOS v6} TC_ARM_IPC {SYS/BIOS v6} TC_BIOS6 {SYS/BIOS v6} IDE {Base Installation} DMED Documentation KEYSTONE1 {JTAG Emulator Support} EMU_TI {JTAG Emulator Support} EMU_SD {JTAG Emulator Support} CCSINIT {Base Installation} SIM_TI Simulators TC_C2000_IPC {SYS/BIOS v6} DS {Base Installation} UIA {SYS/BIOS v6} CGT_DEFAULTLIBS_C5400 {Compiler Tools} TC_XDCTOOLS_BIOS5 {DSP/BIOS v5} EMU_NOWFLASH {JTAG Emulator Support} EMU_C2000_FLASH {JTAG Emulator Support} TC_ARM_BIOS6 {SYS/BIOS v6} CGT_DEFAULTLIBS_C5500 {Compiler Tools} TC_XDAIS_BIOS5 {DSP/BIOS v5} ARM_RSE {Base Installation} C6FLO C6FLO TC_C6000_IPC {SYS/BIOS v6} TC_C2000_XDCTOOLS {SYS/BIOS v6} CGT_DEFAULTLIBS_TMS470 {Compiler Tools} TC_IPC {SYS/BIOS v6} EMU_C2000 {JTAG Emulator Support} ARM_QT {Base Installation} CGT_DEFAULTLIBS_C6000 {Compiler Tools} TC_C2000_BIOS6 {SYS/BIOS v6} TC_ARM_XDCTOOLS {SYS/BIOS v6} DVT {Base Installation} TC_C6000_XDCTOOLS {SYS/BIOS v6} TC_XDCTOOLS {SYS/BIOS v6} TC_XDAIS {SYS/BIOS v6}
12/05/2012 14:14:35PM - not skipping AMxx Cortex-A and ARM9 processors
12/05/2012 14:14:35PM - Looking for arm
12/05/2012 14:14:35PM - /noc2400 /noc2800 /noc5400 /noc5500 /noc6000 /noomap /nodavinci
12/05/2012 14:14:35PM - writing ccs_config file: JRE
12/05/2012 14:14:35PM - writing ccs_config file: ECLIPSE
12/05/2012 14:14:35PM - writing ccs_config file: P2TOOLS
12/05/2012 14:14:35PM - writing ccs_config file: INSTALL_JAR
12/05/2012 14:14:35PM - writing ccs_config file: INSTALLER
12/05/2012 14:14:35PM - writing ccs_config file: DS
12/05/2012 14:14:35PM - ccs_config: searching for DS in
12/05/2012 14:14:35PM - DS is new
12/05/2012 14:14:35PM - DS is selected
12/05/2012 14:14:35PM - adding size 31
12/05/2012 14:14:35PM - binary = ti_dspack_setup_5.1.0.539.bin downloaded
12/05/2012 14:14:35PM - adding DS to JRE ECLIPSE P2TOOLS INSTALL_JAR INSTALLER
12/05/2012 14:14:35PM - writing ccs_config file: CGT_DEFAULTLIBS_C2800
12/05/2012 14:14:35PM - ccs_config: searching for CGT_DEFAULTLIBS_C2800 in
12/05/2012 14:14:35PM - CGT_DEFAULTLIBS_C2800 is new
12/05/2012 14:14:35PM - CGT_DEFAULTLIBS_C2800 is not selected
12/05/2012 14:14:35PM - binary = ti_cgt_c2000_6.0.2_setup_linux_x86.bin do not install
12/05/2012 14:14:35PM - writing ccs_config file: CGT_DEFAULTLIBS_C5400
12/05/2012 14:14:35PM - ccs_config: searching for CGT_DEFAULTLIBS_C5400 in
12/05/2012 14:14:35PM - CGT_DEFAULTLIBS_C5400 is new
12/05/2012 14:14:35PM - CGT_DEFAULTLIBS_C5400 is not selected
12/05/2012 14:14:35PM - binary = ld_4_2_0.tar.gz do not install
12/05/2012 14:14:35PM - writing ccs_config file: CGT_DEFAULTLIBS_C5500
12/05/2012 14:14:35PM - ccs_config: searching for CGT_DEFAULTLIBS_C5500 in
12/05/2012 14:14:35PM - CGT_DEFAULTLIBS_C5500 is new
12/05/2012 14:14:35PM - CGT_DEFAULTLIBS_C5500 is not selected
12/05/2012 14:14:35PM - binary = ti_cgt_c5500_4.4.0_setup_linux_x86.bin do not install
12/05/2012 14:14:35PM - writing ccs_config file: CGT_DEFAULTLIBS_C6000
12/05/2012 14:14:35PM - ccs_config: searching for CGT_DEFAULTLIBS_C6000 in
12/05/2012 14:14:35PM - CGT_DEFAULTLIBS_C6000 is new
12/05/2012 14:14:35PM - CGT_DEFAULTLIBS_C6000 is not selected
12/05/2012 14:14:35PM - binary = ti_cgt_c6000_7.3.1_setup_linux_x86.bin do not install
12/05/2012 14:14:35PM - writing ccs_config file: CGT_DEFAULTLIBS_TMS470
12/05/2012 14:14:35PM - ccs_config: searching for CGT_DEFAULTLIBS_TMS470 in
12/05/2012 14:14:35PM - CGT_DEFAULTLIBS_TMS470 is new
12/05/2012 14:14:35PM - CGT_DEFAULTLIBS_TMS470 is not selected
12/05/2012 14:14:35PM - binary = ti_cgt_tms470_4.9.1_setup_linux_x86.bin do not install
12/05/2012 14:14:35PM - writing ccs_config file: IDE
12/05/2012 14:14:35PM - ccs_config: searching for IDE in
12/05/2012 14:14:35PM - IDE is new
12/05/2012 14:14:35PM - IDE is selected
12/05/2012 14:14:35PM - adding size 14
12/05/2012 14:14:35PM - binary = idecore_setup_5.1.1.N201201061800.bin downloaded
12/05/2012 14:14:35PM - adding IDE to JRE ECLIPSE P2TOOLS INSTALL_JAR INSTALLER DS
12/05/2012 14:14:35PM - writing ccs_config file: DVT
12/05/2012 14:14:35PM - ccs_config: searching for DVT in
12/05/2012 14:14:35PM - DVT is new
12/05/2012 14:14:35PM - DVT is selected
12/05/2012 14:14:35PM - adding size 32
12/05/2012 14:14:35PM - binary = ti_dvt_setup_3.1.0.201201192237.bin downloaded
12/05/2012 14:14:35PM - adding DVT to JRE ECLIPSE P2TOOLS INSTALL_JAR INSTALLER DS IDE
12/05/2012 14:14:35PM - writing ccs_config file: DVT_MIN
12/05/2012 14:14:35PM - ccs_config: searching for DVT_MIN in
12/05/2012 14:14:35PM - DVT_MIN is new
12/05/2012 14:14:35PM - DVT_MIN is not selected
12/05/2012 14:14:35PM - binary = ti_dvt_setup_mini_3.1.0.201201192237.bin do not install
12/05/2012 14:14:35PM - writing ccs_config file: TC_XDCTOOLS
12/05/2012 14:14:35PM - ccs_config: searching for TC_XDCTOOLS in
12/05/2012 14:14:35PM - TC_XDCTOOLS is new
12/05/2012 14:14:35PM - TC_XDCTOOLS is not selected
12/05/2012 14:14:35PM - binary = xdctools_3_22_04_46_base_linux.zip do not install
12/05/2012 14:14:35PM - writing ccs_config file: TC_ARM_XDCTOOLS
12/05/2012 14:14:35PM - ccs_config: searching for TC_ARM_XDCTOOLS in
12/05/2012 14:14:35PM - TC_ARM_XDCTOOLS is new
12/05/2012 14:14:35PM - TC_ARM_XDCTOOLS is not selected
12/05/2012 14:14:35PM - binary = xdctools_3_22_04_46_arm.zip do not install
12/05/2012 14:14:35PM - writing ccs_config file: TC_C2000_XDCTOOLS
12/05/2012 14:14:35PM - ccs_config: searching for TC_C2000_XDCTOOLS in
12/05/2012 14:14:35PM - TC_C2000_XDCTOOLS is new
12/05/2012 14:14:35PM - TC_C2000_XDCTOOLS is not selected
12/05/2012 14:14:35PM - binary = xdctools_3_22_04_46_c2000.zip do not install
12/05/2012 14:14:35PM - writing ccs_config file: TC_C6000_XDCTOOLS
12/05/2012 14:14:35PM - ccs_config: searching for TC_C6000_XDCTOOLS in
12/05/2012 14:14:35PM - TC_C6000_XDCTOOLS is new
12/05/2012 14:14:35PM - TC_C6000_XDCTOOLS is not selected
12/05/2012 14:14:35PM - binary = xdctools_3_22_04_46_c6000.zip do not install
12/05/2012 14:14:35PM - writing ccs_config file: TC_BIOS5
12/05/2012 14:14:35PM - ccs_config: searching for TC_BIOS5 in
12/05/2012 14:14:35PM - TC_BIOS5 is new
12/05/2012 14:14:35PM - TC_BIOS5 is not selected
12/05/2012 14:14:35PM - binary = bios_setuplinux_5_41_11_38.bin do not install
12/05/2012 14:14:35PM - writing ccs_config file: TC_BIOS6
12/05/2012 14:14:35PM - ccs_config: searching for TC_BIOS6 in
12/05/2012 14:14:35PM - TC_BIOS6 is new
12/05/2012 14:14:35PM - TC_BIOS6 is not selected
12/05/2012 14:14:35PM - binary = bios_6_32_05_54_base.zip do not install
12/05/2012 14:14:35PM - writing ccs_config file: TC_ARM_BIOS6
12/05/2012 14:14:35PM - ccs_config: searching for TC_ARM_BIOS6 in
12/05/2012 14:14:35PM - TC_ARM_BIOS6 is new
12/05/2012 14:14:35PM - TC_ARM_BIOS6 is not selected
12/05/2012 14:14:35PM - binary = bios_6_32_05_54_arm.zip do not install
12/05/2012 14:14:35PM - writing ccs_config file: TC_C2000_BIOS6
12/05/2012 14:14:35PM - ccs_config: searching for TC_C2000_BIOS6 in
12/05/2012 14:14:35PM - TC_C2000_BIOS6 is new
12/05/2012 14:14:35PM - TC_C2000_BIOS6 is not selected
12/05/2012 14:14:35PM - binary = bios_6_32_05_54_c2000.zip do not install
12/05/2012 14:14:35PM - writing ccs_config file: TC_C6000_BIOS6
12/05/2012 14:14:35PM - ccs_config: searching for TC_C6000_BIOS6 in
12/05/2012 14:14:35PM - TC_C6000_BIOS6 is new
12/05/2012 14:14:35PM - TC_C6000_BIOS6 is not selected
12/05/2012 14:14:35PM - binary = bios_6_32_05_54_c6000.zip do not install
12/05/2012 14:14:35PM - writing ccs_config file: TC_IPC
12/05/2012 14:14:35PM - ccs_config: searching for TC_IPC in
12/05/2012 14:14:35PM - TC_IPC is new
12/05/2012 14:14:35PM - TC_IPC is not selected
12/05/2012 14:14:35PM - binary = ipc_1_23_05_40_base.zip do not install
12/05/2012 14:14:35PM - writing ccs_config file: TC_ARM_IPC
12/05/2012 14:14:35PM - ccs_config: searching for TC_ARM_IPC in
12/05/2012 14:14:35PM - TC_ARM_IPC is new
12/05/2012 14:14:35PM - TC_ARM_IPC is not selected
12/05/2012 14:14:35PM - binary = ipc_1_23_05_40_arm.zip do not install
12/05/2012 14:14:35PM - writing ccs_config file: TC_C2000_IPC
12/05/2012 14:14:35PM - ccs_config: searching for TC_C2000_IPC in
12/05/2012 14:14:35PM - TC_C2000_IPC is new
12/05/2012 14:14:35PM - TC_C2000_IPC is not selected
12/05/2012 14:14:35PM - binary = ipc_1_23_05_40_c2000.zip do not install
12/05/2012 14:14:35PM - writing ccs_config file: TC_C6000_IPC
12/05/2012 14:14:35PM - ccs_config: searching for TC_C6000_IPC in
12/05/2012 14:14:35PM - TC_C6000_IPC is new
12/05/2012 14:14:35PM - TC_C6000_IPC is not selected
12/05/2012 14:14:35PM - binary = ipc_1_23_05_40_c6000.zip do not install
12/05/2012 14:14:35PM - writing ccs_config file: TC_XDAIS
12/05/2012 14:14:35PM - ccs_config: searching for TC_XDAIS in
12/05/2012 14:14:35PM - TC_XDAIS is new
12/05/2012 14:14:35PM - TC_XDAIS is not selected
12/05/2012 14:14:35PM - binary = xdais_7_21_01_07.tar.gz do not install
12/05/2012 14:14:35PM - writing ccs_config file: UIA
12/05/2012 14:14:35PM - ccs_config: searching for UIA in
12/05/2012 14:14:35PM - UIA is new
12/05/2012 14:14:35PM - UIA is not selected
12/05/2012 14:14:35PM - binary = uia_1_00_03_25.zip do not install
12/05/2012 14:14:35PM - writing ccs_config file: CCSINIT
12/05/2012 14:14:35PM - ccs_config: searching for CCSINIT in
12/05/2012 14:14:35PM - CCSINIT is new
12/05/2012 14:14:35PM - CCSINIT is selected
12/05/2012 14:14:35PM - binary = ccsinit_setup_5.1.0.0.bin downloaded
12/05/2012 14:14:35PM - adding CCSINIT to JRE ECLIPSE P2TOOLS INSTALL_JAR INSTALLER DS IDE DVT
12/05/2012 14:14:35PM - writing ccs_config file: C6FLO
12/05/2012 14:14:35PM - ccs_config: searching for C6FLO in
12/05/2012 14:14:35PM - C6FLO is new
12/05/2012 14:14:35PM - C6FLO is not selected
12/05/2012 14:14:35PM - binary = ti_c6flo_setup_3.1.0.201201192237.bin do not install
12/05/2012 14:14:35PM - writing ccs_config file: SIM_TI
12/05/2012 14:14:35PM - ccs_config: searching for SIM_TI in
12/05/2012 14:14:35PM - SIM_TI is new
12/05/2012 14:14:35PM - SIM_TI is not selected
12/05/2012 14:14:35PM - binary = ti_simpack_setup_3.7.1.0.bin do not install
12/05/2012 14:14:35PM - writing ccs_config file: EMU_BH
12/05/2012 14:14:35PM - ccs_config: searching for EMU_BH in
12/05/2012 14:14:35PM - EMU_BH is new
12/05/2012 14:14:35PM - EMU_BH is not selected
12/05/2012 14:14:35PM - binary = bh_emupack_setup_5.1.0.106.bin do not install
12/05/2012 14:14:35PM - writing ccs_config file: EMU_TI
12/05/2012 14:14:35PM - ccs_config: searching for EMU_TI in
12/05/2012 14:14:35PM - EMU_TI is new
12/05/2012 14:14:35PM - EMU_TI is selected
12/05/2012 14:14:35PM - adding size 25
12/05/2012 14:14:35PM - binary = ti_emupack_setup_5.0.623.0.bin downloaded
12/05/2012 14:14:35PM - adding EMU_TI to JRE ECLIPSE P2TOOLS INSTALL_JAR INSTALLER DS IDE DVT CCSINIT
12/05/2012 14:14:35PM - in ccs_config: EMU_TI: checking ::info(Check_XDS100_Class_Emulator_Support)
12/05/2012 14:14:35PM - writing ccs_config file: EMU_HERCULES
12/05/2012 14:14:35PM - ccs_config: searching for EMU_HERCULES in
12/05/2012 14:14:35PM - EMU_HERCULES is new
12/05/2012 14:14:35PM - EMU_HERCULES is not selected
12/05/2012 14:14:35PM - binary = ti_hercules_setup_4.2.4.0002.bin do not install
12/05/2012 14:14:35PM - writing ccs_config file: EMU_SD
12/05/2012 14:14:35PM - ccs_config: searching for EMU_SD in
12/05/2012 14:14:35PM - EMU_SD is new
12/05/2012 14:14:35PM - EMU_SD is not selected
12/05/2012 14:14:35PM - binary = sd_emupack_setup_5.1.1.06.bin do not install
12/05/2012 14:14:35PM - writing ccs_config file: EMU_C2000
12/05/2012 14:14:35PM - ccs_config: searching for EMU_C2000 in
12/05/2012 14:14:35PM - EMU_C2000 is new
12/05/2012 14:14:35PM - EMU_C2000 is not selected
12/05/2012 14:14:35PM - binary = ti_c2000support_setup_3.0.0.14.bin do not install
12/05/2012 14:14:35PM - writing ccs_config file: EMU_C2000_FLASH
12/05/2012 14:14:35PM - ccs_config: searching for EMU_C2000_FLASH in
12/05/2012 14:14:35PM - EMU_C2000_FLASH is new
12/05/2012 14:14:35PM - EMU_C2000_FLASH is not selected
12/05/2012 14:14:35PM - binary = ti_c2000_flash_setup_1.0.0.2.bin do not install
12/05/2012 14:14:35PM - writing ccs_config file: EMU_NOWFLASH
12/05/2012 14:14:35PM - ccs_config: searching for EMU_NOWFLASH in
12/05/2012 14:14:35PM - EMU_NOWFLASH is new
12/05/2012 14:14:35PM - EMU_NOWFLASH is not selected
12/05/2012 14:14:35PM - binary = ti_ccsnowflash_setup_5.1.0.0.bin do not install
12/05/2012 14:14:35PM - writing ccs_config file: KEYSTONE1
12/05/2012 14:14:35PM - ccs_config: searching for KEYSTONE1 in
12/05/2012 14:14:35PM - KEYSTONE1 is new
12/05/2012 14:14:35PM - KEYSTONE1 is not selected
12/05/2012 14:14:35PM - binary = ti_emupack_keystone1_setup_1.0.0.1.bin do not install
12/05/2012 14:14:35PM - writing ccs_config file: DMED
12/05/2012 14:14:35PM - ccs_config: searching for DMED in
12/05/2012 14:14:35PM - DMED is new
12/05/2012 14:14:35PM - DMED is not selected
12/05/2012 14:14:35PM - binary = ti_cgt_dmed_setup_1.0.0.0.bin do not install
12/05/2012 14:14:35PM - writing ccs_config file: ARM_QT
12/05/2012 14:14:35PM - ccs_config: searching for ARM_QT in
12/05/2012 14:14:35PM - ARM_QT is new
12/05/2012 14:14:35PM - ARM_QT is selected
12/05/2012 14:14:35PM - adding size 23
12/05/2012 14:14:35PM - binary = qt-eclipse-integration-linux.x86-1.6.1.tar.gz downloaded
12/05/2012 14:14:35PM - adding ARM_QT to JRE ECLIPSE P2TOOLS INSTALL_JAR INSTALLER DS IDE DVT CCSINIT EMU_TI
12/05/2012 14:14:35PM - writing ccs_config file: ARM_RSE
12/05/2012 14:14:35PM - ccs_config: searching for ARM_RSE in
12/05/2012 14:14:35PM - ARM_RSE is new
12/05/2012 14:14:35PM - ARM_RSE is selected
12/05/2012 14:14:35PM - adding size 0
12/05/2012 14:14:35PM - binary = downloaded
12/05/2012 14:14:35PM - adding ARM_RSE to JRE ECLIPSE P2TOOLS INSTALL_JAR INSTALLER DS IDE DVT CCSINIT EMU_TI ARM_QT
12/05/2012 14:14:35PM - components verified: JRE ECLIPSE P2TOOLS INSTALL_JAR INSTALLER DS CGT_DEFAULTLIBS_C2800 CGT_DEFAULTLIBS_C5400 CGT_DEFAULTLIBS_C5500 CGT_DEFAULTLIBS_C6000 CGT_DEFAULTLIBS_TMS470 IDE DVT DVT_MIN TC_XDCTOOLS TC_XDCTOOLS_BIOS5 TC_ARM_XDCTOOLS TC_C2000_XDCTOOLS TC_C6000_XDCTOOLS TC_BIOS5 TC_BIOS6 TC_ARM_BIOS6 TC_C2000_BIOS6 TC_C6000_BIOS6 TC_IPC TC_ARM_IPC TC_C2000_IPC TC_C6000_IPC TC_XDAIS TC_XDAIS_BIOS5 UIA CCSINIT C6FLO SIM_TI EMU_BH EMU_TI EMU_HERCULES EMU_SD EMU_C2000 EMU_C2000_FLASH EMU_NOWFLASH KEYSTONE1 DMED ARM_QT ARM_RSE
12/05/2012 14:14:35PM - adding feature list: JRE ECLIPSE P2TOOLS INSTALL_JAR INSTALLER DS IDE DVT CCSINIT EMU_TI ARM_QT ARM_RSE
12/05/2012 14:14:35PM - adding Product families:
12/05/2012 14:14:35PM - adding product AMxx Cortex-A and ARM9 processors
12/05/2012 14:14:35PM - Executing action D00567AE-1434-413D-BBF9-B3F78DF98BF1 - Copy File
12/05/2012 14:14:35PM - Executing action F5F4E6DF-AFC2-48DD-A525-BDAB727CEC7A - Execute CCSExternalReferences Action
12/05/2012 14:14:35PM - Executing actions C7F8AE2D-4F72-4319-B4C3-CF1603BB148D - CCSExternalReferences Action
12/05/2012 14:14:35PM - Checking conditions for DD6015AF-17F4-4949-9688-1198E22040F4 - - Before Action is Executed
12/05/2012 14:14:35PM - Checking condition 21BB6A65-EF62-4E0D-907A-BF0C9EA94CFD - String Is Condition
12/05/2012 14:14:35PM - Executing action DD6015AF-17F4-4949-9688-1198E22040F4 - Write CCSExternalReferences
12/05/2012 14:14:35PM - Executing action EFFD310B-8A6E-49ED-9BBF-DB3EB1CED639 - Set msp430ware values
12/05/2012 14:14:35PM - Checking conditions for 83C5A9F1-B42C-43BC-BD3F-6F09F561DA64 - - Before Action is Executed
12/05/2012 14:14:35PM - Checking condition 6FA5C6EA-EF06-4F77-BB01-282BA316028B - String Is Condition
12/05/2012 14:14:35PM - Checking to see if <%runmsp430ware%> is true
12/05/2012 14:14:35PM - Skipping action 83C5A9F1-B42C-43BC-BD3F-6F09F561DA64 - Write CCSExternalReferences (msp430ware) - conditions failed
12/05/2012 14:14:35PM - Checking conditions for 1C99078C-C159-4C77-BE06-97B942144836 - - Before Action is Executed
12/05/2012 14:14:35PM - Checking condition 47ECC960-3F3F-4749-9320-1946A3F9CBEB - String Is Condition
12/05/2012 14:14:35PM - Executing action 1C99078C-C159-4C77-BE06-97B942144836 - Write ccs.properties
12/05/2012 14:14:35PM - Checking conditions for E199035E-3D19-49EE-8EA4-03DB8ED790DC - - Before Action is Executed
12/05/2012 14:14:35PM - Checking condition 1812B83A-DC51-4100-A3BC-B96979C230E0 - String Is Condition
12/05/2012 14:14:35PM - Checking to see if <%GuiMode%> is true
12/05/2012 14:14:35PM - ** Checking to see if 1 is true
12/05/2012 14:14:35PM - Executing action E199035E-3D19-49EE-8EA4-03DB8ED790DC - Modify Widget
12/05/2012 14:14:35PM - Executing action 8FBEA532-434F-44FD-A478-7B798F8433E6 - Create eclipse downloads folder
12/05/2012 14:14:35PM - Executing action 8BD9A50E-7A86-49F7-B6F6-B2E6374E3163 - Write Installjammer running text file
12/05/2012 14:14:35PM - Executing action D94E95BD-30CD-41B0-916A-05E71BCFD015 - Run LightweightInstaller
12/05/2012 14:14:35PM - Executing with progressive output
12/05/2012 14:14:35PM - Watching progressive output for special syntax.
12/05/2012 14:14:35PM - Executing Command Line: /home/dell/Desktop/Shared/sitara/ti/ccsv5/eclipse/eclipse -application com.ti.ccstudio.install.parser.lightWeightInstaller /home/dell/Desktop/Shared/sitara/ti/ccsv5/eclipse/ccs_config.xml debug -nosplash
12/05/2012 14:14:35PM - Watching progressive output for matches
12/05/2012 14:14:46PM - Download duration is 0
12/05/2012 14:14:46PM - Registering com.ti.ccstudio.debugserver.linux
12/05/2012 14:14:46PM - Eclipse register cmd feature /home/dell/Desktop/Shared/CCS-5.1.1.00033-Sitara-ARM/CCS/featurerepo repository found
12/05/2012 14:14:46PM - Register Operaton com.ti.ccstudio.debugserver.linux
12/05/2012 14:14:47PM - Install Operation resolved
12/05/2012 14:15:08PM - Install Operation provisioning job successful
12/05/2012 14:15:08PM - Install feature successful for feature :com.ti.ccstudio.debugserver.linux
12/05/2012 14:15:08PM - 13
12/05/2012 14:15:08PM - Registering com.ti.ccstudio.ide.linux
12/05/2012 14:15:08PM - Eclipse register cmd feature /home/dell/Desktop/Shared/CCS-5.1.1.00033-Sitara-ARM/CCS/featurerepo repository found
12/05/2012 14:15:08PM - Register Operaton com.ti.ccstudio.ide.linux
12/05/2012 14:15:08PM - Install Operation resolved
12/05/2012 14:15:21PM - Install Operation provisioning job successful
12/05/2012 14:15:21PM - Install feature successful for feature :com.ti.ccstudio.ide.linux
12/05/2012 14:15:22PM - 14
12/05/2012 14:15:22PM - Registering com.ti.dvt.linux
12/05/2012 14:15:22PM - Eclipse register cmd feature /home/dell/Desktop/Shared/CCS-5.1.1.00033-Sitara-ARM/CCS/featurerepo repository found
12/05/2012 14:15:22PM - Register Operaton com.ti.dvt.linux
12/05/2012 14:15:22PM - Install Operation resolved
12/05/2012 14:15:42PM - Install Operation provisioning job successful
12/05/2012 14:15:42PM - Install feature successful for feature :com.ti.dvt.linux
12/05/2012 14:15:42PM - 16
12/05/2012 14:15:42PM - Registering com.ti.ccstudio.ccsinit.linux
12/05/2012 14:15:42PM - Eclipse register cmd feature /home/dell/Desktop/Shared/CCS-5.1.1.00033-Sitara-ARM/CCS/featurerepo repository found
12/05/2012 14:15:42PM - Register Operaton com.ti.ccstudio.ccsinit.linux
12/05/2012 14:15:42PM - Install Operation resolved
12/05/2012 14:15:51PM - Install Operation provisioning job successful
12/05/2012 14:15:51PM - Install feature successful for feature :com.ti.ccstudio.ccsinit.linux
12/05/2012 14:15:51PM - 16
12/05/2012 14:15:51PM - Registering com.ti.emulation.pack.linux
12/05/2012 14:15:52PM - Eclipse register cmd feature /home/dell/Desktop/Shared/CCS-5.1.1.00033-Sitara-ARM/CCS/featurerepo repository found
12/05/2012 14:15:52PM - Register Operaton com.ti.emulation.pack.linux
12/05/2012 14:15:52PM - Install Operation resolved
12/05/2012 14:16:09PM - Install Operation provisioning job successful
12/05/2012 14:16:09PM - Install feature successful for feature :com.ti.emulation.pack.linux
12/05/2012 14:16:09PM - 17
12/05/2012 14:16:09PM - Registering com.ti.trolltech.qtcpp
12/05/2012 14:16:09PM - Eclipse register cmd feature /home/dell/Desktop/Shared/CCS-5.1.1.00033-Sitara-ARM/CCS/featurerepo repository found
12/05/2012 14:16:09PM - Register Operaton com.ti.trolltech.qtcpp
12/05/2012 14:16:09PM - Install Operation resolved
12/05/2012 14:16:26PM - Install Operation provisioning job successful
12/05/2012 14:16:26PM - Install feature successful for feature :com.ti.trolltech.qtcpp
12/05/2012 14:16:26PM - 18
12/05/2012 14:16:26PM - Registering org.eclipse.rse
12/05/2012 14:16:26PM - Eclipse register cmd feature /home/dell/Desktop/Shared/CCS-5.1.1.00033-Sitara-ARM/CCS/featurerepo repository found
12/05/2012 14:16:26PM - Retry uninstall with cmd line call
12/05/2012 14:16:26PM - runInstallCmd on repo:/home/dell/Desktop/Shared/CCS-5.1.1.00033-Sitara-ARM/CCS/featurerepo UIorg.eclipse.rse
12/05/2012 14:16:26PM - runCmd:;/home/dell/Desktop/Shared/sitara/ti/ccsv5/eclipse/eclipse,-nosplash,-application,org.eclipse.equinox.p2.director,-repository,file:/home/dell/Desktop/Shared/CCS-5.1.1.00033-Sitara-ARM/CCS/featurerepo,-u,org.eclipse.rse.feature.group,
12/05/2012 14:16:36PM - Uninstalling org.eclipse.rse.feature.group 3.3.1.R33x_v201109141647-7L7CFGG8wqio8rz0qYtkPgn8qWd4.
12/05/2012 14:16:37PM - Operation completed in 1405 ms.
12/05/2012 14:16:37PM - runInstallCmd on repo:/home/dell/Desktop/Shared/CCS-5.1.1.00033-Sitara-ARM/CCS/featurerepo UIorg.eclipse.rse
12/05/2012 14:16:37PM - runCmd:;/home/dell/Desktop/Shared/sitara/ti/ccsv5/eclipse/eclipse,-nosplash,-application,org.eclipse.equinox.p2.director,-repository,file:/home/dell/Desktop/Shared/CCS-5.1.1.00033-Sitara-ARM/CCS/featurerepo,-installIU,org.eclipse.rse.feature.group,
12/05/2012 14:16:42PM - Installing org.eclipse.rse.feature.group 3.3.1.R33x_v201109141647-7L7CFGG8wqio8rz0qYtkPgn8qWd4.
12/05/2012 14:16:43PM - Operation completed in 2017 ms.
12/05/2012 14:16:43PM - Install feature successful for feature :org.eclipse.rse
12/05/2012 14:16:43PM - 18
12/05/2012 14:16:44PM - Registering duration is 117923
12/05/2012 14:16:44PM - Installing com.ti.ccstudio.debugserver.linux executable
12/05/2012 14:16:44PM - Installing ti_dspack_setup_5.1.0.539.bin
12/05/2012 14:16:44PM - Install Exec phase for feature :com.ti.ccstudio.debugserver.linuxExec:ti_dspack_setup_5.1.0.539.bin,--mode,silent,--prefix,/home/dell/Desktop/Shared/sitara/ti/ccsv5/ccs_base,--prefix2,/home/dell/Desktop/Shared/sitara/ti/ccsv5/eclipse
12/05/2012 14:16:44PM - runCmd:;/home/dell/Desktop/Shared/sitara/ti/ccsv5/eclipse/downloads/ti_dspack_setup_5.1.0.539.bin,--mode,silent,--prefix,/home/dell/Desktop/Shared/sitara/ti/ccsv5/ccs_base,--prefix2,/home/dell/Desktop/Shared/sitara/ti/ccsv5/eclipse,
12/05/2012 14:18:35PM - Install Exec successful for feature :com.ti.ccstudio.debugserver.linux
12/05/2012 14:18:35PM - 26
12/05/2012 14:18:35PM - Installing com.ti.ccstudio.ide.linux executable
12/05/2012 14:18:35PM - Installing idecore_setup_5.1.1.N201201061800.bin
12/05/2012 14:18:35PM - Install Exec phase for feature :com.ti.ccstudio.ide.linuxExec:idecore_setup_5.1.1.N201201061800.bin,--mode,silent,/noc2400,/noc2800,/noc5400,/noc5500,/noc6000,/noomap,/nodavinci,/nomsp430,--prefix,/home/dell/Desktop/Shared/sitara/ti/ccsv5
12/05/2012 14:18:35PM - runCmd:;/home/dell/Desktop/Shared/sitara/ti/ccsv5/eclipse/downloads/idecore_setup_5.1.1.N201201061800.bin,--mode,silent,/noc2400,/noc2800,/noc5400,/noc5500,/noc6000,/noomap,/nodavinci,/nomsp430,--prefix,/home/dell/Desktop/Shared/sitara/ti/ccsv5,
12/05/2012 14:19:53PM - Install Exec successful for feature :com.ti.ccstudio.ide.linux
12/05/2012 14:19:53PM - 29
12/05/2012 14:19:53PM - Installing com.ti.dvt.linux executable
12/05/2012 14:19:53PM - Installing ti_dvt_setup_3.1.0.201201192237.bin
12/05/2012 14:19:53PM - Install Exec phase for feature :com.ti.dvt.linuxExec:ti_dvt_setup_3.1.0.201201192237.bin,--mode,silent,/noc2400,/noc2800,/noc5400,/noc5500,/noc6000,/noomap,/nodavinci,/nomsp430,--prefix,/home/dell/Desktop/Shared/sitara/ti/ccsv5/ccs_base,--prefix2,/home/dell/Desktop/Shared/sitara/ti/ccsv5/eclipse
12/05/2012 14:19:53PM - runCmd:;/home/dell/Desktop/Shared/sitara/ti/ccsv5/eclipse/downloads/ti_dvt_setup_3.1.0.201201192237.bin,--mode,silent,/noc2400,/noc2800,/noc5400,/noc5500,/noc6000,/noomap,/nodavinci,/nomsp430,--prefix,/home/dell/Desktop/Shared/sitara/ti/ccsv5/ccs_base,--prefix2,/home/dell/Desktop/Shared/sitara/ti/ccsv5/eclipse,
12/05/2012 14:22:57PM - Install Exec successful for feature :com.ti.dvt.linux
12/05/2012 14:22:57PM - 37
12/05/2012 14:22:57PM - Installing com.ti.ccstudio.ccsinit.linux executable
12/05/2012 14:22:57PM - Installing ccsinit_setup_5.1.0.0.bin
12/05/2012 14:22:57PM - Install Exec phase for feature :com.ti.ccstudio.ccsinit.linuxExec:ccsinit_setup_5.1.0.0.bin,--mode,silent,--prefix,/home/dell/Desktop/Shared/sitara/ti/ccsv5,--eclipseprefix,/home/dell/Desktop/Shared/sitara/ti/ccsv5/eclipse
12/05/2012 14:22:57PM - runCmd:;/home/dell/Desktop/Shared/sitara/ti/ccsv5/eclipse/downloads/ccsinit_setup_5.1.0.0.bin,--mode,silent,--prefix,/home/dell/Desktop/Shared/sitara/ti/ccsv5,--eclipseprefix,/home/dell/Desktop/Shared/sitara/ti/ccsv5/eclipse,
12/05/2012 14:24:58PM - Install Exec successful for feature :com.ti.ccstudio.ccsinit.linux
12/05/2012 14:24:58PM - 37
12/05/2012 14:24:58PM - Installing com.ti.emulation.pack.linux executable
12/05/2012 14:24:58PM - Installing ti_emupack_setup_5.0.623.0.bin
12/05/2012 14:24:58PM - Install Exec phase for feature :com.ti.emulation.pack.linuxExec:ti_emupack_setup_5.0.623.0.bin,--mode,silent,/noc2400,/noc2800,/noc5400,/noc5500,/noc6000,/noomap,/nodavinci,--prefix,/home/dell/Desktop/Shared/sitara/ti/ccsv5/ccs_base,/noxds100
12/05/2012 14:24:58PM - runCmd:;/home/dell/Desktop/Shared/sitara/ti/ccsv5/eclipse/downloads/ti_emupack_setup_5.0.623.0.bin,--mode,silent,/noc2400,/noc2800,/noc5400,/noc5500,/noc6000,/noomap,/nodavinci,--prefix,/home/dell/Desktop/Shared/sitara/ti/ccsv5/ccs_base,/noxds100,
12/05/2012 14:25:40PM - Install Exec successful for feature :com.ti.emulation.pack.linux
12/05/2012 14:25:40PM - 43
12/05/2012 14:25:40PM - Installing com.ti.trolltech.qtcpp executable
12/05/2012 14:25:40PM - Installing qt-eclipse-integration-linux.x86-1.6.1.tar.gz
12/05/2012 14:25:40PM - Install Exec phase for feature :com.ti.trolltech.qtcppExec:qt-eclipse-integration-linux.x86-1.6.1.tar.gz,/home/dell/Desktop/Shared/sitara/ti/ccsv5/eclipse/dropins
12/05/2012 14:25:40PM - runCmd:;tar,-C,/home/dell/Desktop/Shared/sitara/ti/ccsv5/eclipse/dropins,-zpxvf,/home/dell/Desktop/Shared/sitara/ti/ccsv5/eclipse/downloads/qt-eclipse-integration-linux.x86-1.6.1.tar.gz,
12/05/2012 14:25:40PM - eclipse/
12/05/2012 14:25:40PM - eclipse/plugins/
12/05/2012 14:25:40PM - eclipse/plugins/com.trolltech.qtcpp_1.6.1.jar
12/05/2012 14:25:40PM - eclipse/plugins/com.trolltech.qtcppdesigner_1.6.1.jar
12/05/2012 14:25:40PM - eclipse/plugins/com.trolltech.qtcppdesigner.qtcpp_1.6.1.jar
12/05/2012 14:25:40PM - eclipse/plugins/com.trolltech.qtcppproject_1.6.1.jar
12/05/2012 14:25:40PM - eclipse/plugins/com.trolltech.qtcppintegrationhelp_1.6.1.jar
12/05/2012 14:25:40PM - eclipse/plugins/com.trolltech.qtcpp.linux.x86_4.6.1/
12/05/2012 14:25:40PM - eclipse/plugins/com.trolltech.qtcpp.linux.x86_4.6.1/.classpath
12/05/2012 14:25:40PM - eclipse/plugins/com.trolltech.qtcpp.linux.x86_4.6.1/.project
12/05/2012 14:25:40PM - eclipse/plugins/com.trolltech.qtcpp.linux.x86_4.6.1/build.properties
12/05/2012 14:25:40PM - eclipse/plugins/com.trolltech.qtcpp.linux.x86_4.6.1/META-INF/
12/05/2012 14:25:40PM - eclipse/plugins/com.trolltech.qtcpp.linux.x86_4.6.1/META-INF/MANIFEST.MF
12/05/2012 14:25:40PM - eclipse/plugins/com.trolltech.qtcpp.linux.x86_4.6.1/src/
12/05/2012 14:25:41PM - eclipse/plugins/com.trolltech.qtcpp.linux.x86_4.6.1/src/KEEPME
12/05/2012 14:25:41PM - eclipse/plugins/com.trolltech.qtcpp.linux.x86_4.6.1/lib/
12/05/2012 14:25:41PM - eclipse/plugins/com.trolltech.qtcpp.linux.x86_4.6.1/lib/libQtCoreCppIntegration.so
12/05/2012 14:25:41PM - tar: eclipse/plugins/com.trolltech.qtcpp.linux.x86_4.6.1/lib/libQtCoreCppIntegration.so: Cannot create symlink to `libQtCoreCppIntegration.so.4.6.1': Read-only file system
12/05/2012 14:25:41PM - eclipse/plugins/com.trolltech.qtcpp.linux.x86_4.6.1/lib/libQtCoreCppIntegration.so.4
12/05/2012 14:25:41PM - tar: eclipse/plugins/com.trolltech.qtcpp.linux.x86_4.6.1/lib/libQtCoreCppIntegration.so.4: Cannot create symlink to `libQtCoreCppIntegration.so.4.6.1': Read-only file system
12/05/2012 14:25:41PM - eclipse/plugins/com.trolltech.qtcpp.linux.x86_4.6.1/lib/libQtCoreCppIntegration.so.4.6
12/05/2012 14:25:41PM - tar: eclipse/plugins/com.trolltech.qtcpp.linux.x86_4.6.1/lib/libQtCoreCppIntegration.so.4.6: Cannot create symlink to `libQtCoreCppIntegration.so.4.6.1': Read-only file system
12/05/2012 14:25:41PM - eclipse/plugins/com.trolltech.qtcpp.linux.x86_4.6.1/lib/libQtCoreCppIntegration.so.4.6.1
12/05/2012 14:25:41PM - eclipse/plugins/com.trolltech.qtcpp.linux.x86_4.6.1/lib/libQtGuiCppIntegration.so
12/05/2012 14:25:41PM - tar: eclipse/plugins/com.trolltech.qtcpp.linux.x86_4.6.1/lib/libQtGuiCppIntegration.so: Cannot create symlink to `libQtGuiCppIntegration.so.4.6.1': Read-only file system
12/05/2012 14:25:41PM - eclipse/plugins/com.trolltech.qtcpp.linux.x86_4.6.1/lib/libQtGuiCppIntegration.so.4
12/05/2012 14:25:41PM - tar: eclipse/plugins/com.trolltech.qtcpp.linux.x86_4.6.1/lib/libQtGuiCppIntegration.so.4: Cannot create symlink to `libQtGuiCppIntegration.so.4.6.1': Read-only file system
12/05/2012 14:25:41PM - eclipse/plugins/com.trolltech.qtcpp.linux.x86_4.6.1/lib/libQtGuiCppIntegration.so.4.6
12/05/2012 14:25:41PM - tar: eclipse/plugins/com.trolltech.qtcpp.linux.x86_4.6.1/lib/libQtGuiCppIntegration.so.4.6: Cannot create symlink to `libQtGuiCppIntegration.so.4.6.1': Read-only file system
12/05/2012 14:25:41PM - eclipse/plugins/com.trolltech.qtcpp.linux.x86_4.6.1/lib/libQtGuiCppIntegration.so.4.6.1
12/05/2012 14:25:41PM - eclipse/plugins/com.trolltech.qtcpp.linux.x86_4.6.1/lib/libQtXmlCppIntegration.so
12/05/2012 14:25:41PM - tar: eclipse/plugins/com.trolltech.qtcpp.linux.x86_4.6.1/lib/libQtXmlCppIntegration.so: Cannot create symlink to `libQtXmlCppIntegration.so.4.6.1': Read-only file system
12/05/2012 14:25:41PM - eclipse/plugins/com.trolltech.qtcpp.linux.x86_4.6.1/lib/libQtXmlCppIntegration.so.4
12/05/2012 14:25:41PM - tar: eclipse/plugins/com.trolltech.qtcpp.linux.x86_4.6.1/lib/libQtXmlCppIntegration.so.4: Cannot create symlink to `libQtXmlCppIntegration.so.4.6.1': Read-only file system
12/05/2012 14:25:41PM - eclipse/plugins/com.trolltech.qtcpp.linux.x86_4.6.1/lib/libQtXmlCppIntegration.so.4.6
12/05/2012 14:25:41PM - tar: eclipse/plugins/com.trolltech.qtcpp.linux.x86_4.6.1/lib/libQtXmlCppIntegration.so.4.6: Cannot create symlink to `libQtXmlCppIntegration.so.4.6.1': Read-only file system
12/05/2012 14:25:41PM - eclipse/plugins/com.trolltech.qtcpp.linux.x86_4.6.1/lib/libQtXmlCppIntegration.so.4.6.1
12/05/2012 14:25:41PM - eclipse/plugins/com.trolltech.qtcpp.linux.x86_4.6.1/lib/libQtScriptCppIntegration.so
12/05/2012 14:25:41PM - tar: eclipse/plugins/com.trolltech.qtcpp.linux.x86_4.6.1/lib/libQtScriptCppIntegration.so: Cannot create symlink to `libQtScriptCppIntegration.so.4.6.1': Read-only file system
12/05/2012 14:25:41PM - eclipse/plugins/com.trolltech.qtcpp.linux.x86_4.6.1/lib/libQtScriptCppIntegration.so.4
12/05/2012 14:25:41PM - tar: eclipse/plugins/com.trolltech.qtcpp.linux.x86_4.6.1/lib/libQtScriptCppIntegration.so.4: Cannot create symlink to `libQtScriptCppIntegration.so.4.6.1': Read-only file system
12/05/2012 14:25:41PM - eclipse/plugins/com.trolltech.qtcpp.linux.x86_4.6.1/lib/libQtScriptCppIntegration.so.4.6
12/05/2012 14:25:41PM - tar: eclipse/plugins/com.trolltech.qtcpp.linux.x86_4.6.1/lib/libQtScriptCppIntegration.so.4.6: Cannot create symlink to `libQtScriptCppIntegration.so.4.6.1': Read-only file system
12/05/2012 14:25:41PM - eclipse/plugins/com.trolltech.qtcpp.linux.x86_4.6.1/lib/libQtScriptCppIntegration.so.4.6.1
12/05/2012 14:25:41PM - eclipse/plugins/com.trolltech.qtcpp.linux.x86_4.6.1/lib/libQtDesignerCppIntegration.so
12/05/2012 14:25:41PM - tar: eclipse/plugins/com.trolltech.qtcpp.linux.x86_4.6.1/lib/libQtDesignerCppIntegration.so: Cannot create symlink to `libQtDesignerCppIntegration.so.4.6.1': Read-only file system
12/05/2012 14:25:41PM - eclipse/plugins/com.trolltech.qtcpp.linux.x86_4.6.1/lib/libQtDesignerCppIntegration.so.4
12/05/2012 14:25:41PM - tar: eclipse/plugins/com.trolltech.qtcpp.linux.x86_4.6.1/lib/libQtDesignerCppIntegration.so.4: Cannot create symlink to `libQtDesignerCppIntegration.so.4.6.1': Read-only file system
12/05/2012 14:25:41PM - eclipse/plugins/com.trolltech.qtcpp.linux.x86_4.6.1/lib/libQtDesignerCppIntegration.so.4.6
12/05/2012 14:25:41PM - tar: eclipse/plugins/com.trolltech.qtcpp.linux.x86_4.6.1/lib/libQtDesignerCppIntegration.so.4.6: Cannot create symlink to `libQtDesignerCppIntegration.so.4.6.1': Read-only file system
12/05/2012 14:25:41PM - eclipse/plugins/com.trolltech.qtcpp.linux.x86_4.6.1/lib/libQtDesignerCppIntegration.so.4.6.1
12/05/2012 14:25:41PM - eclipse/plugins/com.trolltech.qtcpp.linux.x86_4.6.1/lib/libQtDesignerComponentsCppIntegration.so
12/05/2012 14:25:41PM - tar: eclipse/plugins/com.trolltech.qtcpp.linux.x86_4.6.1/lib/libQtDesignerComponentsCppIntegration.so: Cannot create symlink to `libQtDesignerComponentsCppIntegration.so.4.6.1': Read-only file system
12/05/2012 14:25:41PM - eclipse/plugins/com.trolltech.qtcpp.linux.x86_4.6.1/lib/libQtDesignerComponentsCppIntegration.so.4
12/05/2012 14:25:41PM - tar: eclipse/plugins/com.trolltech.qtcpp.linux.x86_4.6.1/lib/libQtDesignerComponentsCppIntegration.so.4: Cannot create symlink to `libQtDesignerComponentsCppIntegration.so.4.6.1': Read-only file system
12/05/2012 14:25:41PM - eclipse/plugins/com.trolltech.qtcpp.linux.x86_4.6.1/lib/libQtDesignerComponentsCppIntegration.so.4.6
12/05/2012 14:25:41PM - tar: eclipse/plugins/com.trolltech.qtcpp.linux.x86_4.6.1/lib/libQtDesignerComponentsCppIntegration.so.4.6: Cannot create symlink to `libQtDesignerComponentsCppIntegration.so.4.6.1': Read-only file system
12/05/2012 14:25:41PM - eclipse/plugins/com.trolltech.qtcpp.linux.x86_4.6.1/lib/libQtDesignerComponentsCppIntegration.so.4.6.1
12/05/2012 14:25:41PM - eclipse/plugins/com.trolltech.qtcppdesigner.linux.x86_1.6.1/
12/05/2012 14:25:41PM - eclipse/plugins/com.trolltech.qtcppdesigner.linux.x86_1.6.1/META-INF/
12/05/2012 14:25:41PM - eclipse/plugins/com.trolltech.qtcppdesigner.linux.x86_1.6.1/META-INF/MANIFEST.MF
12/05/2012 14:25:41PM - eclipse/plugins/com.trolltech.qtcppdesigner.linux.x86_1.6.1/bin/
12/05/2012 14:25:41PM - eclipse/plugins/com.trolltech.qtcppdesigner.linux.x86_1.6.1/bin/com/
12/05/2012 14:25:41PM - eclipse/plugins/com.trolltech.qtcppdesigner.linux.x86_1.6.1/bin/com/trolltech/
12/05/2012 14:25:41PM - eclipse/plugins/com.trolltech.qtcppdesigner.linux.x86_1.6.1/bin/com/trolltech/qtcppdesigner/
12/05/2012 14:25:41PM - eclipse/plugins/com.trolltech.qtcppdesigner.linux.x86_1.6.1/bin/com/trolltech/qtcppdesigner/views/
12/05/2012 14:25:41PM - eclipse/plugins/com.trolltech.qtcppdesigner.linux.x86_1.6.1/bin/com/trolltech/qtcppdesigner/views/embedded/
12/05/2012 14:25:41PM - eclipse/plugins/com.trolltech.qtcppdesigner.linux.x86_1.6.1/bin/com/trolltech/qtcppdesigner/views/embedded/ActionEditorW$1.class
12/05/2012 14:25:41PM - eclipse/plugins/com.trolltech.qtcppdesigner.linux.x86_1.6.1/bin/com/trolltech/qtcppdesigner/views/embedded/ActionEditorW$2.class
12/05/2012 14:25:41PM - eclipse/plugins/com.trolltech.qtcppdesigner.linux.x86_1.6.1/bin/com/trolltech/qtcppdesigner/views/embedded/ActionEditorW.class
12/05/2012 14:25:41PM - eclipse/plugins/com.trolltech.qtcppdesigner.linux.x86_1.6.1/bin/com/trolltech/qtcppdesigner/views/embedded/DesignerBridgeW$1.class
12/05/2012 14:25:42PM - eclipse/plugins/com.trolltech.qtcppdesigner.linux.x86_1.6.1/bin/com/trolltech/qtcppdesigner/views/embedded/DesignerBridgeW$2.class
12/05/2012 14:25:42PM - eclipse/plugins/com.trolltech.qtcppdesigner.linux.x86_1.6.1/bin/com/trolltech/qtcppdesigner/views/embedded/DesignerBridgeW.class
12/05/2012 14:25:42PM - eclipse/plugins/com.trolltech.qtcppdesigner.linux.x86_1.6.1/bin/com/trolltech/qtcppdesigner/views/embedded/FormWindowW$1.class
12/05/2012 14:25:42PM - eclipse/plugins/com.trolltech.qtcppdesigner.linux.x86_1.6.1/bin/com/trolltech/qtcppdesigner/views/embedded/FormWindowW$2.class
12/05/2012 14:25:42PM - eclipse/plugins/com.trolltech.qtcppdesigner.linux.x86_1.6.1/bin/com/trolltech/qtcppdesigner/views/embedded/FormWindowW.class
12/05/2012 14:25:42PM - eclipse/plugins/com.trolltech.qtcppdesigner.linux.x86_1.6.1/bin/com/trolltech/qtcppdesigner/views/embedded/FormWindowWListener.class
12/05/2012 14:25:42PM - eclipse/plugins/com.trolltech.qtcppdesigner.linux.x86_1.6.1/bin/com/trolltech/qtcppdesigner/views/embedded/KEEPME
12/05/2012 14:25:42PM - eclipse/plugins/com.trolltech.qtcppdesigner.linux.x86_1.6.1/bin/com/trolltech/qtcppdesigner/views/embedded/ObjectInspectorW$1.class
12/05/2012 14:25:42PM - eclipse/plugins/com.trolltech.qtcppdesigner.linux.x86_1.6.1/bin/com/trolltech/qtcppdesigner/views/embedded/ObjectInspectorW$2.class
12/05/2012 14:25:42PM - eclipse/plugins/com.trolltech.qtcppdesigner.linux.x86_1.6.1/bin/com/trolltech/qtcppdesigner/views/embedded/ObjectInspectorW.class
12/05/2012 14:25:42PM - eclipse/plugins/com.trolltech.qtcppdesigner.linux.x86_1.6.1/bin/com/trolltech/qtcppdesigner/views/embedded/PropertyEditorW$1.class
12/05/2012 14:25:42PM - eclipse/plugins/com.trolltech.qtcppdesigner.linux.x86_1.6.1/bin/com/trolltech/qtcppdesigner/views/embedded/PropertyEditorW$2.class
12/05/2012 14:25:42PM - eclipse/plugins/com.trolltech.qtcppdesigner.linux.x86_1.6.1/bin/com/trolltech/qtcppdesigner/views/embedded/PropertyEditorW.class
12/05/2012 14:25:42PM - eclipse/plugins/com.trolltech.qtcppdesigner.linux.x86_1.6.1/bin/com/trolltech/qtcppdesigner/views/embedded/ResourceEditorW$1.class
12/05/2012 14:25:42PM - eclipse/plugins/com.trolltech.qtcppdesigner.linux.x86_1.6.1/bin/com/trolltech/qtcppdesigner/views/embedded/ResourceEditorW$2.class
12/05/2012 14:25:42PM - eclipse/plugins/com.trolltech.qtcppdesigner.linux.x86_1.6.1/bin/com/trolltech/qtcppdesigner/views/embedded/ResourceEditorW.class
12/05/2012 14:25:42PM - eclipse/plugins/com.trolltech.qtcppdesigner.linux.x86_1.6.1/bin/com/trolltech/qtcppdesigner/views/embedded/SignalSlotEditorW$1.class
12/05/2012 14:25:42PM - eclipse/plugins/com.trolltech.qtcppdesigner.linux.x86_1.6.1/bin/com/trolltech/qtcppdesigner/views/embedded/SignalSlotEditorW$2.class
12/05/2012 14:25:42PM - eclipse/plugins/com.trolltech.qtcppdesigner.linux.x86_1.6.1/bin/com/trolltech/qtcppdesigner/views/embedded/SignalSlotEditorW.class
12/05/2012 14:25:42PM - eclipse/plugins/com.trolltech.qtcppdesigner.linux.x86_1.6.1/bin/com/trolltech/qtcppdesigner/views/embedded/WidgetBoxW$1.class
12/05/2012 14:25:42PM - eclipse/plugins/com.trolltech.qtcppdesigner.linux.x86_1.6.1/bin/com/trolltech/qtcppdesigner/views/embedded/WidgetBoxW$2.class
12/05/2012 14:25:42PM - eclipse/plugins/com.trolltech.qtcppdesigner.linux.x86_1.6.1/bin/com/trolltech/qtcppdesigner/views/embedded/WidgetBoxW.class
12/05/2012 14:25:42PM - eclipse/plugins/com.trolltech.qtcppdesigner.linux.x86_1.6.1/lib/
12/05/2012 14:25:42PM - eclipse/plugins/com.trolltech.qtcppdesigner.linux.x86_1.6.1/lib/libqtcppdesigner.so
12/05/2012 14:25:42PM - eclipse/plugins/com.trolltech.qtcppdesigner.linux.x86_1.6.1/plugin.xml
12/05/2012 14:25:42PM - eclipse/plugins/com.trolltech.qtcppproject.linux.x86_1.6.1/
12/05/2012 14:25:42PM - eclipse/plugins/com.trolltech.qtcppproject.linux.x86_1.6.1/META-INF/
12/05/2012 14:25:42PM - eclipse/plugins/com.trolltech.qtcppproject.linux.x86_1.6.1/META-INF/MANIFEST.MF
12/05/2012 14:25:42PM - eclipse/plugins/com.trolltech.qtcppproject.linux.x86_1.6.1/bin/
12/05/2012 14:25:42PM - eclipse/plugins/com.trolltech.qtcppproject.linux.x86_1.6.1/bin/com/
12/05/2012 14:25:42PM - eclipse/plugins/com.trolltech.qtcppproject.linux.x86_1.6.1/bin/com/trolltech/
12/05/2012 14:25:42PM - eclipse/plugins/com.trolltech.qtcppproject.linux.x86_1.6.1/bin/com/trolltech/qtcppproject/
12/05/2012 14:25:42PM - eclipse/plugins/com.trolltech.qtcppproject.linux.x86_1.6.1/bin/com/trolltech/qtcppproject/pages/
12/05/2012 14:25:42PM - eclipse/plugins/com.trolltech.qtcppproject.linux.x86_1.6.1/bin/com/trolltech/qtcppproject/pages/embedded/
12/05/2012 14:25:42PM - eclipse/plugins/com.trolltech.qtcppproject.linux.x86_1.6.1/bin/com/trolltech/qtcppproject/pages/embedded/KEEPME
12/05/2012 14:25:42PM - eclipse/plugins/com.trolltech.qtcppproject.linux.x86_1.6.1/bin/com/trolltech/qtcppproject/pages/embedded/QrcTreeView$1.class
12/05/2012 14:25:42PM - eclipse/plugins/com.trolltech.qtcppproject.linux.x86_1.6.1/bin/com/trolltech/qtcppproject/pages/embedded/QrcTreeView$2.class
12/05/2012 14:25:42PM - eclipse/plugins/com.trolltech.qtcppproject.linux.x86_1.6.1/bin/com/trolltech/qtcppproject/pages/embedded/QrcTreeView.class
12/05/2012 14:25:42PM - eclipse/plugins/com.trolltech.qtcppproject.linux.x86_1.6.1/bin/com/trolltech/qtcppproject/pages/embedded/QrcTreeViewListener.class
12/05/2012 14:25:42PM - eclipse/plugins/com.trolltech.qtcppproject.linux.x86_1.6.1/bin/com/trolltech/qtcppproject/pages/embedded/ScopeList$1.class
12/05/2012 14:25:42PM - eclipse/plugins/com.trolltech.qtcppproject.linux.x86_1.6.1/bin/com/trolltech/qtcppproject/pages/embedded/ScopeList$2.class
12/05/2012 14:25:42PM - eclipse/plugins/com.trolltech.qtcppproject.linux.x86_1.6.1/bin/com/trolltech/qtcppproject/pages/embedded/ScopeList.class
12/05/2012 14:25:42PM - eclipse/plugins/com.trolltech.qtcppproject.linux.x86_1.6.1/lib/
12/05/2012 14:25:42PM - eclipse/plugins/com.trolltech.qtcppproject.linux.x86_1.6.1/lib/libqtcppproparser.so
12/05/2012 14:25:42PM - eclipse/plugins/com.trolltech.qtcppproject.linux.x86_1.6.1/lib/libqtcppqrceditor.so
12/05/2012 14:25:42PM - eclipse/plugins/com.trolltech.qtcppproject.linux.x86_1.6.1/plugin.xml
12/05/2012 14:25:42PM - eclipse/plugins/com.trolltech.qtcppdesignerplugins.linux.x86/
12/05/2012 14:25:42PM - eclipse/plugins/com.trolltech.qtcppdesignerplugins.linux.x86/.classpath
12/05/2012 14:25:42PM - eclipse/plugins/com.trolltech.qtcppdesignerplugins.linux.x86/.project
12/05/2012 14:25:42PM - eclipse/plugins/com.trolltech.qtcppdesignerplugins.linux.x86/META-INF/
12/05/2012 14:25:42PM - eclipse/plugins/com.trolltech.qtcppdesignerplugins.linux.x86/META-INF/MANIFEST.MF
12/05/2012 14:25:42PM - eclipse/plugins/com.trolltech.qtcppdesignerplugins.linux.x86/src/
12/05/2012 14:25:42PM - eclipse/plugins/com.trolltech.qtcppdesignerplugins.linux.x86/src/KEEPME
12/05/2012 14:25:42PM - eclipse/plugins/com.trolltech.qtcppdesignerplugins.linux.x86/libqt3supportwidgets.so
12/05/2012 14:25:42PM - eclipse/plugins/com.trolltech.qtcppdesignerplugins.linux.x86/dependentlibs/
12/05/2012 14:25:42PM - eclipse/plugins/com.trolltech.qtcppdesignerplugins.linux.x86/dependentlibs/libQtNetworkCppIntegration.so
12/05/2012 14:25:42PM - tar: eclipse/plugins/com.trolltech.qtcppdesignerplugins.linux.x86/dependentlibs/libQtNetworkCppIntegration.so: Cannot create symlink to `libQtNetworkCppIntegration.so.4.6.1': Read-only file system
12/05/2012 14:25:42PM - eclipse/plugins/com.trolltech.qtcppdesignerplugins.linux.x86/dependentlibs/libQtNetworkCppIntegration.so.4
12/05/2012 14:25:43PM - tar: eclipse/plugins/com.trolltech.qtcppdesignerplugins.linux.x86/dependentlibs/libQtNetworkCppIntegration.so.4: Cannot create symlink to `libQtNetworkCppIntegration.so.4.6.1': Read-only file system
12/05/2012 14:25:43PM - eclipse/plugins/com.trolltech.qtcppdesignerplugins.linux.x86/dependentlibs/libQtNetworkCppIntegration.so.4.6
12/05/2012 14:25:43PM - tar: eclipse/plugins/com.trolltech.qtcppdesignerplugins.linux.x86/dependentlibs/libQtNetworkCppIntegration.so.4.6: Cannot create symlink to `libQtNetworkCppIntegration.so.4.6.1': Read-only file system
12/05/2012 14:25:43PM - eclipse/plugins/com.trolltech.qtcppdesignerplugins.linux.x86/dependentlibs/libQtNetworkCppIntegration.so.4.6.1
12/05/2012 14:25:43PM - eclipse/plugins/com.trolltech.qtcppdesignerplugins.linux.x86/dependentlibs/libQtSqlCppIntegration.so
12/05/2012 14:25:43PM - tar: eclipse/plugins/com.trolltech.qtcppdesignerplugins.linux.x86/dependentlibs/libQtSqlCppIntegration.so: Cannot create symlink to `libQtSqlCppIntegration.so.4.6.1': Read-only file system
12/05/2012 14:25:43PM - eclipse/plugins/com.trolltech.qtcppdesignerplugins.linux.x86/dependentlibs/libQtSqlCppIntegration.so.4
12/05/2012 14:25:43PM - tar: eclipse/plugins/com.trolltech.qtcppdesignerplugins.linux.x86/dependentlibs/libQtSqlCppIntegration.so.4: Cannot create symlink to `libQtSqlCppIntegration.so.4.6.1': Read-only file system
12/05/2012 14:25:43PM - eclipse/plugins/com.trolltech.qtcppdesignerplugins.linux.x86/dependentlibs/libQtSqlCppIntegration.so.4.6
12/05/2012 14:25:43PM - tar: eclipse/plugins/com.trolltech.qtcppdesignerplugins.linux.x86/dependentlibs/libQtSqlCppIntegration.so.4.6: Cannot create symlink to `libQtSqlCppIntegration.so.4.6.1': Read-only file system
12/05/2012 14:25:43PM - eclipse/plugins/com.trolltech.qtcppdesignerplugins.linux.x86/dependentlibs/libQtSqlCppIntegration.so.4.6.1
12/05/2012 14:25:43PM - eclipse/plugins/com.trolltech.qtcppdesignerplugins.linux.x86/dependentlibs/libQt3SupportCppIntegration.so
12/05/2012 14:25:43PM - tar: eclipse/plugins/com.trolltech.qtcppdesignerplugins.linux.x86/dependentlibs/libQt3SupportCppIntegration.so: Cannot create symlink to `libQt3SupportCppIntegration.so.4.6.1': Read-only file system
12/05/2012 14:25:43PM - eclipse/plugins/com.trolltech.qtcppdesignerplugins.linux.x86/dependentlibs/libQt3SupportCppIntegration.so.4
12/05/2012 14:25:43PM - tar: eclipse/plugins/com.trolltech.qtcppdesignerplugins.linux.x86/dependentlibs/libQt3SupportCppIntegration.so.4: Cannot create symlink to `libQt3SupportCppIntegration.so.4.6.1': Read-only file system
12/05/2012 14:25:43PM - eclipse/plugins/com.trolltech.qtcppdesignerplugins.linux.x86/dependentlibs/libQt3SupportCppIntegration.so.4.6
12/05/2012 14:25:43PM - tar: eclipse/plugins/com.trolltech.qtcppdesignerplugins.linux.x86/dependentlibs/libQt3SupportCppIntegration.so.4.6: Cannot create symlink to `libQt3SupportCppIntegration.so.4.6.1': Read-only file system
12/05/2012 14:25:43PM - eclipse/plugins/com.trolltech.qtcppdesignerplugins.linux.x86/dependentlibs/libQt3SupportCppIntegration.so.4.6.1
12/05/2012 14:25:43PM - eclipse/plugins/com.trolltech.qtcppdesignerplugins.linux.x86/dependentlibs/libQtWebKitCppIntegration.so
12/05/2012 14:25:43PM - tar: eclipse/plugins/com.trolltech.qtcppdesignerplugins.linux.x86/dependentlibs/libQtWebKitCppIntegration.so: Cannot create symlink to `libQtWebKitCppIntegration.so.4.6.1': Read-only file system
12/05/2012 14:25:43PM - eclipse/plugins/com.trolltech.qtcppdesignerplugins.linux.x86/dependentlibs/libQtWebKitCppIntegration.so.4
12/05/2012 14:25:43PM - tar: eclipse/plugins/com.trolltech.qtcppdesignerplugins.linux.x86/dependentlibs/libQtWebKitCppIntegration.so.4: Cannot create symlink to `libQtWebKitCppIntegration.so.4.6.1': Read-only file system
12/05/2012 14:25:43PM - eclipse/plugins/com.trolltech.qtcppdesignerplugins.linux.x86/dependentlibs/libQtWebKitCppIntegration.so.4.6
12/05/2012 14:25:43PM - tar: eclipse/plugins/com.trolltech.qtcppdesignerplugins.linux.x86/dependentlibs/libQtWebKitCppIntegration.so.4.6: Cannot create symlink to `libQtWebKitCppIntegration.so.4.6.1': Read-only file system
12/05/2012 14:25:43PM - eclipse/plugins/com.trolltech.qtcppdesignerplugins.linux.x86/dependentlibs/libQtWebKitCppIntegration.so.4.6.1
12/05/2012 14:25:43PM - eclipse/plugins/com.trolltech.qtcppdesignerplugins.linux.x86/libqwebview.so
12/05/2012 14:25:43PM - eclipse/plugins/com.trolltech.qtcppintegrationhelp.examples_1.6.1/
12/05/2012 14:25:43PM - eclipse/plugins/com.trolltech.qtcppintegrationhelp.examples_1.6.1/.classpath
12/05/2012 14:25:43PM - eclipse/plugins/com.trolltech.qtcppintegrationhelp.examples_1.6.1/.project
12/05/2012 14:25:43PM - eclipse/plugins/com.trolltech.qtcppintegrationhelp.examples_1.6.1/AddressBook/
12/05/2012 14:25:43PM - eclipse/plugins/com.trolltech.qtcppintegrationhelp.examples_1.6.1/AddressBook/AddressBook.pro
12/05/2012 14:25:43PM - eclipse/plugins/com.trolltech.qtcppintegrationhelp.examples_1.6.1/AddressBook/adddialog.cpp
12/05/2012 14:25:43PM - eclipse/plugins/com.trolltech.qtcppintegrationhelp.examples_1.6.1/AddressBook/adddialog.h
12/05/2012 14:25:43PM - eclipse/plugins/com.trolltech.qtcppintegrationhelp.examples_1.6.1/AddressBook/adddialog.ui
12/05/2012 14:25:43PM - eclipse/plugins/com.trolltech.qtcppintegrationhelp.examples_1.6.1/AddressBook/addressbook.cpp
12/05/2012 14:25:43PM - eclipse/plugins/com.trolltech.qtcppintegrationhelp.examples_1.6.1/AddressBook/addressbook.h
12/05/2012 14:25:43PM - eclipse/plugins/com.trolltech.qtcppintegrationhelp.examples_1.6.1/AddressBook/addressbook.ui
12/05/2012 14:25:43PM - eclipse/plugins/com.trolltech.qtcppintegrationhelp.examples_1.6.1/AddressBook/main.cpp
12/05/2012 14:25:43PM - eclipse/plugins/com.trolltech.qtcppintegrationhelp.examples_1.6.1/META-INF/
12/05/2012 14:25:43PM - eclipse/plugins/com.trolltech.qtcppintegrationhelp.examples_1.6.1/META-INF/MANIFEST.MF
12/05/2012 14:25:43PM - eclipse/plugins/com.trolltech.qtcppintegrationhelp.examples_1.6.1/src/
12/05/2012 14:25:43PM - eclipse/plugins/com.trolltech.qtcppintegrationhelp.examples_1.6.1/src/KEEPME
12/05/2012 14:25:43PM - eclipse/QT_ECLIPSEINTEGRATION_INSTALL.TXT
12/05/2012 14:25:43PM - eclipse/features/
12/05/2012 14:25:43PM - eclipse/features/com.trolltech.qtcpp.feature_1.6.1/
12/05/2012 14:25:43PM - eclipse/features/com.trolltech.qtcpp.feature_1.6.1/.project
12/05/2012 14:25:43PM - eclipse/features/com.trolltech.qtcpp.feature_1.6.1/Changes-0.9.5
12/05/2012 14:25:43PM - eclipse/features/com.trolltech.qtcpp.feature_1.6.1/Changes-1.0.0
12/05/2012 14:25:43PM - eclipse/features/com.trolltech.qtcpp.feature_1.6.1/Changes-1.0.1
12/05/2012 14:25:43PM - eclipse/features/com.trolltech.qtcpp.feature_1.6.1/Changes-1.4.0
12/05/2012 14:25:43PM - eclipse/features/com.trolltech.qtcpp.feature_1.6.1/build.properties
12/05/2012 14:25:43PM - eclipse/features/com.trolltech.qtcpp.feature_1.6.1/feature.xml
12/05/2012 14:25:43PM - eclipse/features/com.trolltech.qtcpp.feature_1.6.1/license.html
12/05/2012 14:25:43PM - eclipse/features/com.trolltech.qtcpp.feature_1.6.1/license.txt
12/05/2012 14:25:43PM - tar: Exiting with failure status due to previous errors
12/05/2012 14:25:43PM - Error installing Featurecom.ti.trolltech.qtcpp
12/05/2012 14:25:43PM - Duration: 657821
12/05/2012 14:25:44PM - Executing action AB6BF92C-17F3-442D-B86F-DC604FCDD272 - Run SiteCleanup
12/05/2012 14:25:44PM - Executing with progressive output
12/05/2012 14:25:44PM - Watching progressive output for special syntax.
12/05/2012 14:25:44PM - Executing Command Line: /home/dell/Desktop/Shared/sitara/ti/ccsv5/eclipse/eclipse -application com.ti.ccstudio.install.parser.siteCleanUp -nosplash
12/05/2012 14:25:44PM - Watching progressive output for matches
12/05/2012 14:26:14PM - Executing action 31112E80-7127-4B73-B048-C6966CF28137 - Set Variables
12/05/2012 14:26:14PM - Executing action 9B3E3C6F-0705-4B76-AABC-30E6D29E9938 - Look for debugserver base plugin
12/05/2012 14:26:14PM - Found baseplugin /home/dell/Desktop/Shared/sitara/ti/ccsv5/eclipse/plugins/com.ti.ccstudio.base_5.1.0.539
12/05/2012 14:26:14PM - Executing action 8722E38C-7F4E-4775-BFA3-E6805C927AE6 - Verify Install
12/05/2012 14:26:14PM - EclipseDir /home/dell/Desktop/Shared/sitara/ti/ccsv5/eclipse
12/05/2012 14:26:14PM - Errors: 0
12/05/2012 14:26:14PM - ccsconfig file /home/dell/Desktop/Shared/sitara/ti/ccsv5/eclipse/ccs_config.xml
12/05/2012 14:26:14PM - found /home/dell/Desktop/Shared/sitara/ti/ccsv5/eclipse/ccs_config.xml
12/05/2012 14:26:14PM - JRE state: feature installed
12/05/2012 14:26:14PM - Eclipse state: feature installed
12/05/2012 14:26:14PM - Eclipse P2 Extensions state: feature installed
12/05/2012 14:26:14PM - LightWeightInstaller state: feature installed
12/05/2012 14:26:14PM - LWInstaller state: feature installed
12/05/2012 14:26:14PM - com.ti.ccstudio.debugserver.linux state: feature installed
12/05/2012 14:26:14PM - com.ti.cgt.c2000.6.0.linux state: do not install
12/05/2012 14:26:14PM - com.ti.cgt.c5400.4.2.linux state: do not install
12/05/2012 14:26:14PM - com.ti.cgt.c5500.4.4.linux state: do not install
12/05/2012 14:26:14PM - com.ti.cgt.c6000.7.3.linux state: do not install
12/05/2012 14:26:14PM - com.ti.cgt.tms470.4.9.linux state: do not install
12/05/2012 14:26:14PM - com.ti.ccstudio.ide.linux state: feature installed
12/05/2012 14:26:14PM - com.ti.dvt.linux state: feature installed
12/05/2012 14:26:14PM - com.ti.dvt.min.linux state: do not install
12/05/2012 14:26:14PM - com.ti.xdctools.base.3.22.linux state: do not install
12/05/2012 14:26:14PM - com.ti.xdctools.arm.3.22.linux state: do not install
12/05/2012 14:26:14PM - com.ti.xdctools.c2000.3.22.linux state: do not install
12/05/2012 14:26:14PM - com.ti.xdctools.c6000.3.22.linux state: do not install
12/05/2012 14:26:14PM - com.ti.bios.5.41.linux state: do not install
12/05/2012 14:26:14PM - com.ti.bios.base.6.32.linux state: do not install
12/05/2012 14:26:14PM - com.ti.bios.arm.6.32.linux state: do not install
12/05/2012 14:26:14PM - com.ti.bios.c2000.6.32.linux state: do not install
12/05/2012 14:26:14PM - com.ti.bios.c6000.6.32.linux state: do not install
12/05/2012 14:26:14PM - com.ti.ipc.base.1.23.linux state: do not install
12/05/2012 14:26:14PM - com.ti.ipc.arm.1.23.linux state: do not install
12/05/2012 14:26:14PM - com.ti.ipc.c2000.1.23.linux state: do not install
12/05/2012 14:26:14PM - com.ti.ipc.c6000.1.23.linux state: do not install
12/05/2012 14:26:14PM - com.ti.xdais.7.21.linux state: do not install
12/05/2012 14:26:14PM - com.ti.uia.1.0.linux state: do not install
12/05/2012 14:26:14PM - com.ti.ccstudio.ccsinit.linux state: feature installed
12/05/2012 14:26:14PM - com.ti.c6flo.linux state: do not install
12/05/2012 14:26:14PM - com.ti.sim.pack.setup.linux state: do not install
12/05/2012 14:26:14PM - com.bh.ccstudio.emulation.linux state: do not install
12/05/2012 14:26:14PM - com.ti.emulation.pack.linux state: feature installed
12/05/2012 14:26:14PM - com.ti.ccstudio.hercules.linux state: do not install
12/05/2012 14:26:14PM - com.sd.ccstudio.emulation.linux state: do not install
12/05/2012 14:26:14PM - com.ti.c2000.support.linux state: do not install
12/05/2012 14:26:14PM - com.ti.c2000.flash.setup.linux state: do not install
12/05/2012 14:26:14PM - com.ti.ccstudio.nowflash.linux state: do not install
12/05/2012 14:26:14PM - com.ti.emulation.keystone1.linux state: do not install
12/05/2012 14:26:14PM - com.ti.cgt.dmed.linux state: do not install
12/05/2012 14:26:14PM - ERROR: com.ti.trolltech.qtcpp state: feature registered - something went wrong with the install
12/05/2012 14:26:14PM - ERROR: org.eclipse.rse state: feature registered - something went wrong with the install
12/05/2012 14:26:14PM - Errors: 2
12/05/2012 14:26:14PM - Checking conditions for C462063B-1B3F-4868-A0BE-DB3305FBA3CF - - Before Action is Executed
12/05/2012 14:26:14PM - Checking condition D103CF1D-9800-4D77-8D82-F1E7718764C5 - String Is Condition
12/05/2012 14:26:14PM - Checking to see if <%BadInstall%> is true
12/05/2012 14:26:14PM - ** Checking to see if true is true
12/05/2012 14:26:14PM - Condition passed
12/05/2012 14:26:14PM - Executing action C462063B-1B3F-4868-A0BE-DB3305FBA3CF - Invalid Install message
12/05/2012 14:26:14PM - One or more features were not installed correctly. Please look at the log /var/lib/installjammer/ccsv5/60556FE5-C1A1-4061-8DF8-FFB8393BAE2D/ccs_setup_5.1.1.00033_install.log for more information.
12/05/2012 14:26:14PM - Checking conditions for CAF7EDEC-8588-485E-BF3B-540E26298D1C - - Before Action is Executed
12/05/2012 14:26:14PM - Checking condition 048786B6-8E1E-4425-A85F-F4EA0002FEAA - String Is Condition
12/05/2012 14:26:14PM - Checking condition CBE3A61C-D649-46E7-AA3C-D3A49CA74479 - String Equal Condition
12/05/2012 14:26:14PM - Checking to see if Silent does not equal <%InstallMode%>
12/05/2012 14:26:14PM - ** Checking to see if Silent does not equal Standard
12/05/2012 14:26:14PM - Executing action CAF7EDEC-8588-485E-BF3B-540E26298D1C - Invalid Install message
Please let me know if you need any more log information.
Anvy
