Global (project) Find/Replace?
Guru 15580 points
Is there a global find/replace that searches the entire project (i.e. all project files)?
    'Control+H' will bring up the search dialog where you can set the search scope. The default is 'workspace' which means search all projects in the workspace but you can set it to search just the selected project.
    When the search results are listed, you have the option in the context menu to 'Replace All'
    ki
  • Ki-Soo,
    Thanks for the feedback. However, I must clarify that the "Replace" option only appears in the File Search tab. It does not appear in the C/C++ Search tab, which is apparently the default tab that pops up when you hit ctl-H. This is what confused me.
