EDMA support in CCS simulator (C6678)
I have some code which uses EDMA to do dsp-to-dsp communication. When running the code in the CCS simulator (C6678), the message "Warning: Write operation not permitted since EDMA is disabled" always pops up and the code does not operate EVM correctly. However, the very same code runs fine with the hardware (C6678 EVM) without any hiccups.
I was wondering if the support of EDMA in CCS simulator (C6678) needs some special set-up or licenses. Any pointers?
Thanks.
Weihua
  • Hi Weihua,
    Which device type you have selected? If you have selected "Device Cycle Approximate Simulator", EDMA may not work. Please select "Device Functional Simulator".
  • Hi Weihua,
    Can you give us below information to better analyse the problem,
    1. Which CCS/simulator version are you using? Is it CCS4.x or CCS5.1, CCS5.2, CCS5.3?
    2. Which simulator configuration are you using for C6678? Is it functional or Cycle Approximate simulator?
    3. Can you share the config files tisim_c6678_pv.cfg and tisim_c6678_cx.cfg - from <ccs install>\ccs_base\simulation_csp_kesytone1\bin\configurations. Alternately you can infer the path from CCS Target configurations-->Adavanced Tab --> and click on the DSP processor name "TMS320C66x_0" and look for config file in teh right pane.
    regards,
    Sheshadri
  • Hi Sheshadri,
    CCS5.2, CCS5.3?
    CCS 5.3.0.00090
    C6678 Device Functional Simulator, Little Endian
    tisim_c6678_cx.cfg - from<ccs
    See Attachment
  • Hi Sheshadri,
    The config file is pasted below:
    // C6657 Platform Functional Simulator Configuration File
    // Copyright (c) 2007-2008 Texas Instruments Incorporated
    // Version 0.0.1//--------------------------------------------------------------------------------
    MODULE GTI_INFO;
     GTI_DVR_NAME tisim_adv_sb.dvr;
     SERVER_AUTO_RUN ON;
    END GTI_INFO;
    MODULE SIMBRIDGE;
      ADVANCE_TYPE            CYCLE_ADVANCE_WITH_INSTR_HALT;
      // To enable simulator construction logs uncomment MODULE SIMBRIGE, END SIMBRIDGE and the line having "FILE_LOG ON"
      // The options here are
      // 1.  ON - will generate the default log files, declare_intf.log, connect_intf.log and sim_integration.log
      // 2.  <file name> - will generate all the log information into the specified file name.
      // 3.  OFF - logging disabled
      FILE_LOG ON;
      // Send global break status to GTIs of the processors
      // that are forced to halt on other processor break point
      SEND_GLOBAL_BREAK_STATUS ON;
      SIMBRIDGE_DLL ../../../bin/components/sim_server.so;
    END SIMBRIDGE;
    MODULE BUS_DESCRIPTORS;
      STD_BUS_HEADERS1 ../../../bin/configurations/tisim_buses.cfg;
    END BUS_DESCRIPTORS;
    MODULE System;
      DEBUGVIEW CPU0,CPU1;
      SUB_MODULES C66XX_N;
      MODULE C66XX_N;
        SUB_MODULES CPU_SYSTEM_0, CPU_SYSTEM_1, SHARED_SYSTEM_INTF,
        SHARED_SYSTEM;
        MODULE CPU_SYSTEM_0;
          SUB_MODULES CPU0, CGEM_SSI_0;
          MODULE CPU0;
            //! Simulation Specific Entries  !//
            //! DLL
            DLL ../../../bin/components/spkfc6xxxd.so;
            //! "C" interfaces to the DLL
            INIT_FUNC         SIM_init;
            INIT_DONE_FUNC    SIM_init_done;
            CONNECT_FUNC      SIM_megamodule_connect;
            SUPPORTS_MEM_STAT ON;
            QUIT_FUNC         SIM_quit;
            //! Debug "C" interfaces
            TS_CREATE_FUNC    SIM_ts_create;
            TS_DESTROY_FUNC   SIM_ts_destroy;
            //! System Integrator version compliance number
            SSI_VER SC_1.0.0;
            //! Module Type.
            TYPE CPU;
            CLOCK_FREQ 1000;    //1000 MHz/1 GHz
            RUN_GRAN 0.000125; // 50 Run granularity (unit is msec)
            USE_SEPARATE_PROG_MEM_MAP ON;
            MISSED_INTERRUPT_WARNING OFF;
            //! CPU Architecture Entries  !//
            //! ISA (JOULE).
            ISA CGEMp75_CORE;
            C66X_INSTR_PROFILING ON;
            //! ISTP reset value. //
            ISTP_RESET_VALUE 0x00800000;    //L2 SRAM Start address
            //! The Resource conflict Detection feature is not supported in the Joule ISA
            RESOURCE_CONFLICT_DETECTION OFF;
            //! Memgamodule ID.
            MM_ID 0;
            MODULE HPS2;
              MAX_BLOCK_SIZE_HINT 65536; // 64KB, in bytes
              BLOCK_HIT_THRESHOLD 2000;
              SPLOOP OFF;
              CODE_COVERAGE ON;
            END HPS2;
            // To enable PDATS trace uncomment the next line
            // IMPORT PDATS_TRACE_ON_CORE0;
            IMPORT PATCH0;
          END CPU0;
          MODULE CGEM_SSI_0;
            TYPE            PERIPHERAL;
            SSI_VER            SC_1.0.0;
            DLL            ../../../bin/components/sim_cgem_ssi.so;
            CPU_VIEW        CPU0;
            INIT_FUNC        cgem_ssi_init;
            INIT_DONE_FUNC        cgem_ssi_init_done;
            CONNECT_FUNC        cgem_ssi_connect_done;
            QUIT_FUNC        cgem_ssi_quit;
            MM_ID            0;
            NUM_MM            4;
            BOOT_MEMORY_MAP        1;        //<CHECK> Is "1" by default
            L1D_START_ADDRESS    0x00F00000;
            L1D_SIZE        0x8000;
            L1P_START_ADDRESS    0x00E00000;
            L1P_SIZE        0x8000;
            L2_START_ADDRESS    0x00800000;
            L2_SIZE            0x100000;
            CGEM_REG_START        0x01800000;    //Excluding the starting reserved region
            CGEM_REG_END        0x01BFFFFF;
            XMC_CONFIG_START    0x08000000;
            XMC_CONFIG_END        0x0801FFFF;
            MASTER_ID         0;
            PRIV_ID            0;    //<CHECK>
            SECURE_MODE        1;
            CACHE_BYPASS        0;
            MODULE DMC;
              CACHE_SIZE         0x8000;
              MEMORY_SIZE        0x8000;
              SRAM_START_ADDRESS 0x00F00000;
            END DMC;
            MODULE PMC;
              CACHE_SIZE         0x8000;
              MEMORY_SIZE        0x8000;
              SRAM_START_ADDRESS 0x00E00000;
            END PMC;
            MODULE UMC;
              CACHE_SIZE         0x00000;
              MAX_CACHE_SIZE     1MB;
              MEMORY_SIZE        0x100000;
              SRAM_START_ADDRESS 0x00800000;
            END UMC;
          END CGEM_SSI_0;
          // security mode change connect
          CONNECT1        CPU0.security_mode_in, CGEM_SSI_0.secure_status_opin;
        END CPU_SYSTEM_0;
        MODULE CPU_SYSTEM_1;
          SUB_MODULES CPU1, CGEM_SSI_1;
          MODULE CPU1;
            //! DLL
            INIT_FUNC         SIM_init;
            QUIT_FUNC         SIM_quit;
            SSI_VER SC_1.0.0;
            //! Module Type.
            TYPE CPU;
            //! ISA (JOULE).
            ISA CGEMp75_CORE;
            //! Memgamodule ID.
            MM_ID 1;
            MODULE EFI;
              FIFO_LEN_A 6;
              FIFO_LEN_B 6;
            END EFI;
            MODULE HPS2;
              SPLOOP OFF;
              CODE_COVERAGE ON;
            END HPS2;
            // IMPORT PDATS_TRACE_ON_CORE1;
            IMPORT PATCH1;
          END CPU1;
          MODULE CGEM_SSI_1;
            TYPE            PERIPHERAL;
            SSI_VER            SC_1.0.0;
            CPU_VIEW        CPU1;
            MM_ID            1;
            NUM_MM            4;
            L1D_SIZE        0x8000;
            L1P_SIZE        0x8000;
            L2_SIZE            0x100000;
            MASTER_ID         1;
            PRIV_ID            1;    //<CHECK>
            SECURE_MODE        1;
            CACHE_BYPASS        0;
            MODULE DMC;
              CACHE_SIZE         0x8000;
              MEMORY_SIZE        0x8000;
            END DMC;
            MODULE PMC;
              CACHE_SIZE         0x8000;
              MEMORY_SIZE        0x8000;
            END PMC;
            MODULE UMC;
              CACHE_SIZE         0x000000;
              MAX_CACHE_SIZE     1MB;
            END UMC;
          END CGEM_SSI_1;
          CONNECT1        CPU1.security_mode_in, CGEM_SSI_1.secure_status_opin;
        END CPU_SYSTEM_1;
        MODULE SHARED_SYSTEM_INTF;
          TYPE SHARED;
          SSI_VER SC_1.0.0;
          CLOCK_FREQ 1000;
          DLL ../../../bin/components/sim_shared_system_intf.so;
          INIT_FUNC         shared_system_intf_init_func;
          INIT_DONE_FUNC    shared_system_intf_init_done_func;
          QUIT_FUNC         shared_system_intf_quit_func;
        END SHARED_SYSTEM_INTF;
        MODULE SHARED_SYSTEM;
          SUB_MODULES
          INTERCONNECT,
          MSMC,
          MEMTR_MSMC_Adaptor,
          MEMTR_FLATMEM_36BIT_Adaptor, //for ARM DDR access
          MEMTR_CGEM0_Slv_Adaptor,
          MEMTR_CGEM1_Slv_Adaptor,
          TIMER64_0,    //Watch Dog for Core0
          TIMER64_1,    //Watch Dog for Core1
          TIMER64_2,    //Watch Dog for Core2
          TIMER64_3,    //Watch Dog for Core3
          TIMER64_4,
          TIMER64_5,
          TIMER64_6,
          TIMER64_7,
          EDMA,
          CP_INTC0,
          CP_INTC1,
          CP_INTC2,
          VCP2_0,
          VCP2_1,
          SEMAPHORE,
          TCP3D_A,
          IPC,
          GPIO,
          QUEUE_MANAGER,
          CDMA_INFRA,
          INTD_TCP3D_A,
          PCIE,
          FLATMEM_36BIT,    //DDR data model
          PSC,
          SRIO,    //!SRIO sub-system
          CDMA_SRIO,
          SSI2SOCK_PORT0,            //for SRIO
          UART_0,
          UART_1,
          DSP_BOOT_ROM,
          Endianess_Adaptor,
          Endianess_Adaptor1,
          BOOT_CONFIG;
          MODULE Endianess_Adaptor;
            NAME            Endianess_Adaptor;
            TYPE            SHARED;
            SSI_VER            SSI_1.1;
            DLL            ../../../bin/components/o2v_a8_bridge_ssi.so;
            INIT_FUNC        init_o2v_a8_bridge_intf;
            INIT_DONE_FUNC        init_done_o2v_a8_bridge_intf;
            QUIT_FUNC        quit_o2v_a8_bridge_intf;
            MODULE    USER_INPUTS;
              INPUT1    CPU_NAME, SHARED;
              INPUT2    EN_WORD_SWAP, 1;
              INPUT3    EN_ADDR_SWAP, 0;    //Reset value
              INPUT4  BIG_ENDIAN,   0;
              // UART0
              INPUT5  BEG_WS_REG0, 0x02540000;
              INPUT6  END_WS_REG0, 0x02540FFF;
            END    USER_INPUTS;
            MODULE INTERFACES;
              CONNECT1        System.C66XX_N.SHARED_SYSTEM.INTERCONNECT.UART_0.memtr_read_opin, System.C66XX_N.SHARED_SYSTEM.Endianess_Adaptor.mbus_in_read;
              CONNECT2        System.C66XX_N.SHARED_SYSTEM.INTERCONNECT.UART_0.memtr_write_opin, System.C66XX_N.SHARED_SYSTEM.Endianess_Adaptor.mbus_in_write;
              CONNECT3        System.C66XX_N.SHARED_SYSTEM.INTERCONNECT.UART_0.memtr_dbg_read_opin, System.C66XX_N.SHARED_SYSTEM.Endianess_Adaptor.mbus_in_dbg_read;
              CONNECT4        System.C66XX_N.SHARED_SYSTEM.INTERCONNECT.UART_0.memtr_dbg_write_opin, System.C66XX_N.SHARED_SYSTEM.Endianess_Adaptor.mbus_in_dbg_write;
              CONNECT5        System.C66XX_N.SHARED_SYSTEM.UART_0.memtr_read_ipin, System.C66XX_N.SHARED_SYSTEM.Endianess_Adaptor.mbus_out_read;
              CONNECT6        System.C66XX_N.SHARED_SYSTEM.UART_0.memtr_write_ipin, System.C66XX_N.SHARED_SYSTEM.Endianess_Adaptor.mbus_out_write;
              CONNECT7        System.C66XX_N.SHARED_SYSTEM.UART_0.memtr_dbg_read_ipin, System.C66XX_N.SHARED_SYSTEM.Endianess_Adaptor.mbus_out_dbg_read;
              CONNECT8        System.C66XX_N.SHARED_SYSTEM.UART_0.memtr_dbg_write_ipin, System.C66XX_N.SHARED_SYSTEM.Endianess_Adaptor.mbus_out_dbg_write;
              CONNECT9        System.C66XX_N.SHARED_SYSTEM.Endianess_Adaptor.reset_in, System.C66XX_N.SHARED_SYSTEM_INTF.reset_out;
              CONNECT10        System.C66XX_N.SHARED_SYSTEM.Endianess_Adaptor.big_endian_in, System.C66XX_N.CPU_SYSTEM_0.CPU0_endianness_big_endian;
            END INTERFACES;
          END Endianess_Adaptor;
          MODULE Endianess_Adaptor1;
            NAME            Endianess_Adaptor1;
            TYPE            SHARED;
            SSI_VER            SSI_1.1;
            MODULE    USER_INPUTS;
              // UART1
              INPUT5  BEG_WS_REG0, 0x02550000;
              INPUT6  END_WS_REG0, 0x02550FFF;
            END    USER_INPUTS;
            MODULE INTERFACES;
              CONNECT1        System.C66XX_N.SHARED_SYSTEM.INTERCONNECT.UART_1.memtr_read_opin, System.C66XX_N.SHARED_SYSTEM.Endianess_Adaptor1.mbus_in_read;
              CONNECT2        System.C66XX_N.SHARED_SYSTEM.INTERCONNECT.UART_1.memtr_write_opin, System.C66XX_N.SHARED_SYSTEM.Endianess_Adaptor1.mbus_in_write;
              CONNECT3        System.C66XX_N.SHARED_SYSTEM.INTERCONNECT.UART_1.memtr_dbg_read_opin, System.C66XX_N.SHARED_SYSTEM.Endianess_Adaptor1.mbus_in_dbg_read;
              CONNECT4        System.C66XX_N.SHARED_SYSTEM.INTERCONNECT.UART_1.memtr_dbg_write_opin, System.C66XX_N.SHARED_SYSTEM.Endianess_Adaptor1.mbus_in_dbg_write;
              CONNECT5        System.C66XX_N.SHARED_SYSTEM.UART_1.memtr_read_ipin, System.C66XX_N.SHARED_SYSTEM.Endianess_Adaptor1.mbus_out_read;
              CONNECT6        System.C66XX_N.SHARED_SYSTEM.UART_1.memtr_write_ipin, System.C66XX_N.SHARED_SYSTEM.Endianess_Adaptor1.mbus_out_write;
              CONNECT7        System.C66XX_N.SHARED_SYSTEM.UART_1.memtr_dbg_read_ipin, System.C66XX_N.SHARED_SYSTEM.Endianess_Adaptor1.mbus_out_dbg_read;
              CONNECT8        System.C66XX_N.SHARED_SYSTEM.UART_1.memtr_dbg_write_ipin, System.C66XX_N.SHARED_SYSTEM.Endianess_Adaptor1.mbus_out_dbg_write;
              CONNECT9        System.C66XX_N.SHARED_SYSTEM.Endianess_Adaptor1.reset_in, System.C66XX_N.SHARED_SYSTEM_INTF.reset_out;
              CONNECT10        System.C66XX_N.SHARED_SYSTEM.Endianess_Adaptor1.big_endian_in, System.C66XX_N.CPU_SYSTEM_0.CPU0_endianness_big_endian;
            END INTERFACES;
          END Endianess_Adaptor1;
          //////////FLAT MEMORY: COMMON //////////////////////////////////
          MODULE DSP_BOOT_ROM;
            DLL             ../../../bin/components/sim_memtr_adaptor.so;
            INIT_FUNC             memtr_adaptor_init;
            INIT_DONE_FUNC        memtr_adaptor_init_done;
            QUIT_FUNC             memtr_adaptor_quit;
            SSI_VER         SC_1.0.0;
            TERMINAL         MT_SSI2FLATMEM;
            TYPE         SHARED;
            BUSCONNECT1 MEMTR_S_M,  System.C66XX_N.SHARED_SYSTEM.DSP_BOOT_ROM.MT_SSI2FLATMEM., System.C66XX_N.SHARED_SYSTEM.INTERCONNECT.DSP_BOOT_ROM.;
          END  DSP_BOOT_ROM;
          MODULE UART_0;
            NAME    UART_0;
            TYPE    SHARED;
            SSI_VER SSI_1.1;
            DLL         ./../../../bin/components/tisim_uartconsole_pv.so;
            INIT_FUNC        UART_init;
            INIT_DONE_FUNC    UART_init_done;
            QUIT_FUNC        UART_quit;
            MODULE  INTERFACES;
              CONNECT1        System.C66XX_N.SHARED_SYSTEM.UART_0.console_clk, System.C66XX_N.SHARED_SYSTEM.UART_0.uart_bit_ack_out;
              CONNECT2        System.C66XX_N.SHARED_SYSTEM.UART_0.recv_uart, System.C66XX_N.SHARED_SYSTEM.UART_0.uart_tx_byte_data_out;
              CONNECT3        System.C66XX_N.SHARED_SYSTEM.UART_0.get_lcr, System.C66XX_N.SHARED_SYSTEM.UART_0.uart_console_lcr_out;
              CONNECT4        System.C66XX_N.SHARED_SYSTEM.UART_0.consolekeypress, System.C66XX_N.SHARED_SYSTEM.UART_0.uart_rx_byte_data_in;
              CONNECT5        System.Shared_System.hps_scheduler, System.C66XX_N.SHARED_SYSTEM.UART_0.uart_infra_scheduler;
              CONNECT6        System.C66XX_N.SHARED_SYSTEM.UART_0.uart_resp_loop_back_memtr , System.C66XX_N.SHARED_SYSTEM.UART_0.uart_read_response_out;
              CONNECT7        System.C66XX_N.CPU_SYSTEM_0.CPU0.error_intf_ssi, System.C66XX_N.SHARED_SYSTEM.UART_0.uart_error_opin;
              CONNECT8        System.C66XX_N.CPU_SYSTEM_1.CPU1.error_intf_ssi, System.C66XX_N.SHARED_SYSTEM.UART_0.uart_error_opin;
            END    INTERFACES;
            MODULE USER_INPUTS;
              INPUT1 IP_NAME, UART_0;
              INPUT2 PORT_REG_OFFSET, 0x7C; // this is default value;
              INPUT3 ALIGNMENT_PARAM, 4;    // this is default value;
              INPUT4 PID, 0x44141102; //as per GAUSS spec
              INPUT5 VERSION, 1.2;
              INPUT6 IP,      127.0.0.1;
              INPUT7 PORT,  8000;
            END USER_INPUTS;
          END UART_0;
          MODULE UART_1;
            NAME    UART_1;
            TYPE    SHARED;
            SSI_VER SSI_1.1;
            MODULE  INTERFACES;
              CONNECT1        System.C66XX_N.SHARED_SYSTEM.UART_1.console_clk, System.C66XX_N.SHARED_SYSTEM.UART_1.uart_bit_ack_out;
              CONNECT2        System.C66XX_N.SHARED_SYSTEM.UART_1.recv_uart, System.C66XX_N.SHARED_SYSTEM.UART_1.uart_tx_byte_data_out;
              CONNECT3        System.C66XX_N.SHARED_SYSTEM.UART_1.get_lcr, System.C66XX_N.SHARED_SYSTEM.UART_1.uart_console_lcr_out;
              CONNECT4        System.C66XX_N.SHARED_SYSTEM.UART_1.consolekeypress, System.C66XX_N.SHARED_SYSTEM.UART_1.uart_rx_byte_data_in;
              CONNECT5        System.Shared_System.hps_scheduler, System.C66XX_N.SHARED_SYSTEM.UART_1.uart_infra_scheduler;
              CONNECT6        System.C66XX_N.SHARED_SYSTEM.UART_1.uart_resp_loop_back_memtr, System.C66XX_N.SHARED_SYSTEM.UART_1.uart_read_response_out;
              CONNECT7        System.C66XX_N.CPU_SYSTEM_0.CPU0.error_intf_ssi, System.C66XX_N.SHARED_SYSTEM.UART_1.uart_error_opin;
              CONNECT8        System.C66XX_N.CPU_SYSTEM_1.CPU1.error_intf_ssi, System.C66XX_N.SHARED_SYSTEM.UART_1.uart_error_opin;
            END    INTERFACES;
            MODULE USER_INPUTS;
              INPUT1 IP_NAME, UART_1;
              INPUT7 PORT,  8001;
            END USER_INPUTS;
          END UART_1;
          MODULE BOOT_CONFIG;
            NAME    BOOT_CONFIG;
            TYPE    SHARED;
            SSI_VER SSI_1.1;
            DLL      ./../../../bin/components/bootconfig_ssi.so;
            INIT_FUNC    init_bootconfig_intf;
            INIT_DONE_FUNC  init_done_bootconfig_intf;
            QUIT_FUNC    quit_bootconfig_intf;
            MODULE  INTERFACES;
              CONNECT1    System.C66XX_N.SHARED_SYSTEM.INTERCONNECT.BOOT_CONFIG.memtr_read_opin, System.C66XX_N.SHARED_SYSTEM.BOOT_CONFIG.mbus_in_read;
              CONNECT2    System.C66XX_N.SHARED_SYSTEM.INTERCONNECT.BOOT_CONFIG.memtr_write_opin, System.C66XX_N.SHARED_SYSTEM.BOOT_CONFIG.mbus_in_write;
              CONNECT3    System.C66XX_N.SHARED_SYSTEM.INTERCONNECT.BOOT_CONFIG.memtr_dbg_read_opin, System.C66XX_N.SHARED_SYSTEM.BOOT_CONFIG.mbus_in_dbg_read;
              CONNECT4    System.C66XX_N.SHARED_SYSTEM.INTERCONNECT.BOOT_CONFIG.memtr_dbg_write_opin, System.C66XX_N.SHARED_SYSTEM.BOOT_CONFIG.mbus_in_dbg_write;
              CONNECT5    System.C66XX_N.SHARED_SYSTEM.BOOT_CONFIG.reset_in, System.C66XX_N.SHARED_SYSTEM_INTF.reset_out;
              CONNECT6    System.C66XX_N.SHARED_SYSTEM.BOOT_CONFIG.little_endian_in, System.C66XX_N.CPU_SYSTEM_0.CPU0_endianness;
              CONNECT7    System.C66XX_N.SHARED_SYSTEM.BOOT_CONFIG.errmsg, System.C66XX_N.CPU_SYSTEM_0.CPU0.error_intf_ssi;
              CONNECT8    System.C66XX_N.SHARED_SYSTEM.BOOT_CONFIG.errmsg, System.C66XX_N.CPU_SYSTEM_1.CPU1.error_intf_ssi;
            END  INTERFACES;
            MODULE USER_INPUTS;
              INPUT2 PID, 0x4e840000;
              INPUT3 SOC, GAUSS;
            END USER_INPUTS;
          END BOOT_CONFIG;
          MODULE INTERCONNECT;
            NAME            GAUSS_INTERCONNECT;
            TYPE            SHARED;
            SSI_VER            SSI_1.1;
            DLL            ../../../bin/components/tisim_sf_ivahd_interconnect_ssi.so;
            INIT_FUNC        ivahd_ic_ocp_init;
            INIT_DONE_FUNC        ivahd_ic_ocp_init_done;
            QUIT_FUNC        ivahd_ic_ocp_quit;
            MODULE    USER_INPUTS;
              INPUT2        CFG_FILE, ../../../bin/configurations/tisim_l3_c6657.cfg;
            END    USER_INPUTS;
            MODULE INTERFACES;
              //INTERCONNECT TO Reset SIGNAL
              CONNECT1        System.C66XX_N.SHARED_SYSTEM_INTF.reset_out, System.C66XX_N.SHARED_SYSTEM.INTERCONNECT.receive_reset;
              CONNECT2        System.C66XX_N.SHARED_SYSTEM.INTERCONNECT.error_opin,System.C66XX_N.CPU_SYSTEM_0.CPU0.error_intf_ssi;
              CONNECT3        System.C66XX_N.SHARED_SYSTEM.INTERCONNECT.error_opin,System.C66XX_N.CPU_SYSTEM_1.CPU1.error_intf_ssi;
              //CONNECT4        System.C66XX_N.SHARED_SYSTEM.INTERCONNECT.ccs_error_q,System.Shared_System.hps_error_q;
            END INTERFACES;
          END INTERCONNECT;
          MODULE MSMC;
            NAME            msmc;
            TYPE            SHARED;
            SSI_VER            SC_1.0.0;
            DLL            ../../../bin/components/sim_msmc_ssi.so;
            INIT_FUNC        msmc_ssi_init_func;
            INIT_DONE_FUNC        msmc_ssi_init_done_func;
            QUIT_FUNC        msmc_ssi_quit_func;
            NO_OF_CORES        2;
            RAM_START_ADDRESS    0x0C000000;
            RAM_SIZE        0x100000;
            CFG_START_ADDRESS    0x0BC00000;
          END MSMC;
          MODULE TIMER64_0;
            //! Module Type.
            TYPE SHARED;
            SSI_VER SC_1.0.0;
            //! DLL
            DLL ../../../bin/components/sim_timer64.so;
            INIT_FUNC         timer64_init_func;
            INIT_DONE_FUNC    timer64_init_done_func;
            QUIT_FUNC         timer64_quit_func;
            CLOCK_DIVIDE 6;
            // Timer64P Configuration.Enables the Hilander features.
            VERSION TIMER64P;
            // Watchdog Capability for TIMER64
            WATCH_DOG ON;
            CONNECT1        System.C66XX_N.SHARED_SYSTEM.TIMER64_0.mt_slv_read_ipin, System.C66XX_N.SHARED_SYSTEM.INTERCONNECT.TIMER0_CFG.memtr_read_opin;
            CONNECT2        System.C66XX_N.SHARED_SYSTEM.TIMER64_0.mt_slv_write_ipin, System.C66XX_N.SHARED_SYSTEM.INTERCONNECT.TIMER0_CFG.memtr_write_opin;
            CONNECT3        System.C66XX_N.SHARED_SYSTEM.TIMER64_0.mt_slv_dbg_read_ipin, System.C66XX_N.SHARED_SYSTEM.INTERCONNECT.TIMER0_CFG.memtr_dbg_read_opin;
            CONNECT4        System.C66XX_N.SHARED_SYSTEM.TIMER64_0.mt_slv_dbg_write_ipin, System.C66XX_N.SHARED_SYSTEM.INTERCONNECT.TIMER0_CFG.memtr_dbg_write_opin;
          END TIMER64_0;
          MODULE TIMER64_1;
            //! Module Type.
            TYPE SHARED;
            SSI_VER SC_1.0.0;
            //! DLL
            CLOCK_DIVIDE 6;
            VERSION TIMER64P;
            WATCH_DOG ON;
            CONNECT1        System.C66XX_N.SHARED_SYSTEM.TIMER64_1.mt_slv_read_ipin, System.C66XX_N.SHARED_SYSTEM.INTERCONNECT.TIMER1_CFG.memtr_read_opin;
            CONNECT2        System.C66XX_N.SHARED_SYSTEM.TIMER64_1.mt_slv_write_ipin, System.C66XX_N.SHARED_SYSTEM.INTERCONNECT.TIMER1_CFG.memtr_write_opin;
            CONNECT3        System.C66XX_N.SHARED_SYSTEM.TIMER64_1.mt_slv_dbg_read_ipin, System.C66XX_N.SHARED_SYSTEM.INTERCONNECT.TIMER1_CFG.memtr_dbg_read_opin;
            CONNECT4        System.C66XX_N.SHARED_SYSTEM.TIMER64_1.mt_slv_dbg_write_ipin, System.C66XX_N.SHARED_SYSTEM.INTERCONNECT.TIMER1_CFG.memtr_dbg_write_opin;
          END TIMER64_1;
          MODULE TIMER64_2;
            //! Module Type.
            TYPE SHARED;
            SSI_VER SC_1.0.0;
            //! DLL
            CLOCK_DIVIDE 6;
            VERSION TIMER64P;
            WATCH_DOG OFF;
            CONNECT1        System.C66XX_N.SHARED_SYSTEM.TIMER64_2.mt_slv_read_ipin, System.C66XX_N.SHARED_SYSTEM.INTERCONNECT.TIMER2_CFG.memtr_read_opin;
            CONNECT2        System.C66XX_N.SHARED_SYSTEM.TIMER64_2.mt_slv_write_ipin, System.C66XX_N.SHARED_SYSTEM.INTERCONNECT.TIMER2_CFG.memtr_write_opin;
            CONNECT3        System.C66XX_N.SHARED_SYSTEM.TIMER64_2.mt_slv_dbg_read_ipin, System.C66XX_N.SHARED_SYSTEM.INTERCONNECT.TIMER2_CFG.memtr_dbg_read_opin;
            CONNECT4        System.C66XX_N.SHARED_SYSTEM.TIMER64_2.mt_slv_dbg_write_ipin, System.C66XX_N.SHARED_SYSTEM.INTERCONNECT.TIMER2_CFG.memtr_dbg_write_opin;
          END TIMER64_2;
          MODULE TIMER64_3;
            //! Module Type.
            TYPE SHARED;
            SSI_VER SC_1.0.0;
            //! DLL
            CLOCK_DIVIDE 6;
            VERSION TIMER64P;
            WATCH_DOG OFF;
            CONNECT1        System.C66XX_N.SHARED_SYSTEM.TIMER64_3.mt_slv_read_ipin, System.C66XX_N.SHARED_SYSTEM.INTERCONNECT.TIMER3_CFG.memtr_read_opin;
            CONNECT2        System.C66XX_N.SHARED_SYSTEM.TIMER64_3.mt_slv_write_ipin, System.C66XX_N.SHARED_SYSTEM.INTERCONNECT.TIMER3_CFG.memtr_write_opin;
            CONNECT3        System.C66XX_N.SHARED_SYSTEM.TIMER64_3.mt_slv_dbg_read_ipin, System.C66XX_N.SHARED_SYSTEM.INTERCONNECT.TIMER3_CFG.memtr_dbg_read_opin;
            CONNECT4        System.C66XX_N.SHARED_SYSTEM.TIMER64_3.mt_slv_dbg_write_ipin, System.C66XX_N.SHARED_SYSTEM.INTERCONNECT.TIMER3_CFG.memtr_dbg_write_opin;
          END TIMER64_3;
          MODULE TIMER64_4;
            //! Module Type.
            TYPE SHARED;
            SSI_VER SC_1.0.0;
            //! DLL
            CLOCK_DIVIDE 6;
            VERSION TIMER64P;
            WATCH_DOG OFF;
            CONNECT1        System.C66XX_N.SHARED_SYSTEM.TIMER64_4.mt_slv_read_ipin, System.C66XX_N.SHARED_SYSTEM.INTERCONNECT.TIMER4_CFG.memtr_read_opin;
            CONNECT2        System.C66XX_N.SHARED_SYSTEM.TIMER64_4.mt_slv_write_ipin, System.C66XX_N.SHARED_SYSTEM.INTERCONNECT.TIMER4_CFG.memtr_write_opin;
            CONNECT3        System.C66XX_N.SHARED_SYSTEM.TIMER64_4.mt_slv_dbg_read_ipin, System.C66XX_N.SHARED_SYSTEM.INTERCONNECT.TIMER4_CFG.memtr_dbg_read_opin;
            CONNECT4        System.C66XX_N.SHARED_SYSTEM.TIMER64_4.mt_slv_dbg_write_ipin, System.C66XX_N.SHARED_SYSTEM.INTERCONNECT.TIMER4_CFG.memtr_dbg_write_opin;
          END TIMER64_4;
          MODULE TIMER64_5;
            //! Module Type.
            TYPE SHARED;
            SSI_VER SC_1.0.0;
            //! DLL
            CLOCK_DIVIDE 6;
            VERSION TIMER64P;
            WATCH_DOG OFF;
            CONNECT1        System.C66XX_N.SHARED_SYSTEM.TIMER64_5.mt_slv_read_ipin, System.C66XX_N.SHARED_SYSTEM.INTERCONNECT.TIMER5_CFG.memtr_read_opin;
            CONNECT2        System.C66XX_N.SHARED_SYSTEM.TIMER64_5.mt_slv_write_ipin, System.C66XX_N.SHARED_SYSTEM.INTERCONNECT.TIMER5_CFG.memtr_write_opin;
            CONNECT3        System.C66XX_N.SHARED_SYSTEM.TIMER64_5.mt_slv_dbg_read_ipin, System.C66XX_N.SHARED_SYSTEM.INTERCONNECT.TIMER5_CFG.memtr_dbg_read_opin;
            CONNECT4        System.C66XX_N.SHARED_SYSTEM.TIMER64_5.mt_slv_dbg_write_ipin, System.C66XX_N.SHARED_SYSTEM.INTERCONNECT.TIMER5_CFG.memtr_dbg_write_opin;
          END TIMER64_5;
          MODULE TIMER64_6;
            //! Module Type.
            TYPE SHARED;
            SSI_VER SC_1.0.0;
            //! DLL
            CLOCK_DIVIDE 6;
            VERSION TIMER64P;
            WATCH_DOG OFF;
            CONNECT1        System.C66XX_N.SHARED_SYSTEM.TIMER64_6.mt_slv_read_ipin, System.C66XX_N.SHARED_SYSTEM.INTERCONNECT.TIMER6_CFG.memtr_read_opin;
            CONNECT2        System.C66XX_N.SHARED_SYSTEM.TIMER64_6.mt_slv_write_ipin, System.C66XX_N.SHARED_SYSTEM.INTERCONNECT.TIMER6_CFG.memtr_write_opin;
            CONNECT3        System.C66XX_N.SHARED_SYSTEM.TIMER64_6.mt_slv_dbg_read_ipin, System.C66XX_N.SHARED_SYSTEM.INTERCONNECT.TIMER6_CFG.memtr_dbg_read_opin;
            CONNECT4        System.C66XX_N.SHARED_SYSTEM.TIMER64_6.mt_slv_dbg_write_ipin, System.C66XX_N.SHARED_SYSTEM.INTERCONNECT.TIMER6_CFG.memtr_dbg_write_opin;
          END TIMER64_6;
          MODULE TIMER64_7;
            //! Module Type.
            TYPE SHARED;
            SSI_VER SC_1.0.0;
            //! DLL
            CLOCK_DIVIDE 6;
            VERSION TIMER64P;
            WATCH_DOG OFF;
            CONNECT1        System.C66XX_N.SHARED_SYSTEM.TIMER64_7.mt_slv_read_ipin, System.C66XX_N.SHARED_SYSTEM.INTERCONNECT.TIMER7_CFG.memtr_read_opin;
            CONNECT2        System.C66XX_N.SHARED_SYSTEM.TIMER64_7.mt_slv_write_ipin, System.C66XX_N.SHARED_SYSTEM.INTERCONNECT.TIMER7_CFG.memtr_write_opin;
            CONNECT3        System.C66XX_N.SHARED_SYSTEM.TIMER64_7.mt_slv_dbg_read_ipin, System.C66XX_N.SHARED_SYSTEM.INTERCONNECT.TIMER7_CFG.memtr_dbg_read_opin;
            CONNECT4        System.C66XX_N.SHARED_SYSTEM.TIMER64_7.mt_slv_dbg_write_ipin, System.C66XX_N.SHARED_SYSTEM.INTERCONNECT.TIMER7_CFG.memtr_dbg_write_opin;
          END TIMER64_7;
          MODULE EDMA;
            //! DLL
            DLL ../../../bin/components/sim_edma.so;
            INIT_FUNC         dma_init_func;
            INIT_DONE_FUNC    dma_init_done_func;
            CONNECT_FUNC      dma_connect_func;
            QUIT_FUNC         dma_quit_func;
            SSI_VER SC_1.0.0;
            //! Module Type.
            TYPE SHARED;
            //! EDMA v3 Architecture Entries  !//
            CLOCK_DIVIDE_RATIO    3;
            NUM_DMA_CHANNELS     64;
            NUM_QDMA_CHANNELS     8;
            NUM_INT_CHANNELS     64;
            NUM_PARAM_ENTRIES   512;
            NUM_EVENT_QUEUES      4;
            NUM_TCS               4;
            CHANNEL_MAP_EXISTS   YES;
            NUM_REGIONS           8;
            EXPOSE_MEMTR_PER_TC YES;
            TC0_MSTID            29;
            TC1_MSTID            31;
            TC2_MSTID            33;
            TC3_MSTID            35;
            CONNECT1        System.C66XX_N.SHARED_SYSTEM.EDMA.tpcc_reg_read_ipin, System.C66XX_N.SHARED_SYSTEM.INTERCONNECT.EDMA_CC.memtr_read_opin;
            CONNECT2        System.C66XX_N.SHARED_SYSTEM.EDMA.tpcc_reg_write_ipin, System.C66XX_N.SHARED_SYSTEM.INTERCONNECT.EDMA_CC.memtr_write_opin;
            CONNECT3        System.C66XX_N.SHARED_SYSTEM.EDMA.tpcc_reg_dbg_read_ipin, System.C66XX_N.SHARED_SYSTEM.INTERCONNECT.EDMA_CC.memtr_dbg_read_opin;
            CONNECT4        System.C66XX_N.SHARED_SYSTEM.EDMA.tpcc_reg_dbg_write_ipin, System.C66XX_N.SHARED_SYSTEM.INTERCONNECT.EDMA_CC.memtr_dbg_write_opin;
            CONNECT5        System.C66XX_N.SHARED_SYSTEM.EDMA.3PTC0.memtr_read_opin, System.C66XX_N.SHARED_SYSTEM.INTERCONNECT.EDMA_TC0_M.memtr_read_ipin;
            CONNECT6        System.C66XX_N.SHARED_SYSTEM.EDMA.3PTC0.memtr_write_opin, System.C66XX_N.SHARED_SYSTEM.INTERCONNECT.EDMA_TC0_M.memtr_write_ipin;
            CONNECT7        System.C66XX_N.SHARED_SYSTEM.EDMA.3PTC0.memtr_dbg_read_opin, System.C66XX_N.SHARED_SYSTEM.INTERCONNECT.EDMA_TC0_M.memtr_dbg_read_ipin;
            CONNECT8        System.C66XX_N.SHARED_SYSTEM.EDMA.3PTC0.memtr_dbg_write_opin, System.C66XX_N.SHARED_SYSTEM.INTERCONNECT.EDMA_TC0_M.memtr_dbg_write_ipin;
            CONNECT9        System.C66XX_N.SHARED_SYSTEM.EDMA.3PTC1.memtr_read_opin, System.C66XX_N.SHARED_SYSTEM.INTERCONNECT.EDMA_TC1_M.memtr_read_ipin;
            CONNECT10        System.C66XX_N.SHARED_SYSTEM.EDMA.3PTC1.memtr_write_opin, System.C66XX_N.SHARED_SYSTEM.INTERCONNECT.EDMA_TC1_M.memtr_write_ipin;
            CONNECT11        System.C66XX_N.SHARED_SYSTEM.EDMA.3PTC1.memtr_dbg_read_opin, System.C66XX_N.SHARED_SYSTEM.INTERCONNECT.EDMA_TC1_M.memtr_dbg_read_ipin;
            CONNECT12        System.C66XX_N.SHARED_SYSTEM.EDMA.3PTC1.memtr_dbg_write_opin, System.C66XX_N.SHARED_SYSTEM.INTERCONNECT.EDMA_TC1_M.memtr_dbg_write_ipin;
            CONNECT13        System.C66XX_N.SHARED_SYSTEM.EDMA.3PTC2.memtr_read_opin, System.C66XX_N.SHARED_SYSTEM.INTERCONNECT.EDMA_TC2_M.memtr_read_ipin;
            CONNECT14        System.C66XX_N.SHARED_SYSTEM.EDMA.3PTC2.memtr_write_opin, System.C66XX_N.SHARED_SYSTEM.INTERCONNECT.EDMA_TC2_M.memtr_write_ipin;
            CONNECT15        System.C66XX_N.SHARED_SYSTEM.EDMA.3PTC2.memtr_dbg_read_opin, System.C66XX_N.SHARED_SYSTEM.INTERCONNECT.EDMA_TC2_M.memtr_dbg_read_ipin;
            CONNECT16        System.C66XX_N.SHARED_SYSTEM.EDMA.3PTC2.memtr_dbg_write_opin, System.C66XX_N.SHARED_SYSTEM.INTERCONNECT.EDMA_TC2_M.memtr_dbg_write_ipin;
            CONNECT17        System.C66XX_N.SHARED_SYSTEM.EDMA.3PTC3.memtr_read_opin, System.C66XX_N.SHARED_SYSTEM.INTERCONNECT.EDMA_TC3_M.memtr_read_ipin;
            CONNECT18        System.C66XX_N.SHARED_SYSTEM.EDMA.3PTC3.memtr_write_opin, System.C66XX_N.SHARED_SYSTEM.INTERCONNECT.EDMA_TC3_M.memtr_write_ipin;
            CONNECT19        System.C66XX_N.SHARED_SYSTEM.EDMA.3PTC3.memtr_dbg_read_opin, System.C66XX_N.SHARED_SYSTEM.INTERCONNECT.EDMA_TC3_M.memtr_dbg_read_ipin;
            CONNECT20        System.C66XX_N.SHARED_SYSTEM.EDMA.3PTC3.memtr_dbg_write_opin, System.C66XX_N.SHARED_SYSTEM.INTERCONNECT.EDMA_TC3_M.memtr_dbg_write_ipin;
            BUSCONNECT1 MEMTR_S_M, System.C66XX_N.SHARED_SYSTEM.EDMA.3PTC0. ,  System.C66XX_N.SHARED_SYSTEM.INTERCONNECT.EDMA_TC0_S.;
            BUSCONNECT2 MEMTR_S_M, System.C66XX_N.SHARED_SYSTEM.EDMA.3PTC1. ,  System.C66XX_N.SHARED_SYSTEM.INTERCONNECT.EDMA_TC1_S.;
            BUSCONNECT3 MEMTR_S_M, System.C66XX_N.SHARED_SYSTEM.EDMA.3PTC2. ,  System.C66XX_N.SHARED_SYSTEM.INTERCONNECT.EDMA_TC2_S.;
            BUSCONNECT4 MEMTR_S_M, System.C66XX_N.SHARED_SYSTEM.EDMA.3PTC3. ,  System.C66XX_N.SHARED_SYSTEM.INTERCONNECT.EDMA_TC3_S.;
          END EDMA;
          MODULE CP_INTC0;
            //! Module Name.
            NAME              CP_INTC0;
            //! Module Type.
            TYPE              SHARED;
            SSI_VER           SC_1.0.0;
            //! DLL
            DLL               ../../../bin/components/tisim_intc_cpintc_pv_ssi.so;
            INIT_FUNC         cp_intc_init;
            INIT_DONE_FUNC    cp_init_done;
            QUIT_FUNC         cp_quit;
            //! Module Configuration
            NUMBER_OF_INTERRUPTS 208;
            NUMBER_OF_CHANNELS 56;    //For GAUSS
            NUMBER_OF_HOST_INTERRUPT 56;//For GAUSS
            NUMBER_OF_DEBUG_INTERRUPT 0;
            VECTORING 0;
            VECTORING_FULL 0;
            NESTING_SUPPORT 1;
            HOST_TYPE GENERIC;
            REVISION  0x4E820000;
            HOST_CHANNEL_MAP0    0;
            HOST_CHANNEL_MAP1    1;
            HOST_CHANNEL_MAP2    2;
            HOST_CHANNEL_MAP3    3;
            HOST_CHANNEL_MAP4    4;
            HOST_CHANNEL_MAP5    5;
            HOST_CHANNEL_MAP6    6;
            HOST_CHANNEL_MAP7    7;
            HOST_CHANNEL_MAP8    8;
            HOST_CHANNEL_MAP9    9;
            HOST_CHANNEL_MAP10    10;
            HOST_CHANNEL_MAP11    11;
            HOST_CHANNEL_MAP12    12;
            HOST_CHANNEL_MAP13    13;
            HOST_CHANNEL_MAP14    14;
            HOST_CHANNEL_MAP15    15;
            HOST_CHANNEL_MAP16    16;
            HOST_CHANNEL_MAP17    17;
            HOST_CHANNEL_MAP18    18;
            HOST_CHANNEL_MAP19    19;
            HOST_CHANNEL_MAP20    20;
            HOST_CHANNEL_MAP21    21;
            HOST_CHANNEL_MAP22    22;
            HOST_CHANNEL_MAP23    23;
            HOST_CHANNEL_MAP24    24;
            HOST_CHANNEL_MAP25    25;
            HOST_CHANNEL_MAP26    26;
            HOST_CHANNEL_MAP27    27;
            HOST_CHANNEL_MAP28    28;
            HOST_CHANNEL_MAP29    29;
            HOST_CHANNEL_MAP30    30;
            HOST_CHANNEL_MAP31    31;
            HOST_CHANNEL_MAP32    32;
            HOST_CHANNEL_MAP33    33;
            HOST_CHANNEL_MAP34    34;
            HOST_CHANNEL_MAP35    35;
            HOST_CHANNEL_MAP36    36;
            HOST_CHANNEL_MAP37    37;
            HOST_CHANNEL_MAP38    38;
            HOST_CHANNEL_MAP39    39;
            HOST_CHANNEL_MAP40    40;
            HOST_CHANNEL_MAP41    41;
            HOST_CHANNEL_MAP42    42;
            HOST_CHANNEL_MAP43    43;
            HOST_CHANNEL_MAP44    44;
            HOST_CHANNEL_MAP45    45;
            HOST_CHANNEL_MAP46    46;
            HOST_CHANNEL_MAP47    47;
            HOST_CHANNEL_MAP48    48;
            HOST_CHANNEL_MAP49    49;
            HOST_CHANNEL_MAP50    50;
            HOST_CHANNEL_MAP51    51;
            HOST_CHANNEL_MAP52    52;
            HOST_CHANNEL_MAP53    53;
            HOST_CHANNEL_MAP54    54;
            HOST_CHANNEL_MAP55    55;
          END CP_INTC0;
          MODULE CP_INTC1;
            //! Module Name.
            NAME              CP_INTC1;
            //! Module Type.
            TYPE              SHARED;
            SSI_VER           SC_1.0.0;
            //! DLL
            QUIT_FUNC         cp_quit;
            NUMBER_OF_INTERRUPTS 160;        //<CHECK>
            NUMBER_OF_CHANNELS 29;        //For GAUSS
            NUMBER_OF_HOST_INTERRUPT 29;    //For GAUSS
            VECTORING 0;
            VECTORING_FULL 0;
            NESTING_SUPPORT 1;
            HOST_TYPE GENERIC;
          END CP_INTC1;
          MODULE CP_INTC2;
            //! Module Name.
            NAME              CP_INTC2;
            //! Module Type.
            TYPE              SHARED;
            SSI_VER           SC_1.0.0;
            //! DLL
            QUIT_FUNC         cp_quit;
            NUMBER_OF_INTERRUPTS 72;        //<CHECK>
            NUMBER_OF_CHANNELS 40;        //For GAUSS
            NUMBER_OF_HOST_INTERRUPT 40;    //For GAUSS
            VECTORING 0;
            VECTORING_FULL 0;
            NESTING_SUPPORT 1;
            HOST_TYPE GENERIC;
          END CP_INTC2;
          MODULE VCP2_0;
            TYPE SHARED;
            SSI_VER SSI_1.1;
            NAME         VCP2_0;//Has to be unique
            DLL                ../../../bin/components/tisim_civ_vcp_ca.so;
            INIT_FUNC       init_vcp_model;
            INIT_DONE_FUNC  vcp_init_done;
            QUIT_FUNC       vcp_quit;
            MODULE INTERFACES;
              //NOTE: don't change the names of the VCP interfaces, they are fixed
              CONNECT1        System.C66XX_N.SHARED_SYSTEM.VCP2_0.CPU_CFG_RD, System.C66XX_N.SHARED_SYSTEM.INTERCONNECT.VCP2_0_CFG.memtr_read_opin;
              CONNECT2        System.C66XX_N.SHARED_SYSTEM.VCP2_0.CPU_CFG_WR, System.C66XX_N.SHARED_SYSTEM.INTERCONNECT.VCP2_0_CFG.memtr_write_opin;
              CONNECT3        System.C66XX_N.SHARED_SYSTEM.VCP2_0.CPU_DBG_RD, System.C66XX_N.SHARED_SYSTEM.INTERCONNECT.VCP2_0_CFG.memtr_dbg_read_opin;
              CONNECT4        System.C66XX_N.SHARED_SYSTEM.VCP2_0.CPU_DBG_WR, System.C66XX_N.SHARED_SYSTEM.INTERCONNECT.VCP2_0_CFG.memtr_dbg_write_opin;
              CONNECT5        System.C66XX_N.SHARED_SYSTEM.VCP2_0.DMA_CFG_RD, System.C66XX_N.SHARED_SYSTEM.INTERCONNECT.VCP2_0_SLV.memtr_read_opin;
              CONNECT6        System.C66XX_N.SHARED_SYSTEM.VCP2_0.DMA_CFG_WR, System.C66XX_N.SHARED_SYSTEM.INTERCONNECT.VCP2_0_SLV.memtr_write_opin;
              CONNECT7        System.C66XX_N.SHARED_SYSTEM.VCP2_0.DMA_DBG_RD, System.C66XX_N.SHARED_SYSTEM.INTERCONNECT.VCP2_0_SLV.memtr_dbg_read_opin;
              CONNECT8        System.C66XX_N.SHARED_SYSTEM.VCP2_0.DMA_DBG_WR, System.C66XX_N.SHARED_SYSTEM.INTERCONNECT.VCP2_0_SLV.memtr_dbg_write_opin;
              CONNECT9        System.C66XX_N.SHARED_SYSTEM.VCP2_0.VCP_CLK, System.C66XX_N.SHARED_SYSTEM_INTF.clock_out;
              CONNECT10        System.C66XX_N.SHARED_SYSTEM.VCP2_0.VCP_RESET, System.C66XX_N.SHARED_SYSTEM_INTF.reset_out;
              CONNECT11        System.C66XX_N.SHARED_SYSTEM.VCP2_0.VCP_ENDIAN, System.C66XX_N.CPU_SYSTEM_0.CPU0_endianness;
            END INTERFACES;
            MODULE USER_INPUTS;
              INPUT1  VCP_DMA_START_ADDRESS ,  0x22A00000;
              INPUT2  VCP_DMA_END_ADDRESS ,    0x22A0FFFF;
              INPUT3  VCP_CFG_START_ADDRESS,   0x021D0000;
              INPUT4  VCP_CFG_END_ADDRESS,     0x021D00FF;
              INPUT5    PID,             0x480A0000;
            END USER_INPUTS;
          END VCP2_0;
          MODULE VCP2_1;
            TYPE SHARED;
            SSI_VER SSI_1.1;
            NAME         VCP2_1;//Has to be unique
            QUIT_FUNC       vcp_quit;
            MODULE INTERFACES;
              CONNECT1        System.C66XX_N.SHARED_SYSTEM.VCP2_1.CPU_CFG_RD, System.C66XX_N.SHARED_SYSTEM.INTERCONNECT.VCP2_1_CFG.memtr_read_opin;
              CONNECT2        System.C66XX_N.SHARED_SYSTEM.VCP2_1.CPU_CFG_WR, System.C66XX_N.SHARED_SYSTEM.INTERCONNECT.VCP2_1_CFG.memtr_write_opin;
              CONNECT3        System.C66XX_N.SHARED_SYSTEM.VCP2_1.CPU_DBG_RD, System.C66XX_N.SHARED_SYSTEM.INTERCONNECT.VCP2_1_CFG.memtr_dbg_read_opin;
              CONNECT4        System.C66XX_N.SHARED_SYSTEM.VCP2_1.CPU_DBG_WR, System.C66XX_N.SHARED_SYSTEM.INTERCONNECT.VCP2_1_CFG.memtr_dbg_write_opin;
              CONNECT5        System.C66XX_N.SHARED_SYSTEM.VCP2_1.DMA_CFG_RD, System.C66XX_N.SHARED_SYSTEM.INTERCONNECT.VCP2_1_SLV.memtr_read_opin;
              CONNECT6        System.C66XX_N.SHARED_SYSTEM.VCP2_1.DMA_CFG_WR, System.C66XX_N.SHARED_SYSTEM.INTERCONNECT.VCP2_1_SLV.memtr_write_opin;
              CONNECT7        System.C66XX_N.SHARED_SYSTEM.VCP2_1.DMA_DBG_RD, System.C66XX_N.SHARED_SYSTEM.INTERCONNECT.VCP2_1_SLV.memtr_dbg_read_opin;
              CONNECT8        System.C66XX_N.SHARED_SYSTEM.VCP2_1.DMA_DBG_WR, System.C66XX_N.SHARED_SYSTEM.INTERCONNECT.VCP2_1_SLV.memtr_dbg_write_opin;
              CONNECT9        System.C66XX_N.SHARED_SYSTEM.VCP2_1.VCP_CLK, System.C66XX_N.SHARED_SYSTEM_INTF.clock_out;
              CONNECT10        System.C66XX_N.SHARED_SYSTEM.VCP2_1.VCP_RESET, System.C66XX_N.SHARED_SYSTEM_INTF.reset_out;
              CONNECT11        System.C66XX_N.SHARED_SYSTEM.VCP2_1.VCP_ENDIAN, System.C66XX_N.CPU_SYSTEM_0.CPU0_endianness;
            END INTERFACES;
            MODULE USER_INPUTS;
              INPUT1  VCP_DMA_START_ADDRESS ,  0x22B00000;
              INPUT2  VCP_DMA_END_ADDRESS ,    0x22B0FFFF;
              INPUT3  VCP_CFG_START_ADDRESS,   0x021D4000;
              INPUT4  VCP_CFG_END_ADDRESS,     0x021D40FF;
            END USER_INPUTS;
          END VCP2_1;
          MODULE SEMAPHORE;
            TYPE SHARED;
            SSI_VER SSI_1.1;
            NAME         semaphore2;
            DLL             ../../../bin/components/semaphore2.so;
            INIT_FUNC       semaphore2_init;
            INIT_DONE_FUNC  semaphore2_init_done;
            QUIT_FUNC       semaphore2_quit;
            MODULE USER_INPUTS;
              INPUT2  PID,          0x48021200;
              INPUT3  NUM_MASTERS,       4;    //Same as TCI6616
              INPUT4  NUM_RESOURCES,  32;
            END USER_INPUTS;
          END SEMAPHORE;
          MODULE TCP3D_A;
            TYPE SHARED;
            SSI_VER SSI_1.1;
            NAME         tcp3d_a;
            DLL             ../../../bin/components/tcp3d.so;
            INIT_FUNC       tcp3d_init;
            INIT_DONE_FUNC  tcp3d_init_done;
            QUIT_FUNC       tcp3d_quit;
            MODULE USER_INPUTS;
              INPUT1    PID ,         0x4804011E;
              INPUT2    CPU_NAME ,    SHARED;
              INPUT3    CLK_DIV ,     0x2;
              //INPUT4  DBG_LOG ,    C:\Tcp3d_a_Debug.log;
            END USER_INPUTS;
          END TCP3D_A;
          MODULE IPC;
            TYPE SHARED;
            SSI_VER SC_1.0.0;
            DLL           ../../../bin/components/sim_inter_core_interrupt.so;
            INIT_FUNC         inter_core_interrupt_init_func;
            INIT_DONE_FUNC    inter_core_interrupt_init_done_func;
            QUIT_FUNC         inter_core_interrupt_quit_func;
            CLOCK_DIVIDE_RATIO  6;        //<CHECK>
            NO_OF_CORES        2;
            WAITING_TIME_WINDOW 8;        //<CHECK>
            NMIGR_SUPPORT            ON;    //Enabling NMIGR support
            NMIGR_START_OFFSET        0;    //Indicates the offset from the start of the Inter-core memory region for inter-core NMIGR
            NMI_PULSE_WINDOW            1;
            IPCGR_START_OFFSET        16;    //offset in no. of bytes, offset/4
            IPCAR_START_OFFSET        32;    //offset in no. of bytes, offset/4
            ENABLE_WARNING_MSGS         OFF;
            HOSTREG_OFFSET_FROM_IPCREG_START 15;
          END IPC;
          MODULE GPIO;
            NAME            gpio;
            TYPE            SHARED;
            SSI_VER            SSI_1.1;
            DLL            ../../../bin/components/tisim_gpio_pv.so;
            INIT_FUNC        gpio_init;
            INIT_DONE_FUNC        gpio_init_done;
            QUIT_FUNC        gpio_quit;
            MODULE INTERFACES;
              CONNECT1        System.C66XX_N.SHARED_SYSTEM.GPIO.gpio_cfg_write_ipin, System.C66XX_N.SHARED_SYSTEM.INTERCONNECT.GPIO_CFG.memtr_write_opin;
              CONNECT2        System.C66XX_N.SHARED_SYSTEM.GPIO.gpio_cfg_read_ipin,System.C66XX_N.SHARED_SYSTEM.INTERCONNECT.GPIO_CFG.memtr_read_opin;
              CONNECT3        System.C66XX_N.SHARED_SYSTEM.GPIO.gpio_dbg_read_ipin, System.C66XX_N.SHARED_SYSTEM.INTERCONNECT.GPIO_CFG.memtr_dbg_read_opin;
              CONNECT4        System.C66XX_N.SHARED_SYSTEM.GPIO.gpio_dbg_write_ipin, System.C66XX_N.SHARED_SYSTEM.INTERCONNECT.GPIO_CFG.memtr_dbg_write_opin;
              CONNECT5        System.C66XX_N.SHARED_SYSTEM.GPIO.gpio_reset_ipin, System.C66XX_N.SHARED_SYSTEM_INTF.reset_out;
              CONNECT6        System.C66XX_N.SHARED_SYSTEM.GPIO.gpio_endian_ipin, System.C66XX_N.CPU_SYSTEM_0.CPU0_endianness;
              CONNECT7        System.C66XX_N.SHARED_SYSTEM.GPIO.gpio_error_opin,System.C66XX_N.CPU_SYSTEM_0.CPU0.error_intf_ssi;
              CONNECT8        System.C66XX_N.SHARED_SYSTEM.GPIO.gpio_error_opin,System.C66XX_N.CPU_SYSTEM_1.CPU1.error_intf_ssi;
            END INTERFACES;
            MODULE USER_INPUTS;
              INPUT2  NUM_GPINT_PINS,    32; //Gauss supports 32
              INPUT3  PID,         0x44831105;
            END USER_INPUTS;
          END GPIO;
          //Same as TCI6616 for GAUSS
          MODULE QUEUE_MANAGER;
            NAME            queue_manager;
            TYPE            SHARED;
            SSI_VER            SSI_1.1;
            DLL            ../../../bin/components/qmss.so;
            //CPU_VIEW        <<CPU_MODULE_NAME>>;  //Update this entry with the CPU module name in the system
            INIT_FUNC        qmss_init;
            INIT_DONE_FUNC        qmss_init_done;
            QUIT_FUNC        qmss_quit;
            //User Inputs to be passed from CPU to the peripheral model
            MODULE USER_INPUTS;
              INPUT1  CPU_NAME              , SHARED;
              //START:Darshan
              INPUT2  NUM_QM                , 1;
              INPUT3  QUEUES_PER_QM         , 8192;
              INPUT4  MEM_REGN_PER_QM       , 20;
              INPUT5  NUM_PDSP              , 2;
              INPUT6  NUM_INTD              , 1;
              INPUT7  NUM_TIMER             , 2;
              INPUT8  NUM_MCDMA             , 1;
              INPUT9  LINKRAM_BASE          , 0x00080000;
              INPUT10 LINKRAM_INDEXES       , 16384;
              INPUT11 QM_CFG_BASE           , 0x00068000;
              INPUT12 QM_CFG_OFFSET         , 0x00002000;
              INPUT13 QM_DESC_BASE          , 0x0006a000;
              INPUT14 QM_DESC_OFFSET        , 0x00002000;
              INPUT15 QM_QUE_BASE           , 0x00020000;
              INPUT16 QM_QUE_OFFSET         , 0x00020000;
              INPUT17 QM_PEEK_BASE          , 0x00000000;
              INPUT18 QM_PEEK_OFFSET        , 0x00020000;
              INPUT19 QM_STATUS_BASE        , 0x00062000;
              INPUT20 QM_STATUS_OFFSET      , 0x00000400;
              INPUT21 QM_PROXY_BASE         , 0x00040000;
              INPUT22 QM_PROXY_OFFSET       , 0x00020000;
              INPUT23 PDSP_GBL_SCRTCH_BASE  , 0x00000000; //na on Ny/Sh/Tn/Aptn
              INPUT24 PDSP_GBL_SCRTCH_SIZE  , 0x00000000; //na on Ny/Sh/Tn/Aptn
              INPUT25 PDSP_LCL_SCRTCH_BASE  , 0x000b8000;
              INPUT26 PDSP_LCL_SCRTCH_OFFSET, 0x00004000;
              INPUT27 PDSP_REG_BASE         , 0x0006E000;
              INPUT28 PDSP_REG_OFFSET       , 0x00001000;
              INPUT29 PDSP_DBG_BASE         , 0x000b0000;
              INPUT30 PDSP_DBG_OFFSET       , 0x00001000;
              INPUT31 PDSP_IRAM_BASE        , 0x00060000;
              INPUT32 PDSP_IRAM_OFFSET      , 0x00001000;
              INPUT33 PDSP_SCRTCH_EVEN_SIZE , 0x00004000;
              INPUT34 PDSP_SCRTCH_ODD_SIZE  , 0x00002000;
              INPUT35 QM_INTD_BASE          , 0x000a0000;
              INPUT36 QM_INTD_OFFSET        , 0x00001000;
              INPUT37 QM_TIMER_BASE         , 0x000a8000;
              INPUT38 QM_TIMER_OFFSET       , 0x00000800;
              INPUT39 QM_MCDMA_BASE         , 0x00090000;
              INPUT40 QM_MCDMA_OFFSET       , 0x00000800;
              INPUT41 TOTAL_CFG_SPACE       , 0x000c0000;
              INPUT42 INTC_1ST_QNUM         , 650;
              INPUT43 INTC_NUM_QUEUES       , 22;
              INPUT44 STARVATION_1ST_QNUM   , 736;
              INPUT45 STARVATION_NUM_QUEUES , 64;
              INPUT46 TIMER_TICK            , 7;
              INPUT47 TIMER_RESOLUTION      , 1000;
              INPUT48 NUM_PKTDMA            , 2;    //Num pktDMA defs to follow
              INPUT49 PKTDMA_1_TXQ          , 800;  //Infra1
              INPUT50 PKTDMA_1_NUMQ         , 32;
              INPUT51 PKTDMA_2_TXQ          , 672;  //SRIO
              INPUT52 PKTDMA_2_NUMQ         , 16;
              //                INPUT53 DEBUG_LOG             , qmss_debug_log.txt;
              //END:Darshan
            END USER_INPUTS;
          END QUEUE_MANAGER;
          MODULE CDMA_INFRA;
            NAME            cdma_qm;
            TYPE            SHARED;
            SSI_VER            SSI_1.1;
            DLL            ../../../bin/components/cdma.so;
            INIT_FUNC        cdma_init;
            INIT_DONE_FUNC        cdma_init_done;
            QUIT_FUNC        cdma_quit;
            MODULE    USER_INPUTS;
              INPUT2  NUM_RX_CHANNELS  ,     32;
              INPUT3  NUM_TX_CHANNELS  ,     32;
              INPUT4  NUM_RX_FLOWS     ,     64;
              INPUT5  RX_FIFO_SIZE     ,     32;
              INPUT6  TX_FIFO_SIZE     ,     33;    //(+1 for CDMA) as per Dave's mail
              INPUT7  FIFO_DESC_SIZE   ,     8;
              INPUT8  RX_FIFO_DEPTH    ,     32;
              INPUT9  TX_FIFO_DEPTH    ,     48;
              INPUT10 TX_CHUNK_READ    ,     128;
              INPUT11    GLOBAL_CFG_OFFSET,    0x0006c000;
              INPUT12    TX_CHAN_CFG_OFFSET,    0x0006c400;
              INPUT13    RX_CHAN_CFG_OFFSET,    0x0006c800;
              INPUT14    TX_SCHED_CFG_OFFSET,    0x0006cc00;
              INPUT15    RX_FLOW_CFG_OFFSET,    0x0006d000;
              INPUT16    QM_QUE_MMR_BASE  ,    0x34020000;    //As per Dave's mail
              //Start:Darshan
              INPUT17 FIRST_HW_QNUM    ,        800;
              INPUT18 PACKET_OFFSET    ,        0;
              INPUT19 PACKET_TAG       ,      0;
              INPUT20 TX_SCHED_BYPASS  ,      0;
              INPUT21 TX_DESCRIPTOR_RELEASE , 0;
              INPUT22 LOOPBACK_MODE    ,        1;
              INPUT23 PAYLOAD_TRANSPARENCY  , 1;
              INPUT24 CYCLE_APPROX_MODE, 0;
              INPUT25 QM_POP_DELAY, 30;
              INPUT26 QM_PUSH_DELAY, 45;
              INPUT27 MEM_RW_DELAY, 1;
              INPUT28 CLK_DIV, 3;
              // INPUT29 DEBUG_LOG,        CDMA_qmss_debug_log.txt;
              //End:Darshan
            END    USER_INPUTS;
          END CDMA_INFRA;
          MODULE INTD_TCP3D_A;
            NAME            intd_tcp3d_a;
            TYPE            SHARED;
            SSI_VER            SSI_1.1;
            DLL            ../../../bin/components/tisim_combiner_intd.so;
            INIT_FUNC        init_combiner_intd;
            INIT_DONE_FUNC        init_combiner_intd_done;
            QUIT_FUNC        quit_combiner_intd;
            MODULE    USER_INPUTS;
              INPUT2  NUMBER_OF_INTERRUPTS  ,     2;
            END    USER_INPUTS;
          END INTD_TCP3D_A;
          MODULE PCIE;
            NAME            pciess;
            TYPE            SHARED;
            SSI_VER            SSI_1.1;
            DLL            ../../../bin/components/tisim_pciess.so;
            INIT_FUNC        pciess_init;
            INIT_DONE_FUNC        pciess_init_done;
            QUIT_FUNC        pciess_quit;
            MODULE INTERFACES;
              CONNECT1        System.C66XX_N.SHARED_SYSTEM.PCIE.pciess_reset, System.C66XX_N.SHARED_SYSTEM_INTF.reset_out;
              CONNECT2        System.C66XX_N.SHARED_SYSTEM.PCIE.pciess_big_endian_ipin, System.C66XX_N.CPU_SYSTEM_0.CPU0_endianness_big_endian;
              CONNECT3        System.C66XX_N.SHARED_SYSTEM.PCIE.pciess_slv_read_ipin, System.C66XX_N.SHARED_SYSTEM.INTERCONNECT.PCIE_SLV.memtr_read_opin;
              CONNECT4        System.C66XX_N.SHARED_SYSTEM.PCIE.pciess_slv_write_ipin, System.C66XX_N.SHARED_SYSTEM.INTERCONNECT.PCIE_SLV.memtr_write_opin;
              CONNECT5        System.C66XX_N.SHARED_SYSTEM.PCIE.pciess_slv_dbg_read_ipin, System.C66XX_N.SHARED_SYSTEM.INTERCONNECT.PCIE_SLV.memtr_dbg_read_opin;
              CONNECT6        System.C66XX_N.SHARED_SYSTEM.PCIE.pciess_slv_dbg_write_ipin, System.C66XX_N.SHARED_SYSTEM.INTERCONNECT.PCIE_SLV.memtr_dbg_write_opin;
              //NOTE:
              // Master interface not modeled.
              // Interrupt functionality not modeled, dll not connected.
            END INTERFACES;
            MODULE    USER_INPUTS;
              INPUT1        PID    ,    0x4e300000;
              INPUT2        CLK_DIV    ,    3;
              INPUT3        CFG_TYPE,    0;
              INPUT4        CPU_NAME,     SHARED;
              INPUT5        CFG_BASE,     0x21800000;
            END    USER_INPUTS;
          END PCIE;
          MODULE MEMTR_MSMC_Adaptor;
            NAME            memtr_msmc_adaptor;
            TYPE            SHARED;
            SSI_VER         SC_1.0.0;
            //-- Entry-point
            //-- Configurable parameters
            TERMINAL        MT_MIF2SSI;
          END MEMTR_MSMC_Adaptor;
          MODULE MEMTR_FLATMEM_36BIT_Adaptor;
            NAME            memtr_flatmem_36bit_adaptor;
            TYPE            SHARED;
            SSI_VER         SC_1.0.0;
            //-- Entry-point
            TERMINAL        MT_SSI2MMAP;
          END MEMTR_FLATMEM_36BIT_Adaptor;
          MODULE MEMTR_CGEM0_Slv_Adaptor;
            NAME            memtr_cgem0_slv_adaptor;
            TYPE            SHARED;
            SSI_VER         SC_1.0.0;
            //-- Entry-point
          END MEMTR_CGEM0_Slv_Adaptor;
          MODULE MEMTR_CGEM1_Slv_Adaptor;
            NAME            memtr_cgem1_slv_adaptor;
            TYPE            SHARED;
            SSI_VER         SC_1.0.0;
            //-- Entry-point
          END MEMTR_CGEM1_Slv_Adaptor;
          MODULE FLATMEM_36BIT;
            NAME            flatmem_36bit;    // Same name as MODULE
            TYPE            SHARED;
            SSI_VER            SC_1.0.0;
            DLL            ../../../bin/components/sim_memstore_36bit_ssi.so;
            INIT_FUNC        memstore_36bit_init;
            INIT_DONE_FUNC        memstore_36bit_init_done;
            QUIT_FUNC        memstore_36bit_quit;
          END FLATMEM_36BIT;
          MODULE PSC;
            NAME            psc;
            TYPE            SHARED;
            SSI_VER            SSI_1.1;
            DLL            ../../../bin/components/tisim_aptn_psc_ssi.so;
            INIT_FUNC        init_aptn_psc_intf;
            INIT_DONE_FUNC        init_done_aptn_psc_intf;
            QUIT_FUNC        quit_aptn_psc_intf;
            MODULE INTERFACES;
              CONNECT1        System.C66XX_N.SHARED_SYSTEM.PSC.mbus_in_write, System.C66XX_N.SHARED_SYSTEM.INTERCONNECT.PSC_CFG.memtr_write_opin;
              CONNECT2        System.C66XX_N.SHARED_SYSTEM.PSC.mbus_in_read, System.C66XX_N.SHARED_SYSTEM.INTERCONNECT.PSC_CFG.memtr_read_opin;
              CONNECT3        System.C66XX_N.SHARED_SYSTEM.PSC.mbus_in_dbg_read, System.C66XX_N.SHARED_SYSTEM.INTERCONNECT.PSC_CFG.memtr_dbg_read_opin;
              CONNECT4        System.C66XX_N.SHARED_SYSTEM.PSC.mbus_in_dbg_write, System.C66XX_N.SHARED_SYSTEM.INTERCONNECT.PSC_CFG.memtr_dbg_write_opin;
              CONNECT5        System.C66XX_N.SHARED_SYSTEM.PSC.rst_in, System.C66XX_N.SHARED_SYSTEM_INTF.reset_out;
              CONNECT6        System.C66XX_N.SHARED_SYSTEM.PSC.endian_in, System.C66XX_N.CPU_SYSTEM_0.CPU0_endianness;
              CONNECT7        System.C66XX_N.SHARED_SYSTEM.PSC.errmsg, System.C66XX_N.CPU_SYSTEM_0.CPU0.error_intf_ssi;
              CONNECT8        System.C66XX_N.SHARED_SYSTEM.PSC.errmsg, System.C66XX_N.CPU_SYSTEM_1.CPU1.error_intf_ssi;
            END INTERFACES;
            MODULE USER_INPUTS;
              INPUT1  CPU_NAME,SHARED;
              INPUT2  PID, 0x44825A00;
              INPUT3  NUM_POWER_DOMAINS, 32;
              //Power domain assignments for modules
              //As per GAUSS power spec
              INPUT4    MDCFG0_PWRDOM, 0;
              INPUT5    MDCFG1_PWRDOM, 0;
              INPUT6    MDCFG2_PWRDOM, 0;
              INPUT7    MDCFG3_PWRDOM, 0;
              INPUT8    MDCFG4_PWRDOM, 0;
              INPUT9    MDCFG5_PWRDOM, 1;
              INPUT10    MDCFG6_PWRDOM, 1;
              INPUT11    MDCFG7_PWRDOM, 2;
              INPUT12    MDCFG8_PWRDOM, 2;
              INPUT13    MDCFG9_PWRDOM, 2;
              INPUT14    MDCFG10_PWRDOM, 3;
              INPUT15    MDCFG11_PWRDOM, 4;
              INPUT16    MDCFG12_PWRDOM, 5;
              INPUT17    MDCFG13_PWRDOM, 6;
              INPUT18    MDCFG14_PWRDOM, 7;
              INPUT19    MDCFG15_PWRDOM, 8;
              INPUT20    MDCFG16_PWRDOM, 8;
              INPUT21    MDCFG17_PWRDOM, 9;
              INPUT22    MDCFG18_PWRDOM, 10;
              INPUT23    MDCFG19_PWRDOM, 11;
              INPUT24    MDCFG20_PWRDOM, 12;
              INPUT25    MDCFG21_PWRDOM, 12;
              INPUT26    MDCFG22_PWRDOM, 12;
              INPUT27    MDCFG23_PWRDOM, 13;
              INPUT28    MDCFG24_PWRDOM, 14;
              INPUT29    MDCFG25_PWRDOM, 14;
              INPUT30    MDCFG26_PWRDOM, 15;
              INPUT31    MDCFG27_PWRDOM, 15;
              INPUT32    MDCFG28_PWRDOM, 16;
              INPUT33    MDCFG29_PWRDOM, 17;
              INPUT34    MDCFG30_PWRDOM, 18;
              INPUT35    MDCFG31_PWRDOM, 0;
            END USER_INPUTS;
          END PSC;
          MODULE SSI2SOCK_PORT0;
            NAME            ssi2sock;
            TYPE            SHARED;
            SSI_VER            SSI_1.1;
            DLL            ../../../bin/components/ssi2sock.so;
            INIT_FUNC        ssi2sock_init;
            INIT_DONE_FUNC        ssi2sock_init_done;
            QUIT_FUNC        ssi2sock_quit;
            MODULE    INTERFACES;
              //SSI connections to CPU and other peripheral;
              CONNECT1        System.C66XX_N.SHARED_SYSTEM.SSI2SOCK_PORT0.SSI2SOCK_reset, System.C66XX_N.SHARED_SYSTEM_INTF.reset_out;
              CONNECT2        System.C66XX_N.SHARED_SYSTEM.SSI2SOCK_PORT0.SSI2SOCK_receive_data, System.C66XX_N.SHARED_SYSTEM.SRIO.srio_tx_opin_port0;
              CONNECT3        System.C66XX_N.SHARED_SYSTEM.SSI2SOCK_PORT0.SSI2SOCK_send_data, System.C66XX_N.SHARED_SYSTEM.SRIO.srio_rx_ipin_port0;
              // Propogate the error to every CPU model.
              CONNECT4        System.C66XX_N.SHARED_SYSTEM.SSI2SOCK_PORT0.SSI2SOCK_error_opin, System.C66XX_N.CPU_SYSTEM_0.CPU0.error_intf_ssi;
              CONNECT5        System.C66XX_N.SHARED_SYSTEM.SSI2SOCK_PORT0.SSI2SOCK_error_opin, System.C66XX_N.CPU_SYSTEM_1.CPU1.error_intf_ssi;
            END    INTERFACES;
            MODULE    USER_INPUTS;
              INPUT1    SOCK,          OFF;
              INPUT2    SOCK_PORT,     2048;
              INPUT3  MAX_NUM_BYTES_PER_SOCK_RECV, 16560; // Number of bytes attempted to receive
              // for every Socket receive call
              // Assuming each SRIO packet contains 4140
              // bytes (max), the simulator is configured to
              // handle upto 4 SRIO packets, in one socket
              // read call.
              INPUT4  RECV_FIFO_LENGTH, 10; // Fifo length. Each fifo entry can
              // hold MAX_NUM_BYTES_PER_SOCK_RECV bytes
              INPUT5    CPU_NAME, SHARED;
              INPUT6  SOCK_PROTOCOL, TCP;
              INPUT7    SOCK_TYPE,     SERVER;
            END    USER_INPUTS;
          END SSI2SOCK_PORT0;
          MODULE SRIO;
            NAME            srio;
            TYPE            SHARED;
            SSI_VER         SSI_1.1;
            DLL             ../../../bin/components/tisim_srio.so;
            INIT_FUNC       srio_init;
            INIT_DONE_FUNC  srio_init_done;
            QUIT_FUNC       srio_quit;
            MODULE    INTERFACES;
              //! NOTE: SRIO Master( Master port for all other traffic other than CPPI) has not been integrated)
              CONNECT1        System.C66XX_N.SHARED_SYSTEM.SRIO.srio_reset, System.C66XX_N.SHARED_SYSTEM_INTF.reset_out;
              CONNECT2        System.C66XX_N.SHARED_SYSTEM.SRIO.srio_big_endian_ipin, System.C66XX_N.CPU_SYSTEM_0.CPU0_endianness_big_endian;
              //These pins setup the Streaming interfaces
              CONNECT3        System.C66XX_N.SHARED_SYSTEM.SRIO.srio_tstrm_thread_mready_opin, System.C66XX_N.SHARED_SYSTEM.CDMA_SRIO.cdma_rstrm_thread_mready_ipin;
              CONNECT4        System.C66XX_N.SHARED_SYSTEM.SRIO.srio_tstrm_thread_sready_ipin, System.C66XX_N.SHARED_SYSTEM.CDMA_SRIO.cdma_rstrm_thread_sready_opin;
              CONNECT5        System.C66XX_N.SHARED_SYSTEM.SRIO.srio_tstrm_data_opin, System.C66XX_N.SHARED_SYSTEM.CDMA_SRIO.cdma_rstrm_data_ipin;
              CONNECT6        System.C66XX_N.SHARED_SYSTEM.SRIO.srio_tstrm_data_accept_ipin, System.C66XX_N.SHARED_SYSTEM.CDMA_SRIO.cdma_rstrm_data_accept_opin;
              CONNECT7        System.C66XX_N.SHARED_SYSTEM.CDMA_SRIO.cdma_tstrm_thread_mready_opin, System.C66XX_N.SHARED_SYSTEM.SRIO.srio_rstrm_thread_mready_ipin;
              CONNECT8        System.C66XX_N.SHARED_SYSTEM.CDMA_SRIO.cdma_tstrm_thread_sready_ipin, System.C66XX_N.SHARED_SYSTEM.SRIO.srio_rstrm_thread_sready_opin;
              CONNECT9        System.C66XX_N.SHARED_SYSTEM.CDMA_SRIO.cdma_tstrm_data_opin, System.C66XX_N.SHARED_SYSTEM.SRIO.srio_rstrm_data_ipin;
              CONNECT10        System.C66XX_N.SHARED_SYSTEM.CDMA_SRIO.cdma_tstrm_data_accept_ipin, System.C66XX_N.SHARED_SYSTEM.SRIO.srio_rstrm_data_accept_opin;
              // CFG and DBG read/write pins
              CONNECT11        System.C66XX_N.SHARED_SYSTEM.SRIO.srio_cfg_read_ipin, System.C66XX_N.SHARED_SYSTEM.INTERCONNECT.SRIO_CFG.memtr_read_opin;
              CONNECT12        System.C66XX_N.SHARED_SYSTEM.SRIO.srio_cfg_write_ipin, System.C66XX_N.SHARED_SYSTEM.INTERCONNECT.SRIO_CFG.memtr_write_opin;
              CONNECT13        System.C66XX_N.SHARED_SYSTEM.SRIO.srio_cfg_dbg_read_ipin, System.C66XX_N.SHARED_SYSTEM.INTERCONNECT.SRIO_CFG.memtr_dbg_read_opin;
              CONNECT14        System.C66XX_N.SHARED_SYSTEM.SRIO.srio_cfg_dbg_write_ipin, System.C66XX_N.SHARED_SYSTEM.INTERCONNECT.SRIO_CFG.memtr_dbg_write_opin;
              // Data region interface
              CONNECT15        System.C66XX_N.SHARED_SYSTEM.INTERCONNECT.SRIO_DMA.memtr_read_opin, System.C66XX_N.SHARED_SYSTEM.SRIO.srio_dma_read_ipin;
              CONNECT16        System.C66XX_N.SHARED_SYSTEM.INTERCONNECT.SRIO_DMA.memtr_write_opin, System.C66XX_N.SHARED_SYSTEM.SRIO.srio_dma_write_ipin;
              CONNECT17        System.C66XX_N.SHARED_SYSTEM.INTERCONNECT.SRIO_DMA.memtr_dbg_read_opin, System.C66XX_N.SHARED_SYSTEM.SRIO.srio_dma_dbg_read_ipin;
              CONNECT18        System.C66XX_N.SHARED_SYSTEM.INTERCONNECT.SRIO_DMA.memtr_dbg_write_opin, System.C66XX_N.SHARED_SYSTEM.SRIO.srio_dma_dbg_write_ipin;
              // Connect SRIO output ports and ready pins to inputs to loopback for testing
              //CONNECT19        System.C66XX_N.SHARED_SYSTEM.SRIO.srio_tx_opin_port0, System.C66XX_N.SHARED_SYSTEM.SRIO.srio_rx_ipin_port0;
              CONNECT19        System.C66XX_N.SHARED_SYSTEM.SRIO.srio_tx_opin_port1, System.C66XX_N.SHARED_SYSTEM.SRIO.srio_rx_ipin_port1;
              CONNECT20        System.C66XX_N.SHARED_SYSTEM.SRIO.srio_tx_opin_port2, System.C66XX_N.SHARED_SYSTEM.SRIO.srio_rx_ipin_port2;
              CONNECT21        System.C66XX_N.SHARED_SYSTEM.SRIO.srio_tx_opin_port3, System.C66XX_N.SHARED_SYSTEM.SRIO.srio_rx_ipin_port3;
              //CONNECT23        System.C66XX_N.SHARED_SYSTEM.SRIO.srio_rx_ready_opin_port0, System.C66XX_N.SHARED_SYSTEM.SRIO.srio_tx_ready_ack_ipin_port0;
              CONNECT22        System.C66XX_N.SHARED_SYSTEM.SRIO.srio_rx_ready_opin_port1, System.C66XX_N.SHARED_SYSTEM.SRIO.srio_tx_ready_ack_ipin_port1;
              CONNECT23        System.C66XX_N.SHARED_SYSTEM.SRIO.srio_rx_ready_opin_port2, System.C66XX_N.SHARED_SYSTEM.SRIO.srio_tx_ready_ack_ipin_port2;
              CONNECT24        System.C66XX_N.SHARED_SYSTEM.SRIO.srio_rx_ready_opin_port3, System.C66XX_N.SHARED_SYSTEM.SRIO.srio_tx_ready_ack_ipin_port3;
            END    INTERFACES;
            MODULE    USER_INPUTS;
              INPUT2 CLK_DIV,          3;
              // INPUT3 FILE_LOG,      srio_dbg;
            END    USER_INPUTS;
          END SRIO;
          //////////        Config spec for CDMA_SRIO Module                              ////////////////////
          MODULE CDMA_SRIO;
            NAME            cdma_srio;
            TYPE            SHARED;
            SSI_VER         SSI_1.1;
            MODULE    INTERFACES;
              CONNECT1        System.C66XX_N.SHARED_SYSTEM.CDMA_SRIO.cdma_reset_ipin, System.C66XX_N.SHARED_SYSTEM_INTF.reset_out;
              CONNECT2        System.C66XX_N.SHARED_SYSTEM.CDMA_SRIO.cdma_endian_ipin, System.C66XX_N.CPU_SYSTEM_0.CPU0_endianness_big_endian;
              //These pins allow the CDMA to read/write memory.
              CONNECT3        System.C66XX_N.SHARED_SYSTEM.CDMA_SRIO.cdma_mstr_read_opin, System.C66XX_N.SHARED_SYSTEM.INTERCONNECT.CDMA_SRIO_MASTER.memtr_read_ipin;
              CONNECT4        System.C66XX_N.SHARED_SYSTEM.CDMA_SRIO.cdma_mstr_write_opin, System.C66XX_N.SHARED_SYSTEM.INTERCONNECT.CDMA_SRIO_MASTER.memtr_write_ipin;
              CONNECT5        System.C66XX_N.SHARED_SYSTEM.CDMA_SRIO.cdma_cfg_read_ipin, System.C66XX_N.SHARED_SYSTEM.INTERCONNECT.CDMA_SRIO_CFG.memtr_read_opin;
              CONNECT6        System.C66XX_N.SHARED_SYSTEM.CDMA_SRIO.cdma_cfg_write_ipin, System.C66XX_N.SHARED_SYSTEM.INTERCONNECT.CDMA_SRIO_CFG.memtr_write_opin;
              CONNECT7        System.C66XX_N.SHARED_SYSTEM.CDMA_SRIO.cdma_dbg_read_ipin, System.C66XX_N.SHARED_SYSTEM.INTERCONNECT.CDMA_SRIO_CFG.memtr_dbg_read_opin;
              CONNECT8        System.C66XX_N.SHARED_SYSTEM.CDMA_SRIO.cdma_dbg_write_ipin, System.C66XX_N.SHARED_SYSTEM.INTERCONNECT.CDMA_SRIO_CFG.memtr_dbg_write_opin;
              CONNECT9        System.C66XX_N.SHARED_SYSTEM.CDMA_SRIO.cdma_rx_teardown_req_opin, System.C66XX_N.SHARED_SYSTEM.CDMA_SRIO.cdma_rx_teardown_ack_ipin;
            END    INTERFACES;
            MODULE    USER_INPUTS;
              INPUT2  NUM_RX_CHANNELS,    16;
              INPUT3  NUM_TX_CHANNELS,    16;
              INPUT4  NUM_RX_FLOWS,       20;
              INPUT5  RX_FIFO_SIZE,       1024;
              INPUT6  TX_FIFO_SIZE,       1025;  // +1 is for CDMA internal usage
              INPUT7  FIFO_DESC_SIZE,     8;
              INPUT8  RX_FIFO_DEPTH,      16;
              INPUT9  TX_FIFO_DEPTH,      16;
              INPUT10 TX_CHUNK_READ,      1024;
              INPUT11 GLOBAL_CFG_OFFSET,  0x00001000;
              INPUT12 TX_CHAN_CFG_OFFSET, 0x00001400;
              INPUT13 RX_CHAN_CFG_OFFSET, 0x00001800;
              INPUT14 TX_SCHED_CFG_OFFSET,0x00001c00;
              INPUT15 RX_FLOW_CFG_OFFSET, 0x00002000;
              INPUT16 QM_QUE_MMR_BASE,    0x34020000;    //<<CHECK>>
              //Start:Darshan
              INPUT17 FIRST_HW_QNUM,      672;
              INPUT18 PACKET_OFFSET,      1;
              INPUT19 PACKET_TAG,         0;
              INPUT20 TX_SCHED_BYPASS,    0;
              INPUT21 TX_DESCRIPTOR_RELEASE, 1;
              INPUT22 LOOPBACK_MODE,         0;
              INPUT23 PAYLOAD_TRANSPARENCY,  0;
              INPUT28 CLK_DIV, 3;
              //INPUT29  DEBUG_LOG ,    C:\CDMA_srio_Debug.log;
              //End:Darshan
            END    USER_INPUTS;
          END CDMA_SRIO;
        END SHARED_SYSTEM;
      END C66XX_N;
      // CONNECTIONS
      // CGEM program path for other
      CONNECT1        C66XX_N.CPU_SYSTEM_0.CGEM_SSI_0.cgem_prog_mif, C66XX_N.CPU_SYSTEM_0.CPU0.prog_mem_map, 0x0, 0xFFFFFFFF, 0;
      CONNECT2        C66XX_N.CPU_SYSTEM_1.CGEM_SSI_1.cgem_prog_mif, C66XX_N.CPU_SYSTEM_1.CPU1.prog_mem_map, 0x0, 0xFFFFFFFF, 0;
      // L1D and L1P connection for CGEM program path
      CONNECT3        C66XX_N.CPU_SYSTEM_0.CGEM_SSI_0.cgem_l1RAM_mif, C66XX_N.CPU_SYSTEM_0.CPU0.prog_mem_map, 0x10E00000, 0x10E07FFF, 0;
      CONNECT4        C66XX_N.CPU_SYSTEM_1.CGEM_SSI_1.cgem_l1RAM_mif, C66XX_N.CPU_SYSTEM_1.CPU1.prog_mem_map, 0x11E00000, 0x11E07FFF, 0;
      CONNECT5        C66XX_N.CPU_SYSTEM_0.CGEM_SSI_0.cgem_l1RAM_mif, C66XX_N.CPU_SYSTEM_0.CPU0.prog_mem_map, 0x10F00000, 0x10F07FFF, 0;
      CONNECT6        C66XX_N.CPU_SYSTEM_1.CGEM_SSI_1.cgem_l1RAM_mif, C66XX_N.CPU_SYSTEM_1.CPU1.prog_mem_map, 0x11F00000, 0x11F07FFF, 0;
      //CGEM_SSI connections to CPU mem_map
      CONNECT7        C66XX_N.CPU_SYSTEM_0.CGEM_SSI_0.cgem_data_mif, C66XX_N.CPU_SYSTEM_0.CPU0_mem_map, 0, 0xFFFFFFFF, 0;
      CONNECT8        C66XX_N.CPU_SYSTEM_1.CGEM_SSI_1.cgem_data_mif, C66XX_N.CPU_SYSTEM_1.CPU1_mem_map, 0, 0xFFFFFFFF, 0;
      // L1D and L1P connection for CGEM Data path
      CONNECT9        C66XX_N.CPU_SYSTEM_0.CGEM_SSI_0.cgem_l1RAM_mif, C66XX_N.CPU_SYSTEM_0.CPU0_mem_map, 0x10E00000, 0x10E07FFF, 0;
      CONNECT10        C66XX_N.CPU_SYSTEM_1.CGEM_SSI_1.cgem_l1RAM_mif, C66XX_N.CPU_SYSTEM_1.CPU1_mem_map, 0x11E00000, 0x11E07FFF, 0;
      CONNECT11        C66XX_N.CPU_SYSTEM_0.CGEM_SSI_0.cgem_l1RAM_mif, C66XX_N.CPU_SYSTEM_0.CPU0_mem_map, 0x10F00000, 0x10F07FFF, 0;
      CONNECT12        C66XX_N.CPU_SYSTEM_1.CGEM_SSI_1.cgem_l1RAM_mif, C66XX_N.CPU_SYSTEM_1.CPU1_mem_map, 0x11F00000, 0x11F07FFF, 0;
      // Register for CGEM and XMC mapping
      CONNECT13        C66XX_N.CPU_SYSTEM_0.CGEM_SSI_0.cgem_reg_mif, C66XX_N.CPU_SYSTEM_0.CPU0_mem_map, 0x01800000, 0x01BFFFFF, 0;
      CONNECT14        C66XX_N.CPU_SYSTEM_1.CGEM_SSI_1.cgem_reg_mif, C66XX_N.CPU_SYSTEM_1.CPU1_mem_map, 0x01800000, 0x01BFFFFF, 0;
      //CGEM INTSEL Connections with CPU mem_map
      CONNECT15        C66XX_N.CPU_SYSTEM_0.CPU0_mem_map, C66XX_N.CPU_SYSTEM_0.CGEM_SSI_0.INTSELcfg_mem_mif, 0x01800000, 0x01800200, 0;
      CONNECT16        C66XX_N.CPU_SYSTEM_1.CPU1_mem_map, C66XX_N.CPU_SYSTEM_1.CGEM_SSI_1.INTSELcfg_mem_mif, 0x01800000, 0x01800200, 0;
      //! Connections of IDMA with CPU
      CONNECT17        C66XX_N.CPU_SYSTEM_0.CPU0_mem_map, C66XX_N.CPU_SYSTEM_0.CGEM_SSI_0.IDMAcfg_mem_mif, 0x01820000, 0x01820114, 0;
      CONNECT18        C66XX_N.CPU_SYSTEM_1.CPU1_mem_map, C66XX_N.CPU_SYSTEM_1.CGEM_SSI_1.IDMAcfg_mem_mif, 0x01820000, 0x01820114, 0;
      // Register for XMC mapping
      CONNECT19        C66XX_N.CPU_SYSTEM_0.CGEM_SSI_0.cgem_reg_mif, C66XX_N.CPU_SYSTEM_0.CPU0_mem_map, 0x08000000, 0x0800FFFF, 0;
      CONNECT20        C66XX_N.CPU_SYSTEM_1.CGEM_SSI_1.cgem_reg_mif, C66XX_N.CPU_SYSTEM_1.CPU1_mem_map, 0x08000000, 0x0800FFFF, 0;
      //! Connections of IDMA with CGEM_SSI
      CONNECT21        C66XX_N.CPU_SYSTEM_0.CGEM_SSI_0.idma_mem_map, C66XX_N.CPU_SYSTEM_0.CGEM_SSI_0.cgem_data_mif, 0x00000000, 0xFFFFFFFF, 0;
      CONNECT22        C66XX_N.CPU_SYSTEM_1.CGEM_SSI_1.idma_mem_map, C66XX_N.CPU_SYSTEM_1.CGEM_SSI_1.cgem_data_mif, 0x00000000, 0xFFFFFFFF, 0;
      // L1D and L1P connection forIDMA
      CONNECT23        C66XX_N.CPU_SYSTEM_0.CGEM_SSI_0.cgem_l1RAM_mif, C66XX_N.CPU_SYSTEM_0.CGEM_SSI_0.idma_mem_map, 0x00E00000, 0x00E07FFF, 0;
      CONNECT24        C66XX_N.CPU_SYSTEM_1.CGEM_SSI_1.cgem_l1RAM_mif, C66XX_N.CPU_SYSTEM_1.CGEM_SSI_1.idma_mem_map, 0x00E00000, 0x00E07FFF, 0;
      CONNECT25        C66XX_N.CPU_SYSTEM_0.CGEM_SSI_0.cgem_l1RAM_mif, C66XX_N.CPU_SYSTEM_0.CGEM_SSI_0.idma_mem_map, 0x00F00000, 0x00F07FFF, 0;
      CONNECT26        C66XX_N.CPU_SYSTEM_1.CGEM_SSI_1.cgem_l1RAM_mif, C66XX_N.CPU_SYSTEM_1.CGEM_SSI_1.idma_mem_map, 0x00F00000, 0x00F07FFF, 0;
      //MSMC connections with CGEM SSI
      CONNECT27        C66XX_N.SHARED_SYSTEM.MSMC.msmc_cGEM0_memtr_read_input_ipin, C66XX_N.CPU_SYSTEM_0.CGEM_SSI_0.cgem_memtr_read_output_opin;
      CONNECT28        C66XX_N.SHARED_SYSTEM.MSMC.msmc_cGEM0_memtr_write_input_ipin, C66XX_N.CPU_SYSTEM_0.CGEM_SSI_0.cgem_memtr_write_output_opin;
      CONNECT29        C66XX_N.SHARED_SYSTEM.MSMC.msmc_cGEM0_memtr_dbg_read_input_ipin, C66XX_N.CPU_SYSTEM_0.CGEM_SSI_0.cgem_memtr_dbg_read_output_opin;
      CONNECT30        C66XX_N.SHARED_SYSTEM.MSMC.msmc_cGEM0_memtr_dbg_write_input_ipin, C66XX_N.CPU_SYSTEM_0.CGEM_SSI_0.cgem_memtr_dbg_write_output_opin;
      CONNECT31        C66XX_N.SHARED_SYSTEM.MSMC.msmc_cGEM1_memtr_read_input_ipin, C66XX_N.CPU_SYSTEM_1.CGEM_SSI_1.cgem_memtr_read_output_opin;
      CONNECT32        C66XX_N.SHARED_SYSTEM.MSMC.msmc_cGEM1_memtr_write_input_ipin, C66XX_N.CPU_SYSTEM_1.CGEM_SSI_1.cgem_memtr_write_output_opin;
      CONNECT33        C66XX_N.SHARED_SYSTEM.MSMC.msmc_cGEM1_memtr_dbg_read_input_ipin, C66XX_N.CPU_SYSTEM_1.CGEM_SSI_1.cgem_memtr_dbg_read_output_opin;
      CONNECT34        C66XX_N.SHARED_SYSTEM.MSMC.msmc_cGEM1_memtr_dbg_write_input_ipin, C66XX_N.CPU_SYSTEM_1.CGEM_SSI_1.cgem_memtr_dbg_write_output_opin;
      //SEMAPHORE connections with MEMTRs
      CONNECT35        C66XX_N.SHARED_SYSTEM.INTERCONNECT.SEMAPHORE2_CFG.memtr_read_opin, C66XX_N.SHARED_SYSTEM.SEMAPHORE.semaphore2_cfg_read_ipin;
      CONNECT36        C66XX_N.SHARED_SYSTEM.INTERCONNECT.SEMAPHORE2_CFG.memtr_write_opin, C66XX_N.SHARED_SYSTEM.SEMAPHORE.semaphore2_cfg_write_ipin;
      CONNECT37        C66XX_N.SHARED_SYSTEM.INTERCONNECT.SEMAPHORE2_CFG.memtr_dbg_read_opin, C66XX_N.SHARED_SYSTEM.SEMAPHORE.semaphore2_dbg_read_ipin;
      CONNECT38        C66XX_N.SHARED_SYSTEM.INTERCONNECT.SEMAPHORE2_CFG.memtr_dbg_write_opin, C66XX_N.SHARED_SYSTEM.SEMAPHORE.semaphore2_dbg_write_ipin;
      //Driving CMD_ID and PRIV_ID through MSMC adaptor
      //VBUSM CMD packet
      CONNECT39        C66XX_N.SHARED_SYSTEM.MEMTR_MSMC_Adaptor.MT_MIF2SSI.vbusm_cmd_ipin, C66XX_N.CPU_SYSTEM_0.CGEM_SSI_0.cgem_memtr_vbusm_cmd_output_opin;
      CONNECT40        C66XX_N.SHARED_SYSTEM.MEMTR_MSMC_Adaptor.MT_MIF2SSI.vbusm_cmd_ipin, C66XX_N.CPU_SYSTEM_1.CGEM_SSI_1.cgem_memtr_vbusm_cmd_output_opin;
      //TCP3D_A connections with MEMTRs
      //TCP3D_A Config
      CONNECT41        C66XX_N.SHARED_SYSTEM.INTERCONNECT.TCP3D_A_CFG.memtr_read_opin, C66XX_N.SHARED_SYSTEM.TCP3D_A.tcp3d_cfg_read_ipin;
      CONNECT42        C66XX_N.SHARED_SYSTEM.INTERCONNECT.TCP3D_A_CFG.memtr_write_opin, C66XX_N.SHARED_SYSTEM.TCP3D_A.tcp3d_cfg_write_ipin;
      CONNECT43        C66XX_N.SHARED_SYSTEM.INTERCONNECT.TCP3D_A_CFG.memtr_dbg_read_opin, C66XX_N.SHARED_SYSTEM.TCP3D_A.tcp3d_cfg_dbg_read_ipin;
      CONNECT44        C66XX_N.SHARED_SYSTEM.INTERCONNECT.TCP3D_A_CFG.memtr_dbg_write_opin, C66XX_N.SHARED_SYSTEM.TCP3D_A.tcp3d_cfg_dbg_write_ipin;
      //TCP3D_A Slave
      CONNECT45        C66XX_N.SHARED_SYSTEM.INTERCONNECT.TCP3D_A_SLV.memtr_read_opin, C66XX_N.SHARED_SYSTEM.TCP3D_A.tcp3d_dma_read_ipin;
      CONNECT46        C66XX_N.SHARED_SYSTEM.INTERCONNECT.TCP3D_A_SLV.memtr_write_opin, C66XX_N.SHARED_SYSTEM.TCP3D_A.tcp3d_dma_write_ipin;
      CONNECT47        C66XX_N.SHARED_SYSTEM.INTERCONNECT.TCP3D_A_SLV.memtr_dbg_read_opin, C66XX_N.SHARED_SYSTEM.TCP3D_A.tcp3d_dma_dbg_read_ipin;
      CONNECT48        C66XX_N.SHARED_SYSTEM.INTERCONNECT.TCP3D_A_SLV.memtr_dbg_write_opin, C66XX_N.SHARED_SYSTEM.TCP3D_A.tcp3d_dma_dbg_write_ipin;
      //QM connections with MEMTRs
      //QM Config
      CONNECT49        C66XX_N.SHARED_SYSTEM.INTERCONNECT.QUEUE_MANAGER_CFG.memtr_read_opin, C66XX_N.SHARED_SYSTEM.QUEUE_MANAGER.qmss_cfg_read_ipin;
      CONNECT50        C66XX_N.SHARED_SYSTEM.INTERCONNECT.QUEUE_MANAGER_CFG.memtr_write_opin, C66XX_N.SHARED_SYSTEM.QUEUE_MANAGER.qmss_cfg_write_ipin;
      CONNECT51        C66XX_N.SHARED_SYSTEM.INTERCONNECT.QUEUE_MANAGER_CFG.memtr_dbg_read_opin, C66XX_N.SHARED_SYSTEM.QUEUE_MANAGER.qmss_dbg_read_ipin;
      CONNECT52        C66XX_N.SHARED_SYSTEM.INTERCONNECT.QUEUE_MANAGER_CFG.memtr_dbg_write_opin, C66XX_N.SHARED_SYSTEM.QUEUE_MANAGER.qmss_dbg_write_ipin;
      //QM Low Accumulator
      CONNECT53        C66XX_N.SHARED_SYSTEM.INTERCONNECT.QUEUE_MANAGER_PDSP_COMMAND_CFG.memtr_read_opin, C66XX_N.SHARED_SYSTEM.QUEUE_MANAGER.qmss_pdsp_cmd_read_ipin;
      CONNECT54        C66XX_N.SHARED_SYSTEM.INTERCONNECT.QUEUE_MANAGER_PDSP_COMMAND_CFG.memtr_write_opin, C66XX_N.SHARED_SYSTEM.QUEUE_MANAGER.qmss_pdsp_cmd_write_ipin;
      CONNECT55        C66XX_N.SHARED_SYSTEM.INTERCONNECT.QUEUE_MANAGER_PDSP_COMMAND_CFG.memtr_dbg_read_opin, C66XX_N.SHARED_SYSTEM.QUEUE_MANAGER.qmss_pdsp_cmd_dbg_read_ipin;
      CONNECT56        C66XX_N.SHARED_SYSTEM.INTERCONNECT.QUEUE_MANAGER_PDSP_COMMAND_CFG.memtr_dbg_write_opin, C66XX_N.SHARED_SYSTEM.QUEUE_MANAGER.qmss_pdsp_cmd_dbg_write_ipin;
      //QM High Accumulator
      //CONNECT57        C66XX_N.SHARED_SYSTEM.INTERCONNECT.QUEUE_MANAGER_HI_ACC_CFG.memtr_read_opin, C66XX_N.SHARED_SYSTEM.QUEUE_MANAGER.qmss_hi_acc_cmd_read_ipin;
      //CONNECT58        C66XX_N.SHARED_SYSTEM.INTERCONNECT.QUEUE_MANAGER_HI_ACC_CFG.memtr_write_opin, C66XX_N.SHARED_SYSTEM.QUEUE_MANAGER.qmss_hi_acc_cmd_write_ipin;
      //CONNECT59        C66XX_N.SHARED_SYSTEM.INTERCONNECT.QUEUE_MANAGER_HI_ACC_CFG.memtr_dbg_read_opin, C66XX_N.SHARED_SYSTEM.QUEUE_MANAGER.qmss_hi_acc_cmd_dbg_read_ipin;
      //CONNECT60        C66XX_N.SHARED_SYSTEM.INTERCONNECT.QUEUE_MANAGER_HI_ACC_CFG.memtr_dbg_write_opin, C66XX_N.SHARED_SYSTEM.QUEUE_MANAGER.qmss_hi_acc_cmd_dbg_write_ipin;
      //QM Master Accumulator
      CONNECT57        C66XX_N.SHARED_SYSTEM.INTERCONNECT.QUEUE_MANAGER_PDSP_MASTER.memtr_read_ipin, C66XX_N.SHARED_SYSTEM.QUEUE_MANAGER.qmss_pdsp_master_read_opin;
      CONNECT58        C66XX_N.SHARED_SYSTEM.INTERCONNECT.QUEUE_MANAGER_PDSP_MASTER.memtr_write_ipin, C66XX_N.SHARED_SYSTEM.QUEUE_MANAGER.qmss_pdsp_master_write_opin;
      //CDMA_INFRA connections with MEMTRs
      //CDMA_INFRA Config
      CONNECT59        C66XX_N.SHARED_SYSTEM.INTERCONNECT.CDMA_INFRA_CFG.memtr_read_opin, C66XX_N.SHARED_SYSTEM.CDMA_INFRA.cdma_cfg_read_ipin;
      CONNECT60        C66XX_N.SHARED_SYSTEM.INTERCONNECT.CDMA_INFRA_CFG.memtr_write_opin, C66XX_N.SHARED_SYSTEM.CDMA_INFRA.cdma_cfg_write_ipin;
      CONNECT61        C66XX_N.SHARED_SYSTEM.INTERCONNECT.CDMA_INFRA_CFG.memtr_dbg_read_opin, C66XX_N.SHARED_SYSTEM.CDMA_INFRA.cdma_dbg_read_ipin;
      CONNECT62        C66XX_N.SHARED_SYSTEM.INTERCONNECT.CDMA_INFRA_CFG.memtr_dbg_write_opin, C66XX_N.SHARED_SYSTEM.CDMA_INFRA.cdma_dbg_write_ipin;
      //CDMA_INFRA Master
      CONNECT63        C66XX_N.SHARED_SYSTEM.INTERCONNECT.CDMA_INFRA_MASTER.memtr_read_ipin, C66XX_N.SHARED_SYSTEM.CDMA_INFRA.cdma_mstr_read_opin;
      CONNECT64        C66XX_N.SHARED_SYSTEM.INTERCONNECT.CDMA_INFRA_MASTER.memtr_write_ipin, C66XX_N.SHARED_SYSTEM.CDMA_INFRA.cdma_mstr_write_opin;
      //FLATMEM_36BIT connections with MSMC
      CONNECT65        C66XX_N.SHARED_SYSTEM.FLATMEM_36BIT.mem36_read_input_ipin, C66XX_N.SHARED_SYSTEM.MSMC.msmc_EMIF_memtr_read_output_opin;
      CONNECT66        C66XX_N.SHARED_SYSTEM.FLATMEM_36BIT.mem36_write_input_ipin, C66XX_N.SHARED_SYSTEM.MSMC.msmc_EMIF_memtr_write_output_opin;
      CONNECT67        C66XX_N.SHARED_SYSTEM.FLATMEM_36BIT.mem36_dbg_read_input_ipin, C66XX_N.SHARED_SYSTEM.MSMC.msmc_EMIF_memtr_dbg_read_output_opin;
      CONNECT68        C66XX_N.SHARED_SYSTEM.FLATMEM_36BIT.mem36_dbg_write_input_ipin, C66XX_N.SHARED_SYSTEM.MSMC.msmc_EMIF_memtr_dbg_write_output_opin;
      //CONNECT151        C66XX_N.SHARED_SYSTEM.INTERCONNECT2.MSMC_DDREMIF_MASTER.memtr_read_ipin, C66XX_N.SHARED_SYSTEM.MSMC.msmc_EMIF_memtr_read_output_opin;
      //CONNECT152        C66XX_N.SHARED_SYSTEM.INTERCONNECT2.MSMC_DDREMIF_MASTER.memtr_write_ipin, C66XX_N.SHARED_SYSTEM.MSMC.msmc_EMIF_memtr_write_output_opin;
      //CONNECT153        C66XX_N.SHARED_SYSTEM.INTERCONNECT2.MSMC_DDREMIF_MASTER.memtr_dbg_read_ipin, C66XX_N.SHARED_SYSTEM.MSMC.msmc_EMIF_memtr_dbg_read_output_opin;
      //CONNECT154        C66XX_N.SHARED_SYSTEM.INTERCONNECT2.MSMC_DDREMIF_MASTER.memtr_dbg_write_ipin, C66XX_N.SHARED_SYSTEM.MSMC.msmc_EMIF_memtr_dbg_write_output_opin;
      //MEMTR connections to SMS and SES interfaces of MSMC
      //SMS connections
      CONNECT69        C66XX_N.SHARED_SYSTEM.INTERCONNECT.SMS_SLV.memtr_read_opin, C66XX_N.SHARED_SYSTEM.MSMC.msmc_SMS_memtr_read_input_ipin;
      CONNECT70        C66XX_N.SHARED_SYSTEM.INTERCONNECT.SMS_SLV.memtr_write_opin, C66XX_N.SHARED_SYSTEM.MSMC.msmc_SMS_memtr_write_input_ipin;
      CONNECT71        C66XX_N.SHARED_SYSTEM.INTERCONNECT.SMS_SLV.memtr_dbg_read_opin, C66XX_N.SHARED_SYSTEM.MSMC.msmc_SMS_memtr_dbg_read_input_ipin;
      CONNECT72        C66XX_N.SHARED_SYSTEM.INTERCONNECT.SMS_SLV.memtr_dbg_write_opin, C66XX_N.SHARED_SYSTEM.MSMC.msmc_SMS_memtr_dbg_write_input_ipin;
      //SES connections
      CONNECT73        C66XX_N.SHARED_SYSTEM.INTERCONNECT.SES_SLV.memtr_read_opin, C66XX_N.SHARED_SYSTEM.MSMC.msmc_SES_memtr_read_input_ipin;
      CONNECT74        C66XX_N.SHARED_SYSTEM.INTERCONNECT.SES_SLV.memtr_write_opin, C66XX_N.SHARED_SYSTEM.MSMC.msmc_SES_memtr_write_input_ipin;
      CONNECT75        C66XX_N.SHARED_SYSTEM.INTERCONNECT.SES_SLV.memtr_dbg_read_opin, C66XX_N.SHARED_SYSTEM.MSMC.msmc_SES_memtr_dbg_read_input_ipin;
      CONNECT76        C66XX_N.SHARED_SYSTEM.INTERCONNECT.SES_SLV.memtr_dbg_write_opin, C66XX_N.SHARED_SYSTEM.MSMC.msmc_SES_memtr_dbg_write_input_ipin;
      //RESET Connections
      CONNECT77        C66XX_N.CPU_SYSTEM_0.CGEM_SSI_0.cgem_reset_ipin, C66XX_N.CPU_SYSTEM_0.CPU0_RESET;
      CONNECT78        C66XX_N.CPU_SYSTEM_1.CGEM_SSI_1.cgem_reset_ipin, C66XX_N.CPU_SYSTEM_1.CPU1_RESET;
      CONNECT79        System.SimBridge.global_reset_list, C66XX_N.SHARED_SYSTEM_INTF.reset_in;
      CONNECT80        C66XX_N.SHARED_SYSTEM.MSMC.msmc_reset_ipin, C66XX_N.SHARED_SYSTEM_INTF.reset_out;
      CONNECT81        C66XX_N.SHARED_SYSTEM.FLATMEM_36BIT.mem36_reset_ipin, C66XX_N.SHARED_SYSTEM_INTF.reset_out;
      CONNECT82        System.SimBridge.global_reset_list, C66XX_N.SHARED_SYSTEM.TIMER64_0.reset;
      CONNECT83        System.SimBridge.global_reset_list, C66XX_N.SHARED_SYSTEM.TIMER64_1.reset;
      CONNECT84        System.SimBridge.global_reset_list, C66XX_N.SHARED_SYSTEM.TIMER64_2.reset;
      CONNECT85        System.SimBridge.global_reset_list, C66XX_N.SHARED_SYSTEM.TIMER64_3.reset;
      CONNECT86        System.SimBridge.global_reset_list, C66XX_N.SHARED_SYSTEM.TIMER64_4.reset;
      CONNECT87        System.SimBridge.global_reset_list, C66XX_N.SHARED_SYSTEM.TIMER64_5.reset;
      CONNECT88        System.SimBridge.global_reset_list, C66XX_N.SHARED_SYSTEM.TIMER64_6.reset;
      CONNECT89        System.SimBridge.global_reset_list, C66XX_N.SHARED_SYSTEM.TIMER64_7.reset;
      CONNECT90        System.SimBridge.global_reset_list, C66XX_N.SHARED_SYSTEM.EDMA.reset;
      CONNECT91        C66XX_N.SHARED_SYSTEM.CP_INTC0.cp_intc_reset_in, C66XX_N.SHARED_SYSTEM_INTF.reset_out;
      CONNECT92        C66XX_N.SHARED_SYSTEM.CP_INTC1.cp_intc_reset_in, C66XX_N.SHARED_SYSTEM_INTF.reset_out;
      CONNECT93        C66XX_N.SHARED_SYSTEM.CP_INTC2.cp_intc_reset_in, C66XX_N.SHARED_SYSTEM_INTF.reset_out;
      CONNECT94        C66XX_N.SHARED_SYSTEM.CP_INTC2.cp_intc_reset_in, C66XX_N.SHARED_SYSTEM_INTF.reset_out;
      CONNECT95        C66XX_N.SHARED_SYSTEM.SEMAPHORE.semaphore2_reset_ipin, C66XX_N.SHARED_SYSTEM_INTF.reset_out;
      CONNECT96        C66XX_N.SHARED_SYSTEM.TCP3D_A.tcp3d_reset_ipin, C66XX_N.SHARED_SYSTEM_INTF.reset_out;
      CONNECT97        C66XX_N.SHARED_SYSTEM.QUEUE_MANAGER.qmss_reset_ipin, C66XX_N.SHARED_SYSTEM_INTF.reset_out;
      CONNECT98        C66XX_N.SHARED_SYSTEM.CDMA_INFRA.cdma_reset_ipin, C66XX_N.SHARED_SYSTEM_INTF.reset_out;
      CONNECT99        System.SimBridge.global_reset_list, C66XX_N.SHARED_SYSTEM.IPC.reset;
      //Endianess Connections
      CONNECT100        C66XX_N.CPU_SYSTEM_0.CGEM_SSI_0.cgem_endian_ipin, C66XX_N.CPU_SYSTEM_0.CPU0_endianness;
      CONNECT101        C66XX_N.CPU_SYSTEM_1.CGEM_SSI_1.cgem_endian_ipin, C66XX_N.CPU_SYSTEM_1.CPU1_endianness;
      //! since the whole system is of the same endianness, connecting any CPU's endian to the entire shared Components
      CONNECT102        C66XX_N.SHARED_SYSTEM.MSMC.msmc_endian_ipin, C66XX_N.CPU_SYSTEM_0.CPU0_endianness;
      CONNECT103        C66XX_N.SHARED_SYSTEM.FLATMEM_36BIT.mem36_endian_ipin, C66XX_N.CPU_SYSTEM_0.CPU0_endianness;
      CONNECT104        C66XX_N.SHARED_SYSTEM.TIMER64_0.endian, C66XX_N.CPU_SYSTEM_0.CPU0_endianness;
      CONNECT105        C66XX_N.SHARED_SYSTEM.TIMER64_1.endian, C66XX_N.CPU_SYSTEM_0.CPU0_endianness;
      CONNECT106        C66XX_N.SHARED_SYSTEM.TIMER64_2.endian, C66XX_N.CPU_SYSTEM_0.CPU0_endianness;
      CONNECT107        C66XX_N.SHARED_SYSTEM.TIMER64_3.endian, C66XX_N.CPU_SYSTEM_0.CPU0_endianness;
      CONNECT108        C66XX_N.SHARED_SYSTEM.TIMER64_4.endian, C66XX_N.CPU_SYSTEM_0.CPU0_endianness;
      CONNECT109        C66XX_N.SHARED_SYSTEM.TIMER64_5.endian, C66XX_N.CPU_SYSTEM_0.CPU0_endianness;
      CONNECT110        C66XX_N.SHARED_SYSTEM.TIMER64_6.endian, C66XX_N.CPU_SYSTEM_0.CPU0_endianness;
      CONNECT111        C66XX_N.SHARED_SYSTEM.TIMER64_7.endian, C66XX_N.CPU_SYSTEM_0.CPU0_endianness;
      CONNECT112        C66XX_N.CPU_SYSTEM_0.CPU0_endianness, C66XX_N.SHARED_SYSTEM.EDMA.endian_in;
      CONNECT113        C66XX_N.CPU_SYSTEM_0.CPU0_endianness, C66XX_N.SHARED_SYSTEM.EDMA.endian_in;
      CONNECT114        C66XX_N.SHARED_SYSTEM.SEMAPHORE.semaphore2_endian_ipin, C66XX_N.CPU_SYSTEM_0.CPU0_endianness;
      CONNECT115        C66XX_N.SHARED_SYSTEM.TCP3D_A.tcp3d_big_endian_ipin, C66XX_N.CPU_SYSTEM_0.CPU0_endianness_big_endian; //<CHECK>
      CONNECT116        C66XX_N.SHARED_SYSTEM.QUEUE_MANAGER.qmss_endian_ipin, C66XX_N.CPU_SYSTEM_0.CPU0_endianness_big_endian; //Corrected
      CONNECT117        C66XX_N.SHARED_SYSTEM.CDMA_INFRA.cdma_endian_ipin, C66XX_N.CPU_SYSTEM_0.CPU0_endianness_big_endian; //Corrected
      CONNECT118        C66XX_N.SHARED_SYSTEM.IPC.endian, C66XX_N.CPU_SYSTEM_0.CPU0_endianness; //<CHECK>
      // INTERRUPT Connections
      // System Interrupt Connections - INTC0
      //GPIO
      CONNECT119        C66XX_N.SHARED_SYSTEM.CP_INTC0.cp_intc_system_intr_in0, C66XX_N.SHARED_SYSTEM.GPIO.gpio_gpint16_opin;
      CONNECT120        C66XX_N.SHARED_SYSTEM.CP_INTC0.cp_intc_system_intr_in1, C66XX_N.SHARED_SYSTEM.GPIO.gpio_gpint17_opin;
      CONNECT121        C66XX_N.SHARED_SYSTEM.CP_INTC0.cp_intc_system_intr_in2, C66XX_N.SHARED_SYSTEM.GPIO.gpio_gpint18_opin;
      CONNECT122        C66XX_N.SHARED_SYSTEM.CP_INTC0.cp_intc_system_intr_in3, C66XX_N.SHARED_SYSTEM.GPIO.gpio_gpint19_opin;
      CONNECT123        C66XX_N.SHARED_SYSTEM.CP_INTC0.cp_intc_system_intr_in4, C66XX_N.SHARED_SYSTEM.GPIO.gpio_gpint20_opin;
      CONNECT124        C66XX_N.SHARED_SYSTEM.CP_INTC0.cp_intc_system_intr_in5, C66XX_N.SHARED_SYSTEM.GPIO.gpio_gpint21_opin;
      CONNECT125        C66XX_N.SHARED_SYSTEM.CP_INTC0.cp_intc_system_intr_in6, C66XX_N.SHARED_SYSTEM.GPIO.gpio_gpint22_opin;
      CONNECT126        C66XX_N.SHARED_SYSTEM.CP_INTC0.cp_intc_system_intr_in7, C66XX_N.SHARED_SYSTEM.GPIO.gpio_gpint23_opin;
      CONNECT127        C66XX_N.SHARED_SYSTEM.CP_INTC0.cp_intc_system_intr_in8, C66XX_N.SHARED_SYSTEM.GPIO.gpio_gpint24_opin;
      CONNECT128        C66XX_N.SHARED_SYSTEM.CP_INTC0.cp_intc_system_intr_in9, C66XX_N.SHARED_SYSTEM.GPIO.gpio_gpint25_opin;
      CONNECT129        C66XX_N.SHARED_SYSTEM.CP_INTC0.cp_intc_system_intr_in10, C66XX_N.SHARED_SYSTEM.GPIO.gpio_gpint26_opin;
      CONNECT130        C66XX_N.SHARED_SYSTEM.CP_INTC0.cp_intc_system_intr_in11, C66XX_N.SHARED_SYSTEM.GPIO.gpio_gpint27_opin;
      CONNECT131        C66XX_N.SHARED_SYSTEM.CP_INTC0.cp_intc_system_intr_in12, C66XX_N.SHARED_SYSTEM.GPIO.gpio_gpint28_opin;
      CONNECT132        C66XX_N.SHARED_SYSTEM.CP_INTC0.cp_intc_system_intr_in13, C66XX_N.SHARED_SYSTEM.GPIO.gpio_gpint29_opin;
      CONNECT133        C66XX_N.SHARED_SYSTEM.CP_INTC0.cp_intc_system_intr_in14, C66XX_N.SHARED_SYSTEM.GPIO.gpio_gpint30_opin;
      CONNECT134        C66XX_N.SHARED_SYSTEM.CP_INTC0.cp_intc_system_intr_in15, C66XX_N.SHARED_SYSTEM.GPIO.gpio_gpint31_opin;
      //EDMA
      CONNECT135        C66XX_N.SHARED_SYSTEM.CP_INTC0.cp_intc_system_intr_in16, C66XX_N.SHARED_SYSTEM.EDMA.errint_out_pin;
      CONNECT136        C66XX_N.SHARED_SYSTEM.CP_INTC0.cp_intc_system_intr_in22, C66XX_N.SHARED_SYSTEM.EDMA_gint_out_pin;
      CONNECT137        C66XX_N.SHARED_SYSTEM.CP_INTC0.cp_intc_system_intr_in24, C66XX_N.SHARED_SYSTEM.EDMA_int_out_pin0;
      CONNECT138        C66XX_N.SHARED_SYSTEM.CP_INTC0.cp_intc_system_intr_in25, C66XX_N.SHARED_SYSTEM.EDMA_int_out_pin1;
      CONNECT139        C66XX_N.SHARED_SYSTEM.CP_INTC0.cp_intc_system_intr_in26, C66XX_N.SHARED_SYSTEM.EDMA_int_out_pin2;
      CONNECT140        C66XX_N.SHARED_SYSTEM.CP_INTC0.cp_intc_system_intr_in27, C66XX_N.SHARED_SYSTEM.EDMA_int_out_pin3;
      CONNECT141        C66XX_N.SHARED_SYSTEM.CP_INTC0.cp_intc_system_intr_in28, C66XX_N.SHARED_SYSTEM.EDMA_int_out_pin4;
      CONNECT142        C66XX_N.SHARED_SYSTEM.CP_INTC0.cp_intc_system_intr_in29, C66XX_N.SHARED_SYSTEM.EDMA_int_out_pin5;
      CONNECT143        C66XX_N.SHARED_SYSTEM.CP_INTC0.cp_intc_system_intr_in30, C66XX_N.SHARED_SYSTEM.EDMA_int_out_pin6;
      CONNECT144        C66XX_N.SHARED_SYSTEM.CP_INTC0.cp_intc_system_intr_in31, C66XX_N.SHARED_SYSTEM.EDMA_int_out_pin7;
      //UART_1
      CONNECT145        C66XX_N.SHARED_SYSTEM.CP_INTC0.cp_intc_system_intr_in40, C66XX_N.SHARED_SYSTEM.UART_1.uart_interrupt_out;
      //SEMAPHORE2
      CONNECT146        C66XX_N.SHARED_SYSTEM.CP_INTC0.cp_intc_system_intr_in68, C66XX_N.SHARED_SYSTEM.SEMAPHORE.semaphore2_intr_opin2;
      CONNECT147        C66XX_N.SHARED_SYSTEM.CP_INTC0.cp_intc_system_intr_in69, C66XX_N.SHARED_SYSTEM.SEMAPHORE.semaphore2_intr_opin3;
      CONNECT148        C66XX_N.SHARED_SYSTEM.CP_INTC0.cp_intc_system_intr_in70, C66XX_N.SHARED_SYSTEM.SEMAPHORE.semaphore2_err_opin2;
      CONNECT149        C66XX_N.SHARED_SYSTEM.CP_INTC0.cp_intc_system_intr_in71, C66XX_N.SHARED_SYSTEM.SEMAPHORE.semaphore2_err_opin3;
      //SRIO
      CONNECT150        C66XX_N.SHARED_SYSTEM.CP_INTC0.cp_intc_system_intr_in112, C66XX_N.SHARED_SYSTEM.SRIO.srio_intdst_intr0;
      CONNECT151        C66XX_N.SHARED_SYSTEM.CP_INTC0.cp_intc_system_intr_in113, C66XX_N.SHARED_SYSTEM.SRIO.srio_intdst_intr1;
      CONNECT152        C66XX_N.SHARED_SYSTEM.CP_INTC0.cp_intc_system_intr_in114, C66XX_N.SHARED_SYSTEM.SRIO.srio_intdst_intr2;
      CONNECT153        C66XX_N.SHARED_SYSTEM.CP_INTC0.cp_intc_system_intr_in115, C66XX_N.SHARED_SYSTEM.SRIO.srio_intdst_intr3;
      CONNECT154        C66XX_N.SHARED_SYSTEM.CP_INTC0.cp_intc_system_intr_in116, C66XX_N.SHARED_SYSTEM.SRIO.srio_intdst_intr4;
      CONNECT155        C66XX_N.SHARED_SYSTEM.CP_INTC0.cp_intc_system_intr_in117, C66XX_N.SHARED_SYSTEM.SRIO.srio_intdst_intr5;
      CONNECT156        C66XX_N.SHARED_SYSTEM.CP_INTC0.cp_intc_system_intr_in118, C66XX_N.SHARED_SYSTEM.SRIO.srio_intdst_intr6;
      CONNECT157        C66XX_N.SHARED_SYSTEM.CP_INTC0.cp_intc_system_intr_in119, C66XX_N.SHARED_SYSTEM.SRIO.srio_intdst_intr7;
      CONNECT158        C66XX_N.SHARED_SYSTEM.CP_INTC0.cp_intc_system_intr_in120, C66XX_N.SHARED_SYSTEM.SRIO.srio_intdst_intr8;
      CONNECT159        C66XX_N.SHARED_SYSTEM.CP_INTC0.cp_intc_system_intr_in121, C66XX_N.SHARED_SYSTEM.SRIO.srio_intdst_intr9;
      CONNECT160        C66XX_N.SHARED_SYSTEM.CP_INTC0.cp_intc_system_intr_in122, C66XX_N.SHARED_SYSTEM.SRIO.srio_intdst_intr10;
      CONNECT161        C66XX_N.SHARED_SYSTEM.CP_INTC0.cp_intc_system_intr_in123, C66XX_N.SHARED_SYSTEM.SRIO.srio_intdst_intr11;
      CONNECT162        C66XX_N.SHARED_SYSTEM.CP_INTC0.cp_intc_system_intr_in124, C66XX_N.SHARED_SYSTEM.SRIO.srio_intdst_intr12;
      CONNECT163        C66XX_N.SHARED_SYSTEM.CP_INTC0.cp_intc_system_intr_in125, C66XX_N.SHARED_SYSTEM.SRIO.srio_intdst_intr13;
      CONNECT164        C66XX_N.SHARED_SYSTEM.CP_INTC0.cp_intc_system_intr_in126, C66XX_N.SHARED_SYSTEM.SRIO.srio_intdst_intr14;
      CONNECT165        C66XX_N.SHARED_SYSTEM.CP_INTC0.cp_intc_system_intr_in127, C66XX_N.SHARED_SYSTEM.SRIO.srio_intdst_intr15;
      //QMSS
      CONNECT166        C66XX_N.SHARED_SYSTEM.QUEUE_MANAGER.qmss_int_pa_tx_22_opin, C66XX_N.SHARED_SYSTEM.CP_INTC0.cp_intc_system_intr_in134;
      CONNECT167        C66XX_N.SHARED_SYSTEM.QUEUE_MANAGER.qmss_int_pa_tx_23_opin, C66XX_N.SHARED_SYSTEM.CP_INTC0.cp_intc_system_intr_in135;
      CONNECT168        C66XX_N.SHARED_SYSTEM.QUEUE_MANAGER.qmss_int_pa_tx_24_opin, C66XX_N.SHARED_SYSTEM.CP_INTC0.cp_intc_system_intr_in136;
      CONNECT169        C66XX_N.SHARED_SYSTEM.QUEUE_MANAGER.qmss_int_pa_tx_25_opin, C66XX_N.SHARED_SYSTEM.CP_INTC0.cp_intc_system_intr_in137;
      CONNECT170        C66XX_N.SHARED_SYSTEM.QUEUE_MANAGER.qmss_int_pa_tx_26_opin, C66XX_N.SHARED_SYSTEM.CP_INTC0.cp_intc_system_intr_in138;
      CONNECT171        C66XX_N.SHARED_SYSTEM.QUEUE_MANAGER.qmss_int_pa_tx_27_opin, C66XX_N.SHARED_SYSTEM.CP_INTC0.cp_intc_system_intr_in139;
      CONNECT172        C66XX_N.SHARED_SYSTEM.QUEUE_MANAGER.qmss_int_pa_tx_28_opin, C66XX_N.SHARED_SYSTEM.CP_INTC0.cp_intc_system_intr_in140;
      CONNECT173        C66XX_N.SHARED_SYSTEM.QUEUE_MANAGER.qmss_int_pa_tx_29_opin, C66XX_N.SHARED_SYSTEM.CP_INTC0.cp_intc_system_intr_in141;
      CONNECT174        C66XX_N.SHARED_SYSTEM.QUEUE_MANAGER.qmss_int_pa_tx_30_opin, C66XX_N.SHARED_SYSTEM.CP_INTC0.cp_intc_system_intr_in142;
      CONNECT175        C66XX_N.SHARED_SYSTEM.QUEUE_MANAGER.qmss_int_pa_tx_31_opin, C66XX_N.SHARED_SYSTEM.CP_INTC0.cp_intc_system_intr_in175;
      //VCP
      CONNECT176        C66XX_N.SHARED_SYSTEM.CP_INTC0.cp_intc_system_intr_in143, C66XX_N.SHARED_SYSTEM.VCP2_0.VCP_INTR;
      CONNECT177        C66XX_N.SHARED_SYSTEM.CP_INTC0.cp_intc_system_intr_in144, C66XX_N.SHARED_SYSTEM.VCP2_1.VCP_INTR;
      CONNECT178        C66XX_N.SHARED_SYSTEM.CP_INTC0.cp_intc_system_intr_in147, C66XX_N.SHARED_SYSTEM.VCP2_0.VCP_DMA_REVT;
      CONNECT179        C66XX_N.SHARED_SYSTEM.CP_INTC0.cp_intc_system_intr_in148, C66XX_N.SHARED_SYSTEM.VCP2_0.VCP_DMA_XEVT;
      CONNECT180        C66XX_N.SHARED_SYSTEM.CP_INTC0.cp_intc_system_intr_in149, C66XX_N.SHARED_SYSTEM.VCP2_1.VCP_DMA_REVT;
      CONNECT181        C66XX_N.SHARED_SYSTEM.CP_INTC0.cp_intc_system_intr_in150, C66XX_N.SHARED_SYSTEM.VCP2_1.VCP_DMA_XEVT;
      //TIMERS
      CONNECT182        C66XX_N.SHARED_SYSTEM.CP_INTC0.cp_intc_system_intr_in145, C66XX_N.SHARED_SYSTEM.TIMER64_4_cpu_int_12;
      CONNECT183        C66XX_N.SHARED_SYSTEM.CP_INTC0.cp_intc_system_intr_in146, C66XX_N.SHARED_SYSTEM.TIMER64_4_cpu_int_34;
      CONNECT184        C66XX_N.SHARED_SYSTEM.CP_INTC0.cp_intc_system_intr_in151, C66XX_N.SHARED_SYSTEM.TIMER64_5_cpu_int_12;
      CONNECT185        C66XX_N.SHARED_SYSTEM.CP_INTC0.cp_intc_system_intr_in152, C66XX_N.SHARED_SYSTEM.TIMER64_5_cpu_int_34;
      CONNECT186        C66XX_N.SHARED_SYSTEM.CP_INTC0.cp_intc_system_intr_in153, C66XX_N.SHARED_SYSTEM.TIMER64_6_cpu_int_12;
      CONNECT187        C66XX_N.SHARED_SYSTEM.CP_INTC0.cp_intc_system_intr_in154, C66XX_N.SHARED_SYSTEM.TIMER64_6_cpu_int_34;
      CONNECT188        C66XX_N.SHARED_SYSTEM.CP_INTC0.cp_intc_system_intr_in162, C66XX_N.SHARED_SYSTEM.TIMER64_7_cpu_int_12;
      CONNECT189        C66XX_N.SHARED_SYSTEM.CP_INTC0.cp_intc_system_intr_in163, C66XX_N.SHARED_SYSTEM.TIMER64_7_cpu_int_34;
      //INTD_TCP3D_A
      CONNECT190        C66XX_N.SHARED_SYSTEM.INTD_TCP3D_A.intr_out_edge, C66XX_N.SHARED_SYSTEM.CP_INTC0.cp_intc_system_intr_in155;
      //TCP3D
      CONNECT191        C66XX_N.SHARED_SYSTEM.CP_INTC0.cp_intc_system_intr_in157, C66XX_N.SHARED_SYSTEM.TCP3D_A.tcp3d_revt0_opin;
      CONNECT192        C66XX_N.SHARED_SYSTEM.CP_INTC0.cp_intc_system_intr_in158, C66XX_N.SHARED_SYSTEM.TCP3D_A.tcp3d_revt1_opin;
      //UART_0
      CONNECT193        C66XX_N.SHARED_SYSTEM.CP_INTC0.cp_intc_system_intr_in164, C66XX_N.SHARED_SYSTEM.UART_0.uart_interrupt_out;
      // System Interrupt Connections - INTC1
      //GPIO
      CONNECT194        C66XX_N.SHARED_SYSTEM.CP_INTC1.cp_intc_system_intr_in0, C66XX_N.SHARED_SYSTEM.GPIO.gpio_gpint8_opin;
      CONNECT195        C66XX_N.SHARED_SYSTEM.CP_INTC1.cp_intc_system_intr_in1, C66XX_N.SHARED_SYSTEM.GPIO.gpio_gpint9_opin;
      CONNECT196        C66XX_N.SHARED_SYSTEM.CP_INTC1.cp_intc_system_intr_in2, C66XX_N.SHARED_SYSTEM.GPIO.gpio_gpint10_opin;
      CONNECT197        C66XX_N.SHARED_SYSTEM.CP_INTC1.cp_intc_system_intr_in3, C66XX_N.SHARED_SYSTEM.GPIO.gpio_gpint11_opin;
      CONNECT198        C66XX_N.SHARED_SYSTEM.CP_INTC1.cp_intc_system_intr_in4, C66XX_N.SHARED_SYSTEM.GPIO.gpio_gpint12_opin;
      CONNECT199        C66XX_N.SHARED_SYSTEM.CP_INTC1.cp_intc_system_intr_in5, C66XX_N.SHARED_SYSTEM.GPIO.gpio_gpint13_opin;
      CONNECT200        C66XX_N.SHARED_SYSTEM.CP_INTC1.cp_intc_system_intr_in6, C66XX_N.SHARED_SYSTEM.GPIO.gpio_gpint14_opin;
      CONNECT201        C66XX_N.SHARED_SYSTEM.CP_INTC1.cp_intc_system_intr_in7, C66XX_N.SHARED_SYSTEM.GPIO.gpio_gpint15_opin;
      CONNECT202        C66XX_N.SHARED_SYSTEM.CP_INTC1.cp_intc_system_intr_in17, C66XX_N.SHARED_SYSTEM.GPIO.gpio_gpint16_opin;
      CONNECT203        C66XX_N.SHARED_SYSTEM.CP_INTC1.cp_intc_system_intr_in18, C66XX_N.SHARED_SYSTEM.GPIO.gpio_gpint17_opin;
      CONNECT204        C66XX_N.SHARED_SYSTEM.CP_INTC1.cp_intc_system_intr_in19, C66XX_N.SHARED_SYSTEM.GPIO.gpio_gpint18_opin;
      CONNECT205        C66XX_N.SHARED_SYSTEM.CP_INTC1.cp_intc_system_intr_in20, C66XX_N.SHARED_SYSTEM.GPIO.gpio_gpint19_opin;
      CONNECT206        C66XX_N.SHARED_SYSTEM.CP_INTC1.cp_intc_system_intr_in21, C66XX_N.SHARED_SYSTEM.GPIO.gpio_gpint20_opin;
      CONNECT207        C66XX_N.SHARED_SYSTEM.CP_INTC1.cp_intc_system_intr_in22, C66XX_N.SHARED_SYSTEM.GPIO.gpio_gpint21_opin;
      CONNECT208        C66XX_N.SHARED_SYSTEM.CP_INTC1.cp_intc_system_intr_in47, C66XX_N.SHARED_SYSTEM.GPIO.gpio_gpint22_opin;
      CONNECT209        C66XX_N.SHARED_SYSTEM.CP_INTC1.cp_intc_system_intr_in48, C66XX_N.SHARED_SYSTEM.GPIO.gpio_gpint23_opin;
      CONNECT210        C66XX_N.SHARED_SYSTEM.CP_INTC1.cp_intc_system_intr_in117, C66XX_N.SHARED_SYSTEM.GPIO.gpio_gpint24_opin;
      CONNECT211        C66XX_N.SHARED_SYSTEM.CP_INTC1.cp_intc_system_intr_in118, C66XX_N.SHARED_SYSTEM.GPIO.gpio_gpint25_opin;
      CONNECT212        C66XX_N.SHARED_SYSTEM.CP_INTC1.cp_intc_system_intr_in121, C66XX_N.SHARED_SYSTEM.GPIO.gpio_gpint26_opin;
      CONNECT213        C66XX_N.SHARED_SYSTEM.CP_INTC1.cp_intc_system_intr_in122, C66XX_N.SHARED_SYSTEM.GPIO.gpio_gpint27_opin;
      CONNECT214        C66XX_N.SHARED_SYSTEM.CP_INTC1.cp_intc_system_intr_in124, C66XX_N.SHARED_SYSTEM.GPIO.gpio_gpint28_opin;
      CONNECT215        C66XX_N.SHARED_SYSTEM.CP_INTC1.cp_intc_system_intr_in125, C66XX_N.SHARED_SYSTEM.GPIO.gpio_gpint29_opin;
      CONNECT216        C66XX_N.SHARED_SYSTEM.CP_INTC1.cp_intc_system_intr_in126, C66XX_N.SHARED_SYSTEM.GPIO.gpio_gpint30_opin;
      CONNECT217        C66XX_N.SHARED_SYSTEM.CP_INTC1.cp_intc_system_intr_in127, C66XX_N.SHARED_SYSTEM.GPIO.gpio_gpint31_opin;
      CONNECT218        C66XX_N.SHARED_SYSTEM.CP_INTC1.cp_intc_system_intr_in128, C66XX_N.SHARED_SYSTEM.GPIO.gpio_gpint4_opin;
      CONNECT219        C66XX_N.SHARED_SYSTEM.CP_INTC1.cp_intc_system_intr_in129, C66XX_N.SHARED_SYSTEM.GPIO.gpio_gpint5_opin;
      CONNECT220        C66XX_N.SHARED_SYSTEM.CP_INTC1.cp_intc_system_intr_in130, C66XX_N.SHARED_SYSTEM.GPIO.gpio_gpint6_opin;
      CONNECT221        C66XX_N.SHARED_SYSTEM.CP_INTC1.cp_intc_system_intr_in131, C66XX_N.SHARED_SYSTEM.GPIO.gpio_gpint7_opin;
      //QUEUE_MANAGER
      CONNECT222        C66XX_N.SHARED_SYSTEM.CP_INTC1.cp_intc_system_intr_in24, C66XX_N.SHARED_SYSTEM.QUEUE_MANAGER.qmss_int1_16_opin;
      CONNECT223        C66XX_N.SHARED_SYSTEM.CP_INTC1.cp_intc_system_intr_in25, C66XX_N.SHARED_SYSTEM.QUEUE_MANAGER.qmss_int1_17_opin;
      CONNECT224        C66XX_N.SHARED_SYSTEM.CP_INTC1.cp_intc_system_intr_in26, C66XX_N.SHARED_SYSTEM.QUEUE_MANAGER.qmss_int1_18_opin;
      CONNECT225        C66XX_N.SHARED_SYSTEM.CP_INTC1.cp_intc_system_intr_in27, C66XX_N.SHARED_SYSTEM.QUEUE_MANAGER.qmss_int1_19_opin;
      CONNECT226        C66XX_N.SHARED_SYSTEM.CP_INTC1.cp_intc_system_intr_in28, C66XX_N.SHARED_SYSTEM.QUEUE_MANAGER.qmss_int1_20_opin;
      CONNECT227        C66XX_N.SHARED_SYSTEM.CP_INTC1.cp_intc_system_intr_in29, C66XX_N.SHARED_SYSTEM.QUEUE_MANAGER.qmss_int1_21_opin;
      CONNECT228        C66XX_N.SHARED_SYSTEM.CP_INTC1.cp_intc_system_intr_in30, C66XX_N.SHARED_SYSTEM.QUEUE_MANAGER.qmss_int1_22_opin;
      CONNECT229        C66XX_N.SHARED_SYSTEM.CP_INTC1.cp_intc_system_intr_in31, C66XX_N.SHARED_SYSTEM.QUEUE_MANAGER.qmss_int1_23_opin;
      CONNECT230        C66XX_N.SHARED_SYSTEM.CP_INTC1.cp_intc_system_intr_in32, C66XX_N.SHARED_SYSTEM.QUEUE_MANAGER.qmss_int1_24_opin;
      CONNECT231        C66XX_N.SHARED_SYSTEM.CP_INTC1.cp_intc_system_intr_in33, C66XX_N.SHARED_SYSTEM.QUEUE_MANAGER.qmss_int1_25_opin;
      CONNECT232        C66XX_N.SHARED_SYSTEM.CP_INTC1.cp_intc_system_intr_in34, C66XX_N.SHARED_SYSTEM.QUEUE_MANAGER.qmss_int1_26_opin;
      CONNECT233        C66XX_N.SHARED_SYSTEM.CP_INTC1.cp_intc_system_intr_in35, C66XX_N.SHARED_SYSTEM.QUEUE_MANAGER.qmss_int1_27_opin;
      CONNECT234        C66XX_N.SHARED_SYSTEM.CP_INTC1.cp_intc_system_intr_in36, C66XX_N.SHARED_SYSTEM.QUEUE_MANAGER.qmss_int1_28_opin;
      CONNECT235        C66XX_N.SHARED_SYSTEM.CP_INTC1.cp_intc_system_intr_in37, C66XX_N.SHARED_SYSTEM.QUEUE_MANAGER.qmss_int1_29_opin;
      CONNECT236        C66XX_N.SHARED_SYSTEM.CP_INTC1.cp_intc_system_intr_in38, C66XX_N.SHARED_SYSTEM.QUEUE_MANAGER.qmss_int1_30_opin;
      CONNECT237        C66XX_N.SHARED_SYSTEM.CP_INTC1.cp_intc_system_intr_in39, C66XX_N.SHARED_SYSTEM.QUEUE_MANAGER.qmss_int1_31_opin;
      CONNECT238        C66XX_N.SHARED_SYSTEM.CP_INTC1.cp_intc_system_intr_in137, C66XX_N.SHARED_SYSTEM.QUEUE_MANAGER.qmss_int1_0_opin;
      CONNECT239        C66XX_N.SHARED_SYSTEM.CP_INTC1.cp_intc_system_intr_in138, C66XX_N.SHARED_SYSTEM.QUEUE_MANAGER.qmss_int1_1_opin;
      CONNECT240        C66XX_N.SHARED_SYSTEM.CP_INTC1.cp_intc_system_intr_in139, C66XX_N.SHARED_SYSTEM.QUEUE_MANAGER.qmss_int1_2_opin;
      CONNECT241        C66XX_N.SHARED_SYSTEM.CP_INTC1.cp_intc_system_intr_in140, C66XX_N.SHARED_SYSTEM.QUEUE_MANAGER.qmss_int1_3_opin;
      CONNECT242        C66XX_N.SHARED_SYSTEM.CP_INTC1.cp_intc_system_intr_in141, C66XX_N.SHARED_SYSTEM.QUEUE_MANAGER.qmss_int1_4_opin;
      CONNECT243        C66XX_N.SHARED_SYSTEM.CP_INTC1.cp_intc_system_intr_in142, C66XX_N.SHARED_SYSTEM.QUEUE_MANAGER.qmss_int1_5_opin;
      CONNECT244        C66XX_N.SHARED_SYSTEM.CP_INTC1.cp_intc_system_intr_in143, C66XX_N.SHARED_SYSTEM.QUEUE_MANAGER.qmss_int1_6_opin;
      CONNECT245        C66XX_N.SHARED_SYSTEM.CP_INTC1.cp_intc_system_intr_in144, C66XX_N.SHARED_SYSTEM.QUEUE_MANAGER.qmss_int1_7_opin;
      CONNECT246        C66XX_N.SHARED_SYSTEM.CP_INTC1.cp_intc_system_intr_in145, C66XX_N.SHARED_SYSTEM.QUEUE_MANAGER.qmss_int1_8_opin;
      CONNECT247        C66XX_N.SHARED_SYSTEM.CP_INTC1.cp_intc_system_intr_in146, C66XX_N.SHARED_SYSTEM.QUEUE_MANAGER.qmss_int1_9_opin;
      CONNECT248        C66XX_N.SHARED_SYSTEM.CP_INTC1.cp_intc_system_intr_in147, C66XX_N.SHARED_SYSTEM.QUEUE_MANAGER.qmss_int1_10_opin;
      CONNECT249        C66XX_N.SHARED_SYSTEM.CP_INTC1.cp_intc_system_intr_in148, C66XX_N.SHARED_SYSTEM.QUEUE_MANAGER.qmss_int1_11_opin;
      CONNECT250        C66XX_N.SHARED_SYSTEM.CP_INTC1.cp_intc_system_intr_in149, C66XX_N.SHARED_SYSTEM.QUEUE_MANAGER.qmss_int1_12_opin;
      CONNECT251        C66XX_N.SHARED_SYSTEM.CP_INTC1.cp_intc_system_intr_in150, C66XX_N.SHARED_SYSTEM.QUEUE_MANAGER.qmss_int1_13_opin;
      CONNECT252        C66XX_N.SHARED_SYSTEM.CP_INTC1.cp_intc_system_intr_in151, C66XX_N.SHARED_SYSTEM.QUEUE_MANAGER.qmss_int1_14_opin;
      CONNECT253        C66XX_N.SHARED_SYSTEM.CP_INTC1.cp_intc_system_intr_in152, C66XX_N.SHARED_SYSTEM.QUEUE_MANAGER.qmss_int1_15_opin;
      //SEMAPHORE
      CONNECT254        C66XX_N.SHARED_SYSTEM.CP_INTC1.cp_intc_system_intr_in58, C66XX_N.SHARED_SYSTEM.SEMAPHORE.semaphore2_err_opin0;
      CONNECT255        C66XX_N.SHARED_SYSTEM.CP_INTC1.cp_intc_system_intr_in59, C66XX_N.SHARED_SYSTEM.SEMAPHORE.semaphore2_err_opin1;
      CONNECT256        C66XX_N.SHARED_SYSTEM.CP_INTC1.cp_intc_system_intr_in60, C66XX_N.SHARED_SYSTEM.SEMAPHORE.semaphore2_err_opin2;
      CONNECT257        C66XX_N.SHARED_SYSTEM.CP_INTC1.cp_intc_system_intr_in61, C66XX_N.SHARED_SYSTEM.SEMAPHORE.semaphore2_err_opin3;
      //SRIO
      CONNECT258        C66XX_N.SHARED_SYSTEM.CP_INTC1.cp_intc_system_intr_in93, C66XX_N.SHARED_SYSTEM.SRIO.srio_intdst_intr0;
      CONNECT259        C66XX_N.SHARED_SYSTEM.CP_INTC1.cp_intc_system_intr_in94, C66XX_N.SHARED_SYSTEM.SRIO.srio_intdst_intr1;
      CONNECT260        C66XX_N.SHARED_SYSTEM.CP_INTC1.cp_intc_system_intr_in95, C66XX_N.SHARED_SYSTEM.SRIO.srio_intdst_intr2;
      CONNECT261        C66XX_N.SHARED_SYSTEM.CP_INTC1.cp_intc_system_intr_in96, C66XX_N.SHARED_SYSTEM.SRIO.srio_intdst_intr3;
      CONNECT262        C66XX_N.SHARED_SYSTEM.CP_INTC1.cp_intc_system_intr_in97, C66XX_N.SHARED_SYSTEM.SRIO.srio_intdst_intr4;
      CONNECT263        C66XX_N.SHARED_SYSTEM.CP_INTC1.cp_intc_system_intr_in98, C66XX_N.SHARED_SYSTEM.SRIO.srio_intdst_intr5;
      CONNECT264        C66XX_N.SHARED_SYSTEM.CP_INTC1.cp_intc_system_intr_in99, C66XX_N.SHARED_SYSTEM.SRIO.srio_intdst_intr6;
      CONNECT265        C66XX_N.SHARED_SYSTEM.CP_INTC1.cp_intc_system_intr_in100, C66XX_N.SHARED_SYSTEM.SRIO.srio_intdst_intr7;
      CONNECT266        C66XX_N.SHARED_SYSTEM.CP_INTC1.cp_intc_system_intr_in101, C66XX_N.SHARED_SYSTEM.SRIO.srio_intdst_intr8;
      CONNECT267        C66XX_N.SHARED_SYSTEM.CP_INTC1.cp_intc_system_intr_in102, C66XX_N.SHARED_SYSTEM.SRIO.srio_intdst_intr9;
      CONNECT268        C66XX_N.SHARED_SYSTEM.CP_INTC1.cp_intc_system_intr_in103, C66XX_N.SHARED_SYSTEM.SRIO.srio_intdst_intr10;
      CONNECT269        C66XX_N.SHARED_SYSTEM.CP_INTC1.cp_intc_system_intr_in104, C66XX_N.SHARED_SYSTEM.SRIO.srio_intdst_intr11;
      CONNECT270        C66XX_N.SHARED_SYSTEM.CP_INTC1.cp_intc_system_intr_in105, C66XX_N.SHARED_SYSTEM.SRIO.srio_intdst_intr12;
      CONNECT271        C66XX_N.SHARED_SYSTEM.CP_INTC1.cp_intc_system_intr_in106, C66XX_N.SHARED_SYSTEM.SRIO.srio_intdst_intr13;
      CONNECT272        C66XX_N.SHARED_SYSTEM.CP_INTC1.cp_intc_system_intr_in107, C66XX_N.SHARED_SYSTEM.SRIO.srio_intdst_intr14;
      CONNECT273        C66XX_N.SHARED_SYSTEM.CP_INTC1.cp_intc_system_intr_in108, C66XX_N.SHARED_SYSTEM.SRIO.srio_intdst_intr15;
      CONNECT274        C66XX_N.SHARED_SYSTEM.CP_INTC1.cp_intc_system_intr_in109, C66XX_N.SHARED_SYSTEM.SRIO.srio_intdst_intr16;
      CONNECT275        C66XX_N.SHARED_SYSTEM.CP_INTC1.cp_intc_system_intr_in110, C66XX_N.SHARED_SYSTEM.SRIO.srio_intdst_intr17;
      CONNECT276        C66XX_N.SHARED_SYSTEM.CP_INTC1.cp_intc_system_intr_in111, C66XX_N.SHARED_SYSTEM.SRIO.srio_intdst_intr18;
      CONNECT277        C66XX_N.SHARED_SYSTEM.CP_INTC1.cp_intc_system_intr_in112, C66XX_N.SHARED_SYSTEM.SRIO.srio_intdst_intr19;
      CONNECT278        C66XX_N.SHARED_SYSTEM.CP_INTC1.cp_intc_system_intr_in113, C66XX_N.SHARED_SYSTEM.SRIO.srio_intdst_intr20;
      CONNECT279        C66XX_N.SHARED_SYSTEM.CP_INTC1.cp_intc_system_intr_in114, C66XX_N.SHARED_SYSTEM.SRIO.srio_intdst_intr21;
      CONNECT280        C66XX_N.SHARED_SYSTEM.CP_INTC1.cp_intc_system_intr_in115, C66XX_N.SHARED_SYSTEM.SRIO.srio_intdst_intr22;
      CONNECT281        C66XX_N.SHARED_SYSTEM.CP_INTC1.cp_intc_system_intr_in116, C66XX_N.SHARED_SYSTEM.SRIO.srio_intdst_intr23;
      //VCP
      CONNECT282        C66XX_N.SHARED_SYSTEM.CP_INTC1.cp_intc_system_intr_in119, C66XX_N.SHARED_SYSTEM.VCP2_0.VCP_INTR;
      CONNECT283        C66XX_N.SHARED_SYSTEM.CP_INTC1.cp_intc_system_intr_in120, C66XX_N.SHARED_SYSTEM.VCP2_1.VCP_INTR;
      //INTD_TCP3D_A
      CONNECT284        C66XX_N.SHARED_SYSTEM.INTD_TCP3D_A.intr_out_edge, C66XX_N.SHARED_SYSTEM.CP_INTC1.cp_intc_system_intr_in123;
      // System Interrupt Connections - INTC2
      //GPIO
      CONNECT285        C66XX_N.SHARED_SYSTEM.CP_INTC2.cp_intc_system_intr_in0, C66XX_N.SHARED_SYSTEM.GPIO.gpio_gpint0_opin;
      CONNECT286        C66XX_N.SHARED_SYSTEM.CP_INTC2.cp_intc_system_intr_in1, C66XX_N.SHARED_SYSTEM.GPIO.gpio_gpint1_opin;
      CONNECT287        C66XX_N.SHARED_SYSTEM.CP_INTC2.cp_intc_system_intr_in2, C66XX_N.SHARED_SYSTEM.GPIO.gpio_gpint2_opin;
      CONNECT288        C66XX_N.SHARED_SYSTEM.CP_INTC2.cp_intc_system_intr_in3, C66XX_N.SHARED_SYSTEM.GPIO.gpio_gpint3_opin;
      CONNECT289        C66XX_N.SHARED_SYSTEM.CP_INTC2.cp_intc_system_intr_in4, C66XX_N.SHARED_SYSTEM.GPIO.gpio_gpint4_opin;
      CONNECT290        C66XX_N.SHARED_SYSTEM.CP_INTC2.cp_intc_system_intr_in5, C66XX_N.SHARED_SYSTEM.GPIO.gpio_gpint5_opin;
      CONNECT291        C66XX_N.SHARED_SYSTEM.CP_INTC2.cp_intc_system_intr_in6, C66XX_N.SHARED_SYSTEM.GPIO.gpio_gpint6_opin;
      CONNECT292        C66XX_N.SHARED_SYSTEM.CP_INTC2.cp_intc_system_intr_in7, C66XX_N.SHARED_SYSTEM.GPIO.gpio_gpint7_opin;
      CONNECT293        C66XX_N.SHARED_SYSTEM.CP_INTC2.cp_intc_system_intr_in8, C66XX_N.SHARED_SYSTEM.GPIO.gpio_gpint8_opin;
      CONNECT294        C66XX_N.SHARED_SYSTEM.CP_INTC2.cp_intc_system_intr_in9, C66XX_N.SHARED_SYSTEM.GPIO.gpio_gpint9_opin;
      CONNECT295        C66XX_N.SHARED_SYSTEM.CP_INTC2.cp_intc_system_intr_in10, C66XX_N.SHARED_SYSTEM.GPIO.gpio_gpint10_opin;
      CONNECT296        C66XX_N.SHARED_SYSTEM.CP_INTC2.cp_intc_system_intr_in11, C66XX_N.SHARED_SYSTEM.GPIO.gpio_gpint11_opin;
      CONNECT297        C66XX_N.SHARED_SYSTEM.CP_INTC2.cp_intc_system_intr_in12, C66XX_N.SHARED_SYSTEM.GPIO.gpio_gpint12_opin;
      CONNECT298        C66XX_N.SHARED_SYSTEM.CP_INTC2.cp_intc_system_intr_in13, C66XX_N.SHARED_SYSTEM.GPIO.gpio_gpint13_opin;
      CONNECT299        C66XX_N.SHARED_SYSTEM.CP_INTC2.cp_intc_system_intr_in14, C66XX_N.SHARED_SYSTEM.GPIO.gpio_gpint14_opin;
      CONNECT300        C66XX_N.SHARED_SYSTEM.CP_INTC2.cp_intc_system_intr_in15, C66XX_N.SHARED_SYSTEM.GPIO.gpio_gpint15_opin;
      CONNECT301        C66XX_N.SHARED_SYSTEM.CP_INTC2.cp_intc_system_intr_in25, C66XX_N.SHARED_SYSTEM.GPIO.gpio_gpint16_opin;
      CONNECT302        C66XX_N.SHARED_SYSTEM.CP_INTC2.cp_intc_system_intr_in26, C66XX_N.SHARED_SYSTEM.GPIO.gpio_gpint17_opin;
      CONNECT303        C66XX_N.SHARED_SYSTEM.CP_INTC2.cp_intc_system_intr_in27, C66XX_N.SHARED_SYSTEM.GPIO.gpio_gpint18_opin;
      CONNECT304        C66XX_N.SHARED_SYSTEM.CP_INTC2.cp_intc_system_intr_in28, C66XX_N.SHARED_SYSTEM.GPIO.gpio_gpint19_opin;
      CONNECT305        C66XX_N.SHARED_SYSTEM.CP_INTC2.cp_intc_system_intr_in29, C66XX_N.SHARED_SYSTEM.GPIO.gpio_gpint20_opin;
      CONNECT306        C66XX_N.SHARED_SYSTEM.CP_INTC2.cp_intc_system_intr_in30, C66XX_N.SHARED_SYSTEM.GPIO.gpio_gpint21_opin;
      CONNECT307        C66XX_N.SHARED_SYSTEM.CP_INTC2.cp_intc_system_intr_in33, C66XX_N.SHARED_SYSTEM.GPIO.gpio_gpint22_opin;
      CONNECT308        C66XX_N.SHARED_SYSTEM.CP_INTC2.cp_intc_system_intr_in34, C66XX_N.SHARED_SYSTEM.GPIO.gpio_gpint23_opin;
      CONNECT309        C66XX_N.SHARED_SYSTEM.CP_INTC2.cp_intc_system_intr_in45, C66XX_N.SHARED_SYSTEM.GPIO.gpio_gpint24_opin;
      CONNECT310        C66XX_N.SHARED_SYSTEM.CP_INTC2.cp_intc_system_intr_in46, C66XX_N.SHARED_SYSTEM.GPIO.gpio_gpint25_opin;
      CONNECT311        C66XX_N.SHARED_SYSTEM.CP_INTC2.cp_intc_system_intr_in47, C66XX_N.SHARED_SYSTEM.GPIO.gpio_gpint26_opin;
      CONNECT312        C66XX_N.SHARED_SYSTEM.CP_INTC2.cp_intc_system_intr_in48, C66XX_N.SHARED_SYSTEM.GPIO.gpio_gpint27_opin;
      CONNECT313        C66XX_N.SHARED_SYSTEM.CP_INTC2.cp_intc_system_intr_in64, C66XX_N.SHARED_SYSTEM.GPIO.gpio_gpint28_opin;
      CONNECT314        C66XX_N.SHARED_SYSTEM.CP_INTC2.cp_intc_system_intr_in65, C66XX_N.SHARED_SYSTEM.GPIO.gpio_gpint29_opin;
      CONNECT315        C66XX_N.SHARED_SYSTEM.CP_INTC2.cp_intc_system_intr_in66, C66XX_N.SHARED_SYSTEM.GPIO.gpio_gpint30_opin;
      CONNECT316        C66XX_N.SHARED_SYSTEM.CP_INTC2.cp_intc_system_intr_in67, C66XX_N.SHARED_SYSTEM.GPIO.gpio_gpint31_opin;
      //TIMER64
      CONNECT317        C66XX_N.SHARED_SYSTEM.CP_INTC2.cp_intc_system_intr_in49, C66XX_N.SHARED_SYSTEM.TIMER64_4_cpu_int_12;
      CONNECT318        C66XX_N.SHARED_SYSTEM.CP_INTC2.cp_intc_system_intr_in50, C66XX_N.SHARED_SYSTEM.TIMER64_4_cpu_int_34;
      CONNECT319        C66XX_N.SHARED_SYSTEM.CP_INTC2.cp_intc_system_intr_in51, C66XX_N.SHARED_SYSTEM.TIMER64_5_cpu_int_12;
      CONNECT320        C66XX_N.SHARED_SYSTEM.CP_INTC2.cp_intc_system_intr_in52, C66XX_N.SHARED_SYSTEM.TIMER64_5_cpu_int_34;
      CONNECT321        C66XX_N.SHARED_SYSTEM.CP_INTC2.cp_intc_system_intr_in53, C66XX_N.SHARED_SYSTEM.TIMER64_6_cpu_int_12;
      CONNECT322        C66XX_N.SHARED_SYSTEM.CP_INTC2.cp_intc_system_intr_in54, C66XX_N.SHARED_SYSTEM.TIMER64_6_cpu_int_34;
      CONNECT323        C66XX_N.SHARED_SYSTEM.CP_INTC2.cp_intc_system_intr_in55, C66XX_N.SHARED_SYSTEM.TIMER64_7_cpu_int_12;
      CONNECT324        C66XX_N.SHARED_SYSTEM.CP_INTC2.cp_intc_system_intr_in56, C66XX_N.SHARED_SYSTEM.TIMER64_7_cpu_int_34;
      CONNECT325        C66XX_N.SHARED_SYSTEM.CP_INTC2.cp_intc_system_intr_in68, C66XX_N.SHARED_SYSTEM.TIMER64_2_cpu_int_12;
      CONNECT326        C66XX_N.SHARED_SYSTEM.CP_INTC2.cp_intc_system_intr_in69, C66XX_N.SHARED_SYSTEM.TIMER64_2_cpu_int_34;
      CONNECT327        C66XX_N.SHARED_SYSTEM.CP_INTC2.cp_intc_system_intr_in70, C66XX_N.SHARED_SYSTEM.TIMER64_3_cpu_int_12;
      CONNECT328        C66XX_N.SHARED_SYSTEM.CP_INTC2.cp_intc_system_intr_in71, C66XX_N.SHARED_SYSTEM.TIMER64_3_cpu_int_34;
      // Host Interrupt Connections for INTC0
      //!  With CGEM_0
      CONNECT329        C66XX_N.SHARED_SYSTEM.CP_INTC0.cp_intc_out0, C66XX_N.CPU_SYSTEM_0.CGEM_SSI_0.INTSEL_in_pin_22;
      CONNECT330        C66XX_N.SHARED_SYSTEM.CP_INTC0.cp_intc_out1, C66XX_N.CPU_SYSTEM_0.CGEM_SSI_0.INTSEL_in_pin_23;
      CONNECT331        C66XX_N.SHARED_SYSTEM.CP_INTC0.cp_intc_out2, C66XX_N.CPU_SYSTEM_0.CGEM_SSI_0.INTSEL_in_pin_24;
      CONNECT332        C66XX_N.SHARED_SYSTEM.CP_INTC0.cp_intc_out3, C66XX_N.CPU_SYSTEM_0.CGEM_SSI_0.INTSEL_in_pin_25;
      CONNECT333        C66XX_N.SHARED_SYSTEM.CP_INTC0.cp_intc_out4, C66XX_N.CPU_SYSTEM_0.CGEM_SSI_0.INTSEL_in_pin_26;
      CONNECT334        C66XX_N.SHARED_SYSTEM.CP_INTC0.cp_intc_out5, C66XX_N.CPU_SYSTEM_0.CGEM_SSI_0.INTSEL_in_pin_27;
      CONNECT335        C66XX_N.SHARED_SYSTEM.CP_INTC0.cp_intc_out6, C66XX_N.CPU_SYSTEM_0.CGEM_SSI_0.INTSEL_in_pin_28;
      CONNECT336        C66XX_N.SHARED_SYSTEM.CP_INTC0.cp_intc_out7, C66XX_N.CPU_SYSTEM_0.CGEM_SSI_0.INTSEL_in_pin_29;
      CONNECT337        C66XX_N.SHARED_SYSTEM.CP_INTC0.cp_intc_out8, C66XX_N.CPU_SYSTEM_0.CGEM_SSI_0.INTSEL_in_pin_30;
      CONNECT338        C66XX_N.SHARED_SYSTEM.CP_INTC0.cp_intc_out9, C66XX_N.CPU_SYSTEM_0.CGEM_SSI_0.INTSEL_in_pin_31;
      CONNECT339        C66XX_N.SHARED_SYSTEM.CP_INTC0.cp_intc_out10, C66XX_N.CPU_SYSTEM_0.CGEM_SSI_0.INTSEL_in_pin_92;
      CONNECT340        C66XX_N.SHARED_SYSTEM.CP_INTC0.cp_intc_out11, C66XX_N.CPU_SYSTEM_0.CGEM_SSI_0.INTSEL_in_pin_93;
      CONNECT341        C66XX_N.SHARED_SYSTEM.CP_INTC0.cp_intc_out40, C66XX_N.CPU_SYSTEM_0.CGEM_SSI_0.INTSEL_in_pin_56;
      CONNECT342        C66XX_N.SHARED_SYSTEM.CP_INTC0.cp_intc_out41, C66XX_N.CPU_SYSTEM_0.CGEM_SSI_0.INTSEL_in_pin_57;
      CONNECT343        C66XX_N.SHARED_SYSTEM.CP_INTC0.cp_intc_out42, C66XX_N.CPU_SYSTEM_0.CGEM_SSI_0.INTSEL_in_pin_58;
      CONNECT344        C66XX_N.SHARED_SYSTEM.CP_INTC0.cp_intc_out43, C66XX_N.CPU_SYSTEM_0.CGEM_SSI_0.INTSEL_in_pin_59;
      CONNECT345        C66XX_N.SHARED_SYSTEM.CP_INTC0.cp_intc_out44, C66XX_N.CPU_SYSTEM_0.CGEM_SSI_0.INTSEL_in_pin_60;
      CONNECT346        C66XX_N.SHARED_SYSTEM.CP_INTC0.cp_intc_out45, C66XX_N.CPU_SYSTEM_0.CGEM_SSI_0.INTSEL_in_pin_61;
      CONNECT347        C66XX_N.SHARED_SYSTEM.CP_INTC0.cp_intc_out46, C66XX_N.CPU_SYSTEM_0.CGEM_SSI_0.INTSEL_in_pin_62;
      CONNECT348        C66XX_N.SHARED_SYSTEM.CP_INTC0.cp_intc_out47, C66XX_N.CPU_SYSTEM_0.CGEM_SSI_0.INTSEL_in_pin_63;
      //!  With CGEM_1
      CONNECT349        C66XX_N.SHARED_SYSTEM.CP_INTC0.cp_intc_out20, C66XX_N.CPU_SYSTEM_1.CGEM_SSI_1.INTSEL_in_pin_22;
      CONNECT350        C66XX_N.SHARED_SYSTEM.CP_INTC0.cp_intc_out21, C66XX_N.CPU_SYSTEM_1.CGEM_SSI_1.INTSEL_in_pin_23;
      CONNECT351        C66XX_N.SHARED_SYSTEM.CP_INTC0.cp_intc_out22, C66XX_N.CPU_SYSTEM_1.CGEM_SSI_1.INTSEL_in_pin_24;
      CONNECT352        C66XX_N.SHARED_SYSTEM.CP_INTC0.cp_intc_out23, C66XX_N.CPU_SYSTEM_1.CGEM_SSI_1.INTSEL_in_pin_25;
      CONNECT353        C66XX_N.SHARED_SYSTEM.CP_INTC0.cp_intc_out24, C66XX_N.CPU_SYSTEM_1.CGEM_SSI_1.INTSEL_in_pin_26;
      CONNECT354        C66XX_N.SHARED_SYSTEM.CP_INTC0.cp_intc_out25, C66XX_N.CPU_SYSTEM_1.CGEM_SSI_1.INTSEL_in_pin_27;
      CONNECT355        C66XX_N.SHARED_SYSTEM.CP_INTC0.cp_intc_out26, C66XX_N.CPU_SYSTEM_1.CGEM_SSI_1.INTSEL_in_pin_28;
      CONNECT356        C66XX_N.SHARED_SYSTEM.CP_INTC0.cp_intc_out27, C66XX_N.CPU_SYSTEM_1.CGEM_SSI_1.INTSEL_in_pin_29;
      CONNECT357        C66XX_N.SHARED_SYSTEM.CP_INTC0.cp_intc_out28, C66XX_N.CPU_SYSTEM_1.CGEM_SSI_1.INTSEL_in_pin_30;
      CONNECT358        C66XX_N.SHARED_SYSTEM.CP_INTC0.cp_intc_out29, C66XX_N.CPU_SYSTEM_1.CGEM_SSI_1.INTSEL_in_pin_31;
      CONNECT359        C66XX_N.SHARED_SYSTEM.CP_INTC0.cp_intc_out30, C66XX_N.CPU_SYSTEM_1.CGEM_SSI_1.INTSEL_in_pin_92;
      CONNECT360        C66XX_N.SHARED_SYSTEM.CP_INTC0.cp_intc_out31, C66XX_N.CPU_SYSTEM_1.CGEM_SSI_1.INTSEL_in_pin_93;
      CONNECT361        C66XX_N.SHARED_SYSTEM.CP_INTC0.cp_intc_out40, C66XX_N.CPU_SYSTEM_1.CGEM_SSI_1.INTSEL_in_pin_56;
      CONNECT362        C66XX_N.SHARED_SYSTEM.CP_INTC0.cp_intc_out41, C66XX_N.CPU_SYSTEM_1.CGEM_SSI_1.INTSEL_in_pin_57;
      CONNECT363        C66XX_N.SHARED_SYSTEM.CP_INTC0.cp_intc_out42, C66XX_N.CPU_SYSTEM_1.CGEM_SSI_1.INTSEL_in_pin_58;
      CONNECT364        C66XX_N.SHARED_SYSTEM.CP_INTC0.cp_intc_out43, C66XX_N.CPU_SYSTEM_1.CGEM_SSI_1.INTSEL_in_pin_59;
      CONNECT365        C66XX_N.SHARED_SYSTEM.CP_INTC0.cp_intc_out44, C66XX_N.CPU_SYSTEM_1.CGEM_SSI_1.INTSEL_in_pin_60;
      CONNECT366        C66XX_N.SHARED_SYSTEM.CP_INTC0.cp_intc_out45, C66XX_N.CPU_SYSTEM_1.CGEM_SSI_1.INTSEL_in_pin_61;
      CONNECT367        C66XX_N.SHARED_SYSTEM.CP_INTC0.cp_intc_out46, C66XX_N.CPU_SYSTEM_1.CGEM_SSI_1.INTSEL_in_pin_62;
      CONNECT368        C66XX_N.SHARED_SYSTEM.CP_INTC0.cp_intc_out47, C66XX_N.CPU_SYSTEM_1.CGEM_SSI_1.INTSEL_in_pin_63;
      // Host Interrupt Connections for INTC1
      //!  With EDMA
      ONNECT481        C66XX_N.SHARED_SYSTEM.CP_INTC1.cp_intc_out0, C66XX_N.SHARED_SYSTEM.EDMA_evt_in_pin43;
      CONNECT369        C66XX_N.SHARED_SYSTEM.CP_INTC1.cp_intc_out1, C66XX_N.SHARED_SYSTEM.EDMA_evt_in_pin44;
      CONNECT370        C66XX_N.SHARED_SYSTEM.CP_INTC1.cp_intc_out2, C66XX_N.SHARED_SYSTEM.EDMA_evt_in_pin45;
      CONNECT371        C66XX_N.SHARED_SYSTEM.CP_INTC1.cp_intc_out3, C66XX_N.SHARED_SYSTEM.EDMA_evt_in_pin46;
      CONNECT372        C66XX_N.SHARED_SYSTEM.CP_INTC1.cp_intc_out4, C66XX_N.SHARED_SYSTEM.EDMA_evt_in_pin47;
      CONNECT373        C66XX_N.SHARED_SYSTEM.CP_INTC1.cp_intc_out5, C66XX_N.SHARED_SYSTEM.EDMA_evt_in_pin48;
      CONNECT374        C66XX_N.SHARED_SYSTEM.CP_INTC1.cp_intc_out6, C66XX_N.SHARED_SYSTEM.EDMA_evt_in_pin49;
      CONNECT375        C66XX_N.SHARED_SYSTEM.CP_INTC1.cp_intc_out7, C66XX_N.SHARED_SYSTEM.EDMA_evt_in_pin50;
      CONNECT376        C66XX_N.SHARED_SYSTEM.CP_INTC1.cp_intc_out8, C66XX_N.SHARED_SYSTEM.EDMA_evt_in_pin51;
      CONNECT377        C66XX_N.SHARED_SYSTEM.CP_INTC1.cp_intc_out9, C66XX_N.SHARED_SYSTEM.EDMA_evt_in_pin52;
      CONNECT378        C66XX_N.SHARED_SYSTEM.CP_INTC1.cp_intc_out10, C66XX_N.SHARED_SYSTEM.EDMA_evt_in_pin53;
      CONNECT379        C66XX_N.SHARED_SYSTEM.CP_INTC1.cp_intc_out11, C66XX_N.SHARED_SYSTEM.EDMA_evt_in_pin54;
      CONNECT380        C66XX_N.SHARED_SYSTEM.CP_INTC1.cp_intc_out12, C66XX_N.SHARED_SYSTEM.EDMA_evt_in_pin55;
      CONNECT381        C66XX_N.SHARED_SYSTEM.CP_INTC1.cp_intc_out13, C66XX_N.SHARED_SYSTEM.EDMA_evt_in_pin56;
      CONNECT382        C66XX_N.SHARED_SYSTEM.CP_INTC1.cp_intc_out14, C66XX_N.SHARED_SYSTEM.EDMA_evt_in_pin57;
      CONNECT383        C66XX_N.SHARED_SYSTEM.CP_INTC1.cp_intc_out15, C66XX_N.SHARED_SYSTEM.EDMA_evt_in_pin58;
      CONNECT384        C66XX_N.SHARED_SYSTEM.CP_INTC1.cp_intc_out16, C66XX_N.SHARED_SYSTEM.EDMA_evt_in_pin59;
      CONNECT385        C66XX_N.SHARED_SYSTEM.CP_INTC1.cp_intc_out17, C66XX_N.SHARED_SYSTEM.EDMA_evt_in_pin60;
      // Primary Interrupt Connections with CPU
      //!CPU0
      //SEMAPHORE
      CONNECT386        C66XX_N.CPU_SYSTEM_0.CGEM_SSI_0.INTSEL_in_pin_15, C66XX_N.SHARED_SYSTEM.SEMAPHORE.semaphore2_err_opin0;
      CONNECT387        C66XX_N.CPU_SYSTEM_0.CGEM_SSI_0.INTSEL_in_pin_16, C66XX_N.SHARED_SYSTEM.SEMAPHORE.semaphore2_intr_opin0;
      //SRIO
      CONNECT388        C66XX_N.CPU_SYSTEM_0.CGEM_SSI_0.INTSEL_in_pin_20, C66XX_N.SHARED_SYSTEM.SRIO.srio_intdst_intr16;
      CONNECT389        C66XX_N.CPU_SYSTEM_0.CGEM_SSI_0.INTSEL_in_pin_21, C66XX_N.SHARED_SYSTEM.SRIO.srio_intdst_intr20;
      CONNECT390        C66XX_N.CPU_SYSTEM_0.CGEM_SSI_0.INTSEL_in_pin_112, C66XX_N.SHARED_SYSTEM.SRIO.srio_intdst_intr18;
      CONNECT391        C66XX_N.CPU_SYSTEM_0.CGEM_SSI_0.INTSEL_in_pin_114, C66XX_N.SHARED_SYSTEM.SRIO.srio_intdst_intr22;
      //QUEUE_MANAGER
      CONNECT392        C66XX_N.CPU_SYSTEM_0.CGEM_SSI_0.INTSEL_in_pin_32, C66XX_N.SHARED_SYSTEM.QUEUE_MANAGER.qmss_int0_0_opin;
      CONNECT393        C66XX_N.CPU_SYSTEM_0.CGEM_SSI_0.INTSEL_in_pin_33, C66XX_N.SHARED_SYSTEM.QUEUE_MANAGER.qmss_int0_1_opin;
      CONNECT394        C66XX_N.CPU_SYSTEM_0.CGEM_SSI_0.INTSEL_in_pin_34, C66XX_N.SHARED_SYSTEM.QUEUE_MANAGER.qmss_int0_2_opin;
      CONNECT395        C66XX_N.CPU_SYSTEM_0.CGEM_SSI_0.INTSEL_in_pin_35, C66XX_N.SHARED_SYSTEM.QUEUE_MANAGER.qmss_int0_3_opin;
      CONNECT396        C66XX_N.CPU_SYSTEM_0.CGEM_SSI_0.INTSEL_in_pin_36, C66XX_N.SHARED_SYSTEM.QUEUE_MANAGER.qmss_int0_4_opin;
      CONNECT397        C66XX_N.CPU_SYSTEM_0.CGEM_SSI_0.INTSEL_in_pin_37, C66XX_N.SHARED_SYSTEM.QUEUE_MANAGER.qmss_int0_5_opin;
      CONNECT398        C66XX_N.CPU_SYSTEM_0.CGEM_SSI_0.INTSEL_in_pin_38, C66XX_N.SHARED_SYSTEM.QUEUE_MANAGER.qmss_int0_6_opin;
      CONNECT399        C66XX_N.CPU_SYSTEM_0.CGEM_SSI_0.INTSEL_in_pin_39, C66XX_N.SHARED_SYSTEM.QUEUE_MANAGER.qmss_int0_7_opin;
      CONNECT400        C66XX_N.CPU_SYSTEM_0.CGEM_SSI_0.INTSEL_in_pin_40, C66XX_N.SHARED_SYSTEM.QUEUE_MANAGER.qmss_int0_8_opin;
      CONNECT401        C66XX_N.CPU_SYSTEM_0.CGEM_SSI_0.INTSEL_in_pin_41, C66XX_N.SHARED_SYSTEM.QUEUE_MANAGER.qmss_int0_9_opin;
      CONNECT402        C66XX_N.CPU_SYSTEM_0.CGEM_SSI_0.INTSEL_in_pin_42, C66XX_N.SHARED_SYSTEM.QUEUE_MANAGER.qmss_int0_10_opin;
      CONNECT403        C66XX_N.CPU_SYSTEM_0.CGEM_SSI_0.INTSEL_in_pin_43, C66XX_N.SHARED_SYSTEM.QUEUE_MANAGER.qmss_int0_11_opin;
      CONNECT404        C66XX_N.CPU_SYSTEM_0.CGEM_SSI_0.INTSEL_in_pin_44, C66XX_N.SHARED_SYSTEM.QUEUE_MANAGER.qmss_int0_12_opin;
      CONNECT405        C66XX_N.CPU_SYSTEM_0.CGEM_SSI_0.INTSEL_in_pin_45, C66XX_N.SHARED_SYSTEM.QUEUE_MANAGER.qmss_int0_13_opin;
      CONNECT406        C66XX_N.CPU_SYSTEM_0.CGEM_SSI_0.INTSEL_in_pin_46, C66XX_N.SHARED_SYSTEM.QUEUE_MANAGER.qmss_int0_14_opin;
      CONNECT407        C66XX_N.CPU_SYSTEM_0.CGEM_SSI_0.INTSEL_in_pin_47, C66XX_N.SHARED_SYSTEM.QUEUE_MANAGER.qmss_int0_15_opin;
      CONNECT408        C66XX_N.CPU_SYSTEM_0.CGEM_SSI_0.INTSEL_in_pin_48, C66XX_N.SHARED_SYSTEM.QUEUE_MANAGER.qmss_int1_0_opin;
      CONNECT409        C66XX_N.CPU_SYSTEM_0.CGEM_SSI_0.INTSEL_in_pin_49, C66XX_N.SHARED_SYSTEM.QUEUE_MANAGER.qmss_int1_4_opin;
      CONNECT410        C66XX_N.CPU_SYSTEM_0.CGEM_SSI_0.INTSEL_in_pin_50, C66XX_N.SHARED_SYSTEM.QUEUE_MANAGER.qmss_int1_8_opin;
      CONNECT411        C66XX_N.CPU_SYSTEM_0.CGEM_SSI_0.INTSEL_in_pin_51, C66XX_N.SHARED_SYSTEM.QUEUE_MANAGER.qmss_int1_12_opin;
      CONNECT412        C66XX_N.CPU_SYSTEM_0.CGEM_SSI_0.INTSEL_in_pin_52, C66XX_N.SHARED_SYSTEM.QUEUE_MANAGER.qmss_int1_16_opin;
      CONNECT413        C66XX_N.CPU_SYSTEM_0.CGEM_SSI_0.INTSEL_in_pin_53, C66XX_N.SHARED_SYSTEM.QUEUE_MANAGER.qmss_int1_20_opin;
      CONNECT414        C66XX_N.CPU_SYSTEM_0.CGEM_SSI_0.INTSEL_in_pin_54, C66XX_N.SHARED_SYSTEM.QUEUE_MANAGER.qmss_int1_24_opin;
      CONNECT415        C66XX_N.CPU_SYSTEM_0.CGEM_SSI_0.INTSEL_in_pin_55, C66XX_N.SHARED_SYSTEM.QUEUE_MANAGER.qmss_int1_28_opin;
      CONNECT416        C66XX_N.CPU_SYSTEM_0.CGEM_SSI_0.INTSEL_in_pin_102, C66XX_N.SHARED_SYSTEM.QUEUE_MANAGER.qmss_int1_2_opin;
      CONNECT417        C66XX_N.CPU_SYSTEM_0.CGEM_SSI_0.INTSEL_in_pin_103, C66XX_N.SHARED_SYSTEM.QUEUE_MANAGER.qmss_int1_6_opin;
      CONNECT418        C66XX_N.CPU_SYSTEM_0.CGEM_SSI_0.INTSEL_in_pin_104, C66XX_N.SHARED_SYSTEM.QUEUE_MANAGER.qmss_int1_10_opin;
      CONNECT419        C66XX_N.CPU_SYSTEM_0.CGEM_SSI_0.INTSEL_in_pin_105, C66XX_N.SHARED_SYSTEM.QUEUE_MANAGER.qmss_int1_14_opin;
      CONNECT420        C66XX_N.CPU_SYSTEM_0.CGEM_SSI_0.INTSEL_in_pin_106, C66XX_N.SHARED_SYSTEM.QUEUE_MANAGER.qmss_int1_18_opin;
      CONNECT421        C66XX_N.CPU_SYSTEM_0.CGEM_SSI_0.INTSEL_in_pin_107, C66XX_N.SHARED_SYSTEM.QUEUE_MANAGER.qmss_int1_22_opin;
      CONNECT422        C66XX_N.CPU_SYSTEM_0.CGEM_SSI_0.INTSEL_in_pin_108, C66XX_N.SHARED_SYSTEM.QUEUE_MANAGER.qmss_int1_26_opin;
      CONNECT423        C66XX_N.CPU_SYSTEM_0.CGEM_SSI_0.INTSEL_in_pin_109, C66XX_N.SHARED_SYSTEM.QUEUE_MANAGER.qmss_int1_30_opin;
      //TIMERS
      CONNECT424        C66XX_N.CPU_SYSTEM_0.CGEM_SSI_0.INTSEL_in_pin_64, C66XX_N.SHARED_SYSTEM.TIMER64_0_cpu_int_12;
      CONNECT425        C66XX_N.CPU_SYSTEM_0.CGEM_SSI_0.INTSEL_in_pin_65, C66XX_N.SHARED_SYSTEM.TIMER64_0_cpu_int_34;
      CONNECT426        C66XX_N.CPU_SYSTEM_0.CGEM_SSI_0.INTSEL_in_pin_66, C66XX_N.SHARED_SYSTEM.TIMER64_2_cpu_int_12;
      CONNECT427        C66XX_N.CPU_SYSTEM_0.CGEM_SSI_0.INTSEL_in_pin_67, C66XX_N.SHARED_SYSTEM.TIMER64_2_cpu_int_34;
      CONNECT428        C66XX_N.CPU_SYSTEM_0.CGEM_SSI_0.INTSEL_in_pin_68, C66XX_N.SHARED_SYSTEM.TIMER64_3_cpu_int_12;
      CONNECT429        C66XX_N.CPU_SYSTEM_0.CGEM_SSI_0.INTSEL_in_pin_69, C66XX_N.SHARED_SYSTEM.TIMER64_3_cpu_int_34;
      //GPIO
      CONNECT430        C66XX_N.CPU_SYSTEM_0.CGEM_SSI_0.INTSEL_in_pin_72, C66XX_N.SHARED_SYSTEM.GPIO.gpio_gpint2_opin;
      CONNECT431        C66XX_N.CPU_SYSTEM_0.CGEM_SSI_0.INTSEL_in_pin_73, C66XX_N.SHARED_SYSTEM.GPIO.gpio_gpint3_opin;
      CONNECT432        C66XX_N.CPU_SYSTEM_0.CGEM_SSI_0.INTSEL_in_pin_78, C66XX_N.SHARED_SYSTEM.GPIO.gpio_gpint4_opin;
      CONNECT433        C66XX_N.CPU_SYSTEM_0.CGEM_SSI_0.INTSEL_in_pin_79, C66XX_N.SHARED_SYSTEM.GPIO.gpio_gpint5_opin;
      CONNECT434        C66XX_N.CPU_SYSTEM_0.CGEM_SSI_0.INTSEL_in_pin_80, C66XX_N.SHARED_SYSTEM.GPIO.gpio_gpint6_opin;
      CONNECT435        C66XX_N.CPU_SYSTEM_0.CGEM_SSI_0.INTSEL_in_pin_81, C66XX_N.SHARED_SYSTEM.GPIO.gpio_gpint7_opin;
      CONNECT436        C66XX_N.CPU_SYSTEM_0.CGEM_SSI_0.INTSEL_in_pin_82, C66XX_N.SHARED_SYSTEM.GPIO.gpio_gpint8_opin;
      CONNECT437        C66XX_N.CPU_SYSTEM_0.CGEM_SSI_0.INTSEL_in_pin_83, C66XX_N.SHARED_SYSTEM.GPIO.gpio_gpint9_opin;
      CONNECT438        C66XX_N.CPU_SYSTEM_0.CGEM_SSI_0.INTSEL_in_pin_84, C66XX_N.SHARED_SYSTEM.GPIO.gpio_gpint10_opin;
      CONNECT439        C66XX_N.CPU_SYSTEM_0.CGEM_SSI_0.INTSEL_in_pin_85, C66XX_N.SHARED_SYSTEM.GPIO.gpio_gpint11_opin;
      CONNECT440        C66XX_N.CPU_SYSTEM_0.CGEM_SSI_0.INTSEL_in_pin_86, C66XX_N.SHARED_SYSTEM.GPIO.gpio_gpint12_opin;
      CONNECT441        C66XX_N.CPU_SYSTEM_0.CGEM_SSI_0.INTSEL_in_pin_87, C66XX_N.SHARED_SYSTEM.GPIO.gpio_gpint13_opin;
      CONNECT442        C66XX_N.CPU_SYSTEM_0.CGEM_SSI_0.INTSEL_in_pin_88, C66XX_N.SHARED_SYSTEM.GPIO.gpio_gpint14_opin;
      CONNECT443        C66XX_N.CPU_SYSTEM_0.CGEM_SSI_0.INTSEL_in_pin_89, C66XX_N.SHARED_SYSTEM.GPIO.gpio_gpint15_opin;
      CONNECT444        C66XX_N.CPU_SYSTEM_0.CGEM_SSI_0.INTSEL_in_pin_91, C66XX_N.SHARED_SYSTEM.GPIO.gpio_gpint0_opin;
      //IPC
      CONNECT445        C66XX_N.CPU_SYSTEM_0.CGEM_SSI_0.INTSEL_in_pin_90, C66XX_N.SHARED_SYSTEM.IPC_cpu_int_0;
      //!CPU1
      //SEMAPHORE
      CONNECT446        C66XX_N.CPU_SYSTEM_1.CGEM_SSI_1.INTSEL_in_pin_15, C66XX_N.SHARED_SYSTEM.SEMAPHORE.semaphore2_err_opin1;
      CONNECT447        C66XX_N.CPU_SYSTEM_1.CGEM_SSI_1.INTSEL_in_pin_16, C66XX_N.SHARED_SYSTEM.SEMAPHORE.semaphore2_intr_opin1;
      //SRIO
      CONNECT448        C66XX_N.CPU_SYSTEM_1.CGEM_SSI_1.INTSEL_in_pin_20, C66XX_N.SHARED_SYSTEM.SRIO.srio_intdst_intr17;
      CONNECT449        C66XX_N.CPU_SYSTEM_1.CGEM_SSI_1.INTSEL_in_pin_21, C66XX_N.SHARED_SYSTEM.SRIO.srio_intdst_intr21;
      CONNECT450        C66XX_N.CPU_SYSTEM_1.CGEM_SSI_1.INTSEL_in_pin_112, C66XX_N.SHARED_SYSTEM.SRIO.srio_intdst_intr19;
      CONNECT451        C66XX_N.CPU_SYSTEM_1.CGEM_SSI_1.INTSEL_in_pin_114, C66XX_N.SHARED_SYSTEM.SRIO.srio_intdst_intr23;
      //QUEUE_MANAGER
      CONNECT452        C66XX_N.CPU_SYSTEM_1.CGEM_SSI_1.INTSEL_in_pin_32, C66XX_N.SHARED_SYSTEM.QUEUE_MANAGER.qmss_int0_0_opin;
      CONNECT453        C66XX_N.CPU_SYSTEM_1.CGEM_SSI_1.INTSEL_in_pin_33, C66XX_N.SHARED_SYSTEM.QUEUE_MANAGER.qmss_int0_1_opin;
      CONNECT454        C66XX_N.CPU_SYSTEM_1.CGEM_SSI_1.INTSEL_in_pin_34, C66XX_N.SHARED_SYSTEM.QUEUE_MANAGER.qmss_int0_2_opin;
      CONNECT455        C66XX_N.CPU_SYSTEM_1.CGEM_SSI_1.INTSEL_in_pin_35, C66XX_N.SHARED_SYSTEM.QUEUE_MANAGER.qmss_int0_3_opin;
      CONNECT456        C66XX_N.CPU_SYSTEM_1.CGEM_SSI_1.INTSEL_in_pin_36, C66XX_N.SHARED_SYSTEM.QUEUE_MANAGER.qmss_int0_4_opin;
      CONNECT457        C66XX_N.CPU_SYSTEM_1.CGEM_SSI_1.INTSEL_in_pin_37, C66XX_N.SHARED_SYSTEM.QUEUE_MANAGER.qmss_int0_5_opin;
      CONNECT458        C66XX_N.CPU_SYSTEM_1.CGEM_SSI_1.INTSEL_in_pin_38, C66XX_N.SHARED_SYSTEM.QUEUE_MANAGER.qmss_int0_6_opin;
      CONNECT459        C66XX_N.CPU_SYSTEM_1.CGEM_SSI_1.INTSEL_in_pin_39, C66XX_N.SHARED_SYSTEM.QUEUE_MANAGER.qmss_int0_7_opin;
      CONNECT460        C66XX_N.CPU_SYSTEM_1.CGEM_SSI_1.INTSEL_in_pin_40, C66XX_N.SHARED_SYSTEM.QUEUE_MANAGER.qmss_int0_8_opin;
      CONNECT461        C66XX_N.CPU_SYSTEM_1.CGEM_SSI_1.INTSEL_in_pin_41, C66XX_N.SHARED_SYSTEM.QUEUE_MANAGER.qmss_int0_9_opin;
      CONNECT462        C66XX_N.CPU_SYSTEM_1.CGEM_SSI_1.INTSEL_in_pin_42, C66XX_N.SHARED_SYSTEM.QUEUE_MANAGER.qmss_int0_10_opin;
      CONNECT463        C66XX_N.CPU_SYSTEM_1.CGEM_SSI_1.INTSEL_in_pin_43, C66XX_N.SHARED_SYSTEM.QUEUE_MANAGER.qmss_int0_11_opin;
      CONNECT464        C66XX_N.CPU_SYSTEM_1.CGEM_SSI_1.INTSEL_in_pin_44, C66XX_N.SHARED_SYSTEM.QUEUE_MANAGER.qmss_int0_12_opin;
      CONNECT465        C66XX_N.CPU_SYSTEM_1.CGEM_SSI_1.INTSEL_in_pin_45, C66XX_N.SHARED_SYSTEM.QUEUE_MANAGER.qmss_int0_13_opin;
      CONNECT466        C66XX_N.CPU_SYSTEM_1.CGEM_SSI_1.INTSEL_in_pin_46, C66XX_N.SHARED_SYSTEM.QUEUE_MANAGER.qmss_int0_14_opin;
      CONNECT467        C66XX_N.CPU_SYSTEM_1.CGEM_SSI_1.INTSEL_in_pin_47, C66XX_N.SHARED_SYSTEM.QUEUE_MANAGER.qmss_int0_15_opin;
      CONNECT468        C66XX_N.CPU_SYSTEM_1.CGEM_SSI_1.INTSEL_in_pin_48, C66XX_N.SHARED_SYSTEM.QUEUE_MANAGER.qmss_int1_1_opin;
      CONNECT469        C66XX_N.CPU_SYSTEM_1.CGEM_SSI_1.INTSEL_in_pin_49, C66XX_N.SHARED_SYSTEM.QUEUE_MANAGER.qmss_int1_5_opin;
      CONNECT470        C66XX_N.CPU_SYSTEM_1.CGEM_SSI_1.INTSEL_in_pin_50, C66XX_N.SHARED_SYSTEM.QUEUE_MANAGER.qmss_int1_9_opin;
      CONNECT471        C66XX_N.CPU_SYSTEM_1.CGEM_SSI_1.INTSEL_in_pin_51, C66XX_N.SHARED_SYSTEM.QUEUE_MANAGER.qmss_int1_13_opin;
      CONNECT472        C66XX_N.CPU_SYSTEM_1.CGEM_SSI_1.INTSEL_in_pin_52, C66XX_N.SHARED_SYSTEM.QUEUE_MANAGER.qmss_int1_17_opin;
      CONNECT473        C66XX_N.CPU_SYSTEM_1.CGEM_SSI_1.INTSEL_in_pin_53, C66XX_N.SHARED_SYSTEM.QUEUE_MANAGER.qmss_int1_21_opin;
      CONNECT474        C66XX_N.CPU_SYSTEM_1.CGEM_SSI_1.INTSEL_in_pin_54, C66XX_N.SHARED_SYSTEM.QUEUE_MANAGER.qmss_int1_25_opin;
      CONNECT475        C66XX_N.CPU_SYSTEM_1.CGEM_SSI_1.INTSEL_in_pin_55, C66XX_N.SHARED_SYSTEM.QUEUE_MANAGER.qmss_int1_29_opin;
      CONNECT476        C66XX_N.CPU_SYSTEM_1.CGEM_SSI_1.INTSEL_in_pin_102, C66XX_N.SHARED_SYSTEM.QUEUE_MANAGER.qmss_int1_3_opin;
      CONNECT477        C66XX_N.CPU_SYSTEM_1.CGEM_SSI_1.INTSEL_in_pin_103, C66XX_N.SHARED_SYSTEM.QUEUE_MANAGER.qmss_int1_7_opin;
      CONNECT478        C66XX_N.CPU_SYSTEM_1.CGEM_SSI_1.INTSEL_in_pin_104, C66XX_N.SHARED_SYSTEM.QUEUE_MANAGER.qmss_int1_11_opin;
      CONNECT479        C66XX_N.CPU_SYSTEM_1.CGEM_SSI_1.INTSEL_in_pin_105, C66XX_N.SHARED_SYSTEM.QUEUE_MANAGER.qmss_int1_15_opin;
      CONNECT480        C66XX_N.CPU_SYSTEM_1.CGEM_SSI_1.INTSEL_in_pin_106, C66XX_N.SHARED_SYSTEM.QUEUE_MANAGER.qmss_int1_19_opin;
      CONNECT481        C66XX_N.CPU_SYSTEM_1.CGEM_SSI_1.INTSEL_in_pin_107, C66XX_N.SHARED_SYSTEM.QUEUE_MANAGER.qmss_int1_23_opin;
      CONNECT482        C66XX_N.CPU_SYSTEM_1.CGEM_SSI_1.INTSEL_in_pin_108, C66XX_N.SHARED_SYSTEM.QUEUE_MANAGER.qmss_int1_27_opin;
      CONNECT483        C66XX_N.CPU_SYSTEM_1.CGEM_SSI_1.INTSEL_in_pin_109, C66XX_N.SHARED_SYSTEM.QUEUE_MANAGER.qmss_int1_31_opin;
      //TIMERS
      CONNECT484        C66XX_N.CPU_SYSTEM_1.CGEM_SSI_1.INTSEL_in_pin_64, C66XX_N.SHARED_SYSTEM.TIMER64_1_cpu_int_12;
      CONNECT485        C66XX_N.CPU_SYSTEM_1.CGEM_SSI_1.INTSEL_in_pin_65, C66XX_N.SHARED_SYSTEM.TIMER64_1_cpu_int_34;
      CONNECT486        C66XX_N.CPU_SYSTEM_1.CGEM_SSI_1.INTSEL_in_pin_66, C66XX_N.SHARED_SYSTEM.TIMER64_2_cpu_int_12;
      CONNECT487        C66XX_N.CPU_SYSTEM_1.CGEM_SSI_1.INTSEL_in_pin_67, C66XX_N.SHARED_SYSTEM.TIMER64_2_cpu_int_34;
      CONNECT488        C66XX_N.CPU_SYSTEM_1.CGEM_SSI_1.INTSEL_in_pin_68, C66XX_N.SHARED_SYSTEM.TIMER64_3_cpu_int_12;
      CONNECT489        C66XX_N.CPU_SYSTEM_1.CGEM_SSI_1.INTSEL_in_pin_69, C66XX_N.SHARED_SYSTEM.TIMER64_3_cpu_int_34;
      //GPIO
      CONNECT490        C66XX_N.CPU_SYSTEM_1.CGEM_SSI_1.INTSEL_in_pin_72, C66XX_N.SHARED_SYSTEM.GPIO.gpio_gpint2_opin;
      CONNECT491        C66XX_N.CPU_SYSTEM_1.CGEM_SSI_1.INTSEL_in_pin_73, C66XX_N.SHARED_SYSTEM.GPIO.gpio_gpint3_opin;
      CONNECT492        C66XX_N.CPU_SYSTEM_1.CGEM_SSI_1.INTSEL_in_pin_78, C66XX_N.SHARED_SYSTEM.GPIO.gpio_gpint4_opin;
      CONNECT493        C66XX_N.CPU_SYSTEM_1.CGEM_SSI_1.INTSEL_in_pin_79, C66XX_N.SHARED_SYSTEM.GPIO.gpio_gpint5_opin;
      CONNECT494        C66XX_N.CPU_SYSTEM_1.CGEM_SSI_1.INTSEL_in_pin_80, C66XX_N.SHARED_SYSTEM.GPIO.gpio_gpint6_opin;
      CONNECT495        C66XX_N.CPU_SYSTEM_1.CGEM_SSI_1.INTSEL_in_pin_81, C66XX_N.SHARED_SYSTEM.GPIO.gpio_gpint7_opin;
      CONNECT496        C66XX_N.CPU_SYSTEM_1.CGEM_SSI_1.INTSEL_in_pin_82, C66XX_N.SHARED_SYSTEM.GPIO.gpio_gpint8_opin;
      CONNECT497        C66XX_N.CPU_SYSTEM_1.CGEM_SSI_1.INTSEL_in_pin_83, C66XX_N.SHARED_SYSTEM.GPIO.gpio_gpint9_opin;
      CONNECT498        C66XX_N.CPU_SYSTEM_1.CGEM_SSI_1.INTSEL_in_pin_84, C66XX_N.SHARED_SYSTEM.GPIO.gpio_gpint10_opin;
      CONNECT499        C66XX_N.CPU_SYSTEM_1.CGEM_SSI_1.INTSEL_in_pin_85, C66XX_N.SHARED_SYSTEM.GPIO.gpio_gpint11_opin;
      CONNECT500        C66XX_N.CPU_SYSTEM_1.CGEM_SSI_1.INTSEL_in_pin_86, C66XX_N.SHARED_SYSTEM.GPIO.gpio_gpint12_opin;
      CONNECT501        C66XX_N.CPU_SYSTEM_1.CGEM_SSI_1.INTSEL_in_pin_87, C66XX_N.SHARED_SYSTEM.GPIO.gpio_gpint13_opin;
      CONNECT502        C66XX_N.CPU_SYSTEM_1.CGEM_SSI_1.INTSEL_in_pin_88, C66XX_N.SHARED_SYSTEM.GPIO.gpio_gpint14_opin;
      CONNECT503        C66XX_N.CPU_SYSTEM_1.CGEM_SSI_1.INTSEL_in_pin_89, C66XX_N.SHARED_SYSTEM.GPIO.gpio_gpint15_opin;
      CONNECT504        C66XX_N.CPU_SYSTEM_1.CGEM_SSI_1.INTSEL_in_pin_91, C66XX_N.SHARED_SYSTEM.GPIO.gpio_gpint1_opin;
      //IPC
      CONNECT505        C66XX_N.CPU_SYSTEM_1.CGEM_SSI_1.INTSEL_in_pin_90, C66XX_N.SHARED_SYSTEM.IPC_cpu_int_1;
      // Primary Interrupt Connections with EDMA
      //TCP3D
      CONNECT506        C66XX_N.SHARED_SYSTEM.EDMA_evt_in_pin0, C66XX_N.SHARED_SYSTEM.TCP3D_A.tcp3d_revt0_opin;
      CONNECT507        C66XX_N.SHARED_SYSTEM.EDMA_evt_in_pin1, C66XX_N.SHARED_SYSTEM.TCP3D_A.tcp3d_revt1_opin;
      //TIMER64
      CONNECT508        C66XX_N.SHARED_SYSTEM.EDMA_evt_in_pin2, C66XX_N.SHARED_SYSTEM.TIMER64_2_cpu_int_12;
      CONNECT509        C66XX_N.SHARED_SYSTEM.EDMA_evt_in_pin3, C66XX_N.SHARED_SYSTEM.TIMER64_2_cpu_int_34;
      CONNECT510        C66XX_N.SHARED_SYSTEM.EDMA_evt_in_pin22, C66XX_N.SHARED_SYSTEM.TIMER64_4_cpu_int_12;
      CONNECT511        C66XX_N.SHARED_SYSTEM.EDMA_evt_in_pin23, C66XX_N.SHARED_SYSTEM.TIMER64_4_cpu_int_34;
      CONNECT512        C66XX_N.SHARED_SYSTEM.EDMA_evt_in_pin24, C66XX_N.SHARED_SYSTEM.TIMER64_5_cpu_int_12;
      CONNECT513        C66XX_N.SHARED_SYSTEM.EDMA_evt_in_pin25, C66XX_N.SHARED_SYSTEM.TIMER64_5_cpu_int_34;
      CONNECT514        C66XX_N.SHARED_SYSTEM.EDMA_evt_in_pin26, C66XX_N.SHARED_SYSTEM.TIMER64_6_cpu_int_12;
      CONNECT515        C66XX_N.SHARED_SYSTEM.EDMA_evt_in_pin27, C66XX_N.SHARED_SYSTEM.TIMER64_6_cpu_int_34;
      CONNECT516        C66XX_N.SHARED_SYSTEM.EDMA_evt_in_pin28, C66XX_N.SHARED_SYSTEM.TIMER64_7_cpu_int_12;
      CONNECT517        C66XX_N.SHARED_SYSTEM.EDMA_evt_in_pin29, C66XX_N.SHARED_SYSTEM.TIMER64_7_cpu_int_34;
      CONNECT518        C66XX_N.SHARED_SYSTEM.EDMA_evt_in_pin34, C66XX_N.SHARED_SYSTEM.TIMER64_3_cpu_int_12;
      CONNECT519        C66XX_N.SHARED_SYSTEM.EDMA_evt_in_pin35, C66XX_N.SHARED_SYSTEM.TIMER64_3_cpu_int_34;
      //GPIO
      CONNECT520        C66XX_N.SHARED_SYSTEM.EDMA_evt_in_pin6, C66XX_N.SHARED_SYSTEM.GPIO.gpio_gpint0_opin;
      CONNECT521        C66XX_N.SHARED_SYSTEM.EDMA_evt_in_pin7, C66XX_N.SHARED_SYSTEM.GPIO.gpio_gpint1_opin;
      CONNECT522        C66XX_N.SHARED_SYSTEM.EDMA_evt_in_pin8, C66XX_N.SHARED_SYSTEM.GPIO.gpio_gpint2_opin;
      CONNECT523        C66XX_N.SHARED_SYSTEM.EDMA_evt_in_pin9, C66XX_N.SHARED_SYSTEM.GPIO.gpio_gpint3_opin;
      //VCP2
      CONNECT524        C66XX_N.SHARED_SYSTEM.EDMA_evt_in_pin10, C66XX_N.SHARED_SYSTEM.VCP2_0.VCP_DMA_REVT;
      CONNECT525        C66XX_N.SHARED_SYSTEM.EDMA_evt_in_pin11, C66XX_N.SHARED_SYSTEM.VCP2_0.VCP_DMA_XEVT;
      CONNECT526        C66XX_N.SHARED_SYSTEM.EDMA_evt_in_pin12, C66XX_N.SHARED_SYSTEM.VCP2_1.VCP_DMA_REVT;
      CONNECT527        C66XX_N.SHARED_SYSTEM.EDMA_evt_in_pin13, C66XX_N.SHARED_SYSTEM.VCP2_1.VCP_DMA_XEVT;
      //SEMAPHORE
      CONNECT528        C66XX_N.SHARED_SYSTEM.EDMA_evt_in_pin18, C66XX_N.SHARED_SYSTEM.SEMAPHORE.semaphore2_intr_opin0;
      CONNECT529        C66XX_N.SHARED_SYSTEM.EDMA_evt_in_pin19, C66XX_N.SHARED_SYSTEM.SEMAPHORE.semaphore2_intr_opin1;
      CONNECT530        C66XX_N.SHARED_SYSTEM.EDMA_evt_in_pin20, C66XX_N.SHARED_SYSTEM.SEMAPHORE.semaphore2_intr_opin2;
      CONNECT531        C66XX_N.SHARED_SYSTEM.EDMA_evt_in_pin21, C66XX_N.SHARED_SYSTEM.SEMAPHORE.semaphore2_intr_opin3;
      //! Connections of INTSEL with CPU
      CONNECT532        System.C66XX_N.CPU_SYSTEM_0.CPU0.EXCEP, System.C66XX_N.CPU_SYSTEM_0.CGEM_SSI_0.INTSELintsel_excep_out;
      CONNECT533        System.C66XX_N.CPU_SYSTEM_0.CPU0.NMI, System.C66XX_N.CPU_SYSTEM_0.CGEM_SSI_0.INTSELintsel_nmi_out;
      CONNECT534        System.C66XX_N.CPU_SYSTEM_0.CPU0.INT4, System.C66XX_N.CPU_SYSTEM_0.CGEM_SSI_0.INTSELintsel_int4_out;
      CONNECT535        System.C66XX_N.CPU_SYSTEM_0.CPU0.INT5, System.C66XX_N.CPU_SYSTEM_0.CGEM_SSI_0.INTSELintsel_int5_out;
      CONNECT536        System.C66XX_N.CPU_SYSTEM_0.CPU0.INT6, System.C66XX_N.CPU_SYSTEM_0.CGEM_SSI_0.INTSELintsel_int6_out;
      CONNECT537        System.C66XX_N.CPU_SYSTEM_0.CPU0.INT7, System.C66XX_N.CPU_SYSTEM_0.CGEM_SSI_0.INTSELintsel_int7_out;
      CONNECT538        System.C66XX_N.CPU_SYSTEM_0.CPU0.INT8, System.C66XX_N.CPU_SYSTEM_0.CGEM_SSI_0.INTSELintsel_int8_out;
      CONNECT539        System.C66XX_N.CPU_SYSTEM_0.CPU0.INT9, System.C66XX_N.CPU_SYSTEM_0.CGEM_SSI_0.INTSELintsel_int9_out;
      CONNECT540        System.C66XX_N.CPU_SYSTEM_0.CPU0.INT10, System.C66XX_N.CPU_SYSTEM_0.CGEM_SSI_0.INTSELintsel_int10_out;
      CONNECT541        System.C66XX_N.CPU_SYSTEM_0.CPU0.INT11, System.C66XX_N.CPU_SYSTEM_0.CGEM_SSI_0.INTSELintsel_int11_out;
      CONNECT542        System.C66XX_N.CPU_SYSTEM_0.CPU0.INT12, System.C66XX_N.CPU_SYSTEM_0.CGEM_SSI_0.INTSELintsel_int12_out;
      CONNECT543        System.C66XX_N.CPU_SYSTEM_0.CPU0.INT13, System.C66XX_N.CPU_SYSTEM_0.CGEM_SSI_0.INTSELintsel_int13_out;
      CONNECT544        System.C66XX_N.CPU_SYSTEM_0.CPU0.INT14, System.C66XX_N.CPU_SYSTEM_0.CGEM_SSI_0.INTSELintsel_int14_out;
      CONNECT545        System.C66XX_N.CPU_SYSTEM_0.CPU0.INT15, System.C66XX_N.CPU_SYSTEM_0.CGEM_SSI_0.INTSELintsel_int15_out;
      CONNECT546        System.C66XX_N.CPU_SYSTEM_0.CPU0cpu_idropped_out, System.C66XX_N.CPU_SYSTEM_0.CGEM_SSI_0.INTSELintsel_idrop_in;
      CONNECT547        System.C66XX_N.CPU_SYSTEM_1.CPU1.EXCEP, System.C66XX_N.CPU_SYSTEM_1.CGEM_SSI_1.INTSELintsel_excep_out;
      CONNECT548        System.C66XX_N.CPU_SYSTEM_1.CPU1.NMI, System.C66XX_N.CPU_SYSTEM_1.CGEM_SSI_1.INTSELintsel_nmi_out;
      CONNECT549        System.C66XX_N.CPU_SYSTEM_1.CPU1.INT4, System.C66XX_N.CPU_SYSTEM_1.CGEM_SSI_1.INTSELintsel_int4_out;
      CONNECT550        System.C66XX_N.CPU_SYSTEM_1.CPU1.INT5, System.C66XX_N.CPU_SYSTEM_1.CGEM_SSI_1.INTSELintsel_int5_out;
      CONNECT551        System.C66XX_N.CPU_SYSTEM_1.CPU1.INT6, System.C66XX_N.CPU_SYSTEM_1.CGEM_SSI_1.INTSELintsel_int6_out;
      CONNECT552        System.C66XX_N.CPU_SYSTEM_1.CPU1.INT7, System.C66XX_N.CPU_SYSTEM_1.CGEM_SSI_1.INTSELintsel_int7_out;
      CONNECT553        System.C66XX_N.CPU_SYSTEM_1.CPU1.INT8, System.C66XX_N.CPU_SYSTEM_1.CGEM_SSI_1.INTSELintsel_int8_out;
      CONNECT554        System.C66XX_N.CPU_SYSTEM_1.CPU1.INT9, System.C66XX_N.CPU_SYSTEM_1.CGEM_SSI_1.INTSELintsel_int9_out;
      CONNECT555        System.C66XX_N.CPU_SYSTEM_1.CPU1.INT10, System.C66XX_N.CPU_SYSTEM_1.CGEM_SSI_1.INTSELintsel_int10_out;
      CONNECT556        System.C66XX_N.CPU_SYSTEM_1.CPU1.INT11, System.C66XX_N.CPU_SYSTEM_1.CGEM_SSI_1.INTSELintsel_int11_out;
      CONNECT557        System.C66XX_N.CPU_SYSTEM_1.CPU1.INT12, System.C66XX_N.CPU_SYSTEM_1.CGEM_SSI_1.INTSELintsel_int12_out;
      CONNECT558        System.C66XX_N.CPU_SYSTEM_1.CPU1.INT13, System.C66XX_N.CPU_SYSTEM_1.CGEM_SSI_1.INTSELintsel_int13_out;
      CONNECT559        System.C66XX_N.CPU_SYSTEM_1.CPU1.INT14, System.C66XX_N.CPU_SYSTEM_1.CGEM_SSI_1.INTSELintsel_int14_out;
      CONNECT560        System.C66XX_N.CPU_SYSTEM_1.CPU1.INT15, System.C66XX_N.CPU_SYSTEM_1.CGEM_SSI_1.INTSELintsel_int15_out;
      CONNECT561        System.C66XX_N.CPU_SYSTEM_1.CPU1cpu_idropped_out, System.C66XX_N.CPU_SYSTEM_1.CGEM_SSI_1.INTSELintsel_idrop_in;
      //! CDMA_INFRA connections
      //! These pins setup loopback mode for the Streaming I/f
      CONNECT562        C66XX_N.SHARED_SYSTEM.CDMA_INFRA.cdma_tstrm_thread_mready_opin, C66XX_N.SHARED_SYSTEM.CDMA_INFRA.cdma_rstrm_thread_mready_ipin;
      CONNECT563        C66XX_N.SHARED_SYSTEM.CDMA_INFRA.cdma_tstrm_thread_sready_ipin, C66XX_N.SHARED_SYSTEM.CDMA_INFRA.cdma_rstrm_thread_sready_opin;
      CONNECT564        C66XX_N.SHARED_SYSTEM.CDMA_INFRA.cdma_tstrm_data_opin, C66XX_N.SHARED_SYSTEM.CDMA_INFRA.cdma_rstrm_data_ipin;
      CONNECT565        C66XX_N.SHARED_SYSTEM.CDMA_INFRA.cdma_tstrm_data_accept_ipin, C66XX_N.SHARED_SYSTEM.CDMA_INFRA.cdma_rstrm_data_accept_opin;
      CONNECT566        System.C66XX_N.SHARED_SYSTEM.CDMA_INFRA.cdma_rx_teardown_req_opin, System.C66XX_N.SHARED_SYSTEM.CDMA_INFRA.cdma_rx_teardown_ack_ipin;
      //! QUEUE_MANAGER with CDMA_INFRA
      CONNECT567        C66XX_N.SHARED_SYSTEM.QUEUE_MANAGER.qmss_qmgr_que_pend1_opin, C66XX_N.SHARED_SYSTEM.CDMA_INFRA.cdma_que_pend_ipin;
      //!             Exposing CPU boundary Pins to Pin-connect Plugin                               //                       //****************************************************************************************************************************//
      CONNECT568        C66XX_N.CPU_SYSTEM_0.CPU0.PINC, C66XX_N.CPU_SYSTEM_0.CPU0.NMI, CPU0_NMI;
      CONNECT569        C66XX_N.CPU_SYSTEM_1.CPU1.PINC, C66XX_N.CPU_SYSTEM_1.CPU1.NMI, CPU1_NMI;
      CONNECT570        C66XX_N.CPU_SYSTEM_0.CPU0.PINC, C66XX_N.CPU_SYSTEM_0.CPU0.INT4, CPU0_INT4;
      CONNECT571        C66XX_N.CPU_SYSTEM_0.CPU0.PINC, C66XX_N.CPU_SYSTEM_0.CPU0.INT5, CPU0_INT5;
      CONNECT572        C66XX_N.CPU_SYSTEM_0.CPU0.PINC, C66XX_N.CPU_SYSTEM_0.CPU0.INT6, CPU0_INT6;
      CONNECT573        C66XX_N.CPU_SYSTEM_0.CPU0.PINC, C66XX_N.CPU_SYSTEM_0.CPU0.INT7, CPU0_INT7;
      CONNECT574        C66XX_N.CPU_SYSTEM_0.CPU0.PINC, C66XX_N.CPU_SYSTEM_0.CPU0.INT8, CPU0_INT8;
      CONNECT575        C66XX_N.CPU_SYSTEM_0.CPU0.PINC, C66XX_N.CPU_SYSTEM_0.CPU0.INT9, CPU0_INT9;
      CONNECT576        C66XX_N.CPU_SYSTEM_0.CPU0.PINC, C66XX_N.CPU_SYSTEM_0.CPU0.INT10, CPU0_INT10;
      CONNECT577        C66XX_N.CPU_SYSTEM_0.CPU0.PINC, C66XX_N.CPU_SYSTEM_0.CPU0.INT11, CPU0_INT11;
      CONNECT578        C66XX_N.CPU_SYSTEM_0.CPU0.PINC, C66XX_N.CPU_SYSTEM_0.CPU0.INT12, CPU0_INT12;
      CONNECT579        C66XX_N.CPU_SYSTEM_0.CPU0.PINC, C66XX_N.CPU_SYSTEM_0.CPU0.INT13, CPU0_INT13;
      CONNECT580        C66XX_N.CPU_SYSTEM_0.CPU0.PINC, C66XX_N.CPU_SYSTEM_0.CPU0.INT14, CPU0_INT14;
      CONNECT581        C66XX_N.CPU_SYSTEM_0.CPU0.PINC, C66XX_N.CPU_SYSTEM_0.CPU0.INT15, CPU0_INT15;
      CONNECT582        C66XX_N.CPU_SYSTEM_1.CPU1.PINC, C66XX_N.CPU_SYSTEM_1.CPU1.INT4, CPU1_INT4;
      CONNECT583        C66XX_N.CPU_SYSTEM_1.CPU1.PINC, C66XX_N.CPU_SYSTEM_1.CPU1.INT5, CPU1_INT5;
      CONNECT584        C66XX_N.CPU_SYSTEM_1.CPU1.PINC, C66XX_N.CPU_SYSTEM_1.CPU1.INT6, CPU1_INT6;
      CONNECT585        C66XX_N.CPU_SYSTEM_1.CPU1.PINC, C66XX_N.CPU_SYSTEM_1.CPU1.INT7, CPU1_INT7;
      CONNECT586        C66XX_N.CPU_SYSTEM_1.CPU1.PINC, C66XX_N.CPU_SYSTEM_1.CPU1.INT8, CPU1_INT8;
      CONNECT587        C66XX_N.CPU_SYSTEM_1.CPU1.PINC, C66XX_N.CPU_SYSTEM_1.CPU1.INT9, CPU1_INT9;
      CONNECT588        C66XX_N.CPU_SYSTEM_1.CPU1.PINC, C66XX_N.CPU_SYSTEM_1.CPU1.INT10, CPU1_INT10;
      CONNECT589        C66XX_N.CPU_SYSTEM_1.CPU1.PINC, C66XX_N.CPU_SYSTEM_1.CPU1.INT11, CPU1_INT11;
      CONNECT590        C66XX_N.CPU_SYSTEM_1.CPU1.PINC, C66XX_N.CPU_SYSTEM_1.CPU1.INT12, CPU1_INT12;
      CONNECT591        C66XX_N.CPU_SYSTEM_1.CPU1.PINC, C66XX_N.CPU_SYSTEM_1.CPU1.INT13, CPU1_INT13;
      CONNECT592        C66XX_N.CPU_SYSTEM_1.CPU1.PINC, C66XX_N.CPU_SYSTEM_1.CPU1.INT14, CPU1_INT14;
      CONNECT593        C66XX_N.CPU_SYSTEM_1.CPU1.PINC, C66XX_N.CPU_SYSTEM_1.CPU1.INT15, CPU1_INT15;
      //! NMI connections from IPC
      CONNECT594        C66XX_N.CPU_SYSTEM_0.CPU0.NMI, C66XX_N.SHARED_SYSTEM.IPC_cpu_nmi_0;
      CONNECT595        C66XX_N.CPU_SYSTEM_1.CPU1.NMI, C66XX_N.SHARED_SYSTEM.IPC_cpu_nmi_1;
      //! Connections for INTD_TCP3D_A
      CONNECT596        C66XX_N.SHARED_SYSTEM.INTD_TCP3D_A.ip_intr_level0, C66XX_N.SHARED_SYSTEM.TCP3D_A.tcp3d_error_intr_p0_opin;
      CONNECT597        C66XX_N.SHARED_SYSTEM.INTD_TCP3D_A.ip_intr_level1, C66XX_N.SHARED_SYSTEM.TCP3D_A.tcp3d_error_intr_p1_opin;
      CONNECT598        C66XX_N.SHARED_SYSTEM.INTD_TCP3D_A.ip_eoi, C66XX_N.SHARED_SYSTEM.TCP3D_A.tcp3d_eoi_vector_opin;
      CONNECT599        C66XX_N.SHARED_SYSTEM.INTD_TCP3D_A.reset_in, C66XX_N.SHARED_SYSTEM_INTF.reset_out;
      // CP_INTC Debug view fix
      CONNECT600        C66XX_N.SHARED_SYSTEM.CP_INTC0.cp_intc_endian_in, C66XX_N.CPU_SYSTEM_0.CPU0_endianness;
      CONNECT601        C66XX_N.SHARED_SYSTEM.CP_INTC1.cp_intc_endian_in, C66XX_N.CPU_SYSTEM_0.CPU0_endianness;
      CONNECT602        C66XX_N.SHARED_SYSTEM.CP_INTC2.cp_intc_endian_in, C66XX_N.CPU_SYSTEM_0.CPU0_endianness;
      CONNECT603        C66XX_N.SHARED_SYSTEM.CP_INTC0.cp_intc_read_in, C66XX_N.SHARED_SYSTEM.INTERCONNECT.INTC0_CFG.memtr_read_opin;
      CONNECT604        C66XX_N.SHARED_SYSTEM.CP_INTC0.cp_intc_write_in, C66XX_N.SHARED_SYSTEM.INTERCONNECT.INTC0_CFG.memtr_write_opin;
      CONNECT605        C66XX_N.SHARED_SYSTEM.CP_INTC0.cp_intc_dbg_read_in, C66XX_N.SHARED_SYSTEM.INTERCONNECT.INTC0_CFG.memtr_dbg_read_opin;
      CONNECT606        C66XX_N.SHARED_SYSTEM.CP_INTC0.cp_intc_dbg_write_in, C66XX_N.SHARED_SYSTEM.INTERCONNECT.INTC0_CFG.memtr_dbg_write_opin;
      CONNECT607        C66XX_N.SHARED_SYSTEM.CP_INTC1.cp_intc_read_in, C66XX_N.SHARED_SYSTEM.INTERCONNECT.INTC1_CFG.memtr_read_opin;
      CONNECT608        C66XX_N.SHARED_SYSTEM.CP_INTC1.cp_intc_write_in, C66XX_N.SHARED_SYSTEM.INTERCONNECT.INTC1_CFG.memtr_write_opin;
      CONNECT609        C66XX_N.SHARED_SYSTEM.CP_INTC1.cp_intc_dbg_read_in, C66XX_N.SHARED_SYSTEM.INTERCONNECT.INTC1_CFG.memtr_dbg_read_opin;
      CONNECT610        C66XX_N.SHARED_SYSTEM.CP_INTC1.cp_intc_dbg_write_in, C66XX_N.SHARED_SYSTEM.INTERCONNECT.INTC1_CFG.memtr_dbg_write_opin;
      CONNECT611        C66XX_N.SHARED_SYSTEM.CP_INTC2.cp_intc_read_in, C66XX_N.SHARED_SYSTEM.INTERCONNECT.INTC2_CFG.memtr_read_opin;
      CONNECT612        C66XX_N.SHARED_SYSTEM.CP_INTC2.cp_intc_write_in, C66XX_N.SHARED_SYSTEM.INTERCONNECT.INTC2_CFG.memtr_write_opin;
      CONNECT613        C66XX_N.SHARED_SYSTEM.CP_INTC2.cp_intc_dbg_read_in, C66XX_N.SHARED_SYSTEM.INTERCONNECT.INTC2_CFG.memtr_dbg_read_opin;
      CONNECT614        C66XX_N.SHARED_SYSTEM.CP_INTC2.cp_intc_dbg_write_in, C66XX_N.SHARED_SYSTEM.INTERCONNECT.INTC2_CFG.memtr_dbg_write_opin;
      CONNECT615        C66XX_N.SHARED_SYSTEM.IPC.ici_read_in, C66XX_N.SHARED_SYSTEM.INTERCONNECT.ICI_CFG.memtr_read_opin;
      CONNECT616        C66XX_N.SHARED_SYSTEM.IPC.ici_write_in, C66XX_N.SHARED_SYSTEM.INTERCONNECT.ICI_CFG.memtr_write_opin;
      CONNECT617        C66XX_N.SHARED_SYSTEM.IPC.ici_dbg_read_in, C66XX_N.SHARED_SYSTEM.INTERCONNECT.ICI_CFG.memtr_dbg_read_opin;
      CONNECT618        C66XX_N.SHARED_SYSTEM.IPC.ici_dbg_write_in, C66XX_N.SHARED_SYSTEM.INTERCONNECT.ICI_CFG.memtr_dbg_write_opin;
      //TIMER64
      CONNECT619        C66XX_N.SHARED_SYSTEM.CP_INTC2.cp_intc_system_intr_in49, C66XX_N.SHARED_SYSTEM.TIMER64_4_cpu_int_12;
      CONNECT620        C66XX_N.SHARED_SYSTEM.CP_INTC2.cp_intc_system_intr_in50, C66XX_N.SHARED_SYSTEM.TIMER64_4_cpu_int_34;
      CONNECT621        C66XX_N.SHARED_SYSTEM.CP_INTC2.cp_intc_system_intr_in51, C66XX_N.SHARED_SYSTEM.TIMER64_5_cpu_int_12;
      CONNECT622        C66XX_N.SHARED_SYSTEM.CP_INTC2.cp_intc_system_intr_in52, C66XX_N.SHARED_SYSTEM.TIMER64_5_cpu_int_34;
      CONNECT623        C66XX_N.SHARED_SYSTEM.CP_INTC2.cp_intc_system_intr_in53, C66XX_N.SHARED_SYSTEM.TIMER64_6_cpu_int_12;
      CONNECT624        C66XX_N.SHARED_SYSTEM.CP_INTC2.cp_intc_system_intr_in54, C66XX_N.SHARED_SYSTEM.TIMER64_6_cpu_int_34;
      CONNECT625        C66XX_N.SHARED_SYSTEM.CP_INTC2.cp_intc_system_intr_in55, C66XX_N.SHARED_SYSTEM.TIMER64_7_cpu_int_12;
      CONNECT626        C66XX_N.SHARED_SYSTEM.CP_INTC2.cp_intc_system_intr_in56, C66XX_N.SHARED_SYSTEM.TIMER64_7_cpu_int_34;
      // L1D and L1P connection for CGEM program path
      CONNECT627        C66XX_N.CPU_SYSTEM_0.CGEM_SSI_0.cgem_l1RAM_mif, C66XX_N.CPU_SYSTEM_0.CPU0.prog_mem_map, 0x00E00000, 0x00E07FFF, 0;
      CONNECT628        C66XX_N.CPU_SYSTEM_1.CGEM_SSI_1.cgem_l1RAM_mif, C66XX_N.CPU_SYSTEM_1.CPU1.prog_mem_map, 0x00E00000, 0x00E07FFF, 0;
      CONNECT629        C66XX_N.CPU_SYSTEM_0.CGEM_SSI_0.cgem_l1RAM_mif, C66XX_N.CPU_SYSTEM_0.CPU0.prog_mem_map, 0x00F00000, 0x00F07FFF, 0;
      CONNECT630        C66XX_N.CPU_SYSTEM_1.CGEM_SSI_1.cgem_l1RAM_mif, C66XX_N.CPU_SYSTEM_1.CPU1.prog_mem_map, 0x00F00000, 0x00F07FFF, 0;
      // L1D and L1P connection for CGEM Data path
      CONNECT631        C66XX_N.CPU_SYSTEM_0.CGEM_SSI_0.cgem_l1RAM_mif, C66XX_N.CPU_SYSTEM_0.CPU0_mem_map, 0x00E00000, 0x00E07FFF, 0;
      CONNECT632        C66XX_N.CPU_SYSTEM_1.CGEM_SSI_1.cgem_l1RAM_mif, C66XX_N.CPU_SYSTEM_1.CPU1_mem_map, 0x00E00000, 0x00E07FFF, 0;
      CONNECT633        C66XX_N.CPU_SYSTEM_0.CGEM_SSI_0.cgem_l1RAM_mif, C66XX_N.CPU_SYSTEM_0.CPU0_mem_map, 0x00F00000, 0x00F07FFF, 0;
      CONNECT634        C66XX_N.CPU_SYSTEM_1.CGEM_SSI_1.cgem_l1RAM_mif, C66XX_N.CPU_SYSTEM_1.CPU1_mem_map, 0x00F00000, 0x00F07FFF, 0;
      // Tag Ram connections
      CONNECT635        C66XX_N.CPU_SYSTEM_0.CGEM_SSI_0.dmc_tag_ram_read, C66XX_N.CPU_SYSTEM_0.CPU0dmc_tag_ram_read;
      CONNECT636        C66XX_N.CPU_SYSTEM_0.CGEM_SSI_0.pmc_tag_ram_read, C66XX_N.CPU_SYSTEM_0.CPU0pmc_tag_ram_read;
      CONNECT637        C66XX_N.CPU_SYSTEM_0.CGEM_SSI_0.umc_tag_ram_read, C66XX_N.CPU_SYSTEM_0.CPU0umc_tag_ram_read;
      CONNECT638        C66XX_N.CPU_SYSTEM_1.CGEM_SSI_1.dmc_tag_ram_read, C66XX_N.CPU_SYSTEM_1.CPU1dmc_tag_ram_read;
      CONNECT639        C66XX_N.CPU_SYSTEM_1.CGEM_SSI_1.pmc_tag_ram_read, C66XX_N.CPU_SYSTEM_1.CPU1pmc_tag_ram_read;
      CONNECT640        C66XX_N.CPU_SYSTEM_1.CGEM_SSI_1.umc_tag_ram_read, C66XX_N.CPU_SYSTEM_1.CPU1umc_tag_ram_read;
      // Memory Viewer Connections
      CONNECT641        C66XX_N.CPU_SYSTEM_0.CPU0l1d_cache_dbg_read_in, C66XX_N.CPU_SYSTEM_0.CGEM_SSI_0.L1D_cache_dbg_read;
      CONNECT642        C66XX_N.CPU_SYSTEM_0.CPU0l1d_cache_dbg_write_out, C66XX_N.CPU_SYSTEM_0.CGEM_SSI_0.L1D_cache_dbg_write;
      CONNECT643        C66XX_N.CPU_SYSTEM_0.CPU0l1d_sram_dbg_read_in, C66XX_N.CPU_SYSTEM_0.CGEM_SSI_0.L1D_sram_dbg_read;
      CONNECT644        C66XX_N.CPU_SYSTEM_0.CPU0l1d_sram_dbg_write_out, C66XX_N.CPU_SYSTEM_0.CGEM_SSI_0.L1D_sram_dbg_write;
      CONNECT645        C66XX_N.CPU_SYSTEM_0.CPU0l1p_cache_dbg_read_in, C66XX_N.CPU_SYSTEM_0.CGEM_SSI_0.L1P_cache_dbg_read;
      CONNECT646        C66XX_N.CPU_SYSTEM_0.CPU0l1p_cache_dbg_write_out, C66XX_N.CPU_SYSTEM_0.CGEM_SSI_0.L1P_cache_dbg_write;
      CONNECT647        C66XX_N.CPU_SYSTEM_0.CPU0l1p_sram_dbg_read_in, C66XX_N.CPU_SYSTEM_0.CGEM_SSI_0.L1P_sram_dbg_read;
      CONNECT648        C66XX_N.CPU_SYSTEM_0.CPU0l1p_sram_dbg_write_out, C66XX_N.CPU_SYSTEM_0.CGEM_SSI_0.L1P_sram_dbg_write;
      CONNECT649        C66XX_N.CPU_SYSTEM_0.CPU0l2_cache_dbg_read_in, C66XX_N.CPU_SYSTEM_0.CGEM_SSI_0.L2_cache_dbg_read;
      CONNECT650        C66XX_N.CPU_SYSTEM_0.CPU0l2_cache_dbg_write_out, C66XX_N.CPU_SYSTEM_0.CGEM_SSI_0.L2_cache_dbg_write;
      CONNECT651        C66XX_N.CPU_SYSTEM_0.CPU0l2_sram_dbg_read_in, C66XX_N.CPU_SYSTEM_0.CGEM_SSI_0.L2_sram_dbg_read;
      CONNECT652        C66XX_N.CPU_SYSTEM_0.CPU0l2_sram_dbg_write_out, C66XX_N.CPU_SYSTEM_0.CGEM_SSI_0.L2_sram_dbg_write;
      CONNECT653        C66XX_N.CPU_SYSTEM_0.CPU0ext_mem_dbg_read_in, C66XX_N.CPU_SYSTEM_0.CGEM_SSI_0.EXTMEM_ext_dbg_read;
      CONNECT654        C66XX_N.CPU_SYSTEM_0.CPU0ext_mem_dbg_write_out, C66XX_N.CPU_SYSTEM_0.CGEM_SSI_0.EXTMEM_ext_dbg_write;
      CONNECT655        C66XX_N.CPU_SYSTEM_1.CPU1l1d_cache_dbg_read_in, C66XX_N.CPU_SYSTEM_1.CGEM_SSI_1.L1D_cache_dbg_read;
      CONNECT656        C66XX_N.CPU_SYSTEM_1.CPU1l1d_cache_dbg_write_out, C66XX_N.CPU_SYSTEM_1.CGEM_SSI_1.L1D_cache_dbg_write;
      CONNECT657        C66XX_N.CPU_SYSTEM_1.CPU1l1d_sram_dbg_read_in, C66XX_N.CPU_SYSTEM_1.CGEM_SSI_1.L1D_sram_dbg_read;
      CONNECT658        C66XX_N.CPU_SYSTEM_1.CPU1l1d_sram_dbg_write_out, C66XX_N.CPU_SYSTEM_1.CGEM_SSI_1.L1D_sram_dbg_write;
      CONNECT659        C66XX_N.CPU_SYSTEM_1.CPU1l1p_cache_dbg_read_in, C66XX_N.CPU_SYSTEM_1.CGEM_SSI_1.L1P_cache_dbg_read;
      CONNECT660        C66XX_N.CPU_SYSTEM_1.CPU1l1p_cache_dbg_write_out, C66XX_N.CPU_SYSTEM_1.CGEM_SSI_1.L1P_cache_dbg_write;
      CONNECT661        C66XX_N.CPU_SYSTEM_1.CPU1l1p_sram_dbg_read_in, C66XX_N.CPU_SYSTEM_1.CGEM_SSI_1.L1P_sram_dbg_read;
      CONNECT662        C66XX_N.CPU_SYSTEM_1.CPU1l1p_sram_dbg_write_out, C66XX_N.CPU_SYSTEM_1.CGEM_SSI_1.L1P_sram_dbg_write;
      CONNECT663        C66XX_N.CPU_SYSTEM_1.CPU1l2_cache_dbg_read_in, C66XX_N.CPU_SYSTEM_1.CGEM_SSI_1.L2_cache_dbg_read;
      CONNECT664        C66XX_N.CPU_SYSTEM_1.CPU1l2_cache_dbg_write_out, C66XX_N.CPU_SYSTEM_1.CGEM_SSI_1.L2_cache_dbg_write;
      CONNECT665        C66XX_N.CPU_SYSTEM_1.CPU1l2_sram_dbg_read_in, C66XX_N.CPU_SYSTEM_1.CGEM_SSI_1.L2_sram_dbg_read;
      CONNECT666        C66XX_N.CPU_SYSTEM_1.CPU1l2_sram_dbg_write_out, C66XX_N.CPU_SYSTEM_1.CGEM_SSI_1.L2_sram_dbg_write;
      CONNECT667        C66XX_N.CPU_SYSTEM_1.CPU1ext_mem_dbg_read_in, C66XX_N.CPU_SYSTEM_1.CGEM_SSI_1.EXTMEM_ext_dbg_read;
      CONNECT668        C66XX_N.CPU_SYSTEM_1.CPU1ext_mem_dbg_write_out, C66XX_N.CPU_SYSTEM_1.CGEM_SSI_1.EXTMEM_ext_dbg_write;
      //For GAUSS
      //Functional Interconnect Related
      CONNECT669        C66XX_N.SHARED_SYSTEM.MSMC.msmc_mem_map, C66XX_N.SHARED_SYSTEM.MEMTR_MSMC_Adaptor.MT_MIF2SSI.memtr_mif_opin, 0x0, 0xFFFFFFFF, 0;
      CONNECT670        C66XX_N.SHARED_SYSTEM.INTERCONNECT.MSMC_PATH.memtr_read_ipin, C66XX_N.SHARED_SYSTEM.MEMTR_MSMC_Adaptor.MT_MIF2SSI.memtr_read_opin;
      CONNECT671        C66XX_N.SHARED_SYSTEM.INTERCONNECT.MSMC_PATH.memtr_write_ipin, C66XX_N.SHARED_SYSTEM.MEMTR_MSMC_Adaptor.MT_MIF2SSI.memtr_write_opin;
      CONNECT672        C66XX_N.SHARED_SYSTEM.INTERCONNECT.MSMC_PATH.memtr_dbg_read_ipin, C66XX_N.SHARED_SYSTEM.MEMTR_MSMC_Adaptor.MT_MIF2SSI.memtr_dbg_read_opin;
      CONNECT673        C66XX_N.SHARED_SYSTEM.INTERCONNECT.MSMC_PATH.memtr_dbg_write_ipin, C66XX_N.SHARED_SYSTEM.MEMTR_MSMC_Adaptor.MT_MIF2SSI.memtr_dbg_write_opin;
      CONNECT674        C66XX_N.SHARED_SYSTEM.MEMTR_MSMC_Adaptor.MT_MIF2SSI.memtr_reset_ipin, System.SimBridge.global_reset_list;
      CONNECT675        C66XX_N.SHARED_SYSTEM.MEMTR_MSMC_Adaptor.MT_MIF2SSI.is_little_endian_ipin, C66XX_N.CPU_SYSTEM_0.CPU0_endianness;
      CONNECT676        C66XX_N.SHARED_SYSTEM.INTERCONNECT.DDR_SLAVE2.memtr_read_opin, C66XX_N.SHARED_SYSTEM.MEMTR_FLATMEM_36BIT_Adaptor.MT_SSI2MMAP.memtr_read_ipin;
      CONNECT677        C66XX_N.SHARED_SYSTEM.INTERCONNECT.DDR_SLAVE2.memtr_write_opin, C66XX_N.SHARED_SYSTEM.MEMTR_FLATMEM_36BIT_Adaptor.MT_SSI2MMAP.memtr_write_ipin;
      CONNECT678        C66XX_N.SHARED_SYSTEM.INTERCONNECT.DDR_SLAVE2.memtr_dbg_read_opin, C66XX_N.SHARED_SYSTEM.MEMTR_FLATMEM_36BIT_Adaptor.MT_SSI2MMAP.memtr_dbg_read_ipin;
      CONNECT679        C66XX_N.SHARED_SYSTEM.INTERCONNECT.DDR_SLAVE2.memtr_dbg_write_opin, C66XX_N.SHARED_SYSTEM.MEMTR_FLATMEM_36BIT_Adaptor.MT_SSI2MMAP.memtr_dbg_write_ipin;
      CONNECT680        C66XX_N.SHARED_SYSTEM.MEMTR_FLATMEM_36BIT_Adaptor.MT_SSI2MMAP.memtr_mmap_ipin, C66XX_N.SHARED_SYSTEM.FLATMEM_36BIT.mem36_mif, 0, 0xFFFFFFFF, 0;
      CONNECT681        C66XX_N.SHARED_SYSTEM.MEMTR_FLATMEM_36BIT_Adaptor.MT_SSI2MMAP.memtr_reset_ipin, System.SimBridge.global_reset_list;
      CONNECT682        C66XX_N.SHARED_SYSTEM.MEMTR_FLATMEM_36BIT_Adaptor.MT_SSI2MMAP.is_little_endian_ipin, C66XX_N.CPU_SYSTEM_0.CPU0_endianness;
      CONNECT683        C66XX_N.SHARED_SYSTEM.INTERCONNECT.CGEM0_SLV.memtr_read_opin, C66XX_N.SHARED_SYSTEM.MEMTR_CGEM0_Slv_Adaptor.MT_SSI2MMAP.memtr_read_ipin;
      CONNECT684        C66XX_N.SHARED_SYSTEM.INTERCONNECT.CGEM0_SLV.memtr_write_opin, C66XX_N.SHARED_SYSTEM.MEMTR_CGEM0_Slv_Adaptor.MT_SSI2MMAP.memtr_write_ipin;
      CONNECT685        C66XX_N.SHARED_SYSTEM.INTERCONNECT.CGEM0_SLV.memtr_dbg_read_opin, C66XX_N.SHARED_SYSTEM.MEMTR_CGEM0_Slv_Adaptor.MT_SSI2MMAP.memtr_dbg_read_ipin;
      CONNECT686        C66XX_N.SHARED_SYSTEM.INTERCONNECT.CGEM0_SLV.memtr_dbg_write_opin, C66XX_N.SHARED_SYSTEM.MEMTR_CGEM0_Slv_Adaptor.MT_SSI2MMAP.memtr_dbg_write_ipin;
      CONNECT687        C66XX_N.SHARED_SYSTEM.MEMTR_CGEM0_Slv_Adaptor.MT_SSI2MMAP.memtr_mmap_ipin, C66XX_N.CPU_SYSTEM_0.CGEM_SSI_0.cgem_slave_mif, 0, 0xFFFFFFFF, 0;
      CONNECT688        C66XX_N.SHARED_SYSTEM.MEMTR_CGEM0_Slv_Adaptor.MT_SSI2MMAP.memtr_reset_ipin, System.SimBridge.global_reset_list;
      CONNECT689        C66XX_N.SHARED_SYSTEM.MEMTR_CGEM0_Slv_Adaptor.MT_SSI2MMAP.is_little_endian_ipin, C66XX_N.CPU_SYSTEM_0.CPU0_endianness;
      CONNECT690        C66XX_N.SHARED_SYSTEM.INTERCONNECT.CGEM1_SLV.memtr_read_opin, C66XX_N.SHARED_SYSTEM.MEMTR_CGEM1_Slv_Adaptor.MT_SSI2MMAP.memtr_read_ipin;
      CONNECT691        C66XX_N.SHARED_SYSTEM.INTERCONNECT.CGEM1_SLV.memtr_write_opin, C66XX_N.SHARED_SYSTEM.MEMTR_CGEM1_Slv_Adaptor.MT_SSI2MMAP.memtr_write_ipin;
      CONNECT692        C66XX_N.SHARED_SYSTEM.INTERCONNECT.CGEM1_SLV.memtr_dbg_read_opin, C66XX_N.SHARED_SYSTEM.MEMTR_CGEM1_Slv_Adaptor.MT_SSI2MMAP.memtr_dbg_read_ipin;
      CONNECT693        C66XX_N.SHARED_SYSTEM.INTERCONNECT.CGEM1_SLV.memtr_dbg_write_opin, C66XX_N.SHARED_SYSTEM.MEMTR_CGEM1_Slv_Adaptor.MT_SSI2MMAP.memtr_dbg_write_ipin;
      CONNECT694        C66XX_N.SHARED_SYSTEM.MEMTR_CGEM1_Slv_Adaptor.MT_SSI2MMAP.memtr_mmap_ipin, C66XX_N.CPU_SYSTEM_1.CGEM_SSI_1.cgem_slave_mif, 0, 0xFFFFFFFF, 0;
      CONNECT695        C66XX_N.SHARED_SYSTEM.MEMTR_CGEM1_Slv_Adaptor.MT_SSI2MMAP.memtr_reset_ipin, System.SimBridge.global_reset_list;
      CONNECT696        C66XX_N.SHARED_SYSTEM.MEMTR_CGEM1_Slv_Adaptor.MT_SSI2MMAP.is_little_endian_ipin, C66XX_N.CPU_SYSTEM_1.CPU1_endianness;
      //! QUEUE_MANAGER with CDMA_SRIO
      CONNECT697        C66XX_N.SHARED_SYSTEM.QUEUE_MANAGER.qmss_qmgr_que_pend2_opin, C66XX_N.SHARED_SYSTEM.CDMA_SRIO.cdma_que_pend_ipin;
      CONNECT698        System.C66XX_N.CPU_SYSTEM_0.CPU0.EXCEP, System.C66XX_N.CPU_SYSTEM_0.CGEM_SSI_0.security_exception_output_opin;
      CONNECT699        System.C66XX_N.CPU_SYSTEM_1.CPU1.EXCEP, System.C66XX_N.CPU_SYSTEM_1.CGEM_SSI_1.security_exception_output_opin;
      CONNECT700        System.C66XX_N.CPU_SYSTEM_0.CPU0.exc_out, System.C66XX_N.CPU_SYSTEM_0.CGEM_SSI_0.exception_in;
      CONNECT701        System.C66XX_N.CPU_SYSTEM_1.CPU1.exc_out, System.C66XX_N.CPU_SYSTEM_1.CGEM_SSI_1.exception_in;
      CONNECT702        System.C66XX_N.CPU_SYSTEM_0.CPU0.inum_out, System.C66XX_N.CPU_SYSTEM_0.CGEM_SSI_0.cgem_inum_ipin;
      CONNECT703        System.C66XX_N.CPU_SYSTEM_1.CPU1.inum_out, System.C66XX_N.CPU_SYSTEM_1.CGEM_SSI_1.cgem_inum_ipin;
      //QM DMA
      CONNECT704        C66XX_N.SHARED_SYSTEM.INTERCONNECT.QUEUE_MANAGER_DMA.memtr_read_opin, C66XX_N.SHARED_SYSTEM.QUEUE_MANAGER.qmss_dma_read_ipin;
      CONNECT705        C66XX_N.SHARED_SYSTEM.INTERCONNECT.QUEUE_MANAGER_DMA.memtr_write_opin, C66XX_N.SHARED_SYSTEM.QUEUE_MANAGER.qmss_dma_write_ipin;
      CONNECT706        C66XX_N.SHARED_SYSTEM.INTERCONNECT.QUEUE_MANAGER_DMA.memtr_dbg_read_opin, C66XX_N.SHARED_SYSTEM.QUEUE_MANAGER.qmss_dma_dbg_read_ipin;
      CONNECT707        C66XX_N.SHARED_SYSTEM.INTERCONNECT.QUEUE_MANAGER_DMA.memtr_dbg_write_opin, C66XX_N.SHARED_SYSTEM.QUEUE_MANAGER.qmss_dma_dbg_write_ipin;
      CONNECT708        System.C66XX_N.SHARED_SYSTEM_INTF.reset_out, C66XX_N.SHARED_SYSTEM.UART_0.uart_reset_in;
      CONNECT709        System.C66XX_N.SHARED_SYSTEM_INTF.reset_out, C66XX_N.SHARED_SYSTEM.UART_1.uart_reset_in;
      CONNECT710        System.C66XX_N.SHARED_SYSTEM.DSP_BOOT_ROM.MT_SSI2FLATMEM.memtr_reset_ipin, System.SimBridge.global_reset_list;
      CONNECT711        System.C66XX_N.SHARED_SYSTEM.DSP_BOOT_ROM.MT_SSI2FLATMEM.memtr_reset_ipin, System.SimBridge.global_reset_list;
      //    BUSCONNECT1     MEMTR_S_M, System.C66XX_N.SHARED_SYSTEM.UART_0. , System.C66XX_N.SHARED_SYSTEM.INTERCONNECT.UART_0.;
      //    BUSCONNECT2     MEMTR_S_M, System.C66XX_N.SHARED_SYSTEM.UART_1. , System.C66XX_N.SHARED_SYSTEM.INTERCONNECT.UART_1.;
    END System;
    // --- PDATS enablement -------------------//
    SECTION PDATS_TRACE_ON_CORE0;
      MODULE PDATS_TRACE;
        ACCESS_SIZE_TRACE ON;  // For Access width tracing
        TIMESTAMP_WITH_MEMSTALLS OFF;  // OFF -> The tracing would be w.r.t CPU cycles (no stalls)
        MULTI_CORE ON;
      END PDATS_TRACE;
      CONNECT1        System.C66XX_N.CPU_SYSTEM_0.CPU0_mem_map, System.C66XX_N.CPU_SYSTEM_0.CPU0.cpu_pdats_mif, 0x0, 0xFFFFFFFF, 0;
    END PDATS_TRACE_ON_CORE0;
    SECTION PDATS_TRACE_ON_CORE1;
      MODULE PDATS_TRACE;
        MULTI_CORE ON;
      END PDATS_TRACE;
      CONNECT1        System.C66XX_N.CPU_SYSTEM_1.CPU1_mem_map, System.C66XX_N.CPU_SYSTEM_1.CPU1.cpu_pdats_mif, 0x0, 0xFFFFFFFF, 0;
    END PDATS_TRACE_ON_CORE1;
    // -------------------- END PDATS enablement -------------------//
    // ----- END of simulator configuration file -------------
  • Hi Weihua,
    It appears like you have attached C6657 config file and not c6678_pv.cfg config file. Can you attach the correct file.
    Also can you provide couple of more information,.
    1. I believe you are using simulator on linux platform, right?
    2. In order to try and reproduce your scenario, can you describe what DSP cores are involved in the DMA xfer?
    regards,
    Shesha.
  • Hi Sheshadri,
    Sorry, I attached the wrong file earlier. The correct file is below after the questions. Thanks.
    1. Yes, I am using CCS on Linux.
    2. The one I am currently testing is from core1 to core0. In earlier tries, I also tried core0 to core1, didn't work either.
    tisim_c6678_pv.cfg
    /// C66xx_S Platform Functional Simulator Configuration File
    // Copyright (c) 2007-2008 Texas Instruments Incorporated
    // Version 1.0.0//--------------------------------------------------------------------------------
    MODULE GTI_INFO;
     GTI_DVR_NAME tisim_adv_sb.dvr;
     SERVER_AUTO_RUN ON;
    END GTI_INFO;
    //MODULE GTI;
    //   ECCSETUP  OFF;
    //   CACHE_MEM_VIEWER ON;
    //END GTI;
    //MODULE OTIS;
    //    DYNAMIC_LIB ../../../bin/components/spkfc6xxxd.so;
    //END OTIS;
    //MODULE C6X;
    //    CHIP CGEMp75_CORE;
    //    SIMBRIDGE_DLL ../../../bin/components/sim_server.so;
    //END C6X;
    MODULE SIMBRIDGE;
       ADVANCE_TYPE            CYCLE_ADVANCE_WITH_INSTR_HALT;
    // To enable simulator construction logs uncomment MODULE SIMBRIGE, END SIMBRIDGE and the line having "FILE_LOG ON"
    // The options here are
    // 1.  ON - will generate the default log files, declare_intf.log, connect_intf.log and sim_integration.log
    // 2.  <file name> - will generate all the log information into the specified file name.
    // 3.  OFF - logging disabled
    //   FILE_LOG ON;
       // Send global break status to GTIs of the processors
       // that are forced to halt on other processor break point
       SEND_GLOBAL_BREAK_STATUS ON;
    END SIMBRIDGE;
    MODULE System;
        DSP CPU0,CPU1,CPU2,CPU3,CPU4,CPU5,CPU6,CPU7;
        DEBUGVIEW CPU0,CPU1,CPU2,CPU3,CPU4,CPU5,CPU6,CPU7;
        SUB_MODULES C66XX_S;
          MODULE C66XX_S;
        SUB_MODULES CPU_SYSTEM_0, CPU_SYSTEM_1, CPU_SYSTEM_2, CPU_SYSTEM_3, CPU_SYSTEM_4, CPU_SYSTEM_5, CPU_SYSTEM_6, CPU_SYSTEM_7, SHARED_SYSTEM;
        MODULE CPU_SYSTEM_0;
            SUB_MODULES CPU0, CGEM_SSI_0;
                MODULE CPU0;
                    //! Simulation Specific Entries  !//
                    //! DLL
                    DLL ../../../bin/components/spkfc6xxxd.so;
                //! "C" interfaces to the DLL
                INIT_FUNC         SIM_init;
                INIT_DONE_FUNC    SIM_init_done;
                CONNECT_FUNC      SIM_megamodule_connect;
                SUPPORTS_MEM_STAT ON;
                QUIT_FUNC         SIM_quit;
                //! Debug "C" interfaces
                TS_CREATE_FUNC    SIM_ts_create;
                TS_DESTROY_FUNC   SIM_ts_destroy;
                //! System Integrator version compliance number
                SSI_VER SC_1.0.0;
                //! Module Type.
                TYPE CPU;
                CLOCK_FREQ 1000;    //1000 MHz/1 GHz
                RUN_GRAN 0.000125; // 50 Run granularity (unit is msec)
                USE_SEPARATE_PROG_MEM_MAP ON;
                MISSED_INTERRUPT_WARNING OFF;
                    //! CPU Architecture Entries  !//
                        //! ISA (JOULE).
                ISA CGEMp75_CORE;
                C66X_INSTR_PROFILING ON;
                //! ISTP reset value. //
                ISTP_RESET_VALUE 0x00800000;    //L2 SRAM Start address
                        //! The Resource conflict Detection feature is not supported in the Joule ISA
                RESOURCE_CONFLICT_DETECTION OFF;
                    //! Memgamodule ID.
                    MM_ID 0;
                        MODULE HPS2;
                   MAX_BLOCK_SIZE_HINT 65536; // 64KB, in bytes
                               BLOCK_HIT_THRESHOLD 2000;
                   SPLOOP OFF;
                   CODE_COVERAGE ON;
                        END HPS2;
                // To enable PDATS trace uncomment the next line
                // IMPORT PDATS_TRACE_ON_CORE0;
            // TO disable register trace collection, comment out all line from MODULE CALLBACK_INTF_REMOVE to END CALLBACK_INTF_REMOVE
            // or rename CALLBACK_INTF to CALLBACK_INTF_REMOVE<some other string> (CALLBACK_INTF_REMOVE__ for eg.,)
            MODULE CALLBACK_INTF;
                DLL_PATH ../../../bin/components/reg_mem_trace_intf_v2.so;
                CALLBACK ON;
                CYCLE_INFO ON;
                PC_INFO ON;
                PC_OPCODE_INFO OFF; // OFF by default
                PC_MAX_OPCODE_SIZE 4; // in bytes
                REG_INFO ON;
                REGS_SELECTED A4,B3,B4,A6,B6,B15;
                REG_SIZE 4; // in bytes
                REG_INDEX_SIZE 1; // in bytes
                MEM_READ_INFO ON;
                MEM_WRITE_INFO ON;
                // size of buffer to hold trace data before transfering  to disk file, in bytes
                BUFFER_SIZE 1048576; // 1MB
                START_COLLECTION 0; //
            END CALLBACK_INTF;
            IMPORT PATCH0;
                END CPU0;
            MODULE CGEM_SSI_0;
                TYPE            PERIPHERAL;
                SSI_VER         SC_1.0.0;
                DLL         ../../../bin/components/sim_cgem_ssi.so;
                CPU_VIEW        CPU0;
                INIT_FUNC       cgem_ssi_init;
                INIT_DONE_FUNC      cgem_ssi_init_done;
                CONNECT_FUNC        cgem_ssi_connect_done;
                QUIT_FUNC       cgem_ssi_quit;
                MM_ID           0;
                NUM_MM          8;
                BOOT_MEMORY_MAP     1;      //<CHECK> Is "1" by default
                L1D_START_ADDRESS   0x00F00000;
                L1D_SIZE        0x8000;
                L1P_START_ADDRESS   0x00E00000;
                L1P_SIZE        0x8000;
                L2_START_ADDRESS    0x00800000;
                L2_SIZE         0x80000;
                CGEM_REG_START      0x01800000; //Excluding the starting reserved region
                CGEM_REG_END        0x01BFFFFF;
                XMC_CONFIG_START    0x08000000;
                XMC_CONFIG_END      0x0801FFFF;
                MASTER_ID       0;
                PRIV_ID         0;
                SECURE_MODE     0;
                CACHE_BYPASS    0;
            MODULE DMC;
                  CACHE_SIZE         0x8000;
                  MEMORY_SIZE        0x8000;
                  SRAM_START_ADDRESS 0x00F00000;
            END DMC;
                MODULE PMC;
                  CACHE_SIZE         0x8000;
                      MEMORY_SIZE        0x8000;
              SRAM_START_ADDRESS 0x00E00000;
            END PMC;
            MODULE UMC;
                     //CACHE_SIZE         0x100000;
                  CACHE_SIZE         0x00000;
                  MAX_CACHE_SIZE     512KB;
              MEMORY_SIZE        0x80000;
              SRAM_START_ADDRESS 0x00800000;
                END UMC;
            END CGEM_SSI_0;
        END CPU_SYSTEM_0;
        MODULE CPU_SYSTEM_1;
            SUB_MODULES CPU1, CGEM_SSI_1;
            MODULE CPU1;
                    //! DLL
                INIT_FUNC         SIM_init;
                QUIT_FUNC         SIM_quit;
                SSI_VER SC_1.0.0;
                //! Module Type.
                TYPE CPU;
                        //! ISA (JOULE).
                ISA CGEMp75_CORE;
                    //! Memgamodule ID.
                    MM_ID 1;
                        MODULE HPS2;
                   SPLOOP OFF;
                   CODE_COVERAGE ON;
                        END HPS2;
                // IMPORT PDATS_TRACE_ON_CORE1;
                CALLBACK ON;
                CYCLE_INFO ON;
                PC_INFO ON;
                REG_INFO ON;
                MEM_READ_INFO ON;
                MEM_WRITE_INFO ON;
            END CALLBACK_INTF;
            IMPORT PATCH1;
                END CPU1;
            MODULE CGEM_SSI_1;
                TYPE            PERIPHERAL;
                SSI_VER         SC_1.0.0;
                CPU_VIEW        CPU1;
                MM_ID           1;
                NUM_MM          8;
                L1D_SIZE        0x8000;
                L1P_SIZE        0x8000;
                L2_SIZE         0x80000;
                MASTER_ID       1;
                PRIV_ID         1;
                SECURE_MODE     0;
                CACHE_BYPASS    0;
            MODULE DMC;
                  CACHE_SIZE         0x8000;
                  MEMORY_SIZE        0x8000;
            END DMC;
                MODULE PMC;
                  CACHE_SIZE         0x8000;
                      MEMORY_SIZE        0x8000;
            END PMC;
            MODULE UMC;
                  CACHE_SIZE         0x00000;
                END UMC;
            END CGEM_SSI_1;
        END CPU_SYSTEM_1;
        MODULE CPU_SYSTEM_2;
            SUB_MODULES CPU2, CGEM_SSI_2;
                MODULE CPU2;
                    //! DLL
                INIT_FUNC         SIM_init;
                QUIT_FUNC         SIM_quit;
                SSI_VER SC_1.0.0;
                //! Module Type.
                TYPE CPU;
                        //! ISA (JOULE).
                ISA CGEMp75_CORE;
                    //! Memgamodule ID.
                    MM_ID 2;
                        MODULE HPS2;
                   SPLOOP OFF;
                   CODE_COVERAGE ON;
                        END HPS2;
                // IMPORT PDATS_TRACE_ON_CORE2;
                CALLBACK ON;
                CYCLE_INFO ON;
                PC_INFO ON;
                REG_INFO ON;
                MEM_READ_INFO ON;
                MEM_WRITE_INFO ON;
            END CALLBACK_INTF;
            IMPORT PATCH2;
                END CPU2;
            MODULE CGEM_SSI_2;
                TYPE            PERIPHERAL;
                SSI_VER         SC_1.0.0;
                CPU_VIEW        CPU2;
                MM_ID           2;
                NUM_MM          8;
                L1D_SIZE        0x8000;
                L1P_SIZE        0x8000;
                L2_SIZE         0x80000;
                MASTER_ID       2;
                PRIV_ID         2;
                SECURE_MODE     0;
                CACHE_BYPASS    0;
            MODULE DMC;
                  CACHE_SIZE         0x8000;
                  MEMORY_SIZE        0x8000;
            END DMC;
                MODULE PMC;
                  CACHE_SIZE         0x8000;
                      MEMORY_SIZE        0x8000;
            END PMC;
            MODULE UMC;
                  CACHE_SIZE         0x00000;
                END UMC;
               END CGEM_SSI_2;
        END CPU_SYSTEM_2;
        MODULE CPU_SYSTEM_3;
            SUB_MODULES CPU3, CGEM_SSI_3;
                MODULE CPU3;
                    //! DLL
                INIT_FUNC         SIM_init;
                QUIT_FUNC         SIM_quit;
                SSI_VER SC_1.0.0;
                //! Module Type.
                TYPE CPU;
                        //! ISA (JOULE).
                ISA CGEMp75_CORE;
                    //! Memgamodule ID.
                    MM_ID 3;
                        MODULE HPS2;
                   SPLOOP OFF;
                   CODE_COVERAGE ON;
                        END HPS2;
                // IMPORT PDATS_TRACE_ON_CORE3;
                CALLBACK ON;
                CYCLE_INFO ON;
                PC_INFO ON;
                REG_INFO ON;
                MEM_READ_INFO ON;
                MEM_WRITE_INFO ON;
            END CALLBACK_INTF;
            IMPORT PATCH3;
                END CPU3;
            MODULE CGEM_SSI_3;
                TYPE            PERIPHERAL;
                SSI_VER         SC_1.0.0;
                CPU_VIEW        CPU3;
                MM_ID           3;
                NUM_MM          8;
                L1D_SIZE        0x8000;
                L1P_SIZE        0x8000;
                L2_SIZE         0x80000;
                MASTER_ID       3;
                PRIV_ID         3;
                SECURE_MODE     0;
                CACHE_BYPASS    0;
            MODULE DMC;
                  CACHE_SIZE         0x8000;
                  MEMORY_SIZE        0x8000;
            END DMC;
                MODULE PMC;
                  CACHE_SIZE         0x8000;
                      MEMORY_SIZE        0x8000;
            END PMC;
            MODULE UMC;
                  CACHE_SIZE         0x00000;
                END UMC;
            END CGEM_SSI_3;
        END CPU_SYSTEM_3;
        MODULE CPU_SYSTEM_4;
            SUB_MODULES CPU4, CGEM_SSI_4;
                MODULE CPU4;
                    //! DLL
                INIT_FUNC         SIM_init;
                QUIT_FUNC         SIM_quit;
                SSI_VER SC_1.0.0;
                //! Module Type.
                TYPE CPU;
                        //! ISA (JOULE).
                ISA CGEMp75_CORE;
                    //! Memgamodule ID.
                    MM_ID 4;
                        MODULE HPS2;
                   SPLOOP OFF;
                   CODE_COVERAGE ON;
                        END HPS2;
                // IMPORT PDATS_TRACE_ON_CORE4;
                CALLBACK ON;
                CYCLE_INFO ON;
                PC_INFO ON;
                REG_INFO ON;
                MEM_READ_INFO ON;
                MEM_WRITE_INFO ON;
            END CALLBACK_INTF;
            IMPORT PATCH4;
                END CPU4;
            MODULE CGEM_SSI_4;
                TYPE            PERIPHERAL;
                SSI_VER         SC_1.0.0;
                CPU_VIEW        CPU4;
                MM_ID           4;
                NUM_MM          8;
                L1D_SIZE        0x8000;
                L1P_SIZE        0x8000;
                L2_SIZE         0x80000;
                MASTER_ID       4;
                PRIV_ID         4;
                SECURE_MODE     0;
                CACHE_BYPASS    0;
            MODULE DMC;
                  CACHE_SIZE         0x8000;
                  MEMORY_SIZE        0x8000;
            END DMC;
                MODULE PMC;
                  CACHE_SIZE         0x8000;
                      MEMORY_SIZE        0x8000;
            END PMC;
            MODULE UMC;
                  CACHE_SIZE         0x00000;
                END UMC;
            END CGEM_SSI_4;
        END CPU_SYSTEM_4;
        MODULE CPU_SYSTEM_5;
            SUB_MODULES CPU5, CGEM_SSI_5;
            MODULE CPU5;
                    //! DLL
                INIT_FUNC         SIM_init;
                QUIT_FUNC         SIM_quit;
                SSI_VER SC_1.0.0;
                //! Module Type.
                TYPE CPU;
                        //! ISA (JOULE).
                ISA CGEMp75_CORE;
                    //! Memgamodule ID.
                    MM_ID 5;
                        MODULE HPS2;
                   SPLOOP OFF;
                   CODE_COVERAGE ON;
                        END HPS2;
                // IMPORT PDATS_TRACE_ON_CORE5;
                CALLBACK ON;
                CYCLE_INFO ON;
                PC_INFO ON;
                REG_INFO ON;
                MEM_READ_INFO ON;
                MEM_WRITE_INFO ON;
            END CALLBACK_INTF;
            IMPORT PATCH5;
                END CPU5;
            MODULE CGEM_SSI_5;
                TYPE            PERIPHERAL;
                SSI_VER         SC_1.0.0;
                CPU_VIEW        CPU5;
                MM_ID           5;
                NUM_MM          8;
                L1D_SIZE        0x8000;
                L1P_SIZE        0x8000;
                L2_SIZE         0x80000;
                MASTER_ID       5;
                PRIV_ID         5;
                SECURE_MODE     0;
                CACHE_BYPASS    0;
            MODULE DMC;
                  CACHE_SIZE         0x8000;
                  MEMORY_SIZE        0x8000;
            END DMC;
                MODULE PMC;
                  CACHE_SIZE         0x8000;
                      MEMORY_SIZE        0x8000;
            END PMC;
            MODULE UMC;
                  CACHE_SIZE         0x00000;
                END UMC;
            END CGEM_SSI_5;
        END CPU_SYSTEM_5;
        MODULE CPU_SYSTEM_6;
            SUB_MODULES CPU6, CGEM_SSI_6;
                MODULE CPU6;
                    //! DLL
                INIT_FUNC         SIM_init;
                QUIT_FUNC         SIM_quit;
                SSI_VER SC_1.0.0;
                //! Module Type.
                TYPE CPU;
                        //! ISA (JOULE).
                ISA CGEMp75_CORE;
                    //! Memgamodule ID.
                    MM_ID 6;
                        MODULE HPS2;
                   SPLOOP OFF;
                   CODE_COVERAGE ON;
                        END HPS2;
                // IMPORT PDATS_TRACE_ON_CORE6;
                CALLBACK ON;
                CYCLE_INFO ON;
                PC_INFO ON;
                REG_INFO ON;
                MEM_READ_INFO ON;
                MEM_WRITE_INFO ON;
            END CALLBACK_INTF;
            IMPORT PATCH6;
                END CPU6;
            MODULE CGEM_SSI_6;
                TYPE            PERIPHERAL;
                SSI_VER         SC_1.0.0;
                CPU_VIEW        CPU6;
                MM_ID           6;
                NUM_MM          8;
                L1D_SIZE        0x8000;
                L1P_SIZE        0x8000;
                L2_SIZE         0x80000;
                MASTER_ID       6;
                PRIV_ID         6;
                SECURE_MODE     0;
                CACHE_BYPASS    0;
            MODULE DMC;
                  CACHE_SIZE         0x8000;
                  MEMORY_SIZE        0x8000;
            END DMC;
                MODULE PMC;
                  CACHE_SIZE         0x8000;
                      MEMORY_SIZE        0x8000;
            END PMC;
            MODULE UMC;
                  CACHE_SIZE         0x00000;
                END UMC;
               END CGEM_SSI_6;
        END CPU_SYSTEM_6;
        MODULE CPU_SYSTEM_7;
            SUB_MODULES CPU7, CGEM_SSI_7;
                MODULE CPU7;
                    //! DLL
                INIT_FUNC         SIM_init;
                QUIT_FUNC         SIM_quit;
                SSI_VER SC_1.0.0;
                //! Module Type.
                TYPE CPU;
                        //! ISA (JOULE).
                ISA CGEMp75_CORE;
                    //! Memgamodule ID.
                    MM_ID 7;
                        MODULE HPS2;
                   SPLOOP OFF;
                   CODE_COVERAGE ON;
                        END HPS2;
                // IMPORT PDATS_TRACE_ON_CORE7;
                CALLBACK ON;
                CYCLE_INFO ON;
                PC_INFO ON;
                REG_INFO ON;
                MEM_READ_INFO ON;
                MEM_WRITE_INFO ON;
            END CALLBACK_INTF;
            IMPORT PATCH7;
                END CPU7;
            MODULE CGEM_SSI_7;
                TYPE            PERIPHERAL;
                SSI_VER         SC_1.0.0;
                CPU_VIEW        CPU7;
                MM_ID           7;
                NUM_MM          8;
                L1D_SIZE        0x8000;
                L1P_SIZE        0x8000;
                L2_SIZE         0x80000;
                MASTER_ID       7;
                PRIV_ID         7;
                SECURE_MODE     0;
                CACHE_BYPASS    0;
            MODULE DMC;
                  CACHE_SIZE         0x8000;
                  MEMORY_SIZE        0x8000;
            END DMC;
                MODULE PMC;
                  CACHE_SIZE         0x8000;
                      MEMORY_SIZE        0x8000;
            END PMC;
            MODULE UMC;
                  CACHE_SIZE         0x00000;
                END UMC;
            END CGEM_SSI_7;
        END CPU_SYSTEM_7;
        MODULE SHARED_SYSTEM;
                SUB_MODULES
            SHARED_SYSTEM_INTF,
            MSMC,
            BOOT_ROM,
            TIMER64_0,  //Watch Dog for Core0
                TIMER64_1,  //Watch Dog for Core1
                TIMER64_2,  //Watch Dog for Core2
                TIMER64_3,  //Watch Dog for Core3
                TIMER64_4,  //Watch Dog for Core4
                TIMER64_5,      //Watch Dog for Core5
            TIMER64_6,      //Watch Dog for Core6
                TIMER64_7,      //Watch Dog for Core7
            TIMER64_8,
                TIMER64_9,
                TIMER64_10,
                TIMER64_11,
                TIMER64_12,
                TIMER64_13,
            TIMER64_14,
                TIMER64_15,
            EDMA_0,
            EDMA_1,
            EDMA_2,
            CP_INTC0,
            MEMTR_CP_INTC0_Config,
            CP_INTC1,
            MEMTR_CP_INTC1_Config,
            CP_INTC2,
            MEMTR_CP_INTC2_Config,
            CP_INTC3,
            MEMTR_CP_INTC3_Config,
            SEMAPHORE,
            IPC,
            MEMTR_IPC_Config,
            GPIO,
            QUEUE_MANAGER,
            CDMA_INFRA,
            SRIO,       //SRIO sub-system
            MEMTR_SRIO_Config,
            MEMTR_SRIO_Slave,
            CDMA_SRIO,
            MEMTR_CDMA_SRIO_Config,
            MEMTR_CDMA_SRIO_Master,
            SWITCHSS,   //PA sub-system
            MEMTR_SWITCHSS_Config,
            MEMTR_SWITCHSS_SERDES_Config,
            EMAC_ADAPTOR,
                    PASS,
            MEMTR_PASS_Master,
            MIF_TO_FUNC_PASS,
            CDMA_PASS,
            MEMTR_CDMA_PASS_Config,
            MEMTR_CDMA_PASS_Master,
            PCIE,
        MEMTR_GPIO_Config,
            MEMTR_SMS,
            MEMTR_SES,
            MEMTR_SEMAPHORE_Config,
        MEMTR_QM_DMA_Config,
            MEMTR_QM_Config,
            MEMTR_QM_PDSP_Command,
            //MEMTR_QM_High_Accumulator,
            MEMTR_QM_PDSP_Master,
            MEMTR_CDMA_INFRA_Config,
            MEMTR_CDMA_INFRA_Master,
            MEMTR_PCIE_Slave,
            SSI2SOCK_PORT0,         //for SRIO
            FLATMEM_36BIT,
            PSC,
            MIF_TO_FUNC_PSC;
            MODULE SHARED_SYSTEM_INTF;
                TYPE SHARED;
                SSI_VER SC_1.0.0; // new ssi module
                CLOCK_FREQ 1000;
                DLL ../../../bin/components/sim_shared_system_intf.so;
                INIT_FUNC         shared_system_intf_init_func;
                INIT_DONE_FUNC    shared_system_intf_init_done_func;
                QUIT_FUNC         shared_system_intf_quit_func;
            END SHARED_SYSTEM_INTF;
            MODULE MSMC;
                NAME            msmc;
                TYPE            SHARED;
                SSI_VER         SC_1.0.0;
                DLL         ../../../bin/components/sim_msmc_ssi.so;
                INIT_FUNC       msmc_ssi_init_func;
                INIT_DONE_FUNC      msmc_ssi_init_done_func;
                QUIT_FUNC       msmc_ssi_quit_func;
                NO_OF_CORES     8;
                RAM_START_ADDRESS   0x0C000000;
                RAM_SIZE        0x400000;
                CFG_START_ADDRESS   0x0BC00000;
            END MSMC;
                MODULE BOOT_ROM;
                        TYPE SHARED;
                        TERMINAL ROM;
                        SSI_VER SC_1.0.0;
                        DLL ../../../bin/components/sim_mif_bridge.so;
                CLOCK_ENABLED       NO;
                        INIT_FUNC         flatmem_init_func;
                        INIT_DONE_FUNC    flatmem_init_done_func;
                        QUIT_FUNC         flatmem_quit_func;
                END BOOT_ROM;
            MODULE TIMER64_0;
                    //! Module Type.
                    TYPE SHARED;
                    SSI_VER SC_1.0.0;
                    //! DLL
                    DLL ../../../bin/components/sim_timer64.so;
                    INIT_FUNC         timer64_init_func;
                    INIT_DONE_FUNC    timer64_init_done_func;
                    QUIT_FUNC         timer64_quit_func;
                        CLOCK_DIVIDE 6;
                    // Timer64P Configuration.Enables the Hilander features.
                    VERSION TIMER64P;
                    // Watchdog Capability for TIMER64
                    WATCH_DOG ON;
                END TIMER64_0;
            MODULE TIMER64_1;
                    //! Module Type.
                    TYPE SHARED;
                    SSI_VER SC_1.0.0;
                    //! DLL
                    CLOCK_DIVIDE 6;
                    VERSION TIMER64P;
                    WATCH_DOG ON;
                END TIMER64_1;
            MODULE TIMER64_2;
                    //! Module Type.
                    TYPE SHARED;
                    SSI_VER SC_1.0.0;
                    //! DLL
                    CLOCK_DIVIDE 6;
                    VERSION TIMER64P;
                    WATCH_DOG ON;
                END TIMER64_2;
            MODULE TIMER64_3;
                    //! Module Type.
                    TYPE SHARED;
                    SSI_VER SC_1.0.0;
                    //! DLL
                    CLOCK_DIVIDE 6;
                    VERSION TIMER64P;
                    WATCH_DOG ON;
                END TIMER64_3;
            MODULE TIMER64_4;
                    //! Module Type.
                    TYPE SHARED;
                    SSI_VER SC_1.0.0;
                    //! DLL
                    CLOCK_DIVIDE 6;
                    VERSION TIMER64P;
                    WATCH_DOG ON;
                END TIMER64_4;
            MODULE TIMER64_5;
                    //! Module Type.
                    TYPE SHARED;
                    SSI_VER SC_1.0.0;
                    //! DLL
                    CLOCK_DIVIDE 6;
                    VERSION TIMER64P;
                    WATCH_DOG ON;
                END TIMER64_5;
            MODULE TIMER64_6;
                    //! Module Type.
                    TYPE SHARED;
                    SSI_VER SC_1.0.0;
                    //! DLL
                    CLOCK_DIVIDE 6;
                    VERSION TIMER64P;
                    WATCH_DOG ON;
                END TIMER64_6;
            MODULE TIMER64_7;
                    //! Module Type.
                    TYPE SHARED;
                    SSI_VER SC_1.0.0;
                    //! DLL
                    CLOCK_DIVIDE 6;
                    VERSION TIMER64P;
                    WATCH_DOG ON;
                END TIMER64_7;
            MODULE TIMER64_8;
                    //! Module Type.
                    TYPE SHARED;
                    SSI_VER SC_1.0.0;
                    //! DLL
                        CLOCK_DIVIDE 6;
                    VERSION TIMER64P;
                    WATCH_DOG OFF;
                END TIMER64_8;
            MODULE TIMER64_9;
                    //! Module Type.
                    TYPE SHARED;
                    SSI_VER SC_1.0.0;
                    //! DLL
                    CLOCK_DIVIDE 6;
                    VERSION TIMER64P;
                    WATCH_DOG OFF;
                END TIMER64_9;
            MODULE TIMER64_10;
                    //! Module Type.
                    TYPE SHARED;
                    SSI_VER SC_1.0.0;
                    //! DLL
                    CLOCK_DIVIDE 6;
                    VERSION TIMER64P;
                    WATCH_DOG OFF;
                END TIMER64_10;
            MODULE TIMER64_11;
                    //! Module Type.
                    TYPE SHARED;
                    SSI_VER SC_1.0.0;
                    //! DLL
                    CLOCK_DIVIDE 6;
                    VERSION TIMER64P;
                    WATCH_DOG OFF;
                END TIMER64_11;
            MODULE TIMER64_12;
                    //! Module Type.
                    TYPE SHARED;
                    SSI_VER SC_1.0.0;
                    //! DLL
                    CLOCK_DIVIDE 6;
                    VERSION TIMER64P;
                    WATCH_DOG OFF;
                END TIMER64_12;
            MODULE TIMER64_13;
                    //! Module Type.
                    TYPE SHARED;
                    SSI_VER SC_1.0.0;
                    //! DLL
                    CLOCK_DIVIDE 6;
                    VERSION TIMER64P;
                    WATCH_DOG OFF;
                END TIMER64_13;
            MODULE TIMER64_14;
                    //! Module Type.
                    TYPE SHARED;
                    SSI_VER SC_1.0.0;
                    //! DLL
                    CLOCK_DIVIDE 6;
                    VERSION TIMER64P;
                    WATCH_DOG OFF;
                END TIMER64_14;
            MODULE TIMER64_15;
                    //! Module Type.
                    TYPE SHARED;
                    SSI_VER SC_1.0.0;
                    //! DLL
                    CLOCK_DIVIDE 6;
                    VERSION TIMER64P;
                    WATCH_DOG OFF;
                END TIMER64_15;
                MODULE EDMA_0;
                     //! DLL
                     DLL ../../../bin/components/sim_edma.so;
                INIT_FUNC         dma_init_func;
                INIT_DONE_FUNC    dma_init_done_func;
                CONNECT_FUNC      dma_connect_func;
                QUIT_FUNC         dma_quit_func;
                SSI_VER SC_1.0.0;
                //! Module Type.
                TYPE SHARED;
                //! EDMA v3 Architecture Entries  !//
                CLOCK_DIVIDE_RATIO    2;
                NUM_DMA_CHANNELS     16;
                NUM_QDMA_CHANNELS     8;
                NUM_INT_CHANNELS     16;
                NUM_PARAM_ENTRIES   128;
                NUM_EVENT_QUEUES      2;
                NUM_TCS               2;
                MP_EXISTS        YES;
                CHANNEL_MAP_EXISTS   YES;
                NUM_REGIONS           8;
                END EDMA_0;
                MODULE EDMA_1;
                     //! DLL
                SSI_VER SC_1.0.0;
                //! Module Type.
                TYPE SHARED;
                CLOCK_DIVIDE_RATIO    3;
                NUM_DMA_CHANNELS     64;
                NUM_INT_CHANNELS     64;
                NUM_PARAM_ENTRIES   512;
                NUM_EVENT_QUEUES      4;
                NUM_TCS               4;
                MP_EXISTS        YES;
                NUM_REGIONS           8;
                END EDMA_1;
                MODULE EDMA_2;
                     //! DLL
                SSI_VER SC_1.0.0;
                //! Module Type.
                TYPE SHARED;
                NUM_EVENT_QUEUES      4;
                NUM_TCS               4;
                MP_EXISTS        YES;
                NUM_REGIONS           8;
                END EDMA_2;
                  MODULE CP_INTC0;
                        //! Module Name.
                        NAME              CP_INTC0;
                        //! Module Type.
                        TYPE              SHARED;
                        SSI_VER           SC_1.0.0;
                        //! DLL
                        DLL               ../../../bin/components/tisim_intc_cpintc_pv_ssi.so;
                        INIT_FUNC         cp_intc_init;
                        INIT_DONE_FUNC    cp_init_done;
                        QUIT_FUNC         cp_quit;
                        //! Module Configuration
                        NUMBER_OF_INTERRUPTS 160;       //<CHECK>
                        NUMBER_OF_CHANNELS 76;
                        NUMBER_OF_HOST_INTERRUPT 76;    //<CHECK>
                        NUMBER_OF_DEBUG_INTERRUPT 0;
                        VECTORING 0;
                        VECTORING_FULL 0;
                        NESTING_SUPPORT 1;
                        HOST_TYPE GENERIC;
                REVISION  0x4E820000;
                HOST_CHANNEL_MAP0   0;
                HOST_CHANNEL_MAP1   1;
                HOST_CHANNEL_MAP2   2;
                HOST_CHANNEL_MAP3   3;
                HOST_CHANNEL_MAP4   4;
                HOST_CHANNEL_MAP5   5;
                HOST_CHANNEL_MAP6   6;
                HOST_CHANNEL_MAP7   7;
                HOST_CHANNEL_MAP8   8;
                HOST_CHANNEL_MAP9   9;
                HOST_CHANNEL_MAP10  10;
                HOST_CHANNEL_MAP11  11;
                HOST_CHANNEL_MAP12  12;
                HOST_CHANNEL_MAP13  13;
                HOST_CHANNEL_MAP14  14;
                HOST_CHANNEL_MAP15  15;
                HOST_CHANNEL_MAP16  16;
                HOST_CHANNEL_MAP17  17;
                HOST_CHANNEL_MAP18  18;
                HOST_CHANNEL_MAP19  19;
                HOST_CHANNEL_MAP20  20;
                HOST_CHANNEL_MAP21  21;
                HOST_CHANNEL_MAP22  22;
                HOST_CHANNEL_MAP23  23;
                HOST_CHANNEL_MAP24  24;
                HOST_CHANNEL_MAP25  25;
                HOST_CHANNEL_MAP26  26;
                HOST_CHANNEL_MAP27  27;
                HOST_CHANNEL_MAP28  28;
                HOST_CHANNEL_MAP29  29;
                HOST_CHANNEL_MAP30  30;
                HOST_CHANNEL_MAP31  31;
                HOST_CHANNEL_MAP32  32;
                HOST_CHANNEL_MAP33  33;
                HOST_CHANNEL_MAP34  34;
                HOST_CHANNEL_MAP35  35;
                HOST_CHANNEL_MAP36  36;
                HOST_CHANNEL_MAP37  37;
                HOST_CHANNEL_MAP38  38;
                HOST_CHANNEL_MAP39  39;
                HOST_CHANNEL_MAP40  40;
                HOST_CHANNEL_MAP41  41;
                HOST_CHANNEL_MAP42  42;
                HOST_CHANNEL_MAP43  43;
                HOST_CHANNEL_MAP44  44;
                HOST_CHANNEL_MAP45  45;
                HOST_CHANNEL_MAP46  46;
                HOST_CHANNEL_MAP47  47;
                HOST_CHANNEL_MAP48  48;
                HOST_CHANNEL_MAP49  49;
                HOST_CHANNEL_MAP50  50;
                HOST_CHANNEL_MAP51  51;
                HOST_CHANNEL_MAP52  52;
                HOST_CHANNEL_MAP53  53;
                HOST_CHANNEL_MAP54  54;
                HOST_CHANNEL_MAP55  55;
                HOST_CHANNEL_MAP56  56;
                HOST_CHANNEL_MAP57  57;
                HOST_CHANNEL_MAP58  58;
                HOST_CHANNEL_MAP59  59;
                HOST_CHANNEL_MAP60  60;
                HOST_CHANNEL_MAP61  61;
                HOST_CHANNEL_MAP62  62;
                HOST_CHANNEL_MAP63  63;
                HOST_CHANNEL_MAP64  64;
                HOST_CHANNEL_MAP65  65;
                HOST_CHANNEL_MAP66  66;
                HOST_CHANNEL_MAP67  67;
                HOST_CHANNEL_MAP68  68;
                HOST_CHANNEL_MAP69  69;
                HOST_CHANNEL_MAP70  70;
                HOST_CHANNEL_MAP71  71;
                HOST_CHANNEL_MAP72  72;
                HOST_CHANNEL_MAP73  73;
                HOST_CHANNEL_MAP74  74;
                HOST_CHANNEL_MAP75  75;
                  END CP_INTC0;
                  MODULE CP_INTC1;
                        //! Module Name.
                        NAME              CP_INTC1;
                        //! Module Type.
                        TYPE              SHARED;
                        SSI_VER           SC_1.0.0;
                        //! DLL
                        QUIT_FUNC         cp_quit;
                        VECTORING 0;
                        VECTORING_FULL 0;
                        NESTING_SUPPORT 1;
                        HOST_TYPE GENERIC;
                  END CP_INTC1;
              MODULE CP_INTC2;
                        //! Module Name.
                        NAME              CP_INTC2;
                        //! Module Type.
                        TYPE              SHARED;
                        SSI_VER           SC_1.0.0;
                        //! DLL
                        QUIT_FUNC         cp_quit;
                        NUMBER_OF_CHANNELS 52;
                        NUMBER_OF_HOST_INTERRUPT 52;    //<CHECK>
                        VECTORING 0;
                        VECTORING_FULL 0;
                        NESTING_SUPPORT 1;
                        HOST_TYPE GENERIC;
                  END CP_INTC2;
              MODULE CP_INTC3;
                        //! Module Name.
                        NAME              CP_INTC3;
                        //! Module Type.
                        TYPE              SHARED;
                        SSI_VER           SC_1.0.0;
                        //! DLL
                        QUIT_FUNC         cp_quit;
                        NUMBER_OF_INTERRUPTS 80;        //<CHECK>
                        NUMBER_OF_CHANNELS 40;
                        NUMBER_OF_HOST_INTERRUPT 40;    //<CHECK>
                        VECTORING 0;
                        VECTORING_FULL 0;
                        NESTING_SUPPORT 1;
                        HOST_TYPE GENERIC;
                  END CP_INTC3;
            MODULE SEMAPHORE;
                TYPE SHARED;
                SSI_VER SSI_1.1;
                NAME        semaphore2;
                DLL             ../../../bin/components/semaphore2.so;
                INIT_FUNC       semaphore2_init;
                INIT_DONE_FUNC  semaphore2_init_done;
                QUIT_FUNC       semaphore2_quit;
                MODULE USER_INPUTS;
                    INPUT1  CPU_NAME,   SHARED;
                    INPUT2  PID,        0x48021200; //"12" as per RTL design
                    INPUT3  NUM_MASTERS,    8;
                    INPUT4  NUM_RESOURCES,  32;
                END USER_INPUTS;
            END SEMAPHORE;
            MODULE IPC;
                TYPE SHARED;
                SSI_VER SC_1.0.0;
                DLL           ../../../bin/components/sim_inter_core_interrupt.so;
                INIT_FUNC         inter_core_interrupt_init_func;
                INIT_DONE_FUNC    inter_core_interrupt_init_done_func;
                QUIT_FUNC         inter_core_interrupt_quit_func;
                CLOCK_DIVIDE_RATIO          6;
                NO_OF_CORES             8;
                WAITING_TIME_WINDOW         8;  //<CHECK>
                NMIGR_SUPPORT           ON; //Enabling NMIGR support
                NMI_PULSE_WINDOW            1;
                NMIGR_START_OFFSET      0;  //Indicates the offset from the start of the Inter-core memory region for inter-core NMIGR
                IPCGR_START_OFFSET      16;
                IPCAR_START_OFFSET      32;
                ENABLE_WARNING_MSGS         OFF;
            END IPC;
            MODULE GPIO;
                NAME            gpio;
                TYPE            SHARED;
                SSI_VER         SSI_1.1;
                DLL         ../../../bin/components/tisim_gpio_pv.so;
                INIT_FUNC       gpio_init;
                INIT_DONE_FUNC      gpio_init_done;
                QUIT_FUNC       gpio_quit;
                    MODULE INTERFACES;
                // MIF_TO_FUNC_GPIO => GPIO
        CONNECT1        System.C66XX_S.SHARED_SYSTEM.GPIO.gpio_cfg_write_ipin, System.C66XX_S.SHARED_SYSTEM.MEMTR_GPIO_Config.MT_MIF2SSI.memtr_write_opin;
        CONNECT2        System.C66XX_S.SHARED_SYSTEM.GPIO.gpio_cfg_read_ipin,System.C66XX_S.SHARED_SYSTEM.MEMTR_GPIO_Config.MT_MIF2SSI.memtr_read_opin;
        CONNECT3        System.C66XX_S.SHARED_SYSTEM.GPIO.gpio_dbg_read_ipin, System.C66XX_S.SHARED_SYSTEM.MEMTR_GPIO_Config.MT_MIF2SSI.memtr_dbg_read_opin;
        CONNECT4        System.C66XX_S.SHARED_SYSTEM.GPIO.gpio_dbg_write_ipin, System.C66XX_S.SHARED_SYSTEM.MEMTR_GPIO_Config.MT_MIF2SSI.memtr_dbg_write_opin;
        CONNECT5        System.C66XX_S.SHARED_SYSTEM.GPIO.gpio_reset_ipin, System.C66XX_S.SHARED_SYSTEM.SHARED_SYSTEM_INTF.reset_out;
        CONNECT6        System.C66XX_S.SHARED_SYSTEM.GPIO.gpio_endian_ipin, System.C66XX_S.CPU_SYSTEM_0.CPU0_endianness;
                    END INTERFACES;
                    MODULE USER_INPUTS;
                        INPUT2  NUM_GPINT_PINS, 16;
                    INOUT3  PID,        0x44831105;
                    END USER_INPUTS;
                END GPIO;
            MODULE QUEUE_MANAGER;
                NAME            queue_manager;
                TYPE            SHARED;
                SSI_VER         SSI_1.1;
                DLL         ../../../bin/components/qmss.so;
                //CPU_VIEW      <<CPU_MODULE_NAME>>;  //Update this entry with the CPU module name in the system
                INIT_FUNC       qmss_init;
                INIT_DONE_FUNC      qmss_init_done;
                QUIT_FUNC       qmss_quit;
                //User Inputs to be passed from CPU to the peripheral model
                MODULE  USER_INPUTS;
                    INPUT1  CPU_NAME              , SHARED;
            INPUT2  NUM_QM                , 1;
                    INPUT3  QUEUES_PER_QM         , 8192;
                    INPUT4  MEM_REGN_PER_QM       , 20;
                    INPUT5  NUM_PDSP              , 2;
                    INPUT6  NUM_INTD              , 1;
                    INPUT7  NUM_TIMER             , 2;
                    INPUT8  NUM_MCDMA             , 1;
                    INPUT9  LINKRAM_BASE          , 0x00080000;
                    INPUT10 LINKRAM_INDEXES       , 16384;
                    INPUT11 QM_CFG_BASE           , 0x00068000;
                    INPUT12 QM_CFG_OFFSET         , 0x00002000;
                    INPUT13 QM_DESC_BASE          , 0x0006a000;
                    INPUT14 QM_DESC_OFFSET        , 0x00002000;
                    INPUT15 QM_QUE_BASE           , 0x00020000;
                    INPUT16 QM_QUE_OFFSET         , 0x00020000;
                    INPUT17 QM_PEEK_BASE          , 0x00000000;
                    INPUT18 QM_PEEK_OFFSET        , 0x00020000;
                    INPUT19 QM_STATUS_BASE        , 0x00062000;
                    INPUT20 QM_STATUS_OFFSET      , 0x00000400;
                    INPUT21 QM_PROXY_BASE         , 0x00040000;
                    INPUT22 QM_PROXY_OFFSET       , 0x00020000;
                    INPUT23 PDSP_GBL_SCRTCH_BASE  , 0x00000000; //na on Ny/Sh/Tn/Aptn
                    INPUT24 PDSP_GBL_SCRTCH_SIZE  , 0x00000000; //na on Ny/Sh/Tn/Aptn
                    INPUT25 PDSP_LCL_SCRTCH_BASE  , 0x000b8000;
                    INPUT26 PDSP_LCL_SCRTCH_OFFSET, 0x00004000;
                    INPUT27 PDSP_REG_BASE         , 0x0006E000;
                    INPUT28 PDSP_REG_OFFSET       , 0x00001000;
                    INPUT29 PDSP_DBG_BASE         , 0x000b0000;
                    INPUT30 PDSP_DBG_OFFSET       , 0x00001000;
                    INPUT31 PDSP_IRAM_BASE        , 0x00060000;
                    INPUT32 PDSP_IRAM_OFFSET      , 0x00001000;
                    INPUT33 PDSP_SCRTCH_EVEN_SIZE , 0x00004000;
                    INPUT34 PDSP_SCRTCH_ODD_SIZE  , 0x00002000;
                    INPUT35 QM_INTD_BASE          , 0x000a0000;
                    INPUT36 QM_INTD_OFFSET        , 0x00001000;
                    INPUT37 QM_TIMER_BASE         , 0x000a8000;
                    INPUT38 QM_TIMER_OFFSET       , 0x00000800;
                    INPUT39 QM_MCDMA_BASE         , 0x00090000;
                    INPUT40 QM_MCDMA_OFFSET       , 0x00000800;
                    INPUT41 TOTAL_CFG_SPACE       , 0x000c0000;
                    INPUT42 INTC_1ST_QNUM         , 650;
                    INPUT43 INTC_NUM_QUEUES       , 22;
                    INPUT44 STARVATION_1ST_QNUM   , 736;
                    INPUT45 STARVATION_NUM_QUEUES , 64;
                    INPUT46 TIMER_TICK            , 7;
                    INPUT47 TIMER_RESOLUTION      , 1000;
            INPUT48 NUM_PKTDMA            , 8;    //Num pktDMA defs to follow
                    INPUT49 PKTDMA_1_TXQ          , 800;  //Infra1
                    INPUT50 PKTDMA_1_NUMQ         , 32;
                    INPUT51 PKTDMA_2_TXQ          , 512;  //AIF2
                    INPUT52 PKTDMA_2_NUMQ         , 128;
                    INPUT53 PKTDMA_3_TXQ          , 640;  //PASS
                    INPUT54 PKTDMA_3_NUMQ         , 9;
                    INPUT55 PKTDMA_4_TXQ          , 672;  //SRIO
                    INPUT56 PKTDMA_4_NUMQ         , 16;
                    INPUT57 PKTDMA_5_TXQ          , 688;  //FFTC_A
                    INPUT58 PKTDMA_5_NUMQ         , 4;
                    INPUT59 PKTDMA_6_TXQ          , 692;  //FFTC_B
                    INPUT60 PKTDMA_6_NUMQ         , 4;
                    INPUT61 PKTDMA_7_TXQ          , 864;  //FFTC_C
                    INPUT62 PKTDMA_7_NUMQ         , 4;
                    INPUT63 PKTDMA_8_TXQ          , 868;  //BCP
                    INPUT64 PKTDMA_8_NUMQ         , 8;
    //              INPUT65 DEBUG_LOG,        qmss_debug_log.txt;
                END USER_INPUTS;
            END QUEUE_MANAGER;
            MODULE CDMA_INFRA;
                NAME            cdma_qm;
                TYPE            SHARED;
                SSI_VER         SSI_1.1;
                DLL         ../../../bin/components/cdma.so;
                INIT_FUNC       cdma_init;
                INIT_DONE_FUNC      cdma_init_done;
                QUIT_FUNC       cdma_quit;
                MODULE  USER_INPUTS;                //changed as per Dave's mail
                    INPUT2  NUM_RX_CHANNELS  ,   32;
                    INPUT3  NUM_TX_CHANNELS  ,   32;
                    INPUT4  NUM_RX_FLOWS     ,  64;
                    INPUT5  RX_FIFO_SIZE     ,  32;
                    INPUT6  TX_FIFO_SIZE     ,  33; //(+1 for CDMA) as per Dave's mail
                    INPUT7  FIFO_DESC_SIZE   ,  8;
                    INPUT8  RX_FIFO_DEPTH    ,  32;
                    INPUT9  TX_FIFO_DEPTH    ,  48;
                    INPUT10 TX_CHUNK_READ    ,  128;
                    INPUT11 GLOBAL_CFG_OFFSET,  0x0006c000;
                    INPUT12 TX_CHAN_CFG_OFFSET, 0x0006c400;
                    INPUT13 RX_CHAN_CFG_OFFSET, 0x0006c800;
                    INPUT14 TX_SCHED_CFG_OFFSET,    0x0006cc00;
                    INPUT15 RX_FLOW_CFG_OFFSET, 0x0006d000;
                    INPUT16 QM_QUE_MMR_BASE  ,  0x34020000; //As per Dave's mail
            INPUT17 FIRST_HW_QNUM    ,        800;
                INPUT18 PACKET_OFFSET    ,        0;
                INPUT19 PACKET_TAG       ,      0;
                INPUT20 TX_SCHED_BYPASS  ,      0;
                INPUT21 TX_DESCRIPTOR_RELEASE , 0;
                INPUT22 LOOPBACK_MODE    ,        1;
                INPUT23 PAYLOAD_TRANSPARENCY  , 1;
            INPUT24 CYCLE_APPROX_MODE, 0;
            INPUT25 QM_POP_DELAY, 30;
            INPUT26 QM_PUSH_DELAY, 45;
            INPUT27 MEM_RW_DELAY, 1;
            INPUT28 CLK_DIV, 3;
            // INPUT29 DEBUG_LOG,        CDMA_qmss_debug_log.txt;
                END USER_INPUTS;
            END CDMA_INFRA;
            MODULE SSI2SOCK_PORT0;
                NAME            ssi2sock;
                TYPE            SHARED;
                SSI_VER         SSI_1.1;
                DLL         ../../../bin/components/ssi2sock.so;
                INIT_FUNC       ssi2sock_init;
                INIT_DONE_FUNC      ssi2sock_init_done;
                QUIT_FUNC       ssi2sock_quit;
                MODULE  INTERFACES;
                            //SSI connections to CPU and other peripheral;
        CONNECT1        System.C66XX_S.SHARED_SYSTEM.SSI2SOCK_PORT0.SSI2SOCK_reset, System.C66XX_S.SHARED_SYSTEM.SHARED_SYSTEM_INTF.reset_out;
        CONNECT2        System.C66XX_S.SHARED_SYSTEM.SSI2SOCK_PORT0.SSI2SOCK_receive_data, System.C66XX_S.SHARED_SYSTEM.SRIO.srio_tx_opin_port0;
        CONNECT3        System.C66XX_S.SHARED_SYSTEM.SSI2SOCK_PORT0.SSI2SOCK_send_data, System.C66XX_S.SHARED_SYSTEM.SRIO.srio_rx_ipin_port0;
                            // Propogate the error to every CPU model.
        CONNECT4        System.C66XX_S.SHARED_SYSTEM.SSI2SOCK_PORT0.SSI2SOCK_error_opin, System.C66XX_S.CPU_SYSTEM_0.CPU0.error_intf_ssi;
        CONNECT5        System.C66XX_S.SHARED_SYSTEM.SSI2SOCK_PORT0.SSI2SOCK_error_opin, System.C66XX_S.CPU_SYSTEM_1.CPU1.error_intf_ssi;
        CONNECT6        System.C66XX_S.SHARED_SYSTEM.SSI2SOCK_PORT0.SSI2SOCK_error_opin, System.C66XX_S.CPU_SYSTEM_2.CPU2.error_intf_ssi;
        CONNECT7        System.C66XX_S.SHARED_SYSTEM.SSI2SOCK_PORT0.SSI2SOCK_error_opin, System.C66XX_S.CPU_SYSTEM_3.CPU3.error_intf_ssi;
                END INTERFACES;
                MODULE  USER_INPUTS;
                    INPUT1  SOCK,          OFF;
                    INPUT2  SOCK_PORT,     2048;
                    INPUT3  MAX_NUM_BYTES_PER_SOCK_RECV, 16560; // Number of bytes attempted to receive
        // for every Socket receive call
        // Assuming each SRIO packet contains 4140
        // bytes (max), the simulator is configured to
        // handle upto 4 SRIO packets, in one socket
        // read call.
                    INPUT4  RECV_FIFO_LENGTH, 10; // Fifo length. Each fifo entry can
        // hold MAX_NUM_BYTES_PER_SOCK_RECV bytes
                    INPUT5  CPU_NAME, SHARED;
                    INPUT6  SOCK_PROTOCOL, TCP;
                    INPUT7  SOCK_TYPE,     SERVER;
                END USER_INPUTS;
            END SSI2SOCK_PORT0;
            MODULE SRIO;
                NAME            srio;
                TYPE            SHARED;
                SSI_VER         SSI_1.1;
                DLL             ../../../bin/components/tisim_srio.so;
                INIT_FUNC       srio_init;
                INIT_DONE_FUNC  srio_init_done;
                QUIT_FUNC       srio_quit;
                MODULE    INTERFACES;
        CONNECT1        System.C66XX_S.SHARED_SYSTEM.SRIO.srio_reset, System.C66XX_S.SHARED_SYSTEM.SHARED_SYSTEM_INTF.reset_out;
        CONNECT2        System.C66XX_S.SHARED_SYSTEM.SRIO.srio_big_endian_ipin, System.C66XX_S.CPU_SYSTEM_0.CPU0_endianness_big_endian;
                        //These pins setup the Streaming interfaces
        CONNECT3        System.C66XX_S.SHARED_SYSTEM.SRIO.srio_tstrm_thread_mready_opin, System.C66XX_S.SHARED_SYSTEM.CDMA_SRIO.cdma_rstrm_thread_mready_ipin;
        CONNECT4        System.C66XX_S.SHARED_SYSTEM.SRIO.srio_tstrm_thread_sready_ipin, System.C66XX_S.SHARED_SYSTEM.CDMA_SRIO.cdma_rstrm_thread_sready_opin;
        CONNECT5        System.C66XX_S.SHARED_SYSTEM.SRIO.srio_tstrm_data_opin, System.C66XX_S.SHARED_SYSTEM.CDMA_SRIO.cdma_rstrm_data_ipin;
        CONNECT6        System.C66XX_S.SHARED_SYSTEM.SRIO.srio_tstrm_data_accept_ipin, System.C66XX_S.SHARED_SYSTEM.CDMA_SRIO.cdma_rstrm_data_accept_opin;
        CONNECT7        System.C66XX_S.SHARED_SYSTEM.CDMA_SRIO.cdma_tstrm_thread_mready_opin, System.C66XX_S.SHARED_SYSTEM.SRIO.srio_rstrm_thread_mready_ipin;
        CONNECT8        System.C66XX_S.SHARED_SYSTEM.CDMA_SRIO.cdma_tstrm_thread_sready_ipin, System.C66XX_S.SHARED_SYSTEM.SRIO.srio_rstrm_thread_sready_opin;
        CONNECT9        System.C66XX_S.SHARED_SYSTEM.CDMA_SRIO.cdma_tstrm_data_opin, System.C66XX_S.SHARED_SYSTEM.SRIO.srio_rstrm_data_ipin;
        CONNECT10        System.C66XX_S.SHARED_SYSTEM.CDMA_SRIO.cdma_tstrm_data_accept_ipin, System.C66XX_S.SHARED_SYSTEM.SRIO.srio_rstrm_data_accept_opin;
                        // CFG and DBG read/write pins
        CONNECT11        System.C66XX_S.SHARED_SYSTEM.SRIO.srio_cfg_read_ipin, System.C66XX_S.SHARED_SYSTEM.MEMTR_SRIO_Config.MT_MIF2SSI.memtr_read_opin;
        CONNECT12        System.C66XX_S.SHARED_SYSTEM.SRIO.srio_cfg_write_ipin, System.C66XX_S.SHARED_SYSTEM.MEMTR_SRIO_Config.MT_MIF2SSI.memtr_write_opin;
        CONNECT13        System.C66XX_S.SHARED_SYSTEM.SRIO.srio_cfg_dbg_read_ipin, System.C66XX_S.SHARED_SYSTEM.MEMTR_SRIO_Config.MT_MIF2SSI.memtr_dbg_read_opin;
        CONNECT14        System.C66XX_S.SHARED_SYSTEM.SRIO.srio_cfg_dbg_write_ipin, System.C66XX_S.SHARED_SYSTEM.MEMTR_SRIO_Config.MT_MIF2SSI.memtr_dbg_write_opin;
                    // Data region interface
        CONNECT15        System.C66XX_S.SHARED_SYSTEM.MEMTR_SRIO_Slave.MT_MIF2SSI.memtr_read_opin, System.C66XX_S.SHARED_SYSTEM.SRIO.srio_dma_read_ipin;
        CONNECT16        System.C66XX_S.SHARED_SYSTEM.MEMTR_SRIO_Slave.MT_MIF2SSI.memtr_write_opin, System.C66XX_S.SHARED_SYSTEM.SRIO.srio_dma_write_ipin;
        CONNECT17        System.C66XX_S.SHARED_SYSTEM.MEMTR_SRIO_Slave.MT_MIF2SSI.memtr_dbg_read_opin, System.C66XX_S.SHARED_SYSTEM.SRIO.srio_dma_dbg_read_ipin;
        CONNECT18        System.C66XX_S.SHARED_SYSTEM.MEMTR_SRIO_Slave.MT_MIF2SSI.memtr_dbg_write_opin, System.C66XX_S.SHARED_SYSTEM.SRIO.srio_dma_dbg_write_ipin;
                        // Connect SRIO output ports and ready pins to inputs to loopback for testing
        //CONNECT19     System.C66XX_S.SHARED_SYSTEM.SRIO.srio_tx_opin_port0, System.C66XX_S.SHARED_SYSTEM.SRIO.srio_rx_ipin_port0;
        CONNECT19        System.C66XX_S.SHARED_SYSTEM.SRIO.srio_tx_opin_port1, System.C66XX_S.SHARED_SYSTEM.SRIO.srio_rx_ipin_port1;
        CONNECT20        System.C66XX_S.SHARED_SYSTEM.SRIO.srio_tx_opin_port2, System.C66XX_S.SHARED_SYSTEM.SRIO.srio_rx_ipin_port2;
        CONNECT21        System.C66XX_S.SHARED_SYSTEM.SRIO.srio_tx_opin_port3, System.C66XX_S.SHARED_SYSTEM.SRIO.srio_rx_ipin_port3;
        //CONNECT23     System.C66XX_S.SHARED_SYSTEM.SRIO.srio_rx_ready_opin_port0, System.C66XX_S.SHARED_SYSTEM.SRIO.srio_tx_ready_ack_ipin_port0;
        CONNECT22        System.C66XX_S.SHARED_SYSTEM.SRIO.srio_rx_ready_opin_port1, System.C66XX_S.SHARED_SYSTEM.SRIO.srio_tx_ready_ack_ipin_port1;
        CONNECT23        System.C66XX_S.SHARED_SYSTEM.SRIO.srio_rx_ready_opin_port2, System.C66XX_S.SHARED_SYSTEM.SRIO.srio_tx_ready_ack_ipin_port2;
        CONNECT24        System.C66XX_S.SHARED_SYSTEM.SRIO.srio_rx_ready_opin_port3, System.C66XX_S.SHARED_SYSTEM.SRIO.srio_tx_ready_ack_ipin_port3;
                END    INTERFACES;
                MODULE    USER_INPUTS;
                INPUT2 CLK_DIV,          3;
                // INPUT3 FILE_LOG,      srio_dbg;
                END    USER_INPUTS;
            END SRIO;
            MODULE CDMA_SRIO;
                NAME            cdma_srio;
                TYPE            SHARED;
                SSI_VER         SSI_1.1;
                MODULE    INTERFACES;
        CONNECT1        System.C66XX_S.SHARED_SYSTEM.CDMA_SRIO.cdma_reset_ipin, System.C66XX_S.SHARED_SYSTEM.SHARED_SYSTEM_INTF.reset_out;
        CONNECT2        System.C66XX_S.SHARED_SYSTEM.CDMA_SRIO.cdma_endian_ipin, System.C66XX_S.CPU_SYSTEM_0.CPU0_endianness_big_endian;
                        //These connections should be changed to connect the Tx Sched. to AIF or QMSS.
                        //CONNECT3      System.C66XX_S.SHARED_SYSTEM.CDMA_SRIO.cdma_tx_scheduler_ipin,     MainCPU.cdmatb_tx_scheduler_opin;
                        //CONNECT4      System.C66XX_S.SHARED_SYSTEM.CDMA_SRIO.cdma_tx_scheduler_opin,     MainCPU.cdmatb_tx_scheduler_ipin;
                        //These pins allow the CDMA to read/write memory.
        CONNECT3        System.C66XX_S.SHARED_SYSTEM.CDMA_SRIO.cdma_mstr_read_opin, System.C66XX_S.SHARED_SYSTEM.MEMTR_CDMA_SRIO_Master.MT_SSI2MMAP.memtr_read_ipin;
        CONNECT4        System.C66XX_S.SHARED_SYSTEM.CDMA_SRIO.cdma_mstr_write_opin, System.C66XX_S.SHARED_SYSTEM.MEMTR_CDMA_SRIO_Master.MT_SSI2MMAP.memtr_write_ipin;
        CONNECT5        System.C66XX_S.SHARED_SYSTEM.CDMA_SRIO.cdma_cfg_read_ipin, System.C66XX_S.SHARED_SYSTEM.MEMTR_CDMA_SRIO_Config.MT_MIF2SSI.memtr_read_opin;
        CONNECT6        System.C66XX_S.SHARED_SYSTEM.CDMA_SRIO.cdma_cfg_write_ipin, System.C66XX_S.SHARED_SYSTEM.MEMTR_CDMA_SRIO_Config.MT_MIF2SSI.memtr_write_opin;
        CONNECT7        System.C66XX_S.SHARED_SYSTEM.CDMA_SRIO.cdma_dbg_read_ipin, System.C66XX_S.SHARED_SYSTEM.MEMTR_CDMA_SRIO_Config.MT_MIF2SSI.memtr_dbg_read_opin;
        CONNECT8        System.C66XX_S.SHARED_SYSTEM.CDMA_SRIO.cdma_dbg_write_ipin, System.C66XX_S.SHARED_SYSTEM.MEMTR_CDMA_SRIO_Config.MT_MIF2SSI.memtr_dbg_write_opin;
        CONNECT9        System.C66XX_S.SHARED_SYSTEM.CDMA_SRIO.cdma_rx_teardown_req_opin, System.C66XX_S.SHARED_SYSTEM.CDMA_SRIO.cdma_rx_teardown_ack_ipin;
                END    INTERFACES;
                MODULE    USER_INPUTS;
                    INPUT2  NUM_RX_CHANNELS,    16;
                    INPUT3  NUM_TX_CHANNELS,    16;
                    INPUT4  NUM_RX_FLOWS,       20;
                    INPUT5  RX_FIFO_SIZE,       1024;
                    INPUT6  TX_FIFO_SIZE,       1025;  // +1 is for CDMA internal usage
                    INPUT7  FIFO_DESC_SIZE,     8;
                    INPUT8  RX_FIFO_DEPTH,      16;
                    INPUT9  TX_FIFO_DEPTH,      16;
                    INPUT10 TX_CHUNK_READ,      1024;
                    INPUT11 GLOBAL_CFG_OFFSET,  0x00001000;
                    INPUT12 TX_CHAN_CFG_OFFSET, 0x00001400;
                    INPUT13 RX_CHAN_CFG_OFFSET, 0x00001800;
                    INPUT14 TX_SCHED_CFG_OFFSET,0x00001c00;
                    INPUT15 RX_FLOW_CFG_OFFSET, 0x00002000;
                    INPUT16 QM_QUE_MMR_BASE,    0x34020000;
            INPUT17 FIRST_HW_QNUM,      672;
                INPUT18 PACKET_OFFSET,      1;
                INPUT19 PACKET_TAG,         0;
                INPUT20 TX_SCHED_BYPASS,    0;
                INPUT21 TX_DESCRIPTOR_RELEASE, 1;
                INPUT22 LOOPBACK_MODE,         0;
            INPUT23 PAYLOAD_TRANSPARENCY,  0;
            INPUT28 CLK_DIV, 3;
            //INPUT29  DEBUG_LOG ,    C:\CDMA_srio_Debug.log;
                END    USER_INPUTS;
            END CDMA_SRIO;
            MODULE SWITCHSS;
                NAME            switchss;
                TYPE            SHARED;
                SSI_VER         SSI_1.1;
                DLL         ../../../bin/components/switchss.so;
                //  CPU_VIEW        MainCPU;  //Update this entry with the CPU module name in the system
                INIT_FUNC       switchss_init;
                INIT_DONE_FUNC  switchss_init_done;
                QUIT_FUNC       switchss_quit;
                MODULE  INTERFACES;
        CONNECT1        System.C66XX_S.SHARED_SYSTEM.SWITCHSS.switchss_big_endian_ipin, System.C66XX_S.CPU_SYSTEM_0.CPU0_endianness_big_endian;
        CONNECT2        System.C66XX_S.SHARED_SYSTEM.SWITCHSS.switchss_vbusp_reset_ipin, System.C66XX_S.SHARED_SYSTEM.SHARED_SYSTEM_INTF.reset_out;
        CONNECT3        System.C66XX_S.SHARED_SYSTEM.SWITCHSS.switchss_memtr_regs_read_ipin, System.C66XX_S.SHARED_SYSTEM.MEMTR_SWITCHSS_Config.MT_MIF2SSI.memtr_read_opin;
        CONNECT4        System.C66XX_S.SHARED_SYSTEM.SWITCHSS.switchss_memtr_regs_write_ipin, System.C66XX_S.SHARED_SYSTEM.MEMTR_SWITCHSS_Config.MT_MIF2SSI.memtr_write_opin;
        CONNECT5        System.C66XX_S.SHARED_SYSTEM.SWITCHSS.switchss_memtr_regs_dbg_read_ipin, System.C66XX_S.SHARED_SYSTEM.MEMTR_SWITCHSS_Config.MT_MIF2SSI.memtr_dbg_read_opin;
        CONNECT6        System.C66XX_S.SHARED_SYSTEM.SWITCHSS.switchss_memtr_regs_dbg_write_ipin, System.C66XX_S.SHARED_SYSTEM.MEMTR_SWITCHSS_Config.MT_MIF2SSI.memtr_dbg_write_opin;
        CONNECT7        System.C66XX_S.SHARED_SYSTEM.SWITCHSS.switchss_memtr_serdes_regs_read_ipin, System.C66XX_S.SHARED_SYSTEM.MEMTR_SWITCHSS_SERDES_Config.MT_MIF2SSI.memtr_read_opin;
        CONNECT8        System.C66XX_S.SHARED_SYSTEM.SWITCHSS.switchss_memtr_serdes_regs_write_ipin, System.C66XX_S.SHARED_SYSTEM.MEMTR_SWITCHSS_SERDES_Config.MT_MIF2SSI.memtr_write_opin;
        CONNECT9        System.C66XX_S.SHARED_SYSTEM.SWITCHSS.switchss_memtr_serdes_regs_dbg_read_ipin, System.C66XX_S.SHARED_SYSTEM.MEMTR_SWITCHSS_SERDES_Config.MT_MIF2SSI.memtr_dbg_read_opin;
        CONNECT10        System.C66XX_S.SHARED_SYSTEM.SWITCHSS.switchss_memtr_serdes_regs_dbg_write_ipin, System.C66XX_S.SHARED_SYSTEM.MEMTR_SWITCHSS_SERDES_Config.MT_MIF2SSI.memtr_dbg_write_opin;
        //CONNECT11     System.C66XX_S.SHARED_SYSTEM.SWITCHSS.switchss_sgmii0_tx_data_gen_opin, System.C66XX_S.SHARED_SYSTEM.SWITCHSS.switchss_sgmii1_rx_data_gen_ipin;
    //  CONNECT12       System.C66XX_S.SHARED_SYSTEM.SWITCHSS.switchss_sgmii0_rx_data_gen_ipin, System.C66XX_S.SHARED_SYSTEM.SWITCHSS.switchss_sgmii1_tx_data_gen_opin;
                    //CONNECT1  System.C66XX_S.SHARED_SYSTEM.SWITCHSS.switchss_stat_intr0_opin, MainCPU.switchsstb_stat_intr0_ipin;
                    //CONNECT2  System.C66XX_S.SHARED_SYSTEM.SWITCHSS.switchss_stat_intr1_opin, MainCPU.switchsstb_stat_intr1_ipin;
                END INTERFACES;
                MODULE  USER_INPUTS;
                    INPUT1      SWITCHSS_IDVER  ,   0x101010;
                    INPUT2      SGMII0_IDVER    ,   0x101010;
                    INPUT3      SGMII1_IDVER    ,   0x101010;
                    INPUT4      CPSW_IDVER  ,   0x101010;
                    INPUT5      SL1_IDVER   ,   0x101010;
                    INPUT6      SL2_IDVER   ,   0x101010;
                    INPUT7      ALE_IDVER   ,   0x101010;
                    INPUT8      NO_EMACS    ,   0x2;  //Two EMACs required in this model
                    INPUT9      CPU_NAME    ,   SHARED;  //Update this entry with the CPU module name in the system
                END USER_INPUTS;
            END SWITCHSS;
             MODULE EMAC_ADAPTOR;
            NAME            emac_adatpor;
            SSI_VER         SSI_1.1;
            TYPE            SHARED;
            DLL         ../../../bin/components/emac_adaptor.so;
            //CPU_VIEW      SHARED;
            INIT_FUNC       emac_adaptor_init;
            INIT_DONE_FUNC      emac_adaptor_init_done;
            QUIT_FUNC       emac_adaptor_quit;
            MODULE  INTERFACES;
        CONNECT1        System.C66XX_S.SHARED_SYSTEM.EMAC_ADAPTOR.EMAC_ADAPTOR_reset, System.C66XX_S.SHARED_SYSTEM.SHARED_SYSTEM_INTF.reset_out;
        CONNECT2        System.C66XX_S.SHARED_SYSTEM.EMAC_ADAPTOR.EMAC_ADAPTOR_receive_data_port0, System.C66XX_S.SHARED_SYSTEM.SWITCHSS.switchss_sgmii0_tx_data_gen_opin;
        CONNECT3        System.C66XX_S.SHARED_SYSTEM.EMAC_ADAPTOR.EMAC_ADAPTOR_send_data_port0, System.C66XX_S.SHARED_SYSTEM.SWITCHSS.switchss_sgmii0_rx_data_gen_ipin;
        CONNECT4        System.C66XX_S.SHARED_SYSTEM.EMAC_ADAPTOR.EMAC_ADAPTOR_receive_data_port1, System.C66XX_S.SHARED_SYSTEM.SWITCHSS.switchss_sgmii1_tx_data_gen_opin;
        CONNECT5        System.C66XX_S.SHARED_SYSTEM.EMAC_ADAPTOR.EMAC_ADAPTOR_send_data_port1, System.C66XX_S.SHARED_SYSTEM.SWITCHSS.switchss_sgmii1_rx_data_gen_ipin;
        CONNECT6        System.C66XX_S.SHARED_SYSTEM.EMAC_ADAPTOR.EMAC_ADAPTOR_error_opin,System.C66XX_S.CPU_SYSTEM_0.CPU0.error_intf_ssi;
        CONNECT7        System.C66XX_S.SHARED_SYSTEM.EMAC_ADAPTOR.EMAC_ADAPTOR_error_opin,System.C66XX_S.CPU_SYSTEM_1.CPU1.error_intf_ssi;
        CONNECT8        System.C66XX_S.SHARED_SYSTEM.EMAC_ADAPTOR.EMAC_ADAPTOR_error_opin,System.C66XX_S.CPU_SYSTEM_2.CPU2.error_intf_ssi;
        CONNECT9        System.C66XX_S.SHARED_SYSTEM.EMAC_ADAPTOR.EMAC_ADAPTOR_error_opin,System.C66XX_S.CPU_SYSTEM_3.CPU3.error_intf_ssi;
            END INTERFACES;
            MODULE  USER_INPUTS;
                INPUT2  ADAPTOR, OFF;
                INPUT3  NUMBER_OF_PORTS,2;
                INPUT4  NETWORK_ADAPTOR, Broadcom;
                INPUT5  MAC_ADDRESS_PORT0, 00-1C-BF-36-25-AF;
                INPUT6  MAC_ADDRESS_PORT1, 00-21-86-81-A8-F0;
                            INPUT7  MAC_CRC, ON;
    //                        INPUT8  LOG_FILE, c:\emac_log.txt;
            END USER_INPUTS;
            END EMAC_ADAPTOR;
            MODULE PASS;
                TYPE            SHARED;
                SSI_VER         SSI_1.1;
                NAME            PASS;
                DLL                 ../../../bin/components/tisim_pass.so;
                INIT_FUNC       pass_init;
                INIT_DONE_FUNC      pass_init_done;
                QUIT_FUNC       pass_quit;
                MODULE    INTERFACES;
    //REMOVED CLOCK PIN CONNECTION, PASS NOW USES SCHEDULER
    //  CONNECT1        System.C66XX_S.SHARED_SYSTEM.PASS.pass_clock_ipin, System.C66XX_S.SHARED_SYSTEM.SHARED_SYSTEM_INTF.clock_out;
        CONNECT1        System.C66XX_S.SHARED_SYSTEM.PASS.pass_reset_ipin, System.C66XX_S.SHARED_SYSTEM.SHARED_SYSTEM_INTF.reset_out;
        CONNECT2        System.C66XX_S.SHARED_SYSTEM.PASS.pass_endian_ipin, System.C66XX_S.CPU_SYSTEM_0.CPU0_endianness;
        CONNECT3        System.C66XX_S.SHARED_SYSTEM.PASS.pass_tstrm_cppi_mready_opin, System.C66XX_S.SHARED_SYSTEM.CDMA_PASS.cdma_rstrm_thread_mready_ipin;
        CONNECT4        System.C66XX_S.SHARED_SYSTEM.PASS.pass_tstrm_cppi_sready_ipin, System.C66XX_S.SHARED_SYSTEM.CDMA_PASS.cdma_rstrm_thread_sready_opin;
        CONNECT5        System.C66XX_S.SHARED_SYSTEM.PASS.pass_tstrm_cppi_data_opin, System.C66XX_S.SHARED_SYSTEM.CDMA_PASS.cdma_rstrm_data_ipin;
        CONNECT6        System.C66XX_S.SHARED_SYSTEM.PASS.pass_tstrm_cppi_data_accept_ipin, System.C66XX_S.SHARED_SYSTEM.CDMA_PASS.cdma_rstrm_data_accept_opin;
        CONNECT7        System.C66XX_S.SHARED_SYSTEM.CDMA_PASS.cdma_tstrm_thread_mready_opin, System.C66XX_S.SHARED_SYSTEM.PASS.pass_rstrm_cppi_mready_ipin;
        CONNECT8        System.C66XX_S.SHARED_SYSTEM.CDMA_PASS.cdma_tstrm_thread_sready_ipin, System.C66XX_S.SHARED_SYSTEM.PASS.pass_rstrm_cppi_sready_opin;
        CONNECT9        System.C66XX_S.SHARED_SYSTEM.CDMA_PASS.cdma_tstrm_data_opin, System.C66XX_S.SHARED_SYSTEM.PASS.pass_rstrm_cppi_data_ipin;
        CONNECT10        System.C66XX_S.SHARED_SYSTEM.CDMA_PASS.cdma_tstrm_data_accept_ipin, System.C66XX_S.SHARED_SYSTEM.PASS.pass_rstrm_cppi_data_accept_opin;
        CONNECT11        System.C66XX_S.SHARED_SYSTEM.CDMA_PASS.cdma_rx_teardown_req_opin, System.C66XX_S.SHARED_SYSTEM.CDMA_PASS.cdma_rx_teardown_ack_ipin;
        CONNECT12        System.C66XX_S.SHARED_SYSTEM.PASS.pass_cfg_read_req_ipin, System.C66XX_S.SHARED_SYSTEM.MIF_TO_FUNC_PASS.MT_MIF2SSI.memtr_read_opin;
        CONNECT13        System.C66XX_S.SHARED_SYSTEM.PASS.pass_cfg_write_ipin, System.C66XX_S.SHARED_SYSTEM.MIF_TO_FUNC_PASS.MT_MIF2SSI.memtr_write_opin;
        CONNECT14        System.C66XX_S.SHARED_SYSTEM.PASS.pass_dbg_read_req_ipin, System.C66XX_S.SHARED_SYSTEM.MIF_TO_FUNC_PASS.MT_MIF2SSI.memtr_dbg_read_opin;
        CONNECT15        System.C66XX_S.SHARED_SYSTEM.PASS.pass_dbg_write_ipin, System.C66XX_S.SHARED_SYSTEM.MIF_TO_FUNC_PASS.MT_MIF2SSI.memtr_dbg_write_opin;
                    END    INTERFACES;
                    MODULE USER_INPUTS;
                        INPUT1  cpu_freq_mhz,  1000;
                        INPUT2  pass_freq_mhz, 350;
                        INPUT3  sass_freq_mhz, 350;
                        INPUT4  CPU_NAME, SHARED;
                        //INPUT5  log_file,      pass.log;
                    END USER_INPUTS;
            END PASS;
            MODULE CDMA_PASS;
                NAME            cdma_pass;
                TYPE            SHARED;
                SSI_VER         SSI_1.1;
                MODULE    INTERFACES;
        CONNECT1        System.C66XX_S.SHARED_SYSTEM.CDMA_PASS.cdma_reset_ipin, System.C66XX_S.SHARED_SYSTEM.SHARED_SYSTEM_INTF.reset_out;
        CONNECT2        System.C66XX_S.SHARED_SYSTEM.CDMA_PASS.cdma_endian_ipin, System.C66XX_S.CPU_SYSTEM_0.CPU0_endianness_big_endian;
                        //CONNECT3      System.C66XX_S.SHARED_SYSTEM.CDMA_PASS.cdma_tx_scheduler_ipin,     MainCPU.cdmatb_tx_scheduler_opin;
                        //CONNECT4      System.C66XX_S.SHARED_SYSTEM.CDMA_PASS.cdma_tx_scheduler_opin,     MainCPU.cdmatb_tx_scheduler_ipin;
        CONNECT3        System.C66XX_S.SHARED_SYSTEM.CDMA_PASS.cdma_mstr_read_opin, System.C66XX_S.SHARED_SYSTEM.MEMTR_CDMA_PASS_Master.MT_SSI2MMAP.memtr_read_ipin;
        CONNECT4        System.C66XX_S.SHARED_SYSTEM.CDMA_PASS.cdma_mstr_write_opin, System.C66XX_S.SHARED_SYSTEM.MEMTR_CDMA_PASS_Master.MT_SSI2MMAP.memtr_write_ipin;
        CONNECT5        System.C66XX_S.SHARED_SYSTEM.CDMA_PASS.cdma_cfg_read_ipin, System.C66XX_S.SHARED_SYSTEM.MEMTR_CDMA_PASS_Config.MT_MIF2SSI.memtr_read_opin;
        CONNECT6        System.C66XX_S.SHARED_SYSTEM.CDMA_PASS.cdma_cfg_write_ipin, System.C66XX_S.SHARED_SYSTEM.MEMTR_CDMA_PASS_Config.MT_MIF2SSI.memtr_write_opin;
        CONNECT7        System.C66XX_S.SHARED_SYSTEM.CDMA_PASS.cdma_dbg_read_ipin, System.C66XX_S.SHARED_SYSTEM.MEMTR_CDMA_PASS_Config.MT_MIF2SSI.memtr_dbg_read_opin;
        CONNECT8        System.C66XX_S.SHARED_SYSTEM.CDMA_PASS.cdma_dbg_write_ipin, System.C66XX_S.SHARED_SYSTEM.MEMTR_CDMA_PASS_Config.MT_MIF2SSI.memtr_dbg_write_opin;
                END    INTERFACES;
                MODULE    USER_INPUTS;
                    INPUT2  NUM_RX_CHANNELS,    24;
                    INPUT3  NUM_TX_CHANNELS,    9;
                    INPUT4  NUM_RX_FLOWS,       32;
                    INPUT5  RX_FIFO_SIZE,       9216;
                    INPUT6  TX_FIFO_SIZE,       9217;  // +1 is for CDMA internal usage
                    INPUT7  FIFO_DESC_SIZE,     64;
                    INPUT8  RX_FIFO_DEPTH,      1;
                    INPUT9  TX_FIFO_DEPTH,      1;
                    INPUT10  TX_CHUNK_READ,     9216;
                    INPUT11 GLOBAL_CFG_OFFSET,      0x00004000;
                    INPUT12 TX_CHAN_CFG_OFFSET,     0x00004400;
                    INPUT13 RX_CHAN_CFG_OFFSET,     0x00004800;
                    INPUT14 TX_SCHED_CFG_OFFSET,    0x00004c00;
                    INPUT15 RX_FLOW_CFG_OFFSET,     0x00005000;
                    INPUT17 FIRST_HW_QNUM,      640;
                    INPUT18 PACKET_OFFSET,      0;
                    INPUT21 TX_DESCRIPTOR_RELEASE,  0;
            INPUT28 CLK_DIV, 3;
            //INPUT29  DEBUG_LOG ,    C:\CDMA_pass.log;
                END    USER_INPUTS;
            END CDMA_PASS;
            MODULE PCIE;
                NAME            pciess;
                TYPE            SHARED;
                SSI_VER         SSI_1.1;
                DLL         ../../../bin/components/tisim_pciess.so;
                INIT_FUNC       pciess_init;
                INIT_DONE_FUNC      pciess_init_done;
                QUIT_FUNC       pciess_quit;
                MODULE INTERFACES;
        CONNECT1        System.C66XX_S.SHARED_SYSTEM.PCIE.pciess_reset, System.C66XX_S.SHARED_SYSTEM.SHARED_SYSTEM_INTF.reset_out;
        CONNECT2        System.C66XX_S.SHARED_SYSTEM.PCIE.pciess_big_endian_ipin, System.C66XX_S.CPU_SYSTEM_0.CPU0_endianness_big_endian;
        CONNECT3        System.C66XX_S.SHARED_SYSTEM.PCIE.pciess_slv_read_ipin, System.C66XX_S.SHARED_SYSTEM.MEMTR_PCIE_Slave.MT_MIF2SSI.memtr_read_opin;
        CONNECT4        System.C66XX_S.SHARED_SYSTEM.PCIE.pciess_slv_write_ipin, System.C66XX_S.SHARED_SYSTEM.MEMTR_PCIE_Slave.MT_MIF2SSI.memtr_write_opin;
        CONNECT5        System.C66XX_S.SHARED_SYSTEM.PCIE.pciess_slv_dbg_read_ipin, System.C66XX_S.SHARED_SYSTEM.MEMTR_PCIE_Slave.MT_MIF2SSI.memtr_dbg_read_opin;
        CONNECT6        System.C66XX_S.SHARED_SYSTEM.PCIE.pciess_slv_dbg_write_ipin, System.C66XX_S.SHARED_SYSTEM.MEMTR_PCIE_Slave.MT_MIF2SSI.memtr_dbg_write_opin;
                    // NOTE:
                    // Master interface not modeled.
                    // Interrupt functionality is not modeled. So, not connected.
                END INTERFACES;
                MODULE  USER_INPUTS;
                    INPUT1      PID ,   0x4e300000;
                    INPUT2      CLK_DIV ,   3;
                    INPUT3      CFG_TYPE,   0;
                    INPUT5      CFG_BASE,   0x21800000;
                END USER_INPUTS;
            END PCIE;
            //GPIO Connections
            MODULE MEMTR_GPIO_Config;
                    NAME            memtr_gpio_config;
                       TYPE            SHARED;
                      SSI_VER         SC_1.0.0;
                     DLL             ../../../bin/components/sim_memtr_adaptor.so;
                    //-- Entry-point
                    INIT_FUNC       memtr_adaptor_init;
                    INIT_DONE_FUNC  memtr_adaptor_init_done;
                    QUIT_FUNC       memtr_adaptor_quit;
                    //-- Configurable parameters
                    TERMINAL        MT_MIF2SSI;
                END MEMTR_GPIO_Config;
            MODULE MEMTR_SMS;
                    NAME            MEMTR_SMS;
                    TYPE            SHARED;
                    SSI_VER         SC_1.0.0;
                    //-- Entry-point
                END MEMTR_SMS;
            MODULE MEMTR_SES;
                    NAME            MEMTR_SES;
                    TYPE            SHARED;
                    SSI_VER         SC_1.0.0;
                    //-- Entry-point
                END MEMTR_SES;
            MODULE MEMTR_SEMAPHORE_Config;
                    NAME            memtr_semaphore_config;
                    TYPE            SHARED;
                    SSI_VER         SC_1.0.0;
                    //-- Entry-point
                END MEMTR_SEMAPHORE_Config;
            MODULE MEMTR_QM_Config;
                    NAME            memtr_qm_config;
                    TYPE            SHARED;
                    SSI_VER         SC_1.0.0;
                    //-- Entry-point
                END MEMTR_QM_Config;
        MODULE MEMTR_QM_DMA_Config;
                NAME            memtr_qm_dma_config;
                   TYPE            SHARED;
                  SSI_VER         SC_1.0.0;
                //-- Entry-point
            END MEMTR_QM_DMA_Config;
        MODULE MEMTR_QM_PDSP_Command;
                NAME            memtr_qm_pdsp_command;
                   TYPE            SHARED;
                  SSI_VER         SC_1.0.0;
                //-- Entry-point
            END MEMTR_QM_PDSP_Command;
        MODULE MEMTR_QM_PDSP_Master;
                   NAME            memtr_qm_pdsp_master;
                TYPE            SHARED;
                SSI_VER         SC_1.0.0;
                   //-- Entry-point
                   TERMINAL        MT_SSI2MMAP;
            END MEMTR_QM_PDSP_Master;
            MODULE MEMTR_CDMA_INFRA_Config;
                    NAME            memtr_cdma_qm_config;
                    TYPE            SHARED;
                    SSI_VER         SC_1.0.0;
                    //-- Entry-point
                END MEMTR_CDMA_INFRA_Config;
            MODULE MEMTR_CDMA_INFRA_Master;
                    NAME            memtr_cdma_qm_master;
                    TYPE            SHARED;
                    SSI_VER         SC_1.0.0;
                    //-- Entry-point
                END MEMTR_CDMA_INFRA_Master;
            MODULE MEMTR_SRIO_Config;
                    NAME            memtr_srio_config;
                    TYPE            SHARED;
                    SSI_VER         SC_1.0.0;
                    //-- Entry-point
                END MEMTR_SRIO_Config;
            MODULE MEMTR_SRIO_Slave;
                    NAME            memtr_srio_slave;
                    TYPE            SHARED;
                    SSI_VER         SC_1.0.0;
                    //-- Entry-point
                END MEMTR_SRIO_Slave;
            MODULE MEMTR_CDMA_SRIO_Config;
                    NAME            memtr_srio_cdma_config;
                    TYPE            SHARED;
                    SSI_VER         SC_1.0.0;
                    //-- Entry-point
                END MEMTR_CDMA_SRIO_Config;
            MODULE MEMTR_CDMA_SRIO_Master;
                    TYPE            SHARED;
                    SSI_VER         SC_1.0.0;
                    //-- Entry-point
                END MEMTR_CDMA_SRIO_Master;
            MODULE MEMTR_SWITCHSS_Config;
                    NAME            memtr_emac_sgmii_config;
                    TYPE            SHARED;
                    SSI_VER         SC_1.0.0;
                    //-- Entry-point
                END MEMTR_SWITCHSS_Config;
            MODULE MEMTR_SWITCHSS_SERDES_Config;
                    NAME            memtr_emac_sgmii_serdes_config;
                    TYPE            SHARED;
                    SSI_VER         SC_1.0.0;
                    //-- Entry-point
                END MEMTR_SWITCHSS_SERDES_Config;
            MODULE MIF_TO_FUNC_PASS;
                NAME            memtr_pass_config;
                TYPE        SHARED;
                    SSI_VER     SC_1.0.0;
            END MIF_TO_FUNC_PASS;
            MODULE MEMTR_PASS_Master;
                    NAME            memtr_pass_master;
                    TYPE            SHARED;
                    SSI_VER         SC_1.0.0;
                    //-- Entry-point
            END MEMTR_PASS_Master;
            MODULE MEMTR_CDMA_PASS_Config;
                    NAME            memtr_cdma_pass_config;
                    TYPE            SHARED;
                    SSI_VER         SC_1.0.0;
                    //-- Entry-point
                END MEMTR_CDMA_PASS_Config;
            MODULE MEMTR_CDMA_PASS_Master;
                    NAME            memtr_cdma_pass_master;
                    TYPE            SHARED;
                    SSI_VER         SC_1.0.0;
                    //-- Entry-point
                END MEMTR_CDMA_PASS_Master;
            MODULE MEMTR_PCIE_Slave;
                    NAME            memtr_pcie_slave;
                    TYPE            SHARED;
                    SSI_VER         SC_1.0.0;
                    //-- Entry-point
                END MEMTR_PCIE_Slave;
            MODULE MEMTR_CP_INTC0_Config;
                    NAME            memtr_cp_intc0_config;
                    TYPE            SHARED;
                    SSI_VER         SC_1.0.0;
                    //-- Entry-point
                END MEMTR_CP_INTC0_Config;
            MODULE MEMTR_CP_INTC1_Config;
                    NAME            memtr_cp_intc1_config;
                    TYPE            SHARED;
                    SSI_VER         SC_1.0.0;
                    //-- Entry-point
                END MEMTR_CP_INTC1_Config;
            MODULE MEMTR_CP_INTC2_Config;
                    NAME            memtr_cp_intc2_config;
                    TYPE            SHARED;
                    SSI_VER         SC_1.0.0;
                    //-- Entry-point
                END MEMTR_CP_INTC2_Config;
            MODULE MEMTR_CP_INTC3_Config;
                    NAME            memtr_cp_intc3_config;
                    TYPE            SHARED;
                    SSI_VER         SC_1.0.0;
                    //-- Entry-point
                END MEMTR_CP_INTC3_Config;
            MODULE MEMTR_IPC_Config;
                    NAME            memtr_ipc_config;
                    TYPE            SHARED;
                    SSI_VER         SC_1.0.0;
                    //-- Entry-point
                END MEMTR_IPC_Config;
            MODULE FLATMEM_36BIT;
                NAME            flatmem_36bit;  // Same name as MODULE
                TYPE            SHARED;
                SSI_VER         SC_1.0.0;
                DLL         ../../../bin/components/sim_memstore_36bit_ssi.so;
                INIT_FUNC       memstore_36bit_init;
                INIT_DONE_FUNC      memstore_36bit_init_done;
                QUIT_FUNC       memstore_36bit_quit;
            END FLATMEM_36BIT;
       MODULE PSC;
        NAME            psc;
        TYPE            SHARED;
        SSI_VER         SSI_1.1;
        DLL         ../../../bin/components/tisim_psc_pv.so;
        INIT_FUNC       psc_init;
        INIT_DONE_FUNC      psc_init_done;
        QUIT_FUNC       psc_quit;
        MODULE INTERFACES;
        CONNECT1        System.C66XX_S.SHARED_SYSTEM.MIF_TO_FUNC_PSC.MT_MIF2SSI.memtr_read_opin, System.C66XX_S.SHARED_SYSTEM.PSC.psc_cfg_read_ipin;
        CONNECT2        System.C66XX_S.SHARED_SYSTEM.MIF_TO_FUNC_PSC.MT_MIF2SSI.memtr_write_opin, System.C66XX_S.SHARED_SYSTEM.PSC.psc_cfg_write_ipin;
        CONNECT3        System.C66XX_S.SHARED_SYSTEM.MIF_TO_FUNC_PSC.MT_MIF2SSI.memtr_dbg_read_opin, System.C66XX_S.SHARED_SYSTEM.PSC.psc_dbg_read_ipin;
        CONNECT4        System.C66XX_S.SHARED_SYSTEM.MIF_TO_FUNC_PSC.MT_MIF2SSI.memtr_dbg_write_opin, System.C66XX_S.SHARED_SYSTEM.PSC.psc_dbg_write_ipin;
        CONNECT5        System.C66XX_S.SHARED_SYSTEM.PSC.psc_reset_ipin, System.C66XX_S.SHARED_SYSTEM.SHARED_SYSTEM_INTF.reset_out;
        CONNECT6        System.C66XX_S.SHARED_SYSTEM.PSC.psc_endian_ipin, System.C66XX_S.CPU_SYSTEM_0.CPU0_endianness;
            END INTERFACES;
            MODULE USER_INPUTS;
                INPUT1  CPU_NAME,SHARED;
                INPUT2  NUMPWRD, 32;
                INPUT3  ALWAYSON, 1;
                INPUT4  NUMLPSC, 16;
            END USER_INPUTS;
       END PSC;
             MODULE MIF_TO_FUNC_PSC;
                        TYPE SHARED;
                        SSI_VER SC_1.0.0;
            END MIF_TO_FUNC_PSC;
        END SHARED_SYSTEM;
         END C66XX_S;
        // CONNECTIONS
        //CGEM_SSI connections to CPU mem_map
        // CGEM program path for other
        CONNECT1        C66XX_S.CPU_SYSTEM_0.CGEM_SSI_0.cgem_prog_mif, C66XX_S.CPU_SYSTEM_0.CPU0.prog_mem_map, 0x0, 0xFFFFFFFF, 0;
        CONNECT2        C66XX_S.CPU_SYSTEM_1.CGEM_SSI_1.cgem_prog_mif, C66XX_S.CPU_SYSTEM_1.CPU1.prog_mem_map, 0x0, 0xFFFFFFFF, 0;
        CONNECT3        C66XX_S.CPU_SYSTEM_2.CGEM_SSI_2.cgem_prog_mif, C66XX_S.CPU_SYSTEM_2.CPU2.prog_mem_map, 0x0, 0xFFFFFFFF, 0;
        CONNECT4        C66XX_S.CPU_SYSTEM_3.CGEM_SSI_3.cgem_prog_mif, C66XX_S.CPU_SYSTEM_3.CPU3.prog_mem_map, 0x0, 0xFFFFFFFF, 0;
        CONNECT5        C66XX_S.CPU_SYSTEM_4.CGEM_SSI_4.cgem_prog_mif, C66XX_S.CPU_SYSTEM_4.CPU4.prog_mem_map, 0x0, 0xFFFFFFFF, 0;
        CONNECT6        C66XX_S.CPU_SYSTEM_5.CGEM_SSI_5.cgem_prog_mif, C66XX_S.CPU_SYSTEM_5.CPU5.prog_mem_map, 0x0, 0xFFFFFFFF, 0;
        CONNECT7        C66XX_S.CPU_SYSTEM_6.CGEM_SSI_6.cgem_prog_mif, C66XX_S.CPU_SYSTEM_6.CPU6.prog_mem_map, 0x0, 0xFFFFFFFF, 0;
        CONNECT8        C66XX_S.CPU_SYSTEM_7.CGEM_SSI_7.cgem_prog_mif, C66XX_S.CPU_SYSTEM_7.CPU7.prog_mem_map, 0x0, 0xFFFFFFFF, 0;
        // L1D and L1P connection for CGEM program path
        CONNECT9        C66XX_S.CPU_SYSTEM_0.CGEM_SSI_0.cgem_l1RAM_mif, C66XX_S.CPU_SYSTEM_0.CPU0.prog_mem_map, 0x10E00000, 0x10E07FFF, 0;
        CONNECT10        C66XX_S.CPU_SYSTEM_1.CGEM_SSI_1.cgem_l1RAM_mif, C66XX_S.CPU_SYSTEM_1.CPU1.prog_mem_map, 0x11E00000, 0x11E07FFF, 0;
        CONNECT11        C66XX_S.CPU_SYSTEM_2.CGEM_SSI_2.cgem_l1RAM_mif, C66XX_S.CPU_SYSTEM_2.CPU2.prog_mem_map, 0x12E00000, 0x12E07FFF, 0;
        CONNECT12        C66XX_S.CPU_SYSTEM_3.CGEM_SSI_3.cgem_l1RAM_mif, C66XX_S.CPU_SYSTEM_3.CPU3.prog_mem_map, 0x13E00000, 0x13E07FFF, 0;
        CONNECT13        C66XX_S.CPU_SYSTEM_4.CGEM_SSI_4.cgem_l1RAM_mif, C66XX_S.CPU_SYSTEM_4.CPU4.prog_mem_map, 0x14E00000, 0x14E07FFF, 0;
        CONNECT14        C66XX_S.CPU_SYSTEM_5.CGEM_SSI_5.cgem_l1RAM_mif, C66XX_S.CPU_SYSTEM_5.CPU5.prog_mem_map, 0x15E00000, 0x15E07FFF, 0;
        CONNECT15        C66XX_S.CPU_SYSTEM_6.CGEM_SSI_6.cgem_l1RAM_mif, C66XX_S.CPU_SYSTEM_6.CPU6.prog_mem_map, 0x16E00000, 0x16E07FFF, 0;
        CONNECT16        C66XX_S.CPU_SYSTEM_7.CGEM_SSI_7.cgem_l1RAM_mif, C66XX_S.CPU_SYSTEM_7.CPU7.prog_mem_map, 0x17E00000, 0x17E07FFF, 0;
        CONNECT17        C66XX_S.CPU_SYSTEM_0.CGEM_SSI_0.cgem_l1RAM_mif, C66XX_S.CPU_SYSTEM_0.CPU0.prog_mem_map, 0x10F00000, 0x10F07FFF, 0;
        CONNECT18        C66XX_S.CPU_SYSTEM_1.CGEM_SSI_1.cgem_l1RAM_mif, C66XX_S.CPU_SYSTEM_1.CPU1.prog_mem_map, 0x11F00000, 0x11F07FFF, 0;
        CONNECT19        C66XX_S.CPU_SYSTEM_2.CGEM_SSI_2.cgem_l1RAM_mif, C66XX_S.CPU_SYSTEM_2.CPU2.prog_mem_map, 0x12F00000, 0x12F07FFF, 0;
        CONNECT20        C66XX_S.CPU_SYSTEM_3.CGEM_SSI_3.cgem_l1RAM_mif, C66XX_S.CPU_SYSTEM_3.CPU3.prog_mem_map, 0x13F00000, 0x13F07FFF, 0;
        CONNECT21        C66XX_S.CPU_SYSTEM_4.CGEM_SSI_4.cgem_l1RAM_mif, C66XX_S.CPU_SYSTEM_4.CPU4.prog_mem_map, 0x14F00000, 0x14F07FFF, 0;
        CONNECT22        C66XX_S.CPU_SYSTEM_5.CGEM_SSI_5.cgem_l1RAM_mif, C66XX_S.CPU_SYSTEM_5.CPU5.prog_mem_map, 0x15F00000, 0x15F07FFF, 0;
        CONNECT23        C66XX_S.CPU_SYSTEM_6.CGEM_SSI_6.cgem_l1RAM_mif, C66XX_S.CPU_SYSTEM_6.CPU6.prog_mem_map, 0x16F00000, 0x16F07FFF, 0;
        CONNECT24        C66XX_S.CPU_SYSTEM_7.CGEM_SSI_7.cgem_l1RAM_mif, C66XX_S.CPU_SYSTEM_7.CPU7.prog_mem_map, 0x17F00000, 0x17F07FFF, 0;
        CONNECT25        C66XX_S.CPU_SYSTEM_0.CGEM_SSI_0.cgem_data_mif, C66XX_S.CPU_SYSTEM_0.CPU0_mem_map, 0, 0xFFFFFFFF, 0;
        CONNECT26        C66XX_S.CPU_SYSTEM_1.CGEM_SSI_1.cgem_data_mif, C66XX_S.CPU_SYSTEM_1.CPU1_mem_map, 0, 0xFFFFFFFF, 0;
        CONNECT27        C66XX_S.CPU_SYSTEM_2.CGEM_SSI_2.cgem_data_mif, C66XX_S.CPU_SYSTEM_2.CPU2_mem_map, 0, 0xFFFFFFFF, 0;
        CONNECT28        C66XX_S.CPU_SYSTEM_3.CGEM_SSI_3.cgem_data_mif, C66XX_S.CPU_SYSTEM_3.CPU3_mem_map, 0, 0xFFFFFFFF, 0;
        CONNECT29        C66XX_S.CPU_SYSTEM_4.CGEM_SSI_4.cgem_data_mif, C66XX_S.CPU_SYSTEM_4.CPU4_mem_map, 0, 0xFFFFFFFF, 0;
        CONNECT30        C66XX_S.CPU_SYSTEM_5.CGEM_SSI_5.cgem_data_mif, C66XX_S.CPU_SYSTEM_5.CPU5_mem_map, 0, 0xFFFFFFFF, 0;
        CONNECT31        C66XX_S.CPU_SYSTEM_6.CGEM_SSI_6.cgem_data_mif, C66XX_S.CPU_SYSTEM_6.CPU6_mem_map, 0, 0xFFFFFFFF, 0;
        CONNECT32        C66XX_S.CPU_SYSTEM_7.CGEM_SSI_7.cgem_data_mif, C66XX_S.CPU_SYSTEM_7.CPU7_mem_map, 0, 0xFFFFFFFF, 0;
        // L1D and L1P connection for CGEM Data path
        CONNECT33        C66XX_S.CPU_SYSTEM_0.CGEM_SSI_0.cgem_l1RAM_mif, C66XX_S.CPU_SYSTEM_0.CPU0_mem_map, 0x10E00000, 0x10E07FFF, 0;
        CONNECT34        C66XX_S.CPU_SYSTEM_1.CGEM_SSI_1.cgem_l1RAM_mif, C66XX_S.CPU_SYSTEM_1.CPU1_mem_map, 0x11E00000, 0x11E07FFF, 0;
        CONNECT35        C66XX_S.CPU_SYSTEM_2.CGEM_SSI_2.cgem_l1RAM_mif, C66XX_S.CPU_SYSTEM_2.CPU2_mem_map, 0x12E00000, 0x12E07FFF, 0;
        CONNECT36        C66XX_S.CPU_SYSTEM_3.CGEM_SSI_3.cgem_l1RAM_mif, C66XX_S.CPU_SYSTEM_3.CPU3_mem_map, 0x13E00000, 0x13E07FFF, 0;
        CONNECT37        C66XX_S.CPU_SYSTEM_4.CGEM_SSI_4.cgem_l1RAM_mif, C66XX_S.CPU_SYSTEM_4.CPU4_mem_map, 0x14E00000, 0x14E07FFF, 0;
        CONNECT38        C66XX_S.CPU_SYSTEM_5.CGEM_SSI_5.cgem_l1RAM_mif, C66XX_S.CPU_SYSTEM_5.CPU5_mem_map, 0x15E00000, 0x15E07FFF, 0;
        CONNECT39        C66XX_S.CPU_SYSTEM_6.CGEM_SSI_6.cgem_l1RAM_mif, C66XX_S.CPU_SYSTEM_6.CPU6_mem_map, 0x16E00000, 0x16E07FFF, 0;
        CONNECT40        C66XX_S.CPU_SYSTEM_7.CGEM_SSI_7.cgem_l1RAM_mif, C66XX_S.CPU_SYSTEM_7.CPU7_mem_map, 0x17E00000, 0x17E07FFF, 0;
        CONNECT41        C66XX_S.CPU_SYSTEM_0.CGEM_SSI_0.cgem_l1RAM_mif, C66XX_S.CPU_SYSTEM_0.CPU0_mem_map, 0x10F00000, 0x10F07FFF, 0;
        CONNECT42        C66XX_S.CPU_SYSTEM_1.CGEM_SSI_1.cgem_l1RAM_mif, C66XX_S.CPU_SYSTEM_1.CPU1_mem_map, 0x11F00000, 0x11F07FFF, 0;
        CONNECT43        C66XX_S.CPU_SYSTEM_2.CGEM_SSI_2.cgem_l1RAM_mif, C66XX_S.CPU_SYSTEM_2.CPU2_mem_map, 0x12F00000, 0x12F07FFF, 0;
        CONNECT44        C66XX_S.CPU_SYSTEM_3.CGEM_SSI_3.cgem_l1RAM_mif, C66XX_S.CPU_SYSTEM_3.CPU3_mem_map, 0x13F00000, 0x13F07FFF, 0;
        CONNECT45        C66XX_S.CPU_SYSTEM_4.CGEM_SSI_4.cgem_l1RAM_mif, C66XX_S.CPU_SYSTEM_4.CPU4_mem_map, 0x14F00000, 0x14F07FFF, 0;
        CONNECT46        C66XX_S.CPU_SYSTEM_5.CGEM_SSI_5.cgem_l1RAM_mif, C66XX_S.CPU_SYSTEM_5.CPU5_mem_map, 0x15F00000, 0x15F07FFF, 0;
        CONNECT47        C66XX_S.CPU_SYSTEM_6.CGEM_SSI_6.cgem_l1RAM_mif, C66XX_S.CPU_SYSTEM_6.CPU6_mem_map, 0x16F00000, 0x16F07FFF, 0;
        CONNECT48        C66XX_S.CPU_SYSTEM_7.CGEM_SSI_7.cgem_l1RAM_mif, C66XX_S.CPU_SYSTEM_7.CPU7_mem_map, 0x17F00000, 0x17F07FFF, 0;
        // Register for CGEM and XMC mapping
        CONNECT49        C66XX_S.CPU_SYSTEM_0.CGEM_SSI_0.cgem_reg_mif, C66XX_S.CPU_SYSTEM_0.CPU0_mem_map, 0x01800000, 0x01BFFFFF, 0;
        CONNECT50        C66XX_S.CPU_SYSTEM_1.CGEM_SSI_1.cgem_reg_mif, C66XX_S.CPU_SYSTEM_1.CPU1_mem_map, 0x01800000, 0x01BFFFFF, 0;
        CONNECT51        C66XX_S.CPU_SYSTEM_2.CGEM_SSI_2.cgem_reg_mif, C66XX_S.CPU_SYSTEM_2.CPU2_mem_map, 0x01800000, 0x01BFFFFF, 0;
        CONNECT52        C66XX_S.CPU_SYSTEM_3.CGEM_SSI_3.cgem_reg_mif, C66XX_S.CPU_SYSTEM_3.CPU3_mem_map, 0x01800000, 0x01BFFFFF, 0;
        CONNECT53        C66XX_S.CPU_SYSTEM_4.CGEM_SSI_4.cgem_reg_mif, C66XX_S.CPU_SYSTEM_4.CPU4_mem_map, 0x01800000, 0x01BFFFFF, 0;
        CONNECT54        C66XX_S.CPU_SYSTEM_5.CGEM_SSI_5.cgem_reg_mif, C66XX_S.CPU_SYSTEM_5.CPU5_mem_map, 0x01800000, 0x01BFFFFF, 0;
        CONNECT55        C66XX_S.CPU_SYSTEM_6.CGEM_SSI_6.cgem_reg_mif, C66XX_S.CPU_SYSTEM_6.CPU6_mem_map, 0x01800000, 0x01BFFFFF, 0;
        CONNECT56        C66XX_S.CPU_SYSTEM_7.CGEM_SSI_7.cgem_reg_mif, C66XX_S.CPU_SYSTEM_7.CPU7_mem_map, 0x01800000, 0x01BFFFFF, 0;
        //CGEM INTSEL Connections with CPU mem_map
        CONNECT57        C66XX_S.CPU_SYSTEM_0.CPU0_mem_map, C66XX_S.CPU_SYSTEM_0.CGEM_SSI_0.INTSELcfg_mem_mif, 0x01800000, 0x01800200, 0;
        CONNECT58        C66XX_S.CPU_SYSTEM_1.CPU1_mem_map, C66XX_S.CPU_SYSTEM_1.CGEM_SSI_1.INTSELcfg_mem_mif, 0x01800000, 0x01800200, 0;
        CONNECT59        C66XX_S.CPU_SYSTEM_2.CPU2_mem_map, C66XX_S.CPU_SYSTEM_2.CGEM_SSI_2.INTSELcfg_mem_mif, 0x01800000, 0x01800200, 0;
        CONNECT60        C66XX_S.CPU_SYSTEM_3.CPU3_mem_map, C66XX_S.CPU_SYSTEM_3.CGEM_SSI_3.INTSELcfg_mem_mif, 0x01800000, 0x01800200, 0;
        CONNECT61        C66XX_S.CPU_SYSTEM_4.CPU4_mem_map, C66XX_S.CPU_SYSTEM_4.CGEM_SSI_4.INTSELcfg_mem_mif, 0x01800000, 0x01800200, 0;
        CONNECT62        C66XX_S.CPU_SYSTEM_5.CPU5_mem_map, C66XX_S.CPU_SYSTEM_5.CGEM_SSI_5.INTSELcfg_mem_mif, 0x01800000, 0x01800200, 0;
        CONNECT63        C66XX_S.CPU_SYSTEM_6.CPU6_mem_map, C66XX_S.CPU_SYSTEM_6.CGEM_SSI_6.INTSELcfg_mem_mif, 0x01800000, 0x01800200, 0;
        CONNECT64        C66XX_S.CPU_SYSTEM_7.CPU7_mem_map, C66XX_S.CPU_SYSTEM_7.CGEM_SSI_7.INTSELcfg_mem_mif, 0x01800000, 0x01800200, 0;
    //! Connections of IDMA with CPU
        CONNECT65        C66XX_S.CPU_SYSTEM_0.CPU0_mem_map, C66XX_S.CPU_SYSTEM_0.CGEM_SSI_0.IDMAcfg_mem_mif, 0x01820000, 0x01820114, 0;
        CONNECT66        C66XX_S.CPU_SYSTEM_1.CPU1_mem_map, C66XX_S.CPU_SYSTEM_1.CGEM_SSI_1.IDMAcfg_mem_mif, 0x01820000, 0x01820114, 0;
        CONNECT67        C66XX_S.CPU_SYSTEM_2.CPU2_mem_map, C66XX_S.CPU_SYSTEM_2.CGEM_SSI_2.IDMAcfg_mem_mif, 0x01820000, 0x01820114, 0;
        CONNECT68        C66XX_S.CPU_SYSTEM_3.CPU3_mem_map, C66XX_S.CPU_SYSTEM_3.CGEM_SSI_3.IDMAcfg_mem_mif, 0x01820000, 0x01820114, 0;
        CONNECT69        C66XX_S.CPU_SYSTEM_4.CPU4_mem_map, C66XX_S.CPU_SYSTEM_4.CGEM_SSI_4.IDMAcfg_mem_mif, 0x01820000, 0x01820114, 0;
        CONNECT70        C66XX_S.CPU_SYSTEM_5.CPU5_mem_map, C66XX_S.CPU_SYSTEM_5.CGEM_SSI_5.IDMAcfg_mem_mif, 0x01820000, 0x01820114, 0;
        CONNECT71        C66XX_S.CPU_SYSTEM_6.CPU6_mem_map, C66XX_S.CPU_SYSTEM_6.CGEM_SSI_6.IDMAcfg_mem_mif, 0x01820000, 0x01820114, 0;
        CONNECT72        C66XX_S.CPU_SYSTEM_7.CPU7_mem_map, C66XX_S.CPU_SYSTEM_7.CGEM_SSI_7.IDMAcfg_mem_mif, 0x01820000, 0x01820114, 0;
        // Register for XMC mapping
        CONNECT73        C66XX_S.CPU_SYSTEM_0.CGEM_SSI_0.cgem_reg_mif, C66XX_S.CPU_SYSTEM_0.CPU0_mem_map, 0x08000000, 0x0800FFFF, 0;
        CONNECT74        C66XX_S.CPU_SYSTEM_1.CGEM_SSI_1.cgem_reg_mif, C66XX_S.CPU_SYSTEM_1.CPU1_mem_map, 0x08000000, 0x0800FFFF, 0;
        CONNECT75        C66XX_S.CPU_SYSTEM_2.CGEM_SSI_2.cgem_reg_mif, C66XX_S.CPU_SYSTEM_2.CPU2_mem_map, 0x08000000, 0x0800FFFF, 0;
        CONNECT76        C66XX_S.CPU_SYSTEM_3.CGEM_SSI_3.cgem_reg_mif, C66XX_S.CPU_SYSTEM_3.CPU3_mem_map, 0x08000000, 0x0800FFFF, 0;
        CONNECT77        C66XX_S.CPU_SYSTEM_4.CGEM_SSI_4.cgem_reg_mif, C66XX_S.CPU_SYSTEM_4.CPU4_mem_map, 0x08000000, 0x0800FFFF, 0;
        CONNECT78        C66XX_S.CPU_SYSTEM_5.CGEM_SSI_5.cgem_reg_mif, C66XX_S.CPU_SYSTEM_5.CPU5_mem_map, 0x08000000, 0x0800FFFF, 0;
        CONNECT79        C66XX_S.CPU_SYSTEM_6.CGEM_SSI_6.cgem_reg_mif, C66XX_S.CPU_SYSTEM_6.CPU6_mem_map, 0x08000000, 0x0800FFFF, 0;
        CONNECT80        C66XX_S.CPU_SYSTEM_7.CGEM_SSI_7.cgem_reg_mif, C66XX_S.CPU_SYSTEM_7.CPU7_mem_map, 0x08000000, 0x0800FFFF, 0;
        //! Connections of IDMA with CGEM_SSI
        CONNECT81        C66XX_S.CPU_SYSTEM_0.CGEM_SSI_0.idma_mem_map, C66XX_S.CPU_SYSTEM_0.CGEM_SSI_0.cgem_data_mif, 0x00000000, 0xFFFFFFFF, 0;
        CONNECT82        C66XX_S.CPU_SYSTEM_1.CGEM_SSI_1.idma_mem_map, C66XX_S.CPU_SYSTEM_1.CGEM_SSI_1.cgem_data_mif, 0x00000000, 0xFFFFFFFF, 0;
        CONNECT83        C66XX_S.CPU_SYSTEM_2.CGEM_SSI_2.idma_mem_map, C66XX_S.CPU_SYSTEM_2.CGEM_SSI_2.cgem_data_mif, 0x00000000, 0xFFFFFFFF, 0;
        CONNECT84        C66XX_S.CPU_SYSTEM_3.CGEM_SSI_3.idma_mem_map, C66XX_S.CPU_SYSTEM_3.CGEM_SSI_3.cgem_data_mif, 0x00000000, 0xFFFFFFFF, 0;
        CONNECT85        C66XX_S.CPU_SYSTEM_4.CGEM_SSI_4.idma_mem_map, C66XX_S.CPU_SYSTEM_4.CGEM_SSI_4.cgem_data_mif, 0x00000000, 0xFFFFFFFF, 0;
        CONNECT86        C66XX_S.CPU_SYSTEM_5.CGEM_SSI_5.idma_mem_map, C66XX_S.CPU_SYSTEM_5.CGEM_SSI_5.cgem_data_mif, 0x00000000, 0xFFFFFFFF, 0;
        CONNECT87        C66XX_S.CPU_SYSTEM_6.CGEM_SSI_6.idma_mem_map, C66XX_S.CPU_SYSTEM_6.CGEM_SSI_6.cgem_data_mif, 0x00000000, 0xFFFFFFFF, 0;
        CONNECT88        C66XX_S.CPU_SYSTEM_7.CGEM_SSI_7.idma_mem_map, C66XX_S.CPU_SYSTEM_7.CGEM_SSI_7.cgem_data_mif, 0x00000000, 0xFFFFFFFF, 0;
        // L1D and L1P connection forIDMA
        CONNECT89        C66XX_S.CPU_SYSTEM_0.CGEM_SSI_0.cgem_l1RAM_mif, C66XX_S.CPU_SYSTEM_0.CGEM_SSI_0.idma_mem_map, 0x00E00000, 0x00E07FFF, 0;
        CONNECT90        C66XX_S.CPU_SYSTEM_1.CGEM_SSI_1.cgem_l1RAM_mif, C66XX_S.CPU_SYSTEM_1.CGEM_SSI_1.idma_mem_map, 0x00E00000, 0x00E07FFF, 0;
        CONNECT91        C66XX_S.CPU_SYSTEM_2.CGEM_SSI_2.cgem_l1RAM_mif, C66XX_S.CPU_SYSTEM_2.CGEM_SSI_2.idma_mem_map, 0x00E00000, 0x00E07FFF, 0;
        CONNECT92        C66XX_S.CPU_SYSTEM_3.CGEM_SSI_3.cgem_l1RAM_mif, C66XX_S.CPU_SYSTEM_3.CGEM_SSI_3.idma_mem_map, 0x00E00000, 0x00E07FFF, 0;
        CONNECT93        C66XX_S.CPU_SYSTEM_4.CGEM_SSI_4.cgem_l1RAM_mif, C66XX_S.CPU_SYSTEM_4.CGEM_SSI_4.idma_mem_map, 0x00E00000, 0x00E07FFF, 0;
        CONNECT94        C66XX_S.CPU_SYSTEM_5.CGEM_SSI_5.cgem_l1RAM_mif, C66XX_S.CPU_SYSTEM_5.CGEM_SSI_5.idma_mem_map, 0x00E00000, 0x00E07FFF, 0;
        CONNECT95        C66XX_S.CPU_SYSTEM_6.CGEM_SSI_6.cgem_l1RAM_mif, C66XX_S.CPU_SYSTEM_6.CGEM_SSI_6.idma_mem_map, 0x00E00000, 0x00E07FFF, 0;
        CONNECT96        C66XX_S.CPU_SYSTEM_7.CGEM_SSI_7.cgem_l1RAM_mif, C66XX_S.CPU_SYSTEM_7.CGEM_SSI_7.idma_mem_map, 0x00E00000, 0x00E07FFF, 0;
        CONNECT97        C66XX_S.CPU_SYSTEM_0.CGEM_SSI_0.cgem_l1RAM_mif, C66XX_S.CPU_SYSTEM_0.CGEM_SSI_0.idma_mem_map, 0x00F00000, 0x00F07FFF, 0;
        CONNECT98        C66XX_S.CPU_SYSTEM_1.CGEM_SSI_1.cgem_l1RAM_mif, C66XX_S.CPU_SYSTEM_1.CGEM_SSI_1.idma_mem_map, 0x00F00000, 0x00F07FFF, 0;
        CONNECT99        C66XX_S.CPU_SYSTEM_2.CGEM_SSI_2.cgem_l1RAM_mif, C66XX_S.CPU_SYSTEM_2.CGEM_SSI_2.idma_mem_map, 0x00F00000, 0x00F07FFF, 0;
        CONNECT100        C66XX_S.CPU_SYSTEM_3.CGEM_SSI_3.cgem_l1RAM_mif, C66XX_S.CPU_SYSTEM_3.CGEM_SSI_3.idma_mem_map, 0x00F00000, 0x00F07FFF, 0;
        CONNECT101        C66XX_S.CPU_SYSTEM_4.CGEM_SSI_4.cgem_l1RAM_mif, C66XX_S.CPU_SYSTEM_4.CGEM_SSI_4.idma_mem_map, 0x00F00000, 0x00F07FFF, 0;
        CONNECT102        C66XX_S.CPU_SYSTEM_5.CGEM_SSI_5.cgem_l1RAM_mif, C66XX_S.CPU_SYSTEM_5.CGEM_SSI_5.idma_mem_map, 0x00F00000, 0x00F07FFF, 0;
        CONNECT103        C66XX_S.CPU_SYSTEM_6.CGEM_SSI_6.cgem_l1RAM_mif, C66XX_S.CPU_SYSTEM_6.CGEM_SSI_6.idma_mem_map, 0x00F00000, 0x00F07FFF, 0;
        CONNECT104        C66XX_S.CPU_SYSTEM_7.CGEM_SSI_7.cgem_l1RAM_mif, C66XX_S.CPU_SYSTEM_7.CGEM_SSI_7.idma_mem_map, 0x00F00000, 0x00F07FFF, 0;
        //MSMC connections with CGEM SSI
        CONNECT105        C66XX_S.SHARED_SYSTEM.MSMC.msmc_cGEM0_memtr_read_input_ipin, C66XX_S.CPU_SYSTEM_0.CGEM_SSI_0.cgem_memtr_read_output_opin;
        CONNECT106        C66XX_S.SHARED_SYSTEM.MSMC.msmc_cGEM0_memtr_write_input_ipin, C66XX_S.CPU_SYSTEM_0.CGEM_SSI_0.cgem_memtr_write_output_opin;
        CONNECT107        C66XX_S.SHARED_SYSTEM.MSMC.msmc_cGEM0_memtr_dbg_read_input_ipin, C66XX_S.CPU_SYSTEM_0.CGEM_SSI_0.cgem_memtr_dbg_read_output_opin;
        CONNECT108        C66XX_S.SHARED_SYSTEM.MSMC.msmc_cGEM0_memtr_dbg_write_input_ipin, C66XX_S.CPU_SYSTEM_0.CGEM_SSI_0.cgem_memtr_dbg_write_output_opin;
        CONNECT109        C66XX_S.SHARED_SYSTEM.MSMC.msmc_cGEM1_memtr_read_input_ipin, C66XX_S.CPU_SYSTEM_1.CGEM_SSI_1.cgem_memtr_read_output_opin;
        CONNECT110        C66XX_S.SHARED_SYSTEM.MSMC.msmc_cGEM1_memtr_write_input_ipin, C66XX_S.CPU_SYSTEM_1.CGEM_SSI_1.cgem_memtr_write_output_opin;
        CONNECT111        C66XX_S.SHARED_SYSTEM.MSMC.msmc_cGEM1_memtr_dbg_read_input_ipin, C66XX_S.CPU_SYSTEM_1.CGEM_SSI_1.cgem_memtr_dbg_read_output_opin;
        CONNECT112        C66XX_S.SHARED_SYSTEM.MSMC.msmc_cGEM1_memtr_dbg_write_input_ipin, C66XX_S.CPU_SYSTEM_1.CGEM_SSI_1.cgem_memtr_dbg_write_output_opin;
        CONNECT113        C66XX_S.SHARED_SYSTEM.MSMC.msmc_cGEM2_memtr_read_input_ipin, C66XX_S.CPU_SYSTEM_2.CGEM_SSI_2.cgem_memtr_read_output_opin;
        CONNECT114        C66XX_S.SHARED_SYSTEM.MSMC.msmc_cGEM2_memtr_write_input_ipin, C66XX_S.CPU_SYSTEM_2.CGEM_SSI_2.cgem_memtr_write_output_opin;
        CONNECT115        C66XX_S.SHARED_SYSTEM.MSMC.msmc_cGEM2_memtr_dbg_read_input_ipin, C66XX_S.CPU_SYSTEM_2.CGEM_SSI_2.cgem_memtr_dbg_read_output_opin;
        CONNECT116        C66XX_S.SHARED_SYSTEM.MSMC.msmc_cGEM2_memtr_dbg_write_input_ipin, C66XX_S.CPU_SYSTEM_2.CGEM_SSI_2.cgem_memtr_dbg_write_output_opin;
        CONNECT117        C66XX_S.SHARED_SYSTEM.MSMC.msmc_cGEM3_memtr_read_input_ipin, C66XX_S.CPU_SYSTEM_3.CGEM_SSI_3.cgem_memtr_read_output_opin;
        CONNECT118        C66XX_S.SHARED_SYSTEM.MSMC.msmc_cGEM3_memtr_write_input_ipin, C66XX_S.CPU_SYSTEM_3.CGEM_SSI_3.cgem_memtr_write_output_opin;
        CONNECT119        C66XX_S.SHARED_SYSTEM.MSMC.msmc_cGEM3_memtr_dbg_read_input_ipin, C66XX_S.CPU_SYSTEM_3.CGEM_SSI_3.cgem_memtr_dbg_read_output_opin;
        CONNECT120        C66XX_S.SHARED_SYSTEM.MSMC.msmc_cGEM3_memtr_dbg_write_input_ipin, C66XX_S.CPU_SYSTEM_3.CGEM_SSI_3.cgem_memtr_dbg_write_output_opin;
        CONNECT121        C66XX_S.SHARED_SYSTEM.MSMC.msmc_cGEM4_memtr_read_input_ipin, C66XX_S.CPU_SYSTEM_4.CGEM_SSI_4.cgem_memtr_read_output_opin;
        CONNECT122        C66XX_S.SHARED_SYSTEM.MSMC.msmc_cGEM4_memtr_write_input_ipin, C66XX_S.CPU_SYSTEM_4.CGEM_SSI_4.cgem_memtr_write_output_opin;
        CONNECT123        C66XX_S.SHARED_SYSTEM.MSMC.msmc_cGEM4_memtr_dbg_read_input_ipin, C66XX_S.CPU_SYSTEM_4.CGEM_SSI_4.cgem_memtr_dbg_read_output_opin;
        CONNECT124        C66XX_S.SHARED_SYSTEM.MSMC.msmc_cGEM4_memtr_dbg_write_input_ipin, C66XX_S.CPU_SYSTEM_4.CGEM_SSI_4.cgem_memtr_dbg_write_output_opin;
        CONNECT125        C66XX_S.SHARED_SYSTEM.MSMC.msmc_cGEM5_memtr_read_input_ipin, C66XX_S.CPU_SYSTEM_5.CGEM_SSI_5.cgem_memtr_read_output_opin;
        CONNECT126        C66XX_S.SHARED_SYSTEM.MSMC.msmc_cGEM5_memtr_write_input_ipin, C66XX_S.CPU_SYSTEM_5.CGEM_SSI_5.cgem_memtr_write_output_opin;
        CONNECT127        C66XX_S.SHARED_SYSTEM.MSMC.msmc_cGEM5_memtr_dbg_read_input_ipin, C66XX_S.CPU_SYSTEM_5.CGEM_SSI_5.cgem_memtr_dbg_read_output_opin;
        CONNECT128        C66XX_S.SHARED_SYSTEM.MSMC.msmc_cGEM5_memtr_dbg_write_input_ipin, C66XX_S.CPU_SYSTEM_5.CGEM_SSI_5.cgem_memtr_dbg_write_output_opin;
        CONNECT129        C66XX_S.SHARED_SYSTEM.MSMC.msmc_cGEM6_memtr_read_input_ipin, C66XX_S.CPU_SYSTEM_6.CGEM_SSI_6.cgem_memtr_read_output_opin;
        CONNECT130        C66XX_S.SHARED_SYSTEM.MSMC.msmc_cGEM6_memtr_write_input_ipin, C66XX_S.CPU_SYSTEM_6.CGEM_SSI_6.cgem_memtr_write_output_opin;
        CONNECT131        C66XX_S.SHARED_SYSTEM.MSMC.msmc_cGEM6_memtr_dbg_read_input_ipin, C66XX_S.CPU_SYSTEM_6.CGEM_SSI_6.cgem_memtr_dbg_read_output_opin;
        CONNECT132        C66XX_S.SHARED_SYSTEM.MSMC.msmc_cGEM6_memtr_dbg_write_input_ipin, C66XX_S.CPU_SYSTEM_6.CGEM_SSI_6.cgem_memtr_dbg_write_output_opin;
        CONNECT133        C66XX_S.SHARED_SYSTEM.MSMC.msmc_cGEM7_memtr_read_input_ipin, C66XX_S.CPU_SYSTEM_7.CGEM_SSI_7.cgem_memtr_read_output_opin;
        CONNECT134        C66XX_S.SHARED_SYSTEM.MSMC.msmc_cGEM7_memtr_write_input_ipin, C66XX_S.CPU_SYSTEM_7.CGEM_SSI_7.cgem_memtr_write_output_opin;
        CONNECT135        C66XX_S.SHARED_SYSTEM.MSMC.msmc_cGEM7_memtr_dbg_read_input_ipin, C66XX_S.CPU_SYSTEM_7.CGEM_SSI_7.cgem_memtr_dbg_read_output_opin;
        CONNECT136        C66XX_S.SHARED_SYSTEM.MSMC.msmc_cGEM7_memtr_dbg_write_input_ipin, C66XX_S.CPU_SYSTEM_7.CGEM_SSI_7.cgem_memtr_dbg_write_output_opin;
        //32BIT mif connection with MSMC mem_map
        CONNECT137        C66XX_S.SHARED_SYSTEM.MSMC.msmc_mem_map, C66XX_S.SHARED_SYSTEM.FLATMEM_36BIT.mem36_mif, 0, 0xFFFFFFFF, 0;
        //TIMER_64 connections with MSMC mem_map
        CONNECT138        C66XX_S.SHARED_SYSTEM.MSMC.msmc_mem_map, C66XX_S.SHARED_SYSTEM.TIMER64_0_mif, 0x02200000, 0x0220007F, -0x02200000;
        CONNECT139        C66XX_S.SHARED_SYSTEM.MSMC.msmc_mem_map, C66XX_S.SHARED_SYSTEM.TIMER64_1_mif, 0x02210000, 0x0221007F, -0x02210000;
        CONNECT140        C66XX_S.SHARED_SYSTEM.MSMC.msmc_mem_map, C66XX_S.SHARED_SYSTEM.TIMER64_2_mif, 0x02220000, 0x0222007F, -0x02220000;
        CONNECT141        C66XX_S.SHARED_SYSTEM.MSMC.msmc_mem_map, C66XX_S.SHARED_SYSTEM.TIMER64_3_mif, 0x02230000, 0x0223007F, -0x02230000;
        CONNECT142        C66XX_S.SHARED_SYSTEM.MSMC.msmc_mem_map, C66XX_S.SHARED_SYSTEM.TIMER64_4_mif, 0x02240000, 0x0224007F, -0x02240000;
        CONNECT143        C66XX_S.SHARED_SYSTEM.MSMC.msmc_mem_map, C66XX_S.SHARED_SYSTEM.TIMER64_5_mif, 0x02250000, 0x0225007F, -0x02250000;
        CONNECT144        C66XX_S.SHARED_SYSTEM.MSMC.msmc_mem_map, C66XX_S.SHARED_SYSTEM.TIMER64_6_mif, 0x02260000, 0x0226007F, -0x02260000;
        CONNECT145        C66XX_S.SHARED_SYSTEM.MSMC.msmc_mem_map, C66XX_S.SHARED_SYSTEM.TIMER64_7_mif, 0x02270000, 0x0227007F, -0x02270000;
        CONNECT146        C66XX_S.SHARED_SYSTEM.MSMC.msmc_mem_map, C66XX_S.SHARED_SYSTEM.TIMER64_8_mif, 0x02280000, 0x0228007F, -0x02280000;
        CONNECT147        C66XX_S.SHARED_SYSTEM.MSMC.msmc_mem_map, C66XX_S.SHARED_SYSTEM.TIMER64_9_mif, 0x02290000, 0x0229007F, -0x02290000;
        CONNECT148        C66XX_S.SHARED_SYSTEM.MSMC.msmc_mem_map, C66XX_S.SHARED_SYSTEM.TIMER64_10_mif, 0x022A0000, 0x022A007F, -0x022A0000;
        CONNECT149        C66XX_S.SHARED_SYSTEM.MSMC.msmc_mem_map, C66XX_S.SHARED_SYSTEM.TIMER64_11_mif, 0x022B0000, 0x022B007F, -0x022B0000;
        CONNECT150        C66XX_S.SHARED_SYSTEM.MSMC.msmc_mem_map, C66XX_S.SHARED_SYSTEM.TIMER64_12_mif, 0x022C0000, 0x022C007F, -0x022C0000;
        CONNECT151        C66XX_S.SHARED_SYSTEM.MSMC.msmc_mem_map, C66XX_S.SHARED_SYSTEM.TIMER64_13_mif, 0x022D0000, 0x022D007F, -0x022D0000;
        CONNECT152        C66XX_S.SHARED_SYSTEM.MSMC.msmc_mem_map, C66XX_S.SHARED_SYSTEM.TIMER64_14_mif, 0x022E0000, 0x022E007F, -0x022E0000;
        CONNECT153        C66XX_S.SHARED_SYSTEM.MSMC.msmc_mem_map, C66XX_S.SHARED_SYSTEM.TIMER64_15_mif, 0x022F0000, 0x022F007F, -0x022F0000;
        //EDMA connections with MSMC mem_map
        CONNECT154        C66XX_S.SHARED_SYSTEM.MSMC.msmc_mem_map, C66XX_S.SHARED_SYSTEM.EDMA_0_mif, 0x02700000, 0x02707FFF, 0;
        //! Decide whether to use memtr adaptors for TPTC accesses
        //CONNECT35     C66XX_S.SHARED_SYSTEM.MSMC.msmc_mem_map, C66XX_S.SHARED_SYSTEM.EDMA_0_mif, 0x02760000, 0x027603FF, 0;
        //CONNECT36     C66XX_S.SHARED_SYSTEM.MSMC.msmc_mem_map, C66XX_S.SHARED_SYSTEM.EDMA_0_mif, 0x02768000, 0x027683FF, 0;
        CONNECT155        C66XX_S.SHARED_SYSTEM.MSMC.msmc_mem_map, C66XX_S.SHARED_SYSTEM.EDMA_1_mif, 0x02720000, 0x02727FFF, 0;
        CONNECT156        C66XX_S.SHARED_SYSTEM.MSMC.msmc_mem_map, C66XX_S.SHARED_SYSTEM.EDMA_2_mif, 0x02740000, 0x02747FFF, 0;
        // CP_INTC connections with MSMC mem_map
        CONNECT157        C66XX_S.SHARED_SYSTEM.MSMC.msmc_mem_map, C66XX_S.SHARED_SYSTEM.MEMTR_CP_INTC0_Config.MT_MIF2SSI.memtr_mif_opin, 0x02600000, 0x02601FFF, -0x02600000;
        CONNECT158        C66XX_S.SHARED_SYSTEM.MSMC.msmc_mem_map, C66XX_S.SHARED_SYSTEM.MEMTR_CP_INTC1_Config.MT_MIF2SSI.memtr_mif_opin, 0x02604000, 0x02605FFF, -0x02604000;
        CONNECT159        C66XX_S.SHARED_SYSTEM.MSMC.msmc_mem_map, C66XX_S.SHARED_SYSTEM.MEMTR_CP_INTC2_Config.MT_MIF2SSI.memtr_mif_opin, 0x02608000, 0x02609FFF, -0x02608000;
        CONNECT160        C66XX_S.SHARED_SYSTEM.MSMC.msmc_mem_map, C66XX_S.SHARED_SYSTEM.MEMTR_CP_INTC3_Config.MT_MIF2SSI.memtr_mif_opin, 0x0260C000, 0x0260DFFF, -0x0260C000;
            // DDR3(to FLATMEM_36BIT) connections with MSMC mem_map
        CONNECT161        C66XX_S.SHARED_SYSTEM.MSMC.msmc_mem_map, C66XX_S.SHARED_SYSTEM.FLATMEM_36BIT.mem36_mif, 0x21000000, 0x210000FF, 0; //EMIF
        CONNECT162        C66XX_S.SHARED_SYSTEM.MSMC.msmc_mem_map, C66XX_S.SHARED_SYSTEM.FLATMEM_36BIT.mem36_mif, 0x80000000, 0xFFFFFFFF, 0; //DDR
        //SEMAPHORE connections with MEMTRs
        CONNECT163        C66XX_S.SHARED_SYSTEM.MEMTR_SEMAPHORE_Config.MT_MIF2SSI.memtr_read_opin, C66XX_S.SHARED_SYSTEM.SEMAPHORE.semaphore2_cfg_read_ipin;
        CONNECT164        C66XX_S.SHARED_SYSTEM.MEMTR_SEMAPHORE_Config.MT_MIF2SSI.memtr_write_opin, C66XX_S.SHARED_SYSTEM.SEMAPHORE.semaphore2_cfg_write_ipin;
        CONNECT165        C66XX_S.SHARED_SYSTEM.MEMTR_SEMAPHORE_Config.MT_MIF2SSI.memtr_dbg_read_opin, C66XX_S.SHARED_SYSTEM.SEMAPHORE.semaphore2_dbg_read_ipin;
        CONNECT166        C66XX_S.SHARED_SYSTEM.MEMTR_SEMAPHORE_Config.MT_MIF2SSI.memtr_dbg_write_opin, C66XX_S.SHARED_SYSTEM.SEMAPHORE.semaphore2_dbg_write_ipin;
        //VBUSM CMD packet
        CONNECT167        C66XX_S.SHARED_SYSTEM.MEMTR_SEMAPHORE_Config.MT_MIF2SSI.vbusm_cmd_ipin, C66XX_S.CPU_SYSTEM_0.CGEM_SSI_0.cgem_memtr_vbusm_cmd_output_opin;
        CONNECT168        C66XX_S.SHARED_SYSTEM.MEMTR_SEMAPHORE_Config.MT_MIF2SSI.vbusm_cmd_ipin, C66XX_S.CPU_SYSTEM_1.CGEM_SSI_1.cgem_memtr_vbusm_cmd_output_opin;
        CONNECT169        C66XX_S.SHARED_SYSTEM.MEMTR_SEMAPHORE_Config.MT_MIF2SSI.vbusm_cmd_ipin, C66XX_S.CPU_SYSTEM_2.CGEM_SSI_2.cgem_memtr_vbusm_cmd_output_opin;
        CONNECT170        C66XX_S.SHARED_SYSTEM.MEMTR_SEMAPHORE_Config.MT_MIF2SSI.vbusm_cmd_ipin, C66XX_S.CPU_SYSTEM_3.CGEM_SSI_3.cgem_memtr_vbusm_cmd_output_opin;
        CONNECT171        C66XX_S.SHARED_SYSTEM.MEMTR_SEMAPHORE_Config.MT_MIF2SSI.vbusm_cmd_ipin, C66XX_S.CPU_SYSTEM_4.CGEM_SSI_4.cgem_memtr_vbusm_cmd_output_opin;
        CONNECT172        C66XX_S.SHARED_SYSTEM.MEMTR_SEMAPHORE_Config.MT_MIF2SSI.vbusm_cmd_ipin, C66XX_S.CPU_SYSTEM_5.CGEM_SSI_5.cgem_memtr_vbusm_cmd_output_opin;
        CONNECT173        C66XX_S.SHARED_SYSTEM.MEMTR_SEMAPHORE_Config.MT_MIF2SSI.vbusm_cmd_ipin, C66XX_S.CPU_SYSTEM_6.CGEM_SSI_6.cgem_memtr_vbusm_cmd_output_opin;
        CONNECT174        C66XX_S.SHARED_SYSTEM.MEMTR_SEMAPHORE_Config.MT_MIF2SSI.vbusm_cmd_ipin, C66XX_S.CPU_SYSTEM_7.CGEM_SSI_7.cgem_memtr_vbusm_cmd_output_opin;
        // SEMAPHORE connections to with MSMC mem_map
        CONNECT175        C66XX_S.SHARED_SYSTEM.MSMC.msmc_mem_map, C66XX_S.SHARED_SYSTEM.MEMTR_SEMAPHORE_Config.MT_MIF2SSI.memtr_mif_opin, 0x02640000, 0x026407FF, 0;
        //IPC connections with MSMC mem_map
        CONNECT176        C66XX_S.SHARED_SYSTEM.MSMC.msmc_mem_map, C66XX_S.SHARED_SYSTEM.MEMTR_IPC_Config.MT_MIF2SSI.memtr_mif_opin, 0x02620200, 0x0262029F, -0x02620200;
        //GPIO connection with MSMC mem_map
        CONNECT177        C66XX_S.SHARED_SYSTEM.MSMC.msmc_mem_map, C66XX_S.SHARED_SYSTEM.MEMTR_GPIO_Config.MT_MIF2SSI.memtr_mif_opin, 0x02320000, 0x023200FF, -0x02320000;
        //QM connections with MEMTRs
        //QM Config
        CONNECT178        C66XX_S.SHARED_SYSTEM.MEMTR_QM_Config.MT_MIF2SSI.memtr_read_opin, C66XX_S.SHARED_SYSTEM.QUEUE_MANAGER.qmss_cfg_read_ipin;
        CONNECT179        C66XX_S.SHARED_SYSTEM.MEMTR_QM_Config.MT_MIF2SSI.memtr_write_opin, C66XX_S.SHARED_SYSTEM.QUEUE_MANAGER.qmss_cfg_write_ipin;
        CONNECT180        C66XX_S.SHARED_SYSTEM.MEMTR_QM_Config.MT_MIF2SSI.memtr_dbg_read_opin, C66XX_S.SHARED_SYSTEM.QUEUE_MANAGER.qmss_dbg_read_ipin;
        CONNECT181        C66XX_S.SHARED_SYSTEM.MEMTR_QM_Config.MT_MIF2SSI.memtr_dbg_write_opin, C66XX_S.SHARED_SYSTEM.QUEUE_MANAGER.qmss_dbg_write_ipin;
        //QM PDSP Scratch RAM (PDSP Command I/F):
        CONNECT182        C66XX_S.SHARED_SYSTEM.MEMTR_QM_PDSP_Command.MT_MIF2SSI.memtr_read_opin, C66XX_S.SHARED_SYSTEM.QUEUE_MANAGER.qmss_pdsp_cmd_read_ipin;
        CONNECT183        C66XX_S.SHARED_SYSTEM.MEMTR_QM_PDSP_Command.MT_MIF2SSI.memtr_write_opin, C66XX_S.SHARED_SYSTEM.QUEUE_MANAGER.qmss_pdsp_cmd_write_ipin;
        CONNECT184        C66XX_S.SHARED_SYSTEM.MEMTR_QM_PDSP_Command.MT_MIF2SSI.memtr_dbg_read_opin, C66XX_S.SHARED_SYSTEM.QUEUE_MANAGER.qmss_pdsp_cmd_dbg_read_ipin;
        CONNECT185        C66XX_S.SHARED_SYSTEM.MEMTR_QM_PDSP_Command.MT_MIF2SSI.memtr_dbg_write_opin, C66XX_S.SHARED_SYSTEM.QUEUE_MANAGER.qmss_pdsp_cmd_dbg_write_ipin;
        //QMSS PDSP Master
        CONNECT186        C66XX_S.SHARED_SYSTEM.MEMTR_QM_PDSP_Master.MT_SSI2MMAP.memtr_read_ipin, C66XX_S.SHARED_SYSTEM.QUEUE_MANAGER.qmss_pdsp_master_read_opin;
        CONNECT187        C66XX_S.SHARED_SYSTEM.MEMTR_QM_PDSP_Master.MT_SSI2MMAP.memtr_write_ipin, C66XX_S.SHARED_SYSTEM.QUEUE_MANAGER.qmss_pdsp_master_write_opin;
        //QM connections with MSMC mem_map
        CONNECT188        C66XX_S.SHARED_SYSTEM.MSMC.msmc_mem_map, C66XX_S.SHARED_SYSTEM.MEMTR_QM_Config.MT_MIF2SSI.memtr_mif_opin, 0x02A00000, 0x02AABFFF, -0x02A00000;
        CONNECT189        C66XX_S.SHARED_SYSTEM.MSMC.msmc_mem_map, C66XX_S.SHARED_SYSTEM.MEMTR_QM_PDSP_Command.MT_MIF2SSI.memtr_mif_opin, 0x02ab8000, 0x02abdFFF, -0x02A00000;
    //    CONNECT194        C66XX_S.SHARED_SYSTEM.MSMC.msmc_mem_map, C66XX_S.SHARED_SYSTEM.MEMTR_QM_High_Accumulator.MT_MIF2SSI.memtr_mif_opin, 0x02AB8000, 0x02AB8FFF, -0x02A00000;
        //CDMA_INFRA connections with MEMTRs
        //CDMA_INFRA Config
        CONNECT190        C66XX_S.SHARED_SYSTEM.MEMTR_CDMA_INFRA_Config.MT_MIF2SSI.memtr_read_opin, C66XX_S.SHARED_SYSTEM.CDMA_INFRA.cdma_cfg_read_ipin;
        CONNECT191        C66XX_S.SHARED_SYSTEM.MEMTR_CDMA_INFRA_Config.MT_MIF2SSI.memtr_write_opin, C66XX_S.SHARED_SYSTEM.CDMA_INFRA.cdma_cfg_write_ipin;
        CONNECT192        C66XX_S.SHARED_SYSTEM.MEMTR_CDMA_INFRA_Config.MT_MIF2SSI.memtr_dbg_read_opin, C66XX_S.SHARED_SYSTEM.CDMA_INFRA.cdma_dbg_read_ipin;
        CONNECT193        C66XX_S.SHARED_SYSTEM.MEMTR_CDMA_INFRA_Config.MT_MIF2SSI.memtr_dbg_write_opin, C66XX_S.SHARED_SYSTEM.CDMA_INFRA.cdma_dbg_write_ipin;
        //CDMA_INFRA Master
        CONNECT194        C66XX_S.SHARED_SYSTEM.MEMTR_CDMA_INFRA_Master.MT_SSI2MMAP.memtr_read_ipin, C66XX_S.SHARED_SYSTEM.CDMA_INFRA.cdma_mstr_read_opin;
        CONNECT195        C66XX_S.SHARED_SYSTEM.MEMTR_CDMA_INFRA_Master.MT_SSI2MMAP.memtr_write_ipin, C66XX_S.SHARED_SYSTEM.CDMA_INFRA.cdma_mstr_write_opin;
        //CDMA_INFRA connections with MSMC mem_map
        CONNECT196        C66XX_S.SHARED_SYSTEM.MSMC.msmc_mem_map, C66XX_S.SHARED_SYSTEM.MEMTR_CDMA_INFRA_Config.MT_MIF2SSI.memtr_mif_opin, 0x02A6C000, 0x02A6DFFF, -0x02A00000;
        //SRIO connections with MSMC mem_map
        CONNECT197        C66XX_S.SHARED_SYSTEM.MSMC.msmc_mem_map, C66XX_S.SHARED_SYSTEM.MEMTR_SRIO_Config.MT_MIF2SSI.memtr_mif_opin, 0x02900000, 0x02900FFF, 0;
        CONNECT198        C66XX_S.SHARED_SYSTEM.MSMC.msmc_mem_map, C66XX_S.SHARED_SYSTEM.MEMTR_SRIO_Slave.MT_MIF2SSI.memtr_mif_opin, 0x50000000, 0x5FFFFFFF, 0;
        //CDMA_SRIO connections with MSMC mem_map
        CONNECT199        C66XX_S.SHARED_SYSTEM.MSMC.msmc_mem_map, C66XX_S.SHARED_SYSTEM.MEMTR_CDMA_SRIO_Config.MT_MIF2SSI.memtr_mif_opin, 0x02901000, 0x02920FFF, -0x02900000;
        CONNECT200        C66XX_S.SHARED_SYSTEM.MSMC.msmc_mem_map, C66XX_S.SHARED_SYSTEM.FLATMEM_36BIT.mem36_mif, 0x0290B000, 0x0291BE4C, 0; //<CHECK>
        //! PA Sub-system connections
        // Switchss connection to PA (packet interface)
        CONNECT201        C66XX_S.SHARED_SYSTEM.PASS.pass_sgmii_rx1_ipin, C66XX_S.SHARED_SYSTEM.SWITCHSS.switchss_tstrm_tx1_data_opin;
        CONNECT202        C66XX_S.SHARED_SYSTEM.PASS.pass_sgmii_rx2_ipin, C66XX_S.SHARED_SYSTEM.SWITCHSS.switchss_tstrm_tx2_data_opin;
        CONNECT203        C66XX_S.SHARED_SYSTEM.PASS.pass_sgmii_tx_data_opin, C66XX_S.SHARED_SYSTEM.SWITCHSS.switchss_tstrm_rx_data_ipin;
        //SWITCHSS connections with MSMC mem_map
        CONNECT204        C66XX_S.SHARED_SYSTEM.MSMC.msmc_mem_map, C66XX_S.SHARED_SYSTEM.MEMTR_SWITCHSS_Config.MT_MIF2SSI.memtr_mif_opin, 0x02090000, 0x0209FFFF, -0x02090000; //actual end-0x02090FFF, giving relative address
        CONNECT205        C66XX_S.SHARED_SYSTEM.MSMC.msmc_mem_map, C66XX_S.SHARED_SYSTEM.MEMTR_SWITCHSS_SERDES_Config.MT_MIF2SSI.memtr_mif_opin, 0x02620340, 0x02620357, -0x02620000; //actual end-0x02090FFF, giving relative address<CHECK>
        //PASS connections with MSMC mem_map
        CONNECT206        C66XX_S.SHARED_SYSTEM.MSMC.msmc_mem_map, C66XX_S.SHARED_SYSTEM.MIF_TO_FUNC_PASS.MT_MIF2SSI.memtr_mif_opin, 0x02000000, 0x02003FFF, -0x02000000;
        CONNECT207        C66XX_S.SHARED_SYSTEM.MSMC.msmc_mem_map, C66XX_S.SHARED_SYSTEM.MIF_TO_FUNC_PASS.MT_MIF2SSI.memtr_mif_opin, 0x02006000, 0x0207FFFF, -0x02000000;
        //CDMA_PASS connections with MSMC mem_map
        CONNECT208        C66XX_S.SHARED_SYSTEM.MSMC.msmc_mem_map, C66XX_S.SHARED_SYSTEM.MEMTR_CDMA_PASS_Config.MT_MIF2SSI.memtr_mif_opin, 0x02004000, 0x02005FFF, -0x02000000;
        // PCIE connection with MSMC mem_map
        CONNECT209        C66XX_S.SHARED_SYSTEM.MSMC.msmc_mem_map, C66XX_S.SHARED_SYSTEM.MEMTR_PCIE_Slave.MT_MIF2SSI.memtr_mif_opin, 0x21800000, 0x21807FFF, 0; //MMR region
        //FLATMEM_36BIT connections with MSMC
        CONNECT210        C66XX_S.SHARED_SYSTEM.FLATMEM_36BIT.mem36_read_input_ipin, C66XX_S.SHARED_SYSTEM.MSMC.msmc_EMIF_memtr_read_output_opin;
        CONNECT211        C66XX_S.SHARED_SYSTEM.FLATMEM_36BIT.mem36_write_input_ipin, C66XX_S.SHARED_SYSTEM.MSMC.msmc_EMIF_memtr_write_output_opin;
        CONNECT212        C66XX_S.SHARED_SYSTEM.FLATMEM_36BIT.mem36_dbg_read_input_ipin, C66XX_S.SHARED_SYSTEM.MSMC.msmc_EMIF_memtr_dbg_read_output_opin;
        CONNECT213        C66XX_S.SHARED_SYSTEM.FLATMEM_36BIT.mem36_dbg_write_input_ipin, C66XX_S.SHARED_SYSTEM.MSMC.msmc_EMIF_memtr_dbg_write_output_opin;
            //MEMTR connections to SMS and SES interfaces of MSMC
        //SMS connections
        CONNECT214        C66XX_S.SHARED_SYSTEM.MEMTR_SMS.MT_MIF2SSI.memtr_read_opin, C66XX_S.SHARED_SYSTEM.MSMC.msmc_SMS_memtr_read_input_ipin;
        CONNECT215        C66XX_S.SHARED_SYSTEM.MEMTR_SMS.MT_MIF2SSI.memtr_write_opin, C66XX_S.SHARED_SYSTEM.MSMC.msmc_SMS_memtr_write_input_ipin;
        CONNECT216        C66XX_S.SHARED_SYSTEM.MEMTR_SMS.MT_MIF2SSI.memtr_dbg_read_opin, C66XX_S.SHARED_SYSTEM.MSMC.msmc_SMS_memtr_dbg_read_input_ipin;
        CONNECT217        C66XX_S.SHARED_SYSTEM.MEMTR_SMS.MT_MIF2SSI.memtr_dbg_write_opin, C66XX_S.SHARED_SYSTEM.MSMC.msmc_SMS_memtr_dbg_write_input_ipin;
        //SES connections
        CONNECT218        C66XX_S.SHARED_SYSTEM.MEMTR_SES.MT_MIF2SSI.memtr_read_opin, C66XX_S.SHARED_SYSTEM.MSMC.msmc_SES_memtr_read_input_ipin;
        CONNECT219        C66XX_S.SHARED_SYSTEM.MEMTR_SES.MT_MIF2SSI.memtr_write_opin, C66XX_S.SHARED_SYSTEM.MSMC.msmc_SES_memtr_write_input_ipin;
        CONNECT220        C66XX_S.SHARED_SYSTEM.MEMTR_SES.MT_MIF2SSI.memtr_dbg_read_opin, C66XX_S.SHARED_SYSTEM.MSMC.msmc_SES_memtr_dbg_read_input_ipin;
        CONNECT221        C66XX_S.SHARED_SYSTEM.MEMTR_SES.MT_MIF2SSI.memtr_dbg_write_opin, C66XX_S.SHARED_SYSTEM.MSMC.msmc_SES_memtr_dbg_write_input_ipin;
        //EDMA Memory map Connections
            //32BIT mif connections with EDMA mem_map
        CONNECT222        C66XX_S.SHARED_SYSTEM.EDMA_0_mem_map, C66XX_S.SHARED_SYSTEM.FLATMEM_36BIT.mem36_mif, 0, 0xFFFFFFFF, 0;
        CONNECT223        C66XX_S.SHARED_SYSTEM.EDMA_1_mem_map, C66XX_S.SHARED_SYSTEM.FLATMEM_36BIT.mem36_mif, 0, 0xFFFFFFFF, 0;
        CONNECT224        C66XX_S.SHARED_SYSTEM.EDMA_2_mem_map, C66XX_S.SHARED_SYSTEM.FLATMEM_36BIT.mem36_mif, 0, 0xFFFFFFFF, 0;
        //TIMER_64 connections with EDMA mem_map
        CONNECT225        C66XX_S.SHARED_SYSTEM.EDMA_0_mem_map, C66XX_S.SHARED_SYSTEM.TIMER64_0_mif, 0x02200000, 0x0220007F, -0x02200000;
        CONNECT226        C66XX_S.SHARED_SYSTEM.EDMA_0_mem_map, C66XX_S.SHARED_SYSTEM.TIMER64_1_mif, 0x02210000, 0x0221007F, -0x02210000;
        CONNECT227        C66XX_S.SHARED_SYSTEM.EDMA_0_mem_map, C66XX_S.SHARED_SYSTEM.TIMER64_2_mif, 0x02220000, 0x0222007F, -0x02220000;
        CONNECT228        C66XX_S.SHARED_SYSTEM.EDMA_0_mem_map, C66XX_S.SHARED_SYSTEM.TIMER64_3_mif, 0x02230000, 0x0223007F, -0x02230000;
        CONNECT229        C66XX_S.SHARED_SYSTEM.EDMA_0_mem_map, C66XX_S.SHARED_SYSTEM.TIMER64_4_mif, 0x02240000, 0x0224007F, -0x02240000;
        CONNECT230        C66XX_S.SHARED_SYSTEM.EDMA_0_mem_map, C66XX_S.SHARED_SYSTEM.TIMER64_5_mif, 0x02250000, 0x0225007F, -0x02250000;
        CONNECT231        C66XX_S.SHARED_SYSTEM.EDMA_0_mem_map, C66XX_S.SHARED_SYSTEM.TIMER64_6_mif, 0x02260000, 0x0226007F, -0x02260000;
        CONNECT232        C66XX_S.SHARED_SYSTEM.EDMA_0_mem_map, C66XX_S.SHARED_SYSTEM.TIMER64_7_mif, 0x02270000, 0x0227007F, -0x02270000;
        CONNECT233        C66XX_S.SHARED_SYSTEM.EDMA_0_mem_map, C66XX_S.SHARED_SYSTEM.TIMER64_8_mif, 0x02280000, 0x0228007F, -0x02280000;
        CONNECT234        C66XX_S.SHARED_SYSTEM.EDMA_0_mem_map, C66XX_S.SHARED_SYSTEM.TIMER64_9_mif, 0x02290000, 0x0229007F, -0x02290000;
        CONNECT235        C66XX_S.SHARED_SYSTEM.EDMA_0_mem_map, C66XX_S.SHARED_SYSTEM.TIMER64_10_mif, 0x022A0000, 0x022A007F, -0x022A0000;
        CONNECT236        C66XX_S.SHARED_SYSTEM.EDMA_0_mem_map, C66XX_S.SHARED_SYSTEM.TIMER64_11_mif, 0x022B0000, 0x022B007F, -0x022B0000;
        CONNECT237        C66XX_S.SHARED_SYSTEM.EDMA_0_mem_map, C66XX_S.SHARED_SYSTEM.TIMER64_12_mif, 0x022C0000, 0x022C007F, -0x022C0000;
        CONNECT238        C66XX_S.SHARED_SYSTEM.EDMA_0_mem_map, C66XX_S.SHARED_SYSTEM.TIMER64_13_mif, 0x022D0000, 0x022D007F, -0x022D0000;
        CONNECT239        C66XX_S.SHARED_SYSTEM.EDMA_0_mem_map, C66XX_S.SHARED_SYSTEM.TIMER64_14_mif, 0x022E0000, 0x022E007F, -0x022E0000;
        CONNECT240        C66XX_S.SHARED_SYSTEM.EDMA_0_mem_map, C66XX_S.SHARED_SYSTEM.TIMER64_15_mif, 0x022F0000, 0x022F007F, -0x022F0000;
        CONNECT241        C66XX_S.SHARED_SYSTEM.EDMA_1_mem_map, C66XX_S.SHARED_SYSTEM.TIMER64_0_mif, 0x02200000, 0x0220007F, -0x02200000;
        CONNECT242        C66XX_S.SHARED_SYSTEM.EDMA_1_mem_map, C66XX_S.SHARED_SYSTEM.TIMER64_1_mif, 0x02210000, 0x0221007F, -0x02210000;
        CONNECT243        C66XX_S.SHARED_SYSTEM.EDMA_1_mem_map, C66XX_S.SHARED_SYSTEM.TIMER64_2_mif, 0x02220000, 0x0222007F, -0x02220000;
        CONNECT244        C66XX_S.SHARED_SYSTEM.EDMA_1_mem_map, C66XX_S.SHARED_SYSTEM.TIMER64_3_mif, 0x02230000, 0x0223007F, -0x02230000;
        CONNECT245        C66XX_S.SHARED_SYSTEM.EDMA_1_mem_map, C66XX_S.SHARED_SYSTEM.TIMER64_4_mif, 0x02240000, 0x0224007F, -0x02240000;
        CONNECT246        C66XX_S.SHARED_SYSTEM.EDMA_1_mem_map, C66XX_S.SHARED_SYSTEM.TIMER64_5_mif, 0x02250000, 0x0225007F, -0x02250000;
        CONNECT247        C66XX_S.SHARED_SYSTEM.EDMA_1_mem_map, C66XX_S.SHARED_SYSTEM.TIMER64_6_mif, 0x02260000, 0x0226007F, -0x02260000;
        CONNECT248        C66XX_S.SHARED_SYSTEM.EDMA_1_mem_map, C66XX_S.SHARED_SYSTEM.TIMER64_7_mif, 0x02270000, 0x0227007F, -0x02270000;
        CONNECT249        C66XX_S.SHARED_SYSTEM.EDMA_1_mem_map, C66XX_S.SHARED_SYSTEM.TIMER64_8_mif, 0x02280000, 0x0228007F, -0x02280000;
        CONNECT250        C66XX_S.SHARED_SYSTEM.EDMA_1_mem_map, C66XX_S.SHARED_SYSTEM.TIMER64_9_mif, 0x02290000, 0x0229007F, -0x02290000;
        CONNECT251        C66XX_S.SHARED_SYSTEM.EDMA_1_mem_map, C66XX_S.SHARED_SYSTEM.TIMER64_10_mif, 0x022A0000, 0x022A007F, -0x022A0000;
        CONNECT252        C66XX_S.SHARED_SYSTEM.EDMA_1_mem_map, C66XX_S.SHARED_SYSTEM.TIMER64_11_mif, 0x022B0000, 0x022B007F, -0x022B0000;
        CONNECT253        C66XX_S.SHARED_SYSTEM.EDMA_1_mem_map, C66XX_S.SHARED_SYSTEM.TIMER64_12_mif, 0x022C0000, 0x022C007F, -0x022C0000;
        CONNECT254        C66XX_S.SHARED_SYSTEM.EDMA_1_mem_map, C66XX_S.SHARED_SYSTEM.TIMER64_13_mif, 0x022D0000, 0x022D007F, -0x022D0000;
        CONNECT255        C66XX_S.SHARED_SYSTEM.EDMA_1_mem_map, C66XX_S.SHARED_SYSTEM.TIMER64_14_mif, 0x022E0000, 0x022E007F, -0x022E0000;
        CONNECT256        C66XX_S.SHARED_SYSTEM.EDMA_1_mem_map, C66XX_S.SHARED_SYSTEM.TIMER64_15_mif, 0x022F0000, 0x022F007F, -0x022F0000;
        CONNECT257        C66XX_S.SHARED_SYSTEM.EDMA_2_mem_map, C66XX_S.SHARED_SYSTEM.TIMER64_0_mif, 0x02200000, 0x0220007F, -0x02200000;
        CONNECT258        C66XX_S.SHARED_SYSTEM.EDMA_2_mem_map, C66XX_S.SHARED_SYSTEM.TIMER64_1_mif, 0x02210000, 0x0221007F, -0x02210000;
        CONNECT259        C66XX_S.SHARED_SYSTEM.EDMA_2_mem_map, C66XX_S.SHARED_SYSTEM.TIMER64_2_mif, 0x02220000, 0x0222007F, -0x02220000;
        CONNECT260        C66XX_S.SHARED_SYSTEM.EDMA_2_mem_map, C66XX_S.SHARED_SYSTEM.TIMER64_3_mif, 0x02230000, 0x0223007F, -0x02230000;
        CONNECT261        C66XX_S.SHARED_SYSTEM.EDMA_2_mem_map, C66XX_S.SHARED_SYSTEM.TIMER64_4_mif, 0x02240000, 0x0224007F, -0x02240000;
        CONNECT262        C66XX_S.SHARED_SYSTEM.EDMA_2_mem_map, C66XX_S.SHARED_SYSTEM.TIMER64_5_mif, 0x02250000, 0x0225007F, -0x02250000;
        CONNECT263        C66XX_S.SHARED_SYSTEM.EDMA_2_mem_map, C66XX_S.SHARED_SYSTEM.TIMER64_6_mif, 0x02260000, 0x0226007F, -0x02260000;
        CONNECT264        C66XX_S.SHARED_SYSTEM.EDMA_2_mem_map, C66XX_S.SHARED_SYSTEM.TIMER64_7_mif, 0x02270000, 0x0227007F, -0x02270000;
        CONNECT265        C66XX_S.SHARED_SYSTEM.EDMA_2_mem_map, C66XX_S.SHARED_SYSTEM.TIMER64_8_mif, 0x02280000, 0x0228007F, -0x02280000;
        CONNECT266        C66XX_S.SHARED_SYSTEM.EDMA_2_mem_map, C66XX_S.SHARED_SYSTEM.TIMER64_9_mif, 0x02290000, 0x0229007F, -0x02290000;
        CONNECT267        C66XX_S.SHARED_SYSTEM.EDMA_2_mem_map, C66XX_S.SHARED_SYSTEM.TIMER64_10_mif, 0x022A0000, 0x022A007F, -0x022A0000;
        CONNECT268        C66XX_S.SHARED_SYSTEM.EDMA_2_mem_map, C66XX_S.SHARED_SYSTEM.TIMER64_11_mif, 0x022B0000, 0x022B007F, -0x022B0000;
        CONNECT269        C66XX_S.SHARED_SYSTEM.EDMA_2_mem_map, C66XX_S.SHARED_SYSTEM.TIMER64_12_mif, 0x022C0000, 0x022C007F, -0x022C0000;
        CONNECT270        C66XX_S.SHARED_SYSTEM.EDMA_2_mem_map, C66XX_S.SHARED_SYSTEM.TIMER64_13_mif, 0x022D0000, 0x022D007F, -0x022D0000;
        CONNECT271        C66XX_S.SHARED_SYSTEM.EDMA_2_mem_map, C66XX_S.SHARED_SYSTEM.TIMER64_14_mif, 0x022E0000, 0x022E007F, -0x022E0000;
        CONNECT272        C66XX_S.SHARED_SYSTEM.EDMA_2_mem_map, C66XX_S.SHARED_SYSTEM.TIMER64_15_mif, 0x022F0000, 0x022F007F, -0x022F0000;
        //EDMA connections with other EDMA mem_map
        CONNECT273        C66XX_S.SHARED_SYSTEM.EDMA_0_mem_map, C66XX_S.SHARED_SYSTEM.EDMA_1_mif, 0x02720000, 0x02727FFF, 0;
    //  CONNECT207      C66XX_S.SHARED_SYSTEM.EDMA_0_mem_map, C66XX_S.SHARED_SYSTEM.EDMA_1_mif, 0x02770000, 0x027703FF, 0;
    //  CONNECT208      C66XX_S.SHARED_SYSTEM.EDMA_0_mem_map, C66XX_S.SHARED_SYSTEM.EDMA_1_mif, 0x02778000, 0x027783FF, 0;
    //  CONNECT209      C66XX_S.SHARED_SYSTEM.EDMA_0_mem_map, C66XX_S.SHARED_SYSTEM.EDMA_1_mif, 0x02780000, 0x027803FF, 0;
    //  CONNECT210      C66XX_S.SHARED_SYSTEM.EDMA_0_mem_map, C66XX_S.SHARED_SYSTEM.EDMA_1_mif, 0x02788000, 0x027883FF, 0;
        CONNECT274        C66XX_S.SHARED_SYSTEM.EDMA_0_mem_map, C66XX_S.SHARED_SYSTEM.EDMA_2_mif, 0x02740000, 0x02747FFF, 0;
    //  CONNECT212      C66XX_S.SHARED_SYSTEM.EDMA_0_mem_map, C66XX_S.SHARED_SYSTEM.EDMA_2_mif, 0x02790000, 0x027903FF, 0;
    //  CONNECT213      C66XX_S.SHARED_SYSTEM.EDMA_0_mem_map, C66XX_S.SHARED_SYSTEM.EDMA_2_mif, 0x02798000, 0x027983FF, 0;
    //  CONNECT214      C66XX_S.SHARED_SYSTEM.EDMA_0_mem_map, C66XX_S.SHARED_SYSTEM.EDMA_2_mif, 0x027A0000, 0x027A03FF, 0;
    //  CONNECT215      C66XX_S.SHARED_SYSTEM.EDMA_0_mem_map, C66XX_S.SHARED_SYSTEM.EDMA_2_mif, 0x027A8000, 0x027A83FF, 0;
        CONNECT275        C66XX_S.SHARED_SYSTEM.EDMA_1_mem_map, C66XX_S.SHARED_SYSTEM.EDMA_0_mif, 0x02700000, 0x02707FFF, 0;
        CONNECT276        C66XX_S.SHARED_SYSTEM.EDMA_1_mem_map, C66XX_S.SHARED_SYSTEM.EDMA_2_mif, 0x02740000, 0x02747FFF, 0;
        CONNECT277        C66XX_S.SHARED_SYSTEM.EDMA_2_mem_map, C66XX_S.SHARED_SYSTEM.EDMA_0_mif, 0x02700000, 0x02707FFF, 0;
        CONNECT278        C66XX_S.SHARED_SYSTEM.EDMA_2_mem_map, C66XX_S.SHARED_SYSTEM.EDMA_1_mif, 0x02720000, 0x02727FFF, 0;
        //! EDMA connections with itself
        //! All the EDMA read/write ports are fully connected with all the EDMA抯 registers.
            //! EDMA X can read/write EDMA Y抯 register. X and Y can be the same or they can be different.
        CONNECT279        C66XX_S.SHARED_SYSTEM.EDMA_0_mem_map, C66XX_S.SHARED_SYSTEM.EDMA_0_mif, 0x02700000, 0x02707FFF, 0;
    //  CONNECT1341     C66XX_S.SHARED_SYSTEM.EDMA_0_mem_map, C66XX_S.SHARED_SYSTEM.EDMA_0_mif, 0x02760000, 0x027603FF, 0;
    //  CONNECT1342     C66XX_S.SHARED_SYSTEM.EDMA_0_mem_map, C66XX_S.SHARED_SYSTEM.EDMA_0_mif, 0x02768000, 0x027683FF, 0;
        CONNECT280        C66XX_S.SHARED_SYSTEM.EDMA_1_mem_map, C66XX_S.SHARED_SYSTEM.EDMA_1_mif, 0x02720000, 0x02727FFF, 0;
        CONNECT281        C66XX_S.SHARED_SYSTEM.EDMA_2_mem_map, C66XX_S.SHARED_SYSTEM.EDMA_2_mif, 0x02740000, 0x02747FFF, 0;
        // CP_INTC connections with EDMA mem_map
        CONNECT282        C66XX_S.SHARED_SYSTEM.EDMA_0_mem_map, C66XX_S.SHARED_SYSTEM.MEMTR_CP_INTC0_Config.MT_MIF2SSI.memtr_mif_opin, 0x02600000, 0x02601FFF, -0x02600000;
        CONNECT283        C66XX_S.SHARED_SYSTEM.EDMA_0_mem_map, C66XX_S.SHARED_SYSTEM.MEMTR_CP_INTC1_Config.MT_MIF2SSI.memtr_mif_opin, 0x02604000, 0x02605FFF, -0x02604000;
        CONNECT284        C66XX_S.SHARED_SYSTEM.EDMA_0_mem_map, C66XX_S.SHARED_SYSTEM.MEMTR_CP_INTC2_Config.MT_MIF2SSI.memtr_mif_opin, 0x02608000, 0x02609FFF, -0x02608000;
        CONNECT285        C66XX_S.SHARED_SYSTEM.EDMA_0_mem_map, C66XX_S.SHARED_SYSTEM.MEMTR_CP_INTC3_Config.MT_MIF2SSI.memtr_mif_opin, 0x0260C000, 0x0260DFFF, -0x0260C000;
        CONNECT286        C66XX_S.SHARED_SYSTEM.EDMA_1_mem_map, C66XX_S.SHARED_SYSTEM.MEMTR_CP_INTC0_Config.MT_MIF2SSI.memtr_mif_opin, 0x02600000, 0x02601FFF, -0x02600000;
        CONNECT287        C66XX_S.SHARED_SYSTEM.EDMA_1_mem_map, C66XX_S.SHARED_SYSTEM.MEMTR_CP_INTC1_Config.MT_MIF2SSI.memtr_mif_opin, 0x02604000, 0x02605FFF, -0x02604000;
        CONNECT288        C66XX_S.SHARED_SYSTEM.EDMA_1_mem_map, C66XX_S.SHARED_SYSTEM.MEMTR_CP_INTC2_Config.MT_MIF2SSI.memtr_mif_opin, 0x02608000, 0x02609FFF, -0x02608000;
        CONNECT289        C66XX_S.SHARED_SYSTEM.EDMA_1_mem_map, C66XX_S.SHARED_SYSTEM.MEMTR_CP_INTC3_Config.MT_MIF2SSI.memtr_mif_opin, 0x0260C000, 0x0260DFFF, -0x0260C000;
        CONNECT290        C66XX_S.SHARED_SYSTEM.EDMA_2_mem_map, C66XX_S.SHARED_SYSTEM.MEMTR_CP_INTC0_Config.MT_MIF2SSI.memtr_mif_opin, 0x02600000, 0x02601FFF, -0x02600000;
        CONNECT291        C66XX_S.SHARED_SYSTEM.EDMA_2_mem_map, C66XX_S.SHARED_SYSTEM.MEMTR_CP_INTC1_Config.MT_MIF2SSI.memtr_mif_opin, 0x02604000, 0x02605FFF, -0x02604000;
        CONNECT292        C66XX_S.SHARED_SYSTEM.EDMA_2_mem_map, C66XX_S.SHARED_SYSTEM.MEMTR_CP_INTC2_Config.MT_MIF2SSI.memtr_mif_opin, 0x02608000, 0x02609FFF, -0x02608000;
        CONNECT293        C66XX_S.SHARED_SYSTEM.EDMA_2_mem_map, C66XX_S.SHARED_SYSTEM.MEMTR_CP_INTC3_Config.MT_MIF2SSI.memtr_mif_opin, 0x0260C000, 0x0260DFFF, -0x0260C000;
        // L1/L2 MEM connections connections with EDMA mem map
        CONNECT294        C66XX_S.SHARED_SYSTEM.EDMA_0_mem_map, C66XX_S.CPU_SYSTEM_0.CGEM_SSI_0.cgem_slave_mif, 0x10800000, 0x1087FFFF, -0x10000000; //L2
        CONNECT295        C66XX_S.SHARED_SYSTEM.EDMA_0_mem_map, C66XX_S.CPU_SYSTEM_0.CGEM_SSI_0.cgem_slave_mif, 0x10E00000, 0x10E07FFF, -0x10000000; //L1P
        CONNECT296        C66XX_S.SHARED_SYSTEM.EDMA_0_mem_map, C66XX_S.CPU_SYSTEM_0.CGEM_SSI_0.cgem_slave_mif, 0x10F00000, 0x10F07FFF, -0x10000000; //L1D
        CONNECT297        C66XX_S.SHARED_SYSTEM.EDMA_0_mem_map, C66XX_S.CPU_SYSTEM_1.CGEM_SSI_1.cgem_slave_mif, 0x11800000, 0x1187FFFF, -0x11000000; //L2
        CONNECT298        C66XX_S.SHARED_SYSTEM.EDMA_0_mem_map, C66XX_S.CPU_SYSTEM_1.CGEM_SSI_1.cgem_slave_mif, 0x11E00000, 0x11E07FFF, -0x11000000; //L1P
        CONNECT299        C66XX_S.SHARED_SYSTEM.EDMA_0_mem_map, C66XX_S.CPU_SYSTEM_1.CGEM_SSI_1.cgem_slave_mif, 0x11F00000, 0x11F07FFF, -0x11000000; //L1D
        CONNECT300        C66XX_S.SHARED_SYSTEM.EDMA_0_mem_map, C66XX_S.CPU_SYSTEM_2.CGEM_SSI_2.cgem_slave_mif, 0x12800000, 0x1287FFFF, -0x12000000; //L2
        CONNECT301        C66XX_S.SHARED_SYSTEM.EDMA_0_mem_map, C66XX_S.CPU_SYSTEM_2.CGEM_SSI_2.cgem_slave_mif, 0x12E00000, 0x12E07FFF, -0x12000000; //L1P
        CONNECT302        C66XX_S.SHARED_SYSTEM.EDMA_0_mem_map, C66XX_S.CPU_SYSTEM_2.CGEM_SSI_2.cgem_slave_mif, 0x12F00000, 0x12F07FFF, -0x12000000; //L1D
        CONNECT303        C66XX_S.SHARED_SYSTEM.EDMA_0_mem_map, C66XX_S.CPU_SYSTEM_3.CGEM_SSI_3.cgem_slave_mif, 0x13800000, 0x1387FFFF, -0x13000000; //L2
        CONNECT304        C66XX_S.SHARED_SYSTEM.EDMA_0_mem_map, C66XX_S.CPU_SYSTEM_3.CGEM_SSI_3.cgem_slave_mif, 0x13E00000, 0x13E07FFF, -0x13000000; //L1P
        CONNECT305        C66XX_S.SHARED_SYSTEM.EDMA_0_mem_map, C66XX_S.CPU_SYSTEM_3.CGEM_SSI_3.cgem_slave_mif, 0x13F00000, 0x13F07FFF, -0x13000000; //L1D
        CONNECT306        C66XX_S.SHARED_SYSTEM.EDMA_0_mem_map, C66XX_S.CPU_SYSTEM_4.CGEM_SSI_4.cgem_slave_mif, 0x14800000, 0x1487FFFF, -0x14000000; //L2
        CONNECT307        C66XX_S.SHARED_SYSTEM.EDMA_0_mem_map, C66XX_S.CPU_SYSTEM_4.CGEM_SSI_4.cgem_slave_mif, 0x14E00000, 0x14E07FFF, -0x14000000; //L1P
        CONNECT308        C66XX_S.SHARED_SYSTEM.EDMA_0_mem_map, C66XX_S.CPU_SYSTEM_4.CGEM_SSI_4.cgem_slave_mif, 0x14F00000, 0x14F07FFF, -0x14000000; //L1D
        CONNECT309        C66XX_S.SHARED_SYSTEM.EDMA_0_mem_map, C66XX_S.CPU_SYSTEM_5.CGEM_SSI_5.cgem_slave_mif, 0x15800000, 0x1587FFFF, -0x15000000; //L2
        CONNECT310        C66XX_S.SHARED_SYSTEM.EDMA_0_mem_map, C66XX_S.CPU_SYSTEM_5.CGEM_SSI_5.cgem_slave_mif, 0x15E00000, 0x15E07FFF, -0x15000000; //L1P
        CONNECT311        C66XX_S.SHARED_SYSTEM.EDMA_0_mem_map, C66XX_S.CPU_SYSTEM_5.CGEM_SSI_5.cgem_slave_mif, 0x15F00000, 0x15F07FFF, -0x15000000; //L1D
        CONNECT312        C66XX_S.SHARED_SYSTEM.EDMA_0_mem_map, C66XX_S.CPU_SYSTEM_6.CGEM_SSI_6.cgem_slave_mif, 0x16800000, 0x1687FFFF, -0x16000000; //L2
        CONNECT313        C66XX_S.SHARED_SYSTEM.EDMA_0_mem_map, C66XX_S.CPU_SYSTEM_6.CGEM_SSI_6.cgem_slave_mif, 0x16E00000, 0x16E07FFF, -0x16000000; //L1P
        CONNECT314        C66XX_S.SHARED_SYSTEM.EDMA_0_mem_map, C66XX_S.CPU_SYSTEM_6.CGEM_SSI_6.cgem_slave_mif, 0x16F00000, 0x16F07FFF, -0x16000000; //L1D
        CONNECT315        C66XX_S.SHARED_SYSTEM.EDMA_0_mem_map, C66XX_S.CPU_SYSTEM_7.CGEM_SSI_7.cgem_slave_mif, 0x17800000, 0x1787FFFF, -0x17000000; //L2
        CONNECT316        C66XX_S.SHARED_SYSTEM.EDMA_0_mem_map, C66XX_S.CPU_SYSTEM_7.CGEM_SSI_7.cgem_slave_mif, 0x17E00000, 0x17E07FFF, -0x17000000; //L1P
        CONNECT317        C66XX_S.SHARED_SYSTEM.EDMA_0_mem_map, C66XX_S.CPU_SYSTEM_7.CGEM_SSI_7.cgem_slave_mif, 0x17F00000, 0x17F07FFF, -0x17000000; //L1D
        CONNECT318        C66XX_S.SHARED_SYSTEM.EDMA_1_mem_map, C66XX_S.CPU_SYSTEM_0.CGEM_SSI_0.cgem_slave_mif, 0x10800000, 0x1087FFFF, -0x10000000; //L2
        CONNECT319        C66XX_S.SHARED_SYSTEM.EDMA_1_mem_map, C66XX_S.CPU_SYSTEM_0.CGEM_SSI_0.cgem_slave_mif, 0x10E00000, 0x10E07FFF, -0x10000000; //L1P
        CONNECT320        C66XX_S.SHARED_SYSTEM.EDMA_1_mem_map, C66XX_S.CPU_SYSTEM_0.CGEM_SSI_0.cgem_slave_mif, 0x10F00000, 0x10F07FFF, -0x10000000; //L1D
        CONNECT321        C66XX_S.SHARED_SYSTEM.EDMA_1_mem_map, C66XX_S.CPU_SYSTEM_1.CGEM_SSI_1.cgem_slave_mif, 0x11800000, 0x1187FFFF, -0x11000000; //L2
        CONNECT322        C66XX_S.SHARED_SYSTEM.EDMA_1_mem_map, C66XX_S.CPU_SYSTEM_1.CGEM_SSI_1.cgem_slave_mif, 0x11E00000, 0x11E07FFF, -0x11000000; //L1P
        CONNECT323        C66XX_S.SHARED_SYSTEM.EDMA_1_mem_map, C66XX_S.CPU_SYSTEM_1.CGEM_SSI_1.cgem_slave_mif, 0x11F00000, 0x11F07FFF, -0x11000000; //L1D
        CONNECT324        C66XX_S.SHARED_SYSTEM.EDMA_1_mem_map, C66XX_S.CPU_SYSTEM_2.CGEM_SSI_2.cgem_slave_mif, 0x12800000, 0x1287FFFF, -0x12000000; //L2
        CONNECT325        C66XX_S.SHARED_SYSTEM.EDMA_1_mem_map, C66XX_S.CPU_SYSTEM_2.CGEM_SSI_2.cgem_slave_mif, 0x12E00000, 0x12E07FFF, -0x12000000; //L1P
        CONNECT326        C66XX_S.SHARED_SYSTEM.EDMA_1_mem_map, C66XX_S.CPU_SYSTEM_2.CGEM_SSI_2.cgem_slave_mif, 0x12F00000, 0x12F07FFF, -0x12000000; //L1D
        CONNECT327        C66XX_S.SHARED_SYSTEM.EDMA_1_mem_map, C66XX_S.CPU_SYSTEM_3.CGEM_SSI_3.cgem_slave_mif, 0x13800000, 0x1387FFFF, -0x13000000; //L2
        CONNECT328        C66XX_S.SHARED_SYSTEM.EDMA_1_mem_map, C66XX_S.CPU_SYSTEM_3.CGEM_SSI_3.cgem_slave_mif, 0x13E00000, 0x13E07FFF, -0x13000000; //L1P
        CONNECT329        C66XX_S.SHARED_SYSTEM.EDMA_1_mem_map, C66XX_S.CPU_SYSTEM_3.CGEM_SSI_3.cgem_slave_mif, 0x13F00000, 0x13F07FFF, -0x13000000; //L1D
        CONNECT330        C66XX_S.SHARED_SYSTEM.EDMA_1_mem_map, C66XX_S.CPU_SYSTEM_4.CGEM_SSI_4.cgem_slave_mif, 0x14800000, 0x1487FFFF, -0x14000000; //L2
        CONNECT331        C66XX_S.SHARED_SYSTEM.EDMA_1_mem_map, C66XX_S.CPU_SYSTEM_4.CGEM_SSI_4.cgem_slave_mif, 0x14E00000, 0x14E07FFF, -0x14000000; //L1P
        CONNECT332        C66XX_S.SHARED_SYSTEM.EDMA_1_mem_map, C66XX_S.CPU_SYSTEM_4.CGEM_SSI_4.cgem_slave_mif, 0x14F00000, 0x14F07FFF, -0x14000000; //L1D
        CONNECT333        C66XX_S.SHARED_SYSTEM.EDMA_1_mem_map, C66XX_S.CPU_SYSTEM_5.CGEM_SSI_5.cgem_slave_mif, 0x15800000, 0x1587FFFF, -0x15000000; //L2
        CONNECT334        C66XX_S.SHARED_SYSTEM.EDMA_1_mem_map, C66XX_S.CPU_SYSTEM_5.CGEM_SSI_5.cgem_slave_mif, 0x15E00000, 0x15E07FFF, -0x15000000; //L1P
        CONNECT335        C66XX_S.SHARED_SYSTEM.EDMA_1_mem_map, C66XX_S.CPU_SYSTEM_5.CGEM_SSI_5.cgem_slave_mif, 0x15F00000, 0x15F07FFF, -0x15000000; //L1D
        CONNECT336        C66XX_S.SHARED_SYSTEM.EDMA_1_mem_map, C66XX_S.CPU_SYSTEM_6.CGEM_SSI_6.cgem_slave_mif, 0x16800000, 0x1687FFFF, -0x16000000; //L2
        CONNECT337        C66XX_S.SHARED_SYSTEM.EDMA_1_mem_map, C66XX_S.CPU_SYSTEM_6.CGEM_SSI_6.cgem_slave_mif, 0x16E00000, 0x16E07FFF, -0x16000000; //L1P
        CONNECT338        C66XX_S.SHARED_SYSTEM.EDMA_1_mem_map, C66XX_S.CPU_SYSTEM_6.CGEM_SSI_6.cgem_slave_mif, 0x16F00000, 0x16F07FFF, -0x16000000; //L1D
        CONNECT339        C66XX_S.SHARED_SYSTEM.EDMA_1_mem_map, C66XX_S.CPU_SYSTEM_7.CGEM_SSI_7.cgem_slave_mif, 0x17800000, 0x1787FFFF, -0x17000000; //L2
        CONNECT340        C66XX_S.SHARED_SYSTEM.EDMA_1_mem_map, C66XX_S.CPU_SYSTEM_7.CGEM_SSI_7.cgem_slave_mif, 0x17E00000, 0x17E07FFF, -0x17000000; //L1P
        CONNECT341        C66XX_S.SHARED_SYSTEM.EDMA_1_mem_map, C66XX_S.CPU_SYSTEM_7.CGEM_SSI_7.cgem_slave_mif, 0x17F00000, 0x17F07FFF, -0x17000000; //L1D
       // L1/L2 MEM connections with EDMA mem map
        CONNECT342        C66XX_S.SHARED_SYSTEM.EDMA_2_mem_map, C66XX_S.CPU_SYSTEM_0.CGEM_SSI_0.cgem_slave_mif, 0x10800000, 0x1087FFFF, -0x10000000; //L2
        CONNECT343        C66XX_S.SHARED_SYSTEM.EDMA_2_mem_map, C66XX_S.CPU_SYSTEM_0.CGEM_SSI_0.cgem_slave_mif, 0x10E00000, 0x10E07FFF, -0x10000000; //L1P
        CONNECT344        C66XX_S.SHARED_SYSTEM.EDMA_2_mem_map, C66XX_S.CPU_SYSTEM_0.CGEM_SSI_0.cgem_slave_mif, 0x10F00000, 0x10F07FFF, -0x10000000; //L1D
        CONNECT345        C66XX_S.SHARED_SYSTEM.EDMA_2_mem_map, C66XX_S.CPU_SYSTEM_1.CGEM_SSI_1.cgem_slave_mif, 0x11800000, 0x1187FFFF, -0x11000000; //L2
        CONNECT346        C66XX_S.SHARED_SYSTEM.EDMA_2_mem_map, C66XX_S.CPU_SYSTEM_1.CGEM_SSI_1.cgem_slave_mif, 0x11E00000, 0x11E07FFF, -0x11000000; //L1P
        CONNECT347        C66XX_S.SHARED_SYSTEM.EDMA_2_mem_map, C66XX_S.CPU_SYSTEM_1.CGEM_SSI_1.cgem_slave_mif, 0x11F00000, 0x11F07FFF, -0x11000000; //L1D
        CONNECT348        C66XX_S.SHARED_SYSTEM.EDMA_2_mem_map, C66XX_S.CPU_SYSTEM_2.CGEM_SSI_2.cgem_slave_mif, 0x12800000, 0x1287FFFF, -0x12000000; //L2
        CONNECT349        C66XX_S.SHARED_SYSTEM.EDMA_2_mem_map, C66XX_S.CPU_SYSTEM_2.CGEM_SSI_2.cgem_slave_mif, 0x12E00000, 0x12E07FFF, -0x12000000; //L1P
        CONNECT350        C66XX_S.SHARED_SYSTEM.EDMA_2_mem_map, C66XX_S.CPU_SYSTEM_2.CGEM_SSI_2.cgem_slave_mif, 0x12F00000, 0x12F07FFF, -0x12000000; //L1D
        CONNECT351        C66XX_S.SHARED_SYSTEM.EDMA_2_mem_map, C66XX_S.CPU_SYSTEM_3.CGEM_SSI_3.cgem_slave_mif, 0x13800000, 0x1387FFFF, -0x13000000; //L2
        CONNECT352        C66XX_S.SHARED_SYSTEM.EDMA_2_mem_map, C66XX_S.CPU_SYSTEM_3.CGEM_SSI_3.cgem_slave_mif, 0x13E00000, 0x13E07FFF, -0x13000000; //L1P
        CONNECT353        C66XX_S.SHARED_SYSTEM.EDMA_2_mem_map, C66XX_S.CPU_SYSTEM_3.CGEM_SSI_3.cgem_slave_mif, 0x13F00000, 0x13F07FFF, -0x13000000; //L1D
        CONNECT354        C66XX_S.SHARED_SYSTEM.EDMA_2_mem_map, C66XX_S.CPU_SYSTEM_4.CGEM_SSI_4.cgem_slave_mif, 0x14800000, 0x1487FFFF, -0x14000000; //L2
        CONNECT355        C66XX_S.SHARED_SYSTEM.EDMA_2_mem_map, C66XX_S.CPU_SYSTEM_4.CGEM_SSI_4.cgem_slave_mif, 0x14E00000, 0x14E07FFF, -0x14000000; //L1P
        CONNECT356        C66XX_S.SHARED_SYSTEM.EDMA_2_mem_map, C66XX_S.CPU_SYSTEM_4.CGEM_SSI_4.cgem_slave_mif, 0x14F00000, 0x14F07FFF, -0x14000000; //L1D
        CONNECT357        C66XX_S.SHARED_SYSTEM.EDMA_2_mem_map, C66XX_S.CPU_SYSTEM_5.CGEM_SSI_5.cgem_slave_mif, 0x15800000, 0x1587FFFF, -0x15000000; //L2
        CONNECT358        C66XX_S.SHARED_SYSTEM.EDMA_2_mem_map, C66XX_S.CPU_SYSTEM_5.CGEM_SSI_5.cgem_slave_mif, 0x15E00000, 0x15E07FFF, -0x15000000; //L1P
        CONNECT359        C66XX_S.SHARED_SYSTEM.EDMA_2_mem_map, C66XX_S.CPU_SYSTEM_5.CGEM_SSI_5.cgem_slave_mif, 0x15F00000, 0x15F07FFF, -0x15000000; //L1D
        CONNECT360        C66XX_S.SHARED_SYSTEM.EDMA_2_mem_map, C66XX_S.CPU_SYSTEM_6.CGEM_SSI_6.cgem_slave_mif, 0x16800000, 0x1687FFFF, -0x16000000; //L2
        CONNECT361        C66XX_S.SHARED_SYSTEM.EDMA_2_mem_map, C66XX_S.CPU_SYSTEM_6.CGEM_SSI_6.cgem_slave_mif, 0x16E00000, 0x16E07FFF, -0x16000000; //L1P
        CONNECT362        C66XX_S.SHARED_SYSTEM.EDMA_2_mem_map, C66XX_S.CPU_SYSTEM_6.CGEM_SSI_6.cgem_slave_mif, 0x16F00000, 0x16F07FFF, -0x16000000; //L1D
        CONNECT363        C66XX_S.SHARED_SYSTEM.EDMA_2_mem_map, C66XX_S.CPU_SYSTEM_7.CGEM_SSI_7.cgem_slave_mif, 0x17800000, 0x1787FFFF, -0x17000000; //L2
        CONNECT364        C66XX_S.SHARED_SYSTEM.EDMA_2_mem_map, C66XX_S.CPU_SYSTEM_7.CGEM_SSI_7.cgem_slave_mif, 0x17E00000, 0x17E07FFF, -0x17000000; //L1P
        CONNECT365        C66XX_S.SHARED_SYSTEM.EDMA_2_mem_map, C66XX_S.CPU_SYSTEM_7.CGEM_SSI_7.cgem_slave_mif, 0x17F00000, 0x17F07FFF, -0x17000000; //L1D
        // SEMAPHORE connections to with EDMA mem_map( through MEMTR)
        CONNECT366        C66XX_S.SHARED_SYSTEM.EDMA_0_mem_map, C66XX_S.SHARED_SYSTEM.MEMTR_SEMAPHORE_Config.MT_MIF2SSI.memtr_mif_opin, 0x02640000, 0x026407FF, 0;
        CONNECT367        C66XX_S.SHARED_SYSTEM.EDMA_1_mem_map, C66XX_S.SHARED_SYSTEM.MEMTR_SEMAPHORE_Config.MT_MIF2SSI.memtr_mif_opin, 0x02640000, 0x026407FF, 0;
        CONNECT368        C66XX_S.SHARED_SYSTEM.EDMA_2_mem_map, C66XX_S.SHARED_SYSTEM.MEMTR_SEMAPHORE_Config.MT_MIF2SSI.memtr_mif_opin, 0x02640000, 0x026407FF, 0;
        //IPC connections with EDMA mem_map
        CONNECT369        C66XX_S.SHARED_SYSTEM.EDMA_0_mem_map, C66XX_S.SHARED_SYSTEM.MEMTR_IPC_Config.MT_MIF2SSI.memtr_mif_opin, 0x02620200, 0x0262029F, -0x02620200;
        CONNECT370        C66XX_S.SHARED_SYSTEM.EDMA_1_mem_map, C66XX_S.SHARED_SYSTEM.MEMTR_IPC_Config.MT_MIF2SSI.memtr_mif_opin, 0x02620200, 0x0262029F, -0x02620200;
        CONNECT371        C66XX_S.SHARED_SYSTEM.EDMA_2_mem_map, C66XX_S.SHARED_SYSTEM.MEMTR_IPC_Config.MT_MIF2SSI.memtr_mif_opin, 0x02620200, 0x0262029F, -0x02620200;
        // GPIO connections with EDMA mem_map( through MIF_TO_FUNC)
        CONNECT372        C66XX_S.SHARED_SYSTEM.EDMA_0_mem_map, C66XX_S.SHARED_SYSTEM.MEMTR_GPIO_Config.MT_MIF2SSI.memtr_mif_opin, 0x02320000, 0x023200FF, -0x02320000;
        CONNECT373        C66XX_S.SHARED_SYSTEM.EDMA_1_mem_map, C66XX_S.SHARED_SYSTEM.MEMTR_GPIO_Config.MT_MIF2SSI.memtr_mif_opin, 0x02320000, 0x023200FF, -0x02320000;
        CONNECT374        C66XX_S.SHARED_SYSTEM.EDMA_2_mem_map, C66XX_S.SHARED_SYSTEM.MEMTR_GPIO_Config.MT_MIF2SSI.memtr_mif_opin, 0x02320000, 0x023200FF, -0x02320000;
        // QM connections with EDMA mem_map( through MEMTR)
        CONNECT375        C66XX_S.SHARED_SYSTEM.EDMA_0_mem_map, C66XX_S.SHARED_SYSTEM.MEMTR_QM_Config.MT_MIF2SSI.memtr_mif_opin, 0x02a00000, 0x02AABFFF, -0x02A00000;
        CONNECT376        C66XX_S.SHARED_SYSTEM.EDMA_0_mem_map, C66XX_S.SHARED_SYSTEM.MEMTR_QM_PDSP_Command.MT_MIF2SSI.memtr_mif_opin, 0x02ab8000, 0x02abdFFF, -0x02A00000;
    //    CONNECT440        C66XX_S.SHARED_SYSTEM.EDMA_0_mem_map, C66XX_S.SHARED_SYSTEM.MEMTR_QM_High_Accumulator.MT_MIF2SSI.memtr_mif_opin, 0x02FFFFFF, 0x02FFFFFF, -0x02A00000; //not used!
        CONNECT377        C66XX_S.SHARED_SYSTEM.EDMA_1_mem_map, C66XX_S.SHARED_SYSTEM.MEMTR_QM_Config.MT_MIF2SSI.memtr_mif_opin, 0x02A00000, 0x02AABFFF, -0x02A00000;
        CONNECT378        C66XX_S.SHARED_SYSTEM.EDMA_1_mem_map, C66XX_S.SHARED_SYSTEM.MEMTR_QM_PDSP_Command.MT_MIF2SSI.memtr_mif_opin, 0x02AB8000, 0x02ABDFFF, -0x02A00000;
    //    CONNECT443        C66XX_S.SHARED_SYSTEM.EDMA_1_mem_map, C66XX_S.SHARED_SYSTEM.MEMTR_QM_High_Accumulator.MT_MIF2SSI.memtr_mif_opin, 0x02FFFFFF, 0x02FFFFFF, -0x02A00000; //not used!
        CONNECT379        C66XX_S.SHARED_SYSTEM.EDMA_2_mem_map, C66XX_S.SHARED_SYSTEM.MEMTR_QM_Config.MT_MIF2SSI.memtr_mif_opin, 0x02A00000, 0x02AABFFF, -0x02A00000;
        CONNECT380        C66XX_S.SHARED_SYSTEM.EDMA_2_mem_map, C66XX_S.SHARED_SYSTEM.MEMTR_QM_PDSP_Command.MT_MIF2SSI.memtr_mif_opin, 0x02ab8000, 0x02abdFFF, -0x02A00000;
    //    CONNECT446        C66XX_S.SHARED_SYSTEM.EDMA_2_mem_map, C66XX_S.SHARED_SYSTEM.MEMTR_QM_High_Accumulator.MT_MIF2SSI.memtr_mif_opin, 0x02FFFFFF, 0x02FFFFFF, -0x02A00000; //not used!
        //CDMA_INFRA connections with EDMA mem_map( through MEMTR)
        CONNECT381        C66XX_S.SHARED_SYSTEM.EDMA_0_mem_map, C66XX_S.SHARED_SYSTEM.MEMTR_CDMA_INFRA_Config.MT_MIF2SSI.memtr_mif_opin, 0x02A6C000, 0x02A6DFFF, -0x02A00000;
        CONNECT382        C66XX_S.SHARED_SYSTEM.EDMA_1_mem_map, C66XX_S.SHARED_SYSTEM.MEMTR_CDMA_INFRA_Config.MT_MIF2SSI.memtr_mif_opin, 0x02A6C000, 0x02A6DFFF, -0x02A00000;
        CONNECT383        C66XX_S.SHARED_SYSTEM.EDMA_2_mem_map, C66XX_S.SHARED_SYSTEM.MEMTR_CDMA_INFRA_Config.MT_MIF2SSI.memtr_mif_opin, 0x02A6C000, 0x02A6DFFF, -0x02A00000;
        //SRIO connections with EDMA mem_map
        CONNECT384        C66XX_S.SHARED_SYSTEM.EDMA_0_mem_map, C66XX_S.SHARED_SYSTEM.MEMTR_SRIO_Config.MT_MIF2SSI.memtr_mif_opin, 0x02900000, 0x02900FFF, 0;
        CONNECT385        C66XX_S.SHARED_SYSTEM.EDMA_0_mem_map, C66XX_S.SHARED_SYSTEM.MEMTR_SRIO_Slave.MT_MIF2SSI.memtr_mif_opin, 0x50000000, 0x5FFFFFFF, 0;
        CONNECT386        C66XX_S.SHARED_SYSTEM.EDMA_1_mem_map, C66XX_S.SHARED_SYSTEM.MEMTR_SRIO_Config.MT_MIF2SSI.memtr_mif_opin, 0x02900000, 0x02900FFF, 0;
        CONNECT387        C66XX_S.SHARED_SYSTEM.EDMA_1_mem_map, C66XX_S.SHARED_SYSTEM.MEMTR_SRIO_Slave.MT_MIF2SSI.memtr_mif_opin, 0x50000000, 0x5FFFFFFF, 0;
        CONNECT388        C66XX_S.SHARED_SYSTEM.EDMA_2_mem_map, C66XX_S.SHARED_SYSTEM.MEMTR_SRIO_Config.MT_MIF2SSI.memtr_mif_opin, 0x02900000, 0x02900FFF, 0;
        CONNECT389        C66XX_S.SHARED_SYSTEM.EDMA_2_mem_map, C66XX_S.SHARED_SYSTEM.MEMTR_SRIO_Slave.MT_MIF2SSI.memtr_mif_opin, 0x50000000, 0x5FFFFFFF, 0;
        //CDMA_SRIO connections with EDMA mem_map
        CONNECT390        C66XX_S.SHARED_SYSTEM.EDMA_0_mem_map, C66XX_S.SHARED_SYSTEM.MEMTR_CDMA_SRIO_Config.MT_MIF2SSI.memtr_mif_opin, 0x02901000, 0x02920FFF, -0x02900000;
        CONNECT391        C66XX_S.SHARED_SYSTEM.EDMA_1_mem_map, C66XX_S.SHARED_SYSTEM.MEMTR_CDMA_SRIO_Config.MT_MIF2SSI.memtr_mif_opin, 0x02901000, 0x02920FFF, -0x02900000;
        CONNECT392        C66XX_S.SHARED_SYSTEM.EDMA_2_mem_map, C66XX_S.SHARED_SYSTEM.MEMTR_CDMA_SRIO_Config.MT_MIF2SSI.memtr_mif_opin, 0x02901000, 0x02920FFF, -0x02900000;
        //SRIO TUNDRA
        CONNECT393        C66XX_S.SHARED_SYSTEM.EDMA_0_mem_map, C66XX_S.SHARED_SYSTEM.FLATMEM_36BIT.mem36_mif, 0x0290B000, 0x0291BE4C, 0; //<CHECK>
        CONNECT394        C66XX_S.SHARED_SYSTEM.EDMA_1_mem_map, C66XX_S.SHARED_SYSTEM.FLATMEM_36BIT.mem36_mif, 0x0290B000, 0x0291BE4C, 0; //<CHECK>
        CONNECT395        C66XX_S.SHARED_SYSTEM.EDMA_2_mem_map, C66XX_S.SHARED_SYSTEM.FLATMEM_36BIT.mem36_mif, 0x0290B000, 0x0291BE4C, 0; //<CHECK>
        //SWITCHSS connections with EDMA mem_map
        CONNECT396        C66XX_S.SHARED_SYSTEM.EDMA_0_mem_map, C66XX_S.SHARED_SYSTEM.MEMTR_SWITCHSS_Config.MT_MIF2SSI.memtr_mif_opin, 0x02090000, 0x0209FFFF, -0x02090000; //actual end-0x02090FFF, giving relative address
        CONNECT397        C66XX_S.SHARED_SYSTEM.EDMA_1_mem_map, C66XX_S.SHARED_SYSTEM.MEMTR_SWITCHSS_Config.MT_MIF2SSI.memtr_mif_opin, 0x02090000, 0x0209FFFF, -0x02090000; //actual end-0x02090FFF, giving relative address
        CONNECT398        C66XX_S.SHARED_SYSTEM.EDMA_2_mem_map, C66XX_S.SHARED_SYSTEM.MEMTR_SWITCHSS_Config.MT_MIF2SSI.memtr_mif_opin, 0x02090000, 0x0209FFFF, -0x02090000; //actual end-0x02090FFF, giving relative address
        //SWITCHSS SERDES connections with EDMA mem_map
        CONNECT399        C66XX_S.SHARED_SYSTEM.EDMA_0_mem_map, C66XX_S.SHARED_SYSTEM.MEMTR_SWITCHSS_SERDES_Config.MT_MIF2SSI.memtr_mif_opin, 0x02620340, 0x02620357, -0x02620000; //actual end-0x02090FFF, giving relative address
        CONNECT400        C66XX_S.SHARED_SYSTEM.EDMA_1_mem_map, C66XX_S.SHARED_SYSTEM.MEMTR_SWITCHSS_SERDES_Config.MT_MIF2SSI.memtr_mif_opin, 0x02620340, 0x02620357, -0x02620000; //actual end-0x02090FFF, giving relative address
        CONNECT401        C66XX_S.SHARED_SYSTEM.EDMA_2_mem_map, C66XX_S.SHARED_SYSTEM.MEMTR_SWITCHSS_SERDES_Config.MT_MIF2SSI.memtr_mif_opin, 0x02620340, 0x02620357, -0x02620000; //actual end-0x02090FFF, giving relative address
        //PASS connections with EDMA mem_map
        CONNECT402        C66XX_S.SHARED_SYSTEM.EDMA_0_mem_map, C66XX_S.SHARED_SYSTEM.MIF_TO_FUNC_PASS.MT_MIF2SSI.memtr_mif_opin, 0x02000000, 0x02003FFF, -0x02000000;
        CONNECT403        C66XX_S.SHARED_SYSTEM.EDMA_0_mem_map, C66XX_S.SHARED_SYSTEM.MIF_TO_FUNC_PASS.MT_MIF2SSI.memtr_mif_opin, 0x02006000, 0x0207FFFF, -0x02000000;
        CONNECT404        C66XX_S.SHARED_SYSTEM.EDMA_1_mem_map, C66XX_S.SHARED_SYSTEM.MIF_TO_FUNC_PASS.MT_MIF2SSI.memtr_mif_opin, 0x02000000, 0x02003FFF, -0x02000000;
        CONNECT405        C66XX_S.SHARED_SYSTEM.EDMA_1_mem_map, C66XX_S.SHARED_SYSTEM.MIF_TO_FUNC_PASS.MT_MIF2SSI.memtr_mif_opin, 0x02006000, 0x0207FFFF, -0x02000000;
        CONNECT406        C66XX_S.SHARED_SYSTEM.EDMA_2_mem_map, C66XX_S.SHARED_SYSTEM.MIF_TO_FUNC_PASS.MT_MIF2SSI.memtr_mif_opin, 0x02000000, 0x02003FFF, -0x02000000;
        CONNECT407        C66XX_S.SHARED_SYSTEM.EDMA_2_mem_map, C66XX_S.SHARED_SYSTEM.MIF_TO_FUNC_PASS.MT_MIF2SSI.memtr_mif_opin, 0x02006000, 0x0207FFFF, -0x02000000;
        //CDMA_PASS connections with EDMA mem_map
        CONNECT408        C66XX_S.SHARED_SYSTEM.EDMA_0_mem_map, C66XX_S.SHARED_SYSTEM.MEMTR_CDMA_PASS_Config.MT_MIF2SSI.memtr_mif_opin, 0x02004000, 0x02005FFF, -0x02000000;
        CONNECT409        C66XX_S.SHARED_SYSTEM.EDMA_1_mem_map, C66XX_S.SHARED_SYSTEM.MEMTR_CDMA_PASS_Config.MT_MIF2SSI.memtr_mif_opin, 0x02004000, 0x02005FFF, -0x02000000;
        CONNECT410        C66XX_S.SHARED_SYSTEM.EDMA_2_mem_map, C66XX_S.SHARED_SYSTEM.MEMTR_CDMA_PASS_Config.MT_MIF2SSI.memtr_mif_opin, 0x02004000, 0x02005FFF, -0x02000000;
        // PCIE connection with EDMA mem_map
        CONNECT411        C66XX_S.SHARED_SYSTEM.EDMA_0_mem_map, C66XX_S.SHARED_SYSTEM.MEMTR_PCIE_Slave.MT_MIF2SSI.memtr_mif_opin, 0x21800000, 0x21807FFF, 0; //MMR region
        CONNECT412        C66XX_S.SHARED_SYSTEM.EDMA_1_mem_map, C66XX_S.SHARED_SYSTEM.MEMTR_PCIE_Slave.MT_MIF2SSI.memtr_mif_opin, 0x21800000, 0x21807FFF, 0; //MMR region
        CONNECT413        C66XX_S.SHARED_SYSTEM.EDMA_2_mem_map, C66XX_S.SHARED_SYSTEM.MEMTR_PCIE_Slave.MT_MIF2SSI.memtr_mif_opin, 0x21800000, 0x21807FFF, 0; //MMR region
            // SMS and SES MEMTR connections with EDMA mem_map
        //SMS connections
        CONNECT414        C66XX_S.SHARED_SYSTEM.EDMA_0_mem_map, C66XX_S.SHARED_SYSTEM.MEMTR_SMS.MT_MIF2SSI.memtr_mif_opin, 0x0BC00000, 0x0BCFFFFF, 0; //MSMC Config
        CONNECT415        C66XX_S.SHARED_SYSTEM.EDMA_0_mem_map, C66XX_S.SHARED_SYSTEM.MEMTR_SMS.MT_MIF2SSI.memtr_mif_opin, 0x0C000000, 0x0C3FFFFF, 0; //MSMC RAM
        CONNECT416        C66XX_S.SHARED_SYSTEM.EDMA_1_mem_map, C66XX_S.SHARED_SYSTEM.MEMTR_SMS.MT_MIF2SSI.memtr_mif_opin, 0x0BC00000, 0x0BCFFFFF, 0; //MSMC Config
        CONNECT417        C66XX_S.SHARED_SYSTEM.EDMA_1_mem_map, C66XX_S.SHARED_SYSTEM.MEMTR_SMS.MT_MIF2SSI.memtr_mif_opin, 0x0C000000, 0x0C3FFFFF, 0; //MSMC RAM
        CONNECT418        C66XX_S.SHARED_SYSTEM.EDMA_2_mem_map, C66XX_S.SHARED_SYSTEM.MEMTR_SMS.MT_MIF2SSI.memtr_mif_opin, 0x0BC00000, 0x0BCFFFFF, 0; //MSMC Config
        CONNECT419        C66XX_S.SHARED_SYSTEM.EDMA_2_mem_map, C66XX_S.SHARED_SYSTEM.MEMTR_SMS.MT_MIF2SSI.memtr_mif_opin, 0x0C000000, 0x0C3FFFFF, 0; //MSMC RAM
        //SES connections(DDR connections)
        CONNECT420        C66XX_S.SHARED_SYSTEM.EDMA_0_mem_map, C66XX_S.SHARED_SYSTEM.MEMTR_SES.MT_MIF2SSI.memtr_mif_opin, 0x21000000, 0x210000FF, 0;//EMIF
        CONNECT421        C66XX_S.SHARED_SYSTEM.EDMA_0_mem_map, C66XX_S.SHARED_SYSTEM.MEMTR_SES.MT_MIF2SSI.memtr_mif_opin, 0x80000000, 0xFFFFFFFF, 0;//DDR
        CONNECT422        C66XX_S.SHARED_SYSTEM.EDMA_1_mem_map, C66XX_S.SHARED_SYSTEM.MEMTR_SES.MT_MIF2SSI.memtr_mif_opin, 0x21000000, 0x210000FF, 0;//EMIF
        CONNECT423        C66XX_S.SHARED_SYSTEM.EDMA_1_mem_map, C66XX_S.SHARED_SYSTEM.MEMTR_SES.MT_MIF2SSI.memtr_mif_opin, 0x80000000, 0xFFFFFFFF, 0;//DDR
        CONNECT424        C66XX_S.SHARED_SYSTEM.EDMA_2_mem_map, C66XX_S.SHARED_SYSTEM.MEMTR_SES.MT_MIF2SSI.memtr_mif_opin, 0x21000000, 0x210000FF, 0;//EMIF
        CONNECT425        C66XX_S.SHARED_SYSTEM.EDMA_2_mem_map, C66XX_S.SHARED_SYSTEM.MEMTR_SES.MT_MIF2SSI.memtr_mif_opin, 0x80000000, 0xFFFFFFFF, 0;//DDR
        //QM_Accumulator Memory Map connections
        // 32BIT mif connections with QM_Accumulator Master mem_map
        CONNECT426        C66XX_S.SHARED_SYSTEM.MEMTR_QM_PDSP_Master.MT_SSI2MMAP.memtr_mmap_ipin, C66XX_S.SHARED_SYSTEM.FLATMEM_36BIT.mem36_mif, 0, 0xFFFFFFFF, 0;
        // L1/L2 MEM connections with QM_Accumulator Master mem_map
        CONNECT427        C66XX_S.SHARED_SYSTEM.MEMTR_QM_PDSP_Master.MT_SSI2MMAP.memtr_mmap_ipin, C66XX_S.CPU_SYSTEM_0.CGEM_SSI_0.cgem_slave_mif, 0x10800000, 0x1087FFFF, -0x10000000; //L2
        CONNECT428        C66XX_S.SHARED_SYSTEM.MEMTR_QM_PDSP_Master.MT_SSI2MMAP.memtr_mmap_ipin, C66XX_S.CPU_SYSTEM_0.CGEM_SSI_0.cgem_slave_mif, 0x10E00000, 0x10E07FFF, -0x10000000; //L1P
        CONNECT429        C66XX_S.SHARED_SYSTEM.MEMTR_QM_PDSP_Master.MT_SSI2MMAP.memtr_mmap_ipin, C66XX_S.CPU_SYSTEM_0.CGEM_SSI_0.cgem_slave_mif, 0x10F00000, 0x10F07FFF, -0x10000000; //L1D
        CONNECT430        C66XX_S.SHARED_SYSTEM.MEMTR_QM_PDSP_Master.MT_SSI2MMAP.memtr_mmap_ipin, C66XX_S.CPU_SYSTEM_1.CGEM_SSI_1.cgem_slave_mif, 0x11800000, 0x1187FFFF, -0x11000000; //L2
        CONNECT431        C66XX_S.SHARED_SYSTEM.MEMTR_QM_PDSP_Master.MT_SSI2MMAP.memtr_mmap_ipin, C66XX_S.CPU_SYSTEM_1.CGEM_SSI_1.cgem_slave_mif, 0x11E00000, 0x11E07FFF, -0x11000000; //L1P
        CONNECT432        C66XX_S.SHARED_SYSTEM.MEMTR_QM_PDSP_Master.MT_SSI2MMAP.memtr_mmap_ipin, C66XX_S.CPU_SYSTEM_1.CGEM_SSI_1.cgem_slave_mif, 0x11F00000, 0x11F07FFF, -0x11000000; //L1D
        CONNECT433        C66XX_S.SHARED_SYSTEM.MEMTR_QM_PDSP_Master.MT_SSI2MMAP.memtr_mmap_ipin, C66XX_S.CPU_SYSTEM_2.CGEM_SSI_2.cgem_slave_mif, 0x12800000, 0x1287FFFF, -0x12000000; //L2
        CONNECT434        C66XX_S.SHARED_SYSTEM.MEMTR_QM_PDSP_Master.MT_SSI2MMAP.memtr_mmap_ipin, C66XX_S.CPU_SYSTEM_2.CGEM_SSI_2.cgem_slave_mif, 0x12E00000, 0x12E07FFF, -0x12000000; //L1P
        CONNECT435        C66XX_S.SHARED_SYSTEM.MEMTR_QM_PDSP_Master.MT_SSI2MMAP.memtr_mmap_ipin, C66XX_S.CPU_SYSTEM_2.CGEM_SSI_2.cgem_slave_mif, 0x12F00000, 0x12F07FFF, -0x12000000; //L1D
        CONNECT436        C66XX_S.SHARED_SYSTEM.MEMTR_QM_PDSP_Master.MT_SSI2MMAP.memtr_mmap_ipin, C66XX_S.CPU_SYSTEM_3.CGEM_SSI_3.cgem_slave_mif, 0x13800000, 0x1387FFFF, -0x13000000; //L2
        CONNECT437        C66XX_S.SHARED_SYSTEM.MEMTR_QM_PDSP_Master.MT_SSI2MMAP.memtr_mmap_ipin, C66XX_S.CPU_SYSTEM_3.CGEM_SSI_3.cgem_slave_mif, 0x13E00000, 0x13E07FFF, -0x13000000; //L1P
        CONNECT438        C66XX_S.SHARED_SYSTEM.MEMTR_QM_PDSP_Master.MT_SSI2MMAP.memtr_mmap_ipin, C66XX_S.CPU_SYSTEM_3.CGEM_SSI_3.cgem_slave_mif, 0x13F00000, 0x13F07FFF, -0x13000000; //L1D
        CONNECT439        C66XX_S.SHARED_SYSTEM.MEMTR_QM_PDSP_Master.MT_SSI2MMAP.memtr_mmap_ipin, C66XX_S.CPU_SYSTEM_4.CGEM_SSI_4.cgem_slave_mif, 0x14800000, 0x1487FFFF, -0x14000000; //L2
        CONNECT440        C66XX_S.SHARED_SYSTEM.MEMTR_QM_PDSP_Master.MT_SSI2MMAP.memtr_mmap_ipin, C66XX_S.CPU_SYSTEM_4.CGEM_SSI_4.cgem_slave_mif, 0x14E00000, 0x14E07FFF, -0x14000000; //L1P
        CONNECT441        C66XX_S.SHARED_SYSTEM.MEMTR_QM_PDSP_Master.MT_SSI2MMAP.memtr_mmap_ipin, C66XX_S.CPU_SYSTEM_4.CGEM_SSI_4.cgem_slave_mif, 0x14F00000, 0x14F07FFF, -0x14000000; //L1D
        CONNECT442        C66XX_S.SHARED_SYSTEM.MEMTR_QM_PDSP_Master.MT_SSI2MMAP.memtr_mmap_ipin, C66XX_S.CPU_SYSTEM_5.CGEM_SSI_5.cgem_slave_mif, 0x15800000, 0x1587FFFF, -0x15000000; //L2
        CONNECT443        C66XX_S.SHARED_SYSTEM.MEMTR_QM_PDSP_Master.MT_SSI2MMAP.memtr_mmap_ipin, C66XX_S.CPU_SYSTEM_5.CGEM_SSI_5.cgem_slave_mif, 0x15E00000, 0x15E07FFF, -0x15000000; //L1P
        CONNECT444        C66XX_S.SHARED_SYSTEM.MEMTR_QM_PDSP_Master.MT_SSI2MMAP.memtr_mmap_ipin, C66XX_S.CPU_SYSTEM_5.CGEM_SSI_5.cgem_slave_mif, 0x15F00000, 0x15F07FFF, -0x15000000; //L1D
        CONNECT445        C66XX_S.SHARED_SYSTEM.MEMTR_QM_PDSP_Master.MT_SSI2MMAP.memtr_mmap_ipin, C66XX_S.CPU_SYSTEM_6.CGEM_SSI_6.cgem_slave_mif, 0x16800000, 0x1687FFFF, -0x16000000; //L2
        CONNECT446        C66XX_S.SHARED_SYSTEM.MEMTR_QM_PDSP_Master.MT_SSI2MMAP.memtr_mmap_ipin, C66XX_S.CPU_SYSTEM_6.CGEM_SSI_6.cgem_slave_mif, 0x16E00000, 0x16E07FFF, -0x16000000; //L1P
        CONNECT447        C66XX_S.SHARED_SYSTEM.MEMTR_QM_PDSP_Master.MT_SSI2MMAP.memtr_mmap_ipin, C66XX_S.CPU_SYSTEM_6.CGEM_SSI_6.cgem_slave_mif, 0x16F00000, 0x16F07FFF, -0x16000000; //L1D
        CONNECT448        C66XX_S.SHARED_SYSTEM.MEMTR_QM_PDSP_Master.MT_SSI2MMAP.memtr_mmap_ipin, C66XX_S.CPU_SYSTEM_7.CGEM_SSI_7.cgem_slave_mif, 0x17800000, 0x1787FFFF, -0x17000000; //L2
        CONNECT449        C66XX_S.SHARED_SYSTEM.MEMTR_QM_PDSP_Master.MT_SSI2MMAP.memtr_mmap_ipin, C66XX_S.CPU_SYSTEM_7.CGEM_SSI_7.cgem_slave_mif, 0x17E00000, 0x17E07FFF, -0x17000000; //L1P
        CONNECT450        C66XX_S.SHARED_SYSTEM.MEMTR_QM_PDSP_Master.MT_SSI2MMAP.memtr_mmap_ipin, C66XX_S.CPU_SYSTEM_7.CGEM_SSI_7.cgem_slave_mif, 0x17F00000, 0x17F07FFF, -0x17000000; //L1D
            // SMS and SES MEMTR connections with QM_Accumulator Master mem_map
        //SMS connections
        CONNECT451        C66XX_S.SHARED_SYSTEM.MEMTR_QM_PDSP_Master.MT_SSI2MMAP.memtr_mmap_ipin, C66XX_S.SHARED_SYSTEM.MEMTR_SMS.MT_MIF2SSI.memtr_mif_opin, 0x0BC00000, 0x0BCFFFFF, 0; //MSMC Config
        CONNECT452        C66XX_S.SHARED_SYSTEM.MEMTR_QM_PDSP_Master.MT_SSI2MMAP.memtr_mmap_ipin, C66XX_S.SHARED_SYSTEM.MEMTR_SMS.MT_MIF2SSI.memtr_mif_opin, 0x0C000000, 0x0C3FFFFF, 0; //MSMC RAM
        CONNECT453        C66XX_S.SHARED_SYSTEM.MEMTR_QM_PDSP_Master.MT_SSI2MMAP.memtr_mmap_ipin, C66XX_S.SHARED_SYSTEM.MEMTR_SES.MT_MIF2SSI.memtr_mif_opin, 0x21000000, 0x210000FF, 0; //EMIF
        CONNECT454        C66XX_S.SHARED_SYSTEM.MEMTR_QM_PDSP_Master.MT_SSI2MMAP.memtr_mmap_ipin, C66XX_S.SHARED_SYSTEM.MEMTR_SES.MT_MIF2SSI.memtr_mif_opin, 0x80000000, 0xFFFFFFFF, 0; //DDR
        //PASS Memory Map connections
        // 32BIT mif connections with PASS Master mem_map
        CONNECT455        C66XX_S.SHARED_SYSTEM.MEMTR_PASS_Master.MT_SSI2MMAP.memtr_mmap_ipin, C66XX_S.SHARED_SYSTEM.FLATMEM_36BIT.mem36_mif, 0, 0xFFFFFFFF, 0;
        // L1/L2 connections with PASS Master mem_map
        CONNECT456        C66XX_S.SHARED_SYSTEM.MEMTR_PASS_Master.MT_SSI2MMAP.memtr_mmap_ipin, C66XX_S.CPU_SYSTEM_0.CGEM_SSI_0.cgem_slave_mif, 0x10800000, 0x1087FFFF, -0x10000000; //L2
        CONNECT457        C66XX_S.SHARED_SYSTEM.MEMTR_PASS_Master.MT_SSI2MMAP.memtr_mmap_ipin, C66XX_S.CPU_SYSTEM_0.CGEM_SSI_0.cgem_slave_mif, 0x10E00000, 0x10E07FFF, -0x10000000; //L1P
        CONNECT458        C66XX_S.SHARED_SYSTEM.MEMTR_PASS_Master.MT_SSI2MMAP.memtr_mmap_ipin, C66XX_S.CPU_SYSTEM_0.CGEM_SSI_0.cgem_slave_mif, 0x10F00000, 0x10F07FFF, -0x10000000; //L1D
        CONNECT459        C66XX_S.SHARED_SYSTEM.MEMTR_PASS_Master.MT_SSI2MMAP.memtr_mmap_ipin, C66XX_S.CPU_SYSTEM_1.CGEM_SSI_1.cgem_slave_mif, 0x11800000, 0x1187FFFF, -0x11000000; //L2
        CONNECT460        C66XX_S.SHARED_SYSTEM.MEMTR_PASS_Master.MT_SSI2MMAP.memtr_mmap_ipin, C66XX_S.CPU_SYSTEM_1.CGEM_SSI_1.cgem_slave_mif, 0x11E00000, 0x11E07FFF, -0x11000000; //L1P
        CONNECT461        C66XX_S.SHARED_SYSTEM.MEMTR_PASS_Master.MT_SSI2MMAP.memtr_mmap_ipin, C66XX_S.CPU_SYSTEM_1.CGEM_SSI_1.cgem_slave_mif, 0x11F00000, 0x11F07FFF, -0x11000000; //L1D
        CONNECT462        C66XX_S.SHARED_SYSTEM.MEMTR_PASS_Master.MT_SSI2MMAP.memtr_mmap_ipin, C66XX_S.CPU_SYSTEM_2.CGEM_SSI_2.cgem_slave_mif, 0x12800000, 0x1287FFFF, -0x12000000; //L2
        CONNECT463        C66XX_S.SHARED_SYSTEM.MEMTR_PASS_Master.MT_SSI2MMAP.memtr_mmap_ipin, C66XX_S.CPU_SYSTEM_2.CGEM_SSI_2.cgem_slave_mif, 0x12E00000, 0x12E07FFF, -0x12000000; //L1P
        CONNECT464        C66XX_S.SHARED_SYSTEM.MEMTR_PASS_Master.MT_SSI2MMAP.memtr_mmap_ipin, C66XX_S.CPU_SYSTEM_2.CGEM_SSI_2.cgem_slave_mif, 0x12F00000, 0x12F07FFF, -0x12000000; //L1D
        CONNECT465        C66XX_S.SHARED_SYSTEM.MEMTR_PASS_Master.MT_SSI2MMAP.memtr_mmap_ipin, C66XX_S.CPU_SYSTEM_3.CGEM_SSI_3.cgem_slave_mif, 0x13800000, 0x1387FFFF, -0x13000000; //L2
        CONNECT466        C66XX_S.SHARED_SYSTEM.MEMTR_PASS_Master.MT_SSI2MMAP.memtr_mmap_ipin, C66XX_S.CPU_SYSTEM_3.CGEM_SSI_3.cgem_slave_mif, 0x13E00000, 0x13E07FFF, -0x13000000; //L1P
        CONNECT467        C66XX_S.SHARED_SYSTEM.MEMTR_PASS_Master.MT_SSI2MMAP.memtr_mmap_ipin, C66XX_S.CPU_SYSTEM_3.CGEM_SSI_3.cgem_slave_mif, 0x13F00000, 0x13F07FFF, -0x13000000; //L1D
        CONNECT468        C66XX_S.SHARED_SYSTEM.MEMTR_PASS_Master.MT_SSI2MMAP.memtr_mmap_ipin, C66XX_S.CPU_SYSTEM_4.CGEM_SSI_4.cgem_slave_mif, 0x14800000, 0x1487FFFF, -0x14000000; //L2
        CONNECT469        C66XX_S.SHARED_SYSTEM.MEMTR_PASS_Master.MT_SSI2MMAP.memtr_mmap_ipin, C66XX_S.CPU_SYSTEM_4.CGEM_SSI_4.cgem_slave_mif, 0x14E00000, 0x14E07FFF, -0x14000000; //L1P
        CONNECT470        C66XX_S.SHARED_SYSTEM.MEMTR_PASS_Master.MT_SSI2MMAP.memtr_mmap_ipin, C66XX_S.CPU_SYSTEM_4.CGEM_SSI_4.cgem_slave_mif, 0x14F00000, 0x14F07FFF, -0x14000000; //L1D
        CONNECT471        C66XX_S.SHARED_SYSTEM.MEMTR_PASS_Master.MT_SSI2MMAP.memtr_mmap_ipin, C66XX_S.CPU_SYSTEM_5.CGEM_SSI_5.cgem_slave_mif, 0x15800000, 0x1587FFFF, -0x15000000; //L2
        CONNECT472        C66XX_S.SHARED_SYSTEM.MEMTR_PASS_Master.MT_SSI2MMAP.memtr_mmap_ipin, C66XX_S.CPU_SYSTEM_5.CGEM_SSI_5.cgem_slave_mif, 0x15E00000, 0x15E07FFF, -0x15000000; //L1P
        CONNECT473        C66XX_S.SHARED_SYSTEM.MEMTR_PASS_Master.MT_SSI2MMAP.memtr_mmap_ipin, C66XX_S.CPU_SYSTEM_5.CGEM_SSI_5.cgem_slave_mif, 0x15F00000, 0x15F07FFF, -0x15000000; //L1D
        CONNECT474        C66XX_S.SHARED_SYSTEM.MEMTR_PASS_Master.MT_SSI2MMAP.memtr_mmap_ipin, C66XX_S.CPU_SYSTEM_6.CGEM_SSI_6.cgem_slave_mif, 0x16800000, 0x1687FFFF, -0x16000000; //L2
        CONNECT475        C66XX_S.SHARED_SYSTEM.MEMTR_PASS_Master.MT_SSI2MMAP.memtr_mmap_ipin, C66XX_S.CPU_SYSTEM_6.CGEM_SSI_6.cgem_slave_mif, 0x16E00000, 0x16E07FFF, -0x16000000; //L1P
        CONNECT476        C66XX_S.SHARED_SYSTEM.MEMTR_PASS_Master.MT_SSI2MMAP.memtr_mmap_ipin, C66XX_S.CPU_SYSTEM_6.CGEM_SSI_6.cgem_slave_mif, 0x16F00000, 0x16F07FFF, -0x16000000; //L1D
        CONNECT477        C66XX_S.SHARED_SYSTEM.MEMTR_PASS_Master.MT_SSI2MMAP.memtr_mmap_ipin, C66XX_S.CPU_SYSTEM_7.CGEM_SSI_7.cgem_slave_mif, 0x17800000, 0x1787FFFF, -0x17000000; //L2
        CONNECT478        C66XX_S.SHARED_SYSTEM.MEMTR_PASS_Master.MT_SSI2MMAP.memtr_mmap_ipin, C66XX_S.CPU_SYSTEM_7.CGEM_SSI_7.cgem_slave_mif, 0x17E00000, 0x17E07FFF, -0x17000000; //L1P
        CONNECT479        C66XX_S.SHARED_SYSTEM.MEMTR_PASS_Master.MT_SSI2MMAP.memtr_mmap_ipin, C66XX_S.CPU_SYSTEM_7.CGEM_SSI_7.cgem_slave_mif, 0x17F00000, 0x17F07FFF, -0x17000000; //L1D
            // SMS and SES MEMTR connections with PASS Master mem_map
        //SMS connections
        CONNECT480        C66XX_S.SHARED_SYSTEM.MEMTR_PASS_Master.MT_SSI2MMAP.memtr_mmap_ipin, C66XX_S.SHARED_SYSTEM.MEMTR_SMS.MT_MIF2SSI.memtr_mif_opin, 0x0BC00000, 0x0BCFFFFF, 0; //MSMC Config
        CONNECT481        C66XX_S.SHARED_SYSTEM.MEMTR_PASS_Master.MT_SSI2MMAP.memtr_mmap_ipin, C66XX_S.SHARED_SYSTEM.MEMTR_SMS.MT_MIF2SSI.memtr_mif_opin, 0x0C000000, 0x0C3FFFFF, 0; //MSMC RAM
        CONNECT482        C66XX_S.SHARED_SYSTEM.MEMTR_PASS_Master.MT_SSI2MMAP.memtr_mmap_ipin, C66XX_S.SHARED_SYSTEM.MEMTR_SES.MT_MIF2SSI.memtr_mif_opin, 0x21000000, 0x210000FF, 0; //EMIF
        CONNECT483        C66XX_S.SHARED_SYSTEM.MEMTR_PASS_Master.MT_SSI2MMAP.memtr_mmap_ipin, C66XX_S.SHARED_SYSTEM.MEMTR_SES.MT_MIF2SSI.memtr_mif_opin, 0x80000000, 0xFFFFFFFF, 0; //DDR
        //CDMA_INFRA Master Memory Map connections
        // 32BIT mif connections with CDMA_INFRA Master mem_map
        CONNECT484        C66XX_S.SHARED_SYSTEM.MEMTR_CDMA_INFRA_Master.MT_SSI2MMAP.memtr_mmap_ipin, C66XX_S.SHARED_SYSTEM.FLATMEM_36BIT.mem36_mif, 0, 0xFFFFFFFF, 0;
        // L1/L2 connections with CDMA_INFRA Master mem_map
        CONNECT485        C66XX_S.SHARED_SYSTEM.MEMTR_CDMA_INFRA_Master.MT_SSI2MMAP.memtr_mmap_ipin, C66XX_S.CPU_SYSTEM_0.CGEM_SSI_0.cgem_slave_mif, 0x10800000, 0x1087FFFF, -0x10000000; //L2
        CONNECT486        C66XX_S.SHARED_SYSTEM.MEMTR_CDMA_INFRA_Master.MT_SSI2MMAP.memtr_mmap_ipin, C66XX_S.CPU_SYSTEM_0.CGEM_SSI_0.cgem_slave_mif, 0x10E00000, 0x10E07FFF, -0x10000000; //L1P
        CONNECT487        C66XX_S.SHARED_SYSTEM.MEMTR_CDMA_INFRA_Master.MT_SSI2MMAP.memtr_mmap_ipin, C66XX_S.CPU_SYSTEM_0.CGEM_SSI_0.cgem_slave_mif, 0x10F00000, 0x10F07FFF, -0x10000000; //L1D
        CONNECT488        C66XX_S.SHARED_SYSTEM.MEMTR_CDMA_INFRA_Master.MT_SSI2MMAP.memtr_mmap_ipin, C66XX_S.CPU_SYSTEM_1.CGEM_SSI_1.cgem_slave_mif, 0x11800000, 0x1187FFFF, -0x11000000; //L2
        CONNECT489        C66XX_S.SHARED_SYSTEM.MEMTR_CDMA_INFRA_Master.MT_SSI2MMAP.memtr_mmap_ipin, C66XX_S.CPU_SYSTEM_1.CGEM_SSI_1.cgem_slave_mif, 0x11E00000, 0x11E07FFF, -0x11000000; //L1P
        CONNECT490        C66XX_S.SHARED_SYSTEM.MEMTR_CDMA_INFRA_Master.MT_SSI2MMAP.memtr_mmap_ipin, C66XX_S.CPU_SYSTEM_1.CGEM_SSI_1.cgem_slave_mif, 0x11F00000, 0x11F07FFF, -0x11000000; //L1D
        CONNECT491        C66XX_S.SHARED_SYSTEM.MEMTR_CDMA_INFRA_Master.MT_SSI2MMAP.memtr_mmap_ipin, C66XX_S.CPU_SYSTEM_2.CGEM_SSI_2.cgem_slave_mif, 0x12800000, 0x1287FFFF, -0x12000000; //L2
        CONNECT492        C66XX_S.SHARED_SYSTEM.MEMTR_CDMA_INFRA_Master.MT_SSI2MMAP.memtr_mmap_ipin, C66XX_S.CPU_SYSTEM_2.CGEM_SSI_2.cgem_slave_mif, 0x12E00000, 0x12E07FFF, -0x12000000; //L1P
        CONNECT493        C66XX_S.SHARED_SYSTEM.MEMTR_CDMA_INFRA_Master.MT_SSI2MMAP.memtr_mmap_ipin, C66XX_S.CPU_SYSTEM_2.CGEM_SSI_2.cgem_slave_mif, 0x12F00000, 0x12F07FFF, -0x12000000; //L1D
        CONNECT494        C66XX_S.SHARED_SYSTEM.MEMTR_CDMA_INFRA_Master.MT_SSI2MMAP.memtr_mmap_ipin, C66XX_S.CPU_SYSTEM_3.CGEM_SSI_3.cgem_slave_mif, 0x13800000, 0x1387FFFF, -0x13000000; //L2
        CONNECT495        C66XX_S.SHARED_SYSTEM.MEMTR_CDMA_INFRA_Master.MT_SSI2MMAP.memtr_mmap_ipin, C66XX_S.CPU_SYSTEM_3.CGEM_SSI_3.cgem_slave_mif, 0x13E00000, 0x13E07FFF, -0x13000000; //L1P
        CONNECT496        C66XX_S.SHARED_SYSTEM.MEMTR_CDMA_INFRA_Master.MT_SSI2MMAP.memtr_mmap_ipin, C66XX_S.CPU_SYSTEM_3.CGEM_SSI_3.cgem_slave_mif, 0x13F00000, 0x13F07FFF, -0x13000000; //L1D
        CONNECT497        C66XX_S.SHARED_SYSTEM.MEMTR_CDMA_INFRA_Master.MT_SSI2MMAP.memtr_mmap_ipin, C66XX_S.CPU_SYSTEM_4.CGEM_SSI_4.cgem_slave_mif, 0x14800000, 0x1487FFFF, -0x14000000; //L2
        CONNECT498        C66XX_S.SHARED_SYSTEM.MEMTR_CDMA_INFRA_Master.MT_SSI2MMAP.memtr_mmap_ipin, C66XX_S.CPU_SYSTEM_4.CGEM_SSI_4.cgem_slave_mif, 0x14E00000, 0x14E07FFF, -0x14000000; //L1P
        CONNECT499        C66XX_S.SHARED_SYSTEM.MEMTR_CDMA_INFRA_Master.MT_SSI2MMAP.memtr_mmap_ipin, C66XX_S.CPU_SYSTEM_4.CGEM_SSI_4.cgem_slave_mif, 0x14F00000, 0x14F07FFF, -0x14000000; //L1D
        CONNECT500        C66XX_S.SHARED_SYSTEM.MEMTR_CDMA_INFRA_Master.MT_SSI2MMAP.memtr_mmap_ipin, C66XX_S.CPU_SYSTEM_5.CGEM_SSI_5.cgem_slave_mif, 0x15800000, 0x1587FFFF, -0x15000000; //L2
        CONNECT501        C66XX_S.SHARED_SYSTEM.MEMTR_CDMA_INFRA_Master.MT_SSI2MMAP.memtr_mmap_ipin, C66XX_S.CPU_SYSTEM_5.CGEM_SSI_5.cgem_slave_mif, 0x15E00000, 0x15E07FFF, -0x15000000; //L1P
        CONNECT502        C66XX_S.SHARED_SYSTEM.MEMTR_CDMA_INFRA_Master.MT_SSI2MMAP.memtr_mmap_ipin, C66XX_S.CPU_SYSTEM_5.CGEM_SSI_5.cgem_slave_mif, 0x15F00000, 0x15F07FFF, -0x15000000; //L1D
        CONNECT503        C66XX_S.SHARED_SYSTEM.MEMTR_CDMA_INFRA_Master.MT_SSI2MMAP.memtr_mmap_ipin, C66XX_S.CPU_SYSTEM_6.CGEM_SSI_6.cgem_slave_mif, 0x16800000, 0x1687FFFF, -0x16000000; //L2
        CONNECT504        C66XX_S.SHARED_SYSTEM.MEMTR_CDMA_INFRA_Master.MT_SSI2MMAP.memtr_mmap_ipin, C66XX_S.CPU_SYSTEM_6.CGEM_SSI_6.cgem_slave_mif, 0x16E00000, 0x16E07FFF, -0x16000000; //L1P
        CONNECT505        C66XX_S.SHARED_SYSTEM.MEMTR_CDMA_INFRA_Master.MT_SSI2MMAP.memtr_mmap_ipin, C66XX_S.CPU_SYSTEM_6.CGEM_SSI_6.cgem_slave_mif, 0x16F00000, 0x16F07FFF, -0x16000000; //L1D
        CONNECT506        C66XX_S.SHARED_SYSTEM.MEMTR_CDMA_INFRA_Master.MT_SSI2MMAP.memtr_mmap_ipin, C66XX_S.CPU_SYSTEM_7.CGEM_SSI_7.cgem_slave_mif, 0x17800000, 0x1787FFFF, -0x17000000; //L2
        CONNECT507        C66XX_S.SHARED_SYSTEM.MEMTR_CDMA_INFRA_Master.MT_SSI2MMAP.memtr_mmap_ipin, C66XX_S.CPU_SYSTEM_7.CGEM_SSI_7.cgem_slave_mif, 0x17E00000, 0x17E07FFF, -0x17000000; //L1P
        CONNECT508        C66XX_S.SHARED_SYSTEM.MEMTR_CDMA_INFRA_Master.MT_SSI2MMAP.memtr_mmap_ipin, C66XX_S.CPU_SYSTEM_7.CGEM_SSI_7.cgem_slave_mif, 0x17F00000, 0x17F07FFF, -0x17000000; //L1D
            // SMS and SES MEMTR connections with CDMA_INFRA Master mem_map
        //SMS connections
        CONNECT509        C66XX_S.SHARED_SYSTEM.MEMTR_CDMA_INFRA_Master.MT_SSI2MMAP.memtr_mmap_ipin, C66XX_S.SHARED_SYSTEM.MEMTR_SMS.MT_MIF2SSI.memtr_mif_opin, 0x0BC00000, 0x0BCFFFFF, 0; //MSMC Config
        CONNECT510        C66XX_S.SHARED_SYSTEM.MEMTR_CDMA_INFRA_Master.MT_SSI2MMAP.memtr_mmap_ipin, C66XX_S.SHARED_SYSTEM.MEMTR_SMS.MT_MIF2SSI.memtr_mif_opin, 0x0C000000, 0x0C3FFFFF, 0; //MSMC RAM
        CONNECT511        C66XX_S.SHARED_SYSTEM.MEMTR_CDMA_INFRA_Master.MT_SSI2MMAP.memtr_mmap_ipin, C66XX_S.SHARED_SYSTEM.MEMTR_SES.MT_MIF2SSI.memtr_mif_opin, 0x21000000, 0x210000FF, 0; //EMIF
        CONNECT512        C66XX_S.SHARED_SYSTEM.MEMTR_CDMA_INFRA_Master.MT_SSI2MMAP.memtr_mmap_ipin, C66XX_S.SHARED_SYSTEM.MEMTR_SES.MT_MIF2SSI.memtr_mif_opin, 0x80000000, 0xFFFFFFFF, 0; //DDR
        // QM_Config connections with CDMA_INFRA Master mem_map
        CONNECT513        C66XX_S.SHARED_SYSTEM.MEMTR_CDMA_INFRA_Master.MT_SSI2MMAP.memtr_mmap_ipin, C66XX_S.SHARED_SYSTEM.MEMTR_QM_DMA_Config.MT_MIF2SSI.memtr_mif_opin, 0x34000000, 0x34063000, -0x34000000;
        CONNECT514        C66XX_S.SHARED_SYSTEM.MEMTR_CDMA_INFRA_Master.MT_SSI2MMAP.memtr_mmap_ipin, C66XX_S.SHARED_SYSTEM.MEMTR_QM_PDSP_Command.MT_MIF2SSI.memtr_mif_opin, 0x02AB8000, 0x02ABDFFF, -0x02A00000;
    //    CONNECT599        C66XX_S.SHARED_SYSTEM.MEMTR_CDMA_INFRA_Master.MT_SSI2MMAP.memtr_mmap_ipin, C66XX_S.SHARED_SYSTEM.MEMTR_QM_High_Accumulator.MT_MIF2SSI.memtr_mif_opin, 0x02FFFFFF, 0x02FFFFFF, -0x02A00000; //not used!
        //CDMA_SRIO Master Memory Map connections
        // 32BIT mif connections with CDMA_SRIO Master mem_map
        CONNECT515        C66XX_S.SHARED_SYSTEM.MEMTR_CDMA_SRIO_Master.MT_SSI2MMAP.memtr_mmap_ipin, C66XX_S.SHARED_SYSTEM.FLATMEM_36BIT.mem36_mif, 0, 0xFFFFFFFF, 0;
        // L1/L2 connections with CDMA_SRIO Master mem_map
        CONNECT516        C66XX_S.SHARED_SYSTEM.MEMTR_CDMA_SRIO_Master.MT_SSI2MMAP.memtr_mmap_ipin, C66XX_S.CPU_SYSTEM_0.CGEM_SSI_0.cgem_slave_mif, 0x10800000, 0x1087FFFF, -0x10000000; //L2
        CONNECT517        C66XX_S.SHARED_SYSTEM.MEMTR_CDMA_SRIO_Master.MT_SSI2MMAP.memtr_mmap_ipin, C66XX_S.CPU_SYSTEM_0.CGEM_SSI_0.cgem_slave_mif, 0x10E00000, 0x10E07FFF, -0x10000000; //L1P
        CONNECT518        C66XX_S.SHARED_SYSTEM.MEMTR_CDMA_SRIO_Master.MT_SSI2MMAP.memtr_mmap_ipin, C66XX_S.CPU_SYSTEM_0.CGEM_SSI_0.cgem_slave_mif, 0x10F00000, 0x10F07FFF, -0x10000000; //L1D
        CONNECT519        C66XX_S.SHARED_SYSTEM.MEMTR_CDMA_SRIO_Master.MT_SSI2MMAP.memtr_mmap_ipin, C66XX_S.CPU_SYSTEM_1.CGEM_SSI_1.cgem_slave_mif, 0x11800000, 0x1187FFFF, -0x11000000; //L2
        CONNECT520        C66XX_S.SHARED_SYSTEM.MEMTR_CDMA_SRIO_Master.MT_SSI2MMAP.memtr_mmap_ipin, C66XX_S.CPU_SYSTEM_1.CGEM_SSI_1.cgem_slave_mif, 0x11E00000, 0x11E07FFF, -0x11000000; //L1P
        CONNECT521        C66XX_S.SHARED_SYSTEM.MEMTR_CDMA_SRIO_Master.MT_SSI2MMAP.memtr_mmap_ipin, C66XX_S.CPU_SYSTEM_1.CGEM_SSI_1.cgem_slave_mif, 0x11F00000, 0x11F07FFF, -0x11000000; //L1D
        CONNECT522        C66XX_S.SHARED_SYSTEM.MEMTR_CDMA_SRIO_Master.MT_SSI2MMAP.memtr_mmap_ipin, C66XX_S.CPU_SYSTEM_2.CGEM_SSI_2.cgem_slave_mif, 0x12800000, 0x1287FFFF, -0x12000000; //L2
        CONNECT523        C66XX_S.SHARED_SYSTEM.MEMTR_CDMA_SRIO_Master.MT_SSI2MMAP.memtr_mmap_ipin, C66XX_S.CPU_SYSTEM_2.CGEM_SSI_2.cgem_slave_mif, 0x12E00000, 0x12E07FFF, -0x12000000; //L1P
        CONNECT524        C66XX_S.SHARED_SYSTEM.MEMTR_CDMA_SRIO_Master.MT_SSI2MMAP.memtr_mmap_ipin, C66XX_S.CPU_SYSTEM_2.CGEM_SSI_2.cgem_slave_mif, 0x12F00000, 0x12F07FFF, -0x12000000; //L1D
        CONNECT525        C66XX_S.SHARED_SYSTEM.MEMTR_CDMA_SRIO_Master.MT_SSI2MMAP.memtr_mmap_ipin, C66XX_S.CPU_SYSTEM_3.CGEM_SSI_3.cgem_slave_mif, 0x13800000, 0x1387FFFF, -0x13000000; //L2
        CONNECT526        C66XX_S.SHARED_SYSTEM.MEMTR_CDMA_SRIO_Master.MT_SSI2MMAP.memtr_mmap_ipin, C66XX_S.CPU_SYSTEM_3.CGEM_SSI_3.cgem_slave_mif, 0x13E00000, 0x13E07FFF, -0x13000000; //L1P
        CONNECT527        C66XX_S.SHARED_SYSTEM.MEMTR_CDMA_SRIO_Master.MT_SSI2MMAP.memtr_mmap_ipin, C66XX_S.CPU_SYSTEM_3.CGEM_SSI_3.cgem_slave_mif, 0x13F00000, 0x13F07FFF, -0x13000000; //L1D
        CONNECT528        C66XX_S.SHARED_SYSTEM.MEMTR_CDMA_SRIO_Master.MT_SSI2MMAP.memtr_mmap_ipin, C66XX_S.CPU_SYSTEM_4.CGEM_SSI_4.cgem_slave_mif, 0x14800000, 0x1487FFFF, -0x14000000; //L2
        CONNECT529        C66XX_S.SHARED_SYSTEM.MEMTR_CDMA_SRIO_Master.MT_SSI2MMAP.memtr_mmap_ipin, C66XX_S.CPU_SYSTEM_4.CGEM_SSI_4.cgem_slave_mif, 0x14E00000, 0x14E07FFF, -0x14000000; //L1P
        CONNECT530        C66XX_S.SHARED_SYSTEM.MEMTR_CDMA_SRIO_Master.MT_SSI2MMAP.memtr_mmap_ipin, C66XX_S.CPU_SYSTEM_4.CGEM_SSI_4.cgem_slave_mif, 0x14F00000, 0x14F07FFF, -0x14000000; //L1D
        CONNECT531        C66XX_S.SHARED_SYSTEM.MEMTR_CDMA_SRIO_Master.MT_SSI2MMAP.memtr_mmap_ipin, C66XX_S.CPU_SYSTEM_5.CGEM_SSI_5.cgem_slave_mif, 0x15800000, 0x1587FFFF, -0x15000000; //L2
        CONNECT532        C66XX_S.SHARED_SYSTEM.MEMTR_CDMA_SRIO_Master.MT_SSI2MMAP.memtr_mmap_ipin, C66XX_S.CPU_SYSTEM_5.CGEM_SSI_5.cgem_slave_mif, 0x15E00000, 0x15E07FFF, -0x15000000; //L1P
        CONNECT533        C66XX_S.SHARED_SYSTEM.MEMTR_CDMA_SRIO_Master.MT_SSI2MMAP.memtr_mmap_ipin, C66XX_S.CPU_SYSTEM_5.CGEM_SSI_5.cgem_slave_mif, 0x15F00000, 0x15F07FFF, -0x15000000; //L1D
        CONNECT534        C66XX_S.SHARED_SYSTEM.MEMTR_CDMA_SRIO_Master.MT_SSI2MMAP.memtr_mmap_ipin, C66XX_S.CPU_SYSTEM_6.CGEM_SSI_6.cgem_slave_mif, 0x16800000, 0x1687FFFF, -0x16000000; //L2
        CONNECT535        C66XX_S.SHARED_SYSTEM.MEMTR_CDMA_SRIO_Master.MT_SSI2MMAP.memtr_mmap_ipin, C66XX_S.CPU_SYSTEM_6.CGEM_SSI_6.cgem_slave_mif, 0x16E00000, 0x16E07FFF, -0x16000000; //L1P
        CONNECT536        C66XX_S.SHARED_SYSTEM.MEMTR_CDMA_SRIO_Master.MT_SSI2MMAP.memtr_mmap_ipin, C66XX_S.CPU_SYSTEM_6.CGEM_SSI_6.cgem_slave_mif, 0x16F00000, 0x16F07FFF, -0x16000000; //L1D
        CONNECT537        C66XX_S.SHARED_SYSTEM.MEMTR_CDMA_SRIO_Master.MT_SSI2MMAP.memtr_mmap_ipin, C66XX_S.CPU_SYSTEM_7.CGEM_SSI_7.cgem_slave_mif, 0x17800000, 0x1787FFFF, -0x17000000; //L2
        CONNECT538        C66XX_S.SHARED_SYSTEM.MEMTR_CDMA_SRIO_Master.MT_SSI2MMAP.memtr_mmap_ipin, C66XX_S.CPU_SYSTEM_7.CGEM_SSI_7.cgem_slave_mif, 0x17E00000, 0x17E07FFF, -0x17000000; //L1P
        CONNECT539        C66XX_S.SHARED_SYSTEM.MEMTR_CDMA_SRIO_Master.MT_SSI2MMAP.memtr_mmap_ipin, C66XX_S.CPU_SYSTEM_7.CGEM_SSI_7.cgem_slave_mif, 0x17F00000, 0x17F07FFF, -0x17000000; //L1D
            // SMS and SES MEMTR connections with CDMA_SRIO Master mem_map
        //SMS connections
        CONNECT540        C66XX_S.SHARED_SYSTEM.MEMTR_CDMA_SRIO_Master.MT_SSI2MMAP.memtr_mmap_ipin, C66XX_S.SHARED_SYSTEM.MEMTR_SMS.MT_MIF2SSI.memtr_mif_opin, 0x0BC00000, 0x0BCFFFFF, 0; //MSMC Config
        CONNECT541        C66XX_S.SHARED_SYSTEM.MEMTR_CDMA_SRIO_Master.MT_SSI2MMAP.memtr_mmap_ipin, C66XX_S.SHARED_SYSTEM.MEMTR_SMS.MT_MIF2SSI.memtr_mif_opin, 0x0C000000, 0x0C3FFFFF, 0; //MSMC RAM
        CONNECT542        C66XX_S.SHARED_SYSTEM.MEMTR_CDMA_SRIO_Master.MT_SSI2MMAP.memtr_mmap_ipin, C66XX_S.SHARED_SYSTEM.MEMTR_SES.MT_MIF2SSI.memtr_mif_opin, 0x21000000, 0x210000FF, 0; //EMIF
        CONNECT543        C66XX_S.SHARED_SYSTEM.MEMTR_CDMA_SRIO_Master.MT_SSI2MMAP.memtr_mmap_ipin, C66XX_S.SHARED_SYSTEM.MEMTR_SES.MT_MIF2SSI.memtr_mif_opin, 0x80000000, 0xFFFFFFFF, 0; //DDR
        // QM_Config connections with CDMA_SRIO Master mem_map
        CONNECT544        C66XX_S.SHARED_SYSTEM.MEMTR_CDMA_SRIO_Master.MT_SSI2MMAP.memtr_mmap_ipin, C66XX_S.SHARED_SYSTEM.MEMTR_QM_DMA_Config.MT_MIF2SSI.memtr_mif_opin, 0x34000000, 0x34063000, -0x34000000;
        CONNECT545        C66XX_S.SHARED_SYSTEM.MEMTR_CDMA_SRIO_Master.MT_SSI2MMAP.memtr_mmap_ipin, C66XX_S.SHARED_SYSTEM.MEMTR_QM_PDSP_Command.MT_MIF2SSI.memtr_mif_opin, 0x02AB8000, 0x02ABDFFF, -0x02A00000;
    //    CONNECT619        C66XX_S.SHARED_SYSTEM.MEMTR_CDMA_SRIO_Master.MT_SSI2MMAP.memtr_mmap_ipin, C66XX_S.SHARED_SYSTEM.MEMTR_QM_High_Accumulator.MT_MIF2SSI.memtr_mif_opin, 0x02FFFFFF, 0x02FFFFFF, -0x02A00000; //not used!
        //CDMA_PASS Master Memory Map connections
        // 32BIT mif connections with CDMA_PASS Master mem_map
        CONNECT546        C66XX_S.SHARED_SYSTEM.MEMTR_CDMA_PASS_Master.MT_SSI2MMAP.memtr_mmap_ipin, C66XX_S.SHARED_SYSTEM.FLATMEM_36BIT.mem36_mif, 0, 0xFFFFFFFF, 0;
        // L1/L2 connections with CDMA_PASS Master mem_map
        CONNECT547        C66XX_S.SHARED_SYSTEM.MEMTR_CDMA_PASS_Master.MT_SSI2MMAP.memtr_mmap_ipin, C66XX_S.CPU_SYSTEM_0.CGEM_SSI_0.cgem_slave_mif, 0x10800000, 0x1087FFFF, -0x10000000; //L2
        CONNECT548        C66XX_S.SHARED_SYSTEM.MEMTR_CDMA_PASS_Master.MT_SSI2MMAP.memtr_mmap_ipin, C66XX_S.CPU_SYSTEM_0.CGEM_SSI_0.cgem_slave_mif, 0x10E00000, 0x10E07FFF, -0x10000000; //L1P
        CONNECT549        C66XX_S.SHARED_SYSTEM.MEMTR_CDMA_PASS_Master.MT_SSI2MMAP.memtr_mmap_ipin, C66XX_S.CPU_SYSTEM_0.CGEM_SSI_0.cgem_slave_mif, 0x10F00000, 0x10F07FFF, -0x10000000; //L1D
        CONNECT550        C66XX_S.SHARED_SYSTEM.MEMTR_CDMA_PASS_Master.MT_SSI2MMAP.memtr_mmap_ipin, C66XX_S.CPU_SYSTEM_1.CGEM_SSI_1.cgem_slave_mif, 0x11800000, 0x1187FFFF, -0x11000000; //L2
        CONNECT551        C66XX_S.SHARED_SYSTEM.MEMTR_CDMA_PASS_Master.MT_SSI2MMAP.memtr_mmap_ipin, C66XX_S.CPU_SYSTEM_1.CGEM_SSI_1.cgem_slave_mif, 0x11E00000, 0x11E07FFF, -0x11000000; //L1P
        CONNECT552        C66XX_S.SHARED_SYSTEM.MEMTR_CDMA_PASS_Master.MT_SSI2MMAP.memtr_mmap_ipin, C66XX_S.CPU_SYSTEM_1.CGEM_SSI_1.cgem_slave_mif, 0x11F00000, 0x11F07FFF, -0x11000000; //L1D
        CONNECT553        C66XX_S.SHARED_SYSTEM.MEMTR_CDMA_PASS_Master.MT_SSI2MMAP.memtr_mmap_ipin, C66XX_S.CPU_SYSTEM_2.CGEM_SSI_2.cgem_slave_mif, 0x12800000, 0x1287FFFF, -0x12000000; //L2
        CONNECT554        C66XX_S.SHARED_SYSTEM.MEMTR_CDMA_PASS_Master.MT_SSI2MMAP.memtr_mmap_ipin, C66XX_S.CPU_SYSTEM_2.CGEM_SSI_2.cgem_slave_mif, 0x12E00000, 0x12E07FFF, -0x12000000; //L1P
        CONNECT555        C66XX_S.SHARED_SYSTEM.MEMTR_CDMA_PASS_Master.MT_SSI2MMAP.memtr_mmap_ipin, C66XX_S.CPU_SYSTEM_2.CGEM_SSI_2.cgem_slave_mif, 0x12F00000, 0x12F07FFF, -0x12000000; //L1D
        CONNECT556        C66XX_S.SHARED_SYSTEM.MEMTR_CDMA_PASS_Master.MT_SSI2MMAP.memtr_mmap_ipin, C66XX_S.CPU_SYSTEM_3.CGEM_SSI_3.cgem_slave_mif, 0x13800000, 0x1387FFFF, -0x13000000; //L2
        CONNECT557        C66XX_S.SHARED_SYSTEM.MEMTR_CDMA_PASS_Master.MT_SSI2MMAP.memtr_mmap_ipin, C66XX_S.CPU_SYSTEM_3.CGEM_SSI_3.cgem_slave_mif, 0x13E00000, 0x13E07FFF, -0x13000000; //L1P
        CONNECT558        C66XX_S.SHARED_SYSTEM.MEMTR_CDMA_PASS_Master.MT_SSI2MMAP.memtr_mmap_ipin, C66XX_S.CPU_SYSTEM_3.CGEM_SSI_3.cgem_slave_mif, 0x13F00000, 0x13F07FFF, -0x13000000; //L1D
        CONNECT559        C66XX_S.SHARED_SYSTEM.MEMTR_CDMA_PASS_Master.MT_SSI2MMAP.memtr_mmap_ipin, C66XX_S.CPU_SYSTEM_4.CGEM_SSI_4.cgem_slave_mif, 0x14800000, 0x1487FFFF, -0x14000000; //L2
        CONNECT560        C66XX_S.SHARED_SYSTEM.MEMTR_CDMA_PASS_Master.MT_SSI2MMAP.memtr_mmap_ipin, C66XX_S.CPU_SYSTEM_4.CGEM_SSI_4.cgem_slave_mif, 0x14E00000, 0x14E07FFF, -0x14000000; //L1P
        CONNECT561        C66XX_S.SHARED_SYSTEM.MEMTR_CDMA_PASS_Master.MT_SSI2MMAP.memtr_mmap_ipin, C66XX_S.CPU_SYSTEM_4.CGEM_SSI_4.cgem_slave_mif, 0x14F00000, 0x14F07FFF, -0x14000000; //L1D
        CONNECT562        C66XX_S.SHARED_SYSTEM.MEMTR_CDMA_PASS_Master.MT_SSI2MMAP.memtr_mmap_ipin, C66XX_S.CPU_SYSTEM_5.CGEM_SSI_5.cgem_slave_mif, 0x15800000, 0x1587FFFF, -0x15000000; //L2
        CONNECT563        C66XX_S.SHARED_SYSTEM.MEMTR_CDMA_PASS_Master.MT_SSI2MMAP.memtr_mmap_ipin, C66XX_S.CPU_SYSTEM_5.CGEM_SSI_5.cgem_slave_mif, 0x15E00000, 0x15E07FFF, -0x15000000; //L1P
        CONNECT564        C66XX_S.SHARED_SYSTEM.MEMTR_CDMA_PASS_Master.MT_SSI2MMAP.memtr_mmap_ipin, C66XX_S.CPU_SYSTEM_5.CGEM_SSI_5.cgem_slave_mif, 0x15F00000, 0x15F07FFF, -0x15000000; //L1D
        CONNECT565        C66XX_S.SHARED_SYSTEM.MEMTR_CDMA_PASS_Master.MT_SSI2MMAP.memtr_mmap_ipin, C66XX_S.CPU_SYSTEM_6.CGEM_SSI_6.cgem_slave_mif, 0x16800000, 0x1687FFFF, -0x16000000; //L2
        CONNECT566        C66XX_S.SHARED_SYSTEM.MEMTR_CDMA_PASS_Master.MT_SSI2MMAP.memtr_mmap_ipin, C66XX_S.CPU_SYSTEM_6.CGEM_SSI_6.cgem_slave_mif, 0x16E00000, 0x16E07FFF, -0x16000000; //L1P
        CONNECT567        C66XX_S.SHARED_SYSTEM.MEMTR_CDMA_PASS_Master.MT_SSI2MMAP.memtr_mmap_ipin, C66XX_S.CPU_SYSTEM_6.CGEM_SSI_6.cgem_slave_mif, 0x16F00000, 0x16F07FFF, -0x16000000; //L1D
        CONNECT568        C66XX_S.SHARED_SYSTEM.MEMTR_CDMA_PASS_Master.MT_SSI2MMAP.memtr_mmap_ipin, C66XX_S.CPU_SYSTEM_7.CGEM_SSI_7.cgem_slave_mif, 0x17800000, 0x1787FFFF, -0x17000000; //L2
        CONNECT569        C66XX_S.SHARED_SYSTEM.MEMTR_CDMA_PASS_Master.MT_SSI2MMAP.memtr_mmap_ipin, C66XX_S.CPU_SYSTEM_7.CGEM_SSI_7.cgem_slave_mif, 0x17E00000, 0x17E07FFF, -0x17000000; //L1P
        CONNECT570        C66XX_S.SHARED_SYSTEM.MEMTR_CDMA_PASS_Master.MT_SSI2MMAP.memtr_mmap_ipin, C66XX_S.CPU_SYSTEM_7.CGEM_SSI_7.cgem_slave_mif, 0x17F00000, 0x17F07FFF, -0x17000000; //L1D
            // SMS and SES MEMTR connections with CDMA_PASS Master mem_map
        //SMS connections
        CONNECT571        C66XX_S.SHARED_SYSTEM.MEMTR_CDMA_PASS_Master.MT_SSI2MMAP.memtr_mmap_ipin, C66XX_S.SHARED_SYSTEM.MEMTR_SMS.MT_MIF2SSI.memtr_mif_opin, 0x0BC00000, 0x0BCFFFFF, 0; //MSMC Config
        CONNECT572        C66XX_S.SHARED_SYSTEM.MEMTR_CDMA_PASS_Master.MT_SSI2MMAP.memtr_mmap_ipin, C66XX_S.SHARED_SYSTEM.MEMTR_SMS.MT_MIF2SSI.memtr_mif_opin, 0x0C000000, 0x0C3FFFFF, 0; //MSMC RAM
        CONNECT573        C66XX_S.SHARED_SYSTEM.MEMTR_CDMA_PASS_Master.MT_SSI2MMAP.memtr_mmap_ipin, C66XX_S.SHARED_SYSTEM.MEMTR_SES.MT_MIF2SSI.memtr_mif_opin, 0x21000000, 0x210000FF, 0; //EMIF
        CONNECT574        C66XX_S.SHARED_SYSTEM.MEMTR_CDMA_PASS_Master.MT_SSI2MMAP.memtr_mmap_ipin, C66XX_S.SHARED_SYSTEM.MEMTR_SES.MT_MIF2SSI.memtr_mif_opin, 0x80000000, 0xFFFFFFFF, 0; //DDR
        // QM_Config connections with CDMA_PASS Master mem_map
        CONNECT575        C66XX_S.SHARED_SYSTEM.MEMTR_CDMA_PASS_Master.MT_SSI2MMAP.memtr_mmap_ipin, C66XX_S.SHARED_SYSTEM.MEMTR_QM_DMA_Config.MT_MIF2SSI.memtr_mif_opin, 0x34000000, 0x34063000, -0x34000000;
        CONNECT576        C66XX_S.SHARED_SYSTEM.MEMTR_CDMA_PASS_Master.MT_SSI2MMAP.memtr_mmap_ipin, C66XX_S.SHARED_SYSTEM.MEMTR_QM_PDSP_Command.MT_MIF2SSI.memtr_mif_opin, 0x02AB8000, 0x02ABDFFF, -0x02A00000;
    //    CONNECT1636        C66XX_S.SHARED_SYSTEM.MEMTR_CDMA_PASS_Master.MT_SSI2MMAP.memtr_mmap_ipin, C66XX_S.SHARED_SYSTEM.MEMTR_QM_High_Accumulator.MT_MIF2SSI.memtr_mif_opin, 0x02FFFFFF, 0x02FFFFFF, -0x02A00000; //not used!
        //RESET Connections
        CONNECT577        C66XX_S.CPU_SYSTEM_0.CGEM_SSI_0.cgem_reset_ipin, C66XX_S.CPU_SYSTEM_0.CPU0_RESET;
        CONNECT578        C66XX_S.CPU_SYSTEM_1.CGEM_SSI_1.cgem_reset_ipin, C66XX_S.CPU_SYSTEM_1.CPU1_RESET;
        CONNECT579        C66XX_S.CPU_SYSTEM_2.CGEM_SSI_2.cgem_reset_ipin, C66XX_S.CPU_SYSTEM_2.CPU2_RESET;
        CONNECT580        C66XX_S.CPU_SYSTEM_3.CGEM_SSI_3.cgem_reset_ipin, C66XX_S.CPU_SYSTEM_3.CPU3_RESET;
        CONNECT581        C66XX_S.CPU_SYSTEM_4.CGEM_SSI_4.cgem_reset_ipin, C66XX_S.CPU_SYSTEM_4.CPU4_RESET;
        CONNECT582        C66XX_S.CPU_SYSTEM_5.CGEM_SSI_5.cgem_reset_ipin, C66XX_S.CPU_SYSTEM_5.CPU5_RESET;
        CONNECT583        C66XX_S.CPU_SYSTEM_6.CGEM_SSI_6.cgem_reset_ipin, C66XX_S.CPU_SYSTEM_6.CPU6_RESET;
        CONNECT584        C66XX_S.CPU_SYSTEM_7.CGEM_SSI_7.cgem_reset_ipin, C66XX_S.CPU_SYSTEM_7.CPU7_RESET;
        CONNECT585        System.SimBridge.global_reset_list, C66XX_S.SHARED_SYSTEM.SHARED_SYSTEM_INTF.reset_in;
        CONNECT586        C66XX_S.SHARED_SYSTEM.MSMC.msmc_reset_ipin, System.SimBridge.global_reset_list;
        CONNECT587        C66XX_S.SHARED_SYSTEM.FLATMEM_36BIT.mem36_reset_ipin, System.SimBridge.global_reset_list;
        CONNECT588        System.SimBridge.global_reset_list, C66XX_S.SHARED_SYSTEM.TIMER64_0.reset;
        CONNECT589        System.SimBridge.global_reset_list, C66XX_S.SHARED_SYSTEM.TIMER64_1.reset;
        CONNECT590        System.SimBridge.global_reset_list, C66XX_S.SHARED_SYSTEM.TIMER64_2.reset;
        CONNECT591        System.SimBridge.global_reset_list, C66XX_S.SHARED_SYSTEM.TIMER64_3.reset;
        CONNECT592        System.SimBridge.global_reset_list, C66XX_S.SHARED_SYSTEM.TIMER64_4.reset;
        CONNECT593        System.SimBridge.global_reset_list, C66XX_S.SHARED_SYSTEM.TIMER64_5.reset;
        CONNECT594        System.SimBridge.global_reset_list, C66XX_S.SHARED_SYSTEM.TIMER64_6.reset;
        CONNECT595        System.SimBridge.global_reset_list, C66XX_S.SHARED_SYSTEM.TIMER64_7.reset;
        CONNECT596        System.SimBridge.global_reset_list, C66XX_S.SHARED_SYSTEM.TIMER64_8.reset;
        CONNECT597        System.SimBridge.global_reset_list, C66XX_S.SHARED_SYSTEM.TIMER64_9.reset;
        CONNECT598        System.SimBridge.global_reset_list, C66XX_S.SHARED_SYSTEM.TIMER64_10.reset;
        CONNECT599        System.SimBridge.global_reset_list, C66XX_S.SHARED_SYSTEM.TIMER64_11.reset;
        CONNECT600        System.SimBridge.global_reset_list, C66XX_S.SHARED_SYSTEM.TIMER64_12.reset;
        CONNECT601        System.SimBridge.global_reset_list, C66XX_S.SHARED_SYSTEM.TIMER64_13.reset;
        CONNECT602        System.SimBridge.global_reset_list, C66XX_S.SHARED_SYSTEM.TIMER64_14.reset;
        CONNECT603        System.SimBridge.global_reset_list, C66XX_S.SHARED_SYSTEM.TIMER64_15.reset;
        CONNECT604        System.SimBridge.global_reset_list, C66XX_S.SHARED_SYSTEM.EDMA_0.reset;
        CONNECT605        System.SimBridge.global_reset_list, C66XX_S.SHARED_SYSTEM.EDMA_1.reset;
        CONNECT606        System.SimBridge.global_reset_list, C66XX_S.SHARED_SYSTEM.EDMA_2.reset;
        CONNECT607        C66XX_S.SHARED_SYSTEM.CP_INTC0.cp_intc_reset_in, C66XX_S.SHARED_SYSTEM.SHARED_SYSTEM_INTF.reset_out;
        CONNECT608        C66XX_S.SHARED_SYSTEM.CP_INTC1.cp_intc_reset_in, C66XX_S.SHARED_SYSTEM.SHARED_SYSTEM_INTF.reset_out;
        CONNECT609        C66XX_S.SHARED_SYSTEM.CP_INTC2.cp_intc_reset_in, C66XX_S.SHARED_SYSTEM.SHARED_SYSTEM_INTF.reset_out;
        CONNECT610        C66XX_S.SHARED_SYSTEM.CP_INTC3.cp_intc_reset_in, C66XX_S.SHARED_SYSTEM.SHARED_SYSTEM_INTF.reset_out;
        CONNECT611        C66XX_S.SHARED_SYSTEM.SEMAPHORE.semaphore2_reset_ipin, C66XX_S.SHARED_SYSTEM.SHARED_SYSTEM_INTF.reset_out;
        CONNECT612        C66XX_S.SHARED_SYSTEM.QUEUE_MANAGER.qmss_reset_ipin, C66XX_S.SHARED_SYSTEM.SHARED_SYSTEM_INTF.reset_out;
        CONNECT613        C66XX_S.SHARED_SYSTEM.CDMA_INFRA.cdma_reset_ipin, C66XX_S.SHARED_SYSTEM.SHARED_SYSTEM_INTF.reset_out;
        CONNECT614        System.SimBridge.global_reset_list, C66XX_S.SHARED_SYSTEM.IPC.reset;
        CONNECT615        System.SimBridge.global_reset_list, C66XX_S.SHARED_SYSTEM.MEMTR_GPIO_Config.MT_MIF2SSI.memtr_reset_ipin;
        CONNECT616        System.SimBridge.global_reset_list, C66XX_S.SHARED_SYSTEM.BOOT_ROM.reset;
        CONNECT617        C66XX_S.SHARED_SYSTEM.MEMTR_SMS.MT_MIF2SSI.memtr_reset_ipin, System.SimBridge.global_reset_list;
        CONNECT618        C66XX_S.SHARED_SYSTEM.MEMTR_SES.MT_MIF2SSI.memtr_reset_ipin, System.SimBridge.global_reset_list;
        CONNECT619        C66XX_S.SHARED_SYSTEM.MEMTR_SEMAPHORE_Config.MT_MIF2SSI.memtr_reset_ipin, System.SimBridge.global_reset_list;
        CONNECT620        C66XX_S.SHARED_SYSTEM.MEMTR_QM_Config.MT_MIF2SSI.memtr_reset_ipin, System.SimBridge.global_reset_list;
        CONNECT621        C66XX_S.SHARED_SYSTEM.MEMTR_QM_PDSP_Command.MT_MIF2SSI.memtr_reset_ipin, System.SimBridge.global_reset_list;
    //    CONNECT633        C66XX_S.SHARED_SYSTEM.MEMTR_QM_High_Accumulator.MT_MIF2SSI.memtr_reset_ipin, System.SimBridge.global_reset_list;
        CONNECT622        C66XX_S.SHARED_SYSTEM.MEMTR_QM_PDSP_Master.MT_SSI2MMAP.memtr_reset_ipin, System.SimBridge.global_reset_list;
        CONNECT623        C66XX_S.SHARED_SYSTEM.MEMTR_CDMA_INFRA_Config.MT_MIF2SSI.memtr_reset_ipin, System.SimBridge.global_reset_list;
        CONNECT624        C66XX_S.SHARED_SYSTEM.MEMTR_CDMA_INFRA_Master.MT_SSI2MMAP.memtr_reset_ipin, System.SimBridge.global_reset_list;
        CONNECT625        C66XX_S.SHARED_SYSTEM.MEMTR_SRIO_Config.MT_MIF2SSI.memtr_reset_ipin, System.SimBridge.global_reset_list;
        CONNECT626        C66XX_S.SHARED_SYSTEM.MEMTR_SRIO_Slave.MT_MIF2SSI.memtr_reset_ipin, System.SimBridge.global_reset_list;
        CONNECT627        C66XX_S.SHARED_SYSTEM.MEMTR_CDMA_SRIO_Config.MT_MIF2SSI.memtr_reset_ipin, System.SimBridge.global_reset_list;
        CONNECT628        C66XX_S.SHARED_SYSTEM.MEMTR_CDMA_SRIO_Master.MT_SSI2MMAP.memtr_reset_ipin, System.SimBridge.global_reset_list;
        CONNECT629        C66XX_S.SHARED_SYSTEM.MEMTR_SWITCHSS_Config.MT_MIF2SSI.memtr_reset_ipin, System.SimBridge.global_reset_list;
        CONNECT630        C66XX_S.SHARED_SYSTEM.MEMTR_SWITCHSS_SERDES_Config.MT_MIF2SSI.memtr_reset_ipin, System.SimBridge.global_reset_list;
        CONNECT631        C66XX_S.SHARED_SYSTEM.MIF_TO_FUNC_PASS.MT_MIF2SSI.memtr_reset_ipin, System.SimBridge.global_reset_list;
        CONNECT632        C66XX_S.SHARED_SYSTEM.MEMTR_CDMA_PASS_Config.MT_MIF2SSI.memtr_reset_ipin, System.SimBridge.global_reset_list;
        CONNECT633        C66XX_S.SHARED_SYSTEM.MEMTR_CDMA_PASS_Master.MT_SSI2MMAP.memtr_reset_ipin, System.SimBridge.global_reset_list;
        CONNECT634        C66XX_S.SHARED_SYSTEM.MEMTR_PCIE_Slave.MT_MIF2SSI.memtr_reset_ipin, System.SimBridge.global_reset_list;
        //Endianess Connections
        CONNECT635        C66XX_S.CPU_SYSTEM_0.CGEM_SSI_0.cgem_endian_ipin, C66XX_S.CPU_SYSTEM_0.CPU0_endianness;
        CONNECT636        C66XX_S.CPU_SYSTEM_1.CGEM_SSI_1.cgem_endian_ipin, C66XX_S.CPU_SYSTEM_1.CPU1_endianness;
        CONNECT637        C66XX_S.CPU_SYSTEM_2.CGEM_SSI_2.cgem_endian_ipin, C66XX_S.CPU_SYSTEM_2.CPU2_endianness;
        CONNECT638        C66XX_S.CPU_SYSTEM_3.CGEM_SSI_3.cgem_endian_ipin, C66XX_S.CPU_SYSTEM_3.CPU3_endianness;
        CONNECT639        C66XX_S.CPU_SYSTEM_4.CGEM_SSI_4.cgem_endian_ipin, C66XX_S.CPU_SYSTEM_4.CPU4_endianness;
        CONNECT640        C66XX_S.CPU_SYSTEM_5.CGEM_SSI_5.cgem_endian_ipin, C66XX_S.CPU_SYSTEM_5.CPU5_endianness;
        CONNECT641        C66XX_S.CPU_SYSTEM_6.CGEM_SSI_6.cgem_endian_ipin, C66XX_S.CPU_SYSTEM_6.CPU6_endianness;
        CONNECT642        C66XX_S.CPU_SYSTEM_7.CGEM_SSI_7.cgem_endian_ipin, C66XX_S.CPU_SYSTEM_7.CPU7_endianness;
        //! since the whole system is of the same endianness, connecting any CPU's endian to the entire shared Components
        CONNECT643        C66XX_S.SHARED_SYSTEM.MSMC.msmc_endian_ipin, C66XX_S.CPU_SYSTEM_0.CPU0_endianness;
        CONNECT644        C66XX_S.SHARED_SYSTEM.FLATMEM_36BIT.mem36_endian_ipin, C66XX_S.CPU_SYSTEM_0.CPU0_endianness;
        CONNECT645        C66XX_S.SHARED_SYSTEM.TIMER64_0.endian, C66XX_S.CPU_SYSTEM_0.CPU0_endianness;
        CONNECT646        C66XX_S.SHARED_SYSTEM.TIMER64_1.endian, C66XX_S.CPU_SYSTEM_0.CPU0_endianness;
        CONNECT647        C66XX_S.SHARED_SYSTEM.TIMER64_2.endian, C66XX_S.CPU_SYSTEM_0.CPU0_endianness;
        CONNECT648        C66XX_S.SHARED_SYSTEM.TIMER64_3.endian, C66XX_S.CPU_SYSTEM_0.CPU0_endianness;
        CONNECT649        C66XX_S.SHARED_SYSTEM.TIMER64_4.endian, C66XX_S.CPU_SYSTEM_0.CPU0_endianness;
        CONNECT650        C66XX_S.SHARED_SYSTEM.TIMER64_5.endian, C66XX_S.CPU_SYSTEM_0.CPU0_endianness;
        CONNECT651        C66XX_S.SHARED_SYSTEM.TIMER64_6.endian, C66XX_S.CPU_SYSTEM_0.CPU0_endianness;
        CONNECT652        C66XX_S.SHARED_SYSTEM.TIMER64_7.endian, C66XX_S.CPU_SYSTEM_0.CPU0_endianness;
        CONNECT653        C66XX_S.SHARED_SYSTEM.TIMER64_8.endian, C66XX_S.CPU_SYSTEM_0.CPU0_endianness;
        CONNECT654        C66XX_S.SHARED_SYSTEM.TIMER64_9.endian, C66XX_S.CPU_SYSTEM_0.CPU0_endianness;
        CONNECT655        C66XX_S.SHARED_SYSTEM.TIMER64_10.endian, C66XX_S.CPU_SYSTEM_0.CPU0_endianness;
        CONNECT656        C66XX_S.SHARED_SYSTEM.TIMER64_11.endian, C66XX_S.CPU_SYSTEM_0.CPU0_endianness;
        CONNECT657        C66XX_S.SHARED_SYSTEM.TIMER64_12.endian, C66XX_S.CPU_SYSTEM_0.CPU0_endianness;
        CONNECT658        C66XX_S.SHARED_SYSTEM.TIMER64_13.endian, C66XX_S.CPU_SYSTEM_0.CPU0_endianness;
        CONNECT659        C66XX_S.SHARED_SYSTEM.TIMER64_14.endian, C66XX_S.CPU_SYSTEM_0.CPU0_endianness;
        CONNECT660        C66XX_S.SHARED_SYSTEM.TIMER64_15.endian, C66XX_S.CPU_SYSTEM_0.CPU0_endianness;
        CONNECT661        C66XX_S.SHARED_SYSTEM.CP_INTC0.cp_intc_endian_in, C66XX_S.CPU_SYSTEM_0.CPU0_endianness;
        CONNECT662        C66XX_S.SHARED_SYSTEM.CP_INTC1.cp_intc_endian_in, C66XX_S.CPU_SYSTEM_0.CPU0_endianness;
        CONNECT663        C66XX_S.SHARED_SYSTEM.CP_INTC2.cp_intc_endian_in, C66XX_S.CPU_SYSTEM_0.CPU0_endianness;
        CONNECT664        C66XX_S.SHARED_SYSTEM.CP_INTC3.cp_intc_endian_in, C66XX_S.CPU_SYSTEM_0.CPU0_endianness;
        CONNECT665        C66XX_S.CPU_SYSTEM_0.CPU0_endianness, C66XX_S.SHARED_SYSTEM.EDMA_0.endian_in;
        CONNECT666        C66XX_S.CPU_SYSTEM_0.CPU0_endianness, C66XX_S.SHARED_SYSTEM.EDMA_1.endian_in;
        CONNECT667        C66XX_S.CPU_SYSTEM_0.CPU0_endianness, C66XX_S.SHARED_SYSTEM.EDMA_2.endian_in;
        CONNECT668        C66XX_S.SHARED_SYSTEM.SEMAPHORE.semaphore2_endian_ipin, C66XX_S.CPU_SYSTEM_0.CPU0_endianness;
        CONNECT669        C66XX_S.SHARED_SYSTEM.IPC.endian, C66XX_S.CPU_SYSTEM_0.CPU0_endianness;
        CONNECT670        C66XX_S.SHARED_SYSTEM.QUEUE_MANAGER.qmss_endian_ipin, C66XX_S.CPU_SYSTEM_0.CPU0_endianness_big_endian; //Big-endian
        CONNECT671        C66XX_S.SHARED_SYSTEM.CDMA_INFRA.cdma_endian_ipin, C66XX_S.CPU_SYSTEM_0.CPU0_endianness_big_endian; //Big-endian
        CONNECT672        C66XX_S.SHARED_SYSTEM.BOOT_ROM.endian_in, C66XX_S.CPU_SYSTEM_0.CPU0_endianness;
        CONNECT673        C66XX_S.SHARED_SYSTEM.MEMTR_GPIO_Config.MT_MIF2SSI.is_little_endian_ipin, C66XX_S.CPU_SYSTEM_0.CPU0_endianness;
        //! MEMTR adaptors endianess
        CONNECT674        C66XX_S.SHARED_SYSTEM.MEMTR_SMS.MT_MIF2SSI.is_little_endian_ipin, C66XX_S.CPU_SYSTEM_0.CPU0_endianness;
        CONNECT675        C66XX_S.SHARED_SYSTEM.MEMTR_SES.MT_MIF2SSI.is_little_endian_ipin, C66XX_S.CPU_SYSTEM_0.CPU0_endianness;
        CONNECT676        C66XX_S.SHARED_SYSTEM.MEMTR_SEMAPHORE_Config.MT_MIF2SSI.is_little_endian_ipin, C66XX_S.CPU_SYSTEM_0.CPU0_endianness;
        CONNECT677        C66XX_S.SHARED_SYSTEM.MEMTR_QM_Config.MT_MIF2SSI.is_little_endian_ipin, C66XX_S.CPU_SYSTEM_0.CPU0_endianness;
        CONNECT678        C66XX_S.SHARED_SYSTEM.MEMTR_QM_PDSP_Command.MT_MIF2SSI.is_little_endian_ipin, C66XX_S.CPU_SYSTEM_0.CPU0_endianness;
    //    CONNECT691        C66XX_S.SHARED_SYSTEM.MEMTR_QM_High_Accumulator.MT_MIF2SSI.is_little_endian_ipin, C66XX_S.CPU_SYSTEM_0.CPU0_endianness;
        CONNECT679        C66XX_S.SHARED_SYSTEM.MEMTR_QM_PDSP_Master.MT_SSI2MMAP.is_little_endian_ipin, C66XX_S.CPU_SYSTEM_0.CPU0_endianness;
        CONNECT680        C66XX_S.SHARED_SYSTEM.MEMTR_CDMA_INFRA_Config.MT_MIF2SSI.is_little_endian_ipin, C66XX_S.CPU_SYSTEM_0.CPU0_endianness;
        CONNECT681        C66XX_S.SHARED_SYSTEM.MEMTR_CDMA_INFRA_Master.MT_SSI2MMAP.is_little_endian_ipin, C66XX_S.CPU_SYSTEM_0.CPU0_endianness;
        CONNECT682        C66XX_S.SHARED_SYSTEM.MEMTR_SRIO_Config.MT_MIF2SSI.is_little_endian_ipin, C66XX_S.CPU_SYSTEM_0.CPU0_endianness;
        CONNECT683        C66XX_S.SHARED_SYSTEM.MEMTR_SRIO_Slave.MT_MIF2SSI.is_little_endian_ipin, C66XX_S.CPU_SYSTEM_0.CPU0_endianness;
        CONNECT684        C66XX_S.SHARED_SYSTEM.MEMTR_CDMA_SRIO_Config.MT_MIF2SSI.is_little_endian_ipin, C66XX_S.CPU_SYSTEM_0.CPU0_endianness;
        CONNECT685        C66XX_S.SHARED_SYSTEM.MEMTR_CDMA_SRIO_Master.MT_SSI2MMAP.is_little_endian_ipin, C66XX_S.CPU_SYSTEM_0.CPU0_endianness;
        CONNECT686        C66XX_S.SHARED_SYSTEM.MEMTR_SWITCHSS_Config.MT_MIF2SSI.is_little_endian_ipin, C66XX_S.CPU_SYSTEM_0.CPU0_endianness;
        CONNECT687        C66XX_S.SHARED_SYSTEM.MEMTR_SWITCHSS_SERDES_Config.MT_MIF2SSI.is_little_endian_ipin, C66XX_S.CPU_SYSTEM_0.CPU0_endianness;
        CONNECT688        C66XX_S.SHARED_SYSTEM.MIF_TO_FUNC_PASS.MT_MIF2SSI.is_little_endian_ipin, C66XX_S.CPU_SYSTEM_0.CPU0_endianness;
        CONNECT689        C66XX_S.SHARED_SYSTEM.MEMTR_CDMA_PASS_Config.MT_MIF2SSI.is_little_endian_ipin, C66XX_S.CPU_SYSTEM_0.CPU0_endianness;
        CONNECT690        C66XX_S.SHARED_SYSTEM.MEMTR_CDMA_PASS_Master.MT_SSI2MMAP.is_little_endian_ipin, C66XX_S.CPU_SYSTEM_0.CPU0_endianness;
        CONNECT691        C66XX_S.SHARED_SYSTEM.MEMTR_PCIE_Slave.MT_MIF2SSI.is_little_endian_ipin, C66XX_S.CPU_SYSTEM_0.CPU0_endianness;
        //! CDMA_INFRA connections
        //! These pins setup loopback mode for the Streaming I/f
        CONNECT692        C66XX_S.SHARED_SYSTEM.CDMA_INFRA.cdma_tstrm_thread_mready_opin, C66XX_S.SHARED_SYSTEM.CDMA_INFRA.cdma_rstrm_thread_mready_ipin;
        CONNECT693        C66XX_S.SHARED_SYSTEM.CDMA_INFRA.cdma_tstrm_thread_sready_ipin, C66XX_S.SHARED_SYSTEM.CDMA_INFRA.cdma_rstrm_thread_sready_opin;
        CONNECT694        C66XX_S.SHARED_SYSTEM.CDMA_INFRA.cdma_tstrm_data_opin, C66XX_S.SHARED_SYSTEM.CDMA_INFRA.cdma_rstrm_data_ipin;
        CONNECT695        C66XX_S.SHARED_SYSTEM.CDMA_INFRA.cdma_tstrm_data_accept_ipin, C66XX_S.SHARED_SYSTEM.CDMA_INFRA.cdma_rstrm_data_accept_opin;
        CONNECT696        System.C66XX_S.SHARED_SYSTEM.CDMA_INFRA.cdma_rx_teardown_req_opin, System.C66XX_S.SHARED_SYSTEM.CDMA_INFRA.cdma_rx_teardown_ack_ipin;
        //! QUEUE_MANAGER with CDMA_INFRA
        CONNECT697        C66XX_S.SHARED_SYSTEM.QUEUE_MANAGER.qmss_qmgr_que_pend1_opin, C66XX_S.SHARED_SYSTEM.CDMA_INFRA.cdma_que_pend_ipin;
        //! QUEUE_MANAGER with CDMA_SRIO
        CONNECT698        C66XX_S.SHARED_SYSTEM.QUEUE_MANAGER.qmss_qmgr_que_pend4_opin, C66XX_S.SHARED_SYSTEM.CDMA_SRIO.cdma_que_pend_ipin;
        //! QUEUE_MANAGER with CDMA_PASS
        CONNECT699        C66XX_S.SHARED_SYSTEM.QUEUE_MANAGER.qmss_qmgr_que_pend3_opin, C66XX_S.SHARED_SYSTEM.CDMA_PASS.cdma_que_pend_ipin;
            //! NMI connections from IPC
        CONNECT700        C66XX_S.CPU_SYSTEM_0.CPU0.NMI, C66XX_S.SHARED_SYSTEM.IPC_cpu_nmi_0;
        CONNECT701        C66XX_S.CPU_SYSTEM_1.CPU1.NMI, C66XX_S.SHARED_SYSTEM.IPC_cpu_nmi_1;
        CONNECT702        C66XX_S.CPU_SYSTEM_2.CPU2.NMI, C66XX_S.SHARED_SYSTEM.IPC_cpu_nmi_2;
        CONNECT703        C66XX_S.CPU_SYSTEM_3.CPU3.NMI, C66XX_S.SHARED_SYSTEM.IPC_cpu_nmi_3;
        CONNECT704        C66XX_S.CPU_SYSTEM_4.CPU4.NMI, C66XX_S.SHARED_SYSTEM.IPC_cpu_nmi_4;
        CONNECT705        C66XX_S.CPU_SYSTEM_5.CPU5.NMI, C66XX_S.SHARED_SYSTEM.IPC_cpu_nmi_5;
        CONNECT706        C66XX_S.CPU_SYSTEM_6.CPU6.NMI, C66XX_S.SHARED_SYSTEM.IPC_cpu_nmi_6;
        CONNECT707        C66XX_S.CPU_SYSTEM_7.CPU7.NMI, C66XX_S.SHARED_SYSTEM.IPC_cpu_nmi_7;
        //! Exposing CPU boundary Pins to Pin-connect Plugin
        CONNECT708        C66XX_S.CPU_SYSTEM_0.CPU0.PINC, C66XX_S.CPU_SYSTEM_0.CPU0.NMI, CPU0_NMI;
        CONNECT709        C66XX_S.CPU_SYSTEM_1.CPU1.PINC, C66XX_S.CPU_SYSTEM_1.CPU1.NMI, CPU1_NMI;
        CONNECT710        C66XX_S.CPU_SYSTEM_2.CPU2.PINC, C66XX_S.CPU_SYSTEM_2.CPU2.NMI, CPU2_NMI;
        CONNECT711        C66XX_S.CPU_SYSTEM_3.CPU3.PINC, C66XX_S.CPU_SYSTEM_3.CPU3.NMI, CPU3_NMI;
        CONNECT712        C66XX_S.CPU_SYSTEM_4.CPU4.PINC, C66XX_S.CPU_SYSTEM_4.CPU4.NMI, CPU4_NMI;
        CONNECT713        C66XX_S.CPU_SYSTEM_5.CPU5.PINC, C66XX_S.CPU_SYSTEM_5.CPU5.NMI, CPU5_NMI;
        CONNECT714        C66XX_S.CPU_SYSTEM_6.CPU6.PINC, C66XX_S.CPU_SYSTEM_6.CPU6.NMI, CPU6_NMI;
        CONNECT715        C66XX_S.CPU_SYSTEM_7.CPU7.PINC, C66XX_S.CPU_SYSTEM_7.CPU7.NMI, CPU7_NMI;
        CONNECT716        C66XX_S.CPU_SYSTEM_0.CPU0.PINC, C66XX_S.CPU_SYSTEM_0.CPU0.INT4, CPU0_INT4;
        CONNECT717        C66XX_S.CPU_SYSTEM_0.CPU0.PINC, C66XX_S.CPU_SYSTEM_0.CPU0.INT5, CPU0_INT5;
        CONNECT718        C66XX_S.CPU_SYSTEM_0.CPU0.PINC, C66XX_S.CPU_SYSTEM_0.CPU0.INT6, CPU0_INT6;
        CONNECT719        C66XX_S.CPU_SYSTEM_0.CPU0.PINC, C66XX_S.CPU_SYSTEM_0.CPU0.INT7, CPU0_INT7;
        CONNECT720        C66XX_S.CPU_SYSTEM_0.CPU0.PINC, C66XX_S.CPU_SYSTEM_0.CPU0.INT8, CPU0_INT8;
        CONNECT721        C66XX_S.CPU_SYSTEM_0.CPU0.PINC, C66XX_S.CPU_SYSTEM_0.CPU0.INT9, CPU0_INT9;
        CONNECT722        C66XX_S.CPU_SYSTEM_0.CPU0.PINC, C66XX_S.CPU_SYSTEM_0.CPU0.INT10, CPU0_INT10;
        CONNECT723        C66XX_S.CPU_SYSTEM_0.CPU0.PINC, C66XX_S.CPU_SYSTEM_0.CPU0.INT11, CPU0_INT11;
        CONNECT724        C66XX_S.CPU_SYSTEM_0.CPU0.PINC, C66XX_S.CPU_SYSTEM_0.CPU0.INT12, CPU0_INT12;
        CONNECT725        C66XX_S.CPU_SYSTEM_0.CPU0.PINC, C66XX_S.CPU_SYSTEM_0.CPU0.INT13, CPU0_INT13;
        CONNECT726        C66XX_S.CPU_SYSTEM_0.CPU0.PINC, C66XX_S.CPU_SYSTEM_0.CPU0.INT14, CPU0_INT14;
        CONNECT727        C66XX_S.CPU_SYSTEM_0.CPU0.PINC, C66XX_S.CPU_SYSTEM_0.CPU0.INT15, CPU0_INT15;
        CONNECT728        C66XX_S.CPU_SYSTEM_1.CPU1.PINC, C66XX_S.CPU_SYSTEM_1.CPU1.INT4, CPU1_INT4;
        CONNECT729        C66XX_S.CPU_SYSTEM_1.CPU1.PINC, C66XX_S.CPU_SYSTEM_1.CPU1.INT5, CPU1_INT5;
        CONNECT730        C66XX_S.CPU_SYSTEM_1.CPU1.PINC, C66XX_S.CPU_SYSTEM_1.CPU1.INT6, CPU1_INT6;
        CONNECT731        C66XX_S.CPU_SYSTEM_1.CPU1.PINC, C66XX_S.CPU_SYSTEM_1.CPU1.INT7, CPU1_INT7;
        CONNECT732        C66XX_S.CPU_SYSTEM_1.CPU1.PINC, C66XX_S.CPU_SYSTEM_1.CPU1.INT8, CPU1_INT8;
        CONNECT733        C66XX_S.CPU_SYSTEM_1.CPU1.PINC, C66XX_S.CPU_SYSTEM_1.CPU1.INT9, CPU1_INT9;
        CONNECT734        C66XX_S.CPU_SYSTEM_1.CPU1.PINC, C66XX_S.CPU_SYSTEM_1.CPU1.INT10, CPU1_INT10;
        CONNECT735        C66XX_S.CPU_SYSTEM_1.CPU1.PINC, C66XX_S.CPU_SYSTEM_1.CPU1.INT11, CPU1_INT11;
        CONNECT736        C66XX_S.CPU_SYSTEM_1.CPU1.PINC, C66XX_S.CPU_SYSTEM_1.CPU1.INT12, CPU1_INT12;
        CONNECT737        C66XX_S.CPU_SYSTEM_1.CPU1.PINC, C66XX_S.CPU_SYSTEM_1.CPU1.INT13, CPU1_INT13;
        CONNECT738        C66XX_S.CPU_SYSTEM_1.CPU1.PINC, C66XX_S.CPU_SYSTEM_1.CPU1.INT14, CPU1_INT14;
        CONNECT739        C66XX_S.CPU_SYSTEM_1.CPU1.PINC, C66XX_S.CPU_SYSTEM_1.CPU1.INT15, CPU1_INT15;
        CONNECT740        C66XX_S.CPU_SYSTEM_2.CPU2.PINC, C66XX_S.CPU_SYSTEM_2.CPU2.INT4, CPU2_INT4;
        CONNECT741        C66XX_S.CPU_SYSTEM_2.CPU2.PINC, C66XX_S.CPU_SYSTEM_2.CPU2.INT5, CPU2_INT5;
        CONNECT742        C66XX_S.CPU_SYSTEM_2.CPU2.PINC, C66XX_S.CPU_SYSTEM_2.CPU2.INT6, CPU2_INT6;
        CONNECT743        C66XX_S.CPU_SYSTEM_2.CPU2.PINC, C66XX_S.CPU_SYSTEM_2.CPU2.INT7, CPU2_INT7;
        CONNECT744        C66XX_S.CPU_SYSTEM_2.CPU2.PINC, C66XX_S.CPU_SYSTEM_2.CPU2.INT8, CPU2_INT8;
        CONNECT745        C66XX_S.CPU_SYSTEM_2.CPU2.PINC, C66XX_S.CPU_SYSTEM_2.CPU2.INT9, CPU2_INT9;
        CONNECT746        C66XX_S.CPU_SYSTEM_2.CPU2.PINC, C66XX_S.CPU_SYSTEM_2.CPU2.INT10, CPU2_INT10;
        CONNECT747        C66XX_S.CPU_SYSTEM_2.CPU2.PINC, C66XX_S.CPU_SYSTEM_2.CPU2.INT11, CPU2_INT11;
        CONNECT748        C66XX_S.CPU_SYSTEM_2.CPU2.PINC, C66XX_S.CPU_SYSTEM_2.CPU2.INT12, CPU2_INT12;
        CONNECT749        C66XX_S.CPU_SYSTEM_2.CPU2.PINC, C66XX_S.CPU_SYSTEM_2.CPU2.INT13, CPU2_INT13;
        CONNECT750        C66XX_S.CPU_SYSTEM_2.CPU2.PINC, C66XX_S.CPU_SYSTEM_2.CPU2.INT14, CPU2_INT14;
        CONNECT751        C66XX_S.CPU_SYSTEM_2.CPU2.PINC, C66XX_S.CPU_SYSTEM_2.CPU2.INT15, CPU2_INT15;
        CONNECT752        C66XX_S.CPU_SYSTEM_3.CPU3.PINC, C66XX_S.CPU_SYSTEM_3.CPU3.INT4, CPU3_INT4;
        CONNECT753        C66XX_S.CPU_SYSTEM_3.CPU3.PINC, C66XX_S.CPU_SYSTEM_3.CPU3.INT5, CPU3_INT5;
        CONNECT754        C66XX_S.CPU_SYSTEM_3.CPU3.PINC, C66XX_S.CPU_SYSTEM_3.CPU3.INT6, CPU3_INT6;
        CONNECT755        C66XX_S.CPU_SYSTEM_3.CPU3.PINC, C66XX_S.CPU_SYSTEM_3.CPU3.INT7, CPU3_INT7;
        CONNECT756        C66XX_S.CPU_SYSTEM_3.CPU3.PINC, C66XX_S.CPU_SYSTEM_3.CPU3.INT8, CPU3_INT8;
        CONNECT757        C66XX_S.CPU_SYSTEM_3.CPU3.PINC, C66XX_S.CPU_SYSTEM_3.CPU3.INT9, CPU3_INT9;
        CONNECT758        C66XX_S.CPU_SYSTEM_3.CPU3.PINC, C66XX_S.CPU_SYSTEM_3.CPU3.INT10, CPU3_INT10;
        CONNECT759        C66XX_S.CPU_SYSTEM_3.CPU3.PINC, C66XX_S.CPU_SYSTEM_3.CPU3.INT11, CPU3_INT11;
        CONNECT760        C66XX_S.CPU_SYSTEM_3.CPU3.PINC, C66XX_S.CPU_SYSTEM_3.CPU3.INT12, CPU3_INT12;
        CONNECT761        C66XX_S.CPU_SYSTEM_3.CPU3.PINC, C66XX_S.CPU_SYSTEM_3.CPU3.INT13, CPU3_INT13;
        CONNECT762        C66XX_S.CPU_SYSTEM_3.CPU3.PINC, C66XX_S.CPU_SYSTEM_3.CPU3.INT14, CPU3_INT14;
        CONNECT763        C66XX_S.CPU_SYSTEM_3.CPU3.PINC, C66XX_S.CPU_SYSTEM_3.CPU3.INT15, CPU3_INT15;
        CONNECT764        C66XX_S.CPU_SYSTEM_4.CPU4.PINC, C66XX_S.CPU_SYSTEM_4.CPU4.INT4, CPU4_INT4;
        CONNECT765        C66XX_S.CPU_SYSTEM_4.CPU4.PINC, C66XX_S.CPU_SYSTEM_4.CPU4.INT5, CPU4_INT5;
        CONNECT766        C66XX_S.CPU_SYSTEM_4.CPU4.PINC, C66XX_S.CPU_SYSTEM_4.CPU4.INT6, CPU4_INT6;
        CONNECT767        C66XX_S.CPU_SYSTEM_4.CPU4.PINC, C66XX_S.CPU_SYSTEM_4.CPU4.INT7, CPU4_INT7;
        CONNECT768        C66XX_S.CPU_SYSTEM_4.CPU4.PINC, C66XX_S.CPU_SYSTEM_4.CPU4.INT8, CPU4_INT8;
        CONNECT769        C66XX_S.CPU_SYSTEM_4.CPU4.PINC, C66XX_S.CPU_SYSTEM_4.CPU4.INT9, CPU4_INT9;
        CONNECT770        C66XX_S.CPU_SYSTEM_4.CPU4.PINC, C66XX_S.CPU_SYSTEM_4.CPU4.INT10, CPU4_INT10;
        CONNECT771        C66XX_S.CPU_SYSTEM_4.CPU4.PINC, C66XX_S.CPU_SYSTEM_4.CPU4.INT11, CPU4_INT11;
        CONNECT772        C66XX_S.CPU_SYSTEM_4.CPU4.PINC, C66XX_S.CPU_SYSTEM_4.CPU4.INT12, CPU4_INT12;
        CONNECT773        C66XX_S.CPU_SYSTEM_4.CPU4.PINC, C66XX_S.CPU_SYSTEM_4.CPU4.INT13, CPU4_INT13;
        CONNECT774        C66XX_S.CPU_SYSTEM_4.CPU4.PINC, C66XX_S.CPU_SYSTEM_4.CPU4.INT14, CPU4_INT14;
        CONNECT775        C66XX_S.CPU_SYSTEM_4.CPU4.PINC, C66XX_S.CPU_SYSTEM_4.CPU4.INT15, CPU4_INT15;
        CONNECT776        C66XX_S.CPU_SYSTEM_5.CPU5.PINC, C66XX_S.CPU_SYSTEM_5.CPU5.INT4, CPU5_INT4;
        CONNECT777        C66XX_S.CPU_SYSTEM_5.CPU5.PINC, C66XX_S.CPU_SYSTEM_5.CPU5.INT5, CPU5_INT5;
        CONNECT778        C66XX_S.CPU_SYSTEM_5.CPU5.PINC, C66XX_S.CPU_SYSTEM_5.CPU5.INT6, CPU5_INT6;
        CONNECT779        C66XX_S.CPU_SYSTEM_5.CPU5.PINC, C66XX_S.CPU_SYSTEM_5.CPU5.INT7, CPU5_INT7;
        CONNECT780        C66XX_S.CPU_SYSTEM_5.CPU5.PINC, C66XX_S.CPU_SYSTEM_5.CPU5.INT8, CPU5_INT8;
        CONNECT781        C66XX_S.CPU_SYSTEM_5.CPU5.PINC, C66XX_S.CPU_SYSTEM_5.CPU5.INT9, CPU5_INT9;
        CONNECT782        C66XX_S.CPU_SYSTEM_5.CPU5.PINC, C66XX_S.CPU_SYSTEM_5.CPU5.INT10, CPU5_INT10;
        CONNECT783        C66XX_S.CPU_SYSTEM_5.CPU5.PINC, C66XX_S.CPU_SYSTEM_5.CPU5.INT11, CPU5_INT11;
        CONNECT784        C66XX_S.CPU_SYSTEM_5.CPU5.PINC, C66XX_S.CPU_SYSTEM_5.CPU5.INT12, CPU5_INT12;
        CONNECT785        C66XX_S.CPU_SYSTEM_5.CPU5.PINC, C66XX_S.CPU_SYSTEM_5.CPU5.INT13, CPU5_INT13;
        CONNECT786        C66XX_S.CPU_SYSTEM_5.CPU5.PINC, C66XX_S.CPU_SYSTEM_5.CPU5.INT14, CPU5_INT14;
        CONNECT787        C66XX_S.CPU_SYSTEM_5.CPU5.PINC, C66XX_S.CPU_SYSTEM_5.CPU5.INT15, CPU5_INT15;
        CONNECT788        C66XX_S.CPU_SYSTEM_6.CPU6.PINC, C66XX_S.CPU_SYSTEM_6.CPU6.INT4, CPU6_INT4;
        CONNECT789        C66XX_S.CPU_SYSTEM_6.CPU6.PINC, C66XX_S.CPU_SYSTEM_6.CPU6.INT5, CPU6_INT5;
        CONNECT790        C66XX_S.CPU_SYSTEM_6.CPU6.PINC, C66XX_S.CPU_SYSTEM_6.CPU6.INT6, CPU6_INT6;
        CONNECT791        C66XX_S.CPU_SYSTEM_6.CPU6.PINC, C66XX_S.CPU_SYSTEM_6.CPU6.INT7, CPU6_INT7;
        CONNECT792        C66XX_S.CPU_SYSTEM_6.CPU6.PINC, C66XX_S.CPU_SYSTEM_6.CPU6.INT8, CPU6_INT8;
        CONNECT793        C66XX_S.CPU_SYSTEM_6.CPU6.PINC, C66XX_S.CPU_SYSTEM_6.CPU6.INT9, CPU6_INT9;
        CONNECT794        C66XX_S.CPU_SYSTEM_6.CPU6.PINC, C66XX_S.CPU_SYSTEM_6.CPU6.INT10, CPU6_INT10;
        CONNECT795        C66XX_S.CPU_SYSTEM_6.CPU6.PINC, C66XX_S.CPU_SYSTEM_6.CPU6.INT11, CPU6_INT11;
        CONNECT796        C66XX_S.CPU_SYSTEM_6.CPU6.PINC, C66XX_S.CPU_SYSTEM_6.CPU6.INT12, CPU6_INT12;
        CONNECT797        C66XX_S.CPU_SYSTEM_6.CPU6.PINC, C66XX_S.CPU_SYSTEM_6.CPU6.INT13, CPU6_INT13;
        CONNECT798        C66XX_S.CPU_SYSTEM_6.CPU6.PINC, C66XX_S.CPU_SYSTEM_6.CPU6.INT14, CPU6_INT14;
        CONNECT799        C66XX_S.CPU_SYSTEM_6.CPU6.PINC, C66XX_S.CPU_SYSTEM_6.CPU6.INT15, CPU6_INT15;
        CONNECT800        C66XX_S.CPU_SYSTEM_7.CPU7.PINC, C66XX_S.CPU_SYSTEM_7.CPU7.INT4, CPU7_INT4;
        CONNECT801        C66XX_S.CPU_SYSTEM_7.CPU7.PINC, C66XX_S.CPU_SYSTEM_7.CPU7.INT5, CPU7_INT5;
        CONNECT802        C66XX_S.CPU_SYSTEM_7.CPU7.PINC, C66XX_S.CPU_SYSTEM_7.CPU7.INT6, CPU7_INT6;
        CONNECT803        C66XX_S.CPU_SYSTEM_7.CPU7.PINC, C66XX_S.CPU_SYSTEM_7.CPU7.INT7, CPU7_INT7;
        CONNECT804        C66XX_S.CPU_SYSTEM_7.CPU7.PINC, C66XX_S.CPU_SYSTEM_7.CPU7.INT8, CPU7_INT8;
        CONNECT805        C66XX_S.CPU_SYSTEM_7.CPU7.PINC, C66XX_S.CPU_SYSTEM_7.CPU7.INT9, CPU7_INT9;
        CONNECT806        C66XX_S.CPU_SYSTEM_7.CPU7.PINC, C66XX_S.CPU_SYSTEM_7.CPU7.INT10, CPU7_INT10;
        CONNECT807        C66XX_S.CPU_SYSTEM_7.CPU7.PINC, C66XX_S.CPU_SYSTEM_7.CPU7.INT11, CPU7_INT11;
        CONNECT808        C66XX_S.CPU_SYSTEM_7.CPU7.PINC, C66XX_S.CPU_SYSTEM_7.CPU7.INT12, CPU7_INT12;
        CONNECT809        C66XX_S.CPU_SYSTEM_7.CPU7.PINC, C66XX_S.CPU_SYSTEM_7.CPU7.INT13, CPU7_INT13;
        CONNECT810        C66XX_S.CPU_SYSTEM_7.CPU7.PINC, C66XX_S.CPU_SYSTEM_7.CPU7.INT14, CPU7_INT14;
        CONNECT811        C66XX_S.CPU_SYSTEM_7.CPU7.PINC, C66XX_S.CPU_SYSTEM_7.CPU7.INT15, CPU7_INT15;
        // INTERRUPT Connections
        //! Connections of INTSEL with CPU
        CONNECT812        System.C66XX_S.CPU_SYSTEM_0.CPU0.EXCEP, System.C66XX_S.CPU_SYSTEM_0.CGEM_SSI_0.INTSELintsel_excep_out;
        CONNECT813        System.C66XX_S.CPU_SYSTEM_0.CPU0.NMI, System.C66XX_S.CPU_SYSTEM_0.CGEM_SSI_0.INTSELintsel_nmi_out;
        CONNECT814        System.C66XX_S.CPU_SYSTEM_0.CPU0.INT4, System.C66XX_S.CPU_SYSTEM_0.CGEM_SSI_0.INTSELintsel_int4_out;
        CONNECT815        System.C66XX_S.CPU_SYSTEM_0.CPU0.INT5, System.C66XX_S.CPU_SYSTEM_0.CGEM_SSI_0.INTSELintsel_int5_out;
        CONNECT816        System.C66XX_S.CPU_SYSTEM_0.CPU0.INT6, System.C66XX_S.CPU_SYSTEM_0.CGEM_SSI_0.INTSELintsel_int6_out;
        CONNECT817        System.C66XX_S.CPU_SYSTEM_0.CPU0.INT7, System.C66XX_S.CPU_SYSTEM_0.CGEM_SSI_0.INTSELintsel_int7_out;
        CONNECT818        System.C66XX_S.CPU_SYSTEM_0.CPU0.INT8, System.C66XX_S.CPU_SYSTEM_0.CGEM_SSI_0.INTSELintsel_int8_out;
        CONNECT819        System.C66XX_S.CPU_SYSTEM_0.CPU0.INT9, System.C66XX_S.CPU_SYSTEM_0.CGEM_SSI_0.INTSELintsel_int9_out;
        CONNECT820        System.C66XX_S.CPU_SYSTEM_0.CPU0.INT10, System.C66XX_S.CPU_SYSTEM_0.CGEM_SSI_0.INTSELintsel_int10_out;
        CONNECT821        System.C66XX_S.CPU_SYSTEM_0.CPU0.INT11, System.C66XX_S.CPU_SYSTEM_0.CGEM_SSI_0.INTSELintsel_int11_out;
        CONNECT822        System.C66XX_S.CPU_SYSTEM_0.CPU0.INT12, System.C66XX_S.CPU_SYSTEM_0.CGEM_SSI_0.INTSELintsel_int12_out;
        CONNECT823        System.C66XX_S.CPU_SYSTEM_0.CPU0.INT13, System.C66XX_S.CPU_SYSTEM_0.CGEM_SSI_0.INTSELintsel_int13_out;
        CONNECT824        System.C66XX_S.CPU_SYSTEM_0.CPU0.INT14, System.C66XX_S.CPU_SYSTEM_0.CGEM_SSI_0.INTSELintsel_int14_out;
        CONNECT825        System.C66XX_S.CPU_SYSTEM_0.CPU0.INT15, System.C66XX_S.CPU_SYSTEM_0.CGEM_SSI_0.INTSELintsel_int15_out;
        CONNECT826        System.C66XX_S.CPU_SYSTEM_0.CPU0cpu_idropped_out, System.C66XX_S.CPU_SYSTEM_0.CGEM_SSI_0.INTSELintsel_idrop_in;
        CONNECT827        System.C66XX_S.CPU_SYSTEM_1.CPU1.EXCEP, System.C66XX_S.CPU_SYSTEM_1.CGEM_SSI_1.INTSELintsel_excep_out;
        CONNECT828        System.C66XX_S.CPU_SYSTEM_1.CPU1.NMI, System.C66XX_S.CPU_SYSTEM_1.CGEM_SSI_1.INTSELintsel_nmi_out;
        CONNECT829        System.C66XX_S.CPU_SYSTEM_1.CPU1.INT4, System.C66XX_S.CPU_SYSTEM_1.CGEM_SSI_1.INTSELintsel_int4_out;
        CONNECT830        System.C66XX_S.CPU_SYSTEM_1.CPU1.INT5, System.C66XX_S.CPU_SYSTEM_1.CGEM_SSI_1.INTSELintsel_int5_out;
        CONNECT831        System.C66XX_S.CPU_SYSTEM_1.CPU1.INT6, System.C66XX_S.CPU_SYSTEM_1.CGEM_SSI_1.INTSELintsel_int6_out;
        CONNECT832        System.C66XX_S.CPU_SYSTEM_1.CPU1.INT7, System.C66XX_S.CPU_SYSTEM_1.CGEM_SSI_1.INTSELintsel_int7_out;
        CONNECT833        System.C66XX_S.CPU_SYSTEM_1.CPU1.INT8, System.C66XX_S.CPU_SYSTEM_1.CGEM_SSI_1.INTSELintsel_int8_out;
        CONNECT834        System.C66XX_S.CPU_SYSTEM_1.CPU1.INT9, System.C66XX_S.CPU_SYSTEM_1.CGEM_SSI_1.INTSELintsel_int9_out;
        CONNECT835        System.C66XX_S.CPU_SYSTEM_1.CPU1.INT10, System.C66XX_S.CPU_SYSTEM_1.CGEM_SSI_1.INTSELintsel_int10_out;
        CONNECT836        System.C66XX_S.CPU_SYSTEM_1.CPU1.INT11, System.C66XX_S.CPU_SYSTEM_1.CGEM_SSI_1.INTSELintsel_int11_out;
        CONNECT837        System.C66XX_S.CPU_SYSTEM_1.CPU1.INT12, System.C66XX_S.CPU_SYSTEM_1.CGEM_SSI_1.INTSELintsel_int12_out;
        CONNECT838        System.C66XX_S.CPU_SYSTEM_1.CPU1.INT13, System.C66XX_S.CPU_SYSTEM_1.CGEM_SSI_1.INTSELintsel_int13_out;
        CONNECT839        System.C66XX_S.CPU_SYSTEM_1.CPU1.INT14, System.C66XX_S.CPU_SYSTEM_1.CGEM_SSI_1.INTSELintsel_int14_out;
        CONNECT840        System.C66XX_S.CPU_SYSTEM_1.CPU1.INT15, System.C66XX_S.CPU_SYSTEM_1.CGEM_SSI_1.INTSELintsel_int15_out;
        CONNECT841        System.C66XX_S.CPU_SYSTEM_1.CPU1cpu_idropped_out, System.C66XX_S.CPU_SYSTEM_1.CGEM_SSI_1.INTSELintsel_idrop_in;
        CONNECT842        System.C66XX_S.CPU_SYSTEM_2.CPU2.EXCEP, System.C66XX_S.CPU_SYSTEM_2.CGEM_SSI_2.INTSELintsel_excep_out;
        CONNECT843        System.C66XX_S.CPU_SYSTEM_2.CPU2.NMI, System.C66XX_S.CPU_SYSTEM_2.CGEM_SSI_2.INTSELintsel_nmi_out;
        CONNECT844        System.C66XX_S.CPU_SYSTEM_2.CPU2.INT4, System.C66XX_S.CPU_SYSTEM_2.CGEM_SSI_2.INTSELintsel_int4_out;
        CONNECT845        System.C66XX_S.CPU_SYSTEM_2.CPU2.INT5, System.C66XX_S.CPU_SYSTEM_2.CGEM_SSI_2.INTSELintsel_int5_out;
        CONNECT846        System.C66XX_S.CPU_SYSTEM_2.CPU2.INT6, System.C66XX_S.CPU_SYSTEM_2.CGEM_SSI_2.INTSELintsel_int6_out;
        CONNECT847        System.C66XX_S.CPU_SYSTEM_2.CPU2.INT7, System.C66XX_S.CPU_SYSTEM_2.CGEM_SSI_2.INTSELintsel_int7_out;
        CONNECT848        System.C66XX_S.CPU_SYSTEM_2.CPU2.INT8, System.C66XX_S.CPU_SYSTEM_2.CGEM_SSI_2.INTSELintsel_int8_out;
        CONNECT849        System.C66XX_S.CPU_SYSTEM_2.CPU2.INT9, System.C66XX_S.CPU_SYSTEM_2.CGEM_SSI_2.INTSELintsel_int9_out;
        CONNECT850        System.C66XX_S.CPU_SYSTEM_2.CPU2.INT10, System.C66XX_S.CPU_SYSTEM_2.CGEM_SSI_2.INTSELintsel_int10_out;
        CONNECT851        System.C66XX_S.CPU_SYSTEM_2.CPU2.INT11, System.C66XX_S.CPU_SYSTEM_2.CGEM_SSI_2.INTSELintsel_int11_out;
        CONNECT852        System.C66XX_S.CPU_SYSTEM_2.CPU2.INT12, System.C66XX_S.CPU_SYSTEM_2.CGEM_SSI_2.INTSELintsel_int12_out;
        CONNECT853        System.C66XX_S.CPU_SYSTEM_2.CPU2.INT13, System.C66XX_S.CPU_SYSTEM_2.CGEM_SSI_2.INTSELintsel_int13_out;
        CONNECT854        System.C66XX_S.CPU_SYSTEM_2.CPU2.INT14, System.C66XX_S.CPU_SYSTEM_2.CGEM_SSI_2.INTSELintsel_int14_out;
        CONNECT855        System.C66XX_S.CPU_SYSTEM_2.CPU2.INT15, System.C66XX_S.CPU_SYSTEM_2.CGEM_SSI_2.INTSELintsel_int15_out;
        CONNECT856        System.C66XX_S.CPU_SYSTEM_2.CPU2cpu_idropped_out, System.C66XX_S.CPU_SYSTEM_2.CGEM_SSI_2.INTSELintsel_idrop_in;
        CONNECT857        System.C66XX_S.CPU_SYSTEM_3.CPU3.EXCEP, System.C66XX_S.CPU_SYSTEM_3.CGEM_SSI_3.INTSELintsel_excep_out;
        CONNECT858        System.C66XX_S.CPU_SYSTEM_3.CPU3.NMI, System.C66XX_S.CPU_SYSTEM_3.CGEM_SSI_3.INTSELintsel_nmi_out;
        CONNECT859        System.C66XX_S.CPU_SYSTEM_3.CPU3.INT4, System.C66XX_S.CPU_SYSTEM_3.CGEM_SSI_3.INTSELintsel_int4_out;
        CONNECT860        System.C66XX_S.CPU_SYSTEM_3.CPU3.INT5, System.C66XX_S.CPU_SYSTEM_3.CGEM_SSI_3.INTSELintsel_int5_out;
        CONNECT861        System.C66XX_S.CPU_SYSTEM_3.CPU3.INT6, System.C66XX_S.CPU_SYSTEM_3.CGEM_SSI_3.INTSELintsel_int6_out;
        CONNECT862        System.C66XX_S.CPU_SYSTEM_3.CPU3.INT7, System.C66XX_S.CPU_SYSTEM_3.CGEM_SSI_3.INTSELintsel_int7_out;
        CONNECT863        System.C66XX_S.CPU_SYSTEM_3.CPU3.INT8, System.C66XX_S.CPU_SYSTEM_3.CGEM_SSI_3.INTSELintsel_int8_out;
        CONNECT864        System.C66XX_S.CPU_SYSTEM_3.CPU3.INT9, System.C66XX_S.CPU_SYSTEM_3.CGEM_SSI_3.INTSELintsel_int9_out;
        CONNECT865        System.C66XX_S.CPU_SYSTEM_3.CPU3.INT10, System.C66XX_S.CPU_SYSTEM_3.CGEM_SSI_3.INTSELintsel_int10_out;
        CONNECT866        System.C66XX_S.CPU_SYSTEM_3.CPU3.INT11, System.C66XX_S.CPU_SYSTEM_3.CGEM_SSI_3.INTSELintsel_int11_out;
        CONNECT867        System.C66XX_S.CPU_SYSTEM_3.CPU3.INT12, System.C66XX_S.CPU_SYSTEM_3.CGEM_SSI_3.INTSELintsel_int12_out;
        CONNECT868        System.C66XX_S.CPU_SYSTEM_3.CPU3.INT13, System.C66XX_S.CPU_SYSTEM_3.CGEM_SSI_3.INTSELintsel_int13_out;
        CONNECT869        System.C66XX_S.CPU_SYSTEM_3.CPU3.INT14, System.C66XX_S.CPU_SYSTEM_3.CGEM_SSI_3.INTSELintsel_int14_out;
        CONNECT870        System.C66XX_S.CPU_SYSTEM_3.CPU3.INT15, System.C66XX_S.CPU_SYSTEM_3.CGEM_SSI_3.INTSELintsel_int15_out;
        CONNECT871        System.C66XX_S.CPU_SYSTEM_3.CPU3cpu_idropped_out, System.C66XX_S.CPU_SYSTEM_3.CGEM_SSI_3.INTSELintsel_idrop_in;
        CONNECT872        System.C66XX_S.CPU_SYSTEM_4.CPU4.EXCEP, System.C66XX_S.CPU_SYSTEM_4.CGEM_SSI_4.INTSELintsel_excep_out;
        CONNECT873        System.C66XX_S.CPU_SYSTEM_4.CPU4.NMI, System.C66XX_S.CPU_SYSTEM_4.CGEM_SSI_4.INTSELintsel_nmi_out;
        CONNECT874        System.C66XX_S.CPU_SYSTEM_4.CPU4.INT4, System.C66XX_S.CPU_SYSTEM_4.CGEM_SSI_4.INTSELintsel_int4_out;
        CONNECT875        System.C66XX_S.CPU_SYSTEM_4.CPU4.INT5, System.C66XX_S.CPU_SYSTEM_4.CGEM_SSI_4.INTSELintsel_int5_out;
        CONNECT876        System.C66XX_S.CPU_SYSTEM_4.CPU4.INT6, System.C66XX_S.CPU_SYSTEM_4.CGEM_SSI_4.INTSELintsel_int6_out;
        CONNECT877        System.C66XX_S.CPU_SYSTEM_4.CPU4.INT7, System.C66XX_S.CPU_SYSTEM_4.CGEM_SSI_4.INTSELintsel_int7_out;
        CONNECT878        System.C66XX_S.CPU_SYSTEM_4.CPU4.INT8, System.C66XX_S.CPU_SYSTEM_4.CGEM_SSI_4.INTSELintsel_int8_out;
        CONNECT879        System.C66XX_S.CPU_SYSTEM_4.CPU4.INT9, System.C66XX_S.CPU_SYSTEM_4.CGEM_SSI_4.INTSELintsel_int9_out;
        CONNECT880        System.C66XX_S.CPU_SYSTEM_4.CPU4.INT10, System.C66XX_S.CPU_SYSTEM_4.CGEM_SSI_4.INTSELintsel_int10_out;
        CONNECT881        System.C66XX_S.CPU_SYSTEM_4.CPU4.INT11, System.C66XX_S.CPU_SYSTEM_4.CGEM_SSI_4.INTSELintsel_int11_out;
        CONNECT882        System.C66XX_S.CPU_SYSTEM_4.CPU4.INT12, System.C66XX_S.CPU_SYSTEM_4.CGEM_SSI_4.INTSELintsel_int12_out;
        CONNECT883        System.C66XX_S.CPU_SYSTEM_4.CPU4.INT13, System.C66XX_S.CPU_SYSTEM_4.CGEM_SSI_4.INTSELintsel_int13_out;
        CONNECT884        System.C66XX_S.CPU_SYSTEM_4.CPU4.INT14, System.C66XX_S.CPU_SYSTEM_4.CGEM_SSI_4.INTSELintsel_int14_out;
        CONNECT885        System.C66XX_S.CPU_SYSTEM_4.CPU4.INT15, System.C66XX_S.CPU_SYSTEM_4.CGEM_SSI_4.INTSELintsel_int15_out;
        CONNECT886        System.C66XX_S.CPU_SYSTEM_4.CPU4cpu_idropped_out, System.C66XX_S.CPU_SYSTEM_4.CGEM_SSI_4.INTSELintsel_idrop_in;
        CONNECT887        System.C66XX_S.CPU_SYSTEM_5.CPU5.EXCEP, System.C66XX_S.CPU_SYSTEM_5.CGEM_SSI_5.INTSELintsel_excep_out;
        CONNECT888        System.C66XX_S.CPU_SYSTEM_5.CPU5.NMI, System.C66XX_S.CPU_SYSTEM_5.CGEM_SSI_5.INTSELintsel_nmi_out;
        CONNECT889        System.C66XX_S.CPU_SYSTEM_5.CPU5.INT4, System.C66XX_S.CPU_SYSTEM_5.CGEM_SSI_5.INTSELintsel_int4_out;
        CONNECT890        System.C66XX_S.CPU_SYSTEM_5.CPU5.INT5, System.C66XX_S.CPU_SYSTEM_5.CGEM_SSI_5.INTSELintsel_int5_out;
        CONNECT891        System.C66XX_S.CPU_SYSTEM_5.CPU5.INT6, System.C66XX_S.CPU_SYSTEM_5.CGEM_SSI_5.INTSELintsel_int6_out;
        CONNECT892        System.C66XX_S.CPU_SYSTEM_5.CPU5.INT7, System.C66XX_S.CPU_SYSTEM_5.CGEM_SSI_5.INTSELintsel_int7_out;
        CONNECT893        System.C66XX_S.CPU_SYSTEM_5.CPU5.INT8, System.C66XX_S.CPU_SYSTEM_5.CGEM_SSI_5.INTSELintsel_int8_out;
        CONNECT894        System.C66XX_S.CPU_SYSTEM_5.CPU5.INT9, System.C66XX_S.CPU_SYSTEM_5.CGEM_SSI_5.INTSELintsel_int9_out;
        CONNECT895        System.C66XX_S.CPU_SYSTEM_5.CPU5.INT10, System.C66XX_S.CPU_SYSTEM_5.CGEM_SSI_5.INTSELintsel_int10_out;
        CONNECT896        System.C66XX_S.CPU_SYSTEM_5.CPU5.INT11, System.C66XX_S.CPU_SYSTEM_5.CGEM_SSI_5.INTSELintsel_int11_out;
        CONNECT897        System.C66XX_S.CPU_SYSTEM_5.CPU5.INT12, System.C66XX_S.CPU_SYSTEM_5.CGEM_SSI_5.INTSELintsel_int12_out;
        CONNECT898        System.C66XX_S.CPU_SYSTEM_5.CPU5.INT13, System.C66XX_S.CPU_SYSTEM_5.CGEM_SSI_5.INTSELintsel_int13_out;
        CONNECT899        System.C66XX_S.CPU_SYSTEM_5.CPU5.INT14, System.C66XX_S.CPU_SYSTEM_5.CGEM_SSI_5.INTSELintsel_int14_out;
        CONNECT900        System.C66XX_S.CPU_SYSTEM_5.CPU5.INT15, System.C66XX_S.CPU_SYSTEM_5.CGEM_SSI_5.INTSELintsel_int15_out;
        CONNECT901        System.C66XX_S.CPU_SYSTEM_5.CPU5cpu_idropped_out, System.C66XX_S.CPU_SYSTEM_5.CGEM_SSI_5.INTSELintsel_idrop_in;
        CONNECT902        System.C66XX_S.CPU_SYSTEM_6.CPU6.EXCEP, System.C66XX_S.CPU_SYSTEM_6.CGEM_SSI_6.INTSELintsel_excep_out;
        CONNECT903        System.C66XX_S.CPU_SYSTEM_6.CPU6.NMI, System.C66XX_S.CPU_SYSTEM_6.CGEM_SSI_6.INTSELintsel_nmi_out;
        CONNECT904        System.C66XX_S.CPU_SYSTEM_6.CPU6.INT4, System.C66XX_S.CPU_SYSTEM_6.CGEM_SSI_6.INTSELintsel_int4_out;
        CONNECT905        System.C66XX_S.CPU_SYSTEM_6.CPU6.INT5, System.C66XX_S.CPU_SYSTEM_6.CGEM_SSI_6.INTSELintsel_int5_out;
        CONNECT906        System.C66XX_S.CPU_SYSTEM_6.CPU6.INT6, System.C66XX_S.CPU_SYSTEM_6.CGEM_SSI_6.INTSELintsel_int6_out;
        CONNECT907        System.C66XX_S.CPU_SYSTEM_6.CPU6.INT7, System.C66XX_S.CPU_SYSTEM_6.CGEM_SSI_6.INTSELintsel_int7_out;
        CONNECT908        System.C66XX_S.CPU_SYSTEM_6.CPU6.INT8, System.C66XX_S.CPU_SYSTEM_6.CGEM_SSI_6.INTSELintsel_int8_out;
        CONNECT909        System.C66XX_S.CPU_SYSTEM_6.CPU6.INT9, System.C66XX_S.CPU_SYSTEM_6.CGEM_SSI_6.INTSELintsel_int9_out;
        CONNECT910        System.C66XX_S.CPU_SYSTEM_6.CPU6.INT10, System.C66XX_S.CPU_SYSTEM_6.CGEM_SSI_6.INTSELintsel_int10_out;
        CONNECT911        System.C66XX_S.CPU_SYSTEM_6.CPU6.INT11, System.C66XX_S.CPU_SYSTEM_6.CGEM_SSI_6.INTSELintsel_int11_out;
        CONNECT912        System.C66XX_S.CPU_SYSTEM_6.CPU6.INT12, System.C66XX_S.CPU_SYSTEM_6.CGEM_SSI_6.INTSELintsel_int12_out;
        CONNECT913        System.C66XX_S.CPU_SYSTEM_6.CPU6.INT13, System.C66XX_S.CPU_SYSTEM_6.CGEM_SSI_6.INTSELintsel_int13_out;
        CONNECT914        System.C66XX_S.CPU_SYSTEM_6.CPU6.INT14, System.C66XX_S.CPU_SYSTEM_6.CGEM_SSI_6.INTSELintsel_int14_out;
        CONNECT915        System.C66XX_S.CPU_SYSTEM_6.CPU6.INT15, System.C66XX_S.CPU_SYSTEM_6.CGEM_SSI_6.INTSELintsel_int15_out;
        CONNECT916        System.C66XX_S.CPU_SYSTEM_6.CPU6cpu_idropped_out, System.C66XX_S.CPU_SYSTEM_6.CGEM_SSI_6.INTSELintsel_idrop_in;
        CONNECT917        System.C66XX_S.CPU_SYSTEM_7.CPU7.EXCEP, System.C66XX_S.CPU_SYSTEM_7.CGEM_SSI_7.INTSELintsel_excep_out;
        CONNECT918        System.C66XX_S.CPU_SYSTEM_7.CPU7.NMI, System.C66XX_S.CPU_SYSTEM_7.CGEM_SSI_7.INTSELintsel_nmi_out;
        CONNECT919        System.C66XX_S.CPU_SYSTEM_7.CPU7.INT4, System.C66XX_S.CPU_SYSTEM_7.CGEM_SSI_7.INTSELintsel_int4_out;
        CONNECT920        System.C66XX_S.CPU_SYSTEM_7.CPU7.INT5, System.C66XX_S.CPU_SYSTEM_7.CGEM_SSI_7.INTSELintsel_int5_out;
        CONNECT921        System.C66XX_S.CPU_SYSTEM_7.CPU7.INT6, System.C66XX_S.CPU_SYSTEM_7.CGEM_SSI_7.INTSELintsel_int6_out;
        CONNECT922        System.C66XX_S.CPU_SYSTEM_7.CPU7.INT7, System.C66XX_S.CPU_SYSTEM_7.CGEM_SSI_7.INTSELintsel_int7_out;
        CONNECT923        System.C66XX_S.CPU_SYSTEM_7.CPU7.INT8, System.C66XX_S.CPU_SYSTEM_7.CGEM_SSI_7.INTSELintsel_int8_out;
        CONNECT924        System.C66XX_S.CPU_SYSTEM_7.CPU7.INT9, System.C66XX_S.CPU_SYSTEM_7.CGEM_SSI_7.INTSELintsel_int9_out;
        CONNECT925        System.C66XX_S.CPU_SYSTEM_7.CPU7.INT10, System.C66XX_S.CPU_SYSTEM_7.CGEM_SSI_7.INTSELintsel_int10_out;
        CONNECT926        System.C66XX_S.CPU_SYSTEM_7.CPU7.INT11, System.C66XX_S.CPU_SYSTEM_7.CGEM_SSI_7.INTSELintsel_int11_out;
        CONNECT927        System.C66XX_S.CPU_SYSTEM_7.CPU7.INT12, System.C66XX_S.CPU_SYSTEM_7.CGEM_SSI_7.INTSELintsel_int12_out;
        CONNECT928        System.C66XX_S.CPU_SYSTEM_7.CPU7.INT13, System.C66XX_S.CPU_SYSTEM_7.CGEM_SSI_7.INTSELintsel_int13_out;
        CONNECT929        System.C66XX_S.CPU_SYSTEM_7.CPU7.INT14, System.C66XX_S.CPU_SYSTEM_7.CGEM_SSI_7.INTSELintsel_int14_out;
        CONNECT930        System.C66XX_S.CPU_SYSTEM_7.CPU7.INT15, System.C66XX_S.CPU_SYSTEM_7.CGEM_SSI_7.INTSELintsel_int15_out;
        CONNECT931        System.C66XX_S.CPU_SYSTEM_7.CPU7cpu_idropped_out, System.C66XX_S.CPU_SYSTEM_7.CGEM_SSI_7.INTSELintsel_idrop_in;
        // System Interrupt Connections - INTC0
        //EDMA1
        CONNECT932        C66XX_S.SHARED_SYSTEM.CP_INTC0.cp_intc_system_intr_in0, C66XX_S.SHARED_SYSTEM.EDMA_1.errint_out_pin;
        CONNECT933        C66XX_S.SHARED_SYSTEM.CP_INTC0.cp_intc_system_intr_in6, C66XX_S.SHARED_SYSTEM.EDMA_1_gint_out_pin;
        CONNECT934        C66XX_S.SHARED_SYSTEM.CP_INTC0.cp_intc_system_intr_in8, C66XX_S.SHARED_SYSTEM.EDMA_1_int_out_pin0;
        CONNECT935        C66XX_S.SHARED_SYSTEM.CP_INTC0.cp_intc_system_intr_in9, C66XX_S.SHARED_SYSTEM.EDMA_1_int_out_pin1;
        CONNECT936        C66XX_S.SHARED_SYSTEM.CP_INTC0.cp_intc_system_intr_in10, C66XX_S.SHARED_SYSTEM.EDMA_1_int_out_pin2;
        CONNECT937        C66XX_S.SHARED_SYSTEM.CP_INTC0.cp_intc_system_intr_in11, C66XX_S.SHARED_SYSTEM.EDMA_1_int_out_pin3;
        CONNECT938        C66XX_S.SHARED_SYSTEM.CP_INTC0.cp_intc_system_intr_in12, C66XX_S.SHARED_SYSTEM.EDMA_1_int_out_pin4;
        CONNECT939        C66XX_S.SHARED_SYSTEM.CP_INTC0.cp_intc_system_intr_in13, C66XX_S.SHARED_SYSTEM.EDMA_1_int_out_pin5;
        CONNECT940        C66XX_S.SHARED_SYSTEM.CP_INTC0.cp_intc_system_intr_in14, C66XX_S.SHARED_SYSTEM.EDMA_1_int_out_pin6;
        CONNECT941        C66XX_S.SHARED_SYSTEM.CP_INTC0.cp_intc_system_intr_in15, C66XX_S.SHARED_SYSTEM.EDMA_1_int_out_pin7;
        //EDMA2
        CONNECT942        C66XX_S.SHARED_SYSTEM.CP_INTC0.cp_intc_system_intr_in16, C66XX_S.SHARED_SYSTEM.EDMA_2.errint_out_pin;
        CONNECT943        C66XX_S.SHARED_SYSTEM.CP_INTC0.cp_intc_system_intr_in22, C66XX_S.SHARED_SYSTEM.EDMA_2_gint_out_pin;
        CONNECT944        C66XX_S.SHARED_SYSTEM.CP_INTC0.cp_intc_system_intr_in24, C66XX_S.SHARED_SYSTEM.EDMA_2_int_out_pin0;
        CONNECT945        C66XX_S.SHARED_SYSTEM.CP_INTC0.cp_intc_system_intr_in25, C66XX_S.SHARED_SYSTEM.EDMA_2_int_out_pin1;
        CONNECT946        C66XX_S.SHARED_SYSTEM.CP_INTC0.cp_intc_system_intr_in26, C66XX_S.SHARED_SYSTEM.EDMA_2_int_out_pin2;
        CONNECT947        C66XX_S.SHARED_SYSTEM.CP_INTC0.cp_intc_system_intr_in27, C66XX_S.SHARED_SYSTEM.EDMA_2_int_out_pin3;
        CONNECT948        C66XX_S.SHARED_SYSTEM.CP_INTC0.cp_intc_system_intr_in28, C66XX_S.SHARED_SYSTEM.EDMA_2_int_out_pin4;
        CONNECT949        C66XX_S.SHARED_SYSTEM.CP_INTC0.cp_intc_system_intr_in29, C66XX_S.SHARED_SYSTEM.EDMA_2_int_out_pin5;
        CONNECT950        C66XX_S.SHARED_SYSTEM.CP_INTC0.cp_intc_system_intr_in30, C66XX_S.SHARED_SYSTEM.EDMA_2_int_out_pin6;
        CONNECT951        C66XX_S.SHARED_SYSTEM.CP_INTC0.cp_intc_system_intr_in31, C66XX_S.SHARED_SYSTEM.EDMA_2_int_out_pin7;
        //EDMA0
        CONNECT952        C66XX_S.SHARED_SYSTEM.CP_INTC0.cp_intc_system_intr_in32, C66XX_S.SHARED_SYSTEM.EDMA_0.errint_out_pin;
        CONNECT953        C66XX_S.SHARED_SYSTEM.CP_INTC0.cp_intc_system_intr_in36, C66XX_S.SHARED_SYSTEM.EDMA_0_gint_out_pin;
        CONNECT954        C66XX_S.SHARED_SYSTEM.CP_INTC0.cp_intc_system_intr_in38, C66XX_S.SHARED_SYSTEM.EDMA_0_int_out_pin0;
        CONNECT955        C66XX_S.SHARED_SYSTEM.CP_INTC0.cp_intc_system_intr_in39, C66XX_S.SHARED_SYSTEM.EDMA_0_int_out_pin1;
        CONNECT956        C66XX_S.SHARED_SYSTEM.CP_INTC0.cp_intc_system_intr_in40, C66XX_S.SHARED_SYSTEM.EDMA_0_int_out_pin2;
        CONNECT957        C66XX_S.SHARED_SYSTEM.CP_INTC0.cp_intc_system_intr_in41, C66XX_S.SHARED_SYSTEM.EDMA_0_int_out_pin3;
        CONNECT958        C66XX_S.SHARED_SYSTEM.CP_INTC0.cp_intc_system_intr_in42, C66XX_S.SHARED_SYSTEM.EDMA_0_int_out_pin4;
        CONNECT959        C66XX_S.SHARED_SYSTEM.CP_INTC0.cp_intc_system_intr_in43, C66XX_S.SHARED_SYSTEM.EDMA_0_int_out_pin5;
        CONNECT960        C66XX_S.SHARED_SYSTEM.CP_INTC0.cp_intc_system_intr_in44, C66XX_S.SHARED_SYSTEM.EDMA_0_int_out_pin6;
        CONNECT961        C66XX_S.SHARED_SYSTEM.CP_INTC0.cp_intc_system_intr_in45, C66XX_S.SHARED_SYSTEM.EDMA_0_int_out_pin7;
        //SRIO
        CONNECT962        C66XX_S.SHARED_SYSTEM.CP_INTC0.cp_intc_system_intr_in112, C66XX_S.SHARED_SYSTEM.SRIO.srio_intdst_intr0;
        CONNECT963        C66XX_S.SHARED_SYSTEM.CP_INTC0.cp_intc_system_intr_in113, C66XX_S.SHARED_SYSTEM.SRIO.srio_intdst_intr1;
        CONNECT964        C66XX_S.SHARED_SYSTEM.CP_INTC0.cp_intc_system_intr_in114, C66XX_S.SHARED_SYSTEM.SRIO.srio_intdst_intr2;
        CONNECT965        C66XX_S.SHARED_SYSTEM.CP_INTC0.cp_intc_system_intr_in115, C66XX_S.SHARED_SYSTEM.SRIO.srio_intdst_intr3;
        CONNECT966        C66XX_S.SHARED_SYSTEM.CP_INTC0.cp_intc_system_intr_in116, C66XX_S.SHARED_SYSTEM.SRIO.srio_intdst_intr4;
        CONNECT967        C66XX_S.SHARED_SYSTEM.CP_INTC0.cp_intc_system_intr_in117, C66XX_S.SHARED_SYSTEM.SRIO.srio_intdst_intr5;
        CONNECT968        C66XX_S.SHARED_SYSTEM.CP_INTC0.cp_intc_system_intr_in118, C66XX_S.SHARED_SYSTEM.SRIO.srio_intdst_intr6;
        CONNECT969        C66XX_S.SHARED_SYSTEM.CP_INTC0.cp_intc_system_intr_in119, C66XX_S.SHARED_SYSTEM.SRIO.srio_intdst_intr7;
        CONNECT970        C66XX_S.SHARED_SYSTEM.CP_INTC0.cp_intc_system_intr_in120, C66XX_S.SHARED_SYSTEM.SRIO.srio_intdst_intr8;
        CONNECT971        C66XX_S.SHARED_SYSTEM.CP_INTC0.cp_intc_system_intr_in121, C66XX_S.SHARED_SYSTEM.SRIO.srio_intdst_intr9;
        CONNECT972        C66XX_S.SHARED_SYSTEM.CP_INTC0.cp_intc_system_intr_in122, C66XX_S.SHARED_SYSTEM.SRIO.srio_intdst_intr10;
        CONNECT973        C66XX_S.SHARED_SYSTEM.CP_INTC0.cp_intc_system_intr_in123, C66XX_S.SHARED_SYSTEM.SRIO.srio_intdst_intr11;
        CONNECT974        C66XX_S.SHARED_SYSTEM.CP_INTC0.cp_intc_system_intr_in124, C66XX_S.SHARED_SYSTEM.SRIO.srio_intdst_intr12;
        CONNECT975        C66XX_S.SHARED_SYSTEM.CP_INTC0.cp_intc_system_intr_in125, C66XX_S.SHARED_SYSTEM.SRIO.srio_intdst_intr13;
        CONNECT976        C66XX_S.SHARED_SYSTEM.CP_INTC0.cp_intc_system_intr_in126, C66XX_S.SHARED_SYSTEM.SRIO.srio_intdst_intr14;
        CONNECT977        C66XX_S.SHARED_SYSTEM.CP_INTC0.cp_intc_system_intr_in127, C66XX_S.SHARED_SYSTEM.SRIO.srio_intdst_intr15;
        //QUEUE_MANAGER
        //CONNECT574        C66XX_S.SHARED_SYSTEM.CP_INTC0.cp_intc_system_intr_in133, C66XX_S.SHARED_SYSTEM.QUEUE_MANAGER.;
        //CONNECT575        C66XX_S.SHARED_SYSTEM.CP_INTC0.cp_intc_system_intr_in134, C66XX_S.SHARED_SYSTEM.QUEUE_MANAGER.;
        //CONNECT575        C66XX_S.SHARED_SYSTEM.CP_INTC0.cp_intc_system_intr_in135, C66XX_S.SHARED_SYSTEM.SRIO.;
        // System Interrupt Connections - INTC1
        //EDMA1
        CONNECT978        C66XX_S.SHARED_SYSTEM.CP_INTC1.cp_intc_system_intr_in0, C66XX_S.SHARED_SYSTEM.EDMA_1.errint_out_pin;
        CONNECT979        C66XX_S.SHARED_SYSTEM.CP_INTC1.cp_intc_system_intr_in6, C66XX_S.SHARED_SYSTEM.EDMA_1_gint_out_pin;
        CONNECT980        C66XX_S.SHARED_SYSTEM.CP_INTC1.cp_intc_system_intr_in8, C66XX_S.SHARED_SYSTEM.EDMA_1_int_out_pin0;
        CONNECT981        C66XX_S.SHARED_SYSTEM.CP_INTC1.cp_intc_system_intr_in9, C66XX_S.SHARED_SYSTEM.EDMA_1_int_out_pin1;
        CONNECT982        C66XX_S.SHARED_SYSTEM.CP_INTC1.cp_intc_system_intr_in10, C66XX_S.SHARED_SYSTEM.EDMA_1_int_out_pin2;
        CONNECT983        C66XX_S.SHARED_SYSTEM.CP_INTC1.cp_intc_system_intr_in11, C66XX_S.SHARED_SYSTEM.EDMA_1_int_out_pin3;
        CONNECT984        C66XX_S.SHARED_SYSTEM.CP_INTC1.cp_intc_system_intr_in12, C66XX_S.SHARED_SYSTEM.EDMA_1_int_out_pin4;
        CONNECT985        C66XX_S.SHARED_SYSTEM.CP_INTC1.cp_intc_system_intr_in13, C66XX_S.SHARED_SYSTEM.EDMA_1_int_out_pin5;
        CONNECT986        C66XX_S.SHARED_SYSTEM.CP_INTC1.cp_intc_system_intr_in14, C66XX_S.SHARED_SYSTEM.EDMA_1_int_out_pin6;
        CONNECT987        C66XX_S.SHARED_SYSTEM.CP_INTC1.cp_intc_system_intr_in15, C66XX_S.SHARED_SYSTEM.EDMA_1_int_out_pin7;
        //EDMA2
        CONNECT988        C66XX_S.SHARED_SYSTEM.CP_INTC1.cp_intc_system_intr_in16, C66XX_S.SHARED_SYSTEM.EDMA_2.errint_out_pin;
        CONNECT989        C66XX_S.SHARED_SYSTEM.CP_INTC1.cp_intc_system_intr_in22, C66XX_S.SHARED_SYSTEM.EDMA_2_gint_out_pin;
        CONNECT990        C66XX_S.SHARED_SYSTEM.CP_INTC1.cp_intc_system_intr_in24, C66XX_S.SHARED_SYSTEM.EDMA_2_int_out_pin0;
        CONNECT991        C66XX_S.SHARED_SYSTEM.CP_INTC1.cp_intc_system_intr_in25, C66XX_S.SHARED_SYSTEM.EDMA_2_int_out_pin1;
        CONNECT992        C66XX_S.SHARED_SYSTEM.CP_INTC1.cp_intc_system_intr_in26, C66XX_S.SHARED_SYSTEM.EDMA_2_int_out_pin2;
        CONNECT993        C66XX_S.SHARED_SYSTEM.CP_INTC1.cp_intc_system_intr_in27, C66XX_S.SHARED_SYSTEM.EDMA_2_int_out_pin3;
        CONNECT994        C66XX_S.SHARED_SYSTEM.CP_INTC1.cp_intc_system_intr_in28, C66XX_S.SHARED_SYSTEM.EDMA_2_int_out_pin4;
        CONNECT995        C66XX_S.SHARED_SYSTEM.CP_INTC1.cp_intc_system_intr_in29, C66XX_S.SHARED_SYSTEM.EDMA_2_int_out_pin5;
        CONNECT996        C66XX_S.SHARED_SYSTEM.CP_INTC1.cp_intc_system_intr_in30, C66XX_S.SHARED_SYSTEM.EDMA_2_int_out_pin6;
        CONNECT997        C66XX_S.SHARED_SYSTEM.CP_INTC1.cp_intc_system_intr_in31, C66XX_S.SHARED_SYSTEM.EDMA_2_int_out_pin7;
        //EDMA0
        CONNECT998        C66XX_S.SHARED_SYSTEM.CP_INTC1.cp_intc_system_intr_in32, C66XX_S.SHARED_SYSTEM.EDMA_0.errint_out_pin;
        CONNECT999        C66XX_S.SHARED_SYSTEM.CP_INTC1.cp_intc_system_intr_in36, C66XX_S.SHARED_SYSTEM.EDMA_0_gint_out_pin;
        CONNECT1000        C66XX_S.SHARED_SYSTEM.CP_INTC1.cp_intc_system_intr_in38, C66XX_S.SHARED_SYSTEM.EDMA_0_int_out_pin0;
        CONNECT1001        C66XX_S.SHARED_SYSTEM.CP_INTC1.cp_intc_system_intr_in39, C66XX_S.SHARED_SYSTEM.EDMA_0_int_out_pin1;
        CONNECT1002        C66XX_S.SHARED_SYSTEM.CP_INTC1.cp_intc_system_intr_in40, C66XX_S.SHARED_SYSTEM.EDMA_0_int_out_pin2;
        CONNECT1003        C66XX_S.SHARED_SYSTEM.CP_INTC1.cp_intc_system_intr_in41, C66XX_S.SHARED_SYSTEM.EDMA_0_int_out_pin3;
        CONNECT1004        C66XX_S.SHARED_SYSTEM.CP_INTC1.cp_intc_system_intr_in42, C66XX_S.SHARED_SYSTEM.EDMA_0_int_out_pin4;
        CONNECT1005        C66XX_S.SHARED_SYSTEM.CP_INTC1.cp_intc_system_intr_in43, C66XX_S.SHARED_SYSTEM.EDMA_0_int_out_pin5;
        CONNECT1006        C66XX_S.SHARED_SYSTEM.CP_INTC1.cp_intc_system_intr_in44, C66XX_S.SHARED_SYSTEM.EDMA_0_int_out_pin6;
        CONNECT1007        C66XX_S.SHARED_SYSTEM.CP_INTC1.cp_intc_system_intr_in45, C66XX_S.SHARED_SYSTEM.EDMA_0_int_out_pin7;
        //SRIO
        CONNECT1008        C66XX_S.SHARED_SYSTEM.CP_INTC1.cp_intc_system_intr_in112, C66XX_S.SHARED_SYSTEM.SRIO.srio_intdst_intr0;
        CONNECT1009        C66XX_S.SHARED_SYSTEM.CP_INTC1.cp_intc_system_intr_in113, C66XX_S.SHARED_SYSTEM.SRIO.srio_intdst_intr1;
        CONNECT1010        C66XX_S.SHARED_SYSTEM.CP_INTC1.cp_intc_system_intr_in114, C66XX_S.SHARED_SYSTEM.SRIO.srio_intdst_intr2;
        CONNECT1011        C66XX_S.SHARED_SYSTEM.CP_INTC1.cp_intc_system_intr_in115, C66XX_S.SHARED_SYSTEM.SRIO.srio_intdst_intr3;
        CONNECT1012        C66XX_S.SHARED_SYSTEM.CP_INTC1.cp_intc_system_intr_in116, C66XX_S.SHARED_SYSTEM.SRIO.srio_intdst_intr4;
        CONNECT1013        C66XX_S.SHARED_SYSTEM.CP_INTC1.cp_intc_system_intr_in117, C66XX_S.SHARED_SYSTEM.SRIO.srio_intdst_intr5;
        CONNECT1014        C66XX_S.SHARED_SYSTEM.CP_INTC1.cp_intc_system_intr_in118, C66XX_S.SHARED_SYSTEM.SRIO.srio_intdst_intr6;
        CONNECT1015        C66XX_S.SHARED_SYSTEM.CP_INTC1.cp_intc_system_intr_in119, C66XX_S.SHARED_SYSTEM.SRIO.srio_intdst_intr7;
        CONNECT1016        C66XX_S.SHARED_SYSTEM.CP_INTC1.cp_intc_system_intr_in120, C66XX_S.SHARED_SYSTEM.SRIO.srio_intdst_intr8;
        CONNECT1017        C66XX_S.SHARED_SYSTEM.CP_INTC1.cp_intc_system_intr_in121, C66XX_S.SHARED_SYSTEM.SRIO.srio_intdst_intr9;
        CONNECT1018        C66XX_S.SHARED_SYSTEM.CP_INTC1.cp_intc_system_intr_in122, C66XX_S.SHARED_SYSTEM.SRIO.srio_intdst_intr10;
        CONNECT1019        C66XX_S.SHARED_SYSTEM.CP_INTC1.cp_intc_system_intr_in123, C66XX_S.SHARED_SYSTEM.SRIO.srio_intdst_intr11;
        CONNECT1020        C66XX_S.SHARED_SYSTEM.CP_INTC1.cp_intc_system_intr_in124, C66XX_S.SHARED_SYSTEM.SRIO.srio_intdst_intr12;
        CONNECT1021        C66XX_S.SHARED_SYSTEM.CP_INTC1.cp_intc_system_intr_in125, C66XX_S.SHARED_SYSTEM.SRIO.srio_intdst_intr13;
        CONNECT1022        C66XX_S.SHARED_SYSTEM.CP_INTC1.cp_intc_system_intr_in126, C66XX_S.SHARED_SYSTEM.SRIO.srio_intdst_intr14;
        CONNECT1023        C66XX_S.SHARED_SYSTEM.CP_INTC1.cp_intc_system_intr_in127, C66XX_S.SHARED_SYSTEM.SRIO.srio_intdst_intr15;
        //QUEUE_MANAGER
        //CONNECT574        C66XX_S.SHARED_SYSTEM.CP_INTC1.cp_intc_system_intr_in133, C66XX_S.SHARED_SYSTEM.QUEUE_MANAGER.;
        //CONNECT575        C66XX_S.SHARED_SYSTEM.CP_INTC1.cp_intc_system_intr_in134, C66XX_S.SHARED_SYSTEM.QUEUE_MANAGER.;
        //CONNECT575        C66XX_S.SHARED_SYSTEM.CP_INTC1.cp_intc_system_intr_in135, C66XX_S.SHARED_SYSTEM.SRIO.;
        // System Interrupt Connections - INTC2
        //GPIO
        CONNECT1024        C66XX_S.SHARED_SYSTEM.CP_INTC2.cp_intc_system_intr_in0, C66XX_S.SHARED_SYSTEM.GPIO.gpio_gpint8_opin;
        CONNECT1025        C66XX_S.SHARED_SYSTEM.CP_INTC2.cp_intc_system_intr_in1, C66XX_S.SHARED_SYSTEM.GPIO.gpio_gpint9_opin;
        CONNECT1026        C66XX_S.SHARED_SYSTEM.CP_INTC2.cp_intc_system_intr_in2, C66XX_S.SHARED_SYSTEM.GPIO.gpio_gpint10_opin;
        CONNECT1027        C66XX_S.SHARED_SYSTEM.CP_INTC2.cp_intc_system_intr_in3, C66XX_S.SHARED_SYSTEM.GPIO.gpio_gpint11_opin;
        CONNECT1028        C66XX_S.SHARED_SYSTEM.CP_INTC2.cp_intc_system_intr_in4, C66XX_S.SHARED_SYSTEM.GPIO.gpio_gpint12_opin;
        CONNECT1029        C66XX_S.SHARED_SYSTEM.CP_INTC2.cp_intc_system_intr_in5, C66XX_S.SHARED_SYSTEM.GPIO.gpio_gpint13_opin;
        CONNECT1030        C66XX_S.SHARED_SYSTEM.CP_INTC2.cp_intc_system_intr_in6, C66XX_S.SHARED_SYSTEM.GPIO.gpio_gpint14_opin;
        CONNECT1031        C66XX_S.SHARED_SYSTEM.CP_INTC2.cp_intc_system_intr_in7, C66XX_S.SHARED_SYSTEM.GPIO.gpio_gpint15_opin;
        //QUEUE_MANAGER
        CONNECT1032        C66XX_S.SHARED_SYSTEM.CP_INTC2.cp_intc_system_intr_in24, C66XX_S.SHARED_SYSTEM.QUEUE_MANAGER.qmss_int1_16_opin;
        CONNECT1033        C66XX_S.SHARED_SYSTEM.CP_INTC2.cp_intc_system_intr_in25, C66XX_S.SHARED_SYSTEM.QUEUE_MANAGER.qmss_int1_17_opin;
        CONNECT1034        C66XX_S.SHARED_SYSTEM.CP_INTC2.cp_intc_system_intr_in26, C66XX_S.SHARED_SYSTEM.QUEUE_MANAGER.qmss_int1_18_opin;
        CONNECT1035        C66XX_S.SHARED_SYSTEM.CP_INTC2.cp_intc_system_intr_in27, C66XX_S.SHARED_SYSTEM.QUEUE_MANAGER.qmss_int1_19_opin;
        CONNECT1036        C66XX_S.SHARED_SYSTEM.CP_INTC2.cp_intc_system_intr_in28, C66XX_S.SHARED_SYSTEM.QUEUE_MANAGER.qmss_int1_20_opin;
        CONNECT1037        C66XX_S.SHARED_SYSTEM.CP_INTC2.cp_intc_system_intr_in29, C66XX_S.SHARED_SYSTEM.QUEUE_MANAGER.qmss_int1_21_opin;
        CONNECT1038        C66XX_S.SHARED_SYSTEM.CP_INTC2.cp_intc_system_intr_in30, C66XX_S.SHARED_SYSTEM.QUEUE_MANAGER.qmss_int1_22_opin;
        CONNECT1039        C66XX_S.SHARED_SYSTEM.CP_INTC2.cp_intc_system_intr_in31, C66XX_S.SHARED_SYSTEM.QUEUE_MANAGER.qmss_int1_23_opin;
        CONNECT1040        C66XX_S.SHARED_SYSTEM.CP_INTC2.cp_intc_system_intr_in32, C66XX_S.SHARED_SYSTEM.QUEUE_MANAGER.qmss_int1_24_opin;
        CONNECT1041        C66XX_S.SHARED_SYSTEM.CP_INTC2.cp_intc_system_intr_in33, C66XX_S.SHARED_SYSTEM.QUEUE_MANAGER.qmss_int1_25_opin;
        CONNECT1042        C66XX_S.SHARED_SYSTEM.CP_INTC2.cp_intc_system_intr_in34, C66XX_S.SHARED_SYSTEM.QUEUE_MANAGER.qmss_int1_26_opin;
        CONNECT1043        C66XX_S.SHARED_SYSTEM.CP_INTC2.cp_intc_system_intr_in35, C66XX_S.SHARED_SYSTEM.QUEUE_MANAGER.qmss_int1_27_opin;
        CONNECT1044        C66XX_S.SHARED_SYSTEM.CP_INTC2.cp_intc_system_intr_in36, C66XX_S.SHARED_SYSTEM.QUEUE_MANAGER.qmss_int1_28_opin;
        CONNECT1045        C66XX_S.SHARED_SYSTEM.CP_INTC2.cp_intc_system_intr_in37, C66XX_S.SHARED_SYSTEM.QUEUE_MANAGER.qmss_int1_29_opin;
        CONNECT1046        C66XX_S.SHARED_SYSTEM.CP_INTC2.cp_intc_system_intr_in38, C66XX_S.SHARED_SYSTEM.QUEUE_MANAGER.qmss_int1_30_opin;
        CONNECT1047        C66XX_S.SHARED_SYSTEM.CP_INTC2.cp_intc_system_intr_in58, C66XX_S.SHARED_SYSTEM.SEMAPHORE.semaphore2_err_opin0;
        CONNECT1048        C66XX_S.SHARED_SYSTEM.CP_INTC2.cp_intc_system_intr_in39, C66XX_S.SHARED_SYSTEM.QUEUE_MANAGER.qmss_int1_31_opin;
        CONNECT1049        C66XX_S.SHARED_SYSTEM.CP_INTC2.cp_intc_system_intr_in134, C66XX_S.SHARED_SYSTEM.SEMAPHORE.semaphore2_err_opin4;
        CONNECT1050        C66XX_S.SHARED_SYSTEM.CP_INTC2.cp_intc_system_intr_in135, C66XX_S.SHARED_SYSTEM.SEMAPHORE.semaphore2_err_opin5;
        CONNECT1051        C66XX_S.SHARED_SYSTEM.CP_INTC2.cp_intc_system_intr_in136, C66XX_S.SHARED_SYSTEM.SEMAPHORE.semaphore2_err_opin6;
        CONNECT1052        C66XX_S.SHARED_SYSTEM.CP_INTC2.cp_intc_system_intr_in137, C66XX_S.SHARED_SYSTEM.SEMAPHORE.semaphore2_err_opin7;
        CONNECT1053        C66XX_S.SHARED_SYSTEM.CP_INTC2.cp_intc_system_intr_in138, C66XX_S.SHARED_SYSTEM.QUEUE_MANAGER.qmss_int1_0_opin;
        CONNECT1054        C66XX_S.SHARED_SYSTEM.CP_INTC2.cp_intc_system_intr_in139, C66XX_S.SHARED_SYSTEM.QUEUE_MANAGER.qmss_int1_1_opin;
        CONNECT1055        C66XX_S.SHARED_SYSTEM.CP_INTC2.cp_intc_system_intr_in140, C66XX_S.SHARED_SYSTEM.QUEUE_MANAGER.qmss_int1_2_opin;
        CONNECT1056        C66XX_S.SHARED_SYSTEM.CP_INTC2.cp_intc_system_intr_in141, C66XX_S.SHARED_SYSTEM.QUEUE_MANAGER.qmss_int1_3_opin;
        CONNECT1057        C66XX_S.SHARED_SYSTEM.CP_INTC2.cp_intc_system_intr_in142, C66XX_S.SHARED_SYSTEM.QUEUE_MANAGER.qmss_int1_4_opin;
        CONNECT1058        C66XX_S.SHARED_SYSTEM.CP_INTC2.cp_intc_system_intr_in143, C66XX_S.SHARED_SYSTEM.QUEUE_MANAGER.qmss_int1_5_opin;
        CONNECT1059        C66XX_S.SHARED_SYSTEM.CP_INTC2.cp_intc_system_intr_in144, C66XX_S.SHARED_SYSTEM.QUEUE_MANAGER.qmss_int1_6_opin;
        CONNECT1060        C66XX_S.SHARED_SYSTEM.CP_INTC2.cp_intc_system_intr_in145, C66XX_S.SHARED_SYSTEM.QUEUE_MANAGER.qmss_int1_7_opin;
        CONNECT1061        C66XX_S.SHARED_SYSTEM.CP_INTC2.cp_intc_system_intr_in146, C66XX_S.SHARED_SYSTEM.QUEUE_MANAGER.qmss_int1_8_opin;
        CONNECT1062        C66XX_S.SHARED_SYSTEM.CP_INTC2.cp_intc_system_intr_in147, C66XX_S.SHARED_SYSTEM.QUEUE_MANAGER.qmss_int1_9_opin;
        CONNECT1063        C66XX_S.SHARED_SYSTEM.CP_INTC2.cp_intc_system_intr_in148, C66XX_S.SHARED_SYSTEM.QUEUE_MANAGER.qmss_int1_10_opin;
        CONNECT1064        C66XX_S.SHARED_SYSTEM.CP_INTC2.cp_intc_system_intr_in149, C66XX_S.SHARED_SYSTEM.QUEUE_MANAGER.qmss_int1_11_opin;
        CONNECT1065        C66XX_S.SHARED_SYSTEM.CP_INTC2.cp_intc_system_intr_in150, C66XX_S.SHARED_SYSTEM.QUEUE_MANAGER.qmss_int1_12_opin;
        CONNECT1066        C66XX_S.SHARED_SYSTEM.CP_INTC2.cp_intc_system_intr_in151, C66XX_S.SHARED_SYSTEM.QUEUE_MANAGER.qmss_int1_13_opin;
        CONNECT1067        C66XX_S.SHARED_SYSTEM.CP_INTC2.cp_intc_system_intr_in152, C66XX_S.SHARED_SYSTEM.QUEUE_MANAGER.qmss_int1_14_opin;
        CONNECT1068        C66XX_S.SHARED_SYSTEM.CP_INTC2.cp_intc_system_intr_in153, C66XX_S.SHARED_SYSTEM.QUEUE_MANAGER.qmss_int1_15_opin;
        //SEMAPHORE
        CONNECT1069        C66XX_S.SHARED_SYSTEM.CP_INTC2.cp_intc_system_intr_in58, C66XX_S.SHARED_SYSTEM.SEMAPHORE.semaphore2_err_opin0;
        CONNECT1070        C66XX_S.SHARED_SYSTEM.CP_INTC2.cp_intc_system_intr_in59, C66XX_S.SHARED_SYSTEM.SEMAPHORE.semaphore2_err_opin1;
        CONNECT1071        C66XX_S.SHARED_SYSTEM.CP_INTC2.cp_intc_system_intr_in60, C66XX_S.SHARED_SYSTEM.SEMAPHORE.semaphore2_err_opin2;
        CONNECT1072        C66XX_S.SHARED_SYSTEM.CP_INTC2.cp_intc_system_intr_in61, C66XX_S.SHARED_SYSTEM.SEMAPHORE.semaphore2_err_opin3;
        //SRIO
        CONNECT1073        C66XX_S.SHARED_SYSTEM.CP_INTC2.cp_intc_system_intr_in93, C66XX_S.SHARED_SYSTEM.SRIO.srio_intdst_intr0;
        CONNECT1074        C66XX_S.SHARED_SYSTEM.CP_INTC2.cp_intc_system_intr_in94, C66XX_S.SHARED_SYSTEM.SRIO.srio_intdst_intr1;
        CONNECT1075        C66XX_S.SHARED_SYSTEM.CP_INTC2.cp_intc_system_intr_in95, C66XX_S.SHARED_SYSTEM.SRIO.srio_intdst_intr2;
        CONNECT1076        C66XX_S.SHARED_SYSTEM.CP_INTC2.cp_intc_system_intr_in96, C66XX_S.SHARED_SYSTEM.SRIO.srio_intdst_intr3;
        CONNECT1077        C66XX_S.SHARED_SYSTEM.CP_INTC2.cp_intc_system_intr_in97, C66XX_S.SHARED_SYSTEM.SRIO.srio_intdst_intr4;
        CONNECT1078        C66XX_S.SHARED_SYSTEM.CP_INTC2.cp_intc_system_intr_in98, C66XX_S.SHARED_SYSTEM.SRIO.srio_intdst_intr5;
        CONNECT1079        C66XX_S.SHARED_SYSTEM.CP_INTC2.cp_intc_system_intr_in99, C66XX_S.SHARED_SYSTEM.SRIO.srio_intdst_intr6;
        CONNECT1080        C66XX_S.SHARED_SYSTEM.CP_INTC2.cp_intc_system_intr_in100, C66XX_S.SHARED_SYSTEM.SRIO.srio_intdst_intr7;
        CONNECT1081        C66XX_S.SHARED_SYSTEM.CP_INTC2.cp_intc_system_intr_in101, C66XX_S.SHARED_SYSTEM.SRIO.srio_intdst_intr8;
        CONNECT1082        C66XX_S.SHARED_SYSTEM.CP_INTC2.cp_intc_system_intr_in102, C66XX_S.SHARED_SYSTEM.SRIO.srio_intdst_intr9;
        CONNECT1083        C66XX_S.SHARED_SYSTEM.CP_INTC2.cp_intc_system_intr_in103, C66XX_S.SHARED_SYSTEM.SRIO.srio_intdst_intr10;
        CONNECT1084        C66XX_S.SHARED_SYSTEM.CP_INTC2.cp_intc_system_intr_in104, C66XX_S.SHARED_SYSTEM.SRIO.srio_intdst_intr11;
        CONNECT1085        C66XX_S.SHARED_SYSTEM.CP_INTC2.cp_intc_system_intr_in105, C66XX_S.SHARED_SYSTEM.SRIO.srio_intdst_intr12;
        CONNECT1086        C66XX_S.SHARED_SYSTEM.CP_INTC2.cp_intc_system_intr_in106, C66XX_S.SHARED_SYSTEM.SRIO.srio_intdst_intr13;
        CONNECT1087        C66XX_S.SHARED_SYSTEM.CP_INTC2.cp_intc_system_intr_in107, C66XX_S.SHARED_SYSTEM.SRIO.srio_intdst_intr14;
        CONNECT1088        C66XX_S.SHARED_SYSTEM.CP_INTC2.cp_intc_system_intr_in108, C66XX_S.SHARED_SYSTEM.SRIO.srio_intdst_intr15;
        CONNECT1089        C66XX_S.SHARED_SYSTEM.CP_INTC2.cp_intc_system_intr_in109, C66XX_S.SHARED_SYSTEM.SRIO.srio_intdst_intr16;
        CONNECT1090        C66XX_S.SHARED_SYSTEM.CP_INTC2.cp_intc_system_intr_in110, C66XX_S.SHARED_SYSTEM.SRIO.srio_intdst_intr17;
        CONNECT1091        C66XX_S.SHARED_SYSTEM.CP_INTC2.cp_intc_system_intr_in111, C66XX_S.SHARED_SYSTEM.SRIO.srio_intdst_intr18;
        CONNECT1092        C66XX_S.SHARED_SYSTEM.CP_INTC2.cp_intc_system_intr_in112, C66XX_S.SHARED_SYSTEM.SRIO.srio_intdst_intr19;
        CONNECT1093        C66XX_S.SHARED_SYSTEM.CP_INTC2.cp_intc_system_intr_in113, C66XX_S.SHARED_SYSTEM.SRIO.srio_intdst_intr20;
        CONNECT1094        C66XX_S.SHARED_SYSTEM.CP_INTC2.cp_intc_system_intr_in114, C66XX_S.SHARED_SYSTEM.SRIO.srio_intdst_intr21;
        CONNECT1095        C66XX_S.SHARED_SYSTEM.CP_INTC2.cp_intc_system_intr_in115, C66XX_S.SHARED_SYSTEM.SRIO.srio_intdst_intr22;
        CONNECT1096        C66XX_S.SHARED_SYSTEM.CP_INTC2.cp_intc_system_intr_in116, C66XX_S.SHARED_SYSTEM.SRIO.srio_intdst_intr23;
        // System Interrupt Connections - INTC3
        //GPIO
        CONNECT1097        C66XX_S.SHARED_SYSTEM.CP_INTC3.cp_intc_system_intr_in0, C66XX_S.SHARED_SYSTEM.GPIO.gpio_gpint0_opin;
        CONNECT1098        C66XX_S.SHARED_SYSTEM.CP_INTC3.cp_intc_system_intr_in1, C66XX_S.SHARED_SYSTEM.GPIO.gpio_gpint1_opin;
        CONNECT1099        C66XX_S.SHARED_SYSTEM.CP_INTC3.cp_intc_system_intr_in2, C66XX_S.SHARED_SYSTEM.GPIO.gpio_gpint2_opin;
        CONNECT1100        C66XX_S.SHARED_SYSTEM.CP_INTC3.cp_intc_system_intr_in3, C66XX_S.SHARED_SYSTEM.GPIO.gpio_gpint3_opin;
        CONNECT1101        C66XX_S.SHARED_SYSTEM.CP_INTC3.cp_intc_system_intr_in4, C66XX_S.SHARED_SYSTEM.GPIO.gpio_gpint4_opin;
        CONNECT1102        C66XX_S.SHARED_SYSTEM.CP_INTC3.cp_intc_system_intr_in5, C66XX_S.SHARED_SYSTEM.GPIO.gpio_gpint5_opin;
        CONNECT1103        C66XX_S.SHARED_SYSTEM.CP_INTC3.cp_intc_system_intr_in6, C66XX_S.SHARED_SYSTEM.GPIO.gpio_gpint6_opin;
        CONNECT1104        C66XX_S.SHARED_SYSTEM.CP_INTC3.cp_intc_system_intr_in7, C66XX_S.SHARED_SYSTEM.GPIO.gpio_gpint7_opin;
        CONNECT1105        C66XX_S.SHARED_SYSTEM.CP_INTC3.cp_intc_system_intr_in8, C66XX_S.SHARED_SYSTEM.GPIO.gpio_gpint8_opin;
        CONNECT1106        C66XX_S.SHARED_SYSTEM.CP_INTC3.cp_intc_system_intr_in9, C66XX_S.SHARED_SYSTEM.GPIO.gpio_gpint9_opin;
        CONNECT1107        C66XX_S.SHARED_SYSTEM.CP_INTC3.cp_intc_system_intr_in10, C66XX_S.SHARED_SYSTEM.GPIO.gpio_gpint10_opin;
        CONNECT1108        C66XX_S.SHARED_SYSTEM.CP_INTC3.cp_intc_system_intr_in11, C66XX_S.SHARED_SYSTEM.GPIO.gpio_gpint11_opin;
        CONNECT1109        C66XX_S.SHARED_SYSTEM.CP_INTC3.cp_intc_system_intr_in12, C66XX_S.SHARED_SYSTEM.GPIO.gpio_gpint12_opin;
        CONNECT1110        C66XX_S.SHARED_SYSTEM.CP_INTC3.cp_intc_system_intr_in13, C66XX_S.SHARED_SYSTEM.GPIO.gpio_gpint13_opin;
        CONNECT1111        C66XX_S.SHARED_SYSTEM.CP_INTC3.cp_intc_system_intr_in14, C66XX_S.SHARED_SYSTEM.GPIO.gpio_gpint14_opin;
        CONNECT1112        C66XX_S.SHARED_SYSTEM.CP_INTC3.cp_intc_system_intr_in15, C66XX_S.SHARED_SYSTEM.GPIO.gpio_gpint15_opin;
        // Host Interrupt Connections for INTC0
        //!  With CGEM_0
    //  CONNECT1078     C66XX_S.SHARED_SYSTEM.CP_INTC0.cp_intc_out0, C66XX_S.CPU_SYSTEM_0.CGEM_SSI_0.INTSEL_in_pin_60;
    //  CONNECT1079     C66XX_S.SHARED_SYSTEM.CP_INTC0.cp_intc_out1, C66XX_S.CPU_SYSTEM_0.CGEM_SSI_0.INTSEL_in_pin_61;
        CONNECT1113        C66XX_S.SHARED_SYSTEM.CP_INTC0.cp_intc_out2, C66XX_S.CPU_SYSTEM_0.CGEM_SSI_0.INTSEL_in_pin_62;
        CONNECT1114        C66XX_S.SHARED_SYSTEM.CP_INTC0.cp_intc_out3, C66XX_S.CPU_SYSTEM_0.CGEM_SSI_0.INTSEL_in_pin_63;
        CONNECT1115        C66XX_S.SHARED_SYSTEM.CP_INTC0.cp_intc_out4, C66XX_S.CPU_SYSTEM_0.CGEM_SSI_0.INTSEL_in_pin_92;
        CONNECT1116        C66XX_S.SHARED_SYSTEM.CP_INTC0.cp_intc_out5, C66XX_S.CPU_SYSTEM_0.CGEM_SSI_0.INTSEL_in_pin_93;
        CONNECT1117        C66XX_S.SHARED_SYSTEM.CP_INTC0.cp_intc_out6, C66XX_S.CPU_SYSTEM_0.CGEM_SSI_0.INTSEL_in_pin_94;
        CONNECT1118        C66XX_S.SHARED_SYSTEM.CP_INTC0.cp_intc_out7, C66XX_S.CPU_SYSTEM_0.CGEM_SSI_0.INTSEL_in_pin_95;
        CONNECT1119        C66XX_S.SHARED_SYSTEM.CP_INTC0.cp_intc_out32, C66XX_S.CPU_SYSTEM_0.CGEM_SSI_0.INTSEL_in_pin_21;
        CONNECT1120        C66XX_S.SHARED_SYSTEM.CP_INTC0.cp_intc_out33, C66XX_S.CPU_SYSTEM_0.CGEM_SSI_0.INTSEL_in_pin_22;
        CONNECT1121        C66XX_S.SHARED_SYSTEM.CP_INTC0.cp_intc_out34, C66XX_S.CPU_SYSTEM_0.CGEM_SSI_0.INTSEL_in_pin_23;
        CONNECT1122        C66XX_S.SHARED_SYSTEM.CP_INTC0.cp_intc_out35, C66XX_S.CPU_SYSTEM_0.CGEM_SSI_0.INTSEL_in_pin_24;
        CONNECT1123        C66XX_S.SHARED_SYSTEM.CP_INTC0.cp_intc_out36, C66XX_S.CPU_SYSTEM_0.CGEM_SSI_0.INTSEL_in_pin_25;
        CONNECT1124        C66XX_S.SHARED_SYSTEM.CP_INTC0.cp_intc_out37, C66XX_S.CPU_SYSTEM_0.CGEM_SSI_0.INTSEL_in_pin_26;
        CONNECT1125        C66XX_S.SHARED_SYSTEM.CP_INTC0.cp_intc_out38, C66XX_S.CPU_SYSTEM_0.CGEM_SSI_0.INTSEL_in_pin_27;
        CONNECT1126        C66XX_S.SHARED_SYSTEM.CP_INTC0.cp_intc_out39, C66XX_S.CPU_SYSTEM_0.CGEM_SSI_0.INTSEL_in_pin_28;
        CONNECT1127        C66XX_S.SHARED_SYSTEM.CP_INTC0.cp_intc_out40, C66XX_S.CPU_SYSTEM_0.CGEM_SSI_0.INTSEL_in_pin_29;
        CONNECT1128        C66XX_S.SHARED_SYSTEM.CP_INTC0.cp_intc_out41, C66XX_S.CPU_SYSTEM_0.CGEM_SSI_0.INTSEL_in_pin_30;
        CONNECT1129        C66XX_S.SHARED_SYSTEM.CP_INTC0.cp_intc_out42, C66XX_S.CPU_SYSTEM_0.CGEM_SSI_0.INTSEL_in_pin_31;
        //!  With CGEM_1
    //  CONNECT1097     C66XX_S.SHARED_SYSTEM.CP_INTC0.cp_intc_out8, C66XX_S.CPU_SYSTEM_1.CGEM_SSI_1.INTSEL_in_pin_60;
    //  CONNECT1098     C66XX_S.SHARED_SYSTEM.CP_INTC0.cp_intc_out9, C66XX_S.CPU_SYSTEM_1.CGEM_SSI_1.INTSEL_in_pin_61;
        CONNECT1130        C66XX_S.SHARED_SYSTEM.CP_INTC0.cp_intc_out10, C66XX_S.CPU_SYSTEM_1.CGEM_SSI_1.INTSEL_in_pin_62;
        CONNECT1131        C66XX_S.SHARED_SYSTEM.CP_INTC0.cp_intc_out11, C66XX_S.CPU_SYSTEM_1.CGEM_SSI_1.INTSEL_in_pin_63;
        CONNECT1132        C66XX_S.SHARED_SYSTEM.CP_INTC0.cp_intc_out12, C66XX_S.CPU_SYSTEM_1.CGEM_SSI_1.INTSEL_in_pin_92;
        CONNECT1133        C66XX_S.SHARED_SYSTEM.CP_INTC0.cp_intc_out13, C66XX_S.CPU_SYSTEM_1.CGEM_SSI_1.INTSEL_in_pin_93;
        CONNECT1134        C66XX_S.SHARED_SYSTEM.CP_INTC0.cp_intc_out14, C66XX_S.CPU_SYSTEM_1.CGEM_SSI_1.INTSEL_in_pin_94;
        CONNECT1135        C66XX_S.SHARED_SYSTEM.CP_INTC0.cp_intc_out15, C66XX_S.CPU_SYSTEM_1.CGEM_SSI_1.INTSEL_in_pin_95;
        CONNECT1136        C66XX_S.SHARED_SYSTEM.CP_INTC0.cp_intc_out43, C66XX_S.CPU_SYSTEM_1.CGEM_SSI_1.INTSEL_in_pin_21;
        CONNECT1137        C66XX_S.SHARED_SYSTEM.CP_INTC0.cp_intc_out44, C66XX_S.CPU_SYSTEM_1.CGEM_SSI_1.INTSEL_in_pin_22;
        CONNECT1138        C66XX_S.SHARED_SYSTEM.CP_INTC0.cp_intc_out45, C66XX_S.CPU_SYSTEM_1.CGEM_SSI_1.INTSEL_in_pin_23;
        CONNECT1139        C66XX_S.SHARED_SYSTEM.CP_INTC0.cp_intc_out46, C66XX_S.CPU_SYSTEM_1.CGEM_SSI_1.INTSEL_in_pin_24;
        CONNECT1140        C66XX_S.SHARED_SYSTEM.CP_INTC0.cp_intc_out47, C66XX_S.CPU_SYSTEM_1.CGEM_SSI_1.INTSEL_in_pin_25;
        CONNECT1141        C66XX_S.SHARED_SYSTEM.CP_INTC0.cp_intc_out48, C66XX_S.CPU_SYSTEM_1.CGEM_SSI_1.INTSEL_in_pin_26;
        CONNECT1142        C66XX_S.SHARED_SYSTEM.CP_INTC0.cp_intc_out49, C66XX_S.CPU_SYSTEM_1.CGEM_SSI_1.INTSEL_in_pin_27;
        CONNECT1143        C66XX_S.SHARED_SYSTEM.CP_INTC0.cp_intc_out50, C66XX_S.CPU_SYSTEM_1.CGEM_SSI_1.INTSEL_in_pin_28;
        CONNECT1144        C66XX_S.SHARED_SYSTEM.CP_INTC0.cp_intc_out51, C66XX_S.CPU_SYSTEM_1.CGEM_SSI_1.INTSEL_in_pin_29;
        CONNECT1145        C66XX_S.SHARED_SYSTEM.CP_INTC0.cp_intc_out52, C66XX_S.CPU_SYSTEM_1.CGEM_SSI_1.INTSEL_in_pin_30;
        CONNECT1146        C66XX_S.SHARED_SYSTEM.CP_INTC0.cp_intc_out53, C66XX_S.CPU_SYSTEM_1.CGEM_SSI_1.INTSEL_in_pin_31;
        //!  With CGEM_2
    //  CONNECT1116     C66XX_S.SHARED_SYSTEM.CP_INTC0.cp_intc_out16, C66XX_S.CPU_SYSTEM_2.CGEM_SSI_2.INTSEL_in_pin_60;
    //  CONNECT1117     C66XX_S.SHARED_SYSTEM.CP_INTC0.cp_intc_out17, C66XX_S.CPU_SYSTEM_2.CGEM_SSI_2.INTSEL_in_pin_61;
        CONNECT1147        C66XX_S.SHARED_SYSTEM.CP_INTC0.cp_intc_out18, C66XX_S.CPU_SYSTEM_2.CGEM_SSI_2.INTSEL_in_pin_62;
        CONNECT1148        C66XX_S.SHARED_SYSTEM.CP_INTC0.cp_intc_out19, C66XX_S.CPU_SYSTEM_2.CGEM_SSI_2.INTSEL_in_pin_63;
        CONNECT1149        C66XX_S.SHARED_SYSTEM.CP_INTC0.cp_intc_out20, C66XX_S.CPU_SYSTEM_2.CGEM_SSI_2.INTSEL_in_pin_92;
        CONNECT1150        C66XX_S.SHARED_SYSTEM.CP_INTC0.cp_intc_out21, C66XX_S.CPU_SYSTEM_2.CGEM_SSI_2.INTSEL_in_pin_93;
        CONNECT1151        C66XX_S.SHARED_SYSTEM.CP_INTC0.cp_intc_out22, C66XX_S.CPU_SYSTEM_2.CGEM_SSI_2.INTSEL_in_pin_94;
        CONNECT1152        C66XX_S.SHARED_SYSTEM.CP_INTC0.cp_intc_out23, C66XX_S.CPU_SYSTEM_2.CGEM_SSI_2.INTSEL_in_pin_95;
        CONNECT1153        C66XX_S.SHARED_SYSTEM.CP_INTC0.cp_intc_out54, C66XX_S.CPU_SYSTEM_2.CGEM_SSI_2.INTSEL_in_pin_21;
        CONNECT1154        C66XX_S.SHARED_SYSTEM.CP_INTC0.cp_intc_out55, C66XX_S.CPU_SYSTEM_2.CGEM_SSI_2.INTSEL_in_pin_22;
        CONNECT1155        C66XX_S.SHARED_SYSTEM.CP_INTC0.cp_intc_out56, C66XX_S.CPU_SYSTEM_2.CGEM_SSI_2.INTSEL_in_pin_23;
        CONNECT1156        C66XX_S.SHARED_SYSTEM.CP_INTC0.cp_intc_out57, C66XX_S.CPU_SYSTEM_2.CGEM_SSI_2.INTSEL_in_pin_24;
        CONNECT1157        C66XX_S.SHARED_SYSTEM.CP_INTC0.cp_intc_out58, C66XX_S.CPU_SYSTEM_2.CGEM_SSI_2.INTSEL_in_pin_25;
        CONNECT1158        C66XX_S.SHARED_SYSTEM.CP_INTC0.cp_intc_out59, C66XX_S.CPU_SYSTEM_2.CGEM_SSI_2.INTSEL_in_pin_26;
        CONNECT1159        C66XX_S.SHARED_SYSTEM.CP_INTC0.cp_intc_out60, C66XX_S.CPU_SYSTEM_2.CGEM_SSI_2.INTSEL_in_pin_27;
        CONNECT1160        C66XX_S.SHARED_SYSTEM.CP_INTC0.cp_intc_out61, C66XX_S.CPU_SYSTEM_2.CGEM_SSI_2.INTSEL_in_pin_28;
        CONNECT1161        C66XX_S.SHARED_SYSTEM.CP_INTC0.cp_intc_out62, C66XX_S.CPU_SYSTEM_2.CGEM_SSI_2.INTSEL_in_pin_29;
        CONNECT1162        C66XX_S.SHARED_SYSTEM.CP_INTC0.cp_intc_out63, C66XX_S.CPU_SYSTEM_2.CGEM_SSI_2.INTSEL_in_pin_30;
        CONNECT1163        C66XX_S.SHARED_SYSTEM.CP_INTC0.cp_intc_out64, C66XX_S.CPU_SYSTEM_2.CGEM_SSI_2.INTSEL_in_pin_31;
        //!  With CGEM_3
    //  CONNECT1135     C66XX_S.SHARED_SYSTEM.CP_INTC0.cp_intc_out24, C66XX_S.CPU_SYSTEM_3.CGEM_SSI_3.INTSEL_in_pin_60;
    //  CONNECT1136     C66XX_S.SHARED_SYSTEM.CP_INTC0.cp_intc_out25, C66XX_S.CPU_SYSTEM_3.CGEM_SSI_3.INTSEL_in_pin_61;
        CONNECT1164        C66XX_S.SHARED_SYSTEM.CP_INTC0.cp_intc_out26, C66XX_S.CPU_SYSTEM_3.CGEM_SSI_3.INTSEL_in_pin_62;
        CONNECT1165        C66XX_S.SHARED_SYSTEM.CP_INTC0.cp_intc_out27, C66XX_S.CPU_SYSTEM_3.CGEM_SSI_3.INTSEL_in_pin_63;
        CONNECT1166        C66XX_S.SHARED_SYSTEM.CP_INTC0.cp_intc_out28, C66XX_S.CPU_SYSTEM_3.CGEM_SSI_3.INTSEL_in_pin_92;
        CONNECT1167        C66XX_S.SHARED_SYSTEM.CP_INTC0.cp_intc_out29, C66XX_S.CPU_SYSTEM_3.CGEM_SSI_3.INTSEL_in_pin_93;
        CONNECT1168        C66XX_S.SHARED_SYSTEM.CP_INTC0.cp_intc_out30, C66XX_S.CPU_SYSTEM_3.CGEM_SSI_3.INTSEL_in_pin_94;
        CONNECT1169        C66XX_S.SHARED_SYSTEM.CP_INTC0.cp_intc_out31, C66XX_S.CPU_SYSTEM_3.CGEM_SSI_3.INTSEL_in_pin_95;
        CONNECT1170        C66XX_S.SHARED_SYSTEM.CP_INTC0.cp_intc_out65, C66XX_S.CPU_SYSTEM_3.CGEM_SSI_3.INTSEL_in_pin_21;
        CONNECT1171        C66XX_S.SHARED_SYSTEM.CP_INTC0.cp_intc_out66, C66XX_S.CPU_SYSTEM_3.CGEM_SSI_3.INTSEL_in_pin_22;
        CONNECT1172        C66XX_S.SHARED_SYSTEM.CP_INTC0.cp_intc_out67, C66XX_S.CPU_SYSTEM_3.CGEM_SSI_3.INTSEL_in_pin_23;
        CONNECT1173        C66XX_S.SHARED_SYSTEM.CP_INTC0.cp_intc_out68, C66XX_S.CPU_SYSTEM_3.CGEM_SSI_3.INTSEL_in_pin_24;
        CONNECT1174        C66XX_S.SHARED_SYSTEM.CP_INTC0.cp_intc_out69, C66XX_S.CPU_SYSTEM_3.CGEM_SSI_3.INTSEL_in_pin_25;
        CONNECT1175        C66XX_S.SHARED_SYSTEM.CP_INTC0.cp_intc_out70, C66XX_S.CPU_SYSTEM_3.CGEM_SSI_3.INTSEL_in_pin_26;
        CONNECT1176        C66XX_S.SHARED_SYSTEM.CP_INTC0.cp_intc_out71, C66XX_S.CPU_SYSTEM_3.CGEM_SSI_3.INTSEL_in_pin_27;
        CONNECT1177        C66XX_S.SHARED_SYSTEM.CP_INTC0.cp_intc_out72, C66XX_S.CPU_SYSTEM_3.CGEM_SSI_3.INTSEL_in_pin_28;
        CONNECT1178        C66XX_S.SHARED_SYSTEM.CP_INTC0.cp_intc_out73, C66XX_S.CPU_SYSTEM_3.CGEM_SSI_3.INTSEL_in_pin_29;
        CONNECT1179        C66XX_S.SHARED_SYSTEM.CP_INTC0.cp_intc_out74, C66XX_S.CPU_SYSTEM_3.CGEM_SSI_3.INTSEL_in_pin_30;
        CONNECT1180        C66XX_S.SHARED_SYSTEM.CP_INTC0.cp_intc_out75, C66XX_S.CPU_SYSTEM_3.CGEM_SSI_3.INTSEL_in_pin_31;
        // Host Interrupt Connections for INTC1
        //!  With CGEM_4
    //  CONNECT1154     C66XX_S.SHARED_SYSTEM.CP_INTC1.cp_intc_out0, C66XX_S.CPU_SYSTEM_4.CGEM_SSI_4.INTSEL_in_pin_60;
    //  CONNECT1155     C66XX_S.SHARED_SYSTEM.CP_INTC1.cp_intc_out1, C66XX_S.CPU_SYSTEM_4.CGEM_SSI_4.INTSEL_in_pin_61;
        CONNECT1181        C66XX_S.SHARED_SYSTEM.CP_INTC1.cp_intc_out2, C66XX_S.CPU_SYSTEM_4.CGEM_SSI_4.INTSEL_in_pin_62;
        CONNECT1182        C66XX_S.SHARED_SYSTEM.CP_INTC1.cp_intc_out3, C66XX_S.CPU_SYSTEM_4.CGEM_SSI_4.INTSEL_in_pin_63;
        CONNECT1183        C66XX_S.SHARED_SYSTEM.CP_INTC1.cp_intc_out4, C66XX_S.CPU_SYSTEM_4.CGEM_SSI_4.INTSEL_in_pin_92;
        CONNECT1184        C66XX_S.SHARED_SYSTEM.CP_INTC1.cp_intc_out5, C66XX_S.CPU_SYSTEM_4.CGEM_SSI_4.INTSEL_in_pin_93;
        CONNECT1185        C66XX_S.SHARED_SYSTEM.CP_INTC1.cp_intc_out6, C66XX_S.CPU_SYSTEM_4.CGEM_SSI_4.INTSEL_in_pin_94;
        CONNECT1186        C66XX_S.SHARED_SYSTEM.CP_INTC1.cp_intc_out7, C66XX_S.CPU_SYSTEM_4.CGEM_SSI_4.INTSEL_in_pin_95;
        CONNECT1187        C66XX_S.SHARED_SYSTEM.CP_INTC1.cp_intc_out32, C66XX_S.CPU_SYSTEM_4.CGEM_SSI_4.INTSEL_in_pin_21;
        CONNECT1188        C66XX_S.SHARED_SYSTEM.CP_INTC1.cp_intc_out33, C66XX_S.CPU_SYSTEM_4.CGEM_SSI_4.INTSEL_in_pin_22;
        CONNECT1189        C66XX_S.SHARED_SYSTEM.CP_INTC1.cp_intc_out34, C66XX_S.CPU_SYSTEM_4.CGEM_SSI_4.INTSEL_in_pin_23;
        CONNECT1190        C66XX_S.SHARED_SYSTEM.CP_INTC1.cp_intc_out35, C66XX_S.CPU_SYSTEM_4.CGEM_SSI_4.INTSEL_in_pin_24;
        CONNECT1191        C66XX_S.SHARED_SYSTEM.CP_INTC1.cp_intc_out36, C66XX_S.CPU_SYSTEM_4.CGEM_SSI_4.INTSEL_in_pin_25;
        CONNECT1192        C66XX_S.SHARED_SYSTEM.CP_INTC1.cp_intc_out37, C66XX_S.CPU_SYSTEM_4.CGEM_SSI_4.INTSEL_in_pin_26;
        CONNECT1193        C66XX_S.SHARED_SYSTEM.CP_INTC1.cp_intc_out38, C66XX_S.CPU_SYSTEM_4.CGEM_SSI_4.INTSEL_in_pin_27;
        CONNECT1194        C66XX_S.SHARED_SYSTEM.CP_INTC1.cp_intc_out39, C66XX_S.CPU_SYSTEM_4.CGEM_SSI_4.INTSEL_in_pin_28;
        CONNECT1195        C66XX_S.SHARED_SYSTEM.CP_INTC1.cp_intc_out40, C66XX_S.CPU_SYSTEM_4.CGEM_SSI_4.INTSEL_in_pin_29;
        CONNECT1196        C66XX_S.SHARED_SYSTEM.CP_INTC1.cp_intc_out41, C66XX_S.CPU_SYSTEM_4.CGEM_SSI_4.INTSEL_in_pin_30;
        CONNECT1197        C66XX_S.SHARED_SYSTEM.CP_INTC1.cp_intc_out42, C66XX_S.CPU_SYSTEM_4.CGEM_SSI_4.INTSEL_in_pin_31;
        //!  With CGEM_5
    //  CONNECT1173     C66XX_S.SHARED_SYSTEM.CP_INTC1.cp_intc_out8, C66XX_S.CPU_SYSTEM_5.CGEM_SSI_5.INTSEL_in_pin_60;
    //  CONNECT1174     C66XX_S.SHARED_SYSTEM.CP_INTC1.cp_intc_out9, C66XX_S.CPU_SYSTEM_5.CGEM_SSI_5.INTSEL_in_pin_61;
        CONNECT1198        C66XX_S.SHARED_SYSTEM.CP_INTC1.cp_intc_out10, C66XX_S.CPU_SYSTEM_5.CGEM_SSI_5.INTSEL_in_pin_62;
        CONNECT1199        C66XX_S.SHARED_SYSTEM.CP_INTC1.cp_intc_out11, C66XX_S.CPU_SYSTEM_5.CGEM_SSI_5.INTSEL_in_pin_63;
        CONNECT1200        C66XX_S.SHARED_SYSTEM.CP_INTC1.cp_intc_out12, C66XX_S.CPU_SYSTEM_5.CGEM_SSI_5.INTSEL_in_pin_92;
        CONNECT1201        C66XX_S.SHARED_SYSTEM.CP_INTC1.cp_intc_out13, C66XX_S.CPU_SYSTEM_5.CGEM_SSI_5.INTSEL_in_pin_93;
        CONNECT1202        C66XX_S.SHARED_SYSTEM.CP_INTC1.cp_intc_out14, C66XX_S.CPU_SYSTEM_5.CGEM_SSI_5.INTSEL_in_pin_94;
        CONNECT1203        C66XX_S.SHARED_SYSTEM.CP_INTC1.cp_intc_out15, C66XX_S.CPU_SYSTEM_5.CGEM_SSI_5.INTSEL_in_pin_95;
        CONNECT1204        C66XX_S.SHARED_SYSTEM.CP_INTC1.cp_intc_out43, C66XX_S.CPU_SYSTEM_5.CGEM_SSI_5.INTSEL_in_pin_21;
        CONNECT1205        C66XX_S.SHARED_SYSTEM.CP_INTC1.cp_intc_out44, C66XX_S.CPU_SYSTEM_5.CGEM_SSI_5.INTSEL_in_pin_22;
        CONNECT1206        C66XX_S.SHARED_SYSTEM.CP_INTC1.cp_intc_out45, C66XX_S.CPU_SYSTEM_5.CGEM_SSI_5.INTSEL_in_pin_23;
        CONNECT1207        C66XX_S.SHARED_SYSTEM.CP_INTC1.cp_intc_out46, C66XX_S.CPU_SYSTEM_5.CGEM_SSI_5.INTSEL_in_pin_24;
        CONNECT1208        C66XX_S.SHARED_SYSTEM.CP_INTC1.cp_intc_out47, C66XX_S.CPU_SYSTEM_5.CGEM_SSI_5.INTSEL_in_pin_25;
        CONNECT1209        C66XX_S.SHARED_SYSTEM.CP_INTC1.cp_intc_out48, C66XX_S.CPU_SYSTEM_5.CGEM_SSI_5.INTSEL_in_pin_26;
        CONNECT1210        C66XX_S.SHARED_SYSTEM.CP_INTC1.cp_intc_out49, C66XX_S.CPU_SYSTEM_5.CGEM_SSI_5.INTSEL_in_pin_27;
        CONNECT1211        C66XX_S.SHARED_SYSTEM.CP_INTC1.cp_intc_out50, C66XX_S.CPU_SYSTEM_5.CGEM_SSI_5.INTSEL_in_pin_28;
        CONNECT1212        C66XX_S.SHARED_SYSTEM.CP_INTC1.cp_intc_out51, C66XX_S.CPU_SYSTEM_5.CGEM_SSI_5.INTSEL_in_pin_29;
        CONNECT1213        C66XX_S.SHARED_SYSTEM.CP_INTC1.cp_intc_out52, C66XX_S.CPU_SYSTEM_5.CGEM_SSI_5.INTSEL_in_pin_30;
        CONNECT1214        C66XX_S.SHARED_SYSTEM.CP_INTC1.cp_intc_out53, C66XX_S.CPU_SYSTEM_5.CGEM_SSI_5.INTSEL_in_pin_31;
        //!  With CGEM_6
    //  CONNECT1192     C66XX_S.SHARED_SYSTEM.CP_INTC1.cp_intc_out16, C66XX_S.CPU_SYSTEM_6.CGEM_SSI_6.INTSEL_in_pin_60;
    //  CONNECT1193     C66XX_S.SHARED_SYSTEM.CP_INTC1.cp_intc_out17, C66XX_S.CPU_SYSTEM_6.CGEM_SSI_6.INTSEL_in_pin_61;
        CONNECT1215        C66XX_S.SHARED_SYSTEM.CP_INTC1.cp_intc_out18, C66XX_S.CPU_SYSTEM_6.CGEM_SSI_6.INTSEL_in_pin_62;
        CONNECT1216        C66XX_S.SHARED_SYSTEM.CP_INTC1.cp_intc_out19, C66XX_S.CPU_SYSTEM_6.CGEM_SSI_6.INTSEL_in_pin_63;
        CONNECT1217        C66XX_S.SHARED_SYSTEM.CP_INTC1.cp_intc_out20, C66XX_S.CPU_SYSTEM_6.CGEM_SSI_6.INTSEL_in_pin_92;
        CONNECT1218        C66XX_S.SHARED_SYSTEM.CP_INTC1.cp_intc_out21, C66XX_S.CPU_SYSTEM_6.CGEM_SSI_6.INTSEL_in_pin_93;
        CONNECT1219        C66XX_S.SHARED_SYSTEM.CP_INTC1.cp_intc_out22, C66XX_S.CPU_SYSTEM_6.CGEM_SSI_6.INTSEL_in_pin_94;
        CONNECT1220        C66XX_S.SHARED_SYSTEM.CP_INTC1.cp_intc_out23, C66XX_S.CPU_SYSTEM_6.CGEM_SSI_6.INTSEL_in_pin_95;
        CONNECT1221        C66XX_S.SHARED_SYSTEM.CP_INTC1.cp_intc_out54, C66XX_S.CPU_SYSTEM_6.CGEM_SSI_6.INTSEL_in_pin_21;
        CONNECT1222        C66XX_S.SHARED_SYSTEM.CP_INTC1.cp_intc_out55, C66XX_S.CPU_SYSTEM_6.CGEM_SSI_6.INTSEL_in_pin_22;
        CONNECT1223        C66XX_S.SHARED_SYSTEM.CP_INTC1.cp_intc_out56, C66XX_S.CPU_SYSTEM_6.CGEM_SSI_6.INTSEL_in_pin_23;
        CONNECT1224        C66XX_S.SHARED_SYSTEM.CP_INTC1.cp_intc_out57, C66XX_S.CPU_SYSTEM_6.CGEM_SSI_6.INTSEL_in_pin_24;
        CONNECT1225        C66XX_S.SHARED_SYSTEM.CP_INTC1.cp_intc_out58, C66XX_S.CPU_SYSTEM_6.CGEM_SSI_6.INTSEL_in_pin_25;
        CONNECT1226        C66XX_S.SHARED_SYSTEM.CP_INTC1.cp_intc_out59, C66XX_S.CPU_SYSTEM_6.CGEM_SSI_6.INTSEL_in_pin_26;
        CONNECT1227        C66XX_S.SHARED_SYSTEM.CP_INTC1.cp_intc_out60, C66XX_S.CPU_SYSTEM_6.CGEM_SSI_6.INTSEL_in_pin_27;
        CONNECT1228        C66XX_S.SHARED_SYSTEM.CP_INTC1.cp_intc_out61, C66XX_S.CPU_SYSTEM_6.CGEM_SSI_6.INTSEL_in_pin_28;
        CONNECT1229        C66XX_S.SHARED_SYSTEM.CP_INTC1.cp_intc_out62, C66XX_S.CPU_SYSTEM_6.CGEM_SSI_6.INTSEL_in_pin_29;
        CONNECT1230        C66XX_S.SHARED_SYSTEM.CP_INTC1.cp_intc_out63, C66XX_S.CPU_SYSTEM_6.CGEM_SSI_6.INTSEL_in_pin_30;
        CONNECT1231        C66XX_S.SHARED_SYSTEM.CP_INTC1.cp_intc_out64, C66XX_S.CPU_SYSTEM_6.CGEM_SSI_6.INTSEL_in_pin_31;
        //!  With CGEM_7
    //  CONNECT1211     C66XX_S.SHARED_SYSTEM.CP_INTC1.cp_intc_out24, C66XX_S.CPU_SYSTEM_7.CGEM_SSI_7.INTSEL_in_pin_60;
    //  CONNECT1212     C66XX_S.SHARED_SYSTEM.CP_INTC1.cp_intc_out25, C66XX_S.CPU_SYSTEM_7.CGEM_SSI_7.INTSEL_in_pin_61;
        CONNECT1232        C66XX_S.SHARED_SYSTEM.CP_INTC1.cp_intc_out26, C66XX_S.CPU_SYSTEM_7.CGEM_SSI_7.INTSEL_in_pin_62;
        CONNECT1233        C66XX_S.SHARED_SYSTEM.CP_INTC1.cp_intc_out27, C66XX_S.CPU_SYSTEM_7.CGEM_SSI_7.INTSEL_in_pin_63;
        CONNECT1234        C66XX_S.SHARED_SYSTEM.CP_INTC1.cp_intc_out28, C66XX_S.CPU_SYSTEM_7.CGEM_SSI_7.INTSEL_in_pin_92;
        CONNECT1235        C66XX_S.SHARED_SYSTEM.CP_INTC1.cp_intc_out29, C66XX_S.CPU_SYSTEM_7.CGEM_SSI_7.INTSEL_in_pin_93;
        CONNECT1236        C66XX_S.SHARED_SYSTEM.CP_INTC1.cp_intc_out30, C66XX_S.CPU_SYSTEM_7.CGEM_SSI_7.INTSEL_in_pin_94;
        CONNECT1237        C66XX_S.SHARED_SYSTEM.CP_INTC1.cp_intc_out31, C66XX_S.CPU_SYSTEM_7.CGEM_SSI_7.INTSEL_in_pin_95;
        CONNECT1238        C66XX_S.SHARED_SYSTEM.CP_INTC1.cp_intc_out65, C66XX_S.CPU_SYSTEM_7.CGEM_SSI_7.INTSEL_in_pin_21;
        CONNECT1239        C66XX_S.SHARED_SYSTEM.CP_INTC1.cp_intc_out66, C66XX_S.CPU_SYSTEM_7.CGEM_SSI_7.INTSEL_in_pin_22;
        CONNECT1240        C66XX_S.SHARED_SYSTEM.CP_INTC1.cp_intc_out67, C66XX_S.CPU_SYSTEM_7.CGEM_SSI_7.INTSEL_in_pin_23;
        CONNECT1241        C66XX_S.SHARED_SYSTEM.CP_INTC1.cp_intc_out68, C66XX_S.CPU_SYSTEM_7.CGEM_SSI_7.INTSEL_in_pin_24;
        CONNECT1242        C66XX_S.SHARED_SYSTEM.CP_INTC1.cp_intc_out69, C66XX_S.CPU_SYSTEM_7.CGEM_SSI_7.INTSEL_in_pin_25;
        CONNECT1243        C66XX_S.SHARED_SYSTEM.CP_INTC1.cp_intc_out70, C66XX_S.CPU_SYSTEM_7.CGEM_SSI_7.INTSEL_in_pin_26;
        CONNECT1244        C66XX_S.SHARED_SYSTEM.CP_INTC1.cp_intc_out71, C66XX_S.CPU_SYSTEM_7.CGEM_SSI_7.INTSEL_in_pin_27;
        CONNECT1245        C66XX_S.SHARED_SYSTEM.CP_INTC1.cp_intc_out72, C66XX_S.CPU_SYSTEM_7.CGEM_SSI_7.INTSEL_in_pin_28;
        CONNECT1246        C66XX_S.SHARED_SYSTEM.CP_INTC1.cp_intc_out73, C66XX_S.CPU_SYSTEM_7.CGEM_SSI_7.INTSEL_in_pin_29;
        CONNECT1247        C66XX_S.SHARED_SYSTEM.CP_INTC1.cp_intc_out74, C66XX_S.CPU_SYSTEM_7.CGEM_SSI_7.INTSEL_in_pin_30;
        CONNECT1248        C66XX_S.SHARED_SYSTEM.CP_INTC1.cp_intc_out75, C66XX_S.CPU_SYSTEM_7.CGEM_SSI_7.INTSEL_in_pin_31;
        // Host Interrupt Connections for INTC2
        //!  With EDMA_1
        CONNECT1249        C66XX_S.SHARED_SYSTEM.CP_INTC2.cp_intc_out0, C66XX_S.SHARED_SYSTEM.EDMA_1_evt_in_pin42;
        CONNECT1250        C66XX_S.SHARED_SYSTEM.CP_INTC2.cp_intc_out1, C66XX_S.SHARED_SYSTEM.EDMA_1_evt_in_pin43;
        CONNECT1251        C66XX_S.SHARED_SYSTEM.CP_INTC2.cp_intc_out2, C66XX_S.SHARED_SYSTEM.EDMA_1_evt_in_pin44;
        CONNECT1252        C66XX_S.SHARED_SYSTEM.CP_INTC2.cp_intc_out3, C66XX_S.SHARED_SYSTEM.EDMA_1_evt_in_pin45;
        CONNECT1253        C66XX_S.SHARED_SYSTEM.CP_INTC2.cp_intc_out4, C66XX_S.SHARED_SYSTEM.EDMA_1_evt_in_pin46;
        CONNECT1254        C66XX_S.SHARED_SYSTEM.CP_INTC2.cp_intc_out5, C66XX_S.SHARED_SYSTEM.EDMA_1_evt_in_pin47;
        CONNECT1255        C66XX_S.SHARED_SYSTEM.CP_INTC2.cp_intc_out6, C66XX_S.SHARED_SYSTEM.EDMA_1_evt_in_pin48;
        CONNECT1256        C66XX_S.SHARED_SYSTEM.CP_INTC2.cp_intc_out7, C66XX_S.SHARED_SYSTEM.EDMA_1_evt_in_pin49;
        CONNECT1257        C66XX_S.SHARED_SYSTEM.CP_INTC2.cp_intc_out8, C66XX_S.SHARED_SYSTEM.EDMA_1_evt_in_pin50;
        CONNECT1258        C66XX_S.SHARED_SYSTEM.CP_INTC2.cp_intc_out9, C66XX_S.SHARED_SYSTEM.EDMA_1_evt_in_pin51;
        CONNECT1259        C66XX_S.SHARED_SYSTEM.CP_INTC2.cp_intc_out10, C66XX_S.SHARED_SYSTEM.EDMA_1_evt_in_pin52;
        CONNECT1260        C66XX_S.SHARED_SYSTEM.CP_INTC2.cp_intc_out11, C66XX_S.SHARED_SYSTEM.EDMA_1_evt_in_pin53;
        CONNECT1261        C66XX_S.SHARED_SYSTEM.CP_INTC2.cp_intc_out12, C66XX_S.SHARED_SYSTEM.EDMA_1_evt_in_pin54;
        CONNECT1262        C66XX_S.SHARED_SYSTEM.CP_INTC2.cp_intc_out13, C66XX_S.SHARED_SYSTEM.EDMA_1_evt_in_pin55;
        CONNECT1263        C66XX_S.SHARED_SYSTEM.CP_INTC2.cp_intc_out14, C66XX_S.SHARED_SYSTEM.EDMA_1_evt_in_pin56;
        CONNECT1264        C66XX_S.SHARED_SYSTEM.CP_INTC2.cp_intc_out15, C66XX_S.SHARED_SYSTEM.EDMA_1_evt_in_pin57;
        CONNECT1265        C66XX_S.SHARED_SYSTEM.CP_INTC2.cp_intc_out16, C66XX_S.SHARED_SYSTEM.EDMA_1_evt_in_pin58;
        CONNECT1266        C66XX_S.SHARED_SYSTEM.CP_INTC2.cp_intc_out17, C66XX_S.SHARED_SYSTEM.EDMA_1_evt_in_pin59;
        CONNECT1267        C66XX_S.SHARED_SYSTEM.CP_INTC2.cp_intc_out18, C66XX_S.SHARED_SYSTEM.EDMA_1_evt_in_pin60;
        CONNECT1268        C66XX_S.SHARED_SYSTEM.CP_INTC2.cp_intc_out19, C66XX_S.SHARED_SYSTEM.EDMA_1_evt_in_pin61;
        CONNECT1269        C66XX_S.SHARED_SYSTEM.CP_INTC2.cp_intc_out20, C66XX_S.SHARED_SYSTEM.EDMA_1_evt_in_pin62;
        CONNECT1270        C66XX_S.SHARED_SYSTEM.CP_INTC2.cp_intc_out21, C66XX_S.SHARED_SYSTEM.EDMA_1_evt_in_pin63;
        CONNECT1271        C66XX_S.SHARED_SYSTEM.CP_INTC2.cp_intc_out44, C66XX_S.SHARED_SYSTEM.EDMA_1_evt_in_pin38;
        CONNECT1272        C66XX_S.SHARED_SYSTEM.CP_INTC2.cp_intc_out45, C66XX_S.SHARED_SYSTEM.EDMA_1_evt_in_pin39;
        CONNECT1273        C66XX_S.SHARED_SYSTEM.CP_INTC2.cp_intc_out46, C66XX_S.SHARED_SYSTEM.EDMA_1_evt_in_pin40;
        CONNECT1274        C66XX_S.SHARED_SYSTEM.CP_INTC2.cp_intc_out47, C66XX_S.SHARED_SYSTEM.EDMA_1_evt_in_pin41;
        //!  With EDMA_2
        CONNECT1275        C66XX_S.SHARED_SYSTEM.CP_INTC2.cp_intc_out22, C66XX_S.SHARED_SYSTEM.EDMA_2_evt_in_pin42;
        CONNECT1276        C66XX_S.SHARED_SYSTEM.CP_INTC2.cp_intc_out23, C66XX_S.SHARED_SYSTEM.EDMA_2_evt_in_pin43;
        CONNECT1277        C66XX_S.SHARED_SYSTEM.CP_INTC2.cp_intc_out24, C66XX_S.SHARED_SYSTEM.EDMA_2_evt_in_pin44;
        CONNECT1278        C66XX_S.SHARED_SYSTEM.CP_INTC2.cp_intc_out25, C66XX_S.SHARED_SYSTEM.EDMA_2_evt_in_pin45;
        CONNECT1279        C66XX_S.SHARED_SYSTEM.CP_INTC2.cp_intc_out26, C66XX_S.SHARED_SYSTEM.EDMA_2_evt_in_pin46;
        CONNECT1280        C66XX_S.SHARED_SYSTEM.CP_INTC2.cp_intc_out27, C66XX_S.SHARED_SYSTEM.EDMA_2_evt_in_pin47;
        CONNECT1281        C66XX_S.SHARED_SYSTEM.CP_INTC2.cp_intc_out28, C66XX_S.SHARED_SYSTEM.EDMA_2_evt_in_pin48;
        CONNECT1282        C66XX_S.SHARED_SYSTEM.CP_INTC2.cp_intc_out29, C66XX_S.SHARED_SYSTEM.EDMA_2_evt_in_pin49;
        CONNECT1283        C66XX_S.SHARED_SYSTEM.CP_INTC2.cp_intc_out30, C66XX_S.SHARED_SYSTEM.EDMA_2_evt_in_pin50;
        CONNECT1284        C66XX_S.SHARED_SYSTEM.CP_INTC2.cp_intc_out31, C66XX_S.SHARED_SYSTEM.EDMA_2_evt_in_pin51;
        CONNECT1285        C66XX_S.SHARED_SYSTEM.CP_INTC2.cp_intc_out32, C66XX_S.SHARED_SYSTEM.EDMA_2_evt_in_pin52;
        CONNECT1286        C66XX_S.SHARED_SYSTEM.CP_INTC2.cp_intc_out33, C66XX_S.SHARED_SYSTEM.EDMA_2_evt_in_pin53;
        CONNECT1287        C66XX_S.SHARED_SYSTEM.CP_INTC2.cp_intc_out34, C66XX_S.SHARED_SYSTEM.EDMA_2_evt_in_pin54;
        CONNECT1288        C66XX_S.SHARED_SYSTEM.CP_INTC2.cp_intc_out35, C66XX_S.SHARED_SYSTEM.EDMA_2_evt_in_pin55;
        CONNECT1289        C66XX_S.SHARED_SYSTEM.CP_INTC2.cp_intc_out36, C66XX_S.SHARED_SYSTEM.EDMA_2_evt_in_pin56;
        CONNECT1290        C66XX_S.SHARED_SYSTEM.CP_INTC2.cp_intc_out37, C66XX_S.SHARED_SYSTEM.EDMA_2_evt_in_pin57;
        CONNECT1291        C66XX_S.SHARED_SYSTEM.CP_INTC2.cp_intc_out38, C66XX_S.SHARED_SYSTEM.EDMA_2_evt_in_pin58;
        CONNECT1292        C66XX_S.SHARED_SYSTEM.CP_INTC2.cp_intc_out39, C66XX_S.SHARED_SYSTEM.EDMA_2_evt_in_pin59;
        CONNECT1293        C66XX_S.SHARED_SYSTEM.CP_INTC2.cp_intc_out40, C66XX_S.SHARED_SYSTEM.EDMA_2_evt_in_pin60;
        CONNECT1294        C66XX_S.SHARED_SYSTEM.CP_INTC2.cp_intc_out41, C66XX_S.SHARED_SYSTEM.EDMA_2_evt_in_pin61;
        CONNECT1295        C66XX_S.SHARED_SYSTEM.CP_INTC2.cp_intc_out42, C66XX_S.SHARED_SYSTEM.EDMA_2_evt_in_pin62;
        CONNECT1296        C66XX_S.SHARED_SYSTEM.CP_INTC2.cp_intc_out43, C66XX_S.SHARED_SYSTEM.EDMA_2_evt_in_pin63;
        CONNECT1297        C66XX_S.SHARED_SYSTEM.CP_INTC2.cp_intc_out48, C66XX_S.SHARED_SYSTEM.EDMA_2_evt_in_pin38;
        CONNECT1298        C66XX_S.SHARED_SYSTEM.CP_INTC2.cp_intc_out49, C66XX_S.SHARED_SYSTEM.EDMA_2_evt_in_pin39;
        CONNECT1299        C66XX_S.SHARED_SYSTEM.CP_INTC2.cp_intc_out50, C66XX_S.SHARED_SYSTEM.EDMA_2_evt_in_pin40;
        CONNECT1300        C66XX_S.SHARED_SYSTEM.CP_INTC2.cp_intc_out51, C66XX_S.SHARED_SYSTEM.EDMA_2_evt_in_pin41;
        // Host Interrupt Connections for INTC3
        //!  With EDMA_0
        CONNECT1301        C66XX_S.SHARED_SYSTEM.CP_INTC3.cp_intc_out0, C66XX_S.SHARED_SYSTEM.EDMA_0_evt_in_pin8;
        CONNECT1302        C66XX_S.SHARED_SYSTEM.CP_INTC3.cp_intc_out1, C66XX_S.SHARED_SYSTEM.EDMA_0_evt_in_pin9;
        CONNECT1303        C66XX_S.SHARED_SYSTEM.CP_INTC3.cp_intc_out2, C66XX_S.SHARED_SYSTEM.EDMA_0_evt_in_pin10;
        CONNECT1304        C66XX_S.SHARED_SYSTEM.CP_INTC3.cp_intc_out3, C66XX_S.SHARED_SYSTEM.EDMA_0_evt_in_pin11;
        CONNECT1305        C66XX_S.SHARED_SYSTEM.CP_INTC3.cp_intc_out4, C66XX_S.SHARED_SYSTEM.EDMA_0_evt_in_pin12;
        CONNECT1306        C66XX_S.SHARED_SYSTEM.CP_INTC3.cp_intc_out5, C66XX_S.SHARED_SYSTEM.EDMA_0_evt_in_pin13;
        CONNECT1307        C66XX_S.SHARED_SYSTEM.CP_INTC3.cp_intc_out6, C66XX_S.SHARED_SYSTEM.EDMA_0_evt_in_pin14;
        CONNECT1308        C66XX_S.SHARED_SYSTEM.CP_INTC3.cp_intc_out7, C66XX_S.SHARED_SYSTEM.EDMA_0_evt_in_pin15;
        // Primary Interrupt Connections with CPU
        //!CPU0
        //SEMAPHORE
        CONNECT1309        C66XX_S.CPU_SYSTEM_0.CGEM_SSI_0.INTSEL_in_pin_15, C66XX_S.SHARED_SYSTEM.SEMAPHORE.semaphore2_err_opin0;
        CONNECT1310        C66XX_S.CPU_SYSTEM_0.CGEM_SSI_0.INTSEL_in_pin_16, C66XX_S.SHARED_SYSTEM.SEMAPHORE.semaphore2_intr_opin0;
        //SRIO
        CONNECT1311        C66XX_S.CPU_SYSTEM_0.CGEM_SSI_0.INTSEL_in_pin_20, C66XX_S.SHARED_SYSTEM.SRIO.srio_intdst_intr16;
        //QUEUE_MANAGER
        CONNECT1312        C66XX_S.CPU_SYSTEM_0.CGEM_SSI_0.INTSEL_in_pin_32, C66XX_S.SHARED_SYSTEM.QUEUE_MANAGER.qmss_int0_0_opin;
        CONNECT1313        C66XX_S.CPU_SYSTEM_0.CGEM_SSI_0.INTSEL_in_pin_33, C66XX_S.SHARED_SYSTEM.QUEUE_MANAGER.qmss_int0_1_opin;
        CONNECT1314        C66XX_S.CPU_SYSTEM_0.CGEM_SSI_0.INTSEL_in_pin_34, C66XX_S.SHARED_SYSTEM.QUEUE_MANAGER.qmss_int0_2_opin;
        CONNECT1315        C66XX_S.CPU_SYSTEM_0.CGEM_SSI_0.INTSEL_in_pin_35, C66XX_S.SHARED_SYSTEM.QUEUE_MANAGER.qmss_int0_3_opin;
        CONNECT1316        C66XX_S.CPU_SYSTEM_0.CGEM_SSI_0.INTSEL_in_pin_36, C66XX_S.SHARED_SYSTEM.QUEUE_MANAGER.qmss_int0_4_opin;
        CONNECT1317        C66XX_S.CPU_SYSTEM_0.CGEM_SSI_0.INTSEL_in_pin_37, C66XX_S.SHARED_SYSTEM.QUEUE_MANAGER.qmss_int0_5_opin;
        CONNECT1318        C66XX_S.CPU_SYSTEM_0.CGEM_SSI_0.INTSEL_in_pin_38, C66XX_S.SHARED_SYSTEM.QUEUE_MANAGER.qmss_int0_6_opin;
        CONNECT1319        C66XX_S.CPU_SYSTEM_0.CGEM_SSI_0.INTSEL_in_pin_39, C66XX_S.SHARED_SYSTEM.QUEUE_MANAGER.qmss_int0_7_opin;
        CONNECT1320        C66XX_S.CPU_SYSTEM_0.CGEM_SSI_0.INTSEL_in_pin_40, C66XX_S.SHARED_SYSTEM.QUEUE_MANAGER.qmss_int0_8_opin;
        CONNECT1321        C66XX_S.CPU_SYSTEM_0.CGEM_SSI_0.INTSEL_in_pin_41, C66XX_S.SHARED_SYSTEM.QUEUE_MANAGER.qmss_int0_9_opin;
        CONNECT1322        C66XX_S.CPU_SYSTEM_0.CGEM_SSI_0.INTSEL_in_pin_42, C66XX_S.SHARED_SYSTEM.QUEUE_MANAGER.qmss_int0_10_opin;
        CONNECT1323        C66XX_S.CPU_SYSTEM_0.CGEM_SSI_0.INTSEL_in_pin_43, C66XX_S.SHARED_SYSTEM.QUEUE_MANAGER.qmss_int0_11_opin;
        CONNECT1324        C66XX_S.CPU_SYSTEM_0.CGEM_SSI_0.INTSEL_in_pin_44, C66XX_S.SHARED_SYSTEM.QUEUE_MANAGER.qmss_int0_12_opin;
        CONNECT1325        C66XX_S.CPU_SYSTEM_0.CGEM_SSI_0.INTSEL_in_pin_45, C66XX_S.SHARED_SYSTEM.QUEUE_MANAGER.qmss_int0_13_opin;
        CONNECT1326        C66XX_S.CPU_SYSTEM_0.CGEM_SSI_0.INTSEL_in_pin_46, C66XX_S.SHARED_SYSTEM.QUEUE_MANAGER.qmss_int0_14_opin;
        CONNECT1327        C66XX_S.CPU_SYSTEM_0.CGEM_SSI_0.INTSEL_in_pin_47, C66XX_S.SHARED_SYSTEM.QUEUE_MANAGER.qmss_int0_15_opin;
        CONNECT1328        C66XX_S.CPU_SYSTEM_0.CGEM_SSI_0.INTSEL_in_pin_48, C66XX_S.SHARED_SYSTEM.QUEUE_MANAGER.qmss_int1_0_opin;
        CONNECT1329        C66XX_S.CPU_SYSTEM_0.CGEM_SSI_0.INTSEL_in_pin_49, C66XX_S.SHARED_SYSTEM.QUEUE_MANAGER.qmss_int1_8_opin;
        CONNECT1330        C66XX_S.CPU_SYSTEM_0.CGEM_SSI_0.INTSEL_in_pin_50, C66XX_S.SHARED_SYSTEM.QUEUE_MANAGER.qmss_int1_16_opin;
        CONNECT1331        C66XX_S.CPU_SYSTEM_0.CGEM_SSI_0.INTSEL_in_pin_51, C66XX_S.SHARED_SYSTEM.QUEUE_MANAGER.qmss_int1_24_opin;
        //TIMERS
        CONNECT1332        C66XX_S.CPU_SYSTEM_0.CGEM_SSI_0.INTSEL_in_pin_64, C66XX_S.SHARED_SYSTEM.TIMER64_0_cpu_int_12;
        CONNECT1333        C66XX_S.CPU_SYSTEM_0.CGEM_SSI_0.INTSEL_in_pin_65, C66XX_S.SHARED_SYSTEM.TIMER64_0_cpu_int_34;
        CONNECT1334        C66XX_S.CPU_SYSTEM_0.CGEM_SSI_0.INTSEL_in_pin_66, C66XX_S.SHARED_SYSTEM.TIMER64_8_cpu_int_12;
        CONNECT1335        C66XX_S.CPU_SYSTEM_0.CGEM_SSI_0.INTSEL_in_pin_67, C66XX_S.SHARED_SYSTEM.TIMER64_8_cpu_int_34;
        CONNECT1336        C66XX_S.CPU_SYSTEM_0.CGEM_SSI_0.INTSEL_in_pin_68, C66XX_S.SHARED_SYSTEM.TIMER64_9_cpu_int_12;
        CONNECT1337        C66XX_S.CPU_SYSTEM_0.CGEM_SSI_0.INTSEL_in_pin_69, C66XX_S.SHARED_SYSTEM.TIMER64_9_cpu_int_34;
        CONNECT1338        C66XX_S.CPU_SYSTEM_0.CGEM_SSI_0.INTSEL_in_pin_70, C66XX_S.SHARED_SYSTEM.TIMER64_10_cpu_int_12;
        CONNECT1339        C66XX_S.CPU_SYSTEM_0.CGEM_SSI_0.INTSEL_in_pin_71, C66XX_S.SHARED_SYSTEM.TIMER64_10_cpu_int_34;
        CONNECT1340        C66XX_S.CPU_SYSTEM_0.CGEM_SSI_0.INTSEL_in_pin_72, C66XX_S.SHARED_SYSTEM.TIMER64_11_cpu_int_12;
        CONNECT1341        C66XX_S.CPU_SYSTEM_0.CGEM_SSI_0.INTSEL_in_pin_73, C66XX_S.SHARED_SYSTEM.TIMER64_11_cpu_int_34;
        CONNECT1342        C66XX_S.CPU_SYSTEM_0.CGEM_SSI_0.INTSEL_in_pin_74, C66XX_S.SHARED_SYSTEM.TIMER64_12_cpu_int_12;
        CONNECT1343        C66XX_S.CPU_SYSTEM_0.CGEM_SSI_0.INTSEL_in_pin_75, C66XX_S.SHARED_SYSTEM.TIMER64_12_cpu_int_34;
        CONNECT1344        C66XX_S.CPU_SYSTEM_0.CGEM_SSI_0.INTSEL_in_pin_76, C66XX_S.SHARED_SYSTEM.TIMER64_13_cpu_int_12;
        CONNECT1345        C66XX_S.CPU_SYSTEM_0.CGEM_SSI_0.INTSEL_in_pin_77, C66XX_S.SHARED_SYSTEM.TIMER64_13_cpu_int_34;
        CONNECT1346        C66XX_S.CPU_SYSTEM_0.CGEM_SSI_0.INTSEL_in_pin_78, C66XX_S.SHARED_SYSTEM.TIMER64_14_cpu_int_12;
        CONNECT1347        C66XX_S.CPU_SYSTEM_0.CGEM_SSI_0.INTSEL_in_pin_79, C66XX_S.SHARED_SYSTEM.TIMER64_14_cpu_int_34;
        CONNECT1348        C66XX_S.CPU_SYSTEM_0.CGEM_SSI_0.INTSEL_in_pin_80, C66XX_S.SHARED_SYSTEM.TIMER64_15_cpu_int_12;
        CONNECT1349        C66XX_S.CPU_SYSTEM_0.CGEM_SSI_0.INTSEL_in_pin_81, C66XX_S.SHARED_SYSTEM.TIMER64_15_cpu_int_34;
        //GPIO
        CONNECT1350        C66XX_S.CPU_SYSTEM_0.CGEM_SSI_0.INTSEL_in_pin_82, C66XX_S.SHARED_SYSTEM.GPIO.gpio_gpint8_opin;
        CONNECT1351        C66XX_S.CPU_SYSTEM_0.CGEM_SSI_0.INTSEL_in_pin_83, C66XX_S.SHARED_SYSTEM.GPIO.gpio_gpint9_opin;
        CONNECT1352        C66XX_S.CPU_SYSTEM_0.CGEM_SSI_0.INTSEL_in_pin_84, C66XX_S.SHARED_SYSTEM.GPIO.gpio_gpint10_opin;
        CONNECT1353        C66XX_S.CPU_SYSTEM_0.CGEM_SSI_0.INTSEL_in_pin_85, C66XX_S.SHARED_SYSTEM.GPIO.gpio_gpint11_opin;
        CONNECT1354        C66XX_S.CPU_SYSTEM_0.CGEM_SSI_0.INTSEL_in_pin_86, C66XX_S.SHARED_SYSTEM.GPIO.gpio_gpint12_opin;
        CONNECT1355        C66XX_S.CPU_SYSTEM_0.CGEM_SSI_0.INTSEL_in_pin_87, C66XX_S.SHARED_SYSTEM.GPIO.gpio_gpint13_opin;
        CONNECT1356        C66XX_S.CPU_SYSTEM_0.CGEM_SSI_0.INTSEL_in_pin_88, C66XX_S.SHARED_SYSTEM.GPIO.gpio_gpint14_opin;
        CONNECT1357        C66XX_S.CPU_SYSTEM_0.CGEM_SSI_0.INTSEL_in_pin_89, C66XX_S.SHARED_SYSTEM.GPIO.gpio_gpint15_opin;
        CONNECT1358        C66XX_S.CPU_SYSTEM_0.CGEM_SSI_0.INTSEL_in_pin_90, C66XX_S.SHARED_SYSTEM.GPIO.gpio_gpint0_opin;
        //IPC
        CONNECT1359        C66XX_S.CPU_SYSTEM_0.CGEM_SSI_0.INTSEL_in_pin_91, C66XX_S.SHARED_SYSTEM.IPC_cpu_int_0;
        //!CPU1
        //SEMAPHORE
        CONNECT1360        C66XX_S.CPU_SYSTEM_1.CGEM_SSI_1.INTSEL_in_pin_15, C66XX_S.SHARED_SYSTEM.SEMAPHORE.semaphore2_err_opin1;
        CONNECT1361        C66XX_S.CPU_SYSTEM_1.CGEM_SSI_1.INTSEL_in_pin_16, C66XX_S.SHARED_SYSTEM.SEMAPHORE.semaphore2_intr_opin1;
        //SRIO
        CONNECT1362        C66XX_S.CPU_SYSTEM_1.CGEM_SSI_1.INTSEL_in_pin_20, C66XX_S.SHARED_SYSTEM.SRIO.srio_intdst_intr17;
        //QUEUE_MANAGER
        CONNECT1363        C66XX_S.CPU_SYSTEM_1.CGEM_SSI_1.INTSEL_in_pin_32, C66XX_S.SHARED_SYSTEM.QUEUE_MANAGER.qmss_int0_0_opin;
        CONNECT1364        C66XX_S.CPU_SYSTEM_1.CGEM_SSI_1.INTSEL_in_pin_33, C66XX_S.SHARED_SYSTEM.QUEUE_MANAGER.qmss_int0_1_opin;
        CONNECT1365        C66XX_S.CPU_SYSTEM_1.CGEM_SSI_1.INTSEL_in_pin_34, C66XX_S.SHARED_SYSTEM.QUEUE_MANAGER.qmss_int0_2_opin;
        CONNECT1366        C66XX_S.CPU_SYSTEM_1.CGEM_SSI_1.INTSEL_in_pin_35, C66XX_S.SHARED_SYSTEM.QUEUE_MANAGER.qmss_int0_3_opin;
        CONNECT1367        C66XX_S.CPU_SYSTEM_1.CGEM_SSI_1.INTSEL_in_pin_36, C66XX_S.SHARED_SYSTEM.QUEUE_MANAGER.qmss_int0_4_opin;
        CONNECT1368        C66XX_S.CPU_SYSTEM_1.CGEM_SSI_1.INTSEL_in_pin_37, C66XX_S.SHARED_SYSTEM.QUEUE_MANAGER.qmss_int0_5_opin;
        CONNECT1369        C66XX_S.CPU_SYSTEM_1.CGEM_SSI_1.INTSEL_in_pin_38, C66XX_S.SHARED_SYSTEM.QUEUE_MANAGER.qmss_int0_6_opin;
        CONNECT1370        C66XX_S.CPU_SYSTEM_1.CGEM_SSI_1.INTSEL_in_pin_39, C66XX_S.SHARED_SYSTEM.QUEUE_MANAGER.qmss_int0_7_opin;
        CONNECT1371        C66XX_S.CPU_SYSTEM_1.CGEM_SSI_1.INTSEL_in_pin_40, C66XX_S.SHARED_SYSTEM.QUEUE_MANAGER.qmss_int0_8_opin;
        CONNECT1372        C66XX_S.CPU_SYSTEM_1.CGEM_SSI_1.INTSEL_in_pin_41, C66XX_S.SHARED_SYSTEM.QUEUE_MANAGER.qmss_int0_9_opin;
        CONNECT1373        C66XX_S.CPU_SYSTEM_1.CGEM_SSI_1.INTSEL_in_pin_42, C66XX_S.SHARED_SYSTEM.QUEUE_MANAGER.qmss_int0_10_opin;
        CONNECT1374        C66XX_S.CPU_SYSTEM_1.CGEM_SSI_1.INTSEL_in_pin_43, C66XX_S.SHARED_SYSTEM.QUEUE_MANAGER.qmss_int0_11_opin;
        CONNECT1375        C66XX_S.CPU_SYSTEM_1.CGEM_SSI_1.INTSEL_in_pin_44, C66XX_S.SHARED_SYSTEM.QUEUE_MANAGER.qmss_int0_12_opin;
        CONNECT1376        C66XX_S.CPU_SYSTEM_1.CGEM_SSI_1.INTSEL_in_pin_45, C66XX_S.SHARED_SYSTEM.QUEUE_MANAGER.qmss_int0_13_opin;
        CONNECT1377        C66XX_S.CPU_SYSTEM_1.CGEM_SSI_1.INTSEL_in_pin_46, C66XX_S.SHARED_SYSTEM.QUEUE_MANAGER.qmss_int0_14_opin;
        CONNECT1378        C66XX_S.CPU_SYSTEM_1.CGEM_SSI_1.INTSEL_in_pin_47, C66XX_S.SHARED_SYSTEM.QUEUE_MANAGER.qmss_int0_15_opin;
        CONNECT1379        C66XX_S.CPU_SYSTEM_1.CGEM_SSI_1.INTSEL_in_pin_48, C66XX_S.SHARED_SYSTEM.QUEUE_MANAGER.qmss_int1_1_opin;
        CONNECT1380        C66XX_S.CPU_SYSTEM_1.CGEM_SSI_1.INTSEL_in_pin_49, C66XX_S.SHARED_SYSTEM.QUEUE_MANAGER.qmss_int1_9_opin;
        CONNECT1381        C66XX_S.CPU_SYSTEM_1.CGEM_SSI_1.INTSEL_in_pin_50, C66XX_S.SHARED_SYSTEM.QUEUE_MANAGER.qmss_int1_17_opin;
        CONNECT1382        C66XX_S.CPU_SYSTEM_1.CGEM_SSI_1.INTSEL_in_pin_51, C66XX_S.SHARED_SYSTEM.QUEUE_MANAGER.qmss_int1_25_opin;
        //TIMERS
        CONNECT1383        C66XX_S.CPU_SYSTEM_1.CGEM_SSI_1.INTSEL_in_pin_64, C66XX_S.SHARED_SYSTEM.TIMER64_1_cpu_int_12;
        CONNECT1384        C66XX_S.CPU_SYSTEM_1.CGEM_SSI_1.INTSEL_in_pin_65, C66XX_S.SHARED_SYSTEM.TIMER64_1_cpu_int_34;
        CONNECT1385        C66XX_S.CPU_SYSTEM_1.CGEM_SSI_1.INTSEL_in_pin_66, C66XX_S.SHARED_SYSTEM.TIMER64_8_cpu_int_12;
        CONNECT1386        C66XX_S.CPU_SYSTEM_1.CGEM_SSI_1.INTSEL_in_pin_67, C66XX_S.SHARED_SYSTEM.TIMER64_8_cpu_int_34;
        CONNECT1387        C66XX_S.CPU_SYSTEM_1.CGEM_SSI_1.INTSEL_in_pin_68, C66XX_S.SHARED_SYSTEM.TIMER64_9_cpu_int_12;
        CONNECT1388        C66XX_S.CPU_SYSTEM_1.CGEM_SSI_1.INTSEL_in_pin_69, C66XX_S.SHARED_SYSTEM.TIMER64_9_cpu_int_34;
        CONNECT1389        C66XX_S.CPU_SYSTEM_1.CGEM_SSI_1.INTSEL_in_pin_70, C66XX_S.SHARED_SYSTEM.TIMER64_10_cpu_int_12;
        CONNECT1390        C66XX_S.CPU_SYSTEM_1.CGEM_SSI_1.INTSEL_in_pin_71, C66XX_S.SHARED_SYSTEM.TIMER64_10_cpu_int_34;
        CONNECT1391        C66XX_S.CPU_SYSTEM_1.CGEM_SSI_1.INTSEL_in_pin_72, C66XX_S.SHARED_SYSTEM.TIMER64_11_cpu_int_12;
        CONNECT1392        C66XX_S.CPU_SYSTEM_1.CGEM_SSI_1.INTSEL_in_pin_73, C66XX_S.SHARED_SYSTEM.TIMER64_11_cpu_int_34;
        CONNECT1393        C66XX_S.CPU_SYSTEM_1.CGEM_SSI_1.INTSEL_in_pin_74, C66XX_S.SHARED_SYSTEM.TIMER64_12_cpu_int_12;
        CONNECT1394        C66XX_S.CPU_SYSTEM_1.CGEM_SSI_1.INTSEL_in_pin_75, C66XX_S.SHARED_SYSTEM.TIMER64_12_cpu_int_34;
        CONNECT1395        C66XX_S.CPU_SYSTEM_1.CGEM_SSI_1.INTSEL_in_pin_76, C66XX_S.SHARED_SYSTEM.TIMER64_13_cpu_int_12;
        CONNECT1396        C66XX_S.CPU_SYSTEM_1.CGEM_SSI_1.INTSEL_in_pin_77, C66XX_S.SHARED_SYSTEM.TIMER64_13_cpu_int_34;
        CONNECT1397        C66XX_S.CPU_SYSTEM_1.CGEM_SSI_1.INTSEL_in_pin_78, C66XX_S.SHARED_SYSTEM.TIMER64_14_cpu_int_12;
        CONNECT1398        C66XX_S.CPU_SYSTEM_1.CGEM_SSI_1.INTSEL_in_pin_79, C66XX_S.SHARED_SYSTEM.TIMER64_14_cpu_int_34;
        CONNECT1399        C66XX_S.CPU_SYSTEM_1.CGEM_SSI_1.INTSEL_in_pin_80, C66XX_S.SHARED_SYSTEM.TIMER64_15_cpu_int_12;
        CONNECT1400        C66XX_S.CPU_SYSTEM_1.CGEM_SSI_1.INTSEL_in_pin_81, C66XX_S.SHARED_SYSTEM.TIMER64_15_cpu_int_34;
         //GPIO
        CONNECT1401        C66XX_S.CPU_SYSTEM_1.CGEM_SSI_1.INTSEL_in_pin_82, C66XX_S.SHARED_SYSTEM.GPIO.gpio_gpint8_opin;
        CONNECT1402        C66XX_S.CPU_SYSTEM_1.CGEM_SSI_1.INTSEL_in_pin_83, C66XX_S.SHARED_SYSTEM.GPIO.gpio_gpint9_opin;
        CONNECT1403        C66XX_S.CPU_SYSTEM_1.CGEM_SSI_1.INTSEL_in_pin_84, C66XX_S.SHARED_SYSTEM.GPIO.gpio_gpint10_opin;
        CONNECT1404        C66XX_S.CPU_SYSTEM_1.CGEM_SSI_1.INTSEL_in_pin_85, C66XX_S.SHARED_SYSTEM.GPIO.gpio_gpint11_opin;
        CONNECT1405        C66XX_S.CPU_SYSTEM_1.CGEM_SSI_1.INTSEL_in_pin_86, C66XX_S.SHARED_SYSTEM.GPIO.gpio_gpint12_opin;
        CONNECT1406        C66XX_S.CPU_SYSTEM_1.CGEM_SSI_1.INTSEL_in_pin_87, C66XX_S.SHARED_SYSTEM.GPIO.gpio_gpint13_opin;
        CONNECT1407        C66XX_S.CPU_SYSTEM_1.CGEM_SSI_1.INTSEL_in_pin_88, C66XX_S.SHARED_SYSTEM.GPIO.gpio_gpint14_opin;
        CONNECT1408        C66XX_S.CPU_SYSTEM_1.CGEM_SSI_1.INTSEL_in_pin_89, C66XX_S.SHARED_SYSTEM.GPIO.gpio_gpint15_opin;
        CONNECT1409        C66XX_S.CPU_SYSTEM_1.CGEM_SSI_1.INTSEL_in_pin_90, C66XX_S.SHARED_SYSTEM.GPIO.gpio_gpint1_opin;
        //IPC
        CONNECT1410        C66XX_S.CPU_SYSTEM_1.CGEM_SSI_1.INTSEL_in_pin_91, C66XX_S.SHARED_SYSTEM.IPC_cpu_int_1;
        //!CPU2
        //SEMAPHORE
        CONNECT1411        C66XX_S.CPU_SYSTEM_2.CGEM_SSI_2.INTSEL_in_pin_15, C66XX_S.SHARED_SYSTEM.SEMAPHORE.semaphore2_err_opin2;
        CONNECT1412        C66XX_S.CPU_SYSTEM_2.CGEM_SSI_2.INTSEL_in_pin_16, C66XX_S.SHARED_SYSTEM.SEMAPHORE.semaphore2_intr_opin2;
        //SRIO
        CONNECT1413        C66XX_S.CPU_SYSTEM_2.CGEM_SSI_2.INTSEL_in_pin_20, C66XX_S.SHARED_SYSTEM.SRIO.srio_intdst_intr18;
        //QUEUE_MANAGER
        CONNECT1414        C66XX_S.CPU_SYSTEM_2.CGEM_SSI_2.INTSEL_in_pin_32, C66XX_S.SHARED_SYSTEM.QUEUE_MANAGER.qmss_int0_0_opin;
        CONNECT1415        C66XX_S.CPU_SYSTEM_2.CGEM_SSI_2.INTSEL_in_pin_33, C66XX_S.SHARED_SYSTEM.QUEUE_MANAGER.qmss_int0_1_opin;
        CONNECT1416        C66XX_S.CPU_SYSTEM_2.CGEM_SSI_2.INTSEL_in_pin_34, C66XX_S.SHARED_SYSTEM.QUEUE_MANAGER.qmss_int0_2_opin;
        CONNECT1417        C66XX_S.CPU_SYSTEM_2.CGEM_SSI_2.INTSEL_in_pin_35, C66XX_S.SHARED_SYSTEM.QUEUE_MANAGER.qmss_int0_3_opin;
        CONNECT1418        C66XX_S.CPU_SYSTEM_2.CGEM_SSI_2.INTSEL_in_pin_36, C66XX_S.SHARED_SYSTEM.QUEUE_MANAGER.qmss_int0_4_opin;
        CONNECT1419        C66XX_S.CPU_SYSTEM_2.CGEM_SSI_2.INTSEL_in_pin_37, C66XX_S.SHARED_SYSTEM.QUEUE_MANAGER.qmss_int0_5_opin;
        CONNECT1420        C66XX_S.CPU_SYSTEM_2.CGEM_SSI_2.INTSEL_in_pin_38, C66XX_S.SHARED_SYSTEM.QUEUE_MANAGER.qmss_int0_6_opin;
        CONNECT1421        C66XX_S.CPU_SYSTEM_2.CGEM_SSI_2.INTSEL_in_pin_39, C66XX_S.SHARED_SYSTEM.QUEUE_MANAGER.qmss_int0_7_opin;
        CONNECT1422        C66XX_S.CPU_SYSTEM_2.CGEM_SSI_2.INTSEL_in_pin_40, C66XX_S.SHARED_SYSTEM.QUEUE_MANAGER.qmss_int0_8_opin;
        CONNECT1423        C66XX_S.CPU_SYSTEM_2.CGEM_SSI_2.INTSEL_in_pin_41, C66XX_S.SHARED_SYSTEM.QUEUE_MANAGER.qmss_int0_9_opin;
        CONNECT1424        C66XX_S.CPU_SYSTEM_2.CGEM_SSI_2.INTSEL_in_pin_42, C66XX_S.SHARED_SYSTEM.QUEUE_MANAGER.qmss_int0_10_opin;
        CONNECT1425        C66XX_S.CPU_SYSTEM_2.CGEM_SSI_2.INTSEL_in_pin_43, C66XX_S.SHARED_SYSTEM.QUEUE_MANAGER.qmss_int0_11_opin;
        CONNECT1426        C66XX_S.CPU_SYSTEM_2.CGEM_SSI_2.INTSEL_in_pin_44, C66XX_S.SHARED_SYSTEM.QUEUE_MANAGER.qmss_int0_12_opin;
        CONNECT1427        C66XX_S.CPU_SYSTEM_2.CGEM_SSI_2.INTSEL_in_pin_45, C66XX_S.SHARED_SYSTEM.QUEUE_MANAGER.qmss_int0_13_opin;
        CONNECT1428        C66XX_S.CPU_SYSTEM_2.CGEM_SSI_2.INTSEL_in_pin_46, C66XX_S.SHARED_SYSTEM.QUEUE_MANAGER.qmss_int0_14_opin;
        CONNECT1429        C66XX_S.CPU_SYSTEM_2.CGEM_SSI_2.INTSEL_in_pin_47, C66XX_S.SHARED_SYSTEM.QUEUE_MANAGER.qmss_int0_15_opin;
        CONNECT1430        C66XX_S.CPU_SYSTEM_2.CGEM_SSI_2.INTSEL_in_pin_48, C66XX_S.SHARED_SYSTEM.QUEUE_MANAGER.qmss_int1_2_opin;
        CONNECT1431        C66XX_S.CPU_SYSTEM_2.CGEM_SSI_2.INTSEL_in_pin_49, C66XX_S.SHARED_SYSTEM.QUEUE_MANAGER.qmss_int1_10_opin;
        CONNECT1432        C66XX_S.CPU_SYSTEM_2.CGEM_SSI_2.INTSEL_in_pin_50, C66XX_S.SHARED_SYSTEM.QUEUE_MANAGER.qmss_int1_18_opin;
        CONNECT1433        C66XX_S.CPU_SYSTEM_2.CGEM_SSI_2.INTSEL_in_pin_51, C66XX_S.SHARED_SYSTEM.QUEUE_MANAGER.qmss_int1_26_opin;
        //TIMERS
        CONNECT1434        C66XX_S.CPU_SYSTEM_2.CGEM_SSI_2.INTSEL_in_pin_64, C66XX_S.SHARED_SYSTEM.TIMER64_2_cpu_int_12;
        CONNECT1435        C66XX_S.CPU_SYSTEM_2.CGEM_SSI_2.INTSEL_in_pin_65, C66XX_S.SHARED_SYSTEM.TIMER64_2_cpu_int_34;
        CONNECT1436        C66XX_S.CPU_SYSTEM_2.CGEM_SSI_2.INTSEL_in_pin_66, C66XX_S.SHARED_SYSTEM.TIMER64_8_cpu_int_12;
        CONNECT1437        C66XX_S.CPU_SYSTEM_2.CGEM_SSI_2.INTSEL_in_pin_67, C66XX_S.SHARED_SYSTEM.TIMER64_8_cpu_int_34;
        CONNECT1438        C66XX_S.CPU_SYSTEM_2.CGEM_SSI_2.INTSEL_in_pin_68, C66XX_S.SHARED_SYSTEM.TIMER64_9_cpu_int_12;
        CONNECT1439        C66XX_S.CPU_SYSTEM_2.CGEM_SSI_2.INTSEL_in_pin_69, C66XX_S.SHARED_SYSTEM.TIMER64_9_cpu_int_34;
        CONNECT1440        C66XX_S.CPU_SYSTEM_2.CGEM_SSI_2.INTSEL_in_pin_70, C66XX_S.SHARED_SYSTEM.TIMER64_10_cpu_int_12;
        CONNECT1441        C66XX_S.CPU_SYSTEM_2.CGEM_SSI_2.INTSEL_in_pin_71, C66XX_S.SHARED_SYSTEM.TIMER64_10_cpu_int_34;
        CONNECT1442        C66XX_S.CPU_SYSTEM_2.CGEM_SSI_2.INTSEL_in_pin_72, C66XX_S.SHARED_SYSTEM.TIMER64_11_cpu_int_12;
        CONNECT1443        C66XX_S.CPU_SYSTEM_2.CGEM_SSI_2.INTSEL_in_pin_73, C66XX_S.SHARED_SYSTEM.TIMER64_11_cpu_int_34;
        CONNECT1444        C66XX_S.CPU_SYSTEM_2.CGEM_SSI_2.INTSEL_in_pin_74, C66XX_S.SHARED_SYSTEM.TIMER64_12_cpu_int_12;
        CONNECT1445        C66XX_S.CPU_SYSTEM_2.CGEM_SSI_2.INTSEL_in_pin_75, C66XX_S.SHARED_SYSTEM.TIMER64_12_cpu_int_34;
        CONNECT1446        C66XX_S.CPU_SYSTEM_2.CGEM_SSI_2.INTSEL_in_pin_76, C66XX_S.SHARED_SYSTEM.TIMER64_13_cpu_int_12;
        CONNECT1447        C66XX_S.CPU_SYSTEM_2.CGEM_SSI_2.INTSEL_in_pin_77, C66XX_S.SHARED_SYSTEM.TIMER64_13_cpu_int_34;
        CONNECT1448        C66XX_S.CPU_SYSTEM_2.CGEM_SSI_2.INTSEL_in_pin_78, C66XX_S.SHARED_SYSTEM.TIMER64_14_cpu_int_12;
        CONNECT1449        C66XX_S.CPU_SYSTEM_2.CGEM_SSI_2.INTSEL_in_pin_79, C66XX_S.SHARED_SYSTEM.TIMER64_14_cpu_int_34;
        CONNECT1450        C66XX_S.CPU_SYSTEM_2.CGEM_SSI_2.INTSEL_in_pin_80, C66XX_S.SHARED_SYSTEM.TIMER64_15_cpu_int_12;
        CONNECT1451        C66XX_S.CPU_SYSTEM_2.CGEM_SSI_2.INTSEL_in_pin_81, C66XX_S.SHARED_SYSTEM.TIMER64_15_cpu_int_34;
         //GPIO
        CONNECT1452        C66XX_S.CPU_SYSTEM_2.CGEM_SSI_2.INTSEL_in_pin_82, C66XX_S.SHARED_SYSTEM.GPIO.gpio_gpint8_opin;
        CONNECT1453        C66XX_S.CPU_SYSTEM_2.CGEM_SSI_2.INTSEL_in_pin_83, C66XX_S.SHARED_SYSTEM.GPIO.gpio_gpint9_opin;
        CONNECT1454        C66XX_S.CPU_SYSTEM_2.CGEM_SSI_2.INTSEL_in_pin_84, C66XX_S.SHARED_SYSTEM.GPIO.gpio_gpint10_opin;
        CONNECT1455        C66XX_S.CPU_SYSTEM_2.CGEM_SSI_2.INTSEL_in_pin_85, C66XX_S.SHARED_SYSTEM.GPIO.gpio_gpint11_opin;
        CONNECT1456        C66XX_S.CPU_SYSTEM_2.CGEM_SSI_2.INTSEL_in_pin_86, C66XX_S.SHARED_SYSTEM.GPIO.gpio_gpint12_opin;
        CONNECT1457        C66XX_S.CPU_SYSTEM_2.CGEM_SSI_2.INTSEL_in_pin_87, C66XX_S.SHARED_SYSTEM.GPIO.gpio_gpint13_opin;
        CONNECT1458        C66XX_S.CPU_SYSTEM_2.CGEM_SSI_2.INTSEL_in_pin_88, C66XX_S.SHARED_SYSTEM.GPIO.gpio_gpint14_opin;
        CONNECT1459        C66XX_S.CPU_SYSTEM_2.CGEM_SSI_2.INTSEL_in_pin_89, C66XX_S.SHARED_SYSTEM.GPIO.gpio_gpint15_opin;
        CONNECT1460        C66XX_S.CPU_SYSTEM_2.CGEM_SSI_2.INTSEL_in_pin_90, C66XX_S.SHARED_SYSTEM.GPIO.gpio_gpint2_opin;
        //IPC
        CONNECT1461        C66XX_S.CPU_SYSTEM_2.CGEM_SSI_2.INTSEL_in_pin_91, C66XX_S.SHARED_SYSTEM.IPC_cpu_int_2;
        //!CPU3
        //SEMAPHORE
        CONNECT1462        C66XX_S.CPU_SYSTEM_3.CGEM_SSI_3.INTSEL_in_pin_15, C66XX_S.SHARED_SYSTEM.SEMAPHORE.semaphore2_err_opin3;
        CONNECT1463        C66XX_S.CPU_SYSTEM_3.CGEM_SSI_3.INTSEL_in_pin_16, C66XX_S.SHARED_SYSTEM.SEMAPHORE.semaphore2_intr_opin3;
        //SRIO
        CONNECT1464        C66XX_S.CPU_SYSTEM_3.CGEM_SSI_3.INTSEL_in_pin_20, C66XX_S.SHARED_SYSTEM.SRIO.srio_intdst_intr19;
        //QUEUE_MANAGER
        CONNECT1465        C66XX_S.CPU_SYSTEM_3.CGEM_SSI_3.INTSEL_in_pin_32, C66XX_S.SHARED_SYSTEM.QUEUE_MANAGER.qmss_int0_0_opin;
        CONNECT1466        C66XX_S.CPU_SYSTEM_3.CGEM_SSI_3.INTSEL_in_pin_33, C66XX_S.SHARED_SYSTEM.QUEUE_MANAGER.qmss_int0_1_opin;
        CONNECT1467        C66XX_S.CPU_SYSTEM_3.CGEM_SSI_3.INTSEL_in_pin_34, C66XX_S.SHARED_SYSTEM.QUEUE_MANAGER.qmss_int0_2_opin;
        CONNECT1468        C66XX_S.CPU_SYSTEM_3.CGEM_SSI_3.INTSEL_in_pin_35, C66XX_S.SHARED_SYSTEM.QUEUE_MANAGER.qmss_int0_3_opin;
        CONNECT1469        C66XX_S.CPU_SYSTEM_3.CGEM_SSI_3.INTSEL_in_pin_36, C66XX_S.SHARED_SYSTEM.QUEUE_MANAGER.qmss_int0_4_opin;
        CONNECT1470        C66XX_S.CPU_SYSTEM_3.CGEM_SSI_3.INTSEL_in_pin_37, C66XX_S.SHARED_SYSTEM.QUEUE_MANAGER.qmss_int0_5_opin;
        CONNECT1471        C66XX_S.CPU_SYSTEM_3.CGEM_SSI_3.INTSEL_in_pin_38, C66XX_S.SHARED_SYSTEM.QUEUE_MANAGER.qmss_int0_6_opin;
        CONNECT1472        C66XX_S.CPU_SYSTEM_3.CGEM_SSI_3.INTSEL_in_pin_39, C66XX_S.SHARED_SYSTEM.QUEUE_MANAGER.qmss_int0_7_opin;
        CONNECT1473        C66XX_S.CPU_SYSTEM_3.CGEM_SSI_3.INTSEL_in_pin_40, C66XX_S.SHARED_SYSTEM.QUEUE_MANAGER.qmss_int0_8_opin;
        CONNECT1474        C66XX_S.CPU_SYSTEM_3.CGEM_SSI_3.INTSEL_in_pin_41, C66XX_S.SHARED_SYSTEM.QUEUE_MANAGER.qmss_int0_9_opin;
        CONNECT1475        C66XX_S.CPU_SYSTEM_3.CGEM_SSI_3.INTSEL_in_pin_42, C66XX_S.SHARED_SYSTEM.QUEUE_MANAGER.qmss_int0_10_opin;
        CONNECT1476        C66XX_S.CPU_SYSTEM_3.CGEM_SSI_3.INTSEL_in_pin_43, C66XX_S.SHARED_SYSTEM.QUEUE_MANAGER.qmss_int0_11_opin;
        CONNECT1477        C66XX_S.CPU_SYSTEM_3.CGEM_SSI_3.INTSEL_in_pin_44, C66XX_S.SHARED_SYSTEM.QUEUE_MANAGER.qmss_int0_12_opin;
        CONNECT1478        C66XX_S.CPU_SYSTEM_3.CGEM_SSI_3.INTSEL_in_pin_45, C66XX_S.SHARED_SYSTEM.QUEUE_MANAGER.qmss_int0_13_opin;
        CONNECT1479        C66XX_S.CPU_SYSTEM_3.CGEM_SSI_3.INTSEL_in_pin_46, C66XX_S.SHARED_SYSTEM.QUEUE_MANAGER.qmss_int0_14_opin;
        CONNECT1480        C66XX_S.CPU_SYSTEM_3.CGEM_SSI_3.INTSEL_in_pin_47, C66XX_S.SHARED_SYSTEM.QUEUE_MANAGER.qmss_int0_15_opin;
        CONNECT1481        C66XX_S.CPU_SYSTEM_3.CGEM_SSI_3.INTSEL_in_pin_48, C66XX_S.SHARED_SYSTEM.QUEUE_MANAGER.qmss_int1_3_opin;
        CONNECT1482        C66XX_S.CPU_SYSTEM_3.CGEM_SSI_3.INTSEL_in_pin_49, C66XX_S.SHARED_SYSTEM.QUEUE_MANAGER.qmss_int1_11_opin;
        CONNECT1483        C66XX_S.CPU_SYSTEM_3.CGEM_SSI_3.INTSEL_in_pin_50, C66XX_S.SHARED_SYSTEM.QUEUE_MANAGER.qmss_int1_19_opin;
        CONNECT1484        C66XX_S.CPU_SYSTEM_3.CGEM_SSI_3.INTSEL_in_pin_51, C66XX_S.SHARED_SYSTEM.QUEUE_MANAGER.qmss_int1_27_opin;
        //TIMERS
        CONNECT1485        C66XX_S.CPU_SYSTEM_3.CGEM_SSI_3.INTSEL_in_pin_64, C66XX_S.SHARED_SYSTEM.TIMER64_3_cpu_int_12;
        CONNECT1486        C66XX_S.CPU_SYSTEM_3.CGEM_SSI_3.INTSEL_in_pin_65, C66XX_S.SHARED_SYSTEM.TIMER64_3_cpu_int_34;
        CONNECT1487        C66XX_S.CPU_SYSTEM_3.CGEM_SSI_3.INTSEL_in_pin_66, C66XX_S.SHARED_SYSTEM.TIMER64_8_cpu_int_12;
        CONNECT1488        C66XX_S.CPU_SYSTEM_3.CGEM_SSI_3.INTSEL_in_pin_67, C66XX_S.SHARED_SYSTEM.TIMER64_8_cpu_int_34;
        CONNECT1489        C66XX_S.CPU_SYSTEM_3.CGEM_SSI_3.INTSEL_in_pin_68, C66XX_S.SHARED_SYSTEM.TIMER64_9_cpu_int_12;
        CONNECT1490        C66XX_S.CPU_SYSTEM_3.CGEM_SSI_3.INTSEL_in_pin_69, C66XX_S.SHARED_SYSTEM.TIMER64_9_cpu_int_34;
        CONNECT1491        C66XX_S.CPU_SYSTEM_3.CGEM_SSI_3.INTSEL_in_pin_70, C66XX_S.SHARED_SYSTEM.TIMER64_10_cpu_int_12;
        CONNECT1492        C66XX_S.CPU_SYSTEM_3.CGEM_SSI_3.INTSEL_in_pin_71, C66XX_S.SHARED_SYSTEM.TIMER64_10_cpu_int_34;
        CONNECT1493        C66XX_S.CPU_SYSTEM_3.CGEM_SSI_3.INTSEL_in_pin_72, C66XX_S.SHARED_SYSTEM.TIMER64_11_cpu_int_12;
        CONNECT1494        C66XX_S.CPU_SYSTEM_3.CGEM_SSI_3.INTSEL_in_pin_73, C66XX_S.SHARED_SYSTEM.TIMER64_11_cpu_int_34;
        CONNECT1495        C66XX_S.CPU_SYSTEM_3.CGEM_SSI_3.INTSEL_in_pin_74, C66XX_S.SHARED_SYSTEM.TIMER64_12_cpu_int_12;
        CONNECT1496        C66XX_S.CPU_SYSTEM_3.CGEM_SSI_3.INTSEL_in_pin_75, C66XX_S.SHARED_SYSTEM.TIMER64_12_cpu_int_34;
        CONNECT1497        C66XX_S.CPU_SYSTEM_3.CGEM_SSI_3.INTSEL_in_pin_76, C66XX_S.SHARED_SYSTEM.TIMER64_13_cpu_int_12;
        CONNECT1498        C66XX_S.CPU_SYSTEM_3.CGEM_SSI_3.INTSEL_in_pin_77, C66XX_S.SHARED_SYSTEM.TIMER64_13_cpu_int_34;
        CONNECT1499        C66XX_S.CPU_SYSTEM_3.CGEM_SSI_3.INTSEL_in_pin_78, C66XX_S.SHARED_SYSTEM.TIMER64_14_cpu_int_12;
        CONNECT1500        C66XX_S.CPU_SYSTEM_3.CGEM_SSI_3.INTSEL_in_pin_79, C66XX_S.SHARED_SYSTEM.TIMER64_14_cpu_int_34;
        CONNECT1501        C66XX_S.CPU_SYSTEM_3.CGEM_SSI_3.INTSEL_in_pin_80, C66XX_S.SHARED_SYSTEM.TIMER64_15_cpu_int_12;
        CONNECT1502        C66XX_S.CPU_SYSTEM_3.CGEM_SSI_3.INTSEL_in_pin_81, C66XX_S.SHARED_SYSTEM.TIMER64_15_cpu_int_34;
         //GPIO
        CONNECT1503        C66XX_S.CPU_SYSTEM_3.CGEM_SSI_3.INTSEL_in_pin_82, C66XX_S.SHARED_SYSTEM.GPIO.gpio_gpint8_opin;
        CONNECT1504        C66XX_S.CPU_SYSTEM_3.CGEM_SSI_3.INTSEL_in_pin_83, C66XX_S.SHARED_SYSTEM.GPIO.gpio_gpint9_opin;
        CONNECT1505        C66XX_S.CPU_SYSTEM_3.CGEM_SSI_3.INTSEL_in_pin_84, C66XX_S.SHARED_SYSTEM.GPIO.gpio_gpint10_opin;
        CONNECT1506        C66XX_S.CPU_SYSTEM_3.CGEM_SSI_3.INTSEL_in_pin_85, C66XX_S.SHARED_SYSTEM.GPIO.gpio_gpint11_opin;
        CONNECT1507        C66XX_S.CPU_SYSTEM_3.CGEM_SSI_3.INTSEL_in_pin_86, C66XX_S.SHARED_SYSTEM.GPIO.gpio_gpint12_opin;
        CONNECT1508        C66XX_S.CPU_SYSTEM_3.CGEM_SSI_3.INTSEL_in_pin_87, C66XX_S.SHARED_SYSTEM.GPIO.gpio_gpint13_opin;
        CONNECT1509        C66XX_S.CPU_SYSTEM_3.CGEM_SSI_3.INTSEL_in_pin_88, C66XX_S.SHARED_SYSTEM.GPIO.gpio_gpint14_opin;
        CONNECT1510        C66XX_S.CPU_SYSTEM_3.CGEM_SSI_3.INTSEL_in_pin_89, C66XX_S.SHARED_SYSTEM.GPIO.gpio_gpint15_opin;
        CONNECT1511        C66XX_S.CPU_SYSTEM_3.CGEM_SSI_3.INTSEL_in_pin_90, C66XX_S.SHARED_SYSTEM.GPIO.gpio_gpint3_opin;
         //IPC
        CONNECT1512        C66XX_S.CPU_SYSTEM_3.CGEM_SSI_3.INTSEL_in_pin_91, C66XX_S.SHARED_SYSTEM.IPC_cpu_int_3;
        //!CPU4
        //SEMAPHORE
        CONNECT1513        C66XX_S.CPU_SYSTEM_4.CGEM_SSI_4.INTSEL_in_pin_15, C66XX_S.SHARED_SYSTEM.SEMAPHORE.semaphore2_err_opin4;
        CONNECT1514        C66XX_S.CPU_SYSTEM_4.CGEM_SSI_4.INTSEL_in_pin_16, C66XX_S.SHARED_SYSTEM.SEMAPHORE.semaphore2_intr_opin4;
        //SRIO
        CONNECT1515        C66XX_S.CPU_SYSTEM_4.CGEM_SSI_4.INTSEL_in_pin_20, C66XX_S.SHARED_SYSTEM.SRIO.srio_intdst_intr20;
        //QUEUE_MANAGER
        CONNECT1516        C66XX_S.CPU_SYSTEM_4.CGEM_SSI_4.INTSEL_in_pin_32, C66XX_S.SHARED_SYSTEM.QUEUE_MANAGER.qmss_int0_0_opin;
        CONNECT1517        C66XX_S.CPU_SYSTEM_4.CGEM_SSI_4.INTSEL_in_pin_33, C66XX_S.SHARED_SYSTEM.QUEUE_MANAGER.qmss_int0_1_opin;
        CONNECT1518        C66XX_S.CPU_SYSTEM_4.CGEM_SSI_4.INTSEL_in_pin_34, C66XX_S.SHARED_SYSTEM.QUEUE_MANAGER.qmss_int0_2_opin;
        CONNECT1519        C66XX_S.CPU_SYSTEM_4.CGEM_SSI_4.INTSEL_in_pin_35, C66XX_S.SHARED_SYSTEM.QUEUE_MANAGER.qmss_int0_3_opin;
        CONNECT1520        C66XX_S.CPU_SYSTEM_4.CGEM_SSI_4.INTSEL_in_pin_36, C66XX_S.SHARED_SYSTEM.QUEUE_MANAGER.qmss_int0_4_opin;
        CONNECT1521        C66XX_S.CPU_SYSTEM_4.CGEM_SSI_4.INTSEL_in_pin_37, C66XX_S.SHARED_SYSTEM.QUEUE_MANAGER.qmss_int0_5_opin;
        CONNECT1522        C66XX_S.CPU_SYSTEM_4.CGEM_SSI_4.INTSEL_in_pin_38, C66XX_S.SHARED_SYSTEM.QUEUE_MANAGER.qmss_int0_6_opin;
        CONNECT1523        C66XX_S.CPU_SYSTEM_4.CGEM_SSI_4.INTSEL_in_pin_39, C66XX_S.SHARED_SYSTEM.QUEUE_MANAGER.qmss_int0_7_opin;
        CONNECT1524        C66XX_S.CPU_SYSTEM_4.CGEM_SSI_4.INTSEL_in_pin_40, C66XX_S.SHARED_SYSTEM.QUEUE_MANAGER.qmss_int0_8_opin;
        CONNECT1525        C66XX_S.CPU_SYSTEM_4.CGEM_SSI_4.INTSEL_in_pin_41, C66XX_S.SHARED_SYSTEM.QUEUE_MANAGER.qmss_int0_9_opin;
        CONNECT1526        C66XX_S.CPU_SYSTEM_4.CGEM_SSI_4.INTSEL_in_pin_42, C66XX_S.SHARED_SYSTEM.QUEUE_MANAGER.qmss_int0_10_opin;
        CONNECT1527        C66XX_S.CPU_SYSTEM_4.CGEM_SSI_4.INTSEL_in_pin_43, C66XX_S.SHARED_SYSTEM.QUEUE_MANAGER.qmss_int0_11_opin;
        CONNECT1528        C66XX_S.CPU_SYSTEM_4.CGEM_SSI_4.INTSEL_in_pin_44, C66XX_S.SHARED_SYSTEM.QUEUE_MANAGER.qmss_int0_12_opin;
        CONNECT1529        C66XX_S.CPU_SYSTEM_4.CGEM_SSI_4.INTSEL_in_pin_45, C66XX_S.SHARED_SYSTEM.QUEUE_MANAGER.qmss_int0_13_opin;
        CONNECT1530        C66XX_S.CPU_SYSTEM_4.CGEM_SSI_4.INTSEL_in_pin_46, C66XX_S.SHARED_SYSTEM.QUEUE_MANAGER.qmss_int0_14_opin;
        CONNECT1531        C66XX_S.CPU_SYSTEM_4.CGEM_SSI_4.INTSEL_in_pin_47, C66XX_S.SHARED_SYSTEM.QUEUE_MANAGER.qmss_int0_15_opin;
        CONNECT1532        C66XX_S.CPU_SYSTEM_4.CGEM_SSI_4.INTSEL_in_pin_48, C66XX_S.SHARED_SYSTEM.QUEUE_MANAGER.qmss_int1_4_opin;
        CONNECT1533        C66XX_S.CPU_SYSTEM_4.CGEM_SSI_4.INTSEL_in_pin_49, C66XX_S.SHARED_SYSTEM.QUEUE_MANAGER.qmss_int1_12_opin;
        CONNECT1534        C66XX_S.CPU_SYSTEM_4.CGEM_SSI_4.INTSEL_in_pin_50, C66XX_S.SHARED_SYSTEM.QUEUE_MANAGER.qmss_int1_20_opin;
        CONNECT1535        C66XX_S.CPU_SYSTEM_4.CGEM_SSI_4.INTSEL_in_pin_51, C66XX_S.SHARED_SYSTEM.QUEUE_MANAGER.qmss_int1_28_opin;
        //TIMERS
        CONNECT1536        C66XX_S.CPU_SYSTEM_4.CGEM_SSI_4.INTSEL_in_pin_64, C66XX_S.SHARED_SYSTEM.TIMER64_4_cpu_int_12;
        CONNECT1537        C66XX_S.CPU_SYSTEM_4.CGEM_SSI_4.INTSEL_in_pin_65, C66XX_S.SHARED_SYSTEM.TIMER64_4_cpu_int_34;
        CONNECT1538        C66XX_S.CPU_SYSTEM_4.CGEM_SSI_4.INTSEL_in_pin_66, C66XX_S.SHARED_SYSTEM.TIMER64_8_cpu_int_12;
        CONNECT1539        C66XX_S.CPU_SYSTEM_4.CGEM_SSI_4.INTSEL_in_pin_67, C66XX_S.SHARED_SYSTEM.TIMER64_8_cpu_int_34;
        CONNECT1540        C66XX_S.CPU_SYSTEM_4.CGEM_SSI_4.INTSEL_in_pin_68, C66XX_S.SHARED_SYSTEM.TIMER64_9_cpu_int_12;
        CONNECT1541        C66XX_S.CPU_SYSTEM_4.CGEM_SSI_4.INTSEL_in_pin_69, C66XX_S.SHARED_SYSTEM.TIMER64_9_cpu_int_34;
        CONNECT1542        C66XX_S.CPU_SYSTEM_4.CGEM_SSI_4.INTSEL_in_pin_70, C66XX_S.SHARED_SYSTEM.TIMER64_10_cpu_int_12;
        CONNECT1543        C66XX_S.CPU_SYSTEM_4.CGEM_SSI_4.INTSEL_in_pin_71, C66XX_S.SHARED_SYSTEM.TIMER64_10_cpu_int_34;
        CONNECT1544        C66XX_S.CPU_SYSTEM_4.CGEM_SSI_4.INTSEL_in_pin_72, C66XX_S.SHARED_SYSTEM.TIMER64_11_cpu_int_12;
        CONNECT1545        C66XX_S.CPU_SYSTEM_4.CGEM_SSI_4.INTSEL_in_pin_73, C66XX_S.SHARED_SYSTEM.TIMER64_11_cpu_int_34;
        CONNECT1546        C66XX_S.CPU_SYSTEM_4.CGEM_SSI_4.INTSEL_in_pin_74, C66XX_S.SHARED_SYSTEM.TIMER64_12_cpu_int_12;
        CONNECT1547        C66XX_S.CPU_SYSTEM_4.CGEM_SSI_4.INTSEL_in_pin_75, C66XX_S.SHARED_SYSTEM.TIMER64_12_cpu_int_34;
        CONNECT1548        C66XX_S.CPU_SYSTEM_4.CGEM_SSI_4.INTSEL_in_pin_76, C66XX_S.SHARED_SYSTEM.TIMER64_13_cpu_int_12;
        CONNECT1549        C66XX_S.CPU_SYSTEM_4.CGEM_SSI_4.INTSEL_in_pin_77, C66XX_S.SHARED_SYSTEM.TIMER64_13_cpu_int_34;
        CONNECT1550        C66XX_S.CPU_SYSTEM_4.CGEM_SSI_4.INTSEL_in_pin_78, C66XX_S.SHARED_SYSTEM.TIMER64_14_cpu_int_12;
        CONNECT1551        C66XX_S.CPU_SYSTEM_4.CGEM_SSI_4.INTSEL_in_pin_79, C66XX_S.SHARED_SYSTEM.TIMER64_14_cpu_int_34;
        CONNECT1552        C66XX_S.CPU_SYSTEM_4.CGEM_SSI_4.INTSEL_in_pin_80, C66XX_S.SHARED_SYSTEM.TIMER64_15_cpu_int_12;
        CONNECT1553        C66XX_S.CPU_SYSTEM_4.CGEM_SSI_4.INTSEL_in_pin_81, C66XX_S.SHARED_SYSTEM.TIMER64_15_cpu_int_34;
        //GPIO
        CONNECT1554        C66XX_S.CPU_SYSTEM_4.CGEM_SSI_4.INTSEL_in_pin_82, C66XX_S.SHARED_SYSTEM.GPIO.gpio_gpint8_opin;
        CONNECT1555        C66XX_S.CPU_SYSTEM_4.CGEM_SSI_4.INTSEL_in_pin_83, C66XX_S.SHARED_SYSTEM.GPIO.gpio_gpint9_opin;
        CONNECT1556        C66XX_S.CPU_SYSTEM_4.CGEM_SSI_4.INTSEL_in_pin_84, C66XX_S.SHARED_SYSTEM.GPIO.gpio_gpint10_opin;
        CONNECT1557        C66XX_S.CPU_SYSTEM_4.CGEM_SSI_4.INTSEL_in_pin_85, C66XX_S.SHARED_SYSTEM.GPIO.gpio_gpint11_opin;
        CONNECT1558        C66XX_S.CPU_SYSTEM_4.CGEM_SSI_4.INTSEL_in_pin_86, C66XX_S.SHARED_SYSTEM.GPIO.gpio_gpint12_opin;
        CONNECT1559        C66XX_S.CPU_SYSTEM_4.CGEM_SSI_4.INTSEL_in_pin_87, C66XX_S.SHARED_SYSTEM.GPIO.gpio_gpint13_opin;
        CONNECT1560        C66XX_S.CPU_SYSTEM_4.CGEM_SSI_4.INTSEL_in_pin_88, C66XX_S.SHARED_SYSTEM.GPIO.gpio_gpint14_opin;
        CONNECT1561        C66XX_S.CPU_SYSTEM_4.CGEM_SSI_4.INTSEL_in_pin_89, C66XX_S.SHARED_SYSTEM.GPIO.gpio_gpint15_opin;
        CONNECT1562        C66XX_S.CPU_SYSTEM_4.CGEM_SSI_4.INTSEL_in_pin_90, C66XX_S.SHARED_SYSTEM.GPIO.gpio_gpint4_opin;
        //IPC
        CONNECT1563        C66XX_S.CPU_SYSTEM_4.CGEM_SSI_4.INTSEL_in_pin_91, C66XX_S.SHARED_SYSTEM.IPC_cpu_int_4;
        //!CPU5
        //SEMAPHORE
        CONNECT1564        C66XX_S.CPU_SYSTEM_5.CGEM_SSI_5.INTSEL_in_pin_15, C66XX_S.SHARED_SYSTEM.SEMAPHORE.semaphore2_err_opin5;
        CONNECT1565        C66XX_S.CPU_SYSTEM_5.CGEM_SSI_5.INTSEL_in_pin_16, C66XX_S.SHARED_SYSTEM.SEMAPHORE.semaphore2_intr_opin5;
        //SRIO
        CONNECT1566        C66XX_S.CPU_SYSTEM_5.CGEM_SSI_5.INTSEL_in_pin_20, C66XX_S.SHARED_SYSTEM.SRIO.srio_intdst_intr21;
        //QUEUE_MANAGER
        CONNECT1567        C66XX_S.CPU_SYSTEM_5.CGEM_SSI_5.INTSEL_in_pin_32, C66XX_S.SHARED_SYSTEM.QUEUE_MANAGER.qmss_int0_0_opin;
        CONNECT1568        C66XX_S.CPU_SYSTEM_5.CGEM_SSI_5.INTSEL_in_pin_33, C66XX_S.SHARED_SYSTEM.QUEUE_MANAGER.qmss_int0_1_opin;
        CONNECT1569        C66XX_S.CPU_SYSTEM_5.CGEM_SSI_5.INTSEL_in_pin_34, C66XX_S.SHARED_SYSTEM.QUEUE_MANAGER.qmss_int0_2_opin;
        CONNECT1570        C66XX_S.CPU_SYSTEM_5.CGEM_SSI_5.INTSEL_in_pin_35, C66XX_S.SHARED_SYSTEM.QUEUE_MANAGER.qmss_int0_3_opin;
        CONNECT1571        C66XX_S.CPU_SYSTEM_5.CGEM_SSI_5.INTSEL_in_pin_36, C66XX_S.SHARED_SYSTEM.QUEUE_MANAGER.qmss_int0_4_opin;
        CONNECT1572        C66XX_S.CPU_SYSTEM_5.CGEM_SSI_5.INTSEL_in_pin_37, C66XX_S.SHARED_SYSTEM.QUEUE_MANAGER.qmss_int0_5_opin;
        CONNECT1573        C66XX_S.CPU_SYSTEM_5.CGEM_SSI_5.INTSEL_in_pin_38, C66XX_S.SHARED_SYSTEM.QUEUE_MANAGER.qmss_int0_6_opin;
        CONNECT1574        C66XX_S.CPU_SYSTEM_5.CGEM_SSI_5.INTSEL_in_pin_39, C66XX_S.SHARED_SYSTEM.QUEUE_MANAGER.qmss_int0_7_opin;
        CONNECT1575        C66XX_S.CPU_SYSTEM_5.CGEM_SSI_5.INTSEL_in_pin_40, C66XX_S.SHARED_SYSTEM.QUEUE_MANAGER.qmss_int0_8_opin;
        CONNECT1576        C66XX_S.CPU_SYSTEM_5.CGEM_SSI_5.INTSEL_in_pin_41, C66XX_S.SHARED_SYSTEM.QUEUE_MANAGER.qmss_int0_9_opin;
        CONNECT1577        C66XX_S.CPU_SYSTEM_5.CGEM_SSI_5.INTSEL_in_pin_42, C66XX_S.SHARED_SYSTEM.QUEUE_MANAGER.qmss_int0_10_opin;
        CONNECT1578        C66XX_S.CPU_SYSTEM_5.CGEM_SSI_5.INTSEL_in_pin_43, C66XX_S.SHARED_SYSTEM.QUEUE_MANAGER.qmss_int0_11_opin;
        CONNECT1579        C66XX_S.CPU_SYSTEM_5.CGEM_SSI_5.INTSEL_in_pin_44, C66XX_S.SHARED_SYSTEM.QUEUE_MANAGER.qmss_int0_12_opin;
        CONNECT1580        C66XX_S.CPU_SYSTEM_5.CGEM_SSI_5.INTSEL_in_pin_45, C66XX_S.SHARED_SYSTEM.QUEUE_MANAGER.qmss_int0_13_opin;
        CONNECT1581        C66XX_S.CPU_SYSTEM_5.CGEM_SSI_5.INTSEL_in_pin_46, C66XX_S.SHARED_SYSTEM.QUEUE_MANAGER.qmss_int0_14_opin;
        CONNECT1582        C66XX_S.CPU_SYSTEM_5.CGEM_SSI_5.INTSEL_in_pin_47, C66XX_S.SHARED_SYSTEM.QUEUE_MANAGER.qmss_int0_15_opin;
        CONNECT1583        C66XX_S.CPU_SYSTEM_5.CGEM_SSI_5.INTSEL_in_pin_48, C66XX_S.SHARED_SYSTEM.QUEUE_MANAGER.qmss_int1_5_opin;
        CONNECT1584        C66XX_S.CPU_SYSTEM_5.CGEM_SSI_5.INTSEL_in_pin_49, C66XX_S.SHARED_SYSTEM.QUEUE_MANAGER.qmss_int1_13_opin;
        CONNECT1585        C66XX_S.CPU_SYSTEM_5.CGEM_SSI_5.INTSEL_in_pin_50, C66XX_S.SHARED_SYSTEM.QUEUE_MANAGER.qmss_int1_21_opin;
        CONNECT1586        C66XX_S.CPU_SYSTEM_5.CGEM_SSI_5.INTSEL_in_pin_51, C66XX_S.SHARED_SYSTEM.QUEUE_MANAGER.qmss_int1_29_opin;
        //TIMERS
        CONNECT1587        C66XX_S.CPU_SYSTEM_5.CGEM_SSI_5.INTSEL_in_pin_64, C66XX_S.SHARED_SYSTEM.TIMER64_5_cpu_int_12;
        CONNECT1588        C66XX_S.CPU_SYSTEM_5.CGEM_SSI_5.INTSEL_in_pin_65, C66XX_S.SHARED_SYSTEM.TIMER64_5_cpu_int_34;
        CONNECT1589        C66XX_S.CPU_SYSTEM_5.CGEM_SSI_5.INTSEL_in_pin_66, C66XX_S.SHARED_SYSTEM.TIMER64_8_cpu_int_12;
        CONNECT1590        C66XX_S.CPU_SYSTEM_5.CGEM_SSI_5.INTSEL_in_pin_67, C66XX_S.SHARED_SYSTEM.TIMER64_8_cpu_int_34;
        CONNECT1591        C66XX_S.CPU_SYSTEM_5.CGEM_SSI_5.INTSEL_in_pin_68, C66XX_S.SHARED_SYSTEM.TIMER64_9_cpu_int_12;
        CONNECT1592        C66XX_S.CPU_SYSTEM_5.CGEM_SSI_5.INTSEL_in_pin_69, C66XX_S.SHARED_SYSTEM.TIMER64_9_cpu_int_34;
        CONNECT1593        C66XX_S.CPU_SYSTEM_5.CGEM_SSI_5.INTSEL_in_pin_70, C66XX_S.SHARED_SYSTEM.TIMER64_10_cpu_int_12;
        CONNECT1594        C66XX_S.CPU_SYSTEM_5.CGEM_SSI_5.INTSEL_in_pin_71, C66XX_S.SHARED_SYSTEM.TIMER64_10_cpu_int_34;
        CONNECT1595        C66XX_S.CPU_SYSTEM_5.CGEM_SSI_5.INTSEL_in_pin_72, C66XX_S.SHARED_SYSTEM.TIMER64_11_cpu_int_12;
        CONNECT1596        C66XX_S.CPU_SYSTEM_5.CGEM_SSI_5.INTSEL_in_pin_73, C66XX_S.SHARED_SYSTEM.TIMER64_11_cpu_int_34;
        CONNECT1597        C66XX_S.CPU_SYSTEM_5.CGEM_SSI_5.INTSEL_in_pin_74, C66XX_S.SHARED_SYSTEM.TIMER64_12_cpu_int_12;
        CONNECT1598        C66XX_S.CPU_SYSTEM_5.CGEM_SSI_5.INTSEL_in_pin_75, C66XX_S.SHARED_SYSTEM.TIMER64_12_cpu_int_34;
        CONNECT1599        C66XX_S.CPU_SYSTEM_5.CGEM_SSI_5.INTSEL_in_pin_76, C66XX_S.SHARED_SYSTEM.TIMER64_13_cpu_int_12;
        CONNECT1600        C66XX_S.CPU_SYSTEM_5.CGEM_SSI_5.INTSEL_in_pin_77, C66XX_S.SHARED_SYSTEM.TIMER64_13_cpu_int_34;
        CONNECT1601        C66XX_S.CPU_SYSTEM_5.CGEM_SSI_5.INTSEL_in_pin_78, C66XX_S.SHARED_SYSTEM.TIMER64_14_cpu_int_12;
        CONNECT1602        C66XX_S.CPU_SYSTEM_5.CGEM_SSI_5.INTSEL_in_pin_79, C66XX_S.SHARED_SYSTEM.TIMER64_14_cpu_int_34;
        CONNECT1603        C66XX_S.CPU_SYSTEM_5.CGEM_SSI_5.INTSEL_in_pin_80, C66XX_S.SHARED_SYSTEM.TIMER64_15_cpu_int_12;
        CONNECT1604        C66XX_S.CPU_SYSTEM_5.CGEM_SSI_5.INTSEL_in_pin_81, C66XX_S.SHARED_SYSTEM.TIMER64_15_cpu_int_34;
         //GPIO
        CONNECT1605        C66XX_S.CPU_SYSTEM_5.CGEM_SSI_5.INTSEL_in_pin_82, C66XX_S.SHARED_SYSTEM.GPIO.gpio_gpint8_opin;
        CONNECT1606        C66XX_S.CPU_SYSTEM_5.CGEM_SSI_5.INTSEL_in_pin_83, C66XX_S.SHARED_SYSTEM.GPIO.gpio_gpint9_opin;
        CONNECT1607        C66XX_S.CPU_SYSTEM_5.CGEM_SSI_5.INTSEL_in_pin_84, C66XX_S.SHARED_SYSTEM.GPIO.gpio_gpint10_opin;
        CONNECT1608        C66XX_S.CPU_SYSTEM_5.CGEM_SSI_5.INTSEL_in_pin_85, C66XX_S.SHARED_SYSTEM.GPIO.gpio_gpint11_opin;
        CONNECT1609        C66XX_S.CPU_SYSTEM_5.CGEM_SSI_5.INTSEL_in_pin_86, C66XX_S.SHARED_SYSTEM.GPIO.gpio_gpint12_opin;
        CONNECT1610        C66XX_S.CPU_SYSTEM_5.CGEM_SSI_5.INTSEL_in_pin_87, C66XX_S.SHARED_SYSTEM.GPIO.gpio_gpint13_opin;
        CONNECT1611        C66XX_S.CPU_SYSTEM_5.CGEM_SSI_5.INTSEL_in_pin_88, C66XX_S.SHARED_SYSTEM.GPIO.gpio_gpint14_opin;
        CONNECT1612        C66XX_S.CPU_SYSTEM_5.CGEM_SSI_5.INTSEL_in_pin_89, C66XX_S.SHARED_SYSTEM.GPIO.gpio_gpint15_opin;
        CONNECT1613        C66XX_S.CPU_SYSTEM_5.CGEM_SSI_5.INTSEL_in_pin_90, C66XX_S.SHARED_SYSTEM.GPIO.gpio_gpint5_opin;
        //IPC
        CONNECT1614        C66XX_S.CPU_SYSTEM_5.CGEM_SSI_5.INTSEL_in_pin_91, C66XX_S.SHARED_SYSTEM.IPC_cpu_int_5;
        //!CPU6
        //SEMAPHORE
        CONNECT1615        C66XX_S.CPU_SYSTEM_6.CGEM_SSI_6.INTSEL_in_pin_15, C66XX_S.SHARED_SYSTEM.SEMAPHORE.semaphore2_err_opin6;
        CONNECT1616        C66XX_S.CPU_SYSTEM_6.CGEM_SSI_6.INTSEL_in_pin_16, C66XX_S.SHARED_SYSTEM.SEMAPHORE.semaphore2_intr_opin6;
        //SRIO
        CONNECT1617        C66XX_S.CPU_SYSTEM_6.CGEM_SSI_6.INTSEL_in_pin_20, C66XX_S.SHARED_SYSTEM.SRIO.srio_intdst_intr22;
        //QUEUE_MANAGER
        CONNECT1618        C66XX_S.CPU_SYSTEM_6.CGEM_SSI_6.INTSEL_in_pin_32, C66XX_S.SHARED_SYSTEM.QUEUE_MANAGER.qmss_int0_0_opin;
        CONNECT1619        C66XX_S.CPU_SYSTEM_6.CGEM_SSI_6.INTSEL_in_pin_33, C66XX_S.SHARED_SYSTEM.QUEUE_MANAGER.qmss_int0_1_opin;
        CONNECT1620        C66XX_S.CPU_SYSTEM_6.CGEM_SSI_6.INTSEL_in_pin_34, C66XX_S.SHARED_SYSTEM.QUEUE_MANAGER.qmss_int0_2_opin;
        CONNECT1621        C66XX_S.CPU_SYSTEM_6.CGEM_SSI_6.INTSEL_in_pin_35, C66XX_S.SHARED_SYSTEM.QUEUE_MANAGER.qmss_int0_3_opin;
        CONNECT1622        C66XX_S.CPU_SYSTEM_6.CGEM_SSI_6.INTSEL_in_pin_36, C66XX_S.SHARED_SYSTEM.QUEUE_MANAGER.qmss_int0_4_opin;
        CONNECT1623        C66XX_S.CPU_SYSTEM_6.CGEM_SSI_6.INTSEL_in_pin_37, C66XX_S.SHARED_SYSTEM.QUEUE_MANAGER.qmss_int0_5_opin;
        CONNECT1624        C66XX_S.CPU_SYSTEM_6.CGEM_SSI_6.INTSEL_in_pin_38, C66XX_S.SHARED_SYSTEM.QUEUE_MANAGER.qmss_int0_6_opin;
        CONNECT1625        C66XX_S.CPU_SYSTEM_6.CGEM_SSI_6.INTSEL_in_pin_39, C66XX_S.SHARED_SYSTEM.QUEUE_MANAGER.qmss_int0_7_opin;
        CONNECT1626        C66XX_S.CPU_SYSTEM_6.CGEM_SSI_6.INTSEL_in_pin_40, C66XX_S.SHARED_SYSTEM.QUEUE_MANAGER.qmss_int0_8_opin;
        CONNECT1627        C66XX_S.CPU_SYSTEM_6.CGEM_SSI_6.INTSEL_in_pin_41, C66XX_S.SHARED_SYSTEM.QUEUE_MANAGER.qmss_int0_9_opin;
        CONNECT1628        C66XX_S.CPU_SYSTEM_6.CGEM_SSI_6.INTSEL_in_pin_42, C66XX_S.SHARED_SYSTEM.QUEUE_MANAGER.qmss_int0_10_opin;
        CONNECT1629        C66XX_S.CPU_SYSTEM_6.CGEM_SSI_6.INTSEL_in_pin_43, C66XX_S.SHARED_SYSTEM.QUEUE_MANAGER.qmss_int0_11_opin;
        CONNECT1630        C66XX_S.CPU_SYSTEM_6.CGEM_SSI_6.INTSEL_in_pin_44, C66XX_S.SHARED_SYSTEM.QUEUE_MANAGER.qmss_int0_12_opin;
        CONNECT1631        C66XX_S.CPU_SYSTEM_6.CGEM_SSI_6.INTSEL_in_pin_45, C66XX_S.SHARED_SYSTEM.QUEUE_MANAGER.qmss_int0_13_opin;
        CONNECT1632        C66XX_S.CPU_SYSTEM_6.CGEM_SSI_6.INTSEL_in_pin_46, C66XX_S.SHARED_SYSTEM.QUEUE_MANAGER.qmss_int0_14_opin;
        CONNECT1633        C66XX_S.CPU_SYSTEM_6.CGEM_SSI_6.INTSEL_in_pin_47, C66XX_S.SHARED_SYSTEM.QUEUE_MANAGER.qmss_int0_15_opin;
        CONNECT1634        C66XX_S.CPU_SYSTEM_6.CGEM_SSI_6.INTSEL_in_pin_48, C66XX_S.SHARED_SYSTEM.QUEUE_MANAGER.qmss_int1_6_opin;
        CONNECT1635        C66XX_S.CPU_SYSTEM_6.CGEM_SSI_6.INTSEL_in_pin_49, C66XX_S.SHARED_SYSTEM.QUEUE_MANAGER.qmss_int1_14_opin;
        CONNECT1636        C66XX_S.CPU_SYSTEM_6.CGEM_SSI_6.INTSEL_in_pin_50, C66XX_S.SHARED_SYSTEM.QUEUE_MANAGER.qmss_int1_22_opin;
        CONNECT1637        C66XX_S.CPU_SYSTEM_6.CGEM_SSI_6.INTSEL_in_pin_51, C66XX_S.SHARED_SYSTEM.QUEUE_MANAGER.qmss_int1_30_opin;
        //TIMERS
        CONNECT1638        C66XX_S.CPU_SYSTEM_6.CGEM_SSI_6.INTSEL_in_pin_64, C66XX_S.SHARED_SYSTEM.TIMER64_6_cpu_int_12;
        CONNECT1639        C66XX_S.CPU_SYSTEM_6.CGEM_SSI_6.INTSEL_in_pin_65, C66XX_S.SHARED_SYSTEM.TIMER64_6_cpu_int_34;
        CONNECT1640        C66XX_S.CPU_SYSTEM_6.CGEM_SSI_6.INTSEL_in_pin_66, C66XX_S.SHARED_SYSTEM.TIMER64_8_cpu_int_12;
        CONNECT1641        C66XX_S.CPU_SYSTEM_6.CGEM_SSI_6.INTSEL_in_pin_67, C66XX_S.SHARED_SYSTEM.TIMER64_8_cpu_int_34;
        CONNECT1642        C66XX_S.CPU_SYSTEM_6.CGEM_SSI_6.INTSEL_in_pin_68, C66XX_S.SHARED_SYSTEM.TIMER64_9_cpu_int_12;
        CONNECT1643        C66XX_S.CPU_SYSTEM_6.CGEM_SSI_6.INTSEL_in_pin_69, C66XX_S.SHARED_SYSTEM.TIMER64_9_cpu_int_34;
        CONNECT1644        C66XX_S.CPU_SYSTEM_6.CGEM_SSI_6.INTSEL_in_pin_70, C66XX_S.SHARED_SYSTEM.TIMER64_10_cpu_int_12;
        CONNECT1645        C66XX_S.CPU_SYSTEM_6.CGEM_SSI_6.INTSEL_in_pin_71, C66XX_S.SHARED_SYSTEM.TIMER64_10_cpu_int_34;
        CONNECT1646        C66XX_S.CPU_SYSTEM_6.CGEM_SSI_6.INTSEL_in_pin_72, C66XX_S.SHARED_SYSTEM.TIMER64_11_cpu_int_12;
        CONNECT1647        C66XX_S.CPU_SYSTEM_6.CGEM_SSI_6.INTSEL_in_pin_73, C66XX_S.SHARED_SYSTEM.TIMER64_11_cpu_int_34;
        CONNECT1648        C66XX_S.CPU_SYSTEM_6.CGEM_SSI_6.INTSEL_in_pin_74, C66XX_S.SHARED_SYSTEM.TIMER64_12_cpu_int_12;
        CONNECT1649        C66XX_S.CPU_SYSTEM_6.CGEM_SSI_6.INTSEL_in_pin_75, C66XX_S.SHARED_SYSTEM.TIMER64_12_cpu_int_34;
        CONNECT1650        C66XX_S.CPU_SYSTEM_6.CGEM_SSI_6.INTSEL_in_pin_76, C66XX_S.SHARED_SYSTEM.TIMER64_13_cpu_int_12;
        CONNECT1651        C66XX_S.CPU_SYSTEM_6.CGEM_SSI_6.INTSEL_in_pin_77, C66XX_S.SHARED_SYSTEM.TIMER64_13_cpu_int_34;
        CONNECT1652        C66XX_S.CPU_SYSTEM_6.CGEM_SSI_6.INTSEL_in_pin_78, C66XX_S.SHARED_SYSTEM.TIMER64_14_cpu_int_12;
        CONNECT1653        C66XX_S.CPU_SYSTEM_6.CGEM_SSI_6.INTSEL_in_pin_79, C66XX_S.SHARED_SYSTEM.TIMER64_14_cpu_int_34;
        CONNECT1654        C66XX_S.CPU_SYSTEM_6.CGEM_SSI_6.INTSEL_in_pin_80, C66XX_S.SHARED_SYSTEM.TIMER64_15_cpu_int_12;
        CONNECT1655        C66XX_S.CPU_SYSTEM_6.CGEM_SSI_6.INTSEL_in_pin_81, C66XX_S.SHARED_SYSTEM.TIMER64_15_cpu_int_34;
         //GPIO
        CONNECT1656        C66XX_S.CPU_SYSTEM_6.CGEM_SSI_6.INTSEL_in_pin_82, C66XX_S.SHARED_SYSTEM.GPIO.gpio_gpint8_opin;
        CONNECT1657        C66XX_S.CPU_SYSTEM_6.CGEM_SSI_6.INTSEL_in_pin_83, C66XX_S.SHARED_SYSTEM.GPIO.gpio_gpint9_opin;
        CONNECT1658        C66XX_S.CPU_SYSTEM_6.CGEM_SSI_6.INTSEL_in_pin_84, C66XX_S.SHARED_SYSTEM.GPIO.gpio_gpint10_opin;
        CONNECT1659        C66XX_S.CPU_SYSTEM_6.CGEM_SSI_6.INTSEL_in_pin_85, C66XX_S.SHARED_SYSTEM.GPIO.gpio_gpint11_opin;
        CONNECT1660        C66XX_S.CPU_SYSTEM_6.CGEM_SSI_6.INTSEL_in_pin_86, C66XX_S.SHARED_SYSTEM.GPIO.gpio_gpint12_opin;
        CONNECT1661        C66XX_S.CPU_SYSTEM_6.CGEM_SSI_6.INTSEL_in_pin_87, C66XX_S.SHARED_SYSTEM.GPIO.gpio_gpint13_opin;
        CONNECT1662        C66XX_S.CPU_SYSTEM_6.CGEM_SSI_6.INTSEL_in_pin_88, C66XX_S.SHARED_SYSTEM.GPIO.gpio_gpint14_opin;
        CONNECT1663        C66XX_S.CPU_SYSTEM_6.CGEM_SSI_6.INTSEL_in_pin_89, C66XX_S.SHARED_SYSTEM.GPIO.gpio_gpint15_opin;
        CONNECT1664        C66XX_S.CPU_SYSTEM_6.CGEM_SSI_6.INTSEL_in_pin_90, C66XX_S.SHARED_SYSTEM.GPIO.gpio_gpint6_opin;
        //IPC
        CONNECT1665        C66XX_S.CPU_SYSTEM_6.CGEM_SSI_6.INTSEL_in_pin_91, C66XX_S.SHARED_SYSTEM.IPC_cpu_int_6;
        //!CPU7
        //SEMAPHORE
        CONNECT1666        C66XX_S.CPU_SYSTEM_7.CGEM_SSI_7.INTSEL_in_pin_15, C66XX_S.SHARED_SYSTEM.SEMAPHORE.semaphore2_err_opin7;
        CONNECT1667        C66XX_S.CPU_SYSTEM_7.CGEM_SSI_7.INTSEL_in_pin_16, C66XX_S.SHARED_SYSTEM.SEMAPHORE.semaphore2_intr_opin7;
        //SRIO
        CONNECT1668        C66XX_S.CPU_SYSTEM_7.CGEM_SSI_7.INTSEL_in_pin_20, C66XX_S.SHARED_SYSTEM.SRIO.srio_intdst_intr23;
        //QUEUE_MANAGER
        CONNECT1669        C66XX_S.CPU_SYSTEM_7.CGEM_SSI_7.INTSEL_in_pin_32, C66XX_S.SHARED_SYSTEM.QUEUE_MANAGER.qmss_int0_0_opin;
        CONNECT1670        C66XX_S.CPU_SYSTEM_7.CGEM_SSI_7.INTSEL_in_pin_33, C66XX_S.SHARED_SYSTEM.QUEUE_MANAGER.qmss_int0_1_opin;
        CONNECT1671        C66XX_S.CPU_SYSTEM_7.CGEM_SSI_7.INTSEL_in_pin_34, C66XX_S.SHARED_SYSTEM.QUEUE_MANAGER.qmss_int0_2_opin;
        CONNECT1672        C66XX_S.CPU_SYSTEM_7.CGEM_SSI_7.INTSEL_in_pin_35, C66XX_S.SHARED_SYSTEM.QUEUE_MANAGER.qmss_int0_3_opin;
        CONNECT1673        C66XX_S.CPU_SYSTEM_7.CGEM_SSI_7.INTSEL_in_pin_36, C66XX_S.SHARED_SYSTEM.QUEUE_MANAGER.qmss_int0_4_opin;
        CONNECT1674        C66XX_S.CPU_SYSTEM_7.CGEM_SSI_7.INTSEL_in_pin_37, C66XX_S.SHARED_SYSTEM.QUEUE_MANAGER.qmss_int0_5_opin;
        CONNECT1675        C66XX_S.CPU_SYSTEM_7.CGEM_SSI_7.INTSEL_in_pin_38, C66XX_S.SHARED_SYSTEM.QUEUE_MANAGER.qmss_int0_6_opin;
        CONNECT1676        C66XX_S.CPU_SYSTEM_7.CGEM_SSI_7.INTSEL_in_pin_39, C66XX_S.SHARED_SYSTEM.QUEUE_MANAGER.qmss_int0_7_opin;
        CONNECT1677        C66XX_S.CPU_SYSTEM_7.CGEM_SSI_7.INTSEL_in_pin_40, C66XX_S.SHARED_SYSTEM.QUEUE_MANAGER.qmss_int0_8_opin;
        CONNECT1678        C66XX_S.CPU_SYSTEM_7.CGEM_SSI_7.INTSEL_in_pin_41, C66XX_S.SHARED_SYSTEM.QUEUE_MANAGER.qmss_int0_9_opin;
        CONNECT1679        C66XX_S.CPU_SYSTEM_7.CGEM_SSI_7.INTSEL_in_pin_42, C66XX_S.SHARED_SYSTEM.QUEUE_MANAGER.qmss_int0_10_opin;
        CONNECT1680        C66XX_S.CPU_SYSTEM_7.CGEM_SSI_7.INTSEL_in_pin_43, C66XX_S.SHARED_SYSTEM.QUEUE_MANAGER.qmss_int0_11_opin;
        CONNECT1681        C66XX_S.CPU_SYSTEM_7.CGEM_SSI_7.INTSEL_in_pin_44, C66XX_S.SHARED_SYSTEM.QUEUE_MANAGER.qmss_int0_12_opin;
        CONNECT1682        C66XX_S.CPU_SYSTEM_7.CGEM_SSI_7.INTSEL_in_pin_45, C66XX_S.SHARED_SYSTEM.QUEUE_MANAGER.qmss_int0_13_opin;
        CONNECT1683        C66XX_S.CPU_SYSTEM_7.CGEM_SSI_7.INTSEL_in_pin_46, C66XX_S.SHARED_SYSTEM.QUEUE_MANAGER.qmss_int0_14_opin;
        CONNECT1684        C66XX_S.CPU_SYSTEM_7.CGEM_SSI_7.INTSEL_in_pin_47, C66XX_S.SHARED_SYSTEM.QUEUE_MANAGER.qmss_int0_15_opin;
        CONNECT1685        C66XX_S.CPU_SYSTEM_7.CGEM_SSI_7.INTSEL_in_pin_48, C66XX_S.SHARED_SYSTEM.QUEUE_MANAGER.qmss_int1_7_opin;
        CONNECT1686        C66XX_S.CPU_SYSTEM_7.CGEM_SSI_7.INTSEL_in_pin_49, C66XX_S.SHARED_SYSTEM.QUEUE_MANAGER.qmss_int1_15_opin;
        CONNECT1687        C66XX_S.CPU_SYSTEM_7.CGEM_SSI_7.INTSEL_in_pin_50, C66XX_S.SHARED_SYSTEM.QUEUE_MANAGER.qmss_int1_23_opin;
        CONNECT1688        C66XX_S.CPU_SYSTEM_7.CGEM_SSI_7.INTSEL_in_pin_51, C66XX_S.SHARED_SYSTEM.QUEUE_MANAGER.qmss_int1_31_opin;
        //TIMERS
        CONNECT1689        C66XX_S.CPU_SYSTEM_7.CGEM_SSI_7.INTSEL_in_pin_64, C66XX_S.SHARED_SYSTEM.TIMER64_7_cpu_int_12;
        CONNECT1690        C66XX_S.CPU_SYSTEM_7.CGEM_SSI_7.INTSEL_in_pin_65, C66XX_S.SHARED_SYSTEM.TIMER64_7_cpu_int_34;
        CONNECT1691        C66XX_S.CPU_SYSTEM_7.CGEM_SSI_7.INTSEL_in_pin_66, C66XX_S.SHARED_SYSTEM.TIMER64_8_cpu_int_12;
        CONNECT1692        C66XX_S.CPU_SYSTEM_7.CGEM_SSI_7.INTSEL_in_pin_67, C66XX_S.SHARED_SYSTEM.TIMER64_8_cpu_int_34;
        CONNECT1693        C66XX_S.CPU_SYSTEM_7.CGEM_SSI_7.INTSEL_in_pin_68, C66XX_S.SHARED_SYSTEM.TIMER64_9_cpu_int_12;
        CONNECT1694        C66XX_S.CPU_SYSTEM_7.CGEM_SSI_7.INTSEL_in_pin_69, C66XX_S.SHARED_SYSTEM.TIMER64_9_cpu_int_34;
        CONNECT1695        C66XX_S.CPU_SYSTEM_7.CGEM_SSI_7.INTSEL_in_pin_70, C66XX_S.SHARED_SYSTEM.TIMER64_10_cpu_int_12;
        CONNECT1696        C66XX_S.CPU_SYSTEM_7.CGEM_SSI_7.INTSEL_in_pin_71, C66XX_S.SHARED_SYSTEM.TIMER64_10_cpu_int_34;
        CONNECT1697        C66XX_S.CPU_SYSTEM_7.CGEM_SSI_7.INTSEL_in_pin_72, C66XX_S.SHARED_SYSTEM.TIMER64_11_cpu_int_12;
        CONNECT1698        C66XX_S.CPU_SYSTEM_7.CGEM_SSI_7.INTSEL_in_pin_73, C66XX_S.SHARED_SYSTEM.TIMER64_11_cpu_int_34;
        CONNECT1699        C66XX_S.CPU_SYSTEM_7.CGEM_SSI_7.INTSEL_in_pin_74, C66XX_S.SHARED_SYSTEM.TIMER64_12_cpu_int_12;
        CONNECT1700        C66XX_S.CPU_SYSTEM_7.CGEM_SSI_7.INTSEL_in_pin_75, C66XX_S.SHARED_SYSTEM.TIMER64_12_cpu_int_34;
        CONNECT1701        C66XX_S.CPU_SYSTEM_7.CGEM_SSI_7.INTSEL_in_pin_76, C66XX_S.SHARED_SYSTEM.TIMER64_13_cpu_int_12;
        CONNECT1702        C66XX_S.CPU_SYSTEM_7.CGEM_SSI_7.INTSEL_in_pin_77, C66XX_S.SHARED_SYSTEM.TIMER64_13_cpu_int_34;
        CONNECT1703        C66XX_S.CPU_SYSTEM_7.CGEM_SSI_7.INTSEL_in_pin_78, C66XX_S.SHARED_SYSTEM.TIMER64_14_cpu_int_12;
        CONNECT1704        C66XX_S.CPU_SYSTEM_7.CGEM_SSI_7.INTSEL_in_pin_79, C66XX_S.SHARED_SYSTEM.TIMER64_14_cpu_int_34;
        CONNECT1705        C66XX_S.CPU_SYSTEM_7.CGEM_SSI_7.INTSEL_in_pin_80, C66XX_S.SHARED_SYSTEM.TIMER64_15_cpu_int_12;
        CONNECT1706        C66XX_S.CPU_SYSTEM_7.CGEM_SSI_7.INTSEL_in_pin_81, C66XX_S.SHARED_SYSTEM.TIMER64_15_cpu_int_34;
         //GPIO
        CONNECT1707        C66XX_S.CPU_SYSTEM_7.CGEM_SSI_7.INTSEL_in_pin_82, C66XX_S.SHARED_SYSTEM.GPIO.gpio_gpint8_opin;
        CONNECT1708        C66XX_S.CPU_SYSTEM_7.CGEM_SSI_7.INTSEL_in_pin_83, C66XX_S.SHARED_SYSTEM.GPIO.gpio_gpint9_opin;
        CONNECT1709        C66XX_S.CPU_SYSTEM_7.CGEM_SSI_7.INTSEL_in_pin_84, C66XX_S.SHARED_SYSTEM.GPIO.gpio_gpint10_opin;
        CONNECT1710        C66XX_S.CPU_SYSTEM_7.CGEM_SSI_7.INTSEL_in_pin_85, C66XX_S.SHARED_SYSTEM.GPIO.gpio_gpint11_opin;
        CONNECT1711        C66XX_S.CPU_SYSTEM_7.CGEM_SSI_7.INTSEL_in_pin_86, C66XX_S.SHARED_SYSTEM.GPIO.gpio_gpint12_opin;
        CONNECT1712        C66XX_S.CPU_SYSTEM_7.CGEM_SSI_7.INTSEL_in_pin_87, C66XX_S.SHARED_SYSTEM.GPIO.gpio_gpint13_opin;
        CONNECT1713        C66XX_S.CPU_SYSTEM_7.CGEM_SSI_7.INTSEL_in_pin_88, C66XX_S.SHARED_SYSTEM.GPIO.gpio_gpint14_opin;
        CONNECT1714        C66XX_S.CPU_SYSTEM_7.CGEM_SSI_7.INTSEL_in_pin_89, C66XX_S.SHARED_SYSTEM.GPIO.gpio_gpint15_opin;
        CONNECT1715        C66XX_S.CPU_SYSTEM_7.CGEM_SSI_7.INTSEL_in_pin_90, C66XX_S.SHARED_SYSTEM.GPIO.gpio_gpint7_opin;
         //IPC
        CONNECT1716        C66XX_S.CPU_SYSTEM_7.CGEM_SSI_7.INTSEL_in_pin_91, C66XX_S.SHARED_SYSTEM.IPC_cpu_int_7;
        // Primary Interrupt Connections with EDMA_1
        //GPIO
        CONNECT1717        C66XX_S.SHARED_SYSTEM.EDMA_1_evt_in_pin6, C66XX_S.SHARED_SYSTEM.GPIO.gpio_gpint0_opin;
        CONNECT1718        C66XX_S.SHARED_SYSTEM.EDMA_1_evt_in_pin7, C66XX_S.SHARED_SYSTEM.GPIO.gpio_gpint1_opin;
        CONNECT1719        C66XX_S.SHARED_SYSTEM.EDMA_1_evt_in_pin8, C66XX_S.SHARED_SYSTEM.GPIO.gpio_gpint2_opin;
        CONNECT1720        C66XX_S.SHARED_SYSTEM.EDMA_1_evt_in_pin9, C66XX_S.SHARED_SYSTEM.GPIO.gpio_gpint3_opin;
        CONNECT1721        C66XX_S.SHARED_SYSTEM.EDMA_1_evt_in_pin10, C66XX_S.SHARED_SYSTEM.GPIO.gpio_gpint4_opin;
        CONNECT1722        C66XX_S.SHARED_SYSTEM.EDMA_1_evt_in_pin11, C66XX_S.SHARED_SYSTEM.GPIO.gpio_gpint5_opin;
        CONNECT1723        C66XX_S.SHARED_SYSTEM.EDMA_1_evt_in_pin12, C66XX_S.SHARED_SYSTEM.GPIO.gpio_gpint6_opin;
        CONNECT1724        C66XX_S.SHARED_SYSTEM.EDMA_1_evt_in_pin13, C66XX_S.SHARED_SYSTEM.GPIO.gpio_gpint7_opin;
        //SEMAPHORE
        CONNECT1725        C66XX_S.SHARED_SYSTEM.EDMA_1_evt_in_pin14, C66XX_S.SHARED_SYSTEM.SEMAPHORE.semaphore2_intr_opin0;
        CONNECT1726        C66XX_S.SHARED_SYSTEM.EDMA_1_evt_in_pin15, C66XX_S.SHARED_SYSTEM.SEMAPHORE.semaphore2_intr_opin1;
        CONNECT1727        C66XX_S.SHARED_SYSTEM.EDMA_1_evt_in_pin16, C66XX_S.SHARED_SYSTEM.SEMAPHORE.semaphore2_intr_opin2;
        CONNECT1728        C66XX_S.SHARED_SYSTEM.EDMA_1_evt_in_pin17, C66XX_S.SHARED_SYSTEM.SEMAPHORE.semaphore2_intr_opin3;
        CONNECT1729        C66XX_S.SHARED_SYSTEM.EDMA_1_evt_in_pin18, C66XX_S.SHARED_SYSTEM.SEMAPHORE.semaphore2_intr_opin4;
        CONNECT1730        C66XX_S.SHARED_SYSTEM.EDMA_1_evt_in_pin19, C66XX_S.SHARED_SYSTEM.SEMAPHORE.semaphore2_intr_opin5;
        CONNECT1731        C66XX_S.SHARED_SYSTEM.EDMA_1_evt_in_pin20, C66XX_S.SHARED_SYSTEM.SEMAPHORE.semaphore2_intr_opin6;
        CONNECT1732        C66XX_S.SHARED_SYSTEM.EDMA_1_evt_in_pin21, C66XX_S.SHARED_SYSTEM.SEMAPHORE.semaphore2_intr_opin7;
            //TIMER64
        CONNECT1733        C66XX_S.SHARED_SYSTEM.EDMA_1_evt_in_pin22, C66XX_S.SHARED_SYSTEM.TIMER64_8_cpu_int_12;
        CONNECT1734        C66XX_S.SHARED_SYSTEM.EDMA_1_evt_in_pin23, C66XX_S.SHARED_SYSTEM.TIMER64_8_cpu_int_34;
        CONNECT1735        C66XX_S.SHARED_SYSTEM.EDMA_1_evt_in_pin24, C66XX_S.SHARED_SYSTEM.TIMER64_9_cpu_int_12;
        CONNECT1736        C66XX_S.SHARED_SYSTEM.EDMA_1_evt_in_pin25, C66XX_S.SHARED_SYSTEM.TIMER64_9_cpu_int_34;
        CONNECT1737        C66XX_S.SHARED_SYSTEM.EDMA_1_evt_in_pin26, C66XX_S.SHARED_SYSTEM.TIMER64_10_cpu_int_12;
        CONNECT1738        C66XX_S.SHARED_SYSTEM.EDMA_1_evt_in_pin27, C66XX_S.SHARED_SYSTEM.TIMER64_10_cpu_int_34;
        CONNECT1739        C66XX_S.SHARED_SYSTEM.EDMA_1_evt_in_pin28, C66XX_S.SHARED_SYSTEM.TIMER64_11_cpu_int_12;
        CONNECT1740        C66XX_S.SHARED_SYSTEM.EDMA_1_evt_in_pin29, C66XX_S.SHARED_SYSTEM.TIMER64_11_cpu_int_34;
        CONNECT1741        C66XX_S.SHARED_SYSTEM.EDMA_1_evt_in_pin30, C66XX_S.SHARED_SYSTEM.TIMER64_12_cpu_int_12;
        CONNECT1742        C66XX_S.SHARED_SYSTEM.EDMA_1_evt_in_pin31, C66XX_S.SHARED_SYSTEM.TIMER64_12_cpu_int_34;
        CONNECT1743        C66XX_S.SHARED_SYSTEM.EDMA_1_evt_in_pin32, C66XX_S.SHARED_SYSTEM.TIMER64_13_cpu_int_12;
        CONNECT1744        C66XX_S.SHARED_SYSTEM.EDMA_1_evt_in_pin33, C66XX_S.SHARED_SYSTEM.TIMER64_13_cpu_int_34;
        CONNECT1745        C66XX_S.SHARED_SYSTEM.EDMA_1_evt_in_pin34, C66XX_S.SHARED_SYSTEM.TIMER64_14_cpu_int_12;
        CONNECT1746        C66XX_S.SHARED_SYSTEM.EDMA_1_evt_in_pin35, C66XX_S.SHARED_SYSTEM.TIMER64_14_cpu_int_34;
        CONNECT1747        C66XX_S.SHARED_SYSTEM.EDMA_1_evt_in_pin36, C66XX_S.SHARED_SYSTEM.TIMER64_15_cpu_int_12;
        CONNECT1748        C66XX_S.SHARED_SYSTEM.EDMA_1_evt_in_pin37, C66XX_S.SHARED_SYSTEM.TIMER64_15_cpu_int_34;
        // Primary Interrupt Connections with EDMA_2
        //GPIO
        CONNECT1749        C66XX_S.SHARED_SYSTEM.EDMA_2_evt_in_pin6, C66XX_S.SHARED_SYSTEM.GPIO.gpio_gpint0_opin;
        CONNECT1750        C66XX_S.SHARED_SYSTEM.EDMA_2_evt_in_pin7, C66XX_S.SHARED_SYSTEM.GPIO.gpio_gpint1_opin;
        CONNECT1751        C66XX_S.SHARED_SYSTEM.EDMA_2_evt_in_pin8, C66XX_S.SHARED_SYSTEM.GPIO.gpio_gpint2_opin;
        CONNECT1752        C66XX_S.SHARED_SYSTEM.EDMA_2_evt_in_pin9, C66XX_S.SHARED_SYSTEM.GPIO.gpio_gpint3_opin;
        CONNECT1753        C66XX_S.SHARED_SYSTEM.EDMA_2_evt_in_pin10, C66XX_S.SHARED_SYSTEM.GPIO.gpio_gpint4_opin;
        CONNECT1754        C66XX_S.SHARED_SYSTEM.EDMA_2_evt_in_pin11, C66XX_S.SHARED_SYSTEM.GPIO.gpio_gpint5_opin;
        CONNECT1755        C66XX_S.SHARED_SYSTEM.EDMA_2_evt_in_pin12, C66XX_S.SHARED_SYSTEM.GPIO.gpio_gpint6_opin;
        CONNECT1756        C66XX_S.SHARED_SYSTEM.EDMA_2_evt_in_pin13, C66XX_S.SHARED_SYSTEM.GPIO.gpio_gpint7_opin;
        //SEMAPHORE
        CONNECT1757        C66XX_S.SHARED_SYSTEM.EDMA_2_evt_in_pin14, C66XX_S.SHARED_SYSTEM.SEMAPHORE.semaphore2_intr_opin0;
        CONNECT1758        C66XX_S.SHARED_SYSTEM.EDMA_2_evt_in_pin15, C66XX_S.SHARED_SYSTEM.SEMAPHORE.semaphore2_intr_opin1;
        CONNECT1759        C66XX_S.SHARED_SYSTEM.EDMA_2_evt_in_pin16, C66XX_S.SHARED_SYSTEM.SEMAPHORE.semaphore2_intr_opin2;
        CONNECT1760        C66XX_S.SHARED_SYSTEM.EDMA_2_evt_in_pin17, C66XX_S.SHARED_SYSTEM.SEMAPHORE.semaphore2_intr_opin3;
        CONNECT1761        C66XX_S.SHARED_SYSTEM.EDMA_2_evt_in_pin18, C66XX_S.SHARED_SYSTEM.SEMAPHORE.semaphore2_intr_opin4;
        CONNECT1762        C66XX_S.SHARED_SYSTEM.EDMA_2_evt_in_pin19, C66XX_S.SHARED_SYSTEM.SEMAPHORE.semaphore2_intr_opin5;
        CONNECT1763        C66XX_S.SHARED_SYSTEM.EDMA_2_evt_in_pin20, C66XX_S.SHARED_SYSTEM.SEMAPHORE.semaphore2_intr_opin6;
        CONNECT1764        C66XX_S.SHARED_SYSTEM.EDMA_2_evt_in_pin21, C66XX_S.SHARED_SYSTEM.SEMAPHORE.semaphore2_intr_opin7;
        //TIMER64
        CONNECT1765        C66XX_S.SHARED_SYSTEM.EDMA_2_evt_in_pin22, C66XX_S.SHARED_SYSTEM.TIMER64_8_cpu_int_12;
        CONNECT1766        C66XX_S.SHARED_SYSTEM.EDMA_2_evt_in_pin23, C66XX_S.SHARED_SYSTEM.TIMER64_8_cpu_int_34;
        CONNECT1767        C66XX_S.SHARED_SYSTEM.EDMA_2_evt_in_pin24, C66XX_S.SHARED_SYSTEM.TIMER64_9_cpu_int_12;
        CONNECT1768        C66XX_S.SHARED_SYSTEM.EDMA_2_evt_in_pin25, C66XX_S.SHARED_SYSTEM.TIMER64_9_cpu_int_34;
        CONNECT1769        C66XX_S.SHARED_SYSTEM.EDMA_2_evt_in_pin26, C66XX_S.SHARED_SYSTEM.TIMER64_10_cpu_int_12;
        CONNECT1770        C66XX_S.SHARED_SYSTEM.EDMA_2_evt_in_pin27, C66XX_S.SHARED_SYSTEM.TIMER64_10_cpu_int_34;
        CONNECT1771        C66XX_S.SHARED_SYSTEM.EDMA_2_evt_in_pin28, C66XX_S.SHARED_SYSTEM.TIMER64_11_cpu_int_12;
        CONNECT1772        C66XX_S.SHARED_SYSTEM.EDMA_2_evt_in_pin29, C66XX_S.SHARED_SYSTEM.TIMER64_11_cpu_int_34;
        CONNECT1773        C66XX_S.SHARED_SYSTEM.EDMA_2_evt_in_pin30, C66XX_S.SHARED_SYSTEM.TIMER64_12_cpu_int_12;
        CONNECT1774        C66XX_S.SHARED_SYSTEM.EDMA_2_evt_in_pin31, C66XX_S.SHARED_SYSTEM.TIMER64_12_cpu_int_34;
        CONNECT1775        C66XX_S.SHARED_SYSTEM.EDMA_2_evt_in_pin32, C66XX_S.SHARED_SYSTEM.TIMER64_13_cpu_int_12;
        CONNECT1776        C66XX_S.SHARED_SYSTEM.EDMA_2_evt_in_pin33, C66XX_S.SHARED_SYSTEM.TIMER64_13_cpu_int_34;
        CONNECT1777        C66XX_S.SHARED_SYSTEM.EDMA_2_evt_in_pin34, C66XX_S.SHARED_SYSTEM.TIMER64_14_cpu_int_12;
        CONNECT1778        C66XX_S.SHARED_SYSTEM.EDMA_2_evt_in_pin35, C66XX_S.SHARED_SYSTEM.TIMER64_14_cpu_int_34;
        CONNECT1779        C66XX_S.SHARED_SYSTEM.EDMA_2_evt_in_pin36, C66XX_S.SHARED_SYSTEM.TIMER64_15_cpu_int_12;
        CONNECT1780        C66XX_S.SHARED_SYSTEM.EDMA_2_evt_in_pin37, C66XX_S.SHARED_SYSTEM.TIMER64_15_cpu_int_34;
        // Primary Interrupt Connections with EDMA_0
        //TIMER64
        CONNECT1781        C66XX_S.SHARED_SYSTEM.EDMA_0_evt_in_pin0, C66XX_S.SHARED_SYSTEM.TIMER64_8_cpu_int_12;
        CONNECT1782        C66XX_S.SHARED_SYSTEM.EDMA_0_evt_in_pin1, C66XX_S.SHARED_SYSTEM.TIMER64_8_cpu_int_34;
        CONNECT1783        C66XX_S.SHARED_SYSTEM.EDMA_0_evt_in_pin2, C66XX_S.SHARED_SYSTEM.TIMER64_9_cpu_int_12;
        CONNECT1784        C66XX_S.SHARED_SYSTEM.EDMA_0_evt_in_pin3, C66XX_S.SHARED_SYSTEM.TIMER64_9_cpu_int_34;
        CONNECT1785        C66XX_S.SHARED_SYSTEM.EDMA_0_evt_in_pin4, C66XX_S.SHARED_SYSTEM.TIMER64_10_cpu_int_12;
        CONNECT1786        C66XX_S.SHARED_SYSTEM.EDMA_0_evt_in_pin5, C66XX_S.SHARED_SYSTEM.TIMER64_10_cpu_int_34;
        CONNECT1787        C66XX_S.SHARED_SYSTEM.EDMA_0_evt_in_pin6, C66XX_S.SHARED_SYSTEM.TIMER64_11_cpu_int_12;
        CONNECT1788        C66XX_S.SHARED_SYSTEM.EDMA_0_evt_in_pin7, C66XX_S.SHARED_SYSTEM.TIMER64_11_cpu_int_34;
        CONNECT1789        C66XX_S.SHARED_SYSTEM.MSMC.msmc_mem_map, C66XX_S.SHARED_SYSTEM.BOOT_ROM_mif, 0x20B00000, 0x20B1FFFF, 0;
        CONNECT1790        C66XX_S.SHARED_SYSTEM.EDMA_0_mem_map, C66XX_S.SHARED_SYSTEM.BOOT_ROM_mif, 0x20B00000, 0x20B1FFFF, 0;
        CONNECT1791        C66XX_S.SHARED_SYSTEM.EDMA_1_mem_map, C66XX_S.SHARED_SYSTEM.BOOT_ROM_mif, 0x20B00000, 0x20B1FFFF, 0;
        CONNECT1792        C66XX_S.SHARED_SYSTEM.EDMA_2_mem_map, C66XX_S.SHARED_SYSTEM.BOOT_ROM_mif, 0x20B00000, 0x20B1FFFF, 0;
        // Interrupt connections for PA_SS
        //! with INTC0
        CONNECT1793        C66XX_S.SHARED_SYSTEM.PASS.pass_intr_opin, C66XX_S.SHARED_SYSTEM.CP_INTC0.cp_intc_system_intr_in72;
        //! with INTC1
        CONNECT1794        C66XX_S.SHARED_SYSTEM.PASS.pass_intr_opin, C66XX_S.SHARED_SYSTEM.CP_INTC1.cp_intc_system_intr_in72;
        //! with INTC2
        CONNECT1795        C66XX_S.SHARED_SYSTEM.PASS.pass_intr_opin, C66XX_S.SHARED_SYSTEM.CP_INTC2.cp_intc_system_intr_in44;
        // PASS memory master connections
        CONNECT1796        C66XX_S.SHARED_SYSTEM.PASS.pass_read_opin, C66XX_S.SHARED_SYSTEM.MEMTR_PASS_Master.MT_SSI2MMAP.memtr_read_ipin;
        CONNECT1797        C66XX_S.SHARED_SYSTEM.PASS.pass_write_opin, C66XX_S.SHARED_SYSTEM.MEMTR_PASS_Master.MT_SSI2MMAP.memtr_write_ipin;
        CONNECT1798        C66XX_S.SHARED_SYSTEM.MEMTR_PASS_Master.MT_SSI2MMAP.memtr_reset_ipin, System.SimBridge.global_reset_list;
        CONNECT1799        C66XX_S.SHARED_SYSTEM.MEMTR_PASS_Master.MT_SSI2MMAP.is_little_endian_ipin, C66XX_S.CPU_SYSTEM_0.CPU0_endianness;
        CONNECT1800        C66XX_S.SHARED_SYSTEM.MEMTR_CP_INTC0_Config.MT_MIF2SSI.memtr_reset_ipin, System.SimBridge.global_reset_list;
        CONNECT1801        C66XX_S.SHARED_SYSTEM.MEMTR_CP_INTC1_Config.MT_MIF2SSI.memtr_reset_ipin, System.SimBridge.global_reset_list;
        CONNECT1802        C66XX_S.SHARED_SYSTEM.MEMTR_CP_INTC2_Config.MT_MIF2SSI.memtr_reset_ipin, System.SimBridge.global_reset_list;
        CONNECT1803        C66XX_S.SHARED_SYSTEM.MEMTR_CP_INTC3_Config.MT_MIF2SSI.memtr_reset_ipin, System.SimBridge.global_reset_list;
        CONNECT1804        C66XX_S.SHARED_SYSTEM.MEMTR_IPC_Config.MT_MIF2SSI.memtr_reset_ipin, System.SimBridge.global_reset_list;
        CONNECT1805        C66XX_S.SHARED_SYSTEM.MEMTR_CP_INTC0_Config.MT_MIF2SSI.is_little_endian_ipin, C66XX_S.CPU_SYSTEM_0.CPU0_endianness;
        CONNECT1806        C66XX_S.SHARED_SYSTEM.MEMTR_CP_INTC1_Config.MT_MIF2SSI.is_little_endian_ipin, C66XX_S.CPU_SYSTEM_0.CPU0_endianness;
        CONNECT1807        C66XX_S.SHARED_SYSTEM.MEMTR_CP_INTC2_Config.MT_MIF2SSI.is_little_endian_ipin, C66XX_S.CPU_SYSTEM_0.CPU0_endianness;
        CONNECT1808        C66XX_S.SHARED_SYSTEM.MEMTR_CP_INTC3_Config.MT_MIF2SSI.is_little_endian_ipin, C66XX_S.CPU_SYSTEM_0.CPU0_endianness;
        CONNECT1809        C66XX_S.SHARED_SYSTEM.MEMTR_IPC_Config.MT_MIF2SSI.is_little_endian_ipin, C66XX_S.CPU_SYSTEM_0.CPU0_endianness;
        CONNECT1810        C66XX_S.SHARED_SYSTEM.CP_INTC0.cp_intc_read_in, C66XX_S.SHARED_SYSTEM.MEMTR_CP_INTC0_Config.MT_MIF2SSI.memtr_read_opin;
        CONNECT1811        C66XX_S.SHARED_SYSTEM.CP_INTC0.cp_intc_write_in, C66XX_S.SHARED_SYSTEM.MEMTR_CP_INTC0_Config.MT_MIF2SSI.memtr_write_opin;
        CONNECT1812        C66XX_S.SHARED_SYSTEM.CP_INTC0.cp_intc_dbg_read_in, C66XX_S.SHARED_SYSTEM.MEMTR_CP_INTC0_Config.MT_MIF2SSI.memtr_dbg_read_opin;
        CONNECT1813        C66XX_S.SHARED_SYSTEM.CP_INTC0.cp_intc_dbg_write_in, C66XX_S.SHARED_SYSTEM.MEMTR_CP_INTC0_Config.MT_MIF2SSI.memtr_dbg_write_opin;
        CONNECT1814        C66XX_S.SHARED_SYSTEM.CP_INTC1.cp_intc_read_in, C66XX_S.SHARED_SYSTEM.MEMTR_CP_INTC1_Config.MT_MIF2SSI.memtr_read_opin;
        CONNECT1815        C66XX_S.SHARED_SYSTEM.CP_INTC1.cp_intc_write_in, C66XX_S.SHARED_SYSTEM.MEMTR_CP_INTC1_Config.MT_MIF2SSI.memtr_write_opin;
        CONNECT1816        C66XX_S.SHARED_SYSTEM.CP_INTC1.cp_intc_dbg_read_in, C66XX_S.SHARED_SYSTEM.MEMTR_CP_INTC1_Config.MT_MIF2SSI.memtr_dbg_read_opin;
        CONNECT1817        C66XX_S.SHARED_SYSTEM.CP_INTC1.cp_intc_dbg_write_in, C66XX_S.SHARED_SYSTEM.MEMTR_CP_INTC1_Config.MT_MIF2SSI.memtr_dbg_write_opin;
        CONNECT1818        C66XX_S.SHARED_SYSTEM.CP_INTC2.cp_intc_read_in, C66XX_S.SHARED_SYSTEM.MEMTR_CP_INTC2_Config.MT_MIF2SSI.memtr_read_opin;
        CONNECT1819        C66XX_S.SHARED_SYSTEM.CP_INTC2.cp_intc_write_in, C66XX_S.SHARED_SYSTEM.MEMTR_CP_INTC2_Config.MT_MIF2SSI.memtr_write_opin;
        CONNECT1820        C66XX_S.SHARED_SYSTEM.CP_INTC2.cp_intc_dbg_read_in, C66XX_S.SHARED_SYSTEM.MEMTR_CP_INTC2_Config.MT_MIF2SSI.memtr_dbg_read_opin;
        CONNECT1821        C66XX_S.SHARED_SYSTEM.CP_INTC2.cp_intc_dbg_write_in, C66XX_S.SHARED_SYSTEM.MEMTR_CP_INTC2_Config.MT_MIF2SSI.memtr_dbg_write_opin;
        CONNECT1822        C66XX_S.SHARED_SYSTEM.CP_INTC3.cp_intc_read_in, C66XX_S.SHARED_SYSTEM.MEMTR_CP_INTC3_Config.MT_MIF2SSI.memtr_read_opin;
        CONNECT1823        C66XX_S.SHARED_SYSTEM.CP_INTC3.cp_intc_write_in, C66XX_S.SHARED_SYSTEM.MEMTR_CP_INTC3_Config.MT_MIF2SSI.memtr_write_opin;
        CONNECT1824        C66XX_S.SHARED_SYSTEM.CP_INTC3.cp_intc_dbg_read_in, C66XX_S.SHARED_SYSTEM.MEMTR_CP_INTC3_Config.MT_MIF2SSI.memtr_dbg_read_opin;
        CONNECT1825        C66XX_S.SHARED_SYSTEM.CP_INTC3.cp_intc_dbg_write_in, C66XX_S.SHARED_SYSTEM.MEMTR_CP_INTC3_Config.MT_MIF2SSI.memtr_dbg_write_opin;
        CONNECT1826        C66XX_S.SHARED_SYSTEM.IPC.ici_read_in, C66XX_S.SHARED_SYSTEM.MEMTR_IPC_Config.MT_MIF2SSI.memtr_read_opin;
        CONNECT1827        C66XX_S.SHARED_SYSTEM.IPC.ici_write_in, C66XX_S.SHARED_SYSTEM.MEMTR_IPC_Config.MT_MIF2SSI.memtr_write_opin;
        CONNECT1828        C66XX_S.SHARED_SYSTEM.IPC.ici_dbg_read_in, C66XX_S.SHARED_SYSTEM.MEMTR_IPC_Config.MT_MIF2SSI.memtr_dbg_read_opin;
        CONNECT1829        C66XX_S.SHARED_SYSTEM.IPC.ici_dbg_write_in, C66XX_S.SHARED_SYSTEM.MEMTR_IPC_Config.MT_MIF2SSI.memtr_dbg_write_opin;
        //Addition in jan 2010, additional QMSS interrupts
        CONNECT1830        C66XX_S.SHARED_SYSTEM.QUEUE_MANAGER.qmss_int_pa_tx_12_opin, C66XX_S.SHARED_SYSTEM.CP_INTC0.cp_intc_system_intr_in47;
        CONNECT1831        C66XX_S.SHARED_SYSTEM.QUEUE_MANAGER.qmss_int_pa_tx_13_opin, C66XX_S.SHARED_SYSTEM.CP_INTC0.cp_intc_system_intr_in91;
        CONNECT1832        C66XX_S.SHARED_SYSTEM.QUEUE_MANAGER.qmss_int_pa_tx_14_opin, C66XX_S.SHARED_SYSTEM.CP_INTC0.cp_intc_system_intr_in93;
        CONNECT1833        C66XX_S.SHARED_SYSTEM.QUEUE_MANAGER.qmss_int_pa_tx_15_opin, C66XX_S.SHARED_SYSTEM.CP_INTC0.cp_intc_system_intr_in95;
        CONNECT1834        C66XX_S.SHARED_SYSTEM.QUEUE_MANAGER.qmss_int_pa_tx_16_opin, C66XX_S.SHARED_SYSTEM.CP_INTC0.cp_intc_system_intr_in97;
        CONNECT1835        C66XX_S.SHARED_SYSTEM.QUEUE_MANAGER.qmss_int_pa_tx_17_opin, C66XX_S.SHARED_SYSTEM.CP_INTC0.cp_intc_system_intr_in151;
        CONNECT1836        C66XX_S.SHARED_SYSTEM.QUEUE_MANAGER.qmss_int_pa_tx_18_opin, C66XX_S.SHARED_SYSTEM.CP_INTC0.cp_intc_system_intr_in152;
        CONNECT1837        C66XX_S.SHARED_SYSTEM.QUEUE_MANAGER.qmss_int_pa_tx_19_opin, C66XX_S.SHARED_SYSTEM.CP_INTC0.cp_intc_system_intr_in153;
        CONNECT1838        C66XX_S.SHARED_SYSTEM.QUEUE_MANAGER.qmss_int_pa_tx_20_opin, C66XX_S.SHARED_SYSTEM.CP_INTC0.cp_intc_system_intr_in154;
        CONNECT1839        C66XX_S.SHARED_SYSTEM.QUEUE_MANAGER.qmss_int_pa_tx_21_opin, C66XX_S.SHARED_SYSTEM.CP_INTC0.cp_intc_system_intr_in155;
        CONNECT1840        C66XX_S.SHARED_SYSTEM.QUEUE_MANAGER.qmss_int_pa_tx_22_opin, C66XX_S.SHARED_SYSTEM.CP_INTC0.cp_intc_system_intr_in156;
        CONNECT1841        C66XX_S.SHARED_SYSTEM.QUEUE_MANAGER.qmss_int_pa_tx_23_opin, C66XX_S.SHARED_SYSTEM.CP_INTC0.cp_intc_system_intr_in157;
        CONNECT1842        C66XX_S.SHARED_SYSTEM.QUEUE_MANAGER.qmss_int_pa_tx_24_opin, C66XX_S.SHARED_SYSTEM.CP_INTC0.cp_intc_system_intr_in158;
        CONNECT1843        C66XX_S.SHARED_SYSTEM.QUEUE_MANAGER.qmss_int_pa_tx_25_opin, C66XX_S.SHARED_SYSTEM.CP_INTC0.cp_intc_system_intr_in159;
        CONNECT1844        C66XX_S.SHARED_SYSTEM.QUEUE_MANAGER.qmss_int_pa_tx_18_opin, C66XX_S.SHARED_SYSTEM.CP_INTC1.cp_intc_system_intr_in47;
        CONNECT1845        C66XX_S.SHARED_SYSTEM.QUEUE_MANAGER.qmss_int_pa_tx_19_opin, C66XX_S.SHARED_SYSTEM.CP_INTC1.cp_intc_system_intr_in91;
        CONNECT1846        C66XX_S.SHARED_SYSTEM.QUEUE_MANAGER.qmss_int_pa_tx_20_opin, C66XX_S.SHARED_SYSTEM.CP_INTC1.cp_intc_system_intr_in93;
        CONNECT1847        C66XX_S.SHARED_SYSTEM.QUEUE_MANAGER.qmss_int_pa_tx_21_opin, C66XX_S.SHARED_SYSTEM.CP_INTC1.cp_intc_system_intr_in95;
        CONNECT1848        C66XX_S.SHARED_SYSTEM.QUEUE_MANAGER.qmss_int_pa_tx_22_opin, C66XX_S.SHARED_SYSTEM.CP_INTC1.cp_intc_system_intr_in97;
        CONNECT1849        C66XX_S.SHARED_SYSTEM.QUEUE_MANAGER.qmss_int_pa_tx_23_opin, C66XX_S.SHARED_SYSTEM.CP_INTC1.cp_intc_system_intr_in151;
        CONNECT1850        C66XX_S.SHARED_SYSTEM.QUEUE_MANAGER.qmss_int_pa_tx_24_opin, C66XX_S.SHARED_SYSTEM.CP_INTC1.cp_intc_system_intr_in152;
        CONNECT1851        C66XX_S.SHARED_SYSTEM.QUEUE_MANAGER.qmss_int_pa_tx_25_opin, C66XX_S.SHARED_SYSTEM.CP_INTC1.cp_intc_system_intr_in153;
        CONNECT1852        C66XX_S.SHARED_SYSTEM.QUEUE_MANAGER.qmss_int_pa_tx_26_opin, C66XX_S.SHARED_SYSTEM.CP_INTC1.cp_intc_system_intr_in154;
        CONNECT1853        C66XX_S.SHARED_SYSTEM.QUEUE_MANAGER.qmss_int_pa_tx_27_opin, C66XX_S.SHARED_SYSTEM.CP_INTC1.cp_intc_system_intr_in155;
        CONNECT1854        C66XX_S.SHARED_SYSTEM.QUEUE_MANAGER.qmss_int_pa_tx_28_opin, C66XX_S.SHARED_SYSTEM.CP_INTC1.cp_intc_system_intr_in156;
        CONNECT1855        C66XX_S.SHARED_SYSTEM.QUEUE_MANAGER.qmss_int_pa_tx_29_opin, C66XX_S.SHARED_SYSTEM.CP_INTC1.cp_intc_system_intr_in157;
        CONNECT1856        C66XX_S.SHARED_SYSTEM.QUEUE_MANAGER.qmss_int_pa_tx_30_opin, C66XX_S.SHARED_SYSTEM.CP_INTC1.cp_intc_system_intr_in158;
        CONNECT1857        C66XX_S.SHARED_SYSTEM.QUEUE_MANAGER.qmss_int_pa_tx_31_opin, C66XX_S.SHARED_SYSTEM.CP_INTC1.cp_intc_system_intr_in159;
    //PSC
        CONNECT1858        C66XX_S.SHARED_SYSTEM.MSMC.msmc_mem_map, C66XX_S.SHARED_SYSTEM.MIF_TO_FUNC_PSC.MT_MIF2SSI.memtr_mif_opin, 0x02350000, 0x02350FFF, -0x02350000;
        CONNECT1859        System.SimBridge.global_reset_list, C66XX_S.SHARED_SYSTEM.MIF_TO_FUNC_PSC.MT_MIF2SSI.memtr_reset_ipin;
        CONNECT1860        C66XX_S.SHARED_SYSTEM.MIF_TO_FUNC_PSC.MT_MIF2SSI.is_little_endian_ipin, C66XX_S.CPU_SYSTEM_0.CPU0_endianness;
        // PSC connections with EDMA mem_map( through MIF_TO_FUNC)
        CONNECT1861        C66XX_S.SHARED_SYSTEM.EDMA_0_mem_map, C66XX_S.SHARED_SYSTEM.MIF_TO_FUNC_PSC.MT_MIF2SSI.memtr_mif_opin, 0x02350000, 0x02350FFF, -0x02350000;
        CONNECT1862        C66XX_S.SHARED_SYSTEM.EDMA_1_mem_map, C66XX_S.SHARED_SYSTEM.MIF_TO_FUNC_PSC.MT_MIF2SSI.memtr_mif_opin, 0x02350000, 0x02350FFF, -0x02350000;
        CONNECT1863        C66XX_S.SHARED_SYSTEM.EDMA_2_mem_map, C66XX_S.SHARED_SYSTEM.MIF_TO_FUNC_PSC.MT_MIF2SSI.memtr_mif_opin, 0x02350000, 0x02350FFF, -0x02350000;
        CONNECT1864        C66XX_S.SHARED_SYSTEM.CP_INTC0.cp_intc_out0, C66XX_S.CPU_SYSTEM_0.CGEM_SSI_0.INTSEL_in_pin_102;
        CONNECT1865        C66XX_S.SHARED_SYSTEM.CP_INTC0.cp_intc_out1, C66XX_S.CPU_SYSTEM_0.CGEM_SSI_0.INTSEL_in_pin_103;
        CONNECT1866        C66XX_S.SHARED_SYSTEM.CP_INTC0.cp_intc_out8, C66XX_S.CPU_SYSTEM_0.CGEM_SSI_0.INTSEL_in_pin_104;
        CONNECT1867        C66XX_S.SHARED_SYSTEM.CP_INTC0.cp_intc_out9, C66XX_S.CPU_SYSTEM_0.CGEM_SSI_0.INTSEL_in_pin_105;
        CONNECT1868        C66XX_S.SHARED_SYSTEM.CP_INTC0.cp_intc_out16, C66XX_S.CPU_SYSTEM_0.CGEM_SSI_0.INTSEL_in_pin_106;
        CONNECT1869        C66XX_S.SHARED_SYSTEM.CP_INTC0.cp_intc_out17, C66XX_S.CPU_SYSTEM_0.CGEM_SSI_0.INTSEL_in_pin_107;
        CONNECT1870        C66XX_S.SHARED_SYSTEM.CP_INTC0.cp_intc_out24, C66XX_S.CPU_SYSTEM_0.CGEM_SSI_0.INTSEL_in_pin_108;
        CONNECT1871        C66XX_S.SHARED_SYSTEM.CP_INTC0.cp_intc_out25, C66XX_S.CPU_SYSTEM_0.CGEM_SSI_0.INTSEL_in_pin_109;
        CONNECT1872        C66XX_S.SHARED_SYSTEM.CP_INTC0.cp_intc_out0, C66XX_S.CPU_SYSTEM_1.CGEM_SSI_1.INTSEL_in_pin_102;
        CONNECT1873        C66XX_S.SHARED_SYSTEM.CP_INTC0.cp_intc_out1, C66XX_S.CPU_SYSTEM_1.CGEM_SSI_1.INTSEL_in_pin_103;
        CONNECT1874        C66XX_S.SHARED_SYSTEM.CP_INTC0.cp_intc_out8, C66XX_S.CPU_SYSTEM_1.CGEM_SSI_1.INTSEL_in_pin_104;
        CONNECT1875        C66XX_S.SHARED_SYSTEM.CP_INTC0.cp_intc_out9, C66XX_S.CPU_SYSTEM_1.CGEM_SSI_1.INTSEL_in_pin_105;
        CONNECT1876        C66XX_S.SHARED_SYSTEM.CP_INTC0.cp_intc_out16, C66XX_S.CPU_SYSTEM_1.CGEM_SSI_1.INTSEL_in_pin_106;
        CONNECT1877        C66XX_S.SHARED_SYSTEM.CP_INTC0.cp_intc_out17, C66XX_S.CPU_SYSTEM_1.CGEM_SSI_1.INTSEL_in_pin_107;
        CONNECT1878        C66XX_S.SHARED_SYSTEM.CP_INTC0.cp_intc_out24, C66XX_S.CPU_SYSTEM_1.CGEM_SSI_1.INTSEL_in_pin_108;
        CONNECT1879        C66XX_S.SHARED_SYSTEM.CP_INTC0.cp_intc_out25, C66XX_S.CPU_SYSTEM_1.CGEM_SSI_1.INTSEL_in_pin_109;
        CONNECT1880        C66XX_S.SHARED_SYSTEM.CP_INTC0.cp_intc_out0, C66XX_S.CPU_SYSTEM_2.CGEM_SSI_2.INTSEL_in_pin_102;
        CONNECT1881        C66XX_S.SHARED_SYSTEM.CP_INTC0.cp_intc_out1, C66XX_S.CPU_SYSTEM_2.CGEM_SSI_2.INTSEL_in_pin_103;
        CONNECT1882        C66XX_S.SHARED_SYSTEM.CP_INTC0.cp_intc_out8, C66XX_S.CPU_SYSTEM_2.CGEM_SSI_2.INTSEL_in_pin_104;
        CONNECT1883        C66XX_S.SHARED_SYSTEM.CP_INTC0.cp_intc_out9, C66XX_S.CPU_SYSTEM_2.CGEM_SSI_2.INTSEL_in_pin_105;
        CONNECT1884        C66XX_S.SHARED_SYSTEM.CP_INTC0.cp_intc_out16, C66XX_S.CPU_SYSTEM_2.CGEM_SSI_2.INTSEL_in_pin_106;
        CONNECT1885        C66XX_S.SHARED_SYSTEM.CP_INTC0.cp_intc_out17, C66XX_S.CPU_SYSTEM_2.CGEM_SSI_2.INTSEL_in_pin_107;
        CONNECT1886        C66XX_S.SHARED_SYSTEM.CP_INTC0.cp_intc_out24, C66XX_S.CPU_SYSTEM_2.CGEM_SSI_2.INTSEL_in_pin_108;
        CONNECT1887        C66XX_S.SHARED_SYSTEM.CP_INTC0.cp_intc_out25, C66XX_S.CPU_SYSTEM_2.CGEM_SSI_2.INTSEL_in_pin_109;
        CONNECT1888        C66XX_S.SHARED_SYSTEM.CP_INTC0.cp_intc_out0, C66XX_S.CPU_SYSTEM_3.CGEM_SSI_3.INTSEL_in_pin_102;
        CONNECT1889        C66XX_S.SHARED_SYSTEM.CP_INTC0.cp_intc_out1, C66XX_S.CPU_SYSTEM_3.CGEM_SSI_3.INTSEL_in_pin_103;
        CONNECT1890        C66XX_S.SHARED_SYSTEM.CP_INTC0.cp_intc_out8, C66XX_S.CPU_SYSTEM_3.CGEM_SSI_3.INTSEL_in_pin_104;
        CONNECT1891        C66XX_S.SHARED_SYSTEM.CP_INTC0.cp_intc_out9, C66XX_S.CPU_SYSTEM_3.CGEM_SSI_3.INTSEL_in_pin_105;
        CONNECT1892        C66XX_S.SHARED_SYSTEM.CP_INTC0.cp_intc_out16, C66XX_S.CPU_SYSTEM_3.CGEM_SSI_3.INTSEL_in_pin_106;
        CONNECT1893        C66XX_S.SHARED_SYSTEM.CP_INTC0.cp_intc_out17, C66XX_S.CPU_SYSTEM_3.CGEM_SSI_3.INTSEL_in_pin_107;
        CONNECT1894        C66XX_S.SHARED_SYSTEM.CP_INTC0.cp_intc_out24, C66XX_S.CPU_SYSTEM_3.CGEM_SSI_3.INTSEL_in_pin_108;
        CONNECT1895        C66XX_S.SHARED_SYSTEM.CP_INTC0.cp_intc_out25, C66XX_S.CPU_SYSTEM_3.CGEM_SSI_3.INTSEL_in_pin_109;
        CONNECT1896        C66XX_S.SHARED_SYSTEM.CP_INTC1.cp_intc_out0, C66XX_S.CPU_SYSTEM_4.CGEM_SSI_4.INTSEL_in_pin_102;
        CONNECT1897        C66XX_S.SHARED_SYSTEM.CP_INTC1.cp_intc_out1, C66XX_S.CPU_SYSTEM_4.CGEM_SSI_4.INTSEL_in_pin_103;
        CONNECT1898        C66XX_S.SHARED_SYSTEM.CP_INTC1.cp_intc_out8, C66XX_S.CPU_SYSTEM_4.CGEM_SSI_4.INTSEL_in_pin_104;
        CONNECT1899        C66XX_S.SHARED_SYSTEM.CP_INTC1.cp_intc_out9, C66XX_S.CPU_SYSTEM_4.CGEM_SSI_4.INTSEL_in_pin_105;
        CONNECT1900        C66XX_S.SHARED_SYSTEM.CP_INTC1.cp_intc_out16, C66XX_S.CPU_SYSTEM_4.CGEM_SSI_4.INTSEL_in_pin_106;
        CONNECT1901        C66XX_S.SHARED_SYSTEM.CP_INTC1.cp_intc_out17, C66XX_S.CPU_SYSTEM_4.CGEM_SSI_4.INTSEL_in_pin_107;
        CONNECT1902        C66XX_S.SHARED_SYSTEM.CP_INTC1.cp_intc_out24, C66XX_S.CPU_SYSTEM_4.CGEM_SSI_4.INTSEL_in_pin_108;
        CONNECT1903        C66XX_S.SHARED_SYSTEM.CP_INTC1.cp_intc_out25, C66XX_S.CPU_SYSTEM_4.CGEM_SSI_4.INTSEL_in_pin_109;
        CONNECT1904        C66XX_S.SHARED_SYSTEM.CP_INTC1.cp_intc_out0, C66XX_S.CPU_SYSTEM_5.CGEM_SSI_5.INTSEL_in_pin_102;
        CONNECT1905        C66XX_S.SHARED_SYSTEM.CP_INTC1.cp_intc_out1, C66XX_S.CPU_SYSTEM_5.CGEM_SSI_5.INTSEL_in_pin_103;
        CONNECT1906        C66XX_S.SHARED_SYSTEM.CP_INTC1.cp_intc_out8, C66XX_S.CPU_SYSTEM_5.CGEM_SSI_5.INTSEL_in_pin_104;
        CONNECT1907        C66XX_S.SHARED_SYSTEM.CP_INTC1.cp_intc_out9, C66XX_S.CPU_SYSTEM_5.CGEM_SSI_5.INTSEL_in_pin_105;
        CONNECT1908        C66XX_S.SHARED_SYSTEM.CP_INTC1.cp_intc_out16, C66XX_S.CPU_SYSTEM_5.CGEM_SSI_5.INTSEL_in_pin_106;
        CONNECT1909        C66XX_S.SHARED_SYSTEM.CP_INTC1.cp_intc_out17, C66XX_S.CPU_SYSTEM_5.CGEM_SSI_5.INTSEL_in_pin_107;
        CONNECT1910        C66XX_S.SHARED_SYSTEM.CP_INTC1.cp_intc_out24, C66XX_S.CPU_SYSTEM_5.CGEM_SSI_5.INTSEL_in_pin_108;
        CONNECT1911        C66XX_S.SHARED_SYSTEM.CP_INTC1.cp_intc_out25, C66XX_S.CPU_SYSTEM_5.CGEM_SSI_5.INTSEL_in_pin_109;
        CONNECT1912        C66XX_S.SHARED_SYSTEM.CP_INTC1.cp_intc_out0, C66XX_S.CPU_SYSTEM_6.CGEM_SSI_6.INTSEL_in_pin_102;
        CONNECT1913        C66XX_S.SHARED_SYSTEM.CP_INTC1.cp_intc_out1, C66XX_S.CPU_SYSTEM_6.CGEM_SSI_6.INTSEL_in_pin_103;
        CONNECT1914        C66XX_S.SHARED_SYSTEM.CP_INTC1.cp_intc_out8, C66XX_S.CPU_SYSTEM_6.CGEM_SSI_6.INTSEL_in_pin_104;
        CONNECT1915        C66XX_S.SHARED_SYSTEM.CP_INTC1.cp_intc_out9, C66XX_S.CPU_SYSTEM_6.CGEM_SSI_6.INTSEL_in_pin_105;
        CONNECT1916        C66XX_S.SHARED_SYSTEM.CP_INTC1.cp_intc_out16, C66XX_S.CPU_SYSTEM_6.CGEM_SSI_6.INTSEL_in_pin_106;
        CONNECT1917        C66XX_S.SHARED_SYSTEM.CP_INTC1.cp_intc_out17, C66XX_S.CPU_SYSTEM_6.CGEM_SSI_6.INTSEL_in_pin_107;
        CONNECT1918        C66XX_S.SHARED_SYSTEM.CP_INTC1.cp_intc_out24, C66XX_S.CPU_SYSTEM_6.CGEM_SSI_6.INTSEL_in_pin_108;
        CONNECT1919        C66XX_S.SHARED_SYSTEM.CP_INTC1.cp_intc_out25, C66XX_S.CPU_SYSTEM_6.CGEM_SSI_6.INTSEL_in_pin_109;
        CONNECT1920        C66XX_S.SHARED_SYSTEM.CP_INTC1.cp_intc_out0, C66XX_S.CPU_SYSTEM_7.CGEM_SSI_7.INTSEL_in_pin_102;
        CONNECT1921        C66XX_S.SHARED_SYSTEM.CP_INTC1.cp_intc_out1, C66XX_S.CPU_SYSTEM_7.CGEM_SSI_7.INTSEL_in_pin_103;
        CONNECT1922        C66XX_S.SHARED_SYSTEM.CP_INTC1.cp_intc_out8, C66XX_S.CPU_SYSTEM_7.CGEM_SSI_7.INTSEL_in_pin_104;
        CONNECT1923        C66XX_S.SHARED_SYSTEM.CP_INTC1.cp_intc_out9, C66XX_S.CPU_SYSTEM_7.CGEM_SSI_7.INTSEL_in_pin_105;
        CONNECT1924        C66XX_S.SHARED_SYSTEM.CP_INTC1.cp_intc_out16, C66XX_S.CPU_SYSTEM_7.CGEM_SSI_7.INTSEL_in_pin_106;
        CONNECT1925        C66XX_S.SHARED_SYSTEM.CP_INTC1.cp_intc_out17, C66XX_S.CPU_SYSTEM_7.CGEM_SSI_7.INTSEL_in_pin_107;
        CONNECT1926        C66XX_S.SHARED_SYSTEM.CP_INTC1.cp_intc_out24, C66XX_S.CPU_SYSTEM_7.CGEM_SSI_7.INTSEL_in_pin_108;
        CONNECT1927        C66XX_S.SHARED_SYSTEM.CP_INTC1.cp_intc_out25, C66XX_S.CPU_SYSTEM_7.CGEM_SSI_7.INTSEL_in_pin_109;
        // SASS Connections
        CONNECT1928        C66XX_S.SHARED_SYSTEM.MSMC.msmc_mem_map, C66XX_S.SHARED_SYSTEM.MIF_TO_FUNC_PASS.MT_MIF2SSI.memtr_mif_opin, 0x020C0000, 0x020CFFFF, -0x02000000;
        CONNECT1929        C66XX_S.SHARED_SYSTEM.EDMA_0_mem_map, C66XX_S.SHARED_SYSTEM.MIF_TO_FUNC_PASS.MT_MIF2SSI.memtr_mif_opin, 0x020C0000, 0x020CFFFF, -0x02000000;
        CONNECT1930        C66XX_S.SHARED_SYSTEM.EDMA_1_mem_map, C66XX_S.SHARED_SYSTEM.MIF_TO_FUNC_PASS.MT_MIF2SSI.memtr_mif_opin, 0x020C0000, 0x020CFFFF, -0x02000000;
        CONNECT1931        C66XX_S.SHARED_SYSTEM.EDMA_2_mem_map, C66XX_S.SHARED_SYSTEM.MIF_TO_FUNC_PASS.MT_MIF2SSI.memtr_mif_opin, 0x020C0000, 0x020CFFFF, -0x02000000;
    // L1/L2 connections with MSMC mem_map
        CONNECT1932        C66XX_S.SHARED_SYSTEM.MSMC.msmc_mem_map, C66XX_S.CPU_SYSTEM_0.CGEM_SSI_0.cgem_slave_mif, 0x10800000, 0x1087FFFF, -0x10000000; //L2
        CONNECT1933        C66XX_S.SHARED_SYSTEM.MSMC.msmc_mem_map, C66XX_S.CPU_SYSTEM_0.CGEM_SSI_0.cgem_slave_mif, 0x10E00000, 0x10E07FFF, -0x10000000; //L1P
        CONNECT1934        C66XX_S.SHARED_SYSTEM.MSMC.msmc_mem_map, C66XX_S.CPU_SYSTEM_0.CGEM_SSI_0.cgem_slave_mif, 0x10F00000, 0x10F07FFF, -0x10000000; //L1D
        CONNECT1935        C66XX_S.SHARED_SYSTEM.MSMC.msmc_mem_map, C66XX_S.CPU_SYSTEM_1.CGEM_SSI_1.cgem_slave_mif, 0x11800000, 0x1187FFFF, -0x11000000; //L2
        CONNECT1936        C66XX_S.SHARED_SYSTEM.MSMC.msmc_mem_map, C66XX_S.CPU_SYSTEM_1.CGEM_SSI_1.cgem_slave_mif, 0x11E00000, 0x11E07FFF, -0x11000000; //L1P
        CONNECT1937        C66XX_S.SHARED_SYSTEM.MSMC.msmc_mem_map, C66XX_S.CPU_SYSTEM_1.CGEM_SSI_1.cgem_slave_mif, 0x11F00000, 0x11F07FFF, -0x11000000; //L1D
        CONNECT1938        C66XX_S.SHARED_SYSTEM.MSMC.msmc_mem_map, C66XX_S.CPU_SYSTEM_2.CGEM_SSI_2.cgem_slave_mif, 0x12800000, 0x1287FFFF, -0x12000000; //L2
        CONNECT1939        C66XX_S.SHARED_SYSTEM.MSMC.msmc_mem_map, C66XX_S.CPU_SYSTEM_2.CGEM_SSI_2.cgem_slave_mif, 0x12E00000, 0x12E07FFF, -0x12000000; //L1P
        CONNECT1940        C66XX_S.SHARED_SYSTEM.MSMC.msmc_mem_map, C66XX_S.CPU_SYSTEM_2.CGEM_SSI_2.cgem_slave_mif, 0x12F00000, 0x12F07FFF, -0x12000000; //L1D
        CONNECT1941        C66XX_S.SHARED_SYSTEM.MSMC.msmc_mem_map, C66XX_S.CPU_SYSTEM_3.CGEM_SSI_3.cgem_slave_mif, 0x13800000, 0x1387FFFF, -0x13000000; //L2
        CONNECT1942        C66XX_S.SHARED_SYSTEM.MSMC.msmc_mem_map, C66XX_S.CPU_SYSTEM_3.CGEM_SSI_3.cgem_slave_mif, 0x13E00000, 0x13E07FFF, -0x13000000; //L1P
        CONNECT1943        C66XX_S.SHARED_SYSTEM.MSMC.msmc_mem_map, C66XX_S.CPU_SYSTEM_3.CGEM_SSI_3.cgem_slave_mif, 0x13F00000, 0x13F07FFF, -0x13000000; //L1D
        CONNECT1944        C66XX_S.SHARED_SYSTEM.MSMC.msmc_mem_map, C66XX_S.CPU_SYSTEM_4.CGEM_SSI_4.cgem_slave_mif, 0x14800000, 0x1487FFFF, -0x14000000; //L2
        CONNECT1945        C66XX_S.SHARED_SYSTEM.MSMC.msmc_mem_map, C66XX_S.CPU_SYSTEM_4.CGEM_SSI_4.cgem_slave_mif, 0x14E00000, 0x14E07FFF, -0x14000000; //L1P
        CONNECT1946        C66XX_S.SHARED_SYSTEM.MSMC.msmc_mem_map, C66XX_S.CPU_SYSTEM_4.CGEM_SSI_4.cgem_slave_mif, 0x14F00000, 0x14F07FFF, -0x14000000; //L1D
        CONNECT1947        C66XX_S.SHARED_SYSTEM.MSMC.msmc_mem_map, C66XX_S.CPU_SYSTEM_5.CGEM_SSI_5.cgem_slave_mif, 0x15800000, 0x1587FFFF, -0x15000000; //L2
        CONNECT1948        C66XX_S.SHARED_SYSTEM.MSMC.msmc_mem_map, C66XX_S.CPU_SYSTEM_5.CGEM_SSI_5.cgem_slave_mif, 0x15E00000, 0x15E07FFF, -0x15000000; //L1P
        CONNECT1949        C66XX_S.SHARED_SYSTEM.MSMC.msmc_mem_map, C66XX_S.CPU_SYSTEM_5.CGEM_SSI_5.cgem_slave_mif, 0x15F00000, 0x15F07FFF, -0x15000000; //L1D
        CONNECT1950        C66XX_S.SHARED_SYSTEM.MSMC.msmc_mem_map, C66XX_S.CPU_SYSTEM_6.CGEM_SSI_6.cgem_slave_mif, 0x16800000, 0x1687FFFF, -0x16000000; //L2
        CONNECT1951        C66XX_S.SHARED_SYSTEM.MSMC.msmc_mem_map, C66XX_S.CPU_SYSTEM_6.CGEM_SSI_6.cgem_slave_mif, 0x16E00000, 0x16E07FFF, -0x16000000; //L1P
        CONNECT1952        C66XX_S.SHARED_SYSTEM.MSMC.msmc_mem_map, C66XX_S.CPU_SYSTEM_6.CGEM_SSI_6.cgem_slave_mif, 0x16F00000, 0x16F07FFF, -0x16000000; //L1D
        CONNECT1953        C66XX_S.SHARED_SYSTEM.MSMC.msmc_mem_map, C66XX_S.CPU_SYSTEM_7.CGEM_SSI_7.cgem_slave_mif, 0x17800000, 0x1787FFFF, -0x17000000; //L2
        CONNECT1954        C66XX_S.SHARED_SYSTEM.MSMC.msmc_mem_map, C66XX_S.CPU_SYSTEM_7.CGEM_SSI_7.cgem_slave_mif, 0x17E00000, 0x17E07FFF, -0x17000000; //L1P
        CONNECT1955        C66XX_S.SHARED_SYSTEM.MSMC.msmc_mem_map, C66XX_S.CPU_SYSTEM_7.CGEM_SSI_7.cgem_slave_mif, 0x17F00000, 0x17F07FFF, -0x17000000; //L1D
        // L1D and L1P connection for CGEM program path
        CONNECT1956        C66XX_S.CPU_SYSTEM_0.CGEM_SSI_0.cgem_l1RAM_mif, C66XX_S.CPU_SYSTEM_0.CPU0.prog_mem_map, 0x00E00000, 0x00E07FFF, 0;
        CONNECT1957        C66XX_S.CPU_SYSTEM_1.CGEM_SSI_1.cgem_l1RAM_mif, C66XX_S.CPU_SYSTEM_1.CPU1.prog_mem_map, 0x00E00000, 0x00E07FFF, 0;
        CONNECT1958        C66XX_S.CPU_SYSTEM_2.CGEM_SSI_2.cgem_l1RAM_mif, C66XX_S.CPU_SYSTEM_2.CPU2.prog_mem_map, 0x00E00000, 0x00E07FFF, 0;
        CONNECT1959        C66XX_S.CPU_SYSTEM_3.CGEM_SSI_3.cgem_l1RAM_mif, C66XX_S.CPU_SYSTEM_3.CPU3.prog_mem_map, 0x00E00000, 0x00E07FFF, 0;
        CONNECT1960        C66XX_S.CPU_SYSTEM_4.CGEM_SSI_4.cgem_l1RAM_mif, C66XX_S.CPU_SYSTEM_4.CPU4.prog_mem_map, 0x00E00000, 0x00E07FFF, 0;
        CONNECT1961        C66XX_S.CPU_SYSTEM_5.CGEM_SSI_5.cgem_l1RAM_mif, C66XX_S.CPU_SYSTEM_5.CPU5.prog_mem_map, 0x00E00000, 0x00E07FFF, 0;
        CONNECT1962        C66XX_S.CPU_SYSTEM_6.CGEM_SSI_6.cgem_l1RAM_mif, C66XX_S.CPU_SYSTEM_6.CPU6.prog_mem_map, 0x00E00000, 0x00E07FFF, 0;
        CONNECT1963        C66XX_S.CPU_SYSTEM_7.CGEM_SSI_7.cgem_l1RAM_mif, C66XX_S.CPU_SYSTEM_7.CPU7.prog_mem_map, 0x00E00000, 0x00E07FFF, 0;
        CONNECT1964        C66XX_S.CPU_SYSTEM_0.CGEM_SSI_0.cgem_l1RAM_mif, C66XX_S.CPU_SYSTEM_0.CPU0.prog_mem_map, 0x00F00000, 0x00F07FFF, 0;
        CONNECT1965        C66XX_S.CPU_SYSTEM_1.CGEM_SSI_1.cgem_l1RAM_mif, C66XX_S.CPU_SYSTEM_1.CPU1.prog_mem_map, 0x00F00000, 0x00F07FFF, 0;
        CONNECT1966        C66XX_S.CPU_SYSTEM_2.CGEM_SSI_2.cgem_l1RAM_mif, C66XX_S.CPU_SYSTEM_2.CPU2.prog_mem_map, 0x00F00000, 0x00F07FFF, 0;
        CONNECT1967        C66XX_S.CPU_SYSTEM_3.CGEM_SSI_3.cgem_l1RAM_mif, C66XX_S.CPU_SYSTEM_3.CPU3.prog_mem_map, 0x00F00000, 0x00F07FFF, 0;
        CONNECT1968        C66XX_S.CPU_SYSTEM_4.CGEM_SSI_4.cgem_l1RAM_mif, C66XX_S.CPU_SYSTEM_4.CPU4.prog_mem_map, 0x00F00000, 0x00F07FFF, 0;
        CONNECT1969        C66XX_S.CPU_SYSTEM_5.CGEM_SSI_5.cgem_l1RAM_mif, C66XX_S.CPU_SYSTEM_5.CPU5.prog_mem_map, 0x00F00000, 0x00F07FFF, 0;
        CONNECT1970        C66XX_S.CPU_SYSTEM_6.CGEM_SSI_6.cgem_l1RAM_mif, C66XX_S.CPU_SYSTEM_6.CPU6.prog_mem_map, 0x00F00000, 0x00F07FFF, 0;
        CONNECT1971        C66XX_S.CPU_SYSTEM_7.CGEM_SSI_7.cgem_l1RAM_mif, C66XX_S.CPU_SYSTEM_7.CPU7.prog_mem_map, 0x00F00000, 0x00F07FFF, 0;
        // L1D and L1P connection for CGEM Data path
        CONNECT1972        C66XX_S.CPU_SYSTEM_0.CGEM_SSI_0.cgem_l1RAM_mif, C66XX_S.CPU_SYSTEM_0.CPU0_mem_map, 0x00E00000, 0x00E07FFF, 0;
        CONNECT1973        C66XX_S.CPU_SYSTEM_1.CGEM_SSI_1.cgem_l1RAM_mif, C66XX_S.CPU_SYSTEM_1.CPU1_mem_map, 0x00E00000, 0x00E07FFF, 0;
        CONNECT1974        C66XX_S.CPU_SYSTEM_2.CGEM_SSI_2.cgem_l1RAM_mif, C66XX_S.CPU_SYSTEM_2.CPU2_mem_map, 0x00E00000, 0x00E07FFF, 0;
        CONNECT1975        C66XX_S.CPU_SYSTEM_3.CGEM_SSI_3.cgem_l1RAM_mif, C66XX_S.CPU_SYSTEM_3.CPU3_mem_map, 0x00E00000, 0x00E07FFF, 0;
        CONNECT1976        C66XX_S.CPU_SYSTEM_4.CGEM_SSI_4.cgem_l1RAM_mif, C66XX_S.CPU_SYSTEM_4.CPU4_mem_map, 0x00E00000, 0x00E07FFF, 0;
        CONNECT1977        C66XX_S.CPU_SYSTEM_5.CGEM_SSI_5.cgem_l1RAM_mif, C66XX_S.CPU_SYSTEM_5.CPU5_mem_map, 0x00E00000, 0x00E07FFF, 0;
        CONNECT1978        C66XX_S.CPU_SYSTEM_6.CGEM_SSI_6.cgem_l1RAM_mif, C66XX_S.CPU_SYSTEM_6.CPU6_mem_map, 0x00E00000, 0x00E07FFF, 0;
        CONNECT1979        C66XX_S.CPU_SYSTEM_7.CGEM_SSI_7.cgem_l1RAM_mif, C66XX_S.CPU_SYSTEM_7.CPU7_mem_map, 0x00E00000, 0x00E07FFF, 0;
        CONNECT1980        C66XX_S.CPU_SYSTEM_0.CGEM_SSI_0.cgem_l1RAM_mif, C66XX_S.CPU_SYSTEM_0.CPU0_mem_map, 0x00F00000, 0x00F07FFF, 0;
        CONNECT1981        C66XX_S.CPU_SYSTEM_1.CGEM_SSI_1.cgem_l1RAM_mif, C66XX_S.CPU_SYSTEM_1.CPU1_mem_map, 0x00F00000, 0x00F07FFF, 0;
        CONNECT1982        C66XX_S.CPU_SYSTEM_2.CGEM_SSI_2.cgem_l1RAM_mif, C66XX_S.CPU_SYSTEM_2.CPU2_mem_map, 0x00F00000, 0x00F07FFF, 0;
        CONNECT1983        C66XX_S.CPU_SYSTEM_3.CGEM_SSI_3.cgem_l1RAM_mif, C66XX_S.CPU_SYSTEM_3.CPU3_mem_map, 0x00F00000, 0x00F07FFF, 0;
        CONNECT1984        C66XX_S.CPU_SYSTEM_4.CGEM_SSI_4.cgem_l1RAM_mif, C66XX_S.CPU_SYSTEM_4.CPU4_mem_map, 0x00F00000, 0x00F07FFF, 0;
        CONNECT1985        C66XX_S.CPU_SYSTEM_5.CGEM_SSI_5.cgem_l1RAM_mif, C66XX_S.CPU_SYSTEM_5.CPU5_mem_map, 0x00F00000, 0x00F07FFF, 0;
        CONNECT1986        C66XX_S.CPU_SYSTEM_6.CGEM_SSI_6.cgem_l1RAM_mif, C66XX_S.CPU_SYSTEM_6.CPU6_mem_map, 0x00F00000, 0x00F07FFF, 0;
        CONNECT1987        C66XX_S.CPU_SYSTEM_7.CGEM_SSI_7.cgem_l1RAM_mif, C66XX_S.CPU_SYSTEM_7.CPU7_mem_map, 0x00F00000, 0x00F07FFF, 0;
            // Tag Ram connections
        CONNECT1988        C66XX_S.CPU_SYSTEM_0.CGEM_SSI_0.dmc_tag_ram_read, C66XX_S.CPU_SYSTEM_0.CPU0dmc_tag_ram_read;
        CONNECT1989        C66XX_S.CPU_SYSTEM_0.CGEM_SSI_0.pmc_tag_ram_read, C66XX_S.CPU_SYSTEM_0.CPU0pmc_tag_ram_read;
        CONNECT1990        C66XX_S.CPU_SYSTEM_0.CGEM_SSI_0.umc_tag_ram_read, C66XX_S.CPU_SYSTEM_0.CPU0umc_tag_ram_read;
        CONNECT1991        C66XX_S.CPU_SYSTEM_1.CGEM_SSI_1.dmc_tag_ram_read, C66XX_S.CPU_SYSTEM_1.CPU1dmc_tag_ram_read;
        CONNECT1992        C66XX_S.CPU_SYSTEM_1.CGEM_SSI_1.pmc_tag_ram_read, C66XX_S.CPU_SYSTEM_1.CPU1pmc_tag_ram_read;
        CONNECT1993        C66XX_S.CPU_SYSTEM_1.CGEM_SSI_1.umc_tag_ram_read, C66XX_S.CPU_SYSTEM_1.CPU1umc_tag_ram_read;
        CONNECT1994        C66XX_S.CPU_SYSTEM_2.CGEM_SSI_2.dmc_tag_ram_read, C66XX_S.CPU_SYSTEM_2.CPU2dmc_tag_ram_read;
        CONNECT1995        C66XX_S.CPU_SYSTEM_2.CGEM_SSI_2.pmc_tag_ram_read, C66XX_S.CPU_SYSTEM_2.CPU2pmc_tag_ram_read;
        CONNECT1996        C66XX_S.CPU_SYSTEM_2.CGEM_SSI_2.umc_tag_ram_read, C66XX_S.CPU_SYSTEM_2.CPU2umc_tag_ram_read;
        CONNECT1997        C66XX_S.CPU_SYSTEM_3.CGEM_SSI_3.dmc_tag_ram_read, C66XX_S.CPU_SYSTEM_3.CPU3dmc_tag_ram_read;
        CONNECT1998        C66XX_S.CPU_SYSTEM_3.CGEM_SSI_3.pmc_tag_ram_read, C66XX_S.CPU_SYSTEM_3.CPU3pmc_tag_ram_read;
        CONNECT1999        C66XX_S.CPU_SYSTEM_3.CGEM_SSI_3.umc_tag_ram_read, C66XX_S.CPU_SYSTEM_3.CPU3umc_tag_ram_read;
        CONNECT2000        C66XX_S.CPU_SYSTEM_4.CGEM_SSI_4.dmc_tag_ram_read, C66XX_S.CPU_SYSTEM_4.CPU4dmc_tag_ram_read;
        CONNECT2001        C66XX_S.CPU_SYSTEM_4.CGEM_SSI_4.pmc_tag_ram_read, C66XX_S.CPU_SYSTEM_4.CPU4pmc_tag_ram_read;
        CONNECT2002        C66XX_S.CPU_SYSTEM_4.CGEM_SSI_4.umc_tag_ram_read, C66XX_S.CPU_SYSTEM_4.CPU4umc_tag_ram_read;
        CONNECT2003        C66XX_S.CPU_SYSTEM_5.CGEM_SSI_5.dmc_tag_ram_read, C66XX_S.CPU_SYSTEM_5.CPU5dmc_tag_ram_read;
        CONNECT2004        C66XX_S.CPU_SYSTEM_5.CGEM_SSI_5.pmc_tag_ram_read, C66XX_S.CPU_SYSTEM_5.CPU5pmc_tag_ram_read;
        CONNECT2005        C66XX_S.CPU_SYSTEM_5.CGEM_SSI_5.umc_tag_ram_read, C66XX_S.CPU_SYSTEM_5.CPU5umc_tag_ram_read;
        CONNECT2006        C66XX_S.CPU_SYSTEM_6.CGEM_SSI_6.dmc_tag_ram_read, C66XX_S.CPU_SYSTEM_6.CPU6dmc_tag_ram_read;
        CONNECT2007        C66XX_S.CPU_SYSTEM_6.CGEM_SSI_6.pmc_tag_ram_read, C66XX_S.CPU_SYSTEM_6.CPU6pmc_tag_ram_read;
        CONNECT2008        C66XX_S.CPU_SYSTEM_6.CGEM_SSI_6.umc_tag_ram_read, C66XX_S.CPU_SYSTEM_6.CPU6umc_tag_ram_read;
        CONNECT2009        C66XX_S.CPU_SYSTEM_7.CGEM_SSI_7.dmc_tag_ram_read, C66XX_S.CPU_SYSTEM_7.CPU7dmc_tag_ram_read;
        CONNECT2010        C66XX_S.CPU_SYSTEM_7.CGEM_SSI_7.pmc_tag_ram_read, C66XX_S.CPU_SYSTEM_7.CPU7pmc_tag_ram_read;
        CONNECT2011        C66XX_S.CPU_SYSTEM_7.CGEM_SSI_7.umc_tag_ram_read, C66XX_S.CPU_SYSTEM_7.CPU7umc_tag_ram_read;
        // Memory Viewer Connections
        //! For CPU0
        CONNECT2012        C66XX_S.CPU_SYSTEM_0.CPU0l1d_cache_dbg_read_in, C66XX_S.CPU_SYSTEM_0.CGEM_SSI_0.L1D_cache_dbg_read;
        CONNECT2013        C66XX_S.CPU_SYSTEM_0.CPU0l1d_cache_dbg_write_out, C66XX_S.CPU_SYSTEM_0.CGEM_SSI_0.L1D_cache_dbg_write;
        CONNECT2014        C66XX_S.CPU_SYSTEM_0.CPU0l1d_sram_dbg_read_in, C66XX_S.CPU_SYSTEM_0.CGEM_SSI_0.L1D_sram_dbg_read;
        CONNECT2015        C66XX_S.CPU_SYSTEM_0.CPU0l1d_sram_dbg_write_out, C66XX_S.CPU_SYSTEM_0.CGEM_SSI_0.L1D_sram_dbg_write;
        CONNECT2016        C66XX_S.CPU_SYSTEM_0.CPU0l1p_cache_dbg_read_in, C66XX_S.CPU_SYSTEM_0.CGEM_SSI_0.L1P_cache_dbg_read;
        CONNECT2017        C66XX_S.CPU_SYSTEM_0.CPU0l1p_cache_dbg_write_out, C66XX_S.CPU_SYSTEM_0.CGEM_SSI_0.L1P_cache_dbg_write;
        CONNECT2018        C66XX_S.CPU_SYSTEM_0.CPU0l1p_sram_dbg_read_in, C66XX_S.CPU_SYSTEM_0.CGEM_SSI_0.L1P_sram_dbg_read;
        CONNECT2019        C66XX_S.CPU_SYSTEM_0.CPU0l1p_sram_dbg_write_out, C66XX_S.CPU_SYSTEM_0.CGEM_SSI_0.L1P_sram_dbg_write;
        CONNECT2020        C66XX_S.CPU_SYSTEM_0.CPU0l2_cache_dbg_read_in, C66XX_S.CPU_SYSTEM_0.CGEM_SSI_0.L2_cache_dbg_read;
        CONNECT2021        C66XX_S.CPU_SYSTEM_0.CPU0l2_cache_dbg_write_out, C66XX_S.CPU_SYSTEM_0.CGEM_SSI_0.L2_cache_dbg_write;
        CONNECT2022        C66XX_S.CPU_SYSTEM_0.CPU0l2_sram_dbg_read_in, C66XX_S.CPU_SYSTEM_0.CGEM_SSI_0.L2_sram_dbg_read;
        CONNECT2023        C66XX_S.CPU_SYSTEM_0.CPU0l2_sram_dbg_write_out, C66XX_S.CPU_SYSTEM_0.CGEM_SSI_0.L2_sram_dbg_write;
        CONNECT2024        C66XX_S.CPU_SYSTEM_0.CPU0ext_mem_dbg_read_in, C66XX_S.CPU_SYSTEM_0.CGEM_SSI_0.EXTMEM_ext_dbg_read;
        CONNECT2025        C66XX_S.CPU_SYSTEM_0.CPU0ext_mem_dbg_write_out, C66XX_S.CPU_SYSTEM_0.CGEM_SSI_0.EXTMEM_ext_dbg_write;
        //! For CPU1
        CONNECT2026        C66XX_S.CPU_SYSTEM_1.CPU1l1d_cache_dbg_read_in, C66XX_S.CPU_SYSTEM_1.CGEM_SSI_1.L1D_cache_dbg_read;
        CONNECT2027        C66XX_S.CPU_SYSTEM_1.CPU1l1d_cache_dbg_write_out, C66XX_S.CPU_SYSTEM_1.CGEM_SSI_1.L1D_cache_dbg_write;
        CONNECT2028        C66XX_S.CPU_SYSTEM_1.CPU1l1d_sram_dbg_read_in, C66XX_S.CPU_SYSTEM_1.CGEM_SSI_1.L1D_sram_dbg_read;
        CONNECT2029        C66XX_S.CPU_SYSTEM_1.CPU1l1d_sram_dbg_write_out, C66XX_S.CPU_SYSTEM_1.CGEM_SSI_1.L1D_sram_dbg_write;
        CONNECT2030        C66XX_S.CPU_SYSTEM_1.CPU1l1p_cache_dbg_read_in, C66XX_S.CPU_SYSTEM_1.CGEM_SSI_1.L1P_cache_dbg_read;
        CONNECT2031        C66XX_S.CPU_SYSTEM_1.CPU1l1p_cache_dbg_write_out, C66XX_S.CPU_SYSTEM_1.CGEM_SSI_1.L1P_cache_dbg_write;
        CONNECT2032        C66XX_S.CPU_SYSTEM_1.CPU1l1p_sram_dbg_read_in, C66XX_S.CPU_SYSTEM_1.CGEM_SSI_1.L1P_sram_dbg_read;
        CONNECT2033        C66XX_S.CPU_SYSTEM_1.CPU1l1p_sram_dbg_write_out, C66XX_S.CPU_SYSTEM_1.CGEM_SSI_1.L1P_sram_dbg_write;
        CONNECT2034        C66XX_S.CPU_SYSTEM_1.CPU1l2_cache_dbg_read_in, C66XX_S.CPU_SYSTEM_1.CGEM_SSI_1.L2_cache_dbg_read;
        CONNECT2035        C66XX_S.CPU_SYSTEM_1.CPU1l2_cache_dbg_write_out, C66XX_S.CPU_SYSTEM_1.CGEM_SSI_1.L2_cache_dbg_write;
        CONNECT2036        C66XX_S.CPU_SYSTEM_1.CPU1l2_sram_dbg_read_in, C66XX_S.CPU_SYSTEM_1.CGEM_SSI_1.L2_sram_dbg_read;
        CONNECT2037        C66XX_S.CPU_SYSTEM_1.CPU1l2_sram_dbg_write_out, C66XX_S.CPU_SYSTEM_1.CGEM_SSI_1.L2_sram_dbg_write;
        CONNECT2038        C66XX_S.CPU_SYSTEM_1.CPU1ext_mem_dbg_read_in, C66XX_S.CPU_SYSTEM_1.CGEM_SSI_1.EXTMEM_ext_dbg_read;
        CONNECT2039        C66XX_S.CPU_SYSTEM_1.CPU1ext_mem_dbg_write_out, C66XX_S.CPU_SYSTEM_1.CGEM_SSI_1.EXTMEM_ext_dbg_write;
        //! For CPU2
        CONNECT2040        C66XX_S.CPU_SYSTEM_2.CPU2l1d_cache_dbg_read_in, C66XX_S.CPU_SYSTEM_2.CGEM_SSI_2.L1D_cache_dbg_read;
        CONNECT2041        C66XX_S.CPU_SYSTEM_2.CPU2l1d_cache_dbg_write_out, C66XX_S.CPU_SYSTEM_2.CGEM_SSI_2.L1D_cache_dbg_write;
        CONNECT2042        C66XX_S.CPU_SYSTEM_2.CPU2l1d_sram_dbg_read_in, C66XX_S.CPU_SYSTEM_2.CGEM_SSI_2.L1D_sram_dbg_read;
        CONNECT2043        C66XX_S.CPU_SYSTEM_2.CPU2l1d_sram_dbg_write_out, C66XX_S.CPU_SYSTEM_2.CGEM_SSI_2.L1D_sram_dbg_write;
        CONNECT2044        C66XX_S.CPU_SYSTEM_2.CPU2l1p_cache_dbg_read_in, C66XX_S.CPU_SYSTEM_2.CGEM_SSI_2.L1P_cache_dbg_read;
        CONNECT2045        C66XX_S.CPU_SYSTEM_2.CPU2l1p_cache_dbg_write_out, C66XX_S.CPU_SYSTEM_2.CGEM_SSI_2.L1P_cache_dbg_write;
        CONNECT2046        C66XX_S.CPU_SYSTEM_2.CPU2l1p_sram_dbg_read_in, C66XX_S.CPU_SYSTEM_2.CGEM_SSI_2.L1P_sram_dbg_read;
        CONNECT2047        C66XX_S.CPU_SYSTEM_2.CPU2l1p_sram_dbg_write_out, C66XX_S.CPU_SYSTEM_2.CGEM_SSI_2.L1P_sram_dbg_write;
        CONNECT2048        C66XX_S.CPU_SYSTEM_2.CPU2l2_cache_dbg_read_in, C66XX_S.CPU_SYSTEM_2.CGEM_SSI_2.L2_cache_dbg_read;
        CONNECT2049        C66XX_S.CPU_SYSTEM_2.CPU2l2_cache_dbg_write_out, C66XX_S.CPU_SYSTEM_2.CGEM_SSI_2.L2_cache_dbg_write;
        CONNECT2050        C66XX_S.CPU_SYSTEM_2.CPU2l2_sram_dbg_read_in, C66XX_S.CPU_SYSTEM_2.CGEM_SSI_2.L2_sram_dbg_read;
        CONNECT2051        C66XX_S.CPU_SYSTEM_2.CPU2l2_sram_dbg_write_out, C66XX_S.CPU_SYSTEM_2.CGEM_SSI_2.L2_sram_dbg_write;
        CONNECT2052        C66XX_S.CPU_SYSTEM_2.CPU2ext_mem_dbg_read_in, C66XX_S.CPU_SYSTEM_2.CGEM_SSI_2.EXTMEM_ext_dbg_read;
        CONNECT2053        C66XX_S.CPU_SYSTEM_2.CPU2ext_mem_dbg_write_out, C66XX_S.CPU_SYSTEM_2.CGEM_SSI_2.EXTMEM_ext_dbg_write;
        //! For CPU3
        CONNECT2054        C66XX_S.CPU_SYSTEM_3.CPU3l1d_cache_dbg_read_in, C66XX_S.CPU_SYSTEM_3.CGEM_SSI_3.L1D_cache_dbg_read;
        CONNECT2055        C66XX_S.CPU_SYSTEM_3.CPU3l1d_cache_dbg_write_out, C66XX_S.CPU_SYSTEM_3.CGEM_SSI_3.L1D_cache_dbg_write;
        CONNECT2056        C66XX_S.CPU_SYSTEM_3.CPU3l1d_sram_dbg_read_in, C66XX_S.CPU_SYSTEM_3.CGEM_SSI_3.L1D_sram_dbg_read;
        CONNECT2057        C66XX_S.CPU_SYSTEM_3.CPU3l1d_sram_dbg_write_out, C66XX_S.CPU_SYSTEM_3.CGEM_SSI_3.L1D_sram_dbg_write;
        CONNECT2058        C66XX_S.CPU_SYSTEM_3.CPU3l1p_cache_dbg_read_in, C66XX_S.CPU_SYSTEM_3.CGEM_SSI_3.L1P_cache_dbg_read;
        CONNECT2059        C66XX_S.CPU_SYSTEM_3.CPU3l1p_cache_dbg_write_out, C66XX_S.CPU_SYSTEM_3.CGEM_SSI_3.L1P_cache_dbg_write;
        CONNECT2060        C66XX_S.CPU_SYSTEM_3.CPU3l1p_sram_dbg_read_in, C66XX_S.CPU_SYSTEM_3.CGEM_SSI_3.L1P_sram_dbg_read;
        CONNECT2061        C66XX_S.CPU_SYSTEM_3.CPU3l1p_sram_dbg_write_out, C66XX_S.CPU_SYSTEM_3.CGEM_SSI_3.L1P_sram_dbg_write;
        CONNECT2062        C66XX_S.CPU_SYSTEM_3.CPU3l2_cache_dbg_read_in, C66XX_S.CPU_SYSTEM_3.CGEM_SSI_3.L2_cache_dbg_read;
        CONNECT2063        C66XX_S.CPU_SYSTEM_3.CPU3l2_cache_dbg_write_out, C66XX_S.CPU_SYSTEM_3.CGEM_SSI_3.L2_cache_dbg_write;
        CONNECT2064        C66XX_S.CPU_SYSTEM_3.CPU3l2_sram_dbg_read_in, C66XX_S.CPU_SYSTEM_3.CGEM_SSI_3.L2_sram_dbg_read;
        CONNECT2065        C66XX_S.CPU_SYSTEM_3.CPU3l2_sram_dbg_write_out, C66XX_S.CPU_SYSTEM_3.CGEM_SSI_3.L2_sram_dbg_write;
        CONNECT2066        C66XX_S.CPU_SYSTEM_3.CPU3ext_mem_dbg_read_in, C66XX_S.CPU_SYSTEM_3.CGEM_SSI_3.EXTMEM_ext_dbg_read;
        CONNECT2067        C66XX_S.CPU_SYSTEM_3.CPU3ext_mem_dbg_write_out, C66XX_S.CPU_SYSTEM_3.CGEM_SSI_3.EXTMEM_ext_dbg_write;
        //! For CPU4
        CONNECT2068        C66XX_S.CPU_SYSTEM_4.CPU4l1d_cache_dbg_read_in, C66XX_S.CPU_SYSTEM_4.CGEM_SSI_4.L1D_cache_dbg_read;
        CONNECT2069        C66XX_S.CPU_SYSTEM_4.CPU4l1d_cache_dbg_write_out, C66XX_S.CPU_SYSTEM_4.CGEM_SSI_4.L1D_cache_dbg_write;
        CONNECT2070        C66XX_S.CPU_SYSTEM_4.CPU4l1d_sram_dbg_read_in, C66XX_S.CPU_SYSTEM_4.CGEM_SSI_4.L1D_sram_dbg_read;
        CONNECT2071        C66XX_S.CPU_SYSTEM_4.CPU4l1d_sram_dbg_write_out, C66XX_S.CPU_SYSTEM_4.CGEM_SSI_4.L1D_sram_dbg_write;
        CONNECT2072        C66XX_S.CPU_SYSTEM_4.CPU4l1p_cache_dbg_read_in, C66XX_S.CPU_SYSTEM_4.CGEM_SSI_4.L1P_cache_dbg_read;
        CONNECT2073        C66XX_S.CPU_SYSTEM_4.CPU4l1p_cache_dbg_write_out, C66XX_S.CPU_SYSTEM_4.CGEM_SSI_4.L1P_cache_dbg_write;
        CONNECT2074        C66XX_S.CPU_SYSTEM_4.CPU4l1p_sram_dbg_read_in, C66XX_S.CPU_SYSTEM_4.CGEM_SSI_4.L1P_sram_dbg_read;
        CONNECT2075        C66XX_S.CPU_SYSTEM_4.CPU4l1p_sram_dbg_write_out, C66XX_S.CPU_SYSTEM_4.CGEM_SSI_4.L1P_sram_dbg_write;
        CONNECT2076        C66XX_S.CPU_SYSTEM_4.CPU4l2_cache_dbg_read_in, C66XX_S.CPU_SYSTEM_4.CGEM_SSI_4.L2_cache_dbg_read;
        CONNECT2077        C66XX_S.CPU_SYSTEM_4.CPU4l2_cache_dbg_write_out, C66XX_S.CPU_SYSTEM_4.CGEM_SSI_4.L2_cache_dbg_write;
        CONNECT2078        C66XX_S.CPU_SYSTEM_4.CPU4l2_sram_dbg_read_in, C66XX_S.CPU_SYSTEM_4.CGEM_SSI_4.L2_sram_dbg_read;
        CONNECT2079        C66XX_S.CPU_SYSTEM_4.CPU4l2_sram_dbg_write_out, C66XX_S.CPU_SYSTEM_4.CGEM_SSI_4.L2_sram_dbg_write;
        CONNECT2080        C66XX_S.CPU_SYSTEM_4.CPU4ext_mem_dbg_read_in, C66XX_S.CPU_SYSTEM_4.CGEM_SSI_4.EXTMEM_ext_dbg_read;
        CONNECT2081        C66XX_S.CPU_SYSTEM_4.CPU4ext_mem_dbg_write_out, C66XX_S.CPU_SYSTEM_4.CGEM_SSI_4.EXTMEM_ext_dbg_write;
        //! For CPU5
        CONNECT2082        C66XX_S.CPU_SYSTEM_5.CPU5l1d_cache_dbg_read_in, C66XX_S.CPU_SYSTEM_5.CGEM_SSI_5.L1D_cache_dbg_read;
        CONNECT2083        C66XX_S.CPU_SYSTEM_5.CPU5l1d_cache_dbg_write_out, C66XX_S.CPU_SYSTEM_5.CGEM_SSI_5.L1D_cache_dbg_write;
        CONNECT2084        C66XX_S.CPU_SYSTEM_5.CPU5l1d_sram_dbg_read_in, C66XX_S.CPU_SYSTEM_5.CGEM_SSI_5.L1D_sram_dbg_read;
        CONNECT2085        C66XX_S.CPU_SYSTEM_5.CPU5l1d_sram_dbg_write_out, C66XX_S.CPU_SYSTEM_5.CGEM_SSI_5.L1D_sram_dbg_write;
        CONNECT2086        C66XX_S.CPU_SYSTEM_5.CPU5l1p_cache_dbg_read_in, C66XX_S.CPU_SYSTEM_5.CGEM_SSI_5.L1P_cache_dbg_read;
        CONNECT2087        C66XX_S.CPU_SYSTEM_5.CPU5l1p_cache_dbg_write_out, C66XX_S.CPU_SYSTEM_5.CGEM_SSI_5.L1P_cache_dbg_write;
        CONNECT2088        C66XX_S.CPU_SYSTEM_5.CPU5l1p_sram_dbg_read_in, C66XX_S.CPU_SYSTEM_5.CGEM_SSI_5.L1P_sram_dbg_read;
        CONNECT2089        C66XX_S.CPU_SYSTEM_5.CPU5l1p_sram_dbg_write_out, C66XX_S.CPU_SYSTEM_5.CGEM_SSI_5.L1P_sram_dbg_write;
        CONNECT2090        C66XX_S.CPU_SYSTEM_5.CPU5l2_cache_dbg_read_in, C66XX_S.CPU_SYSTEM_5.CGEM_SSI_5.L2_cache_dbg_read;
        CONNECT2091        C66XX_S.CPU_SYSTEM_5.CPU5l2_cache_dbg_write_out, C66XX_S.CPU_SYSTEM_5.CGEM_SSI_5.L2_cache_dbg_write;
        CONNECT2092        C66XX_S.CPU_SYSTEM_5.CPU5l2_sram_dbg_read_in, C66XX_S.CPU_SYSTEM_5.CGEM_SSI_5.L2_sram_dbg_read;
        CONNECT2093        C66XX_S.CPU_SYSTEM_5.CPU5l2_sram_dbg_write_out, C66XX_S.CPU_SYSTEM_5.CGEM_SSI_5.L2_sram_dbg_write;
        CONNECT2094        C66XX_S.CPU_SYSTEM_5.CPU5ext_mem_dbg_read_in, C66XX_S.CPU_SYSTEM_5.CGEM_SSI_5.EXTMEM_ext_dbg_read;
        CONNECT2095        C66XX_S.CPU_SYSTEM_5.CPU5ext_mem_dbg_write_out, C66XX_S.CPU_SYSTEM_5.CGEM_SSI_5.EXTMEM_ext_dbg_write;
        //! For CPU6
        CONNECT2096        C66XX_S.CPU_SYSTEM_6.CPU6l1d_cache_dbg_read_in, C66XX_S.CPU_SYSTEM_6.CGEM_SSI_6.L1D_cache_dbg_read;
        CONNECT2097        C66XX_S.CPU_SYSTEM_6.CPU6l1d_cache_dbg_write_out, C66XX_S.CPU_SYSTEM_6.CGEM_SSI_6.L1D_cache_dbg_write;
        CONNECT2098        C66XX_S.CPU_SYSTEM_6.CPU6l1d_sram_dbg_read_in, C66XX_S.CPU_SYSTEM_6.CGEM_SSI_6.L1D_sram_dbg_read;
        CONNECT2099        C66XX_S.CPU_SYSTEM_6.CPU6l1d_sram_dbg_write_out, C66XX_S.CPU_SYSTEM_6.CGEM_SSI_6.L1D_sram_dbg_write;
        CONNECT2100        C66XX_S.CPU_SYSTEM_6.CPU6l1p_cache_dbg_read_in, C66XX_S.CPU_SYSTEM_6.CGEM_SSI_6.L1P_cache_dbg_read;
        CONNECT2101        C66XX_S.CPU_SYSTEM_6.CPU6l1p_cache_dbg_write_out, C66XX_S.CPU_SYSTEM_6.CGEM_SSI_6.L1P_cache_dbg_write;
        CONNECT2102        C66XX_S.CPU_SYSTEM_6.CPU6l1p_sram_dbg_read_in, C66XX_S.CPU_SYSTEM_6.CGEM_SSI_6.L1P_sram_dbg_read;
        CONNECT2103        C66XX_S.CPU_SYSTEM_6.CPU6l1p_sram_dbg_write_out, C66XX_S.CPU_SYSTEM_6.CGEM_SSI_6.L1P_sram_dbg_write;
        CONNECT2104        C66XX_S.CPU_SYSTEM_6.CPU6l2_cache_dbg_read_in, C66XX_S.CPU_SYSTEM_6.CGEM_SSI_6.L2_cache_dbg_read;
        CONNECT2105        C66XX_S.CPU_SYSTEM_6.CPU6l2_cache_dbg_write_out, C66XX_S.CPU_SYSTEM_6.CGEM_SSI_6.L2_cache_dbg_write;
        CONNECT2106        C66XX_S.CPU_SYSTEM_6.CPU6l2_sram_dbg_read_in, C66XX_S.CPU_SYSTEM_6.CGEM_SSI_6.L2_sram_dbg_read;
        CONNECT2107        C66XX_S.CPU_SYSTEM_6.CPU6l2_sram_dbg_write_out, C66XX_S.CPU_SYSTEM_6.CGEM_SSI_6.L2_sram_dbg_write;
        CONNECT2108        C66XX_S.CPU_SYSTEM_6.CPU6ext_mem_dbg_read_in, C66XX_S.CPU_SYSTEM_6.CGEM_SSI_6.EXTMEM_ext_dbg_read;
        CONNECT2109        C66XX_S.CPU_SYSTEM_6.CPU6ext_mem_dbg_write_out, C66XX_S.CPU_SYSTEM_6.CGEM_SSI_6.EXTMEM_ext_dbg_write;
        //! For CPU7
        CONNECT2110        C66XX_S.CPU_SYSTEM_7.CPU7l1d_cache_dbg_read_in, C66XX_S.CPU_SYSTEM_7.CGEM_SSI_7.L1D_cache_dbg_read;
        CONNECT2111        C66XX_S.CPU_SYSTEM_7.CPU7l1d_cache_dbg_write_out, C66XX_S.CPU_SYSTEM_7.CGEM_SSI_7.L1D_cache_dbg_write;
        CONNECT2112        C66XX_S.CPU_SYSTEM_7.CPU7l1d_sram_dbg_read_in, C66XX_S.CPU_SYSTEM_7.CGEM_SSI_7.L1D_sram_dbg_read;
        CONNECT2113        C66XX_S.CPU_SYSTEM_7.CPU7l1d_sram_dbg_write_out, C66XX_S.CPU_SYSTEM_7.CGEM_SSI_7.L1D_sram_dbg_write;
        CONNECT2114        C66XX_S.CPU_SYSTEM_7.CPU7l1p_cache_dbg_read_in, C66XX_S.CPU_SYSTEM_7.CGEM_SSI_7.L1P_cache_dbg_read;
        CONNECT2115        C66XX_S.CPU_SYSTEM_7.CPU7l1p_cache_dbg_write_out, C66XX_S.CPU_SYSTEM_7.CGEM_SSI_7.L1P_cache_dbg_write;
        CONNECT2116        C66XX_S.CPU_SYSTEM_7.CPU7l1p_sram_dbg_read_in, C66XX_S.CPU_SYSTEM_7.CGEM_SSI_7.L1P_sram_dbg_read;
        CONNECT2117        C66XX_S.CPU_SYSTEM_7.CPU7l1p_sram_dbg_write_out, C66XX_S.CPU_SYSTEM_7.CGEM_SSI_7.L1P_sram_dbg_write;
        CONNECT2118        C66XX_S.CPU_SYSTEM_7.CPU7l2_cache_dbg_read_in, C66XX_S.CPU_SYSTEM_7.CGEM_SSI_7.L2_cache_dbg_read;
        CONNECT2119        C66XX_S.CPU_SYSTEM_7.CPU7l2_cache_dbg_write_out, C66XX_S.CPU_SYSTEM_7.CGEM_SSI_7.L2_cache_dbg_write;
        CONNECT2120        C66XX_S.CPU_SYSTEM_7.CPU7l2_sram_dbg_read_in, C66XX_S.CPU_SYSTEM_7.CGEM_SSI_7.L2_sram_dbg_read;
        CONNECT2121        C66XX_S.CPU_SYSTEM_7.CPU7l2_sram_dbg_write_out, C66XX_S.CPU_SYSTEM_7.CGEM_SSI_7.L2_sram_dbg_write;
        CONNECT2122        C66XX_S.CPU_SYSTEM_7.CPU7ext_mem_dbg_read_in, C66XX_S.CPU_SYSTEM_7.CGEM_SSI_7.EXTMEM_ext_dbg_read;
        CONNECT2123        C66XX_S.CPU_SYSTEM_7.CPU7ext_mem_dbg_write_out, C66XX_S.CPU_SYSTEM_7.CGEM_SSI_7.EXTMEM_ext_dbg_write;
        //New - added for new QMSS interface and CDMA model changes
        CONNECT2124        C66XX_S.SHARED_SYSTEM.MEMTR_QM_DMA_Config.MT_MIF2SSI.memtr_read_opin, C66XX_S.SHARED_SYSTEM.QUEUE_MANAGER.qmss_dma_read_ipin;
        CONNECT2125        C66XX_S.SHARED_SYSTEM.MEMTR_QM_DMA_Config.MT_MIF2SSI.memtr_write_opin, C66XX_S.SHARED_SYSTEM.QUEUE_MANAGER.qmss_dma_write_ipin;
        CONNECT2126        C66XX_S.SHARED_SYSTEM.MSMC.msmc_mem_map, C66XX_S.SHARED_SYSTEM.MEMTR_QM_DMA_Config.MT_MIF2SSI.memtr_mif_opin, 0x34000000, 0x34063000, -0x34000000;
        CONNECT2127        C66XX_S.SHARED_SYSTEM.EDMA_0_mem_map, C66XX_S.SHARED_SYSTEM.MEMTR_QM_DMA_Config.MT_MIF2SSI.memtr_mif_opin, 0x34000000, 0x34063000, -0x34000000;
        CONNECT2128        C66XX_S.SHARED_SYSTEM.EDMA_1_mem_map, C66XX_S.SHARED_SYSTEM.MEMTR_QM_DMA_Config.MT_MIF2SSI.memtr_mif_opin, 0x34000000, 0x34063000, -0x34000000;
        CONNECT2129        C66XX_S.SHARED_SYSTEM.EDMA_2_mem_map, C66XX_S.SHARED_SYSTEM.MEMTR_QM_DMA_Config.MT_MIF2SSI.memtr_mif_opin, 0x34000000, 0x34063000, -0x34000000;
        CONNECT2130        C66XX_S.SHARED_SYSTEM.MEMTR_QM_DMA_Config.MT_MIF2SSI.memtr_reset_ipin, System.SimBridge.global_reset_list;
        CONNECT2131        C66XX_S.SHARED_SYSTEM.MEMTR_QM_DMA_Config.MT_MIF2SSI.is_little_endian_ipin, C66XX_S.CPU_SYSTEM_0.CPU0_endianness;
        CONNECT2132        C66XX_S.SHARED_SYSTEM.MEMTR_QM_DMA_Config.MT_MIF2SSI.memtr_dbg_read_opin, C66XX_S.SHARED_SYSTEM.QUEUE_MANAGER.qmss_dma_dbg_read_ipin;
        CONNECT2133        C66XX_S.SHARED_SYSTEM.MEMTR_QM_DMA_Config.MT_MIF2SSI.memtr_dbg_write_opin, C66XX_S.SHARED_SYSTEM.QUEUE_MANAGER.qmss_dma_dbg_write_ipin;
        CONNECT2134        C66XX_S.SHARED_SYSTEM.MSMC.msmc_mem_map, C66XX_S.SHARED_SYSTEM.MEMTR_QM_Config.MT_MIF2SSI.memtr_mif_opin, 0x02AB0000, 0x02AB1FFF, -0x02A00000;
    END System;
    // --- PDATS enablement -------------------//
    SECTION PDATS_TRACE_ON_CORE0;
            MODULE PDATS_TRACE;
                 ACCESS_SIZE_TRACE ON;  // For Access width tracing
                 TIMESTAMP_WITH_MEMSTALLS OFF;  // OFF -> The tracing would be w.r.t CPU cycles (no stalls)
             MULTI_CORE ON;
            END PDATS_TRACE;
        CONNECT1        System.C66XX_S.CPU_SYSTEM_0.CPU0_mem_map, System.C66XX_S.CPU_SYSTEM_0.CPU0.cpu_pdats_mif, 0x0, 0xFFFFFFFF, 0;
    END PDATS_TRACE_ON_CORE0;
    SECTION PDATS_TRACE_ON_CORE1;
            MODULE PDATS_TRACE;
             MULTI_CORE ON;
            END PDATS_TRACE;
        CONNECT1        System.C66XX_S.CPU_SYSTEM_1.CPU1_mem_map, System.C66XX_S.CPU_SYSTEM_1.CPU1.cpu_pdats_mif, 0x0, 0xFFFFFFFF, 0;
    END PDATS_TRACE_ON_CORE1;
    SECTION PDATS_TRACE_ON_CORE2;
            MODULE PDATS_TRACE;
             MULTI_CORE ON;
            END PDATS_TRACE;
        CONNECT1        System.C66XX_S.CPU_SYSTEM_2.CPU2_mem_map, System.C66XX_S.CPU_SYSTEM_2.CPU2.cpu_pdats_mif, 0x0, 0xFFFFFFFF, 0;
    END PDATS_TRACE_ON_CORE2;
    SECTION PDATS_TRACE_ON_CORE3;
            MODULE PDATS_TRACE;
             MULTI_CORE ON;
            END PDATS_TRACE;
        CONNECT1        System.C66XX_S.CPU_SYSTEM_3.CPU3_mem_map, System.C66XX_S.CPU_SYSTEM_3.CPU3.cpu_pdats_mif, 0x0, 0xFFFFFFFF, 0;
    END PDATS_TRACE_ON_CORE3;
    SECTION PDATS_TRACE_ON_CORE4;
            MODULE PDATS_TRACE;
             MULTI_CORE ON;
            END PDATS_TRACE;
        CONNECT1        System.C66XX_S.CPU_SYSTEM_4.CPU4_mem_map, System.C66XX_S.CPU_SYSTEM_4.CPU4.cpu_pdats_mif, 0x0, 0xFFFFFFFF, 0;
    END PDATS_TRACE_ON_CORE4;
    SECTION PDATS_TRACE_ON_CORE5;
            MODULE PDATS_TRACE;
             MULTI_CORE ON;
            END PDATS_TRACE;
        CONNECT1        System.C66XX_S.CPU_SYSTEM_5.CPU5_mem_map, System.C66XX_S.CPU_SYSTEM_5.CPU5.cpu_pdats_mif, 0x0, 0xFFFFFFFF, 0;
    END PDATS_TRACE_ON_CORE5;
    SECTION PDATS_TRACE_ON_CORE6;
            MODULE PDATS_TRACE;
             MULTI_CORE ON;
            END PDATS_TRACE;
        CONNECT1        System.C66XX_S.CPU_SYSTEM_6.CPU6_mem_map, System.C66XX_S.CPU_SYSTEM_6.CPU6.cpu_pdats_mif, 0x0, 0xFFFFFFFF, 0;
    END PDATS_TRACE_ON_CORE6;
    SECTION PDATS_TRACE_ON_CORE7;
            MODULE PDATS_TRACE;
             MULTI_CORE ON;
            END PDATS_TRACE;
        CONNECT1        System.C66XX_S.CPU_SYSTEM_7.CPU7_mem_map, System.C66XX_S.CPU_SYSTEM_7.CPU7.cpu_pdats_mif, 0x0, 0xFFFFFFFF, 0;
    END PDATS_TRACE_ON_CORE7;
    // -------------------- END PDATS enablement -------------------//
    //  As per following specs-
    //  chip_level_nysh.pdf                                 VERSION 0.1.0
    //  interrupts_nysh.pdf                                 VERSION 0.1.1
    //  ip_integration_nysh.pdf                             VERSION 0.1.0
    //  chip_config_nysh.pdf                                VERSION 0.1.0
    //  QM Queue assignment                             VERSION
  • Hi Weihua,
    did you solve your problem? I guess I have the same on
    - C6670 Device Functional Simulator, Little Endian
    - Linux Machine (Ubuntu 12.04.1 LTS (GNU/Linux 3.2.0-31-generic x86_64) )
    I always get this warning :
    TMS320C66x_0: Warning: Write operation not permitted since EDMA is disabled Read operation not permitted since EDMA is disabled ...
    Anyone else with a solution?
    Best Regards
    Simon
  • Simon,
    We will look into this issue. Somehow we are unable to reproduce this issue on existing edma testcases in our regression suite. I verified one of the edma cases now on windows  also and it works. Is it possible for you send some .out that can reproduce this issue?
    regards,
    Sheshadri
  • Simon,
    We loaded the .out you had shared on C6670 Device Functional Simulator, Little Endian on C66x_0 and found that the testcase completes without any EDMA messages. This is on CCS5.3 on ubuntu10 linux.  It halts at abort label.
    Below is the message we got on console...
    [TMS320C66x_0] DSP Revision: Revision = 0x0000
    Debug message - /home/schuberts/projekte/sdrnyq/branches/sync_module__test_project_simulator/src/board/board.c:260 (set_local_mac_and_ip_address)
    Local MAC: 00:00:00:00:00:00
     This is C6670 simulator
     This is Board 0
     This is DSP number 0
     This is core number 0
     The IP address of this DSP is: 0.0.0.0
     The MAC address of this DSP is: 00:00:00:00:00:00
    AIF2: Module Power Domain [ON]
     EVM initialization done.
     regards,
    Sheshadri
  • please press "pause" to get the message
    maybe it's useful to set an software breakpoint right before starting the edma process...i will investigate this.
    regards,
    simon
  • Sheshadri,
    I investigated a bit and found, that the function  EDMA3_DRV_create () leads to this warning ("Write operation not permitted since EDMA is disabled ...").
    I use the file 'sample_init.c' , coming with the EDMA example. There the above function is called three times. the resulting "edma3Result" is never EDMA3_DRV_SOK.
    I will send you an .out with a breakpoint right before calling the function, so you can step and see the warning.
    Many thanks for your help,
    Simon
  • Hi Simon,
    Sorry I could not respond earlier. Even with the new .out you shared, I am unable to reproduce. Can you share the folder simulation_keystone1 inside <ccs installation>/.../ccs_base. You can zip this folder and share it with me. Will get back to you to see is I can reproduce with this,.
    regards,
    Sheshadri
