I am using ccs5.2. The CCS does not detect the re-installed RTSC component autonomously. By the way, the installation directory is changed as well. Is there any way to trigger CCS to search again or ad it manually.
Eric
Eric
Hi Eric,
What OS are you running?
If Windows, this might be due to the change in install directory. What do you see under Window->Preferences->Code Composer Studio->RTSC->Products? This is also where you can try pointing CCS to the components.
If Linux, another thing that we have seen trigger similar behaviour is not using consistent permissions. Ie if you installed as sudo you should launch, and do further updates/installs etc as sudo with the same login.
Please keep us informed.
Lisa
Hi, Lisa:
Thank you very much for your quick response! My PC is Windows XP. It seems to work after I reinstall the RTSC component at c:/ti. It does not work if I install the RTSC component at the cccsv5 directory which is e:\ti3.
Eric
